4741 connectés
Sujet(s) à lire :
    - Driver NVidia sous Mandrake 10.1
 Page :   1  2  3  4  5  6  7
Installation drivers Nvidia : 6111 à 7167 sous Mdk 10.1 et ultérieur
n°582256
bricezenic​e
Posté le 29-10-2004 à 18:06:18  profilanswer
voila ce que j'ai quand j'applique la premiere page !
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Fri Oct 29 18:08:24 2004
option status:
  license pre-accepted    : true
  update                  : false
  force update            : false
  expert                  : false
  uninstall               : false
  driver info             : false
  no precompiled interface: false
  no ncurses color        : false
  query latest driver ver : false
  OpenGL header files     : false
  no questions            : false
  silent                  : false
  X install prefix        : /usr/X11R6
  OpenGL install prefix   : /usr
  Installer install prefix: /usr
  kernel source path      : (not specified)
  kernel install path     : (not specified)
  proc mount point        : /proc
  ui                      : (not specified)
  tmpdir                  : /root/tmp
  ftp site                : ftp://download.nvidia.com
Using: nvidia-installer ncurses user interface
-> License accepted by command line option.
-> No precompiled kernel interface was found to match your kernel; would you li
   ke the installer to attempt to download a kernel interface for your kernel f
   rom the NVIDIA ftp site (ftp://download.nvidia.com)? (Answer: Yes)
-> No matching precompiled kernel interface was found on the NVIDIA ftp site;
   this means that the installer will need to compile a kernel interface for
   your kernel.
-> Kernel source path: '/usr/src/linux'
-> Performing cc_version_check with CC="cc".
-> Performing rivafb check.
-> Performing rivafb module check.
WARNING: Your kernel was configured to include rivafb support as
         a loadable kernel module.
         The rivafb driver conflicts with the NVIDIA driver; the
         NVIDIA kernel module will still be built and installed,
         but be aware that the NVIDIA driver will not be able to
         function properly if the rivafb module is loaded!
ERROR: Unable to determine the NVIDIA kernel module filename.
ERROR: Installation has failed.
n°582257
lenainquit​ue
Posté le 29-10-2004 à 18:11:42  profilanswer
T'énerves pas va, tu as déjà posté ton log, alors attends, sois patient. N'insiste pas comme ça car c'est relativement lourd.
Les gars qui nous aide le font très sympathiquement mais ils ont une vie aussi à côté, ne l'oublie pas  ;)
n°582259
bricezenic​e
Posté le 29-10-2004 à 18:15:52  profilanswer
Quelqu'un peut expliquer comment on fait pour mettre à jour le noyau et les sources ! I am a newbie !
n°582262
lenainquit​ue
Posté le 29-10-2004 à 18:22:56  profilanswer
1. il fallait être root pour faire les commande que je t'ai demandé
Ok, j'ai tapé en root celles qui ne fonctionnaient pas en utilisateur normal.
2. il faut mettre dans /etc/modprobe.conf
alias /dev/nvidia* nvidia
et non "alias char-major-195* nvidia"
J'ai jamais mis ça moi  :heink: D'ailleurs, je ne savais pas qu'il fallait mettre qquechose dans le /etc/modprobe.conf
3. le module nvidia n'a pas été compilé vue qu'il n'est pas listé par le noyau
Hmm, pourtant il m'a dis que l'installation s'est faite avec succès. Je n'y connais rien, donc je dis certainement une erreur mais, est-ce qu'il n'apparait pas à cause du fait que j'ai remis les fichiers xorg.conf et modprobe.preload à leur état initial ? Dois-je réinstaller les drivers par "./nvidia-installer --kernel-name 2.6.8.1.10mdk" comme je l'ai fait la première fois ? Mon kernel source n'a pas l'air d'être le bon d'ailleurs en passant, ça vient peut être de là :
Code :
  1. [root@localhost stephane]# rpm -qa | grep kernel-source
  2. kernel-source-2.4.27-0.pre2.1mdk
  3. [root@localhost stephane]# uname -r
  4. 2.6.8.1-12mdk
4. il faut mettre [g]nvidia[/g] dans /etc/modprobe.preload
Oui je l'ai mis, je t'ai dit que je l'avais retiré pour pouvoir revenir à l'interface graphique car cela ne fonctionnait pas.
