6996 connectés
 Page :   1  2  3  4  5  ..  754  755  756  ..  814  815  816  817  818  819
[Topic Unique] Sony NEX/Alpha - Hybrides APS-C
n°5644682
alffir
Posté le 08-02-2016 à 16:11:45  profilanswer
-Chris- a écrit :
Peut-être une explication de la non intégration de l'IBIS dans les derniers boîtiers APS-C Sony.
Explication par ... Fuji
“First of all, our XF mount is not compatible with IBIS. You may be thinking that our mount size is similar to competitors’ and why Fujifilm cannot do it. The answer is simple: for the sake of image quality.
IBIS has both advantages and disadvantages. IBIS moves the sensor in the mount to stabilize the image. To secure the amount of light at any position, the diameter of mount must cover the wider image circle considering the margin of sensor movement. The diameter of our mount was designed for the image circle without IBIS. It means the amount of light at the corners is reduced when the sensor is shifted. We could correct it digitally, but we don’t want to do it: we don’t want to compromise our image quality.
To cover the larger image circle, not only mount size (and body size), but also lens size must be bigger. We are pursuing the best balance of image quality, size and weight of both cameras and lenses, operability and performance. When we were deciding on the design of our mount, we decided to provide the best quality body and lens in comfortable small package as the best balance. And we don’t think this direction will be changed in the future. Our highest priority is always image quality. We hope you agree!”
La monture E est utilisée par des boîtiers FF et stabilisés, du coup ça devrait marcher en APS-C.
Je ne sais pas quel déplacement du capteur cela implique, cela avait été discuté pour les boitiers Pentax FF stabilisé. Quand on voit les performances du 16mm f/2.8 dans les coins, ça ne donne pas envie d'aller encore plus loin :o.
Par contre, les optiques m43 Oympus ne me paraissent pas énorme comparées aux Panasonic, et la stab' fait des miracles en vidéo.
Sony avait stabilisé pas mal d'optiques en APS-C (18-55, 50, 35, 55-210, 16-50, 16-70), du coup la stabilisation capteur parait moins utile, mais quand on voit la qualité de la stab' Olympus en vidéo et les performances en vidéo du A6300, on ne peut que regretter qu'ils ne soit pas stabilisé de la sorte.
Message édité par alffir le 08-02-2016 à 16:19:08
n°5644794
leserigrap​he
Stop the music and go home
Posté le 08-02-2016 à 17:19:18  profilanswer
Voici mon retour sur le sony A6000. L'article étant sur mon blog Pro je mets le lien en " SPOILER" afin que ce ne soit pas considéré comme du spam.
n°5644875
leserigrap​he
Posté le 08-02-2016 à 20:11:20  profilanswer
Vous savez s'il y a moyen d'avoir l aide la mise au point ( a l aide du zoom), avec des objectif non sony ? Exemple avec mes objectif fd ?
n°5644878
fd400
Posté le 08-02-2016 à 20:15:23  profilanswer
Oui bien sûr;j'utilise régulièrement mon pseudo sur un nex7 ou 6000;focus peaking et loupe fonctionnent très bien ! Ca marche avec tous les nex,même mon vieux nex3 (le 1er nex).
Message édité par fd400 le 08-02-2016 à 20:18:54
n°5644882
GingerBrea​d Monster
Night worker !
Posté le 08-02-2016 à 20:21:10  profilanswer
+1,
Fuji sur ce coup ce sont des manches a c****e :D
Minimaliste quand même ton feed :D
Feed Back HFR
n°5644887
leserigrap​he
Posté le 08-02-2016 à 20:36:53  profilanswer
GingerBread Monster a écrit :
+1,
Premier retour pas eu le temps de plus tester.
n°5644889
leserigrap​he
Posté le 08-02-2016 à 20:37:49  profilanswer
Et comment on l active car ça marche avec les objo sony mais pas les autres chez moi.
n°5644895
Night worker !
