2333 connectés
La 15.0 est là (en vrai !)
Les invités peuvent voter
 Page :   1  2  3  4  5  ..  97  98  99  ..  109  110  111  112  113  114
[SLACKWARE] du présent - 15.0
n°1457535
cycojesus
Mèo Lười
Posté le 04-12-2020 à 10:43:49  profilanswer
Thu Dec  3 23:52:38 UTC 2020
a/kernel-generic-5.4.81-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.4.81-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.4.81-x86_64-1.txz:  Upgraded.
ap/cups-filters-1.28.6-x86_64-1.txz:  Upgraded.
ap/nano-5.4-x86_64-1.txz:  Upgraded.
d/binutils-2.35.1-x86_64-1.txz:  Upgraded.
d/gcc-10.2.0-x86_64-2.txz:  Rebuilt.
  These are the same GCC packages that were previously in /testing.
d/gcc-brig-10.2.0-x86_64-2.txz:  Rebuilt.
d/gcc-g++-10.2.0-x86_64-2.txz:  Rebuilt.
d/gcc-gdc-10.2.0-x86_64-2.txz:  Rebuilt.
  Shared library .so-version bump.
d/gcc-gfortran-10.2.0-x86_64-2.txz:  Rebuilt.
d/gcc-gnat-10.2.0-x86_64-2.txz:  Rebuilt.
d/gcc-go-10.2.0-x86_64-2.txz:  Rebuilt.
d/gcc-objc-10.2.0-x86_64-2.txz:  Rebuilt.
d/kernel-headers-5.4.81-x86-1.txz:  Upgraded.
d/libtool-2.4.6-x86_64-14.txz:  Rebuilt.
  Recompiled to update embedded GCC version number.
d/mercurial-5.6.1-x86_64-1.txz:  Upgraded.
d/oprofile-1.4.0-x86_64-2.txz:  Rebuilt.
d/python-pip-20.3.1-x86_64-1.txz:  Upgraded.
k/kernel-source-5.4.81-noarch-1.txz:  Upgraded.
 GCC_VERSION 90300 -> 100200
l/PyQt5-5.15.2-x86_64-1.txz:  Upgraded.
l/glibmm-2.64.5-x86_64-1.txz:  Upgraded.
x/mesa-20.3.0-x86_64-1.txz:  Upgraded.
xap/geeqie-1.6-x86_64-1.txz:  Upgraded.
xap/mozilla-thunderbird-78.5.1-x86_64-1.txz:  Upgraded.
  This release contains security fixes and improvements.
  For more information, see:
    https://www.mozilla.org/en-US/thunderbird/78.5.1/releasenotes/
    https://www.mozilla.org/en-US/security/advisories/mfsa2020-53/
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-26970
  (* Security fix *)
isolinux/initrd.img:  Rebuilt.
kernels/*:  Upgraded.
usb-and-pxe-installers/usbboot.img:  Rebuilt.
Message édité par cycojesus le 04-12-2020 à 11:23:24
Chết rồi ! ✍ ⌥⌘ http://codeberg.org/gwh
n°1457606
cycojesus
Mèo Lười
Posté le 05-12-2020 à 01:29:43  profilanswer
Fri Dec  4 21:30:08 UTC 2020
l/pcre2-10.36-x86_64-1.txz:  Upgraded.
l/poppler-20.12.0-x86_64-1.txz:  Upgraded.
n/libtirpc-1.3.1-x86_64-1.txz:  Upgraded.
x/libva-2.10.0-x86_64-1.txz:  Upgraded.
n°1457709
cycojesus
Mèo Lười
Posté le 06-12-2020 à 13:44:24  profilanswer
Sat Dec  5 20:36:27 UTC 2020
l/libproxy-0.4.16-x86_64-1.txz:  Upgraded.
n/mutt-2.0.3-x86_64-1.txz:  Upgraded.
n°1457782
cycojesus
Mèo Lười
Posté le 08-12-2020 à 08:46:35  profilanswer
Met des bretelles à ton slip, ça tournicote !
Mon Dec  7 21:49:58 UTC 2020
Goodbye vtown... we hardly knew you.
It is indeed the day of the Big Merge(tm) leaving nothing left in /testing (but
I'll try to work on that soon). In addition to merging packages from /testing,
Qt4 and related packages have gone away, along with some other libraries that
were only used by KDE4. Perhaps someone will want to take up maintenance of Qt4
(but I'm also pretty sure that SBo wouldn't touch that build script with a ten
foot pole). ConsoleKit2 is gone, replaced by elogind (which also takes over for
cgmanager and pm-utils).
Huge thanks to Eric Hameleers, Heinz Wiesinger, and Robby Workman for all the
help making this possible.
There's still more cleanup to do here, but that'll be easier with everything in
the main tree instead of maintaining side installs running the /testing
packages.
I'll look into what can be done about extra/pure-alsa-system/ soon.
Enjoy! :-)
a/aaa_elflibs-15.0-x86_64-28.txz:  Rebuilt.
  Upgraded: libcap.so.2.45, libelf-0.182.so, libglib-2.0.so.0.6600.3,
  libgmodule-2.0.so.0.6600.3, libgmp.so.10.4.1, libgmpxx.so.4.6.1,
  libgobject-2.0.so.0.6600.3, libgthread-2.0.so.0.6600.3, libhistory.so.8.1,
  libisl.so.23.0.0, liblber-2.4.so.2.11.4, libldap-2.4.so.2.11.4,
  libpcre2-8.so.0.10.1, libreadline.so.8.1.
  Removed: libHalf.so.12.0.0, libIex-2_2.so.12.0.0, libIexMath-2_2.so.12.0.0,
  libIlmImf-2_2.so.22.0.0, libIlmImfUtil-2_2.so.22.0.0,
  libIlmThread-2_2.so.12.0.0, libImath-2_2.so.12.0.0, libexiv2.so.26.0.0,
  libpoppler-qt4.so.4.11.0, libpoppler.so.79.0.0, libraw.so.16.0.0,
  libraw_r.so.16.0.0.
a/bash-5.1.000-x86_64-1.txz:  Upgraded.
a/dbus-1.12.20-x86_64-2.txz:  Rebuilt.
a/elogind-243.7-x86_64-1.txz:  Added.
a/eudev-3.2.9-x86_64-2.txz:  Rebuilt.
  Applied Pavilion 13 x360 keys patch from upstream git.
  Thanks to Robby Workman.
a/procps-ng-3.3.16-x86_64-3.txz:  Rebuilt.
  Recompiled using --with-elogind.
ap/cgmanager-0.42-x86_64-1.txz:  Removed.
ap/pm-utils-1.4.1-x86_64-6.txz:  Removed.
ap/vim-8.2.2105-x86_64-1.txz:  Upgraded.
d/python-setuptools-51.0.0-x86_64-1.txz:  Upgraded.
kde/akonadi-20.08.3-x86_64-1.txz:  Upgraded.
kde/akonadi-calendar-20.08.3-x86_64-1.txz:  Added.
kde/akonadi-calendar-tools-20.08.3-x86_64-1.txz:  Added.
kde/akonadi-contacts-20.08.3-x86_64-1.txz:  Added.
kde/akonadi-import-wizard-20.08.3-x86_64-1.txz:  Added.
kde/akonadi-mime-20.08.3-x86_64-1.txz:  Added.
kde/akonadi-notes-20.08.3-x86_64-1.txz:  Added.
kde/akonadi-search-20.08.3-x86_64-1.txz:  Added.
kde/akonadiconsole-20.08.3-x86_64-1.txz:  Added.
kde/akregator-20.08.3-x86_64-1.txz:  Added.
kde/alkimia-8.0.4-x86_64-1.txz:  Added.
kde/amarok-2.9.0-x86_64-3.txz:  Removed.
kde/amor-4.14.3-x86_64-3.txz:  Removed.
kde/analitza-20.08.3-x86_64-1.txz:  Upgraded.
kde/ark-20.08.3-x86_64-1.txz:  Upgraded.
kde/artikulate-20.08.3-x86_64-1.txz:  Upgraded.
kde/attica-5.76.0-x86_64-1.txz:  Upgraded.
kde/audiocd-kio-20.08.3-x86_64-1.txz:  Upgraded.
kde/baloo-5.76.0-x86_64-1.txz:  Upgraded.
kde/baloo-widgets-20.08.3-x86_64-1.txz:  Upgraded.
kde/blinken-20.08.3-x86_64-1.txz:  Upgraded.
kde/bluedevil-5.20.4-x86_64-1.txz:  Upgraded.
kde/bluez-qt-5.76.0-x86_64-1.txz:  Added.
kde/bomber-20.08.3-x86_64-1.txz:  Upgraded.
kde/bovo-20.08.3-x86_64-1.txz:  Upgraded.
kde/breeze-5.20.4-x86_64-1.txz:  Added.
kde/breeze-grub-5.20.4-x86_64-1.txz:  Added.
kde/breeze-gtk-5.20.4-x86_64-1.txz:  Added.
kde/breeze-icons-5.76.0-noarch-1.txz:  Added.
kde/calendarsupport-20.08.3-x86_64-1.txz:  Added.
kde/calligra-3.2.1-x86_64-1.txz:  Upgraded.
kde/calligraplan-3.2.2-x86_64-1.txz:  Added.
kde/cantor-20.08.3-x86_64-1.txz:  Upgraded.
kde/cervisia-20.08.3-x86_64-1.txz:  Upgraded.
kde/digikam-7.1.0-x86_64-1.txz:  Added.
kde/dolphin-20.08.3-x86_64-1.txz:  Added.
kde/dolphin-plugins-20.08.3-x86_64-1.txz:  Upgraded.
kde/dragon-20.08.3-x86_64-1.txz:  Upgraded.
kde/drkonqi-5.20.4-x86_64-1.txz:  Added.
kde/elisa-20.08.3-x86_64-1.txz:  Added.
kde/eventviews-20.08.3-x86_64-1.txz:  Added.
kde/extra-cmake-modules-5.76.0-x86_64-1.txz:  Added.
kde/falkon-3.1.0-x86_64-1.txz:  Added.
kde/ffmpegthumbs-20.08.3-x86_64-1.txz:  Added.
kde/filelight-20.08.3-x86_64-1.txz:  Upgraded.
kde/frameworkintegration-5.76.0-x86_64-1.txz:  Added.
kde/granatier-20.08.3-x86_64-1.txz:  Upgraded.
kde/grantlee-editor-20.08.3-x86_64-1.txz:  Added.
kde/grantleetheme-20.08.3-x86_64-1.txz:  Added.
kde/gwenview-20.08.3-x86_64-1.txz:  Upgraded.
kde/incidenceeditor-20.08.3-x86_64-1.txz:  Added.
kde/juk-20.08.3-x86_64-1.txz:  Upgraded.
kde/k3b-20.08.3-x86_64-1.txz:  Upgraded.
kde/kaccessible-4.14.3-x86_64-3.txz:  Removed.
kde/kactivities-5.76.0-x86_64-1.txz:  Upgraded.
kde/kactivities-stats-5.76.0-x86_64-1.txz:  Added.
kde/kactivitymanagerd-5.20.4-x86_64-1.txz:  Added.
kde/kaddressbook-20.08.3-x86_64-1.txz:  Added.
kde/kajongg-4.14.3-x86_64-3.txz:  Removed.
kde/kalarm-20.08.3-x86_64-1.txz:  Added.
kde/kalarmcal-20.08.3-x86_64-1.txz:  Added.
kde/kalgebra-20.08.3-x86_64-1.txz:  Upgraded.
kde/kalzium-20.08.3-x86_64-1.txz:  Upgraded.
kde/kamera-20.08.3-x86_64-1.txz:  Upgraded.
kde/kamoso-20.08.3-x86_64-1.txz:  Added.
kde/kanagram-20.08.3-x86_64-1.txz:  Upgraded.
kde/kapidox-5.76.0-x86_64-1.txz:  Added.
kde/kapman-20.08.3-x86_64-1.txz:  Upgraded.
kde/kapptemplate-20.08.3-x86_64-1.txz:  Upgraded.
kde/karchive-5.76.0-x86_64-1.txz:  Added.
kde/kate-20.08.3-x86_64-1.txz:  Upgraded.
kde/katomic-20.08.3-x86_64-1.txz:  Upgraded.
kde/kaudiocreator-1.3-x86_64-3.txz:  Removed.
kde/kauth-5.76.0-x86_64-1.txz:  Added.
kde/kbackup-20.08.3-x86_64-1.txz:  Added.
kde/kblackbox-20.08.3-x86_64-1.txz:  Upgraded.
kde/kblocks-20.08.3-x86_64-1.txz:  Upgraded.
kde/kbookmarks-5.76.0-x86_64-1.txz:  Added.
kde/kbounce-20.08.3-x86_64-1.txz:  Upgraded.
kde/kbreakout-20.08.3-x86_64-1.txz:  Upgraded.
kde/kbruch-20.08.3-x86_64-1.txz:  Upgraded.
kde/kcachegrind-20.08.3-x86_64-1.txz:  Upgraded.
kde/kcalc-20.08.3-x86_64-1.txz:  Upgraded.
kde/kcalendarcore-5.76.0-x86_64-1.txz:  Added.
kde/kcalutils-20.08.3-x86_64-1.txz:  Added.
kde/kcharselect-20.08.3-x86_64-1.txz:  Upgraded.
kde/kcm-fcitx-0.5.6-x86_64-1.txz:  Added.
kde/kcmutils-5.76.0-x86_64-1.txz:  Added.
kde/kcodecs-5.76.0-x86_64-1.txz:  Added.
kde/kcolorchooser-20.08.3-x86_64-1.txz:  Upgraded.
kde/kcompletion-5.76.0-x86_64-1.txz:  Added.
kde/kconfig-5.76.0-x86_64-1.txz:  Added.
kde/kconfigwidgets-5.76.0-x86_64-1.txz:  Added.
kde/kcontacts-5.76.0-x86_64-1.txz:  Added.
kde/kcoreaddons-5.76.0-x86_64-1.txz:  Added.
kde/kcrash-5.76.0-x86_64-1.txz:  Added.
kde/kcron-20.08.3-x86_64-1.txz:  Upgraded.
kde/kdav-5.76.0-x86_64-1.txz:  Added.
kde/kdbusaddons-5.76.0-x86_64-1.txz:  Added.
kde/kde-base-artwork-4.14.3-x86_64-3.txz:  Removed.
kde/kde-baseapps-4.14.3-x86_64-3.txz:  Removed.
kde/kde-cli-tools-5.20.4-x86_64-1.txz:  Added.
kde/kde-dev-scripts-20.08.3-x86_64-1.txz:  Upgraded.
kde/kde-dev-utils-20.08.3-x86_64-1.txz:  Upgraded.
kde/kde-gtk-config-5.20.4-x86_64-1.txz:  Added.
kde/kde-runtime-4.14.3-x86_64-8.txz:  Removed.
kde/kde-wallpapers-4.14.3-noarch-2.txz:  Removed.
kde/kde-workspace-4.11.22-x86_64-9.txz:  Removed.
kde/kdeartwork-4.14.3-x86_64-3.txz:  Removed.
kde/kdebugsettings-20.08.3-x86_64-1.txz:  Added.
kde/kdeclarative-5.76.0-x86_64-1.txz:  Added.
kde/kdeconnect-kde-20.08.3-x86_64-1.txz:  Upgraded.
kde/kdecoration-5.20.4-x86_64-1.txz:  Added.
kde/kded-5.76.0-x86_64-1.txz:  Added.
kde/kdeedu-data-20.08.3-x86_64-1.txz:  Added.
kde/kdegraphics-mobipocket-20.08.3-x86_64-1.txz:  Upgraded.
kde/kdegraphics-strigi-analyzer-4.14.3-x86_64-3.txz:  Removed.
kde/kdegraphics-thumbnailers-20.08.3-x86_64-1.txz:  Upgraded.
kde/kdelibs-4.14.38-x86_64-8.txz:  Removed.
kde/kdelibs4support-5.76.0-x86_64-1.txz:  Added.
kde/kdenetwork-filesharing-20.08.3-x86_64-1.txz:  Upgraded.
kde/kdenetwork-strigi-analyzers-4.14.3-x86_64-3.txz:  Removed.
kde/kdenlive-20.08.3-x86_64-1.txz:  Added.
kde/kdepim-4.14.10-x86_64-5.txz:  Removed.
kde/kdepim-addons-20.08.3-x86_64-1.txz:  Added.
kde/kdepim-apps-libs-20.08.3-x86_64-1.txz:  Added.
kde/kdepim-runtime-20.08.3-x86_64-1.txz:  Upgraded.
kde/kdepimlibs-4.14.10-x86_64-9.txz:  Removed.
kde/kdeplasma-addons-5.20.4-x86_64-1.txz:  Upgraded.
kde/kdesdk-kioslaves-20.08.3-x86_64-1.txz:  Upgraded.
kde/kdesdk-strigi-analyzers-4.14.3-x86_64-3.txz:  Removed.
kde/kdesdk-thumbnailers-20.08.3-x86_64-1.txz:  Upgraded.
kde/kdesignerplugin-5.76.0-x86_64-1.txz:  Added.
kde/kdesu-5.76.0-x86_64-1.txz:  Added.
kde/kdev-php-5.6.0-x86_64-1.txz:  Added.
kde/kdev-python-5.6.0-x86_64-1.txz:  Upgraded.
kde/kdevelop-5.6.0-x86_64-1.txz:  Upgraded.
kde/kdevelop-pg-qt-2.2.1-x86_64-1.txz:  Upgraded.
kde/kdevelop-php-1.7.4-x86_64-2.txz:  Removed.
kde/kdevelop-php-docs-1.7.4-x86_64-2.txz:  Removed.
kde/kdevplatform-1.7.4-x86_64-2.txz:  Removed.
kde/kdewebdev-4.14.3-x86_64-3.txz:  Removed.
kde/kdewebkit-5.76.0-x86_64-1.txz:  Added.
kde/kdf-20.08.3-x86_64-1.txz:  Upgraded.
kde/kdiagram-2.7.0-x86_64-1.txz:  Added.
kde/kdialog-20.08.3-x86_64-1.txz:  Added.
kde/kdiamond-20.08.3-x86_64-1.txz:  Upgraded.
kde/kdnssd-5.76.0-x86_64-1.txz:  Added.
kde/kdoctools-5.76.0-x86_64-1.txz:  Added.
kde/keditbookmarks-20.08.3-x86_64-1.txz:  Added.
kde/kemoticons-5.76.0-x86_64-1.txz:  Added.
kde/kfilemetadata-5.76.0-x86_64-1.txz:  Upgraded.
kde/kfind-20.08.3-x86_64-1.txz:  Added.
kde/kfloppy-20.08.3-x86_64-1.txz:  Upgraded.
kde/kfourinline-20.08.3-x86_64-1.txz:  Upgraded.
kde/kgamma-4.14.3-x86_64-3.txz:  Removed.
kde/kgamma5-5.20.4-x86_64-1.txz:  Added.
kde/kgeography-20.08.3-x86_64-1.txz:  Upgraded.
kde/kget-20.08.3-x86_64-1.txz:  Upgraded.
