9723 connectés
La 15.0 est là (en vrai !)
Les invités peuvent voter
 Page :   1  2  3  4  5  ..  76  77  78  ..  109  110  111  112  113  114
[SLACKWARE] du présent - 15.0
n°1417091
cycojesus
Mèo Lười
Posté le 10-04-2018 à 07:09:33  profilanswer
Mon Apr  9 23:03:06 UTC 2018
l/gobject-introspection-1.56.1-x86_64-1.txz:  Upgraded.
l/gvfs-1.36.1-x86_64-1.txz:  Upgraded.
l/libsoup-2.62.1-x86_64-1.txz:  Upgraded.
n/wireless-tools-29-x86_64-10.txz:  Removed.
n/wireless_tools-29-x86_64-11.txz:  Rebuilt.
  Renamed package to match upstream tarball name.
x/libinput-1.10.4-x86_64-1.txz:  Upgraded.
Chết rồi ! ✍ ⌥⌘ http://codeberg.org/gwh
n°1417157
cycojesus
Mèo Lười
Posté le 11-04-2018 à 07:07:44  profilanswer
Tue Apr 10 23:38:57 UTC 2018
a/procps-ng-3.3.14-x86_64-1.txz:  Upgraded.
ap/htop-2.2.0-x86_64-1.txz:  Upgraded.
l/vte-0.52.1-x86_64-1.txz:  Upgraded.
n/gnupg2-2.2.6-x86_64-1.txz:  Upgraded.
x/xf86-input-libinput-0.27.1-x86_64-1.txz:  Upgraded.
n°1417221
cycojesus
Mèo Lười
Posté le 12-04-2018 à 07:08:10  profilanswer
Wed Apr 11 20:38:06 UTC 2018
a/lbzip2-2.5-x86_64-1.txz:  Added.
a/pkgtools-15.0-noarch-7.txz:  Rebuilt.
  explodepkg: support parallel bzip2 (lbzip2). Thanks to ruario.
  installpkg: support parallel bzip2 (lbzip2). Thanks to ruario.
  makepkg: support parallel bzip2 (lbzip2). Thanks to ruario.
  pkgdiff: added tool to compare the file contents of two packages.
ap/sqlite-3.23.1-x86_64-1.txz:  Upgraded.
l/libzip-1.5.1-x86_64-1.txz:  Upgraded.
l/mozilla-nss-3.36.1-x86_64-1.txz:  Upgraded.
n/libgpg-error-1.29-x86_64-1.txz:  Upgraded.
n°1417255
cycojesus
Mèo Lười
Posté le 13-04-2018 à 07:22:28  profilanswer
Thu Apr 12 23:00:51 UTC 2018
a/aaa_base-14.2-x86_64-3.txz:  Rebuilt.
  If the system is running -current, append a "+" to /etc/slackware-version.
  Identify the system as stable or current in /etc/os-release by setting
  VERSION_CODENAME to either stable or current. In PRETTY_NAME, really
  spell it out, e.g: PRETTY_NAME="Slackware 14.2 (pre-15.0 -current)"
a/kernel-generic-4.14.34-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.14.34-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.14.34-x86_64-1.txz:  Upgraded.
d/kernel-headers-4.14.34-x86-1.txz:  Upgraded.
k/kernel-source-4.14.34-noarch-1.txz:  Upgraded.
   SND_HDA_INPUT_BEEP n -> y
  +SND_HDA_INPUT_BEEP_MODE 0
  Thanks to GazL.
l/cairo-1.15.12-x86_64-1.txz:  Upgraded.
isolinux/initrd.img:  Rebuilt.
kernels/*:  Upgraded.
usb-and-pxe-installers/usbboot.img:  Rebuilt.
n°1417547
cycojesus
Mèo Lười
Posté le 19-04-2018 à 07:19:27  profilanswer
Pat sait que c'est la grève de la radio et que tu t'ennuies. Alors
Thu Apr 19 01:04:06 UTC 2018
Hi folks, and welcome to the third ever Slackware Mass Rebuild (and the
longest ChangeLog entry in project history). There were two primary
motivations for rebuilding everything in the main tree. The first was to
switch to the new C++ ABI. The second was to get rid of all the .la files
in the LD_LIBRARY_PATH. Really, having .la files installed has been mostly
obsolete since things began to use pkg-config instead, but it's not easy
to get rid of them unless you do it all at once. If you just take them out
of one package, any other packages containing .la files that refer to the
removed ones will be broken. We've removed a few here and there before
(and then handled any packages that had referred to them with a rebuild),
but it was time to finally remove all the ones in /lib{,64} and
/usr/lib{,64}. One of the reasons that this really needed to happen is that
many projects are starting to migrate to build systems other than autotools,
and those systems do not generate .la files. So if we didn't get rid of them
now, we might end up in a situation later on where they are being removed
by upstream and then we would have to chase down the dependency breakage and
recompile (possibly many) other pacakges. The .la files that are outside of
the LD_LIBRARY_PATH were not removed (and shouldn't be) - those ones are
often used by the lt_dlopen() function to load plugins and removing those
ones can break things. But those ones don't cause problems... they aren't
likely to try to infect .la files produced by other packages.
IMPORTANT NOTE: If you have any third party or other packages installed on
your system that don't come with Slackware, and those packages have installed
any .la files, it is very likely that they refer to some .la files which we
have just removed, and that trying to compile against these packages will no
longer work. Luckily, the solution is simple: remove them. This command will
remove any stale .la files from the LD_LIBRARY_PATH:
rm /{,usr/}lib{,64}/*.la
Moving forward, nothing shipped in Slackware will contain any .la files in
those directories, and any SlackBuilds intended to be used with Slackware 15.0
should contain this bit of script:
# Don't ship .la files:
rm -f $PKG/{,usr/}lib${LIBDIRSUFFIX}/*.la
In addition to those goals, the opportunity was taken to clean up slack-desc
files and make many trivial fixes to build scripts. We've also made it easy
to recompile everything again should there be a good reason to do so.
You'll also find various updates scattered throughout this long list.
Enjoy, and sorry about the bandwidth. ;-)
a/aaa_base-14.2-x86_64-4.txz:  Rebuilt.
  In /etc/os-release, change PRETTY_NAME to:
  PRETTY_NAME="Slackware 14.2 $ARCH (post 14.2 -current)"
a/aaa_elflibs-14.2-x86_64-35.txz:  Rebuilt.
  Removed obsolete libraries: libudev.so.0.13.1, libgdbm.so.3.0.0,
  libhistory.so.5.2, libjpeg.so.8.0.1, libmpfr.so.4.1.6, libpng14.so.14.18.0,
  libreadline.so.5.2, libstdc++.so.5.0.7, libtiff.so.3.9.7,
  and libtiffxx.so.3.9.7.
  Don't create library symlinks in the install script - let installpkg's
  ldconfig do the work.
a/aaa_terminfo-6.1_20180324-x86_64-4.txz:  Rebuilt.
