Radeon24 | Bon ben voilà mon log (jvous averti il est long :
Code :
- X Window System Version 6.8.2 (Ubuntu 6.8.2-77 20051010174523 root@vernadsky.buildd)
- Release Date: 9 February 2005
- X Protocol Version 11, Revision 0, Release 6.8.2
- Build Operating System: Linux 2.6.10 i686 [ELF]
- Current Operating System: Linux Ordi1 2.6.12-9-386 #1 Mon Oct 10 13:14:36 BST 2005 i686
- Build Date: 10 October 2005
- Before reporting problems, check http://wiki.X.Org
- to make sure that you have the latest version.
- Module Loader present
- OS Kernel: Linux version 2.6.12-9-386 (buildd@rothera) (gcc version 3.4.5 20050809 (prerelease) (Ubuntu 3.4.4-6ubuntu8)) #1 Mon Oct 10 13:14:36 BST 2005
- Markers: (--) probed, (**) from config file, (==) default setting,
- (++) from command line, (!!) notice, (II) informational,
- (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
- (==) Log file: "/var/log/Xorg.0.log", Time: Tue Jun 13 17:14:15 2006
- (==) Using config file: "/etc/X11/xorg.conf"
- (==) ServerLayout "Default Layout"
- (**) |-->Screen "Default Screen" (0)
- (**) | |-->Monitor "NEC CI VR17"
- (**) | |-->Device "ATI Technologies, Inc. Radeon X800 XL (R430 UM)"
- (**) |-->Input Device "Generic Keyboard"
- (**) |-->Input Device "Configured Mouse"
- (WW) The directory "/usr/share/X11/fonts/cyrillic" does not exist.
- Entry deleted from font path.
- (WW) The directory "/usr/share/X11/fonts/CID" does not exist.
- (WW) `fonts.dir' not found (or not valid) in "/var/lib/defoma/x-ttcidfont-conf.d/dirs/CID".
- (Run 'mkfontdir' on "/var/lib/defoma/x-ttcidfont-conf.d/dirs/CID" ).
- (**) FontPath set to "/usr/share/X11/fonts/misc,/usr/share/X11/fonts/100dpi/:unscaled,/usr/share/X11/fonts/75dpi/:unscaled,/usr/share/X11/fonts/Type1,/usr/share/X11/fonts/100dpi,/usr/share/X11/fonts/75dpi,/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
- (==) RgbPath set to "/usr/X11R6/lib/X11/rgb"
- (==) ModulePath set to "/usr/X11R6/lib/modules"
- (WW) Open APM failed (/dev/apm_bios) (No such file or directory)
- (II) Module ABI versions:
- X.Org ANSI C Emulation: 0.2
- X.Org Video Driver: 0.7
- X.Org XInput driver : 0.4
- X.Org Server Extension : 0.2
- X.Org Font Renderer : 0.4
- (II) Loader running on linux
- (II) LoadModule: "bitmap"
- (II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
- (II) Module bitmap: vendor="X.Org Foundation"
- compiled for 6.8.2, module version = 1.0.0
- Module class: X.Org Font Renderer
- ABI class: X.Org Font Renderer, version 0.4
- (II) Loading font Bitmap
- (II) LoadModule: "pcidata"
- (II) Loading /usr/X11R6/lib/modules/libpcidata.a
- (II) Module pcidata: vendor="X.Org Foundation"
- ABI class: X.Org Video Driver, version 0.7
- (++) using VT number 7
- (II) PCI: PCI scan (all values are in hex)
- (II) PCI: 00:00:0: chip 10de,005e card 0000,0000 rev a3 class 05,80,00 hdr 00
- (II) PCI: 00:01:0: chip 10de,0050 card 10de,cb84 rev a3 class 06,01,00 hdr 80