kde/kglobalaccel-5.76.0-x86_64-1.txz:  Added.
kde/kgoldrunner-20.08.3-x86_64-1.txz:  Upgraded.
kde/kgpg-20.08.3-x86_64-1.txz:  Upgraded.
kde/kguiaddons-5.76.0-x86_64-1.txz:  Added.
kde/khangman-20.08.3-x86_64-1.txz:  Upgraded.
kde/khelpcenter-20.08.3-x86_64-1.txz:  Added.
kde/kholidays-5.76.0-x86_64-1.txz:  Added.
kde/khotkeys-5.20.4-x86_64-1.txz:  Added.
kde/khtml-5.76.0-x86_64-1.txz:  Added.
kde/ki18n-5.76.0-x86_64-1.txz:  Added.
kde/kiconthemes-5.76.0-x86_64-1.txz:  Added.
kde/kid3-3.8.4-x86_64-1.txz:  Added.
kde/kidentitymanagement-20.08.3-x86_64-1.txz:  Added.
kde/kidletime-5.76.0-x86_64-1.txz:  Added.
kde/kig-20.08.3-x86_64-1.txz:  Upgraded.
kde/kigo-20.08.3-x86_64-1.txz:  Upgraded.
kde/kile-2.9.93-x86_64-1.txz:  Added.
kde/killbots-20.08.3-x86_64-1.txz:  Upgraded.
kde/kimageformats-5.76.0-x86_64-1.txz:  Added.
kde/kimagemapeditor-20.08.3-x86_64-1.txz:  Added.
kde/kimap-20.08.3-x86_64-1.txz:  Added.
kde/kinfocenter-5.20.4-x86_64-1.txz:  Added.
kde/kinit-5.76.0-x86_64-1.txz:  Added.
kde/kio-5.76.0-x86_64-1.txz:  Added.
kde/kio-extras-20.08.3-x86_64-1.txz:  Added.
kde/kio-gdrive-20.08.3-x86_64-1.txz:  Added.
kde/kio-mtp-2063e75_20131020git-x86_64-4.txz:  Removed.
kde/kipi-plugins-20.08.3-x86_64-1.txz:  Added.
kde/kirigami-gallery-20.08.3-x86_64-1.txz:  Added.
kde/kirigami2-5.76.0-x86_64-1.txz:  Added.
kde/kiriki-20.08.3-x86_64-1.txz:  Upgraded.
kde/kitemmodels-5.76.0-x86_64-1.txz:  Added.
kde/kitemviews-5.76.0-x86_64-1.txz:  Added.
kde/kiten-20.08.3-x86_64-1.txz:  Upgraded.
kde/kitinerary-20.08.3-x86_64-1.txz:  Added.
kde/kjobwidgets-5.76.0-x86_64-1.txz:  Added.
kde/kjots-20200924_355b642-x86_64-1.txz:  Added.
kde/kjs-5.76.0-x86_64-1.txz:  Added.
kde/kjsembed-5.76.0-x86_64-1.txz:  Added.
kde/kjumpingcube-20.08.3-x86_64-1.txz:  Upgraded.
kde/kldap-20.08.3-x86_64-1.txz:  Added.
kde/kleopatra-20.08.3-x86_64-1.txz:  Added.
kde/klettres-4.14.3-x86_64-3.txz:  Removed.
kde/klickety-20.08.3-x86_64-1.txz:  Upgraded.
kde/klines-20.08.3-x86_64-1.txz:  Upgraded.
kde/kmag-20.08.3-x86_64-1.txz:  Upgraded.
kde/kmahjongg-20.08.3-x86_64-1.txz:  Upgraded.
kde/kmail-20.08.3-x86_64-1.txz:  Added.
kde/kmail-account-wizard-20.08.3-x86_64-1.txz:  Added.
kde/kmailtransport-20.08.3-x86_64-1.txz:  Added.
kde/kmbox-20.08.3-x86_64-1.txz:  Added.
kde/kmediaplayer-5.76.0-x86_64-1.txz:  Added.
kde/kmenuedit-5.20.4-x86_64-1.txz:  Added.
kde/kmime-20.08.3-x86_64-1.txz:  Added.
kde/kmines-20.08.3-x86_64-1.txz:  Upgraded.
kde/kmix-20.08.3-x86_64-1.txz:  Upgraded.
kde/kmousetool-20.08.3-x86_64-1.txz:  Upgraded.
kde/kmouth-20.08.3-x86_64-1.txz:  Upgraded.
kde/kmplot-20.08.3-x86_64-1.txz:  Upgraded.
kde/kmymoney-5.1.0-x86_64-1.txz:  Added.
kde/knavalbattle-20.08.3-x86_64-1.txz:  Upgraded.
kde/knetwalk-20.08.3-x86_64-1.txz:  Upgraded.
kde/knewstuff-5.76.0-x86_64-1.txz:  Added.
kde/knights-20.08.3-x86_64-1.txz:  Added.
kde/knotes-20.08.3-x86_64-1.txz:  Added.
kde/knotifications-5.76.0-x86_64-1.txz:  Added.
kde/knotifyconfig-5.76.0-x86_64-1.txz:  Added.
kde/kolf-20.08.3-x86_64-1.txz:  Upgraded.
kde/kollision-20.08.3-x86_64-1.txz:  Upgraded.
kde/kolourpaint-20.08.3-x86_64-1.txz:  Upgraded.
kde/kompare-20.08.3-x86_64-1.txz:  Upgraded.
kde/konqueror-20.08.3-x86_64-1.txz:  Added.
kde/konquest-20.08.3-x86_64-1.txz:  Upgraded.
kde/konsole-20.08.3-x86_64-1.txz:  Upgraded.
kde/kontact-20.08.3-x86_64-1.txz:  Added.
kde/kontactinterface-20.08.3-x86_64-1.txz:  Added.
kde/kopete-20.08.3-x86_64-1.txz:  Upgraded.
kde/korganizer-20.08.3-x86_64-1.txz:  Added.
kde/korundum-4.14.3-x86_64-8.txz:  Removed.
kde/kpackage-5.76.0-x86_64-1.txz:  Added.
kde/kparts-5.76.0-x86_64-1.txz:  Added.
kde/kpat-20.08.3-x86_64-1.txz:  Upgraded.
kde/kpeople-5.76.0-x86_64-1.txz:  Added.
kde/kpeoplevcard-0.1-x86_64-1.txz:  Added.
kde/kpimtextedit-20.08.3-x86_64-1.txz:  Added.
kde/kpkpass-20.08.3-x86_64-1.txz:  Added.
kde/kplayer-0.7.2-x86_64-3.txz:  Removed.
kde/kplotting-5.76.0-x86_64-1.txz:  Added.
kde/kpmcore-4.2.0-x86_64-1.txz:  Added.
kde/kppp-4.14.3-x86_64-3.txz:  Removed.
kde/kpty-5.76.0-x86_64-1.txz:  Added.
kde/kqtquickcharts-20.08.3-x86_64-1.txz:  Upgraded.
kde/kquickcharts-5.76.0-x86_64-1.txz:  Added.
kde/krdc-20.08.3-x86_64-1.txz:  Upgraded.
kde/kremotecontrol-4.14.3-x86_64-3.txz:  Removed.
kde/krename-5.0.1-x86_64-1.txz:  Added.
kde/kreversi-20.08.3-x86_64-1.txz:  Upgraded.
kde/krfb-20.08.3-x86_64-1.txz:  Upgraded.
kde/krita-4.4.1-x86_64-1.txz:  Added.
kde/kross-5.76.0-x86_64-1.txz:  Added.
kde/kross-interpreters-20.08.3-x86_64-1.txz:  Upgraded.
kde/kruler-20.08.3-x86_64-1.txz:  Upgraded.
kde/krunner-5.76.0-x86_64-1.txz:  Added.
kde/krusader-2.7.2-x86_64-1.txz:  Added.
kde/ksaneplugin-4.14.3-x86_64-3.txz:  Removed.
kde/kscreen-5.20.4-x86_64-1.txz:  Upgraded.
kde/kscreenlocker-5.20.4-x86_64-1.txz:  Added.
kde/kservice-5.76.0-x86_64-1.txz:  Added.
kde/kshisen-20.08.3-x86_64-1.txz:  Upgraded.
kde/ksirk-20.08.3-x86_64-1.txz:  Upgraded.
kde/ksmtp-20.08.3-x86_64-1.txz:  Added.
kde/ksnakeduel-20.08.3-x86_64-1.txz:  Upgraded.
kde/ksnapshot-4.14.3-x86_64-3.txz:  Removed.
kde/kspaceduel-20.08.3-x86_64-1.txz:  Upgraded.
kde/ksquares-20.08.3-x86_64-1.txz:  Upgraded.
kde/ksshaskpass-5.20.4-x86_64-1.txz:  Added.
kde/kstars-3.5.0-x86_64-1.txz:  Upgraded.
kde/ksudoku-20.08.3-x86_64-1.txz:  Upgraded.
kde/ksysguard-5.20.4-x86_64-1.txz:  Added.
kde/ksystemlog-20.08.3-x86_64-1.txz:  Upgraded.
kde/kteatime-20.08.3-x86_64-1.txz:  Upgraded.
kde/ktexteditor-5.76.0-x86_64-1.txz:  Added.
kde/ktextwidgets-5.76.0-x86_64-1.txz:  Added.
kde/ktimer-20.08.3-x86_64-1.txz:  Upgraded.
kde/ktimetracker-5.0.1-x86_64-1.txz:  Added.
kde/ktnef-20.08.3-x86_64-1.txz:  Added.
kde/ktorrent-5.2.0-x86_64-1.txz:  Upgraded.
kde/ktouch-20.08.3-x86_64-1.txz:  Upgraded.
kde/ktuberling-4.14.3-x86_64-3.txz:  Removed.
kde/kturtle-20.08.3-x86_64-1.txz:  Upgraded.
kde/ktux-4.14.3-x86_64-3.txz:  Removed.
kde/kubrick-20.08.3-x86_64-1.txz:  Upgraded.
kde/kunitconversion-5.76.0-x86_64-1.txz:  Added.
kde/kuser-4.14.3-x86_64-3.txz:  Removed.
kde/kwallet-5.76.0-x86_64-1.txz:  Added.
kde/kwallet-pam-5.20.4-x86_64-1.txz:  Added.
kde/kwalletmanager-20.08.3-x86_64-1.txz:  Upgraded.
kde/kwave-20.08.3-x86_64-1.txz:  Added.
kde/kwayland-5.76.0-x86_64-1.txz:  Added.
kde/kwayland-integration-5.20.4-x86_64-1.txz:  Added.
kde/kwayland-server-5.20.4-x86_64-1.txz:  Added.
kde/kwebkitpart-1.3.4-x86_64-3.txz:  Removed.
kde/kwidgetsaddons-5.76.0-x86_64-1.txz:  Added.
kde/kwin-5.20.4-x86_64-1.txz:  Added.
kde/kwindowsystem-5.76.0-x86_64-1.txz:  Added.
kde/kwordquiz-20.08.3-x86_64-1.txz:  Upgraded.
kde/kwrited-5.20.4-x86_64-1.txz:  Added.
kde/kxmlgui-5.76.0-x86_64-1.txz:  Added.
kde/kxmlrpcclient-5.76.0-x86_64-1.txz:  Added.
kde/latte-dock-0.9.11-x86_64-1.txz:  Added.
kde/libgravatar-20.08.3-x86_64-1.txz:  Added.
kde/libkcddb-20.08.3-x86_64-1.txz:  Upgraded.
kde/libkcompactdisc-20.08.3-x86_64-1.txz:  Upgraded.
kde/libkdcraw-20.08.3-x86_64-1.txz:  Upgraded.
kde/libkdeedu-4.14.3-x86_64-3.txz:  Removed.
kde/libkdegames-20.08.3-x86_64-1.txz:  Upgraded.
kde/libkdepim-20.08.3-x86_64-1.txz:  Added.
kde/libkeduvocdocument-20.08.3-x86_64-1.txz:  Added.
kde/libkexiv2-20.08.3-x86_64-1.txz:  Upgraded.
kde/libkgapi-20.08.3-x86_64-1.txz:  Added.
kde/libkgeomap-20.08.3-x86_64-1.txz:  Added.
kde/libkipi-20.08.3-x86_64-1.txz:  Upgraded.
kde/libkleo-20.08.3-x86_64-1.txz:  Added.
kde/libkmahjongg-20.08.3-x86_64-1.txz:  Upgraded.
kde/libkomparediff2-20.08.3-x86_64-1.txz:  Upgraded.
kde/libksane-20.08.3-x86_64-1.txz:  Upgraded.
kde/libkscreen-5.20.4-x86_64-1.txz:  Upgraded.
kde/libksieve-20.08.3-x86_64-1.txz:  Added.
kde/libksysguard-5.20.4-x86_64-1.txz:  Added.
kde/libktorrent-2.2.0-x86_64-1.txz:  Upgraded.
kde/libmm-qt-1.0.1-x86_64-3.txz:  Removed.
kde/libnm-qt-0.9.8.4-x86_64-1.txz:  Removed.
kde/lokalize-20.08.3-x86_64-1.txz:  Upgraded.
kde/lskat-20.08.3-x86_64-1.txz:  Upgraded.
kde/mailcommon-20.08.3-x86_64-1.txz:  Added.
kde/mailimporter-20.08.3-x86_64-1.txz:  Added.
kde/marble-20.08.3-x86_64-1.txz:  Upgraded.
kde/mbox-importer-20.08.3-x86_64-1.txz:  Added.
kde/messagelib-20.08.3-x86_64-1.txz:  Added.
kde/milou-5.20.4-x86_64-1.txz:  Added.
kde/minuet-20.08.3-x86_64-1.txz:  Added.
kde/modemmanager-qt-5.76.0-x86_64-1.txz:  Added.
kde/mplayerthumbs-4.14.3-x86_64-3.txz:  Removed.
kde/nepomuk-core-4.14.3-x86_64-5.txz:  Removed.
kde/nepomuk-widgets-4.14.3-x86_64-3.txz:  Removed.
kde/networkmanager-qt-5.76.0-x86_64-1.txz:  Added.
kde/okteta-0.26.4-x86_64-1.txz:  Upgraded.
kde/okular-20.08.3-x86_64-1.txz:  Upgraded.
kde/oxygen-5.20.4-x86_64-1.txz:  Added.
kde/oxygen-fonts-5.4.3-noarch-1.txz:  Added.
kde/oxygen-gtk2-1.4.6-x86_64-1.txz:  Upgraded.
kde/oxygen-icons-4.14.3-x86_64-3.txz:  Removed.
kde/oxygen-icons5-5.76.0-noarch-1.txz:  Added.
kde/pairs-4.14.3-x86_64-3.txz:  Removed.
kde/palapeli-20.08.3-x86_64-1.txz:  Upgraded.
kde/parley-20.08.3-x86_64-1.txz:  Upgraded.
kde/partitionmanager-4.2.0-x86_64-1.txz:  Upgraded.
kde/perlkde-4.14.3-x86_64-10.txz:  Removed.
kde/perlqt-4.14.3-x86_64-11.txz:  Removed.
kde/picmi-20.08.3-x86_64-1.txz:  Upgraded.
kde/pim-data-exporter-20.08.3-x86_64-1.txz:  Added.
kde/pim-sieve-editor-20.08.3-x86_64-1.txz:  Added.
kde/pimcommon-20.08.3-x86_64-1.txz:  Added.
kde/plasma-browser-integration-5.20.4-x86_64-1.txz:  Added.
kde/plasma-desktop-5.20.4-x86_64-1.txz:  Added.
kde/plasma-disks-5.20.4-x86_64-1.txz:  Added.
kde/plasma-framework-5.76.0-x86_64-1.txz:  Added.
kde/plasma-integration-5.20.4-x86_64-1.txz:  Added.
kde/plasma-nm-5.20.4-x86_64-1.txz:  Upgraded.
kde/plasma-pa-5.20.4-x86_64-1.txz:  Added.
kde/plasma-sdk-5.20.4-x86_64-1.txz:  Added.
kde/plasma-vault-5.20.4-x86_64-1.txz:  Added.
kde/plasma-wayland-protocols-1.1.1-x86_64-1.txz:  Added.
kde/plasma-workspace-5.20.4-x86_64-1.txz:  Added.
kde/plasma-workspace-wallpapers-5.20.4-x86_64-1.txz:  Added.
kde/polkit-kde-agent-1-5.20.4-x86_64-1.txz:  Upgraded.
kde/polkit-kde-kcmodules-1-001bdf7_20120111git-x86_64-3.txz:  Removed.
kde/powerdevil-5.20.4-x86_64-1.txz:  Added.
kde/poxml-20.08.3-x86_64-1.txz:  Upgraded.
kde/print-manager-20.08.3-x86_64-1.txz:  Upgraded.
kde/prison-5.76.0-x86_64-1.txz:  Added.
kde/pulseaudio-qt-1.2-x86_64-1.txz:  Added.
kde/purpose-5.76.0-x86_64-1.txz:  Added.
kde/pykde4-4.14.3-x86_64-11.txz:  Removed.
kde/qqc2-desktop-style-5.76.0-x86_64-1.txz:  Added.
kde/qtruby-4.14.3-x86_64-11.txz:  Removed.
kde/rocs-20.08.3-x86_64-1.txz:  Upgraded.
kde/sddm-0.19.0-x86_64-1.txz:  Added.
kde/sddm-kcm-5.20.4-x86_64-1.txz:  Added.
kde/skanlite-2.2.0-x86_64-1.txz:  Upgraded.
kde/smokegen-4.14.3-x86_64-3.txz:  Removed.
kde/smokekde-4.14.3-x86_64-3.txz:  Removed.
kde/smokeqt-4.14.3-x86_64-6.txz:  Removed.
kde/solid-5.76.0-x86_64-1.txz:  Added.
kde/sonnet-5.76.0-x86_64-1.txz:  Added.
kde/spectacle-20.08.3-x86_64-1.txz:  Added.
kde/step-20.08.3-x86_64-1.txz:  Upgraded.
kde/superkaramba-4.14.3-x86_64-4.txz:  Removed.
kde/svgpart-20.08.3-x86_64-1.txz:  Upgraded.
kde/sweeper-20.08.3-x86_64-1.txz:  Upgraded.
kde/syndication-5.76.0-x86_64-1.txz:  Added.
kde/syntax-highlighting-5.76.0-x86_64-1.txz:  Added.
kde/systemsettings-5.20.4-x86_64-1.txz:  Added.
kde/threadweaver-5.76.0-x86_64-1.txz:  Added.
kde/umbrello-20.08.3-x86_64-1.txz:  Upgraded.
kde/wacomtablet-20201030_417d9d9-x86_64-1.txz:  Added.
kde/wicd-kde-0.3.0_bcf27d8-x86_64-3.txz:  Removed.
kde/xdg-desktop-portal-kde-5.20.4-x86_64-1.txz:  Added.
kde/yakuake-20.08.3-x86_64-1.txz:  Added.
kde/zeroconf-ioslave-20.08.3-x86_64-1.txz:  Upgraded.
