6313 connectés
 Page :   1  2  3  4  5  ..  99  100  101  ..  306  307  308  309  310  311
[topic unique]ATI Radeon HD2900XT (512 Mo et 1 Go)
n°5710382
rootsayen
Jungle Cat
Posté le 12-08-2007 à 12:40:03  profilanswer
"Huddy said that the new API ‘eliminates one of the minor but annoying differences between different vendor's hardware,’ but also described the changed in some of Shader Model 4.1’s other graphical features. ‘The two most obvious changes to affect games programmers will be in the enhancement of the Vertex Shader,’ saids Huddy, ‘which is now allowed to export up to 32 elements instead of the previous maximum of just 16.’ Huddy said that this ‘will generally reduce the number of passes that hardware takes to render complex surfaces.’
As well as this, games that used deferred rendering, such as Ghost Recon: Advanced Warfighter, will be helped along by the ability to have individual blend modes per target when using multiple render targets. Huddy said that ‘AMD welcomes all of these changes and will be enthusiastic in its support of DirectX 10.1.’ He then cryptically added: ‘Expect timely announcements from us...’"
Tout ce qui peut entrainer mois de passes, je prends :D
"Being solitary is being alone well; being alone luxuriously immersed in doings of your own choice, aware of the fullness of your own presence rather than the absence of others."
n°5710474
kaiser52
Posté le 12-08-2007 à 13:49:55  profilanswer
Mais vous pensez avoir des améliorations de perfs de ouf à chaque driver ou quoi ? :heink:
Benchmarks du peuple - Crysis War - Vide grenier ! - nVIDIA Tegra
n°5710476
rxjy
JeanZyves
Posté le 12-08-2007 à 13:50:55  profilanswer
avec les beta 7.8 par rapport aux 7.6
trackmania nation ne marche toujours pas
sous lost planet dx9 je fais +10% de FPS
sous fear : rien
sous le bench unigine, je n'arrive pas à remettre les mêmes paramètres mais la 2900xt est maintenant reconnue comme une 1go...
n°5710484
rootsayen
Jungle Cat
Posté le 12-08-2007 à 13:54:35  profilanswer
Moi non, je suis resté avec ma bonne vieille 1950xt, toujours très satisfait. Le R600 est presque une blague pour moi... très interessant techniquement, mais trop peu trop tard...
HFR doit d'ailleurs sortir un nouveau test des R6xx avec de nouveaux drivers non ?
Message édité par rootsayen le 12-08-2007 à 13:55:03
n°5710486
ubermario
Posté le 12-08-2007 à 13:55:49  profilanswer
Bah c'est pourtant le cas hein :spamafote:
Ma Golf G60
n°5710488
kaiser52
Posté le 12-08-2007 à 13:57:27  profilanswer
ha bon ?? j'avais pas remarqué  :jap:
edit :
Avant que je me fasse lapider et traiter de troller :
Je parle d'augmentation de barbar, pas 10% par si, 10% par là...
Message édité par kaiser52 le 12-08-2007 à 14:03:32
n°5710508
MacIntoc
tu lis une phrase formidable.
Posté le 12-08-2007 à 14:08:39  profilanswer
Bah... 10% par drivers, ça fait prés de 35% après 3 driver par rapport aux perfs d'origines :D
n°5710510
ANViL
yep...definitely ♫
Posté le 12-08-2007 à 14:12:57  profilanswer
jeff74700 a écrit :
salut je viens de lire une news assez triste :( les cartes graph actuelles directx 10 ne seront pas compatibles directx 10.1 pour moi il y a un gros foutage de gueule. déjà qu'on sait même pas ce que les 8800 et hd 2900 donneront sur un jeux fait 100 % directx 10 et bin on l'a bien dans l'os car on devra changer pour profiter des évolutions de directx 10. en tout cas ça me donne pas envie de passer pour le moment sur vista!! voilà ct mon coup de gueule perso.