Posté le 08-02-2016 à 20:43:12  profilanswer
Nan mais je te charie :D
Je n'ai pas d'objectif MF donc aucune idée, mais un des anciens va pas tarder a te rencarder ;)
Feed Back HFR
n°5644900
chaca
Posté le 08-02-2016 à 20:50:59  profilanswer
maliniooo a écrit :
Bon tout est à jour, ça marche pas, j'ai l'impression que c'est le non support d'Android 6.0 qui en est la raison... Vais bosser la chose :)
moi ça marche avec un S6 Version Androide : 5.1.1
Message édité par chaca le 08-02-2016 à 20:51:39
sonyA77V2grip,min500/F8miroir,100/2.8macro,T17-50 2.8,T70-200 2.8,CZ16-80,Sony16-50ssm,Sigma120-400OS,flashHVLF58AM,et hvlF20M,A6000,A6700,18-135oss,SEL16/2.8+VCL-ECU1,E16-50PZ,E18-200,sigma30/2.8+19/2.8+16-300,Magic28/2.8,CCTV 50F1.4,Fujian35/1.7+min50
n°5644904
maliniooo
Posté le 08-02-2016 à 21:00:30  profilanswer
ouais en android 5.xx ça marche.. mais pas en 6.0 apparemment, dans l'application y a une news qui indique en gros que depuis la maj du 7/02 playmemories est compatible avec android 6.x sur nexus uniquement, donc je pense que sur un autre phone ça marche pas encore, misère...
Pour les questions sur le focus peaking et loupe plus haut, bah je sais plus trop mais faut activer dans le menu le "déclenchement sans objectif" et l'accentuation ( avec trois niveau de réglage et couleur ), après pour la loupe c'est chacun qui décide sur quel bouton tu la configure :)
n°5644907
chaca
Posté le 08-02-2016 à 21:03:02  profilanswer
http://www.alphadxd.fr/viewtopic.php?f=7&t=93137
ça marche avec les tous les objos (même les vieux),l'A6000 doit être sur MF et il faut assigner la loupe à une touche (moi c'est la touche AEL)
Message édité par chaca le 08-02-2016 à 21:20:19
n°5644915
leserigrap​he
Posté le 08-02-2016 à 21:15:25  profilanswer
Je pensais que juste en changeant la mise au point l appareil allait simplement zoomer pour me montrer la zone. Mais non si j ai bien compris, il faut activer un bouton et utiliser constamment.
n°5644917
chaca
Posté le 08-02-2016 à 21:21:59  profilanswer
oui tu assignes cette fonction à une touche. Sauf pour les optiques sony
n°5644918
leserigrap​he
Posté le 08-02-2016 à 21:24:31  profilanswer
Je me limiterai au focus peaking qui fonctionne très bien.
n°5644922
Fantome Pe​rsecuteur
Pseudo ridicule
Posté le 08-02-2016 à 21:29:33  profilanswer
La loupe est très pratique pour les cas où le focus peaking ne marche pas bien ou n'est pas assez précis. C'est LA touche à binder quand tu utilises un objo manuel :)
Si elle ne marche pas quand tu tournes la bague de focus, c'est que les objo non-natifs ne fournissent aucune information sur la distance ou le focus, car pas de contacts électroniques. Les objo Sony natifs fournissent cette information, l'appareil le détecte et active la loupe automatiquement.
c cui ki di ki é
n°5644929
leserigrap​he
Posté le 08-02-2016 à 21:42:17  profilanswer
Tu as activé quel touche pour ça ? :)
n°5644970
fd400
Posté le 09-02-2016 à 00:41:14  profilanswer
touche AF/MF sur le nex 7;et ne pas oublier ds le menu:cocher "déclenchement sans objectif".
Sur mimille il y a une touche "loupe" et il faut paramétrer "MF" ds le menu focus.
