3401 connectés
 Page :   1  2  3  4  5  ..  12  13  14  ..  20  21  22  23  24  25
*Topic officiel Epox 8K3A à la 8RGA+*--> REVIEW BARTON 2500+ page 130
n°717303
Oxygen3
Tears from the moon
Posté le 04-02-2003 à 23:38:01  profilanswer
pgeo a écrit :
il monte a combien le agoia now ?
133x12.5 en semi passif :o
Metro-Pole ▬ Réseau A Suivre...: Annuseries|LeVillage|pErDUSA
n°717304
razorbak83
achetez pgeo en plus c'est bô
Posté le 04-02-2003 à 23:38:46  profilanswer
cpulloverclock a écrit :
4-2-2 ou 7-2-2 c pareil
hein ?
tu peux expliquer cpull ??
7=4 ?
on a pas du suivre le meme cursus scolaire :ange:  :whistle:  :lol:  :hello:
powered by 1700+ JIUHB 0251 F @ 2450 / 1.74v :ange: et rock stable !!!! :sol:
n°717305
cpulloverc​lock
Posté le 04-02-2003 à 23:38:59  profilanswer
tain faut que je pete 3200MHz en prometeia
2100+@3180
1733@3180
Nah ive not had one of the 2003 chips.
Its a 2100+ 0250XPAW AIUHB. Nice little chip on air - 2430mhz @ default volts for 3dmark, 2500mhz into windows @ default volts. Had to knock it right back to 2333 @ default volts though for stability. It seems to really like low temps, was crying out for phase change right from the start.
Anyway, details for above...
Set to 14.5 x 209 aggressive in bios. Running 1.875v - cant get it stable any higher, max I can boot into windows @ 1.875v is 3130mhz. Setting up to 2v gives another 50mhz for a max cpuid shot but doesnt help stability at all. 2.2v wont even boot . Seems to really like the lower voltage scales - it feels a lot like a C1 step northy tbh.
Absolute max (unstable) OC possible. This is the highest I could boot into 2k, and even this took 3 attempts .
http://freespace.virgin.net/matt.farmer/3180maxOC.jpg
n°717306
alanou
Remembering M.P.
Posté le 04-02-2003 à 23:39:22  profilanswer
Euh
ceux qui ont viré le jumper... c juste une impression où le SPP chauffe bcp moins jumper viré ? (et le MCP-T aussi j'ai l'impression)
Jdois me tromper, ca serait bizarre :D
n°717307
niktard
Posté le 04-02-2003 à 23:39:54  profilanswer
ah?! je vais testé ca en fin de semaine ( chiotte j'ai commencé la mod de ma tour trop tot moi ! vais devoir attendre pour vérifier ke ca marche ché moi:....10.5*200 :love: là ce serai le summum mais je pense etre limité par mon proco....1800+0.13µ0237 AO... :sweat: )
n°717308
Out4L
Posté le 04-02-2003 à 23:43:27  profilanswer
alanou a écrit :
Euh
Je l'ai viré, je vois padeu diff :/
n°717309
pierrotlem​aboule
Posté le 04-02-2003 à 23:43:37  profilanswer
bon vais tester ma pc2700 pqi chip 7ns [:ddr555]
apparement ça resolu mon pb de fsb bloque a 166  [:markdavis]
mon topic de vente
n°717320
Learn
Tigre & Dragon
Posté le 04-02-2003 à 23:51:58  profilanswer
alanou a écrit :
Euh
c'est possible.  j'ai testé mon system avec mon 'old' 1600+, à 200 de fsb synchro le north été pas très chaud(sans ventillation sur le north), je remet mon 2700+  a 200 de fsb a quelque minutes il été boulliant   bizarre
le 1600+ été a 1900mhz et le 2700+ a 2200
L'obscurité ne peut pas chasser l'obscurité ; seule la lumière le peut. La haine ne peut pas chasser la haine ; seul l'amour le peut. Martin Luther King
n°717324
pgeo
Posté le 04-02-2003 à 23:58:32  profilanswer
bin pousse le !! toi aussi tu as une revanche a prendre avant cpull :D  lui il va pas lui faire de cadeaux :sol:
n°717332
Oxygen3
Tears from the moon
Posté le 05-02-2003 à 00:09:04  profilanswer