  Changed xterm definition as noted for the ncurses package below.
a/acl-2.2.52-x86_64-2.txz:  Rebuilt.
a/acpid-2.0.29-x86_64-1.txz:  Upgraded.
a/attr-2.4.47-x86_64-2.txz:  Rebuilt.
a/bash-4.4.019-x86_64-3.txz:  Rebuilt.
a/bin-11.1-x86_64-2.txz:  Rebuilt.
a/btrfs-progs-v4.16-x86_64-2.txz:  Rebuilt.
a/bzip2-1.0.6-x86_64-2.txz:  Rebuilt.
a/coreutils-8.29-x86_64-2.txz:  Rebuilt.
a/cpio-2.12-x86_64-2.txz:  Rebuilt.
a/cpufrequtils-008-x86_64-2.txz:  Rebuilt.
a/cryptsetup-1.7.5-x86_64-2.txz:  Rebuilt.
a/dbus-1.12.6-x86_64-2.txz:  Rebuilt.
a/dcron-4.5-x86_64-6.txz:  Rebuilt.
a/dialog-1.3_20170509-x86_64-2.txz:  Rebuilt.
a/dosfstools-4.1-x86_64-2.txz:  Rebuilt.
a/e2fsprogs-1.44.1-x86_64-2.txz:  Rebuilt.
a/ed-1.14.2-x86_64-2.txz:  Rebuilt.
a/efibootmgr-0.5.4-x86_64-2.txz:  Rebuilt.
a/elilo-3.16-x86_64-6.txz:  Rebuilt.
a/elvis-2.2_0-x86_64-4.txz:  Rebuilt.
a/etc-15.0-x86_64-4.txz:  Rebuilt.
a/eudev-3.2.5-x86_64-2.txz:  Rebuilt.
a/file-5.33-x86_64-1.txz:  Upgraded.
a/findutils-4.4.2-x86_64-2.txz:  Rebuilt.
a/floppy-5.5-x86_64-2.txz:  Rebuilt.
a/gawk-4.2.1-x86_64-2.txz:  Rebuilt.
a/genpower-1.0.5-x86_64-3.txz:  Rebuilt.
a/gettext-0.19.8.1-x86_64-5.txz:  Rebuilt.
a/getty-ps-2.1.0b-x86_64-4.txz:  Rebuilt.
a/glibc-solibs-2.27-x86_64-2.txz:  Rebuilt.
a/glibc-zoneinfo-2018d-noarch-2.txz:  Rebuilt.
a/gpm-1.20.7-x86_64-6.txz:  Rebuilt.
a/gptfdisk-1.0.3-x86_64-2.txz:  Rebuilt.
a/grep-3.1-x86_64-2.txz:  Rebuilt.
a/grub-2.02-x86_64-2.txz:  Rebuilt.
a/gzip-1.9-x86_64-2.txz:  Rebuilt.
a/hdparm-9.56-x86_64-2.txz:  Rebuilt.
a/hostname-3.18-x86_64-2.txz:  Rebuilt.
a/hwdata-0.304-noarch-2.txz:  Rebuilt.
a/infozip-6.0-x86_64-4.txz:  Rebuilt.
a/inotify-tools-3.14-x86_64-2.txz:  Rebuilt.
a/jfsutils-1.1.15-x86_64-2.txz:  Rebuilt.
a/kbd-1.15.3-x86_64-4.txz:  Rebuilt.
a/kernel-firmware-20180409_b562d2f-noarch-1.txz:  Upgraded.
a/kmod-25-x86_64-2.txz:  Rebuilt.
a/lbzip2-2.5-x86_64-2.txz:  Rebuilt.
a/less-530-x86_64-3.txz:  Rebuilt.
a/lha-114i-x86_64-2.txz:  Rebuilt.
a/libcgroup-0.41-x86_64-3.txz:  Rebuilt.
a/libgudev-232-x86_64-2.txz:  Rebuilt.
a/lilo-24.2-x86_64-8.txz:  Rebuilt.
a/logrotate-3.14.0-x86_64-2.txz:  Rebuilt.
a/lrzip-0.631-x86_64-2.txz:  Rebuilt.
a/lvm2-2.02.176-x86_64-2.txz:  Rebuilt.
a/lzip-1.20-x86_64-3.txz:  Rebuilt.
a/lzlib-1.10-x86_64-3.txz:  Rebuilt.
a/mcelog-153-x86_64-2.txz:  Rebuilt.
a/mdadm-4.0-x86_64-2.txz:  Rebuilt.
a/minicom-2.7.1-x86_64-2.txz:  Rebuilt.
a/mkinitrd-1.4.11-x86_64-6.txz:  Rebuilt.
  Improved and documented UUID support. Thanks to Xsane.
  Upgraded to busybox-1.28.3.
a/mlocate-0.26-x86_64-2.txz:  Rebuilt.
a/mt-st-1.3-x86_64-2.txz:  Rebuilt.
a/mtx-1.3.12-x86_64-2.txz:  Rebuilt.
a/ncompress-4.2.4.4-x86_64-2.txz:  Rebuilt.
a/ntfs-3g-2017.3.23-x86_64-2.txz:  Rebuilt.
a/openssl-solibs-1.0.2o-x86_64-2.txz:  Rebuilt.
a/os-prober-1.76-x86_64-2.txz:  Rebuilt.
a/patch-2.7.6-x86_64-3.txz:  Rebuilt.
a/pciutils-3.5.6-x86_64-2.txz:  Rebuilt.
a/pcmciautils-018-x86_64-2.txz:  Rebuilt.
a/pkgtools-15.0-noarch-8.txz:  Rebuilt.
  installpkg: avoid messing with the system /install directory.
  removepkg: also run ldconfig following package removal.
a/plzip-1.7-x86_64-3.txz:  Rebuilt.
a/procps-ng-3.3.14-x86_64-2.txz:  Rebuilt.
a/quota-4.03-x86_64-2.txz:  Rebuilt.
a/reiserfsprogs-3.6.27-x86_64-2.txz:  Rebuilt.
a/rpm2tgz-1.2.2-x86_64-2.txz:  Rebuilt.
a/sdparm-1.10-x86_64-2.txz:  Rebuilt.
a/sed-4.5-x86_64-2.txz:  Rebuilt.
a/shadow-4.2.1-x86_64-4.txz:  Rebuilt.
a/sharutils-4.15.2-x86_64-2.txz:  Rebuilt.
a/smartmontools-6.6-x86_64-3.txz:  Rebuilt.
a/splitvt-1.6.6-x86_64-2.txz:  Rebuilt.
a/sysfsutils-2.1.0-x86_64-2.txz:  Rebuilt.
a/sysklogd-1.5.1-x86_64-3.txz:  Rebuilt.
a/syslinux-4.07-x86_64-2.txz:  Rebuilt.
a/sysvinit-2.88dsf-x86_64-5.txz:  Rebuilt.
a/sysvinit-functions-8.53-x86_64-3.txz:  Rebuilt.
a/sysvinit-scripts-2.1-noarch-9.txz:  Rebuilt.
a/tar-1.30-x86_64-2.txz:  Rebuilt.
a/tcsh-6.20.00-x86_64-2.txz:  Rebuilt.
a/time-1.9-x86_64-2.txz:  Rebuilt.
a/tree-1.7.0-x86_64-2.txz:  Rebuilt.
a/udisks-1.0.5-x86_64-4.txz:  Rebuilt.
a/udisks2-2.6.5-x86_64-2.txz:  Rebuilt.
a/unarj-265-x86_64-2.txz:  Rebuilt.
a/upower-0.9.23-x86_64-4.txz:  Rebuilt.
