9077 connectés
 Page :   1  2  3  4  5  ..  1145  1146  1147  ..  1169  1170  1171  1172  1173  1174
[topick unique] Nikon D50
n°3248299
the bulleu​r
Born to be alive ☺☺☺
Posté le 22-06-2009 à 21:53:24  profilanswer
mamankangourou a écrit :
pas de photos sur cette page ?????
Ben si tu veux, prem' tof postée içi le 18/05/2006, je venais d'acquerir mon D50:
http://img504.imageshack.us/img504/950/dsc00058yx.jpg
Exifs:
[Image]
Make = NIKON CORPORATION
Model = NIKON D50
Orientation = top/left
X Resolution = 300
Y Resolution = 300
Resolution Unit = inch
Software = Ver.1.00
Date Time = 2006-05-18 14:06:22
YCbCr Positioning = co-sited
Exif IFD Pointer = Offset: 216
[Camera]
Exposure Time = 1/320"
F Number = F8
Exposure Program = Not defined
Exif Version = Version 2.21
Date Time Original = 2006-05-18 14:06:22
Date Time Digitized = 2006-05-18 14:06:22
Components Configuration = YCbcr
Compressed Bits Per Pixel = 2
Exposure Bias Value = ±0EV
Max Aperture Value = F5.66
Metering Mode = Pattern
Light Source = unknown
Flash = Off
Focal Length = 55mm
Maker Note = 30834 Byte
User Comment =
Subsec Time = 0.70"
Subsec Time Original = 0.70"
Subsec Time Digitized = 0.70"
Flashpix Version = Version 1.0
Color Space = sRGB
Exif Image Width = 752
Exif Image Height = 500
Interoperability IFD Pointer = Offset: 31674
Sensing Method = One-chip color area sensor
File Source = DSC
Scene Type = A directly photographed image
CFA Pattern = [B,G],
[G,R]
Custom Rendered = Normal process
Exposure Mode = Auto exposure
White Balance = Auto white balance
Digital Zoom Ratio = 1x
Focal Length In 35mm Film = 82mm
Scene Capture Type = Normal
Gain Control = None
Contrast = Normal
Saturation = Normal
Sharpness = Normal
Subject Distance Range = unknown
[Interoperability]
Interoperability Index = ExifR98
Interoperability Version = Version 1.0
[Thumbnail Info]
Compression = JPEG Compressed (Thumbnail)
X Resolution = 300
Y Resolution = 300
JPEG Interchange Format = Offset: 31812
JPEG Interchange Format Length = Length: 8896
[Thumbnail]
Thumbnail = 160 x 120
[MakerNote (Nikon)]
Makernote Version = 0210
ISO Speed Used = 200
Quality = NORMAL
White Balance = AUTO
Sharpening = AUTO
Focus Mode = AF-A
Flash Setting = NORMAL
Auto Flash Mode =
White Balance Bias Value = 0
000D = 00, 01, 06, 00
Exposure Diff = 00, 01, 0C, 00
ThumbOffset = 1662
Flash Compensation = 00, 01, 06, 00
ISO Speed Requested = 200
Photo corner coordinates = 0, 0, 3008, 2000
0017 = 00, 01, 06, 00
Flash Bracket Compensation Applied = 00, 01, 06, 00
AE Bracket Compensation Applied = 0EV
001D = D50
Tone Compensation (Contrast) = AUTO
Lens Type = Nikon D series Lens
Lens Min/Max Focal Length, Max Aperture = 180/10, 550/10, 35/10, 56/10
Flash Used = Flash Not Used
Auto Focus Area = 00, 00, 00, 01
Bracketing & Shooting Mode = 32
008A = 0
008B = 40, 01, 0C, 00
Colour Mode = MODE3a
Lighting Type = NATURAL
Total Number of Shutter Releases for Camera = 5
Image optimisation =
Saturation = NORMAL
Digital Vari-Program = CLOSE UP
Message édité par the bulleur le 22-06-2009 à 21:56:50
http://www.flickr.com/photos/88605
n°3248308
jeremie59
Posté le 22-06-2009 à 21:55:47  profilanswer
photofan a écrit :
faut acheter des sensor swabs ou alors le faire nettoyer chez un photographe
oué mais je trouve ca ou ? Moi fainéant, moi pas envie chercher  :)
n°3248314
the bulleu​r
Posté le 22-06-2009 à 22:00:42  profilanswer
Chez Magma par ex: http://www.magma.fr/?module=boutiq [...] b45e7457f7
http://hfr-rehost.net/preview/www.magma.fr/images/products/1007751/1007751_zo.jpg
Où tappe gaugueule où encore va dans un magasin foto (Phox par ex)
Edit>> autre marque (moins chére) de sensor swab, pas testé: http://www.magma.fr/?module=boutiq [...] id=1009294
http://hfr-rehost.net/preview/www.magma.fr/images/products/1009294/1009294_zo.jpg
Message édité par the bulleur le 22-06-2009 à 22:04:38
n°3248552
jeremie59
Posté le 23-06-2009 à 00:58:43  profilanswer
http://hfr-rehost.net/preview/http [...] 751_zo.jpg
http://hfr-rehost.net/preview/http [...] 294_zo.jpg
Merci The Bulleur, c'est de la boulette ! :jap:
n°3248804
the bulleu​r
Posté le 23-06-2009 à 10:12:31  profilanswer
De rien, j'aique ça à faire! :D  Perso je nettoye le capteur une foi par an, et si quelques poussiéres j'evite de toffer le ciel...