Message édité par fd400 le 09-02-2016 à 00:48:38
n°5644976
chaca
Posté le 09-02-2016 à 01:42:33  profilanswer
si tu veux faire une map aux petits "o(i)gnons" la loupe est vraiment très efficace,bien plus que  le peaking .
n°5644977
fd400
Posté le 09-02-2016 à 01:52:50  profilanswer
oui,le peacking marche bien avec des focales courtes à moyennes; avec des télés loupe quasi obligatoire,sauf à longue distance.
n°5644988
Pseudo ridicule
Posté le 09-02-2016 à 07:39:50  profilanswer
J'ai mis ça sur C2 pour l'A7ii, et ? pour le A5k (par manque de bouton personnalisable plus accessible :D)
n°5644994
Benji Tshi
Posté le 09-02-2016 à 07:57:11  profilanswer
Et d'ailleurs, comment on vire cette fonction de zoom automatique avec les objos natifs ?
flick r - 5∞px - Ventes
n°5645138
chaca
Posté le 09-02-2016 à 12:05:05  profilanswer
t'as eu une maj pour une nouvelle version d'android ?
n°5645150
Night worker !
Posté le 09-02-2016 à 12:30:01  profilanswer
Tu parle du Clear-Image Zoom ?
Pas de MAJ officielle Marshmallow pour le GS4 (y'a que des rumeurs), il a installer par un custom firmware pour passer en v.6
Par contre ça va venir pour ton S6, la MAJ va pas tarder a être déployé ;)
http://www.frandroid.com/marques/s [...] -en-images
Message édité par GingerBread Monster le 09-02-2016 à 12:32:22
Feed Back HFR
n°5645164
Benji Tshi
Posté le 09-02-2016 à 12:48:50  profilanswer
J'ignore comment ca s'appele, mais le fait que ca affiche la loupe quand tu modifie la map. J'ai déja un bouton pour assigner la loupe (qui me sert avec mes objos non natifs), donc si j'en ai l'utilité avec les natifs, je préfère l'appeler moi meme plutot que ca s'affiche automatiquement (ce qui me gene dans plus de la moitié des cas)
n°5645171
Night worker !
Posté le 09-02-2016 à 13:15:31  profilanswer
Donc tu est en map manu ou DMF pour que ça t'ouvre la loupe :jap:
Cherche dans le menu l'option aide MF ou un truc dans le genre ;)
Feed Back HFR
n°5645173
Benji Tshi
Posté le 09-02-2016 à 13:20:18  profilanswer
Bah ouais mais les autres modes (AFS et AFC) c'est de la pure daube, dans les deux cas j'ai de l'AF continu, donc totalement ingérable si tu veux recadrer...et en plus du coup la retouche du point ne se fait pas
Message édité par Benji Tshi le 09-02-2016 à 13:21:47
n°5645176
cazeloof
Luc vous êtes là?
Posté le 09-02-2016 à 13:24:32  profilanswer
Tu dois pas passer en AFS ou AFC mais juste désactiver la loupe pour le MF dans les réglages (si c'est possible).
n°5645179
Benji Tshi
Posté le 09-02-2016 à 13:31:03  profilanswer
Ah vouiiii, c'est MF-assist ! Je pensais connement que c'était l'activation du peaking, mais il est vrai que ca s'active ailleurs ca...
Et donc sinon le coup de l'AFS qui se comporte comme l'AFC, une idée ?
n°5645181
cazeloof
Luc vous êtes là?
Posté le 09-02-2016 à 13:32:58  profilanswer
J'ai déjà eu ce problème mais uniquement avec mon SEL50 et je pensais que c'était ponctuel. Mais faudrait que je vérifie si c'est toujours comme ça.
n°5645184
Night worker !
Posté le 09-02-2016 à 13:45:46  profilanswer
On a tous eu ce cas de figure bien chiant en MAP manu ou DMF :o
Quand tu as binder une touche pour la loupe, que tu est en MF avec le peaking activé pour dégrossir, et dés que tu tourne la bague de MAP, paf la loupe :D
Les 2 sont dissociable ;)
Quel boitier, quel mode, quel réglage ?
