5346 connectés
La 15.0 est là (en vrai !)
Les invités peuvent voter
 Page :   1  2  3  4  5  ..  98  99  100  ..  109  110  111  112  113  114
[SLACKWARE] du présent - 15.0
n°1459472
cycojesus
Mèo Lười
Posté le 14-01-2021 à 09:52:36  profilanswer
 :hello: Flash
Wed Jan 13 19:51:45 UTC 2021
ap/diffstat-1.64-x86_64-1.txz:  Upgraded.
d/cmake-3.19.3-x86_64-1.txz:  Upgraded.
l/gcr-3.38.1-x86_64-1.txz:  Upgraded.
l/mlt-6.24.0-x86_64-2.txz:  Rebuilt.
  Patched for opencv >= 4.5.1. Thanks to nobodino.
l/pulseaudio-14.1-x86_64-1.txz:  Upgraded.
n/netkit-bootparamd-0.17-x86_64-4.txz:  Rebuilt.
  Patched for libtirpc. Thanks to nobodino.
n/netkit-rusers-0.17-x86_64-3.txz:  Rebuilt.
n/netkit-rwall-0.17-x86_64-3.txz:  Rebuilt.
xfce/Greybird-3.22.14-noarch-1.txz:  Upgraded.
extra/source/flashplayer-plugin/:  Removed.
Chết rồi ! ✍ ⌥⌘ http://codeberg.org/gwh
n°1459509
cycojesus
Mèo Lười
Posté le 15-01-2021 à 08:54:56  profilanswer
Thu Jan 14 20:36:17 UTC 2021
a/gptfdisk-1.0.6-x86_64-1.txz:  Upgraded.
a/usb_modeswitch-2.6.1-x86_64-1.txz:  Upgraded.
ap/nano-5.5-x86_64-1.txz:  Upgraded.
l/Mako-1.1.4-x86_64-1.txz:  Upgraded.
l/gst-plugins-base-1.18.3-x86_64-1.txz:  Upgraded.
l/gst-plugins-good-1.18.3-x86_64-1.txz:  Upgraded.
l/gst-plugins-libav-1.18.3-x86_64-1.txz:  Upgraded.
l/gstreamer-1.18.3-x86_64-1.txz:  Upgraded.
l/system-config-printer-1.5.15-x86_64-1.txz:  Upgraded.
l/wavpack-5.4.0-x86_64-1.txz:  Upgraded.
  WavPack 5.4.0 fixes an issue where a specially crafted WAV file could cause
  the wavpack command-line program to crash with an out-of-bounds write.
  For more information, see:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-35738
  (* Security fix *)
l/xapian-core-1.4.18-x86_64-1.txz:  Upgraded.
tcl/tk-8.6.11.1-x86_64-1.txz:  Upgraded.
x/mesa-20.3.3-x86_64-1.txz:  Upgraded.
  Added options: -Dvulkan-device-select-layer=true -Dopengl=true -Dglx=dri
  Add a symlink for libGLX_system.so.0.
  Use a more complete patch for converting from drmPciDeviceInfo to uint32_t
  in device_select.h and device_select_layer.c.
xfce/thunar-4.16.2-x86_64-1.txz:  Upgraded.
n°1459575
cycojesus
Mèo Lười
Posté le 16-01-2021 à 14:04:29  profilanswer
Fri Jan 15 19:37:22 UTC 2021
a/elogind-246.9.2-x86_64-1.txz:  Upgraded.
a/minicom-2.8-x86_64-1.txz:  Upgraded.
kde/kdiagram-2.8.0-x86_64-1.txz:  Upgraded.
n/getmail-6.14-x86_64-1.txz:  Upgraded.
n/nftables-0.9.7-x86_64-2.txz:  Rebuilt.
  Rebuilt using --with-python-bin=python3. Thanks to walecha.
xfce/xfwm4-4.16.1-x86_64-1.txz:  Upgraded.
n°1459626
cycojesus
Mèo Lười
Posté le 18-01-2021 à 10:05:22  profilanswer
Sun Jan 17 23:48:59 UTC 2021
a/kernel-generic-5.10.8-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.10.8-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.10.8-x86_64-1.txz:  Upgraded.
a/mkinitrd-1.4.11-x86_64-17.txz:  Rebuilt.
  Upgraded to busybox-1.32.1.
ap/sc-im-20200904_bdd936a-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.10.8-x86-1.txz:  Upgraded.
d/python-setuptools-51.3.1-x86_64-1.txz:  Upgraded.
k/kernel-source-5.10.8-noarch-1.txz:  Upgraded.
l/libical-3.0.9-x86_64-1.txz:  Upgraded.
l/pulseaudio-14.2-x86_64-1.txz:  Upgraded.
n/ModemManager-1.14.10-x86_64-1.txz:  Upgraded.
n/iptables-1.8.7-x86_64-1.txz:  Upgraded.
n/libnftnl-1.1.9-x86_64-1.txz:  Upgraded.
xfce/garcon-4.16.1-x86_64-1.txz:  Upgraded.
xfce/xfce4-whiskermenu-plugin-2.5.2-x86_64-1.txz:  Upgraded.
isolinux/initrd.img:  Rebuilt.
kernels/*:  Upgraded.
usb-and-pxe-installers/usbboot.img:  Rebuilt.
n°1459644
cycojesus
Mèo Lười
Posté le 19-01-2021 à 09:25:43  profilanswer
Beta approaches. :-)
Mon Jan 18 13:50:16 UTC 2021
Hey folks, a little status update here. First, huge thanks are due to
nobodino for helping to shake out packages that weren't building from source.
With all those fixes in place (plus a few more), we have tested and found that
everything in the tree compiles cleanly against glibc-2.32. So, the plan is to
have another mass rebuild soon against that. Although the ABI didn't
technically change, I've heard that libpthread may not be 100% compatible in
some corner cases, so we'll err on the side of caution. Hopefully we can get a
little testing done on the recompiled system and then go through it all again
at the beginning of next month when glibc-2.33 is released. Other than that,
how's Mesa working these days? If there are still issues that are resolved by
dropping back to the previous branch, let's try to figure those out. I'd rather
not revert Mesa unless there's no other choice. I'm hoping that the (probably
unrelated) issues with Intel video hardware will be helped by today's
xorg-server patch that uses the modesetting driver with newer chipsets. Please
report any improvement on the LQ thread.
a/sysklogd-2.2.0-x86_64-1.txz:  Upgraded.
d/distcc-3.3.5-x86_64-2.txz:  Rebuilt.
  Properly install distccmon-gnome.desktop. Thanks to marco70.
d/python-setuptools-51.3.3-x86_64-1.txz:  Upgraded.
l/imagemagick-7.0.10_58-x86_64-1.txz:  Upgraded.
l/libodfgen-0.1.8-x86_64-1.txz:  Upgraded.
l/libsigsegv-2.13-x86_64-1.txz:  Upgraded.
n/inetd-1.79s-x86_64-12.txz:  Rebuilt.
  Rebuilt to link with libtirpc. Thanks to nobodino.
n/nftables-0.9.8-x86_64-1.txz:  Upgraded.
n/postfix-3.5.9-x86_64-1.txz:  Upgraded.
n/tcp_wrappers-7.6-x86_64-4.txz:  Rebuilt.
  Use strerror(), not sys_errlist(). Thanks to nobodino.
x/xorg-server-1.20.10-x86_64-3.txz:  Rebuilt.
  Only use the Intel DDX with pre-gen4 hardware. Newer hardware will use the
  modesetting driver.
x/xorg-server-xephyr-1.20.10-x86_64-3.txz:  Rebuilt.
x/xorg-server-xnest-1.20.10-x86_64-3.txz:  Rebuilt.
x/xorg-server-xvfb-1.20.10-x86_64-3.txz:  Rebuilt.
x/xorg-server-xwayland-1.20.10-x86_64-3.txz:  Rebuilt.
xfce/xfce4-appfinder-4.16.1-x86_64-1.txz:  Upgraded.
Message édité par cycojesus le 19-01-2021 à 17:49:08
n°1459690
cycojesus
Mèo Lười
Posté le 20-01-2021 à 11:07:27  profilanswer
Wed Jan 20 03:08:10 UTC 2021
a/btrfs-progs-5.10-x86_64-1.txz:  Upgraded.
a/dialog-1.3_20210117-x86_64-1.txz:  Upgraded.
a/glibc-solibs-2.32-x86_64-1.txz:  Upgraded.
a/kernel-firmware-20210119_0578970-noarch-1.txz:  Upgraded.
a/kernel-generic-5.10.9-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.10.9-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.10.9-x86_64-1.txz:  Upgraded.
d/gcc-10.2.0-x86_64-3.txz:  Rebuilt.
d/gcc-brig-10.2.0-x86_64-3.txz:  Rebuilt.
d/gcc-g++-10.2.0-x86_64-3.txz:  Rebuilt.
d/gcc-gdc-10.2.0-x86_64-3.txz:  Rebuilt.
d/gcc-gfortran-10.2.0-x86_64-3.txz:  Rebuilt.
d/gcc-gnat-10.2.0-x86_64-3.txz:  Rebuilt.
d/gcc-go-10.2.0-x86_64-3.txz:  Rebuilt.
d/gcc-objc-10.2.0-x86_64-3.txz:  Rebuilt.
d/help2man-1.47.17-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.10.9-x86-1.txz:  Upgraded.
d/rust-1.49.0-x86_64-1.txz:  Upgraded.
k/kernel-source-5.10.9-noarch-1.txz:  Upgraded.
kde/krita-4.4.2-x86_64-1.txz:  Upgraded.
l/glibc-2.32-x86_64-1.txz:  Upgraded.
l/glibc-i18n-2.32-x86_64-1.txz:  Upgraded.
l/glibc-profile-2.32-x86_64-1.txz:  Upgraded.
n/dnsmasq-2.83-x86_64-1.txz:  Upgraded.
n/openldap-2.4.57-x86_64-1.txz:  Upgraded.
xap/mozilla-firefox-78.6.1esr-x86_64-2.txz:  Rebuilt.
xap/mozilla-thunderbird-78.6.1-x86_64-2.txz:  Rebuilt.
xap/seamonkey-2.53.5.1-x86_64-2.txz:  Rebuilt.
xap/xaos-4.2.1-x86_64-1.txz:  Upgraded.
n°1459823
cycojesus
Mèo Lười
Posté le 23-01-2021 à 08:04:59  profilanswer
refait ALL THE THINGS!!! :o [1/2] (le post qui casse HFR en deux...)
Fri Jan 22 19:17:44 UTC 2021
Mass rebuild against the new glibc complete. This batch consists only of
rebuilds - no new packages or upgrades. Enjoy the fresh binaries!
a/aaa_base-14.2-x86_64-6.txz:  Rebuilt.
a/aaa_elflibs-15.0-x86_64-30.txz:  Rebuilt.
  Upgraded: libnsl-2.32.so, libsigsegv.so.2.0.6, liblber-2.4.so.2.11.5,
  libldap-2.4.so.2.11.5.
a/aaa_terminfo-6.2_20201219-x86_64-3.txz:  Rebuilt.
a/acl-2.2.53-x86_64-2.txz:  Rebuilt.
a/acpid-2.0.32-x86_64-2.txz:  Rebuilt.
a/attr-2.4.48-x86_64-2.txz:  Rebuilt.
a/bash-5.1.004-x86_64-2.txz:  Rebuilt.
a/bin-11.1-x86_64-4.txz:  Rebuilt.
a/bzip2-1.0.8-x86_64-2.txz:  Rebuilt.
a/coreutils-8.32-x86_64-2.txz:  Rebuilt.
a/cpio-2.13-x86_64-2.txz:  Rebuilt.
a/cpufrequtils-008-x86_64-3.txz:  Rebuilt.
a/cracklib-2.9.7-x86_64-2.txz:  Rebuilt.
a/cryptsetup-2.3.4-x86_64-2.txz:  Rebuilt.
a/dbus-1.12.20-x86_64-4.txz:  Rebuilt.
a/dcron-4.5-x86_64-10.txz:  Rebuilt.
a/dosfstools-4.1-x86_64-3.txz:  Rebuilt.
a/e2fsprogs-1.45.6-x86_64-3.txz:  Rebuilt.
a/ed-1.17-x86_64-2.txz:  Rebuilt.
a/efibootmgr-20191011_e8ce9fe-x86_64-3.txz:  Rebuilt.
a/efivar-20191015_ca85d51-x86_64-2.txz:  Rebuilt.
a/elilo-3.16-x86_64-11.txz:  Rebuilt.
a/elogind-246.9.2-x86_64-2.txz:  Rebuilt.
a/elvis-2.2_0-x86_64-6.txz:  Rebuilt.
a/etc-15.0-x86_64-12.txz:  Rebuilt.
a/eudev-3.2.9-x86_64-4.txz:  Rebuilt.
a/exfatprogs-1.0.4-x86_64-2.txz:  Rebuilt.
a/f2fs-tools-1.14.0-x86_64-2.txz:  Rebuilt.
a/file-5.39-x86_64-2.txz:  Rebuilt.
a/findutils-4.8.0-x86_64-2.txz:  Rebuilt.
a/floppy-5.5-x86_64-3.txz:  Rebuilt.
a/gawk-5.1.0-x86_64-2.txz:  Rebuilt.
a/genpower-1.0.5-x86_64-4.txz:  Rebuilt.
a/gettext-0.21-x86_64-2.txz:  Rebuilt.
a/glibc-zoneinfo-2020f-noarch-2.txz:  Rebuilt.
a/gpm-1.20.7-x86_64-8.txz:  Rebuilt.
a/gptfdisk-1.0.6-x86_64-2.txz:  Rebuilt.
a/grep-3.6-x86_64-2.txz:  Rebuilt.
a/grub-2.04-x86_64-2.txz:  Rebuilt.
a/gzip-1.10-x86_64-2.txz:  Rebuilt.
a/haveged-1.9.14-x86_64-2.txz:  Rebuilt.
a/hdparm-9.60-x86_64-2.txz:  Rebuilt.
a/hostname-3.23-x86_64-2.txz:  Rebuilt.
a/hwdata-0.343-noarch-2.txz:  Rebuilt.
a/infozip-6.0-x86_64-6.txz:  Rebuilt.
a/inih-r52-x86_64-2.txz:  Rebuilt.
a/inotify-tools-3.20.11.0-x86_64-2.txz:  Rebuilt.
a/jfsutils-1.1.15-x86_64-3.txz:  Rebuilt.
a/kbd-1.15.3-x86_64-5.txz:  Rebuilt.
a/kmod-28-x86_64-2.txz:  Rebuilt.
a/lbzip2-2.5-x86_64-3.txz:  Rebuilt.
a/less-563-x86_64-2.txz:  Rebuilt.
a/lhasa-0.3.1-x86_64-2.txz:  Rebuilt.
a/libblockdev-2.25-x86_64-2.txz:  Rebuilt.
a/libbytesize-2.4-x86_64-2.txz:  Rebuilt.
a/libcgroup-0.41-x86_64-8.txz:  Rebuilt.
a/libgudev-234-x86_64-2.txz:  Rebuilt.
a/libpwquality-1.4.4-x86_64-3.txz:  Rebuilt.
a/lilo-24.2-x86_64-11.txz:  Rebuilt.
a/logrotate-3.18.0-x86_64-2.txz:  Rebuilt.
a/lrzip-0.631-x86_64-3.txz:  Rebuilt.
a/lvm2-2.03.11-x86_64-2.txz:  Rebuilt.
a/lzip-1.22-x86_64-2.txz:  Rebuilt.
a/lzlib-1.12-x86_64-2.txz:  Rebuilt.
a/mcelog-175-x86_64-2.txz:  Rebuilt.
a/mdadm-4.1-x86_64-2.txz:  Rebuilt.
a/minicom-2.8-x86_64-2.txz:  Rebuilt.
a/mkinitrd-1.4.11-x86_64-18.txz:  Rebuilt.
a/mlocate-0.26-x86_64-3.txz:  Rebuilt.
a/mt-st-1.4-x86_64-2.txz:  Rebuilt.
a/mtx-1.3.12-x86_64-3.txz:  Rebuilt.
a/ncompress-4.2.4.6-x86_64-2.txz:  Rebuilt.
a/ndctl-71.1-x86_64-3.txz:  Rebuilt.
a/ntfs-3g-2017.3.23-x86_64-3.txz:  Rebuilt.
a/nvi-1.81.6-x86_64-2.txz:  Rebuilt.
a/openssl-solibs-1.1.1i-x86_64-2.txz:  Rebuilt.
a/openssl10-solibs-1.0.2u-x86_64-2.txz:  Rebuilt.
a/os-prober-1.77-x86_64-4.txz:  Rebuilt.
a/pam-1.5.1-x86_64-2.txz:  Rebuilt.
a/patch-2.7.6-x86_64-4.txz:  Rebuilt.
a/pciutils-3.7.0-x86_64-2.txz:  Rebuilt.
a/pcmciautils-018-x86_64-3.txz:  Rebuilt.
a/pkgtools-15.0-noarch-35.txz:  Rebuilt.
a/plzip-1.9-x86_64-2.txz:  Rebuilt.
a/procps-ng-3.3.16-x86_64-4.txz:  Rebuilt.
a/quota-4.06-x86_64-2.txz:  Rebuilt.
a/reiserfsprogs-3.6.27-x86_64-3.txz:  Rebuilt.
a/rpm2tgz-1.2.2-x86_64-3.txz:  Rebuilt.
a/sdparm-1.11-x86_64-2.txz:  Rebuilt.
a/sed-4.8-x86_64-2.txz:  Rebuilt.
a/shadow-4.8.1-x86_64-11.txz:  Rebuilt.
a/sharutils-4.15.2-x86_64-3.txz:  Rebuilt.
a/smartmontools-7.2-x86_64-2.txz:  Rebuilt.
a/splitvt-1.6.6-x86_64-4.txz:  Rebuilt.
a/sysfsutils-2.1.0-x86_64-3.txz:  Rebuilt.
a/sysklogd-2.2.0-x86_64-2.txz:  Rebuilt.
a/syslinux-4.07-x86_64-3.txz:  Rebuilt.
a/sysvinit-2.98-x86_64-2.txz:  Rebuilt.
a/sysvinit-functions-8.53-x86_64-4.txz:  Rebuilt.
a/sysvinit-scripts-2.1-noarch-38.txz:  Rebuilt.
a/tar-1.33-x86_64-2.txz:  Rebuilt.
a/tcsh-6.22.03-x86_64-2.txz:  Rebuilt.
a/time-1.9-x86_64-3.txz:  Rebuilt.
a/tree-1.8.0-x86_64-2.txz:  Rebuilt.
a/udisks-1.0.5-x86_64-7.txz:  Rebuilt.
a/udisks2-2.9.1-x86_64-3.txz:  Rebuilt.
a/unarj-265-x86_64-3.txz:  Rebuilt.
a/upower-0.99.11-x86_64-3.txz:  Rebuilt.
a/usb_modeswitch-2.6.1-x86_64-2.txz:  Rebuilt.
a/usbutils-013-x86_64-2.txz:  Rebuilt.
a/utempter-1.2.0-x86_64-2.txz:  Rebuilt.
a/util-linux-2.36.1-x86_64-2.txz:  Rebuilt.
a/volume_key-0.3.12-x86_64-2.txz:  Rebuilt.
a/which-2.21-x86_64-3.txz:  Rebuilt.
a/xfsprogs-5.10.0-x86_64-2.txz:  Rebuilt.
a/xz-5.2.5-x86_64-2.txz:  Rebuilt.
a/zerofree-1.1.1-x86_64-2.txz:  Rebuilt.
a/zoo-2.10_22-x86_64-3.txz:  Rebuilt.
ap/a2ps-4.14-x86_64-8.txz:  Rebuilt.
ap/acct-6.6.4-x86_64-3.txz:  Rebuilt.
ap/alsa-utils-1.2.4-x86_64-2.txz:  Rebuilt.
ap/amp-0.7.6-x86_64-4.txz:  Rebuilt.
ap/at-3.2.1-x86_64-3.txz:  Rebuilt.
ap/bc-1.07.1-x86_64-4.txz:  Rebuilt.
ap/bpe-2.01.00-x86_64-5.txz:  Rebuilt.
ap/cdparanoia-III_10.2-x86_64-4.txz:  Rebuilt.
ap/cdrdao-1.2.4-x86_64-2.txz:  Rebuilt.
ap/cdrtools-3.01-x86_64-5.txz:  Rebuilt.
ap/cups-2.3.3-x86_64-4.txz:  Rebuilt.
ap/cups-filters-1.28.7-x86_64-2.txz:  Rebuilt.
ap/dash-0.5.11.2-x86_64-2.txz:  Rebuilt.
ap/dc3dd-7.2.646-x86_64-3.txz:  Rebuilt.
ap/ddrescue-1.25-x86_64-2.txz:  Rebuilt.
ap/diffstat-1.64-x86_64-2.txz:  Rebuilt.
ap/diffutils-3.7-x86_64-2.txz:  Rebuilt.
ap/dmapi-2.2.12-x86_64-4.txz:  Rebuilt.
ap/dmidecode-3.3-x86_64-2.txz:  Rebuilt.
ap/dvd+rw-tools-7.1-x86_64-4.txz:  Rebuilt.
ap/enscript-1.6.6-x86_64-3.txz:  Rebuilt.
ap/flac-1.3.3-x86_64-2.txz:  Rebuilt.
ap/ghostscript-9.53.3-x86_64-2.txz:  Rebuilt.
ap/ghostscript-fonts-std-8.11-noarch-4.txz:  Rebuilt.
ap/gphoto2-2.5.26-x86_64-2.txz:  Rebuilt.
ap/groff-1.22.4-x86_64-3.txz:  Rebuilt.
ap/gutenprint-5.3.4-x86_64-2.txz:  Rebuilt.
ap/hplip-3.20.6-x86_64-5.txz:  Rebuilt.
ap/htop-3.0.5-x86_64-2.txz:  Rebuilt.
ap/inxi-20201217_df45e6d4-noarch-2.txz:  Rebuilt.
ap/ispell-3.4.02-x86_64-2.txz:  Rebuilt.
ap/itstool-2.0.6-x86_64-2.txz:  Rebuilt.
ap/jed-0.99_19-x86_64-4.txz:  Rebuilt.
ap/joe-4.6-x86_64-3.txz:  Rebuilt.
ap/jove-4.16.0.74-x86_64-2.txz:  Rebuilt.
ap/ksh93-20200131_e4fea8c5-x86_64-2.txz:  Rebuilt.
ap/libx86-1.1-x86_64-4.txz:  Rebuilt.
ap/linuxdoc-tools-0.9.73-x86_64-8.txz:  Rebuilt.
ap/lm_sensors-3.6.0-x86_64-2.txz:  Rebuilt.
ap/lsof-4.94.0-x86_64-2.txz:  Rebuilt.
ap/lsscsi-0.31-x86_64-2.txz:  Rebuilt.
ap/lxc-2.0.11_fad08f383-x86_64-6.txz:  Rebuilt.
ap/madplay-0.15.2b-x86_64-6.txz:  Rebuilt.
ap/man-db-2.9.3-x86_64-2.txz:  Rebuilt.
ap/man-pages-5.10-noarch-2.txz:  Rebuilt.
ap/mariadb-10.5.8-x86_64-2.txz:  Rebuilt.
ap/mc-4.8.25-x86_64-2.txz:  Rebuilt.
ap/moc-2.5.2-x86_64-7.txz:  Rebuilt.
ap/most-5.1.0-x86_64-2.txz:  Rebuilt.
ap/mpg123-1.26.4-x86_64-2.txz:  Rebuilt.
ap/nano-5.5-x86_64-2.txz:  Rebuilt.
ap/neofetch-20201126_6dd85d6-noarch-2.txz:  Rebuilt.
ap/normalize-0.7.7-x86_64-4.txz:  Rebuilt.
ap/nvme-cli-1.13-x86_64-2.txz:  Rebuilt.
ap/opus-tools-0.2-x86_64-2.txz:  Rebuilt.
ap/pamixer-1.4-x86_64-8.txz:  Rebuilt.
ap/powertop-2.13-x86_64-2.txz:  Rebuilt.
ap/qpdf-10.1.0-x86_64-2.txz:  Rebuilt.
ap/radeontool-1.6.3-x86_64-3.txz:  Rebuilt.
ap/rpm-4.16.1.2-x86_64-2.txz:  Rebuilt.
ap/rzip-2.1-x86_64-3.txz:  Rebuilt.
ap/sc-7.16-x86_64-9.txz:  Rebuilt.
ap/sc-im-20200904_bdd936a-x86_64-2.txz:  Rebuilt.
ap/screen-4.8.0-x86_64-3.txz:  Rebuilt.
ap/seejpeg-1.10-x86_64-3.txz:  Rebuilt.
ap/slackpkg-2.83.0-noarch-5.txz:  Rebuilt.
ap/soma-3.3.6-noarch-2.txz:  Rebuilt.
ap/sox-14.4.2-x86_64-7.txz:  Rebuilt.
ap/sqlite-3.34.0-x86_64-2.txz:  Rebuilt.
ap/squashfs-tools-4.4-x86_64-3.txz:  Rebuilt.
ap/sudo-1.9.5p1-x86_64-2.txz:  Rebuilt.
ap/sysstat-12.5.2-x86_64-2.txz:  Rebuilt.
ap/terminus-font-4.49.1-noarch-2.txz:  Rebuilt.
ap/texinfo-6.7-x86_64-3.txz:  Rebuilt.
ap/tmux-3.1c-x86_64-2.txz:  Rebuilt.
ap/undervolt-20201024_13fa33d-x86_64-2.txz:  Rebuilt.
ap/usbmuxd-20200615_3daa1e9-x86_64-2.txz:  Rebuilt.
ap/vbetool-1.2.2-x86_64-3.txz:  Rebuilt.
ap/vim-8.2.2323-x86_64-2.txz:  Rebuilt.
ap/vorbis-tools-1.4.0-x86_64-6.txz:  Rebuilt.
ap/xfsdump-3.1.9-x86_64-2.txz:  Rebuilt.
ap/xorriso-1.5.2-x86_64-2.txz:  Rebuilt.
ap/zsh-5.8-x86_64-2.txz:  Rebuilt.
d/Cython-0.29.21-x86_64-3.txz:  Rebuilt.
d/autoconf-2.69-noarch-3.txz:  Rebuilt.
d/autoconf-archive-2019.01.06-noarch-2.txz:  Rebuilt.
d/automake-1.16.2-noarch-2.txz:  Rebuilt.
d/binutils-2.35.1-x86_64-2.txz:  Rebuilt.
d/bison-3.7.4-x86_64-2.txz:  Rebuilt.
d/ccache-4.1-x86_64-2.txz:  Rebuilt.
d/check-0.15.2-x86_64-2.txz:  Rebuilt.
d/clisp-2.50_20191103_c26de7873-x86_64-3.txz:  Rebuilt.
d/cmake-3.19.3-x86_64-2.txz:  Rebuilt.
d/cscope-15.9-x86_64-2.txz:  Rebuilt.
d/cvs-1.11.23-x86_64-6.txz:  Rebuilt.
d/dev86-0.16.21-x86_64-3.txz:  Rebuilt.
d/distcc-3.3.5-x86_64-3.txz:  Rebuilt.
d/doxygen-1.8.20-x86_64-2.txz:  Rebuilt.
d/flex-2.6.4-x86_64-4.txz:  Rebuilt.
d/gdb-10.1-x86_64-2.txz:  Rebuilt.
d/gettext-tools-0.21-x86_64-2.txz:  Rebuilt.
d/git-2.30.0-x86_64-2.txz:  Rebuilt.
d/gnucobol-3.1.2-x86_64-2.txz:  Rebuilt.
d/gperf-3.1-x86_64-3.txz:  Rebuilt.
d/guile-3.0.5-x86_64-2.txz:  Rebuilt.
d/gyp-20200512_caa60026-x86_64-3.txz:  Rebuilt.
d/icecream-1.3.1-x86_64-2.txz:  Rebuilt.
d/indent-2.2.12-x86_64-2.txz:  Rebuilt.
d/intltool-0.51.0-x86_64-5.txz:  Rebuilt.
d/libtool-2.4.6-x86_64-15.txz:  Rebuilt.
d/llvm-11.0.1-x86_64-2.txz:  Rebuilt.
d/m4-1.4.18-x86_64-3.txz:  Rebuilt.
d/make-4.2.1-x86_64-8.txz:  Rebuilt.
d/mercurial-5.6.1-x86_64-2.txz:  Rebuilt.
d/meson-0.56.2-x86_64-2.txz:  Rebuilt.
d/nasm-2.15.05-x86_64-2.txz:  Rebuilt.
d/ninja-1.10.2-x86_64-2.txz:  Rebuilt.
d/opencl-headers-2.2-noarch-3.txz:  Rebuilt.
d/oprofile-1.4.0-x86_64-3.txz:  Rebuilt.
d/p2c-2.01-x86_64-2.txz:  Rebuilt.
d/parallel-20201222-noarch-2.txz:  Rebuilt.
d/patchelf-0.12-x86_64-2.txz:  Rebuilt.
d/perl-5.32.0-x86_64-4.txz:  Rebuilt.
d/pkg-config-0.29.2-x86_64-3.txz:  Rebuilt.
d/pmake-1.111-x86_64-6.txz:  Rebuilt.
d/python-pip-20.3.3-x86_64-2.txz:  Rebuilt.
d/python-setuptools-51.3.3-x86_64-2.txz:  Rebuilt.
d/python2-2.7.18-x86_64-3.txz:  Rebuilt.
d/python3-3.9.1-x86_64-2.txz:  Rebuilt.
d/rcs-5.10.0-x86_64-2.txz:  Rebuilt.
d/re2c-2.0.3-x86_64-2.txz:  Rebuilt.
d/rinutils-0.8.0-x86_64-2.txz:  Rebuilt.
d/ruby-3.0.0-x86_64-2.txz:  Rebuilt.
d/sassc-3.6.1-x86_64-2.txz:  Rebuilt.
d/scons-4.0.1-x86_64-3.txz:  Rebuilt.
d/slacktrack-2.20-x86_64-2.txz:  Rebuilt.
d/strace-5.10-x86_64-2.txz:  Rebuilt.
d/subversion-1.14.0-x86_64-5.txz:  Rebuilt.
d/swig-4.0.2-x86_64-2.txz:  Rebuilt.
d/vala-0.50.3-x86_64-2.txz:  Rebuilt.
d/yasm-1.3.0-x86_64-3.txz:  Rebuilt.
e/emacs-27.1-x86_64-3.txz:  Rebuilt.
e/emacspeak-53.0-x86_64-2.txz:  Rebuilt.
kde/akonadi-20.12.1-x86_64-2.txz:  Rebuilt.
kde/akonadi-calendar-20.12.1-x86_64-2.txz:  Rebuilt.
kde/akonadi-calendar-tools-20.12.1-x86_64-2.txz:  Rebuilt.
kde/akonadi-contacts-20.12.1-x86_64-2.txz:  Rebuilt.
kde/akonadi-import-wizard-20.12.1-x86_64-2.txz:  Rebuilt.
kde/akonadi-mime-20.12.1-x86_64-2.txz:  Rebuilt.
kde/akonadi-notes-20.12.1-x86_64-2.txz:  Rebuilt.
kde/akonadi-search-20.12.1-x86_64-2.txz:  Rebuilt.
kde/akonadiconsole-20.12.1-x86_64-2.txz:  Rebuilt.
kde/akregator-20.12.1-x86_64-2.txz:  Rebuilt.
kde/alkimia-8.0.4-x86_64-2.txz:  Rebuilt.
kde/analitza-20.12.1-x86_64-2.txz:  Rebuilt.
kde/ark-20.12.1-x86_64-2.txz:  Rebuilt.
kde/artikulate-20.12.1-x86_64-2.txz:  Rebuilt.
kde/attica-5.78.0-x86_64-2.txz:  Rebuilt.
kde/audiocd-kio-20.12.1-x86_64-2.txz:  Rebuilt.
kde/baloo-5.78.0-x86_64-2.txz:  Rebuilt.
kde/baloo-widgets-20.12.1-x86_64-2.txz:  Rebuilt.
kde/blinken-20.12.1-x86_64-2.txz:  Rebuilt.
kde/bluedevil-5.20.5-x86_64-2.txz:  Rebuilt.
kde/bluez-qt-5.78.0-x86_64-2.txz:  Rebuilt.
kde/bomber-20.12.1-x86_64-2.txz:  Rebuilt.
kde/bovo-20.12.1-x86_64-2.txz:  Rebuilt.
kde/breeze-5.20.5-x86_64-2.txz:  Rebuilt.
kde/breeze-grub-5.20.5-x86_64-2.txz:  Rebuilt.
kde/breeze-gtk-5.20.5-x86_64-2.txz:  Rebuilt.
kde/breeze-icons-5.78.0-noarch-2.txz:  Rebuilt.
kde/calendarsupport-20.12.1-x86_64-2.txz:  Rebuilt.
kde/calligra-3.2.1-x86_64-3.txz:  Rebuilt.
kde/calligraplan-3.2.2-x86_64-2.txz:  Rebuilt.
kde/cantor-20.12.1-x86_64-2.txz:  Rebuilt.
kde/cervisia-20.12.1-x86_64-2.txz:  Rebuilt.
kde/digikam-7.1.0-x86_64-2.txz:  Rebuilt.
kde/dolphin-20.12.1-x86_64-2.txz:  Rebuilt.
kde/dolphin-plugins-20.12.1-x86_64-2.txz:  Rebuilt.
kde/dragon-20.12.1-x86_64-2.txz:  Rebuilt.
kde/drkonqi-5.20.5-x86_64-2.txz:  Rebuilt.
kde/elisa-20.12.1-x86_64-2.txz:  Rebuilt.
kde/eventviews-20.12.1-x86_64-2.txz:  Rebuilt.
kde/extra-cmake-modules-5.78.0-x86_64-2.txz:  Rebuilt.
kde/falkon-3.1.0-x86_64-2.txz:  Rebuilt.
kde/ffmpegthumbs-20.12.1-x86_64-2.txz:  Rebuilt.
kde/filelight-20.12.1-x86_64-2.txz:  Rebuilt.
kde/frameworkintegration-5.78.0-x86_64-2.txz:  Rebuilt.
kde/granatier-20.12.1-x86_64-2.txz:  Rebuilt.
kde/grantlee-editor-20.12.1-x86_64-2.txz:  Rebuilt.
kde/grantleetheme-20.12.1-x86_64-2.txz:  Rebuilt.
kde/gwenview-20.12.1-x86_64-2.txz:  Rebuilt.
kde/incidenceeditor-20.12.1-x86_64-2.txz:  Rebuilt.
kde/itinerary-20.12.1-x86_64-2.txz:  Rebuilt.
kde/juk-20.12.1-x86_64-2.txz:  Rebuilt.
kde/k3b-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kactivities-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kactivities-stats-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kactivitymanagerd-5.20.5-x86_64-2.txz:  Rebuilt.
kde/kaddressbook-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kalarm-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kalarmcal-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kalgebra-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kalzium-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kamera-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kamoso-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kanagram-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kapidox-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kapman-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kapptemplate-20.12.1-x86_64-2.txz:  Rebuilt.
kde/karchive-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kate-20.12.1-x86_64-2.txz:  Rebuilt.
kde/katomic-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kauth-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kbackup-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kblackbox-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kblocks-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kbookmarks-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kbounce-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kbreakout-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kbruch-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kcachegrind-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kcalc-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kcalendarcore-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kcalutils-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kcharselect-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kcm-fcitx-0.5.6-x86_64-3.txz:  Rebuilt.
kde/kcmutils-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kcodecs-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kcolorchooser-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kcompletion-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kconfig-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kconfigwidgets-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kcontacts-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kcoreaddons-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kcrash-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kcron-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kdav-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kdbusaddons-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kde-cli-tools-5.20.5-x86_64-2.txz:  Rebuilt.
kde/kde-dev-scripts-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kde-dev-utils-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kde-gtk-config-5.20.5-x86_64-2.txz:  Rebuilt.
kde/kdebugsettings-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kdeclarative-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kdeconnect-kde-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kdecoration-5.20.5-x86_64-2.txz:  Rebuilt.
kde/kded-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kdeedu-data-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kdegraphics-mobipocket-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kdegraphics-thumbnailers-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kdelibs4support-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kdenetwork-filesharing-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kdenlive-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kdepim-addons-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kdepim-runtime-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kdeplasma-addons-5.20.5-x86_64-2.txz:  Rebuilt.
