6922 connectés
 Page :   1  2  3  4  5  ..  732  733  734  ..  2952  2953  2954  2955  2956  2957
### [Matos] - News - Spéculations et même des vertes et des pas mûres
n°2832555
lionoche
Posté le 30-09-2008 à 15:03:35  profilanswer
The Pentax K20D and the Pentax K200D both use a new metering system which allows their CMOS sensors to take simultaneous readings of both highlight and shadow areas.
The user then simply needs to access the camera's HDR mode through the menu dial, set the camera up for the first shot, press the shutter, and off it goes. The internal sensors will then take three shots and combine them into a single HDR image.
How it works
Firstly, the standard correct exposure photograph is metered and exposed. The onboard sensors then independently calculate an overexposed image and an underexposed image.
Within seconds, the K20D and the K200D will have taken three separate photographs and will begin the process of merging them into a single HDR image. Control is limited as the only control the user has over the process is to decide whether the camera will expose the over and underexposed images at one or two stops above or below correct exposure.
Once all three photos are taken, the contrasting areas of the images are compared, balanced and combined into a single picture which displays a broader dynamic range than a conventional photograph, allowing for more evenly exposed images and a more natural look. With LiveView, the results can be instantly previewed, and the process repeated if necessary.
Faut sortir du grand beau sac hein, de temps en temps  ;)
http://www.flickr.com/lionoche
n°2832561
Megalyth
no way
Posté le 30-09-2008 à 15:04:59  profilanswer
raoul_volfoni a écrit :
... le Raoul au méga' 7000D (livré en kit avec un 18-55mm f:7,3-11 non stabilisé)
Ah mais j'en veux pas mwa ! :o
√ ... √ Feedb4ck
n°2832562
raoul_volf​oni
Klaatu Barada Nikto
Posté le 30-09-2008 à 15:05:13  profilanswer
alainphoto a écrit :
Et gratuite. (Non moi, je ferai payer ça très cher - Canon staïle)
Et rétroactive par firmware. (oui, aussi)
Et n'impose pas de délai supplémentaire avant de déclencher. (oui, pareil)
Et est largement configurable. (pareil, mais encore mieux)
I win  [:hahaguy] Non.
En 2034, tout le monde fera de la vidéo 3D en HDR  [:vapeur_cochonne]  Et en 2035, ils se rendront compte de leur erreur et passeront tous sur mon système sans équivalent... :o
"L'homme de la pampa, parfois rude, reste toujours courtois." - GalerieHFR (dernière m.a.j : 453 av. JC)
n°2832568
raoul_volf​oni
Klaatu Barada Nikto
Posté le 30-09-2008 à 15:06:59  profilanswer
Pff... :pfff:
Décidément, tu ne veux pas te mettre à la photo.  [:sweetiiiie]
n°2832579
alainphoto
Posté le 30-09-2008 à 15:11:06  profilanswer
 [:gaga jap]
je suis battu par pentax  [:gaga cry]
Photographie du Japon
n°2832612
Posté le 30-09-2008 à 15:29:37  answer
How it works
C'est un CMOS le K200D :??:
C'est pas plutôt le vieux CCD du K10D :o ?
n°2832682
Nicky_rr
L'art est la manière
Posté le 30-09-2008 à 15:48:34  profilanswer
Si, mais ça change rien, c'est du logiciel de toute façon. Par contre il me semble que le résultat n'était pas génial avec cette fonction, peut être un problème de réglage, je ne sais pas à quel point on peut jouer dessus.
Quiconque sacrifie sa liberté pour plus de sécurité ne mérite ni l'un ni l'autre, et n'aura aucun des deux. - Sur internet si le service semble gratuit, c'est que le produit, c'est vous.
n°2832691
lionoche
Posté le 30-09-2008 à 15:50:26  profilanswer
http://apcmag.com/pentax_adds_hdr_ [...] _dslrs.htm
Ca change rien à la fonction HDR disponible...
n°2832706
Poogz
Posté le 30-09-2008 à 15:55:43  profilanswer
ça doit être l'équivalent du d lighting chez nikon ou le priorité haute lumière chez canon.
n°2832746
lionoche
Posté le 30-09-2008 à 16:11:51  profilanswer
Clairement non...
Le D-lighting, c'est une seule photo et un traitement logiciel.
Message édité par lionoche le 30-09-2008 à 16:12:04
n°2832796
Cygne_d_Et​ang
Punk's not dead
Posté le 30-09-2008 à 16:29:05  profilanswer
lionoche a écrit :
Clairement non...
ils viennent de reinventer la trichromie
henri gaud's spirit [:neffy]
Message édité par Cygne_d_Etang le 30-09-2008 à 16:29:37
n°2832834
lionoche
Posté le 30-09-2008 à 16:38:11  profilanswer
n°2832933
isofouet
Moi faut pas m'énerver
Posté le 30-09-2008 à 17:18:53  profilanswer
lionoche a écrit :
C'est un vieux hoax cette histoire d'HDR   :lol:
http://www.stevesforums.com/forums [...] orum_id=80
Tu t'es auto tacklé ?  [:pingouino dei]
L'APS-C Vaincra :o ├ Galerie ┤ ├ Rome ┤ ├ Belgique ┤
n°2832953
lionoche
Posté le 30-09-2008 à 17:28:56  profilanswer
Je ne vais pas m'en relever, adieu  :sweat:
n°2832961
isofouet
Posté le 30-09-2008 à 17:33:03  profilanswer
 [:shay]
 :whistle:
n°2832973
lionoche
Posté le 30-09-2008 à 17:38:13  profilanswer
Mais je vais acheter un D80, comme ça je ne te manquerai pas trop  :whistle:
n°2833270
isofouet
Posté le 30-09-2008 à 20:25:07  profilanswer
Tu te décides enfin à commencer la photo  [:implosion du tibia]
n°2833486
VIASAC
Le jour me nuit.
