3078 connectés
 Page :   1  2  3  4  5  ..  329  330  331  ..  775  776  777  778  779  780
[DEBIAN] - Intégristes barbus, |337, femmes nues...
n°1134131
enfoiro
a nickname is just a nickname
Posté le 09-05-2009 à 21:18:32  profilanswer
hppp a écrit :
Donc voila la situation:
cat /proc/mdstat :
Code :
  1. cesar:~# cat /proc/mdstat
  2. Personalities : [raid6] [raid5] [raid4]
  3. md0 : active raid5 sda[0] sdc[1]
  4.       976770816 blocks level 5, 64k chunk, algorithm 2 [3/2] [UU_]
  5.
  6. unused devices: <none>
mdadm --detail /dev/md0 :
Code :
  1. cesar:~# mdadm --detail /dev/md0
  2. /dev/md0:
  3.         Version : 00.90.03
  4.   Creation Time : Wed May  6 21:23:00 2009
  5.      Raid Level : raid5
  6.      Array Size : 976770816 (931.52 GiB 1000.21 GB)
  7.     Device Size : 488385408 (465.76 GiB 500.11 GB)
  8.    Raid Devices : 3
  9.   Total Devices : 2
  10. Preferred Minor : 0
  11.     Persistence : Superblock is persistent
  12.     Update Time : Wed May  6 21:23:00 2009
  13.           State : clean, degraded
  14. Active Devices : 2
  15. Working Devices : 2
  16. Failed Devices : 0
  17.   Spare Devices : 0
  18.          Layout : left-symmetric
  19.      Chunk Size : 64K
  20.            UUID : 58900402:d9c398e5:6f2233a9:b779757b
  21.          Events : 0.1
  22.     Number   Major   Minor   RaidDevice State
  23.        0       8        0        0      active sync   /dev/sda
  24.        1       8       32        1      active sync   /dev/sdc
  25.        2       0        0        2      removed
fdisk -l :
Code :
  1. cesar:~# fdisk -l
  2. Disk /dev/sda: 500.1 GB, 500106780160 bytes
  3. 255 heads, 63 sectors/track, 60801 cylinders
  4. Units = cylinders of 16065 * 512 = 8225280 bytes
  5. Disk /dev/sda doesn't contain a valid partition table
  6. Disk /dev/sdb: 500.1 GB, 500106780160 bytes
  7. 255 heads, 63 sectors/track, 60801 cylinders
  8. Units = cylinders of 16065 * 512 = 8225280 bytes
  9. Disk /dev/sdb doesn't contain a valid partition table
  10. Disk /dev/sdc: 500.1 GB, 500106780160 bytes
  11. 255 heads, 63 sectors/track, 60801 cylinders
  12. Units = cylinders of 16065 * 512 = 8225280 bytes
  13. Disk /dev/sdc doesn't contain a valid partition table
  14. Disk /dev/hda: 80.0 GB, 80026361856 bytes
  15. 255 heads, 63 sectors/track, 9729 cylinders
  16. Units = cylinders of 16065 * 512 = 8225280 bytes
  17.    Device Boot      Start         End      Blocks   Id  System
  18. /dev/hda1   *           1         851     6835626   83  Linux
  19. /dev/hda2             852        9729    71312535    5  Extended
  20. /dev/hda5             852        1014     1309266   82  Linux swap / Solaris
  21. /dev/hda6            1015        9729    70003206   83  Linux
  22. Disk /dev/md0: 1000.2 GB, 1000213315584 bytes
  23. 2 heads, 4 sectors/track, 244192704 cylinders
  24. Units = cylinders of 8 * 512 = 4096 bytes
  25. Disk /dev/md0 doesn't contain a valid partition table
/dev/sdb me fait donc que des erreurs:
Code :
  1. May  6 20:08:05 cesar kernel: Buffer I/O error on device sdb, logical block 0
  2. May  6 20:08:05 cesar kernel: sd 2:0:0:0: SCSI error: return code = 0x00040000
  3. May  6 20:08:05 cesar kernel: end_request: I/O error, dev sdb, sector 0
