8277 connectés
  Linux et OS Alternatifs
  Installation
  Driver NVidia sous Mandrake 10.1
 Page :   1  2
Page Précédente
n°562027
zapan25
Posté le 26-09-2004 à 00:22:46  profilanswer
Bonjour, j'essaie d'installer les driver de NVidia pour ma carte graphique sous la Mandrake 10.1.
Pour cela j'ai suivi le tutorial HOWTO NVIDIA : http://www.linux-wizard.net/howto_nvidia.html#install
J'ai installé le kernel source et j'ai télécharger les drivers 6111.
Pendant l'installation, le driver essaie de compilé, mais ca ne marche pas.
Voici le log :
Code :
  1. nvidia-installer log file '/var/log/nvidia-installer.log'
  2. creation time: Sat Sep 25 14:38:18 2004
  3. option status:
  4.   license pre-accepted    : false
  5.   update                  : false
  6.   force update            : false
  7.   expert                  : false
  8.   uninstall               : false
  9.   driver info             : false
  10.   no precompiled interface: false
  11.   no ncurses color        : false
  12.   query latest driver ver : false
  13.   OpenGL header files     : false
  14.   no questions            : false
  15.   silent                  : false
  16.   X install prefix        : /usr/X11R6
  17.   OpenGL install prefix   : /usr
  18.   Installer install prefix: /usr
  19.   kernel source path      : (not specified)
  20.   kernel install path     : (not specified)
  21.   proc mount point        : /proc
  22.   ui                      : (not specified)
  23.   tmpdir                  : /root/tmp
  24.   ftp site                : ftp://download.nvidia.com
  25. Using: nvidia-installer ncurses user interface
  26. -> License accepted.
  27. -> No precompiled kernel interface was found to match your kernel; would you li
  28.    ke the installer to attempt to download a kernel interface for your kernel f
  29.    rom the NVIDIA ftp site (ftp://download.nvidia.com)? (Answer: Yes)
  30. -> No matching precompiled kernel interface was found on the NVIDIA ftp site;
  31.    this means that the installer will need to compile a kernel interface for
  32.    your kernel.
  33. -> Kernel source path: '/lib/modules/2.6.8.1-10mdk/build'
  34. -> Performing cc_version_check with CC="cc".
  35. -> Performing rivafb check.
  36. -> Performing rivafb module check.
  37. WARNING: Your kernel was configured to include rivafb support as
  38.          a loadable kernel module.
  39.
  40.          The rivafb driver conflicts with the NVIDIA driver; the
  41.          NVIDIA kernel module will still be built and installed,
  42.          but be aware that the NVIDIA driver will not be able to
  43.          function properly if the rivafb module is loaded!
  44. -> Cleaning kernel module build directory.
  45.    executing: 'cd ./usr/src/nv; make clean'...
  46.    rm -f -f nv.o os-agp.o os-interface.o os-registry.o nv.o os-agp.o os-interfa
  47.    ce.o os-registry.o nvidia.mod.o
  48.    rm -f -f build-in.o nv-linux.o *.d .*.{cmd,flags}
  49.    rm -f -f nvidia.{o,ko,mod.{o,c}} nv_compiler.h *~
  50. -> Building kernel module:
  51.    executing: 'cd ./usr/src/nv; make module SYSSRC=/lib/modules/2.6.8.1-10mdk/b
  52.    uild SYSOUT=/lib/modules/2.6.8.1-10mdk/build'...
  53.    Your kernel was configured to include rivafb support as
  54.    a loadable kernel module.
  55.
  56.    The rivafb driver conflicts with the NVIDIA driver; the
  57.    NVIDIA kernel module will still be built and installed,
  58.    but be aware that the NVIDIA driver will not be able to
  59.    function properly if the rivafb module is loaded!
  60.
  61.    *** Failed rivafb module sanity check, but continuing! ***
  62.
  63.
  64.    NVIDIA: calling KBUILD...
  65.    make -C /lib/modules/2.6.8.1-10mdk/build  \
  66.    KBUILD_SRC=/usr/src/linux-2.6.8.1-10mdk      KBUILD_VERBOSE=1 \
  67.    KBUILD_CHECK= KBUILD_EXTMOD="/root/tmp/selfgz5677/NVIDIA-Linux-x86-1.0-6111-
  68.    pkg1/usr/src/nv" \
  69.            -f /usr/src/linux-2.6.8.1-10mdk/Makefile modules
  70.    mkdir -p /root/tmp/selfgz5677/NVIDIA-Linux-x86-1.0-6111-pkg1/usr/src/nv/.tmp
  71.    _versions
  72.    make -f /usr/src/linux-2.6.8.1-10mdk/scripts/Makefile.build obj=/root/tmp/se
  73.    lfgz5677/NVIDIA-Linux-x86-1.0-6111-pkg1/usr/src/nv
  74.    echo \#define NV_COMPILER \"`cc -v 2>&1 | tail -n 1`\" > /root/tmp/selfgz567
  75.    7/NVIDIA-Linux-x86-1.0-6111-pkg1/usr/src/nv/nv_compiler.h
  76.      cc -Wp,-MD,/root/tmp/selfgz5677/NVIDIA-Linux-x86-1.0-6111-pkg1/usr/src/nv/
  77.    .nv.o.d -nostdinc -iwithprefix include -D__KERNEL__ -Iinclude -Iinclude2 -I/
  78.    usr/src/linux-2.6.8.1-10mdk/include  -I/root/tmp/selfgz5677/NVIDIA-Linux-x86
  79.    -1.0-6111-pkg1/usr/src/nv -Wall -Wstrict-prototypes -Wno-trigraphs -fno-stri
  80.    ct-aliasing -fno-common -pipe -msoft-float -mpreferred-stack-boundary=2 -fno
  81.    -unit-at-a-time -march=i686 -I/usr/src/linux-2.6.8.1-10mdk/include/asm-i386/
  82.    mach-default -Iinclude/asm-i386/mach-default -O2 -Wdeclaration-after-stateme
  83.    nt  -I/root/tmp/selfgz5677/NVIDIA-Linux-x86-1.0-6111-pkg1/usr/src/nv -Wall -
  84.    Wimplicit -Wreturn-type -Wswitch -Wformat -Wchar-subscripts -Wparentheses -W
  85.    pointer-arith -Wno-multichar -Werror -O -fno-common -MD -Wno-cast-qual -Wno-
  86.    error -D_LOOSE_KERNEL_NAMES -D__KERNEL__ -DMODULE -DNTRM -D_GNU_SOURCE -D_LO
  87.    OSE_KERNEL_NAMES -D__KERNEL__ -DMODULE -DNV_MAJOR_VERSION=1 -DNV_MINOR_VERSI
  88.    ON=0 -DNV_PATCHLEVEL=6111 -DNV_UNIX -DNV_LINUX -DNV_INT64_OK -DNVCPU_X86 -UD
  89.    EBUG -U_DEBUG -DNDEBUG -DNV_CHANGE_PAGE_ATTR_PRESENT -DNV_CLASS
  90.    _SIMPLE_PRESENT -DMODULE -DKBUILD_BASENAME=nv -DKBUILD_MODNAME=nvidia -c -o
  91.    /root/tmp/selfgz5677/NVIDIA-Linux-x86-1.0-6111-pkg1/usr/src/nv/nv.o /root/tm
  92.    p/selfgz5677/NVIDIA-Linux-x86-1.0-6111-pkg1/usr/src/nv/nv.c
  93.    /root/tmp/selfgz5677/NVIDIA-Linux-x86-1.0-6111-pkg1/usr/src/nv/nv.c: In func
  94.    tion `nv_acpi_event':
  95.    /root/tmp/selfgz5677/NVIDIA-Linux-x86-1.0-6111-pkg1/usr/src/nv/nv.c:3697: er
  96.    ror: `PM_SAVE_STATE' undeclared (first use in this function)
  97.    /root/tmp/selfgz5677/NVIDIA-Linux-x86-1.0-6111-pkg1/usr/src/nv/nv.c:3697: er
  98.    ror: (Each undeclared identifier is reported only once
  99.    /root/tmp/selfgz5677/NVIDIA-Linux-x86-1.0-6111-pkg1/usr/src/nv/nv.c:3697: er
  100.    ror: for each function it appears in.)
  101.    make[4]: *** [/root/tmp/selfgz5677/NVIDIA-Linux-x86-1.0-6111-pkg1/usr/src/nv
  102.    /nv.o] Erreur 1
  103.    make[3]: *** [_module_/root/tmp/selfgz5677/NVIDIA-Linux-x86-1.0-6111-pkg1/us
  104.    r/src/nv] Erreur 2
  105.    make[2]: *** [modules] Erreur 2
  106.    NVIDIA: left KBUILD.
  107.    nvidia.ko failed to build!
  108.    make[1]: *** [module] Erreur 1
  109.    make: *** [module] Erreur 2
  110. -> Error.
  111. ERROR: Unable to build the NVIDIA kernel module.
  112. ERROR: Installation has failed.  Please see the file
  113.        '/var/log/nvidia-installer.log' for details.  You may find suggestions
  114.        on fixing installation problems in the README available on the Linux
  115.        driver download page at www.nvidia.com.
Merci pour votre aide.
n°562029
Tomake
Posté le 26-09-2004 à 00:37:46  profilanswer
Idem pour moi, je n'arrive pas à installer les drivers :(
J'ai la même erreur dans les logs !!
Apparemment c'est une question d'acpi mais en passant les options au noyau il ne se passe rien...
Là je ne sais plus quoi faire... [:w3c compliant]
Message édité par Tomake le 26-09-2004 à 00:38:30
n°562055
Zzozo
Un peu, passionément, à la fol
Posté le 26-09-2004 à 02:05:31  profilanswer
Question con (mais bon on sait jamais :o ) :
Les sources (ou au moins les headers) du noyau en question sont installés sur ta machine ?
Et si oui, est ce que l'"installeur" Nvidia les voit bien ?
Y'a plus d'infos dans le fichier /var/log/nvidia-installer.log auquel il est fait référence à la fin ? Si oui, on peut le voir ? :o
n°562056
Tomake
Posté le 26-09-2004 à 02:13:33  profilanswer
:lol: ouais quand même j'ai installé les sources du noyau !!
voici mon fichier de log nvidia-installer :
creation time: Sun Sep 26 02:11:17 2004
option status:
  update                  : false
  expert                  : false
  uninstall               : false
  driver info             : false
  silent                  : false
  tmpdir                  : /root/tmp
-> Copying kernel module sources to temporary directory.
-> Building kernel interface:
   executing: 'cd /root/tmp/nvidia-4277; make nv-linux.o SYSSRC=/lib/modules/2.
   mkdir -p /root/tmp/nvidia-4277/.tmp_versions
   make -f scripts/Makefile.build obj=/root/tmp/nvidia-4277
   echo \#define NV_COMPILER \"`cc -v 2>&1 | tail -n 1`\" > /root/tmp/nvidia-42
   77/nv_compiler.h
     cc -Wp,-MD,/root/tmp/nvidia-4277/.nv.o.d -nostdinc -iwithprefix include -D
   __KERNEL__ -Iinclude  -Wall -Wstrict-prototypes -Wno-trigraphs -fno-strict-a
   liasing -fno-common -pipe -msoft-float -mpreferred-stack-boundary=2 -fno-uni
   t-at-a-time -march=i686 -Iinclude/asm-i386/mach-default -O2 -Wdeclaration-af
   ter-statement -I/root/tmp/nvidia-4277 -Wall -Wimplicit -Wreturn-type -Wswitc
   h -Wformat -Wchar-subscripts -Wparentheses -Wpointer-arith
    -Wno-multichar  -Werror -O -fno-common -MD   -Wno-cast-qual -Wno-error -D_L
   OOSE_KERNEL_NAMES -D__KERNEL__ -DMODULE  -DNTRM -D_GNU_SOURCE -D_LOOSE_KERNE
   L_NAMES -D__KERNEL__ -DMODULE  -DNV_MAJOR_VERSION=1 -DNV_MINOR_VERSION=0 -DN
   -UDEBUG -U_DEBUG -DNDEBUG -DNV_CHANGE_PAGE_ATTR_PRESENT -DNV_CLASS_SIMPLE_PR
   ESENT  -DMODULE -DKBUILD_BASENAME=nv -DKBUILD_MODNAME=nvidia -c -o /root/tmp
   /nvidia-4277/nv.o /root/tmp/nvidia-4277/nv.c
   /root/tmp/nvidia-4277/nv.c: In function `nv_acpi_event':
   /root/tmp/nvidia-4277/nv.c:3697: error: `PM_SAVE_STATE' undeclared (first us
   e in this function)
   /root/tmp/nvidia-4277/nv.c:3697: error: (Each undeclared identifier is repor
   ted only once
   /root/tmp/nvidia-4277/nv.c:3697: error: for each function it appears in.)
   make[3]: *** [/root/tmp/nvidia-4277/nv.o] Erreur 1
   make[2]: *** [_module_/root/tmp/nvidia-4277] Erreur 2
   make: *** [nv-linux.o] Erreur 2
-> Error.
ERROR: Unable to build the NVIDIA kernel module interface.
ERROR: Unable to add a precompiled kernel interface for the running kernel.
n°562057
Zzozo
Posté le 26-09-2004 à 02:18:52  profilanswer
ok :o
On peut voir le résultat d'un uname -a
et d'un ls -l /usr/src ? :o
n°562058
Tomake
Posté le 26-09-2004 à 02:21:55  profilanswer
Voilà  :)
[root@workshop root]# uname -a
Linux workshop 2.6.8.1-10mdk #1 Wed Sep 8 17:00:52 CEST 2004 i686 AMD Athlon(tm) XP 1900+ unknown GNU/Linux
[root@workshop root]# ls -l /usr/src
total 12
lrwxrwxrwx   1 root root   17 sep 26 01:26 linux -> linux-2.6.3-15mdk/
drwxr-xr-x  21 root root 4096 sep 26 01:30 linux-2.6.3-15mdk/
drwxr-xr-x  21 root root 4096 sep 26 01:26 linux-2.6.8.1-10mdk/
drwxr-xr-x   4 root root 4096 sep 26 01:21 RPM/
n°562060
Zzozo
Posté le 26-09-2004 à 02:31:04  profilanswer
tomake a écrit :
Voilà  :)
total 12
alors 2 choses :
1/ On peut connaitre les options (le .config en gros) utilisées lors de la compil du noyau que tu utilises ?
2/ faudrait faire pointer le /usr/src/linux vers /usr/src/linux-2.6.8.1-10mdk, pour une question de cohérence, parce que ca peut "gêner" certains "modules/drivers/programmes" qui ont besoin des
headers du noyau, qui se basent justement sur le /usr/src/linux pour savoir quels headers correspondent au noyau en cours d'utilisation. :o
Message édité par Zzozo le 26-09-2004 à 02:31:32
n°562062
Tomake
Posté le 26-09-2004 à 02:34:45  profilanswer
1- j'utilise le kernel 2.6.8.1 fourni dans la mdk 10.1 community
2- ok pour la cohérence des liens. Entre mon premier post et le ls -l /usr/src j'ai résinstallé mon ancien noyau mais ça ne parche pas non plus
n°562063
Tomake
Posté le 26-09-2004 à 02:37:07  profilanswer
Tu veux vraiment tout le .config du 2.6.8.1 parce que ça va faire monobloc :/ ???
