8004 connectés
 Page :   1  2  3  4  5  ..  108  109  110  ..  1028  1029  1030  1031  1032  1033
[Topic Unique] NVIDIA GeForce GTX 660Ti/670/680/690/760/770 (GK104)
n°8239635
neo673
Posté le 09-03-2012 à 10:49:02  profilanswer
Charles K a écrit :
NVIDIA Kepler Takes Shape: GeForce GTX 680 to Offer Dynamic Clocking, 2 and 4GB GDDR5
Dynamic Clock Adjustment is very similar to former “hot clocks”, with the difference that GK104 comes with several dozen power planes, and will operate on varying clocks depending on the computational load, card temperature and the power consumption. As we posted several days ago, the complete GK104 chip will operate at a lower clock, very similar figure to GTX 480: low power mode is 300 MHz, standard is 705 MHz extendable to 950 MHz – while the cores alone will be able to reach 1411 MHz when the chip is loaded to 100%.
The rumored performance is a mixed bag between HD 7870 and HD 7970: 10% faster than Radeon HD 7970 in Battlefield 3, but 10% slower in 3DMark11. Also, Epic's Samaritan demo, which required three GTX 580 boards only requires a single Kepler, i.e. a single GK104 chip.
When it comes to availability, partners are typically saying one thing in public, and another thing behind closed doors. The availability isn’t known, and it won’t be known until partners receive launch quantities. The estimations we heard went from pessimistic “small quantities of Kepler graphics cards only”, “no overclocking boards at launch” to “they had the first silicon in September 2011, they (NVIDIA) must have to stacked up the chips to flood the market and claw the market and mindshare back”.
As usuall, the rumors need to be taken with a few grams of salt (the Hawaiian one being one of most tastiest salts I have ever tried).
L'info principale de ton post c'est le sel hawaïan... Je ne connaissais pas, je m'en vais en acheter immédiatement !!  :ouch:
Message édité par neo673 le 09-03-2012 à 10:53:55
n°8239640
Agent heav​y
Posté le 09-03-2012 à 10:55:01  profilanswer
http://www.xtremesystems.org/forum [...] 780/page41
Photos de la gtx6xx.
Les connecteurs semblent bien être à la verticale sur le modèle commercial.
Sinon on retrouve une chambre à vapeur avec une plate en aluminium qui couvre le pcb comme sur la Gtx580.
Avec les rumeurs sur le tdp et au vu du dispositif de refroidissement, je ne prends pas trop de risque en disant que le modèle de référence sera bon et fera peu de bruit.
Reste à savoir si ce sera confirmé et a quel prix.
Message édité par Agent heavy le 09-03-2012 à 10:55:34
Feed-back
n°8239668
hifibuff
Posté le 09-03-2012 à 11:18:56  profilanswer
la_taupe a écrit :
Pas trop dans les habitudes de Nv mais pas impossible, pour jouer à la plus grosse avec l'argument "Surround à 4 Go vs. Eyefinity à 3 Go". Je serais curieux de voir ça.
Je compte un peu la dessus, si il n'y a que des modèles avec 2go, je risque d'attendre les GK100/110.
"Every man dies, not every man really lives"
n°8239734
Posté le 09-03-2012 à 12:22:15  answer
Et on fait comment pour adapter un autre rad comme l'Artic Accelero Twin Turbo II ou l'Artic Accelero Xtreme PLUS II, on ne pourra plus avec les connecteurs à la verticale ? :cry:
Message édité par Profil supprimé le 09-03-2012 à 12:23:47
n°8239740
Charles K
Posté le 09-03-2012 à 12:28:47  profilanswer
le twinturbo doit être limite pour ce genre de carte et l'xtreme sortira en version adaptée (ils font toujours ça).
Le shaman lui est plus court donc pas de problème, idem pour le setsugen 2, par contre le peter va buter, à voir si Alpenfohn sort une version adaptée
Message édité par Charles K le 09-03-2012 à 12:32:38
n°8239743
Activation
21:9 kill Surround Gaming
Posté le 09-03-2012 à 12:29:55  profilanswer
bah t attend les modèle non de référence :o équipé direct avec :o
n°8239744
Posté le 09-03-2012 à 12:32:09  answer
Oui mais quand on a déjà un Artic Accelero Twin Turbo II, je ne vais pas le jeter à la poubelle ou si ? :cry:
Il supporte 250w de tdp et est monté sur ma GTX470 est-ce que c'est suffisant ou pas ?