  4. May  6 20:08:05 cesar kernel: sd 2:0:0:0: SCSI error: return code = 0x00040000
  5. May  6 20:08:05 cesar kernel: end_request: I/O error, dev sdb, sector 1
  6. May  6 20:08:05 cesar kernel: sd 2:0:0:0: SCSI error: return code = 0x00040000
  7. May  6 20:08:05 cesar kernel: end_request: I/O error, dev sdb, sector 128
  8. May  6 20:08:05 cesar kernel: sd 2:0:0:0: SCSI error: return code = 0x00040000
  9. May  6 20:08:05 cesar kernel: end_request: I/O error, dev sdb, sector 129
  10. May  6 20:08:05 cesar kernel: sd 2:0:0:0: SCSI error: return code = 0x00040000
  11. May  6 20:08:05 cesar kernel: end_request: I/O error, dev sdb, sector 128
  12. May  6 20:08:05 cesar kernel: sd 2:0:0:0: SCSI error: return code = 0x00040000
  13. May  6 20:08:05 cesar kernel: end_request: I/O error, dev sdb, sector 129
  14. May  6 20:08:05 cesar kernel: sd 2:0:0:0: SCSI error: return code = 0x00040000
  15. May  6 20:08:05 cesar kernel: end_request: I/O error, dev sdb, sector 976770816
  16. May  6 20:08:05 cesar kernel: sd 2:0:0:0: SCSI error: return code = 0x00040000
  17. May  6 20:08:05 cesar kernel: end_request: I/O error, dev sdb, sector 976770817
  18. May  6 20:08:05 cesar kernel: sd 2:0:0:0: SCSI error: return code = 0x00040000
  19. May  6 20:08:05 cesar kernel: end_request: I/O error, dev sdb, sector 976770816
  20. May  6 20:08:05 cesar kernel: sd 2:0:0:0: SCSI error: return code = 0x00040000
  21. May  6 20:08:05 cesar kernel: end_request: I/O error, dev sdb, sector 976770817
  22. May  6 20:08:05 cesar kernel: sd 2:0:0:0: SCSI error: return code = 0x00040000
  23. May  6 20:08:05 cesar kernel: end_request: I/O error, dev sdb, sector 976771032
  24. May  6 20:08:05 cesar kernel: sd 2:0:0:0: SCSI error: return code = 0x00040000
  25. May  6 20:08:05 cesar kernel: end_request: I/O error, dev sdb, sector 97677103
Code :
  1. May  6 20:09:09 cesar kernel: sd 2:0:0:0: SCSI error: return code = 0x00040000
  2. May  6 20:09:09 cesar kernel: end_request: I/O error, dev sdb, sector 0
  3. May  6 20:09:09 cesar kernel: printk: 79 messages suppressed.
  4. May  6 20:09:09 cesar kernel: Buffer I/O error on device sdb, logical block 0
  5. May  6 20:09:09 cesar kernel: Buffer I/O error on device sdb, logical block 1
  6. May  6 20:09:09 cesar kernel: Buffer I/O error on device sdb, logical block 2
  7. May  6 20:09:09 cesar kernel: Buffer I/O error on device sdb, logical block 3
  8. May  6 20:09:09 cesar kernel: Buffer I/O error on device sdb, logical block 4
  9. May  6 20:09:09 cesar kernel: Buffer I/O error on device sdb, logical block 5
  10. May  6 20:09:09 cesar kernel: Buffer I/O error on device sdb, logical block 6
  11. May  6 20:09:09 cesar kernel: Buffer I/O error on device sdb, logical block 7
  12. May  6 20:09:09 cesar kernel: Buffer I/O error on device sdb, logical block 8
  13. May  6 20:09:09 cesar kernel: Buffer I/O error on device sdb, logical block 9
  14. May  6 20:09:09 cesar kernel: sd 2:0:0:0: SCSI error: return code = 0x00040000
  15. May  6 20:09:09 cesar kernel: end_request: I/O error, dev sdb, sector 0
  16. May  6 20:09:09 cesar kernel: sd 2:0:0:0: SCSI error: return code = 0x00040000
  17. May  6 20:09:09 cesar kernel: end_request: I/O error, dev sdb, sector 1
voilà la situation.