n°3248849
Soft'M1
Posté le 23-06-2009 à 11:02:20  profilanswer
                                   BIG BROTHER IS WATCHING YOU
http://img395.imageshack.us/img395/4137/ladfense010red.jpg
n°3248882
Soft'M1
Posté le 23-06-2009 à 11:25:08  profilanswer
:hello: je viens faire mon petit tour
tu veux pas essayer un petit recadrage en coupant les immeubles noirs en bas à droite pour faire ressortir l'arche et les belles couleurs ...
parce qu'ils me choquent ces immeubles, c'est dommage
les voilà, les immeubles noirs dont tu parlais,
moi, je les aime bien
http://img523.imageshack.us/img523/6531/ladefense36776red312pic.jpg
n°3249169
photofan
Posté le 23-06-2009 à 14:39:37  profilanswer
http://img395.imageshack.us/img395 [...] 010red.jpg
très réussie la pub pour casto!  :o
n°3249173
photofan
Posté le 23-06-2009 à 14:40:13  profilanswer
http://img523.imageshack.us/img523 [...] 312pic.jpg
c'est mieux!  :o
n°3249176
photofan
Posté le 23-06-2009 à 14:41:02  profilanswer
bon peut-être que je posterai ce soir une ou 2 photos de Grèce si vous êtes sages!  :o
Message édité par photofan le 23-06-2009 à 14:41:29
n°3249279
Soft'M1
Posté le 23-06-2009 à 15:35:08  profilanswer
c'est parti  :bounce:
http://img188.imageshack.us/img188/2154/grece2.jpg
http://img241.imageshack.us/img241/6004/grece8.jpg
je fais comme the bulleur, je ressers les vieux plats   [:aloy]
n°3249380
photofan
Posté le 23-06-2009 à 16:45:22  profilanswer
c'est très beau mais spabien de ressortir de vieilles photos!   :o
n°3249582
Soft'M1
Posté le 23-06-2009 à 18:01:49  profilanswer
c'est pour se remettre dans l'ambiance avant tes photos  :)
je fais la 1ère partie quoi !
t'es allé où d'ailleurs ?
non pas là (surtout chez les grecs)
n°3249782
photofan
Posté le 23-06-2009 à 20:36:07  profilanswer
oui ho c'est la grèce...
pas l'islande!  :cry:
n°3249818
photofan
Posté le 23-06-2009 à 20:51:51  profilanswer
n°3250597
Soft'M1
Posté le 24-06-2009 à 10:33:39  profilanswer
on n'a pas dû etre assez sages, on n'a pas eu droit à la 2ème  :o
n°3250714
photofan
Posté le 24-06-2009 à 12:06:04  profilanswer
j'ai eu la flemme lol
en même temps j'en ai pas fait des masses...
n°3250832
Soft'M1
Posté le 24-06-2009 à 13:37:30  profilanswer
ok, alors on va parler de celle-là
d'abord, j'ai comme un doute sur l'heure indiquée sur les exifs  :heink:
(on a plutôt l'impression qu'elle a été prise entre 10h et 16h)
ensuite, je trouve dommage que le 1er plan prenne tant d'importance, il est plutôt secos et sans intérêt, alors qu'au fond ça a l'air bien plus beau (les vignes et les collines sont top)
enfin, malgré le format kinopanorama, la photo n'est toujours pas fermée sur les côtés, ce qui ne serait pas génant s'il n'y avait justement ce 1er plan
bref, on te sent mieux en Islande  :D
n°3250884
photofan
Posté le 24-06-2009 à 14:33:41  profilanswer
alors les exifs déjà je savais même pas qu'il y en avait vu que c'est un assemblage de photos...
la photo a été prise vers 17h00 je dirais de mémoire
et tu as raison ça aurait été plus sympa avec l'eau au premier plan
et d'une façon générale j'ai pas forcément recherché le meilleure cadrage c'est pour ça que j'ai pa trop de photos à montrer
c'est super sec comme pays, la lumière de juin est abominable donc bon et pas inspiré ...