kde/kdesdk-kioslaves-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kdesdk-thumbnailers-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kdesignerplugin-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kdesu-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kdev-php-5.6.1-x86_64-2.txz:  Rebuilt.
kde/kdev-python-5.6.1-x86_64-2.txz:  Rebuilt.
kde/kdevelop-5.6.1-x86_64-2.txz:  Rebuilt.
kde/kdevelop-pg-qt-2.2.1-x86_64-2.txz:  Rebuilt.
kde/kdewebkit-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kdf-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kdiagram-2.8.0-x86_64-2.txz:  Rebuilt.
kde/kdialog-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kdiamond-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kdnssd-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kdoctools-5.78.0-x86_64-2.txz:  Rebuilt.
kde/keditbookmarks-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kemoticons-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kfilemetadata-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kfind-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kfloppy-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kfourinline-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kgamma5-5.20.5-x86_64-2.txz:  Rebuilt.
kde/kgeography-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kget-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kglobalaccel-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kgoldrunner-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kgpg-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kguiaddons-5.78.0-x86_64-2.txz:  Rebuilt.
kde/khangman-20.12.1-x86_64-2.txz:  Rebuilt.
kde/khelpcenter-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kholidays-5.78.0-x86_64-2.txz:  Rebuilt.
kde/khotkeys-5.20.5-x86_64-2.txz:  Rebuilt.
kde/khtml-5.78.0-x86_64-2.txz:  Rebuilt.
kde/ki18n-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kiconthemes-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kid3-3.8.4-x86_64-2.txz:  Rebuilt.
kde/kidentitymanagement-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kidletime-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kig-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kigo-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kile-2.9.93-x86_64-3.txz:  Rebuilt.
kde/killbots-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kimageformats-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kimagemapeditor-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kimap-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kinfocenter-5.20.5-x86_64-2.txz:  Rebuilt.
kde/kinit-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kio-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kio-extras-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kio-gdrive-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kipi-plugins-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kirigami-gallery-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kirigami2-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kiriki-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kitemmodels-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kitemviews-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kiten-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kitinerary-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kjobwidgets-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kjots-20201206_f7d555c-x86_64-2.txz:  Rebuilt.
kde/kjs-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kjsembed-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kjumpingcube-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kldap-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kleopatra-20.12.1-x86_64-2.txz:  Rebuilt.
kde/klickety-20.12.1-x86_64-2.txz:  Rebuilt.
kde/klines-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kmag-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kmahjongg-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kmail-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kmail-account-wizard-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kmailtransport-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kmbox-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kmediaplayer-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kmenuedit-5.20.5-x86_64-2.txz:  Rebuilt.
kde/kmime-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kmines-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kmix-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kmousetool-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kmouth-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kmplot-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kmymoney-5.1.1-x86_64-2.txz:  Rebuilt.
kde/knavalbattle-20.12.1-x86_64-2.txz:  Rebuilt.
kde/knetwalk-20.12.1-x86_64-2.txz:  Rebuilt.
kde/knewstuff-5.78.0-x86_64-2.txz:  Rebuilt.
kde/knights-20.12.1-x86_64-2.txz:  Rebuilt.
kde/knotes-20.12.1-x86_64-2.txz:  Rebuilt.
kde/knotifications-5.78.0-x86_64-2.txz:  Rebuilt.
kde/knotifyconfig-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kolf-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kollision-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kolourpaint-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kompare-20.12.1-x86_64-2.txz:  Rebuilt.
kde/konqueror-20.12.1-x86_64-2.txz:  Rebuilt.
kde/konquest-20.12.1-x86_64-2.txz:  Rebuilt.
kde/konsole-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kontact-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kontactinterface-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kontrast-20.12.1-x86_64-2.txz:  Rebuilt.
kde/konversation-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kopete-20.12.1-x86_64-2.txz:  Rebuilt.
kde/korganizer-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kosmindoormap-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kpackage-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kparts-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kpat-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kpeople-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kpeoplevcard-0.1-x86_64-2.txz:  Rebuilt.
kde/kpimtextedit-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kpkpass-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kplotting-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kpmcore-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kpty-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kpublictransport-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kqtquickcharts-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kquickcharts-5.78.0-x86_64-2.txz:  Rebuilt.
kde/krdc-20.12.1-x86_64-2.txz:  Rebuilt.
kde/krename-5.0.1-x86_64-2.txz:  Rebuilt.
kde/kreversi-20.12.1-x86_64-2.txz:  Rebuilt.
kde/krfb-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kross-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kross-interpreters-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kruler-20.12.1-x86_64-2.txz:  Rebuilt.
kde/krunner-5.78.0-x86_64-2.txz:  Rebuilt.
kde/krusader-2.7.2-x86_64-2.txz:  Rebuilt.
kde/kscreen-5.20.5-x86_64-2.txz:  Rebuilt.
kde/kscreenlocker-5.20.5-x86_64-2.txz:  Rebuilt.
kde/kservice-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kshisen-20.12.1-x86_64-2.txz:  Rebuilt.
kde/ksirk-20.12.1-x86_64-2.txz:  Rebuilt.
kde/ksmtp-20.12.1-x86_64-2.txz:  Rebuilt.
kde/ksnakeduel-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kspaceduel-20.12.1-x86_64-2.txz:  Rebuilt.
kde/ksquares-20.12.1-x86_64-2.txz:  Rebuilt.
kde/ksshaskpass-5.20.5-x86_64-2.txz:  Rebuilt.
kde/kstars-3.5.1-x86_64-2.txz:  Rebuilt.
kde/ksudoku-20.12.1-x86_64-2.txz:  Rebuilt.
kde/ksysguard-5.20.5-x86_64-2.txz:  Rebuilt.
kde/ksystemlog-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kteatime-20.12.1-x86_64-2.txz:  Rebuilt.
kde/ktexteditor-5.78.0-x86_64-2.txz:  Rebuilt.
kde/ktextwidgets-5.78.0-x86_64-2.txz:  Rebuilt.
kde/ktimer-20.12.1-x86_64-2.txz:  Rebuilt.
kde/ktimetracker-5.0.1-x86_64-2.txz:  Rebuilt.
kde/ktnef-20.12.1-x86_64-2.txz:  Rebuilt.
kde/ktorrent-20.12.1-x86_64-2.txz:  Rebuilt.
kde/ktouch-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kturtle-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kubrick-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kunitconversion-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kwallet-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kwallet-pam-5.20.5-x86_64-2.txz:  Rebuilt.
kde/kwalletmanager-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kwave-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kwayland-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kwayland-integration-5.20.5-x86_64-2.txz:  Rebuilt.
kde/kwayland-server-5.20.5-x86_64-2.txz:  Rebuilt.
kde/kwidgetsaddons-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kwin-5.20.5-x86_64-2.txz:  Rebuilt.
kde/kwindowsystem-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kwordquiz-20.12.1-x86_64-2.txz:  Rebuilt.
kde/kwrited-5.20.5-x86_64-2.txz:  Rebuilt.
kde/kxmlgui-5.78.0-x86_64-2.txz:  Rebuilt.
kde/kxmlrpcclient-5.78.0-x86_64-2.txz:  Rebuilt.
kde/latte-dock-0.9.11-x86_64-2.txz:  Rebuilt.
kde/libgravatar-20.12.1-x86_64-2.txz:  Rebuilt.
kde/libkcddb-20.12.1-x86_64-2.txz:  Rebuilt.
kde/libkcompactdisc-20.12.1-x86_64-2.txz:  Rebuilt.
kde/libkdcraw-20.12.1-x86_64-2.txz:  Rebuilt.
kde/libkdegames-20.12.1-x86_64-2.txz:  Rebuilt.
kde/libkdepim-20.12.1-x86_64-2.txz:  Rebuilt.
kde/libkeduvocdocument-20.12.1-x86_64-2.txz:  Rebuilt.
kde/libkexiv2-20.12.1-x86_64-2.txz:  Rebuilt.
kde/libkgapi-20.12.1-x86_64-2.txz:  Rebuilt.
kde/libkipi-20.12.1-x86_64-2.txz:  Rebuilt.
kde/libkleo-20.12.1-x86_64-2.txz:  Rebuilt.
kde/libkmahjongg-20.12.1-x86_64-2.txz:  Rebuilt.
kde/libkomparediff2-20.12.1-x86_64-2.txz:  Rebuilt.
kde/libksane-20.12.1-x86_64-2.txz:  Rebuilt.
kde/libkscreen-5.20.5-x86_64-2.txz:  Rebuilt.
kde/libksieve-20.12.1-x86_64-2.txz:  Rebuilt.
kde/libksysguard-5.20.5-x86_64-2.txz:  Rebuilt.
kde/libktorrent-20.12.1-x86_64-2.txz:  Rebuilt.
kde/lokalize-20.12.1-x86_64-2.txz:  Rebuilt.
kde/lskat-20.12.1-x86_64-2.txz:  Rebuilt.
kde/mailcommon-20.12.1-x86_64-2.txz:  Rebuilt.
kde/mailimporter-20.12.1-x86_64-2.txz:  Rebuilt.
kde/marble-20.12.1-x86_64-2.txz:  Rebuilt.
kde/markdownpart-20.12.1-x86_64-2.txz:  Rebuilt.
kde/mbox-importer-20.12.1-x86_64-2.txz:  Rebuilt.
kde/messagelib-20.12.1-x86_64-2.txz:  Rebuilt.
kde/milou-5.20.5-x86_64-2.txz:  Rebuilt.
kde/minuet-20.12.1-x86_64-2.txz:  Rebuilt.
kde/modemmanager-qt-5.78.0-x86_64-2.txz:  Rebuilt.
kde/networkmanager-qt-5.78.0-x86_64-2.txz:  Rebuilt.
kde/okteta-0.26.4-x86_64-2.txz:  Rebuilt.
kde/okular-20.12.1-x86_64-2.txz:  Rebuilt.
kde/oxygen-5.20.5-x86_64-2.txz:  Rebuilt.
kde/oxygen-fonts-5.4.3-noarch-2.txz:  Rebuilt.
kde/oxygen-gtk2-1.4.6-x86_64-2.txz:  Rebuilt.
kde/oxygen-icons5-5.78.0-noarch-2.txz:  Rebuilt.
kde/palapeli-20.12.1-x86_64-2.txz:  Rebuilt.
kde/parley-20.12.1-x86_64-2.txz:  Rebuilt.
kde/partitionmanager-20.12.1-x86_64-2.txz:  Rebuilt.
kde/picmi-20.12.1-x86_64-2.txz:  Rebuilt.
kde/pim-data-exporter-20.12.1-x86_64-2.txz:  Rebuilt.
kde/pim-sieve-editor-20.12.1-x86_64-2.txz:  Rebuilt.
kde/pimcommon-20.12.1-x86_64-2.txz:  Rebuilt.
kde/plasma-browser-integration-5.20.5-x86_64-2.txz:  Rebuilt.
kde/plasma-desktop-5.20.5-x86_64-2.txz:  Rebuilt.
kde/plasma-disks-5.20.5-x86_64-2.txz:  Rebuilt.
kde/plasma-framework-5.78.0-x86_64-2.txz:  Rebuilt.
kde/plasma-integration-5.20.5-x86_64-2.txz:  Rebuilt.
kde/plasma-nm-5.20.5-x86_64-2.txz:  Rebuilt.
kde/plasma-pa-5.20.5-x86_64-2.txz:  Rebuilt.
kde/plasma-sdk-5.20.5-x86_64-2.txz:  Rebuilt.
kde/plasma-vault-5.20.5-x86_64-2.txz:  Rebuilt.
kde/plasma-wayland-protocols-1.1.1-x86_64-2.txz:  Rebuilt.
kde/plasma-workspace-5.20.5-x86_64-2.txz:  Rebuilt.
kde/plasma-workspace-wallpapers-5.20.5-x86_64-2.txz:  Rebuilt.
kde/polkit-kde-agent-1-5.20.5-x86_64-2.txz:  Rebuilt.
kde/powerdevil-5.20.5-x86_64-2.txz:  Rebuilt.
kde/poxml-20.12.1-x86_64-2.txz:  Rebuilt.
kde/print-manager-20.12.1-x86_64-2.txz:  Rebuilt.
kde/prison-5.78.0-x86_64-2.txz:  Rebuilt.
kde/pulseaudio-qt-1.2-x86_64-2.txz:  Rebuilt.
kde/purpose-5.78.0-x86_64-2.txz:  Rebuilt.
kde/qqc2-desktop-style-5.78.0-x86_64-2.txz:  Rebuilt.
kde/rocs-20.12.1-x86_64-2.txz:  Rebuilt.
kde/sddm-0.19.0-x86_64-5.txz:  Rebuilt.
kde/sddm-kcm-5.20.5-x86_64-2.txz:  Rebuilt.
kde/skanlite-2.2.0-x86_64-2.txz:  Rebuilt.
kde/solid-5.78.0-x86_64-2.txz:  Rebuilt.
kde/sonnet-5.78.0-x86_64-2.txz:  Rebuilt.
kde/spectacle-20.12.1-x86_64-2.txz:  Rebuilt.
kde/step-20.12.1-x86_64-2.txz:  Rebuilt.
kde/svgpart-20.12.1-x86_64-2.txz:  Rebuilt.
kde/sweeper-20.12.1-x86_64-2.txz:  Rebuilt.
kde/syndication-5.78.0-x86_64-2.txz:  Rebuilt.
kde/syntax-highlighting-5.78.0-x86_64-2.txz:  Rebuilt.
kde/systemsettings-5.20.5-x86_64-2.txz:  Rebuilt.
kde/threadweaver-5.78.0-x86_64-2.txz:  Rebuilt.
kde/umbrello-20.12.1-x86_64-2.txz:  Rebuilt.
kde/wacomtablet-20201030_417d9d9-x86_64-2.txz:  Rebuilt.
kde/xdg-desktop-portal-kde-5.20.5-x86_64-2.txz:  Rebuilt.
kde/yakuake-20.12.1-x86_64-2.txz:  Rebuilt.
kde/zeroconf-ioslave-20.12.1-x86_64-2.txz:  Rebuilt.
l/GConf-3.2.6-x86_64-6.txz:  Rebuilt.
l/LibRaw-0.20.2-x86_64-2.txz:  Rebuilt.
l/M2Crypto-0.37.1-x86_64-2.txz:  Rebuilt.
l/Mako-1.1.4-x86_64-2.txz:  Rebuilt.
l/PyQt5-5.15.2-x86_64-2.txz:  Rebuilt.
l/QScintilla-2.11.6-x86_64-2.txz:  Rebuilt.
l/QtAV-20200910_2a470d2a-x86_64-2.txz:  Rebuilt.
l/SDL2-2.0.14-x86_64-2.txz:  Rebuilt.
l/SDL2_gfx-1.0.4-x86_64-2.txz:  Rebuilt.
l/SDL2_image-2.0.5-x86_64-2.txz:  Rebuilt.
l/SDL2_mixer-2.0.4-x86_64-3.txz:  Rebuilt.
l/SDL2_net-2.0.1-x86_64-3.txz:  Rebuilt.
l/SDL2_ttf-2.0.15-x86_64-2.txz:  Rebuilt.
l/a52dec-0.7.4-x86_64-4.txz:  Rebuilt.
l/aalib-1.4rc5-x86_64-7.txz:  Rebuilt.
l/accountsservice-0.6.55-x86_64-3.txz:  Rebuilt.
l/adwaita-icon-theme-3.38.0-noarch-2.txz:  Rebuilt.
l/alsa-lib-1.2.4-x86_64-2.txz:  Rebuilt.
l/alsa-oss-1.1.8-x86_64-2.txz:  Rebuilt.
l/alsa-plugins-1.2.2-x86_64-2.txz:  Rebuilt.
l/apr-1.7.0-x86_64-2.txz:  Rebuilt.
l/apr-util-1.6.1-x86_64-9.txz:  Rebuilt.
l/argon2-20190702-x86_64-4.txz:  Rebuilt.
l/aspell-0.60.8-x86_64-2.txz:  Rebuilt.
l/at-spi2-atk-2.38.0-x86_64-2.txz:  Rebuilt.
l/at-spi2-core-2.38.0-x86_64-2.txz:  Rebuilt.
l/atk-2.36.0-x86_64-2.txz:  Rebuilt.
l/atkmm-2.28.1-x86_64-2.txz:  Rebuilt.
l/audiofile-0.3.6-x86_64-3.txz:  Rebuilt.
l/babl-0.1.84-x86_64-2.txz:  Rebuilt.
l/boost-1.75.0-x86_64-2.txz:  Rebuilt.
l/brotli-1.0.9-x86_64-4.txz:  Rebuilt.
l/cairo-1.16.0-x86_64-2.txz:  Rebuilt.
l/cairomm-1.12.2-x86_64-3.txz:  Rebuilt.
l/cfitsio-3.49-x86_64-2.txz:  Rebuilt.
l/chmlib-0.40-x86_64-4.txz:  Rebuilt.
l/clucene-2.3.3.4-x86_64-4.txz:  Rebuilt.
l/cryfs-0.10.2-x86_64-3.txz:  Rebuilt.
l/cryptopp-8.2.0-x86_64-2.txz:  Rebuilt.
l/db48-4.8.30-x86_64-5.txz:  Rebuilt.
l/dbus-glib-0.110-x86_64-3.txz:  Rebuilt.
l/dbus-python-1.2.16-x86_64-3.txz:  Rebuilt.
l/dconf-0.38.0-x86_64-2.txz:  Rebuilt.
l/dconf-editor-3.38.2-x86_64-2.txz:  Rebuilt.
l/desktop-file-utils-0.26-x86_64-2.txz:  Rebuilt.
l/djvulibre-3.5.28-x86_64-2.txz:  Rebuilt.
l/dotconf-1.3-x86_64-2.txz:  Rebuilt.
l/dvdauthor-0.7.2-x86_64-2.txz:  Rebuilt.
l/ebook-tools-0.2.2-x86_64-6.txz:  Rebuilt.
l/eigen2-2.0.17-x86_64-3.txz:  Rebuilt.
l/eigen3-3.3.9-x86_64-2.txz:  Rebuilt.
l/elfutils-0.182-x86_64-2.txz:  Rebuilt.
l/enchant-1.6.1-x86_64-3.txz:  Rebuilt.
l/esound-0.2.41-x86_64-4.txz:  Rebuilt.
l/espeak-ng-1.50-x86_64-2.txz:  Rebuilt.
l/exiv2-0.27.3-x86_64-2.txz:  Rebuilt.
l/expat-2.2.10-x86_64-2.txz:  Rebuilt.
l/farstream-0.2.9-x86_64-2.txz:  Rebuilt.
l/ffmpeg-4.3.1-x86_64-2.txz:  Rebuilt.
l/fftw-3.3.9-x86_64-2.txz:  Rebuilt.
l/fluidsynth-1.1.11-x86_64-3.txz:  Rebuilt.
l/freecell-solver-6.2.0-x86_64-2.txz:  Rebuilt.
l/freetype-2.10.4-x86_64-2.txz:  Rebuilt.
l/frei0r-plugins-1.7.0-x86_64-2.txz:  Rebuilt.
l/fribidi-1.0.10-x86_64-2.txz:  Rebuilt.
l/fuse-2.9.9-x86_64-2.txz:  Rebuilt.
l/fuse3-3.10.1-x86_64-2.txz:  Rebuilt.
l/gamin-0.1.10-x86_64-7.txz:  Rebuilt.
l/gc-8.0.4-x86_64-2.txz:  Rebuilt.
l/gcr-3.38.1-x86_64-2.txz:  Rebuilt.
l/gd-2.3.0-x86_64-2.txz:  Rebuilt.
l/gdbm-1.19-x86_64-2.txz:  Rebuilt.
l/gdk-pixbuf2-2.42.2-x86_64-2.txz:  Rebuilt.
l/gdk-pixbuf2-xlib-2.40.2-x86_64-2.txz:  Rebuilt.
l/gegl-0.4.28-x86_64-3.txz:  Rebuilt.
l/gexiv2-0.12.1-x86_64-2.txz:  Rebuilt.
l/giflib-5.2.1-x86_64-3.txz:  Rebuilt.
l/gjs-1.66.2-x86_64-2.txz:  Rebuilt.
l/glade-3.38.2-x86_64-2.txz:  Rebuilt.
l/glib-1.2.10-x86_64-8.txz:  Rebuilt.
l/glib-networking-2.66.0-x86_64-2.txz:  Rebuilt.
l/glib2-2.66.4-x86_64-2.txz:  Rebuilt.
l/glibmm-2.64.5-x86_64-2.txz:  Rebuilt.
l/gmime-3.2.7-x86_64-3.txz:  Rebuilt.
l/gmm-5.4-noarch-2.txz:  Rebuilt.
l/gmp-6.2.1-x86_64-2.txz:  Rebuilt.
l/gnome-keyring-3.36.0-x86_64-3.txz:  Rebuilt.
l/gnome-themes-extra-3.28-x86_64-2.txz:  Rebuilt.
l/gnu-efi-3.0.12-x86_64-2.txz:  Rebuilt.
l/gobject-introspection-1.66.1-x86_64-2.txz:  Rebuilt.
l/grantlee-5.2.0-x86_64-2.txz:  Rebuilt.
l/graphene-1.10.2-x86_64-2.txz:  Rebuilt.
l/graphite2-1.3.14-x86_64-2.txz:  Rebuilt.
l/gsettings-desktop-schemas-3.38.0-x86_64-2.txz:  Rebuilt.
l/gsl-2.6-x86_64-2.txz:  Rebuilt.
l/gst-plugins-base-1.18.3-x86_64-2.txz:  Rebuilt.
l/gst-plugins-base0-0.10.36-x86_64-4.txz:  Rebuilt.
l/gst-plugins-good-1.18.3-x86_64-2.txz:  Rebuilt.
l/gst-plugins-good0-0.10.31-x86_64-4.txz:  Rebuilt.
l/gst-plugins-libav-1.18.3-x86_64-2.txz:  Rebuilt.
l/gstreamer-1.18.3-x86_64-2.txz:  Rebuilt.
l/gstreamer0-0.10.36-x86_64-3.txz:  Rebuilt.
l/gtk+-1.2.10-x86_64-8.txz:  Rebuilt.
l/gtk+2-2.24.32-x86_64-4.txz:  Rebuilt.
l/gtk+3-3.24.24-x86_64-2.txz:  Rebuilt.
l/gtkmm2-2.24.5-x86_64-3.txz:  Rebuilt.
l/gtkmm3-3.24.3-x86_64-2.txz:  Rebuilt.
l/gtksourceview3-3.24.11-x86_64-3.txz:  Rebuilt.
l/gtkspell-2.0.16-x86_64-5.txz:  Rebuilt.
l/gvfs-1.46.2-x86_64-2.txz:  Rebuilt.
l/harfbuzz-2.7.4-x86_64-2.txz:  Rebuilt.
l/hicolor-icon-theme-0.17-noarch-3.txz:  Rebuilt.
l/hunspell-1.6.2-x86_64-4.txz:  Rebuilt.
l/hyphen-2.8.8-x86_64-2.txz:  Rebuilt.
l/icon-naming-utils-0.8.90-x86_64-4.txz:  Rebuilt.
l/icu4c-68.2-x86_64-2.txz:  Rebuilt.
l/id3lib-3.8.3-x86_64-3.txz:  Rebuilt.
l/imagemagick-7.0.10_58-x86_64-2.txz:  Rebuilt.
l/isl-0.23-x86_64-2.txz:  Rebuilt.
l/iso-codes-4.5.0-noarch-2.txz:  Rebuilt.
l/jansson-2.13.1-x86_64-2.txz:  Rebuilt.
l/jasper-2.0.24-x86_64-2.txz:  Rebuilt.
l/jemalloc-5.2.1-x86_64-2.txz:  Rebuilt.
l/jmtpfs-0.5-x86_64-2.txz:  Rebuilt.
l/json-c-0.15_20200726-x86_64-2.txz:  Rebuilt.
l/json-glib-1.6.0-x86_64-2.txz:  Rebuilt.
l/judy-1.0.5-x86_64-3.txz:  Rebuilt.
l/kdsoap-1.10.0-x86_64-2.txz:  Rebuilt.
l/keybinder3-3.0_0.3.2-x86_64-2.txz:  Rebuilt.
l/keyutils-1.6.3-x86_64-2.txz:  Rebuilt.
l/lame-3.100-x86_64-3.txz:  Rebuilt.
l/lcms-1.19-x86_64-5.txz:  Rebuilt.
l/lcms2-2.11-x86_64-2.txz:  Rebuilt.
l/lensfun-0.3.95-x86_64-2.txz:  Rebuilt.
l/libaio-0.3.112-x86_64-2.txz:  Rebuilt.
l/libao-1.2.2-x86_64-3.txz:  Rebuilt.
l/libappindicator-12.10.0-x86_64-2.txz:  Rebuilt.
l/libarchive-3.5.1-x86_64-2.txz:  Rebuilt.
l/libasyncns-0.8-x86_64-4.txz:  Rebuilt.
l/libatasmart-0.19-x86_64-4.txz:  Rebuilt.
l/libbluray-1.2.1-x86_64-2.txz:  Rebuilt.
l/libburn-1.5.2.pl01-x86_64-2.txz:  Rebuilt.
l/libcaca-0.99.beta19-x86_64-8.txz:  Rebuilt.
l/libcanberra-0.30-x86_64-7.txz:  Rebuilt.
l/libcap-2.46-x86_64-2.txz:  Rebuilt.
l/libcap-ng-0.8.2-x86_64-2.txz:  Rebuilt.
l/libcddb-1.3.2-x86_64-7.txz:  Rebuilt.
l/libcdio-2.1.0-x86_64-2.txz:  Rebuilt.
l/libcdio-paranoia-10.2+2.0.1-x86_64-2.txz:  Rebuilt.
l/libclc-11.0.1-x86_64-2.txz:  Rebuilt.
l/libcue-2.2.1-x86_64-2.txz:  Rebuilt.
l/libdbusmenu-16.04.0-x86_64-2.txz:  Rebuilt.
l/libdbusmenu-qt-0.9.3+16.04.20160218-x86_64-2.txz:  Rebuilt.
l/libdiscid-0.6.2-x86_64-3.txz:  Rebuilt.
l/libdmtx-0.7.5-x86_64-2.txz:  Rebuilt.
l/libdvdnav-6.1.0-x86_64-3.txz:  Rebuilt.
l/libdvdread-6.1.1-x86_64-2.txz:  Rebuilt.
l/libedit-20191231_3.1-x86_64-2.txz:  Rebuilt.
l/libevent-2.1.12-x86_64-2.txz:  Rebuilt.
l/libexif-0.6.22-x86_64-2.txz:  Rebuilt.
l/libfakekey-0.3-x86_64-3.txz:  Rebuilt.
l/libffi-3.3-x86_64-2.txz:  Rebuilt.
l/libglade-2.6.4-x86_64-7.txz:  Rebuilt.
l/libgnome-keyring-3.12.0-x86_64-3.txz:  Rebuilt.
l/libgphoto2-2.5.26-x86_64-2.txz:  Rebuilt.
l/libgpod-0.8.3-x86_64-8.txz:  Rebuilt.
l/libgsf-1.14.47-x86_64-2.txz:  Rebuilt.
l/libgtop-2.40.0-x86_64-2.txz:  Rebuilt.
l/libical-3.0.9-x86_64-2.txz:  Rebuilt.
l/libid3tag-0.15.1b-x86_64-6.txz:  Rebuilt.
l/libidl-0.8.14-x86_64-3.txz:  Rebuilt.
l/libidn-1.36-x86_64-2.txz:  Rebuilt.
l/libidn2-2.3.0-x86_64-2.txz:  Rebuilt.
l/libieee1284-0.2.11-x86_64-5.txz:  Rebuilt.
l/libimobiledevice-20200615_4791a82-x86_64-3.txz:  Rebuilt.
l/libindicator-12.10.1-x86_64-2.txz:  Rebuilt.
l/libiodbc-3.52.13-x86_64-2.txz:  Rebuilt.
l/libjpeg-turbo-2.0.6-x86_64-2.txz:  Rebuilt.
l/libkarma-0.1.2-x86_64-2.txz:  Rebuilt.
l/libmad-0.15.1b-x86_64-5.txz:  Rebuilt.
l/libmcrypt-2.5.8-x86_64-3.txz:  Rebuilt.
l/libmng-2.0.3-x86_64-3.txz:  Rebuilt.
l/libmpc-1.2.1-x86_64-2.txz:  Rebuilt.
l/libmtp-1.1.18-x86_64-2.txz:  Rebuilt.
l/libnice-0.1.18-x86_64-2.txz:  Rebuilt.
l/libnih-1.0.3-x86_64-4.txz:  Rebuilt.
l/libnjb-2.2.7-x86_64-3.txz:  Rebuilt.
l/libnl-1.1.4-x86_64-4.txz:  Rebuilt.
l/libnl3-3.5.0-x86_64-2.txz:  Rebuilt.
l/libnotify-0.7.9-x86_64-2.txz:  Rebuilt.
l/libnsl-1.3.0-x86_64-2.txz:  Rebuilt.
l/libnss_nis-3.1-x86_64-2.txz:  Rebuilt.
l/libodfgen-0.1.8-x86_64-2.txz:  Rebuilt.
l/libogg-1.3.4-x86_64-2.txz:  Rebuilt.
l/liboggz-1.1.1-x86_64-4.txz:  Rebuilt.
l/liboil-0.3.17-x86_64-3.txz:  Rebuilt.
l/libopusenc-0.2.1-x86_64-2.txz:  Rebuilt.
l/libpcap-1.9.1-x86_64-2.txz:  Rebuilt.
l/libplist-2.2.0-x86_64-2.txz:  Rebuilt.
l/libpng-1.6.37-x86_64-2.txz:  Rebuilt.
l/libproxy-0.4.17-x86_64-2.txz:  Rebuilt.
l/libpsl-0.21.1-x86_64-3.txz:  Rebuilt.
l/libqalculate-3.16.1-x86_64-2.txz:  Rebuilt.
l/libraw1394-2.1.2-x86_64-3.txz:  Rebuilt.
l/librevenge-0.0.4-x86_64-3.txz:  Rebuilt.
l/librsvg-2.50.2-x86_64-2.txz:  Rebuilt.
l/libsamplerate-0.1.9-x86_64-3.txz:  Rebuilt.
l/libsass-3.6.4-x86_64-2.txz:  Rebuilt.
l/libsecret-0.20.4-x86_64-2.txz:  Rebuilt.
l/libsigc++-2.10.2-x86_64-2.txz:  Rebuilt.
l/libsigsegv-2.13-x86_64-2.txz:  Rebuilt.
l/libsndfile-1.0.30-x86_64-2.txz:  Rebuilt.
l/libsodium-1.0.18-x86_64-2.txz:  Rebuilt.
l/libsoup-2.72.0-x86_64-2.txz:  Rebuilt.
l/libspectre-0.2.9-x86_64-3.txz:  Rebuilt.
l/libssh-0.9.5-x86_64-2.txz:  Rebuilt.
l/libssh2-1.9.0-x86_64-2.txz:  Rebuilt.
l/libtasn1-4.16.0-x86_64-2.txz:  Rebuilt.
l/libtheora-1.1.1-x86_64-3.txz:  Rebuilt.
l/libtiff-4.2.0-x86_64-2.txz:  Rebuilt.
l/libunistring-0.9.10-x86_64-2.txz:  Rebuilt.
l/libunwind-1.5.0-x86_64-2.txz:  Rebuilt.
l/libusb-1.0.24-x86_64-2.txz:  Rebuilt.
l/libusb-compat-0.1.5-x86_64-4.txz:  Rebuilt.
l/libusbmuxd-20200615_c7d7d1a-x86_64-2.txz:  Rebuilt.
l/libuv-1.40.0-x86_64-2.txz:  Rebuilt.
l/libvisio-0.1.7-x86_64-5.txz:  Rebuilt.
l/libvisual-0.4.0-x86_64-5.txz:  Rebuilt.
l/libvisual-plugins-0.4.0-x86_64-5.txz:  Rebuilt.
l/libvncserver-0.9.13-x86_64-2.txz:  Rebuilt.
l/libvorbis-1.3.7-x86_64-2.txz:  Rebuilt.
l/libvpx-1.9.0-x86_64-2.txz:  Rebuilt.
l/libwebp-1.1.0-x86_64-4.txz:  Rebuilt.
l/libwmf-0.2.12-x86_64-2.txz:  Rebuilt.
l/libwnck-2.31.0-x86_64-4.txz:  Rebuilt.
l/libwnck3-3.36.0-x86_64-2.txz:  Rebuilt.
l/libwpd-0.10.3-x86_64-2.txz:  Rebuilt.
l/libwpg-0.3.3-x86_64-2.txz:  Rebuilt.
l/libxkbcommon-1.0.3-x86_64-2.txz:  Rebuilt.
l/libxklavier-5.4-x86_64-3.txz:  Rebuilt.
l/libxml2-2.9.10-x86_64-4.txz:  Rebuilt.
l/libxslt-1.1.34-x86_64-2.txz:  Rebuilt.
l/libyaml-0.2.5-x86_64-2.txz:  Rebuilt.
l/libzip-1.7.3-x86_64-2.txz:  Rebuilt.
l/lmdb-0.9.27-x86_64-2.txz:  Rebuilt.
l/loudmouth-1.5.3-x86_64-6.txz:  Rebuilt.
l/lz4-1.9.3-x86_64-2.txz:  Rebuilt.
l/lzo-2.10-x86_64-3.txz:  Rebuilt.
l/media-player-info-24-noarch-2.txz:  Rebuilt.
l/mhash-0.9.9.9-x86_64-5.txz:  Rebuilt.
l/mlt-6.24.0-x86_64-3.txz:  Rebuilt.
l/mm-1.4.2-x86_64-4.txz:  Rebuilt.
l/mozilla-nss-3.60.1-x86_64-2.txz:  Rebuilt.
l/mozjs78-78.6.1esr-x86_64-2.txz:  Rebuilt.
l/mpfr-4.1.0-x86_64-2.txz:  Rebuilt.
l/ncurses-6.2_20201219-x86_64-3.txz:  Rebuilt.
l/neon-0.31.2-x86_64-2.txz:  Rebuilt.
l/netpbm-10.93.00-x86_64-2.txz:  Rebuilt.
l/newt-0.52.21-x86_64-4.txz:  Rebuilt.
l/ocl-icd-2.2.14-x86_64-2.txz:  Rebuilt.
l/oniguruma-6.9.6-x86_64-2.txz:  Rebuilt.
l/openal-soft-1.21.0-x86_64-2.txz:  Rebuilt.
l/opencv-4.5.1-x86_64-2.txz:  Rebuilt.
l/openexr-2.5.4-x86_64-2.txz:  Rebuilt.
l/openjpeg-2.4.0-x86_64-2.txz:  Rebuilt.
l/opus-1.3.1-x86_64-2.txz:  Rebuilt.
l/opusfile-0.12-x86_64-2.txz:  Rebuilt.
l/orc-0.4.32-x86_64-2.txz:  Rebuilt.
l/pango-1.48.0-x86_64-2.txz:  Rebuilt.
l/pangomm-2.42.2-x86_64-2.txz:  Rebuilt.
l/parted-3.3-x86_64-2.txz:  Rebuilt.
l/pcaudiolib-1.1-x86_64-2.txz:  Rebuilt.
l/pcre-8.44-x86_64-2.txz:  Rebuilt.
l/pcre2-10.36-x86_64-2.txz:  Rebuilt.
l/phonon-4.11.1-x86_64-2.txz:  Rebuilt.
l/phonon-backend-gstreamer-4.10.0-x86_64-2.txz:  Rebuilt.
l/pilot-link-0.12.5-x86_64-15.txz:  Rebuilt.
l/pipewire-0.3.19-x86_64-2.txz:  Rebuilt.
l/polkit-0.118-x86_64-4.txz:  Rebuilt.
l/polkit-gnome-0.105-x86_64-3.txz:  Rebuilt.
l/polkit-qt-1-0.113.0-x86_64-2.txz:  Rebuilt.
l/poppler-21.01.0-x86_64-2.txz:  Rebuilt.
l/poppler-data-0.4.10-noarch-2.txz:  Rebuilt.
l/popt-1.18-x86_64-2.txz:  Rebuilt.
l/pulseaudio-14.2-x86_64-2.txz:  Rebuilt.
l/pycairo-1.20.0-x86_64-3.txz:  Rebuilt.
l/pycups-2.0.1-x86_64-3.txz:  Rebuilt.
l/pycurl-7.43.0.6-x86_64-3.txz:  Rebuilt.