Message édité par Profil supprimé le 09-03-2012 à 12:33:48
n°8239748
Charles K
Posté le 09-03-2012 à 12:33:47  profilanswer
il reste toujours cette solution  [:gotcha]
si t'en es satisfait sur ta carte alors oui surement.
Message édité par Charles K le 09-03-2012 à 12:36:59
n°8239749
Activation
Posté le 09-03-2012 à 12:33:48  profilanswer
EpinardsHachés a écrit :
mais bien sur....  bientôt tu vas nous dire que si le GK110 n'est pas encore sorti c'est qu'il est inutile  :o
t'en a besoin pour quoi (mono screen s'entend)  .... metro 2033 ... y en a encore pour vouloir jouer à 60i/s avec ce jeu linéaire :o
crysederires 2  ... pas beaucoup mieux
 [:nicoozz]
the witcher II   ... j arrive pas à savoir si c est gpu ou cpu ses plus grosse exigence
nop sans plaisanter je suis preneur de liste de jeux auquel la gtx580 ou hd7950 ne suffit pas
je veux dire un jeu de shoot perso (ça sera pas l avis de tous) si le framerate se pète pas la gueule en dessous de 35 fps je trouve ça bien
un jeu de bagnole là par contre j ai tendance à trouver qu en dessous de 45/50 fps c est incontrôlable
on en revient à la problématique suivante, c'est les chute de framerate.... c'est pas le framerate moyen le pb, mais on en est bien à vouloir des gpus plus puissant pour ptet les 10% du temps ou dans un jeu le framerate se pète la gueule
alors, aux devs de faire mieux leur boulot ? le cpu ? la quantité mémoire ? le gpu ?  le jeu pas au minima avec LARGEADDRESSAWARE
http://www.presence-pc.com/tests/j [...] s-23090/5/
il n y a pas QUE la piste du gpu
Message édité par Activation le 09-03-2012 à 12:43:01
n°8239750
Posté le 09-03-2012 à 12:34:41  answer
nooooooooooooooooooon :cry: :cry:
Posté le 09-03-2012 à 12:34:41  profilanswer
n°8239772
Invite_Sur​prise
Racaille de Shanghaï
Posté le 09-03-2012 à 13:03:33  profilanswer
PHK vient de donner quelques "hints" concernant les parties avantageuses de la GTX 680 comparée à la HD7970 :
- Tension + basse
- Fréquences élevées
- Faible conso
- Faible bruit
- Meilleurs performances en AA + DX11
- Meilleur support Devs
http://bbs.expreview.com/thread-49806-1-1.html
edit :
http://tof.canardpc.com/view/b2e039b7-e475-4f3b-b7f3-5d5a107e6cf1.jpg
http://we.pcinlife.com/thread-1849001-1-1.html
edit2 :
Avec les MAJ BIOS + Pilotes (300.83), les résultats seraient bien meilleurs :
680-> X3200~3300
(7970)-> X2700~2800
670Ti -> X2500~2600
(7950) -> X2200~2300
http://bbs.expreview.com/thread-49802-1-1.html
Message édité par Invite_Surprise le 11-03-2012 à 11:11:45
n°8239777
Space
Profil: Maux des rateurs
Posté le 09-03-2012 à 13:13:12  profilanswer
et de meilleurs drivers  [:chownkey]
Vais ptete me faire un SLI de 670 [:prodigy]
n°8239783
kriechbaum
Posté le 09-03-2012 à 13:20:40  profilanswer
Salut
680-> X3200
à quoi ça correspond X3200-3300 ?
A+
n°8239793
hifibuff
Posté le 09-03-2012 à 13:25:46  profilanswer
si le résultat de ce bench se concrétise dans les jeux, à savoir, entre 15 et 25% au dessus d'une 7970, c'est pas mal je trouve. En espérant que les modèles à 4gb sortent TRES vite!
n°8239795
TheRealObi​-One
♥ Maître Jedi du Taunt ♥
Posté le 09-03-2012 à 13:28:10  profilanswer
4Gb en Vram pourquoi faire :whistle: ?