- (II) PCI: 00:01:1: chip 10de,0052 card 10de,cb84 rev a2 class 0c,05,00 hdr 80
- (II) PCI: 00:02:0: chip 10de,005a card 10de,cb84 rev a2 class 0c,03,10 hdr 80
- (II) PCI: 00:02:1: chip 10de,005b card 10de,cb84 rev a3 class 0c,03,20 hdr 80
- (II) PCI: 00:04:0: chip 10de,0059 card 10de,cb84 rev a2 class 04,01,00 hdr 00
- (II) PCI: 00:06:0: chip 10de,0053 card 10de,cb84 rev a2 class 01,01,8a hdr 00
- (II) PCI: 00:07:0: chip 10de,0054 card 10de,cb84 rev a3 class 01,01,85 hdr 00
- (II) PCI: 00:08:0: chip 10de,0055 card 10de,cb84 rev a3 class 01,01,85 hdr 00
- (II) PCI: 00:09:0: chip 10de,005c card 0000,0000 rev a2 class 06,04,01 hdr 01
- (II) PCI: 00:0a:0: chip 10de,0057 card 10de,cb84 rev a3 class 06,80,00 hdr 00
- (II) PCI: 00:0b:0: chip 10de,005d card 0000,0000 rev a3 class 06,04,00 hdr 01
- (II) PCI: 00:0c:0: chip 10de,005d card 0000,0000 rev a3 class 06,04,00 hdr 01
- (II) PCI: 00:0d:0: chip 10de,005d card 0000,0000 rev a3 class 06,04,00 hdr 01
- (II) PCI: 00:0e:0: chip 10de,005d card 0000,0000 rev a3 class 06,04,00 hdr 01
- (II) PCI: 00:18:0: chip 1022,1100 card 0000,0000 rev 00 class 06,00,00 hdr 80
- (II) PCI: 00:18:1: chip 1022,1101 card 0000,0000 rev 00 class 06,00,00 hdr 80
- (II) PCI: 00:18:2: chip 1022,1102 card 0000,0000 rev 00 class 06,00,00 hdr 80
- (II) PCI: 00:18:3: chip 1022,1103 card 0000,0000 rev 00 class 06,00,00 hdr 80
- (II) PCI: 01:09:0: chip 1106,3044 card 15bd,1006 rev 80 class 0c,00,10 hdr 00
- (II) PCI: 01:0a:0: chip 11ab,4320 card 15bd,100a rev 13 class 02,00,00 hdr 00
- (II) PCI: 05:00:0: chip 1002,554d card 174b,1600 rev 00 class 03,00,00 hdr 80
- (II) PCI: 05:00:1: chip 1002,556d card 174b,1601 rev 00 class 03,80,00 hdr 00
- (II) PCI: End of PCI scan
- (II) PCI-to-ISA bridge:
- (II) Bus -1: bridge is at (0:1:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
- (II) Subtractive PCI-to-PCI bridge:
- (II) Bus 1: bridge is at (0:9:0), (0,1,1), BCTRL: 0x0204 (VGA_EN is cleared)
- (II) Bus 1 I/O range:
- [0] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX[B]
- [1] -1 0 0x0000a400 - 0x0000a4ff (0x100) IX[B]
- [2] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX[B]
- [3] -1 0 0x0000ac00 - 0x0000acff (0x100) IX[B]
- (II) Bus 1 non-prefetchable memory range:
- [0] -1 0 0xfde00000 - 0xfdefffff (0x100000) MX[B]
- (II) Bus 1 prefetchable memory range:
- [0] -1 0 0xfdf00000 - 0xfdffffff (0x100000) MX[B]
- (II) PCI-to-PCI bridge:
- (II) Bus 2: bridge is at (0:11:0), (0,2,2), BCTRL: 0x0004 (VGA_EN is cleared)
- (II) Bus 2 I/O range:
- [0] -1 0 0x00009000 - 0x000090ff (0x100) IX[B]
- [1] -1 0 0x00009400 - 0x000094ff (0x100) IX[B]
- [2] -1 0 0x00009800 - 0x000098ff (0x100) IX[B]
- [3] -1 0 0x00009c00 - 0x00009cff (0x100) IX[B]
- (II) Bus 2 non-prefetchable memory range:
- [0] -1 0 0xfdd00000 - 0xfddfffff (0x100000) MX[B]
- (II) Bus 2 prefetchable memory range:
