4171 connectés
  [Topic Unique] ASUS P4C800 & P4P800 (BIOS 1011 officiel) !!!
 Page :   1  2  3  4  5  ..  244  245  246  247  248  249
Page Précédente
n°2464610
cybermatos
Posté le 23-05-2003 à 10:29:58  profilanswer
Reprise du premier post (génération automatique) :
http://membres.lycos.fr/cybear/Forum/topicR+.gif
Pour ceux qui auraient de grosses lacunes dans les tables de multiplications: :D
http://www.hardware.fr/marc/ram.gif
ASUS P4C800 DELUXE
http://img.clubic.com/images/auto/img42374.jpg
Tres bon article sur la carte-mere (et par un site serieux... ;)):
http://www.x86-secret.com/popups/a [...] .php?id=77
Ftp directe des derniers Bios dispos (bétas et officiels):
ftp://ftp.asuscom.de/pub/ASUSCOM/ [...] 800_Deluxe
Bios 1011 officiel:
ftp://ftp.asuscom.de/pub/ASUSCOM/ [...] /1011d.zip
http://www.clubic.com/images/auto/img42246.jpg
P4C800 Deluxe Introduction:
The P4 CPU on 800MHz FSB, Intel 875P chipset and ASUS' motherboard expertise are exactly what you need if extreme performance is what you are looking for. The P4C800 Deluxe has all of the above plus dual-channel ECC DDR 400 memory, Hyper-Threading Technology support and a whole bunch of advanced innovations for an expert like you.
P4C800 Deluxe also integrates artificial intelligent features such as net-diagnosing utility, audio-jack sensing technology, auto-adjusting CPU Fan and more. The P4C800 Deluxe simply out-performs, out-smarts and out-shines all competition.
Intel 875P chipset
Leveraging the Intel 875P chipset to support 3.2 GHz+ P4 CPU on 800MHz FSB, Dual DDR 400 memory, Intel Hyper-Threading Technology, Intel Performance Acceleration Technology, and a full-range of advanced features, P4C800 Deluxe really delivers a full-value, high-performance solution for today's most demanding tasks.
Dual-Channel DDR400
Dual-channel DDR technology doubles the bandwidth of your system memory and hence boost the system performance to out perform any memory existing solutions in the market. System bottlenecks are eliminated with balanced architecture and peak bandwidths up to 6.4GB/s.
Intel PAT
P4C800 Deluxe's built-in Intel PAT (Intel Performance Acceleration Technology) is a trigger for extreme performance. It helps to boost performance by 3~5%.
Multi-RAID for ATA133 & Serial ATA
The P4C800 Deluxe offers the most complete RAID solution. A Promise SATA controller offers RAID 0, 1 and 10 functions with Max. 2 UltraATA 133 ports and 2 SATA HD ports, enabling users to build a RAID array with any 2, 3 or 4 of the ports. With unique multi-RAID function, RAID 0 and RAID 1 array can co-exist.
AI NET (Gigabit LAN)
The AI Series supports Gigabit LAN by integrating the 3COM 3C940 controller, equipped with a unique net-diagnosing utility-- VCT (Virtual Cable Tester). The controller intelligently detects net connection status up to 100 meters from a remote location and reports the distance of bad cable.
AI AUDIO (6-channel digital audio)
AI series motherboards employed the world's first intelligent audio CODEC. The 6-channel AD1985 audio CODEC automatically detects and identifies what types of peripherals are plugged into the audio I/O jacks and notifies users of inappropriate connection, meaning there will be no more confusion of Line-in, Line-out and Mic jacks.
AI BIOS
CrashFree BIOS 2
Whenever BIOS gets corrupted, ASUS CrashFree BIOS 2 allows users to reboot the computer and perform an smart auto-recovery procedure through the motherboard support CD.
Q-Fan
This unique technology intelligently and automatically adjusts CPU fan speeds according to system load and temperature, enabling users to work in a distraction-free environment with minimal noise.
ASUS POST Reporter
A voice warning design during POST notifies users of any system errors, which means no more complicated LED messages!
AI Overclocking
A unique option in BIOS that enables quick overclocking up to 30% (depends on CPU and RAM). It automatically detects and optimizes every relevant parameter to provide both performance and stability.