n°562064
Zzozo
Posté le 26-09-2004 à 02:37:36  profilanswer
Certes, mais ca m'avance pas sur les options utilisées lors de la compil de ce noyau ... :o ... pas envie de chercher sur le site de mandrake ... :o ... feignant inside ce soir ...  :whistle:
Message édité par Zzozo le 26-09-2004 à 02:39:06
n°562065
Zzozo
Posté le 26-09-2004 à 02:38:48  profilanswer
Yep ... ou tu me mets le fichier accessible à un endroit si tu préfères ... :o ... et celui qui correspond vraiment au noyau en cours d'utilisation, pas un qui "devrait" être le même ... :o
n°562066
Tomake
Posté le 26-09-2004 à 02:40:52  profilanswer
Voilà le .config du kernel en cours :
# Automatically generated make config: don't edit
CONFIG_X86=y
CONFIG_MMU=y
CONFIG_UID16=y
CONFIG_GENERIC_ISA_DMA=y
# Code maturity level options
CONFIG_EXPERIMENTAL=y
CONFIG_CLEAN_COMPILE=y
CONFIG_BROKEN_ON_SMP=y
# General setup
CONFIG_SWAP=y
CONFIG_SYSVIPC=y
CONFIG_POSIX_MQUEUE=y
CONFIG_BSD_PROCESS_ACCT=y
CONFIG_BSD_PROCESS_ACCT_V3=y
CONFIG_SYSCTL=y
CONFIG_AUDIT=y
CONFIG_AUDITSYSCALL=y
CONFIG_LOG_BUF_SHIFT=17
CONFIG_HOTPLUG=y
# CONFIG_IKCONFIG is not set
CONFIG_EMBEDDED=y
CONFIG_KALLSYMS=y
# CONFIG_KALLSYMS_ALL is not set
CONFIG_KALLSYMS_EXTRA_PASS=y
CONFIG_FUTEX=y
CONFIG_EPOLL=y
CONFIG_IOSCHED_NOOP=y
CONFIG_IOSCHED_AS=y
CONFIG_IOSCHED_DEADLINE=y
CONFIG_IOSCHED_CFQ=y
# CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
# Loadable module support
CONFIG_MODULES=y
CONFIG_MODULE_UNLOAD=y
CONFIG_MODULE_FORCE_UNLOAD=y
CONFIG_OBSOLETE_MODPARM=y
# CONFIG_MODVERSIONS is not set
CONFIG_KMOD=y
# Processor type and features
CONFIG_X86_PC=y
# CONFIG_X86_ELAN is not set
# CONFIG_X86_VOYAGER is not set
# CONFIG_X86_NUMAQ is not set
# CONFIG_X86_SUMMIT is not set
# CONFIG_X86_BIGSMP is not set
# CONFIG_X86_VISWS is not set
# CONFIG_X86_GENERICARCH is not set
# CONFIG_X86_ES7000 is not set
# CONFIG_M386 is not set
# CONFIG_M486 is not set
# CONFIG_M586 is not set
# CONFIG_M586TSC is not set
# CONFIG_M586MMX is not set
CONFIG_M686=y
# CONFIG_MPENTIUMII is not set
# CONFIG_MPENTIUMIII is not set
# CONFIG_MPENTIUMM is not set
# CONFIG_MPENTIUM4 is not set
# CONFIG_MK6 is not set
# CONFIG_MK7 is not set
# CONFIG_MK8 is not set
# CONFIG_MCRUSOE is not set
# CONFIG_MWINCHIPC6 is not set
# CONFIG_MWINCHIP2 is not set
# CONFIG_MWINCHIP3D is not set
# CONFIG_MCYRIXIII is not set
# CONFIG_MVIAC3_2 is not set
# CONFIG_X86_GENERIC is not set
CONFIG_X86_CMPXCHG=y
CONFIG_X86_XADD=y
CONFIG_X86_L1_CACHE_SHIFT=5
CONFIG_RWSEM_XCHGADD_ALGORITHM=y
CONFIG_X86_PPRO_FENCE=y
CONFIG_X86_WP_WORKS_OK=y
CONFIG_X86_INVLPG=y
CONFIG_X86_BSWAP=y
CONFIG_X86_POPAD_OK=y
CONFIG_X86_GOOD_APIC=y
CONFIG_X86_USE_PPRO_CHECKSUM=y
CONFIG_HPET_TIMER=y
# CONFIG_SMP is not set
# CONFIG_PREEMPT is not set
CONFIG_X86_UP_APIC=y
CONFIG_X86_UP_IOAPIC=y
CONFIG_X86_LOCAL_APIC=y
CONFIG_X86_IO_APIC=y
CONFIG_X86_TSC=y
CONFIG_X86_MCE=y
# CONFIG_X86_MCE_NONFATAL is not set
CONFIG_X86_MCE_P4THERMAL=y
CONFIG_TOSHIBA=m
CONFIG_I8K=m
CONFIG_MICROCODE=m
CONFIG_X86_MSR=m
CONFIG_X86_CPUID=m
# Firmware Drivers
CONFIG_EDD=y
# CONFIG_NOHIGHMEM is not set
CONFIG_HIGHMEM4G=y
# CONFIG_HIGHMEM64G is not set
CONFIG_HIGHMEM=y
CONFIG_BADRAM=y
# CONFIG_HIGHPTE is not set
# CONFIG_MATH_EMULATION is not set
CONFIG_MTRR=y
# CONFIG_EFI is not set
# CONFIG_REGPARM is not set
# Power management options (ACPI, APM)
CONFIG_PM=y
# CONFIG_PM_DEBUG is not set
CONFIG_SOFTWARE_SUSPEND=y
CONFIG_PM_STD_PARTITION=""