Posté le 30-09-2008 à 22:58:06  profilanswer
C'est bien ce que j'ai cru comprendre tout au long de ces pages ...: c'est la marque qui fait le photographe :lol:
L'abus de santé est dangereux pour l'alcool<Flickr>
n°2833497
Lycos5
Don't feed !
Posté le 30-09-2008 à 23:08:43  profilanswer
Ou plutot, c'est la marque, qui rate la photo pour trop de monde ici :/
FlickR | Speed matters | gtag:Arkht
n°2833545
Nivacrin
Wat ?
Posté le 01-10-2008 à 00:12:24  profilanswer
Pas du tout, regarde moi j'ai bien un Pentax, et pourtant même avec un rouge ou un jaune dans les mains, je suis une grosse merde.
n°2833721
delantera
Hail Seitan.
Posté le 01-10-2008 à 09:15:19  profilanswer
c'est pas faux [:rofl]
n°2833770
Nicky_rr
Posté le 01-10-2008 à 09:41:04  profilanswer
Ca a sans doute déjà été dit mais c'est pas grave, non c'est pas pareil, il y a aussi une option comme le Dlightning, c'est deux choses différentes.
n°2833796
lionoche
Posté le 01-10-2008 à 09:57:06  profilanswer
n°2834096
johnny-vul​ture
Wesh wesh ma poule !
Posté le 01-10-2008 à 11:39:57  profilanswer
J'ai bien peur que la photographie devient ce que l'informatique est au G33K...
Changer d'appareil comme des chaussettes mais le résultats est le même, juste d'avoir le dernier matos et de ne pas le contempler à son maximum...
n°2834108
Toxin
Carpe ★★ Vitam
Posté le 01-10-2008 à 11:42:26  profilanswer
Vu la vitesse à laquelle j'use mes chaussettes :sweat:
n°2834120
vinsurvain
Et pas la moyenne...
Posté le 01-10-2008 à 11:45:44  profilanswer
Tu vas te retrouver dans le plus simple appareil...  :sweat:
https://www.flickr.com/photos/18565691@N07/albums   HFR
n°2834129
Toxin
Carpe ★★ Vitam
Posté le 01-10-2008 à 11:48:21  profilanswer
Un pinhole :sweat:
n°2834142
raoul_volf​oni
Klaatu Barada Nikto
Posté le 01-10-2008 à 11:53:07  profilanswer
Toxin a écrit :
Un pinhole :sweat:
Fabriqué avec la chaussette (le trou est déjà là).
n°2834151
delantera
Hail Seitan.
Posté le 01-10-2008 à 11:55:05  profilanswer
mais en 4x5 :sol:
n°2834154
Cygne_d_Et​ang
Punk's not dead
Posté le 01-10-2008 à 11:55:48  profilanswer
 [:cygne_d_etang]
n°2834158
isofouet
Posté le 01-10-2008 à 11:56:30  profilanswer
n°2834167
raoul_volf​oni
Klaatu Barada Nikto
Posté le 01-10-2008 à 11:57:21  profilanswer
isofouet a écrit :
Et le boss de fin, c'est un D3 ?  [:vince_astuce]
Le code pour les cheats c'est "Canikon" (godmode...) :o
Message édité par raoul_volfoni le 01-10-2008 à 11:58:09
n°2834185
lionoche
Posté le 01-10-2008 à 11:59:59  profilanswer
 [:ddr555]
n°2834196
Posté le 01-10-2008 à 12:01:58  answer
gode-mod [:negro]
n°2834199
delantera
Hail Seitan.
Posté le 01-10-2008 à 12:03:05  profilanswer
[:rofl]
n°2834200
isofouet
Posté le 01-10-2008 à 12:03:11  profilanswer
Ca c'est leica :o
n°2834457
alainphoto
Posté le 01-10-2008 à 14:00:36  profilanswer
je l'ai vu tourner dans pas mal de magasins ici, ça m'a tout l'air d'une grosse grosse bouze, j'ai bien rigolé  :lol:
tu te balade dans une savane en 3D digne de 1999 et si tu rapporte la 'photo' (faut le dire très très vite ...) qu'il faut tu as le droit de choisir un nouveau matos, ça a l'air super naze  :lol:
si un trailer sort, mattez le :D
Message édité par alainphoto le 01-10-2008 à 14:01:01
n°2834459
Posté le 01-10-2008 à 14:02:30  answer
à la limite je préfère endless ocean sur la wii :d :D
n°2836199
Dkiller
Posté le 02-10-2008 à 07:22:08  profilanswer
http://images.quickblogcast.com/3/2/2/2/2/130718-122223/NewNikonAd.jpg
http://images.quickblogcast.com/3/2/2/2/2/130718-122223/Nikon_MX.jpg
[:chriscool007]
Si pas fake, on ne voit pas de bouton (cachés?) et viseur rikiki mais top tendance [:kbchris]
Message édité par Dkiller le 02-10-2008 à 07:25:59
n°2836252
babylone83
Corse :o
Posté le 02-10-2008 à 08:47:57  profilanswer
:love:
n°2836254
Toxin
Carpe ★★ Vitam
Posté le 02-10-2008 à 08:49:23  profilanswer
Viseur riquiki ? Un beau viseur rond comme ça, ça laisse présager d'un beau joujou :o
Plus de sujets relatifs à : ### [Matos] - News - Spéculations et même des vertes et des pas mûres