- [0] -1 0 0xfdc00000 - 0xfdcfffff (0x100000) MX[B]
- (II) Bus 3: bridge is at (0:12:0), (0,3,3), BCTRL: 0x0004 (VGA_EN is cleared)
- (II) Bus 3 I/O range:
- [0] -1 0 0x00008000 - 0x000080ff (0x100) IX[B]
- [1] -1 0 0x00008400 - 0x000084ff (0x100) IX[B]
- [2] -1 0 0x00008800 - 0x000088ff (0x100) IX[B]
- [3] -1 0 0x00008c00 - 0x00008cff (0x100) IX[B]
- (II) Bus 3 non-prefetchable memory range:
- [0] -1 0 0xfdb00000 - 0xfdbfffff (0x100000) MX[B]
- (II) Bus 3 prefetchable memory range:
- [0] -1 0 0xfda00000 - 0xfdafffff (0x100000) MX[B]
- (II) Bus 4: bridge is at (0:13:0), (0,4,4), BCTRL: 0x0004 (VGA_EN is cleared)
- (II) Bus 4 I/O range:
- [0] -1 0 0x00007000 - 0x000070ff (0x100) IX[B]
- [1] -1 0 0x00007400 - 0x000074ff (0x100) IX[B]
- [2] -1 0 0x00007800 - 0x000078ff (0x100) IX[B]
- [3] -1 0 0x00007c00 - 0x00007cff (0x100) IX[B]
- (II) Bus 4 non-prefetchable memory range:
- [0] -1 0 0xfd900000 - 0xfd9fffff (0x100000) MX[B]
- (II) Bus 4 prefetchable memory range:
- [0] -1 0 0xfd800000 - 0xfd8fffff (0x100000) MX[B]
- (II) Bus 5: bridge is at (0:14:0), (0,5,5), BCTRL: 0x000c (VGA_EN is set)
- (II) Bus 5 I/O range:
- [0] -1 0 0x00006000 - 0x000060ff (0x100) IX[B]
- [1] -1 0 0x00006400 - 0x000064ff (0x100) IX[B]
- [2] -1 0 0x00006800 - 0x000068ff (0x100) IX[B]
- [3] -1 0 0x00006c00 - 0x00006cff (0x100) IX[B]
- (II) Bus 5 non-prefetchable memory range:
- [0] -1 0 0xfd700000 - 0xfd7fffff (0x100000) MX[B]
- (II) Bus 5 prefetchable memory range:
- [0] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B]
- (II) Host-to-PCI bridge:
- (II) Bus 0: bridge is at (0:24:0), (0,0,5), BCTRL: 0x0008 (VGA_EN is set)
- (II) Bus 0 I/O range:
- [0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
- (II) Bus 0 non-prefetchable memory range:
- [0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
- (II) Bus 0 prefetchable memory range:
- (II) Bus -1: bridge is at (0:24:1), (-1,-1,5), BCTRL: 0x0008 (VGA_EN is set)
- (II) Bus -1 I/O range:
- (II) Bus -1 non-prefetchable memory range:
- (II) Bus -1 prefetchable memory range:
- (II) Bus -1: bridge is at (0:24:2), (-1,-1,5), BCTRL: 0x0008 (VGA_EN is set)
- (II) Bus -1: bridge is at (0:24:3), (-1,-1,5), BCTRL: 0x0008 (VGA_EN is set)
- (--) PCI:*(5:0:0) ATI Technologies Inc unknown chipset (0x554d) rev 0, Mem @ 0xd0000000/28, 0xfd7f0000/16, I/O @ 0x6c00/8
- (--) PCI: (5:0:1) ATI Technologies Inc unknown chipset (0x556d) rev 0, Mem @ 0xfd7e0000/16
- (II) Addressable bus resource ranges are
- [1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
- (II) OS-reported resource ranges:
- [0] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
- [1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
- [2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
- [3] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
- [4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
- [5] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
