5655 connectés
 Page :   1  2  3  4  5  ..  83  84  85  ..  149  150  151  152  153  154
[Topic unique] Nikon D7000
n°4521572
capsone
Pfiou !
Posté le 15-01-2012 à 22:42:48  profilanswer
prix HK : http://www.hk-digi.com/index.php?m [...] ts_id=1183
Ma galerie
n°4521629
Pl4y4z
Monte le son, j'ai froid...
Posté le 15-01-2012 à 23:21:05  profilanswer
Cadeau :
Maia Vidal :
283
http://farm8.staticflickr.com/7165/6702536343_2316200741.jpg
284
http://farm8.staticflickr.com/7156/6702534643_50b526d4fe.jpg
Imany
285
http://farm8.staticflickr.com/7164/6702599551_14c1b9ed75.jpg
286
http://farm8.staticflickr.com/7165/6702592401_4bec45eedc.jpg
287
http://farm8.staticflickr.com/7003/6702663375_0de851df5e.jpg
Flickr ● REX:Salles Concert ● D750
n°4521645
Posté le 15-01-2012 à 23:28:36  answer
n°4521655
Posté le 15-01-2012 à 23:48:32  answer
Retour de Flaine - J'ai du mal à descendre de mon nuage
1
http://farm8.staticflickr.com/7022/6701730351_4a9b3d5de9_z.jpg
_DSC3058 by McflyIer, on Flickr
2
http://farm8.staticflickr.com/7162/6701828755_284fe5f894_z.jpg
_DSC3196 by McflyIer, on Flickr
3
http://farm8.staticflickr.com/7020/6701918227_33b2fedd14_z.jpg
_DSC3224 by McflyIer, on Flickr
4
http://farm8.staticflickr.com/7155/6702024725_e881be5246_z.jpg
_DSC3248 by McflyIer, on Flickr
5
http://farm8.staticflickr.com/7016/6702278727_b647fa0831_z.jpg
_DSC3321 by McflyIer, on Flickr
6
http://farm8.staticflickr.com/7004/6702088045_d2dd121fdf_z.jpg
_DSC3261 by McflyIer, on Flickr
7
http://farm8.staticflickr.com/7153/6702401831_72ebbd925f_z.jpg
_DSC3363 by McflyIer, on Flickr
8
http://farm8.staticflickr.com/7021/6702112461_466404d9ff_z.jpg
_DSC3270 by McflyIer, on Flickr
9
http://farm8.staticflickr.com/7015/6702696575_bc8b484c03_z.jpg
pano-2 by McflyIer, on Flickr
10
http://farm8.staticflickr.com/7006/6702741507_5551239ccd_z.jpg
pano-1 by McflyIer, on Flickr
11
http://farm8.staticflickr.com/7153/6703141791_8b84ec99ec_z.jpg
pano-4 by McflyIer, on Flickr
12
http://farm8.staticflickr.com/7001/6702265021_2456822f4d_z.jpg
_DSC3315 by McflyIer, on Flickr
Message édité par Profil supprimé le 15-01-2012 à 23:51:06
n°4521664
bisso_
Posté le 16-01-2012 à 00:10:11  profilanswer
tyvain a écrit :
Je vais à Hong-Kong bientot, savez-vous si c'est intéressant de l'acheter là-bas plutot qu en france??
J'arrive pas à trouver des infos sur les prix là bas.
