5580 connectés
 Page :   1  2  3  4  5  ..  417  418  419  ..  2952  2953  2954  2955  2956  2957
### [Matos] - News - Spéculations et même des vertes et des pas mûres
n°2601187
la poutanc​e
wacca wacca wacca
Posté le 19-06-2008 à 07:56:48  profilanswer
Sur que les photos en 2D c'est quand même moins kitchouille :o
n°2601292
raoul_volf​oni
Klaatu Barada Nikto
Posté le 19-06-2008 à 09:17:56  profilanswer
Poogz a écrit :
http://www.northlight-images.co.uk [...] uture_tech
Future technology
DIGIC IV uses less power, and is faster than the dual DIGIC 3 found in the 1D3 and 1Ds3. In particular it can support 16bit raw and the larger 40-50MP sensors under development. With the larger sensors, it also supports pixel-binning where pixels are aggregated to deliver low noise and higher ISO performance at lower resolutions.
Canon is working on a new generation CMOS sensor – lower voltage, full 100% cover micro-lenses and better dynamic range allowing 16 bit per channel raw files.
These will support a clean 6400 ISO similar to today's 1600 and go to 25600 with acceptable noise.
Target for this is the next generation of the 1D series cameras in 2010, before spreading to other models. These are being trialled at 50MP in FF format
Canon is very excited about these sensors – seeing them as being as big a step up in performance as their move from CCD to CMOS a decade ago.
What to do with those 50MP images... Canon is considering built in hard drives (moving or solid state) in the 80-100GB range in future generations of cameras – mostly likely in a optional grip.
Canon have working MPEG DIGIC III code for their P&S range
This was tried in some of the test cameras sent out during 1D Mk3 trials. It's expected that this will appear in the entry level camera (xxxD range) next year
Canon is seeing this as an important feature in the 1D Mk IV range in 2010 (it would be HD video)
50 millions de pixels... [:minipinguin]
Ils prévoient des objectifs pour aller avec ?
"L'homme de la pampa, parfois rude, reste toujours courtois." - GalerieHFR (dernière m.a.j : 453 av. JC)
n°2601343
swing
Posté le 19-06-2008 à 09:38:51  profilanswer
Irradiami d'Amore a écrit :
Nikon vient à peine de sortir le D3 et le D300.
Si ce D700 est tel qu'on le présente, ça plombe un peu l'ambiance pour ceux qui viennent d'acheter le D300 (et les optiques) .... mais ça appauvrit aussi le public du D3 qui pourrait pourquoi pas se contenter de ce petit frère.
Quoiqu'il en soit, ça stimule la concurrence ....
je parle pas du tout de ça !
le D700 c'est sur et certain.
mon doute était sur le viseur 100% au vu des photos postées...
photoblog
n°2603532
swing
Posté le 20-06-2008 à 08:31:08  profilanswer
n°2603702
Kezakel
Posté le 20-06-2008 à 10:21:58  profilanswer
non, c'est pas une rumeur, mais une "supposition" pour reprendre les mots de l'article
n°2604399
Poogz
Posté le 20-06-2008 à 14:37:56  profilanswer
http://canonrumors.com/
Friday, June 20, 2008, 08:08 AM - Canon 3D & 6D
Different Source
I've received some megapixel info from a different source about the 3D and 6D (Not official names).
Difference from the previous rumor:
6D - Resolution: 12mp
Price: $2199 USD
3D - Resolution: 18mp
Price: $3199 USD
He also mentioned there may be a new type of live view in one of the cameras.