a/usb_modeswitch-2.5.1-x86_64-2.txz:  Rebuilt.
a/usbutils-009-x86_64-2.txz:  Rebuilt.
a/utempter-1.1.6-x86_64-3.txz:  Rebuilt.
a/util-linux-2.32-x86_64-2.txz:  Rebuilt.
a/which-2.21-x86_64-2.txz:  Rebuilt.
a/xfsprogs-4.15.1-x86_64-2.txz:  Rebuilt.
a/xz-5.2.3-x86_64-2.txz:  Rebuilt.
a/zoo-2.10_22-x86_64-2.txz:  Rebuilt.
ap/a2ps-4.14-x86_64-7.txz:  Rebuilt.
ap/acct-6.6.4-x86_64-2.txz:  Rebuilt.
ap/alsa-utils-1.1.6-x86_64-2.txz:  Rebuilt.
ap/amp-0.7.6-x86_64-2.txz:  Rebuilt.
ap/at-3.1.20-x86_64-2.txz:  Rebuilt.
ap/bc-1.07.1-x86_64-2.txz:  Rebuilt.
ap/bpe-2.01.00-x86_64-4.txz:  Rebuilt.
ap/cdparanoia-III_10.2-x86_64-2.txz:  Rebuilt.
ap/cdrdao-1.2.3-x86_64-4.txz:  Rebuilt.
ap/cdrtools-3.01-x86_64-4.txz:  Rebuilt.
ap/cgmanager-0.41-x86_64-4.txz:  Rebuilt.
ap/cups-2.2.7-x86_64-2.txz:  Rebuilt.
ap/cups-filters-1.20.3-x86_64-1.txz:  Upgraded.
  Recompiled against poppler-0.64.0.
ap/dash-0.5.9.1-x86_64-2.txz:  Rebuilt.
ap/dc3dd-7.2.646-x86_64-2.txz:  Rebuilt.
ap/ddrescue-1.23-x86_64-2.txz:  Rebuilt.
ap/diffstat-1.61-x86_64-2.txz:  Rebuilt.
ap/diffutils-3.6-x86_64-2.txz:  Rebuilt.
ap/dmapi-2.2.12-x86_64-3.txz:  Rebuilt.
ap/dmidecode-3.1-x86_64-2.txz:  Rebuilt.
ap/dvd+rw-tools-7.1-x86_64-3.txz:  Rebuilt.
ap/enscript-1.6.6-x86_64-2.txz:  Rebuilt.
ap/flac-1.3.2-x86_64-2.txz:  Rebuilt.
ap/ghostscript-9.23-x86_64-2.txz:  Rebuilt.
ap/ghostscript-fonts-std-8.11-noarch-2.txz:  Rebuilt.
ap/gphoto2-2.5.17-x86_64-1.txz:  Upgraded.
ap/groff-1.22.3-x86_64-3.txz:  Rebuilt.
ap/gutenprint-5.2.13-x86_64-2.txz:  Rebuilt.
ap/hplip-3.18.3-x86_64-2.txz:  Rebuilt.
ap/htop-2.2.0-x86_64-2.txz:  Rebuilt.
ap/ispell-3.4.00-x86_64-2.txz:  Rebuilt.
ap/itstool-2.0.4-x86_64-3.txz:  Rebuilt.
ap/jed-0.99_19-x86_64-3.txz:  Rebuilt.
ap/joe-4.6-x86_64-2.txz:  Rebuilt.
ap/jove-4.16.0.73-x86_64-4.txz:  Rebuilt.
ap/ksh93-20180412_71e6fdad-x86_64-1.txz:  Upgraded.
ap/libx86-1.1-x86_64-3.txz:  Rebuilt.
ap/linuxdoc-tools-0.9.72-x86_64-5.txz:  Rebuilt.
ap/lm_sensors-3.4.0-x86_64-2.txz:  Rebuilt.
ap/lsof-4.91-x86_64-2.txz:  Rebuilt.
ap/lsscsi-0.28-x86_64-2.txz:  Rebuilt.
ap/lxc-2.0.9-x86_64-2.txz:  Rebuilt.
ap/madplay-0.15.2b-x86_64-5.txz:  Rebuilt.
ap/man-db-2.8.3-x86_64-2.txz:  Rebuilt.
ap/man-pages-4.15-noarch-2.txz:  Rebuilt.
ap/mariadb-10.2.14-x86_64-2.txz:  Rebuilt.
ap/mc-4.8.20-x86_64-2.txz:  Rebuilt.
ap/moc-2.5.2-x86_64-4.txz:  Rebuilt.
ap/most-5.0.0a-x86_64-3.txz:  Rebuilt.
ap/mpg123-1.25.10-x86_64-2.txz:  Rebuilt.
ap/nano-2.9.5-x86_64-2.txz:  Rebuilt.
ap/normalize-0.7.7-x86_64-3.txz:  Rebuilt.
ap/opus-tools-0.1.10-x86_64-2.txz:  Rebuilt.
ap/pamixer-1.3.1-x86_64-6.txz:  Rebuilt.
  Recompiled against boost-1.67.0.
ap/pm-utils-1.4.1-x86_64-6.txz:  Rebuilt.
ap/powertop-2.8-x86_64-3.txz:  Rebuilt.
ap/qpdf-8.0.2-x86_64-2.txz:  Rebuilt.
ap/radeontool-1.6.3-x86_64-2.txz:  Rebuilt.
ap/rpm-4.14.1-x86_64-2.txz:  Rebuilt.
ap/rzip-2.1-x86_64-2.txz:  Rebuilt.
ap/sc-7.16-x86_64-6.txz:  Rebuilt.
ap/screen-4.6.2-x86_64-2.txz:  Rebuilt.
ap/seejpeg-1.10-x86_64-2.txz:  Rebuilt.
ap/slackpkg-2.82.2-noarch-2.txz:  Rebuilt.
ap/soma-2.12.3-noarch-2.txz:  Rebuilt.
ap/sox-14.4.2-x86_64-5.txz:  Rebuilt.
ap/sqlite-3.23.1-x86_64-2.txz:  Rebuilt.
ap/squashfs-tools-4.3-x86_64-3.txz:  Rebuilt.
ap/sudo-1.8.22-x86_64-2.txz:  Rebuilt.
ap/sysstat-11.6.3-x86_64-2.txz:  Rebuilt.
ap/terminus-font-4.40-noarch-2.txz:  Rebuilt.
ap/texinfo-6.5-x86_64-3.txz:  Rebuilt.
