4527 connectés
  Nvidia et ATI vous mentent ! Ils vous Spolient ! ( Grave inside)
 Page :   1  2  3  4  5  6
Page Précédente
n°2166050
Tetedeienc​h
Head Of God
Posté le 26-01-2003 à 21:07:09  profilanswer
Je fais un topic a part car ce truc me fait halluciner.
ATI et Nvidia vous vendent des produits fallacieux.
Nvidia clame que ses cartes GeForce4 supportent le HSR. Ce n'est pas vrai !
ATI clame que ses R9500 supportent le HSR. Ce n'est pas vrai !
Qu'est ce que le HSR ?
Imaginez que vous ayez deux polygones. Le premier se situe derriere le second. Donc, quand vous regardez la scene, vous ne voyez que le second polygone, pas le premier, qui est cache. A quoi ca sert de le calculer alors ?
Eh ben digit-life viens de lacher une bombe :
http://www.digit-life.com/articles [...] x9-p2.html
Isn't it shocking?
The HSR doesn't work in both NVIDIA chips! It's disabled by the drivers (though it remains enabled on the NV20). The register key which allows turning it on/off doesn't work - we failed to enable this function on the NV25. What's the matter? An error in the chip that makes it impossible?
It does work (HyperZ) in all the RADEON 9700 and RADEON 9500 PRO chips and demonstrates a perfect performance. But it is not supported in all RADEON 9500 chips! It's disabled, and probably on the driver level again. Why? Maybe, for creation of an additional difference in real applications? But the more believable version is that there are some defects in the die, and that is why they are used for cards on the RADEON 9500. Besides, to make performance lower relative to the RADEON 9500 PRO and 9700, such dies have half of their pipelines disabled. In the first part we discussed the problem of turning the RADEON 9500 into RADEON 9700 (9500 PRO) with the RivaTuner, i.e. on the software level. The following events showed that it's not so smooth as we wanted it to be. First of all, not all R9500 chips work without artefacts after the redesigning, about 28% have bugs which indicate some problems in the HyperZ unit. Isn't it the unit that controls the HSR? I think that ATI disables the crippled HSR unit on the software level with half of the pipelines and then uses such chips as RADEON 9500.
http://www.ifrance.com/tetedetcha/hsr-d5.jpg
Pour ceux qui ne comprennent pas l'anglais :
N'est-ce pas choquant ?
Le HSR ne marche pas sur les deux chips Nvidia ! Il est desactive par les driver ( meme si il reste active sur le NV20). La cle du registre qui permet de l'activer ne marche pas non plus - Nous n'avons pas reussi a activer cette fonction sur le NV25. Pourquoi ? Un bug dans la puce qui le rend inutilisable ?
Par contre, le HSR ( HyperZ) marche sur toutes les Radeon 9700 et les R9500 Pro et montre des performances parfaites. Mais il n'estpas supporte par les R9500 ! Il est desactive, et probablement au niveau du driver, encore une fois. Pourquoi ? Peut etre pour creer une relle difference au niveau des applis entre les chips ? Mais la version la plus probable c'est qu'il y a des defauts dans le chip, et ce serait pourquoi ces chips sont utilises sur des R9500. De plus, pour que les performances soient inferieures a celles du 9500 pro et 9700, de tels chips ont la moitie de leur pipelines desactives.
Dans la premiere partie nous avons aborde le probleme visant a modifier une R9500 en R9700 ( R9500 Pro) avec RivaTuner, i.e. au niveau du software. Les tests d'aujourd'hui nous montre que ce n'est pas aussi simple que nous le voudrions. D'une part, certains chips R9500 ne marchent qu'avec des bugs apres la ransformation, a peu pres 28% des puces ont des bugs montrant desproblemes dans l'unite HyperZ. N'est-ce pas l'unite controlant le HSR ? Je pense qu'ATI desactive l'unite HSR defectueuse au niveau des pilotes avec la moitie des pipelines et apres nomme ces chips R9500
On peux tous porter plainte pour publicite mensongere contre les DEUX compagnies...
n°2166056
napalm57
Posté le 26-01-2003 à 21:08:50  profilanswer
Isn't it shocking?
La 3dfx supporte le HSR  :whistle:
n°2166057
hide
Posté le 26-01-2003 à 21:08:55  profilanswer
[:meganne]
chiche :D
Et si c’était ça la vie / Et si on nous l’avait pas dit ?
n°2166059
hide
Posté le 26-01-2003 à 21:09:20  profilanswer
déquote tout le post, plz :D
n°2166062
yannick_fr​ere
Posté le 26-01-2003 à 21:10:19  profilanswer
Si c'est désactivé au niveau des drivers, alors il est inutile de porter plainte : ils te diront qu'une maj des drivers sortira bientôt etc ... Et ne ils ne mentent même pas, puisque la carte supporte bien le HSR (juste qu'il est désactivé logiciellement ! ;)
M'enfin, si c'est vrai, ce n'est guère joli-joli ...
n°2166067
Tetedeienc​h
Head Of God
Posté le 26-01-2003 à 21:11:07  profilanswer
Dans le cas de Nvidia, peut etre.