La HD2900 supporte DX 10.1 pourtant  :heink:
Message édité par ANViL le 12-08-2007 à 14:57:39
n°5710534
kaiser52
Posté le 12-08-2007 à 14:26:57  profilanswer
Ouai si c'etait tous le temps sur le même jeux ^^
C'est souvent des perfs gagné sur des jeux differents,  et surtout sur des jeux qui n'en on pas besoin. C'est surtout ca le truc, puis c'est pas tous le temps 10% hein, défois plus, défois moin.
Perso, je trouve que placer cette arguments dans tous les débats concernent les 2900 est un peu abuser. Qui plus est les perfs des Geforces 8 augmente aussi avec les drivers surtout sur vista la ou elle en à le plus besoin. C'est une bonne carte à ne pas en douter, point barre depuis le temps que ces cartes sont là  (R600, G80) on à plus à chipoter sur la quel est mieux, mais laquel correspond le mieux à nos attentes  :jap: .
edit :
La HH2900 supporte DX 10.1 pourtant  :heink:
C'etait purement marketing.  :sol:
Message édité par kaiser52 le 12-08-2007 à 14:27:42
n°5710538
rootsayen
Jungle Cat
Posté le 12-08-2007 à 14:29:37  profilanswer
Officiellement, maintenant, non.
Ati a dit qu'on allait les entendre bientot à ce sujet...wait&see.
n°5710587
ubermario
Posté le 12-08-2007 à 15:05:26  profilanswer
edit :
Exactement ca...
Les drivers augmentent progressivement leurs perfs, mais au total, on se retrouve avec une carte ayant quasiment (les shader 2.0 sont un peu moins bons sur 2900xt, l'inverse avec les shader 3.0 par contre) les mêmes perfs qu'une 8800gtx...
Mais à cela, tu rajoute le support de la HD, l'avivo, un prix inférieur de +/- 200€...
Donc ca reste quand même une carte avec un super rapport qualité/prix, et c'est ce que le public demande :)
Ma Golf G60
n°5710660
Cizia
Posté le 12-08-2007 à 15:57:19  profilanswer
sur certain jeux,elle vaut la gtx...
n°5710664
ubermario
Posté le 12-08-2007 à 15:59:22  profilanswer
C'est bel et bien la réalité :)
Et également testé chez un pote, même config, la 2900xt rivalise très bien face a la gtx et la surpasse même une fois clockée, avec rad stock :D
Message édité par ubermario le 12-08-2007 à 16:00:51
Ma Golf G60
n°5710678
rootsayen
Jungle Cat
Posté le 12-08-2007 à 16:07:40  profilanswer
Avec AA et Aniso, c'est pas trop le cas ...
n°5710686
kaiser52
Posté le 12-08-2007 à 16:11:52  profilanswer
Oui sur certains jeux, on peut dire pareil de la GTS face à la HD....
Oui et la GTX une ois cloké avec le rad stock elle la surpasse aussi.
Faut arreté là. Ca en devient ridicule. Elle n'à pas le même prix face à la GTX don elle joue forcement pas sur le même terrain.
C'est une réalitée faut pas chercher plus loin. Elle à de tres bonnes perfs c'est indéniable mais pas de quoi rivaliser contre une GTX.
n°5710697
god is dea​d
Demain, j'arrête de poster.
Posté le 12-08-2007 à 16:24:01  profilanswer
Faudrait faire des tests sérieux. Parce que les "moi j'ai vu chez un pote" ou "oué chez moi (avec deux jeux)", ça vaut quedalle :o
n°5710708
kaiser52
Posté le 12-08-2007 à 16:34:28  profilanswer
Ouaip je suis tous à fait d'accord.
Le probleme c'est que faudrait les 3 cartes (HD, GTX, GTS) sur un seul et unique PC pour les testes.
Ca differe souvent même si on le fais le plus serieusement possible, sur 2 platformes, même le plus identique qui soit.
n°5710719
ubermario
Posté le 12-08-2007 à 16:41:07  profilanswer
Kaiser, je te met au défi, on va comparer nos cg.
Pousse ton proco a 3.5 ou 3.6ghz, ta gtx à la fréquence que tu veux, je ferais pareil à la même fréquence, et go 3dmark06.