kdei/calligra-l10n-bs-2.9.11-noarch-1.txz:  Removed.
kdei/calligra-l10n-ca-2.9.11-noarch-1.txz:  Removed.
kdei/calligra-l10n-ca@valencia-2.9.11-noarch-1.txz:  Removed.
kdei/calligra-l10n-cs-2.9.11-noarch-1.txz:  Removed.
kdei/calligra-l10n-da-2.9.11-noarch-1.txz:  Removed.
kdei/calligra-l10n-de-2.9.11-noarch-1.txz:  Removed.
kdei/calligra-l10n-el-2.9.11-noarch-1.txz:  Removed.
kdei/calligra-l10n-en_GB-2.9.11-noarch-1.txz:  Removed.
kdei/calligra-l10n-es-2.9.11-noarch-1.txz:  Removed.
kdei/calligra-l10n-et-2.9.11-noarch-1.txz:  Removed.
kdei/calligra-l10n-fi-2.9.11-noarch-1.txz:  Removed.
kdei/calligra-l10n-fr-2.9.11-noarch-1.txz:  Removed.
kdei/calligra-l10n-gl-2.9.11-noarch-1.txz:  Removed.
kdei/calligra-l10n-hu-2.9.11-noarch-1.txz:  Removed.
kdei/calligra-l10n-it-2.9.11-noarch-1.txz:  Removed.
kdei/calligra-l10n-ja-2.9.11-noarch-1.txz:  Removed.
kdei/calligra-l10n-kk-2.9.11-noarch-1.txz:  Removed.
kdei/calligra-l10n-nb-2.9.11-noarch-1.txz:  Removed.
kdei/calligra-l10n-nl-2.9.11-noarch-1.txz:  Removed.
kdei/calligra-l10n-pl-2.9.11-noarch-1.txz:  Removed.
kdei/calligra-l10n-pt-2.9.11-noarch-1.txz:  Removed.
kdei/calligra-l10n-pt_BR-2.9.11-noarch-1.txz:  Removed.
kdei/calligra-l10n-ru-2.9.11-noarch-1.txz:  Removed.
kdei/calligra-l10n-sk-2.9.11-noarch-1.txz:  Removed.
kdei/calligra-l10n-sv-2.9.11-noarch-1.txz:  Removed.
kdei/calligra-l10n-tr-2.9.11-noarch-1.txz:  Removed.
kdei/calligra-l10n-uk-2.9.11-noarch-1.txz:  Removed.
kdei/calligra-l10n-zh_CN-2.9.11-noarch-1.txz:  Removed.
kdei/calligra-l10n-zh_TW-2.9.11-noarch-1.txz:  Removed.
kdei/kde-l10n-ar-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-bg-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-bs-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-ca-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-ca@valencia-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-cs-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-da-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-de-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-el-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-en_GB-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-es-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-et-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-eu-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-fa-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-fi-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-fr-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-ga-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-gl-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-he-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-hi-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-hr-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-hu-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-ia-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-id-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-is-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-it-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-ja-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-kk-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-km-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-ko-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-lt-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-lv-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-mr-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-nb-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-nds-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-nl-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-nn-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-pa-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-pl-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-pt-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-pt_BR-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-ro-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-ru-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-sk-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-sl-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-sr-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-sv-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-tr-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-ug-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-uk-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-wa-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-zh_CN-4.14.3-noarch-1.txz:  Removed.
kdei/kde-l10n-zh_TW-4.14.3-noarch-1.txz:  Removed.
l/ConsoleKit2-1.2.1-x86_64-4.txz:  Removed.
l/PyQt-4.12.3-x86_64-3.txz:  Removed.
l/QScintilla-2.11.6-x86_64-1.txz:  Upgraded.
  Drop Qt4 support.
l/QtAV-20200910_2a470d2a-x86_64-1.txz:  Added.
l/SDL2-2.0.12-x86_64-2.txz:  Rebuilt.
l/accountsservice-0.6.55-x86_64-1.txz:  Added.
l/automoc4-0.9.88-x86_64-2.txz:  Removed.
l/cfitsio-3.49-x86_64-1.txz:  Added.
l/cryfs-0.10.2-x86_64-1.txz:  Added.
l/cryptopp-8.2.0-x86_64-1.txz:  Added.
l/dotconf-1.3-x86_64-1.txz:  Added.
l/dvdauthor-0.7.2-x86_64-1.txz:  Added.
l/eigen3-3.3.9-x86_64-1.txz:  Upgraded.
l/frei0r-plugins-1.7.0-x86_64-1.txz:  Added.
l/fuse3-3.10.1-x86_64-1.txz:  Upgraded.
l/grantlee-5.2.0-x86_64-1.txz:  Upgraded.
l/gst-plugins-base-1.18.2-x86_64-1.txz:  Upgraded.
l/gst-plugins-good-1.18.2-x86_64-1.txz:  Upgraded.
l/gst-plugins-libav-1.18.2-x86_64-1.txz:  Upgraded.
l/gstreamer-1.18.2-x86_64-1.txz:  Upgraded.
l/gtk+3-3.24.24-x86_64-1.txz:  Upgraded.
l/gvfs-1.46.1-x86_64-2.txz:  Rebuilt.
  Recompiled using -Dlogind=true.
l/kdsoap-1.9.1-x86_64-1.txz:  Added.
l/lensfun-0.3.95-x86_64-1.txz:  Added.
l/libappindicator-12.10.0-x86_64-1.txz:  Added.
l/libbluedevil-2.1-x86_64-2.txz:  Removed.
l/libburn-1.5.2.pl01-x86_64-1.txz:  Added.
l/libdbusmenu-16.04.0-x86_64-1.txz:  Added.
l/libdbusmenu-qt-0.9.3+16.04.20160218-x86_64-1.txz:  Upgraded.
l/libdmtx-0.7.5-x86_64-1.txz:  Added.
l/libindicator-12.10.1-x86_64-1.txz:  Added.
l/liblastfm-1.1.0-x86_64-1.txz:  Removed.
l/libqalculate-3.14.0-x86_64-1.txz:  Added.
l/mlt-6.22.1-x86_64-1.txz:  Added.
l/opencv-4.5.0-x86_64-1.txz:  Added.
l/phonon-4.11.1-x86_64-1.txz:  Upgraded.
l/phonon-backend-gstreamer-4.10.0-x86_64-1.txz:  Added.
l/phonon-gstreamer-4.8.2-x86_64-2.txz:  Removed.
l/pipewire-0.3.13-x86_64-1.txz:  Added.
l/polkit-0.118-x86_64-2.txz:  Rebuilt.
l/polkit-qt-1-0.113.0-x86_64-1.txz:  Upgraded.
l/poppler-20.12.1-x86_64-1.txz:  Upgraded.
l/python-certifi-2020.12.5-x86_64-1.txz:  Upgraded.
l/python-pygments-2.7.3-x86_64-1.txz:  Upgraded.
l/qca-2.3.1-x86_64-1.txz:  Upgraded.
l/qca-qt5-2.3.1-x86_64-1.txz:  Removed.
l/qimageblitz-0.0.6-x86_64-2.txz:  Removed.
l/qjson-0.9.0-x86_64-1.txz:  Removed.
l/qrencode-4.1.1-x86_64-1.txz:  Added.
l/qt-4.8.7-x86_64-17.txz:  Removed.
l/qt-gstreamer-1.2.0-x86_64-2.txz:  Removed.
l/qt5-5.15.2-x86_64-2.txz:  Rebuilt.
l/qtkeychain-0.11.1-x86_64-1.txz:  Added.
l/qtscriptgenerator-0.2.0-x86_64-3.txz:  Removed.
l/quazip-1.1-x86_64-1.txz:  Added.
l/raptor2-2.0.15-x86_64-10.txz:  Removed.
l/rasqal-0.9.33-x86_64-3.txz:  Removed.
l/readline-8.1.000-x86_64-1.txz:  Upgraded.
l/redland-1.0.17-x86_64-6.txz:  Removed.
l/rttr-0.9.6-x86_64-1.txz:  Added.
l/soprano-2.9.4-x86_64-3.txz:  Removed.
l/speech-dispatcher-0.10.2-x86_64-1.txz:  Added.
l/strigi-0.7.8-x86_64-4.txz:  Removed.
l/vid.stab-20200916_e851e7b-x86_64-1.txz:  Added.
l/xapian-core-1.4.17-x86_64-2.txz:  Rebuilt.
n/NetworkManager-1.28.0-x86_64-1.txz:  Upgraded.
  Drop ConsoleKit2 support and add elogind support.
x/OpenCC-1.1.1-x86_64-1.txz:  Added.
x/cldr-emoji-annotation-37.0_13.0_0_2-noarch-1.txz:  Added.
x/fcitx-4.2.9.8-x86_64-1.txz:  Added.
  Don't build Qt4 components.
x/fcitx-anthy-0.2.3-x86_64-1.txz:  Added.
x/fcitx-configtool-0.4.9-x86_64-1.txz:  Added.
x/fcitx-hangul-0.3.1-x86_64-1.txz:  Added.
x/fcitx-kkc-0.1.4-x86_64-1.txz:  Added.
x/fcitx-libpinyin-0.5.3-x86_64-1.txz:  Added.
x/fcitx-m17n-0.2.4-x86_64-1.txz:  Added.
x/fcitx-qt5-1.2.5-x86_64-1.txz:  Added.
x/fcitx-sayura-0.1.2-x86_64-1.txz:  Added.
x/fcitx-table-extra-0.3.8-x86_64-1.txz:  Added.
x/fcitx-table-other-0.2.4-x86_64-1.txz:  Added.
x/fcitx-unikey-0.2.7-x86_64-1.txz:  Added.
x/ibus-1.5.23-x86_64-1.txz:  Added.
x/ibus-anthy-1.5.11-x86_64-1.txz:  Added.
x/ibus-hangul-1.5.4-x86_64-1.txz:  Added.
x/ibus-kkc-1.5.22-x86_64-1.txz:  Added.
x/ibus-libpinyin-1.11.1-x86_64-1.txz:  Added.
x/ibus-m17n-1.4.3-x86_64-1.txz:  Added.
x/ibus-table-1.12.1-x86_64-1.txz:  Added.
x/ibus-unikey-0.6.1-x86_64-1.txz:  Added.
x/libgee-0.20.1-x86_64-1.txz:  Added.
x/libkkc-0.3.5-x86_64-1.txz:  Added.
x/libkkc-data-0.2.7-x86_64-1.txz:  Added.
x/libpinyin-2.3.0-x86_64-1.txz:  Added.
x/marisa-0.2.4-x86_64-1.txz:  Added.
x/motif-2.3.8-x86_64-3.txz:  Rebuilt.
  Added xinitrc.mwm. Thanks to ziprun.
x/scim-1.4.18-x86_64-1.txz:  Removed.
x/scim-anthy-1.2.7-x86_64-2.txz:  Removed.
x/scim-hangul-0.4.0-x86_64-2.txz:  Removed.
x/scim-input-pad-0.1.3.1-x86_64-2.txz:  Removed.
x/scim-m17n-0.2.3-x86_64-2.txz:  Removed.
x/scim-pinyin-0.5.92-x86_64-2.txz:  Removed.
x/scim-tables-0.5.14.1-x86_64-2.txz:  Removed.
x/skkdic-20200128-noarch-1.txz:  Added.
x/xdm-1.1.11-x86_64-11.txz:  Rebuilt.
  Drop ConsoleKit2 patch, fix pam.d/xdm file.
xap/seamonkey-2.53.5.1-x86_64-1.txz:  Upgraded.
  This update contains security fixes and improvements.
    https://www.seamonkey-project.org/releases/seamonkey2.53.5.1
  (* Security fix *)
xap/vim-gvim-8.2.2105-x86_64-1.txz:  Upgraded.
xap/xine-lib-1.2.11-x86_64-1.txz:  Upgraded.
xfce/Greybird-3.22.12-noarch-1.txz:  Added.
xfce/elementary-xfce-0.15.1-x86_64-1.txz:  Added.
xfce/exo-0.12.11-x86_64-2.txz:  Rebuilt.
xfce/garcon-0.6.4-x86_64-2.txz:  Rebuilt.
xfce/gtk-xfce-engine-2.10.1-x86_64-3.txz:  Removed.
xfce/libxfce4ui-4.14.1-x86_64-1.txz:  Upgraded.
xfce/libxfce4util-4.14.0-x86_64-1.txz:  Upgraded.
xfce/mousepad-0.4.2-x86_64-1.txz:  Added.
xfce/orage-4.12.1-x86_64-5.txz:  Removed.
xfce/thunar-1.8.16-x86_64-2.txz:  Rebuilt.
xfce/thunar-volman-0.9.5-x86_64-2.txz:  Rebuilt.
xfce/tumbler-0.2.9-x86_64-2.txz:  Rebuilt.
xfce/xfce4-appfinder-4.14.0-x86_64-1.txz:  Upgraded.
xfce/xfce4-clipman-plugin-1.6.1-x86_64-1.txz:  Upgraded.
xfce/xfce4-dev-tools-4.14.0-x86_64-1.txz:  Upgraded.
xfce/xfce4-notifyd-0.6.2-x86_64-1.txz:  Upgraded.
xfce/xfce4-panel-4.14.4-x86_64-1.txz:  Upgraded.
xfce/xfce4-panel-profiles-1.0.10-x86_64-1.txz:  Added.
xfce/xfce4-power-manager-1.6.6-x86_64-1.txz:  Upgraded.
xfce/xfce4-pulseaudio-plugin-0.4.3-x86_64-1.txz:  Upgraded.
xfce/xfce4-screensaver-0.1.11-x86_64-1.txz:  Added.
xfce/xfce4-screenshooter-1.9.7-x86_64-1.txz:  Upgraded.
xfce/xfce4-session-4.14.2-x86_64-1.txz:  Upgraded.
xfce/xfce4-settings-4.14.3-x86_64-1.txz:  Upgraded.
xfce/xfce4-systemload-plugin-1.2.3-x86_64-2.txz:  Rebuilt.
xfce/xfce4-taskmanager-1.2.3-x86_64-1.txz:  Upgraded.
xfce/xfce4-terminal-0.8.9.2-x86_64-1.txz:  Upgraded.
xfce/xfce4-weather-plugin-0.10.2-x86_64-1.txz:  Upgraded.
xfce/xfce4-whiskermenu-plugin-2.4.6-x86_64-1.txz:  Added.
xfce/xfconf-4.14.4-x86_64-1.txz:  Upgraded.
xfce/xfdesktop-4.14.3-x86_64-1.txz:  Upgraded.
xfce/xfwm4-4.14.6-x86_64-1.txz:  Upgraded.
n°1457807
regdub
Posté le 08-12-2020 à 16:26:25  profilanswer
[:lex123:2]
Legalize it @HFR
n°1457820
cycojesus
Mèo Lười
Posté le 09-12-2020 à 10:20:23  profilanswer
Tue Dec  8 19:29:55 UTC 2020
a/kernel-generic-5.4.82-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.4.82-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.4.82-x86_64-1.txz:  Upgraded.
a/openssl-solibs-1.1.1i-x86_64-1.txz:  Upgraded.
ap/gutenprint-5.3.4-x86_64-1.txz:  Upgraded.
ap/htop-3.0.3-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.4.82-x86-1.txz:  Upgraded.
d/python3-3.9.1-x86_64-1.txz:  Upgraded.
k/kernel-source-5.4.82-noarch-1.txz:  Upgraded.
l/M2Crypto-0.37.1-x86_64-1.txz:  Upgraded.
l/gdk-pixbuf2-2.42.2-x86_64-1.txz:  Upgraded.
l/imagemagick-7.0.10_46-x86_64-1.txz:  Upgraded.
l/mlt-6.24.0-x86_64-1.txz:  Upgraded.
l/pipewire-0.3.17-x86_64-1.txz:  Upgraded.
n/openssl-1.1.1i-x86_64-1.txz:  Upgraded.
  This fixes a denial-of-service security issue.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-1971
  (* Security fix *)
x/fcitx-configtool-0.4.10-x86_64-1.txz:  Upgraded.
x/libgee-0.20.3-x86_64-1.txz:  Upgraded.
x/marisa-0.2.6-x86_64-1.txz:  Upgraded.
n°1457862
cycojesus
Mèo Lười
Posté le 10-12-2020 à 09:24:17  profilanswer
Wed Dec  9 21:10:40 UTC 2020
a/elogind-243.7-x86_64-2.txz:  Rebuilt.
  Moved default udev rules to /lib/udev/rules.d/. Thanks to Robby Workman.
  Added /usr/share/polkit-1/rules.d/10-enable-session-power.rules.
a/glibc-zoneinfo-2020d-noarch-2.txz:  Rebuilt.
  Make /etc/localtime a symlink pointing into /usr/share/zoneinfo. If you
  have /usr on a separate partition, this might cause time problems prior
  to /usr being mounted (I recommend *not* making /usr a separate partition).
  But if you insist for some reason, you can probably work around it by
  adding the pointed-to directory and timezone file to your empty pre-mounted
  /usr directory.
a/upower-0.99.11-x86_64-2.txz:  Rebuilt.
  Added /usr/share/polkit-1/rules.d/10-enable-upower-suspend.rules.
d/autoconf-2.70-noarch-1.txz:  Upgraded.
d/gnucobol-3.1.1-x86_64-1.txz:  Upgraded.
kde/powerdevil-5.20.4-x86_64-2.txz:  Rebuilt.
  Moved 10-enable-powerdevil-discrete-gpu.rules.new to
  /usr/share/polkit-1/rules.d/. Thanks to Robby Workman.
  Moved 10-enable-session-power.rules to the elogind package.
  Moved 10-enable-upower-suspend.rules to the upower package.
  Thanks to GazL.
l/jasper-2.0.23-x86_64-1.txz:  Upgraded.
  Fix heap-overflow in cp_create() in jpc_enc.c.
    https://github.com/jasper-software/jasper/issues/252
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-27828
  (* Security fix *)
l/sbc-1.5-x86_64-1.txz:  Upgraded.
n/curl-7.74.0-x86_64-1.txz:  Upgraded.