Merci de votre aide.
avec toutes ces précisions on peut avancer.
ton raid 5 mélange les données entre les disques et peut normalement survivre à la perte d'un disque mais ta situation est critique.
ton disque dur fait des erreurs matérielles et le travail de restauration doit donc absolument commencer par celui-ci, sans toucher au reste du raid et dans le meilleur des cas sur un autre ordinateur pour éviter de facheuses erreurs.
il faut arriver à accéder à tes données sur le disque qui présente des défauts matériels, sauvegarder ces données en brut sur un autre support de taille équivalente ou supérieure, puis réinsérer ce support dans le raid, sauvegarder la totalité du raid et tout recommencer à zéro.
rend-toi sur mon topic pour la méthodo concernant le dump de disque dur. et pense éventuellement à spinrite, ca aide beaucoup. Utiliser un vieux kernel permet aussi d'utiliser des fonctionnalités de réduction de vitesse du disque pour maximiser tes chances de récupération de données.
pour ne pas polluer je te propose de continuer sur le topic resto de données, en remettant les infos concernant les erreurs matérielles de /dev/sdb uniquement, il faut s'occuper de ce disque d'abord.
Tu n'aurais jamais du fonctionner à 2 disques en raid 5, c'est pas terrible comme mode surtout sans spare.
En essayant de resynchroniser le deuxieme disque tu a diminué tes chances.
Mais on commence par /dev/sdb
n°1134135
hppp
Serveur@home
Posté le 09-05-2009 à 21:32:27  profilanswer
ouais mais /dev/sdb n'est plus dans le raid, je l'ai viré.
avant j'étais à 3 disque avant que j'ai ces problèmes.
n°1134153
174flo
Posté le 09-05-2009 à 23:12:57  profilanswer
Depuis une mise à jour de ma sid, mon lecteur mp3 se mont en mode mtp au lieu d'ums.Et je trouve ça asse casse c******.
Où est-ce que je peux aller pour faire revenir tout ça dans l'ordre?
EDIT : c'est bon, j'ai trouver, je suis aller dans l'éditeur de configuration et j'ai chercher autoipod,et j'ai décocher se truc :o
EDIT 2 : non c'etait un coup de pot :(
Par pitier comment on desactive le suport du mtp? :cry:
Message édité par 174flo le 10-05-2009 à 02:03:30
Le site des blagues les plus drôles :D
n°1134226
Gavrinis
Open your mind
Posté le 10-05-2009 à 10:34:59  profilanswer
Est-ce normal de n'avoir droit qu'à Lilo à cause du LVM ?
Avant l'étape LVM j'ai le choix entre Lilo et Grub et une fois mes VG créés il n'y a plus que Lilo :( pourtant la dernière fois que j'ai installé une Debian le choix était encore possible malgré le LVM, je n'y comprends rien :sweat:
n°1134232
multani
Dépressionnisé
Posté le 10-05-2009 à 11:08:46  profilanswer
Grub doit pouvoir accéder à sa configuration qui est écrite dans /boot, et il ne sait pas lire sur des volumes logiques LVM. Si ces fichiers sont sur un volume logique géré par LVM, c'est donc normal que l'installeur ne te propose que lilo.
Perso, j'ai un volume logique qui est monté sur / et une petite partition "normale" (hors LVM) montée sur /boot, et du coup j'utilise grub.
À priori, grub2 devrait pouvoir booter directement sur LVM mais j'ai pas testé.
n°1134237
Gavrinis
Open your mind
Posté le 10-05-2009 à 11:14:21  profilanswer
J'utilise le même cas que toi, ma /boot est en dehors du LVM pourtant.
n°1134251
Gavrinis
Open your mind
Posté le 10-05-2009 à 12:19:50  profilanswer
J'ai relancé une installation sur la précédente et cette fois j'ai le choix de Grub :??: enfin tant mieux
n°1134271
san_
Posté le 10-05-2009 à 13:51:24  profilanswer
:hello: j'ai un petit souci, mon service samba nmbd ne se lance jamais au démarrage
mon boot log indique pourtant le contraire :
Sun May 10 13:43:56 2009: Starting NFS common utilities: statd.
Sun May 10 13:43:56 2009: Not starting internet superserver: no services enabled.
Sun May 10 13:43:56 2009: Starting Samba daemons: nmbd smbd.
Sun May 10 13:43:57 2009: Starting FTP server: vsftpd.