Message édité par photofan le 24-06-2009 à 14:34:40
n°3250887
photofan
Posté le 24-06-2009 à 14:35:10  profilanswer
ceci dit c'est une très belle île!
n°3250907
Posté le 24-06-2009 à 15:12:21  answer
j'aime pas trop le premier plan mais sinon c est pô mal :o
n°3250922
Soft'M1
Posté le 24-06-2009 à 15:32:33  profilanswer
on est d'accord  :o
n°3250947
photofan
Posté le 24-06-2009 à 16:00:00  profilanswer
:kaola:   :D
n°3252642
the bulleu​r
Posté le 25-06-2009 à 20:42:29  profilanswer
Vite faite taleur:
http://www.izipik.com/images/200906/25/m0ocl5iduk0ihgb8hk-bubulles.jpg
[Image]
Exifs paske mossieur izipik fait chier:
Model = NIKON D50
Orientation = left/bottom
X Resolution = 300
Y Resolution = 300
Software = Ver.1.00
Date Time = 2009-06-25 17:37:30
[Camera]
Exposure Time = 1/500"
F Number = F4
Exposure Program = Aperture priority
Date Time Original = 2009-06-25 17:37:30
Date Time Digitized = 2009-06-25 17:37:30
Compressed Bits Per Pixel = 4
Exposure Bias Value = -0.33EV
Max Aperture Value = F4
Flash = Off
Focal Length = 70mm
Maker Note = 27680 Byte
User Comment =
Subsec Time = 0.90"
Subsec Time Original = 0.90"
Subsec Time Digitized = 0.90"
Color Space = sRGB
Exif Image Width = 3008
Exif Image Height = 2000
Interoperability IFD Pointer = Offset: 28520
File Source = DSC
[G,R]
Focal Length In 35mm Film = 105mm
Gain Control = None
Contrast = Normal
Saturation = Normal
Sharpness = Normal
[Interoperability]
[Thumbnail Info]
X Resolution = 300
Y Resolution = 300
JPEG Interchange Format = Offset: 28660
JPEG Interchange Format Length = Length: 8927
[Thumbnail]
[MakerNote (Nikon)]
ISO Speed Used = 400
Quality = FINE
Sharpening = AUTO
Focus Mode = AF-S
Auto Flash Mode =
ThumbOffset = 1662
ISO Speed Requested = 400
001D = D50
Lens Type = 2
Lens Min/Max Focal Length, Max Aperture = 700/10, 3000/10, 40/10, 56/10
Auto Focus Area = 01, 00, 00, 01
Bracketing & Shooting Mode = 0
008A = 0
008B = 3C, 01, 0C, 00
Total Number of Shutter Releases for Camera = 15742
00A8 = 30, 31, 30, 30, 00, 48, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00
Image optimisation = NORMAL
Saturation = NORMAL
Message édité par the bulleur le 25-06-2009 à 20:50:43
n°3252664
fabrice261​0
Posté le 25-06-2009 à 20:51:22  profilanswer
:hello: le monde
dites, vous pensez quoi de ce grip: http://cgi.ebay.fr/LCD-Battery-Gri [...] 1|294%3A30
merci :)
n°3252669
the bulleu​r
Posté le 25-06-2009 à 20:55:15  profilanswer
Chero je trouve par rapport au prix du boitier d'occaze...
n°3252672
fabrice261​0
Posté le 25-06-2009 à 20:56:37  profilanswer
ben le boitier je l'ai déjà :jap:
le truc que je comprends pas trop c'est que c'est la seule boutique ou j'ai trouvé un grip pour D50 avec déclencheur  [:axlrose]
n°3252680
the bulleu​r
Posté le 25-06-2009 à 21:04:21  profilanswer
Ca a l'air de marcher par la diode infrarouge pour la telecommande avec une autre diode extractible dans cte grip, bizzare que c'est la seule boutique oui, ya eu un autre grip ya quelques année en vente sur EB et c'etait de la merde d'aprés pas mal d'avis.