ça continue avec 2 remplaçants pour le 5D
Si ça se confirme, D700 vs 3D ça va être bon. [:cerveau delight]
n°2604432
isofouet
Moi faut pas m'énerver
Posté le 20-06-2008 à 14:47:01  profilanswer
Capteur secondaire vers le viseur, à la sony = viseur minuscule [:haha]
L'APS-C Vaincra :o ├ Galerie ┤ ├ Rome ┤ ├ Belgique ┤
n°2604435
Poogz
Posté le 20-06-2008 à 14:47:53  profilanswer
Ou écran wireless détachable :o
n°2604540
la poutanc​e
wacca wacca wacca
Posté le 20-06-2008 à 15:14:20  profilanswer
Taing t'as l'air con le jour où tu égares l'écran  [:tinostar]
n°2604551
Poogz
Posté le 20-06-2008 à 15:16:30  profilanswer
Il reste le viseur :o
Et on est chez canon, tu pourras acheter un autre écran pour la modique somme de 800€ :d
n°2604552
Mako__O
Posté le 20-06-2008 à 15:16:31  profilanswer
Dans ce cas, faut du wifi filaire. ©GAS  :o
Message édité par Mako__O le 20-06-2008 à 15:16:48
n°2604554
Naxos
\o/
Posté le 20-06-2008 à 15:17:45  profilanswer
C'est calme ici pour un vendredi  [:implosion du tibia]
[Folio Photos]
n°2605198
Poogz
Posté le 20-06-2008 à 17:24:48  profilanswer
Pour le fun (niveau de fiabilité le plus bas :d)
http://www.canonrumors.com/images/canoneos5dmk2.jpg
n°2605209
Novocaine_​80
Switcheur compulsif
Posté le 20-06-2008 à 17:29:26  profilanswer
Un 1Ds Mark II quoi :o
https://www.instagram.com/nicolas_loret/
n°2605222
delantera
Hail Seitan.
Posté le 20-06-2008 à 17:31:17  profilanswer
sans grip [:thalis]
/eternelle bataille des grips
n°2605228
Novocaine_​80
Switcheur compulsif
Posté le 20-06-2008 à 17:32:23  profilanswer
delantera a écrit :
sans grip [:thalis]
Avec grip  [:aka44]
(en fin un plus petit comme la rumeur du 3D ca serait nickel :D )
Message édité par Novocaine_80 le 20-06-2008 à 17:32:45
n°2605230
delantera
Hail Seitan.
Posté le 20-06-2008 à 17:32:41  profilanswer
ok j'ouvre un topic :o
n°2605234
Novocaine_​80
Switcheur compulsif
Posté le 20-06-2008 à 17:33:07  profilanswer
Ok j'ouvre un contre topic  :o
n°2605613
thom@s
Ancien geek !
Posté le 20-06-2008 à 19:27:56  profilanswer
 [:al zheimer]
n°2605689
isofouet
Posté le 20-06-2008 à 20:27:18  profilanswer
Fake, les boitiers sont jamais présentés avec ce type d'objo, car le but est de mettre le boitier en valeur et non l'objo :o
en général, c'est le 50 1.4  :o
Message édité par isofouet le 20-06-2008 à 20:27:39
n°2605830
la poutanc​e
wacca wacca wacca
Posté le 20-06-2008 à 22:08:15  profilanswer
La preuve, le D3 presente avec le 85 1.4 :whistle:
n°2605831
lionoche
Posté le 20-06-2008 à 22:10:45  profilanswer
n°2605833
la poutanc​e
wacca wacca wacca
Posté le 20-06-2008 à 22:14:10  profilanswer
Sacre bestiau  :ouch:
C'est le flash a tete rotative dont on a entendu parler il y a qques temps?
Bon entre celui la, le Canon et le probable Nikon, c'est la mode des flashs en ce moment...
n°2607081
mahieu
S+Ko
Posté le 21-06-2008 à 20:45:35  profilanswer
salut à tous,
désolé si je suis à la bourre mais je suis un peu loin du monde civilisé ces temps-ci...
Il y a eu des nouveautés canon depuis 1 mois 1/2? (boitier et objo ou encore série G principalement)
Merci :)
eidt: je précise: ici internet c'est les yeux de la tête, je ne peux aps trop surfer sur le site pour "pêcher" l'info.... :/
Message édité par mahieu le 21-06-2008 à 20:46:13
n°2607091
Poogz
Posté le 21-06-2008 à 20:48:35  profilanswer
mahieu a écrit :
salut à tous,
Merci :)
Un EOS 1000D :d --> 450D en plus cheap (sisi c'est possible) un nouveau flash  430 EX II et rien d'autre, il y a toujours des rumeurs 3D /6D et voir un nouveau G à capteur CMOS d'une taille entre G9 et APS-C
22€ - Merci. :d
n°2607312
JeanY
ça le fait grave...