- [6] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
- (II) Active PCI resource ranges:
- [0] -1 0 0xfdef8000 - 0xfdefbfff (0x4000) MX[B]
- [1] -1 0 0xfdeff000 - 0xfdeff7ff (0x800) MX[B]
- [2] -1 0 0xfe02a000 - 0xfe02afff (0x1000) MX[B]
- [3] -1 0 0xfe02b000 - 0xfe02bfff (0x1000) MX[B]
- [4] -1 0 0xfe02c000 - 0xfe02cfff (0x1000) MX[B]
- [5] -1 0 0xfe02d000 - 0xfe02dfff (0x1000) MX[B]
- [6] -1 0 0xfeb00000 - 0xfeb000ff (0x100) MX[B]
- [7] -1 0 0xfe02f000 - 0xfe02ffff (0x1000) MX[B]
- [8] -1 0 0xfd7f0000 - 0xfd7fffff (0x10000) MX[B](B)
- [9] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B](B)
- [10] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX[B]
- [11] -1 0 0x0000ac00 - 0x0000ac7f (0x80) IX[B]
- [12] -1 0 0x0000bc00 - 0x0000bc07 (0x8) IX[B]
- [13] -1 0 0x0000c000 - 0x0000c00f (0x10) IX[B]
- [14] -1 0 0x00000b60 - 0x00000b63 (0x4) IX[B]
- [15] -1 0 0x00000960 - 0x00000967 (0x8) IX[B]
- [16] -1 0 0x00000be0 - 0x00000be3 (0x4) IX[B]
- [17] -1 0 0x000009e0 - 0x000009e7 (0x8) IX[B]
- [18] -1 0 0x0000d400 - 0x0000d40f (0x10) IX[B]
- [19] -1 0 0x00000b70 - 0x00000b73 (0x4) IX[B]
- [20] -1 0 0x00000970 - 0x00000977 (0x8) IX[B]
- [21] -1 0 0x00000bf0 - 0x00000bf3 (0x4) IX[B]
- [22] -1 0 0x000009f0 - 0x000009f7 (0x8) IX[B]
- [23] -1 0 0x0000e800 - 0x0000e80f (0x10) IX[B]
- [24] -1 0 0x0000ec00 - 0x0000ecff (0x100) IX[B]
- [25] -1 0 0x0000f000 - 0x0000f0ff (0x100) IX[B]
- [26] -1 0 0x00001c40 - 0x00001c7f (0x40) IX[B]
- [27] -1 0 0x00001c00 - 0x00001c3f (0x40) IX[B]
- [28] -1 0 0x0000fc00 - 0x0000fc1f (0x20) IX[B]
- [29] -1 0 0x00006c00 - 0x00006cff (0x100) IX[B](B)
- (II) Inactive PCI resource ranges:
- [0] -1 0 0xfd7e0000 - 0xfd7effff (0x10000) MX[B](B)
- (II) Active PCI resource ranges after removing overlaps:
- (II) Inactive PCI resource ranges after removing overlaps:
- (II) OS-reported resource ranges after removing overlaps with PCI:
- (II) All system resource ranges:
- [5] -1 0 0xfdef8000 - 0xfdefbfff (0x4000) MX[B]
- [6] -1 0 0xfdeff000 - 0xfdeff7ff (0x800) MX[B]
- [7] -1 0 0xfe02a000 - 0xfe02afff (0x1000) MX[B]
- [8] -1 0 0xfe02b000 - 0xfe02bfff (0x1000) MX[B]
- [9] -1 0 0xfe02c000 - 0xfe02cfff (0x1000) MX[B]
- [10] -1 0 0xfe02d000 - 0xfe02dfff (0x1000) MX[B]
- [11] -1 0 0xfeb00000 - 0xfeb000ff (0x100) MX[B]
- [12] -1 0 0xfe02f000 - 0xfe02ffff (0x1000) MX[B]
- [13] -1 0 0xfd7f0000 - 0xfd7fffff (0x10000) MX[B](B)
- [14] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B](B)
- [15] -1 0 0xfd7e0000 - 0xfd7effff (0x10000) MX[B](B)
- [16] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
- [17] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
- [18] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX[B]
- [19] -1 0 0x0000ac00 - 0x0000ac7f (0x80) IX[B]
- [20] -1 0 0x0000bc00 - 0x0000bc07 (0x8) IX[B]
- [21] -1 0 0x0000c000 - 0x0000c00f (0x10) IX[B]
- [22] -1 0 0x00000b60 - 0x00000b63 (0x4) IX[B]
- [23] -1 0 0x00000960 - 0x00000967 (0x8) IX[B]