La plupart des magasins en ligne ne vendent pas en physique à HK, ou du moins pas du tout au même prix. Certains refusent même la livraison vers uen adresse postale située à HK :)
Pas sûr que ça soit vraiment super interessant du coup, mais tente quand meme, à minima tu economiseras la TVA (sauf si tu as une douane zelée)
Cela dit, ca equivaut à du marché gris, donc en cas de problème (calibrage d'AF au hasard...) SAV uniquement sur la région Asie/Pacifique, avec frais de port à ta charge
>> Flickr stream <<
n°4521670
Empedocle
Posté le 16-01-2012 à 00:18:55  profilanswer
Toujours de grosses pénuries du D7000 ? Je suis actuellement à Bruxelles et il se fait très rare dans les linéaires :/
n°4521730
Pl4y4z
Posté le 16-01-2012 à 08:26:19  profilanswer
Merci :)
Un plus pour tes photos n° 10 et 12 :jap:
n°4521818
vini59
Vini
Posté le 16-01-2012 à 10:20:54  profilanswer
concernant les photos de concert, elles sont toujours nickel :)
en regle general, quel est le mode utilisé ? reglage (pour avoir une idée)
n°4521882
Pl4y4z
Posté le 16-01-2012 à 12:13:24  profilanswer
Merci :)
Réglages assez simples :
Je suis en Manuel :
Réglages molette avant pour les ISO, molette arrière pour la vitesse.
Toutes corrections retirées et roule jeunesse.
En concert, la difficulté est que l'ambiance change sans arrêt, donc on passe notre temps, l'oeil posé sur le boitier, à changer les réglages d'ouverture et des ISO grace au petit affichage à l’intérieur. (Upppper pratique)
Et donc, pour les photos plus haut, si je me souvient bien, les réglages étaient compris entre 1/80 et 1/350 et 1000 à 2500 ISO, ouverture constante à 2,8.
Marque de l'appareil : NIKON CORPORATION
Modèle de l'appareil : NIKON D7000
Date et heure de la photo : 2012-01-14 22:15:22 (pas de fuseau horaire)
Distance focale : 45.0mm (équivalence 35mm : 67mm)
Ouverture : f/2.8
Durée d'exposition : 0.010 s (1/100)
Équivalence ISO : 1000
Correction de l'exposition : aucune
Mode de mesure : Matricielle
Exposition : manuelle
Mode d'exposition : manuelle
Balance des blancs : automatique
Utilisation du flash : Non (forcée)
Coordonnées GPS : undefined, undefined
Photographe : Benoit Andreani
Droits d'auteur : Benoit Andreani
Logiciel : Capture NX 2.2.6 W
Message édité par Pl4y4z le 16-01-2012 à 12:15:09
n°4521890
vini59
Vini
Posté le 16-01-2012 à 12:21:00  profilanswer
ok, merci pour ton retour ... ben j'en suis pas encore arrivé à faire de belles photos comme ca avec mon D7000 :pt1cable:
[HS]
faut une autorisation pour photographier en concert ?
[/HS]
n°4521984
Pl4y4z
Posté le 16-01-2012 à 13:46:08  profilanswer
[HS]
[/HS]
Oui :)
Le fameux sésame s'appel un "pass photo" ou encore "une accréditation".
Beaucoup de relationnel et après ça passe lol
n°4521988
Le Taz
Posté le 16-01-2012 à 13:48:29  profilanswer
Sachant que pour les petits concerts, certains artistes peu connu sont demandeur et te propose un échange de bon procédé.
Il te laisse libre accès pour shooter en contrepartie d'une partie de tes photos pour illustration blog/site officiel etc....
http://www.photob.be/technique/la-photo-de-concert/
Message édité par Le Taz le 16-01-2012 à 13:49:00
n°4521994
Pl4y4z
Posté le 16-01-2012 à 13:50:30  profilanswer
J'ai effectivement commencé comme ça il y a plus de 2 ans.
Par contre, les photos ne sont pas à donner en version HD bien entendu... [:pl4y4z]
n°4522059
vini59
Vini
Posté le 16-01-2012 à 14:35:28  profilanswer
Merci pour les explications et le lien  :jap:
n°4522524
Alex_R
Posté le 16-01-2012 à 19:38:00  profilanswer
n°4523579
ganryu
Posté le 17-01-2012 à 09:32:07  profilanswer
+1 très jolies séries.