l/pygobject-2.28.7-x86_64-7.txz:  Rebuilt.
l/pygobject3-3.38.0-x86_64-2.txz:  Rebuilt.
l/pygtk-2.24.0-x86_64-6.txz:  Rebuilt.
l/pyparsing-2.4.7-x86_64-3.txz:  Rebuilt.
l/python-appdirs-1.4.4-x86_64-3.txz:  Rebuilt.
l/python-certifi-2020.12.5-x86_64-2.txz:  Rebuilt.
l/python-chardet-4.0.0-x86_64-2.txz:  Rebuilt.
l/python-distro-1.5.0-x86_64-3.txz:  Rebuilt.
l/python-docutils-0.16-x86_64-5.txz:  Rebuilt.
l/python-future-0.18.2-x86_64-4.txz:  Rebuilt.
l/python-idna-3.1-x86_64-2.txz:  Rebuilt.
l/python-notify2-0.3.1-x86_64-7.txz:  Rebuilt.
l/python-packaging-20.8-x86_64-2.txz:  Rebuilt.
l/python-pillow-8.1.0-x86_64-2.txz:  Rebuilt.
l/python-ply-3.11-x86_64-5.txz:  Rebuilt.
l/python-pygments-2.7.4-x86_64-2.txz:  Rebuilt.
l/python-pysol_cards-0.10.1-x86_64-2.txz:  Rebuilt.
l/python-random2-1.0.1-x86_64-2.txz:  Rebuilt.
l/python-requests-2.25.1-x86_64-2.txz:  Rebuilt.
l/python-sane-2.9.1-x86_64-2.txz:  Rebuilt.
l/python-six-1.15.0-x86_64-3.txz:  Rebuilt.
l/python-urllib3-1.26.2-x86_64-2.txz:  Rebuilt.
l/python2-module-collection-2.7.18-x86_64-2.txz:  Rebuilt.
l/qca-2.3.1-x86_64-2.txz:  Rebuilt.
l/qrencode-4.1.1-x86_64-2.txz:  Rebuilt.
l/qt5-5.15.2-x86_64-3.txz:  Rebuilt.
l/qt5-webkit-5.212.0_alpha4-x86_64-5.txz:  Rebuilt.
l/qtkeychain-0.12.0-x86_64-2.txz:  Rebuilt.
l/quazip-1.1-x86_64-2.txz:  Rebuilt.
l/readline-8.1.000-x86_64-2.txz:  Rebuilt.
l/rpcsvc-proto-1.4.2-x86_64-2.txz:  Rebuilt.
l/rttr-0.9.6-x86_64-3.txz:  Rebuilt.
l/sbc-1.5-x86_64-2.txz:  Rebuilt.
l/sdl-1.2.15-x86_64-10.txz:  Rebuilt.
l/serf-1.3.9-x86_64-5.txz:  Rebuilt.
l/sg3_utils-1.45-x86_64-2.txz:  Rebuilt.
l/shared-desktop-ontologies-0.11.0-x86_64-3.txz:  Rebuilt.
l/shared-mime-info-2.1-x86_64-2.txz:  Rebuilt.
l/sip-4.19.23-x86_64-3.txz:  Rebuilt.
l/slang-2.3.2-x86_64-4.txz:  Rebuilt.
l/slang1-1.4.9-x86_64-3.txz:  Rebuilt.
l/sound-theme-freedesktop-0.8-noarch-3.txz:  Rebuilt.
l/speech-dispatcher-0.10.2-x86_64-2.txz:  Rebuilt.
l/speex-1.2.0-x86_64-3.txz:  Rebuilt.
l/speexdsp-1.2.0-x86_64-2.txz:  Rebuilt.
l/startup-notification-0.12-x86_64-4.txz:  Rebuilt.
l/svgalib-1.9.25-x86_64-5.txz:  Rebuilt.
l/system-config-printer-1.5.15-x86_64-2.txz:  Rebuilt.
l/t1lib-5.1.2-x86_64-5.txz:  Rebuilt.
l/taglib-1.11.1-x86_64-4.txz:  Rebuilt.
l/taglib-extras-1.0.1-x86_64-3.txz:  Rebuilt.
l/talloc-2.3.1-x86_64-5.txz:  Rebuilt.
l/tango-icon-theme-0.8.90-noarch-5.txz:  Rebuilt.
l/tango-icon-theme-extras-0.1.0-noarch-3.txz:  Rebuilt.
l/tdb-1.4.3-x86_64-5.txz:  Rebuilt.
l/tevent-0.10.2-x86_64-5.txz:  Rebuilt.
l/tidy-html5-5.6.0-x86_64-2.txz:  Rebuilt.
l/utf8proc-2.6.1-x86_64-2.txz:  Rebuilt.
l/v4l-utils-1.20.0-x86_64-2.txz:  Rebuilt.
l/vid.stab-20200916_e851e7b-x86_64-2.txz:  Rebuilt.
l/vte-0.62.1-x86_64-3.txz:  Rebuilt.
l/wavpack-5.4.0-x86_64-2.txz:  Rebuilt.
l/woff2-20180531_a0d0ed7-x86_64-2.txz:  Rebuilt.
l/xapian-core-1.4.18-x86_64-2.txz:  Rebuilt.
l/xxHash-0.8.0-x86_64-2.txz:  Rebuilt.
l/zlib-1.2.11-x86_64-3.txz:  Rebuilt.
l/zstd-1.4.8-x86_64-2.txz:  Rebuilt.
n/ModemManager-1.14.10-x86_64-2.txz:  Rebuilt.
n/NetworkManager-1.28.0-x86_64-3.txz:  Rebuilt.
n/alpine-2.24-x86_64-2.txz:  Rebuilt.
n/autofs-5.1.6-x86_64-3.txz:  Rebuilt.
n/biff+comsat-0.17-x86_64-3.txz:  Rebuilt.
n/bind-9.16.10-x86_64-2.txz:  Rebuilt.
n/bluez-5.55-x86_64-3.txz:  Rebuilt.
n/bluez-firmware-1.2-x86_64-3.txz:  Rebuilt.
n/bootp-2.4.3-x86_64-4.txz:  Rebuilt.
n/bridge-utils-1.7-x86_64-2.txz:  Rebuilt.
n/bsd-finger-0.17-x86_64-4.txz:  Rebuilt.
n/ca-certificates-20201219-noarch-2.txz:  Rebuilt.
n/cifs-utils-6.12-x86_64-2.txz:  Rebuilt.
n/conntrack-tools-1.4.6-x86_64-2.txz:  Rebuilt.
n/crda-4.14-x86_64-2.txz:  Rebuilt.
n/curl-7.74.0-x86_64-2.txz:  Rebuilt.
n/cyrus-sasl-2.1.27-x86_64-6.txz:  Rebuilt.
n/dehydrated-0.7.0-noarch-2.txz:  Rebuilt.
n/dhcp-4.4.2-x86_64-2.txz:  Rebuilt.
n/dhcpcd-8.1.9-x86_64-2.txz:  Rebuilt.
n/dovecot-2.3.13-x86_64-2.txz:  Rebuilt.
n/ebtables-2.0.11-x86_64-2.txz:  Rebuilt.
n/elm-2.5.8-x86_64-6.txz:  Rebuilt.
n/epic5-2.1.2-x86_64-6.txz:  Rebuilt.
n/ethtool-5.10-x86_64-2.txz:  Rebuilt.
n/fetchmail-6.4.15-x86_64-2.txz:  Rebuilt.
n/getmail-6.14-x86_64-2.txz:  Rebuilt.
n/gnupg-1.4.23-x86_64-3.txz:  Rebuilt.
n/gnupg2-2.2.27-x86_64-2.txz:  Rebuilt.
n/gnutls-3.6.15-x86_64-2.txz:  Rebuilt.
n/gpa-0.10.0-x86_64-2.txz:  Rebuilt.
n/gpgme-1.15.1-x86_64-2.txz:  Rebuilt.
n/htdig-3.2.0b6-x86_64-7.txz:  Rebuilt.
n/httpd-2.4.46-x86_64-2.txz:  Rebuilt.
n/icmpinfo-1.11-x86_64-4.txz:  Rebuilt.
n/iftop-1.0pre4-x86_64-3.txz:  Rebuilt.
n/inetd-1.79s-x86_64-13.txz:  Rebuilt.
n/iproute2-5.10.0-x86_64-2.txz:  Rebuilt.
n/ipset-7.10-x86_64-2.txz:  Rebuilt.
n/iptables-1.8.7-x86_64-2.txz:  Rebuilt.
n/iptraf-ng-1.2.1-x86_64-2.txz:  Rebuilt.
n/iputils-20200821-x86_64-2.txz:  Rebuilt.
n/ipw2100-fw-1.3-fw-2.txz:  Rebuilt.
n/ipw2200-fw-3.1-fw-2.txz:  Rebuilt.
n/irssi-1.2.2-x86_64-5.txz:  Rebuilt.
n/iw-5.9-x86_64-2.txz:  Rebuilt.
n/krb5-1.18.3-x86_64-2.txz:  Rebuilt.
n/lftp-4.9.2-x86_64-2.txz:  Rebuilt.
n/libassuan-2.5.4-x86_64-2.txz:  Rebuilt.
n/libgcrypt-1.8.7-x86_64-2.txz:  Rebuilt.
n/libgpg-error-1.41-x86_64-2.txz:  Rebuilt.
n/libksba-1.5.0-x86_64-2.txz:  Rebuilt.
n/libmbim-1.24.4-x86_64-2.txz:  Rebuilt.
n/libmilter-8.16.1-x86_64-2.txz:  Rebuilt.
n/libmnl-1.0.4-x86_64-4.txz:  Rebuilt.
n/libndp-1.7-x86_64-2.txz:  Rebuilt.
n/libnetfilter_acct-1.0.3-x86_64-3.txz:  Rebuilt.
n/libnetfilter_conntrack-1.0.8-x86_64-2.txz:  Rebuilt.
n/libnetfilter_cthelper-1.0.0-x86_64-3.txz:  Rebuilt.
n/libnetfilter_cttimeout-1.0.0-x86_64-3.txz:  Rebuilt.
n/libnetfilter_log-1.0.1-x86_64-3.txz:  Rebuilt.
n/libnetfilter_queue-1.0.5-x86_64-2.txz:  Rebuilt.
n/libnfnetlink-1.0.1-x86_64-3.txz:  Rebuilt.
n/libnftnl-1.1.9-x86_64-2.txz:  Rebuilt.
n/libqmi-1.26.8-x86_64-2.txz:  Rebuilt.
n/libtirpc-1.3.1-x86_64-2.txz:  Rebuilt.
n/links-2.21-x86_64-2.txz:  Rebuilt.
n/lynx-2.8.9rel.1-x86_64-2.txz:  Rebuilt.
n/mcabber-1.1.2-x86_64-2.txz:  Rebuilt.
n/metamail-2.7-x86_64-8.txz:  Rebuilt.
n/mobile-broadband-provider-info-20201225-x86_64-2.txz:  Rebuilt.
n/mtr-0.94-x86_64-2.txz:  Rebuilt.
n/mutt-2.0.4-x86_64-2.txz:  Rebuilt.
n/nc-1.10-x86_64-3.txz:  Rebuilt.
n/ncftp-3.2.6-x86_64-3.txz:  Rebuilt.
n/net-snmp-5.9-x86_64-4.txz:  Rebuilt.
n/net-tools-20181103_0eebece-x86_64-2.txz:  Rebuilt.
n/netatalk-3.1.12-x86_64-6.txz:  Rebuilt.
n/netdate-bsd4-x86_64-3.txz:  Rebuilt.
n/netkit-bootparamd-0.17-x86_64-5.txz:  Rebuilt.
n/netkit-ftp-0.17-x86_64-6.txz:  Rebuilt.
n/netkit-ntalk-0.17-x86_64-6.txz:  Rebuilt.
n/netkit-routed-0.17-x86_64-3.txz:  Rebuilt.
n/netkit-rsh-0.17-x86_64-4.txz:  Rebuilt.
n/netkit-rusers-0.17-x86_64-4.txz:  Rebuilt.
n/netkit-rwall-0.17-x86_64-4.txz:  Rebuilt.
n/netkit-rwho-0.17-x86_64-4.txz:  Rebuilt.
n/netkit-timed-0.17-x86_64-3.txz:  Rebuilt.
n/netpipes-4.2-x86_64-3.txz:  Rebuilt.
n/nettle-3.7-x86_64-2.txz:  Rebuilt.
n/netwatch-1.3.1_2-x86_64-4.txz:  Rebuilt.
n/network-scripts-15.0-noarch-10.txz:  Rebuilt.
n/netwrite-0.17-x86_64-3.txz:  Rebuilt.
n/newspost-2.1.1-x86_64-3.txz:  Rebuilt.
n/nfacct-1.0.2-x86_64-3.txz:  Rebuilt.
n/nfs-utils-2.5.2-x86_64-3.txz:  Rebuilt.
n/nftables-0.9.8-x86_64-2.txz:  Rebuilt.
n/nghttp2-1.42.0-x86_64-2.txz:  Rebuilt.
n/nmap-7.91-x86_64-2.txz:  Rebuilt.
n/nn-6.7.3-x86_64-7.txz:  Rebuilt.
n/npth-1.6-x86_64-2.txz:  Rebuilt.
n/nss-pam-ldapd-0.9.11-x86_64-2.txz:  Rebuilt.
n/ntp-4.2.8p15-x86_64-5.txz:  Rebuilt.
n/obexftp-0.24.2-x86_64-7.txz:  Rebuilt.
n/openobex-1.7.2-x86_64-4.txz:  Rebuilt.
n/openssh-8.4p1-x86_64-4.txz:  Rebuilt.
n/openssl-1.1.1i-x86_64-2.txz:  Rebuilt.
n/openssl10-1.0.2u-x86_64-2.txz:  Rebuilt.
n/openvpn-2.5.0-x86_64-2.txz:  Rebuilt.
n/p11-kit-0.23.22-x86_64-2.txz:  Rebuilt.
n/pam-krb5-4.9-x86_64-2.txz:  Rebuilt.
n/php-7.4.14-x86_64-2.txz:  Rebuilt.
n/pidentd-3.0.19-x86_64-5.txz:  Rebuilt.
n/pinentry-1.1.0-x86_64-4.txz:  Rebuilt.
n/popa3d-1.0.3-x86_64-5.txz:  Rebuilt.
n/postfix-3.5.9-x86_64-2.txz:  Rebuilt.
n/ppp-2.4.8-x86_64-4.txz:  Rebuilt.
n/procmail-3.22-x86_64-5.txz:  Rebuilt.
n/proftpd-1.3.7a-x86_64-3.txz:  Rebuilt.
n/pssh-2.3.4-x86_64-3.txz:  Rebuilt.
n/rdist-6.1.5-x86_64-4.txz:  Rebuilt.
n/rp-pppoe-3.14-x86_64-2.txz:  Rebuilt.
n/rpcbind-1.2.5-x86_64-4.txz:  Rebuilt.
n/rsync-3.2.3-x86_64-2.txz:  Rebuilt.
n/s-nail-14.9.20-x86_64-2.txz:  Rebuilt.
n/samba-4.13.3-x86_64-2.txz:  Rebuilt.
n/slrn-1.0.3a-x86_64-2.txz:  Rebuilt.
n/snownews-1.6.10-x86_64-2.txz:  Rebuilt.
n/socat-1.7.4.1-x86_64-2.txz:  Rebuilt.
n/sshfs-3.7.1-x86_64-2.txz:  Rebuilt.
n/stunnel-5.57-x86_64-3.txz:  Rebuilt.
n/tcp_wrappers-7.6-x86_64-5.txz:  Rebuilt.
n/tcpdump-4.9.3-x86_64-2.txz:  Rebuilt.
n/telnet-0.17-x86_64-5.txz:  Rebuilt.
n/tftp-hpa-5.2-x86_64-7.txz:  Rebuilt.
n/tin-2.4.4-x86_64-4.txz:  Rebuilt.
n/traceroute-2.1.0-x86_64-3.txz:  Rebuilt.
n/ulogd-2.0.7-x86_64-3.txz:  Rebuilt.
n/uucp-1.07-x86_64-4.txz:  Rebuilt.
n/vlan-1.9-x86_64-4.txz:  Rebuilt.
n/vsftpd-3.0.3-x86_64-8.txz:  Rebuilt.
n/wget-1.21.1-x86_64-2.txz:  Rebuilt.
n/whois-5.5.7-x86_64-2.txz:  Rebuilt.
n/wireless_tools-30.pre9-x86_64-2.txz:  Rebuilt.
n/wpa_supplicant-2.9-x86_64-5.txz:  Rebuilt.
n/yptools-4.2.3-x86_64-2.txz:  Rebuilt.
n/ytalk-3.3.0-x86_64-5.txz:  Rebuilt.
n/zd1211-firmware-1.5-fw-3.txz:  Rebuilt.
t/fig2dev-3.2.8-x86_64-2.txz:  Rebuilt.
t/texlive-2020.200608-x86_64-3.txz:  Rebuilt.
t/xfig-3.2.8-x86_64-2.txz:  Rebuilt.
tcl/expect-5.45.4-x86_64-3.txz:  Rebuilt.
tcl/hfsutils-3.2.6-x86_64-7.txz:  Rebuilt.
tcl/tcl-8.6.11-x86_64-2.txz:  Rebuilt.
tcl/tclx-8.4.4-x86_64-2.txz:  Rebuilt.
tcl/tix-8.4.3-x86_64-5.txz:  Rebuilt.
tcl/tk-8.6.11.1-x86_64-2.txz:  Rebuilt.
Message édité par cycojesus le 23-01-2021 à 15:14:41
n°1459825
cycojesus
Mèo Lười
Posté le 23-01-2021 à 09:00:59  profilanswer
refait ALL THE THINGS!!! :o [2/2]
x/OpenCC-1.1.1-x86_64-2.txz:  Rebuilt.
x/anthy-9100h-x86_64-3.txz:  Rebuilt.
x/appres-1.0.5-x86_64-3.txz:  Rebuilt.
x/bdftopcf-1.1-x86_64-3.txz:  Rebuilt.
x/beforelight-1.0.5-x86_64-4.txz:  Rebuilt.
x/bitmap-1.0.9-x86_64-2.txz:  Rebuilt.
x/cldr-emoji-annotation-37.0_13.0_0_2-noarch-2.txz:  Rebuilt.
x/compiz-0.8.18-x86_64-2.txz:  Rebuilt.
x/dejavu-fonts-ttf-2.37-noarch-5.txz:  Rebuilt.
x/editres-1.0.7-x86_64-3.txz:  Rebuilt.
x/encodings-1.0.5-noarch-2.txz:  Rebuilt.
x/fcitx-4.2.9.8-x86_64-2.txz:  Rebuilt.
x/fcitx-anthy-0.2.3-x86_64-2.txz:  Rebuilt.
x/fcitx-configtool-0.4.10-x86_64-2.txz:  Rebuilt.
x/fcitx-hangul-0.3.1-x86_64-2.txz:  Rebuilt.
x/fcitx-kkc-0.1.4-x86_64-2.txz:  Rebuilt.
x/fcitx-libpinyin-0.5.3-x86_64-2.txz:  Rebuilt.
x/fcitx-m17n-0.2.4-x86_64-2.txz:  Rebuilt.
x/fcitx-qt5-1.2.5-x86_64-2.txz:  Rebuilt.
x/fcitx-sayura-0.1.2-x86_64-2.txz:  Rebuilt.
x/fcitx-table-extra-0.3.8-x86_64-2.txz:  Rebuilt.
x/fcitx-table-other-0.2.4-x86_64-2.txz:  Rebuilt.
x/fcitx-unikey-0.2.7-x86_64-2.txz:  Rebuilt.
x/font-adobe-100dpi-1.0.3-noarch-4.txz:  Rebuilt.
x/font-adobe-75dpi-1.0.3-noarch-4.txz:  Rebuilt.
x/font-adobe-utopia-100dpi-1.0.4-noarch-4.txz:  Rebuilt.
x/font-adobe-utopia-75dpi-1.0.4-noarch-4.txz:  Rebuilt.
x/font-adobe-utopia-type1-1.0.4-noarch-4.txz:  Rebuilt.
x/font-alias-1.0.4-noarch-2.txz:  Rebuilt.
x/font-arabic-misc-1.0.3-noarch-4.txz:  Rebuilt.
x/font-bh-100dpi-1.0.3-noarch-4.txz:  Rebuilt.
x/font-bh-75dpi-1.0.3-noarch-4.txz:  Rebuilt.
x/font-bh-lucidatypewriter-100dpi-1.0.3-noarch-4.txz:  Rebuilt.
x/font-bh-lucidatypewriter-75dpi-1.0.3-noarch-4.txz:  Rebuilt.
x/font-bh-ttf-1.0.3-noarch-4.txz:  Rebuilt.
x/font-bh-type1-1.0.3-noarch-4.txz:  Rebuilt.
x/font-bitstream-100dpi-1.0.3-noarch-4.txz:  Rebuilt.
x/font-bitstream-75dpi-1.0.3-noarch-4.txz:  Rebuilt.
x/font-bitstream-speedo-1.0.2-noarch-4.txz:  Rebuilt.
x/font-bitstream-type1-1.0.3-noarch-4.txz:  Rebuilt.
x/font-cronyx-cyrillic-1.0.3-noarch-4.txz:  Rebuilt.
x/font-cursor-misc-1.0.3-noarch-4.txz:  Rebuilt.
x/font-daewoo-misc-1.0.3-noarch-4.txz:  Rebuilt.
x/font-dec-misc-1.0.3-noarch-4.txz:  Rebuilt.
x/font-ibm-type1-1.0.3-noarch-4.txz:  Rebuilt.
x/font-isas-misc-1.0.3-noarch-4.txz:  Rebuilt.
x/font-jis-misc-1.0.3-noarch-4.txz:  Rebuilt.
x/font-micro-misc-1.0.3-noarch-4.txz:  Rebuilt.
x/font-misc-cyrillic-1.0.3-noarch-4.txz:  Rebuilt.
x/font-misc-ethiopic-1.0.4-noarch-2.txz:  Rebuilt.
x/font-misc-meltho-1.0.3-noarch-4.txz:  Rebuilt.
x/font-misc-misc-1.1.2-noarch-4.txz:  Rebuilt.
x/font-mutt-misc-1.0.3-noarch-4.txz:  Rebuilt.
x/font-schumacher-misc-1.1.2-noarch-4.txz:  Rebuilt.
x/font-screen-cyrillic-1.0.4-noarch-4.txz:  Rebuilt.
x/font-sony-misc-1.0.3-noarch-4.txz:  Rebuilt.
x/font-sun-misc-1.0.3-noarch-4.txz:  Rebuilt.
x/font-util-1.3.2-x86_64-2.txz:  Rebuilt.
x/font-winitzki-cyrillic-1.0.3-noarch-4.txz:  Rebuilt.
x/font-xfree86-type1-1.0.4-noarch-4.txz:  Rebuilt.
x/fontconfig-2.13.92-x86_64-2.txz:  Rebuilt.
x/fonttosfnt-1.2.1-x86_64-2.txz:  Rebuilt.
x/freeglut-3.2.1-x86_64-2.txz:  Rebuilt.
x/fslsfonts-1.0.5-x86_64-4.txz:  Rebuilt.
x/fstobdf-1.0.6-x86_64-4.txz:  Rebuilt.
x/gccmakedep-1.0.3-noarch-3.txz:  Rebuilt.
x/glew-2.2.0-x86_64-2.txz:  Rebuilt.
x/glu-9.0.1-x86_64-2.txz:  Rebuilt.
x/hack-fonts-ttf-3.003-noarch-2.txz:  Rebuilt.
x/ibus-1.5.23-x86_64-2.txz:  Rebuilt.
x/ibus-anthy-1.5.11-x86_64-2.txz:  Rebuilt.
x/ibus-hangul-1.5.4-x86_64-2.txz:  Rebuilt.
x/ibus-kkc-1.5.22-x86_64-2.txz:  Rebuilt.
x/ibus-libpinyin-1.11.1-x86_64-2.txz:  Rebuilt.
x/ibus-m17n-1.4.3-x86_64-2.txz:  Rebuilt.
x/ibus-table-1.12.3-x86_64-2.txz:  Rebuilt.
x/ibus-unikey-0.6.1-x86_64-2.txz:  Rebuilt.
x/iceauth-1.0.8-x86_64-3.txz:  Rebuilt.
x/ico-1.0.5-x86_64-3.txz:  Rebuilt.
x/igt-gpu-tools-1.25-x86_64-2.txz:  Rebuilt.
x/imake-1.0.8-x86_64-2.txz:  Rebuilt.
x/intel-vaapi-driver-2.4.1-x86_64-2.txz:  Rebuilt.
x/libFS-1.0.8-x86_64-2.txz:  Rebuilt.
x/libICE-1.0.10-x86_64-2.txz:  Rebuilt.
x/libSM-1.2.3-x86_64-2.txz:  Rebuilt.
x/libX11-1.7.0-x86_64-2.txz:  Rebuilt.
x/libXScrnSaver-1.2.3-x86_64-2.txz:  Rebuilt.
x/libXau-1.0.9-x86_64-2.txz:  Rebuilt.
x/libXaw-1.0.13-x86_64-3.txz:  Rebuilt.
x/libXaw3d-1.6.3-x86_64-2.txz:  Rebuilt.
x/libXaw3dXft-1.6.2h-x86_64-2.txz:  Rebuilt.
x/libXcm-0.5.4-x86_64-2.txz:  Rebuilt.
x/libXcomposite-0.4.5-x86_64-2.txz:  Rebuilt.
x/libXcursor-1.2.0-x86_64-2.txz:  Rebuilt.
x/libXdamage-1.1.5-x86_64-2.txz:  Rebuilt.
x/libXdmcp-1.1.3-x86_64-2.txz:  Rebuilt.
x/libXevie-1.0.3-x86_64-4.txz:  Rebuilt.
x/libXext-1.3.4-x86_64-2.txz:  Rebuilt.
x/libXfixes-5.0.3-x86_64-3.txz:  Rebuilt.
x/libXfont2-2.0.4-x86_64-2.txz:  Rebuilt.
x/libXfontcache-1.0.5-x86_64-4.txz:  Rebuilt.
x/libXft-2.3.3-x86_64-2.txz:  Rebuilt.
x/libXi-1.7.10-x86_64-2.txz:  Rebuilt.
x/libXinerama-1.1.4-x86_64-2.txz:  Rebuilt.
x/libXmu-1.1.3-x86_64-2.txz:  Rebuilt.
x/libXp-1.0.3-x86_64-4.txz:  Rebuilt.
x/libXpm-3.5.13-x86_64-2.txz:  Rebuilt.
x/libXpresent-1.0.0-x86_64-3.txz:  Rebuilt.
x/libXrandr-1.5.2-x86_64-2.txz:  Rebuilt.
x/libXrender-0.9.10-x86_64-3.txz:  Rebuilt.
x/libXres-1.2.0-x86_64-3.txz:  Rebuilt.
x/libXt-1.2.0-x86_64-2.txz:  Rebuilt.
x/libXtst-1.2.3-x86_64-3.txz:  Rebuilt.
x/libXv-1.0.11-x86_64-3.txz:  Rebuilt.
x/libXvMC-1.0.12-x86_64-4.txz:  Rebuilt.
x/libXxf86dga-1.1.5-x86_64-2.txz:  Rebuilt.
x/libXxf86misc-1.0.4-x86_64-2.txz:  Rebuilt.
x/libXxf86vm-1.1.4-x86_64-4.txz:  Rebuilt.
x/libdmx-1.1.4-x86_64-2.txz:  Rebuilt.
x/libdrm-2.4.104-x86_64-2.txz:  Rebuilt.
x/libepoxy-1.5.5-x86_64-2.txz:  Rebuilt.
x/liberation-fonts-ttf-2.1.2-noarch-2.txz:  Rebuilt.
x/libevdev-1.10.1-x86_64-2.txz:  Rebuilt.
x/libfontenc-1.1.4-x86_64-2.txz:  Rebuilt.
x/libgee-0.20.3-x86_64-2.txz:  Rebuilt.
x/libglvnd-1.3.2-x86_64-2.txz:  Rebuilt.
x/libhangul-0.1.0-x86_64-3.txz:  Rebuilt.
x/libinput-1.16.4-x86_64-2.txz:  Rebuilt.
x/libkkc-0.3.5-x86_64-2.txz:  Rebuilt.
x/libkkc-data-0.2.7-x86_64-2.txz:  Rebuilt.
x/libmypaint-1.6.1-x86_64-3.txz:  Rebuilt.
x/libpciaccess-0.16-x86_64-2.txz:  Rebuilt.
x/libpinyin-2.3.0-x86_64-2.txz:  Rebuilt.
x/libpthread-stubs-0.4-x86_64-4.txz:  Rebuilt.
x/libva-2.10.0-x86_64-2.txz:  Rebuilt.
x/libva-utils-2.10.0-x86_64-2.txz:  Rebuilt.
x/libvdpau-1.4-x86_64-2.txz:  Rebuilt.
x/libwacom-1.7-x86_64-2.txz:  Rebuilt.
x/libxcb-1.14-x86_64-2.txz:  Rebuilt.
x/libxkbfile-1.1.0-x86_64-2.txz:  Rebuilt.
x/libxshmfence-1.3-x86_64-3.txz:  Rebuilt.
x/listres-1.0.4-x86_64-3.txz:  Rebuilt.
x/lndir-1.0.3-x86_64-4.txz:  Rebuilt.
x/luit-1.1.1-x86_64-4.txz:  Rebuilt.
x/m17n-lib-1.8.0-x86_64-3.txz:  Rebuilt.
x/makedepend-1.0.6-x86_64-2.txz:  Rebuilt.
x/marisa-0.2.6-x86_64-3.txz:  Rebuilt.
x/mesa-20.3.3-x86_64-2.txz:  Rebuilt.
x/mkcomposecache-1.2.1-x86_64-4.txz:  Rebuilt.
x/mkfontscale-1.2.1-x86_64-3.txz:  Rebuilt.
x/motif-2.3.8-x86_64-4.txz:  Rebuilt.
x/mtdev-1.1.6-x86_64-2.txz:  Rebuilt.
x/mypaint-brushes-1.3.0-noarch-2.txz:  Rebuilt.
x/noto-cjk-fonts-ttf-2.001-noarch-2.txz:  Rebuilt.
x/noto-fonts-ttf-20171024-noarch-2.txz:  Rebuilt.
x/oclock-1.0.4-x86_64-3.txz:  Rebuilt.
x/pixman-0.40.0-x86_64-2.txz:  Rebuilt.
x/pyxdg-0.27-x86_64-3.txz:  Rebuilt.
x/rendercheck-1.5-x86_64-3.txz:  Rebuilt.
x/rgb-1.0.6-x86_64-4.txz:  Rebuilt.
x/sazanami-fonts-ttf-20040629-noarch-4.txz:  Rebuilt.
x/sessreg-1.1.2-x86_64-2.txz:  Rebuilt.
x/setxkbmap-1.3.2-x86_64-2.txz:  Rebuilt.
x/showfont-1.0.5-x86_64-4.txz:  Rebuilt.
x/sinhala_lklug-font-ttf-20060929-noarch-4.txz:  Rebuilt.
x/skkdic-20200128-noarch-2.txz:  Rebuilt.
x/smproxy-1.0.6-x86_64-3.txz:  Rebuilt.
x/tibmachuni-font-ttf-1.901b-noarch-4.txz:  Rebuilt.
x/transset-1.0.2-x86_64-3.txz:  Rebuilt.
x/ttf-indic-fonts-0.5.14-noarch-4.txz:  Rebuilt.
x/ttf-tlwg-0.7.2-noarch-2.txz:  Rebuilt.
x/twm-1.0.11-x86_64-2.txz:  Rebuilt.
x/urw-core35-fonts-otf-20170801_91edd6e_git-noarch-3.txz:  Rebuilt.
x/util-macros-1.19.2-noarch-3.txz:  Rebuilt.
x/viewres-1.0.6-x86_64-2.txz:  Rebuilt.
x/vulkan-sdk-1.2.141.0-x86_64-3.txz:  Rebuilt.
x/wayland-1.18.0-x86_64-2.txz:  Rebuilt.
x/wayland-protocols-1.20-noarch-2.txz:  Rebuilt.
x/wqy-zenhei-font-ttf-0.8.38_1-noarch-8.txz:  Rebuilt.
x/x11-skel-7.7-x86_64-7.txz:  Rebuilt.
x/x11perf-1.6.1-x86_64-2.txz:  Rebuilt.
x/xauth-1.1-x86_64-2.txz:  Rebuilt.
x/xbacklight-1.2.3-x86_64-2.txz:  Rebuilt.
x/xbiff-1.0.4-x86_64-2.txz:  Rebuilt.
x/xbitmaps-1.1.2-x86_64-3.txz:  Rebuilt.
x/xcalc-1.1.0-x86_64-2.txz:  Rebuilt.
x/xcb-proto-1.14.1-x86_64-3.txz:  Rebuilt.
x/xcb-util-0.4.0-x86_64-4.txz:  Rebuilt.
x/xcb-util-cursor-0.1.3-x86_64-3.txz:  Rebuilt.
x/xcb-util-errors-1.0-x86_64-3.txz:  Rebuilt.
x/xcb-util-image-0.4.0-x86_64-4.txz:  Rebuilt.
x/xcb-util-keysyms-0.4.0-x86_64-4.txz:  Rebuilt.
x/xcb-util-renderutil-0.3.9-x86_64-4.txz:  Rebuilt.
x/xcb-util-wm-0.4.1-x86_64-4.txz:  Rebuilt.
x/xclipboard-1.1.3-x86_64-4.txz:  Rebuilt.
x/xclock-1.0.9-x86_64-2.txz:  Rebuilt.
x/xcm-0.5.4-x86_64-3.txz:  Rebuilt.
x/xcmsdb-1.0.5-x86_64-3.txz:  Rebuilt.
x/xcompmgr-1.1.8-x86_64-2.txz:  Rebuilt.
x/xconsole-1.0.7-x86_64-3.txz:  Rebuilt.
x/xcursor-themes-1.0.6-noarch-2.txz:  Rebuilt.
x/xcursorgen-1.0.7-x86_64-2.txz:  Rebuilt.
x/xdbedizzy-1.1.0-x86_64-4.txz:  Rebuilt.
x/xdg-user-dirs-0.17-x86_64-2.txz:  Rebuilt.
x/xdg-utils-1.1.3-noarch-3.txz:  Rebuilt.
x/xditview-1.0.5-x86_64-2.txz:  Rebuilt.
x/xdm-1.1.11-x86_64-13.txz:  Rebuilt.
x/xdpyinfo-1.3.2-x86_64-3.txz:  Rebuilt.
x/xdriinfo-1.0.6-x86_64-3.txz:  Rebuilt.
x/xedit-1.2.2-x86_64-4.txz:  Rebuilt.
x/xev-1.2.4-x86_64-2.txz:  Rebuilt.
x/xeyes-1.1.2-x86_64-3.txz:  Rebuilt.
x/xf86-input-acecad-1.5.0-x86_64-13.txz:  Rebuilt.
x/xf86-input-evdev-2.10.6-x86_64-2.txz:  Rebuilt.
x/xf86-input-joystick-1.6.3-x86_64-4.txz:  Rebuilt.
x/xf86-input-keyboard-1.9.0-x86_64-4.txz:  Rebuilt.
x/xf86-input-libinput-0.30.0-x86_64-2.txz:  Rebuilt.
x/xf86-input-mouse-1.9.3-x86_64-2.txz:  Rebuilt.
x/xf86-input-penmount-1.5.0-x86_64-13.txz:  Rebuilt.
x/xf86-input-synaptics-1.9.1-x86_64-2.txz:  Rebuilt.
x/xf86-input-vmmouse-13.1.0-x86_64-8.txz:  Rebuilt.
x/xf86-input-void-1.4.1-x86_64-2.txz:  Rebuilt.
x/xf86-input-wacom-0.39.0-x86_64-2.txz:  Rebuilt.
x/xf86-video-amdgpu-19.1.0-x86_64-2.txz:  Rebuilt.
x/xf86-video-apm-1.3.0-x86_64-2.txz:  Rebuilt.
x/xf86-video-ark-0.7.5-x86_64-12.txz:  Rebuilt.
x/xf86-video-ast-1.1.5-x86_64-6.txz:  Rebuilt.
x/xf86-video-ati-19.1.0-x86_64-2.txz:  Rebuilt.
x/xf86-video-chips-1.4.0-x86_64-2.txz:  Rebuilt.