Message édité par lenainquitue le 29-10-2004 à 18:24:20
n°582263
lenainquit​ue
Posté le 29-10-2004 à 18:23:46  profilanswer
Tout est dit dans les premières pages car j'ai eu le même problème. Relis le topic, tout est dessus.
n°582266
Dark_Schne​ider
Close the World, Open the Net
Posté le 29-10-2004 à 18:28:56  profilanswer
Lenainquitue> tu as les sources pour un noyau 2.4.27 alors que tu as un noyau 2.6.8.1-12mdk
lis mon howto sur l'install des pilotes nvidia et ajoute juste la partie sur le patchage :
http://www.linux-wizard.net/howto. [...] _article=3
Mandriva : parce que nous le valons bien ! http://linux-wizard.net/index.php
n°582267
Mjules
Parle dans le vide
Posté le 29-10-2004 à 18:29:19  profilanswer
vérifie que les sources sont bien installés dans /usr/src
ensuite essayes de recompiler en adaptant la ligne à ton nouveau noyau ;) :
./nvidia-installer --kernel-name 2.6.8.1-12mdk
voire même sans définir le noyau
Celui qui pose une question est idiot 5 minutes. Celui qui n'en pose pas le reste toute sa vie. |  Membre du grand complot pharmaceutico-médico-scientifico-judéo-maçonnique.
n°582280
bricezenic​e
Posté le 29-10-2004 à 19:01:26  profilanswer
Je v craquer ! Je suis a deux doigts de retourner sous windows !!
kernel-source-2.6-2.6.8.1-12mdk
uname -r
2.6.8.1-10mdk
urpmi -p kernel
Tout est déjà installé
n°582284
Dark_Schne​ider
Posté le 29-10-2004 à 19:07:34  profilanswer
urpmi kernel-2.6.8.1.12mdk
extrait de mon HOWTO :
our cela vous tapez soit :
# urpmi -p kernel
qui vous donnera une liste des noyaux disponible, ou alors pour être sûr, vous taper directement le nom entier du noyau que vous voulez :
# urpmi kernel-2.4.22-26mdk
n°582285
lenainquit​ue
Posté le 29-10-2004 à 19:07:59  profilanswer
uname -r
2.6.8.1-10mdk
urpmi -p kernel
Edit : mieux vaut suivre la méthode Dark ! :)
Message édité par lenainquitue le 29-10-2004 à 19:11:27
n°582288
lenainquit​ue
Posté le 29-10-2004 à 19:10:33  profilanswer
# urpmi -p kernel
Urpmi kernel m'a donné tous les kernels existants il me semble hier soir.
Par contre, cela n'est pas vrai pour kernel-source. En faisant urpmq kernel-soource il me répondait : "kernel-source" et en fait il m'installait n'importe lequel quand je passais par urpmi kernel-source.
Donc je suis passé par rpmdrake, et là tous mes kernel-source étaient listés.
Résultat, j'ai réinstallé tout comme j'avais fait avant et désormais ça marche !
Merci à vous tous encore une fois  :jap:
n°582293
bricezenic​e
Posté le 29-10-2004 à 19:21:13  profilanswer
Je vais passer pour un boulet !!!
-> urpmi kernel-2.6.8.1.12mdk
pas de paquetage nommé kernel-2.6.8.1.12mdk
n°582294
lenainquit​ue
Posté le 29-10-2004 à 19:25:02  profilanswer
As tu mis à jour tes sources ? Ensuite, au pire passe par rpm drake (menu étoile / ssystème / configurtation / paquetages / installer des logiciels) et tape kernel-source, tu devrais avoir le bon.
n°582298
bricezenic​e
Posté le 29-10-2004 à 19:29:11  profilanswer
Ben j'ai mis ca :
n°582301
Dark_Schne​ider
Posté le 29-10-2004 à 19:35:34  profilanswer
ftp://ftp.proxad.net/pub/Distribu [...] k.i586.rpm
n°582320
Hyatt
Posté le 29-10-2004 à 20:20:07  profilanswer
par contre petite question tout conne. Lorsque que je lance un urpmi kernel... et l'install des driver nvidia faut t'il k'il soit dans un repertoire specifique ou bien ou je veux (c con mais bon plus rien de m'ettone ^^)
 :pt1cable:
n°582326
bricezenic​e
Posté le 29-10-2004 à 20:32:15  profilanswer
Ca a l'air d'avoir marché mais je n'ai plus l'écran de démarrage ! Je boot dans la console et pas moyen de lancer l'interface !!! telinit 5 ou service dm start !