Sur la montagne j'aime particulièrement la 3 et la 6
http://photos.ansite.eu
n°4524314
Posté le 17-01-2012 à 17:17:27  answer
Merci beaucoup, la montagne me manque  :cry:
n°4524697
alhexx
Posté le 17-01-2012 à 23:21:43  profilanswer
Une petite d'Ecosse
http://farm8.staticflickr.com/7001/6714079659_c945f1313f_z.jpg
n°4524865
capsone
Pfiou !
Posté le 18-01-2012 à 09:31:04  profilanswer
c'est un poil sombre :/
Ma galerie
n°4525460
bisso_
Posté le 18-01-2012 à 15:52:55  profilanswer
Tiens, comme j'ai vu personne en parler ici...
http://www.flickr.com/photos/69296392@N07/6396359065/
http://i.imgur.com/cF2GDl.jpg
Ca annonce peut-etre quelque trucs sympas... :)
Message édité par bisso_ le 18-01-2012 à 15:53:42
>> Flickr stream <<
n°4525517
vini59
Vini
Posté le 18-01-2012 à 16:34:59  profilanswer
tu penses à quoi ?  :heink:
n°4525528
juan1to
Posté le 18-01-2012 à 16:43:29  profilanswer
passage en FF niveau logiciel, yay :o
n°4525593
etienn
Posté le 18-01-2012 à 17:08:42  profilanswer
utilisation du d7k comme une gameboy avec le pad et les jeux sur SD? :o
En fait, je ne vois pas trop quelle limitation logicielle faire sauter qui soit vraiment génante sur le d7k (ce qui était le cas par exemple avec la mesure de lumiere inoperante sur objo AIS sur un D90 par exemple alors qu'il y a tout le hard pourque cela marche)
Flickr Instagram SiteWeb
n°4525627
YodaNC
Posté le 18-01-2012 à 17:17:37  profilanswer
Le 1080p @ 30 fps comme sur le D5100 ?
Changement de l'ouverture quand le mode vidéo est enclenché ?
ISO 80 avec une meilleure dynamique comme sur le K5 ?
Accélérer l'écriture sur les cartes en permettant d'écrire l'image 1 sur la sd 1 et l'image 2 sur la sd 2 en même temps ?
Plus de réglages pour les timelapses ?
Enfin rien d'absolument vital.
[VDS] Pentax: Grip K10/K20, accessoires ...
n°4525631
Pl4y4z
Posté le 18-01-2012 à 17:20:40  profilanswer
Je pense qu'il y a un différence entre "options déblocables et qui marcheront" et "options déblocables mais qui ne peuvent fonctionner techniquement"
Tu es sûr que l'ensemble des changement que tu sites sont techniquements réalisable en vu du hard du D7K ?
n°4525639
YodaNC
Posté le 18-01-2012 à 17:26:13  profilanswer
Avec les sources du firmware je pense qu'un bonne partie est réalisable (mais j'ai pas étudié les docs internes sur tous les composants :o), en hack (même avec décompilation, modification et recompilation) à mon avis on va pas voir grand chose arriver :/
n°4525642
YodaNC
Posté le 18-01-2012 à 17:28:22  profilanswer
On pourrait aussi imaginer le focus peaking comme sur les NEX pour les objos manuels ou pendant la vidéo (mais je n'y crois pas trop).
[/spéculation]
Message édité par YodaNC le 18-01-2012 à 17:32:27
n°4526030
noyau
Posté le 18-01-2012 à 21:32:05  profilanswer
Pourquoi pas un firmware axé vidéo, comme le Green Lantern chez Canon ?
Ca pourrait être chouette ;)
Musique et dev web : www.nicolaskern.fr - Mon feed - Mes ventes info et photo
n°4526214
bisso_
Posté le 18-01-2012 à 23:44:51  profilanswer
Je pense qu'on n'aura rien dans l'immediat, mais la liste ci dessus est deja un bon debut...
Pouvoir assigner l'auto iso a un raccourci serait aussi une chose interessante...