Sun May 10 13:43:57 2009: Starting MD monitoring service: mdadm --monitor.
mais un ps -aux | grep nmbd indique bien que nmbd n'est pas lancé
ainsi qu'un redémarrage de samba :
vault:~# /etc/init.d/samba restart
Stopping Samba daemons: nmbdstart-stop-daemon: warning: failed to kill 2565: No such process
 smbd.
mon smb.conf, des fois que la source du problème y soit
[global]
 workgroup = UNIXGROUP
 netbios name = %h
 server string = %h server
 security = user
 dns proxy = no
 log file = /var/log/samba/log.%m
 max log size = 1000
 syslog = 0
 panic action = /usr/share/samba/panic-action %d
 username map = /etc/samba/smbusers
 encrypt passwords = true
 passdb backend = tdbsam
 obey pam restrictions = yes
 unix password sync = yes
 passwd program = /usr/bin/passwd %u
 passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
 pam password change = yes
[homes]
comment = Home Directories
browseable = no
read only = no
create mask = 0700
directory mask = 0700
valid users = %S
[share]
comment = Share
path = /mnt/share
read only = no
create mask = 0700
public = yes
vous avez une idée d'où ça pourrait venir :??:
Message édité par san_ le 10-05-2009 à 14:52:28
n°1134282
l0g4n
Expert en tout :o
Posté le 10-05-2009 à 15:17:22  profilanswer
J'ai cassé ma testing >< après un apt-get update/upgrade, j'ai pas regardé, j'ai accepté, j'ai paumé aptitude et synaptic...
Je suis le seul ou bien ? Je tente un apt-get install synaptic ou pas ?
[EDIT] Et accessoirement, amarok 2, il passe sur la testing sans mettre des milliers de libs ?[/EDIT]
Message édité par l0g4n le 10-05-2009 à 15:18:30
Fort et motivé. Sauf parfois.
n°1134283
thana54
made in concept
Posté le 10-05-2009 à 15:22:14  profilanswer
J'ai eu ca en sid il y a une quinzaine de jours. Seule solution, downgrade pour récupérer aptitude/synaptic ou attendre.
Depuis la version 0.7.21 ca passe mieux, j'ai récupéré aptitude et synpatique, mais pas encore update-manager.
n°1134285
l0g4n
Expert en tout :o
Posté le 10-05-2009 à 15:29:24  profilanswer
Bon, j'ai apt-get install synaptic sa marche...
Par contre, heu, je tente de down les isos de testing en amd64 et le tracker est pas d'accord, c'est normal ou ma config de transmission foire ?
n°1134366
multani
Dépressionnisé
Posté le 10-05-2009 à 21:28:11  profilanswer
Là, j'en sais rien, la dernière fois où j'ai installé ma distrib, ça date un peu :o
n°1134367
Winpoks
Posté le 10-05-2009 à 21:46:28  profilanswer
Winpoks a écrit :
Je viens d'effectuer une nouvelle installation de débian sur un autre ordinateur, mais j'ai un soucis d'affichage. L'ordinateur est en bi-écran. Sur les deux, la résolution est bien paramètré (1680*1050 et 1600*1200). Le curseur se balade normalement sur les écrans et en bout de course, il s'arrête. Le soucis vient du premier écran avec les logiciel, dès qu'on les met en plein écran, ils n'utilisent pas entièrement l'écran et donc le bas de la fenêtre du logiciel continue plus bas que l'écran et le côté est limité.
En gros j'ai l'impression que les logiciels se comportent sur le premier écran comme sur le second en 1600*1200.
Savez vous d'où peut venir le problème?
Edit: Par contre la barre de tache de fluxbox elle est bien apparente sur l'écran et le soucis ne se pose qu'avec les logiciels comme iceweasel, le terminal en plein écran, lecteur vidéo...
Merci d'avance.
Je reviens sur ce problème. J'ai effectué une nouvelle installation pour voir et le problème persiste encore. Sur le second écran c'est toujours bien. La capture initial fait bien 1680*1050 soit la résolution de l'écran mais ici sous xfce, je n'ai pas la barre du bas non plus. En gros, c'est seulement au niveau de la gestion des fenêtres.
Si vous connaissiez le problème, merci encore.
Voila un screen:
http://www.pixelz.fr/9/d/1/7914c8b8604d9f6350003598bde6b.png
Message édité par Winpoks le 10-05-2009 à 22:16:24
n°1134371
Winpoks
Posté le 10-05-2009 à 22:33:29  profilanswer
Problème résolu avec Xinerama. :)
n°1134395
174flo
Posté le 11-05-2009 à 06:19:39  profilanswer
Par pitier comment on désactive le suport du mtp? :cry:
Après recherche,je pense que ça viens de gvfs, quand je kill se processus : gvfs-gphoto2-vo Tout redeviens normale. Comment je peux faire pour éviter qu'il ne s'exécute à chaque session?
n°1134399
gee
Bon ben hon
Posté le 11-05-2009 à 07:03:36  profilanswer
sysv-rc-conf peut peut-etre t'aider.