- [24] -1 0 0x00000be0 - 0x00000be3 (0x4) IX[B]
- [25] -1 0 0x000009e0 - 0x000009e7 (0x8) IX[B]
- [26] -1 0 0x0000d400 - 0x0000d40f (0x10) IX[B]
- [27] -1 0 0x00000b70 - 0x00000b73 (0x4) IX[B]
- [28] -1 0 0x00000970 - 0x00000977 (0x8) IX[B]
- [29] -1 0 0x00000bf0 - 0x00000bf3 (0x4) IX[B]
- [30] -1 0 0x000009f0 - 0x000009f7 (0x8) IX[B]
- [31] -1 0 0x0000e800 - 0x0000e80f (0x10) IX[B]
- [32] -1 0 0x0000ec00 - 0x0000ecff (0x100) IX[B]
- [33] -1 0 0x0000f000 - 0x0000f0ff (0x100) IX[B]
- [34] -1 0 0x00001c40 - 0x00001c7f (0x40) IX[B]
- [35] -1 0 0x00001c00 - 0x00001c3f (0x40) IX[B]
- [36] -1 0 0x0000fc00 - 0x0000fc1f (0x20) IX[B]
- [37] -1 0 0x00006c00 - 0x00006cff (0x100) IX[B](B)
- (WW) Ignoring request to load module GLcore
- (II) LoadModule: "i2c"
- (II) Loading /usr/X11R6/lib/modules/libi2c.a
- (II) Module i2c: vendor="X.Org Foundation"
- compiled for 6.8.2, module version = 1.2.0
- (II) Reloading /usr/X11R6/lib/modules/fonts/libbitmap.a
- (II) LoadModule: "ddc"
- (II) Loading /usr/X11R6/lib/modules/libddc.a
- (II) Module ddc: vendor="X.Org Foundation"
- (II) LoadModule: "dri"
- (II) Loading /usr/X11R6/lib/modules/extensions/libdri.a
- (II) Module dri: vendor="X.Org Foundation"
- ABI class: X.Org Server Extension, version 0.2
- (II) Loading sub module "drm"
- (II) LoadModule: "drm"
- (II) Loading /usr/X11R6/lib/modules/linux/libdrm.a
- (II) Module drm: vendor="X.Org Foundation"
- (II) Loading extension XFree86-DRI
- (II) LoadModule: "extmod"
- (II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a
- (II) Module extmod: vendor="X.Org Foundation"
- Module class: X.Org Server Extension
- (II) Loading extension SHAPE
- (II) Loading extension MIT-SUNDRY-NONSTANDARD
- (II) Loading extension BIG-REQUESTS
- (II) Loading extension SYNC
- (II) Loading extension MIT-SCREEN-SAVER
- (II) Loading extension XC-MISC
- (II) Loading extension XFree86-VidModeExtension
- (II) Loading extension XFree86-Misc
- (II) Loading extension XFree86-DGA
- (II) Loading extension DPMS
- (II) Loading extension TOG-CUP
- (II) Loading extension Extended-Visual-Information
- (II) Loading extension XVideo
- (II) Loading extension XVideo-MotionCompensation
- (II) Loading extension X-Resource
- (II) LoadModule: "freetype"
- (II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.a
- (II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
- compiled for 6.8.2, module version = 2.1.0
- (II) Loading font FreeType
- (II) LoadModule: "glx"
- (II) Loading /usr/X11R6/lib/modules/extensions/libglx.a
- (II) Module glx: vendor="X.Org Foundation"
- (II) Loading sub module "GLcore"
- (II) LoadModule: "GLcore"
- (II) Loading /usr/X11R6/lib/modules/extensions/libGLcore.a
- Skipping "/usr/X11R6/lib/modules/extensions/libGLcore.a:m_debug_clip.o": No symbols found
- Skipping "/usr/X11R6/lib/modules/extensions/libGLcore.a:m_debug_norm.o": No symbols found