The BIOS in AI Series also keeps all the special design for overclocking:
*Flexible CPU Core Voltage Adjustments in 0.025V increments over defaults
*SFS (Stepless Frequency Selection) up to 400MHz at 1MHz increanerts
*Adjustable FSB/DDR ratio. Fixed AGP/PCI frequencies
*ASUS C.P.R.(CPU Parameter Recall)
AGP8X/Pro
AGP8X (AGP 3.0) is the next generation VGA interface specification that enables enhanced graphics performance with high bandwidth up to 2.12GB/s.
4 Serial ATA ports
Serial ATA is the next generation ATA specification that provides scalable performance for today and tomorrow. With up to 150MB/s data transfer rate, Serial ATA is faster than current Parallel ATA, while providing 100% software compatibility.
IEEE 1394 interface
IEEE 1394 interface provides high speed digital interface for audio / video appliances such as digital television, digital video camcorders, storage peripherals & other PC portable devices.
8 USB 2.0 ports supports
USB 2.0 is the latest connectivity standard for next generation components and peripherals.
Backwards compatible with current USB 1.1 peripherals, USB 2.0 delivers transfer speeds up to 40 times faster at 480Mb/s, for easy connectivity and ultra-fast data transfers.
ASUS P4P800
http://www.asus.com/products/mb/socket478/p4p800/p4p800_box.gif
ftp://ftp.asus.com.tw/pub/ASUS/mb/sock478/p4p800/
Bios 1010 officiel:
ftp://ftp.asus.com.tw/pub/ASUS/mb [...] p81010.zip
http://www.hardware.fr/medias/photos_news/00/05/IMG0005955_1.jpg
P4P800 Introduction:
Fast solution for fast performance
Leveraging the Intel 865PE chipset to support 3.2 GHz+ P4 CPU on 800MHz FSB, Dual DDR 400 memory, Intel Hyper-Threading Technology, and a full-range of advanced features, P4P800 really delivers a full-value, high-performance solution for today's most demanding tasks.
Intel 865PE chipset
P4P800 Series support FSB 800 MHz up to 3.2 GHz+ P4 CPU and Intel Hyper-Threading Technology. They raise the bar of PC industry and deliver a full-value, high-performance solution for today's most demanding tasks.
Dual-Channel DDR400
Dual-channel DDR technology doubles the bandwidth of your system memory and hence boost the system performance to out perform any memory existing solutions in the market. System bottlenecks are eliminated with balanced architecture and peak bandwidths up to 6.4BG/s.
AI NET
The AI Series supports Gigabit LAN by integrating the 3COM 3C940 controller, equipped with a unique net-diagnosing Marvell utility-- VCT (Virtual Cable Tester). The controller intelligently detects net connection status up to 100 meters from a remote location and reports the distance of bad cable.
AGP8X
AGP8X (AGP 3.0) is the next generation VGA interface specification that enables enhanced graphics performance with high bandwidth speeds up to 2.12GB/s.
ICH5R with Integrated SATA and RAID 0
Intel is the world?s first chipset maker to integrate Serial ATA (SATA) and RAID 0 functions into the South Bridge. The latest ICH5R chipset now delivers 150MB/s fast data transfer (SATA) and striping performance (RAID 0) to enhance computing efficiency. Note:Microsoft WinXP only.
Multi-language BIOS
ASUS provides friendly localized BIOS setup menu to help you configure your system as easy as possible.
*For multi-language BIOS, please visit the ASUS website for supported languages information.
AI AUDIO
ASUS Q-Fan technology
This Asus unique technology intelligently adjusts CPU fan speeds according to system loading and temperature to ensure quiet, cool and efficient operation.
Max. 8 USB 2.0 ports supports
USB 2.0 is the latest connectivity standard for next generation components and peripherals. Backwards compatible with current USB 1.1 peripherals, USB 2.0 delivers transfer speeds up to 40 times faster at 480Mb/s, for easy connectivity and ultra-fast data transfers.
Extreme Overclocking
ASUS P4P800 offers robust overclocking options to maximize your system performance.