x/xf86-video-cirrus-1.5.3-x86_64-6.txz:  Rebuilt.
x/xf86-video-dummy-0.3.8-x86_64-4.txz:  Rebuilt.
x/xf86-video-glint-1.2.9-x86_64-4.txz:  Rebuilt.
x/xf86-video-i128-1.4.0-x86_64-2.txz:  Rebuilt.
x/xf86-video-i740-1.4.0-x86_64-2.txz:  Rebuilt.
x/xf86-video-intel-20201215_a511f22c-x86_64-2.txz:  Rebuilt.
x/xf86-video-mach64-6.9.6-x86_64-2.txz:  Rebuilt.
x/xf86-video-mga-2.0.0-x86_64-2.txz:  Rebuilt.
x/xf86-video-neomagic-1.3.0-x86_64-2.txz:  Rebuilt.
x/xf86-video-nouveau-1.0.16-x86_64-2.txz:  Rebuilt.
x/xf86-video-nv-2.1.21-x86_64-4.txz:  Rebuilt.
x/xf86-video-openchrome-0.6.0-x86_64-4.txz:  Rebuilt.
x/xf86-video-r128-6.12.0-x86_64-2.txz:  Rebuilt.
x/xf86-video-rendition-4.2.7-x86_64-2.txz:  Rebuilt.
x/xf86-video-s3-0.7.0-x86_64-2.txz:  Rebuilt.
x/xf86-video-s3virge-1.11.0-x86_64-2.txz:  Rebuilt.
x/xf86-video-savage-20190128_8579718-x86_64-2.txz:  Rebuilt.
x/xf86-video-siliconmotion-1.7.9-x86_64-4.txz:  Rebuilt.
x/xf86-video-sis-0.12.0-x86_64-2.txz:  Rebuilt.
x/xf86-video-sisusb-0.9.7-x86_64-4.txz:  Rebuilt.
x/xf86-video-tdfx-1.5.0-x86_64-2.txz:  Rebuilt.
x/xf86-video-tga-1.2.2-x86_64-12.txz:  Rebuilt.
x/xf86-video-trident-1.3.8-x86_64-4.txz:  Rebuilt.
x/xf86-video-tseng-1.2.5-x86_64-12.txz:  Rebuilt.
x/xf86-video-v4l-0.3.0-x86_64-2.txz:  Rebuilt.
x/xf86-video-vboxvideo-1.0.0-x86_64-4.txz:  Rebuilt.
x/xf86-video-vesa-2.5.0-x86_64-2.txz:  Rebuilt.
x/xf86-video-vmware-13.3.0-x86_64-4.txz:  Rebuilt.
x/xf86-video-voodoo-1.2.5-x86_64-13.txz:  Rebuilt.
x/xf86dga-1.0.3-x86_64-4.txz:  Rebuilt.
x/xfd-1.1.3-x86_64-2.txz:  Rebuilt.
x/xfontsel-1.0.6-x86_64-3.txz:  Rebuilt.
x/xfs-1.2.0-x86_64-3.txz:  Rebuilt.
x/xfsinfo-1.0.6-x86_64-2.txz:  Rebuilt.
x/xgamma-1.0.6-x86_64-3.txz:  Rebuilt.
x/xgc-1.0.5-x86_64-3.txz:  Rebuilt.
x/xhost-1.0.8-x86_64-2.txz:  Rebuilt.
x/xinit-1.4.1-x86_64-3.txz:  Rebuilt.
x/xinput-1.6.3-x86_64-2.txz:  Rebuilt.
x/xisxwayland-1-x86_64-2.txz:  Rebuilt.
x/xkbcomp-1.4.4-x86_64-2.txz:  Rebuilt.
x/xkbevd-1.1.4-x86_64-3.txz:  Rebuilt.
x/xkbprint-1.0.5-x86_64-2.txz:  Rebuilt.
x/xkbutils-1.0.4-x86_64-4.txz:  Rebuilt.
x/xkeyboard-config-2.31-noarch-2.txz:  Rebuilt.
x/xkill-1.0.5-x86_64-3.txz:  Rebuilt.
x/xload-1.1.3-x86_64-3.txz:  Rebuilt.
x/xlogo-1.0.5-x86_64-2.txz:  Rebuilt.
x/xlsatoms-1.1.3-x86_64-2.txz:  Rebuilt.
x/xlsclients-1.1.4-x86_64-3.txz:  Rebuilt.
x/xlsfonts-1.0.6-x86_64-3.txz:  Rebuilt.
x/xmag-1.0.6-x86_64-3.txz:  Rebuilt.
x/xman-1.1.5-x86_64-2.txz:  Rebuilt.
x/xmessage-1.0.5-x86_64-3.txz:  Rebuilt.
x/xmh-1.0.3-x86_64-3.txz:  Rebuilt.
x/xmodmap-1.0.10-x86_64-2.txz:  Rebuilt.
x/xmore-1.0.3-x86_64-2.txz:  Rebuilt.
x/xorg-cf-files-1.0.6-x86_64-4.txz:  Rebuilt.
x/xorg-docs-1.7.1-noarch-3.txz:  Rebuilt.
x/xorg-server-1.20.10-x86_64-4.txz:  Rebuilt.
x/xorg-server-xephyr-1.20.10-x86_64-4.txz:  Rebuilt.
x/xorg-server-xnest-1.20.10-x86_64-4.txz:  Rebuilt.
x/xorg-server-xvfb-1.20.10-x86_64-4.txz:  Rebuilt.
x/xorg-server-xwayland-1.20.10-x86_64-4.txz:  Rebuilt.
x/xorg-sgml-doctools-1.11-x86_64-4.txz:  Rebuilt.
x/xorgproto-2020.1-x86_64-2.txz:  Rebuilt.
x/xpr-1.0.5-x86_64-3.txz:  Rebuilt.
x/xprop-1.2.5-x86_64-2.txz:  Rebuilt.
x/xpyb-1.3.1-x86_64-6.txz:  Rebuilt.
x/xrandr-1.5.1-x86_64-2.txz:  Rebuilt.
x/xrdb-1.2.0-x86_64-2.txz:  Rebuilt.
x/xrefresh-1.0.6-x86_64-3.txz:  Rebuilt.
x/xscope-1.4.1-x86_64-4.txz:  Rebuilt.
x/xset-1.2.4-x86_64-3.txz:  Rebuilt.
x/xsetroot-1.1.2-x86_64-3.txz:  Rebuilt.
x/xsm-1.0.4-x86_64-3.txz:  Rebuilt.
x/xstdcmap-1.0.4-x86_64-2.txz:  Rebuilt.
x/xterm-363-x86_64-2.txz:  Rebuilt.
x/xtrans-1.4.0-noarch-2.txz:  Rebuilt.
x/xvidtune-1.0.3-x86_64-4.txz:  Rebuilt.
x/xvinfo-1.1.4-x86_64-2.txz:  Rebuilt.
x/xwd-1.0.7-x86_64-3.txz:  Rebuilt.
x/xwininfo-1.1.5-x86_64-2.txz:  Rebuilt.
x/xwud-1.0.5-x86_64-3.txz:  Rebuilt.
xap/MPlayer-20200103-x86_64-3.txz:  Rebuilt.
xap/NetworkManager-openvpn-1.8.12-x86_64-2.txz:  Rebuilt.
xap/audacious-4.0.5-x86_64-2.txz:  Rebuilt.
xap/audacious-plugins-4.0.5-x86_64-2.txz:  Rebuilt.
xap/blackbox-0.76-x86_64-2.txz:  Rebuilt.
xap/blueman-2.1.4-x86_64-4.txz:  Rebuilt.
xap/ddd-3.3.12-x86_64-7.txz:  Rebuilt.
xap/easytag-2.4.3-x86_64-3.txz:  Rebuilt.
xap/electricsheep-20090306-x86_64-6.txz:  Rebuilt.
xap/ffmpegthumbnailer-2.2.2-x86_64-2.txz:  Rebuilt.
xap/fluxbox-1.3.7-x86_64-4.txz:  Rebuilt.
xap/fvwm-2.6.9-x86_64-3.txz:  Rebuilt.
xap/geeqie-1.6-x86_64-2.txz:  Rebuilt.
xap/gftp-2.0.19-x86_64-10.txz:  Rebuilt.
xap/gimp-2.10.22-x86_64-3.txz:  Rebuilt.
xap/gkrellm-2.3.11-x86_64-2.txz:  Rebuilt.
xap/gnuchess-6.2.7-x86_64-2.txz:  Rebuilt.
xap/gnuplot-5.4.1-x86_64-2.txz:  Rebuilt.
xap/gparted-1.1.0-x86_64-2.txz:  Rebuilt.
xap/gucharmap-12.0.1-x86_64-2.txz:  Rebuilt.
xap/gv-3.7.4-x86_64-4.txz:  Rebuilt.
xap/hexchat-2.14.3-x86_64-6.txz:  Rebuilt.
xap/libnma-1.8.30-x86_64-2.txz:  Rebuilt.
xap/network-manager-applet-1.18.0-x86_64-2.txz:  Rebuilt.
xap/pan-0.146-x86_64-3.txz:  Rebuilt.
xap/pavucontrol-4.0-x86_64-2.txz:  Rebuilt.
xap/pidgin-2.14.1-x86_64-3.txz:  Rebuilt.
xap/rdesktop-1.9.0-x86_64-3.txz:  Rebuilt.
xap/rxvt-unicode-9.22-x86_64-10.txz:  Rebuilt.
xap/sane-1.0.31-x86_64-2.txz:  Rebuilt.
xap/seyon-2.20c-x86_64-5.txz:  Rebuilt.
xap/ssr-0.4.2-x86_64-3.txz:  Rebuilt.
xap/vim-gvim-8.2.2323-x86_64-2.txz:  Rebuilt.
xap/windowmaker-0.95.9-x86_64-2.txz:  Rebuilt.
xap/x11-ssh-askpass-1.2.4.1-x86_64-4.txz:  Rebuilt.
xap/x3270-3.3.12ga7-x86_64-6.txz:  Rebuilt.
xap/xgames-0.3-x86_64-7.txz:  Rebuilt.
xap/xine-lib-1.2.11-x86_64-2.txz:  Rebuilt.
xap/xine-ui-0.99.12-x86_64-3.txz:  Rebuilt.
xap/xlockmore-5.66-x86_64-2.txz:  Rebuilt.
xap/xmms-1.2.11-x86_64-7.txz:  Rebuilt.
xap/xpaint-3.0.3-x86_64-2.txz:  Rebuilt.
xap/xpdf-4.02-x86_64-4.txz:  Rebuilt.
xap/xsane-0.999-x86_64-4.txz:  Rebuilt.
xap/xscreensaver-5.45-x86_64-3.txz:  Rebuilt.
xap/xsnow-3.2.0-x86_64-2.txz:  Rebuilt.
xfce/Greybird-3.22.14-noarch-2.txz:  Rebuilt.
xfce/elementary-xfce-0.15.1-x86_64-2.txz:  Rebuilt.
xfce/exo-4.16.0-x86_64-2.txz:  Rebuilt.
xfce/garcon-4.16.1-x86_64-2.txz:  Rebuilt.
xfce/libxfce4ui-4.16.0-x86_64-2.txz:  Rebuilt.
xfce/libxfce4util-4.16.0-x86_64-2.txz:  Rebuilt.
xfce/mousepad-0.5.1-x86_64-3.txz:  Rebuilt.
xfce/thunar-4.16.2-x86_64-2.txz:  Rebuilt.
xfce/thunar-volman-4.16.0-x86_64-2.txz:  Rebuilt.
xfce/tumbler-4.16.0-x86_64-2.txz:  Rebuilt.
xfce/xfce4-appfinder-4.16.1-x86_64-2.txz:  Rebuilt.
xfce/xfce4-clipman-plugin-1.6.1-x86_64-3.txz:  Rebuilt.
xfce/xfce4-dev-tools-4.16.0-x86_64-2.txz:  Rebuilt.
xfce/xfce4-notifyd-0.6.2-x86_64-3.txz:  Rebuilt.
xfce/xfce4-panel-4.16.0-x86_64-2.txz:  Rebuilt.
xfce/xfce4-panel-profiles-1.0.12-x86_64-2.txz:  Rebuilt.
xfce/xfce4-power-manager-4.16.0-x86_64-2.txz:  Rebuilt.
xfce/xfce4-pulseaudio-plugin-0.4.3-x86_64-3.txz:  Rebuilt.
xfce/xfce4-screensaver-4.16.0-x86_64-2.txz:  Rebuilt.
xfce/xfce4-screenshooter-1.9.8-x86_64-2.txz:  Rebuilt.
xfce/xfce4-session-4.16.0-x86_64-2.txz:  Rebuilt.
xfce/xfce4-settings-4.16.0-x86_64-2.txz:  Rebuilt.
xfce/xfce4-systemload-plugin-1.2.4-x86_64-3.txz:  Rebuilt.
xfce/xfce4-taskmanager-1.4.0-x86_64-2.txz:  Rebuilt.
xfce/xfce4-terminal-0.8.10-x86_64-2.txz:  Rebuilt.
xfce/xfce4-weather-plugin-0.10.2-x86_64-3.txz:  Rebuilt.
xfce/xfce4-whiskermenu-plugin-2.5.2-x86_64-2.txz:  Rebuilt.
xfce/xfconf-4.16.0-x86_64-2.txz:  Rebuilt.
xfce/xfdesktop-4.16.0-x86_64-2.txz:  Rebuilt.
xfce/xfwm4-4.16.1-x86_64-2.txz:  Rebuilt.
y/bsd-games-2.17-x86_64-2.txz:  Rebuilt.
y/nethack-3.6.6-x86_64-2.txz:  Rebuilt.
Chết rồi ! ✍ ⌥⌘ http://codeberg.org/gwh
n°1459847
cycojesus
Mèo Lười
Posté le 23-01-2021 à 22:55:43  profilanswer
des nouveaux trucs quand même aussi
Sat Jan 23 19:55:29 UTC 2021
a/kernel-generic-5.10.10-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.10.10-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.10.10-x86_64-1.txz:  Upgraded.
a/os-prober-1.78-x86_64-1.txz:  Upgraded.
ap/inxi-20210113_1e2d470c-noarch-1.txz:  Upgraded.
ap/mc-4.8.26-x86_64-1.txz:  Upgraded.
ap/sqlite-3.34.1-x86_64-1.txz:  Upgraded.
ap/vim-8.2.2394-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.10.10-x86-1.txz:  Upgraded.
d/parallel-20210122-noarch-1.txz:  Upgraded.
k/kernel-source-5.10.10-noarch-1.txz:  Upgraded.
l/gtk+2-2.24.33-x86_64-1.txz:  Upgraded.
l/mozilla-nss-3.61-x86_64-1.txz:  Upgraded.
l/pango-1.48.1-x86_64-1.txz:  Upgraded.
l/pipewire-0.3.20-x86_64-1.txz:  Upgraded.
l/vte-0.62.2-x86_64-1.txz:  Upgraded.
n/bind-9.16.11-x86_64-1.txz:  Upgraded.
n/libgcrypt-1.9.0-x86_64-1.txz:  Upgraded.
  Use blinding for ECDSA signing to mitigate a novel side-channel attack.
  Add mitigation against ECC timing attack.
  For more information, see:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-0495
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-13626
  (* Security fix *)
n/libmbim-1.24.6-x86_64-1.txz:  Upgraded.
n/mutt-2.0.5-x86_64-1.txz:  Upgraded.
n/pinentry-1.1.1-x86_64-1.txz:  Upgraded.
n/s-nail-14.9.21-x86_64-1.txz:  Upgraded.
xap/vim-gvim-8.2.2394-x86_64-1.txz:  Upgraded.
xap/xsnow-3.2.2-x86_64-1.txz:  Upgraded.
isolinux/initrd.img:  Rebuilt.
kernels/*:  Upgraded.
usb-and-pxe-installers/usbboot.img:  Rebuilt.
n°1459868
regdub
Posté le 24-01-2021 à 14:23:20  profilanswer
Environ 1H pour le mass upgrade  :D, sans le download :o
cycojesus a écrit :
Beta approaches. :-)
Good news.  :)
Legalize it @HFR
n°1459906
cycojesus
Mèo Lười
Posté le 25-01-2021 à 08:47:20  profilanswer
Mon Jan 25 01:07:00 UTC 2021
a/glibc-zoneinfo-2021a-noarch-1.txz:  Upgraded.
  This package provides the latest timezone updates.
ap/vorbis-tools-1.4.2-x86_64-1.txz:  Upgraded.
d/binutils-2.36-x86_64-1.txz:  Upgraded.
d/bison-3.7.5-x86_64-1.txz:  Upgraded.
d/oprofile-1.4.0-x86_64-4.txz:  Rebuilt.
d/perl-5.32.1-x86_64-1.txz:  Upgraded.
d/python-pip-21.0-x86_64-1.txz:  Upgraded.
d/python-setuptools-52.0.0-x86_64-1.txz:  Upgraded.
l/imagemagick-7.0.10_59-x86_64-1.txz:  Upgraded.
l/libsndfile-1.0.31-x86_64-1.txz:  Upgraded.
x/libXt-1.2.1-x86_64-1.txz:  Upgraded.
x/util-macros-1.19.3-noarch-1.txz:  Upgraded.
x/xf86-video-nouveau-1.0.17-x86_64-1.txz:  Upgraded.
xap/seamonkey-2.53.6-x86_64-1.txz:  Upgraded.
  This update contains security fixes and improvements.
    https://www.seamonkey-project.org/releases/seamonkey2.53.6
  (* Security fix *)
n°1459911
cycojesus
Mèo Lười
Posté le 25-01-2021 à 10:12:46  profilanswer
À peu près pareil ici sur le laptop du boulot
n°1459973
cycojesus
Mèo Lười
Posté le 26-01-2021 à 10:38:40  profilanswer
la poussière dans les coins [:curling]
Mon Jan 25 20:42:50 UTC 2021
a/openssl10-solibs-1.0.2u-x86_64-2.txz:  Removed.
d/make-4.3-x86_64-2.txz:  Rebuilt.
  We'll upgrade to make-4.3 again (with a few patches from Fedora) since this
  is now working with all the sources that we ship.
l/gst-plugins-base0-0.10.36-x86_64-4.txz:  Removed.
l/gst-plugins-good0-0.10.31-x86_64-4.txz:  Removed.
l/gstreamer0-0.10.36-x86_64-3.txz:  Removed.
l/libcap-2.47-x86_64-1.txz:  Upgraded.
l/libsamplerate-0.2.1-x86_64-1.txz:  Upgraded.
l/libvisual-plugins-0.4.0-x86_64-6.txz:  Rebuilt.
  Drop actor_gstreamer.so (requires gstreamer0).
l/mozjs78-78.7.0esr-x86_64-1.txz:  Upgraded.
l/talloc-2.3.2-x86_64-1.txz:  Upgraded.
n/NetworkManager-1.28.0-x86_64-4.txz:  Rebuilt.
  Rebuilt for ppp-2.4.9.
n/openssl10-1.0.2u-x86_64-2.txz:  Removed.
n/ppp-2.4.9-x86_64-1.txz:  Upgraded.
n/rp-pppoe-3.14-x86_64-3.txz:  Rebuilt.
x/ibus-libpinyin-1.12.0-x86_64-1.txz:  Upgraded.
x/ibus-table-1.12.4-x86_64-1.txz:  Upgraded.
x/libpinyin-2.6.0-x86_64-1.txz:  Upgraded.
xap/mozilla-firefox-78.7.0esr-x86_64-1.txz:  Upgraded.
  This release contains security fixes and improvements.
    https://www.mozilla.org/en-US/firefox/78.7.0/releasenotes/
  (* Security fix *)
xfce/xfce4-whiskermenu-plugin-2.5.3-x86_64-1.txz:  Upgraded.
n°1460001
cycojesus
Mèo Lười
Posté le 27-01-2021 à 10:01:58  profilanswer
Tue Jan 26 21:20:58 UTC 2021
ap/sudo-1.9.5p2-x86_64-1.txz:  Upgraded.
  When invoked as sudoedit, the same set of command line options
  are now accepted as for "sudo -e". The -H and -P options are
  now rejected for sudoedit and "sudo -e" which matches the sudo
  1.7 behavior. This is part of the fix for CVE-2021-3156.
  Fixed a potential buffer overflow when unescaping backslashes
  in the command's arguments. Normally, sudo escapes special
  characters when running a command via a shell (sudo -s or sudo
  -i). However, it was also possible to run sudoedit with the -s
  or -i flags in which case no escaping had actually been done,
  making a buffer overflow possible. This fixes CVE-2021-3156.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-3156
  (* Security fix *)
d/binutils-2.36-x86_64-2.txz:  Rebuilt.
  Revert commit d1bcae833b32f1408485ce69f844dcd7ded093a8:
  [PATCH] ELF: Don't generate unused section symbols
  This fixes building the kernel.
l/loudmouth-1.5.4-x86_64-1.txz:  Upgraded.
n/autofs-5.1.7-x86_64-1.txz:  Upgraded.
n/dnsmasq-2.84-x86_64-1.txz:  Upgraded.
n/tin-2.4.5-x86_64-1.txz:  Upgraded.
xap/gparted-1.2.0-x86_64-1.txz:  Upgraded.
xap/mozilla-thunderbird-78.7.0-x86_64-1.txz:  Upgraded.
    https://www.mozilla.org/en-US/thunderbird/78.7.0/releasenotes/
    https://www.mozilla.org/en-US/security/advisories/mfsa2021-05/
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-23953
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-23954
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-15685
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-26976
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-23960
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-23964
  (* Security fix *)
n°1460034
cycojesus
Mèo Lười
Posté le 27-01-2021 à 22:12:44  profilanswer
Wed Jan 27 20:44:08 UTC 2021
a/kernel-generic-5.10.11-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.10.11-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.10.11-x86_64-1.txz:  Upgraded.
a/libbytesize-2.5-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.10.11-x86-1.txz:  Upgraded.
k/kernel-source-5.10.11-noarch-1.txz:  Upgraded.
l/imagemagick-7.0.10_60-x86_64-1.txz:  Upgraded.
l/python-urllib3-1.26.3-x86_64-1.txz:  Upgraded.
n/samba-4.13.4-x86_64-1.txz:  Upgraded.
x/wayland-1.19.0-x86_64-1.txz:  Upgraded.
xfce/xfce4-panel-4.16.1-x86_64-1.txz:  Upgraded.
n°1460098
cycojesus
Mèo Lười
Posté le 29-01-2021 à 11:02:38  profilanswer
Thu Jan 28 21:08:13 UTC 2021
d/cmake-3.19.4-x86_64-1.txz:  Upgraded.
l/librsvg-2.50.3-x86_64-1.txz:  Upgraded.
l/parted-3.4-x86_64-1.txz:  Upgraded.
n/pam-krb5-4.9-x86_64-3.txz:  Rebuilt.
  Move module to /lib${LIBDIRSUFFIX}/security. Thanks to Heinz Wiesinger.
n°1460110
Col Hanzap​last
Jurassic geek. Vive le cobol !
Posté le 29-01-2021 à 15:20:36  profilanswer
Je viens de faire une MAJ générale de ma 14.1:
Code :
  1. slackpkg update
  2. slackpkg upgrade-all
  3. cd /
  4. lftp -c 'open http://slackware.com/~alien/multilib/ ; mirror -c -e 14.1'
  5. cd 14.1
  6. upgradepkg --reinstall --install-new *.t?z
  7. upgradepkg --install-new slackware64-compat32/*-compat32/*.t?z
  8.                   :::::::                      root@kobaia.free.fr
  9.             :::::::::::::::::::                -------------------
  10.          :::::::::::::::::::::::::             OS: Slackware 14.1 x86_64
  11.        ::::::::cllcccccllllllll::::::          Host: VirtualBox 1.2
  12.     :::::::::lc               dc:::::::        Kernel: 3.10.107
  13.    ::::::::cl   clllccllll    oc:::::::::      Uptime: 18 mins
  14.   :::::::::o   lc::::::::co   oc::::::::::     Packages: 1397
  15. ::::::::::o    cccclc:::::clcc::::::::::::    Shell: bash 4.2.53
  16. :::::::::::lc        cclccclc:::::::::::::    Resolution: 1920x1080
  17. ::::::::::::::lcclcc          lc::::::::::::   DE: Xfce
  18. ::::::::::cclcc:::::lccclc     oc:::::::::::   WM: Xfwm4
  19. ::::::::::o    l::::::::::l    lc:::::::::::   WM Theme: Default
  20. :::::cll:o     clcllcccll     o:::::::::::    Theme: GTK+ [GTK2], Adwaita [GTK3]
  21. :::::occ:o                  clc:::::::::::    Icons: Gnome [GTK2/3]
  22.   ::::ocl:ccslclccclclccclclc:::::::::::::     Terminal: xfce4-terminal
  23.    :::oclcccccccccccccllllllllllllll:::::      Terminal Font: Monospace 12
  24.     ::lcc1lcccccccccccccccccccccccco::::       CPU: Intel i5-2500K (1) @ 3.300GHz
  25.       ::::::::::::::::::::::::::::::::         GPU: VMware SVGA II Adapter
  26.         ::::::::::::::::::::::::::::           Memory: 254MiB / 3943MiB
  27.            ::::::::::::::::::::::
  28.                 ::::::::::::
Mais j'ai un problème avec l'application Filmulator qui permet de traiter les fichiers RAW d'appareils-photo.
bash-4.2# ./Filmulator_v0.11.0.AppImage
fuse: warning: library too old, some operations may not work
./Filmulator_v0.11.0.AppImage: /usr/lib64/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by ./Filmulator_v0.11.0.AppImage)
./Filmulator_v0.11.0.AppImage: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by ./Filmulator_v0.11.0.AppImage)
./Filmulator_v0.11.0.AppImage: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.20' not found (required by ./Filmulator_v0.11.0.AppImage)
./Filmulator_v0.11.0.AppImage: /usr/lib64/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by ./Filmulator_v0.11.0.AppImage)
./Filmulator_v0.11.0.AppImage: /usr/lib64/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /tmp/.mount_Filmul1ERYiM/usr/bin/../lib/libQt5Sql.so.5)
./Filmulator_v0.11.0.AppImage: /usr/lib64/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /tmp/.mount_Filmul1ERYiM/usr/bin/../lib/libQt5Widgets.so.5)
./Filmulator_v0.11.0.AppImage: /usr/lib64/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /tmp/.mount_Filmul1ERYiM/usr/bin/../lib/libQt5Quick.so.5)
./Filmulator_v0.11.0.AppImage: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.20' not found (required by /tmp/.mount_Filmul1ERYiM/usr/bin/../lib/libexiv2.so.14)
./Filmulator_v0.11.0.AppImage: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by /tmp/.mount_Filmul1ERYiM/usr/bin/../lib/libexiv2.so.14)
./Filmulator_v0.11.0.AppImage: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by /tmp/.mount_Filmul1ERYiM/usr/bin/../lib/liblensfun.so.2)
./Filmulator_v0.11.0.AppImage: /usr/lib64/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by /tmp/.mount_Filmul1ERYiM/usr/bin/../lib/librtprocess.so.0)
./Filmulator_v0.11.0.AppImage: /usr/lib64/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /tmp/.mount_Filmul1ERYiM/usr/bin/../lib/libQt5Gui.so.5)
./Filmulator_v0.11.0.AppImage: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.20' not found (required by /tmp/.mount_Filmul1ERYiM/usr/bin/../lib/libQt5Qml.so.5)
./Filmulator_v0.11.0.AppImage: /usr/lib64/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /tmp/.mount_Filmul1ERYiM/usr/bin/../lib/libQt5Qml.so.5)
./Filmulator_v0.11.0.AppImage: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by /tmp/.mount_Filmul1ERYiM/usr/bin/../lib/libQt5Core.so.5)
./Filmulator_v0.11.0.AppImage: /usr/lib64/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by /tmp/.mount_Filmul1ERYiM/usr/bin/../lib/libQt5Core.so.5)
./Filmulator_v0.11.0.AppImage: /usr/lib64/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /tmp/.mount_Filmul1ERYiM/usr/bin/../lib/libQt5Core.so.5)
./Filmulator_v0.11.0.AppImage: /usr/lib64/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /tmp/.mount_Filmul1ERYiM/usr/bin/../lib/libQt5QmlModels.so.5)
./Filmulator_v0.11.0.AppImage: /usr/lib64/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /tmp/.mount_Filmul1ERYiM/usr/bin/../lib/libQt5Network.so.5)
./Filmulator_v0.11.0.AppImage: /usr/lib64/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by /tmp/.mount_Filmul1ERYiM/usr/bin/../lib/libicui18n.so.55)
./Filmulator_v0.11.0.AppImage: /usr/lib64/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by /tmp/.mount_Filmul1ERYiM/usr/bin/../lib/libicuuc.so.55)
Que faire ? Que fait la police ? Que fait le gouvernement ?
A+
Hanza
" Il n'y a aucune chance pour que l'iPhone s'attribue une part de marché significative. Aucune chance. " (Steve Ballmer 2007)
n°1460115
regdub
Posté le 29-01-2021 à 18:33:42  profilanswer
Je ne connais pas du tout AppImage.
C'est une régression ou un essai ?
Tu n'a pas commenté des lignes genre "ldconfig" dans les scripts de démarrage ?
T'attends le 3ème confinement pour upgrader ? :o
Message édité par regdub le 29-01-2021 à 18:34:22
Legalize it @HFR
n°1460144
cycojesus
Mèo Lười
Posté le 30-01-2021 à 14:53:39  profilanswer
Code :
  1. slackpkg update
  3. cd /
  5. cd 14.1
  28.                 ::::::::::::
A+
Hanza
Je dirais que ton fuse est trop vieux (comme la 14.1 :o .) T'as un fuse 2.8.5, -current a un fuse 2.9.9
C'est peut-être aussi une lib dont le fuse inclus dans l'Appimage dépends qui serais trop vieille.
Je juge pas (publiquement) mais utiliser une 14.1 en 2021 certes ça rime mais ça frise la perversité...
Sur ma -current ça marche ;)
À propos de -current :
Fri Jan 29 20:26:57 UTC 2021
a/e2fsprogs-1.45.7-x86_64-1.txz:  Upgraded.
n/libgcrypt-1.9.1-x86_64-1.txz:  Upgraded.
  This update fixes a serious security issue present only in libgcrypt-1.9.0.
  Everyone should be sure to update this package as soon as possible.
    https://lists.gnupg.org/pipermail/gnupg-announce/2021q1/000456.html
  (* Security fix *)
x/libwacom-1.8-x86_64-1.txz:  Upgraded.
x/mesa-20.3.4-x86_64-1.txz:  Upgraded.
xap/xpdf-4.03-x86_64-1.txz:  Upgraded.
Message édité par cycojesus le 30-01-2021 à 14:57:55
n°1460168
cycojesus
Mèo Lười
Posté le 31-01-2021 à 16:57:24  profilanswer
Sat Jan 30 21:55:04 UTC 2021
a/e2fsprogs-1.46.0-x86_64-1.txz:  Upgraded.
a/kernel-generic-5.10.12-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.10.12-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.10.12-x86_64-1.txz:  Upgraded.
a/sysklogd-2.2.1-x86_64-1.txz:  Upgraded.
d/binutils-2.35.2-x86_64-1.txz:  Upgraded.
  We're probably better off with this branch for now.
d/kernel-headers-5.10.12-x86-1.txz:  Upgraded.
d/oprofile-1.4.0-x86_64-5.txz:  Rebuilt.
  Recompiled against binutils-2.35.2.
k/kernel-source-5.10.12-noarch-1.txz:  Upgraded.
l/gd-2.3.1-x86_64-1.txz:  Upgraded.
l/libwebp-1.2.0-x86_64-1.txz:  Upgraded.
l/python-packaging-20.9-x86_64-1.txz:  Upgraded.
x/fcitx-libpinyin-0.5.4-x86_64-1.txz:  Upgraded.
n°1460170
Col Hanzap​last
Posté le 31-01-2021 à 18:43:00  profilanswer
Hello
AppImage correspond à l’exécutable plus les librairies nécessaires. J'aime bien ce concept. Je me demande si ce n'est pas comparable au .DMG sur Mac ?
J'ai vu que quand on boote sur le DVD 14.2 il est possible de désinstaller tous les packages de la 14.1 et d'installer tous les nouveaux de la 14.2 après.
C'est comme une installation from scratch mais on ne formate pas le disque dur.
Le seul problème est que la liste des packages à désinstaller fait trois kilomètres et qu'il faut tous les cocher un par un !  :pt1cable:
Ceci dit je suis dans une machine virtuelle VirtualBox donc snapshot de sécurité et go...
Message édité par Col Hanzaplast le 31-01-2021 à 18:44:18
n°1460194
cycojesus
Mèo Lười
Posté le 01-02-2021 à 09:08:34  profilanswer
Mon Feb  1 03:14:27 UTC 2021
d/python-pip-21.0.1-x86_64-1.txz:  Upgraded.
e/emacs-27.1-x86_64-4.txz:  Rebuilt.
  Rebuilt using --with-pdumper=no and --with-dumping=unexec so that both
  emacs-27.1-no-x11 and emacs-27.1-with-x11 will work with the installed files.
  Thanks to Tonus.
extra/brltty/brltty-6.3-x86_64-1.txz:  Upgraded.
Sun Jan 31 20:25:39 UTC 2021
a/dosfstools-4.2-x86_64-1.txz:  Upgraded.
ap/xorriso-1.5.4-x86_64-1.txz:  Upgraded.
kde/calligraplan-3.3.0-x86_64-1.txz:  Upgraded.
kde/kid3-3.8.5-x86_64-1.txz:  Upgraded.
l/imagemagick-7.0.10_61-x86_64-1.txz:  Upgraded.
x/ibus-m17n-1.4.4-x86_64-1.txz:  Upgraded.
xfce/mousepad-0.5.2-x86_64-1.txz:  Upgraded.
n°1460195
cycojesus
Mèo Lười
Posté le 01-02-2021 à 09:26:04  profilanswer
Hello
Il y a aussi https://slackware.osuosl.org/slackw [...] PGRADE.TXT qui détaille la démarche de mise à jour. Good luck :jap:
n°1460199
kisscoolz
Posté le 01-02-2021 à 12:00:00  profilanswer
Oh pinaise le résistant  :o  :lol:
J'ai tenu avec 14.1 pendant longtemps et j'ai du me résoudre à passer à la 14.2 pour éviter toutes sortes de bricoles. Même la 14.2 commence à devenir juste petit à petit :/
Sinon pour le problème, apparemment ca va chercher des appels à des libs plus récentes je dirais.
$ grep 'libstdc++.so' /var/adm/packages/*
/var/adm/packages/gcc-g++-5.5.0-x86_64-1_slack14.2:usr/lib64/libstdc++.so.6.0.21
Peut être qu'en poussant le paquet gcc de la 14.2 ca peut aider (directement en installation ou après recompilation).
n°1460200
Col Hanzap​last
Posté le 01-02-2021 à 13:38:09  profilanswer
Nouvelles du front:
Boot sur le DVD 14.2
mount /dev/sda1 /mnt
pkgtool pour tout désinstaller
setup pour tout installer
Décrochage du DVD de la VM
Boot
Changement de 14.1 par 14.2 dans mon script de MAJ
mkdir /14.2
Lancement du script -> OK
Boot
Test de l'application Filmulator -> OK. Je ne sais pas si un binaire a été créé ?
De toutes façons l'appli est tellement lente qu'elle est difficilement utilisable.
Merci à tous.
https://i.postimg.cc/26MQ3m41/Slackware142.png
Message édité par Col Hanzaplast le 01-02-2021 à 13:48:26
n°1460230
cycojesus
Mèo Lười
Posté le 02-02-2021 à 09:24:43  profilanswer
Nouvelles du front:
Boot
mkdir /14.2
Boot
Merci à tous.
 [:d4buff] La démarche sera toute fraîche en tête pour la 15.0 alors :o
Mon Feb  1 21:53:09 UTC 2021
d/python-setuptools-53.0.0-x86_64-1.txz:  Upgraded.
kde/digikam-7.1.0-x86_64-3.txz:  Rebuilt.
  Recompiled against imagemagick-7.0.10_61.
kde/okteta-0.26.5-x86_64-1.txz:  Upgraded.
l/dvdauthor-0.7.2-x86_64-3.txz:  Rebuilt.
x/libevdev-1.11.0-x86_64-1.txz:  Upgraded.
xap/xine-lib-1.2.11-x86_64-3.txz:  Rebuilt.
n°1460291
cycojesus
Mèo Lười
Posté le 03-02-2021 à 11:28:59  profilanswer
Tue Feb  2 20:16:43 UTC 2021
a/hwdata-0.344-noarch-1.txz:  Upgraded.
kde/calligra-3.2.1-x86_64-4.txz:  Rebuilt.