- Skipping "/usr/X11R6/lib/modules/extensions/libGLcore.a:m_debug_xform.o": No symbols found
- (II) Module GLcore: vendor="X.Org Foundation"
- (II) Loading extension GLX
- (II) LoadModule: "int10"
- (II) Loading /usr/X11R6/lib/modules/linux/libint10.a
- (II) Module int10: vendor="X.Org Foundation"
- (II) LoadModule: "type1"
- (II) Loading /usr/X11R6/lib/modules/fonts/libtype1.a
- (II) Module type1: vendor="X.Org Foundation"
- compiled for 6.8.2, module version = 1.0.2
- (II) Loading font Type1
- (II) Loading font CID
- (II) LoadModule: "vbe"
- (II) Loading /usr/X11R6/lib/modules/libvbe.a
- (II) Module vbe: vendor="X.Org Foundation"
- compiled for 6.8.2, module version = 1.1.0
- (II) LoadModule: "ati"
- (II) Loading /usr/X11R6/lib/modules/drivers/ati_drv.o
- (II) Module ati: vendor="X.Org Foundation"
- compiled for 6.8.2, module version = 6.5.6
- Module class: X.Org Video Driver
- (II) LoadModule: "kbd"
- (II) Loading /usr/X11R6/lib/modules/input/kbd_drv.o
- (II) Module kbd: vendor="X.Org Foundation"
- Module class: X.Org XInput Driver
- ABI class: X.Org XInput driver, version 0.4
- (II) LoadModule: "mouse"
- (II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o
- (II) Module mouse: vendor="X.Org Foundation"
- (II) ATI: ATI driver (version 6.5.6) for chipsets: ati, ativga
- (II) R128: Driver for ATI Rage 128 chipsets:
- ATI Rage 128 Mobility M3 LE (PCI), ATI Rage 128 Mobility M3 LF (AGP),
- ATI Rage 128 Mobility M4 MF (AGP), ATI Rage 128 Mobility M4 ML (AGP),
- ATI Rage 128 Pro GL PA (PCI/AGP), ATI Rage 128 Pro GL PB (PCI/AGP),
- ATI Rage 128 Pro GL PC (PCI/AGP), ATI Rage 128 Pro GL PD (PCI),
- ATI Rage 128 Pro GL PE (PCI/AGP), ATI Rage 128 Pro GL PF (AGP),
- ATI Rage 128 Pro VR PG (PCI/AGP), ATI Rage 128 Pro VR PH (PCI/AGP),
- ATI Rage 128 Pro VR PI (PCI/AGP), ATI Rage 128 Pro VR PJ (PCI/AGP),
- ATI Rage 128 Pro VR PK (PCI/AGP), ATI Rage 128 Pro VR PL (PCI/AGP),
- ATI Rage 128 Pro VR PM (PCI/AGP), ATI Rage 128 Pro VR PN (PCI/AGP),
- ATI Rage 128 Pro VR PO (PCI/AGP), ATI Rage 128 Pro VR PP (PCI),
- ATI Rage 128 Pro VR PQ (PCI/AGP), ATI Rage 128 Pro VR PR (PCI),
- ATI Rage 128 Pro VR PS (PCI/AGP), ATI Rage 128 Pro VR PT (PCI/AGP),
- ATI Rage 128 Pro VR PU (PCI/AGP), ATI Rage 128 Pro VR PV (PCI/AGP),
- ATI Rage 128 Pro VR PW (PCI/AGP), ATI Rage 128 Pro VR PX (PCI/AGP),
- ATI Rage 128 GL RE (PCI), ATI Rage 128 GL RF (AGP),
- ATI Rage 128 RG (AGP), ATI Rage 128 VR RK (PCI),
- ATI Rage 128 VR RL (AGP), ATI Rage 128 4X SE (PCI/AGP),
- ATI Rage 128 4X SF (PCI/AGP), ATI Rage 128 4X SG (PCI/AGP),
- ATI Rage 128 4X SH (PCI/AGP), ATI Rage 128 4X SK (PCI/AGP),
- ATI Rage 128 4X SL (PCI/AGP), ATI Rage 128 4X SM (AGP),
- ATI Rage 128 4X SN (PCI/AGP), ATI Rage 128 Pro ULTRA TF (AGP),
- ATI Rage 128 Pro ULTRA TL (AGP), ATI Rage 128 Pro ULTRA TR (AGP),
- ATI Rage 128 Pro ULTRA TS (AGP?), ATI Rage 128 Pro ULTRA TT (AGP?),
- ATI Rage 128 Pro ULTRA TU (AGP?)