  Recompiled against perl-5.26.2.
ap/tmux-2.7-x86_64-1.txz:  Upgraded.
ap/usbmuxd-1.1.0-x86_64-2.txz:  Rebuilt.
ap/vbetool-1.2.2-x86_64-2.txz:  Rebuilt.
ap/vim-8.0.1733-x86_64-1.txz:  Upgraded.
ap/vorbis-tools-1.4.0-x86_64-4.txz:  Rebuilt.
ap/xfsdump-3.1.8-x86_64-2.txz:  Rebuilt.
ap/xorriso-1.4.8-x86_64-2.txz:  Rebuilt.
ap/zsh-5.5.1-x86_64-1.txz:  Upgraded.
d/Cython-0.28.1-x86_64-2.txz:  Rebuilt.
d/autoconf-2.69-noarch-2.txz:  Rebuilt.
d/automake-1.16.1-noarch-2.txz:  Rebuilt.
d/binutils-2.30-x86_64-2.txz:  Rebuilt.
d/bison-3.0.4-x86_64-2.txz:  Rebuilt.
d/ccache-3.4.2-x86_64-2.txz:  Rebuilt.
d/clisp-2.49.20180409.0e4d38776f59-x86_64-1.txz:  Upgraded.
d/cmake-3.11.1-x86_64-1.txz:  Upgraded.
d/cscope-15.8b-x86_64-3.txz:  Rebuilt.
d/cvs-1.11.23-x86_64-3.txz:  Rebuilt.
d/dev86-0.16.21-x86_64-2.txz:  Rebuilt.
d/distcc-3.3-x86_64-2.txz:  Rebuilt.
d/doxygen-1.8.14-x86_64-2.txz:  Rebuilt.
d/flex-2.6.4-x86_64-3.txz:  Rebuilt.
d/gcc-7.3.0-x86_64-2.txz:  Rebuilt.
d/gcc-brig-7.3.0-x86_64-2.txz:  Rebuilt.
d/gcc-g++-7.3.0-x86_64-2.txz:  Rebuilt.
d/gcc-gfortran-7.3.0-x86_64-2.txz:  Rebuilt.
d/gcc-gnat-7.3.0-x86_64-2.txz:  Rebuilt.
d/gcc-go-7.3.0-x86_64-2.txz:  Rebuilt.
d/gcc-objc-7.3.0-x86_64-2.txz:  Rebuilt.
d/gdb-8.1-x86_64-2.txz:  Rebuilt.
d/gettext-tools-0.19.8.1-x86_64-5.txz:  Rebuilt.
d/git-2.17.0-x86_64-2.txz:  Rebuilt.
d/gnucobol-2.2-x86_64-2.txz:  Rebuilt.
d/gperf-3.1-x86_64-2.txz:  Rebuilt.
d/guile-2.2.3-x86_64-2.txz:  Rebuilt.
d/help2man-1.47.6-x86_64-2.txz:  Rebuilt.
d/indent-2.2.10-x86_64-2.txz:  Rebuilt.
d/intltool-0.51.0-x86_64-4.txz:  Rebuilt.
d/libtool-2.4.6-x86_64-7.txz:  Rebuilt.
d/llvm-6.0.0-x86_64-2.txz:  Rebuilt.
d/m4-1.4.18-x86_64-2.txz:  Rebuilt.
d/make-4.2.1-x86_64-3.txz:  Rebuilt.
d/mercurial-4.5.3-x86_64-2.txz:  Rebuilt.
d/meson-0.45.1-x86_64-2.txz:  Rebuilt.
d/nasm-2.13.03-x86_64-2.txz:  Rebuilt.
d/ninja-1.8.2-x86_64-2.txz:  Rebuilt.
d/opencl-headers-2.1-noarch-2.txz:  Rebuilt.
d/oprofile-1.2.0-x86_64-3.txz:  Rebuilt.
d/p2c-1.21alpha2-x86_64-4.txz:  Rebuilt.
d/patchelf-0.9-x86_64-2.txz:  Rebuilt.
d/perl-5.26.2-x86_64-1.txz:  Upgraded.
  Upgraded to DBD-mysql-4.046, DBI-1.641, and XML-Simple-2.25.
d/pkg-config-0.29.2-x86_64-2.txz:  Rebuilt.
d/pmake-1.111-x86_64-5.txz:  Rebuilt.
d/python-2.7.14-x86_64-2.txz:  Rebuilt.
d/python-pip-9.0.3-x86_64-2.txz:  Rebuilt.
d/python-setuptools-39.0.1-x86_64-2.txz:  Rebuilt.
d/python3-3.6.5-x86_64-2.txz:  Rebuilt.
d/rcs-5.9.4-x86_64-2.txz:  Rebuilt.
d/re2c-1.0.3-x86_64-2.txz:  Rebuilt.
d/ruby-2.5.1-x86_64-2.txz:  Rebuilt.
d/rust-1.25.0-x86_64-2.txz:  Rebuilt.
d/scons-3.0.1-x86_64-2.txz:  Rebuilt.
d/slacktrack-2.18-x86_64-2.txz:  Rebuilt.
d/strace-4.22-x86_64-2.txz:  Rebuilt.
d/subversion-1.10.0-x86_64-1.txz:  Upgraded.
d/swig-3.0.12-x86_64-2.txz:  Rebuilt.
d/yasm-1.3.0-x86_64-2.txz:  Rebuilt.
e/emacs-25.3-x86_64-2.txz:  Rebuilt.
kde/amarok-2.9.0-x86_64-2.txz:  Rebuilt.
kde/amor-4.14.3-x86_64-3.txz:  Rebuilt.
kde/analitza-4.14.3-x86_64-4.txz:  Rebuilt.
kde/ark-4.14.3-x86_64-3.txz:  Rebuilt.
kde/artikulate-4.14.3-x86_64-3.txz:  Rebuilt.
kde/audiocd-kio-4.14.3-x86_64-3.txz:  Rebuilt.
kde/baloo-4.14.3-x86_64-4.txz:  Rebuilt.
kde/baloo-widgets-4.14.3-x86_64-3.txz:  Rebuilt.
kde/blinken-4.14.3-x86_64-3.txz:  Rebuilt.
kde/bluedevil-2.1.1-x86_64-4.txz:  Rebuilt.
kde/bomber-4.14.3-x86_64-3.txz:  Rebuilt.
kde/bovo-4.14.3-x86_64-3.txz:  Rebuilt.
kde/calligra-2.9.11-x86_64-20.txz:  Rebuilt.
  Recompiled against boost-1.67.0 and poppler-0.64.0.
kde/cantor-4.14.3-x86_64-3.txz:  Rebuilt.
kde/cervisia-4.14.3-x86_64-3.txz:  Rebuilt.
kde/dolphin-plugins-4.14.3-x86_64-3.txz:  Rebuilt.
kde/dragon-4.14.3-x86_64-3.txz:  Rebuilt.
kde/filelight-4.14.3-x86_64-3.txz:  Rebuilt.
kde/granatier-4.14.3-x86_64-3.txz:  Rebuilt.
kde/gwenview-4.14.3-x86_64-4.txz:  Rebuilt.
kde/juk-4.14.3-x86_64-3.txz:  Rebuilt.
kde/k3b-2.0.3-x86_64-4.txz:  Rebuilt.
kde/kaccessible-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kactivities-4.13.3-x86_64-3.txz:  Rebuilt.
kde/kajongg-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kalgebra-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kalzium-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kamera-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kanagram-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kapman-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kapptemplate-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kate-4.14.3-x86_64-4.txz:  Rebuilt.
kde/katomic-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kaudiocreator-1.3-x86_64-3.txz:  Rebuilt.
kde/kblackbox-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kblocks-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kbounce-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kbreakout-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kbruch-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kcachegrind-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kcalc-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kcharselect-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kcolorchooser-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kcron-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kde-base-artwork-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kde-baseapps-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kde-dev-scripts-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kde-dev-utils-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kde-runtime-4.14.3-x86_64-6.txz:  Rebuilt.