  This release includes the following security related bugfixes:
  Inferior OCSP verification [93]
  FTP wildcard stack overflow [95]
  Trusting FTP PASV responses [97]
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-8286
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-8285
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-8284
  (* Security fix *)
xap/xscreensaver-5.45-x86_64-1.txz:  Upgraded.
xfce/Greybird-3.22.13-noarch-1.txz:  Upgraded.
n°1458001
cycojesus
Mèo Lười
Posté le 13-12-2020 à 10:29:18  profilanswer
les mises à jour discrètes de KDE
Sat Dec 12 22:14:17 UTC 2020
a/kernel-generic-5.4.83-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.4.83-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.4.83-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.4.83-x86-1.txz:  Upgraded.
k/kernel-source-5.4.83-noarch-1.txz:  Upgraded.
kde/akonadi-20.12.0-x86_64-1.txz:  Upgraded.
kde/akonadi-calendar-20.12.0-x86_64-1.txz:  Upgraded.
kde/akonadi-calendar-tools-20.12.0-x86_64-1.txz:  Upgraded.
kde/akonadi-contacts-20.12.0-x86_64-1.txz:  Upgraded.
kde/akonadi-import-wizard-20.12.0-x86_64-1.txz:  Upgraded.
kde/akonadi-mime-20.12.0-x86_64-1.txz:  Upgraded.
kde/akonadi-notes-20.12.0-x86_64-1.txz:  Upgraded.
kde/akonadi-search-20.12.0-x86_64-1.txz:  Upgraded.
kde/akonadiconsole-20.12.0-x86_64-1.txz:  Upgraded.
kde/akregator-20.12.0-x86_64-1.txz:  Upgraded.
kde/analitza-20.12.0-x86_64-1.txz:  Upgraded.
kde/ark-20.12.0-x86_64-1.txz:  Upgraded.
kde/artikulate-20.12.0-x86_64-1.txz:  Upgraded.
kde/attica-5.77.0-x86_64-1.txz:  Upgraded.
kde/audiocd-kio-20.12.0-x86_64-1.txz:  Upgraded.
kde/baloo-5.77.0-x86_64-1.txz:  Upgraded.
kde/baloo-widgets-20.12.0-x86_64-1.txz:  Upgraded.
kde/blinken-20.12.0-x86_64-1.txz:  Upgraded.
kde/bluez-qt-5.77.0-x86_64-1.txz:  Upgraded.
kde/bomber-20.12.0-x86_64-1.txz:  Upgraded.
kde/bovo-20.12.0-x86_64-1.txz:  Upgraded.
kde/breeze-icons-5.77.0-noarch-1.txz:  Upgraded.
kde/calendarsupport-20.12.0-x86_64-1.txz:  Upgraded.
kde/cantor-20.12.0-x86_64-1.txz:  Upgraded.
kde/cervisia-20.12.0-x86_64-1.txz:  Upgraded.
kde/dolphin-20.12.0-x86_64-1.txz:  Upgraded.
kde/dolphin-plugins-20.12.0-x86_64-1.txz:  Upgraded.
kde/dragon-20.12.0-x86_64-1.txz:  Upgraded.
kde/elisa-20.12.0-x86_64-1.txz:  Upgraded.
kde/eventviews-20.12.0-x86_64-1.txz:  Upgraded.
kde/extra-cmake-modules-5.77.0-x86_64-1.txz:  Upgraded.
kde/ffmpegthumbs-20.12.0-x86_64-1.txz:  Upgraded.
kde/filelight-20.12.0-x86_64-1.txz:  Upgraded.
kde/frameworkintegration-5.77.0-x86_64-1.txz:  Upgraded.
kde/granatier-20.12.0-x86_64-1.txz:  Upgraded.
kde/grantlee-editor-20.12.0-x86_64-1.txz:  Upgraded.
kde/grantleetheme-20.12.0-x86_64-1.txz:  Upgraded.
kde/gwenview-20.12.0-x86_64-1.txz:  Upgraded.
kde/incidenceeditor-20.12.0-x86_64-1.txz:  Upgraded.
kde/itinerary-20.12.0-x86_64-1.txz:  Added.
kde/juk-20.12.0-x86_64-1.txz:  Upgraded.
kde/k3b-20.12.0-x86_64-1.txz:  Upgraded.
kde/kactivities-5.77.0-x86_64-1.txz:  Upgraded.
kde/kactivities-stats-5.77.0-x86_64-1.txz:  Upgraded.
kde/kaddressbook-20.12.0-x86_64-1.txz:  Upgraded.
kde/kalarm-20.12.0-x86_64-1.txz:  Upgraded.
kde/kalarmcal-20.12.0-x86_64-1.txz:  Upgraded.
kde/kalgebra-20.12.0-x86_64-1.txz:  Upgraded.
kde/kalzium-20.12.0-x86_64-1.txz:  Upgraded.
kde/kamera-20.12.0-x86_64-1.txz:  Upgraded.
kde/kamoso-20.12.0-x86_64-1.txz:  Upgraded.
kde/kanagram-20.12.0-x86_64-1.txz:  Upgraded.
kde/kapidox-5.77.0-x86_64-1.txz:  Upgraded.
kde/kapman-20.12.0-x86_64-1.txz:  Upgraded.
kde/kapptemplate-20.12.0-x86_64-1.txz:  Upgraded.
kde/karchive-5.77.0-x86_64-1.txz:  Upgraded.
kde/kate-20.12.0-x86_64-1.txz:  Upgraded.
kde/katomic-20.12.0-x86_64-1.txz:  Upgraded.
kde/kauth-5.77.0-x86_64-1.txz:  Upgraded.
kde/kbackup-20.12.0-x86_64-1.txz:  Upgraded.
kde/kblackbox-20.12.0-x86_64-1.txz:  Upgraded.
kde/kblocks-20.12.0-x86_64-1.txz:  Upgraded.
kde/kbookmarks-5.77.0-x86_64-1.txz:  Upgraded.
kde/kbounce-20.12.0-x86_64-1.txz:  Upgraded.
kde/kbreakout-20.12.0-x86_64-1.txz:  Upgraded.
kde/kbruch-20.12.0-x86_64-1.txz:  Upgraded.
kde/kcachegrind-20.12.0-x86_64-1.txz:  Upgraded.
kde/kcalc-20.12.0-x86_64-1.txz:  Upgraded.
kde/kcalendarcore-5.77.0-x86_64-1.txz:  Upgraded.
kde/kcalutils-20.12.0-x86_64-1.txz:  Upgraded.
kde/kcharselect-20.12.0-x86_64-1.txz:  Upgraded.
kde/kcm-fcitx-0.5.6-x86_64-2.txz:  Rebuilt.
  Applied upstream patch to fix ErrorOverlay panel.
  Thanks to Weng Xuetian and PiterPunk.
kde/kcmutils-5.77.0-x86_64-1.txz:  Upgraded.
kde/kcodecs-5.77.0-x86_64-1.txz:  Upgraded.
kde/kcolorchooser-20.12.0-x86_64-1.txz:  Upgraded.
kde/kcompletion-5.77.0-x86_64-1.txz:  Upgraded.
kde/kconfig-5.77.0-x86_64-1.txz:  Upgraded.
kde/kconfigwidgets-5.77.0-x86_64-1.txz:  Upgraded.
kde/kcontacts-5.77.0-x86_64-1.txz:  Upgraded.
kde/kcoreaddons-5.77.0-x86_64-1.txz:  Upgraded.
kde/kcrash-5.77.0-x86_64-1.txz:  Upgraded.
kde/kcron-20.12.0-x86_64-1.txz:  Upgraded.
kde/kdav-5.77.0-x86_64-1.txz:  Upgraded.
kde/kdbusaddons-5.77.0-x86_64-1.txz:  Upgraded.
kde/kde-dev-scripts-20.12.0-x86_64-1.txz:  Upgraded.
kde/kde-dev-utils-20.12.0-x86_64-1.txz:  Upgraded.
kde/kdebugsettings-20.12.0-x86_64-1.txz:  Upgraded.
kde/kdeclarative-5.77.0-x86_64-1.txz:  Upgraded.
kde/kdeconnect-kde-20.12.0-x86_64-1.txz:  Upgraded.
kde/kded-5.77.0-x86_64-1.txz:  Upgraded.
kde/kdeedu-data-20.12.0-x86_64-1.txz:  Upgraded.
kde/kdegraphics-mobipocket-20.12.0-x86_64-1.txz:  Upgraded.
kde/kdegraphics-thumbnailers-20.12.0-x86_64-1.txz:  Upgraded.
kde/kdelibs4support-5.77.0-x86_64-1.txz:  Upgraded.
kde/kdenetwork-filesharing-20.12.0-x86_64-1.txz:  Upgraded.
kde/kdenlive-20.12.0-x86_64-1.txz:  Upgraded.
kde/kdepim-addons-20.12.0-x86_64-1.txz:  Upgraded.
kde/kdepim-apps-libs-20.08.3-x86_64-1.txz:  Removed.
kde/kdepim-runtime-20.12.0-x86_64-1.txz:  Upgraded.
kde/kdesdk-kioslaves-20.12.0-x86_64-1.txz:  Upgraded.
kde/kdesdk-thumbnailers-20.12.0-x86_64-1.txz:  Upgraded.
kde/kdesignerplugin-5.77.0-x86_64-1.txz:  Upgraded.
kde/kdesu-5.77.0-x86_64-1.txz:  Upgraded.
kde/kdev-php-5.6.1-x86_64-1.txz:  Upgraded.
kde/kdev-python-5.6.1-x86_64-1.txz:  Upgraded.
kde/kdevelop-5.6.1-x86_64-1.txz:  Upgraded.
kde/kdewebkit-5.77.0-x86_64-1.txz:  Upgraded.
kde/kdf-20.12.0-x86_64-1.txz:  Upgraded.
kde/kdialog-20.12.0-x86_64-1.txz:  Upgraded.
kde/kdiamond-20.12.0-x86_64-1.txz:  Upgraded.
kde/kdnssd-5.77.0-x86_64-1.txz:  Upgraded.
kde/kdoctools-5.77.0-x86_64-1.txz:  Upgraded.
kde/keditbookmarks-20.12.0-x86_64-1.txz:  Upgraded.
kde/kemoticons-5.77.0-x86_64-1.txz:  Upgraded.
kde/kfilemetadata-5.77.0-x86_64-1.txz:  Upgraded.
kde/kfind-20.12.0-x86_64-1.txz:  Upgraded.
kde/kfloppy-20.12.0-x86_64-1.txz:  Upgraded.
kde/kfourinline-20.12.0-x86_64-1.txz:  Upgraded.
kde/kgeography-20.12.0-x86_64-1.txz:  Upgraded.
kde/kget-20.12.0-x86_64-1.txz:  Upgraded.
kde/kglobalaccel-5.77.0-x86_64-1.txz:  Upgraded.
kde/kgoldrunner-20.12.0-x86_64-1.txz:  Upgraded.
kde/kgpg-20.12.0-x86_64-1.txz:  Upgraded.
kde/kguiaddons-5.77.0-x86_64-1.txz:  Upgraded.
kde/khangman-20.12.0-x86_64-1.txz:  Upgraded.
kde/khelpcenter-20.12.0-x86_64-1.txz:  Upgraded.
kde/kholidays-5.77.0-x86_64-1.txz:  Upgraded.
kde/khtml-5.77.0-x86_64-1.txz:  Upgraded.
kde/ki18n-5.77.0-x86_64-1.txz:  Upgraded.
kde/kiconthemes-5.77.0-x86_64-1.txz:  Upgraded.
kde/kidentitymanagement-20.12.0-x86_64-1.txz:  Upgraded.
kde/kidletime-5.77.0-x86_64-1.txz:  Upgraded.
kde/kig-20.12.0-x86_64-1.txz:  Upgraded.
kde/kigo-20.12.0-x86_64-1.txz:  Upgraded.
kde/killbots-20.12.0-x86_64-1.txz:  Upgraded.
kde/kimageformats-5.77.0-x86_64-1.txz:  Upgraded.
kde/kimagemapeditor-20.12.0-x86_64-1.txz:  Upgraded.
kde/kimap-20.12.0-x86_64-1.txz:  Upgraded.
kde/kinit-5.77.0-x86_64-1.txz:  Upgraded.
kde/kio-5.77.0-x86_64-1.txz:  Upgraded.
kde/kio-extras-20.12.0-x86_64-1.txz:  Upgraded.
kde/kio-gdrive-20.12.0-x86_64-1.txz:  Upgraded.
kde/kipi-plugins-20.12.0-x86_64-1.txz:  Upgraded.
kde/kirigami-gallery-20.12.0-x86_64-1.txz:  Upgraded.
kde/kirigami2-5.77.0-x86_64-1.txz:  Upgraded.
kde/kiriki-20.12.0-x86_64-1.txz:  Upgraded.
kde/kitemmodels-5.77.0-x86_64-1.txz:  Upgraded.
kde/kitemviews-5.77.0-x86_64-1.txz:  Upgraded.
kde/kiten-20.12.0-x86_64-1.txz:  Upgraded.
kde/kitinerary-20.12.0-x86_64-1.txz:  Upgraded.
kde/kjobwidgets-5.77.0-x86_64-1.txz:  Upgraded.
kde/kjots-20201206_f7d555c-x86_64-1.txz:  Upgraded.
kde/kjs-5.77.0-x86_64-1.txz:  Upgraded.
kde/kjsembed-5.77.0-x86_64-1.txz:  Upgraded.
kde/kjumpingcube-20.12.0-x86_64-1.txz:  Upgraded.
kde/kldap-20.12.0-x86_64-1.txz:  Upgraded.
kde/kleopatra-20.12.0-x86_64-1.txz:  Upgraded.
kde/klickety-20.12.0-x86_64-1.txz:  Upgraded.
kde/klines-20.12.0-x86_64-1.txz:  Upgraded.
kde/kmag-20.12.0-x86_64-1.txz:  Upgraded.
kde/kmahjongg-20.12.0-x86_64-1.txz:  Upgraded.
kde/kmail-20.12.0-x86_64-1.txz:  Upgraded.
kde/kmail-account-wizard-20.12.0-x86_64-1.txz:  Upgraded.
kde/kmailtransport-20.12.0-x86_64-1.txz:  Upgraded.
kde/kmbox-20.12.0-x86_64-1.txz:  Upgraded.
kde/kmediaplayer-5.77.0-x86_64-1.txz:  Upgraded.
kde/kmime-20.12.0-x86_64-1.txz:  Upgraded.
kde/kmines-20.12.0-x86_64-1.txz:  Upgraded.
kde/kmix-20.12.0-x86_64-1.txz:  Upgraded.
kde/kmousetool-20.12.0-x86_64-1.txz:  Upgraded.
kde/kmouth-20.12.0-x86_64-1.txz:  Upgraded.
kde/kmplot-20.12.0-x86_64-1.txz:  Upgraded.
kde/knavalbattle-20.12.0-x86_64-1.txz:  Upgraded.
kde/knetwalk-20.12.0-x86_64-1.txz:  Upgraded.
kde/knewstuff-5.77.0-x86_64-1.txz:  Upgraded.
kde/knights-20.12.0-x86_64-1.txz:  Upgraded.
kde/knotes-20.12.0-x86_64-1.txz:  Upgraded.
kde/knotifications-5.77.0-x86_64-1.txz:  Upgraded.
kde/knotifyconfig-5.77.0-x86_64-1.txz:  Upgraded.
kde/kolf-20.12.0-x86_64-1.txz:  Upgraded.
kde/kollision-20.12.0-x86_64-1.txz:  Upgraded.
kde/kolourpaint-20.12.0-x86_64-1.txz:  Upgraded.
kde/kompare-20.12.0-x86_64-1.txz:  Upgraded.
kde/konqueror-20.12.0-x86_64-1.txz:  Upgraded.
kde/konquest-20.12.0-x86_64-1.txz:  Upgraded.
kde/konsole-20.12.0-x86_64-1.txz:  Upgraded.
kde/kontact-20.12.0-x86_64-1.txz:  Upgraded.
kde/kontactinterface-20.12.0-x86_64-1.txz:  Upgraded.
kde/kontrast-20.12.0-x86_64-1.txz:  Added.
kde/konversation-20.12.0-x86_64-1.txz:  Added.
kde/kopete-20.12.0-x86_64-1.txz:  Upgraded.
kde/korganizer-20.12.0-x86_64-1.txz:  Upgraded.
kde/kosmindoormap-20.12.0-x86_64-1.txz:  Added.
kde/kpackage-5.77.0-x86_64-1.txz:  Upgraded.
kde/kparts-5.77.0-x86_64-1.txz:  Upgraded.
kde/kpat-20.12.0-x86_64-1.txz:  Upgraded.
kde/kpeople-5.77.0-x86_64-1.txz:  Upgraded.
kde/kpimtextedit-20.12.0-x86_64-1.txz:  Upgraded.
kde/kpkpass-20.12.0-x86_64-1.txz:  Upgraded.
kde/kplotting-5.77.0-x86_64-1.txz:  Upgraded.
kde/kpmcore-20.12.0-x86_64-1.txz:  Upgraded.
kde/kpty-5.77.0-x86_64-1.txz:  Upgraded.
kde/kpublictransport-20.12.0-x86_64-1.txz:  Added.
kde/kqtquickcharts-20.12.0-x86_64-1.txz:  Upgraded.
kde/kquickcharts-5.77.0-x86_64-1.txz:  Upgraded.
kde/krdc-20.12.0-x86_64-1.txz:  Upgraded.
kde/kreversi-20.12.0-x86_64-1.txz:  Upgraded.
kde/krfb-20.12.0-x86_64-1.txz:  Upgraded.
kde/kross-5.77.0-x86_64-1.txz:  Upgraded.
kde/kross-interpreters-20.12.0-x86_64-1.txz:  Upgraded.
kde/kruler-20.12.0-x86_64-1.txz:  Upgraded.
kde/krunner-5.77.0-x86_64-1.txz:  Upgraded.
kde/kservice-5.77.0-x86_64-1.txz:  Upgraded.
kde/kshisen-20.12.0-x86_64-1.txz:  Upgraded.
kde/ksirk-20.12.0-x86_64-1.txz:  Upgraded.
kde/ksmtp-20.12.0-x86_64-1.txz:  Upgraded.
kde/ksnakeduel-20.12.0-x86_64-1.txz:  Upgraded.
kde/kspaceduel-20.12.0-x86_64-1.txz:  Upgraded.
kde/ksquares-20.12.0-x86_64-1.txz:  Upgraded.
kde/ksudoku-20.12.0-x86_64-1.txz:  Upgraded.
kde/ksystemlog-20.12.0-x86_64-1.txz:  Upgraded.
kde/kteatime-20.12.0-x86_64-1.txz:  Upgraded.
kde/ktexteditor-5.77.0-x86_64-1.txz:  Upgraded.
kde/ktextwidgets-5.77.0-x86_64-1.txz:  Upgraded.
kde/ktimer-20.12.0-x86_64-1.txz:  Upgraded.
kde/ktnef-20.12.0-x86_64-1.txz:  Upgraded.
kde/ktorrent-20.12.0-x86_64-1.txz:  Upgraded.
kde/ktouch-20.12.0-x86_64-1.txz:  Upgraded.
kde/kturtle-20.12.0-x86_64-1.txz:  Upgraded.
kde/kubrick-20.12.0-x86_64-1.txz:  Upgraded.
kde/kunitconversion-5.77.0-x86_64-1.txz:  Upgraded.
kde/kwallet-5.77.0-x86_64-1.txz:  Upgraded.
kde/kwalletmanager-20.12.0-x86_64-1.txz:  Upgraded.
kde/kwave-20.12.0-x86_64-1.txz:  Upgraded.
kde/kwayland-5.77.0-x86_64-1.txz:  Upgraded.
kde/kwidgetsaddons-5.77.0-x86_64-1.txz:  Upgraded.
kde/kwindowsystem-5.77.0-x86_64-1.txz:  Upgraded.
kde/kwordquiz-20.12.0-x86_64-1.txz:  Upgraded.
kde/kxmlgui-5.77.0-x86_64-1.txz:  Upgraded.