# ACPI (Advanced Configuration and Power Interface) Support
CONFIG_ACPI=y
CONFIG_ACPI_BOOT=y
CONFIG_ACPI_INTERPRETER=y
CONFIG_ACPI_SLEEP=y
CONFIG_ACPI_SLEEP_PROC_FS=y
CONFIG_ACPI_AC=m
CONFIG_ACPI_BATTERY=m
CONFIG_ACPI_BUTTON=m
CONFIG_ACPI_FAN=m
CONFIG_ACPI_PROCESSOR=m
CONFIG_ACPI_THERMAL=m
CONFIG_ACPI_ASUS=m
CONFIG_ACPI_TOSHIBA=m
# CONFIG_ACPI_DEBUG is not set
CONFIG_ACPI_BUS=y
CONFIG_ACPI_EC=y
CONFIG_ACPI_POWER=y
CONFIG_ACPI_PCI=y
CONFIG_ACPI_SYSTEM=y
CONFIG_X86_PM_TIMER=y
CONFIG_ACPI_INITRD=y
CONFIG_ACPI_TC1100=m
# APM (Advanced Power Management) BIOS Support
CONFIG_APM=y
# CONFIG_APM_IGNORE_USER_SUSPEND is not set
# CONFIG_APM_DO_ENABLE is not set
# CONFIG_APM_CPU_IDLE is not set
# CONFIG_APM_DISPLAY_BLANK is not set
CONFIG_APM_RTC_IS_GMT=y
# CONFIG_APM_ALLOW_INTS is not set
# CONFIG_APM_REAL_MODE_POWER_OFF is not set
# CPU Frequency scaling
CONFIG_CPU_FREQ=y
CONFIG_CPU_FREQ_PROC_INTF=y
CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE=y
# CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
CONFIG_CPU_FREQ_GOV_POWERSAVE=m
CONFIG_CPU_FREQ_GOV_USERSPACE=y
CONFIG_CPU_FREQ_24_API=y
CONFIG_CPU_FREQ_TABLE=y
# CPUFreq processor drivers
CONFIG_X86_ACPI_CPUFREQ=m
# CONFIG_X86_ACPI_CPUFREQ_PROC_INTF is not set
CONFIG_X86_POWERNOW_K6=m
CONFIG_X86_POWERNOW_K7=m
CONFIG_X86_POWERNOW_K7_ACPI=y
CONFIG_X86_POWERNOW_K8=m
CONFIG_X86_POWERNOW_K8_ACPI=y
CONFIG_X86_GX_SUSPMOD=m
CONFIG_X86_SPEEDSTEP_CENTRINO=m
CONFIG_X86_SPEEDSTEP_CENTRINO_TABLE=y
CONFIG_X86_SPEEDSTEP_CENTRINO_ACPI=y
CONFIG_X86_SPEEDSTEP_ICH=m
CONFIG_X86_SPEEDSTEP_SMI=m
CONFIG_X86_P4_CLOCKMOD=m
CONFIG_X86_SPEEDSTEP_LIB=m
CONFIG_X86_SPEEDSTEP_RELAXED_CAP_CHECK=y
CONFIG_X86_CPUFREQ_NFORCE2=m
CONFIG_X86_LONGRUN=m
CONFIG_X86_LONGHAUL=m
# Bus options (PCI, PCMCIA, EISA, MCA, ISA)
CONFIG_PCI=y
# CONFIG_PCI_GOBIOS is not set
# CONFIG_PCI_GOMMCONFIG is not set
# CONFIG_PCI_GODIRECT is not set
CONFIG_PCI_GOANY=y
CONFIG_PCI_BIOS=y
CONFIG_PCI_DIRECT=y
CONFIG_PCI_MMCONFIG=y
# CONFIG_PCI_MSI is not set
CONFIG_PCI_LEGACY_PROC=y
# CONFIG_PCI_NAMES is not set
CONFIG_ISA=y
# CONFIG_EISA is not set
# CONFIG_MCA is not set
# CONFIG_SCx200 is not set
# PCMCIA/CardBus support
CONFIG_PCMCIA=m
# CONFIG_PCMCIA_DEBUG is not set
CONFIG_YENTA=m
CONFIG_CARDBUS=y
CONFIG_PD6729=m
CONFIG_I82092=m
CONFIG_I82365=m
CONFIG_TCIC=m
CONFIG_PCMCIA_PROBE=y
# PCI Hotplug Support
CONFIG_HOTPLUG_PCI=m
CONFIG_HOTPLUG_PCI_FAKE=m
CONFIG_HOTPLUG_PCI_COMPAQ=m
# CONFIG_HOTPLUG_PCI_COMPAQ_NVRAM is not set
CONFIG_HOTPLUG_PCI_IBM=m
CONFIG_HOTPLUG_PCI_ACPI=m
CONFIG_HOTPLUG_PCI_CPCI=y
CONFIG_HOTPLUG_PCI_CPCI_ZT5550=m
CONFIG_HOTPLUG_PCI_CPCI_GENERIC=m
CONFIG_HOTPLUG_PCI_PCIE=m
# CONFIG_HOTPLUG_PCI_PCIE_POLL_EVENT_MODE is not set
CONFIG_HOTPLUG_PCI_SHPC=m
# CONFIG_HOTPLUG_PCI_SHPC_POLL_EVENT_MODE is not set
# Rule Set Based Access Control (RSBAC)
# CONFIG_RSBAC is not set
# Executable file formats
CONFIG_BINFMT_ELF=y
CONFIG_BINFMT_AOUT=m
CONFIG_BINFMT_MISC=m
# Device Drivers
# Generic Driver Options
# CONFIG_STANDALONE is not set
CONFIG_PREVENT_FIRMWARE_BUILD=y
CONFIG_FW_LOADER=m
# CONFIG_DEBUG_DRIVER is not set
# Memory Technology Devices (MTD)
CONFIG_MTD=m
# CONFIG_MTD_DEBUG is not set
CONFIG_MTD_PARTITIONS=y
CONFIG_MTD_CONCAT=m
CONFIG_MTD_REDBOOT_PARTS=m
# CONFIG_MTD_REDBOOT_PARTS_UNALLOCATED is not set
# CONFIG_MTD_REDBOOT_PARTS_READONLY is not set
CONFIG_MTD_CMDLINE_PARTS=y
# User Modules And Translation Layers
CONFIG_MTD_CHAR=m
CONFIG_MTD_BLOCK=m
CONFIG_MTD_BLOCK_RO=m
CONFIG_FTL=m
CONFIG_NFTL=m
# CONFIG_NFTL_RW is not set
CONFIG_INFTL=m
# RAM/ROM/Flash chip drivers
CONFIG_MTD_CFI=m
CONFIG_MTD_JEDECPROBE=m
CONFIG_MTD_GEN_PROBE=m
# CONFIG_MTD_CFI_ADV_OPTIONS is not set
CONFIG_MTD_MAP_BANK_WIDTH_1=y
CONFIG_MTD_MAP_BANK_WIDTH_2=y
CONFIG_MTD_MAP_BANK_WIDTH_4=y
# CONFIG_MTD_MAP_BANK_WIDTH_8 is not set
# CONFIG_MTD_MAP_BANK_WIDTH_16 is not set
# CONFIG_MTD_MAP_BANK_WIDTH_32 is not set
CONFIG_MTD_CFI_I1=y
CONFIG_MTD_CFI_I2=y
# CONFIG_MTD_CFI_I4 is not set
# CONFIG_MTD_CFI_I8 is not set
CONFIG_MTD_CFI_INTELEXT=m
CONFIG_MTD_CFI_AMDSTD=m
CONFIG_MTD_CFI_AMDSTD_RETRY=0
CONFIG_MTD_CFI_STAA=m
CONFIG_MTD_CFI_UTIL=m
# CONFIG_MTD_RAM is not set
# CONFIG_MTD_ROM is not set
CONFIG_MTD_ABSENT=m
# Mapping drivers for chip access
# CONFIG_MTD_COMPLEX_MAPPINGS is not set
CONFIG_MTD_PHYSMAP=m
CONFIG_MTD_PHYSMAP_START=0x8000000
CONFIG_MTD_PHYSMAP_LEN=0x4000000
CONFIG_MTD_PHYSMAP_BANKWIDTH=2
CONFIG_MTD_PNC2000=m
CONFIG_MTD_SC520CDP=m
CONFIG_MTD_NETSC520=m
# CONFIG_MTD_SCx200_DOCFLASH is not set
CONFIG_MTD_AMD76XROM=m
CONFIG_MTD_SCB2_FLASH=m
CONFIG_MTD_NETtel=m
CONFIG_MTD_DILNETPC=m
CONFIG_MTD_DILNETPC_BOOTSIZE=0x80000
# CONFIG_MTD_L440GX is not set
# Self-contained MTD device drivers
CONFIG_MTD_PMC551=m
# CONFIG_MTD_PMC551_BUGFIX is not set
# CONFIG_MTD_PMC551_DEBUG is not set
CONFIG_MTD_SLRAM=m
CONFIG_MTD_PHRAM=m
CONFIG_MTD_MTDRAM=m
CONFIG_MTDRAM_TOTAL_SIZE=4096
CONFIG_MTDRAM_ERASE_SIZE=128
CONFIG_MTD_BLKMTD=m
# Disk-On-Chip Device Drivers
CONFIG_MTD_DOC2000=m
CONFIG_MTD_DOC2001=m
CONFIG_MTD_DOC2001PLUS=m
CONFIG_MTD_DOCPROBE=m
CONFIG_MTD_DOCECC=m
CONFIG_MTD_DOCPROBE_ADVANCED=y
CONFIG_MTD_DOCPROBE_ADDRESS=0x0000
CONFIG_MTD_DOCPROBE_HIGH=y
CONFIG_MTD_DOCPROBE_55AA=y
# NAND Flash Device Drivers
CONFIG_MTD_NAND=m
# CONFIG_MTD_NAND_VERIFY_WRITE is not set
CONFIG_MTD_NAND_IDS=m
CONFIG_MTD_NAND_DISKONCHIP=m
# CONFIG_MTD_NAND_DISKONCHIP_PROBE_ADVANCED is not set
CONFIG_MTD_NAND_DISKONCHIP_PROBE_ADDRESS=0
# CONFIG_MTD_NAND_DISKONCHIP_BBTWRITE is not set
# Parallel port support
CONFIG_PARPORT=m
CONFIG_PARPORT_PC=m
CONFIG_PARPORT_PC_CML1=m
CONFIG_PARPORT_SERIAL=m
CONFIG_PARPORT_PC_FIFO=y
# CONFIG_PARPORT_PC_SUPERIO is not set
CONFIG_PARPORT_PC_PCMCIA=m
CONFIG_PARPORT_OTHER=y
CONFIG_PARPORT_1284=y
# Plug and Play support
CONFIG_PNP=y
# CONFIG_PNP_DEBUG is not set
# Protocols
CONFIG_ISAPNP=y
CONFIG_PNPBIOS=y
CONFIG_PNPBIOS_PROC_FS=y
# Block devices
CONFIG_BLK_DEV_FD=m
CONFIG_BLK_DEV_XD=m
CONFIG_PARIDE=m
CONFIG_PARIDE_PARPORT=m
# Parallel IDE high-level drivers
CONFIG_PARIDE_PD=m
CONFIG_PARIDE_PCD=m
CONFIG_PARIDE_PF=m
CONFIG_PARIDE_PT=m
CONFIG_PARIDE_PG=m
# Parallel IDE protocol modules
CONFIG_PARIDE_ATEN=m
CONFIG_PARIDE_BPCK=m
CONFIG_PARIDE_BPCK6=m
CONFIG_PARIDE_COMM=m
CONFIG_PARIDE_DSTR=m
CONFIG_PARIDE_FIT2=m
CONFIG_PARIDE_FIT3=m
CONFIG_PARIDE_EPAT=m
CONFIG_PARIDE_EPATC8=y
CONFIG_PARIDE_EPIA=m
CONFIG_PARIDE_FRIQ=m
CONFIG_PARIDE_FRPW=m
CONFIG_PARIDE_KBIC=m
CONFIG_PARIDE_KTTI=m
CONFIG_PARIDE_ON20=m
CONFIG_PARIDE_ON26=m
CONFIG_BLK_CPQ_DA=m
CONFIG_BLK_CPQ_CISS_DA=m
CONFIG_CISS_SCSI_TAPE=y
CONFIG_BLK_DEV_DAC960=m
CONFIG_BLK_DEV_UMEM=m
CONFIG_BLK_DEV_LOOP=m
CONFIG_BLK_DEV_CRYPTOLOOP=m
CONFIG_BLK_DEV_GZLOOP=m
CONFIG_BLK_DEV_NBD=m
CONFIG_BLK_DEV_SX8=m
CONFIG_BLK_DEV_RAM=y
CONFIG_BLK_DEV_RAM_SIZE=32000
CONFIG_BLK_DEV_INITRD=y
CONFIG_LBD=y
CONFIG_CDROM_PKTCDVD=m
CONFIG_CDROM_PKTCDVD_BUFFERS=8
# CONFIG_CDROM_PKTCDVD_WCACHE is not set
# ATA/ATAPI/MFM/RLL support
CONFIG_IDE=y
CONFIG_BLK_DEV_IDE=y
# Please see Documentation/ide.txt for help/info on IDE drives
# CONFIG_BLK_DEV_IDE_SATA is not set
# CONFIG_BLK_DEV_HD_IDE is not set
CONFIG_BLK_DEV_IDEDISK=y
CONFIG_IDEDISK_MULTI_MODE=y
CONFIG_BLK_DEV_IDECS=m
CONFIG_BLK_DEV_IDECD=m
CONFIG_BLK_DEV_IDETAPE=m
CONFIG_BLK_DEV_IDEFLOPPY=m
CONFIG_BLK_DEV_IDESCSI=m
CONFIG_IDE_TASK_IOCTL=y
# CONFIG_IDE_TASKFILE_IO is not set
# IDE chipset support/bugfixes
CONFIG_IDE_GENERIC=m
CONFIG_BLK_DEV_CMD640=y
# CONFIG_BLK_DEV_CMD640_ENHANCED is not set
# CONFIG_BLK_DEV_IDEPNP is not set
CONFIG_BLK_DEV_IDEPCI=y
CONFIG_IDEPCI_SHARE_IRQ=y
CONFIG_BLK_DEV_OFFBOARD=y
# CONFIG_BLK_DEV_GENERIC is not set
# CONFIG_BLK_DEV_OPTI621 is not set
CONFIG_BLK_DEV_RZ1000=m
CONFIG_BLK_DEV_IDEDMA_PCI=y
# CONFIG_BLK_DEV_IDEDMA_FORCED is not set
CONFIG_IDEDMA_PCI_AUTO=y
# CONFIG_IDEDMA_ONLYDISK is not set
CONFIG_BLK_DEV_ADMA=y
CONFIG_BLK_DEV_AEC62XX=m
CONFIG_BLK_DEV_ALI15X3=y
# CONFIG_WDC_ALI15X3 is not set
CONFIG_BLK_DEV_AMD74XX=y
CONFIG_BLK_DEV_ATIIXP=y
CONFIG_BLK_DEV_CMD64X=y
CONFIG_BLK_DEV_TRIFLEX=m
# CONFIG_BLK_DEV_CY82C693 is not set
CONFIG_BLK_DEV_CS5520=m
CONFIG_BLK_DEV_CS5530=m
CONFIG_BLK_DEV_HPT34X=y
CONFIG_HPT34X_AUTODMA=y
CONFIG_BLK_DEV_HPT366=y
# CONFIG_BLK_DEV_SC1200 is not set
CONFIG_BLK_DEV_PIIX=y
CONFIG_BLK_DEV_IT8212=m
# CONFIG_BLK_DEV_NS87415 is not set
CONFIG_BLK_DEV_PDC202XX_OLD=y
# CONFIG_PDC202XX_BURST is not set
CONFIG_BLK_DEV_PDC202XX_NEW=y
CONFIG_PDC202XX_FORCE=y
CONFIG_BLK_DEV_SVWKS=y
CONFIG_BLK_DEV_SIIMAGE=y
CONFIG_BLK_DEV_SIS5513=y
CONFIG_BLK_DEV_SLC90E66=m
CONFIG_BLK_DEV_TRM290=m
CONFIG_BLK_DEV_VIA82CXXX=y
# CONFIG_IDE_ARM is not set
# CONFIG_IDE_CHIPSETS is not set
CONFIG_BLK_DEV_IDEDMA=y
# CONFIG_IDEDMA_IVB is not set
CONFIG_IDEDMA_AUTO=y
# CONFIG_BLK_DEV_HD is not set
# SCSI device support
CONFIG_SCSI=m
CONFIG_SCSI_PROC_FS=y
# SCSI support type (disk, tape, CD-ROM)
CONFIG_BLK_DEV_SD=m
CONFIG_CHR_DEV_ST=m
CONFIG_CHR_DEV_OSST=m
CONFIG_BLK_DEV_SR=m
CONFIG_BLK_DEV_SR_VENDOR=y
CONFIG_CHR_DEV_SG=m
# Some SCSI devices (e.g. CD jukebox) support multiple LUNs
CONFIG_SCSI_MULTI_LUN=y
CONFIG_SCSI_CONSTANTS=y
CONFIG_SCSI_LOGGING=y
# SCSI Transport Attributes
CONFIG_SCSI_SPI_ATTRS=m
CONFIG_SCSI_FC_ATTRS=m
# SCSI low-level drivers
CONFIG_BLK_DEV_3W_XXXX_RAID=m
CONFIG_SCSI_3W_9XXX=m
CONFIG_SCSI_7000FASST=m
CONFIG_SCSI_ACARD=m
CONFIG_SCSI_AHA152X=m
CONFIG_SCSI_AHA1542=m
CONFIG_SCSI_AACRAID=m
CONFIG_SCSI_AIC7XXX=m
CONFIG_AIC7XXX_CMDS_PER_DEVICE=253
CONFIG_AIC7XXX_RESET_DELAY_MS=15000
# CONFIG_AIC7XXX_BUILD_FIRMWARE is not set
# CONFIG_AIC7XXX_DEBUG_ENABLE is not set
CONFIG_AIC7XXX_DEBUG_MASK=0
CONFIG_AIC7XXX_REG_PRETTY_PRINT=y
CONFIG_SCSI_AIC7XXX_OLD=m
CONFIG_SCSI_AIC79XX=m
CONFIG_AIC79XX_CMDS_PER_DEVICE=32
CONFIG_AIC79XX_RESET_DELAY_MS=15000
# CONFIG_AIC79XX_BUILD_FIRMWARE is not set
# CONFIG_AIC79XX_ENABLE_RD_STRM is not set
# CONFIG_AIC79XX_DEBUG_ENABLE is not set
CONFIG_AIC79XX_DEBUG_MASK=0
CONFIG_AIC79XX_REG_PRETTY_PRINT=y
CONFIG_SCSI_DPT_I2O=m
CONFIG_SCSI_IN2000=m
CONFIG_SCSI_MEGARAID=m
CONFIG_SCSI_SATA=y
CONFIG_SCSI_SATA_SVW=m
CONFIG_SCSI_ATA_PIIX=m
CONFIG_SCSI_SATA_NV=m
CONFIG_SCSI_SATA_PROMISE=m
CONFIG_SCSI_SATA_SX4=m
CONFIG_SCSI_SATA_SIL=m
CONFIG_SCSI_SATA_SIS=m
CONFIG_SCSI_SATA_VIA=m
CONFIG_SCSI_SATA_VITESSE=m
CONFIG_SCSI_BUSLOGIC=m
# CONFIG_SCSI_OMIT_FLASHPOINT is not set
CONFIG_SCSI_DMX3191D=m
CONFIG_SCSI_DTC3280=m
CONFIG_SCSI_EATA=m
CONFIG_SCSI_EATA_TAGGED_QUEUE=y
# CONFIG_SCSI_EATA_LINKED_COMMANDS is not set
CONFIG_SCSI_EATA_MAX_TAGS=16
CONFIG_SCSI_EATA_PIO=m
CONFIG_SCSI_FUTURE_DOMAIN=m
CONFIG_SCSI_GDTH=m
CONFIG_SCSI_GENERIC_NCR5380=m
CONFIG_SCSI_GENERIC_NCR5380_MMIO=m
CONFIG_SCSI_GENERIC_NCR53C400=y
CONFIG_SCSI_IPS=m
CONFIG_SCSI_INITIO=m
CONFIG_SCSI_INIA100=m
CONFIG_SCSI_PPA=m
CONFIG_SCSI_IMM=m
# CONFIG_SCSI_IZIP_EPP16 is not set
# CONFIG_SCSI_IZIP_SLOW_CTR is not set
# CONFIG_PPSCSI is not set
CONFIG_SCSI_NCR53C406A=m
CONFIG_SCSI_SYM53C8XX_2=m
CONFIG_SCSI_SYM53C8XX_DMA_ADDRESSING_MODE=0
CONFIG_SCSI_SYM53C8XX_DEFAULT_TAGS=16
CONFIG_SCSI_SYM53C8XX_MAX_TAGS=64
# CONFIG_SCSI_SYM53C8XX_IOMAPPED is not set
CONFIG_SCSI_IPR=m