Posté le 22-06-2008 à 00:19:26  profilanswer
22€ - Merci. :d
t'inquiètes pas, à mon avis, le 5DII sera dispo avant le D700...  :whistle:
Ma galerie : Lanzarote page 25
n°2609026
Megalyth
no way
Posté le 23-06-2008 à 08:23:15  profilanswer
[:hahasparta]  [:hahaaulas]  [:hahaguy]  [:apo_isis]  [:gingerspirit]  [:sebire]
√ ... √ Feedb4ck
n°2610890
thom@s
Ancien geek !
Posté le 23-06-2008 à 21:30:23  profilanswer
 [:labbaipierre]
n°2611103
bobor
tueur de n44b
Posté le 23-06-2008 à 23:12:46  profilanswer
:o pas besoin d'être dispo pour en discuter sur HFR! En revanche, faut qu'il soit annoncé  [:bigsmilev]
Gitan des temps modernes
n°2611379
swing
Posté le 24-06-2008 à 08:40:27  profilanswer
a900, pré-série
http://img529.imageshack.us/img529/6527/a91dw5.jpg
http://img50.imageshack.us/img50/4771/a92xu4.jpg
http://img50.imageshack.us/img50/8204/a93oh1.jpg
http://img149.imageshack.us/img149/6362/a94wv5.jpg
http://img529.imageshack.us/img529/4239/a95hi7.jpg
http://img50.imageshack.us/img50/3489/a96fd9.jpg
photoblog
n°2611383
Toxin
Carpe ★★ Vitam
Posté le 24-06-2008 à 08:42:34  profilanswer
Arrivera t-il avant le D700 ?
n°2611386
Dkiller
Posté le 24-06-2008 à 08:43:53  profilanswer
De toutes façons D700/A900/5DII ça sera pour noël/janvier au plus optimiste :o
n°2611388
Cygne_d_Et​ang
Punk's not dead
Posté le 24-06-2008 à 08:44:16  profilanswer
et avant le 5d2 [:toto le hros]
n°2611389
Toxin
Carpe ★★ Vitam
Posté le 24-06-2008 à 08:44:29  profilanswer
Si le 5DII est annoncé en novembre ça peut le faire :o
n°2611390
Toxin
Carpe ★★ Vitam
Posté le 24-06-2008 à 08:44:49  profilanswer
L'autre qui s'intercale j'en reviens pas :o
n°2611392
swing
Posté le 24-06-2008 à 08:45:52  profilanswer
D700 en septembre épicäÿtou :o
Message édité par swing le 24-06-2008 à 08:46:04
photoblog
n°2611394
isofouet
Posté le 24-06-2008 à 08:46:27  profilanswer
[:haha] le sony a encore un mode carré vert
n°2611440
Cpu Toaste​r
R pixel overclocking!
Posté le 24-06-2008 à 09:11:28  profilanswer
Il va y avoir 2 gammes en full frame finalement... une en 1x MP et l'autre en 2x MP.
Photo Toaster - Flickr Toaster - Blog Toaster
n°2611491
FLo14
Gouranga !
Posté le 24-06-2008 à 09:51:04  profilanswer
Je viens de démarrer le compte à rebours pour attendre les premières réactions horrifiées sur la laideur du boîtier [:dawa]
« Franchement si j'étais toi, je... – T'es moi ? – Nan. – Bon bah tu fermes ta gueule alors. »
n°2611493
Posté le 24-06-2008 à 09:51:31  answer
ben faut dire qu'il est vraiment laid  [:elcap]
n°2611512
la poutanc​e
wacca wacca wacca
Posté le 24-06-2008 à 10:04:17  profilanswer
parce qu'il ne faut pas passer à coté des choses simples: wouah qu'c'est laid! [:elcap]
Sérieux ce prisme taillé à la serpe, les 12 boutons sur le dessus accessibles par tout être muni de 2 pouces à la main droite :miam:
Sinon ça a l'air sympa niveau taille, et je crois bien que l'écran (+3" non?) est articulé??
Plus de sujets relatifs à : ### [Matos] - News - Spéculations et même des vertes et des pas mûres