Message édité par TheRealObi-One le 09-03-2012 à 13:28:31
(Ex one1504) - [VDS] - Feed - Nostalg33k du PiseptO
n°8239796
Invite_Sur​prise
Posté le 09-03-2012 à 13:29:49  profilanswer
kriechbaum a écrit :
Salut
680-> X3200
A+
C'est le score Extreme 3DMark11.
n°8239798
Space
Posté le 09-03-2012 à 13:32:42  profilanswer
BF 3 Ultra en 3D Vision Surround ? :d
n°8239804
TheRealObi​-One
Posté le 09-03-2012 à 13:36:27  profilanswer
ah :D ?! désolay je ne connais pas ce jeu :p
n°8239808
kriechbaum
Posté le 09-03-2012 à 13:38:31  profilanswer
merci invité surprise...  Ca fait une bonne difference entre la 7970, et pourtant cette derniere etait soit disant plus rapide a 3DMark..
Pensez-vous que lundi on aura des tests?
A+
n°8239812
wnorton
Je suis néerlandophone
Posté le 09-03-2012 à 13:40:32  profilanswer
A+
Surement qui parler de la GTX670ti  ;)
Je suis néerlandophone une fois
n°8239816
Invite_Sur​prise
Posté le 09-03-2012 à 13:42:10  profilanswer
A+
N'en tiens pas trop compte non plus, on est au stade la rumeur ...
n°8239818
Charles K
Posté le 09-03-2012 à 13:43:18  profilanswer
- Tension + basse
- Faible conso
- Faible bruit
edit :
http://tof.canardpc.com/view/b2e03 [...] 7e6cf1.jpg
edit2 :
680-> X3200~3300
(7970)-> X2700~2800
670Ti -> X2500~2600
ouai mais 680 ou 670ti alors pour ce gk104 ? il y a les 2 dans les scores
il faut comprendre :
680 = gk104 et 670ti = gk104 castré
OU
680 = gk100 et 670ti = gk104
Sinon j'aime bien ce qu'il dit ce phk   [:cerveau delight]
Message édité par Charles K le 09-03-2012 à 13:44:38
n°8239821
aliss
Rhyme the Rhyme Well
Posté le 09-03-2012 à 13:44:29  profilanswer
Si ça s'avère exact, ceux qui attendaient une carte à 300 euros peuvent prévoir de doubler leur budget... :D
n°8239822
wnorton
Posté le 09-03-2012 à 13:46:56  profilanswer
Ben la sortie des GTX600 se prépare côté L.D.L.C il ne reste plus qu'une GTX580 en stock. :pt1cable:
Marc doit surement savoir 2 à 3 petit chose  :heink:
Message édité par wnorton le 09-03-2012 à 13:47:17
n°8239835
dav38620
Posté le 09-03-2012 à 14:05:25  profilanswer
n°8239837
wnorton
Posté le 09-03-2012 à 14:07:24  profilanswer
Pour le prix
Code :
  1. At CeBIT, world’s largest computer expo in the world (as opposed to CES, which is consumer electronics), details of the first Kepler-powered Nvidia graphics card, the GeForce GTX 680, have leaked out. It is expected to launch by the end of March and will probably cost upwards of $500.
n°8239843
wnorton
Posté le 09-03-2012 à 14:12:49  profilanswer
une photo de la GTX680
http://t1.gstatic.com/images?q=tbn:ANd9GcRLbhJxtpjSn1J4RFaBLYi8-_OkNX374XssN70znWb1oIIHvSjo-w
n°8239845
kriechbaum
Posté le 09-03-2012 à 14:14:52  profilanswer
vu que les cartes se montrent doucement, on va pouvoir avoir des infos plus fiables à présent !!
miam  miam !  si ça depote, je prend un bon SLi de deux 680,  pour avoir la paix 3-4 ans  :p
n°8239849
Invite_Sur​prise
Posté le 09-03-2012 à 14:18:11  profilanswer
n°8239851
wnorton
Posté le 09-03-2012 à 14:20:26  profilanswer
Un lien ? C'est possible ?
la voici en plus grande avec le lien
http://i42.servimg.com/u/f42/16/92/14/13/gtx68010.jpg
le lien http://diybbs.zol.com.cn/tips/show [...] id=5427318
n°8239855
Invite_Sur​prise
Posté le 09-03-2012 à 14:22:10  profilanswer
Le vieux toshop à 2 francs ...  [:power600]
Ah parce que y' en avait qui pensait que NV allait sortir un GTX 680 à 300€ ?  [:fromturkey:4]
Message édité par Invite_Surprise le 09-03-2012 à 14:25:44
n°8239859
0b1
There's good in him
Posté le 09-03-2012 à 14:24:12  profilanswer
OU
Bah ça me paraît limpide qu'nVIDIA ne fera pas qu'une seule carte avec ce GK104.