Est-ce que c'est possible de rajouter au premier message du topic comment on fait proprement pour insteller les kernel avec les liens ....
n°582334
Hyatt
Posté le 29-10-2004 à 20:50:40  profilanswer
et avec startx rien ne se lance (on en aprend des commende sur se topic :p)
n°582337
bricezenic​e
Posté le 29-10-2004 à 21:02:52  profilanswer
En fait les drivers ne sont pas installer je me suis trompé !
Les kernel et les kernel source sont les bonnes !
Par contre, quand je lance nvidia-installer, ca me met divers message d'erreur et le dernier c'est unable to find the nvidia kernel name, un truc comme ca !
n°582345
Tomake
Posté le 29-10-2004 à 21:25:59  profilanswer
 :pt1cable:
ils installent les sources dans /usr/src
les modules dans /lib/modules
et le kernel dans /boot
Donc ça n'a pas marché  [:ocube]
Quelles sont les erreurs de startx  :??:
Tu sais ce qu'il faut faire pour les drivers now ;)
Pour le unable to find the nvidia kernel name pas de souci tu fais ok et tu passes c'est que l'installateur n'a pas trouvé de kernel sur le ftp de nvidia (d'un côté je l'ai jamais vu en trouvé)
"Parfois brutal, toujours loyal"
n°582353
bricezenic​e
Posté le 29-10-2004 à 21:44:48  profilanswer
oui mais apres ca s'arrete ! Les drivers sont quand même installés ? Je ne crois pas que c'est à cause du ftp !
Mais récapitulons : l'installation fonctionne sur toutes les versions de kernel ? 2.6.8.1 ??
n°582366
Tomake
Posté le 29-10-2004 à 22:10:03  profilanswer
Tu commences par installer normalement et si ça parche pas tu suis mon premier post ya pas de raison ça marche pour tous les kernel
Message édité par Tomake le 29-10-2004 à 22:10:56
n°582717
Lamasso
Posté le 30-10-2004 à 18:06:07  profilanswer
Muuthauwg a écrit :
Ben non, j'étais pas chez moi jusqu'à aujourd'hui. Tu as le même problème ?
J'avais problème de kernel source pas installé alors que c'était le cas....
Finalement j'ai complètement reglé le problème en passant sur une Suse 9.1.
n°583095
Dark_Schne​ider
Posté le 31-10-2004 à 17:54:46  profilanswer
bricezenice> pour installer les pilotes nvidia avec un noyau 2.6.8.1, il faut modifier le fichier nv.c
la procédure est expliqué dans le 1er post de ce topic.
merci de le lire et de suivare les instructions.
une fois nv.c modifié et la procédure d'installtion des pilotes finies, merci de lire mon site pour savoir comment configurer le système pour qu'il utilise les pilotes nvidia.
n°583193
Tomake
Posté le 31-10-2004 à 20:46:37  profilanswer
Premier post updated ;)
n°583208
Tomake
Posté le 31-10-2004 à 22:24:10  profilanswer
Hébergement trouvé  [:extazaille] et un patch online  [:udok]
Le second va suivre (mais quelques difficultés techniques surviennent :( )
n°583312
Posté le 01-11-2004 à 10:01:54  answer
Tomake a écrit :
10/ Normalement tout s'installe comme il faut  :o
Moi ca se passe pas comme il faut ! Il trouve pas mes kernel-sources  :fou: #!?%§ :fou:
Il me dit de faire --kernel-source-path= mais je sais pas quoi mettre après le =.
uname -a :
2.6.8.1-10mdk
Distrib fraichement installer :
Mandrake 10.1 Co
n°583313
Posté le 01-11-2004 à 10:06:32  answer
Ca marche mais modprobe nvidia refuse !