n°3252804
photofan
Posté le 25-06-2009 à 22:27:08  profilanswer
Vite faite taleur:
http://www.izipik.com/images/20090 [...] bulles.jpg
[Image]
bla bla
bla bla
bla bla
bla bla
bla bla
bla bla
bla bla
bla bla
c'est vraiment obligé les exifs?  :o
n°3256983
Soft'M1
Posté le 29-06-2009 à 11:45:14  profilanswer
  Claire
http://img8.imageshack.us/img8/8510/claire36901picadaptmod.jpg
sans exifs
n°3258392
Soft'M1
Posté le 30-06-2009 à 08:57:24  profilanswer
du blé ... et du flood
http://img514.imageshack.us/img514/8541/blesvexin36931picred.jpg
http://img141.imageshack.us/img141/6321/blesduvexin030red.jpg
http://img4.imageshack.us/img4/4633/blesduvexin042red.jpg
http://img5.imageshack.us/img5/9585/blesvexin37215picred.jpg
 [:chadouw]
Message édité par Soft'M1 le 30-06-2009 à 19:34:03
n°3258585
babylone83
Corse :o
Posté le 30-06-2009 à 11:11:58  profilanswer
pas mal la mioche :)
juste une tite critique le fond est légèrement parasité par les objets qui y sont
n°3258748
Soft'M1
Posté le 30-06-2009 à 13:06:01  profilanswer
merci baby  :jap:
Au départ, le fond avait son importance :c'’est un lit à barreaux, ou plutôt son évocation qu’on devait apercevoir
Mais la photo, prise dans de très mauvaises conditions, ne donnait rien
Je la montre en vignette
http://img269.imageshack.us/img269/5898/claire36861adaptmodred3.jpg
après j’ai voulu la refaire, mais c’est difficile de diriger une pépette de 2 ans !
n°3258755
babylone83
Corse :o
Posté le 30-06-2009 à 13:09:17  profilanswer
ouais l'idée est bonne mais sur la première c'est pas bon :/
n°3258760
the bulleu​r
Posté le 30-06-2009 à 13:12:18  profilanswer
Soft'M1 a écrit :
merci baby  :jap:
http://img269.imageshack.us/img269 [...] odred3.jpg
Martine va au chiotes...  :whistle:
n°3258762
Soft'M1
Posté le 30-06-2009 à 13:13:25  profilanswer
elle court jamais où on lui dit  :o
je me demande si je vais pas la revendre [:blinkgt]
n°3258766
Soft'M1
Posté le 30-06-2009 à 13:14:58  profilanswer
t'as des chiottes à barreaux chez toi ? [:blinkgt]
n°3258776
babylone83
Corse :o
Posté le 30-06-2009 à 13:20:14  profilanswer
j'ai toujours su que the bulleur etait zarb :o
n°3259498
le pox
Posté le 30-06-2009 à 21:16:33  profilanswer
J'ai un Nikon D50 depuis 3 ans (plus de garantie ! !) et j'ai un problème: quand je prends une photo, il n'y a pas de déclenchement (le miroir ne bouge pas) et l'affichage écrit "ERR". Quand je reprends une photo, le miroir fait deux aller retour (un très rapide et l'autre à la vitesse demandée). De plus, la photo ne s'enregistre pas. Savez vous ce que c'est et si c'est réparable à un prix raisonnable ou est ce que je dois suivre les conseils du photographe en bas de chez moi qui me conseille d'acheter un autre pour a peine plus cher que ce que pourrait couter la réparation (sachant qu'il n'a aucune idée de ce que peut être cette panne).
D'avance merci de me répondre
n°3259534
the bulleu​r
Posté le 30-06-2009 à 21:36:54  profilanswer
Prie papa nowel de t'aporter un D700  :whistle:
Message édité par the bulleur le 30-06-2009 à 21:37:14
n°3259548
photofan
Posté le 30-06-2009 à 21:44:20  profilanswer
ça risque de venir de l'obturateur à remplacer... tu as fait beaucoup de déclenchements avec ton D50?
[topick unique] D70 szoom nikon 35/80
[Topic unique] Canon Ixus 700recherche dobjectif pour nikon d 70
Mode vidéo avec le Nikon Coolpix 5200[Topic unique] Canon Ixus 50
Nikon D70 vs Pentax *ist DSNikon F75 etc - débutante recherche conseils avt achat...
[Topic Unique] KONICA-MINOLTA Dimage X50
Plus de sujets relatifs à : [topick unique] Nikon D50