# CONFIG_SCSI_IPR_TRACE is not set
# CONFIG_SCSI_IPR_DUMP is not set
CONFIG_SCSI_PAS16=m
CONFIG_SCSI_PSI240I=m
CONFIG_SCSI_QLOGIC_FAS=m
CONFIG_SCSI_QLOGIC_ISP=m
CONFIG_SCSI_QLOGIC_FC=m
# CONFIG_SCSI_QLOGIC_FC_FIRMWARE is not set
CONFIG_SCSI_QLOGIC_1280=m
CONFIG_SCSI_QLA2XXX=m
CONFIG_SCSI_QLA21XX=m
CONFIG_SCSI_QLA22XX=m
CONFIG_SCSI_QLA2300=m
CONFIG_SCSI_QLA2322=m
CONFIG_SCSI_QLA6312=m
CONFIG_SCSI_QLA6322=m
CONFIG_SCSI_SYM53C416=m
CONFIG_SCSI_DC395x=m
CONFIG_SCSI_DC390T=m
CONFIG_SCSI_T128=m
CONFIG_SCSI_U14_34F=m
# CONFIG_SCSI_U14_34F_TAGGED_QUEUE is not set
CONFIG_SCSI_U14_34F_LINKED_COMMANDS=y
CONFIG_SCSI_U14_34F_MAX_TAGS=8
CONFIG_SCSI_ULTRASTOR=m
CONFIG_SCSI_NSP32=m
CONFIG_SCSI_DEBUG=m
# PCMCIA SCSI adapter support
CONFIG_PCMCIA_AHA152X=m
CONFIG_PCMCIA_FDOMAIN=m
CONFIG_PCMCIA_NINJA_SCSI=m
CONFIG_PCMCIA_QLOGIC=m
CONFIG_PCMCIA_SYM53C500=m
# Old CD-ROM drivers (not SCSI, not IDE)
CONFIG_CD_NO_IDESCSI=y
CONFIG_AZTCD=m
CONFIG_GSCD=m
CONFIG_SBPCD=m
CONFIG_MCD=m
CONFIG_MCD_IRQ=11
CONFIG_MCD_BASE=0x300
CONFIG_MCDX=m
CONFIG_OPTCD=m
CONFIG_CM206=m
CONFIG_SJCD=m
CONFIG_ISP16_CDI=m
CONFIG_CDU31A=m
CONFIG_CDU535=m
# Multi-device support (RAID and LVM)
CONFIG_MD=y
CONFIG_BLK_DEV_MD=y
CONFIG_MD_LINEAR=m
CONFIG_MD_RAID0=m
CONFIG_MD_RAID1=m
CONFIG_MD_RAID5=m
CONFIG_MD_RAID6=m
CONFIG_MD_MULTIPATH=m
CONFIG_BLK_DEV_DM=m
CONFIG_DM_CRYPT=m
CONFIG_DM_SNAPSHOT=m
CONFIG_DM_MIRROR=m
CONFIG_DM_ZERO=m
# Fusion MPT device support
CONFIG_FUSION=m
CONFIG_FUSION_MAX_SGE=40
CONFIG_FUSION_ISENSE=m
CONFIG_FUSION_CTL=m
CONFIG_FUSION_LAN=m
# IEEE 1394 (FireWire) support
CONFIG_IEEE1394=m
# Subsystem Options
# CONFIG_IEEE1394_VERBOSEDEBUG is not set
CONFIG_IEEE1394_OUI_DB=y
CONFIG_IEEE1394_EXTRA_CONFIG_ROMS=y
CONFIG_IEEE1394_CONFIG_ROM_IP1394=y
# Device Drivers
CONFIG_IEEE1394_PCILYNX=m
CONFIG_IEEE1394_OHCI1394=m
# Protocol Drivers
CONFIG_IEEE1394_VIDEO1394=m
CONFIG_IEEE1394_SBP2=m
# CONFIG_IEEE1394_SBP2_PHYS_DMA is not set
CONFIG_IEEE1394_ETH1394=m
CONFIG_IEEE1394_DV1394=m
CONFIG_IEEE1394_RAWIO=m
CONFIG_IEEE1394_CMP=m
CONFIG_IEEE1394_AMDTP=m
# I2O device support
CONFIG_I2O=m
CONFIG_I2O_CONFIG=m
CONFIG_I2O_BLOCK=m
CONFIG_I2O_SCSI=m
CONFIG_I2O_PROC=m
# Networking support
CONFIG_NET=y
# Networking options
CONFIG_PACKET=m
CONFIG_PACKET_MMAP=y
CONFIG_NETLINK_DEV=m
CONFIG_UNIX=y
CONFIG_IPMI_SOCKET=m
CONFIG_NET_KEY=m
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
CONFIG_IP_ADVANCED_ROUTER=y
CONFIG_IP_MULTIPLE_TABLES=y
CONFIG_IP_ROUTE_FWMARK=y
CONFIG_IP_ROUTE_NAT=y
CONFIG_IP_ROUTE_MULTIPATH=y
CONFIG_IP_ROUTE_TOS=y
CONFIG_IP_ROUTE_VERBOSE=y
# CONFIG_IP_PNP is not set
CONFIG_NET_IPIP=m
CONFIG_NET_IPGRE=m
CONFIG_NET_IPGRE_BROADCAST=y
CONFIG_IP_MROUTE=y
CONFIG_IP_PIMSM_V1=y
CONFIG_IP_PIMSM_V2=y
# CONFIG_ARPD is not set
CONFIG_SYN_COOKIES=y
CONFIG_INET_AH=m
CONFIG_INET_ESP=m
CONFIG_INET_IPCOMP=m
# IP: Virtual Server Configuration
CONFIG_IP_VS=m
CONFIG_IP_VS_DEBUG=y
CONFIG_IP_VS_TAB_BITS=12
# IPVS transport protocol load balancing support
CONFIG_IP_VS_PROTO_TCP=y
CONFIG_IP_VS_PROTO_UDP=y
CONFIG_IP_VS_PROTO_ESP=y
CONFIG_IP_VS_PROTO_AH=y
# IPVS scheduler
CONFIG_IP_VS_RR=m
CONFIG_IP_VS_WRR=m
CONFIG_IP_VS_LC=m
CONFIG_IP_VS_WLC=m
CONFIG_IP_VS_LBLC=m
CONFIG_IP_VS_LBLCR=m
CONFIG_IP_VS_DH=m
CONFIG_IP_VS_SH=m
CONFIG_IP_VS_SED=m
CONFIG_IP_VS_NQ=m
# IPVS application helper
CONFIG_IP_VS_FTP=m
CONFIG_IPV6=m
CONFIG_IPV6_PRIVACY=y
CONFIG_INET6_AH=m
CONFIG_INET6_ESP=m
CONFIG_INET6_IPCOMP=m
CONFIG_IPV6_TUNNEL=m
CONFIG_NETFILTER=y
# CONFIG_NETFILTER_DEBUG is not set
CONFIG_BRIDGE_NETFILTER=y
# IP: Netfilter Configuration
CONFIG_IP_NF_CONNTRACK=m
CONFIG_IP_NF_FTP=m
CONFIG_IP_NF_IRC=m
CONFIG_IP_NF_TFTP=m
CONFIG_IP_NF_AMANDA=m
CONFIG_IP_NF_QUEUE=m
CONFIG_IP_NF_IPTABLES=m
CONFIG_IP_NF_MATCH_LIMIT=m
CONFIG_IP_NF_MATCH_IPRANGE=m
CONFIG_IP_NF_MATCH_MAC=m
CONFIG_IP_NF_MATCH_PKTTYPE=m
CONFIG_IP_NF_MATCH_MARK=m
CONFIG_IP_NF_MATCH_MULTIPORT=m
CONFIG_IP_NF_MATCH_TOS=m
CONFIG_IP_NF_MATCH_RECENT=m
CONFIG_IP_NF_MATCH_ECN=m
CONFIG_IP_NF_MATCH_DSCP=m
CONFIG_IP_NF_MATCH_AH_ESP=m
CONFIG_IP_NF_MATCH_LENGTH=m
CONFIG_IP_NF_MATCH_TTL=m
CONFIG_IP_NF_MATCH_TCPMSS=m
CONFIG_IP_NF_MATCH_HELPER=m
CONFIG_IP_NF_MATCH_STATE=m
CONFIG_IP_NF_MATCH_CONNTRACK=m
CONFIG_IP_NF_MATCH_OWNER=m
CONFIG_IP_NF_MATCH_PHYSDEV=m
CONFIG_IP_NF_FILTER=m
CONFIG_IP_NF_TARGET_REJECT=m
CONFIG_IP_NF_NAT=m
CONFIG_IP_NF_NAT_NEEDED=y
CONFIG_IP_NF_TARGET_MASQUERADE=m
CONFIG_IP_NF_TARGET_REDIRECT=m
CONFIG_IP_NF_TARGET_NETMAP=m
CONFIG_IP_NF_TARGET_SAME=m
CONFIG_IP_NF_TARGET_TARPIT=m
CONFIG_IP_NF_NAT_LOCAL=y
CONFIG_IP_NF_NAT_SNMP_BASIC=m
CONFIG_IP_NF_NAT_IRC=m
CONFIG_IP_NF_NAT_FTP=m
CONFIG_IP_NF_NAT_TFTP=m
CONFIG_IP_NF_NAT_AMANDA=m
CONFIG_IP_NF_MANGLE=m
CONFIG_IP_NF_TARGET_TOS=m
CONFIG_IP_NF_TARGET_ECN=m
CONFIG_IP_NF_TARGET_DSCP=m
CONFIG_IP_NF_TARGET_MARK=m
CONFIG_IP_NF_TARGET_CLASSIFY=m
CONFIG_IP_NF_TARGET_LOG=m
CONFIG_IP_NF_TARGET_ULOG=m
CONFIG_IP_NF_TARGET_TCPMSS=m
CONFIG_IP_NF_ARPTABLES=m
CONFIG_IP_NF_ARPFILTER=m
CONFIG_IP_NF_ARP_MANGLE=m
CONFIG_IP_NF_COMPAT_IPCHAINS=m
CONFIG_IP_NF_COMPAT_IPFWADM=m
CONFIG_IP_NF_TARGET_NOTRACK=m
CONFIG_IP_NF_RAW=m
CONFIG_IP_NF_MATCH_ADDRTYPE=m
CONFIG_IP_NF_MATCH_REALM=m
CONFIG_IP_NF_CONNTRACK_MARK=y
CONFIG_IP_NF_TARGET_CONNMARK=m
CONFIG_IP_NF_MATCH_CONNMARK=m
CONFIG_IP_NF_TARGET_IPMARK=m
CONFIG_IP_NF_MATCH_CONDITION=m
CONFIG_IP_NF_MATCH_CONNLIMIT=m
CONFIG_IP_NF_MATCH_DSTLIMIT=m
CONFIG_IP_NF_NAT_H323=m
CONFIG_IP_NF_H323=m
CONFIG_IP_NF_MATCH_MPORT=m
CONFIG_IP_NF_MATCH_NTH=m
CONFIG_IP_NF_MATCH_OSF=m
CONFIG_IP_NF_CT_PROTO_GRE=m
CONFIG_IP_NF_PPTP=m
CONFIG_IP_NF_MATCH_QUOTA=m
CONFIG_IP_NF_MATCH_RANDOM=m
CONFIG_IP_NF_MATCH_TIME=m
# IPv6: Netfilter Configuration
CONFIG_IP6_NF_QUEUE=m
CONFIG_IP6_NF_IPTABLES=m
CONFIG_IP6_NF_MATCH_LIMIT=m
CONFIG_IP6_NF_MATCH_MAC=m
CONFIG_IP6_NF_MATCH_RT=m
CONFIG_IP6_NF_MATCH_OPTS=m
CONFIG_IP6_NF_MATCH_FRAG=m
CONFIG_IP6_NF_MATCH_HL=m
CONFIG_IP6_NF_MATCH_MULTIPORT=m
CONFIG_IP6_NF_MATCH_OWNER=m
CONFIG_IP6_NF_MATCH_MARK=m
CONFIG_IP6_NF_MATCH_IPV6HEADER=m
CONFIG_IP6_NF_MATCH_AHESP=m
CONFIG_IP6_NF_MATCH_LENGTH=m
CONFIG_IP6_NF_MATCH_EUI64=m
CONFIG_IP6_NF_FILTER=m
CONFIG_IP6_NF_TARGET_LOG=m
CONFIG_IP6_NF_MANGLE=m
CONFIG_IP6_NF_TARGET_MARK=m
CONFIG_IP6_NF_RAW=m
CONFIG_IP6_NF_MATCH_CONDITION=m
CONFIG_IP6_NF_MATCH_NTH=m
CONFIG_IP6_NF_MATCH_RANDOM=m
# DECnet: Netfilter Configuration
CONFIG_DECNET_NF_GRABULATOR=m
# Bridge: Netfilter Configuration
CONFIG_BRIDGE_NF_EBTABLES=m
CONFIG_BRIDGE_EBT_BROUTE=m
CONFIG_BRIDGE_EBT_T_FILTER=m
CONFIG_BRIDGE_EBT_T_NAT=m
CONFIG_BRIDGE_EBT_802_3=m
CONFIG_BRIDGE_EBT_AMONG=m
CONFIG_BRIDGE_EBT_ARP=m
CONFIG_BRIDGE_EBT_IP=m
CONFIG_BRIDGE_EBT_LIMIT=m
CONFIG_BRIDGE_EBT_MARK=m
CONFIG_BRIDGE_EBT_PKTTYPE=m
CONFIG_BRIDGE_EBT_STP=m
CONFIG_BRIDGE_EBT_VLAN=m
CONFIG_BRIDGE_EBT_ARPREPLY=m
CONFIG_BRIDGE_EBT_DNAT=m
CONFIG_BRIDGE_EBT_MARK_T=m
CONFIG_BRIDGE_EBT_REDIRECT=m
CONFIG_BRIDGE_EBT_SNAT=m
CONFIG_BRIDGE_EBT_LOG=m
CONFIG_XFRM=y
CONFIG_XFRM_USER=m
# SCTP Configuration (EXPERIMENTAL)
CONFIG_IP_SCTP=m
# CONFIG_SCTP_DBG_MSG is not set
# CONFIG_SCTP_DBG_OBJCNT is not set
CONFIG_SCTP_HMAC_NONE=y
# CONFIG_SCTP_HMAC_SHA1 is not set
# CONFIG_SCTP_HMAC_MD5 is not set
CONFIG_ATM=m
CONFIG_ATM_CLIP=m
# CONFIG_ATM_CLIP_NO_ICMP is not set
CONFIG_ATM_LANE=m
CONFIG_ATM_MPOA=m
CONFIG_ATM_BR2684=m
CONFIG_ATM_BR2684_IPFILTER=y
CONFIG_BRIDGE=m
CONFIG_VLAN_8021Q=m
CONFIG_DECNET=m
# CONFIG_DECNET_SIOCGIFCONF is not set
# CONFIG_DECNET_ROUTER is not set
CONFIG_LLC=y
CONFIG_LLC2=m
CONFIG_IPX=m
# CONFIG_IPX_INTERN is not set
CONFIG_ATALK=m
CONFIG_DEV_APPLETALK=y
CONFIG_LTPC=m
CONFIG_COPS=m
CONFIG_COPS_DAYNA=y
CONFIG_COPS_TANGENT=y
CONFIG_IPDDP=m
CONFIG_IPDDP_ENCAP=y
CONFIG_IPDDP_DECAP=y
CONFIG_X25=m
CONFIG_LAPB=m
# CONFIG_NET_DIVERT is not set
CONFIG_ECONET=m
CONFIG_ECONET_AUNUDP=y
CONFIG_ECONET_NATIVE=y
CONFIG_WAN_ROUTER=m
# CONFIG_NET_HW_FLOWCONTROL is not set
# QoS and/or fair queueing
CONFIG_NET_SCHED=y
CONFIG_NET_SCH_CLK_JIFFIES=y
# CONFIG_NET_SCH_CLK_GETTIMEOFDAY is not set
# CONFIG_NET_SCH_CLK_CPU is not set
CONFIG_NET_SCH_CBQ=m
CONFIG_NET_SCH_HTB=m
CONFIG_NET_SCH_HFSC=m
# CONFIG_NET_SCH_ATM is not set
CONFIG_NET_SCH_PRIO=m
CONFIG_NET_SCH_RED=m
CONFIG_NET_SCH_SFQ=m
CONFIG_NET_SCH_TEQL=m
CONFIG_NET_SCH_TBF=m
CONFIG_NET_SCH_GRED=m
CONFIG_NET_SCH_DSMARK=m
CONFIG_NET_SCH_NETEM=m
CONFIG_NET_SCH_INGRESS=m
CONFIG_NET_QOS=y
CONFIG_NET_ESTIMATOR=y
CONFIG_NET_CLS=y
CONFIG_NET_CLS_TCINDEX=m
CONFIG_NET_CLS_ROUTE4=m
CONFIG_NET_CLS_ROUTE=y
CONFIG_NET_CLS_FW=m
CONFIG_NET_CLS_U32=m
# CONFIG_CLS_U32_PERF is not set
# CONFIG_NET_CLS_IND is not set
CONFIG_NET_CLS_RSVP=m
CONFIG_NET_CLS_RSVP6=m
# CONFIG_NET_CLS_ACT is not set
CONFIG_NET_CLS_POLICE=y
# Network testing
CONFIG_NET_PKTGEN=m
# CONFIG_KGDBOE is not set
CONFIG_NETPOLL=y
# CONFIG_NETPOLL_RX is not set
# CONFIG_NETPOLL_TRAP is not set
CONFIG_NET_POLL_CONTROLLER=y
CONFIG_HAMRADIO=y
# Packet Radio protocols
CONFIG_AX25=m
CONFIG_AX25_DAMA_SLAVE=y
CONFIG_NETROM=m
CONFIG_ROSE=m
# AX.25 network device drivers
CONFIG_MKISS=m
CONFIG_6PACK=m
CONFIG_BPQETHER=m
CONFIG_DMASCC=m
CONFIG_SCC=m
# CONFIG_SCC_DELAY is not set
# CONFIG_SCC_TRXECHO is not set
CONFIG_BAYCOM_SER_FDX=m
CONFIG_BAYCOM_SER_HDX=m
CONFIG_BAYCOM_PAR=m
CONFIG_BAYCOM_EPP=m
CONFIG_YAM=m
CONFIG_IRDA=m
# IrDA protocols
CONFIG_IRLAN=m
CONFIG_IRNET=m
CONFIG_IRCOMM=m
CONFIG_IRDA_ULTRA=y
# IrDA options
CONFIG_IRDA_CACHE_LAST_LSAP=y
CONFIG_IRDA_FAST_RR=y
# CONFIG_IRDA_DEBUG is not set
# Infrared-port device drivers
# SIR device drivers
CONFIG_IRTTY_SIR=m
# Dongle support
CONFIG_DONGLE=y
CONFIG_ESI_DONGLE=m
CONFIG_ACTISYS_DONGLE=m
CONFIG_TEKRAM_DONGLE=m
CONFIG_LITELINK_DONGLE=m
CONFIG_MA600_DONGLE=m
CONFIG_GIRBIL_DONGLE=m
CONFIG_MCP2120_DONGLE=m
CONFIG_OLD_BELKIN_DONGLE=m
CONFIG_ACT200L_DONGLE=m
# Old SIR device drivers
CONFIG_IRPORT_SIR=m
# Old Serial dongle support
CONFIG_DONGLE_OLD=y
CONFIG_ESI_DONGLE_OLD=m
CONFIG_ACTISYS_DONGLE_OLD=m
# CONFIG_TEKRAM_DONGLE_OLD is not set
CONFIG_GIRBIL_DONGLE_OLD=m
CONFIG_LITELINK_DONGLE_OLD=m
CONFIG_MCP2120_DONGLE_OLD=m
CONFIG_OLD_BELKIN_DONGLE_OLD=m
CONFIG_ACT200L_DONGLE_OLD=m
CONFIG_MA600_DONGLE_OLD=m
# FIR device drivers
CONFIG_USB_IRDA=m
CONFIG_SIGMATEL_FIR=m
CONFIG_NSC_FIR=m
CONFIG_WINBOND_FIR=m
CONFIG_TOSHIBA_FIR=m
CONFIG_SMC_IRCC_FIR=m
CONFIG_ALI_FIR=m
CONFIG_VLSI_FIR=m
CONFIG_VIA_FIR=m
CONFIG_BT=m
CONFIG_BT_L2CAP=m
CONFIG_BT_SCO=m
CONFIG_BT_RFCOMM=m
CONFIG_BT_RFCOMM_TTY=y
CONFIG_BT_BNEP=m
CONFIG_BT_BNEP_MC_FILTER=y
CONFIG_BT_BNEP_PROTO_FILTER=y
CONFIG_BT_CMTP=m
CONFIG_BT_HIDP=m
# Bluetooth device drivers
CONFIG_BT_HCIUSB=m
CONFIG_BT_HCIUSB_SCO=y
CONFIG_BT_HCIUART=m
CONFIG_BT_HCIUART_H4=y
CONFIG_BT_HCIUART_BCSP=y
CONFIG_BT_HCIUART_BCSP_TXCRC=y
CONFIG_BT_HCIBCM203X=m
CONFIG_BT_HCIBFUSB=m
CONFIG_BT_HCIDTL1=m
CONFIG_BT_HCIBT3C=m
CONFIG_BT_HCIBLUECARD=m
CONFIG_BT_HCIBTUART=m
CONFIG_BT_HCIVHCI=m
CONFIG_NETDEVICES=y
CONFIG_DUMMY=m
CONFIG_BONDING=m
CONFIG_EQUALIZER=m
CONFIG_TUN=m
CONFIG_ETHERTAP=m
CONFIG_NET_SB1000=m
# ARCnet devices
CONFIG_ARCNET=m
CONFIG_ARCNET_1201=m
CONFIG_ARCNET_1051=m
CONFIG_ARCNET_RAW=m
CONFIG_ARCNET_COM90xx=m
CONFIG_ARCNET_COM90xxIO=m
CONFIG_ARCNET_RIM_I=m