  Recompiled against poppler-21.02.0.
  Patched to fix blank screen when starting calligragemini.
  Thanks to PiterPunk.
kde/cantor-20.12.1-x86_64-3.txz:  Rebuilt.
kde/kdev-php-5.6.2-x86_64-1.txz:  Upgraded.
kde/kdev-python-5.6.2-x86_64-1.txz:  Upgraded.
kde/kdevelop-5.6.2-x86_64-1.txz:  Upgraded.
kde/kfilemetadata-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kile-2.9.93-x86_64-4.txz:  Rebuilt.
kde/kitinerary-20.12.1-x86_64-3.txz:  Rebuilt.
kde/krita-4.4.2-x86_64-2.txz:  Rebuilt.
kde/okular-20.12.1-x86_64-3.txz:  Rebuilt.
l/gamin-0.1.10-x86_64-8.txz:  Rebuilt.
  Patched to poll files on NFSv4 filesystems. Thanks to Stuart Winter.
l/poppler-21.02.0-x86_64-1.txz:  Upgraded.
  Shared library .so-version bump.
n/krb5-1.19-x86_64-1.txz:  Upgraded.
n/nghttp2-1.43.0-x86_64-1.txz:  Upgraded.
n/samba-4.13.4-x86_64-2.txz:  Rebuilt.
  Recompiled against krb5-1.19 to fix libkrb5samba-samba4.so which had an
  undefined symbol after krb5-1.19 dropped it. Upstream krb5 says that the
  function in question was never shipped in any header and wasn't intended
  to be part of any public interface.
n°1460373
Col Hanzap​last
Posté le 04-02-2021 à 15:59:15  profilanswer
J'ai voulu faire une MAJ:
slackpkg update -> OK.
slackpkg upgrade-all -> Tous les packages sont déjà en cache ? Bizarre.
cd / ; lftp -c 'open http://slackware.com/~alien/multilib/ ; mirror -c -e 14.2' -> Erreur partout, gpt ou gpg ou gpd, me rappelle plus...
reboot -> OK
Login/passwd OK mais le shell 4.1.14 boucle sur la demande. Impossible de se connecter.
Retour sans dommage en 14.1 possible car snapshot VM mais j'aimerais bien comprendre ?
n°1460397
cycojesus
Mèo Lười
Posté le 05-02-2021 à 09:19:31  profilanswer
Fri Feb  5 00:57:05 UTC 2021
a/kernel-generic-5.10.13-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.10.13-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.10.13-x86_64-1.txz:  Upgraded.
a/ncompress-5.0-x86_64-1.txz:  Upgraded.
ap/vim-8.2.2461-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.10.13-x86-1.txz:  Upgraded.
d/mercurial-5.7-x86_64-1.txz:  Upgraded.
k/kernel-source-5.10.13-noarch-1.txz:  Upgraded.
kde/akonadi-20.12.2-x86_64-1.txz:  Upgraded.
kde/akonadi-calendar-20.12.2-x86_64-1.txz:  Upgraded.
kde/akonadi-calendar-tools-20.12.2-x86_64-1.txz:  Upgraded.
kde/akonadi-contacts-20.12.2-x86_64-1.txz:  Upgraded.
kde/akonadi-import-wizard-20.12.2-x86_64-1.txz:  Upgraded.
kde/akonadi-mime-20.12.2-x86_64-1.txz:  Upgraded.
kde/akonadi-notes-20.12.2-x86_64-1.txz:  Upgraded.
kde/akonadi-search-20.12.2-x86_64-1.txz:  Upgraded.
kde/akonadiconsole-20.12.2-x86_64-1.txz:  Upgraded.
kde/akregator-20.12.2-x86_64-1.txz:  Upgraded.
kde/analitza-20.12.2-x86_64-1.txz:  Upgraded.
kde/ark-20.12.2-x86_64-1.txz:  Upgraded.
kde/artikulate-20.12.2-x86_64-1.txz:  Upgraded.
kde/audiocd-kio-20.12.2-x86_64-1.txz:  Upgraded.
kde/baloo-widgets-20.12.2-x86_64-1.txz:  Upgraded.
kde/blinken-20.12.2-x86_64-1.txz:  Upgraded.
kde/bomber-20.12.2-x86_64-1.txz:  Upgraded.
kde/bovo-20.12.2-x86_64-1.txz:  Upgraded.
kde/calendarsupport-20.12.2-x86_64-1.txz:  Upgraded.
kde/cantor-20.12.2-x86_64-1.txz:  Upgraded.
kde/cervisia-20.12.2-x86_64-1.txz:  Upgraded.
kde/dolphin-20.12.2-x86_64-1.txz:  Upgraded.
kde/dolphin-plugins-20.12.2-x86_64-1.txz:  Upgraded.
kde/dragon-20.12.2-x86_64-1.txz:  Upgraded.
kde/elisa-20.12.2-x86_64-1.txz:  Upgraded.
kde/eventviews-20.12.2-x86_64-1.txz:  Upgraded.
kde/ffmpegthumbs-20.12.2-x86_64-1.txz:  Upgraded.
kde/filelight-20.12.2-x86_64-1.txz:  Upgraded.
kde/granatier-20.12.2-x86_64-1.txz:  Upgraded.
kde/grantlee-editor-20.12.2-x86_64-1.txz:  Upgraded.
kde/grantleetheme-20.12.2-x86_64-1.txz:  Upgraded.
kde/gwenview-20.12.2-x86_64-1.txz:  Upgraded.
kde/incidenceeditor-20.12.2-x86_64-1.txz:  Upgraded.
kde/itinerary-20.12.2-x86_64-1.txz:  Upgraded.
kde/juk-20.12.2-x86_64-1.txz:  Upgraded.
kde/k3b-20.12.2-x86_64-1.txz:  Upgraded.
kde/kaddressbook-20.12.2-x86_64-1.txz:  Upgraded.
kde/kalarm-20.12.2-x86_64-1.txz:  Upgraded.
kde/kalarmcal-20.12.2-x86_64-1.txz:  Upgraded.
kde/kalgebra-20.12.2-x86_64-1.txz:  Upgraded.
kde/kalzium-20.12.2-x86_64-1.txz:  Upgraded.
kde/kamera-20.12.2-x86_64-1.txz:  Upgraded.
kde/kamoso-20.12.2-x86_64-1.txz:  Upgraded.
kde/kanagram-20.12.2-x86_64-1.txz:  Upgraded.
kde/kapman-20.12.2-x86_64-1.txz:  Upgraded.
kde/kapptemplate-20.12.2-x86_64-1.txz:  Upgraded.
kde/kate-20.12.2-x86_64-1.txz:  Upgraded.
kde/katomic-20.12.2-x86_64-1.txz:  Upgraded.
kde/kbackup-20.12.2-x86_64-1.txz:  Upgraded.
kde/kblackbox-20.12.2-x86_64-1.txz:  Upgraded.
kde/kblocks-20.12.2-x86_64-1.txz:  Upgraded.
kde/kbounce-20.12.2-x86_64-1.txz:  Upgraded.
kde/kbreakout-20.12.2-x86_64-1.txz:  Upgraded.
kde/kbruch-20.12.2-x86_64-1.txz:  Upgraded.
kde/kcachegrind-20.12.2-x86_64-1.txz:  Upgraded.
kde/kcalc-20.12.2-x86_64-1.txz:  Upgraded.
kde/kcalutils-20.12.2-x86_64-1.txz:  Upgraded.
kde/kcharselect-20.12.2-x86_64-1.txz:  Upgraded.
kde/kcolorchooser-20.12.2-x86_64-1.txz:  Upgraded.
kde/kcron-20.12.2-x86_64-1.txz:  Upgraded.
kde/kde-dev-scripts-20.12.2-x86_64-1.txz:  Upgraded.
kde/kde-dev-utils-20.12.2-x86_64-1.txz:  Upgraded.
kde/kdebugsettings-20.12.2-x86_64-1.txz:  Upgraded.
kde/kdeconnect-kde-20.12.2-x86_64-1.txz:  Upgraded.
kde/kdeedu-data-20.12.2-x86_64-1.txz:  Upgraded.
kde/kdegraphics-mobipocket-20.12.2-x86_64-1.txz:  Upgraded.
kde/kdegraphics-thumbnailers-20.12.2-x86_64-1.txz:  Upgraded.
kde/kdenetwork-filesharing-20.12.2-x86_64-1.txz:  Upgraded.
kde/kdenlive-20.12.2-x86_64-1.txz:  Upgraded.
kde/kdepim-addons-20.12.2-x86_64-1.txz:  Upgraded.
kde/kdepim-runtime-20.12.2-x86_64-1.txz:  Upgraded.
kde/kdesdk-kioslaves-20.12.2-x86_64-1.txz:  Upgraded.
kde/kdesdk-thumbnailers-20.12.2-x86_64-1.txz:  Upgraded.
kde/kdf-20.12.2-x86_64-1.txz:  Upgraded.
kde/kdialog-20.12.2-x86_64-1.txz:  Upgraded.
kde/kdiamond-20.12.2-x86_64-1.txz:  Upgraded.
kde/keditbookmarks-20.12.2-x86_64-1.txz:  Upgraded.
kde/kfind-20.12.2-x86_64-1.txz:  Upgraded.
kde/kfloppy-20.12.2-x86_64-1.txz:  Upgraded.
kde/kfourinline-20.12.2-x86_64-1.txz:  Upgraded.
kde/kgeography-20.12.2-x86_64-1.txz:  Upgraded.
kde/kget-20.12.2-x86_64-1.txz:  Upgraded.
kde/kgoldrunner-20.12.2-x86_64-1.txz:  Upgraded.
kde/kgpg-20.12.2-x86_64-1.txz:  Upgraded.
kde/khangman-20.12.2-x86_64-1.txz:  Upgraded.
kde/khelpcenter-20.12.2-x86_64-1.txz:  Upgraded.
kde/kidentitymanagement-20.12.2-x86_64-1.txz:  Upgraded.
kde/kig-20.12.2-x86_64-1.txz:  Upgraded.
kde/kigo-20.12.2-x86_64-1.txz:  Upgraded.
kde/killbots-20.12.2-x86_64-1.txz:  Upgraded.
kde/kimagemapeditor-20.12.2-x86_64-1.txz:  Upgraded.
kde/kimap-20.12.2-x86_64-1.txz:  Upgraded.
kde/kio-extras-20.12.2-x86_64-1.txz:  Upgraded.
kde/kio-gdrive-20.12.2-x86_64-1.txz:  Upgraded.
kde/kipi-plugins-20.12.2-x86_64-1.txz:  Upgraded.
kde/kirigami-gallery-20.12.2-x86_64-1.txz:  Upgraded.
kde/kiriki-20.12.2-x86_64-1.txz:  Upgraded.
kde/kiten-20.12.2-x86_64-1.txz:  Upgraded.
kde/kitinerary-20.12.2-x86_64-1.txz:  Upgraded.
kde/kjumpingcube-20.12.2-x86_64-1.txz:  Upgraded.
kde/kldap-20.12.2-x86_64-1.txz:  Upgraded.
kde/kleopatra-20.12.2-x86_64-1.txz:  Upgraded.
kde/klickety-20.12.2-x86_64-1.txz:  Upgraded.
kde/klines-20.12.2-x86_64-1.txz:  Upgraded.
kde/kmag-20.12.2-x86_64-1.txz:  Upgraded.
kde/kmahjongg-20.12.2-x86_64-1.txz:  Upgraded.
kde/kmail-20.12.2-x86_64-1.txz:  Upgraded.
kde/kmail-account-wizard-20.12.2-x86_64-1.txz:  Upgraded.
kde/kmailtransport-20.12.2-x86_64-1.txz:  Upgraded.
kde/kmbox-20.12.2-x86_64-1.txz:  Upgraded.
kde/kmime-20.12.2-x86_64-1.txz:  Upgraded.
kde/kmines-20.12.2-x86_64-1.txz:  Upgraded.
kde/kmix-20.12.2-x86_64-1.txz:  Upgraded.
kde/kmousetool-20.12.2-x86_64-1.txz:  Upgraded.
kde/kmouth-20.12.2-x86_64-1.txz:  Upgraded.
kde/kmplot-20.12.2-x86_64-1.txz:  Upgraded.
kde/knavalbattle-20.12.2-x86_64-1.txz:  Upgraded.
kde/knetwalk-20.12.2-x86_64-1.txz:  Upgraded.
kde/knights-20.12.2-x86_64-1.txz:  Upgraded.
kde/knotes-20.12.2-x86_64-1.txz:  Upgraded.
kde/kolf-20.12.2-x86_64-1.txz:  Upgraded.
kde/kollision-20.12.2-x86_64-1.txz:  Upgraded.
kde/kolourpaint-20.12.2-x86_64-1.txz:  Upgraded.
kde/kompare-20.12.2-x86_64-1.txz:  Upgraded.
kde/konqueror-20.12.2-x86_64-1.txz:  Upgraded.
kde/konquest-20.12.2-x86_64-1.txz:  Upgraded.
kde/konsole-20.12.2-x86_64-1.txz:  Upgraded.
kde/kontact-20.12.2-x86_64-1.txz:  Upgraded.
kde/kontactinterface-20.12.2-x86_64-1.txz:  Upgraded.
kde/kontrast-20.12.2-x86_64-1.txz:  Upgraded.
kde/konversation-20.12.2-x86_64-1.txz:  Upgraded.
kde/kopete-20.12.2-x86_64-1.txz:  Upgraded.
kde/korganizer-20.12.2-x86_64-1.txz:  Upgraded.
kde/kosmindoormap-20.12.2-x86_64-1.txz:  Upgraded.
kde/kpat-20.12.2-x86_64-1.txz:  Upgraded.
kde/kpimtextedit-20.12.2-x86_64-1.txz:  Upgraded.
kde/kpkpass-20.12.2-x86_64-1.txz:  Upgraded.
kde/kpmcore-20.12.2-x86_64-1.txz:  Upgraded.
kde/kpublictransport-20.12.2-x86_64-1.txz:  Upgraded.
kde/kqtquickcharts-20.12.2-x86_64-1.txz:  Upgraded.
kde/krdc-20.12.2-x86_64-1.txz:  Upgraded.
kde/kreversi-20.12.2-x86_64-1.txz:  Upgraded.
kde/krfb-20.12.2-x86_64-1.txz:  Upgraded.
kde/kross-interpreters-20.12.2-x86_64-1.txz:  Upgraded.
kde/kruler-20.12.2-x86_64-1.txz:  Upgraded.
kde/kshisen-20.12.2-x86_64-1.txz:  Upgraded.
kde/ksirk-20.12.2-x86_64-1.txz:  Upgraded.
kde/ksmtp-20.12.2-x86_64-1.txz:  Upgraded.
kde/ksnakeduel-20.12.2-x86_64-1.txz:  Upgraded.
kde/kspaceduel-20.12.2-x86_64-1.txz:  Upgraded.
kde/ksquares-20.12.2-x86_64-1.txz:  Upgraded.
kde/ksudoku-20.12.2-x86_64-1.txz:  Upgraded.
kde/ksystemlog-20.12.2-x86_64-1.txz:  Upgraded.
kde/kteatime-20.12.2-x86_64-1.txz:  Upgraded.
kde/ktimer-20.12.2-x86_64-1.txz:  Upgraded.
kde/ktnef-20.12.2-x86_64-1.txz:  Upgraded.
kde/ktorrent-20.12.2-x86_64-1.txz:  Upgraded.
kde/ktouch-20.12.2-x86_64-1.txz:  Upgraded.
kde/kturtle-20.12.2-x86_64-1.txz:  Upgraded.
kde/kubrick-20.12.2-x86_64-1.txz:  Upgraded.
kde/kwalletmanager-20.12.2-x86_64-1.txz:  Upgraded.
kde/kwave-20.12.2-x86_64-1.txz:  Upgraded.
kde/kwordquiz-20.12.2-x86_64-1.txz:  Upgraded.
kde/libgravatar-20.12.2-x86_64-1.txz:  Upgraded.
kde/libkcddb-20.12.2-x86_64-1.txz:  Upgraded.
kde/libkcompactdisc-20.12.2-x86_64-1.txz:  Upgraded.
kde/libkdcraw-20.12.2-x86_64-1.txz:  Upgraded.
kde/libkdegames-20.12.2-x86_64-1.txz:  Upgraded.
kde/libkdepim-20.12.2-x86_64-1.txz:  Upgraded.
kde/libkeduvocdocument-20.12.2-x86_64-1.txz:  Upgraded.
kde/libkexiv2-20.12.2-x86_64-1.txz:  Upgraded.
kde/libkgapi-20.12.2-x86_64-1.txz:  Upgraded.
kde/libkipi-20.12.2-x86_64-1.txz:  Upgraded.
kde/libkleo-20.12.2-x86_64-1.txz:  Upgraded.
kde/libkmahjongg-20.12.2-x86_64-1.txz:  Upgraded.
kde/libkomparediff2-20.12.2-x86_64-1.txz:  Upgraded.
kde/libksane-20.12.2-x86_64-1.txz:  Upgraded.
kde/libksieve-20.12.2-x86_64-1.txz:  Upgraded.
kde/libktorrent-20.12.2-x86_64-1.txz:  Upgraded.
kde/lokalize-20.12.2-x86_64-1.txz:  Upgraded.
kde/lskat-20.12.2-x86_64-1.txz:  Upgraded.
kde/mailcommon-20.12.2-x86_64-1.txz:  Upgraded.
kde/mailimporter-20.12.2-x86_64-1.txz:  Upgraded.
kde/marble-20.12.2-x86_64-1.txz:  Upgraded.
kde/markdownpart-20.12.2-x86_64-1.txz:  Upgraded.
kde/mbox-importer-20.12.2-x86_64-1.txz:  Upgraded.
kde/messagelib-20.12.2-x86_64-1.txz:  Upgraded.
kde/minuet-20.12.2-x86_64-1.txz:  Upgraded.
kde/okular-20.12.2-x86_64-1.txz:  Upgraded.
kde/palapeli-20.12.2-x86_64-1.txz:  Upgraded.
kde/parley-20.12.2-x86_64-1.txz:  Upgraded.
kde/partitionmanager-20.12.2-x86_64-1.txz:  Upgraded.
kde/picmi-20.12.2-x86_64-1.txz:  Upgraded.
kde/pim-data-exporter-20.12.2-x86_64-1.txz:  Upgraded.
kde/pim-sieve-editor-20.12.2-x86_64-1.txz:  Upgraded.
kde/pimcommon-20.12.2-x86_64-1.txz:  Upgraded.
kde/poxml-20.12.2-x86_64-1.txz:  Upgraded.
kde/print-manager-20.12.2-x86_64-1.txz:  Upgraded.
kde/rocs-20.12.2-x86_64-1.txz:  Upgraded.
kde/spectacle-20.12.2-x86_64-1.txz:  Upgraded.
kde/step-20.12.2-x86_64-1.txz:  Upgraded.
kde/svgpart-20.12.2-x86_64-1.txz:  Upgraded.
kde/sweeper-20.12.2-x86_64-1.txz:  Upgraded.
kde/umbrello-20.12.2-x86_64-1.txz:  Upgraded.
kde/yakuake-20.12.2-x86_64-1.txz:  Upgraded.
kde/zeroconf-ioslave-20.12.2-x86_64-1.txz:  Upgraded.
l/glib2-2.66.5-x86_64-1.txz:  Upgraded.
l/libpcap-1.10.0-x86_64-1.txz:  Upgraded.
l/pipewire-0.3.21-x86_64-1.txz:  Upgraded.
l/qca-2.3.2-x86_64-1.txz:  Upgraded.
n/curl-7.75.0-x86_64-1.txz:  Upgraded.
n/iputils-20210202-x86_64-1.txz:  Upgraded.
n/php-7.4.15-x86_64-1.txz:  Upgraded.
n/tcpdump-4.99.0-x86_64-1.txz:  Upgraded.
x/xterm-364-x86_64-1.txz:  Upgraded.
xap/audacious-4.1-x86_64-1.txz:  Upgraded.
xap/audacious-plugins-4.1-x86_64-1.txz:  Upgraded.
xap/network-manager-applet-1.20.0-x86_64-1.txz:  Upgraded.
xap/vim-gvim-8.2.2461-x86_64-1.txz:  Upgraded.
n°1460398
cycojesus
Mèo Lười
Posté le 05-02-2021 à 09:22:00  profilanswer
reboot -> OK
Je vois pas bien le rapport entre les packages en cache et des erreurs lftp.
Disque plein ? Disque corrompu ?
Tu avais rebooté avant sans problème ?
n°1460438
cycojesus
Mèo Lười
Posté le 06-02-2021 à 10:48:49  profilanswer
Fri Feb  5 21:18:59 UTC 2021
a/udisks2-2.9.2-x86_64-1.txz:  Upgraded.
d/ccache-4.2-x86_64-1.txz:  Upgraded.
l/fuse3-3.10.2-x86_64-1.txz:  Upgraded.
l/glib2-2.66.6-x86_64-1.txz:  Upgraded.
l/libcap-2.48-x86_64-1.txz:  Upgraded.
l/lmdb-0.9.28-x86_64-1.txz:  Upgraded.
l/mozjs78-78.7.1esr-x86_64-1.txz:  Upgraded.
l/openal-soft-1.21.1-x86_64-1.txz:  Upgraded.
x/xterm-365-x86_64-1.txz:  Upgraded.
xap/mozilla-firefox-78.7.1esr-x86_64-1.txz:  Upgraded.
  This release contains a security fix.
    https://www.mozilla.org/en-US/firefox/78.7.1/releasenotes/
    https://www.mozilla.org/en-US/security/advisories/mfsa2021-06/#MOZ-2021-0001
  (* Security fix *)
xap/mozilla-thunderbird-78.7.1-x86_64-1.txz:  Upgraded.
  This is a bugfix release.
    https://www.mozilla.org/en-US/thunderbird/78.7.1/releasenotes/
n°1460515
cycojesus
Mèo Lười
Posté le 08-02-2021 à 12:50:25  profilanswer
Mon Feb  8 05:13:26 UTC 2021
a/aaa_elflibs-15.0-x86_64-30.txz:  Removed.
  Renamed to aaa_libraries.
a/aaa_glibc-solibs-2.32-x86_64-2.txz:  Added.
  This package has been renamed from glibc-solibs, which helps avoid trouble
  if someone upgrades using "upgradepkg --install-new */*.txz" by upgrading
  this package before aaa_libraries. Otherwise, if aaa_libraries is upgraded
  first any libraries in it that are linked against a newer version of glibc
  than the one installed on the system would refuse to load.
a/aaa_libraries-15.0-x86_64-1.txz:  Added.
  This package has been renamed from aaa_elflibs to insure that it will come
  after aaa_glibc-solibs when upgraded in alphabetical order.
  Upgraded: libcap.so.2.48, libelf-0.183.so, libglib-2.0.so.0.6600.6,
  libgmodule-2.0.so.0.6600.6, libgobject-2.0.so.0.6600.6,
  libgthread-2.0.so.0.6600.6.
  Added: libtirpc.so.3.0.0.
a/btrfs-progs-5.10.1-x86_64-1.txz:  Upgraded.
a/glibc-solibs-2.32-x86_64-1.txz:  Removed.
  Renamed to aaa_glibc-solibs.
a/kernel-generic-5.10.14-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.10.14-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.10.14-x86_64-1.txz:  Upgraded.
ap/slackpkg-15.0-noarch-1.txz:  Upgraded.
  These are some of the important changes (see the ChangeLog for more):
  Note that this slackpkg release contains a backwards-incompatible change to
  the blacklisting syntax (e.g. glibc ---> glibc-*). This changes the prior
  behavior of the blacklist function; previously, adding "glibc" to the
  blacklist would cause glibc, glibc-profile, glibc-zoneinfo, et al to be
  ignored by slackpkg. The new behavior is that *only* the glibc package is
  ignored. If you want to blacklist all packages whose names begin with glibc,
  you would need to add "glibc.*" to the blacklist now. Also note that any
  special characters, e.g. "+", will need to be escaped in the blacklist file.
  To blacklist entire package sets, a trailing slash is now required: e.g. kde/
  Another backwards-incompatibility warning: check-updates will now return 1 if
  there are updates available - this will make it easier to use this feature
  with cron (thanks to Peter Hyman).
  Added support for Slackware-AArch64 (thanks to Stuart Winter).
  Added aaa_glibc-solibs and aaa_libraries to the "do these first" routine.
  Thanks to Robby Workman for the new slackpkg release!
ap/soma-3.3.7-noarch-1.txz:  Upgraded.
  Thanks to David Woodfall.
ap/xorriso-1.5.4.pl02-x86_64-1.txz:  Upgraded.
d/help2man-1.48.1-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.10.14-x86-1.txz:  Upgraded.
k/kernel-source-5.10.14-noarch-1.txz:  Upgraded.
l/elfutils-0.183-x86_64-1.txz:  Upgraded.
l/glibc-2.32-x86_64-2.txz:  Rebuilt.
l/glibc-i18n-2.32-x86_64-2.txz:  Rebuilt.
l/glibc-profile-2.32-x86_64-2.txz:  Rebuilt.
l/lcms2-2.12-x86_64-1.txz:  Upgraded.
l/libburn-1.5.4-x86_64-1.txz:  Upgraded.
x/xf86-input-wacom-0.40.0-x86_64-1.txz:  Upgraded.
n°1460614
cycojesus
Mèo Lười
Posté le 09-02-2021 à 21:59:51  profilanswer
Tue Feb  9 20:43:33 UTC 2021
a/exfatprogs-1.1.0-x86_64-1.txz:  Upgraded.
a/kernel-firmware-20210208_b79d239-noarch-1.txz:  Upgraded.
a/procps-ng-3.3.17-x86_64-1.txz:  Upgraded.
ap/man-db-2.9.4-x86_64-1.txz:  Upgraded.
ap/slackpkg-15.0-noarch-2.txz:  Rebuilt.
  Allow new-config after slackpkg upgrade itself. Thanks to PiterPUNK.
d/git-2.30.1-x86_64-1.txz:  Upgraded.
l/imagemagick-7.0.10_62-x86_64-1.txz:  Upgraded.
l/jasper-2.0.25-x86_64-1.txz:  Upgraded.
n/fetchmail-6.4.16-x86_64-1.txz:  Upgraded.
xfce/thunar-4.16.3-x86_64-1.txz:  Upgraded.
testing/packages/aaa_glibc-solibs-2.33-x86_64-1_testing.txz:  Added.
testing/packages/glibc-2.33-x86_64-1_testing.txz:  Added.
  This is here for some actual testing - don't go just jumping into this one
  all willy-nilly, especially if you're on 32-bit. The internal implementation
  of some glibc functions has changed in ways that can break sandboxes that
  restrict the allowable functions. So far this is known to affect
  qt5-webengine and openssl, and in the case of openssl upgrading to this
  version of glibc will lock out ssh access to the machine. I've seen one
  mention of the openssh issue online as a comment posted to LWN's article
  about the release of glibc-2.33. It says that a patch was submitted upstream,
  but I haven't been able to locate a copy yet.
  On the qt5 issue, alienBOB has given me a link to this patch:
  https://src.fedoraproject.org/rpms/qt5-qtwebengine/blob/09e1adb883639325aa8115dc1fc3e8f5088a2438/f/qtwebengine-everywhere-src-5.15.2-%231904652.patch
  If anyone has a fix for openssl on 32-bit, kindly post it to LQ.
testing/packages/glibc-i18n-2.33-x86_64-1_testing.txz:  Added.
testing/packages/glibc-profile-2.33-x86_64-1_testing.txz:  Added.
n°1460678
cycojesus
Mèo Lười
Posté le 11-02-2021 à 09:54:23  profilanswer
Wed Feb 10 21:38:28 UTC 2021
a/e2fsprogs-1.46.1-x86_64-1.txz:  Upgraded.
a/eudev-3.2.10-x86_64-1.txz:  Upgraded.
a/kernel-generic-5.10.15-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.10.15-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.10.15-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.10.15-x86-1.txz:  Upgraded.
d/subversion-1.14.1-x86_64-1.txz:  Upgraded.
k/kernel-source-5.10.15-noarch-1.txz:  Upgraded.
l/graphene-1.10.4-x86_64-1.txz:  Upgraded.
l/json-glib-1.6.2-x86_64-1.txz:  Upgraded.
n°1460720
cycojesus
Mèo Lười
Posté le 12-02-2021 à 09:38:29  profilanswer
Thu Feb 11 20:13:26 UTC 2021
l/pango-1.48.2-x86_64-1.txz:  Upgraded.
x/xterm-366-x86_64-1.txz:  Upgraded.
xap/gftp-2.7.0b-x86_64-1.txz:  Upgraded.
n°1460723
Col Hanzap​last
Posté le 12-02-2021 à 10:57:02  profilanswer
Des nouvelles pour une éventuelle V15 ? Pourra-t-on migrer de 14 en 15 ?
n°1460725
regdub
Posté le 12-02-2021 à 13:50:49  profilanswer
Je pense que la Beta devrait arriver dans la semaine.
Pour la 2, oui, pas de souci.
Legalize it @HFR
n°1460749
cycojesus
Mèo Lười
Posté le 13-02-2021 à 13:59:57  profilanswer
Fri Feb 12 21:42:42 UTC 2021
a/inih-53-x86_64-1.txz:  Upgraded.
a/kernel-firmware-20210211_f7915a0-noarch-1.txz:  Upgraded.
a/util-linux-2.36.2-x86_64-1.txz:  Upgraded.
d/binutils-2.36.1-x86_64-1.txz:  Upgraded.
d/oprofile-1.4.0-x86_64-6.txz:  Rebuilt.
  Recompiled against binutils-2.36.1.
kde/digikam-7.1.0-x86_64-4.txz:  Rebuilt.
  Recompiled against imagemagick-7.0.10_62.
l/glib2-2.66.7-x86_64-1.txz:  Upgraded.
l/openexr-2.5.5-x86_64-1.txz:  Upgraded.
n°1460829
cycojesus
Mèo Lười
Posté le 15-02-2021 à 23:03:06  profilanswer
T'est assis ? ALPHA 1 (1/2)
Mon Feb 15 19:23:44 UTC 2021
Here we go again... upgraded to glibc-2.33 and one last mass rebuild for
Slackware 15.0. The only packages upgraded in this batch are glibc and the
kernels - everything else is just a rebuild against the new glibc. Not
rebuilt in this batch: devs (best to just leave this alone), glibc-zoneinfo,
kernel-firmware, rust, linux-faqs, linux-howtos, aspell-en, mozilla-firefox,
mozilla-thunderbird, and seamonkey. There's a new Rust compiler but Firefox
and Thunderbird will need to be patched to use it, so we'll hold off on
those until they're ready for the new Rust either with patches or new
upstream releases. Until we have that and a few more scheduled upgrades I'm
not quite ready to call this beta yet, but you can call it 15.0-alpha1. :-)
Cheers!
a/aaa_base-14.2-x86_64-7.txz:  Rebuilt.
a/aaa_glibc-solibs-2.33-x86_64-1.txz:  Upgraded.
a/aaa_libraries-15.0-x86_64-2.txz:  Rebuilt.