kde/kde-wallpapers-4.14.3-noarch-2.txz:  Rebuilt.
kde/kde-workspace-4.11.22-x86_64-5.txz:  Rebuilt.
kde/kdeartwork-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kdeconnect-kde-0.8-x86_64-4.txz:  Rebuilt.
kde/kdegraphics-mobipocket-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kdegraphics-strigi-analyzer-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kdegraphics-thumbnailers-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kdelibs-4.14.38-x86_64-2.txz:  Rebuilt.
kde/kdenetwork-filesharing-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kdenetwork-strigi-analyzers-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kdepim-4.14.10-x86_64-3.txz:  Rebuilt.
kde/kdepim-runtime-4.14.10-x86_64-2.txz:  Rebuilt.
kde/kdepimlibs-4.14.10-x86_64-5.txz:  Rebuilt.
kde/kdeplasma-addons-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kdesdk-kioslaves-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kdesdk-strigi-analyzers-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kdesdk-thumbnailers-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kdev-python-1.7.3-x86_64-3.txz:  Rebuilt.
kde/kdevelop-4.7.4-x86_64-2.txz:  Rebuilt.
kde/kdevelop-pg-qt-1.0.0-x86_64-3.txz:  Rebuilt.
kde/kdevelop-php-1.7.4-x86_64-2.txz:  Rebuilt.
kde/kdevelop-php-docs-1.7.4-x86_64-2.txz:  Rebuilt.
kde/kdevplatform-1.7.4-x86_64-2.txz:  Rebuilt.
kde/kdewebdev-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kdf-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kdiamond-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kfilemetadata-4.14.3-x86_64-4.txz:  Rebuilt.
kde/kfloppy-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kfourinline-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kgamma-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kgeography-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kget-4.14.3-x86_64-4.txz:  Rebuilt.
kde/kgoldrunner-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kgpg-4.14.3-x86_64-3.txz:  Rebuilt.
kde/khangman-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kig-4.14.3-x86_64-8.txz:  Rebuilt.
kde/kigo-4.14.3-x86_64-3.txz:  Rebuilt.
kde/killbots-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kio-mtp-2063e75_20131020git-x86_64-4.txz:  Rebuilt.
kde/kiriki-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kiten-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kjumpingcube-4.14.3-x86_64-3.txz:  Rebuilt.
kde/klettres-4.14.3-x86_64-3.txz:  Rebuilt.
kde/klickety-4.14.3-x86_64-3.txz:  Rebuilt.
kde/klines-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kmag-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kmahjongg-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kmines-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kmix-4.14.3-x86_64-4.txz:  Rebuilt.
kde/kmousetool-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kmouth-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kmplot-4.14.3-x86_64-3.txz:  Rebuilt.
kde/knavalbattle-4.14.3-x86_64-3.txz:  Rebuilt.
kde/knetwalk-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kolf-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kollision-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kolourpaint-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kompare-4.14.3-x86_64-3.txz:  Rebuilt.
kde/konquest-4.14.3-x86_64-3.txz:  Rebuilt.
kde/konsole-4.14.3-x86_64-5.txz:  Rebuilt.
  Reverted TERM change, so by default TERM=xterm again.
kde/kopete-4.14.3-x86_64-5.txz:  Rebuilt.
kde/korundum-4.14.3-x86_64-6.txz:  Rebuilt.
kde/kpat-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kplayer-0.7.2-x86_64-3.txz:  Rebuilt.
kde/kppp-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kqtquickcharts-4.14.3-x86_64-3.txz:  Rebuilt.
kde/krdc-4.14.3-x86_64-4.txz:  Rebuilt.
kde/kremotecontrol-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kreversi-4.14.3-x86_64-3.txz:  Rebuilt.
kde/krfb-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kross-interpreters-4.14.3-x86_64-4.txz:  Rebuilt.
kde/kruler-4.14.3-x86_64-3.txz:  Rebuilt.
kde/ksaneplugin-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kscreen-1.0.2.1-x86_64-3.txz:  Rebuilt.
kde/kshisen-4.14.3-x86_64-3.txz:  Rebuilt.
kde/ksirk-4.14.3-x86_64-3.txz:  Rebuilt.
kde/ksnakeduel-4.14.3-x86_64-3.txz:  Rebuilt.
kde/ksnapshot-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kspaceduel-4.14.3-x86_64-3.txz:  Rebuilt.
kde/ksquares-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kstars-4.14.3-x86_64-3.txz:  Rebuilt.
kde/ksudoku-4.14.3-x86_64-3.txz:  Rebuilt.
kde/ksystemlog-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kteatime-4.14.3-x86_64-3.txz:  Rebuilt.
kde/ktimer-4.14.3-x86_64-3.txz:  Rebuilt.
kde/ktorrent-4.3.1-x86_64-3.txz:  Rebuilt.
kde/ktouch-4.14.3-x86_64-4.txz:  Rebuilt.
kde/ktuberling-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kturtle-4.14.3-x86_64-3.txz:  Rebuilt.
kde/ktux-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kubrick-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kuser-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kwalletmanager-4.14.3-x86_64-3.txz:  Rebuilt.
kde/kwebkitpart-1.3.4-x86_64-3.txz:  Rebuilt.
kde/kwordquiz-4.14.3-x86_64-3.txz:  Rebuilt.
kde/libkcddb-4.14.3-x86_64-3.txz:  Rebuilt.
kde/libkcompactdisc-4.14.3-x86_64-3.txz:  Rebuilt.
kde/libkdcraw-4.14.3-x86_64-5.txz:  Rebuilt.
kde/libkdeedu-4.14.3-x86_64-3.txz:  Rebuilt.
kde/libkdegames-4.14.3-x86_64-3.txz:  Rebuilt.
kde/libkexiv2-4.14.3-x86_64-4.txz:  Rebuilt.
kde/libkipi-4.14.3-x86_64-3.txz:  Rebuilt.
kde/libkmahjongg-4.14.3-x86_64-3.txz:  Rebuilt.
kde/libkomparediff2-4.14.3-x86_64-3.txz:  Rebuilt.
kde/libksane-4.14.3-x86_64-3.txz:  Rebuilt.
kde/libkscreen-1.0.5-x86_64-3.txz:  Rebuilt.
kde/libktorrent-1.3.1-x86_64-4.txz:  Rebuilt.
kde/libmm-qt-1.0.1-x86_64-3.txz:  Rebuilt.
kde/libnm-qt-0.9.8.3-x86_64-3.txz:  Rebuilt.
kde/lokalize-4.14.3-x86_64-4.txz:  Rebuilt.
kde/lskat-4.14.3-x86_64-4.txz:  Rebuilt.
kde/marble-4.14.3-x86_64-3.txz:  Rebuilt.
kde/mplayerthumbs-4.14.3-x86_64-3.txz:  Rebuilt.
kde/nepomuk-core-4.14.3-x86_64-4.txz:  Rebuilt.
kde/nepomuk-widgets-4.14.3-x86_64-3.txz:  Rebuilt.
kde/okteta-4.14.3-x86_64-3.txz:  Rebuilt.
kde/okular-4.14.3-x86_64-3.txz:  Rebuilt.
kde/oxygen-gtk2-1.4.6-x86_64-3.txz:  Rebuilt.
kde/oxygen-icons-4.14.3-x86_64-3.txz:  Rebuilt.
