8500 connectés
 Page :   1  2  3  4  5  ..  19  20  21  ..  257  258  259  260  261  262
[Topic nVidia 6800 series]
n°3172479
syntaxx_er​ror
Posté le 03-05-2004 à 15:18:04  profilanswer
pred_wan a écrit :
oui c'est cool :)
je pense que les drivers vont encore gagner en perfs
http://www.clubic.com/n/n12513.html
C'est rarement l'inverse en effet  :D
n°3172486
pred_wan
Posté le 03-05-2004 à 15:23:52  profilanswer
raremement ;) mais c'est arrivé avec des détonators il me semble.
Bonne nouvelle (je savais pas) :
Beyond3D is reporting that a recent conversation with John Carmack of id Software has given them a couple of good tidbits of information. It seems as though NVIDIA-specific rendering paths have been removed from DOOM3 with the recent drivers showing much improved performance using the "ARB2" path. This puts the latest-gen ATI (9700+) hardware and the new silicon from NVIDIA on "even ground" which will make the people more interested in benchmark numbers than actual gameplay very very happy. (Repost for those of you that missed it.)
la qualité de doom3 sera la même sur carte ATI et NVIDIA [:itm]
Message édité par pred_wan le 03-05-2004 à 15:24:56
n°3172622
evildeus
Posté le 03-05-2004 à 16:41:20  profilanswer
http://files.skenegroup.net/nvidia [...] n2k_xp.zip ;)
But if they think they're going to hold onto it, they're smoking something hallucinogenic - Jen-Hsun Huang
n°3172648
vingtcent
C'est c'laaaa ouiiii !
Posté le 03-05-2004 à 16:58:18  profilanswer
[:drapo]
n°3172809
evildeus
Posté le 03-05-2004 à 18:07:22  profilanswer
http://www.gamers-depot.com/hardwa [...] 40/002.htm :D
n°3174136
evildeus
Posté le 04-05-2004 à 08:57:05  profilanswer
Concernant le fameux article de DH:
The explanation for the rendering differences is GeForce 6800's new isotropic filtering algorithm: It differs from that of the reference rasterizer. There is an analysis of this available at Digit Life (http://www.digit-life.com/articles2...40-part1-d.html). Based on all information we have, it seems that this algorithm is applied consistently the same way regardless of the application, i.e. it is not application specific and it is not targeting 3DMark specifically.
We also contacted Microsoft about the difference between the rendering of the reference rasterizer and NV40: "The DX9 reference rasterizer does not produce an ideal result for level-of-detail computation for isotropic filtering, the algorithm used in NV40 produces a higher quality result. Remember, our API is constantly evolving as is graphics hardware, we will continue to improve all aspects of our API including the reference rasterizer."
:love:
http://www.techreport.com/onearticle.x/6668
n°3174187
rycky
Posté le 04-05-2004 à 09:30:42  profilanswer
Comme quoi certains sites peu scrupuleux tentent de lancer des accusations de tricherie infondée dans le seul but de nuire à un produit qui visiblement est réellement réussi et n'a pas besoin (contrairement au passé!) du moindre cheat pour délivrer des perfs haut de gamme à qualité maximale...
n°3174195
Posté le 04-05-2004 à 09:33:22  answer
les test de l'ati sont dispo :)
resultat kif-kif :)
n°3174239
rycky
Posté le 04-05-2004 à 09:49:42  profilanswer
Tu parles de celui-ci? http://www.meristation.com/sc/arti [...] EN&cr=5218
J'attends le test de marc pour me faire une opinion + précise...
Message édité par rycky le 04-05-2004 à 09:50:39
n°3174245
Posté le 04-05-2004 à 09:54:06  answer
il y en a 2 dispo toms et celui la :)
Posté le 04-05-2004 à 09:54:06  profilanswer
n°3174265
rycky
Posté le 04-05-2004 à 10:03:33  profilanswer
Celui de tom's c'est uniquement les graphiques c'est ça? Donc je les ai vu les 2  ;)
n°3174691
Dimebag Da​rrell
The Trend Is Fuckin' Over
Posté le 04-05-2004 à 13:49:43  profilanswer
vivement qu'ils nous sortent une version passive, quoi parce que y en a marre d'avoir un réacteur à coté de soi
..::The Trend Is Fuckin' Over::..