kde/kxmlrpcclient-5.77.0-x86_64-1.txz:  Upgraded.
kde/libgravatar-20.12.0-x86_64-1.txz:  Upgraded.
kde/libkcddb-20.12.0-x86_64-1.txz:  Upgraded.
kde/libkcompactdisc-20.12.0-x86_64-1.txz:  Upgraded.
kde/libkdcraw-20.12.0-x86_64-1.txz:  Upgraded.
kde/libkdegames-20.12.0-x86_64-1.txz:  Upgraded.
kde/libkdepim-20.12.0-x86_64-1.txz:  Upgraded.
kde/libkeduvocdocument-20.12.0-x86_64-1.txz:  Upgraded.
kde/libkexiv2-20.12.0-x86_64-1.txz:  Upgraded.
kde/libkgapi-20.12.0-x86_64-1.txz:  Upgraded.
kde/libkgeomap-20.08.3-x86_64-1.txz:  Removed.
kde/libkipi-20.12.0-x86_64-1.txz:  Upgraded.
kde/libkleo-20.12.0-x86_64-1.txz:  Upgraded.
kde/libkmahjongg-20.12.0-x86_64-1.txz:  Upgraded.
kde/libkomparediff2-20.12.0-x86_64-1.txz:  Upgraded.
kde/libksane-20.12.0-x86_64-1.txz:  Upgraded.
kde/libksieve-20.12.0-x86_64-1.txz:  Upgraded.
kde/libktorrent-20.12.0-x86_64-1.txz:  Upgraded.
kde/lokalize-20.12.0-x86_64-1.txz:  Upgraded.
kde/lskat-20.12.0-x86_64-1.txz:  Upgraded.
kde/mailcommon-20.12.0-x86_64-1.txz:  Upgraded.
kde/mailimporter-20.12.0-x86_64-1.txz:  Upgraded.
kde/marble-20.12.0-x86_64-1.txz:  Upgraded.
kde/markdownpart-20.12.0-x86_64-1.txz:  Added.
kde/mbox-importer-20.12.0-x86_64-1.txz:  Upgraded.
kde/messagelib-20.12.0-x86_64-1.txz:  Upgraded.
kde/minuet-20.12.0-x86_64-1.txz:  Upgraded.
kde/modemmanager-qt-5.77.0-x86_64-1.txz:  Upgraded.
kde/networkmanager-qt-5.77.0-x86_64-1.txz:  Upgraded.
kde/okular-20.12.0-x86_64-1.txz:  Upgraded.
kde/oxygen-icons5-5.77.0-noarch-1.txz:  Upgraded.
kde/palapeli-20.12.0-x86_64-1.txz:  Upgraded.
kde/parley-20.12.0-x86_64-1.txz:  Upgraded.
kde/partitionmanager-20.12.0-x86_64-1.txz:  Upgraded.
kde/picmi-20.12.0-x86_64-1.txz:  Upgraded.
kde/pim-data-exporter-20.12.0-x86_64-1.txz:  Upgraded.
kde/pim-sieve-editor-20.12.0-x86_64-1.txz:  Upgraded.
kde/pimcommon-20.12.0-x86_64-1.txz:  Upgraded.
kde/plasma-framework-5.77.0-x86_64-1.txz:  Upgraded.
kde/powerdevil-5.20.4-x86_64-3.txz:  Rebuilt.
  Don't make polkit rules shipped in /usr/share/polkit-1/rules.d/ .new.
  These can be overridden in /etc/polkit-1/rules.d/.
kde/poxml-20.12.0-x86_64-1.txz:  Upgraded.
kde/print-manager-20.12.0-x86_64-1.txz:  Upgraded.
kde/prison-5.77.0-x86_64-1.txz:  Upgraded.
kde/purpose-5.77.0-x86_64-1.txz:  Upgraded.
kde/qqc2-desktop-style-5.77.0-x86_64-1.txz:  Upgraded.
kde/rocs-20.12.0-x86_64-1.txz:  Upgraded.
kde/sddm-0.19.0-x86_64-2.txz:  Rebuilt.
  Don't make files under /usr .new. If custom scripts are needed, these may
  be specified in /etc/sddm.conf.
kde/solid-5.77.0-x86_64-1.txz:  Upgraded.
kde/sonnet-5.77.0-x86_64-1.txz:  Upgraded.
kde/spectacle-20.12.0-x86_64-1.txz:  Upgraded.
kde/step-20.12.0-x86_64-1.txz:  Upgraded.
kde/svgpart-20.12.0-x86_64-1.txz:  Upgraded.
kde/sweeper-20.12.0-x86_64-1.txz:  Upgraded.
kde/syndication-5.77.0-x86_64-1.txz:  Upgraded.
kde/syntax-highlighting-5.77.0-x86_64-1.txz:  Upgraded.
kde/threadweaver-5.77.0-x86_64-1.txz:  Upgraded.
kde/umbrello-20.12.0-x86_64-1.txz:  Upgraded.
kde/yakuake-20.12.0-x86_64-1.txz:  Upgraded.
kde/zeroconf-ioslave-20.12.0-x86_64-1.txz:  Upgraded.
l/imagemagick-7.0.10_48-x86_64-1.txz:  Upgraded.
l/libcap-ng-0.8.2-x86_64-1.txz:  Upgraded.
l/mozilla-nss-3.60-x86_64-1.txz:  Upgraded.
n/p11-kit-0.23.22-x86_64-1.txz:  Upgraded.
  Fix memory-safety issues that affect the RPC protocol.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-29361
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-29362
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-29363
  (* Security fix *)
n°1458008
kisscoolz
Posté le 13-12-2020 à 10:58:22  profilanswer
Chacun sa définition de la discrétion  :lol:
n°1458116
cycojesus
Mèo Lười
Posté le 15-12-2020 à 10:31:35  profilanswer
les mises à jour de boost qui te font recompiler des choses et/ou installer http://www.slackware.com/~alien/sl [...] st-compat/ pour que les choses continuent à tourner le temps de les recompiler
Mon Dec 14 22:41:16 UTC 2020
ap/pamixer-1.4-x86_64-7.txz:  Rebuilt.
  Recompiled against boost-1.75.0.
ap/rpm-4.16.1-x86_64-1.txz:  Upgraded.
d/strace-5.10-x86_64-1.txz:  Upgraded.
kde/kig-20.12.0-x86_64-2.txz:  Rebuilt.
kde/krita-4.4.1-x86_64-2.txz:  Rebuilt.
l/atkmm-2.28.1-x86_64-1.txz:  Upgraded.
l/boost-1.75.0-x86_64-1.txz:  Upgraded.
l/cryfs-0.10.2-x86_64-2.txz:  Rebuilt.
l/fftw-3.3.9-x86_64-1.txz:  Upgraded.
l/glade3-3.8.6-x86_64-2.txz:  Removed.
l/gtkmm3-3.24.3-x86_64-1.txz:  Upgraded.
l/libcap-2.46-x86_64-1.txz:  Upgraded.
l/mozjs78-78.6.0esr-x86_64-1.txz:  Upgraded.
l/openexr-2.5.3-x86_64-2.txz:  Rebuilt.
l/pangomm-2.42.2-x86_64-1.txz:  Upgraded.
l/rttr-0.9.6-x86_64-2.txz:  Rebuilt.
  Get rid of /usr/doc/index.html (and excessive docs).
n/s-nail-14.9.20-x86_64-1.txz:  Upgraded.
xap/mozilla-firefox-78.6.0esr-x86_64-1.txz:  Upgraded.
  This is a bugfix release.
    https://www.mozilla.org/en-US/firefox/78.6.0/releasenotes/
xap/xpaint-3.0.3-x86_64-1.txz:  Upgraded.
xfce/libxfce4ui-4.14.1-x86_64-2.txz:  Rebuilt.
  Recompiled against glade-3.38.2.
n°1458186
cycojesus
Mèo Lười
Posté le 16-12-2020 à 08:21:42  profilanswer
Tue Dec 15 20:39:53 UTC 2020
d/python-pip-20.3.3-x86_64-1.txz:  Upgraded.
kde/sddm-0.19.0-x86_64-3.txz:  Rebuilt.
  In SDDM's Xsession script, don't source $HOME/.xsession as this may launch
  the wrong session type or cause dbus-run-session to start twice breaking
  logout.
l/orc-0.4.32-x86_64-1.txz:  Upgraded.
l/pipewire-0.3.18-x86_64-1.txz:  Upgraded.
l/python-chardet-4.0.0-x86_64-1.txz:  Upgraded.
l/python-packaging-20.8-x86_64-1.txz:  Upgraded.
n/samba-4.13.3-x86_64-1.txz:  Upgraded.
xap/mozilla-thunderbird-78.6.0-x86_64-1.txz:  Upgraded.
    https://www.mozilla.org/en-US/thunderbird/78.6.0/releasenotes/
xfce/mousepad-0.5.0-x86_64-1.txz:  Upgraded.
n°1458257
cycojesus
Mèo Lười
Posté le 17-12-2020 à 10:26:36  profilanswer
Thu Dec 17 04:05:14 UTC 2020
I'm still poking at that other kernel, but it shouldn't take too much longer.
a/kernel-generic-5.4.84-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.4.84-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.4.84-x86_64-1.txz:  Upgraded.
ap/rpm-4.16.1.2-x86_64-1.txz:  Upgraded.
d/cmake-3.19.2-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.4.84-x86-1.txz:  Upgraded.
k/kernel-source-5.4.84-noarch-1.txz:  Upgraded.
l/utf8proc-2.6.1-x86_64-1.txz:  Upgraded.
x/fonttosfnt-1.2.1-x86_64-1.txz:  Upgraded.
x/mesa-20.3.1-x86_64-1.txz:  Upgraded.
  Don't specify dri-drivers-path.  Thanks to 414N.
n°1458327
cycojesus
Mèo Lười
Posté le 18-12-2020 à 08:50:18  profilanswer
Thu Dec 17 23:02:41 UTC 2020
a/inih-r52-x86_64-1.txz:  Added.
  This is required by the latest xfsprogs.
a/sysklogd-2.1.2-x86_64-2.txz:  Rebuilt.
  rc.syslog: fix lack of <CR> after startup output.
a/xfsprogs-5.10.0-x86_64-1.txz:  Upgraded.
ap/vim-8.2.2151-x86_64-1.txz:  Upgraded.
l/glib2-2.66.4-x86_64-1.txz:  Upgraded.
l/imagemagick-7.0.10_50-x86_64-1.txz:  Upgraded.
l/python-requests-2.25.1-x86_64-1.txz:  Upgraded.
l/qtkeychain-0.12.0-x86_64-1.txz:  Upgraded.
l/zstd-1.4.7-x86_64-1.txz:  Upgraded.
n/bind-9.16.10-x86_64-1.txz:  Upgraded.
x/libwacom-1.7-x86_64-1.txz:  Upgraded.
x/xorg-server-1.20.10-x86_64-2.txz:  Rebuilt.
  Recompiled to find DRI modules in the new location.
x/xorg-server-xephyr-1.20.10-x86_64-2.txz:  Rebuilt.
x/xorg-server-xnest-1.20.10-x86_64-2.txz:  Rebuilt.
x/xorg-server-xvfb-1.20.10-x86_64-2.txz:  Rebuilt.
x/xorg-server-xwayland-1.20.10-x86_64-2.txz:  Rebuilt.
xap/vim-gvim-8.2.2151-x86_64-1.txz:  Upgraded.
extra/pure-alsa-system/kde-runtime-4.14.3-x86_64-8_alsa.txz:  Removed.
  I'm starting to learn towards removing all of these packages as there are
  ways to configure PulseAudio to get out of the way. See (for example) this
  article mentioned in a blog post by alienBOB:
  https://wiki.archlinux.org/index.php/PulseAudio/Examples#PulseAudio_as_a_minimal_unintrusive_dumb_pipe_to_ALSA
n°1458389
cycojesus
Mèo Lười
Posté le 18-12-2020 à 22:27:35  profilanswer
Fri Dec 18 20:41:05 UTC 2020
ap/sudo-1.9.4p1-x86_64-1.txz:  Upgraded.
l/icu4c-68.2-x86_64-1.txz:  Upgraded.
l/netpbm-10.92.01-x86_64-1.txz:  Upgraded.
n/ethtool-5.10-x86_64-1.txz:  Upgraded.
x/libva-utils-2.10.0-x86_64-1.txz:  Upgraded.
x/xf86-video-intel-20201215_a511f22c-x86_64-1.txz:  Upgraded.
Message édité par cycojesus le 18-12-2020 à 22:28:06
n°1458450
cycojesus
Mèo Lười
Posté le 20-12-2020 à 08:57:57  profilanswer
5.10.1 ! :sol:
Sun Dec 20 03:10:57 UTC 2020
Linus didn't think this was a scary kernel and in spite of skipping a few
branches here before getting to this one, I don't either. Not scary enough
to make me think I need to start it out in /testing, anyway. I have a good
feeling about this kernel. Enjoy! :-)
a/bash-5.1.004-x86_64-1.txz:  Upgraded.
a/elogind-246.9-x86_64-1.txz:  Upgraded.
  Don't make 10-enable-session-power.rules a .new file.
a/kernel-firmware-20201218_646f159-noarch-1.txz:  Upgraded.
a/kernel-generic-5.10.1-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.10.1-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.10.1-x86_64-1.txz:  Upgraded.
a/ndctl-71-x86_64-1.txz:  Upgraded.
a/sysvinit-scripts-2.1-noarch-37.txz:  Rebuilt.
  rc.S: don't start cgmanager/cgproxy.
  rc.6: don't stop cgmanager/cgproxy.
d/kernel-headers-5.10.1-x86-1.txz:  Upgraded.
k/kernel-source-5.10.1-noarch-1.txz:  Upgraded.
l/libtiff-4.2.0-x86_64-1.txz:  Upgraded.
l/zstd-1.4.8-x86_64-1.txz:  Upgraded.
n/ca-certificates-20201219-noarch-1.txz:  Upgraded.
  This update provides the latest CA certificates to check for the
  authenticity of SSL connections.
xap/libnma-1.8.30-x86_64-1.txz:  Upgraded.
n°1458476
cycojesus
Mèo Lười
Posté le 21-12-2020 à 08:28:16  profilanswer
Sun Dec 20 21:30:36 UTC 2020
ap/sudo-1.9.4p2-x86_64-1.txz:  Upgraded.
kde/kmymoney-5.1.1-x86_64-1.txz:  Upgraded.
l/babl-0.1.84-x86_64-1.txz:  Upgraded.
l/gegl-0.4.28-x86_64-1.txz:  Upgraded.
l/imagemagick-7.0.10_51-x86_64-1.txz:  Upgraded.
n°1458495
regdub
Posté le 21-12-2020 à 16:56:11  profilanswer
Bien ! So far so good.  [:klemo:3]
Legalize it @HFR
n°1458512
cycojesus
Mèo Lười
Posté le 22-12-2020 à 10:34:23  profilanswer
et donc 5.10.2
Mon Dec 21 22:23:10 UTC 2020
a/kernel-generic-5.10.2-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.10.2-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.10.2-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.10.2-x86-1.txz:  Upgraded.
d/parallel-20201222-noarch-1.txz:  Upgraded.
d/python-setuptools-51.1.0-x86_64-1.txz:  Upgraded.
k/kernel-source-5.10.2-noarch-1.txz:  Upgraded.
  -USB_SISUSBVGA_CON y
   PCIE_BW y -> n
  Thanks to walecha.
l/gegl-0.4.28-x86_64-2.txz:  Rebuilt.
  Make sure gegl:introspect is available or GIMP won't start.
n/gnupg2-2.2.26-x86_64-1.txz:  Upgraded.
n/iproute2-5.10.0-x86_64-1.txz:  Upgraded.
n/ipset-7.10-x86_64-1.txz:  Upgraded.
x/liberation-fonts-ttf-2.1.2-noarch-1.txz:  Upgraded.
xfce/xfce4-systemload-plugin-1.2.4-x86_64-1.txz:  Upgraded.
n°1458562
cycojesus
Mèo Lười
Posté le 23-12-2020 à 08:03:07  profilanswer
Tue Dec 22 20:45:03 UTC 2020
a/elogind-246.9.1-x86_64-1.txz:  Upgraded.
ap/htop-3.0.4-x86_64-1.txz:  Upgraded.
ap/man-pages-5.10-noarch-1.txz:  Upgraded.
l/SDL2-2.0.14-x86_64-1.txz:  Upgraded.
l/kdsoap-1.10.0-x86_64-1.txz:  Upgraded.
l/opencv-4.5.1-x86_64-1.txz:  Upgraded.
n/libgpg-error-1.41-x86_64-1.txz:  Upgraded.
t/xfig-3.2.8-x86_64-1.txz:  Upgraded.
xap/blueman-2.1.4-x86_64-2.txz:  Rebuilt.
  Restore the AppIndicator.py plugin.
n°1458600
cycojesus
Mèo Lười
Posté le 24-12-2020 à 15:05:15  profilanswer
Wed Dec 23 21:21:34 UTC 2020
a/lilo-24.2-x86_64-10.txz:  Rebuilt.
  Add -fcommon to fix build with gcc10.
  liloconfig:
  Don't warn about UMSDOS which is long obsolete.
  Detect QEMU and use /dev/vda as the boot device in that case.
  Fix a case where /mnt was used instead of the target partition variable.
  Thanks to alienBOB.
a/mkinitrd-1.4.11-x86_64-16.txz:  Rebuilt.
  Blacklist rules.d/73-seat-late.rules. Thanks to Robby Workman.
a/ndctl-71.1-x86_64-1.txz:  Upgraded.
a/sysklogd-2.1.2-x86_64-3.txz:  Rebuilt.
  /etc/logrotate.d/syslog.new: add missingok option. Thanks to sovteq.
l/gdbm-1.19-x86_64-1.txz:  Upgraded.
t/fig2dev-3.2.8-x86_64-1.txz:  Upgraded.
x/libepoxy-1.5.5-x86_64-1.txz:  Upgraded.
n°1458617
cycojesus
Mèo Lười
Posté le 25-12-2020 à 11:07:12  profilanswer
Fri Dec 25 06:10:08 UTC 2020
l/harfbuzz-2.7.3-x86_64-2.txz:  Rebuilt.
  Seems the --enable-introspection option didn't work, so rebuild with meson
  since that's probably what most of the developers do. Fixes blueman.
  Thanks to marav for the bug report.
Fri Dec 25 00:52:08 UTC 2020
Here are some updates to provide a little holiday cheer. The kernels are
rebuilt (yeah, we'll probably have new ones tomorrow but whatever) to build in
HWMON making NVMe temperature monitoring available, and there's also a massive
cleanup of polkit/dbus related packages to move most of the config files out
of /etc and not install them as .new. Local config files that override the
shipped ones may be placed in the directories in /etc to override the ones that
we ship. Thanks to Robby Workman for this!
None of the packages included in Slackware place any files in
/etc/polkit-1/rules.d/ or /etc/dbus-1/system.d/ any more, but there may be
third-party packages that still do. However, since Slackware's packages
originally installed these as .new files, the leftover configs will remain.