"Phildar t'es vraiment une pute pas finie toi! Et Manu le gros porc arrete de t'marrer!"
n°1134454
MsieurDams
Livreur de lasagnes en moto
Posté le 11-05-2009 à 12:43:41  profilanswer
Hello, je suis un nouveau débianiste, j'ai essayé d'installer Lenny sur mon eeePC 1000HE. Cela fonctionne bien, en tout cas depuis que j'ai passé le kernel en 2.6.29 afin d'avoir le wifi de disponible. J'ai utilisé l'installeur standard, lequel m'a au départ généré quelques soucis avec les dépôts.
Néanmoins, ça fonctionne plutôt bien même si chose curieuse, la référence de la carte wifi renvoyée par LSPCI est Ralink alors que j'attends normalement une Atheros 8k (donc devrait normalement utiliser ath9k), référence indiquée par la version RC de seven qui cohabite sur le disque dur. J'ai collé les eeePC-ACPI-scripts afin d'avoir la majorité des touches de fonction opérationnelles, Fn+F2 semble bien désactiver la carte wifi, mais la led reste allumée (peut être parce que le bluetooth est toujours actif)
Pour l'instant, j'en suis là, je pense essayer d'installer les scripts Eeeasy, prévus à la base pour les distributions Ubuntu. Mais à partir du moment où il requiert les modules eeePC_laptop et asus_eee, il doit tout à fait être possible d'installer ça sur Debian. Qu'en pensez-vous?
Message édité par MsieurDams le 11-05-2009 à 12:43:54
n°1134455
M300A
Posté le 11-05-2009 à 13:08:41  profilanswer
Si lspci le dit, c'est que tu as une Ralink. D'ailleurs dans mon EEE 901 c'est aussi une Ralink :)
Très probable pour le bluetooth, en effet.
Aucune idée mais dans l'idée ça me parait pas déconnant. Ca fait quoi exactement ?
n°1134457
MsieurDams
Posté le 11-05-2009 à 13:25:19  profilanswer
Dans ce cas, pourquoi Seven l'identifie comme une Atheros?
D'autre part, ça ne colle pas avec ce qui est présenté ici
http://wiki.debian.org/DebianEeePC/Model/1000HE
Je vais peut être pour être certain tester avec une autre distribution, une backtrack ou une fedora par exemple
http://forum.eeeuser.com/viewtopic [...] =49081&p=1
C'est le remplaçant d'eee-control, lequel permet de gérer assez finement l'ACPI des eeePC, activer ou désactiver les modules etc.
http://hfr-rehost.net/img299.imageshack.us/img299/3623/elmuratoconfiggj1.png
n°1134461
dam1330
Posté le 11-05-2009 à 13:41:24  profilanswer
personne n'a de souci avec pidgin + gtalk sur debian sid ?
depuis la semaine derniere, quand j'active mon compte gtalk sur pidgin, pidgin segfault. j'ai pas de debug.
J'ai supprimé mes fichiers de config, mais rien y fait
n°1134488
M300A
Posté le 11-05-2009 à 14:46:20  profilanswer
Ca serait pas la première fois qu'un constructeur change le matos présent dans un même produit...
lsmod | grep -e ath -e rt ;)
n°1134501
tecoxe
Posté le 11-05-2009 à 15:18:23  profilanswer
Petite question, j'ai récupéré un thin client sur lequel j'installerais bien une debian. Problème l'espace disque est trés limité (512Mo), du coup je pensais installer ça sur un disque Usb ou une clé Usb.
J'ai testé avec une Archlinux, mais pas moyen de booter.
Y a t'il une méthode pour le faire avec une debian ?