  Upgraded: libnsl-2.33.so, libglib-2.0.so.0.6600.7,
  libgmodule-2.0.so.0.6600.7, libgobject-2.0.so.0.6600.7,
  libgthread-2.0.so.0.6600.7.
a/aaa_terminfo-6.2_20201219-x86_64-4.txz:  Rebuilt.
a/acl-2.2.53-x86_64-3.txz:  Rebuilt.
a/acpid-2.0.32-x86_64-3.txz:  Rebuilt.
a/attr-2.4.48-x86_64-3.txz:  Rebuilt.
a/bash-5.1.004-x86_64-3.txz:  Rebuilt.
a/bin-11.1-x86_64-5.txz:  Rebuilt.
a/btrfs-progs-5.10.1-x86_64-2.txz:  Rebuilt.
a/bzip2-1.0.8-x86_64-3.txz:  Rebuilt.
a/coreutils-8.32-x86_64-3.txz:  Rebuilt.
a/cpio-2.13-x86_64-3.txz:  Rebuilt.
a/cpufrequtils-008-x86_64-4.txz:  Rebuilt.
a/cracklib-2.9.7-x86_64-3.txz:  Rebuilt.
a/cryptsetup-2.3.4-x86_64-3.txz:  Rebuilt.
a/dbus-1.12.20-x86_64-5.txz:  Rebuilt.
a/dcron-4.5-x86_64-11.txz:  Rebuilt.
a/dialog-1.3_20210117-x86_64-2.txz:  Rebuilt.
a/dosfstools-4.2-x86_64-2.txz:  Rebuilt.
a/e2fsprogs-1.46.1-x86_64-2.txz:  Rebuilt.
a/ed-1.17-x86_64-3.txz:  Rebuilt.
a/efibootmgr-20191011_e8ce9fe-x86_64-4.txz:  Rebuilt.
a/efivar-20191015_ca85d51-x86_64-3.txz:  Rebuilt.
a/elilo-3.16-x86_64-12.txz:  Rebuilt.
a/elogind-246.9.2-x86_64-3.txz:  Rebuilt.
a/elvis-2.2_0-x86_64-7.txz:  Rebuilt.
a/etc-15.0-x86_64-13.txz:  Rebuilt.
a/eudev-3.2.10-x86_64-2.txz:  Rebuilt.
a/exfatprogs-1.1.0-x86_64-2.txz:  Rebuilt.
a/f2fs-tools-1.14.0-x86_64-3.txz:  Rebuilt.
a/file-5.39-x86_64-3.txz:  Rebuilt.
a/findutils-4.8.0-x86_64-3.txz:  Rebuilt.
a/floppy-5.5-x86_64-4.txz:  Rebuilt.
a/gawk-5.1.0-x86_64-3.txz:  Rebuilt.
a/genpower-1.0.5-x86_64-5.txz:  Rebuilt.
a/gettext-0.21-x86_64-3.txz:  Rebuilt.
a/gpm-1.20.7-x86_64-9.txz:  Rebuilt.
a/gptfdisk-1.0.6-x86_64-3.txz:  Rebuilt.
a/grep-3.6-x86_64-3.txz:  Rebuilt.
a/grub-2.04-x86_64-3.txz:  Rebuilt.
a/gzip-1.10-x86_64-3.txz:  Rebuilt.
a/haveged-1.9.14-x86_64-3.txz:  Rebuilt.
a/hdparm-9.60-x86_64-3.txz:  Rebuilt.
a/hostname-3.23-x86_64-3.txz:  Rebuilt.
a/hwdata-0.344-noarch-2.txz:  Rebuilt.
a/infozip-6.0-x86_64-7.txz:  Rebuilt.
a/inih-53-x86_64-2.txz:  Rebuilt.
a/inotify-tools-3.20.11.0-x86_64-3.txz:  Rebuilt.
a/jfsutils-1.1.15-x86_64-4.txz:  Rebuilt.
a/kbd-1.15.3-x86_64-6.txz:  Rebuilt.
a/kernel-generic-5.10.16-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.10.16-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.10.16-x86_64-1.txz:  Upgraded.
a/kmod-28-x86_64-3.txz:  Rebuilt.
a/lbzip2-2.5-x86_64-4.txz:  Rebuilt.
a/less-563-x86_64-3.txz:  Rebuilt.
a/lhasa-0.3.1-x86_64-3.txz:  Rebuilt.
a/libblockdev-2.25-x86_64-3.txz:  Rebuilt.
a/libbytesize-2.5-x86_64-2.txz:  Rebuilt.
a/libcgroup-0.41-x86_64-9.txz:  Rebuilt.
a/libgudev-234-x86_64-3.txz:  Rebuilt.
a/libpwquality-1.4.4-x86_64-4.txz:  Rebuilt.
a/lilo-24.2-x86_64-12.txz:  Rebuilt.
a/logrotate-3.18.0-x86_64-3.txz:  Rebuilt.
a/lrzip-0.631-x86_64-4.txz:  Rebuilt.
a/lvm2-2.03.11-x86_64-3.txz:  Rebuilt.
a/lzip-1.22-x86_64-3.txz:  Rebuilt.
a/lzlib-1.12-x86_64-3.txz:  Rebuilt.
a/mcelog-175-x86_64-3.txz:  Rebuilt.
a/mdadm-4.1-x86_64-3.txz:  Rebuilt.
a/minicom-2.8-x86_64-3.txz:  Rebuilt.
a/mkinitrd-1.4.11-x86_64-19.txz:  Rebuilt.
a/mlocate-0.26-x86_64-4.txz:  Rebuilt.
a/mt-st-1.4-x86_64-3.txz:  Rebuilt.
a/mtx-1.3.12-x86_64-4.txz:  Rebuilt.
a/ncompress-5.0-x86_64-2.txz:  Rebuilt.
a/ndctl-71.1-x86_64-4.txz:  Rebuilt.
a/ntfs-3g-2017.3.23-x86_64-4.txz:  Rebuilt.
a/nvi-1.81.6-x86_64-3.txz:  Rebuilt.
a/openssl-solibs-1.1.1i-x86_64-3.txz:  Rebuilt.
a/os-prober-1.78-x86_64-2.txz:  Rebuilt.
a/pam-1.5.1-x86_64-3.txz:  Rebuilt.
a/patch-2.7.6-x86_64-5.txz:  Rebuilt.
a/pciutils-3.7.0-x86_64-3.txz:  Rebuilt.
a/pcmciautils-018-x86_64-4.txz:  Rebuilt.
a/pkgtools-15.0-noarch-36.txz:  Rebuilt.
a/plzip-1.9-x86_64-3.txz:  Rebuilt.
a/procps-ng-3.3.17-x86_64-2.txz:  Rebuilt.
a/quota-4.06-x86_64-3.txz:  Rebuilt.
a/reiserfsprogs-3.6.27-x86_64-4.txz:  Rebuilt.
a/rpm2tgz-1.2.2-x86_64-4.txz:  Rebuilt.
a/sdparm-1.11-x86_64-3.txz:  Rebuilt.
a/sed-4.8-x86_64-3.txz:  Rebuilt.
a/shadow-4.8.1-x86_64-12.txz:  Rebuilt.
a/sharutils-4.15.2-x86_64-4.txz:  Rebuilt.
a/smartmontools-7.2-x86_64-3.txz:  Rebuilt.
a/splitvt-1.6.6-x86_64-5.txz:  Rebuilt.
a/sysfsutils-2.1.0-x86_64-4.txz:  Rebuilt.
a/sysklogd-2.2.1-x86_64-2.txz:  Rebuilt.
a/syslinux-4.07-x86_64-4.txz:  Rebuilt.
a/sysvinit-2.98-x86_64-3.txz:  Rebuilt.
a/sysvinit-functions-8.53-x86_64-5.txz:  Rebuilt.
a/sysvinit-scripts-2.1-noarch-39.txz:  Rebuilt.
a/tar-1.33-x86_64-3.txz:  Rebuilt.
a/tcsh-6.22.03-x86_64-3.txz:  Rebuilt.
a/time-1.9-x86_64-4.txz:  Rebuilt.
a/tree-1.8.0-x86_64-3.txz:  Rebuilt.
a/udisks-1.0.5-x86_64-8.txz:  Rebuilt.
a/udisks2-2.9.2-x86_64-2.txz:  Rebuilt.
a/unarj-265-x86_64-4.txz:  Rebuilt.
a/upower-0.99.11-x86_64-4.txz:  Rebuilt.
a/usb_modeswitch-2.6.1-x86_64-3.txz:  Rebuilt.
a/usbutils-013-x86_64-3.txz:  Rebuilt.
a/utempter-1.2.0-x86_64-3.txz:  Rebuilt.
a/util-linux-2.36.2-x86_64-2.txz:  Rebuilt.
a/volume_key-0.3.12-x86_64-3.txz:  Rebuilt.
a/which-2.21-x86_64-4.txz:  Rebuilt.
a/xfsprogs-5.10.0-x86_64-3.txz:  Rebuilt.
a/xz-5.2.5-x86_64-3.txz:  Rebuilt.
a/zerofree-1.1.1-x86_64-3.txz:  Rebuilt.
a/zoo-2.10_22-x86_64-4.txz:  Rebuilt.
ap/a2ps-4.14-x86_64-9.txz:  Rebuilt.
ap/acct-6.6.4-x86_64-4.txz:  Rebuilt.
ap/alsa-utils-1.2.4-x86_64-3.txz:  Rebuilt.
ap/amp-0.7.6-x86_64-5.txz:  Rebuilt.
ap/at-3.2.1-x86_64-4.txz:  Rebuilt.
ap/bc-1.07.1-x86_64-5.txz:  Rebuilt.
ap/bpe-2.01.00-x86_64-6.txz:  Rebuilt.
ap/cdparanoia-III_10.2-x86_64-5.txz:  Rebuilt.
ap/cdrdao-1.2.4-x86_64-3.txz:  Rebuilt.
ap/cdrtools-3.01-x86_64-6.txz:  Rebuilt.
ap/cups-2.3.3-x86_64-5.txz:  Rebuilt.
ap/cups-filters-1.28.7-x86_64-3.txz:  Rebuilt.
ap/dash-0.5.11.2-x86_64-3.txz:  Rebuilt.
ap/dc3dd-7.2.646-x86_64-4.txz:  Rebuilt.
ap/ddrescue-1.25-x86_64-3.txz:  Rebuilt.
ap/diffstat-1.64-x86_64-3.txz:  Rebuilt.
ap/diffutils-3.7-x86_64-3.txz:  Rebuilt.
ap/dmapi-2.2.12-x86_64-5.txz:  Rebuilt.
ap/dmidecode-3.3-x86_64-3.txz:  Rebuilt.
ap/dvd+rw-tools-7.1-x86_64-5.txz:  Rebuilt.
ap/enscript-1.6.6-x86_64-4.txz:  Rebuilt.
ap/flac-1.3.3-x86_64-3.txz:  Rebuilt.
ap/ghostscript-9.53.3-x86_64-3.txz:  Rebuilt.
ap/ghostscript-fonts-std-8.11-noarch-5.txz:  Rebuilt.
ap/gphoto2-2.5.26-x86_64-3.txz:  Rebuilt.
ap/groff-1.22.4-x86_64-4.txz:  Rebuilt.
ap/gutenprint-5.3.4-x86_64-3.txz:  Rebuilt.
ap/hplip-3.20.6-x86_64-6.txz:  Rebuilt.
ap/htop-3.0.5-x86_64-3.txz:  Rebuilt.
ap/inxi-20210113_1e2d470c-noarch-2.txz:  Rebuilt.
ap/ispell-3.4.02-x86_64-3.txz:  Rebuilt.
ap/itstool-2.0.6-x86_64-3.txz:  Rebuilt.
ap/jed-0.99_19-x86_64-5.txz:  Rebuilt.
ap/joe-4.6-x86_64-4.txz:  Rebuilt.
ap/jove-4.16.0.74-x86_64-3.txz:  Rebuilt.
ap/ksh93-20200131_e4fea8c5-x86_64-3.txz:  Rebuilt.
ap/libx86-1.1-x86_64-5.txz:  Rebuilt.
ap/linuxdoc-tools-0.9.73-x86_64-9.txz:  Rebuilt.
ap/lm_sensors-3.6.0-x86_64-3.txz:  Rebuilt.
ap/lsof-4.94.0-x86_64-3.txz:  Rebuilt.
ap/lsscsi-0.31-x86_64-3.txz:  Rebuilt.
ap/lxc-2.0.11_fad08f383-x86_64-7.txz:  Rebuilt.
ap/madplay-0.15.2b-x86_64-7.txz:  Rebuilt.
ap/man-db-2.9.4-x86_64-2.txz:  Rebuilt.
ap/man-pages-5.10-noarch-3.txz:  Rebuilt.
ap/mariadb-10.5.8-x86_64-3.txz:  Rebuilt.
ap/mc-4.8.26-x86_64-2.txz:  Rebuilt.
ap/moc-2.5.2-x86_64-8.txz:  Rebuilt.
ap/most-5.1.0-x86_64-3.txz:  Rebuilt.
ap/mpg123-1.26.4-x86_64-3.txz:  Rebuilt.
ap/nano-5.5-x86_64-3.txz:  Rebuilt.
ap/neofetch-20201126_6dd85d6-noarch-3.txz:  Rebuilt.
ap/normalize-0.7.7-x86_64-5.txz:  Rebuilt.
ap/nvme-cli-1.13-x86_64-3.txz:  Rebuilt.
ap/opus-tools-0.2-x86_64-3.txz:  Rebuilt.
ap/pamixer-1.4-x86_64-9.txz:  Rebuilt.
ap/powertop-2.13-x86_64-3.txz:  Rebuilt.
ap/qpdf-10.1.0-x86_64-3.txz:  Rebuilt.
ap/radeontool-1.6.3-x86_64-4.txz:  Rebuilt.
ap/rpm-4.16.1.2-x86_64-3.txz:  Rebuilt.
ap/rzip-2.1-x86_64-4.txz:  Rebuilt.
ap/sc-7.16-x86_64-10.txz:  Rebuilt.
ap/sc-im-20200904_bdd936a-x86_64-3.txz:  Rebuilt.
ap/screen-4.8.0-x86_64-4.txz:  Rebuilt.
ap/seejpeg-1.10-x86_64-4.txz:  Rebuilt.
ap/slackpkg-15.0-noarch-3.txz:  Rebuilt.
ap/soma-3.3.7-noarch-2.txz:  Rebuilt.
ap/sox-14.4.2-x86_64-8.txz:  Rebuilt.
ap/sqlite-3.34.1-x86_64-2.txz:  Rebuilt.
ap/squashfs-tools-4.4-x86_64-4.txz:  Rebuilt.
ap/sudo-1.9.5p2-x86_64-2.txz:  Rebuilt.
ap/sysstat-12.5.2-x86_64-3.txz:  Rebuilt.
ap/terminus-font-4.49.1-noarch-3.txz:  Rebuilt.
ap/texinfo-6.7-x86_64-4.txz:  Rebuilt.
ap/tmux-3.1c-x86_64-3.txz:  Rebuilt.
ap/undervolt-20201024_13fa33d-x86_64-3.txz:  Rebuilt.
ap/usbmuxd-20200615_3daa1e9-x86_64-3.txz:  Rebuilt.
ap/vbetool-1.2.2-x86_64-4.txz:  Rebuilt.
ap/vim-8.2.2461-x86_64-2.txz:  Rebuilt.
ap/vorbis-tools-1.4.2-x86_64-2.txz:  Rebuilt.
ap/xfsdump-3.1.9-x86_64-3.txz:  Rebuilt.
ap/xorriso-1.5.4.pl02-x86_64-2.txz:  Rebuilt.
ap/zsh-5.8-x86_64-3.txz:  Rebuilt.
d/Cython-0.29.21-x86_64-4.txz:  Rebuilt.
d/autoconf-2.69-noarch-4.txz:  Rebuilt.
d/autoconf-archive-2019.01.06-noarch-3.txz:  Rebuilt.
d/automake-1.16.2-noarch-3.txz:  Rebuilt.
d/binutils-2.36.1-x86_64-2.txz:  Rebuilt.
d/bison-3.7.5-x86_64-2.txz:  Rebuilt.
d/ccache-4.2-x86_64-2.txz:  Rebuilt.
d/check-0.15.2-x86_64-3.txz:  Rebuilt.
d/clisp-2.50_20191103_c26de7873-x86_64-4.txz:  Rebuilt.
d/cmake-3.19.4-x86_64-2.txz:  Rebuilt.
d/cscope-15.9-x86_64-3.txz:  Rebuilt.
d/cvs-1.11.23-x86_64-7.txz:  Rebuilt.
d/dev86-0.16.21-x86_64-4.txz:  Rebuilt.
d/distcc-3.3.5-x86_64-4.txz:  Rebuilt.
d/doxygen-1.8.20-x86_64-3.txz:  Rebuilt.
d/flex-2.6.4-x86_64-5.txz:  Rebuilt.
d/gcc-10.2.0-x86_64-4.txz:  Rebuilt.
d/gcc-brig-10.2.0-x86_64-4.txz:  Rebuilt.
d/gcc-g++-10.2.0-x86_64-4.txz:  Rebuilt.
d/gcc-gdc-10.2.0-x86_64-4.txz:  Rebuilt.
d/gcc-gfortran-10.2.0-x86_64-4.txz:  Rebuilt.
d/gcc-gnat-10.2.0-x86_64-4.txz:  Rebuilt.
d/gcc-go-10.2.0-x86_64-4.txz:  Rebuilt.
d/gcc-objc-10.2.0-x86_64-4.txz:  Rebuilt.
d/gdb-10.1-x86_64-3.txz:  Rebuilt.
d/gettext-tools-0.21-x86_64-3.txz:  Rebuilt.
d/git-2.30.1-x86_64-2.txz:  Rebuilt.
d/gnucobol-3.1.2-x86_64-3.txz:  Rebuilt.
d/gperf-3.1-x86_64-4.txz:  Rebuilt.
d/guile-3.0.5-x86_64-3.txz:  Rebuilt.
d/gyp-20200512_caa60026-x86_64-4.txz:  Rebuilt.
d/help2man-1.48.1-x86_64-2.txz:  Rebuilt.
d/icecream-1.3.1-x86_64-3.txz:  Rebuilt.
d/indent-2.2.12-x86_64-3.txz:  Rebuilt.
d/intltool-0.51.0-x86_64-6.txz:  Rebuilt.
d/kernel-headers-5.10.16-x86-1.txz:  Upgraded.
d/libtool-2.4.6-x86_64-16.txz:  Rebuilt.
d/llvm-11.0.1-x86_64-3.txz:  Rebuilt.
d/m4-1.4.18-x86_64-4.txz:  Rebuilt.
d/make-4.3-x86_64-3.txz:  Rebuilt.
d/mercurial-5.7-x86_64-2.txz:  Rebuilt.
d/meson-0.56.2-x86_64-3.txz:  Rebuilt.
d/nasm-2.15.05-x86_64-3.txz:  Rebuilt.
d/ninja-1.10.2-x86_64-3.txz:  Rebuilt.
d/opencl-headers-2.2-noarch-4.txz:  Rebuilt.
d/oprofile-1.4.0-x86_64-7.txz:  Rebuilt.
d/p2c-2.01-x86_64-3.txz:  Rebuilt.
d/parallel-20210122-noarch-2.txz:  Rebuilt.
d/patchelf-0.12-x86_64-3.txz:  Rebuilt.
d/perl-5.32.1-x86_64-2.txz:  Rebuilt.
d/pkg-config-0.29.2-x86_64-4.txz:  Rebuilt.
d/pmake-1.111-x86_64-7.txz:  Rebuilt.
d/python-pip-21.0.1-x86_64-2.txz:  Rebuilt.
d/python-setuptools-53.0.0-x86_64-2.txz:  Rebuilt.
d/python2-2.7.18-x86_64-4.txz:  Rebuilt.
d/python3-3.9.1-x86_64-3.txz:  Rebuilt.
d/rcs-5.10.0-x86_64-3.txz:  Rebuilt.
d/re2c-2.0.3-x86_64-3.txz:  Rebuilt.
d/rinutils-0.8.0-x86_64-3.txz:  Rebuilt.
d/ruby-3.0.0-x86_64-3.txz:  Rebuilt.
d/sassc-3.6.1-x86_64-3.txz:  Rebuilt.
d/scons-4.0.1-x86_64-4.txz:  Rebuilt.
d/slacktrack-2.20-x86_64-3.txz:  Rebuilt.
d/strace-5.10-x86_64-3.txz:  Rebuilt.
d/subversion-1.14.1-x86_64-2.txz:  Rebuilt.
d/swig-4.0.2-x86_64-3.txz:  Rebuilt.
d/vala-0.50.3-x86_64-3.txz:  Rebuilt.
d/yasm-1.3.0-x86_64-4.txz:  Rebuilt.
e/emacs-27.1-x86_64-5.txz:  Rebuilt.
e/emacspeak-53.0-x86_64-3.txz:  Rebuilt.
k/kernel-source-5.10.16-noarch-1.txz:  Upgraded.
kde/akonadi-20.12.2-x86_64-2.txz:  Rebuilt.
kde/akonadi-calendar-20.12.2-x86_64-2.txz:  Rebuilt.
kde/akonadi-calendar-tools-20.12.2-x86_64-2.txz:  Rebuilt.
kde/akonadi-contacts-20.12.2-x86_64-2.txz:  Rebuilt.
kde/akonadi-import-wizard-20.12.2-x86_64-2.txz:  Rebuilt.
kde/akonadi-mime-20.12.2-x86_64-2.txz:  Rebuilt.
kde/akonadi-notes-20.12.2-x86_64-2.txz:  Rebuilt.
kde/akonadi-search-20.12.2-x86_64-2.txz:  Rebuilt.
kde/akonadiconsole-20.12.2-x86_64-2.txz:  Rebuilt.
kde/akregator-20.12.2-x86_64-2.txz:  Rebuilt.
kde/alkimia-8.0.4-x86_64-3.txz:  Rebuilt.
kde/analitza-20.12.2-x86_64-2.txz:  Rebuilt.
kde/ark-20.12.2-x86_64-2.txz:  Rebuilt.
kde/artikulate-20.12.2-x86_64-2.txz:  Rebuilt.
kde/attica-5.78.0-x86_64-3.txz:  Rebuilt.
kde/audiocd-kio-20.12.2-x86_64-2.txz:  Rebuilt.
kde/baloo-5.78.0-x86_64-3.txz:  Rebuilt.
kde/baloo-widgets-20.12.2-x86_64-2.txz:  Rebuilt.
kde/blinken-20.12.2-x86_64-2.txz:  Rebuilt.
kde/bluedevil-5.20.5-x86_64-3.txz:  Rebuilt.
kde/bluez-qt-5.78.0-x86_64-3.txz:  Rebuilt.
kde/bomber-20.12.2-x86_64-2.txz:  Rebuilt.
kde/bovo-20.12.2-x86_64-2.txz:  Rebuilt.
kde/breeze-5.20.5-x86_64-3.txz:  Rebuilt.
kde/breeze-grub-5.20.5-x86_64-3.txz:  Rebuilt.
kde/breeze-gtk-5.20.5-x86_64-3.txz:  Rebuilt.
kde/breeze-icons-5.78.0-noarch-3.txz:  Rebuilt.
kde/calendarsupport-20.12.2-x86_64-2.txz:  Rebuilt.
kde/calligra-3.2.1-x86_64-5.txz:  Rebuilt.
kde/calligraplan-3.3.0-x86_64-2.txz:  Rebuilt.
kde/cantor-20.12.2-x86_64-2.txz:  Rebuilt.
kde/cervisia-20.12.2-x86_64-2.txz:  Rebuilt.
kde/digikam-7.1.0-x86_64-5.txz:  Rebuilt.
kde/dolphin-20.12.2-x86_64-2.txz:  Rebuilt.
kde/dolphin-plugins-20.12.2-x86_64-2.txz:  Rebuilt.
kde/dragon-20.12.2-x86_64-2.txz:  Rebuilt.
kde/drkonqi-5.20.5-x86_64-3.txz:  Rebuilt.
kde/elisa-20.12.2-x86_64-2.txz:  Rebuilt.
kde/eventviews-20.12.2-x86_64-2.txz:  Rebuilt.
kde/extra-cmake-modules-5.78.0-x86_64-3.txz:  Rebuilt.
kde/falkon-3.1.0-x86_64-3.txz:  Rebuilt.
kde/ffmpegthumbs-20.12.2-x86_64-2.txz:  Rebuilt.
kde/filelight-20.12.2-x86_64-2.txz:  Rebuilt.
kde/frameworkintegration-5.78.0-x86_64-3.txz:  Rebuilt.
kde/granatier-20.12.2-x86_64-2.txz:  Rebuilt.
kde/grantlee-editor-20.12.2-x86_64-2.txz:  Rebuilt.
kde/grantleetheme-20.12.2-x86_64-2.txz:  Rebuilt.
kde/gwenview-20.12.2-x86_64-2.txz:  Rebuilt.
kde/incidenceeditor-20.12.2-x86_64-2.txz:  Rebuilt.
kde/itinerary-20.12.2-x86_64-2.txz:  Rebuilt.
kde/juk-20.12.2-x86_64-2.txz:  Rebuilt.
kde/k3b-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kactivities-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kactivities-stats-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kactivitymanagerd-5.20.5-x86_64-3.txz:  Rebuilt.
kde/kaddressbook-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kalarm-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kalarmcal-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kalgebra-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kalzium-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kamera-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kamoso-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kanagram-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kapidox-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kapman-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kapptemplate-20.12.2-x86_64-2.txz:  Rebuilt.
kde/karchive-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kate-20.12.2-x86_64-2.txz:  Rebuilt.
kde/katomic-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kauth-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kbackup-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kblackbox-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kblocks-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kbookmarks-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kbounce-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kbreakout-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kbruch-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kcachegrind-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kcalc-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kcalendarcore-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kcalutils-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kcharselect-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kcm-fcitx-0.5.6-x86_64-4.txz:  Rebuilt.
kde/kcmutils-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kcodecs-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kcolorchooser-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kcompletion-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kconfig-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kconfigwidgets-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kcontacts-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kcoreaddons-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kcrash-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kcron-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kdav-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kdbusaddons-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kde-cli-tools-5.20.5-x86_64-3.txz:  Rebuilt.
kde/kde-dev-scripts-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kde-dev-utils-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kde-gtk-config-5.20.5-x86_64-3.txz:  Rebuilt.
kde/kdebugsettings-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kdeclarative-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kdeconnect-kde-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kdecoration-5.20.5-x86_64-3.txz:  Rebuilt.
kde/kded-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kdeedu-data-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kdegraphics-mobipocket-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kdegraphics-thumbnailers-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kdelibs4support-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kdenetwork-filesharing-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kdenlive-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kdepim-addons-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kdepim-runtime-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kdeplasma-addons-5.20.5-x86_64-3.txz:  Rebuilt.
kde/kdesdk-kioslaves-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kdesdk-thumbnailers-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kdesignerplugin-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kdesu-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kdev-php-5.6.2-x86_64-2.txz:  Rebuilt.
kde/kdev-python-5.6.2-x86_64-2.txz:  Rebuilt.
kde/kdevelop-5.6.2-x86_64-2.txz:  Rebuilt.
kde/kdevelop-pg-qt-2.2.1-x86_64-3.txz:  Rebuilt.
kde/kdewebkit-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kdf-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kdiagram-2.8.0-x86_64-3.txz:  Rebuilt.
kde/kdialog-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kdiamond-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kdnssd-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kdoctools-5.78.0-x86_64-3.txz:  Rebuilt.
kde/keditbookmarks-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kemoticons-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kfilemetadata-5.78.0-x86_64-4.txz:  Rebuilt.
kde/kfind-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kfloppy-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kfourinline-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kgamma5-5.20.5-x86_64-3.txz:  Rebuilt.
kde/kgeography-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kget-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kglobalaccel-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kgoldrunner-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kgpg-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kguiaddons-5.78.0-x86_64-3.txz:  Rebuilt.
kde/khangman-20.12.2-x86_64-2.txz:  Rebuilt.
kde/khelpcenter-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kholidays-5.78.0-x86_64-3.txz:  Rebuilt.
kde/khotkeys-5.20.5-x86_64-3.txz:  Rebuilt.
kde/khtml-5.78.0-x86_64-3.txz:  Rebuilt.
kde/ki18n-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kiconthemes-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kid3-3.8.5-x86_64-2.txz:  Rebuilt.
kde/kidentitymanagement-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kidletime-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kig-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kigo-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kile-2.9.93-x86_64-5.txz:  Rebuilt.
kde/killbots-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kimageformats-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kimagemapeditor-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kimap-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kinfocenter-5.20.5-x86_64-3.txz:  Rebuilt.
kde/kinit-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kio-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kio-extras-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kio-gdrive-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kipi-plugins-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kirigami-gallery-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kirigami2-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kiriki-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kitemmodels-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kitemviews-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kiten-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kitinerary-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kjobwidgets-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kjots-20201206_f7d555c-x86_64-3.txz:  Rebuilt.
kde/kjs-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kjsembed-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kjumpingcube-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kldap-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kleopatra-20.12.2-x86_64-2.txz:  Rebuilt.
kde/klickety-20.12.2-x86_64-2.txz:  Rebuilt.
kde/klines-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kmag-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kmahjongg-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kmail-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kmail-account-wizard-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kmailtransport-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kmbox-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kmediaplayer-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kmenuedit-5.20.5-x86_64-3.txz:  Rebuilt.
kde/kmime-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kmines-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kmix-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kmousetool-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kmouth-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kmplot-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kmymoney-5.1.1-x86_64-3.txz:  Rebuilt.
kde/knavalbattle-20.12.2-x86_64-2.txz:  Rebuilt.
kde/knetwalk-20.12.2-x86_64-2.txz:  Rebuilt.
kde/knewstuff-5.78.0-x86_64-3.txz:  Rebuilt.
kde/knights-20.12.2-x86_64-2.txz:  Rebuilt.
kde/knotes-20.12.2-x86_64-2.txz:  Rebuilt.
kde/knotifications-5.78.0-x86_64-3.txz:  Rebuilt.
kde/knotifyconfig-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kolf-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kollision-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kolourpaint-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kompare-20.12.2-x86_64-2.txz:  Rebuilt.
kde/konqueror-20.12.2-x86_64-2.txz:  Rebuilt.
kde/konquest-20.12.2-x86_64-2.txz:  Rebuilt.
kde/konsole-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kontact-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kontactinterface-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kontrast-20.12.2-x86_64-2.txz:  Rebuilt.
kde/konversation-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kopete-20.12.2-x86_64-2.txz:  Rebuilt.
kde/korganizer-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kosmindoormap-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kpackage-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kparts-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kpat-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kpeople-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kpeoplevcard-0.1-x86_64-3.txz:  Rebuilt.
kde/kpimtextedit-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kpkpass-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kplotting-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kpmcore-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kpty-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kpublictransport-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kqtquickcharts-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kquickcharts-5.78.0-x86_64-3.txz:  Rebuilt.
kde/krdc-20.12.2-x86_64-2.txz:  Rebuilt.
kde/krename-5.0.1-x86_64-3.txz:  Rebuilt.
kde/kreversi-20.12.2-x86_64-2.txz:  Rebuilt.
kde/krfb-20.12.2-x86_64-2.txz:  Rebuilt.
kde/krita-4.4.2-x86_64-3.txz:  Rebuilt.
kde/kross-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kross-interpreters-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kruler-20.12.2-x86_64-2.txz:  Rebuilt.
kde/krunner-5.78.0-x86_64-3.txz:  Rebuilt.
kde/krusader-2.7.2-x86_64-3.txz:  Rebuilt.
kde/kscreen-5.20.5-x86_64-3.txz:  Rebuilt.
kde/kscreenlocker-5.20.5-x86_64-3.txz:  Rebuilt.
kde/kservice-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kshisen-20.12.2-x86_64-2.txz:  Rebuilt.
kde/ksirk-20.12.2-x86_64-2.txz:  Rebuilt.
kde/ksmtp-20.12.2-x86_64-2.txz:  Rebuilt.
kde/ksnakeduel-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kspaceduel-20.12.2-x86_64-2.txz:  Rebuilt.
kde/ksquares-20.12.2-x86_64-2.txz:  Rebuilt.
kde/ksshaskpass-5.20.5-x86_64-3.txz:  Rebuilt.
kde/kstars-3.5.1-x86_64-3.txz:  Rebuilt.
kde/ksudoku-20.12.2-x86_64-2.txz:  Rebuilt.
kde/ksysguard-5.20.5-x86_64-3.txz:  Rebuilt.
kde/ksystemlog-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kteatime-20.12.2-x86_64-2.txz:  Rebuilt.
kde/ktexteditor-5.78.0-x86_64-3.txz:  Rebuilt.
kde/ktextwidgets-5.78.0-x86_64-3.txz:  Rebuilt.
kde/ktimer-20.12.2-x86_64-2.txz:  Rebuilt.
kde/ktimetracker-5.0.1-x86_64-3.txz:  Rebuilt.
kde/ktnef-20.12.2-x86_64-2.txz:  Rebuilt.
kde/ktorrent-20.12.2-x86_64-2.txz:  Rebuilt.
kde/ktouch-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kturtle-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kubrick-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kunitconversion-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kwallet-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kwallet-pam-5.20.5-x86_64-3.txz:  Rebuilt.
kde/kwalletmanager-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kwave-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kwayland-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kwayland-integration-5.20.5-x86_64-3.txz:  Rebuilt.
kde/kwayland-server-5.20.5-x86_64-3.txz:  Rebuilt.
kde/kwidgetsaddons-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kwin-5.20.5-x86_64-3.txz:  Rebuilt.
kde/kwindowsystem-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kwordquiz-20.12.2-x86_64-2.txz:  Rebuilt.
kde/kwrited-5.20.5-x86_64-3.txz:  Rebuilt.
kde/kxmlgui-5.78.0-x86_64-3.txz:  Rebuilt.
kde/kxmlrpcclient-5.78.0-x86_64-3.txz:  Rebuilt.
kde/latte-dock-0.9.11-x86_64-3.txz:  Rebuilt.
kde/libgravatar-20.12.2-x86_64-2.txz:  Rebuilt.
kde/libkcddb-20.12.2-x86_64-2.txz:  Rebuilt.
kde/libkcompactdisc-20.12.2-x86_64-2.txz:  Rebuilt.
kde/libkdcraw-20.12.2-x86_64-2.txz:  Rebuilt.
kde/libkdegames-20.12.2-x86_64-2.txz:  Rebuilt.
kde/libkdepim-20.12.2-x86_64-2.txz:  Rebuilt.
kde/libkeduvocdocument-20.12.2-x86_64-2.txz:  Rebuilt.
kde/libkexiv2-20.12.2-x86_64-2.txz:  Rebuilt.
kde/libkgapi-20.12.2-x86_64-2.txz:  Rebuilt.
kde/libkipi-20.12.2-x86_64-2.txz:  Rebuilt.
kde/libkleo-20.12.2-x86_64-2.txz:  Rebuilt.
kde/libkmahjongg-20.12.2-x86_64-2.txz:  Rebuilt.
kde/libkomparediff2-20.12.2-x86_64-2.txz:  Rebuilt.
kde/libksane-20.12.2-x86_64-2.txz:  Rebuilt.
kde/libkscreen-5.20.5-x86_64-3.txz:  Rebuilt.
kde/libksieve-20.12.2-x86_64-2.txz:  Rebuilt.
kde/libksysguard-5.20.5-x86_64-3.txz:  Rebuilt.
kde/libktorrent-20.12.2-x86_64-2.txz:  Rebuilt.
kde/lokalize-20.12.2-x86_64-2.txz:  Rebuilt.
kde/lskat-20.12.2-x86_64-2.txz:  Rebuilt.
kde/mailcommon-20.12.2-x86_64-2.txz:  Rebuilt.
kde/mailimporter-20.12.2-x86_64-2.txz:  Rebuilt.
kde/marble-20.12.2-x86_64-2.txz:  Rebuilt.
kde/markdownpart-20.12.2-x86_64-2.txz:  Rebuilt.
kde/mbox-importer-20.12.2-x86_64-2.txz:  Rebuilt.
kde/messagelib-20.12.2-x86_64-2.txz:  Rebuilt.
kde/milou-5.20.5-x86_64-3.txz:  Rebuilt.
kde/minuet-20.12.2-x86_64-2.txz:  Rebuilt.
kde/modemmanager-qt-5.78.0-x86_64-3.txz:  Rebuilt.
kde/networkmanager-qt-5.78.0-x86_64-3.txz:  Rebuilt.
kde/okteta-0.26.5-x86_64-2.txz:  Rebuilt.
kde/okular-20.12.2-x86_64-2.txz:  Rebuilt.
kde/oxygen-5.20.5-x86_64-3.txz:  Rebuilt.
kde/oxygen-fonts-5.4.3-noarch-3.txz:  Rebuilt.
kde/oxygen-gtk2-1.4.6-x86_64-3.txz:  Rebuilt.
kde/oxygen-icons5-5.78.0-noarch-3.txz:  Rebuilt.
kde/palapeli-20.12.2-x86_64-2.txz:  Rebuilt.
kde/parley-20.12.2-x86_64-2.txz:  Rebuilt.
kde/partitionmanager-20.12.2-x86_64-2.txz:  Rebuilt.
kde/picmi-20.12.2-x86_64-2.txz:  Rebuilt.
kde/pim-data-exporter-20.12.2-x86_64-2.txz:  Rebuilt.
kde/pim-sieve-editor-20.12.2-x86_64-2.txz:  Rebuilt.
kde/pimcommon-20.12.2-x86_64-2.txz:  Rebuilt.
kde/plasma-browser-integration-5.20.5-x86_64-3.txz:  Rebuilt.
kde/plasma-desktop-5.20.5-x86_64-3.txz:  Rebuilt.
kde/plasma-disks-5.20.5-x86_64-3.txz:  Rebuilt.
kde/plasma-framework-5.78.0-x86_64-3.txz:  Rebuilt.
kde/plasma-integration-5.20.5-x86_64-3.txz:  Rebuilt.
kde/plasma-nm-5.20.5-x86_64-3.txz:  Rebuilt.
kde/plasma-pa-5.20.5-x86_64-3.txz:  Rebuilt.
kde/plasma-sdk-5.20.5-x86_64-3.txz:  Rebuilt.
kde/plasma-vault-5.20.5-x86_64-3.txz:  Rebuilt.
kde/plasma-wayland-protocols-1.1.1-x86_64-3.txz:  Rebuilt.
kde/plasma-workspace-5.20.5-x86_64-3.txz:  Rebuilt.
kde/plasma-workspace-wallpapers-5.20.5-x86_64-3.txz:  Rebuilt.
kde/polkit-kde-agent-1-5.20.5-x86_64-3.txz:  Rebuilt.
kde/powerdevil-5.20.5-x86_64-3.txz:  Rebuilt.
kde/poxml-20.12.2-x86_64-2.txz:  Rebuilt.
kde/print-manager-20.12.2-x86_64-2.txz:  Rebuilt.
kde/prison-5.78.0-x86_64-3.txz:  Rebuilt.
kde/pulseaudio-qt-1.2-x86_64-3.txz:  Rebuilt.
kde/purpose-5.78.0-x86_64-3.txz:  Rebuilt.
kde/qqc2-desktop-style-5.78.0-x86_64-3.txz:  Rebuilt.
kde/rocs-20.12.2-x86_64-2.txz:  Rebuilt.
kde/sddm-0.19.0-x86_64-6.txz:  Rebuilt.
kde/sddm-kcm-5.20.5-x86_64-3.txz:  Rebuilt.
kde/skanlite-2.2.0-x86_64-3.txz:  Rebuilt.
kde/solid-5.78.0-x86_64-3.txz:  Rebuilt.
kde/sonnet-5.78.0-x86_64-3.txz:  Rebuilt.
kde/spectacle-20.12.2-x86_64-2.txz:  Rebuilt.
kde/step-20.12.2-x86_64-2.txz:  Rebuilt.
kde/svgpart-20.12.2-x86_64-2.txz:  Rebuilt.
kde/sweeper-20.12.2-x86_64-2.txz:  Rebuilt.
kde/syndication-5.78.0-x86_64-3.txz:  Rebuilt.
kde/syntax-highlighting-5.78.0-x86_64-3.txz:  Rebuilt.
kde/systemsettings-5.20.5-x86_64-3.txz:  Rebuilt.
kde/threadweaver-5.78.0-x86_64-3.txz:  Rebuilt.
kde/umbrello-20.12.2-x86_64-2.txz:  Rebuilt.
kde/wacomtablet-20201030_417d9d9-x86_64-3.txz:  Rebuilt.
kde/xdg-desktop-portal-kde-5.20.5-x86_64-3.txz:  Rebuilt.
kde/yakuake-20.12.2-x86_64-2.txz:  Rebuilt.
kde/zeroconf-ioslave-20.12.2-x86_64-2.txz:  Rebuilt.
l/GConf-3.2.6-x86_64-7.txz:  Rebuilt.
l/LibRaw-0.20.2-x86_64-3.txz:  Rebuilt.
l/M2Crypto-0.37.1-x86_64-3.txz:  Rebuilt.
l/Mako-1.1.4-x86_64-3.txz:  Rebuilt.
l/PyQt5-5.15.2-x86_64-3.txz:  Rebuilt.
l/QScintilla-2.11.6-x86_64-3.txz:  Rebuilt.
l/QtAV-20200910_2a470d2a-x86_64-3.txz:  Rebuilt.
l/SDL2-2.0.14-x86_64-3.txz:  Rebuilt.
l/SDL2_gfx-1.0.4-x86_64-3.txz:  Rebuilt.
l/SDL2_image-2.0.5-x86_64-3.txz:  Rebuilt.