You'll probably want to take a look in those directories to clean out any
config files that you haven't modified yourself or that belong to packages that
aren't part of Slackware itself.
Hope everyone has a great day. :-)
a/dbus-1.12.20-x86_64-3.txz:  Rebuilt.
  Added local config override directory /etc/dbus-1/system.d/ since no other
  package provides it now.
a/kernel-generic-5.10.2-x86_64-2.txz:  Upgraded.
a/kernel-huge-5.10.2-x86_64-2.txz:  Upgraded.
a/kernel-modules-5.10.2-x86_64-2.txz:  Upgraded.
a/udisks-1.0.5-x86_64-6.txz:  Rebuilt.
  Move D-Bus configs from /etc to the system location. Thanks to Robby Workman.
a/udisks2-2.9.1-x86_64-2.txz:  Rebuilt.
  Include 20-plugdev-group-mount-override.rules, installed in the system
ap/cups-2.3.3-x86_64-3.txz:  Rebuilt.
ap/hplip-3.20.6-x86_64-4.txz:  Rebuilt.
  Use --enable-qt5.
  Drop HAL support (LOL!)
ap/mpg123-1.26.4-x86_64-1.txz:  Upgraded.
d/gnucobol-3.1.2-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.10.2-x86-2.txz:  Upgraded.
k/kernel-source-5.10.2-noarch-2.txz:  Upgraded.
   HWMON m -> y
  +NVME_HWMON y
  +POWER_SUPPLY_HWMON y
  +THERMAL_HWMON y
  Thanks to Daedra.
kde/sddm-0.19.0-x86_64-4.txz:  Rebuilt.
  Don't include the /etc/dbus-1/system.d/ directory.
l/GConf-3.2.6-x86_64-5.txz:  Rebuilt.
l/accountsservice-0.6.55-x86_64-2.txz:  Rebuilt.
l/cryptopp-8.3.0-x86_64-1.txz:  Upgraded.
l/harfbuzz-2.7.3-x86_64-1.txz:  Upgraded.
l/polkit-0.118-x86_64-3.txz:  Rebuilt.
  Remove D-Bus rules for udisks2 and NetworkManager (moved to those packages).
l/pulseaudio-14.0-x86_64-2.txz:  Rebuilt.
l/system-config-printer-1.5.12-x86_64-6.txz:  Rebuilt.
n/ModemManager-1.14.8-x86_64-2.txz:  Rebuilt.
  Added elogind support.
n/NetworkManager-1.28.0-x86_64-2.txz:  Rebuilt.
  Include 10-org.freedesktop.NetworkManager.rules, installed in the system
n/bluez-5.55-x86_64-2.txz:  Rebuilt.
n/netatalk-3.1.12-x86_64-5.txz:  Rebuilt.
  Patched to fix failure to build from source with gcc10.
n/wpa_supplicant-2.9-x86_64-3.txz:  Rebuilt.
x/mesa-20.3.1-x86_64-2.txz:  Rebuilt.
  [PATCH] vulkan/device_select: Store Vulkan vendorID and deviceID as uint32_t.
  Thanks to sasha69 for the link to the upstream discussion/commit.
xap/blueman-2.1.4-x86_64-3.txz:  Rebuilt.
xap/xgames-0.3-x86_64-6.txz:  Rebuilt.
  Fixed spider failing to build from source with gcc10.
  Removed the ancient version of xsnow.
xap/xscreensaver-5.45-x86_64-2.txz:  Rebuilt.
  Make the description of the xscreensaver settings be clearly for xscreensaver
  as opposed to a generic "screensaver" settings. Thanks to Robby Workman.
xap/xsnow-3.1.9-x86_64-1.txz:  Added.
  Merry Christmas / Happy Holidays! :-)
xfce/mousepad-0.5.1-x86_64-1.txz:  Upgraded.
xfce/xfce4-screensaver-0.1.11-x86_64-2.txz:  Rebuilt.
  Make the description of the xfce4-screensaver settings be clearly for
  xfce4-screensaver as opposed to a generic "screensaver" settings.
xfce/xfce4-session-4.14.2-x86_64-2.txz:  Rebuilt.
  Use xfce4-screensaver by default and don't ship the xscreensaver.desktop
  autostart file. Thanks to Robby Workman.
extra/pure-alsa-system/*:  Removed.
  This served a purpose during the pure ALSA to PulseAudio transition, but
  it's time for it to go away. If the latency is an issue for your use case,
  a look around should turn up documentation on how to reduce it, or how to
  send output directly to ALSA without having to uninstall PulseAudio or
  recompile anything that's linked to it. As an example, see this one (which
  was mentioned here before):
isolinux/initrd.img:  Rebuilt.
kernels/*:  Upgraded.
usb-and-pxe-installers/usbboot.img:  Rebuilt.
Chết rồi ! ✍ ⌥⌘ http://codeberg.org/gwh
n°1458629
cycojesus
Mèo Lười
Posté le 26-12-2020 à 07:58:55  profilanswer
Fri Dec 25 21:31:29 UTC 2020
l/keyutils-1.6.3-x86_64-1.txz:  Upgraded.
l/pulseaudio-14.0-x86_64-3.txz:  Rebuilt.
  Patched to support detecting elogind at compile time when built with meson.
  This restores PulseAudio exiting upon user logout.
  Thanks to LuckyCyborg for the bug report and patch.
l/system-config-printer-1.5.13-x86_64-1.txz:  Upgraded.
n/mobile-broadband-provider-info-20201225-x86_64-1.txz:  Upgraded.
n°1458672
cycojesus
Mèo Lười
Posté le 27-12-2020 à 10:32:04  profilanswer
Sat Dec 26 21:51:18 UTC 2020
a/glibc-zoneinfo-2020e-noarch-1.txz:  Upgraded.
  This package provides the latest timezone updates.
a/kernel-generic-5.10.3-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.10.3-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.10.3-x86_64-1.txz:  Upgraded.
ap/sysstat-12.5.2-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.10.3-x86-1.txz:  Upgraded.
k/kernel-source-5.10.3-noarch-1.txz:  Upgraded.
   SND_PCSP n -> m
   SND_SOC_AK5558 n -> m
   SND_SOC_INTEL_CML_LP_DA7219_MAX98357A_MACH n -> m
   SND_SOC_INTEL_KBL_RT5663_RT5514_MAX98927_MACH n -> m
   SND_SOC_INTEL_SKL_HDA_DSP_GENERIC_MACH n -> m
   SND_SOC_INTEL_SOF_RT5682_MACH n -> m
  +SND_SOC_RT5514 m
  +SND_SOC_RT5514_SPI m
  Added a few more sound modules. Thanks to Loomx for pointing out that
  SND_SOC_INTEL_SKL_HDA_DSP_GENERIC_MACH was missing.
l/imagemagick-7.0.10_53-x86_64-1.txz:  Upgraded.
l/libusb-1.0.24-x86_64-1.txz:  Upgraded.
n°1458689
cycojesus
Mèo Lười
Posté le 28-12-2020 à 08:47:19  profilanswer
Et Xfce 4.16 donc
Sun Dec 27 22:52:10 UTC 2020
And, just a month after Xfce 4.14 appeared in vtown, we have Xfce 4.16 updates
in the main tree. Thanks much to Robby Workman for making it happen. :-)
a/aaa_terminfo-6.2_20201219-x86_64-1.txz:  Upgraded.
a/ndctl-71.1-x86_64-2.txz:  Rebuilt.
  Fix bash-completion file installation (previously it was causing the
  completion dir to have mode 0644). Thanks to Robby Workman.
l/harfbuzz-2.7.4-x86_64-1.txz:  Upgraded.
l/libarchive-3.5.1-x86_64-1.txz:  Upgraded.
l/libgtop-2.40.0-x86_64-1.txz:  Added.
  This is used by libxfce4ui to provide extra information in the about page.
l/ncurses-6.2_20201219-x86_64-1.txz:  Upgraded.
n/wpa_supplicant-2.9-x86_64-4.txz:  Rebuilt.
  Fix desktop file to not show if kdesu isn't available. Thanks to Hyperion.
x/xterm-363-x86_64-1.txz:  Upgraded.
xap/xsnow-3.2.0-x86_64-1.txz:  Upgraded.
xfce/Greybird-3.22.13-noarch-2.txz:  Rebuilt.
xfce/exo-4.16.0-x86_64-1.txz:  Upgraded.
xfce/garcon-0.8.0-x86_64-1.txz:  Upgraded.
xfce/libxfce4ui-4.16.0-x86_64-1.txz:  Upgraded.
xfce/libxfce4util-4.16.0-x86_64-1.txz:  Upgraded.
xfce/mousepad-0.5.1-x86_64-2.txz:  Rebuilt.
xfce/thunar-4.16.0-x86_64-1.txz:  Upgraded.
xfce/thunar-volman-4.16.0-x86_64-1.txz:  Upgraded.
xfce/tumbler-4.16.0-x86_64-1.txz:  Upgraded.
xfce/xfce4-appfinder-4.16.0-x86_64-1.txz:  Upgraded.
xfce/xfce4-clipman-plugin-1.6.1-x86_64-2.txz:  Rebuilt.
xfce/xfce4-dev-tools-4.16.0-x86_64-1.txz:  Upgraded.
xfce/xfce4-notifyd-0.6.2-x86_64-2.txz:  Rebuilt.
xfce/xfce4-panel-4.16.0-x86_64-1.txz:  Upgraded.
xfce/xfce4-panel-profiles-1.0.10-x86_64-2.txz:  Rebuilt.
xfce/xfce4-power-manager-4.16.0-x86_64-1.txz:  Upgraded.
xfce/xfce4-pulseaudio-plugin-0.4.3-x86_64-2.txz:  Rebuilt.
xfce/xfce4-screensaver-0.1.11-x86_64-3.txz:  Rebuilt.
xfce/xfce4-screenshooter-1.9.8-x86_64-1.txz:  Upgraded.
xfce/xfce4-session-4.16.0-x86_64-1.txz:  Upgraded.
xfce/xfce4-settings-4.16.0-x86_64-1.txz:  Upgraded.
xfce/xfce4-systemload-plugin-1.2.4-x86_64-2.txz:  Rebuilt.
xfce/xfce4-taskmanager-1.2.3-x86_64-2.txz:  Rebuilt.
xfce/xfce4-terminal-0.8.10-x86_64-1.txz:  Upgraded.
xfce/xfce4-weather-plugin-0.10.2-x86_64-2.txz:  Rebuilt.
xfce/xfce4-whiskermenu-plugin-2.5.0-x86_64-1.txz:  Upgraded.
xfce/xfconf-4.16.0-x86_64-1.txz:  Upgraded.
xfce/xfdesktop-4.16.0-x86_64-1.txz:  Upgraded.
xfce/xfwm4-4.16.0-x86_64-1.txz:  Upgraded.
n°1458735
cycojesus
Mèo Lười
Posté le 29-12-2020 à 10:56:11  profilanswer
Mon Dec 28 20:13:50 UTC 2020
a/eudev-3.2.9-x86_64-3.txz:  Rebuilt.
  Blacklist the snd-pcsp module. Thanks to Paulo2.
  Fix typo in watchdog.conf: ebc_c384_wdt -> ebc-c384_wdt.
ap/terminus-font-4.49-noarch-1.txz:  Upgraded.
extra/brltty/brltty-6.2-x86_64-1.txz:  Upgraded.
n°1458769
cycojesus
Mèo Lười
Posté le 29-12-2020 à 21:59:20  profilanswer
Tue Dec 29 20:34:54 UTC 2020
a/pkgtools-15.0-noarch-34.txz:  Rebuilt.
  installpkg: run doinst.sh in a subshell for NOLOCK packages.
  removepkg: run uninstall scripts in a subshell.
  This avoids a bug when handling multiple packages where these scripts might
  be in the wrong directory when a new file/package is to be processed.
  Thanks to Mario Preksavec.
ap/terminus-font-4.49.1-noarch-1.txz:  Upgraded.
d/git-2.30.0-x86_64-1.txz:  Upgraded.
d/python-setuptools-51.1.1-x86_64-1.txz:  Upgraded.
l/libproxy-0.4.17-x86_64-1.txz:  Upgraded.
l/netpbm-10.93.00-x86_64-1.txz:  Upgraded.
l/openjpeg-2.4.0-x86_64-1.txz:  Upgraded.
xap/hexchat-2.14.3-x86_64-5.txz:  Rebuilt.
  Compile using -Dwith-python=python3-embed instead of -Dwith-python=python3
  to ensure that /usr/lib*/hexchat/plugins/python.so is linked with libpython,
  otherwise the module will not load properly.
xfce/xfce4-panel-profiles-1.0.12-x86_64-1.txz:  Upgraded.
xfce/xfce4-taskmanager-1.4.0-x86_64-1.txz:  Upgraded.
n°1458823
cycojesus
Mèo Lười
Posté le 31-12-2020 à 08:40:33  profilanswer
nethack pour la Saint-Sylvestre
Wed Dec 30 21:56:42 UTC 2020
a/kernel-firmware-20201230_f580dc2-noarch-1.txz:  Upgraded.
a/kernel-generic-5.10.4-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.10.4-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.10.4-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.10.4-x86-1.txz:  Upgraded.
k/kernel-source-5.10.4-noarch-1.txz:  Upgraded.
xfce/thunar-4.16.1-x86_64-1.txz:  Upgraded.
y/nethack-3.6.6-x86_64-1.txz:  Added.
  Might as well have more than one package in this series. :-)
  We'll use similar install paths to the ones used by bsd-games for this.
n°1458881
cycojesus
Mèo Lười
Posté le 31-12-2020 à 23:30:09  profilanswer
comme ça
Thu Dec 31 20:42:33 UTC 2020
a/glibc-zoneinfo-2020f-noarch-1.txz:  Upgraded.
ap/inxi-20201217_df45e6d4-noarch-1.txz:  Upgraded.
ap/neofetch-20201126_6dd85d6-noarch-1.txz:  Upgraded.
n/getmail-6.12-x86_64-1.txz:  Upgraded.
n/mutt-2.0.4-x86_64-1.txz:  Upgraded.
n/wget-1.21-x86_64-1.txz:  Upgraded.
x/mesa-20.3.2-x86_64-1.txz:  Upgraded.
n°1458905
cycojesus
Mèo Lười
Posté le 01-01-2021 à 15:04:10  profilanswer
chúc mừng năm mới 2021 et saluons la gestation d'un port aarch64 (arm 64 bits) officiel !
L'annonce sur http://arm.slackware.com/
n°1458939
cycojesus
Mèo Lười
Posté le 02-01-2021 à 10:38:11  profilanswer
Ruby 3.0 :sol:
Fri Jan  1 22:45:48 UTC 2021
a/exfatprogs-1.0.4-x86_64-1.txz:  Added.
ap/vim-8.2.2269-x86_64-1.txz:  Upgraded.
  Add Ruby and Tcl support, make language support dynamic if possible.
d/ruby-3.0.0-x86_64-1.txz:  Upgraded.
  Shared library .so-version bump.
d/subversion-1.14.0-x86_64-4.txz:  Rebuilt.
  Recompiled against ruby-3.0.0.
l/openexr-2.5.4-x86_64-1.txz:  Upgraded.
l/python-idna-3.0-x86_64-1.txz:  Upgraded.
n/cifs-utils-6.12-x86_64-1.txz:  Upgraded.
n/epic5-2.1.2-x86_64-5.txz:  Rebuilt.
x/marisa-0.2.6-x86_64-2.txz:  Rebuilt.
xap/vim-gvim-8.2.2269-x86_64-1.txz:  Upgraded.
n°1458968
cycojesus
Mèo Lười
Posté le 03-01-2021 à 00:00:38  profilanswer
Sat Jan  2 20:36:24 UTC 2021
a/smartmontools-7.2-x86_64-1.txz:  Upgraded.
l/cryptopp-8.4.0-x86_64-1.txz:  Upgraded.
l/shared-mime-info-2.1-x86_64-1.txz:  Upgraded.
xfce/xfce4-whiskermenu-plugin-2.5.1-x86_64-1.txz:  Upgraded.
n°1459028
kisscoolz
Posté le 04-01-2021 à 12:22:32  profilanswer
A 38 secondes près  [:haha muscle]
n°1459060
cycojesus
Mèo Lười
Posté le 05-01-2021 à 09:02:01  profilanswer
Tue Jan  5 00:27:10 UTC 2021
a/haveged-1.9.14-x86_64-1.txz:  Upgraded.
ap/ispell-3.4.01-x86_64-1.txz:  Upgraded.
d/distcc-3.3.5-x86_64-1.txz:  Upgraded.
kde/calligra-3.2.1-x86_64-2.txz:  Rebuilt.
  Recompiled against poppler-21.01.0.
kde/cantor-20.12.0-x86_64-2.txz:  Rebuilt.
kde/kfilemetadata-5.77.0-x86_64-2.txz:  Rebuilt.
kde/kile-2.9.93-x86_64-2.txz:  Rebuilt.
kde/kitinerary-20.12.0-x86_64-2.txz:  Rebuilt.
kde/krita-4.4.1-x86_64-3.txz:  Rebuilt.
kde/okular-20.12.0-x86_64-2.txz:  Rebuilt.
l/imagemagick-7.0.10_55-x86_64-1.txz:  Upgraded.
l/jasper-2.0.24-x86_64-1.txz:  Upgraded.
l/mozilla-nss-3.60.1-x86_64-1.txz:  Upgraded.
l/ocl-icd-2.2.14-x86_64-1.txz:  Upgraded.
l/poppler-21.01.0-x86_64-1.txz:  Upgraded.
l/python-idna-3.1-x86_64-1.txz:  Upgraded.
l/python-pillow-8.1.0-x86_64-1.txz:  Upgraded.
n/dehydrated-0.7.0-noarch-1.txz:  Added.
  This is a Let's Encrypt / ACME setup script. Thanks to Heinz Wiesinger.
n/dovecot-2.3.13-x86_64-1.txz:  Upgraded.
n/fetchmail-6.4.15-x86_64-1.txz:  Upgraded.
n/nettle-3.7-x86_64-1.txz:  Upgraded.
tcl/tcl-8.6.11-x86_64-1.txz:  Upgraded.
tcl/tk-8.6.11-x86_64-1.txz:  Upgraded.
xfce/xfce4-screensaver-0.1.11-x86_64-4.txz:  Rebuilt.
