3781 connectés
  Water & Xtreme Cooling
  Asetek WaterChill : le 1er kit de w/c efficace ! [maj 05/07]
 Page :   1  2  3  4  5  ..  29  30  31  32  33  34
Page Précédente
n°811534
mogg
Posté le 23-05-2003 à 16:57:01  profilanswer
MAJ 01/08/2003 :
le kit est dispo chez openjl a un prix défiant toute concurrence ! :sol:
vous avez le lien direct un peu plus bas .
ATTENTION :
Evitez a tout prix de commander le kit chez pcmac2000 ; ils proposent ce kit a la vente sans l'avoir en stock, par contre ils ne se gènent pas pour encaisser votre argent.  Deux forumeurs déja sont tombés dans le panneau !
http://www.watercooling.de/catalog/images/waterchill.jpg
Composition du kit :
Waterblock en demi-lune (perfs equivalentes au maze 3) :
http://www.ocprices.com/ben/waterchill/waterblock.jpg
pompe Hydor L20 (700l/h) avec reservoir :
http://www.ocprices.com/ben/waterchill/pump.jpg
Le radiateur (perfs equivalentes au Black Ice Pro) :
"The tubes are 100% copper with the lamellas made from aluminium"
http://www.ocprices.com/ben/waterchill/radiator.jpg
dossier sur nokytech :
http://www.nokytech.net/dossier.php?lire=91&page=1
avec un award à la clé
http://www.nokytech.net/images/dossiers/waterchill/award_150.gif
conclusion du test de http://www.ocprices.com/
The Asetek Waterchill is a sublime piece of equipment and in my opinion the best quality internal water-cooling kit I have seen. All of the components are absolutely top notch and its ease of use, coupled with fabulous performance, makes the kit difficult to beat. Its spill-proof reservoir makes transportation easy and while I wouldn?t trust UPS or ParcelForce to ship a system full of water, you certainly wont have any problems carting your chilled pc to your mates house for a spot of LAN gaming. The fitting of hosing to the waterblock and integrated pump / reservoir unit is ridiculously easy and even a total chimp should be up and running in less than an hour. There?s hardly a quality case out there that the waterchill won't fit in without mods and best of all the Waterchill comes VERY reasonably priced.
MAJ 01/08/2003 :
Grande nouvelle : le kit est dispo chez openJL  [:yaissev] et la bonne surprise vient aussi de son prix : 199 ?  [:xp1700]
http://www.openjl.fr/cata.asp?cata=69&scata=125
Pour ceux qui veulent la version complete (cpu, gpu, chipst) il reste l'allemagne :
http://www.pc-cooling.de/
259.00  (+ 15 ? de fdp) pour le kit complet cpu+vga+chipset
Message édité par mogg le 01-08-2003 à 18:25:13
Les signatures c'est MAL
n°811538
mogg
Posté le 23-05-2003 à 17:07:06  profilanswer
alors z'en pensez quoi ?
n°811540
eponyme-pr​emier
Posté le 23-05-2003 à 17:16:39  profilanswer
battre le koolance c' est vraiment un exploit  :lol:
n°811543
bitubo
GT Turbo Addict
Posté le 23-05-2003 à 17:21:43  profilanswer
ouais :/
ben je préfère mon montage qui m'est revenu juste au prix de la pompe et j'ai des bonnes perfs
n°811547
mogg
Posté le 23-05-2003 à 17:32:04  profilanswer
bitubo a écrit :
ouais :/
c'est un kit après tout...
je dis pas que c'est le truc de ouf de la tete qui explose tout...
mais pour des gens comme moi qui ont envie de se lancer ds le w/c sans se prendre la tete ca peut etre un bon plan...
n°811550
bitubo
GT Turbo Addict
Posté le 23-05-2003 à 17:36:20  profilanswer
c surtout au niveau du prix que ça fait mal  [:spamafote]
n°811594
mogg
Posté le 23-05-2003 à 19:05:55  profilanswer
je sais mais ca me fait peur de passer du air cooling au w/c home made directement...
n°813161
mogg
Posté le 25-05-2003 à 01:53:58  profilanswer
[:yoyoz]
n°813166
alanou
Remembering M.P.
Posté le 25-05-2003 à 02:02:59  profilanswer
mais des kit du genre jveux dire... y'en a aussi chez innovatek et les perfs ont rien a voir hein :/
n°813174
brouteux
Posté le 25-05-2003 à 02:18:31  profilanswer
mogg a écrit :
http://www.watercooling.de/catalog [...] rchill.jpg
commentaire de http://www.overclex.net/
Vous n'êtes pas sans connaitre le fameux VapoChill d'Asetek.
Mais voici que OCPrices vient de tester le kit watercooling d'Asetek, le WaterChill.
Les résultats sont, contrairement à la majorité des firmes qui se lancent dans le watercooling, plutôt bon.