Dans tous les cas c'est toujours interessant de voir ce genre d'initiative, au pire ca ne mene a rien et la vie continue, au mieux ca debloque des fonctionnalites comme ca a ete le cas par exemple avec le 1080p sur le gf1
>> Flickr stream <<
n°4526345
grotius
Posté le 19-01-2012 à 08:20:44  profilanswer
ou alors c est juste un fake
n°4526401
capsone
Pfiou !
Posté le 19-01-2012 à 09:34:55  profilanswer
je comprends pas bien ce que tu veux dire, puisque l'iso auto est déjà paramétrable en touche fn :heink:
Ma galerie
n°4526421
noyau
Posté le 19-01-2012 à 09:53:05  profilanswer
C'est un paramétrage qu'on fait à la main, de base ça n'y est pas, mais en effet j'ai paramétré moi aussi l'ISO auto/manuel sur la touche FN, en 2 clics on change cette valeur, c'est génial !
n°4526463
Le Taz
Posté le 19-01-2012 à 10:13:30  profilanswer
C'est déjà le cas; lors d'un shoot en RAW+JPEG tu peux choisir de mettre le RAW sur une carte et le JPEG sur l'autre.
Message édité par Le Taz le 19-01-2012 à 10:14:37
n°4526478
capsone
Pfiou !
Posté le 19-01-2012 à 10:29:22  profilanswer
par ex pour la rafale, il pourrait alterner 1 sur 2 avec les 2 cartes, mais ça foutrait le bordel pour après les regrouper :/
Ma galerie
n°4526505
Le Taz
Posté le 19-01-2012 à 10:48:49  profilanswer
Ah ok !
n°4526637
YodaNC
Posté le 19-01-2012 à 12:25:34  profilanswer
ouais mes les jpeg je sais pas ce que c'est [:joce]
bof, juste fusionner les dossiers des 2 cartes [:spamafote]
enfin il faudrait que ce soit une option, ça n'a pas forcément d'utilité pour tout le monde (ni tout le temps :o)
n°4526664
capsone
Pfiou !
Posté le 19-01-2012 à 12:53:56  profilanswer
certes, mais ça pourrait ne s'activer qu'à la sélection du mode rafale :o
Ma galerie
n°4526691
bisso_
Posté le 19-01-2012 à 13:33:59  profilanswer
au temps pour moi alors, il me semblait que non, je vais tester, merci du tuyau :)
(je persiste quand meme, pouvoir ajuster le seuil vitesse en racourci molette serait quand meme bien utile ^^)
>> Flickr stream <<
n°4526700
capsone
Pfiou !
Posté le 19-01-2012 à 13:44:30  profilanswer
j'ai paramétré l'iso auto sur le bouton de l'annulaire droit (bouton du bas à gauche quand on regarde le boitier de face) ;)
Ma galerie
n°4526724
malcbo
épicurien
Posté le 19-01-2012 à 13:59:50  profilanswer
Tu peux déjà le faire, tu te mets en iso auto et en M. De cette manière tu peux régler ta vitesse (et ton ouverture, comme en A) tout en ayant tes iso auto
n°4526771
capsone
Pfiou !
Posté le 19-01-2012 à 14:32:53  profilanswer
aussi :o
Ma galerie
[Topic Unique] Canon EF 8-15mm F4 L fisheye USM : zoom fisheye pro[Topic unique] Canon EF 70-300mm f/4-5.6 L IS USM : le télé des pros
[topic unique] Canon SX30 IS zoom 35x 24-840[Topic Unique] Mugs et autres gadgets à l'effigie de nos joujoux
[Topic unique] Vivitar 100-400mm f/4,5-6,7 ++nouvelle galerie++[ Topic unique ] - *Pentax K-r * - 12.4 MP- Firmware 1.12 -
[Topic Unique] Nikon 85 f1.4 AF-SProblème Exposition Nikon D40x
Plus de sujets relatifs à : [Topic unique] Nikon D7000