- (II) RADEON: Driver for ATI Radeon chipsets: ATI Radeon QD (AGP),
- ATI Radeon QE (AGP), ATI Radeon QF (AGP), ATI Radeon QG (AGP),
- ATI Radeon VE/7000 QY (AGP/PCI), ATI Radeon VE/7000 QZ (AGP/PCI),
- ATI Radeon Mobility M7 LW (AGP),
- ATI Mobility FireGL 7800 M7 LX (AGP),
- ATI Radeon Mobility M6 LY (AGP), ATI Radeon Mobility M6 LZ (AGP),
- ATI Radeon IGP320 (A3) 4136, ATI Radeon IGP320M (U1) 4336,
- ATI Radeon IGP330/340/350 (A4) 4137,
- ATI Radeon IGP330M/340M/350M (U2) 4337,
- ATI Radeon 7000 IGP (A4+) 4237, ATI Radeon Mobility 7000 IGP 4437,
- ATI FireGL 8700/8800 QH (AGP), ATI Radeon 8500 QL (AGP),
- ATI Radeon 9100 QM (AGP), ATI Radeon 8500 AIW BB (AGP),
- ATI Radeon 8500 AIW BC (AGP), ATI Radeon 7500 QW (AGP/PCI),
- ATI Radeon 7500 QX (AGP/PCI), ATI Radeon 9000/PRO If (AGP/PCI),
- ATI Radeon 9000 Ig (AGP/PCI), ATI FireGL Mobility 9000 (M9) Ld (AGP),
- ATI Radeon Mobility 9000 (M9) Lf (AGP),
- ATI Radeon Mobility 9000 (M9) Lg (AGP),
- ATI Radeon 9100 IGP (A5) 5834,
- ATI Radeon Mobility 9100 IGP (U3) 5835, ATI Radeon 9100 PRO IGP 7834,
- ATI Radeon Mobility 9200 IGP 7835, ATI Radeon 9200PRO 5960 (AGP),
- ATI Radeon 9200 5961 (AGP), ATI Radeon 9200 5962 (AGP),
- ATI Radeon 9200SE 5964 (AGP), ATI FireMV 2200 (PCI),
- ATI Radeon Mobility 9200 (M9+) 5C61 (AGP),
- ATI Radeon Mobility 9200 (M9+) 5C63 (AGP), ATI Radeon 9500 AD (AGP),
- ATI Radeon 9500 AE (AGP), ATI Radeon 9600TX AF (AGP),
- ATI FireGL Z1 AG (AGP), ATI Radeon 9700 Pro ND (AGP),
- ATI Radeon 9700/9500Pro NE (AGP), ATI Radeon 9700 NF (AGP),
- ATI FireGL X1 NG (AGP), ATI Radeon 9600 AP (AGP),
- ATI Radeon 9600SE AQ (AGP), ATI Radeon 9600XT AR (AGP),
- ATI Radeon 9600 AS (AGP), ATI FireGL T2 AT (AGP),
- ATI FireGL RV360 AV (AGP),
- ATI Radeon Mobility 9600/9700 (M10/M11) NP (AGP),
- ATI Radeon Mobility 9600 (M10) NQ (AGP),
- ATI Radeon Mobility 9600 (M11) NR (AGP),
- ATI Radeon Mobility 9600 (M10) NS (AGP),
- ATI FireGL Mobility T2 (M10) NT (AGP),
- ATI FireGL Mobility T2e (M11) NV (AGP), ATI RADEON 9650,
- ATI Radeon 9800SE AH (AGP), ATI Radeon 9800 AI (AGP),
- ATI Radeon 9800 AJ (AGP), ATI FireGL X2 AK (AGP),
- ATI Radeon 9800PRO NH (AGP), ATI Radeon 9800 NI (AGP),
- ATI FireGL X2 NK (AGP), ATI Radeon 9800XT NJ (AGP),
- ATI Radeon X600 (RV380) 3E50 (PCIE),