Après... GTX680, GTX670, TI, GTX666 3vilEdichön :o
Message édité par 0b1 le 09-03-2012 à 14:25:06
n°8239861
Chrismatiq​ue
Posté le 09-03-2012 à 14:27:26  profilanswer
C'est vrai qu'on dirait pas que c'est la "vrai" gtx 680, a mon avis un fake. Sinon vous avez vu cette news de generation gpu?
Quelques infos concernant la prochaine générations de cartes graphiques nVidia commence à se confirmer sur le net.
Ainsi voici donc quelques révélations :
-Certains modèles de GeForce 600 auront un Turbo Boost à la manière des CPU d'Intel permettant d'overclocker automatiquement le GPU en cas de grosses surcharges.
-Grâce à un nombre élévé  de cores CUDA Kepler sera extrèmement puissante en GPGPU.
-La GTX 680 devrait être 10% plus puissante que la HD7970 d'AMD avec le jeu Battlefield 3 mais 10%
plus faible que cette dernière sous 3D Mark 2011
-Le GK107 milieu de gamme serait lancé en Avril, quand à  la carte fondée sur 2 GK104, cette dernière devrait  être lancée en Mai.
-Le fleuron de la gamme, le GK110 possédant  2304 Cores Cuda sortira 6 mois après le lancement des premiers modèles.
http://www.generation-gpu.fr/actua [...] c16593.htm
Je pense que AMD va avoir tres mal...
n°8239863
Charles K
Posté le 09-03-2012 à 14:28:18  profilanswer
la jolie gtx 580  :whistle:
n°8239864
kriechbaum
Posté le 09-03-2012 à 14:28:26  profilanswer
on le sait déjà tout ça
n°8239865
wnorton
Posté le 09-03-2012 à 14:28:44  profilanswer
Déjà dit quelque page avant  :hello:
n°8239868
0b1
There's good in him
Posté le 09-03-2012 à 14:30:10  profilanswer
Déjà vu.
En revanche, les pilotes ont déjà l'air de modifier les % annoncés entre GTX680 et HD7970 :jap:
n°8239870
Chrismatiq​ue
Posté le 09-03-2012 à 14:31:03  profilanswer
Oups désolé, comme la news daté d'aujourd hui j'ai cru qu'elle n'avait pas encore ete revelé, désolé...
n°8239871
wnorton
Posté le 09-03-2012 à 14:31:16  profilanswer
0b1 a écrit :
Déjà vu.
Oui, moi je dit vide le mois Avril pour le stock
n°8239888
Fouge
Posté le 09-03-2012 à 14:37:54  profilanswer
Un GK104/GTX660Ti ça aurait pu :o
n°8239891
0b1
There's good in him
Posté le 09-03-2012 à 14:40:29  profilanswer
Du coup, ta fameuse guerre des prix tu vas pouvoir t'assoir dessus, comme d'habitude :D
Concours Nvidia / questions sur les... questionsCartes Mères Z68 GIGABYTE, laquelle choisir ?
Panneau de configuration NVIDIA ?[HFR] Actu : 5 cartes A75 FM1 pour ASRock
Probleme aprés installation carte NVIDIA GEFORCE 8400 GS[HFR] Actu : Nvidia lance les GTX 580M et 570M
[HFR] Actu : 4 cartes Socket FM1 pour Gigabyte[Topic Unique] Problème pour mettre à jour sa carte réseau
Gestion des ventilateurs 3 pins avec les cartes mères P67Configuration MCP73VE NVIDIA MCP73
Plus de sujets relatifs à : [Topic Unique] NVIDIA GeForce GTX 660Ti/670/680/690/760/770 (GK104)