*SFS (Stepless Frequency Selection) at 1MHz increanerts
*C.P.R.(CPU Parameter Recall)
DRIVERS COMMUNS INTEL, UTILITAIRES & BIOS :
Afudos Logiciel de flashage sous Dos :
Ligne de commande : afudos /ixxx.xx (pas d'espace entre le /i et le nom du bios)
ftp://ftp.asuscom.de/pub/asus/mb/ [...] afudos.zip
Dernier Bios Final 1010 P4C800-E Deluxe :
ftp://ftp.asuscom.de/pub/ASUSCOM/ [...] 1010ed.zip
Intel Application Accelerator :
Intel n'a pas encore livré de drivers ATA compatible i875P à ce jour (les drivers natifs WinXP font l'affaire).
Intel Application Accelerator 3.5.2600 RAID Edition :
Attention : Uniquement pour gérer le RAID des southbridge ICH5R
De très nombreux correctifs avec cette nouvelle version, à télécharger ABSOLUMENT :
ftp://aiedownload.intel.com/df-su [...] _multi.exe
Disquette avec drivers RAID pour install système [2K, XP]:
ftp://aiedownload.intel.com/df-su [...] floppy.exe
Intel Chipset Installation Utility 5.00.1015 :
http://fae.abit.com.tw/download/dr [...] /inf50.exe
Driver Intel CSA Gigabit LAN 7.0.37.0 (pour P4C800-E uniquement) :
-Installation grâce à Microsoft Setup Installer (MSI).
-Support de l'interface PRO/1000 CT Desktop Connection.
-Driver multi-langues.
-Amélioration de l'agrégation d'interfaces différentes.
-Meilleures performances des interfaces utilisées en agrégation.
-Amélioration des temps de réponses du PROSet.
-Support du GARP Multicast Registration Protocol (GMRP).
-Priority Packet en version III.
-Boot Agent mis à jour.
Windows 2000 / XP
Version complete : ftp://aiedownload.intel.com/df-su [...] ro2kxp.exe
Driver seul :  ftp://aiedownload.intel.com/df-su [...] o2kxpm.exe
Windows 9x/Me
Version complete : ftp://aiedownload.intel.com/df-su [...] ro98me.exe
Driver seul :  ftp://aiedownload.intel.com/df-su [...] o98mem.exe
Apres install et verification, le driver est en version 7.037 et daté du 21/05/2003. Merci Spine  ;)
Asus LiveUpdate 5.12.01 (utilitaire de flashage de bios sous Windows):
ftp://ftp.asus.com.tw/pub/ASUS/mb [...] .12.01.zip
Asus PcProbe 2.20.08 (logiciel de monitorage):
ftp://ftp.asus.com.tw/pub/asus/mi [...] e22008.zip
Guide d'installation de carte mère en francais :
Un petit guide bien pratique pour les nioubizes de l'info qui ont du mal avec leurs 10 doigts  (et leurs 2 yeux et leur anglais) :D >>>
Le guide de montage
Un grand merci à Lovingbenji pour sa collaboration!! ;)
FAQ:
ASUS P4P800/deluxe: PAT,Performance Mode et Memory Acceleration Mode
http://www.hardware.fr/articles/470/page7.html
-Vous avez raté votre flashage de bios,et CrashFree Bios 2 ne fonctionne pas??Il vous reste une porte de secours qui vous fera peut-etre gagner du temps,en vous evitant un retour inutile au SAV:
http://forum.hardware.fr/forum2.ph [...] h=&subcat=
Merci Phiphi!! ;)
Message édité par cybermatos le 08-09-2003 à 10:12:04
n°2464611
dWarFy81
Super-Connard
DoubleJ a écrit :
Asus vient de mettre le ligne le Bios 1006 par la P4P800.
ca fait un ptit moment :D
(sinon, pour les brackets spdif en rca, j'en ai un moi aussi d'une vieille p4b :))
n°2464616
dWarFy81
Super-Connard
Posté le 23-05-2003 à 10:31:58  profilanswer
split \o/
n°2464624
lovingbenj​i
J'en prendrai pour 1 dollar
Posté le 23-05-2003 à 10:33:57  profilanswer
sur la P4P800 comment je fais ds le bios pour mettre la mémoire en synchro ??  :??: passque pour l'instant elle est en auto et quand je met le fsb à 222MHz dans les freq mem j'ai 266 ou 400 ?? (et pas 444)
Chic not Geek
n°2464626
DoubleJ
Posté le 23-05-2003 à 10:34:18  profilanswer
Oué mé cété pas sur un site officiel (et moi les bios chopés ailleurs que sur le site d'Asus, jm'en méfie un peu :)).