Dans le cas d'ATI, non, vu que les bugs se situent au niveau de l'unite HyperZ...
et la les bugs sont hardware...
Ca fait 25% de cartes a changer.
De plus, je pense que Nvidia ne peux pas activer cette fonction, sinon, ils l'auraient deja fait ( tu penses).
Message édité par Tetedeiench le 26-01-2003 à 21:11:52
n°2166069
leto
Posté le 26-01-2003 à 21:12:06  profilanswer
Ca pourrait etre pire , au moins ca marche sur les 9500Pro,9700 et 9700Pro .
Après, a mon avis si nvidia n'a pas activé ces fonctions , ils doivent avoir une raison .
Et puis faudrait tester avec un autre benchmark (villagemark?).
n°2166070
SANDSTOREK​EEPER
J'ai toasté mon PC !!!!!
Posté le 26-01-2003 à 21:12:10  profilanswer
:fou: s'est où qu'on porte plainte ? :fou:
Mac Gyver avec un trombonne et son couteau suisse il te fait une moto a vapeur.
n°2166071
Posté le 26-01-2003 à 21:12:13  answer
euh pkoi y a si peu de diff ds les jeux ?
n°2166073
hide
Posté le 26-01-2003 à 21:13:03  profilanswer
à moins que le bug ne soit que sur une partie des chips => fo pas prendre le risque de se retrouver avec 30% de geforce 4 crachant un BSOD toutes les 5 min, :D
n°2166076
Tetedeienc​h
Head Of God
Posté le 26-01-2003 à 21:13:51  profilanswer
Exactement.
De toute facon, ATI est dans la merde si on porte plainte, ca c'est clair.
Nvidia je sais pas.
n°2166080
Tetedeienc​h
Head Of God
Posté le 26-01-2003 à 21:14:33  profilanswer
Limite si je vois une action se monter, je fonce acheter une R9500 normale et je me joins a l'action...
n°2166084
hide
Posté le 26-01-2003 à 21:15:47  profilanswer
Exactement.
Nvidia je sais pas.
faudrait qu'on se mettre à plusieurs et réclamer du pognon :D
n°2166085
mikestewar​t
Air Roll Spinnin'
Posté le 26-01-2003 à 21:16:01  profilanswer
Exactement.
Nvidia je sais pas.
Qu'est-ce que t'as contre ATI ?
n°2166087
hide
Posté le 26-01-2003 à 21:16:06  profilanswer
+1 :o
n°2166089
hide
Posté le 26-01-2003 à 21:16:59  profilanswer
:heink:
n°2166090
Tetedeienc​h
Head Of God
Posté le 26-01-2003 à 21:17:09  profilanswer
Rien, mais dans leur cas, c'est avere : le probleme se situe dans le hardware.
Lis le texte : ATI prends des dies defectueux, et desactive les parties defectueuses pour en faire des R9500...
Ce serait sans souci si ils ne desactivaient pas le HSR... chose qu'ils font car l'unite HyperZ gerant le HSR a des bugs dans certains chips ...
n°2166091
@chewie
Posté le 26-01-2003 à 21:17:14  profilanswer
Faut demander aux bitboys de porter plainte, vont pas hésiter une seconde :O
n°2166092
chrisleurn
Hardcore Will Never Die !
Posté le 26-01-2003 à 21:17:37  profilanswer
surtout que les GeForce 4 on le meme probleme :heink:
n°2166098
hide
Posté le 26-01-2003 à 21:18:31  profilanswer
mais qu'on est pas sur que ce soit hw :D
n°2166100
chrisleurn
Posté le 26-01-2003 à 21:19:31  profilanswer
Si j'ai bien compris, c'est pour eviter celles qui sont plus ou moins defecteuse de planter, donc spareil :kaola:
n°2166101
Tetedeienc​h
Head Of God
Posté le 26-01-2003 à 21:19:44  profilanswer
HidE, on estexactement sur la meme longueur d'onde...
n°2166102
mikestewar​t
Air Roll Spinnin'
Posté le 26-01-2003 à 21:19:45  profilanswer
Tu croyais pas qu'ils allaient mettre que des R300 100% opérationnels non plus...la carte est vendue à moins de 200?... :sarcastic:
n°2166106
hide
Posté le 26-01-2003 à 21:20:45  profilanswer
:love:
n°2166107
Posté le 26-01-2003 à 21:20:57  answer
PowerVR vaincra  :D
n°2166111
Tetedeienc​h
Head Of God
Posté le 26-01-2003 à 21:21:06  profilanswer
Pour les GeForce4, non, on en sait rien, car on a aucun moyen d'activer la fonction pour voir si y en a qui ont des problemes.
On sait juste que la fonction est absente.
Comme hidE dit, Nvidia peux tres bien dire maintenant : " on va activer la fonction, ct un bug de nos pilotes" et l'activer par la suite.