kde/pairs-4.14.3-x86_64-3.txz:  Rebuilt.
kde/palapeli-4.14.3-x86_64-3.txz:  Rebuilt.
kde/parley-4.14.3-x86_64-3.txz:  Rebuilt.
kde/partitionmanager-1.1.1-x86_64-3.txz:  Rebuilt.
kde/perlkde-4.14.3-x86_64-5.txz:  Rebuilt.
kde/perlqt-4.14.3-x86_64-6.txz:  Rebuilt.
kde/picmi-4.14.3-x86_64-3.txz:  Rebuilt.
kde/plasma-nm-0.9.3.6-x86_64-2.txz:  Rebuilt.
kde/polkit-kde-agent-1-9d74ae3_20120104git-x86_64-3.txz:  Rebuilt.
kde/polkit-kde-kcmodules-1-001bdf7_20120111git-x86_64-3.txz:  Rebuilt.
kde/poxml-4.14.3-x86_64-3.txz:  Rebuilt.
kde/print-manager-4.14.3-x86_64-3.txz:  Rebuilt.
kde/pykde4-4.14.3-x86_64-7.txz:  Rebuilt.
kde/qtruby-4.14.3-x86_64-8.txz:  Rebuilt.
kde/rocs-4.14.3-x86_64-3.txz:  Rebuilt.
kde/skanlite-1.1-x86_64-3.txz:  Rebuilt.
kde/smokegen-4.14.3-x86_64-3.txz:  Rebuilt.
kde/smokekde-4.14.3-x86_64-3.txz:  Rebuilt.
kde/smokeqt-4.14.3-x86_64-5.txz:  Rebuilt.
kde/step-4.14.3-x86_64-6.txz:  Rebuilt.
kde/superkaramba-4.14.3-x86_64-4.txz:  Rebuilt.
kde/svgpart-4.14.3-x86_64-3.txz:  Rebuilt.
kde/sweeper-4.14.3-x86_64-3.txz:  Rebuilt.
kde/umbrello-4.14.3-x86_64-3.txz:  Rebuilt.
kde/wicd-kde-0.3.0_bcf27d8-x86_64-3.txz:  Rebuilt.
kde/zeroconf-ioslave-4.14.3-x86_64-3.txz:  Rebuilt.
l/ConsoleKit2-1.0.0-x86_64-4.txz:  Rebuilt.
l/GConf-3.2.6-x86_64-4.txz:  Rebuilt.
l/LibRaw-0.18.8-x86_64-2.txz:  Rebuilt.
l/M2Crypto-0.27.0-x86_64-3.txz:  Rebuilt.
l/Mako-1.0.7-x86_64-2.txz:  Rebuilt.
l/PyQt-4.12.1-x86_64-2.txz:  Rebuilt.
l/QScintilla-2.10.2-x86_64-2.txz:  Rebuilt.
l/SDL2-2.0.8-x86_64-2.txz:  Rebuilt.
l/SDL2_gfx-1.0.3-x86_64-2.txz:  Rebuilt.
l/SDL2_image-2.0.3-x86_64-2.txz:  Rebuilt.
l/SDL2_mixer-2.0.2-x86_64-3.txz:  Rebuilt.
l/SDL2_net-2.0.1-x86_64-2.txz:  Rebuilt.
l/SDL2_ttf-2.0.14-x86_64-2.txz:  Rebuilt.
l/a52dec-0.7.4-x86_64-3.txz:  Rebuilt.
l/aalib-1.4rc5-x86_64-6.txz:  Rebuilt.
l/adwaita-icon-theme-3.28.0-noarch-2.txz:  Rebuilt.
l/akonadi-1.13.0-x86_64-9.txz:  Rebuilt.
l/alsa-lib-1.1.6-x86_64-3.txz:  Rebuilt.
l/alsa-oss-1.1.6-x86_64-2.txz:  Rebuilt.
l/alsa-plugins-1.1.6-x86_64-2.txz:  Rebuilt.
l/apr-1.6.3-x86_64-2.txz:  Rebuilt.
l/apr-util-1.6.1-x86_64-6.txz:  Rebuilt.
l/aspell-0.60.6.1-x86_64-3.txz:  Rebuilt.
l/aspell-en-2018.04.16_0-x86_64-1.txz:  Upgraded.
l/at-spi2-atk-2.26.2-x86_64-2.txz:  Rebuilt.
l/at-spi2-core-2.28.0-x86_64-2.txz:  Rebuilt.
l/atk-2.28.1-x86_64-2.txz:  Rebuilt.
l/atkmm-2.24.2-x86_64-2.txz:  Rebuilt.
l/attica-0.4.2-x86_64-2.txz:  Rebuilt.
l/audiofile-0.3.6-x86_64-2.txz:  Rebuilt.
l/automoc4-0.9.88-x86_64-2.txz:  Rebuilt.
l/babl-0.1.46-x86_64-1.txz:  Upgraded.
l/boost-1.67.0-x86_64-1.txz:  Upgraded.
  Shared library .so-version bump.
l/cairo-1.15.12-x86_64-2.txz:  Rebuilt.
l/cairomm-1.12.2-x86_64-2.txz:  Rebuilt.
l/chmlib-0.40-x86_64-3.txz:  Rebuilt.
l/clucene-2.3.3.4-x86_64-3.txz:  Rebuilt.
l/db42-4.2.52-x86_64-4.txz:  Rebuilt.
l/db44-4.4.20-x86_64-4.txz:  Rebuilt.
l/db48-4.8.30-x86_64-3.txz:  Rebuilt.
l/dbus-glib-0.110-x86_64-2.txz:  Rebuilt.
l/dbus-python-1.2.6-x86_64-2.txz:  Rebuilt.
l/dconf-0.26.1-x86_64-2.txz:  Rebuilt.
l/dconf-editor-3.26.2-x86_64-2.txz:  Rebuilt.
l/desktop-file-utils-0.23-x86_64-2.txz:  Rebuilt.
l/djvulibre-3.5.27-x86_64-2.txz:  Rebuilt.
l/ebook-tools-0.2.2-x86_64-5.txz:  Rebuilt.
l/eigen2-2.0.17-x86_64-2.txz:  Rebuilt.
l/eigen3-3.2.10-x86_64-2.txz:  Rebuilt.
l/elfutils-0.170-x86_64-2.txz:  Rebuilt.
l/enchant-1.6.1-x86_64-2.txz:  Rebuilt.
l/esound-0.2.41-x86_64-3.txz:  Rebuilt.
l/exiv2-0.26-x86_64-3.txz:  Rebuilt.
l/expat-2.2.5-x86_64-2.txz:  Rebuilt.
l/ffmpeg-3.4.2-x86_64-2.txz:  Rebuilt.
l/fftw-3.3.7-x86_64-2.txz:  Rebuilt.
l/fluidsynth-1.1.10-x86_64-2.txz:  Rebuilt.
l/freetype-2.9-x86_64-2.txz:  Rebuilt.
l/fribidi-0.19.7-x86_64-2.txz:  Rebuilt.
l/fuse-2.9.7-x86_64-2.txz:  Rebuilt.
l/gamin-0.1.10-x86_64-6.txz:  Rebuilt.
l/gc-7.6.4-x86_64-2.txz:  Rebuilt.
l/gcr-3.28.0-x86_64-2.txz:  Rebuilt.
l/gd-2.2.5-x86_64-1.txz:  Upgraded.