Je dirais même excellent, vu que ce kit bat le Koolance Exos...
Le seul probleme (c'est a chaque fois le meme) : il est disponible partout sauf en france
tu peut le trouver la :
http://ns3308.ovh.net/~pcmac200/sh [...] ml&lang=fr
n°813175
alanou
Remembering M.P.
Posté le 25-05-2003 à 02:21:09  profilanswer
euh non pas là non.
n°813192
mogg
Posté le 25-05-2003 à 02:43:13  profilanswer
temperatures avec un P4 3.06@3700
http://www.ocprices.com/ben/waterchill/chart1.jpg
moi ca me semble pas mal, cela dit j'y connais rien en w/c..
n°813199
mogg
Posté le 25-05-2003 à 02:49:45  profilanswer
j'ai pas trouvé (p'tet que tu confonds avec le vapochill)
sinon pcmac 2000 j'en ai entendu que du mal, donc c'est pas tellement interessant
n°813229
brouteux
Posté le 25-05-2003 à 09:44:16  profilanswer
justement  c'est dans la rubrique vapochill  qui si trouve
n°813231
brouteux
Posté le 25-05-2003 à 09:50:06  profilanswer
n°813238
gilou
Modosaurus Rex
Posté le 25-05-2003 à 10:08:14  profilanswer
Vu les composants que Asetek propose (voir a Waterchill/components sur leur site), quelle serait la meilleure combinaison afin de refroidir le CPU, le Northbridge et la carte VGA?
Ils ne proposent en kit que une ensemble pour le CPU, et un pour les northbridge et VGA, mais pas un ensemble de refroidissement global.
Sinon, ca a l'air plutot bien leur kits.
A+,
n°813242
VW Seb
Who's the Boss !!
Posté le 25-05-2003 à 10:13:21  profilanswer
pk ya pas ke kit innovatek ds le test  :whistle:
vive le home made
n°813248
squal le r​equin
Posté le 25-05-2003 à 10:23:05  profilanswer
vive le home made
+1  :heink:
sinon il vaut combien ce kit ?
n°813251
brouteux
Posté le 25-05-2003 à 10:31:44  profilanswer
230?
n°813252
cpulloverc​lock
Posté le 25-05-2003 à 10:34:38  profilanswer
170€ au moins cher
n°813253
squal le r​equin
Posté le 25-05-2003 à 10:36:09  profilanswer
cpulloverclock a écrit :
170? au moins cher
ou ça ?
sinon toi qui est passé maître en ce domaine  :D  , tu penses qu'il est bien ce kit ?
n°813255
cpulloverc​lock
Posté le 25-05-2003 à 10:38:04  profilanswer
Squal le Requin a écrit :
ou ça ?
en Angleterre
mais bon vaut mieux choisir les pieces soit meme donc pas acheter ce kit
trop cher
n°813262
mogg
Posté le 25-05-2003 à 10:52:22  profilanswer
en Angleterre
trop cher
je ne pense pas qu'on soit dans la meme logique, moi squal et toi.
perso, le w/c j'y connais rien et j'aimerais bien voir comment ca fonctionne, avant de me mettre au home made...
donc commencer par un kit, sans se prendre la tete ...
pour comparer c'est un peu comme acheter son 1er micro a carrouf ou a la fnac...
donc la question "tu penses qu'il est bien ce kit ?" ca veut dire "que penses tu de ce kit dans l'absolu (prix mis a part)"...
n°813265
Magicpanda
Pushing the envelope
Posté le 25-05-2003 à 10:55:46  profilanswer
perso j'ai commencé le wc direct en home made
et ca ne pose absolument aucune difficulté puisque le montage est exactement le mme
c comme acheter son pc chez dell ou le monter avec des pieces de montga
apres c'est toi qui voit mais tu ne galerera pas moins avec un home made qu'avec un kit
en revanche la difference de prix fait tres mal
et la difference de perfs aussi
" Quel est le but du capital ? Le but du capital c'est produire pour le capital. L'objectif, lui, est illimité. L'objectif du capital c'est produire pour produire." - Deleuze || André Gorz - Vers la société libérée
n°813266
cpulloverc​lock
Posté le 25-05-2003 à 10:56:33  profilanswer
ben c pas dur a se renseigner pour se monter un wc
si tas quelqu1 pres de chez toi qui sy connait c encore mieux
mon 1er wc jai achet epar piece
depuis jai un waterchill + watercooling
enfin si ca te rebutes de commencer par un kit c sur que c + simple
mais je trouve quand meme le prix exagere
n°813267
Magicpanda
Posté le 25-05-2003 à 10:57:41  profilanswer
c'est certainement un des meilleurs kit de wc ( dans le genre innovateck je pense )
c'est a dire qu'il est incapable de contenir un proco a 150w  et donc que ca reste un kit  :sweat:
m'enfin tu fait comme tu sent
si vraiment le home made t'effrai ( mais encore une fois ya vraiment pas de quoi , faut s'entrainer a le monter hors du pc d'abord , tu apprendras assez vite comme tout le monde ;) )  :hello:
n°813268
Magicpanda
Posté le 25-05-2003 à 10:58:19  profilanswer
faut que je voit avec zytra si je peut retaper un compresseur de frigo pr faire un chiller moi  :whistle:
n°813271
squal le r​equin
Posté le 25-05-2003 à 11:01:17  profilanswer
si tu me fais un schéma avec tout les tuyaux et tu me trouve tous les composants pour le monter et que ça rentre dans la tour je te file 10? de plus que le prix que cela t'auras couté  :jap: (tu commande tout chez toi, et ensuite tu m'envois tout, tu me montres la facture et je te donne 10? de plus) :hello:
n°813278
mogg
Posté le 25-05-2003 à 11:06:26  profilanswer
une question à la con :
une pompe qui s'alimente sur l'alim du micro, combien de puissance ca demande  ?