Tiens d'ailleurs, d'habitude je vais sur ftp.asuscom.de, ya bien un dossier pour le i875 mais rien pour le i865 !  :??:
Message édité par DoubleJ le 23-05-2003 à 10:34:50
n°2464671
lovingbenj​i
Posté le 23-05-2003 à 10:49:37  profilanswer
personne peut me dire comment on joue avec les ratios DRAM/FSB sur cette sal..erie de bios de P4P800 ??!!!
Chic not Geek
n°2464738
cybermatos
Posté le 23-05-2003 à 11:19:08  profilanswer
Attend j'ai pas suivi l'histoire,t'as une P4P800 maintenant?? :D
Message édité par cybermatos le 23-05-2003 à 11:19:34
n°2464741
lovingbenj​i
Posté le 23-05-2003 à 11:21:16  profilanswer
cybermatos a écrit :
Attends j'ai pas suivi l'histoire,t'as une P4P800 maintenant?? :D
voir les tests plus haut, on m'en a prêté une et je la teste sur ma conf, comme ça je peux réellement voir la diff  :D
En attendant ya pas de dividers dans cette merde de bios Asus (pour ça vraiment chez Abit c'est autre chose ..  :( ), dans DRAM frequency je trouve juste 400/320/266/Auto, génial ... et comme aucun prog n'est compatible avec l'i865 j'arrive pas à connaître ma fréquence mémoire !!!!
Chic not Geek
n°2464763
ajnag
where no man has gone before
Posté le 23-05-2003 à 11:33:15  profilanswer
400 1/1
320 5/4
266 3/2
auto :??:
Chasser sans bière c'est comme... pêcher sans bière.
n°2464773
lovingbenj​i
Posté le 23-05-2003 à 11:36:34  profilanswer
Je savais qu'un des ces quatres tu retournerais chez ASUS,je l'aurai juré...Je dirai meme que tu l'as acheté ta P4P800 (je connais rarement des gars qui pretent leur carte-mere,c'est comme si j'empruntais un slip... :lol: ),et que tu ne l'as pas dit sur le topic ABIT pour ne pas leur foutre un choc...Je me trompes pas??  :D
si tu te trompes
Chic not Geek
n°2464782
dWarFy81
Super-Connard
Posté le 23-05-2003 à 11:40:40  profilanswer
bravo, tu es l'heureux poseur de cette question aujourd'hui.
si la journée est faste, nous en aurons un deuxième, si elle est très faste, cybermatos expliquera *enfin* les joies des divisions en page 1 pour pas qu'on lise trousanmile fois cette question :D
n°2464797
cybermatos
Posté le 23-05-2003 à 11:47:24  profilanswer
si tu te trompes
Pleure pas je te charrie!! ;)
n°2464812
lovingbenj​i
Posté le 23-05-2003 à 11:52:54  profilanswer
Bon en attendant aucun o/c possible pour la mem de la carte, une fois le param dram freq à 400MHz le bios ne boot même pas à 216MHz - avec ou sans le performance mode - !! (sur l'IC7 je bootais à 230 avec les mêmes timings ..  :sarcastic: ). Par contre si je met la ram sur auto, pas de prob mais là la freq de la ram est inférieur à 200MHz je pense vu mes results sandra.
Et bien sûr, comme dab sur ces bios de daube (passque Asus a vraiment un bios de merde et ça c'est pas une légende) IMPOSSIBLE DE CONNAITRE LA FREQ RESULTANTE DE LA MEMOIRE !! :fou:
Bref pour l'instant, à 200MHz ya pas de prob ça marche très bien, au delà faut m'expliquer passque pour l'instant je suis LOIN d'être convaincu ...
Message édité par lovingbenji le 23-05-2003 à 11:56:56
Chic not Geek
n°2464872
dWarFy81
Super-Connard
Posté le 23-05-2003 à 12:10:57  profilanswer
que les bios d'asus soient parfois étranges (voire même bien mauvais), je suis d'accord.
maintenant pour connaitre la frequence, y'a cpu-z aussi ..