Message édité par tecoxe le 11-05-2009 à 15:19:16
n°1134505
174flo
Posté le 11-05-2009 à 15:51:54  profilanswer
Ok merci, je vais regarder ça se soir  :hello:
n°1134522
MsieurDams
Posté le 11-05-2009 à 17:59:30  profilanswer
Kenneee:/home/damien# lsmod | grep -e ath -e rt
rt2860sta         430544 0
parport_pc         22020 0
parport              30868 3 ppdev,parport_pc,lp
agpgart             30624 3 drm,intel_agp
Ce qui voudrait dire que j'ai une ralink dans mon eeePC 1000HE  :heink:
En revanche, la led du wifi se désactive comme il faut après le reboot ;) Ca m'aurait étonné aussi.
Message édité par MsieurDams le 11-05-2009 à 18:01:12
n°1134549
fabetal
Posté le 11-05-2009 à 19:27:11  profilanswer
sur mon 1000H ya une ralink, c'est normal. ça m'étonnerait que ça ait changé entre les 2, vu qu'en gros c'est juste le clavier qui est différent ...
n°1134562
Gwen311
Posté le 11-05-2009 à 20:11:33  profilanswer
Ben... chez moi ça marche. Moi c'est un souci kopete/msn que j'ai ;)
n°1134565
M300A
Posté le 11-05-2009 à 20:18:31  profilanswer
rt2860sta         430544 0
parport_pc         22020 0
Ah bah c'est clair, ni ath, ni ath5k ni ath9k chargés. Par contre on a bien un pilote ralink (rt2860...)
n°1134577
dams78
développateur
Posté le 11-05-2009 à 21:11:08  profilanswer
bonsoir,
je suis sous kde et quand je branche un périf usb il est monté en root
ce week-end je n'ai pas eu ce problème, et j'ai pas eu de grosses mise à jour
je suis en testing
ça peut venir d'où? (mes périf sont tous en fat32)
dam's (debianer), ma galerie Flickr
n°1134819
ogaby
Posté le 12-05-2009 à 21:10:28  profilanswer
[:hurle] A tous ceux qui sont sur sid et qui ont le driver libre ati
Il faut installer le paquet " firmware-linux "
n°1134828
M300A
Posté le 12-05-2009 à 21:45:20  profilanswer
Tu savais pas ? [:dawa]
n°1134877
veggie
Posté le 13-05-2009 à 04:54:25  profilanswer
Hello, je suis étudiant en ingénierie, et ça fait quelques années que je m'intéresse à Linux maintenant. J'ai commencé avec une redhat il y a quelques années de ça (ça devait être juste avant le fork qui a donné Mandrake, j'étais tout djeunz), mais je n'ai jamais pu m'y mettre au point de ne plus utiliser Windows, et au final j'en revenais toujours à Windows pour ma station de travail vu que j'avais la flemme/pas les sous pour fonctionner en dual boot. J'ai toujours besoin de logiciels spécifiques qui ne sont développés que sous Windows (Autocad, divers logiciels d'archi navale, etc)... (Bon pour faire un serveur de fichiers/FTP Debian est quand même très très bien, du coup c'est ce que j'utilisais sur un vieux tromblon).
Maintenant j'aimerais quand même bien m'y mettre plus sérieusement, vu que je me retrouve parfois dans la situation quasi inverse: si je prends le cas de Octave, sous Windows c'est une catastrophe à cause de Cygwin et du frontend de gnuplot, alors que j'ai oui dire que sous Linux ça passait quand même beaucoup mieux. Pareil pour faire du Latex par exemple, les softs libres sous windows sont en général des ports de trucs sous Linux, et on sent que ils seraient mieux dans leur environnement natif.
Donc en gros j'utilisais surtout Windows, mais j'essayais quand même de me servir de Linux de temps à autres car je pense qu'un ingé aujourd'hui doit savoir se servir d'une station de travail sous les deux OS pour pouvoir utiliser les offres logicielles des deux en fonction de ses besoins.
Est-ce qu'il y a des gens qui sont dans le même cas que moi, et qui ont des trucs de vieux briscards pour se faciliter la cohabitation avec les deux systèmes? Le genre de blagues que je voudrais éviter c'est par exemple d'avoir une partie de mes mails stockés en local sur ma partition Windows et l'autre sur la partition Linux.
Autre chose, je suis plutôt enclin à prendre une stable pour bosser sur mon PC, vu que j'ai pas envie de me retrouver planté la veille d'un truc à rendre avec un bug ou autre chose d'imprévu sur une testing, mais j'aime quand même avoir la dernière version de certains logiciels. Pour reprendre l'exemple d'Octave, la version dans la Lenny est déjà vieille d'un an...