CONFIG_ARCNET_COM20020=m
CONFIG_ARCNET_COM20020_ISA=m
CONFIG_ARCNET_COM20020_PCI=m
# Ethernet (10 or 100Mbit)
CONFIG_NET_ETHERNET=y
CONFIG_MII=m
CONFIG_HAPPYMEAL=m
CONFIG_SUNGEM=m
CONFIG_NET_VENDOR_3COM=y
CONFIG_EL1=m
CONFIG_EL2=m
CONFIG_ELPLUS=m
CONFIG_EL16=m
CONFIG_EL3=m
CONFIG_3C515=m
CONFIG_VORTEX=m
CONFIG_TYPHOON=m
CONFIG_LANCE=m
CONFIG_NET_VENDOR_SMC=y
CONFIG_WD80x3=m
CONFIG_ULTRA=m
CONFIG_SMC9194=m
CONFIG_NET_VENDOR_RACAL=y
CONFIG_NI5010=m
CONFIG_NI52=m
CONFIG_NI65=m
# Tulip family network device support
CONFIG_NET_TULIP=y
CONFIG_DE2104X=m
CONFIG_TULIP=m
# CONFIG_TULIP_MWI is not set
# CONFIG_TULIP_MMIO is not set
# CONFIG_TULIP_NAPI is not set
CONFIG_DE4X5=m
CONFIG_WINBOND_840=m
CONFIG_DM9102=m
CONFIG_PCMCIA_XIRCOM=m
CONFIG_PCMCIA_XIRTULIP=m
CONFIG_AT1700=m
CONFIG_DEPCA=m
CONFIG_HP100=m
CONFIG_NET_ISA=y
CONFIG_E2100=m
CONFIG_EWRK3=m
CONFIG_EEXPRESS=m
CONFIG_EEXPRESS_PRO=m
CONFIG_HPLAN_PLUS=m
CONFIG_HPLAN=m
CONFIG_LP486E=m
CONFIG_ETH16I=m
CONFIG_NE2000=m
CONFIG_ZNET=m
CONFIG_SEEQ8005=m
CONFIG_NET_PCI=y
CONFIG_PCNET32=m
CONFIG_AMD8111_ETH=m
# CONFIG_AMD8111E_NAPI is not set
CONFIG_ADAPTEC_STARFIRE=m
# CONFIG_ADAPTEC_STARFIRE_NAPI is not set
CONFIG_AC3200=m
CONFIG_APRICOT=m
CONFIG_B44=m
CONFIG_FORCEDETH=m
CONFIG_CS89x0=m
CONFIG_DGRS=m
CONFIG_EEPRO100=m
# CONFIG_EEPRO100_PIO is not set
CONFIG_E100=m
# CONFIG_E100_NAPI is not set
CONFIG_FEALNX=m
CONFIG_NATSEMI=m
CONFIG_NE2K_PCI=m
CONFIG_8139CP=m
CONFIG_8139TOO=m
# CONFIG_8139TOO_PIO is not set
# CONFIG_8139TOO_TUNE_TWISTER is not set
CONFIG_8139TOO_8129=y
# CONFIG_8139_OLD_RX_RESET is not set
CONFIG_SIS900=m
CONFIG_EPIC100=m
CONFIG_SUNDANCE=m
# CONFIG_SUNDANCE_MMIO is not set
CONFIG_TLAN=m
CONFIG_VIA_RHINE=m
# CONFIG_VIA_RHINE_MMIO is not set
CONFIG_VIA_VELOCITY=m
CONFIG_NET_POCKET=y
CONFIG_ATP=m
CONFIG_DE600=m
CONFIG_DE620=m
# Ethernet (1000 Mbit)
CONFIG_ACENIC=m
# CONFIG_ACENIC_OMIT_TIGON_I is not set
CONFIG_DL2K=m
CONFIG_E1000=m
# CONFIG_E1000_NAPI is not set
CONFIG_NS83820=m
CONFIG_HAMACHI=m
CONFIG_YELLOWFIN=m
CONFIG_R8169=m
CONFIG_SK98LIN=m
CONFIG_TIGON3=m
# Ethernet (10000 Mbit)
CONFIG_IXGB=m
# CONFIG_IXGB_NAPI is not set
CONFIG_S2IO=m
# CONFIG_S2IO_NAPI is not set
# Token Ring devices
CONFIG_TR=y
CONFIG_IBMTR=m
CONFIG_IBMOL=m
CONFIG_IBMLS=m
CONFIG_3C359=m
CONFIG_TMS380TR=m
CONFIG_TMSPCI=m
CONFIG_SKISA=m
CONFIG_PROTEON=m
CONFIG_ABYSS=m
CONFIG_SMCTR=m
# Wireless LAN (non-hamradio)
CONFIG_NET_RADIO=y
# Obsolete Wireless cards support (pre-802.11)
CONFIG_STRIP=m
CONFIG_ARLAN=m
CONFIG_WAVELAN=m
CONFIG_PCMCIA_WAVELAN=m
CONFIG_PCMCIA_NETWAVE=m
# Wireless 802.11 Frequency Hopping cards support
CONFIG_PCMCIA_RAYCS=m
# Wireless 802.11b ISA/PCI cards support
CONFIG_AIRO=m
CONFIG_HERMES=m
CONFIG_PLX_HERMES=m
CONFIG_TMD_HERMES=m
CONFIG_PCI_HERMES=m
CONFIG_ATMEL=m
CONFIG_PCI_ATMEL=m
# Wireless 802.11b Pcmcia/Cardbus cards support
CONFIG_PCMCIA_HERMES=m
CONFIG_AIRO_CS=m
CONFIG_PCMCIA_ATMEL=m
CONFIG_PCMCIA_WL3501=m
# Prism GT/Duette 802.11(a/b/g) PCI/Cardbus support
CONFIG_PRISM54=m
CONFIG_NET_WIRELESS=y
# PCMCIA network device support
CONFIG_NET_PCMCIA=y
CONFIG_PCMCIA_3C589=m
CONFIG_PCMCIA_3C574=m
CONFIG_PCMCIA_FMVJ18X=m
CONFIG_PCMCIA_PCNET=m
CONFIG_PCMCIA_NMCLAN=m
CONFIG_PCMCIA_SMC91C92=m
CONFIG_PCMCIA_XIRC2PS=m
CONFIG_PCMCIA_AXNET=m
CONFIG_ARCNET_COM20020_CS=m
CONFIG_PCMCIA_IBMTR=m
# Wan interfaces
CONFIG_WAN=y
CONFIG_HOSTESS_SV11=m
CONFIG_COSA=m
# CONFIG_DSCC4 is not set
# CONFIG_LANMEDIA is not set
CONFIG_SEALEVEL_4021=m
# CONFIG_SYNCLINK_SYNCPPP is not set
CONFIG_HDLC=m
CONFIG_HDLC_RAW=y
CONFIG_HDLC_RAW_ETH=y
CONFIG_HDLC_CISCO=y
CONFIG_HDLC_FR=y
CONFIG_HDLC_PPP=y
CONFIG_HDLC_X25=y
CONFIG_PCI200SYN=m
CONFIG_WANXL=m
CONFIG_PC300=m
CONFIG_PC300_MLPPP=y
CONFIG_N2=m
CONFIG_C101=m
CONFIG_FARSYNC=m
CONFIG_DLCI=m
CONFIG_DLCI_COUNT=24
CONFIG_DLCI_MAX=8
CONFIG_SDLA=m
CONFIG_WAN_ROUTER_DRIVERS=y
CONFIG_CYCLADES_SYNC=m
CONFIG_CYCLOMX_X25=y
# CONFIG_LAPBETHER is not set
# CONFIG_X25_ASY is not set
CONFIG_SBNI=m
CONFIG_SBNI_MULTILINE=y
# ATM drivers
CONFIG_ATM_TCP=m
CONFIG_ATM_LANAI=m
CONFIG_ATM_ENI=m
# CONFIG_ATM_ENI_DEBUG is not set
# CONFIG_ATM_ENI_TUNE_BURST is not set
CONFIG_ATM_FIRESTREAM=m
CONFIG_ATM_ZATM=m
# CONFIG_ATM_ZATM_DEBUG is not set
CONFIG_ATM_NICSTAR=m
CONFIG_ATM_NICSTAR_USE_SUNI=y
CONFIG_ATM_NICSTAR_USE_IDT77105=y
CONFIG_ATM_IDT77252=m
# CONFIG_ATM_IDT77252_DEBUG is not set
# CONFIG_ATM_IDT77252_RCV_ALL is not set
CONFIG_ATM_IDT77252_USE_SUNI=y
CONFIG_ATM_AMBASSADOR=m
# CONFIG_ATM_AMBASSADOR_DEBUG is not set
CONFIG_ATM_HORIZON=m
# CONFIG_ATM_HORIZON_DEBUG is not set
CONFIG_ATM_IA=m
# CONFIG_ATM_IA_DEBUG is not set
CONFIG_ATM_FORE200E_MAYBE=m
CONFIG_ATM_FORE200E_PCA=y
CONFIG_ATM_FORE200E_PCA_DEFAULT_FW=y
CONFIG_ATM_FORE200E_USE_TASKLET=y
CONFIG_ATM_FORE200E_TX_RETRY=16
CONFIG_ATM_FORE200E_DEBUG=0
CONFIG_ATM_FORE200E=m
CONFIG_ATM_HE=m
CONFIG_ATM_HE_USE_SUNI=y
CONFIG_FDDI=y
CONFIG_DEFXX=m
CONFIG_SKFP=m
# CONFIG_HIPPI is not set
CONFIG_PLIP=m
CONFIG_PPP=m
CONFIG_PPP_MULTILINK=y
CONFIG_PPP_FILTER=y
CONFIG_PPP_ASYNC=m
CONFIG_PPP_SYNC_TTY=m
CONFIG_PPP_DEFLATE=m
CONFIG_PPP_BSDCOMP=m
CONFIG_PPP_MPPE_MPPC=m
CONFIG_PPPOE=m
CONFIG_PPPOATM=m
CONFIG_SLIP=m
CONFIG_SLIP_COMPRESSED=y
CONFIG_SLIP_SMART=y
CONFIG_SLIP_MODE_SLIP6=y
CONFIG_NET_FC=y
CONFIG_SHAPER=m
CONFIG_NETCONSOLE=m
# ISDN subsystem
CONFIG_ISDN=m
# Old ISDN4Linux
CONFIG_ISDN_I4L=m
CONFIG_ISDN_PPP=y
CONFIG_ISDN_PPP_VJ=y
CONFIG_ISDN_MPP=y
# CONFIG_IPPP_FILTER is not set
CONFIG_ISDN_PPP_BSDCOMP=m
CONFIG_ISDN_AUDIO=y
CONFIG_ISDN_TTY_FAX=y
# CONFIG_ISDN_X25 is not set
# ISDN feature submodules
CONFIG_ISDN_DRV_LOOP=m
# ISDN4Linux hardware drivers
# Passive cards
CONFIG_ISDN_DRV_HISAX=m
# D-channel protocol features
CONFIG_HISAX_EURO=y
CONFIG_DE_AOC=y
# CONFIG_HISAX_NO_SENDCOMPLETE is not set
# CONFIG_HISAX_NO_LLC is not set
# CONFIG_HISAX_NO_KEYPAD is not set
CONFIG_HISAX_1TR6=y
CONFIG_HISAX_NI1=y
CONFIG_HISAX_MAX_CARDS=8
# HiSax supported cards
CONFIG_HISAX_16_0=y
CONFIG_HISAX_16_3=y
CONFIG_HISAX_TELESPCI=y
CONFIG_HISAX_S0BOX=y
CONFIG_HISAX_AVM_A1=y
CONFIG_HISAX_FRITZPCI=y
CONFIG_HISAX_AVM_A1_PCMCIA=y
CONFIG_HISAX_ELSA=y
CONFIG_HISAX_IX1MICROR2=y
CONFIG_HISAX_DIEHLDIVA=y
CONFIG_HISAX_ASUSCOM=y
CONFIG_HISAX_TELEINT=y
CONFIG_HISAX_HFCS=y
CONFIG_HISAX_SEDLBAUER=y
CONFIG_HISAX_SPORTSTER=y
CONFIG_HISAX_MIC=y
CONFIG_HISAX_NETJET=y
CONFIG_HISAX_NETJET_U=y
CONFIG_HISAX_NICCY=y
CONFIG_HISAX_ISURF=y
CONFIG_HISAX_HSTSAPHIR=y
CONFIG_HISAX_BKM_A4T=y
CONFIG_HISAX_SCT_QUADRO=y
CONFIG_HISAX_GAZEL=y
CONFIG_HISAX_HFC_PCI=y
CONFIG_HISAX_W6692=y
CONFIG_HISAX_HFC_SX=y
CONFIG_HISAX_ENTERNOW_PCI=y
CONFIG_HISAX_DEBUG=y
# HiSax PCMCIA card service modules
CONFIG_HISAX_SEDLBAUER_CS=m
CONFIG_HISAX_ELSA_CS=m
CONFIG_HISAX_AVM_A1_CS=m
CONFIG_HISAX_TELES_CS=m
# HiSax sub driver modules
CONFIG_HISAX_ST5481=m
CONFIG_HISAX_HFCUSB=m
CONFIG_HISAX_FRITZ_PCIPNP=m
CONFIG_HISAX_HDLC=y
# Active cards
CONFIG_ISDN_DRV_ICN=m
CONFIG_ISDN_DRV_PCBIT=m
CONFIG_ISDN_DRV_SC=m
CONFIG_ISDN_DRV_ACT2000=m
CONFIG_ISDN_DRV_TPAM=m
CONFIG_HYSDN=m
CONFIG_HYSDN_CAPI=y
# CAPI subsystem
CONFIG_ISDN_CAPI=m
CONFIG_ISDN_DRV_AVMB1_VERBOSE_REASON=y
CONFIG_ISDN_CAPI_MIDDLEWARE=y
CONFIG_ISDN_CAPI_CAPI20=m
CONFIG_ISDN_CAPI_CAPIFS_BOOL=y
CONFIG_ISDN_CAPI_CAPIFS=m
CONFIG_ISDN_CAPI_CAPIDRV=m
# CAPI hardware drivers
# Active AVM cards
CONFIG_CAPI_AVM=y
CONFIG_ISDN_DRV_AVMB1_B1ISA=m
CONFIG_ISDN_DRV_AVMB1_B1PCI=m
CONFIG_ISDN_DRV_AVMB1_B1PCIV4=y
CONFIG_ISDN_DRV_AVMB1_T1ISA=m
CONFIG_ISDN_DRV_AVMB1_B1PCMCIA=m
CONFIG_ISDN_DRV_AVMB1_AVM_CS=m
CONFIG_ISDN_DRV_AVMB1_T1PCI=m
CONFIG_ISDN_DRV_AVMB1_C4=m
# Active Eicon DIVA Server cards
CONFIG_CAPI_EICON=y
CONFIG_ISDN_DIVAS=m
CONFIG_ISDN_DIVAS_BRIPCI=y
CONFIG_ISDN_DIVAS_PRIPCI=y
CONFIG_ISDN_DIVAS_DIVACAPI=m
CONFIG_ISDN_DIVAS_USERIDI=m
CONFIG_ISDN_DIVAS_MAINT=m
# Telephony Support
CONFIG_PHONE=m
CONFIG_PHONE_IXJ=m
CONFIG_PHONE_IXJ_PCMCIA=m
# Input device support
CONFIG_INPUT=y
# Userland interfaces
CONFIG_INPUT_MOUSEDEV=y
CONFIG_INPUT_MOUSEDEV_PSAUX=y
CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024
CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768
CONFIG_INPUT_JOYDEV=m
CONFIG_INPUT_TSDEV=m
CONFIG_INPUT_TSDEV_SCREEN_X=240
CONFIG_INPUT_TSDEV_SCREEN_Y=320
CONFIG_INPUT_EVDEV=m
# CONFIG_INPUT_EVBUG is not set
# Input I/O drivers
CONFIG_GAMEPORT=m
CONFIG_SOUND_GAMEPORT=m
CONFIG_GAMEPORT_NS558=m
CONFIG_GAMEPORT_L4=m
CONFIG_GAMEPORT_EMU10K1=m
CONFIG_GAMEPORT_VORTEX=m
CONFIG_GAMEPORT_FM801=m
CONFIG_GAMEPORT_CS461x=m
CONFIG_SERIO=y
CONFIG_SERIO_I8042=y
CONFIG_SERIO_SERPORT=m
CONFIG_SERIO_CT82C710=m
CONFIG_SERIO_PARKBD=m
CONFIG_SERIO_PCIPS2=m
# Input Device Drivers
CONFIG_INPUT_KEYBOARD=y
CONFIG_KEYBOARD_ATKBD=y
CONFIG_KEYBOARD_SUNKBD=m
CONFIG_KEYBOARD_LKKBD=m
CONFIG_KEYBOARD_XTKBD=m
CONFIG_KEYBOARD_NEWTON=m
CONFIG_INPUT_MOUSE=y
CONFIG_MOUSE_PS2=y
CONFIG_MOUSE_SERIAL=m
CONFIG_MOUSE_INPORT=m
# CONFIG_MOUSE_ATIXL is not set
CONFIG_MOUSE_LOGIBM=m
CONFIG_MOUSE_PC110PAD=m
CONFIG_MOUSE_VSXXXAA=m
CONFIG_INPUT_JOYSTICK=y
CONFIG_JOYSTICK_ANALOG=m
CONFIG_JOYSTICK_A3D=m
CONFIG_JOYSTICK_ADI=m
CONFIG_JOYSTICK_COBRA=m
CONFIG_JOYSTICK_GF2K=m
CONFIG_JOYSTICK_GRIP=m
CONFIG_JOYSTICK_GRIP_MP=m
CONFIG_JOYSTICK_GUILLEMOT=m
CONFIG_JOYSTICK_INTERACT=m
CONFIG_JOYSTICK_SIDEWINDER=m
CONFIG_JOYSTICK_TMDC=m
CONFIG_JOYSTICK_IFORCE=m
CONFIG_JOYSTICK_IFORCE_USB=y
CONFIG_JOYSTICK_IFORCE_232=y
CONFIG_JOYSTICK_WARRIOR=m
CONFIG_JOYSTICK_MAGELLAN=m
CONFIG_JOYSTICK_SPACEORB=m
CONFIG_JOYSTICK_SPACEBALL=m
CONFIG_JOYSTICK_STINGER=m
CONFIG_JOYSTICK_TWIDDLER=m
CONFIG_JOYSTICK_DB9=m
CONFIG_JOYSTICK_GAMECON=m
CONFIG_JOYSTICK_TURBOGRAFX=m
CONFIG_INPUT_JOYDUMP=m
CONFIG_INPUT_TOUCHSCREEN=y
CONFIG_TOUCHSCREEN_GUNZE=m
CONFIG_INPUT_MISC=y
CONFIG_INPUT_PCSPKR=m
CONFIG_INPUT_UINPUT=m
# Character devices
CONFIG_VT=y
CONFIG_VT_CONSOLE=y
CONFIG_HW_CONSOLE=y
CONFIG_SERIAL_NONSTANDARD=y
CONFIG_COMPUTONE=m
CONFIG_ROCKETPORT=m
CONFIG_CYCLADES=m
# CONFIG_CYZ_INTR is not set
CONFIG_DIGIEPCA=m
CONFIG_ESPSERIAL=m
CONFIG_MOXA_INTELLIO=m
CONFIG_MOXA_SMARTIO=m
CONFIG_ISI=m
CONFIG_SYNCLINK=m
CONFIG_SYNCLINKMP=m
CONFIG_N_HDLC=m
CONFIG_RISCOM8=m
CONFIG_SPECIALIX=m
# CONFIG_SPECIALIX_RTSCTS is not set
CONFIG_SX=m
CONFIG_RIO=m
# CONFIG_RIO_OLDPCI is not set
CONFIG_STALDRV=y
CONFIG_STALLION=m
CONFIG_ISTALLION=m
# Serial drivers
CONFIG_SERIAL_8250=y
CONFIG_SERIAL_8250_CONSOLE=y
CONFIG_SERIAL_8250_CS=m
CONFIG_SERIAL_8250_ACPI=y
CONFIG_SERIAL_WACOM_ACPI=m
CONFIG_SERIAL_8250_NR_UARTS=4
CONFIG_SERIAL_8250_EXTENDED=y
# CONFIG_SERIAL_8250_MANY_PORTS is not set
CONFIG_SERIAL_8250_SHARE_IRQ=y
# CONFIG_SERIAL_8250_DETECT_IRQ is not set
# CONFIG_SERIAL_8250_MULTIPORT is not set
# CONFIG_SERIAL_8250_RSA is not set
# Non-8250 serial port support
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
CONFIG_UNIX98_PTYS=y
CONFIG_LEGACY_PTYS=y
CONFIG_LEGACY_PTY_COUNT=1024
CONFIG_PRINTER=m
CONFIG_LP_CONSOLE=y
CONFIG_PPDEV=m
CONFIG_TIPAR=m
CONFIG_QIC02_TAPE=m
CONFIG_QIC02_DYNCONF=y
# Setting runtime QIC-02 configuration is done with qic02conf
# from the tpqic02-support package.  It is available at
# metalab.unc.edu or ftp://titus.cfw.com/pub/Linux/util/
# IPMI
CONFIG_IPMI_HANDLER=m