PS: Je rentre, ça [:mchant man]
Message édité par GingerBread Monster le 09-02-2016 à 13:46:33
Feed Back HFR
n°5645217
Benji Tshi
Posté le 09-02-2016 à 14:27:12  profilanswer
Je savais ce qu'était le peaking, mais les menus Sony sont tellement moisis/mal rangés que du coup j'imaginais que c'était ca le peaking (que j'ai toujours activé sur tous mes boitiers). :D
Bon j'avoue, je suis sur A7 II et A7r II...mais j'ai pas eu de réponse sur le topic A7. :D J'ai pas insisté plus que ca non plus, mais comme j'ai trouvé une oreille réceptive ici hein :p
Donc bref, en AF-C, bon bah tout va bien, la map se fait en continu sur le collimateur sélectionné. Mais en AF-S, c'est la meme chose. Moi j'aimerais idéalement qu'en AF-S, la map se fasse à mi course du déclencheur, et qu'une fois faite, elle n'en bouge plus (single shot quoi :o)
n°5645223
Night worker !
Posté le 09-02-2016 à 14:46:46  profilanswer
T'a pas connu les menus Fischer price des 1er Nex ?
Au top !  :D
Vire le verrouillage AF et/ou la détection de visage ;)
C'est pour cette raison qu'il fait la MAP en continu même en AF-S
A mon tour pour des questions :
Ton 7r2,  il fait combien en crop APS-C, 16 mpix ?
Quand tu auras ton 6300,  y'a moyen de comparer l'evf et la vitesse de l'AF face a ton 7r2 ?
Message édité par GingerBread Monster le 09-02-2016 à 14:49:17
Feed Back HFR
n°5645234
maliniooo
Posté le 09-02-2016 à 14:55:13  profilanswer
[:luc@s]
n°5645240
Night worker !
Posté le 09-02-2016 à 14:59:55  profilanswer
Quoi ?  :o
Y'a pas de mal à se renseigner !  :whistle:
Mes livreurs sont la,  à ce soir :hello:
Feed Back HFR
n°5645248
Benji Tshi
Posté le 09-02-2016 à 15:11:10  profilanswer
Ok merci, je vais regarder :jap:
18 Mpx en APS-C. Et ouais, j'essayerais de te faire un feed sur la différence entre les 2. Mais ce sera pas avant la fin du mois le temps que le 6300 arrive :o
n°5645404
Night worker !
Posté le 09-02-2016 à 19:39:12  profilanswer
18 Mpx en APS-C.
Bien, bien :D
C'est sympa,merki ;)
Feed Back HFR
n°5645405
maliniooo
Posté le 09-02-2016 à 19:41:44  profilanswer
Peu de chance que l'a7 fasse aussi bien non ?
n°5645407
Night worker !
Posté le 09-02-2016 à 19:49:25  profilanswer
En quoi ?
Feed Back HFR
n°5645409
maliniooo
Posté le 09-02-2016 à 19:56:02  profilanswer
en vitesse af ?
l'evf change avec le 6300 ? j'ai pas fait gaffe
n°5645414
-Chris-
Posté le 09-02-2016 à 20:12:43  profilanswer
EVF Nex6/7 : 2,3 millions de pixels mais rafraîchissement juste
EVF A6000 : 1,44 millions de pixels mais meilleur rafraîchissement
EVF A6300 : retour à 2,3 millions de pixels et sans doute encore une amélioration du rafraîchissement.
Cela dit vu le prix ça va souvent râler dans les tests car la nouvelle dalle Sharp est dispo (4 millions de pixels, déjà utilisée chez Leica).
Mais enfin 2,3 ça suffit et ça ne doit pas être sans conséquence sur la batterie.
Message édité par -Chris- le 09-02-2016 à 20:13:35
n°5645418
maliniooo
Posté le 09-02-2016 à 20:16:59  profilanswer
bah ça doit être la dalle de l'a7 du coup dans l'a6300 non ? par rapport au nex6 le rafraîchissement est meilleur en effet
[Conseils] Achat d'un APN compact bonne qualitésony dscp 200s
[Topic unique] Les objos de pauvres : tamron, sigma, tokina et < f2,8Formater une compact flash
[Topic unique] Le nouveau pentax blue ray
Plus de sujets relatifs à : [Topic Unique] Sony NEX/Alpha - Hybrides APS-C