[root@localhost rask]# modprobe nvidia
FATAL: Error inserting nvidia (/lib/modules/2.6.8.1-10mdk/kernel/drivers/video/nvidia.ko): Invalid module format
J'ai perdu l'erreur de XOrg ...
Message édité par Profil supprimé le 01-11-2004 à 10:59:29
n°583361
Tomake
Posté le 01-11-2004 à 13:04:34  profilanswer
Le chemin vers les sources de ton kernel ce qui donnent
--kernel-source-path=/usr/src/linux-2.6.8.1-10mdk
Si ça ne marchent pas prend le patch qui est dans le premier post et pour l'installer (une fois que tu as quitté l'environnement X, en faisant en root 'service dm stop') tu fais :
NVIDIA-Linux-x86-1.0-6111-tomake-patched.run --add-this-kernel
puis tu suis les instructions et tu lances le fichier qu'il aura fabraiqué à savoir un nouveau NVIDIA ... -custom.run
n°583416
tuxbleu
renie ses origines
Posté le 01-11-2004 à 17:03:58  profilanswer
J'ai appliqué le contenu de cet article, et ca ne change pas mon problème.
petit descriptif :
quand j'arrive à l'étape sh ./NV...
j'accepte la licence
et j'ai un : "NO precompilated kernel found...."
je continue en ignorant l'erreur (il me propose de chercher sur le site de nv mé il y arrive pas)
la j'ai un warning rivtab, j'ai cru comprendre que ct normal,
puis
"ERROR Unable to build the NVIDIA kernel module"
"Installation has failled..."
Vous avez une idée ?
rappel, je suis sous mdk 10.0 et mon noyau c'est 2.6.3-4mdk, et j'ai bien les kernel-sources équivalentes.
[Citation] de Dark_Schneider
tuxbleu> donne le résultat des commandes suivantes :
uname -r
rpm -q kernel-source
[/citation]
cela donne uname -r --> 2.6.3-4mdk
rpm -q kernel-source --> kernel-source-2.6.3-4mdk
n°583420
tuxbleu
renie ses origines
Posté le 01-11-2004 à 17:16:24  profilanswer
voici le contenu de /var/log/nvidia-installer.log
creation time: Mon Nov  1 18:12:24 2004
option status:
  license pre-accepted    : false
  update                  : false
  expert                  : false
  uninstall               : false
  driver info             : false
  silent                  : false
  tmpdir                  : /root/tmp
-> License accepted.
   your kernel.
-> Kernel source path: '/lib/modules/2.6.3-4mdk/build'
-> Cleaning kernel module build directory.
   executing: 'cd ./usr/src/nv; make clean'...
   rm -f -f nv.o os-agp.o os-interface.o os-registry.o nv.o os-agp.o os-interfa
   ce.o os-registry.o nvidia.mod.o
   rm -f -f build-in.o nv-linux.o *.d .*.{cmd,flags}
   rm -f -f nvidia.{o,ko,mod.{o,c}} nv_compiler.h *~
-> Building kernel module:
   executing: 'cd ./usr/src/nv; make module SYSSRC=/lib/modules/2.6.3-4mdk/buil
   d SYSOUT=/lib/modules/2.6.3-4mdk/build'...
   *** Failed rivafb module sanity check, but continuing! ***
   NVIDIA: calling KBUILD...
   make -C /lib/modules/2.6.3-4mdk/build  \
   KBUILD_SRC=/usr/src/linux-2.6.3-4mdk KBUILD_VERBOSE=1 \
   KBUILD_CHECK= -f /usr/src/linux-2.6.3-4mdk/Makefile modules
     Using /usr/src/linux-2.6.3-4mdk as source for kernel
   if [ -h /usr/src/linux-2.6.3-4mdk/include/asm -o -f /usr/src/linux-2.6.3-4md
   k/.config ]; then \
    echo "  /usr/src/linux-2.6.3-4mdk is not clean, please run 'make mrproper'"
    echo "  in the '/usr/src/linux-2.6.3-4mdk' directory.";\
    /bin/false; \
   fi;
   make[3]: *** [prepare1] Erreur 1
   make[2]: *** [modules] Erreur 2
   NVIDIA: left KBUILD.
   nvidia.ko failed to build!
   make[1]: *** [module] Erreur 1
   make: *** [module] Erreur 2
-> Error.