Là je pars au taf, mais en rentrant demain a 5h, je le lancerais à la même fréquence que toi, poussé la 2900xt, et on pourra donc comparer chez des users "normaux" avec radstock :)
Durant la semaine si tu veux faire des tests avec d'autres jeux, pas de soucis :)
Ma Golf G60
n°5710723
god is dea​d
Posté le 12-08-2007 à 16:44:51  profilanswer
Comparer deux cartes sous 3dk06 c'est vachement représentatif.
n°5710724
rootsayen
Jungle Cat
Posté le 12-08-2007 à 16:44:53  profilanswer
3dmark2006 ne vaut pas grand chose, ou alors lancé le avec fsaa4x et aniso16x, comme dans l'utilisation en jeux quoi. Jouer sans filtrage avec ces cartes, c'est nawak.
n°5710755
kaiser52
Posté le 12-08-2007 à 17:00:53  profilanswer
Déjas mon proco prend pas 3.5 ^^.
En se qui conscerne 3DM06, c'est vachement représentatif des perfs que je fais sous les jeux.
3DM06 est à l'avantage des HD, je peut tous simplement de demandé de faire des testes avec la beta de WIC en DX10 ca sera à mon avantage.
Je prefererais des testes d'une personne qui n'est ni pour la HD ni pour le G80, je vois dans tes propos que tu prefers la 2900 et moi dans les miens que j'ai une preference pour le G80, don les jeux iront dans cette ordre.
n°5710758
dami1stm
Eco-coco φ
Posté le 12-08-2007 à 17:01:52  profilanswer
Prêtez moi vos deux CG et je fais ca  :D
"La liberté d'expression n'a d'ennemis que ceux qui veulent se réserver le droit de tout faire" - "Seems all have gone insane for gold"
n°5710760
kaiser52
Posté le 12-08-2007 à 17:03:44  profilanswer
Pour être franc ! Preter ma CG pas le moin du monde XD.
Ca coute cher ces trucs là  :whistle:
n°5710781
Down to th​e Devil
Posté le 12-08-2007 à 17:16:28  profilanswer
n°5710784
dami1stm
Eco-coco φ
Posté le 12-08-2007 à 17:19:04  profilanswer
Contente toi de me les donner  [:cosmoschtroumpf]
n°5710785
kaiser52
Posté le 12-08-2007 à 17:19:44  profilanswer
Vue sous cette angle qui sait  :lol:
Mais je sasi dejas lesquelles tu vas jeter  :whistle:
Quoi ?? j'ai rien dis :p
n°5710807
patci
Posté le 12-08-2007 à 17:33:59  profilanswer
bonjour, je vois que tout le monde ici ne parvient pas à se mettre d'accord mais je vais quand même poser certaines questions^^: -les shaders 4.0 sont-ils supportées par toutes les hd2900xt?? Je vois sur rue du commerce une shader 3.0 (celle à 469.90 euros).
-j'ai actuellement une config que je désire changer pour: un core 2 duo, une bonne carte graphique (soit hd, soit 8000 gts ou gtx) et un écran 22"!! MAIS: mon alim ne fait que 480 watts, serat-t-elle suffisante?
-au risque de relancer la bagarre: HD2900 ou 8800 gtx??? la différence de performances est-elle si flagrante?
n°5710817
Cizia
Posté le 12-08-2007 à 17:38:29  profilanswer
bien sur que la x2900 est compatible shader 4...
par contre l'alim....je te conseillerais au moins(si tu compte monter une bonne config puissante donc gourmande)550-600w de grande marque(zalman,seasonic,hiper,antec etc...)
n°5710818
dami1stm
Eco-coco φ
Posté le 12-08-2007 à 17:38:32  profilanswer
Sharder 4.0 supporté oui et pour moi la difference n'est pas flagrante surtout si tu ne dépasses pas le 1600X1200 et même en 1920X1200 je pouvais jouer dans de très très bonne conditions avec une seul HD 2900XT
Message édité par dami1stm le 12-08-2007 à 17:38:49
n°5710821
dami1stm
Eco-coco φ
Posté le 12-08-2007 à 17:39:47  profilanswer
30" Wide?