  This update fixes two security issues:
  Double-free in gdImagePngPtr() (denial of service).
  Buffer over-read into uninitialized memory (information leak).
  For more information, see:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-6362
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-7890
  (* Security fix *)
l/gdbm-1.13-x86_64-2.txz:  Rebuilt.
l/gdk-pixbuf2-2.36.12-x86_64-2.txz:  Rebuilt.
l/gegl-0.2.0-x86_64-7.txz:  Rebuilt.
l/giflib-5.1.4-x86_64-2.txz:  Rebuilt.
l/glade3-3.8.6-x86_64-2.txz:  Rebuilt.
l/glib-1.2.10-x86_64-6.txz:  Rebuilt.
l/glib-networking-2.56.0-x86_64-2.txz:  Rebuilt.
l/glib2-2.56.1-x86_64-2.txz:  Rebuilt.
l/glibc-2.27-x86_64-2.txz:  Rebuilt.
  [PATCH] Linux: use reserved name __key in pkey_get [BZ #22797]
l/glibc-i18n-2.27-x86_64-2.txz:  Rebuilt.
l/glibc-profile-2.27-x86_64-2.txz:  Rebuilt.
l/glibmm-2.56.0-x86_64-1.txz:  Upgraded.
l/gmime-2.6.23-x86_64-3.txz:  Rebuilt.
l/gmm-4.3-noarch-2.txz:  Rebuilt.
l/gmp-6.1.2-x86_64-2.txz:  Rebuilt.
l/gnome-keyring-3.28.0.2-x86_64-2.txz:  Rebuilt.
l/gnome-themes-standard-3.22.3-x86_64-2.txz:  Rebuilt.
l/gnu-efi-3.0.6-x86_64-2.txz:  Rebuilt.
l/gobject-introspection-1.56.1-x86_64-2.txz:  Rebuilt.
l/grantlee-0.5.1-x86_64-2.txz:  Rebuilt.
l/gsettings-desktop-schemas-3.28.0-x86_64-2.txz:  Rebuilt.
l/gsl-2.4-x86_64-2.txz:  Rebuilt.
l/gst-plugins-base-1.14.0-x86_64-2.txz:  Rebuilt.
l/gst-plugins-base0-0.10.36-x86_64-3.txz:  Rebuilt.
l/gst-plugins-good-1.14.0-x86_64-2.txz:  Rebuilt.
l/gst-plugins-good0-0.10.31-x86_64-3.txz:  Rebuilt.
l/gst-plugins-libav-1.14.0-x86_64-2.txz:  Rebuilt.
l/gstreamer-1.14.0-x86_64-2.txz:  Rebuilt.
l/gstreamer0-0.10.36-x86_64-2.txz:  Rebuilt.
l/gtk+-1.2.10-x86_64-7.txz:  Rebuilt.
l/gtk+2-2.24.32-x86_64-2.txz:  Rebuilt.
l/gtk+3-3.22.30-x86_64-1.txz:  Upgraded.
l/gtkmm2-2.24.5-x86_64-2.txz:  Rebuilt.
l/gtkmm3-3.22.2-x86_64-2.txz:  Rebuilt.
l/gtkspell-2.0.16-x86_64-4.txz:  Rebuilt.
l/gvfs-1.36.1-x86_64-2.txz:  Rebuilt.
l/harfbuzz-1.7.6-x86_64-3.txz:  Rebuilt.
l/hicolor-icon-theme-0.17-noarch-2.txz:  Rebuilt.
l/hunspell-1.6.2-x86_64-2.txz:  Rebuilt.
l/icon-naming-utils-0.8.90-x86_64-3.txz:  Rebuilt.
l/icu4c-61.1-x86_64-2.txz:  Rebuilt.
l/id3lib-3.8.3-x86_64-2.txz:  Rebuilt.
l/ilmbase-2.2.0-x86_64-2.txz:  Rebuilt.
l/imagemagick-6.9.9_40-x86_64-2.txz:  Rebuilt.
  Don't use OpenCL. Thanks to EdGr.
l/iso-codes-3.76-noarch-2.txz:  Rebuilt.
l/jansson-2.11-x86_64-2.txz:  Rebuilt.
l/jasper-2.0.12-x86_64-2.txz:  Rebuilt.
l/jemalloc-4.5.0-x86_64-2.txz:  Rebuilt.
l/js185-1.0.0-x86_64-2.txz:  Rebuilt.
l/judy-1.0.5-x86_64-2.txz:  Rebuilt.
l/keybinder-0.3.1-x86_64-2.txz:  Rebuilt.
l/keyutils-1.5.10-x86_64-2.txz:  Rebuilt.
l/lame-3.100-x86_64-2.txz:  Rebuilt.
l/lcms-1.19-x86_64-4.txz:  Rebuilt.
l/lcms2-2.9-x86_64-2.txz:  Rebuilt.
l/libaio-0.3.110-x86_64-2.txz:  Rebuilt.
l/libao-1.2.2-x86_64-2.txz:  Rebuilt.
l/libarchive-3.3.2-x86_64-2.txz:  Rebuilt.
l/libart_lgpl-2.3.21-x86_64-2.txz:  Rebuilt.
l/libasyncns-0.8-x86_64-2.txz:  Rebuilt.
l/libatasmart-0.19-x86_64-3.txz:  Rebuilt.
l/libbluedevil-2.1-x86_64-2.txz:  Rebuilt.
l/libbluray-1.0.1-x86_64-2.txz:  Rebuilt.
l/libcaca-0.99.beta19-x86_64-3.txz:  Rebuilt.
l/libcanberra-0.30-x86_64-6.txz:  Rebuilt.
l/libcap-2.25-x86_64-2.txz:  Rebuilt.
l/libcap-ng-0.7.8-x86_64-3.txz:  Rebuilt.
l/libcddb-1.3.2-x86_64-5.txz:  Rebuilt.
l/libcdio-2.0.0-x86_64-2.txz:  Rebuilt.
l/libcdio-paranoia-10.2+0.94+2-x86_64-3.txz:  Rebuilt.
l/libclc-20180223_3554053-x86_64-2.txz:  Rebuilt.
l/libcroco-0.6.12-x86_64-2.txz:  Rebuilt.
l/libdbusmenu-qt-0.9.2-x86_64-3.txz:  Rebuilt.
l/libdiscid-0.6.2-x86_64-2.txz:  Rebuilt.
l/libdvdnav-6.0.0-x86_64-2.txz:  Rebuilt.
l/libdvdread-6.0.0-x86_64-3.txz:  Rebuilt.
l/libedit-20170329_3.1-x86_64-2.txz:  Rebuilt.
l/libevent-2.1.8-x86_64-2.txz:  Rebuilt.
l/libexif-0.6.21-x86_64-2.txz:  Rebuilt.
l/libfakekey-0.3-x86_64-2.txz:  Rebuilt.
l/libffi-3.2.1-x86_64-2.txz:  Rebuilt.
l/libglade-2.6.4-x86_64-6.txz:  Rebuilt.
l/libgnome-keyring-3.12.0-x86_64-2.txz:  Rebuilt.
l/libgphoto2-2.5.17-x86_64-1.txz:  Upgraded.