- ATI FireGL V3200 (RV380) 3E54 (PCIE),
- ATI Radeon Mobility X600 (M24) 3150 (PCIE),
- ATI FireGL M24 GL 3154 (PCIE), ATI Radeon X300 (RV370) 5B60 (PCIE),
- ATI Radeon X600 (RV370) 5B62 (PCIE),
- ATI FireGL V3100 (RV370) 5B64 (PCIE),
- ATI FireGL D1100 (RV370) 5B65 (PCIE),
- ATI Radeon Mobility M300 (M22) 5460 (PCIE),
- ATI FireGL M22 GL 5464 (PCIE), ATI RADEON XPRESS 200 Series,
- ATI RADEON XPRESS 200M Series, ATI RADEON XPRESS 200 Series,
- ATI RADEON XPRESS 200M Series, ATI FireGL V5000,
- ATI MOBILITY FireGL V5000, ATI MOBILITY FireGL V5000,
- ATI MOBILITY RADEON X700, ATI MOBILITY RADEON X700,
- ATI RADEON X700 PRO, ATI RADEON X700 XT, ATI RADEON X700,
- ATI RADEON X700 SE, ATI RADEON X700 SE,
- ATI Radeon X800 (R420) JH (AGP), ATI Radeon X800PRO (R420) JI (AGP),
- ATI Radeon X800SE (R420) JJ (AGP), ATI Radeon X800 (R420) JK (AGP),
- ATI Radeon X800 (R420) JL (AGP), ATI FireGL X3 (R420) JM (AGP),
- ATI Radeon Mobility 9800 (M18) JN (AGP),
- ATI Radeon X800XT (R420) JP (AGP), ATI RADEON X800 SE,
- ATI Radeon X800 (R423) UH (PCIE),
- ATI Radeon X800PRO (R423) UI (PCIE),
- ATI Radeon X800LE (R423) UJ (PCIE),
- ATI Radeon X800SE (R423) UK (PCIE),
- ATI FireGL V7200 (R423) UQ (PCIE), ATI FireGL V5100 (R423) UR (PCIE),
- ATI FireGL V7100 (R423) UT (PCIE),
- ATI Radeon X800XT (R423) 5D57 (PCIE), ATI FireGL V7100,
- ATI MOBILITY FireGL V5100, ATI MOBILITY RADEON X800,
- ATI MOBILITY RADEON X800 XT, ATI RADEON X800, ATI RADEON X800 XL,
- ATI RADEON R430 SE, ATI RADEON R430 XTP, ATI RADEON R480 4P,
- ATI RADEON R480 GL 16P, ATI RADEON R480 SE, ATI RADEON X850 PRO,
- ATI RADEON X850 XT, ATI RADEON X850 XT Platinum Edition,
- ATI RADEON X850 PRO, ATI RADEON X850 SE, ATI RADEON X850 XT,
- ATI RADEON X850 XT Platinum Edition
- (II) Primary Device is: PCI 05:00:0
- (II) ATI: Candidate "Device" section "ATI Technologies, Inc. Radeon X800 XL (R430 UM)".
- (WW) ATI: PCI Mach64 in slot 5:0:0 could not be detected!
- (WW) ATI: PCI Mach64 in slot 5:0:1 could not be detected!
- (EE) No devices detected.
- Fatal server error:
- no screens found
- Please consult the The X.Org Foundation support
- at http://wiki.X.Org
- for help.
- Please also check the log file at "/var/log/Xorg.0.log" for additional information.