avec un aqua690 c'est pas facile, d'autant qu'il est a paris sur mon a7n8x démodée :o
donc bon :D
n°717333
Oxygen3
Tears from the moon
Posté le 05-02-2003 à 00:09:35  profilanswer
au fait chui décu, on peut pas descendre sous les voltages d'origine sur l'a7n8x :(
n°717336
pgeo
Posté le 05-02-2003 à 00:21:46  profilanswer
2 ou trois coups de marteaux sur les fils ça devrais empêcher le courant de passer  :pt1cable:
n°717352
Oxygen3
Tears from the moon
Posté le 05-02-2003 à 00:46:39  profilanswer
oué mais bon c'est le bios qui est pas complet c'est reloo :(
n°717354
pierrotlem​aboule
Posté le 05-02-2003 à 00:49:43  profilanswer
cai bizarre a 12.5*180 je ne fait q 199 a cpumark :heink:  :??:
mon topic de vente
n°717357
Oxygen3
Tears from the moon
Posté le 05-02-2003 à 00:51:20  profilanswer
215 a cette freq [:totoz]
n°717361
pierrotlem​aboule
Posté le 05-02-2003 à 00:58:45  profilanswer
cai l'effet win2k ou je reves :heink:
mon topic de vente
n°717362
Oxygen3
Tears from the moon
Posté le 05-02-2003 à 00:59:42  profilanswer
vérifie tes services en fond tache ...
(je fais 196 à 12.5x166 en dual ... donc y'a un gros blem)
n°717363
pierrotlem​aboule
Posté le 05-02-2003 à 01:00:44  profilanswer
rien en fond de tache niet
je rebbot pr voir :heink:
mon topic de vente
n°717368
pierrotlem​aboule
Posté le 05-02-2003 à 01:45:37  profilanswer
bon tj des perf de merde :fou:  [:markdavis]
mon topic de vente
n°717378
dd83
Posté le 05-02-2003 à 03:37:27  profilanswer
Bon bah moi j'ai enfin résolu mes problèmes de son avec mon Audigy -> je l'ai viré...mais bon ca me fait bien chier, je sais pas quoi en faire :(
Et maintenant que j'utilise le Soundstorm pour le son j'arrive à monter plus haut en FSB, 100% stable à 219x11= 2409Mhz à 1.85V avec Vdd à 1.9V :love:
Mais bon 1.9V j'aime pas trop alors je reste à 1.8V avec 209 de FSB ;)
Sniff...je l'aimais bien moi cette Audigy :sweat:  mais impossible de la faire marcher correctement avec mes 2 8RDA+ (rev 1.0 et 1.1) :heink:
Message édité par dd83 le 05-02-2003 à 04:22:59
Carpe Diem. Enjoy the present as if everyday was a gift...
n°717384
alanou
Remembering M.P.
Posté le 05-02-2003 à 06:04:00  profilanswer
Bon résultat du burn cette nuit -> 9867 fichiers Filexxxx.chk :D
Ct ptet pas très stable :D :lol:
n°717388
jojo61
CS si tu dors t'es mort !
Posté le 05-02-2003 à 07:10:53  profilanswer
alors le jumper deplacé ca a apporté quelque chose ?
Jojo61 R.I.P. 20.02.2003
n°717406
pgeo
Posté le 05-02-2003 à 08:25:55  profilanswer
ton win va etre tres light à force de perdre des fichiers  :D
n°717408
alanou
Remembering M.P.
Posté le 05-02-2003 à 08:26:51  profilanswer
J'ai paumé mes mails  [:totoz]
n°717419
Oxygen3
Tears from the moon
Posté le 05-02-2003 à 09:24:08  profilanswer
j'ai fait le compte, mon inbox globale a 12500 mails [:totoz]
n°717542
nounourse
la peur n'efface pas le danger
Posté le 05-02-2003 à 13:32:49  profilanswer
mon assembleur peut encore avoir des epox 8K3A+,je sent que je vais m'en reprendre une autre si ma nforce2(chaintech) me fait trop galérer :pt1cable:  :pt1cable: comme 80% des mobo nforce en ce moment,j'ai l'impression que l'on essuie les platres :pfff:
n°717556
razorbak83
Posté le 05-02-2003 à 14:04:35  profilanswer
j'ai un truc space, ma ram passe pas au dessus de 175 cas 2 et 180 cas2.5 je crois (elle aimerai plus de voltage à mon avis :cry: )
donc je ma suis dit je vais la desynchro et pousser le fsb à 200...