CONFIG_IPMI_PANIC_EVENT=y
CONFIG_IPMI_PANIC_STRING=y
CONFIG_IPMI_DEVICE_INTERFACE=m
CONFIG_IPMI_SI=m
CONFIG_IPMI_SMB=m
CONFIG_IPMI_WATCHDOG=m
# Watchdog Cards
CONFIG_WATCHDOG=y
CONFIG_WATCHDOG_NOWAYOUT=y
# Watchdog Device Drivers
CONFIG_SOFT_WATCHDOG=m
CONFIG_ACQUIRE_WDT=m
CONFIG_ADVANTECH_WDT=m
CONFIG_ALIM1535_WDT=m
CONFIG_ALIM7101_WDT=m
CONFIG_SC520_WDT=m
CONFIG_EUROTECH_WDT=m
CONFIG_IB700_WDT=m
CONFIG_WAFER_WDT=m
CONFIG_I8XX_TCO=m
# CONFIG_SC1200_WDT is not set
# CONFIG_SCx200_WDT is not set
CONFIG_60XX_WDT=m
CONFIG_CPU5_WDT=m
CONFIG_W83627HF_WDT=m
CONFIG_W83877F_WDT=m
CONFIG_MACHZ_WDT=m
# ISA-based Watchdog Cards
CONFIG_PCWATCHDOG=m
CONFIG_MIXCOMWD=m
CONFIG_WDT=m
CONFIG_WDT_501=y
# PCI-based Watchdog Cards
CONFIG_PCIPCWATCHDOG=m
CONFIG_WDTPCI=m
CONFIG_WDT_501_PCI=y
# USB-based Watchdog Cards
CONFIG_USBPCWATCHDOG=m
CONFIG_HW_RANDOM=m
CONFIG_NVRAM=m
CONFIG_RTC=m
CONFIG_GEN_RTC=m
CONFIG_GEN_RTC_X=y
CONFIG_DTLK=m
CONFIG_R3964=m
CONFIG_APPLICOM=m
CONFIG_SONYPI=m
# Ftape, the floppy tape device driver
CONFIG_FTAPE=m
CONFIG_ZFTAPE=m
CONFIG_ZFT_DFLT_BLK_SZ=10240
# The compressor will be built as a module only!
CONFIG_ZFT_COMPRESSOR=m
CONFIG_FT_NR_BUFFERS=3
CONFIG_FT_PROC_FS=y
CONFIG_FT_NORMAL_DEBUG=y
# CONFIG_FT_FULL_DEBUG is not set
# CONFIG_FT_NO_TRACE is not set
# CONFIG_FT_NO_TRACE_AT_ALL is not set
# Hardware configuration
CONFIG_FT_STD_FDC=y
# CONFIG_FT_MACH2 is not set
# CONFIG_FT_PROBE_FC10 is not set
# CONFIG_FT_ALT_FDC is not set
CONFIG_FT_FDC_THR=8
CONFIG_FT_FDC_MAX_RATE=2000
CONFIG_FT_ALPHA_CLOCK=0
CONFIG_AGP=m
CONFIG_AGP_ALI=m
CONFIG_AGP_ATI=m
CONFIG_AGP_AMD=m
CONFIG_AGP_AMD64=m
CONFIG_AGP_INTEL=m
CONFIG_AGP_INTEL_MCH=m
CONFIG_AGP_NVIDIA=m
CONFIG_AGP_SIS=m
CONFIG_AGP_SWORKS=m
CONFIG_AGP_VIA=m
CONFIG_AGP_EFFICEON=m
CONFIG_DRM=y
CONFIG_DRM_TDFX=m
CONFIG_DRM_GAMMA=m
CONFIG_DRM_R128=m
CONFIG_DRM_RADEON=m
CONFIG_DRM_I810=m
CONFIG_DRM_I830=m
CONFIG_DRM_I915=m
CONFIG_DRM_MGA=m
CONFIG_DRM_SIS=m
# PCMCIA character devices
CONFIG_SYNCLINK_CS=m
CONFIG_MWAVE=m
CONFIG_RAW_DRIVER=m
CONFIG_HPET=y
CONFIG_HPET_RTC_IRQ=y
CONFIG_HPET_MMAP=y
CONFIG_MAX_RAW_DEVS=256
CONFIG_HANGCHECK_TIMER=m
# I2C support
CONFIG_I2C=m
CONFIG_I2C_CHARDEV=m
# I2C Algorithms
CONFIG_I2C_ALGOBIT=m
CONFIG_I2C_ALGOPCF=m
# I2C Hardware Bus support
CONFIG_I2C_ALI1535=m
CONFIG_I2C_ALI1563=m
CONFIG_I2C_ALI15X3=m
CONFIG_I2C_AMD756=m
CONFIG_I2C_AMD8111=m
CONFIG_I2C_ELEKTOR=m
CONFIG_I2C_I801=m
CONFIG_I2C_I810=m
CONFIG_I2C_ISA=m
CONFIG_I2C_NFORCE2=m
CONFIG_I2C_PARPORT=m
CONFIG_I2C_PARPORT_LIGHT=m
CONFIG_I2C_PIIX4=m
CONFIG_I2C_PROSAVAGE=m
CONFIG_I2C_SAVAGE4=m
# CONFIG_SCx200_ACB is not set
CONFIG_I2C_SIS5595=m
CONFIG_I2C_SIS630=m
CONFIG_I2C_SIS96X=m
CONFIG_I2C_VIA=m
CONFIG_I2C_VIAPRO=m
CONFIG_I2C_VOODOO3=m
# Hardware Sensors Chip support
CONFIG_I2C_SENSOR=m
CONFIG_SENSORS_ADM1021=m
CONFIG_SENSORS_ADM1025=m
CONFIG_SENSORS_ADM1031=m
CONFIG_SENSORS_ASB100=m
CONFIG_SENSORS_DS1621=m
CONFIG_SENSORS_FSCHER=m
CONFIG_SENSORS_GL518SM=m
CONFIG_SENSORS_IT87=m
CONFIG_SENSORS_LM75=m
CONFIG_SENSORS_LM77=m
CONFIG_SENSORS_LM78=m
CONFIG_SENSORS_LM80=m
CONFIG_SENSORS_LM83=m
CONFIG_SENSORS_LM85=m
CONFIG_SENSORS_LM90=m
CONFIG_SENSORS_MAX1619=m
CONFIG_SENSORS_VIA686A=m
CONFIG_SENSORS_W83781D=m
CONFIG_SENSORS_W83L785TS=m
CONFIG_SENSORS_W83627HF=m
# Other I2C Chip support
CONFIG_SENSORS_EEPROM=m
CONFIG_SENSORS_PCF8574=m
CONFIG_SENSORS_PCF8591=m
CONFIG_SENSORS_RTC8564=m
# CONFIG_I2C_DEBUG_CORE is not set
# CONFIG_I2C_DEBUG_ALGO is not set
# CONFIG_I2C_DEBUG_BUS is not set
# CONFIG_I2C_DEBUG_CHIP is not set
# Dallas's 1-wire bus
CONFIG_W1=m
CONFIG_W1_MATROX=m
CONFIG_W1_THERM=m
# Misc devices
CONFIG_IBM_ASM=m
# Multimedia devices
CONFIG_VIDEO_DEV=m
# Video For Linux
# Video Adapters
CONFIG_VIDEO_BT848=m
CONFIG_VIDEO_PMS=m
CONFIG_VIDEO_BWQCAM=m
CONFIG_VIDEO_CQCAM=m
CONFIG_VIDEO_W9966=m
CONFIG_VIDEO_CPIA=m
CONFIG_VIDEO_CPIA_PP=m
CONFIG_VIDEO_CPIA_USB=m
CONFIG_VIDEO_SAA5246A=m
CONFIG_VIDEO_SAA5249=m
CONFIG_TUNER_3036=m
CONFIG_VIDEO_STRADIS=m
CONFIG_VIDEO_ZORAN=m
CONFIG_VIDEO_ZORAN_BUZ=m
CONFIG_VIDEO_ZORAN_DC10=m
CONFIG_VIDEO_ZORAN_DC30=m
CONFIG_VIDEO_ZORAN_LML33=m
CONFIG_VIDEO_ZORAN_LML33R10=m
CONFIG_VIDEO_MEYE=m
CONFIG_VIDEO_SAA7134=m
CONFIG_VIDEO_MXB=m
CONFIG_VIDEO_DPC=m
CONFIG_VIDEO_HEXIUM_ORION=m
CONFIG_VIDEO_HEXIUM_GEMINI=m
CONFIG_VIDEO_CX88=m
CONFIG_VIDEO_OVCAMCHIP=m
# Radio Adapters
CONFIG_RADIO_CADET=m
CONFIG_RADIO_RTRACK=m
CONFIG_RADIO_RTRACK2=m
CONFIG_RADIO_AZTECH=m
CONFIG_RADIO_GEMTEK=m
CONFIG_RADIO_GEMTEK_PCI=m
CONFIG_RADIO_MAXIRADIO=m
CONFIG_RADIO_MAESTRO=m
CONFIG_RADIO_MIROPCM20=m
CONFIG_RADIO_MIROPCM20_RDS=m
CONFIG_RADIO_SF16FMI=m
CONFIG_RADIO_SF16FMR2=m
CONFIG_RADIO_TERRATEC=m
CONFIG_RADIO_TRUST=m
CONFIG_RADIO_TYPHOON=m
CONFIG_RADIO_TYPHOON_PROC_FS=y
CONFIG_RADIO_ZOLTRIX=m
# Digital Video Broadcasting Devices
CONFIG_DVB=y
CONFIG_DVB_CORE=m
# Supported Frontend Modules
CONFIG_DVB_TWINHAN_DST=m
CONFIG_DVB_STV0299=m
CONFIG_DVB_SP887X=m
CONFIG_DVB_SP887X_FIRMWARE_FILE="/usr/lib/hotplug/firmware/sc_main.mc"
CONFIG_DVB_ALPS_TDLB7=m
CONFIG_DVB_ALPS_TDMB7=m
CONFIG_DVB_ATMEL_AT76C651=m
CONFIG_DVB_CX24110=m
CONFIG_DVB_GRUNDIG_29504_491=m
CONFIG_DVB_GRUNDIG_29504_401=m
CONFIG_DVB_MT312=m
CONFIG_DVB_VES1820=m
CONFIG_DVB_VES1X93=m
CONFIG_DVB_TDA1004X=m
CONFIG_DVB_TDA1004X_FIRMWARE_FILE="/etc/dvb/tda1004x.bin"
CONFIG_DVB_NXT6000=m
# Supported SAA7146 based PCI Adapters
CONFIG_DVB_AV7110=m
# CONFIG_DVB_AV7110_FIRMWARE is not set
CONFIG_DVB_AV7110_OSD=y
CONFIG_DVB_BUDGET=m
CONFIG_DVB_BUDGET_CI=m
CONFIG_DVB_BUDGET_AV=m
CONFIG_DVB_BUDGET_PATCH=m
# Supported USB Adapters
CONFIG_DVB_TTUSB_BUDGET=m
# CONFIG_DVB_TTUSB_DEC is not set
# Supported FlexCopII (B2C2) Adapters
CONFIG_DVB_B2C2_SKYSTAR=m
# Supported BT878 Adapters
CONFIG_DVB_BT8XX=m
CONFIG_VIDEO_SAA7146=m
CONFIG_VIDEO_SAA7146_VV=m
CONFIG_VIDEO_VIDEOBUF=m
CONFIG_VIDEO_TUNER=m
CONFIG_VIDEO_BUF=m
CONFIG_VIDEO_BTCX=m
CONFIG_VIDEO_IR=m
# Graphics support
CONFIG_FB=y
CONFIG_FB_CIRRUS=m
CONFIG_FB_PM2=m
# CONFIG_FB_PM2_FIFO_DISCONNECT is not set
CONFIG_FB_CYBER2000=m
# CONFIG_FB_ASILIANT is not set
# CONFIG_FB_IMSTT is not set
CONFIG_FB_VGA16=m
CONFIG_FB_VESA=y
CONFIG_VIDEO_SELECT=y
CONFIG_FB_HGA=m
# CONFIG_FB_HGA_ACCEL is not set
CONFIG_FB_RIVA=m
# CONFIG_FB_RIVA_I2C is not set
# CONFIG_FB_RIVA_DEBUG is not set
CONFIG_FB_I810=m
# CONFIG_FB_I810_GTF is not set
CONFIG_FB_MATROX=m
CONFIG_FB_MATROX_MILLENIUM=y
CONFIG_FB_MATROX_MYSTIQUE=y
CONFIG_FB_MATROX_G450=y
CONFIG_FB_MATROX_G100=y
CONFIG_FB_MATROX_I2C=m
CONFIG_FB_MATROX_MAVEN=m
CONFIG_FB_MATROX_MULTIHEAD=y
CONFIG_FB_RADEON_OLD=m
CONFIG_FB_RADEON=m
CONFIG_FB_RADEON_I2C=y
# CONFIG_FB_RADEON_DEBUG is not set
CONFIG_FB_ATY128=m
CONFIG_FB_ATY=m
CONFIG_FB_ATY_CT=y
CONFIG_FB_ATY_GX=y
# CONFIG_FB_ATY_XL_INIT is not set
CONFIG_FB_SIS=m
CONFIG_FB_SIS_300=y
CONFIG_FB_SIS_315=y
CONFIG_FB_NEOMAGIC=m
CONFIG_FB_KYRO=m
CONFIG_FB_3DFX=m
# CONFIG_FB_3DFX_ACCEL is not set
CONFIG_FB_VOODOO1=m
CONFIG_FB_TRIDENT=m
# CONFIG_FB_TRIDENT_ACCEL is not set
CONFIG_FB_VIRTUAL=m
# Console display driver support
CONFIG_VGA_CONSOLE=y
CONFIG_MDA_CONSOLE=m
CONFIG_DUMMY_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE=y
CONFIG_FONTS=y
CONFIG_FONT_8x8=y
CONFIG_FONT_8x16=y
# CONFIG_FONT_6x11 is not set
# CONFIG_FONT_PEARL_8x8 is not set
# CONFIG_FONT_ACORN_8x8 is not set
# CONFIG_FONT_MINI_4x6 is not set
# CONFIG_FONT_SUN8x16 is not set
# CONFIG_FONT_SUN12x22 is not set
# Logo configuration
CONFIG_LOGO=y
CONFIG_LOGO_LINUX_MONO=y
CONFIG_LOGO_LINUX_VGA16=y
CONFIG_LOGO_LINUX_CLUT224=y
CONFIG_LOGO_MDK_CLUT224=y
# Bootsplash configuration
CONFIG_BOOTSPLASH=y
# Sound
CONFIG_SOUND=m
# Advanced Linux Sound Architecture
CONFIG_SND=m
CONFIG_SND_TIMER=m
CONFIG_SND_PCM=m
CONFIG_SND_HWDEP=m
CONFIG_SND_RAWMIDI=m
CONFIG_SND_SEQUENCER=m
CONFIG_SND_SEQ_DUMMY=m
CONFIG_SND_OSSEMUL=y
CONFIG_SND_MIXER_OSS=m
CONFIG_SND_PCM_OSS=m
CONFIG_SND_SEQUENCER_OSS=y
CONFIG_SND_RTCTIMER=m
# CONFIG_SND_VERBOSE_PRINTK is not set
# CONFIG_SND_DEBUG is not set
# Generic devices
CONFIG_SND_MPU401_UART=m
CONFIG_SND_OPL3_LIB=m
CONFIG_SND_OPL4_LIB=m
CONFIG_SND_VX_LIB=m
CONFIG_SND_DUMMY=m
CONFIG_SND_VIRMIDI=m
CONFIG_SND_MTPAV=m
CONFIG_SND_SERIAL_U16550=m
CONFIG_SND_MPU401=m
# ISA devices
CONFIG_SND_AD1816A=m
CONFIG_SND_AD1848=m
CONFIG_SND_CS4231=m
CONFIG_SND_CS4232=m
CONFIG_SND_CS4236=m
CONFIG_SND_ES968=m
CONFIG_SND_ES1688=m
CONFIG_SND_ES18XX=m
CONFIG_SND_GUS_SYNTH=m
CONFIG_SND_GUSCLASSIC=m
CONFIG_SND_GUSEXTREME=m
CONFIG_SND_GUSMAX=m
CONFIG_SND_INTERWAVE=m
CONFIG_SND_INTERWAVE_STB=m
CONFIG_SND_OPTI92X_AD1848=m
CONFIG_SND_OPTI92X_CS4231=m
CONFIG_SND_OPTI93X=m
CONFIG_SND_SB8=m
CONFIG_SND_SB16=m
CONFIG_SND_SBAWE=m
CONFIG_SND_SB16_CSP=y
CONFIG_SND_WAVEFRONT=m
CONFIG_SND_ALS100=m
CONFIG_SND_AZT2320=m
CONFIG_SND_CMI8330=m
CONFIG_SND_DT019X=m
CONFIG_SND_OPL3SA2=m
CONFIG_SND_SGALAXY=m
CONFIG_SND_SSCAPE=m
# PCI devices
CONFIG_SND_AC97_CODEC=m
CONFIG_SND_ALI5451=m
CONFIG_SND_ATIIXP=m
CONFIG_SND_ATIIXP_MODEM=m
CONFIG_SND_AU8810=m
CONFIG_SND_AU8820=m
CONFIG_SND_AU8830=m
CONFIG_SND_AZT3328=m
CONFIG_SND_BT87X=m
CONFIG_SND_CS46XX=m
CONFIG_SND_CS46XX_NEW_DSP=y
CONFIG_SND_CS4281=m
CONFIG_SND_EMU10K1=m
CONFIG_SND_KORG1212=m
CONFIG_SND_MIXART=m
CONFIG_SND_NM256=m
CONFIG_SND_RME32=m
CONFIG_SND_RME96=m
CONFIG_SND_RME9652=m
CONFIG_SND_HDSP=m
CONFIG_SND_TRIDENT=m
CONFIG_SND_YMFPCI=m
CONFIG_SND_ALS4000=m
CONFIG_SND_CMIPCI=m
CONFIG_SND_ENS1370=m
CONFIG_SND_ENS1371=m
CONFIG_SND_ES1938=m
CONFIG_SND_ES1968=m
CONFIG_SND_MAESTRO3=m
CONFIG_SND_FM801=m
CONFIG_SND_FM801_TEA575X=m
CONFIG_SND_ICE1712=m
CONFIG_SND_ICE1724=m
CONFIG_SND_INTEL8X0=m
CONFIG_SND_INTEL8X0M=m
CONFIG_SND_SONICVIBES=m
CONFIG_SND_VIA82XX=m
CONFIG_SND_VX222=m
# ALSA USB devices
CONFIG_SND_USB_AUDIO=m
CONFIG_SND_USB_USX2Y=m
# PCMCIA devices
CONFIG_SND_VXPOCKET=m
CONFIG_SND_VXP440=m
CONFIG_SND_PDAUDIOCF=m
# Open Sound System
CONFIG_SOUND_PRIME=m
CONFIG_SOUND_BT878=m
CONFIG_SOUND_CMPCI=m
CONFIG_SOUND_CMPCI_FM=y
CONFIG_SOUND_CMPCI_MIDI=y
CONFIG_SOUND_CMPCI_JOYSTICK=y
CONFIG_SOUND_EMU10K1=m
# CONFIG_MIDI_EMU10K1 is not set
CONFIG_SOUND_FUSION=m
CONFIG_SOUND_CS4281=m
CONFIG_SOUND_ES1370=m
CONFIG_SOUND_ES1371=m
CONFIG_SOUND_ESSSOLO1=m
CONFIG_SOUND_MAESTRO=m
CONFIG_SOUND_MAESTRO3=m
CONFIG_SOUND_ICH=m
CONFIG_SOUND_SONICVIBES=m
CONFIG_SOUND_TRIDENT=m
CONFIG_SOUND_MSNDCLAS=m
CONFIG_MSNDCLAS_INIT_FILE="/etc/sound/msndinit.bin"
CONFIG_MSNDCLAS_PERM_FILE="/etc/sound/msndperm.bin"
CONFIG_SOUND_MSNDPIN=m
CONFIG_MSNDPIN_INIT_FILE="/etc/sound/pndspini.bin"
CONFIG_MSNDPIN_PERM_FILE="/etc/sound/pndsperm.bin"
CONFIG_SOUND_VIA82CXXX=m
# CONFIG_MIDI_VIA82CXXX is not set
CONFIG_SOUND_OSS=m
# CONFIG_SOUND_TRACEINIT is not set
# CONFIG_SOUND_DMAP is not set
CONFIG_SOUND_AD1816=m
CONFIG_SOUND_AD1889=m
CONFIG_SOUND_SGALAXY=m
CONFIG_SOUND_ADLIB=m
CONFIG_SOUND_ACI_MIXER=m
CONFIG_SOUND_CS4232=m
CONFIG_SOUND_SSCAPE=m
CONFIG_SOUND_GUS=m
# CONFIG_SOUND_GUS16 is not set
CONFIG_SOUND_GUSMAX=y
CONFIG_SOUND_VMIDI=m
CONFIG_SOUND_TRIX=m
CONFIG_SOUND_MSS=m
CONFIG_SOUND_MPU401=m
CONFIG_SOUND_NM256=m
CONFIG_SOUND_MAD16=m
# CONFIG_MAD16_OLDCARD is not set
CONFIG_SOUND_PAS=m