n°3174887
rycky
Posté le 04-05-2004 à 14:50:29  profilanswer
Tu prends la version watercoolée ou tu achètes un waterblock de 5900 qui sont les mêmes et tu as silence + performance  ;)
n°3174895
Posté le 04-05-2004 à 14:52:32  answer
euh ca va pas etre possible ça :/
sauf e nwatercooling
n°3175000
Posté le 04-05-2004 à 15:22:04  answer
http://www.hardware.fr/medias/photos_news/00/07/IMG0007762.gif
http://www.hardware.fr/medias/photos_news/00/07/IMG0007763.gif
ati a gagner :)
bon reste plus qu'a voir les tarif des 2 fabriquant maintenant :/
n°3175070
Dimebag Da​rrell
Posté le 04-05-2004 à 15:37:50  profilanswer
ATi gagné wahahahahaha, encore la gueguerre pour 3 petits points en + dans certains prog, encore une fois, attendons quelques semaines et on pourrait tirer de meilleurs conclusion
n°3175076
tixi
Posté le 04-05-2004 à 15:41:31  profilanswer
3 ptits points pour 100 € de moins ;)
n°3175083
Djadja
Posté le 04-05-2004 à 15:43:19  profilanswer
Surtout que la X800pro fait presque jeu égale avec la 6800 ultra pour un prix somme toute modique  :D
n°3175085
jinxjab
Protection engendre sacrifice
Posté le 04-05-2004 à 15:43:45  profilanswer
voila un raisonnement constructif
+1 pour toi garçon !!!
n°3175090
tixi
Posté le 04-05-2004 à 15:45:11  profilanswer
Modique non ( 450 € qd meme !)
Modique par rapport au futur prix d'une 6800 Ultra Extreme, là oui :D
n°3175091
jey04
Posté le 04-05-2004 à 15:45:34  profilanswer
Si tu penses que ATI a gagné, vas plutôt voir le test de Tom's :
http://www.tomshardware.com/graphi [...] index.html
tssss.. [:jey04]
n°3175094
tixi
Posté le 04-05-2004 à 15:46:08  profilanswer
Justement, faut pas aller chez Tom's lol
n°3175110
jey04
Posté le 04-05-2004 à 15:50:13  profilanswer
oups, voui, afin, faut pas regarder son dernier test quoi.. :)
n°3175117
jey04
Posté le 04-05-2004 à 15:52:59  profilanswer
bah, de toute façon le site de Tom's sature pour le moment...
n°3175135
rycky
Posté le 04-05-2004 à 15:56:43  profilanswer
Je crois que Marc a bien résumé la situation :
NVIDIA est-il battu ? Il serait facile, et surtout hâtif, de tirer de telles conclusions. En effet, l’architecture introduite par NVIDIA avec le GeForce 6800 Ultra est beaucoup plus récente et dispose donc à priori de plus de potentiel pour de futurs gains de performances via les drivers.
Alors oui à l'heure actuelle la X800XT et devant la 6800u, c'est indéniable, par contre qd sera t'il dans quelques temps? De + qu'arrivera t'il à la sortie de la playade de jeux basés sur le moteur de Doom3 qui comme le laisse supposer les benchs des jeux opengl donnent un net avantage à nvidia? Il suffit de bien peu de chose pour l'equilibre se rétablisse.
Je crois que la seule certitude est qu'aujourd'hui nous avons le choix entre 2 super architectures offrant chacunes leurs avantages et que ce n'était pas le cas auparavant, et quelque soit le choix personnes ne sera déçu...
Message édité par rycky le 04-05-2004 à 15:58:06
n°3175155
jey04
Posté le 04-05-2004 à 16:01:33  profilanswer
Et puis de toute façon, d'ici 6mois, il y aura encore une nouvelle génération de carte graphique alors...
n°3175157
magic-sim
Attention, pougnat radioactif
Posté le 04-05-2004 à 16:01:35  profilanswer
La partie OpenGL des pilotes et en train d'être réécrite (et là, on a le vieux morceau). Et apparemment le R420 peut lui aussi faire 32 Z-test/cycle.
n°3175161
magic-sim
Posté le 04-05-2004 à 16:02:53  profilanswer
tssss.. [:jey04]
Tomù's Hardware, ou  le site qui avait conclu le test du 5800 Ultra par "Et nVIDIA reprend la couronne de la puisance et de la qualité".....