c'est quoi l'alim qu'il faudrait idéalement ?
n°813280
Magicpanda
Posté le 25-05-2003 à 11:06:50  profilanswer
prise 220 v c la pompe
n°813281
Magicpanda
Posté le 25-05-2003 à 11:07:27  profilanswer
cpull il   a le meme montage que tout le monde [:rofl]
il a mit du temps a accepter le watercool  :D
Message édité par Magicpanda le 25-05-2003 à 11:11:57
n°813282
gilou
Modosaurus Rex
Posté le 25-05-2003 à 11:07:54  profilanswer
Juste pour le CPU, ou CPU+NB+VGA?
A+,
Message édité par gilou le 25-05-2003 à 11:08:18
n°813284
mogg
Posté le 25-05-2003 à 11:08:11  profilanswer
n°813286
cpulloverc​lock
Posté le 25-05-2003 à 11:11:21  profilanswer
si tu me fais un schéma avec tout les tuyaux et tu me trouve tous les composants pour le monter et que ça rentre dans la tour je te file 10€ de plus que le prix que cela t'auras couté  :jap: (tu commande tout chez toi, et ensuite tu m'envois tout, tu me montres la facture et je te donne 10€ de plus) :hello:
tu prends une photo dun circuit wc c plus rapide
c pas dur de faire rentrer un systeme dns la tour
n°813287
cpulloverc​lock
Posté le 25-05-2003 à 11:11:55  profilanswer
A+,
cpu
ca me dit rien de refroidir la cg comme ca et le chip
n°813289
Magicpanda
Posté le 25-05-2003 à 11:12:58  profilanswer
ouais mais faut une grande tour ou un bix  :jap:
n°813303
mogg
Posté le 25-05-2003 à 11:35:09  profilanswer
tiens un autre graphique :
(il se sont amusés a changer certaines des pieces pour voir l'evolution des temp.)
http://www.ocprices.com/ben/waterchill/chart2.jpg
moi il me plait bien ce kit...
Message édité par mogg le 25-05-2003 à 11:36:17
n°813309
tracker
Posté le 25-05-2003 à 11:48:18  profilanswer
le prob du wc pieces c'est qu'il y a toujours 1 ou 2 éléments qui ont des embouts de diametre different. Et bien souvent il faut bidouiller, adapter, ce qui n'est pas toujours évident surtout pour trouver les embouts adéquats...
le kit, tu déballes, tu le montes ( pâs besoin de manuel ) et ça fonctionne
mais dans tous les cas la 1ere solution est bien mieux : choix des éléments de meilleurs qualités
Profil D3
n°813403
mogg
Posté le 25-05-2003 à 13:43:12  profilanswer
maj en 1er post avec plus de détails concernant la composition du kit.
n°813450
fire in th​e hole !!!
ex-CM marlboro
Posté le 25-05-2003 à 14:33:16  profilanswer
meme moi qu'on a surnomer "l'ultime manchot" j'y suis arriver sans trop de probleme
suffit d'aller sur nokytech de bien lire et de tester toute ces pieces et apres sa roule :love:
Page Précédente
Différence Watercooling Waterchill ?a koi ressemble le nouvo WB Pgeo Edelweiss, est t'il efficace ?
WC 100% efficace inside!!!!watercooling efficace(vpc), ca avance, MAJ 1er post
Refroidissement efficace et silencieux pour P4[Ventilo]Quel est le plus efficace??
[refroidissage] l'underclocking est-il efficace ?Efficace ou pas le refroidisement pour disque durs ?
Kit Peletier, efficace ou pas ??Petit Rad sur le dos de ma SUMA est-ce éfficace?
Plus de sujets relatifs à : Asetek WaterChill : le 1er kit de w/c efficace ! [maj 05/07]