CONFIG_SOUND_PSS=m
# CONFIG_PSS_MIXER is not set
# CONFIG_PSS_HAVE_BOOT is not set
CONFIG_SOUND_SB=m
CONFIG_SOUND_AWE32_SYNTH=m
CONFIG_SOUND_WAVEFRONT=m
CONFIG_SOUND_MAUI=m
CONFIG_SOUND_YM3812=m
CONFIG_SOUND_OPL3SA1=m
CONFIG_SOUND_OPL3SA2=m
CONFIG_SOUND_YMFPCI=m
CONFIG_SOUND_YMFPCI_LEGACY=y
CONFIG_SOUND_UART6850=m
CONFIG_SOUND_AEDSP16=m
CONFIG_SC6600=y
CONFIG_SC6600_JOY=y
CONFIG_SC6600_CDROM=4
CONFIG_SC6600_CDROMBASE=0x0
CONFIG_AEDSP16_MSS=y
# CONFIG_AEDSP16_SBPRO is not set
CONFIG_AEDSP16_MPU401=y
CONFIG_SOUND_TVMIXER=m
CONFIG_SOUND_KAHLUA=m
CONFIG_SOUND_ALI5455=m
CONFIG_SOUND_FORTE=m
CONFIG_SOUND_RME96XX=m
CONFIG_SOUND_AD1980=m
# USB support
CONFIG_USB=m
# CONFIG_USB_DEBUG is not set
# Miscellaneous USB options
CONFIG_USB_DEVICEFS=y
CONFIG_USB_BANDWIDTH=y
CONFIG_USB_DYNAMIC_MINORS=y
CONFIG_USB_SUSPEND=y
# USB Host Controller Drivers
CONFIG_USB_EHCI_HCD=m
# CONFIG_USB_EHCI_SPLIT_ISO is not set
# CONFIG_USB_EHCI_ROOT_HUB_TT is not set
CONFIG_USB_OHCI_HCD=m
CONFIG_USB_UHCI_HCD=m
# USB Device Class drivers
CONFIG_USB_AUDIO=m
# USB Bluetooth TTY can only be used with disabled Bluetooth subsystem
CONFIG_USB_MIDI=m
CONFIG_USB_ACM=m
CONFIG_USB_PRINTER=m
CONFIG_USB_STORAGE=m
# CONFIG_USB_STORAGE_DEBUG is not set
CONFIG_USB_STORAGE_RW_DETECT=y
CONFIG_USB_STORAGE_DATAFAB=y
CONFIG_USB_STORAGE_FREECOM=y
CONFIG_USB_STORAGE_ISD200=y
CONFIG_USB_STORAGE_DPCM=y
CONFIG_USB_STORAGE_HP8200e=y
CONFIG_USB_STORAGE_SDDR09=y
CONFIG_USB_STORAGE_SDDR55=y
CONFIG_USB_STORAGE_JUMPSHOT=y
# CONFIG_USB_STORAGE_USS725 is not set
# USB Human Interface Devices (HID)
CONFIG_USB_HID=m
CONFIG_USB_HIDINPUT=y
CONFIG_HID_FF=y
CONFIG_HID_PID=y
CONFIG_LOGITECH_FF=y
CONFIG_THRUSTMASTER_FF=y
CONFIG_USB_HIDDEV=y
# USB HID Boot Protocol drivers
CONFIG_USB_KBD=m
CONFIG_USB_MOUSE=m
CONFIG_USB_AIPTEK=m
CONFIG_USB_WACOM=m
CONFIG_USB_ACECAD=m
CONFIG_USB_KBTAB=m
CONFIG_USB_POWERMATE=m
CONFIG_USB_MTOUCH=m
CONFIG_USB_EGALAX=m
CONFIG_USB_XPAD=m
CONFIG_USB_ATI_REMOTE=m
# USB Imaging devices
CONFIG_USB_MDC800=m
CONFIG_USB_MICROTEK=m
CONFIG_USB_HPUSBSCSI=m
# USB Multimedia devices
CONFIG_USB_DABUSB=m
CONFIG_USB_VICAM=m
CONFIG_USB_DSBR=m
CONFIG_USB_IBMCAM=m
CONFIG_USB_KONICAWC=m
CONFIG_USB_OV511=m
CONFIG_USB_PWC=m
CONFIG_USB_SE401=m
CONFIG_USB_SN9C102=m
CONFIG_USB_STV680=m
CONFIG_USB_W9968CF=m
# USB Network adaptors
CONFIG_USB_CATC=m
CONFIG_USB_KAWETH=m
CONFIG_USB_PEGASUS=m
CONFIG_USB_RTL8150=m
CONFIG_USB_USBNET=m
# USB Host-to-Host Cables
CONFIG_USB_ALI_M5632=y
CONFIG_USB_AN2720=y
CONFIG_USB_BELKIN=y
CONFIG_USB_GENESYS=y
CONFIG_USB_NET1080=y
CONFIG_USB_PL2301=y
# Intelligent USB Devices/Gadgets
CONFIG_USB_ARMLINUX=y
CONFIG_USB_EPSON2888=y
CONFIG_USB_ZAURUS=y
CONFIG_USB_CDCETHER=y
# USB Network Adapters
CONFIG_USB_AX8817X=y
# USB port drivers
CONFIG_USB_USS720=m
# USB Serial Converter support
CONFIG_USB_SERIAL=m
CONFIG_USB_SERIAL_GENERIC=y
CONFIG_USB_SERIAL_BELKIN=m
CONFIG_USB_SERIAL_WHITEHEAT=m
CONFIG_USB_SERIAL_DIGI_ACCELEPORT=m
CONFIG_USB_SERIAL_EMPEG=m
CONFIG_USB_SERIAL_FTDI_SIO=m
CONFIG_USB_SERIAL_VISOR=m
CONFIG_USB_SERIAL_IPAQ=m
CONFIG_USB_SERIAL_IR=m
CONFIG_USB_SERIAL_EDGEPORT=m
CONFIG_USB_SERIAL_EDGEPORT_TI=m
CONFIG_USB_SERIAL_KEYSPAN_PDA=m
CONFIG_USB_SERIAL_KEYSPAN=m
CONFIG_USB_SERIAL_KEYSPAN_MPR=y
CONFIG_USB_SERIAL_KEYSPAN_USA28=y
CONFIG_USB_SERIAL_KEYSPAN_USA28X=y
CONFIG_USB_SERIAL_KEYSPAN_USA28XA=y
CONFIG_USB_SERIAL_KEYSPAN_USA28XB=y
CONFIG_USB_SERIAL_KEYSPAN_USA19=y
CONFIG_USB_SERIAL_KEYSPAN_USA18X=y
CONFIG_USB_SERIAL_KEYSPAN_USA19W=y
CONFIG_USB_SERIAL_KEYSPAN_USA19QW=y
CONFIG_USB_SERIAL_KEYSPAN_USA19QI=y
CONFIG_USB_SERIAL_KEYSPAN_USA49W=y
CONFIG_USB_SERIAL_KEYSPAN_USA49WLC=y
CONFIG_USB_SERIAL_KLSI=m
CONFIG_USB_SERIAL_KOBIL_SCT=m
CONFIG_USB_SERIAL_MCT_U232=m
CONFIG_USB_SERIAL_PL2303=m
CONFIG_USB_SERIAL_SAFE=m
CONFIG_USB_SERIAL_SAFE_PADDED=y
CONFIG_USB_SERIAL_CYBERJACK=m
CONFIG_USB_SERIAL_XIRCOM=m
CONFIG_USB_SERIAL_OMNINET=m
CONFIG_USB_EZUSB=y
# USB Miscellaneous drivers
CONFIG_USB_EMI62=m
CONFIG_USB_EMI26=m
CONFIG_USB_TIGL=m
CONFIG_USB_AUERSWALD=m
CONFIG_USB_RIO500=m
CONFIG_USB_LEGOTOWER=m
CONFIG_USB_LCD=m
CONFIG_USB_LED=m
CONFIG_USB_CYTHERM=m
CONFIG_USB_SPEEDTOUCH=m
CONFIG_USB_PHIDGETSERVO=m
CONFIG_USB_TEST=m
# USB Gadget Support
CONFIG_USB_GADGET=m
CONFIG_USB_GADGET_NET2280=y
CONFIG_USB_NET2280=m
# CONFIG_USB_GADGET_PXA2XX is not set
# CONFIG_USB_GADGET_GOKU is not set
# CONFIG_USB_GADGET_SA1100 is not set
# CONFIG_USB_GADGET_DUMMY_HCD is not set
CONFIG_USB_GADGET_DUALSPEED=y
CONFIG_USB_ZERO=m
CONFIG_USB_ETH=m
CONFIG_USB_ETH_RNDIS=y
CONFIG_USB_GADGETFS=m
CONFIG_USB_FILE_STORAGE=m
# CONFIG_USB_FILE_STORAGE_TEST is not set
CONFIG_USB_G_SERIAL=m
# File systems
CONFIG_EXT2_FS=y
CONFIG_EXT2_FS_XATTR=y
CONFIG_EXT2_FS_POSIX_ACL=y
CONFIG_EXT2_FS_SECURITY=y
CONFIG_EXT3_FS=m
CONFIG_EXT3_FS_XATTR=y
CONFIG_EXT3_FS_POSIX_ACL=y
CONFIG_EXT3_FS_SECURITY=y
CONFIG_JBD=m
# CONFIG_JBD_DEBUG is not set
CONFIG_FS_MBCACHE=y
CONFIG_REISERFS_FS=m
# CONFIG_REISERFS_CHECK is not set
CONFIG_REISERFS_PROC_INFO=y
CONFIG_REISERFS_FS_XATTR=y
CONFIG_REISERFS_FS_POSIX_ACL=y
CONFIG_REISERFS_FS_SECURITY=y
CONFIG_JFS_FS=m
CONFIG_JFS_POSIX_ACL=y
# CONFIG_JFS_DEBUG is not set
CONFIG_JFS_STATISTICS=y
CONFIG_FS_POSIX_ACL=y
CONFIG_XFS_FS=m
# CONFIG_XFS_RT is not set
CONFIG_XFS_QUOTA=y
# CONFIG_XFS_SECURITY is not set
CONFIG_XFS_POSIX_ACL=y
CONFIG_MINIX_FS=m
CONFIG_ROMFS_FS=m
CONFIG_QUOTA=y
CONFIG_QFMT_V1=m
CONFIG_QFMT_V2=y
CONFIG_QUOTACTL=y
# CONFIG_AUTOFS_FS is not set
CONFIG_AUTOFS4_FS=m
# CD-ROM/DVD Filesystems
CONFIG_ISO9660_FS=m
CONFIG_JOLIET=y
CONFIG_ZISOFS=y
CONFIG_ZISOFS_FS=m
CONFIG_UDF_FS=m
CONFIG_UDF_NLS=y
# DOS/FAT/NT Filesystems
CONFIG_FAT_FS=m
CONFIG_MSDOS_FS=m
CONFIG_VFAT_FS=m
CONFIG_FAT_DEFAULT_CODEPAGE=437
CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
CONFIG_NTFS_FS=m
# CONFIG_NTFS_DEBUG is not set
# CONFIG_NTFS_RW is not set
# Pseudo filesystems
CONFIG_PROC_FS=y
CONFIG_PROC_KCORE=y
CONFIG_SYSFS=y
CONFIG_DEVFS_FS=y
# CONFIG_DEVFS_MOUNT is not set
# CONFIG_DEVFS_DEBUG is not set
# CONFIG_DEVPTS_FS_XATTR is not set
CONFIG_TMPFS=y
# CONFIG_HUGETLBFS is not set
# CONFIG_HUGETLB_PAGE is not set
CONFIG_RAMFS=y
CONFIG_SUPERMOUNT=m
# CONFIG_SUPERMOUNT_DEBUG is not set
# Miscellaneous filesystems
CONFIG_ADFS_FS=m
# CONFIG_ADFS_FS_RW is not set
CONFIG_AFFS_FS=m
CONFIG_HFS_FS=m
CONFIG_HFSPLUS_FS=m
CONFIG_BEFS_FS=m
# CONFIG_BEFS_DEBUG is not set
CONFIG_BFS_FS=m
CONFIG_EFS_FS=m
CONFIG_JFFS_FS=m
CONFIG_JFFS_FS_VERBOSE=0
CONFIG_JFFS_PROC_FS=y
CONFIG_JFFS2_FS=m
CONFIG_JFFS2_FS_DEBUG=0
# CONFIG_JFFS2_FS_NAND is not set
# CONFIG_JFFS2_COMPRESSION_OPTIONS is not set
CONFIG_JFFS2_ZLIB=y
CONFIG_JFFS2_RTIME=y
# CONFIG_JFFS2_RUBIN is not set
CONFIG_CRAMFS=y
CONFIG_SQUASHFS=m
CONFIG_VXFS_FS=m
CONFIG_HPFS_FS=m
CONFIG_QNX4FS_FS=m
# CONFIG_QNX4FS_RW is not set
CONFIG_SYSV_FS=m
CONFIG_UFS_FS=m
# CONFIG_UFS_FS_WRITE is not set
# Network File Systems
CONFIG_NFS_FS=m
CONFIG_NFS_V3=y
CONFIG_NFS_V4=y
CONFIG_NFS_DIRECTIO=y
CONFIG_NFSD=m
CONFIG_NFSD_V3=y
CONFIG_NFSD_V4=y
CONFIG_NFSD_TCP=y
CONFIG_LOCKD=m
CONFIG_LOCKD_V4=y
CONFIG_EXPORTFS=m
CONFIG_SUNRPC=m
CONFIG_SUNRPC_GSS=m
CONFIG_RPCSEC_GSS_KRB5=m
CONFIG_SMB_FS=m
CONFIG_SMB_NLS_DEFAULT=y
CONFIG_SMB_NLS_REMOTE="cp437"
CONFIG_CIFS=m
CONFIG_CIFS_STATS=y
# CONFIG_CIFS_XATTR is not set
CONFIG_CIFS_POSIX=y
CONFIG_NCP_FS=m
CONFIG_NCPFS_PACKET_SIGNING=y
# CONFIG_NCPFS_IOCTL_LOCKING is not set
CONFIG_NCPFS_STRONG=y
CONFIG_NCPFS_NFS_NS=y
CONFIG_NCPFS_OS2_NS=y
CONFIG_NCPFS_SMALLDOS=y
CONFIG_NCPFS_NLS=y
CONFIG_NCPFS_EXTRAS=y
CONFIG_CODA_FS=m
# CONFIG_CODA_FS_OLD_API is not set
CONFIG_AFS_FS=m
CONFIG_RXRPC=m
# Partition Types
CONFIG_PARTITION_ADVANCED=y
# CONFIG_ACORN_PARTITION is not set
# CONFIG_OSF_PARTITION is not set
# CONFIG_AMIGA_PARTITION is not set
# CONFIG_ATARI_PARTITION is not set
CONFIG_MAC_PARTITION=y
CONFIG_MSDOS_PARTITION=y
CONFIG_BSD_DISKLABEL=y
# CONFIG_MINIX_SUBPARTITION is not set
CONFIG_SOLARIS_X86_PARTITION=y
CONFIG_UNIXWARE_DISKLABEL=y
CONFIG_LDM_PARTITION=y
# CONFIG_LDM_DEBUG is not set
CONFIG_SGI_PARTITION=y
# CONFIG_ULTRIX_PARTITION is not set
CONFIG_SUN_PARTITION=y
CONFIG_EFI_PARTITION=y
# Native Language Support
CONFIG_NLS=y
CONFIG_NLS_DEFAULT="iso8859-1"
CONFIG_NLS_CODEPAGE_437=m
CONFIG_NLS_CODEPAGE_737=m
CONFIG_NLS_CODEPAGE_775=m
CONFIG_NLS_CODEPAGE_850=m
CONFIG_NLS_CODEPAGE_852=m
CONFIG_NLS_CODEPAGE_855=m
CONFIG_NLS_CODEPAGE_857=m
CONFIG_NLS_CODEPAGE_860=m
CONFIG_NLS_CODEPAGE_861=m
CONFIG_NLS_CODEPAGE_862=m
CONFIG_NLS_CODEPAGE_863=m
CONFIG_NLS_CODEPAGE_864=m
CONFIG_NLS_CODEPAGE_865=m
CONFIG_NLS_CODEPAGE_866=m
CONFIG_NLS_CODEPAGE_869=m
CONFIG_NLS_CODEPAGE_936=m
CONFIG_NLS_CODEPAGE_950=m
CONFIG_NLS_CODEPAGE_932=m
CONFIG_NLS_CODEPAGE_949=m
CONFIG_NLS_CODEPAGE_874=m
CONFIG_NLS_ISO8859_8=m
CONFIG_NLS_CODEPAGE_1250=m
CONFIG_NLS_CODEPAGE_1251=m
CONFIG_NLS_ASCII=m
CONFIG_NLS_ISO8859_1=m
CONFIG_NLS_ISO8859_2=m
CONFIG_NLS_ISO8859_3=m
CONFIG_NLS_ISO8859_4=m
CONFIG_NLS_ISO8859_5=m
CONFIG_NLS_ISO8859_6=m
CONFIG_NLS_ISO8859_7=m
CONFIG_NLS_ISO8859_9=m
CONFIG_NLS_ISO8859_13=m
CONFIG_NLS_ISO8859_14=m
CONFIG_NLS_ISO8859_15=m
CONFIG_NLS_KOI8_R=m
CONFIG_NLS_KOI8_U=m
CONFIG_NLS_UTF8=m
# Profiling support
CONFIG_PROFILING=y
CONFIG_OPROFILE=m
# Kernel hacking
# CONFIG_BOOT_KERNEL is not set
CONFIG_DEBUG_KERNEL=y
# CONFIG_EARLY_PRINTK is not set
# CONFIG_DEBUG_STACKOVERFLOW is not set
# CONFIG_DEBUG_STACK_USAGE is not set
# CONFIG_DEBUG_SLAB is not set
CONFIG_MAGIC_SYSRQ=y
# CONFIG_DEBUG_SPINLOCK is not set
# CONFIG_DEBUG_PAGEALLOC is not set
# CONFIG_DEBUG_HIGHMEM is not set
# CONFIG_DEBUG_INFO is not set
# CONFIG_DEBUG_SPINLOCK_SLEEP is not set
CONFIG_FRAME_POINTER=y
# CONFIG_4KSTACKS is not set
# CONFIG_KDB is not set
CONFIG_X86_FIND_SMP_CONFIG=y
CONFIG_X86_MPPARSE=y
# Security options
CONFIG_SECURITY=y
CONFIG_SECURITY_NETWORK=y
CONFIG_SECURITY_CAPABILITIES=y
CONFIG_SECURITY_ROOTPLUG=m
CONFIG_SECURITY_SELINUX=y
CONFIG_SECURITY_SELINUX_BOOTPARAM=y
CONFIG_SECURITY_SELINUX_BOOTPARAM_VALUE=0
CONFIG_SECURITY_SELINUX_DISABLE=y
CONFIG_SECURITY_SELINUX_DEVELOP=y
CONFIG_SECURITY_SELINUX_MLS=y
# Cryptographic options
CONFIG_CRYPTO=y
CONFIG_CRYPTO_HMAC=y
CONFIG_CRYPTO_NULL=m
CONFIG_CRYPTO_MD4=m
CONFIG_CRYPTO_MD5=m
CONFIG_CRYPTO_SHA1=m
CONFIG_CRYPTO_SHA256=m
CONFIG_CRYPTO_SHA512=m
CONFIG_CRYPTO_DES=m
CONFIG_CRYPTO_BLOWFISH=m
CONFIG_CRYPTO_TWOFISH=m
CONFIG_CRYPTO_SERPENT=m
CONFIG_CRYPTO_AES_586=m
CONFIG_CRYPTO_CAST5=m
CONFIG_CRYPTO_CAST6=m
CONFIG_CRYPTO_TEA=m
CONFIG_CRYPTO_ARC4=m
CONFIG_CRYPTO_KHAZAD=m
CONFIG_CRYPTO_DEFLATE=m
CONFIG_CRYPTO_MICHAEL_MIC=m
CONFIG_CRYPTO_CRC32C=m
CONFIG_CRYPTO_TEST=m
# Library routines
CONFIG_CRC_CCITT=m
CONFIG_CRC32=y
CONFIG_LIBCRC32C=m
CONFIG_ZLIB_INFLATE=y
CONFIG_ZLIB_DEFLATE=m
CONFIG_X86_BIOS_REBOOT=y
# Unofficial 3rd party kernel additions
CONFIG_ACX100=m
CONFIG_EAGLE_USB=m
CONFIG_HOSTAP=m
CONFIG_HOSTAP_FIRMWARE=y
CONFIG_HOSTAP_PLX=m
CONFIG_HOSTAP_PCI=m
CONFIG_HOSTAP_CS=m
# Linux InfraRed Controller
CONFIG_LIRC_SUPPORT=m
CONFIG_LIRC_MAX_DEV=8
CONFIG_LIRC_I2C=m
CONFIG_LIRC_GPIO=m
CONFIG_LIRC_BT829=m
CONFIG_LIRC_IT87=m