l/SDL2_mixer-2.0.4-x86_64-4.txz:  Rebuilt.
l/SDL2_net-2.0.1-x86_64-4.txz:  Rebuilt.
l/SDL2_ttf-2.0.15-x86_64-3.txz:  Rebuilt.
l/a52dec-0.7.4-x86_64-5.txz:  Rebuilt.
l/aalib-1.4rc5-x86_64-8.txz:  Rebuilt.
l/accountsservice-0.6.55-x86_64-4.txz:  Rebuilt.
l/adwaita-icon-theme-3.38.0-noarch-3.txz:  Rebuilt.
l/alsa-lib-1.2.4-x86_64-3.txz:  Rebuilt.
l/alsa-oss-1.1.8-x86_64-3.txz:  Rebuilt.
l/alsa-plugins-1.2.2-x86_64-3.txz:  Rebuilt.
l/apr-1.7.0-x86_64-3.txz:  Rebuilt.
l/apr-util-1.6.1-x86_64-10.txz:  Rebuilt.
l/argon2-20190702-x86_64-5.txz:  Rebuilt.
l/aspell-0.60.8-x86_64-3.txz:  Rebuilt.
l/at-spi2-atk-2.38.0-x86_64-3.txz:  Rebuilt.
l/at-spi2-core-2.38.0-x86_64-3.txz:  Rebuilt.
l/atk-2.36.0-x86_64-3.txz:  Rebuilt.
l/atkmm-2.28.1-x86_64-3.txz:  Rebuilt.
l/audiofile-0.3.6-x86_64-4.txz:  Rebuilt.
l/babl-0.1.84-x86_64-3.txz:  Rebuilt.
l/boost-1.75.0-x86_64-3.txz:  Rebuilt.
l/brotli-1.0.9-x86_64-5.txz:  Rebuilt.
l/cairo-1.16.0-x86_64-3.txz:  Rebuilt.
l/cairomm-1.12.2-x86_64-4.txz:  Rebuilt.
l/cfitsio-3.49-x86_64-3.txz:  Rebuilt.
l/chmlib-0.40-x86_64-5.txz:  Rebuilt.
l/clucene-2.3.3.4-x86_64-5.txz:  Rebuilt.
l/cryfs-0.10.2-x86_64-4.txz:  Rebuilt.
l/cryptopp-8.2.0-x86_64-3.txz:  Rebuilt.
l/db48-4.8.30-x86_64-6.txz:  Rebuilt.
l/dbus-glib-0.110-x86_64-4.txz:  Rebuilt.
l/dbus-python-1.2.16-x86_64-4.txz:  Rebuilt.
l/dconf-0.38.0-x86_64-3.txz:  Rebuilt.
l/dconf-editor-3.38.2-x86_64-3.txz:  Rebuilt.
l/desktop-file-utils-0.26-x86_64-3.txz:  Rebuilt.
l/djvulibre-3.5.28-x86_64-3.txz:  Rebuilt.
l/dotconf-1.3-x86_64-3.txz:  Rebuilt.
l/dvdauthor-0.7.2-x86_64-4.txz:  Rebuilt.
l/ebook-tools-0.2.2-x86_64-7.txz:  Rebuilt.
l/eigen2-2.0.17-x86_64-4.txz:  Rebuilt.
l/eigen3-3.3.9-x86_64-3.txz:  Rebuilt.
l/elfutils-0.183-x86_64-2.txz:  Rebuilt.
l/enchant-1.6.1-x86_64-4.txz:  Rebuilt.
l/esound-0.2.41-x86_64-5.txz:  Rebuilt.
l/espeak-ng-1.50-x86_64-3.txz:  Rebuilt.
l/exiv2-0.27.3-x86_64-3.txz:  Rebuilt.
l/expat-2.2.10-x86_64-3.txz:  Rebuilt.
l/farstream-0.2.9-x86_64-3.txz:  Rebuilt.
l/ffmpeg-4.3.1-x86_64-3.txz:  Rebuilt.
l/fftw-3.3.9-x86_64-3.txz:  Rebuilt.
l/fluidsynth-1.1.11-x86_64-4.txz:  Rebuilt.
l/freecell-solver-6.2.0-x86_64-3.txz:  Rebuilt.
l/freetype-2.10.4-x86_64-3.txz:  Rebuilt.
l/frei0r-plugins-1.7.0-x86_64-3.txz:  Rebuilt.
l/fribidi-1.0.10-x86_64-3.txz:  Rebuilt.
l/fuse-2.9.9-x86_64-3.txz:  Rebuilt.
l/fuse3-3.10.2-x86_64-2.txz:  Rebuilt.
l/gamin-0.1.10-x86_64-9.txz:  Rebuilt.
l/gc-8.0.4-x86_64-3.txz:  Rebuilt.
l/gcr-3.38.1-x86_64-3.txz:  Rebuilt.
l/gd-2.3.1-x86_64-2.txz:  Rebuilt.
l/gdbm-1.19-x86_64-3.txz:  Rebuilt.
l/gdk-pixbuf2-2.42.2-x86_64-3.txz:  Rebuilt.
l/gdk-pixbuf2-xlib-2.40.2-x86_64-3.txz:  Rebuilt.
l/gegl-0.4.28-x86_64-4.txz:  Rebuilt.
l/gexiv2-0.12.1-x86_64-3.txz:  Rebuilt.
l/giflib-5.2.1-x86_64-4.txz:  Rebuilt.
l/gjs-1.66.2-x86_64-3.txz:  Rebuilt.
l/glade-3.38.2-x86_64-3.txz:  Rebuilt.
l/glib-1.2.10-x86_64-9.txz:  Rebuilt.
l/glib-networking-2.66.0-x86_64-3.txz:  Rebuilt.
l/glib2-2.66.7-x86_64-2.txz:  Rebuilt.
l/glibc-2.33-x86_64-1.txz:  Upgraded.
l/glibc-i18n-2.33-x86_64-1.txz:  Upgraded.
l/glibc-profile-2.33-x86_64-1.txz:  Upgraded.
l/glibmm-2.64.5-x86_64-3.txz:  Rebuilt.
l/gmime-3.2.7-x86_64-4.txz:  Rebuilt.
l/gmm-5.4-noarch-3.txz:  Rebuilt.
l/gmp-6.2.1-x86_64-3.txz:  Rebuilt.
l/gnome-keyring-3.36.0-x86_64-4.txz:  Rebuilt.
l/gnome-themes-extra-3.28-x86_64-3.txz:  Rebuilt.
l/gnu-efi-3.0.12-x86_64-3.txz:  Rebuilt.
l/gobject-introspection-1.66.1-x86_64-3.txz:  Rebuilt.
l/grantlee-5.2.0-x86_64-3.txz:  Rebuilt.
l/graphene-1.10.4-x86_64-2.txz:  Rebuilt.
l/graphite2-1.3.14-x86_64-3.txz:  Rebuilt.
l/gsettings-desktop-schemas-3.38.0-x86_64-3.txz:  Rebuilt.
l/gsl-2.6-x86_64-3.txz:  Rebuilt.
l/gst-plugins-base-1.18.3-x86_64-3.txz:  Rebuilt.
l/gst-plugins-good-1.18.3-x86_64-3.txz:  Rebuilt.
l/gst-plugins-libav-1.18.3-x86_64-3.txz:  Rebuilt.
l/gstreamer-1.18.3-x86_64-3.txz:  Rebuilt.
l/gtk+-1.2.10-x86_64-9.txz:  Rebuilt.
l/gtk+2-2.24.33-x86_64-2.txz:  Rebuilt.
l/gtk+3-3.24.24-x86_64-3.txz:  Rebuilt.
l/gtkmm2-2.24.5-x86_64-4.txz:  Rebuilt.
l/gtkmm3-3.24.3-x86_64-3.txz:  Rebuilt.
l/gtksourceview3-3.24.11-x86_64-4.txz:  Rebuilt.
l/gtkspell-2.0.16-x86_64-6.txz:  Rebuilt.
l/gvfs-1.46.2-x86_64-3.txz:  Rebuilt.
l/harfbuzz-2.7.4-x86_64-3.txz:  Rebuilt.
l/hicolor-icon-theme-0.17-noarch-4.txz:  Rebuilt.
l/hunspell-1.6.2-x86_64-5.txz:  Rebuilt.
l/hyphen-2.8.8-x86_64-3.txz:  Rebuilt.
l/icon-naming-utils-0.8.90-x86_64-5.txz:  Rebuilt.
l/icu4c-68.2-x86_64-3.txz:  Rebuilt.
l/id3lib-3.8.3-x86_64-4.txz:  Rebuilt.
l/imagemagick-7.0.10_62-x86_64-2.txz:  Rebuilt.
l/isl-0.23-x86_64-3.txz:  Rebuilt.
l/iso-codes-4.5.0-noarch-3.txz:  Rebuilt.
l/jansson-2.13.1-x86_64-3.txz:  Rebuilt.
l/jasper-2.0.25-x86_64-2.txz:  Rebuilt.
l/jemalloc-5.2.1-x86_64-3.txz:  Rebuilt.
l/jmtpfs-0.5-x86_64-3.txz:  Rebuilt.
l/json-c-0.15_20200726-x86_64-3.txz:  Rebuilt.
l/json-glib-1.6.2-x86_64-2.txz:  Rebuilt.
l/judy-1.0.5-x86_64-4.txz:  Rebuilt.
l/kdsoap-1.10.0-x86_64-3.txz:  Rebuilt.
l/keybinder3-3.0_0.3.2-x86_64-3.txz:  Rebuilt.
l/keyutils-1.6.3-x86_64-3.txz:  Rebuilt.
l/lame-3.100-x86_64-4.txz:  Rebuilt.
l/lcms-1.19-x86_64-6.txz:  Rebuilt.
l/lcms2-2.12-x86_64-2.txz:  Rebuilt.
l/lensfun-0.3.95-x86_64-3.txz:  Rebuilt.
l/libaio-0.3.112-x86_64-3.txz:  Rebuilt.
l/libao-1.2.2-x86_64-4.txz:  Rebuilt.
l/libappindicator-12.10.0-x86_64-3.txz:  Rebuilt.
l/libarchive-3.5.1-x86_64-3.txz:  Rebuilt.
l/libasyncns-0.8-x86_64-5.txz:  Rebuilt.
l/libatasmart-0.19-x86_64-5.txz:  Rebuilt.
l/libbluray-1.2.1-x86_64-3.txz:  Rebuilt.
l/libburn-1.5.4-x86_64-2.txz:  Rebuilt.
l/libcaca-0.99.beta19-x86_64-9.txz:  Rebuilt.
l/libcanberra-0.30-x86_64-8.txz:  Rebuilt.
l/libcap-2.48-x86_64-2.txz:  Rebuilt.
l/libcap-ng-0.8.2-x86_64-3.txz:  Rebuilt.
l/libcddb-1.3.2-x86_64-8.txz:  Rebuilt.
l/libcdio-2.1.0-x86_64-3.txz:  Rebuilt.
l/libcdio-paranoia-10.2+2.0.1-x86_64-3.txz:  Rebuilt.
l/libclc-11.0.1-x86_64-3.txz:  Rebuilt.
l/libcue-2.2.1-x86_64-3.txz:  Rebuilt.
l/libdbusmenu-16.04.0-x86_64-3.txz:  Rebuilt.
l/libdbusmenu-qt-0.9.3+16.04.20160218-x86_64-3.txz:  Rebuilt.
l/libdiscid-0.6.2-x86_64-4.txz:  Rebuilt.
l/libdmtx-0.7.5-x86_64-3.txz:  Rebuilt.
l/libdvdnav-6.1.0-x86_64-4.txz:  Rebuilt.
l/libdvdread-6.1.1-x86_64-3.txz:  Rebuilt.
l/libedit-20191231_3.1-x86_64-3.txz:  Rebuilt.
l/libevent-2.1.12-x86_64-3.txz:  Rebuilt.
l/libexif-0.6.22-x86_64-3.txz:  Rebuilt.
l/libfakekey-0.3-x86_64-4.txz:  Rebuilt.
l/libffi-3.3-x86_64-3.txz:  Rebuilt.
l/libglade-2.6.4-x86_64-8.txz:  Rebuilt.
l/libgnome-keyring-3.12.0-x86_64-4.txz:  Rebuilt.
l/libgphoto2-2.5.26-x86_64-3.txz:  Rebuilt.
l/libgpod-0.8.3-x86_64-9.txz:  Rebuilt.
l/libgsf-1.14.47-x86_64-3.txz:  Rebuilt.
l/libgtop-2.40.0-x86_64-3.txz:  Rebuilt.
l/libical-3.0.9-x86_64-3.txz:  Rebuilt.
l/libid3tag-0.15.1b-x86_64-7.txz:  Rebuilt.
l/libidl-0.8.14-x86_64-4.txz:  Rebuilt.
l/libidn-1.36-x86_64-3.txz:  Rebuilt.
l/libidn2-2.3.0-x86_64-3.txz:  Rebuilt.
l/libieee1284-0.2.11-x86_64-6.txz:  Rebuilt.
l/libimobiledevice-20200615_4791a82-x86_64-4.txz:  Rebuilt.
l/libindicator-12.10.1-x86_64-3.txz:  Rebuilt.
l/libiodbc-3.52.13-x86_64-3.txz:  Rebuilt.
l/libjpeg-turbo-2.0.6-x86_64-3.txz:  Rebuilt.
l/libkarma-0.1.2-x86_64-3.txz:  Rebuilt.
l/libmad-0.15.1b-x86_64-6.txz:  Rebuilt.
l/libmcrypt-2.5.8-x86_64-4.txz:  Rebuilt.
l/libmng-2.0.3-x86_64-4.txz:  Rebuilt.
l/libmpc-1.2.1-x86_64-3.txz:  Rebuilt.
l/libmtp-1.1.18-x86_64-3.txz:  Rebuilt.
l/libnice-0.1.18-x86_64-3.txz:  Rebuilt.
l/libnih-1.0.3-x86_64-5.txz:  Rebuilt.
l/libnjb-2.2.7-x86_64-4.txz:  Rebuilt.
l/libnl-1.1.4-x86_64-5.txz:  Rebuilt.
l/libnl3-3.5.0-x86_64-3.txz:  Rebuilt.
l/libnotify-0.7.9-x86_64-3.txz:  Rebuilt.
l/libnsl-1.3.0-x86_64-3.txz:  Rebuilt.
l/libnss_nis-3.1-x86_64-3.txz:  Rebuilt.
l/libodfgen-0.1.8-x86_64-3.txz:  Rebuilt.
l/libogg-1.3.4-x86_64-3.txz:  Rebuilt.
l/liboggz-1.1.1-x86_64-5.txz:  Rebuilt.
l/liboil-0.3.17-x86_64-4.txz:  Rebuilt.
l/libopusenc-0.2.1-x86_64-3.txz:  Rebuilt.
l/libpcap-1.10.0-x86_64-2.txz:  Rebuilt.
l/libplist-2.2.0-x86_64-3.txz:  Rebuilt.
l/libpng-1.6.37-x86_64-3.txz:  Rebuilt.
l/libproxy-0.4.17-x86_64-3.txz:  Rebuilt.
l/libpsl-0.21.1-x86_64-4.txz:  Rebuilt.
l/libqalculate-3.16.1-x86_64-3.txz:  Rebuilt.
l/libraw1394-2.1.2-x86_64-4.txz:  Rebuilt.
l/librevenge-0.0.4-x86_64-4.txz:  Rebuilt.
l/librsvg-2.50.3-x86_64-2.txz:  Rebuilt.
l/libsamplerate-0.2.1-x86_64-2.txz:  Rebuilt.
l/libsass-3.6.4-x86_64-3.txz:  Rebuilt.
l/libsecret-0.20.4-x86_64-3.txz:  Rebuilt.
l/libsigc++-2.10.2-x86_64-3.txz:  Rebuilt.
l/libsigsegv-2.13-x86_64-3.txz:  Rebuilt.
l/libsndfile-1.0.31-x86_64-2.txz:  Rebuilt.
l/libsodium-1.0.18-x86_64-3.txz:  Rebuilt.
l/libsoup-2.72.0-x86_64-3.txz:  Rebuilt.
l/libspectre-0.2.9-x86_64-4.txz:  Rebuilt.
l/libssh-0.9.5-x86_64-3.txz:  Rebuilt.
l/libssh2-1.9.0-x86_64-3.txz:  Rebuilt.
l/libtasn1-4.16.0-x86_64-3.txz:  Rebuilt.
l/libtheora-1.1.1-x86_64-4.txz:  Rebuilt.
l/libtiff-4.2.0-x86_64-3.txz:  Rebuilt.
l/libunistring-0.9.10-x86_64-3.txz:  Rebuilt.
l/libunwind-1.5.0-x86_64-3.txz:  Rebuilt.
l/libusb-1.0.24-x86_64-3.txz:  Rebuilt.
l/libusb-compat-0.1.5-x86_64-5.txz:  Rebuilt.
l/libusbmuxd-20200615_c7d7d1a-x86_64-3.txz:  Rebuilt.
l/libuv-1.40.0-x86_64-3.txz:  Rebuilt.
l/libvisio-0.1.7-x86_64-6.txz:  Rebuilt.
l/libvisual-0.4.0-x86_64-6.txz:  Rebuilt.
l/libvisual-plugins-0.4.0-x86_64-7.txz:  Rebuilt.
l/libvncserver-0.9.13-x86_64-3.txz:  Rebuilt.
l/libvorbis-1.3.7-x86_64-3.txz:  Rebuilt.
l/libvpx-1.9.0-x86_64-3.txz:  Rebuilt.
l/libwebp-1.2.0-x86_64-2.txz:  Rebuilt.
l/libwmf-0.2.12-x86_64-3.txz:  Rebuilt.
l/libwnck-2.31.0-x86_64-5.txz:  Rebuilt.
l/libwnck3-3.36.0-x86_64-3.txz:  Rebuilt.
l/libwpd-0.10.3-x86_64-3.txz:  Rebuilt.
l/libwpg-0.3.3-x86_64-3.txz:  Rebuilt.
l/libxkbcommon-1.0.3-x86_64-3.txz:  Rebuilt.
l/libxklavier-5.4-x86_64-4.txz:  Rebuilt.
l/libxml2-2.9.10-x86_64-5.txz:  Rebuilt.
l/libxslt-1.1.34-x86_64-3.txz:  Rebuilt.
l/libyaml-0.2.5-x86_64-3.txz:  Rebuilt.
l/libzip-1.7.3-x86_64-3.txz:  Rebuilt.
l/lmdb-0.9.28-x86_64-2.txz:  Rebuilt.
l/loudmouth-1.5.4-x86_64-2.txz:  Rebuilt.
l/lz4-1.9.3-x86_64-3.txz:  Rebuilt.
l/lzo-2.10-x86_64-4.txz:  Rebuilt.
l/media-player-info-24-noarch-3.txz:  Rebuilt.
l/mhash-0.9.9.9-x86_64-6.txz:  Rebuilt.
l/mlt-6.24.0-x86_64-4.txz:  Rebuilt.
l/mm-1.4.2-x86_64-5.txz:  Rebuilt.
l/mozilla-nss-3.61-x86_64-2.txz:  Rebuilt.
l/mozjs78-78.7.1esr-x86_64-2.txz:  Rebuilt.
l/mpfr-4.1.0-x86_64-3.txz:  Rebuilt.
l/ncurses-6.2_20201219-x86_64-4.txz:  Rebuilt.
l/neon-0.31.2-x86_64-3.txz:  Rebuilt.
l/netpbm-10.93.00-x86_64-3.txz:  Rebuilt.
l/newt-0.52.21-x86_64-5.txz:  Rebuilt.
l/ocl-icd-2.2.14-x86_64-3.txz:  Rebuilt.
l/oniguruma-6.9.6-x86_64-3.txz:  Rebuilt.
l/openal-soft-1.21.1-x86_64-2.txz:  Rebuilt.
l/opencv-4.5.1-x86_64-3.txz:  Rebuilt.
l/openexr-2.5.5-x86_64-2.txz:  Rebuilt.
l/openjpeg-2.4.0-x86_64-3.txz:  Rebuilt.
l/opus-1.3.1-x86_64-3.txz:  Rebuilt.
l/opusfile-0.12-x86_64-3.txz:  Rebuilt.
l/orc-0.4.32-x86_64-3.txz:  Rebuilt.
l/pango-1.48.2-x86_64-2.txz:  Rebuilt.
l/pangomm-2.42.2-x86_64-3.txz:  Rebuilt.
l/parted-3.4-x86_64-2.txz:  Rebuilt.
l/pcaudiolib-1.1-x86_64-3.txz:  Rebuilt.
l/pcre-8.44-x86_64-3.txz:  Rebuilt.
l/pcre2-10.36-x86_64-3.txz:  Rebuilt.
l/phonon-4.11.1-x86_64-3.txz:  Rebuilt.
l/phonon-backend-gstreamer-4.10.0-x86_64-3.txz:  Rebuilt.
l/pilot-link-0.12.5-x86_64-16.txz:  Rebuilt.
l/pipewire-0.3.21-x86_64-2.txz:  Rebuilt.
l/polkit-0.118-x86_64-5.txz:  Rebuilt.
l/polkit-gnome-0.105-x86_64-4.txz:  Rebuilt.
l/polkit-qt-1-0.113.0-x86_64-3.txz:  Rebuilt.
l/poppler-21.02.0-x86_64-2.txz:  Rebuilt.
l/poppler-data-0.4.10-noarch-3.txz:  Rebuilt.
l/popt-1.18-x86_64-3.txz:  Rebuilt.
l/pulseaudio-14.2-x86_64-3.txz:  Rebuilt.
l/pycairo-1.20.0-x86_64-4.txz:  Rebuilt.
l/pycups-2.0.1-x86_64-4.txz:  Rebuilt.
l/pycurl-7.43.0.6-x86_64-4.txz:  Rebuilt.
l/pygobject-2.28.7-x86_64-8.txz:  Rebuilt.
l/pygobject3-3.38.0-x86_64-3.txz:  Rebuilt.
l/pygtk-2.24.0-x86_64-7.txz:  Rebuilt.
l/pyparsing-2.4.7-x86_64-4.txz:  Rebuilt.
l/python-appdirs-1.4.4-x86_64-4.txz:  Rebuilt.
l/python-certifi-2020.12.5-x86_64-3.txz:  Rebuilt.
l/python-chardet-4.0.0-x86_64-3.txz:  Rebuilt.
l/python-distro-1.5.0-x86_64-4.txz:  Rebuilt.
l/python-docutils-0.16-x86_64-6.txz:  Rebuilt.
l/python-future-0.18.2-x86_64-5.txz:  Rebuilt.
l/python-idna-3.1-x86_64-3.txz:  Rebuilt.
l/python-notify2-0.3.1-x86_64-8.txz:  Rebuilt.
l/python-packaging-20.9-x86_64-2.txz:  Rebuilt.
l/python-pillow-8.1.0-x86_64-3.txz:  Rebuilt.
l/python-ply-3.11-x86_64-6.txz:  Rebuilt.
l/python-pygments-2.7.4-x86_64-3.txz:  Rebuilt.
l/python-pysol_cards-0.10.1-x86_64-3.txz:  Rebuilt.
l/python-random2-1.0.1-x86_64-3.txz:  Rebuilt.
l/python-requests-2.25.1-x86_64-3.txz:  Rebuilt.
l/python-sane-2.9.1-x86_64-3.txz:  Rebuilt.
l/python-six-1.15.0-x86_64-4.txz:  Rebuilt.
l/python-urllib3-1.26.3-x86_64-2.txz:  Rebuilt.
l/python2-module-collection-2.7.18-x86_64-3.txz:  Rebuilt.
l/qca-2.3.2-x86_64-2.txz:  Rebuilt.
l/qrencode-4.1.1-x86_64-3.txz:  Rebuilt.
l/qt5-5.15.2-x86_64-4.txz:  Rebuilt.
l/qt5-webkit-5.212.0_alpha4-x86_64-6.txz:  Rebuilt.
l/qtkeychain-0.12.0-x86_64-3.txz:  Rebuilt.
l/quazip-1.1-x86_64-3.txz:  Rebuilt.
l/readline-8.1.000-x86_64-3.txz:  Rebuilt.
l/rpcsvc-proto-1.4.2-x86_64-3.txz:  Rebuilt.
l/rttr-0.9.6-x86_64-4.txz:  Rebuilt.
l/sbc-1.5-x86_64-3.txz:  Rebuilt.
l/sdl-1.2.15-x86_64-11.txz:  Rebuilt.
l/serf-1.3.9-x86_64-6.txz:  Rebuilt.
l/sg3_utils-1.45-x86_64-3.txz:  Rebuilt.
l/shared-desktop-ontologies-0.11.0-x86_64-4.txz:  Rebuilt.
l/shared-mime-info-2.1-x86_64-3.txz:  Rebuilt.
l/sip-4.19.23-x86_64-4.txz:  Rebuilt.
l/slang-2.3.2-x86_64-5.txz:  Rebuilt.
l/slang1-1.4.9-x86_64-4.txz:  Rebuilt.
l/sound-theme-freedesktop-0.8-noarch-4.txz:  Rebuilt.
l/speech-dispatcher-0.10.2-x86_64-3.txz:  Rebuilt.
l/speex-1.2.0-x86_64-4.txz:  Rebuilt.
l/speexdsp-1.2.0-x86_64-3.txz:  Rebuilt.
l/startup-notification-0.12-x86_64-5.txz:  Rebuilt.
l/svgalib-1.9.25-x86_64-6.txz:  Rebuilt.
l/system-config-printer-1.5.15-x86_64-3.txz:  Rebuilt.
l/t1lib-5.1.2-x86_64-6.txz:  Rebuilt.
l/taglib-1.11.1-x86_64-5.txz:  Rebuilt.
l/taglib-extras-1.0.1-x86_64-4.txz:  Rebuilt.
l/talloc-2.3.2-x86_64-2.txz:  Rebuilt.
l/tango-icon-theme-0.8.90-noarch-6.txz:  Rebuilt.
l/tango-icon-theme-extras-0.1.0-noarch-4.txz:  Rebuilt.
l/tdb-1.4.3-x86_64-6.txz:  Rebuilt.
l/tevent-0.10.2-x86_64-6.txz:  Rebuilt.
l/tidy-html5-5.6.0-x86_64-3.txz:  Rebuilt.
l/utf8proc-2.6.1-x86_64-3.txz:  Rebuilt.
l/v4l-utils-1.20.0-x86_64-3.txz:  Rebuilt.
l/vid.stab-20200916_e851e7b-x86_64-3.txz:  Rebuilt.
l/vte-0.62.2-x86_64-2.txz:  Rebuilt.
l/wavpack-5.4.0-x86_64-3.txz:  Rebuilt.
l/woff2-20180531_a0d0ed7-x86_64-3.txz:  Rebuilt.
l/xapian-core-1.4.18-x86_64-3.txz:  Rebuilt.
l/xxHash-0.8.0-x86_64-3.txz:  Rebuilt.
l/zlib-1.2.11-x86_64-4.txz:  Rebuilt.
l/zstd-1.4.8-x86_64-3.txz:  Rebuilt.
n/ModemManager-1.14.10-x86_64-3.txz:  Rebuilt.
n/NetworkManager-1.28.0-x86_64-5.txz:  Rebuilt.
n/alpine-2.24-x86_64-3.txz:  Rebuilt.
n/autofs-5.1.7-x86_64-2.txz:  Rebuilt.
n/biff+comsat-0.17-x86_64-4.txz:  Rebuilt.
n/bind-9.16.11-x86_64-2.txz:  Rebuilt.
n/bluez-5.55-x86_64-4.txz:  Rebuilt.
n/bluez-firmware-1.2-x86_64-4.txz:  Rebuilt.
n/bootp-2.4.3-x86_64-5.txz:  Rebuilt.
n/bridge-utils-1.7-x86_64-3.txz:  Rebuilt.
n/bsd-finger-0.17-x86_64-5.txz:  Rebuilt.
n/ca-certificates-20201219-noarch-3.txz:  Rebuilt.
n/cifs-utils-6.12-x86_64-3.txz:  Rebuilt.
n/conntrack-tools-1.4.6-x86_64-3.txz:  Rebuilt.
n/crda-4.14-x86_64-3.txz:  Rebuilt.
n/curl-7.75.0-x86_64-2.txz:  Rebuilt.
n/cyrus-sasl-2.1.27-x86_64-7.txz:  Rebuilt.
n/dehydrated-0.7.0-noarch-3.txz:  Rebuilt.
n/dhcp-4.4.2-x86_64-3.txz:  Rebuilt.
n/dhcpcd-8.1.9-x86_64-3.txz:  Rebuilt.
n/dnsmasq-2.84-x86_64-2.txz:  Rebuilt.
n/dovecot-2.3.13-x86_64-3.txz:  Rebuilt.
n/ebtables-2.0.11-x86_64-3.txz:  Rebuilt.
n/elm-2.5.8-x86_64-7.txz:  Rebuilt.
n/epic5-2.1.2-x86_64-7.txz:  Rebuilt.
n/ethtool-5.10-x86_64-3.txz:  Rebuilt.
n/fetchmail-6.4.16-x86_64-2.txz:  Rebuilt.
n/getmail-6.14-x86_64-3.txz:  Rebuilt.
n/gnupg-1.4.23-x86_64-4.txz:  Rebuilt.
n/gnupg2-2.2.27-x86_64-3.txz:  Rebuilt.
n/gnutls-3.6.15-x86_64-3.txz:  Rebuilt.
n/gpa-0.10.0-x86_64-3.txz:  Rebuilt.
n/gpgme-1.15.1-x86_64-3.txz:  Rebuilt.
n/htdig-3.2.0b6-x86_64-8.txz:  Rebuilt.
n/httpd-2.4.46-x86_64-3.txz:  Rebuilt.
n/icmpinfo-1.11-x86_64-5.txz:  Rebuilt.
n/iftop-1.0pre4-x86_64-4.txz:  Rebuilt.
n/inetd-1.79s-x86_64-14.txz:  Rebuilt.
n/iproute2-5.10.0-x86_64-3.txz:  Rebuilt.
n/ipset-7.10-x86_64-3.txz:  Rebuilt.
n/iptables-1.8.7-x86_64-3.txz:  Rebuilt.
n/iptraf-ng-1.2.1-x86_64-3.txz:  Rebuilt.
n/iputils-20210202-x86_64-2.txz:  Rebuilt.
n/ipw2100-fw-1.3-fw-3.txz:  Rebuilt.
n/ipw2200-fw-3.1-fw-3.txz:  Rebuilt.
n/irssi-1.2.2-x86_64-6.txz:  Rebuilt.
n/iw-5.9-x86_64-3.txz:  Rebuilt.
n/krb5-1.19-x86_64-2.txz:  Rebuilt.
n/lftp-4.9.2-x86_64-3.txz:  Rebuilt.
n/libassuan-2.5.4-x86_64-3.txz:  Rebuilt.
n/libgcrypt-1.9.1-x86_64-2.txz:  Rebuilt.
n/libgpg-error-1.41-x86_64-3.txz:  Rebuilt.
n/libksba-1.5.0-x86_64-3.txz:  Rebuilt.
n/libmbim-1.24.6-x86_64-2.txz:  Rebuilt.
n/libmilter-8.16.1-x86_64-3.txz:  Rebuilt.
n/libmnl-1.0.4-x86_64-5.txz:  Rebuilt.
n/libndp-1.7-x86_64-3.txz:  Rebuilt.
n/libnetfilter_acct-1.0.3-x86_64-4.txz:  Rebuilt.
n/libnetfilter_conntrack-1.0.8-x86_64-3.txz:  Rebuilt.
n/libnetfilter_cthelper-1.0.0-x86_64-4.txz:  Rebuilt.
n/libnetfilter_cttimeout-1.0.0-x86_64-4.txz:  Rebuilt.
n/libnetfilter_log-1.0.1-x86_64-4.txz:  Rebuilt.
n/libnetfilter_queue-1.0.5-x86_64-3.txz:  Rebuilt.
n/libnfnetlink-1.0.1-x86_64-4.txz:  Rebuilt.
n/libnftnl-1.1.9-x86_64-3.txz:  Rebuilt.
n/libqmi-1.26.8-x86_64-3.txz:  Rebuilt.
n/libtirpc-1.3.1-x86_64-3.txz:  Rebuilt.
n/links-2.21-x86_64-3.txz:  Rebuilt.
n/lynx-2.8.9rel.1-x86_64-3.txz:  Rebuilt.
n/mcabber-1.1.2-x86_64-3.txz:  Rebuilt.
n/metamail-2.7-x86_64-9.txz:  Rebuilt.
n/mobile-broadband-provider-info-20201225-x86_64-3.txz:  Rebuilt.
n/mtr-0.94-x86_64-3.txz:  Rebuilt.
n/mutt-2.0.5-x86_64-2.txz:  Rebuilt.
n/nc-1.10-x86_64-4.txz:  Rebuilt.
n/ncftp-3.2.6-x86_64-4.txz:  Rebuilt.
n/net-snmp-5.9-x86_64-5.txz:  Rebuilt.
n/net-tools-20181103_0eebece-x86_64-3.txz:  Rebuilt.
n/netatalk-3.1.12-x86_64-7.txz:  Rebuilt.
n/netdate-bsd4-x86_64-4.txz:  Rebuilt.
n/netkit-bootparamd-0.17-x86_64-6.txz:  Rebuilt.
n/netkit-ftp-0.17-x86_64-7.txz:  Rebuilt.
n/netkit-ntalk-0.17-x86_64-7.txz:  Rebuilt.
n/netkit-routed-0.17-x86_64-4.txz:  Rebuilt.
n/netkit-rsh-0.17-x86_64-5.txz:  Rebuilt.
n/netkit-rusers-0.17-x86_64-5.txz:  Rebuilt.
n/netkit-rwall-0.17-x86_64-5.txz:  Rebuilt.
n/netkit-rwho-0.17-x86_64-5.txz:  Rebuilt.
n/netkit-timed-0.17-x86_64-4.txz:  Rebuilt.
n/netpipes-4.2-x86_64-4.txz:  Rebuilt.
n/nettle-3.7-x86_64-3.txz:  Rebuilt.
n/netwatch-1.3.1_2-x86_64-5.txz:  Rebuilt.
n/network-scripts-15.0-noarch-11.txz:  Rebuilt.
n/netwrite-0.17-x86_64-4.txz:  Rebuilt.
n/newspost-2.1.1-x86_64-4.txz:  Rebuilt.
n/nfacct-1.0.2-x86_64-4.txz:  Rebuilt.
n/nfs-utils-2.5.2-x86_64-4.txz:  Rebuilt.
n/nftables-0.9.8-x86_64-3.txz:  Rebuilt.
n/nghttp2-1.43.0-x86_64-2.txz:  Rebuilt.
n/nmap-7.91-x86_64-3.txz:  Rebuilt.
n/nn-6.7.3-x86_64-8.txz:  Rebuilt.
n/npth-1.6-x86_64-3.txz:  Rebuilt.
n/nss-pam-ldapd-0.9.11-x86_64-3.txz:  Rebuilt.
n/ntp-4.2.8p15-x86_64-6.txz:  Rebuilt.
n/obexftp-0.24.2-x86_64-8.txz:  Rebuilt.
n/openldap-2.4.57-x86_64-2.txz:  Rebuilt.
n/openobex-1.7.2-x86_64-5.txz:  Rebuilt.
n/openssh-8.4p1-x86_64-5.txz:  Rebuilt.
n/openssl-1.1.1i-x86_64-3.txz:  Rebuilt.
n/openvpn-2.5.0-x86_64-3.txz:  Rebuilt.
n/p11-kit-0.23.22-x86_64-3.txz:  Rebuilt.
n/pam-krb5-4.9-x86_64-4.txz:  Rebuilt.
n/php-7.4.15-x86_64-2.txz:  Rebuilt.
n/pidentd-3.0.19-x86_64-6.txz:  Rebuilt.
n/pinentry-1.1.1-x86_64-2.txz:  Rebuilt.
n/popa3d-1.0.3-x86_64-6.txz:  Rebuilt.
n/postfix-3.5.9-x86_64-3.txz:  Rebuilt.
n/ppp-2.4.9-x86_64-2.txz:  Rebuilt.
n/procmail-3.22-x86_64-6.txz:  Rebuilt.
n/proftpd-1.3.7a-x86_64-4.txz:  Rebuilt.
n/pssh-2.3.4-x86_64-4.txz:  Rebuilt.
n/rdist-6.1.5-x86_64-5.txz:  Rebuilt.
n/rp-pppoe-3.14-x86_64-4.txz:  Rebuilt.
n/rpcbind-1.2.5-x86_64-5.txz:  Rebuilt.
n/rsync-3.2.3-x86_64-3.txz:  Rebuilt.
n/s-nail-14.9.21-x86_64-2.txz:  Rebuilt.
n/samba-4.13.4-x86_64-3.txz:  Rebuilt.
n/slrn-1.0.3a-x86_64-3.txz:  Rebuilt.
n/snownews-1.6.10-x86_64-3.txz:  Rebuilt.
n/socat-1.7.4.1-x86_64-3.txz:  Rebuilt.
n/sshfs-3.7.1-x86_64-3.txz:  Rebuilt.
n/stunnel-5.57-x86_64-4.txz:  Rebuilt.
n/tcp_wrappers-7.6-x86_64-6.txz:  Rebuilt.
n/tcpdump-4.99.0-x86_64-2.txz:  Rebuilt.
n/telnet-0.17-x86_64-6.txz:  Rebuilt.
n/tftp-hpa-5.2-x86_64-8.txz:  Rebuilt.
n/tin-2.4.5-x86_64-2.txz:  Rebuilt.
n/traceroute-2.1.0-x86_64-4.txz:  Rebuilt.
n/ulogd-2.0.7-x86_64-4.txz:  Rebuilt.
n/uucp-1.07-x86_64-5.txz:  Rebuilt.
n/vlan-1.9-x86_64-5.txz:  Rebuilt.
n/vsftpd-3.0.3-x86_64-9.txz:  Rebuilt.
n/wget-1.21.1-x86_64-3.txz:  Rebuilt.
n/whois-5.5.7-x86_64-3.txz:  Rebuilt.
n/wireless_tools-30.pre9-x86_64-3.txz:  Rebuilt.
n/wpa_supplicant-2.9-x86_64-6.txz:  Rebuilt.
n/yptools-4.2.3-x86_64-3.txz:  Rebuilt.
n/ytalk-3.3.0-x86_64-6.txz:  Rebuilt.
n/zd1211-firmware-1.5-fw-4.txz:  Rebuilt.
t/fig2dev-3.2.8-x86_64-3.txz:  Rebuilt.
t/texlive-2020.200608-x86_64-4.txz:  Rebuilt.
t/xfig-3.2.8-x86_64-3.txz:  Rebuilt.
tcl/expect-5.45.4-x86_64-4.txz:  Rebuilt.
tcl/hfsutils-3.2.6-x86_64-8.txz:  Rebuilt.
tcl/tcl-8.6.11-x86_64-3.txz:  Rebuilt.
tcl/tclx-8.4.4-x86_64-3.txz:  Rebuilt.
tcl/tix-8.4.3-x86_64-6.txz:  Rebuilt.
tcl/tk-8.6.11.1-x86_64-3.txz:  Rebuilt.