A l'usage, vaut-il mieux installer une stable et upgrader ses softs au cas par cas quite à les compiler, ou carrément passer sur une test?
EDIT: et l'écriture sur du NTFS, c'est de la roulette russe ou y a pas de soucis?
Merci d'avance pour vos avis.
Message édité par veggie le 13-05-2009 à 04:55:26
n°1134878
the_k586
♥ Punk à Chats ♥
Posté le 13-05-2009 à 04:59:41  profilanswer
n°1134879
veggie
Posté le 13-05-2009 à 05:04:14  profilanswer
Non ça justement c'est ce que je cherche à éviter  :whistle: : dans le genre usine à gaz il y a pas pire. Faire tourner Windows pour faire tourner Linux pour y faire tourner un soft sous Linux, au final ça va être une vraie boucherie niveau perfs. J'étais tombé sur des benchs sous Octave, et le fait d'avoir Cygwin pour faire tourner Octave sous Windows était déjà un vrai massacre niveau perfs.
n°1134881
the_k586
♥ Punk à Chats ♥
Posté le 13-05-2009 à 05:33:31  profilanswer
Wokay
ça je sais pas trop ce que ça vaut niveau perf enfait, faudrais que je le teste un de ces 4, mais ça m'avait paru bien mieux foutu de cygwin et les autres machins assez catastrophe
Je vais tester sur mon windows voir tiens :o
♦ bl0g ♦ // ♠ Twitter ♠ // << Just for the lulz ! The Only reason anyone does anything >> // Free Open DNS
n°1134889
M300A
Posté le 13-05-2009 à 08:13:54  profilanswer
http://packages.debian.org/search?keywords=octave
n°1134933
e_esprit
Posté le 13-05-2009 à 10:09:15  profilanswer
Veggie> pour tes mails, utilise une relève en IMAP, comme ça pas de problème.
Sinon, testing est un très bon choix sous Debian, un compromis raisonnable entre stabilité et nouveauté.
n°1134942
veggie
Posté le 13-05-2009 à 10:37:35  profilanswer
Heu oui, et donc?
Merci, meilleur à ton avis que d'upgrader à la main les trucs qui m'intéressent?
Message édité par veggie le 13-05-2009 à 10:43:41
n°1134947
e_esprit
Posté le 13-05-2009 à 10:58:39  profilanswer
Tu peux aussi faire un mix stable + testing pour certains paquets (+ dépendances) en utilisant le pinning (man apt_preferences),
mais globalement la testing est généralement stable et tout à fait utilisable de façon intensive sans problème.
Pas mal içi tournent avec, certains sont même en unstable sur leur machine de travail (mais bon, là par contre il faut être capable
de rattrapper d'eventuels problèmes qui peuvent survenir, donc globalement je ne recommanderai pas à tout le monde).
n°1134978
black_lord
Truth speaks from peacefulness
Posté le 13-05-2009 à 13:29:03  profilanswer
bah ça fait des années que je tourne en SID, y'a pas de soucis
uptime is for lousy system administrators what Viagra is for impotent people - mes unixeries - github me
n°1134992
e_esprit
Posté le 13-05-2009 à 14:47:30  profilanswer
Oui mais t'es un peu capable de résoudre d'eventuels petits problèmes, pour toi c'est à peine notable, parce
que ca ne te prends que 2 minutes (et encore), mais pour un débutant ou quelqu'un dont ce n'est pas le
métier, ca peut parfois être plus problématique, donc je conseille plutot testing dans ces cas-là :jap:
n°1135036
tecoxe
Posté le 13-05-2009 à 19:35:47  profilanswer
A ce sujet le system profiler me dit que je suis en squeeze/sid alors que juste j'ai ajouté les dépots unstable, ce qui m'a valu quelques mésaventures mais au moins ca à le mérite d'etre formateur ^^
[neewbe debian]Package mplayer pour debian Woodydebian ou slackware?
du gnu debian dans une sauce apple melangez avec du freebsd et on a[Debian] probleme avec Xfree
[Debian] comment installer KDE 2 voir KDE3 si possible ??comment installe-t-on une debian
disquette de boot debianinstall carte reseau ISA debian
[ncurses] DEBIAN - je peux pas configurer mon noyau Sniff[Debian] stable / unstable
Plus de sujets relatifs à : [DEBIAN] - Intégristes barbus, |337, femmes nues...