  Don't ship unneeded autostart file. Thanks to ljb643.
n°1459096
cycojesus
Mèo Lười
Posté le 06-01-2021 à 09:56:11  profilanswer
blague sur KDE
Tue Jan  5 22:42:46 UTC 2021
a/lzlib-1.12-x86_64-1.txz:  Upgraded.
ap/qpdf-10.1.0-x86_64-1.txz:  Upgraded.
kde/bluedevil-5.20.5-x86_64-1.txz:  Upgraded.
kde/breeze-5.20.5-x86_64-1.txz:  Upgraded.
kde/breeze-grub-5.20.5-x86_64-1.txz:  Upgraded.
kde/breeze-gtk-5.20.5-x86_64-1.txz:  Upgraded.
kde/drkonqi-5.20.5-x86_64-1.txz:  Upgraded.
kde/kactivitymanagerd-5.20.5-x86_64-1.txz:  Upgraded.
kde/kde-cli-tools-5.20.5-x86_64-1.txz:  Upgraded.
kde/kde-gtk-config-5.20.5-x86_64-1.txz:  Upgraded.
kde/kdecoration-5.20.5-x86_64-1.txz:  Upgraded.
kde/kdeplasma-addons-5.20.5-x86_64-1.txz:  Upgraded.
kde/kgamma5-5.20.5-x86_64-1.txz:  Upgraded.
kde/khotkeys-5.20.5-x86_64-1.txz:  Upgraded.
kde/kinfocenter-5.20.5-x86_64-1.txz:  Upgraded.
kde/kmenuedit-5.20.5-x86_64-1.txz:  Upgraded.
kde/kscreen-5.20.5-x86_64-1.txz:  Upgraded.
kde/kscreenlocker-5.20.5-x86_64-1.txz:  Upgraded.
kde/ksshaskpass-5.20.5-x86_64-1.txz:  Upgraded.
kde/ksysguard-5.20.5-x86_64-1.txz:  Upgraded.
kde/kwallet-pam-5.20.5-x86_64-1.txz:  Upgraded.
kde/kwayland-integration-5.20.5-x86_64-1.txz:  Upgraded.
kde/kwayland-server-5.20.5-x86_64-1.txz:  Upgraded.
kde/kwin-5.20.5-x86_64-1.txz:  Upgraded.
kde/kwrited-5.20.5-x86_64-1.txz:  Upgraded.
kde/libkscreen-5.20.5-x86_64-1.txz:  Upgraded.
kde/libksysguard-5.20.5-x86_64-1.txz:  Upgraded.
kde/milou-5.20.5-x86_64-1.txz:  Upgraded.
kde/oxygen-5.20.5-x86_64-1.txz:  Upgraded.
kde/plasma-browser-integration-5.20.5-x86_64-1.txz:  Upgraded.
kde/plasma-desktop-5.20.5-x86_64-1.txz:  Upgraded.
kde/plasma-disks-5.20.5-x86_64-1.txz:  Upgraded.
kde/plasma-integration-5.20.5-x86_64-1.txz:  Upgraded.
kde/plasma-nm-5.20.5-x86_64-1.txz:  Upgraded.
kde/plasma-pa-5.20.5-x86_64-1.txz:  Upgraded.
kde/plasma-sdk-5.20.5-x86_64-1.txz:  Upgraded.
kde/plasma-vault-5.20.5-x86_64-1.txz:  Upgraded.
kde/plasma-workspace-5.20.5-x86_64-1.txz:  Upgraded.
kde/plasma-workspace-wallpapers-5.20.5-x86_64-1.txz:  Upgraded.
kde/polkit-kde-agent-1-5.20.5-x86_64-1.txz:  Upgraded.
kde/powerdevil-5.20.5-x86_64-1.txz:  Upgraded.
kde/sddm-kcm-5.20.5-x86_64-1.txz:  Upgraded.
kde/systemsettings-5.20.5-x86_64-1.txz:  Upgraded.
kde/xdg-desktop-portal-kde-5.20.5-x86_64-1.txz:  Upgraded.
l/pipewire-0.3.19-x86_64-1.txz:  Upgraded.
l/vte-0.62.1-x86_64-2.txz:  Rebuilt.
  Get rid of bogus symlink in the docs directory. Thanks to titopoquito.
n/php-7.4.14-x86_64-1.txz:  Upgraded.
  This update fixes bugs and a security issue:
  Standard: FILTER_VALIDATE_URL accepts URLs with invalid userinfo.
  For more information, see:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-7071
  (* Security fix *)
x/x11-skel-7.7-x86_64-6.txz:  Rebuilt.
  Added /usr/share/xsessions/xwmconfig.desktop to run the session type
  configured by xwmconfig. This will show up in SDDM.
x/xdm-1.1.11-x86_64-12.txz:  Rebuilt.
  Fix some permissions in /etc/X11/xdm/.
n°1459135
cycojesus
Mèo Lười
Posté le 07-01-2021 à 14:02:03  profilanswer
Wed Jan  6 22:59:38 UTC 2021
a/kernel-generic-5.10.5-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.10.5-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.10.5-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.10.5-x86-1.txz:  Upgraded.
d/meson-0.56.1-x86_64-1.txz:  Upgraded.
k/kernel-source-5.10.5-noarch-1.txz:  Upgraded.
  We'll turn off the silent stream feature as there's a known deadlock bug that
  remains in 5.10.5. Perhaps we'll restore it once that's patched... but we
  made it this far without the feature so I'll probably wait for a case to be
  made for it. Thanks to Petri Kaukasoina.
  Also build the intelfb module. This doesn't have anything to do with the
  lockups occurring on Intel systems, but we might as well provide the module.
  It remains blacklisted by default.
   FB_INTEL n -> m
   SND_HDA_INTEL_HDMI_SILENT_STREAM y -> n
  +FB_INTEL_DEBUG n
  +FB_INTEL_I2C y
l/imagemagick-7.0.10_56-x86_64-1.txz:  Upgraded.
x/ibus-table-1.12.3-x86_64-1.txz:  Upgraded.
xap/mozilla-firefox-78.6.1esr-x86_64-1.txz:  Upgraded.
  This release contains a security fix:
  A malicious peer could have modified a COOKIE-ECHO chunk in a SCTP packet
  in a way that potentially resulted in a use-after-free. We presume that with
  enough effort it could have been exploited to run arbitrary code.
    https://www.mozilla.org/en-US/firefox/78.6.1/releasenotes/
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-16044
  (* Security fix *)
n°1459185
cycojesus
Mèo Lười
Posté le 09-01-2021 à 13:01:38  profilanswer
KDagain
Fri Jan  8 19:43:46 UTC 2021
a/hwdata-0.343-noarch-1.txz:  Upgraded.
a/kernel-firmware-20210107_060ad8b-noarch-1.txz:  Upgraded.
a/logrotate-3.18.0-x86_64-1.txz:  Upgraded.
a/lvm2-2.03.11-x86_64-1.txz:  Upgraded.
a/mcelog-174-x86_64-1.txz:  Upgraded.
a/plzip-1.9-x86_64-1.txz:  Upgraded.
a/tar-1.33-x86_64-1.txz:  Upgraded.
ap/cups-filters-1.28.7-x86_64-1.txz:  Upgraded.
d/automake-1.16.2-noarch-1.txz:  Upgraded.
  It appears that automake-1.16.3 enforces -gnu at the end of the host string.
  I have no philosophical objection to this, but now's not the time. We'll
  revisit this in the next release cycle.
  Thanks to nobodino and chrisretusn.
d/guile-3.0.5-x86_64-1.txz:  Upgraded.
d/llvm-11.0.1-x86_64-1.txz:  Upgraded.
kde/akonadi-20.12.1-x86_64-1.txz:  Upgraded.
kde/akonadi-calendar-20.12.1-x86_64-1.txz:  Upgraded.
kde/akonadi-calendar-tools-20.12.1-x86_64-1.txz:  Upgraded.
kde/akonadi-contacts-20.12.1-x86_64-1.txz:  Upgraded.
kde/akonadi-import-wizard-20.12.1-x86_64-1.txz:  Upgraded.
kde/akonadi-mime-20.12.1-x86_64-1.txz:  Upgraded.
kde/akonadi-notes-20.12.1-x86_64-1.txz:  Upgraded.
kde/akonadi-search-20.12.1-x86_64-1.txz:  Upgraded.
kde/akonadiconsole-20.12.1-x86_64-1.txz:  Upgraded.
kde/akregator-20.12.1-x86_64-1.txz:  Upgraded.
kde/analitza-20.12.1-x86_64-1.txz:  Upgraded.
kde/ark-20.12.1-x86_64-1.txz:  Upgraded.
kde/artikulate-20.12.1-x86_64-1.txz:  Upgraded.
kde/audiocd-kio-20.12.1-x86_64-1.txz:  Upgraded.
kde/baloo-widgets-20.12.1-x86_64-1.txz:  Upgraded.
kde/blinken-20.12.1-x86_64-1.txz:  Upgraded.
kde/bomber-20.12.1-x86_64-1.txz:  Upgraded.
kde/bovo-20.12.1-x86_64-1.txz:  Upgraded.
kde/calendarsupport-20.12.1-x86_64-1.txz:  Upgraded.
kde/cantor-20.12.1-x86_64-1.txz:  Upgraded.
kde/cervisia-20.12.1-x86_64-1.txz:  Upgraded.
kde/dolphin-20.12.1-x86_64-1.txz:  Upgraded.
kde/dolphin-plugins-20.12.1-x86_64-1.txz:  Upgraded.
kde/dragon-20.12.1-x86_64-1.txz:  Upgraded.
kde/elisa-20.12.1-x86_64-1.txz:  Upgraded.
kde/eventviews-20.12.1-x86_64-1.txz:  Upgraded.
kde/ffmpegthumbs-20.12.1-x86_64-1.txz:  Upgraded.
kde/filelight-20.12.1-x86_64-1.txz:  Upgraded.
kde/granatier-20.12.1-x86_64-1.txz:  Upgraded.
kde/grantlee-editor-20.12.1-x86_64-1.txz:  Upgraded.
kde/grantleetheme-20.12.1-x86_64-1.txz:  Upgraded.
kde/gwenview-20.12.1-x86_64-1.txz:  Upgraded.
kde/incidenceeditor-20.12.1-x86_64-1.txz:  Upgraded.
kde/itinerary-20.12.1-x86_64-1.txz:  Upgraded.
kde/juk-20.12.1-x86_64-1.txz:  Upgraded.
kde/k3b-20.12.1-x86_64-1.txz:  Upgraded.
kde/kaddressbook-20.12.1-x86_64-1.txz:  Upgraded.
kde/kalarm-20.12.1-x86_64-1.txz:  Upgraded.
kde/kalarmcal-20.12.1-x86_64-1.txz:  Upgraded.
kde/kalgebra-20.12.1-x86_64-1.txz:  Upgraded.
kde/kalzium-20.12.1-x86_64-1.txz:  Upgraded.
kde/kamera-20.12.1-x86_64-1.txz:  Upgraded.
kde/kamoso-20.12.1-x86_64-1.txz:  Upgraded.
kde/kanagram-20.12.1-x86_64-1.txz:  Upgraded.
kde/kapman-20.12.1-x86_64-1.txz:  Upgraded.
kde/kapptemplate-20.12.1-x86_64-1.txz:  Upgraded.
kde/kate-20.12.1-x86_64-1.txz:  Upgraded.
kde/katomic-20.12.1-x86_64-1.txz:  Upgraded.
kde/kbackup-20.12.1-x86_64-1.txz:  Upgraded.
kde/kblackbox-20.12.1-x86_64-1.txz:  Upgraded.
kde/kblocks-20.12.1-x86_64-1.txz:  Upgraded.
kde/kbounce-20.12.1-x86_64-1.txz:  Upgraded.
kde/kbreakout-20.12.1-x86_64-1.txz:  Upgraded.
kde/kbruch-20.12.1-x86_64-1.txz:  Upgraded.
kde/kcachegrind-20.12.1-x86_64-1.txz:  Upgraded.
kde/kcalc-20.12.1-x86_64-1.txz:  Upgraded.
kde/kcalutils-20.12.1-x86_64-1.txz:  Upgraded.
kde/kcharselect-20.12.1-x86_64-1.txz:  Upgraded.
kde/kcolorchooser-20.12.1-x86_64-1.txz:  Upgraded.
kde/kcron-20.12.1-x86_64-1.txz:  Upgraded.
kde/kde-dev-scripts-20.12.1-x86_64-1.txz:  Upgraded.
kde/kde-dev-utils-20.12.1-x86_64-1.txz:  Upgraded.
kde/kdebugsettings-20.12.1-x86_64-1.txz:  Upgraded.
kde/kdeconnect-kde-20.12.1-x86_64-1.txz:  Upgraded.
kde/kdeedu-data-20.12.1-x86_64-1.txz:  Upgraded.
kde/kdegraphics-mobipocket-20.12.1-x86_64-1.txz:  Upgraded.
kde/kdegraphics-thumbnailers-20.12.1-x86_64-1.txz:  Upgraded.
kde/kdenetwork-filesharing-20.12.1-x86_64-1.txz:  Upgraded.
kde/kdenlive-20.12.1-x86_64-1.txz:  Upgraded.
kde/kdepim-addons-20.12.1-x86_64-1.txz:  Upgraded.
kde/kdepim-runtime-20.12.1-x86_64-1.txz:  Upgraded.
kde/kdesdk-kioslaves-20.12.1-x86_64-1.txz:  Upgraded.
kde/kdesdk-thumbnailers-20.12.1-x86_64-1.txz:  Upgraded.
kde/kdf-20.12.1-x86_64-1.txz:  Upgraded.
kde/kdialog-20.12.1-x86_64-1.txz:  Upgraded.
kde/kdiamond-20.12.1-x86_64-1.txz:  Upgraded.
kde/keditbookmarks-20.12.1-x86_64-1.txz:  Upgraded.
kde/kfind-20.12.1-x86_64-1.txz:  Upgraded.
kde/kfloppy-20.12.1-x86_64-1.txz:  Upgraded.
kde/kfourinline-20.12.1-x86_64-1.txz:  Upgraded.
kde/kgeography-20.12.1-x86_64-1.txz:  Upgraded.
kde/kget-20.12.1-x86_64-1.txz:  Upgraded.
kde/kgoldrunner-20.12.1-x86_64-1.txz:  Upgraded.
kde/kgpg-20.12.1-x86_64-1.txz:  Upgraded.
kde/khangman-20.12.1-x86_64-1.txz:  Upgraded.
kde/khelpcenter-20.12.1-x86_64-1.txz:  Upgraded.
kde/kidentitymanagement-20.12.1-x86_64-1.txz:  Upgraded.
kde/kig-20.12.1-x86_64-1.txz:  Upgraded.
kde/kigo-20.12.1-x86_64-1.txz:  Upgraded.
kde/killbots-20.12.1-x86_64-1.txz:  Upgraded.
kde/kimagemapeditor-20.12.1-x86_64-1.txz:  Upgraded.
kde/kimap-20.12.1-x86_64-1.txz:  Upgraded.
kde/kio-extras-20.12.1-x86_64-1.txz:  Upgraded.
kde/kio-gdrive-20.12.1-x86_64-1.txz:  Upgraded.
kde/kipi-plugins-20.12.1-x86_64-1.txz:  Upgraded.
kde/kirigami-gallery-20.12.1-x86_64-1.txz:  Upgraded.
kde/kiriki-20.12.1-x86_64-1.txz:  Upgraded.
kde/kiten-20.12.1-x86_64-1.txz:  Upgraded.
kde/kitinerary-20.12.1-x86_64-1.txz:  Upgraded.
kde/kjumpingcube-20.12.1-x86_64-1.txz:  Upgraded.
kde/kldap-20.12.1-x86_64-1.txz:  Upgraded.
kde/kleopatra-20.12.1-x86_64-1.txz:  Upgraded.
kde/klickety-20.12.1-x86_64-1.txz:  Upgraded.
kde/klines-20.12.1-x86_64-1.txz:  Upgraded.
kde/kmag-20.12.1-x86_64-1.txz:  Upgraded.
kde/kmahjongg-20.12.1-x86_64-1.txz:  Upgraded.
kde/kmail-20.12.1-x86_64-1.txz:  Upgraded.
kde/kmail-account-wizard-20.12.1-x86_64-1.txz:  Upgraded.
kde/kmailtransport-20.12.1-x86_64-1.txz:  Upgraded.
kde/kmbox-20.12.1-x86_64-1.txz:  Upgraded.
kde/kmime-20.12.1-x86_64-1.txz:  Upgraded.
kde/kmines-20.12.1-x86_64-1.txz:  Upgraded.
kde/kmix-20.12.1-x86_64-1.txz:  Upgraded.
kde/kmousetool-20.12.1-x86_64-1.txz:  Upgraded.
kde/kmouth-20.12.1-x86_64-1.txz:  Upgraded.
kde/kmplot-20.12.1-x86_64-1.txz:  Upgraded.
kde/knavalbattle-20.12.1-x86_64-1.txz:  Upgraded.
kde/knetwalk-20.12.1-x86_64-1.txz:  Upgraded.
kde/knights-20.12.1-x86_64-1.txz:  Upgraded.
kde/knotes-20.12.1-x86_64-1.txz:  Upgraded.
kde/kolf-20.12.1-x86_64-1.txz:  Upgraded.
kde/kollision-20.12.1-x86_64-1.txz:  Upgraded.
kde/kolourpaint-20.12.1-x86_64-1.txz:  Upgraded.
kde/kompare-20.12.1-x86_64-1.txz:  Upgraded.
kde/konqueror-20.12.1-x86_64-1.txz:  Upgraded.
kde/konquest-20.12.1-x86_64-1.txz:  Upgraded.
kde/konsole-20.12.1-x86_64-1.txz:  Upgraded.
kde/kontact-20.12.1-x86_64-1.txz:  Upgraded.
kde/kontactinterface-20.12.1-x86_64-1.txz:  Upgraded.
kde/kontrast-20.12.1-x86_64-1.txz:  Upgraded.
kde/konversation-20.12.1-x86_64-1.txz:  Upgraded.
kde/kopete-20.12.1-x86_64-1.txz:  Upgraded.
kde/korganizer-20.12.1-x86_64-1.txz:  Upgraded.
kde/kosmindoormap-20.12.1-x86_64-1.txz:  Upgraded.
kde/kpat-20.12.1-x86_64-1.txz:  Upgraded.
kde/kpimtextedit-20.12.1-x86_64-1.txz:  Upgraded.
kde/kpkpass-20.12.1-x86_64-1.txz:  Upgraded.
kde/kpmcore-20.12.1-x86_64-1.txz:  Upgraded.
kde/kpublictransport-20.12.1-x86_64-1.txz:  Upgraded.
kde/kqtquickcharts-20.12.1-x86_64-1.txz:  Upgraded.
kde/krdc-20.12.1-x86_64-1.txz:  Upgraded.
kde/kreversi-20.12.1-x86_64-1.txz:  Upgraded.
kde/krfb-20.12.1-x86_64-1.txz:  Upgraded.
kde/kross-interpreters-20.12.1-x86_64-1.txz:  Upgraded.
kde/kruler-20.12.1-x86_64-1.txz:  Upgraded.
kde/kshisen-20.12.1-x86_64-1.txz:  Upgraded.
kde/ksirk-20.12.1-x86_64-1.txz:  Upgraded.
kde/ksmtp-20.12.1-x86_64-1.txz:  Upgraded.
kde/ksnakeduel-20.12.1-x86_64-1.txz:  Upgraded.
kde/kspaceduel-20.12.1-x86_64-1.txz:  Upgraded.
kde/ksquares-20.12.1-x86_64-1.txz:  Upgraded.
kde/kstars-3.5.1-x86_64-1.txz:  Upgraded.