Chết rồi ! ✍ ⌥⌘ http://codeberg.org/gwh
n°1460830
cycojesus
Mèo Lười
Posté le 15-02-2021 à 23:03:38  profilanswer
T'as encore soif ? (2/2)
x/OpenCC-1.1.1-x86_64-3.txz:  Rebuilt.
x/anthy-9100h-x86_64-4.txz:  Rebuilt.
x/appres-1.0.5-x86_64-4.txz:  Rebuilt.
x/bdftopcf-1.1-x86_64-4.txz:  Rebuilt.
x/beforelight-1.0.5-x86_64-5.txz:  Rebuilt.
x/bitmap-1.0.9-x86_64-3.txz:  Rebuilt.
x/cldr-emoji-annotation-37.0_13.0_0_2-noarch-3.txz:  Rebuilt.
x/compiz-0.8.18-x86_64-3.txz:  Rebuilt.
x/dejavu-fonts-ttf-2.37-noarch-6.txz:  Rebuilt.
x/editres-1.0.7-x86_64-4.txz:  Rebuilt.
x/encodings-1.0.5-noarch-3.txz:  Rebuilt.
x/fcitx-4.2.9.8-x86_64-3.txz:  Rebuilt.
x/fcitx-anthy-0.2.3-x86_64-3.txz:  Rebuilt.
x/fcitx-configtool-0.4.10-x86_64-3.txz:  Rebuilt.
x/fcitx-hangul-0.3.1-x86_64-3.txz:  Rebuilt.
x/fcitx-kkc-0.1.4-x86_64-3.txz:  Rebuilt.
x/fcitx-libpinyin-0.5.4-x86_64-2.txz:  Rebuilt.
x/fcitx-m17n-0.2.4-x86_64-3.txz:  Rebuilt.
x/fcitx-qt5-1.2.5-x86_64-3.txz:  Rebuilt.
x/fcitx-sayura-0.1.2-x86_64-3.txz:  Rebuilt.
x/fcitx-table-extra-0.3.8-x86_64-3.txz:  Rebuilt.
x/fcitx-table-other-0.2.4-x86_64-3.txz:  Rebuilt.
x/fcitx-unikey-0.2.7-x86_64-3.txz:  Rebuilt.
x/font-adobe-100dpi-1.0.3-noarch-5.txz:  Rebuilt.
x/font-adobe-75dpi-1.0.3-noarch-5.txz:  Rebuilt.
x/font-adobe-utopia-100dpi-1.0.4-noarch-5.txz:  Rebuilt.
x/font-adobe-utopia-75dpi-1.0.4-noarch-5.txz:  Rebuilt.
x/font-adobe-utopia-type1-1.0.4-noarch-5.txz:  Rebuilt.
x/font-alias-1.0.4-noarch-3.txz:  Rebuilt.
x/font-arabic-misc-1.0.3-noarch-5.txz:  Rebuilt.
x/font-bh-100dpi-1.0.3-noarch-5.txz:  Rebuilt.
x/font-bh-75dpi-1.0.3-noarch-5.txz:  Rebuilt.
x/font-bh-lucidatypewriter-100dpi-1.0.3-noarch-5.txz:  Rebuilt.
x/font-bh-lucidatypewriter-75dpi-1.0.3-noarch-5.txz:  Rebuilt.
x/font-bh-ttf-1.0.3-noarch-5.txz:  Rebuilt.
x/font-bh-type1-1.0.3-noarch-5.txz:  Rebuilt.
x/font-bitstream-100dpi-1.0.3-noarch-5.txz:  Rebuilt.
x/font-bitstream-75dpi-1.0.3-noarch-5.txz:  Rebuilt.
x/font-bitstream-speedo-1.0.2-noarch-5.txz:  Rebuilt.
x/font-bitstream-type1-1.0.3-noarch-5.txz:  Rebuilt.
x/font-cronyx-cyrillic-1.0.3-noarch-5.txz:  Rebuilt.
x/font-cursor-misc-1.0.3-noarch-5.txz:  Rebuilt.
x/font-daewoo-misc-1.0.3-noarch-5.txz:  Rebuilt.
x/font-dec-misc-1.0.3-noarch-5.txz:  Rebuilt.
x/font-ibm-type1-1.0.3-noarch-5.txz:  Rebuilt.
x/font-isas-misc-1.0.3-noarch-5.txz:  Rebuilt.
x/font-jis-misc-1.0.3-noarch-5.txz:  Rebuilt.
x/font-micro-misc-1.0.3-noarch-5.txz:  Rebuilt.
x/font-misc-cyrillic-1.0.3-noarch-5.txz:  Rebuilt.
x/font-misc-ethiopic-1.0.4-noarch-3.txz:  Rebuilt.
x/font-misc-meltho-1.0.3-noarch-5.txz:  Rebuilt.
x/font-misc-misc-1.1.2-noarch-5.txz:  Rebuilt.
x/font-mutt-misc-1.0.3-noarch-5.txz:  Rebuilt.
x/font-schumacher-misc-1.1.2-noarch-5.txz:  Rebuilt.
x/font-screen-cyrillic-1.0.4-noarch-5.txz:  Rebuilt.
x/font-sony-misc-1.0.3-noarch-5.txz:  Rebuilt.
x/font-sun-misc-1.0.3-noarch-5.txz:  Rebuilt.
x/font-util-1.3.2-x86_64-3.txz:  Rebuilt.
x/font-winitzki-cyrillic-1.0.3-noarch-5.txz:  Rebuilt.
x/font-xfree86-type1-1.0.4-noarch-5.txz:  Rebuilt.
x/fontconfig-2.13.92-x86_64-3.txz:  Rebuilt.
x/fonttosfnt-1.2.1-x86_64-3.txz:  Rebuilt.
x/freeglut-3.2.1-x86_64-3.txz:  Rebuilt.
x/fslsfonts-1.0.5-x86_64-5.txz:  Rebuilt.
x/fstobdf-1.0.6-x86_64-5.txz:  Rebuilt.
x/gccmakedep-1.0.3-noarch-4.txz:  Rebuilt.
x/glew-2.2.0-x86_64-3.txz:  Rebuilt.
x/glu-9.0.1-x86_64-3.txz:  Rebuilt.
x/hack-fonts-ttf-3.003-noarch-3.txz:  Rebuilt.
x/ibus-1.5.23-x86_64-3.txz:  Rebuilt.
x/ibus-anthy-1.5.11-x86_64-3.txz:  Rebuilt.
x/ibus-hangul-1.5.4-x86_64-3.txz:  Rebuilt.
x/ibus-kkc-1.5.22-x86_64-3.txz:  Rebuilt.
x/ibus-libpinyin-1.12.0-x86_64-2.txz:  Rebuilt.
x/ibus-m17n-1.4.4-x86_64-2.txz:  Rebuilt.
x/ibus-table-1.12.4-x86_64-2.txz:  Rebuilt.
x/ibus-unikey-0.6.1-x86_64-3.txz:  Rebuilt.
x/iceauth-1.0.8-x86_64-4.txz:  Rebuilt.
x/ico-1.0.5-x86_64-4.txz:  Rebuilt.
x/igt-gpu-tools-1.25-x86_64-3.txz:  Rebuilt.
x/imake-1.0.8-x86_64-3.txz:  Rebuilt.
x/intel-vaapi-driver-2.4.1-x86_64-3.txz:  Rebuilt.
x/libFS-1.0.8-x86_64-3.txz:  Rebuilt.
x/libICE-1.0.10-x86_64-3.txz:  Rebuilt.
x/libSM-1.2.3-x86_64-3.txz:  Rebuilt.
x/libX11-1.7.0-x86_64-3.txz:  Rebuilt.
x/libXScrnSaver-1.2.3-x86_64-3.txz:  Rebuilt.
x/libXau-1.0.9-x86_64-3.txz:  Rebuilt.
x/libXaw-1.0.13-x86_64-4.txz:  Rebuilt.
x/libXaw3d-1.6.3-x86_64-3.txz:  Rebuilt.
x/libXaw3dXft-1.6.2h-x86_64-3.txz:  Rebuilt.
x/libXcm-0.5.4-x86_64-3.txz:  Rebuilt.
x/libXcomposite-0.4.5-x86_64-3.txz:  Rebuilt.
x/libXcursor-1.2.0-x86_64-3.txz:  Rebuilt.
x/libXdamage-1.1.5-x86_64-3.txz:  Rebuilt.
x/libXdmcp-1.1.3-x86_64-3.txz:  Rebuilt.
x/libXevie-1.0.3-x86_64-5.txz:  Rebuilt.
x/libXext-1.3.4-x86_64-3.txz:  Rebuilt.
x/libXfixes-5.0.3-x86_64-4.txz:  Rebuilt.
x/libXfont2-2.0.4-x86_64-3.txz:  Rebuilt.
x/libXfontcache-1.0.5-x86_64-5.txz:  Rebuilt.
x/libXft-2.3.3-x86_64-3.txz:  Rebuilt.
x/libXi-1.7.10-x86_64-3.txz:  Rebuilt.
x/libXinerama-1.1.4-x86_64-3.txz:  Rebuilt.
x/libXmu-1.1.3-x86_64-3.txz:  Rebuilt.
x/libXp-1.0.3-x86_64-5.txz:  Rebuilt.
x/libXpm-3.5.13-x86_64-3.txz:  Rebuilt.
x/libXpresent-1.0.0-x86_64-4.txz:  Rebuilt.
x/libXrandr-1.5.2-x86_64-3.txz:  Rebuilt.
x/libXrender-0.9.10-x86_64-4.txz:  Rebuilt.
x/libXres-1.2.0-x86_64-4.txz:  Rebuilt.
x/libXt-1.2.1-x86_64-2.txz:  Rebuilt.
x/libXtst-1.2.3-x86_64-4.txz:  Rebuilt.
x/libXv-1.0.11-x86_64-4.txz:  Rebuilt.
x/libXvMC-1.0.12-x86_64-5.txz:  Rebuilt.
x/libXxf86dga-1.1.5-x86_64-3.txz:  Rebuilt.
x/libXxf86misc-1.0.4-x86_64-3.txz:  Rebuilt.
x/libXxf86vm-1.1.4-x86_64-5.txz:  Rebuilt.
x/libdmx-1.1.4-x86_64-3.txz:  Rebuilt.
x/libdrm-2.4.104-x86_64-3.txz:  Rebuilt.
x/libepoxy-1.5.5-x86_64-3.txz:  Rebuilt.
x/liberation-fonts-ttf-2.1.2-noarch-3.txz:  Rebuilt.
x/libevdev-1.11.0-x86_64-2.txz:  Rebuilt.
x/libfontenc-1.1.4-x86_64-3.txz:  Rebuilt.
x/libgee-0.20.3-x86_64-3.txz:  Rebuilt.
x/libglvnd-1.3.2-x86_64-3.txz:  Rebuilt.
x/libhangul-0.1.0-x86_64-4.txz:  Rebuilt.
x/libinput-1.16.4-x86_64-3.txz:  Rebuilt.
x/libkkc-0.3.5-x86_64-3.txz:  Rebuilt.
x/libkkc-data-0.2.7-x86_64-3.txz:  Rebuilt.
x/libmypaint-1.6.1-x86_64-4.txz:  Rebuilt.
x/libpciaccess-0.16-x86_64-3.txz:  Rebuilt.
x/libpinyin-2.6.0-x86_64-2.txz:  Rebuilt.
x/libpthread-stubs-0.4-x86_64-5.txz:  Rebuilt.
x/libva-2.10.0-x86_64-3.txz:  Rebuilt.
x/libva-utils-2.10.0-x86_64-3.txz:  Rebuilt.
x/libvdpau-1.4-x86_64-3.txz:  Rebuilt.
x/libwacom-1.8-x86_64-2.txz:  Rebuilt.
x/libxcb-1.14-x86_64-3.txz:  Rebuilt.
x/libxkbfile-1.1.0-x86_64-3.txz:  Rebuilt.
x/libxshmfence-1.3-x86_64-4.txz:  Rebuilt.
x/listres-1.0.4-x86_64-4.txz:  Rebuilt.
x/lndir-1.0.3-x86_64-5.txz:  Rebuilt.
x/luit-1.1.1-x86_64-5.txz:  Rebuilt.
x/m17n-lib-1.8.0-x86_64-4.txz:  Rebuilt.
x/makedepend-1.0.6-x86_64-3.txz:  Rebuilt.
x/marisa-0.2.6-x86_64-4.txz:  Rebuilt.
x/mesa-20.3.4-x86_64-2.txz:  Rebuilt.
x/mkcomposecache-1.2.1-x86_64-5.txz:  Rebuilt.
x/mkfontscale-1.2.1-x86_64-4.txz:  Rebuilt.
x/motif-2.3.8-x86_64-5.txz:  Rebuilt.
x/mtdev-1.1.6-x86_64-3.txz:  Rebuilt.
x/mypaint-brushes-1.3.0-noarch-3.txz:  Rebuilt.
x/noto-cjk-fonts-ttf-2.001-noarch-3.txz:  Rebuilt.
x/noto-fonts-ttf-20171024-noarch-3.txz:  Rebuilt.
x/oclock-1.0.4-x86_64-4.txz:  Rebuilt.
x/pixman-0.40.0-x86_64-3.txz:  Rebuilt.
x/pyxdg-0.27-x86_64-4.txz:  Rebuilt.
x/rendercheck-1.5-x86_64-4.txz:  Rebuilt.
x/rgb-1.0.6-x86_64-5.txz:  Rebuilt.
x/sazanami-fonts-ttf-20040629-noarch-5.txz:  Rebuilt.
x/sessreg-1.1.2-x86_64-3.txz:  Rebuilt.
x/setxkbmap-1.3.2-x86_64-3.txz:  Rebuilt.
x/showfont-1.0.5-x86_64-5.txz:  Rebuilt.
x/sinhala_lklug-font-ttf-20060929-noarch-5.txz:  Rebuilt.
x/skkdic-20200128-noarch-3.txz:  Rebuilt.
x/smproxy-1.0.6-x86_64-4.txz:  Rebuilt.
x/tibmachuni-font-ttf-1.901b-noarch-5.txz:  Rebuilt.
x/transset-1.0.2-x86_64-4.txz:  Rebuilt.
x/ttf-indic-fonts-0.5.14-noarch-5.txz:  Rebuilt.
x/ttf-tlwg-0.7.2-noarch-3.txz:  Rebuilt.
x/twm-1.0.11-x86_64-3.txz:  Rebuilt.
x/urw-core35-fonts-otf-20170801_91edd6e_git-noarch-4.txz:  Rebuilt.
x/util-macros-1.19.3-noarch-2.txz:  Rebuilt.
x/viewres-1.0.6-x86_64-3.txz:  Rebuilt.
x/vulkan-sdk-1.2.141.0-x86_64-4.txz:  Rebuilt.
x/wayland-1.19.0-x86_64-2.txz:  Rebuilt.
x/wayland-protocols-1.20-noarch-3.txz:  Rebuilt.
x/wqy-zenhei-font-ttf-0.8.38_1-noarch-9.txz:  Rebuilt.
x/x11-skel-7.7-x86_64-8.txz:  Rebuilt.
x/x11perf-1.6.1-x86_64-3.txz:  Rebuilt.
x/xauth-1.1-x86_64-3.txz:  Rebuilt.
x/xbacklight-1.2.3-x86_64-3.txz:  Rebuilt.
x/xbiff-1.0.4-x86_64-3.txz:  Rebuilt.
x/xbitmaps-1.1.2-x86_64-4.txz:  Rebuilt.
x/xcalc-1.1.0-x86_64-3.txz:  Rebuilt.
x/xcb-proto-1.14.1-x86_64-4.txz:  Rebuilt.
x/xcb-util-0.4.0-x86_64-5.txz:  Rebuilt.
x/xcb-util-cursor-0.1.3-x86_64-4.txz:  Rebuilt.
x/xcb-util-errors-1.0-x86_64-4.txz:  Rebuilt.
x/xcb-util-image-0.4.0-x86_64-5.txz:  Rebuilt.
x/xcb-util-keysyms-0.4.0-x86_64-5.txz:  Rebuilt.
x/xcb-util-renderutil-0.3.9-x86_64-5.txz:  Rebuilt.
x/xcb-util-wm-0.4.1-x86_64-5.txz:  Rebuilt.
x/xclipboard-1.1.3-x86_64-5.txz:  Rebuilt.
x/xclock-1.0.9-x86_64-3.txz:  Rebuilt.
x/xcm-0.5.4-x86_64-4.txz:  Rebuilt.
x/xcmsdb-1.0.5-x86_64-4.txz:  Rebuilt.
x/xcompmgr-1.1.8-x86_64-3.txz:  Rebuilt.
x/xconsole-1.0.7-x86_64-4.txz:  Rebuilt.
x/xcursor-themes-1.0.6-noarch-3.txz:  Rebuilt.
x/xcursorgen-1.0.7-x86_64-3.txz:  Rebuilt.
x/xdbedizzy-1.1.0-x86_64-5.txz:  Rebuilt.
x/xdg-user-dirs-0.17-x86_64-3.txz:  Rebuilt.
x/xdg-utils-1.1.3-noarch-4.txz:  Rebuilt.
x/xditview-1.0.5-x86_64-3.txz:  Rebuilt.
x/xdm-1.1.11-x86_64-14.txz:  Rebuilt.
x/xdpyinfo-1.3.2-x86_64-4.txz:  Rebuilt.
x/xdriinfo-1.0.6-x86_64-4.txz:  Rebuilt.
x/xedit-1.2.2-x86_64-5.txz:  Rebuilt.
x/xev-1.2.4-x86_64-3.txz:  Rebuilt.
x/xeyes-1.1.2-x86_64-4.txz:  Rebuilt.
x/xf86-input-acecad-1.5.0-x86_64-14.txz:  Rebuilt.
x/xf86-input-evdev-2.10.6-x86_64-3.txz:  Rebuilt.
x/xf86-input-joystick-1.6.3-x86_64-5.txz:  Rebuilt.
x/xf86-input-keyboard-1.9.0-x86_64-5.txz:  Rebuilt.
x/xf86-input-libinput-0.30.0-x86_64-3.txz:  Rebuilt.
x/xf86-input-mouse-1.9.3-x86_64-3.txz:  Rebuilt.
x/xf86-input-penmount-1.5.0-x86_64-14.txz:  Rebuilt.
x/xf86-input-synaptics-1.9.1-x86_64-3.txz:  Rebuilt.
x/xf86-input-vmmouse-13.1.0-x86_64-9.txz:  Rebuilt.
x/xf86-input-void-1.4.1-x86_64-3.txz:  Rebuilt.
x/xf86-input-wacom-0.40.0-x86_64-2.txz:  Rebuilt.
x/xf86-video-amdgpu-19.1.0-x86_64-3.txz:  Rebuilt.
x/xf86-video-apm-1.3.0-x86_64-3.txz:  Rebuilt.
x/xf86-video-ark-0.7.5-x86_64-13.txz:  Rebuilt.
x/xf86-video-ast-1.1.5-x86_64-7.txz:  Rebuilt.
x/xf86-video-ati-19.1.0-x86_64-3.txz:  Rebuilt.
x/xf86-video-chips-1.4.0-x86_64-3.txz:  Rebuilt.
x/xf86-video-cirrus-1.5.3-x86_64-7.txz:  Rebuilt.
x/xf86-video-dummy-0.3.8-x86_64-5.txz:  Rebuilt.
x/xf86-video-glint-1.2.9-x86_64-5.txz:  Rebuilt.
x/xf86-video-i128-1.4.0-x86_64-3.txz:  Rebuilt.
x/xf86-video-i740-1.4.0-x86_64-3.txz:  Rebuilt.
x/xf86-video-intel-20201215_a511f22c-x86_64-3.txz:  Rebuilt.
x/xf86-video-mach64-6.9.6-x86_64-3.txz:  Rebuilt.
x/xf86-video-mga-2.0.0-x86_64-3.txz:  Rebuilt.
x/xf86-video-neomagic-1.3.0-x86_64-3.txz:  Rebuilt.
x/xf86-video-nouveau-1.0.17-x86_64-2.txz:  Rebuilt.
x/xf86-video-nv-2.1.21-x86_64-5.txz:  Rebuilt.
x/xf86-video-openchrome-0.6.0-x86_64-5.txz:  Rebuilt.
x/xf86-video-r128-6.12.0-x86_64-3.txz:  Rebuilt.
x/xf86-video-rendition-4.2.7-x86_64-3.txz:  Rebuilt.
x/xf86-video-s3-0.7.0-x86_64-3.txz:  Rebuilt.
x/xf86-video-s3virge-1.11.0-x86_64-3.txz:  Rebuilt.
x/xf86-video-savage-20190128_8579718-x86_64-3.txz:  Rebuilt.
x/xf86-video-siliconmotion-1.7.9-x86_64-5.txz:  Rebuilt.
x/xf86-video-sis-0.12.0-x86_64-3.txz:  Rebuilt.
x/xf86-video-sisusb-0.9.7-x86_64-5.txz:  Rebuilt.
x/xf86-video-tdfx-1.5.0-x86_64-3.txz:  Rebuilt.
x/xf86-video-tga-1.2.2-x86_64-13.txz:  Rebuilt.
x/xf86-video-trident-1.3.8-x86_64-5.txz:  Rebuilt.
x/xf86-video-tseng-1.2.5-x86_64-13.txz:  Rebuilt.
x/xf86-video-v4l-0.3.0-x86_64-3.txz:  Rebuilt.
x/xf86-video-vboxvideo-1.0.0-x86_64-5.txz:  Rebuilt.
x/xf86-video-vesa-2.5.0-x86_64-3.txz:  Rebuilt.
x/xf86-video-vmware-13.3.0-x86_64-5.txz:  Rebuilt.
x/xf86-video-voodoo-1.2.5-x86_64-14.txz:  Rebuilt.
x/xf86dga-1.0.3-x86_64-5.txz:  Rebuilt.
x/xfd-1.1.3-x86_64-3.txz:  Rebuilt.
x/xfontsel-1.0.6-x86_64-4.txz:  Rebuilt.
x/xfs-1.2.0-x86_64-4.txz:  Rebuilt.
x/xfsinfo-1.0.6-x86_64-3.txz:  Rebuilt.
x/xgamma-1.0.6-x86_64-4.txz:  Rebuilt.
x/xgc-1.0.5-x86_64-4.txz:  Rebuilt.
x/xhost-1.0.8-x86_64-3.txz:  Rebuilt.
x/xinit-1.4.1-x86_64-4.txz:  Rebuilt.
x/xinput-1.6.3-x86_64-3.txz:  Rebuilt.
x/xisxwayland-1-x86_64-3.txz:  Rebuilt.
x/xkbcomp-1.4.4-x86_64-3.txz:  Rebuilt.
x/xkbevd-1.1.4-x86_64-4.txz:  Rebuilt.
x/xkbprint-1.0.5-x86_64-3.txz:  Rebuilt.
x/xkbutils-1.0.4-x86_64-5.txz:  Rebuilt.
x/xkeyboard-config-2.31-noarch-3.txz:  Rebuilt.
x/xkill-1.0.5-x86_64-4.txz:  Rebuilt.
x/xload-1.1.3-x86_64-4.txz:  Rebuilt.
x/xlogo-1.0.5-x86_64-3.txz:  Rebuilt.
x/xlsatoms-1.1.3-x86_64-3.txz:  Rebuilt.
x/xlsclients-1.1.4-x86_64-4.txz:  Rebuilt.
x/xlsfonts-1.0.6-x86_64-4.txz:  Rebuilt.
x/xmag-1.0.6-x86_64-4.txz:  Rebuilt.
x/xman-1.1.5-x86_64-3.txz:  Rebuilt.
x/xmessage-1.0.5-x86_64-4.txz:  Rebuilt.
x/xmh-1.0.3-x86_64-4.txz:  Rebuilt.
x/xmodmap-1.0.10-x86_64-3.txz:  Rebuilt.
x/xmore-1.0.3-x86_64-3.txz:  Rebuilt.
x/xorg-cf-files-1.0.6-x86_64-5.txz:  Rebuilt.
x/xorg-docs-1.7.1-noarch-4.txz:  Rebuilt.
x/xorg-server-1.20.10-x86_64-5.txz:  Rebuilt.
x/xorg-server-xephyr-1.20.10-x86_64-5.txz:  Rebuilt.
x/xorg-server-xnest-1.20.10-x86_64-5.txz:  Rebuilt.
x/xorg-server-xvfb-1.20.10-x86_64-5.txz:  Rebuilt.
x/xorg-server-xwayland-1.20.10-x86_64-5.txz:  Rebuilt.
x/xorg-sgml-doctools-1.11-x86_64-5.txz:  Rebuilt.
x/xorgproto-2020.1-x86_64-3.txz:  Rebuilt.
x/xpr-1.0.5-x86_64-4.txz:  Rebuilt.
x/xprop-1.2.5-x86_64-3.txz:  Rebuilt.
x/xpyb-1.3.1-x86_64-7.txz:  Rebuilt.
x/xrandr-1.5.1-x86_64-3.txz:  Rebuilt.
x/xrdb-1.2.0-x86_64-3.txz:  Rebuilt.
x/xrefresh-1.0.6-x86_64-4.txz:  Rebuilt.
x/xscope-1.4.1-x86_64-5.txz:  Rebuilt.
x/xset-1.2.4-x86_64-4.txz:  Rebuilt.
x/xsetroot-1.1.2-x86_64-4.txz:  Rebuilt.
x/xsm-1.0.4-x86_64-4.txz:  Rebuilt.
x/xstdcmap-1.0.4-x86_64-3.txz:  Rebuilt.
x/xterm-366-x86_64-2.txz:  Rebuilt.
x/xtrans-1.4.0-noarch-3.txz:  Rebuilt.
x/xvidtune-1.0.3-x86_64-5.txz:  Rebuilt.
x/xvinfo-1.1.4-x86_64-3.txz:  Rebuilt.
x/xwd-1.0.7-x86_64-4.txz:  Rebuilt.
x/xwininfo-1.1.5-x86_64-3.txz:  Rebuilt.
x/xwud-1.0.5-x86_64-4.txz:  Rebuilt.
xap/MPlayer-20200103-x86_64-4.txz:  Rebuilt.
xap/NetworkManager-openvpn-1.8.12-x86_64-3.txz:  Rebuilt.
xap/audacious-4.1-x86_64-2.txz:  Rebuilt.
xap/audacious-plugins-4.1-x86_64-2.txz:  Rebuilt.
xap/blackbox-0.76-x86_64-3.txz:  Rebuilt.
xap/blueman-2.1.4-x86_64-5.txz:  Rebuilt.
xap/ddd-3.3.12-x86_64-8.txz:  Rebuilt.
xap/easytag-2.4.3-x86_64-4.txz:  Rebuilt.
xap/electricsheep-20090306-x86_64-7.txz:  Rebuilt.
xap/ffmpegthumbnailer-2.2.2-x86_64-3.txz:  Rebuilt.
xap/fluxbox-1.3.7-x86_64-5.txz:  Rebuilt.
xap/fvwm-2.6.9-x86_64-4.txz:  Rebuilt.
xap/geeqie-1.6-x86_64-3.txz:  Rebuilt.
xap/gftp-2.7.0b-x86_64-2.txz:  Rebuilt.
xap/gimp-2.10.22-x86_64-4.txz:  Rebuilt.
xap/gkrellm-2.3.11-x86_64-3.txz:  Rebuilt.
xap/gnuchess-6.2.7-x86_64-3.txz:  Rebuilt.
xap/gnuplot-5.4.1-x86_64-3.txz:  Rebuilt.
xap/gparted-1.2.0-x86_64-2.txz:  Rebuilt.
xap/gucharmap-12.0.1-x86_64-3.txz:  Rebuilt.
xap/gv-3.7.4-x86_64-5.txz:  Rebuilt.
xap/hexchat-2.14.3-x86_64-7.txz:  Rebuilt.
xap/libnma-1.8.30-x86_64-3.txz:  Rebuilt.
xap/network-manager-applet-1.20.0-x86_64-2.txz:  Rebuilt.
xap/pan-0.146-x86_64-4.txz:  Rebuilt.
xap/pavucontrol-4.0-x86_64-3.txz:  Rebuilt.
xap/pidgin-2.14.1-x86_64-4.txz:  Rebuilt.
xap/rdesktop-1.9.0-x86_64-4.txz:  Rebuilt.
xap/rxvt-unicode-9.22-x86_64-11.txz:  Rebuilt.
xap/sane-1.0.31-x86_64-3.txz:  Rebuilt.
xap/seyon-2.20c-x86_64-6.txz:  Rebuilt.
xap/ssr-0.4.2-x86_64-4.txz:  Rebuilt.
xap/vim-gvim-8.2.2461-x86_64-2.txz:  Rebuilt.
xap/windowmaker-0.95.9-x86_64-3.txz:  Rebuilt.
xap/x11-ssh-askpass-1.2.4.1-x86_64-5.txz:  Rebuilt.
xap/x3270-3.3.12ga7-x86_64-7.txz:  Rebuilt.
xap/xaos-4.2.1-x86_64-2.txz:  Rebuilt.
xap/xgames-0.3-x86_64-8.txz:  Rebuilt.
xap/xine-lib-1.2.11-x86_64-4.txz:  Rebuilt.
xap/xine-ui-0.99.12-x86_64-4.txz:  Rebuilt.
xap/xlockmore-5.66-x86_64-3.txz:  Rebuilt.
xap/xmms-1.2.11-x86_64-8.txz:  Rebuilt.
xap/xpaint-3.0.3-x86_64-3.txz:  Rebuilt.
xap/xpdf-4.03-x86_64-2.txz:  Rebuilt.
xap/xsane-0.999-x86_64-5.txz:  Rebuilt.
xap/xscreensaver-5.45-x86_64-4.txz:  Rebuilt.
xap/xsnow-3.2.2-x86_64-2.txz:  Rebuilt.
xfce/Greybird-3.22.14-noarch-3.txz:  Rebuilt.
xfce/elementary-xfce-0.15.1-x86_64-3.txz:  Rebuilt.
xfce/exo-4.16.0-x86_64-3.txz:  Rebuilt.
xfce/garcon-4.16.1-x86_64-3.txz:  Rebuilt.
xfce/libxfce4ui-4.16.0-x86_64-3.txz:  Rebuilt.
xfce/libxfce4util-4.16.0-x86_64-3.txz:  Rebuilt.
xfce/mousepad-0.5.2-x86_64-2.txz:  Rebuilt.
xfce/thunar-4.16.3-x86_64-2.txz:  Rebuilt.
xfce/thunar-volman-4.16.0-x86_64-3.txz:  Rebuilt.
xfce/tumbler-4.16.0-x86_64-3.txz:  Rebuilt.
xfce/xfce4-appfinder-4.16.1-x86_64-3.txz:  Rebuilt.
xfce/xfce4-clipman-plugin-1.6.1-x86_64-4.txz:  Rebuilt.
xfce/xfce4-dev-tools-4.16.0-x86_64-3.txz:  Rebuilt.
xfce/xfce4-notifyd-0.6.2-x86_64-4.txz:  Rebuilt.
xfce/xfce4-panel-4.16.1-x86_64-2.txz:  Rebuilt.
xfce/xfce4-panel-profiles-1.0.12-x86_64-3.txz:  Rebuilt.
xfce/xfce4-power-manager-4.16.0-x86_64-3.txz:  Rebuilt.
xfce/xfce4-pulseaudio-plugin-0.4.3-x86_64-4.txz:  Rebuilt.
xfce/xfce4-screensaver-4.16.0-x86_64-3.txz:  Rebuilt.
xfce/xfce4-screenshooter-1.9.8-x86_64-3.txz:  Rebuilt.
xfce/xfce4-session-4.16.0-x86_64-3.txz:  Rebuilt.
xfce/xfce4-settings-4.16.0-x86_64-3.txz:  Rebuilt.
xfce/xfce4-systemload-plugin-1.2.4-x86_64-4.txz:  Rebuilt.
xfce/xfce4-taskmanager-1.4.0-x86_64-3.txz:  Rebuilt.
xfce/xfce4-terminal-0.8.10-x86_64-3.txz:  Rebuilt.
xfce/xfce4-weather-plugin-0.10.2-x86_64-4.txz:  Rebuilt.
xfce/xfce4-whiskermenu-plugin-2.5.3-x86_64-2.txz:  Rebuilt.
xfce/xfconf-4.16.0-x86_64-3.txz:  Rebuilt.
xfce/xfdesktop-4.16.0-x86_64-3.txz:  Rebuilt.
xfce/xfwm4-4.16.1-x86_64-3.txz:  Rebuilt.
y/bsd-games-2.17-x86_64-3.txz:  Rebuilt.
y/nethack-3.6.6-x86_64-3.txz:  Rebuilt.
isolinux/initrd.img:  Rebuilt.
kernels/*:  Upgraded.
usb-and-pxe-installers/usbboot.img:  Rebuilt.
n°1460843
kisscoolz
Posté le 16-02-2021 à 11:05:28  profilanswer
[:hish]
Question au passage. Le noyau a basculer du 5.4 au 5.10 y'a quelque temps. Qu'en est il du 5.4 actuellement ? Je ne vois pas de suivi sur celui ci.
 Page :   1  2  3  4  5  ..  98  99  100  ..  109  110  111  112  113  114
Slackware 9.0[slackware] Suppression de terminaux virtuels ?
!! Configuration reseaux, slackware 9 !!Installer slackware 9.0 par ftp (boot disquette)
[Pb] Installation new HDD sous slackware 8.0[RESOLU] Pb d'execution mysql sur slackware ...
Slackware 9 du pur bonheurMonter une partition NTFS sous linux (slackware 9.0)
Slackware 9.0 Finale OUTJe sens que je vais quitter Slackware (pas en serv)
Plus de sujets relatifs à : [SLACKWARE] du présent - 15.0