(et ptet que dans les versions futures les bios afficheront la VRAIE frequence en fonction du fsb et non pas 266 333 400, c'est ce qui s'est passé sur 533-v par ex, au debut elle affichait les ratios, puis après 5 ou 6 beta, le bios affichait la vraie fréquence (et pour la 517eme fois : c'est pas un mal vu le nombre de questions, ne serait-ce que sur ce thread, qu'on voit tous les jours à ce sujet))
n°2464887
Marc
Chasseur de joce & sly
Posté le 23-05-2003 à 12:13:50  profilanswer
En FSB800 DDR400 = 1:1, DDR320 = 5:4 et DDR266 = 3:2, faut pas être fut-fut pour ne pas le comprendre ... enfin bon c'est vrai que ASUS pourrait faire un effort de ce coté mais bon.
n°2464888
lovingbenj​i
Posté le 23-05-2003 à 12:14:01  profilanswer
t'as déjà essayé de le faire marcher avec un i865PE ??  :sarcastic:
Chic not Geek
n°2464894
lovingbenj​i
Posté le 23-05-2003 à 12:16:26  profilanswer
Je pose la question passque avec mon OCZ PC3700 (qui marchait à plus de 230MHz sur l'IC7) là je post même pas à 208MHz !!!!!
performance mode "Auto" et plus sur "enabled"
timings 2-3-3-6-4 ou 2-3-3-6-8 ou 2-3-3-7-8 !!!!
VDDR : 2.75v ...
faut m'expliquer là  :o
Chic not Geek
n°2464896
Marc
Posté le 23-05-2003 à 12:16:39  profilanswer
Pour les handis de la calculette :D
n°2464897
Marc
Posté le 23-05-2003 à 12:17:33  profilanswer
VDDR : 2.75v ...
C'est simple, ton OCZ sur l'ABIT elle est sous exploitée alors elle peut aller haut en FSB, sur l'ASUS c'est plus serré donc ca passe moins haut :D
P.S. : Tu a désactivé les deux performances ? Dans ram et dans jumperfree ?
n°2464899
lovingbenj​i
Posté le 23-05-2003 à 12:18:20  profilanswer
avec le bios 1006 yen a plus dans jumperfree.
Chic not Geek
n°2464901
Marc
Posté le 23-05-2003 à 12:18:45  profilanswer
Oh les lourds
n°2464905
lovingbenj​i
Posté le 23-05-2003 à 12:19:25  profilanswer
Marc a écrit :
Oh les lourds
tu l'avais monté à combien la ram toi ??
Chic not Geek
n°2464927
dWarFy81
Super-Connard
Posté le 23-05-2003 à 12:27:05  profilanswer
si cybermatos retrouve le bouton "éditer" il serait bon de mettre ca en haut en haut du thread :whistle:
comme ça après, dès que quelqu'un pas foutu de faire une division (ni de se documenter) posera la question je lancerai un cinglant "regarde la page 1 :fou:" :D
(il va falloir que je foute le "regarde la page 1 :fou:" dans le presse papier alors vu le nombre de fois où je vais devoir le sortir par jour [:tinostar])
n°2464936
cybermatos
Posté le 23-05-2003 à 12:30:25  profilanswer
Ah ben genial cette image,j'aurai pas à tout retaper...C'est bon j'ai retrouvé le boutton EDITER!!! :D
n°2464942
lovingbenj​i
Posté le 23-05-2003 à 12:32:19  profilanswer
va vite falloir que t'arrêtes de faire le malin toi ...
1- c'était documenté où ça ???