 [:criun]
n°3175164
PlayTime
Posté le 04-05-2004 à 16:03:35  profilanswer
 :jap: peace and love  :jap:
Message édité par PlayTime le 04-05-2004 à 16:04:19
n°3175166
Djadja
Posté le 04-05-2004 à 16:04:08  profilanswer
 [:criun]
[:atari]
n°3175168
tixi
Posté le 04-05-2004 à 16:04:25  profilanswer
 [:criun]
 :lol:  :wahoo:
Au revoir et adieu jolie Jey04 madrilène :D
n°3175203
Posté le 04-05-2004 à 16:16:32  answer
et surement 150€de difference :/
n°3175310
THE REAL K​RYSTOPHE
ストリートファイターBrasileiro NTSC-J
Posté le 04-05-2004 à 16:54:21  profilanswer
http://www.hardware.fr/medias/photos_news/00/07/IMG0007737.gif
et la konso du X800 pro et du 69800 GT  :??:   c pour moi un element important kan au futur choix de ma karte... :(
n°3175314
Mr Markovi​tch
Posté le 04-05-2004 à 16:55:29  profilanswer
THE REAL KRYSTOPHE a écrit :
http://www.hardware.fr/medias/phot [...] 007737.gif
222W en charge pour une 9700 + P4C etc...?  et il recommande une 300 W?
n°3175402
Marc
Chasseur de joce & sly
Posté le 04-05-2004 à 17:31:40  profilanswer
Pouvait pas, c'est damien qui a finis les tests de perfs et il n'avait ni la même alim ni le truc pour mesurer donc ...
n°3175438
THE REAL K​RYSTOPHE
Posté le 04-05-2004 à 17:46:36  profilanswer
A Mince  :(  bon si ta des chiffres un jour n esite pas :)
n°3175444
sharpei
Posté le 04-05-2004 à 17:49:44  profilanswer
Crotte et moi qui viens de te mailer  :(
n°3175537
sennenmout
Cat Addict !
Posté le 04-05-2004 à 18:29:56  profilanswer
je crois pas que les cartes ATI soient moins chères...
ça n'est jamais le cas (sauf 9800 Pro actuellment)et ce sera pareil sur ce coup avec une X800 XT à 550/600 euros ,tout com la 6800 Ultra deja annoncée entre 550 et 600 aussi..alors pas 150 ,ni mem 100 euros d'écart..
Pareil pour X800 Pro et 6800 GT qui seront entre 400 et 500 euros dispo en magasin.
On a bien vu avec la Leadtek Ultra annoncée à 499 euros et "réajustée" 1 semaine plus tard à 549 euros et finalement en précommande à 589 euros....
Alors arretez avec le cinema à 2 balles pro ATI qui n'a rien gagné ni perdu.
La version du X800XT qui "gagne" est sur sur cadencéé"version plutonium machin" et on en aura pas ds le commerce..Alors au frequences normales c'est égalité sur tte la gamme et ça reste donc une question  de "préference" et à perfs égales...avec une archi un peu plus tournée vers l'avenir..Ben y en a bokou qui retourneront chez Nvidia.
Pfft c'est incroyable cette interpretation des chiffres(dont on se fout ds l'absolu)..dirigée et partiale.
n°3175759
babaorum
Posté le 04-05-2004 à 19:55:55  profilanswer
la GT chez nvidia et la Pro chez ATI, voilà le vrai match ;)
n°3175772
THE REAL K​RYSTOPHE
Posté le 04-05-2004 à 20:01:42  profilanswer
ben la X800 pro est largement au dessu de la  gt mais bon apparament 100 euro de +...:(
n°3175815
pred_wan
Posté le 04-05-2004 à 20:19:19  profilanswer
nan elle est loin d'être largement devant.
sur la somme de tous les benchs c'est quasi équivalent je trouve
coup de geule contre ati/nvidia & carte mere :qualitée de l'Entree Video ATI vs Nvidia
Bi-Ecran: (9800pro) ATI /nVidia (5900) ? - surchauffe ?"Nvidia WDM Video capture (universal)"?!?
Pilotes NvidiaPilotes Nvidia 45.xx pour 2k/xp : ou est ce qu'on active la sortie tv?
[CG] Quelle est la meilleure Nvidia 4 Gamers sur le marché ?new drivers nvidia 56.72
NVidia TI 4200 - Ventilo misèreInstallation d'une ATi après une NVIDIA
Plus de sujets relatifs à : [Topic nVidia 6800 series]