et ben qd je met la ram à 83% du fsb, ça boot po, 80% idem, à 75% ça marche, enfin pour l'instant :heink:
c pareil chez vous ?
n°717577
razorbak83
Posté le 05-02-2003 à 14:29:03  profilanswer
bon je viens de faire un test :
fsb de 190
ram desynchro à 75% du fsb : donc 143 mhz
ben j'ai la meme chose que qd la ram est à 190 ... :heink:
en gros j'ai l'impression que leur systeme de desynchro fonctionne po :heink:
n°717656
dd83
Posté le 05-02-2003 à 16:07:36  profilanswer
C'est normal, certaines fréquences de désynchro semblent en effet ne pas fonctionner :(
n°717677
bibouovni
Posté le 05-02-2003 à 16:32:28  profilanswer
en rajoutant 1 rad et 2 ventillo
je suis passé de 195 à 205 stable sur la rda+
207/208 je perd le son en 15 mn
à partir de 208 j ai des freezes aléatoires :fou:
à 212 ca part en couilles les deux pieds en avant! :na:
va falloir moder le vdd ou un nouveau bios! :kaola:
[:bibouovni]
n°717730
pierrotlem​aboule
Posté le 05-02-2003 à 17:32:43  profilanswer
moi j'ai un pb
a plus de 166 de fsb les perf baissent :heink:
sinon a 12.5*166 j'ai des perf po terrible...a peine 191 a cpumark :/
mon topic de vente
n°717733
cpulloverc​lock
Posté le 05-02-2003 à 17:34:29  profilanswer
moi j'ai un pb
ben fsb assez faible aussi
t en agressif 4-2-2 cas2?
dual ddr?
n°717770
kyky
Je suis newbie et alors,
Posté le 05-02-2003 à 18:27:02  profilanswer
http://www.vtr-hardware.com/images/auto/2626.jpg
tien ils ont encore modifie les mofsets sur la nouvelle 8RGA+  :pt1cable:
le progrès ne vaut que s'il est partage par tous.Ce que je vends
n°717778
rom_neo
Posté le 05-02-2003 à 18:33:01  profilanswer
qu'es qu'ils on les mosfet ?
n°717781
alanou
Remembering M.P.
Posté le 05-02-2003 à 18:33:53  profilanswer
à mon avis, c pa la carte finale ;)
n°717797
rom_neo
Posté le 05-02-2003 à 18:43:27  profilanswer
c une 8DRA+ qui a pris un coup de photoshop ca non ??? ( qils ont quoi de particulier les mosfet ??? )
n°717837
razorbak83
Posté le 05-02-2003 à 19:11:40  profilanswer
nop ya rien qui fonctionne avec le desynchro plutot :lol:
n°717843
kyky
Posté le 05-02-2003 à 19:23:54  profilanswer
et pourkoi  :heink: , ils se sont aperçu que les anciens mofsets chauffaient trop donc ils l'ont change, il ressenble a ceux utilise par abit (sur les nf7)
n°717847
kyky
Posté le 05-02-2003 à 19:25:30  profilanswer
nan c'est une 8RGA+ (nForce2 IGP (core graphique du Geforce4 MX) et du MCP-T,)
n°717848
Learn
Tigre & Dragon
Posté le 05-02-2003 à 19:25:56  profilanswer
c'est une version 0.1  ça sera une version 1.0 ds ls commerce (je suppose)
n°717851
rom_neo
Posté le 05-02-2003 à 19:27:47  profilanswer
Il semble petit c ca ? e tout cas il resemble a ceux de ma 8rda+
Diviseur 1/6 et Epox 8KA3+[Topic Officiel] - Le Boîtier ICARICIO IC 111F (full tower)
*Topic officiel Epox 8K3A à la 8RDA+*-->bios 3129 8RDA+[topic officiel ] Fanbus/ Rhéobus....
Probleme de Ram su epox 8k5a2Débrider une Radeon 9500 -> Teste Effectué page 3 par [Dma]JF
Epox 8K3A + Corsair 3500 = plantage avec 175mhz de FSB !!! help....
Plus de sujets relatifs à : *Topic officiel Epox 8K3A à la 8RGA+*--> REVIEW BARTON 2500+ page 130