2- cpu-z ne marche pas encore sur l'i865PE pour la mem, si tu t'étais documenté tu l'saurais  :sarcastic:
Chic not Geek
n°2464948
Marc
Posté le 23-05-2003 à 12:33:37  profilanswer
Ca poste jusqu'a 230 en synch (2.5-3-3-6-8, le reste en auto, twinx 3200, a 235 bad bios checksum) mais étant donné que pour l'instant je n'ai fait ni un test de mobo a proprement parlé ni un test de mémoire à proprement parlé je n'ai pas cherché plus loin
n°2464949
dWarFy81
Super-Connard
Posté le 23-05-2003 à 12:33:48  profilanswer
n°2464953
lovingbenj​i
Posté le 23-05-2003 à 12:34:48  profilanswer
ok, vais essayé en cas 2.5 pour voir mais bon même si l'IC7 sous-exploite la mémoire, de là à passer en CAS2.5 au lieu du CAS2 ... :(
Chic not Geek
n°2464955
Marc
Posté le 23-05-2003 à 12:34:51  profilanswer
Dans ton cerveau en réfléchissant ... mais bon c'est sûr faut faire plus travailler de neurones que pour lancer un sandra :D
n°2464956
dWarFy81
Super-Connard
Posté le 23-05-2003 à 12:35:10  profilanswer
Ca a dû être dit environ 154784575 fois sur ce thread, également dans l'article de marc, également dans ... bref. voilà quoi.
EDIT : oui, "en réfléchissant" me parait aussi une bonne réponse :)
Message édité par dWarFy81 le 23-05-2003 à 12:35:48
n°2464958
Marc
Posté le 23-05-2003 à 12:35:15  profilanswer
T'est le genre de mec à garder le CAS à 2 à tout prix quitte à être en 4-4-8 derrière ? :lol:
n°2464961
lovingbenj​i
Posté le 23-05-2003 à 12:36:33  profilanswer
nan 2-3-3-7 me va très bien
Chic not Geek
n°2464967
Marc
Posté le 23-05-2003 à 12:37:30  profilanswer
PS : ca boote aussi à 230 en 2-3-3-6 ;)
(j'en connais un qui va moins aimer son OCZ)
n°2464975
lovingbenj​i
Posté le 23-05-2003 à 12:39:04  profilanswer
Corsair PC3500 ??
Chic not Geek
n°2464977
Marc
Posté le 23-05-2003 à 12:39:30  profilanswer
TwinX 3200 ... sert à rien la 3500 ce sont les mêmes puces Winbond dessus :D
n°2464978
Prems
Just a lie
Posté le 23-05-2003 à 12:40:05  profilanswer
Noté :D
Ratures - Cuisine
n°2464982
lovingbenj​i
Posté le 23-05-2003 à 12:41:56  profilanswer
je sais mais Corsair conseillait les 3500 pour éviter le prob du spd trop aggressif, m'enfin c'est effectivement la même chose à ceci près que faut juste pas oublier de mettre les réglages en manuel (surtout à 230  :whistle: )
Chic not Geek
n°2464983
lovingbenj​i
Posté le 23-05-2003 à 12:42:32  profilanswer
vddr ??
Chic not Geek
n°2464985
Marc
Posté le 23-05-2003 à 12:43:24  profilanswer
Ba 2.85, pas essayé en dessous ca sert à rien :D
Cf plus haut "étant donné que pour l'instant je n'ai fait ni un test de mobo a proprement parlé ni un test de mémoire à proprement parlé je n'ai pas cherché plus loin"
n°2465006
dWarFy81
Super-Connard
Posté le 23-05-2003 à 12:50:11  profilanswer
bon, j'ai eu beau cherché, j'ai rien trouvé sur les twinmos 3700 (comme reviews ou comparo j'entends) en dehors de sites de vpc.
y'a des chances (en dehors de toutes considérations tarifaires, uniquement niveaux perfs) que ca marche mieux que les twinxll en 3200 ?
(parceque si jamais je dois acheter cette cm, j'hésite entre ces deux là en 2x256)
et au passage : une p4b533-v, un p4 1.8 et 1x512 de corsair p3200c2 (mais pas LL), on doit pouvoir en tirer combien à la vente en occaz environ ?
Page Précédente
A7V8X > temp° "tres" basse dans le bios est ce normalBIOS ROM checksum error --- A7N8X ---
Retiter un bios pour le flasher?Comment imprimer les infos du bios ?
newbie: install 2 dd en raid 0 sur Asus P4c800ASUS A7V8X et "basse" temperatures ???
L' asus A7N8X-X est il un bon choix ?Kg7 dernier bios (DS) et Athlon XP 2200+
asus a7n8x
Plus de sujets relatifs à : [Topic Unique] ASUS P4C800 & P4P800 (BIOS 1011 officiel) !!!