> GTX alors de préférence  :)
n°5710826
patci
Posté le 12-08-2007 à 17:41:20  profilanswer
Alors c'est une errreur sur Rue du commerce?? Une autre question: une HD2900 xt avec 1 go de ram n'est-elle pas meilleure qu'une 8800 gtx? ET est-ce que mon alim de 480 wats suffira pr une super CG comme celles-ci, un core2duo et un 22"?
n°5710832
fred378
Posté le 12-08-2007 à 17:44:35  profilanswer
salut à tous
voila un screen de 3dm06 avec ma 2900 xt 512 mo oc à 833/1017
Cpu  core duo 6600 oc à 3590 mhz
2GO de team xtrem 800
pilote ati 7.8 beta
j'en suis trés content
http://img261.imageshack.us/img261/5140/126523590mhzcf3.th.jpg
n°5710834
dami1stm
Eco-coco φ
Posté le 12-08-2007 à 17:48:16  profilanswer
La 2900XT était déjà très bonne en 1920X1200 et dans de très bonne conditions, il suffit de ne pas mettre systématiquement tout à fond, du moins pour les filtres  :)
n°5710869
patci
Posté le 12-08-2007 à 18:17:25  profilanswer
heu... quelqu'un peut me répondre svp?
n°5710901
patci
Posté le 12-08-2007 à 18:33:59  profilanswer
la résolution max d'un 22" c'est 1680 par 1050... non?? donc là pas besoin de plus qu'une hd 2900... qu'en pensez vous?
n°5710930
rxjy
JeanZyves
Posté le 12-08-2007 à 18:46:57  profilanswer
Dami1, t'as pas l'occasion de le faire en Lan o/c???
n°5710931
dami1stm
Eco-coco φ
Posté le 12-08-2007 à 18:48:38  profilanswer
Euh si mais pas le temps quoi...
En LAN j'ai des Ultra, GTX et 2900 aisni que des GTS facilement à disposition mais je préfère bencher que jouer ou faire des tests  :D
Message édité par dami1stm le 12-08-2007 à 18:48:48
n°5710937
dami1stm
Eco-coco φ
Posté le 12-08-2007 à 18:50:25  profilanswer
une 2900XT est parfaite pour cette résolution, 480W ca devrait aller pour une 2900 sans soucis normalement mais ca dépend encore de sa qualité.
La version 512mo de la 2900 suffit amplement, la 1Go a une intérêt assez limité  :)
n°5710948
kaiser52
Posté le 12-08-2007 à 18:55:10  profilanswer
Moi je dirais 8800GTS 320 pour cette reso. au pire un petit coup d'O/C
n°5710966
dami1stm
Eco-coco φ
Posté le 12-08-2007 à 19:02:57  profilanswer
Biensur que ca peut suffir, mais là on parle pas de sufisance mais de tout à fond avec la 2900XT et cette reso.
n°5710968
dami1stm
Eco-coco φ
Posté le 12-08-2007 à 19:03:57  profilanswer
Bah la mienne est morte en voulant la passer sous DOD donc peut être suis 'je mal placer pour émettre un avis neutre, mais je ne vois pas légion venir se plaindre de ce coté là  :)
Ati Radeon 9250 et résolution d'affichage ...Probleme avec ATI 9200 SE
Comment savoir si ma radeon 9800 pro est naze ?1 GO mais seulement 512 ...
HD2900xt, 8800GT(?) ou attendre la HD2950 annoncée pour aout/sept ?[ topic unique ] Dfi Lanparty UT NF680i LT SLI-T2R
Drivers ATI Rage IntrouvableAti 9600 sapphire gros probleme
[Topik Unique] : Différences entre Striker Extreme et P5N 32 SLI
Plus de sujets relatifs à : [topic unique]ATI Radeon HD2900XT (512 Mo et 1 Go)