kde/ksudoku-20.12.1-x86_64-1.txz:  Upgraded.
kde/ksystemlog-20.12.1-x86_64-1.txz:  Upgraded.
kde/kteatime-20.12.1-x86_64-1.txz:  Upgraded.
kde/ktimer-20.12.1-x86_64-1.txz:  Upgraded.
kde/ktnef-20.12.1-x86_64-1.txz:  Upgraded.
kde/ktorrent-20.12.1-x86_64-1.txz:  Upgraded.
kde/ktouch-20.12.1-x86_64-1.txz:  Upgraded.
kde/kturtle-20.12.1-x86_64-1.txz:  Upgraded.
kde/kubrick-20.12.1-x86_64-1.txz:  Upgraded.
kde/kwalletmanager-20.12.1-x86_64-1.txz:  Upgraded.
kde/kwave-20.12.1-x86_64-1.txz:  Upgraded.
kde/kwordquiz-20.12.1-x86_64-1.txz:  Upgraded.
kde/libgravatar-20.12.1-x86_64-1.txz:  Upgraded.
kde/libkcddb-20.12.1-x86_64-1.txz:  Upgraded.
kde/libkcompactdisc-20.12.1-x86_64-1.txz:  Upgraded.
kde/libkdcraw-20.12.1-x86_64-1.txz:  Upgraded.
kde/libkdegames-20.12.1-x86_64-1.txz:  Upgraded.
kde/libkdepim-20.12.1-x86_64-1.txz:  Upgraded.
kde/libkeduvocdocument-20.12.1-x86_64-1.txz:  Upgraded.
kde/libkexiv2-20.12.1-x86_64-1.txz:  Upgraded.
kde/libkgapi-20.12.1-x86_64-1.txz:  Upgraded.
kde/libkipi-20.12.1-x86_64-1.txz:  Upgraded.
kde/libkleo-20.12.1-x86_64-1.txz:  Upgraded.
kde/libkmahjongg-20.12.1-x86_64-1.txz:  Upgraded.
kde/libkomparediff2-20.12.1-x86_64-1.txz:  Upgraded.
kde/libksane-20.12.1-x86_64-1.txz:  Upgraded.
kde/libksieve-20.12.1-x86_64-1.txz:  Upgraded.
kde/libktorrent-20.12.1-x86_64-1.txz:  Upgraded.
kde/lokalize-20.12.1-x86_64-1.txz:  Upgraded.
kde/lskat-20.12.1-x86_64-1.txz:  Upgraded.
kde/mailcommon-20.12.1-x86_64-1.txz:  Upgraded.
kde/mailimporter-20.12.1-x86_64-1.txz:  Upgraded.
kde/marble-20.12.1-x86_64-1.txz:  Upgraded.
kde/markdownpart-20.12.1-x86_64-1.txz:  Upgraded.
kde/mbox-importer-20.12.1-x86_64-1.txz:  Upgraded.
kde/messagelib-20.12.1-x86_64-1.txz:  Upgraded.
kde/minuet-20.12.1-x86_64-1.txz:  Upgraded.
kde/okular-20.12.1-x86_64-1.txz:  Upgraded.
kde/palapeli-20.12.1-x86_64-1.txz:  Upgraded.
kde/parley-20.12.1-x86_64-1.txz:  Upgraded.
kde/partitionmanager-20.12.1-x86_64-1.txz:  Upgraded.
kde/picmi-20.12.1-x86_64-1.txz:  Upgraded.
kde/pim-data-exporter-20.12.1-x86_64-1.txz:  Upgraded.
kde/pim-sieve-editor-20.12.1-x86_64-1.txz:  Upgraded.
kde/pimcommon-20.12.1-x86_64-1.txz:  Upgraded.
kde/poxml-20.12.1-x86_64-1.txz:  Upgraded.
kde/print-manager-20.12.1-x86_64-1.txz:  Upgraded.
kde/rocs-20.12.1-x86_64-1.txz:  Upgraded.
kde/spectacle-20.12.1-x86_64-1.txz:  Upgraded.
kde/step-20.12.1-x86_64-1.txz:  Upgraded.
kde/svgpart-20.12.1-x86_64-1.txz:  Upgraded.
kde/sweeper-20.12.1-x86_64-1.txz:  Upgraded.
kde/umbrello-20.12.1-x86_64-1.txz:  Upgraded.
kde/yakuake-20.12.1-x86_64-1.txz:  Upgraded.
kde/zeroconf-ioslave-20.12.1-x86_64-1.txz:  Upgraded.
l/mozjs78-78.6.1esr-x86_64-1.txz:  Upgraded.
xfce/xfce4-screensaver-4.16.0-x86_64-1.txz:  Upgraded.
n°1459216
cycojesus
Mèo Lười
Posté le 10-01-2021 à 08:16:52  profilanswer
Sat Jan  9 20:53:30 UTC 2021
a/aaa_elflibs-15.0-x86_64-29.txz:  Rebuilt.
  Upgraded: libcap.so.2.46, libkeyutils.so.1.10, libglib-2.0.so.0.6600.4,
  libgmodule-2.0.so.0.6600.4, libgobject-2.0.so.0.6600.4,
  libgthread-2.0.so.0.6600.4, libtiff.so.5.6.0, libtiffxx.so.5.6.0,
  libusb-1.0.so.0.3.0.
  Added: libzstd.so.1.4.8.
a/kernel-firmware-20210109_d528862-noarch-1.txz:  Upgraded.
a/kernel-generic-5.10.6-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.10.6-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.10.6-x86_64-1.txz:  Upgraded.
a/kmod-28-x86_64-1.txz:  Upgraded.
  Built using --with-zstd to support zstd compressed modules. This means that
  this package depends on libzstd or it will not function.
a/mcelog-175-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.10.6-x86-1.txz:  Upgraded.
k/kernel-source-5.10.6-noarch-1.txz:  Upgraded.
  Looks like the patch landed, so we'll give this another try.
  SND_HDA_INTEL_HDMI_SILENT_STREAM n -> y
kde/attica-5.78.0-x86_64-1.txz:  Upgraded.
kde/baloo-5.78.0-x86_64-1.txz:  Upgraded.
kde/bluez-qt-5.78.0-x86_64-1.txz:  Upgraded.
kde/breeze-icons-5.78.0-noarch-1.txz:  Upgraded.
kde/extra-cmake-modules-5.78.0-x86_64-1.txz:  Upgraded.
kde/frameworkintegration-5.78.0-x86_64-1.txz:  Upgraded.
kde/kactivities-5.78.0-x86_64-1.txz:  Upgraded.
kde/kactivities-stats-5.78.0-x86_64-1.txz:  Upgraded.
kde/kapidox-5.78.0-x86_64-1.txz:  Upgraded.
kde/karchive-5.78.0-x86_64-1.txz:  Upgraded.
kde/kauth-5.78.0-x86_64-1.txz:  Upgraded.
kde/kbookmarks-5.78.0-x86_64-1.txz:  Upgraded.
kde/kcalendarcore-5.78.0-x86_64-1.txz:  Upgraded.
kde/kcmutils-5.78.0-x86_64-1.txz:  Upgraded.
kde/kcodecs-5.78.0-x86_64-1.txz:  Upgraded.
kde/kcompletion-5.78.0-x86_64-1.txz:  Upgraded.
kde/kconfig-5.78.0-x86_64-1.txz:  Upgraded.
kde/kconfigwidgets-5.78.0-x86_64-1.txz:  Upgraded.
kde/kcontacts-5.78.0-x86_64-1.txz:  Upgraded.
kde/kcoreaddons-5.78.0-x86_64-1.txz:  Upgraded.
kde/kcrash-5.78.0-x86_64-1.txz:  Upgraded.
kde/kdav-5.78.0-x86_64-1.txz:  Upgraded.
kde/kdbusaddons-5.78.0-x86_64-1.txz:  Upgraded.
kde/kdeclarative-5.78.0-x86_64-1.txz:  Upgraded.
kde/kded-5.78.0-x86_64-1.txz:  Upgraded.
kde/kdelibs4support-5.78.0-x86_64-1.txz:  Upgraded.
kde/kdesignerplugin-5.78.0-x86_64-1.txz:  Upgraded.
kde/kdesu-5.78.0-x86_64-1.txz:  Upgraded.
kde/kdewebkit-5.78.0-x86_64-1.txz:  Upgraded.
kde/kdnssd-5.78.0-x86_64-1.txz:  Upgraded.
kde/kdoctools-5.78.0-x86_64-1.txz:  Upgraded.
kde/kemoticons-5.78.0-x86_64-1.txz:  Upgraded.
kde/kfilemetadata-5.78.0-x86_64-1.txz:  Upgraded.
kde/kglobalaccel-5.78.0-x86_64-1.txz:  Upgraded.
kde/kguiaddons-5.78.0-x86_64-1.txz:  Upgraded.
kde/kholidays-5.78.0-x86_64-1.txz:  Upgraded.
kde/khtml-5.78.0-x86_64-1.txz:  Upgraded.
kde/ki18n-5.78.0-x86_64-1.txz:  Upgraded.
kde/kiconthemes-5.78.0-x86_64-1.txz:  Upgraded.
kde/kidletime-5.78.0-x86_64-1.txz:  Upgraded.
kde/kimageformats-5.78.0-x86_64-1.txz:  Upgraded.
kde/kinit-5.78.0-x86_64-1.txz:  Upgraded.
kde/kio-5.78.0-x86_64-1.txz:  Upgraded.
kde/kirigami2-5.78.0-x86_64-1.txz:  Upgraded.
kde/kitemmodels-5.78.0-x86_64-1.txz:  Upgraded.
kde/kitemviews-5.78.0-x86_64-1.txz:  Upgraded.
kde/kjobwidgets-5.78.0-x86_64-1.txz:  Upgraded.
kde/kjs-5.78.0-x86_64-1.txz:  Upgraded.
kde/kjsembed-5.78.0-x86_64-1.txz:  Upgraded.
kde/kmediaplayer-5.78.0-x86_64-1.txz:  Upgraded.
kde/knewstuff-5.78.0-x86_64-1.txz:  Upgraded.
kde/knotifications-5.78.0-x86_64-1.txz:  Upgraded.
kde/knotifyconfig-5.78.0-x86_64-1.txz:  Upgraded.
kde/kpackage-5.78.0-x86_64-1.txz:  Upgraded.
kde/kparts-5.78.0-x86_64-1.txz:  Upgraded.
kde/kpeople-5.78.0-x86_64-1.txz:  Upgraded.
kde/kplotting-5.78.0-x86_64-1.txz:  Upgraded.
kde/kpty-5.78.0-x86_64-1.txz:  Upgraded.
kde/kquickcharts-5.78.0-x86_64-1.txz:  Upgraded.
kde/kross-5.78.0-x86_64-1.txz:  Upgraded.
kde/krunner-5.78.0-x86_64-1.txz:  Upgraded.
kde/kservice-5.78.0-x86_64-1.txz:  Upgraded.
kde/ktexteditor-5.78.0-x86_64-1.txz:  Upgraded.
kde/ktextwidgets-5.78.0-x86_64-1.txz:  Upgraded.
kde/kunitconversion-5.78.0-x86_64-1.txz:  Upgraded.
kde/kwallet-5.78.0-x86_64-1.txz:  Upgraded.
kde/kwayland-5.78.0-x86_64-1.txz:  Upgraded.
kde/kwidgetsaddons-5.78.0-x86_64-1.txz:  Upgraded.
kde/kwindowsystem-5.78.0-x86_64-1.txz:  Upgraded.
kde/kxmlgui-5.78.0-x86_64-1.txz:  Upgraded.
kde/kxmlrpcclient-5.78.0-x86_64-1.txz:  Upgraded.
kde/modemmanager-qt-5.78.0-x86_64-1.txz:  Upgraded.
kde/networkmanager-qt-5.78.0-x86_64-1.txz:  Upgraded.
kde/oxygen-icons5-5.78.0-noarch-1.txz:  Upgraded.
kde/plasma-framework-5.78.0-x86_64-1.txz:  Upgraded.
kde/prison-5.78.0-x86_64-1.txz:  Upgraded.
kde/purpose-5.78.0-x86_64-1.txz:  Upgraded.
kde/qqc2-desktop-style-5.78.0-x86_64-1.txz:  Upgraded.
kde/solid-5.78.0-x86_64-1.txz:  Upgraded.
kde/sonnet-5.78.0-x86_64-1.txz:  Upgraded.
kde/syndication-5.78.0-x86_64-1.txz:  Upgraded.
kde/syntax-highlighting-5.78.0-x86_64-1.txz:  Upgraded.
kde/threadweaver-5.78.0-x86_64-1.txz:  Upgraded.
l/gvfs-1.46.2-x86_64-1.txz:  Upgraded.
l/libqalculate-3.16.1-x86_64-1.txz:  Upgraded.
l/system-config-printer-1.5.14-x86_64-1.txz:  Upgraded.
n/gpgme-1.15.1-x86_64-1.txz:  Upgraded.
n/wget-1.21.1-x86_64-1.txz:  Upgraded.
n°1459250
cycojesus
Mèo Lười
Posté le 10-01-2021 à 20:54:15  profilanswer
Sun Jan 10 19:35:56 UTC 2021
a/findutils-4.8.0-x86_64-1.txz:  Upgraded.
a/lzip-1.22-x86_64-1.txz:  Upgraded.
ap/vim-8.2.2323-x86_64-1.txz:  Upgraded.
d/meson-0.56.2-x86_64-1.txz:  Upgraded.
d/python-setuptools-51.1.2-x86_64-1.txz:  Upgraded.
l/cryptopp-8.2.0-x86_64-1.txz:  Upgraded.
  In the ChangeLog for cryfs: * Updated to crypto++ 8.2
  Seems cryfs does not work with newer versions of cryptopp, so since nothing
  else uses it in Slackware we'll pin it at this version until cryfs notes
  that it's OK to move forward.
  Thanks to alienBOB and USUARIONUEVO for the bug report.
l/gjs-1.66.2-x86_64-1.txz:  Upgraded.
l/imagemagick-7.0.10_57-x86_64-1.txz:  Upgraded.
l/python-sane-2.9.1-x86_64-1.txz:  Upgraded.
n/libqmi-1.26.8-x86_64-1.txz:  Upgraded.
xap/vim-gvim-8.2.2323-x86_64-1.txz:  Upgraded.
n°1459335
cycojesus
Mèo Lười
Posté le 12-01-2021 à 11:22:02  profilanswer
Mon Jan 11 19:51:04 UTC 2021
a/ed-1.17-x86_64-1.txz:  Upgraded.
ap/htop-3.0.5-x86_64-1.txz:  Upgraded.
ap/ispell-3.4.02-x86_64-1.txz:  Upgraded.
ap/sudo-1.9.5-x86_64-1.txz:  Upgraded.
  This update fixes security issues:
  Potential information leak in sudoedit that could be used to test for
  the existence of directories not normally accessible to the user.
  Flaw in the temporary file handling of sudoedit's SELinux RBAC support.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-23239
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-23240
  (* Security fix *)
d/vala-0.50.3-x86_64-1.txz:  Upgraded.
n°1459391
cycojesus
Mèo Lười
Posté le 13-01-2021 à 09:30:25  profilanswer
Tue Jan 12 22:20:40 UTC 2021
a/kernel-generic-5.10.7-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.10.7-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.10.7-x86_64-1.txz:  Upgraded.
a/libblockdev-2.25-x86_64-1.txz:  Upgraded.
ap/sudo-1.9.5p1-x86_64-1.txz:  Upgraded.
  Fixed a regression introduced in sudo 1.9.5 where the editor run by sudoedit
  was set-user-ID root unless SELinux RBAC was in use. The editor is now run
  with the user's real and effective user-IDs.
d/autoconf-2.69-noarch-2.txz:  Rebuilt.
  We're seeing failures using autoconf-2.70 with some packages that use
  autoreconf. It looks like most distributions have not moved on to
  autoconf-2.70, and probably we shouldn't either until the next release cycle.
  Thanks to nobodino.
d/kernel-headers-5.10.7-x86-1.txz:  Upgraded.
e/emacs-27.1-x86_64-2.txz:  Rebuilt.
  Increase SYSTEM_PURESIZE_EXTRA to 100000 to avoid overflows. Nobody should be
  too concerned about adding 97K to emacs' memory footprint given the amount of
  memory available on modern machines. Thanks to Jefferson for the bug report.
k/kernel-source-5.10.7-noarch-1.txz:  Upgraded.
l/libclc-11.0.1-x86_64-1.txz:  Upgraded.
  Thanks to USUARIONUEVO.
l/python-pygments-2.7.4-x86_64-1.txz:  Upgraded.
n/gnupg2-2.2.27-x86_64-1.txz:  Upgraded.
n/socat-1.7.4.1-x86_64-1.txz:  Upgraded.
x/libdrm-2.4.104-x86_64-1.txz:  Upgraded.
x/libevdev-1.10.1-x86_64-1.txz:  Upgraded.
x/vulkan-sdk-1.2.141.0-x86_64-2.txz:  Rebuilt.
  Install additional Vulkan-ValidationLayers-sdk header files.
  Thanks to walecha.
xap/mozilla-thunderbird-78.6.1-x86_64-1.txz:  Upgraded.
  This release contains security fixes and improvements.
    https://www.mozilla.org/en-US/thunderbird/78.6.1/releasenotes/
    https://www.mozilla.org/en-US/security/advisories/mfsa2021-02/
  (* Security fix *)
n°1459472
cycojesus
Mèo Lười
Posté le 14-01-2021 à 09:52:36  profilanswer
:hello: Flash
Wed Jan 13 19:51:45 UTC 2021
ap/diffstat-1.64-x86_64-1.txz:  Upgraded.
d/cmake-3.19.3-x86_64-1.txz:  Upgraded.
l/gcr-3.38.1-x86_64-1.txz:  Upgraded.
l/mlt-6.24.0-x86_64-2.txz:  Rebuilt.
  Patched for opencv >= 4.5.1. Thanks to nobodino.
l/pulseaudio-14.1-x86_64-1.txz:  Upgraded.
n/netkit-bootparamd-0.17-x86_64-4.txz:  Rebuilt.
  Patched for libtirpc. Thanks to nobodino.
n/netkit-rusers-0.17-x86_64-3.txz:  Rebuilt.
n/netkit-rwall-0.17-x86_64-3.txz:  Rebuilt.
xfce/Greybird-3.22.14-noarch-1.txz:  Upgraded.
extra/source/flashplayer-plugin/:  Removed.
 Page :   1  2  3  4  5  ..  97  98  99  ..  109  110  111  112  113  114
Slackware 9.0[slackware] Suppression de terminaux virtuels ?
!! Configuration reseaux, slackware 9 !!Installer slackware 9.0 par ftp (boot disquette)
[Pb] Installation new HDD sous slackware 8.0[RESOLU] Pb d'execution mysql sur slackware ...
Slackware 9 du pur bonheurMonter une partition NTFS sous linux (slackware 9.0)
Slackware 9.0 Finale OUTJe sens que je vais quitter Slackware (pas en serv)
Plus de sujets relatifs à : [SLACKWARE] du présent - 15.0