Cependant, si ils l'ont desactive c'est pas pour rien, donc...
n°2166112
chrisleurn
Posté le 26-01-2003 à 21:21:14  profilanswer
Moi je porte plainte contre Nvidia alors, en plus j'en ais une
n°2166113
hide
Posté le 26-01-2003 à 21:21:16  profilanswer
Hr a écrit :
3DFx 4 ever [:dawa]
dans 10 ans, quand l'agp n'existera plus, ça sera cool :D
n°2166114
Tetedeienc​h
Head Of God
Posté le 26-01-2003 à 21:21:34  profilanswer
C'est marque sur la boite des R9500, le voila le souci mike... c'est pareil pour les Nvidia...
n°2166116
hide
Posté le 26-01-2003 à 21:21:56  profilanswer
çai p'tet l'origine des bsod à une époque :??: [:meganne]
n°2166118
hide
Posté le 26-01-2003 à 21:22:42  profilanswer
ouais mais elle est sencée faire un truc qu'elle fait po :o
n°2166120
Sonark
Posté le 26-01-2003 à 21:23:30  profilanswer
Vis à vis de la loi française la publicité mensongère (qui trompe donc le consommateur) est très sévèrement punie. Il faut que je relise le code de la consommation pour avoir les chiffres exacts, mais je sais que les indemnités sont importantes quand la supercherie est prouvée (ce qui n'est pas difficile ici).
Alors chiche ?
Qui veut gagner des sous sur le dos d'ATI et de Nvidia ?
(pour une fois que ça sera dans ce sens :D )
Message édité par Sonark le 26-01-2003 à 21:24:39
n°2166121
mikestewar​t
Air Roll Spinnin'
Posté le 26-01-2003 à 21:23:31  profilanswer
Ben marketing encore et toujours, l'HyperZ est là depuis les Radeon1, une R9500 sans hyperZ ça aurait fait tâche c'est sur.
n°2166123
Tetedeienc​h
Head Of God
Posté le 26-01-2003 à 21:24:52  profilanswer
Fueled by the Acclaimed Feature-Set of the ATi RADEON 9500? VPU
The pulse of the RADEON 9500 ATLANTIS and RADEON 9500 ATLANIS PRO lies in the raw power of the world's most complex VPU in the RADEON 9500, operating at a blistering 275MHz. Enjoy elaborate worlds erupting with life, rendered in real-time with sophisticated lighting effects supported by DirectX® 9.0 and made possible by the RADEON 9500 VPU's Veretex Shader Engine, SMARTSHADER? 2.0. Surround yourself in environments absent of jagged edges, and constructed with precision spatial representation, made possible by full-scene anti-aliasing (FSAA) and anisotropic filtering, found in SMOOTHVISION? 2.0. Further extending the pursuit of true-to-life graphics, the RADEON 9500 ATLANTIS and 9500 RADEON ATLANTIS PRO make use of TRUFORM? 2.0 to generate scene models that demonstrate the same skeletal and muscular features as their real world counterparts. All of these features, without the frame rate hit due in part to the HYPERZ? III technology embedded in the RADEON 9500 core that removes unseen pixels from memory and reduce the necessary memory bandwidth consumption by over 50%! When paired with the acclaimed CATALYST driver suite, no graphics solution can rival it!
http://www.makeitsimple.com/article.php?sid=358
mike, la, c'est de la publicite mensongere, pas du vaporware ou du marketing...
Arrete la mauvaise foi tu veux ?
Message édité par Tetedeiench le 26-01-2003 à 21:25:16
n°2166125
hide
Posté le 26-01-2003 à 21:25:28  profilanswer
Hr a écrit :
Adaptateur AGP §
ouais çai ce que certains disaient lors du passage isa => pci :D
n°2166126
hide
Posté le 26-01-2003 à 21:26:08  profilanswer
vite , envoie les chiffres :D
n°2166130
Sonark
Posté le 26-01-2003 à 21:27:37  profilanswer
Ok je cherche, 5 min....
n°2166132
mikestewar​t
Air Roll Spinnin'
Posté le 26-01-2003 à 21:28:10  profilanswer
Ni ATI ni Hercules ne vendent de R9500, va savoir pourquoi... :sarcastic:
Et comment être sûr que Sapphire fait de la pub mensongère, si eux-même ne sont pas au courant... :/
n°2166133
hide
Posté le 26-01-2003 à 21:28:24  profilanswer
yeah, merci d'avance :jap:
n°2166135
@chewie
Posté le 26-01-2003 à 21:29:44  profilanswer
ati interdira la vente de ses chips sur le territoire francais, c tous que vous aurez gagnés :D
 Page :   1  2  3  4  5  6
Page Précédente
Bi-ecran avec Ati 8500Pb de distorsion d'image sur la sortie VGA d'un Dell avec ATI Mobility
A tous les possesseurs de Nview (Nvidia)xp + Nforce 2 = graveur 48x grave a 10-12 X ????
Probleme avec CG nvidiaNvidia Problème bizzard en 2d
Mon XP est un 0.13 ou un 0.18 [REF Inside]ATI Rage vs S3 savage
[ ATI AIW 128 Pro ] Accélération matérielleProb super zarb sur ATI All in Wonder 9000 Pro
Plus de sujets relatifs à : Nvidia et ATI vous mentent ! Ils vous Spolient ! ( Grave inside)