ERROR: Unable to build the NVIDIA kernel module.
ERROR: Installation has failed.  Please see the file
       '/var/log/nvidia-installer.log' for details.  You may find suggestions
       on fixing installation problems in the README available on the Linux
       driver download page at www.nvidia.com.
n°583443
Tomake
Posté le 01-11-2004 à 18:01:19  profilanswer
Pourquoi tu passes pas au noyau 2.6.8.1 ??
Essaye aussi d'exécuter l'installateur nvidia en lui indiquant les sources de ton noyau :
NVIDIA ... .run --kernel-source-path=/usr/src/linux-2.6.3-4mdk
Essaye aussi NVIDIA ... .run --add-this-kernel
Sinon essaye de réinstaller tes sources du noyaux
n°583578
paydret
How ? That is the question...
Posté le 01-11-2004 à 21:15:23  profilanswer
Salut
je tente d'installer ces maudits pilotes NVidia en suivant scrupuleusement la méthode de Tomake , à l'étape 8/ la commande sh nvidia -a me renvoie le message suivant : "cannot execute binary file" ? si quelqu'un a une idée
Mandrake 10.1 Com kernel 2.6.8.1-10 mdk
kernel source idem
GF4
n°583579
Tomake
Posté le 01-11-2004 à 21:19:54  profilanswer
tapes ./nvidia.....
et respecte bien la casse du nom de fichier
Message édité par Tomake le 01-11-2004 à 21:20:15
n°583580
Posté le 01-11-2004 à 21:21:58  answer
Voila si vous pouviez m'aider ...
n°583624
paydret
Posté le 01-11-2004 à 21:56:32  profilanswer
Euh... ./nvidia... ne marche pas!
désolé! autre chose?
n°583631
Tomake
Posté le 01-11-2004 à 22:12:38  profilanswer
T as bien respecté majuscules/minuscules ??
Message édité par Tomake le 01-11-2004 à 23:03:43
n°583661
paydret
Posté le 01-11-2004 à 22:46:08  profilanswer
oui je pense,la touche tab est bien pratique pour cela;
je laisse tomber pour ce soir ,je sature ;j'ai essayé d'autres choses vues sur d'autres forums ,mais sans résultats
bonne continuation et merci
n°583768
lenainquit​ue
Posté le 02-11-2004 à 10:07:40  profilanswer
A tous les coups il a tapé ./nvidia.... et pas le nom du fichier entier.
Ce qui manque peut être sur la première page, c'est les commandes permettant de vérifier le noyau installé, vérifier que le kernel-source est bien installé et surtt qu'il correspond au Kernel.
Pour 80% des personnes les problèmes sont liés à ça.
n°583776
Posté le 02-11-2004 à 10:51:48  answer
90% je pense... Moi je met le nouveau kernel car c'est la cata ! Aucun drivers NVidia ne veut s'installer ! Meme les 0.5xx
n°583793
antolionux
Posté le 02-11-2004 à 11:52:30  profilanswer
sh nvidia-installer -a ne fonctionne pas
==> Le shell refuse de l'exécuter car il dit que c'est un fichier binaire (l'option exécutable est pourtant bien cochée)
Quelqu'un à une idée ?
mandrake 10.0 pbs apres installationDriver NVidia sous Mandrake 10.1
Problèmes après une installation.probleme install drivers radeon 9600
Installation de Mandrake 10.0...mdk 10 + dhcp +routeur belkin
probleme install mdk 9.2Montage module ehci sur mdk 10
Installation Linux sur Station Sun Ultra 10Pb d'installation sarge Debian via le net HELP!!!!
Plus de sujets relatifs à : Installation drivers Nvidia : 6111 à 7167 sous Mdk 10.1 et ultérieur