CONFIG_LIRC_ATIUSB=m
# CONFIG_LIRC_MCEUSB is not set
# CONFIG_LIRC_PARALLEL is not set
CONFIG_LIRC_SERIAL=m
# CONFIG_LIRC_HOMEBREW is not set
# CONFIG_LIRC_SERIAL_ANIMAX is not set
CONFIG_LIRC_SERIAL_IRDEO=y
# CONFIG_LIRC_SERIAL_IRDEO_REMOTE is not set
CONFIG_LIRC_SERIAL_TRANSMITTER=y
CONFIG_LIRC_SERIAL_SOFTCARRIER=y
# CONFIG_LIRC_SERIAL_IGOR is not set
CONFIG_LIRC_SERIAL_COM1=y
# CONFIG_LIRC_SERIAL_COM2 is not set
# CONFIG_LIRC_SERIAL_COM3 is not set
# CONFIG_LIRC_SERIAL_COM4 is not set
# CONFIG_LIRC_SERIAL_OTHER is not set
CONFIG_LIRC_PORT_SERIAL=0x3f8
CONFIG_LIRC_IRQ_SERIAL=0x4
CONFIG_LIRC_SIR=m
# CONFIG_LIRC_ON_SA1100 is not set
CONFIG_LIRC_SIR_IRDA=y
# CONFIG_LIRC_SIR_TEKRAM is not set
# CONFIG_LIRC_SIR_ACTISYS_ACT200L is not set
CONFIG_LIRC_SIR_COM1=y
# CONFIG_LIRC_SIR_COM2 is not set
# CONFIG_LIRC_SIR_COM3 is not set
# CONFIG_LIRC_SIR_COM4 is not set
# CONFIG_LIRC_SIR_OTHER is not set
CONFIG_LIRC_PORT_SIR=0x3f8
CONFIG_LIRC_IRQ_SIR=0x4
CONFIG_LUFS=m
CONFIG_QC_USB=m
CONFIG_DFG1394=m
# Prism2.5 wireless support
CONFIG_PRISM25=m
CONFIG_P80211=m
CONFIG_PRISM2_PLX=m
CONFIG_PRISM2_PCI=m
CONFIG_PRISM2_USB=m
CONFIG_PRISM2_CS=m
CONFIG_OV511=m
# Hollywood Plus / DXR3
CONFIG_DXR3=m
CONFIG_EM8300=m
# CONFIG_EM8300_LOOPBACK is not set
# CONFIG_EM8300_UCODETIMEOUT is not set
# CONFIG_EM8300_DICOMFIX is not set
# CONFIG_EM8300_DICOMCTRL is not set
# CONFIG_EM8300_DICOMPAL is not set
CONFIG_ADV717X=m
# CONFIG_ADV717X_SWAP is not set
# CONFIG_ADV717X_PIXELPORT16BIT is not set
# CONFIG_ADV717X_PIXELPORTPAL is not set
CONFIG_BT865=m
CONFIG_ISCSI_MOD=m
CONFIG_BCM5700=m
CONFIG_AT76C503A=m
CONFIG_VT_AR5K=m
CONFIG_NDISWRAPPER=m
CONFIG_MOD_MARVEL=m
CONFIG_MOD_MARVEL_ZR36060=m
CONFIG_MOD_MARVEL_I33=m
CONFIG_MOD_MARVEL_MGAJPG=m
CONFIG_BCM4400=m
CONFIG_LPFC=m
CONFIG_IVTV=m
CONFIG_VIDEO_RIVATV=m
CONFIG_VIAHSS=m
CONFIG_SN9C102=m
CONFIG_POLDHU=m
CONFIG_FUSE=m
CONFIG_SVGALIB_HELPER=m
# CONFIG_OGFS is not set
CONFIG_ITERAID=m
CONFIG_SHFS=m
CONFIG_DAZUKO=m
CONFIG_IPW2100=m
CONFIG_IPW2100_PROMISC=y
# CONFIG_IPW2100_LEGACY_FW_LOAD is not set
# CONFIG_IPW2100_NOWEP is not set
# CONFIG_IPW2100_DEBUG is not set
CONFIG_IPW2200=m
# CONFIG_IPW2200_DEBUG is not set
n°562067
Zzozo
Un peu, passionément, à la fol
Posté le 26-09-2004 à 02:50:11  profilanswer
Mouais ... bon ben cé un bug propre à ce kernel là et aux drivers Nvidia ... :o
J'en ai eu la confirmation là :
http://www.nvnews.net/vbulletin/showthread.php?t=36001
Voilà un post avec la réponse à ton souci apparamment :o :
Please read the warning message more carefully, the potential problem it hints at can't occur until the NVIDIA kernel module is built, installed and an attempt is made to load it. The problem here is that 1.0-6111 fails to build against recent Linux 2.6 kernels; this problem can be solved by replacing PM_SAVE_STATE with PM_SUSPEND_MEM in usr/src/nv/nv.c.
EDIT :
http://linuxfr.org/forums/14/3277.html    :o
EDIT2 :
Ca ressemble bcp à ca :
http://lkml.org/lkml/2004/8/20/209
Message édité par Zzozo le 26-09-2004 à 02:59:05
n°562069
Tomake
Posté le 26-09-2004 à 02:54:12  profilanswer
:) Merci Zzozo  ;)
J'essaye ça de suite et je te tiens au courant....
n°562072
Tomake
Posté le 26-09-2004 à 03:30:41  profilanswer
Je ne trouve pas ce fichier : usr/src/nv/nv.c
Et pour le lien avec le patch (edit2), je l'avais déjà trouvé mais je voudrais éviter de recompiler tout le noyau !!
n°562074
Zzozo
Posté le 26-09-2004 à 03:35:35  profilanswer
Il se trouve pas forcément dans /usr/src/nv à mon avis ... tu dois regarder si l'install du driver Nvidia génère de nouveaux répertoires et ne les efface pas à la fin de l'install ... et dedans tu devrais trouver ton bonheur ... :o
n°562075
Tomake
Posté le 26-09-2004 à 03:38:42  profilanswer
j'ai trouvé c'est dans le NVIDIA....run que se trouve le fichier. Il faut décompresser l'installateur nvidia
liens : http://qa.mandrakesoft.com/show_bug.cgi?id=11060
n°562076
Zzozo
Posté le 26-09-2004 à 03:45:42  profilanswer
en effet, et y'a ce post vers le bas de la page :
Hi, from a thread on nvidia site:
You'll need to extract the .run installer with --extract-only, then change to
the newly created directory and edit usr/src/nv/nv.c;
you can then install the driver with ./nvidia-installer in the same directory
"Aides toi, et le ciel t'aidera ... :o"  :D
n°562077
Tomake
Posté le 26-09-2004 à 03:48:19  profilanswer
ça c'est vrai !! :o
C'est pas en restant les bras croisés à attendre les réponses que les solutions viennent :D
n°562078
Tomake
Posté le 26-09-2004 à 04:38:04  profilanswer
J'ai réussi à compiler les drivers !!
MAIS (et oui) il arrive pas à charger les drivers nvidia !!
Voilà l'extrait du log :
(EE) NVIDIA(0): Failed to initialize the NVIDIA kernel module!
(EE) NVIDIA(0):  *** Aborting ***
(II) UnloadModule: "nvidia"
(II) UnloadModule: "vgahw"
(II) Unloading /usr/X11R6/lib/modules/libvgahw.a
(EE) Screen(s) found, but none have a usable configuration.
Fatal server error:
no screens found
Il semble charger le driver nvidia puis le rejeter !! Bizarre !
Du coup je sens que je vais retourner en 10.0 et attendre un peu !!
Enfin si d'ici demain quelqu'un a une solution je suis preneur  :D
n°562079
Zzozo
Posté le 26-09-2004 à 04:41:44  profilanswer
Fatal server error:
no screens found
Le Dimanche y'a la messe ... :o
Vas y et allumes un cierge ... :o
n°562108
Dark_Schne​ider
Close the World, Open the Net
Posté le 26-09-2004 à 11:54:52  profilanswer
que donne un : modprobe nvidia
donne les éventuels messages d'erreurs.
si il n'y en a pas, relance X.
si cela marche ajoute nvidia dans /etc/modprobe.preload
ton module agp est bien chargé j'espère ...
Mandriva : parce que nous le valons bien ! http://linux-wizard.net/index.php
n°562122
Tomake
Posté le 26-09-2004 à 12:21:45  profilanswer
Effectivement le driver nvidia n'était pas chargé automatiquement après l'install des drivers.
Je l'avais vu par un lsmod. Donc j'ai après rajouté hier soir la ligne dans le fichier modprobe le driver se chargeait mais n'était pas utilisé !!
En fait, et je viens seulement de m'en rendre compte ce matin, j'avais oublié de changer le xorg.conf et de mettre comme driver nvidia !!  :pfff:
Donc pas besoin d'allumer de cierges  :D
 :bounce: ça marche now
Reste le problème du son alsa dit qu'il ne trouve pas ma carte  :??:
Message édité par Tomake le 26-09-2004 à 12:23:12
n°562125
Dark_Schne​ider
Posté le 26-09-2004 à 12:25:22  profilanswer
ouvre un autre topic stp. draksound est ton ami pour les cartes son
Message édité par Dark_Schneider le 26-09-2004 à 12:25:43
n°562128
Tomake
Posté le 26-09-2004 à 12:26:48  profilanswer
C'est ce que je suis en train de faire, ne t'inquiète pas ;)
n°573806
the_farbar​ian
Posté le 16-10-2004 à 18:57:11  profilanswer
up ! j'ai les memes pb, je n'arrive pas a installer les drivers nvidia avec la mandrake 10.1 community alors que cela ne posait aucun soucis avec la 10.0 :(
n°573812
Tomake
Posté le 16-10-2004 à 19:10:54  profilanswer
Essaye de suivre ça :
http://forum.hardware.fr/forum2.ph [...] 0&subcat=0
"Parfois brutal, toujours loyal"
n°573821
the_farbar​ian
Posté le 16-10-2004 à 19:27:04  profilanswer
Merci, j'ai vu ton topic juste apres avoir poste.
Mais je n'ai pas encore reussi, comme j'avais bidouille un peu, je retente une nouvelle install ...
Faut bien installer le noyau apres ?
n°573823
Tomake
Posté le 16-10-2004 à 19:28:03  profilanswer
il faut que tu installes le noyau et les sources qui lui correspondent
n°573825
the_farbar​ian
Posté le 16-10-2004 à 19:31:30  profilanswer
ok merci
n°635106
ben33
Posté le 11-02-2005 à 22:00:08  profilanswer
Bonsoir,
Je suis désolé de réouvrir un post la dessus... mais malgré tout ce que j'ai lu.. .il m'est impossible d'installer les pilotes nvidia.. que ce soit la version 6629 ou 6611...
J'ai pourtant changé pm.h ... ou nv.c ... ca ne change rien...
la je suis en pilote vesa... c pas top du tout..
voila mon probleme :
NVIDIA: left KBUILD.
FATAL: Error inserting nvidia (/lib/modules/2.6.8.1-12mdk/kernel/drivers/video/nvidia.ko): No such device
J'ai une GeForce 6800 de Leadtek...Serait ce la carte qui est défectueuse..?
Je me demande à force...
Help...
n°635111
mikala
Souviens toi du 5 Novembre...
Posté le 11-02-2005 à 22:20:25  profilanswer
tu peux déja utiliser les pilotes 'nv' en lieu et place du pilote vesa a mon avis .
ensuite il me semble qu'il traine certains rpms pour les drivers nvidia.
il faudrait remettre la main dessus .
Message édité par mikala le 11-02-2005 à 22:22:56
n°635142
ben33
Posté le 11-02-2005 à 23:36:37  profilanswer
non mv me fait planter l'interface graphique....
D'ou vesa qui est le seul à fonctionner apparemment...
n°635144
mikala
Posté le 11-02-2005 à 23:38:12  profilanswer
planter l'interface graphique ?
tu as quoi comme erreur ?
tu utilises quoi comme 'interface graphique' ?
tu es sur que c'est lié ?
n°635148
ben33
Posté le 11-02-2005 à 23:42:22  profilanswer
beh je n'ai rien qui se lance... tout simplement si je passe en nv .... un bel écran noir!
n°635153
mikala
Posté le 11-02-2005 à 23:52:28  profilanswer
et si tu le lances tout en ligne de commande par un startx?
tu dois bien avoir un message d'erreur a la con non ?
n°635226
ben33
Posté le 12-02-2005 à 08:27:36  profilanswer
je vais retenter ca...
Et te dire...
n°635245
Faxone
Posté le 12-02-2005 à 10:09:07  profilanswer
Pour la version 6629, je n'ai rien changé dans les sources pour ma mdk 10.1
- Passer en level 3 par un "init 3"
- Faut juste bien vérifier que les sources du kernel correspondent bien au noyau actuellement utilisé.
- Ensuite exécuter et suivre les instructions du script nvidia.
- Après faire un "modprobe nvidia" et mettre "nvidia" dans /etc/modules.preload
- Passez en level 5 par init 5
Et ca roule
n°635289
ben33
Posté le 12-02-2005 à 12:21:36  profilanswer
C'est ce que je fais Faxone...
Cependant, il n'arrive pas a compiler quelque soit la méthode utilisée... (nvidia.ko : no such device)....
10.1 version download DVD
Ge Force 6800 ...
n°635294
mikala
Posté le 12-02-2005 à 12:28:33  profilanswer
le fait que tu n'arrives pas a compiler un driver est quand meme nettement différent d'un problème matériel de ta carte graphique la .
tu n'as pas besoin d'avoir le dit matos pour le compiler , ah mon avis tu devrais revoir la manière dont tu compiles le module et t'assurer que tu disposes bien de tous les élements nécessaires a cette compilation
 Page :   1  2
Page Précédente
  Linux et OS Alternatifs
  Installation
  Driver NVidia sous Mandrake 10.1
Cherche jaquette pour cd linux (mandrake, debian, etc...)Installation de Mandrake 10.0...
Mandrake Linux et les écrans de portable wide ?Mandrake 10 et portable : noyau supportant l'APM ?
L'install de Mandrake 10.0 se lance pas ...Mandrake 10.1 Community: Démarrage Hyper lent...
Probleme de Mandrake control centerInstaller driver nvidia sur mandrake ?
[ mandrake 10 ] - installation de driver nvidiadriver nvidia sous mandrake pb???
Plus de sujets relatifs à : Driver NVidia sous Mandrake 10.1