l/libgpod-0.8.3-x86_64-5.txz:  Rebuilt.
l/libgsf-1.14.42-x86_64-2.txz:  Rebuilt.
l/libical-3.0.1-x86_64-3.txz:  Rebuilt.
l/libid3tag-0.15.1b-x86_64-5.txz:  Rebuilt.
l/libidl-0.8.14-x86_64-2.txz:  Rebuilt.
l/libidn-1.34-x86_64-2.txz:  Rebuilt.
l/libidn2-2.0.4-x86_64-2.txz:  Rebuilt.
l/libieee1284-0.2.11-x86_64-4.txz:  Rebuilt.
l/libimobiledevice-1.2.0-x86_64-3.txz:  Rebuilt.
l/libiodbc-3.52.10-x86_64-3.txz:  Rebuilt.
l/libjpeg-turbo-1.5.3-x86_64-2.txz:  Rebuilt.
l/libkarma-0.1.1-x86_64-3.txz:  Rebuilt.
l/liblastfm-1.0.9-x86_64-2.txz:  Rebuilt.
l/libmad-0.15.1b-x86_64-4.txz:  Rebuilt.
l/libmcrypt-2.5.8-x86_64-2.txz:  Rebuilt.
l/libmng-2.0.3-x86_64-2.txz:  Rebuilt.
l/libmpc-1.1.0-x86_64-2.txz:  Rebuilt.
l/libmsn-4.2.1-x86_64-3.txz:  Rebuilt.
l/libmtp-1.1.15-x86_64-2.txz:  Rebuilt.
l/libnih-1.0.3-x86_64-3.txz:  Rebuilt.
l/libnjb-2.2.7-x86_64-2.txz:  Rebuilt.
l/libnl-1.1.4-x86_64-2.txz:  Rebuilt.
l/libnl3-3.4.0-x86_64-2.txz:  Rebuilt.
l/libnotify-0.7.7-x86_64-2.txz:  Rebuilt.
l/libodfgen-0.1.6-x86_64-2.txz:  Rebuilt.
l/libogg-1.3.3-x86_64-2.txz:  Rebuilt.
l/liboggz-1.1.1-x86_64-3.txz:  Rebuilt.
l/liboil-0.3.17-x86_64-2.txz:  Rebuilt.
l/libpcap-1.8.1-x86_64-2.txz:  Rebuilt.
l/libplist-2.0.0-x86_64-2.txz:  Rebuilt.
l/libpng-1.6.34-x86_64-2.txz:  Rebuilt.
l/libproxy-0.4.15-x86_64-2.txz:  Rebuilt.
l/libraw1394-2.1.2-x86_64-2.txz:  Rebuilt.
l/librevenge-0.0.4-x86_64-2.txz:  Rebuilt.
l/librsvg-2.42.3-x86_64-3.txz:  Rebuilt.
l/libsamplerate-0.1.9-x86_64-2.txz:  Rebuilt.
l/libsecret-0.18.6-x86_64-2.txz:  Rebuilt.
l/libsigc++-2.10.0-x86_64-2.txz:  Rebuilt.
l/libsigsegv-2.12-x86_64-2.txz:  Rebuilt.
l/libsndfile-1.0.28-x86_64-2.txz:  Rebuilt.
l/libsodium-1.0.16-x86_64-2.txz:  Rebuilt.
l/libsoup-2.62.1-x86_64-2.txz:  Rebuilt.
l/libspectre-0.2.8-x86_64-2.txz:  Rebuilt.
l/libssh-0.7.5-x86_64-2.txz:  Rebuilt.
l/libssh2-1.8.0-x86_64-2.txz:  Rebuilt.
l/libtasn1-4.13-x86_64-2.txz:  Rebuilt.
l/libtheora-1.1.1-x86_64-2.txz:  Rebuilt.
l/libtiff-4.0.9-x86_64-2.txz:  Rebuilt.
l/libunistring-0.9.9-x86_64-2.txz:  Rebuilt.
l/libunwind-1.2.1-x86_64-3.txz:  Rebuilt.
l/libusb-1.0.22-x86_64-2.txz:  Rebuilt.
l/libusb-compat-0.1.5-x86_64-3.txz:  Rebuilt.
l/libusbmuxd-1.0.10-x86_64-2.txz:  Rebuilt.
l/libvisio-0.1.6-x86_64-3.txz:  Rebuilt.
l/libvisual-0.4.0-x86_64-4.txz:  Rebuilt.
l/libvisual-plugins-0.4.0-x86_64-3.txz:  Rebuilt.
l/libvncserver-0.9.11-x86_64-3.txz:  Rebuilt.
l/libvorbis-1.3.6-x86_64-2.txz:  Rebuilt.
l/libvpx-1.7.0-x86_64-2.txz:  Rebuilt.
l/libwebp-0.6.1-x86_64-2.txz:  Rebuilt.
l/libwmf-0.2.8.4-x86_64-7.txz:  Rebuilt.
l/libwmf-docs-0.2.8.4-noarch-7.txz:  Rebuilt.
l/libwnck-2.31.0-x86_64-3.txz:  Rebuilt.
l/libwpd-0.10.1-x86_64-2.txz:  Rebuilt.
l/libwpg-0.3.1-x86_64-2.txz:  Rebuilt.
l/libxklavier-5.4-x86_64-2.txz:  Rebuilt.
l/libxml2-2.9.8-x86_64-2.txz:  Rebuilt.
l/libxslt-1.1.32-x86_64-2.txz:  Rebuilt.
l/libyaml-0.1.7-x86_64-2.txz:  Rebuilt.
l/libzip-1.5.1-x86_64-2.txz:  Rebuilt.
l/loudmouth-1.5.3-x86_64-2.txz:  Rebuilt.
l/lzo-2.10-x86_64-2.txz:  Rebuilt.
l/media-player-info-23-noarch-2.txz:  Rebuilt.
l/mhash-0.9.9.9-x86_64-4.txz:  Rebuilt.
l/mm-1.4.2-x86_64-3.txz:  Rebuilt.
l/mozilla-nss-3.36.1-x86_64-2.txz:  Rebuilt.
l/mpfr-4.0.1-x86_64-2.txz:  Rebuilt.
l/ncurses-6.1_20180324-x86_64-4.txz:  Rebuilt.
  Change the xterm entry in xterm.terminfo (way down at the bottom, where it
  says "customization begins here" and that we may need to change the xterm
  entry since it is used "for a variety of incompatible terminal emulations" )
  to drop the use of use=rep+ansi. In addition to causing Konsole breakage, I
  have verification that rep= was causing problems with terminals connecting
  from OSX. Only the xterm entry has changed. Previously this was an alias for
  xterm-new, which has not been altered. Feel free to use xterm-new instead if
  it suits your needs better.
l/neon-0.30.1-x86_64-3.txz:  Rebuilt.
l/netpbm-10.66.02-x86_64-5.txz:  Rebuilt.
l/newt-0.52.20-x86_64-3.txz:  Rebuilt.
l/ocl-icd-2.2.12-x86_64-2.txz:  Rebuilt.
l/openexr-2.2.0-x86_64-3.txz:  Rebuilt.
l/openjpeg-2.3.0-x86_64-2.txz:  Rebuilt.
l/opus-1.3_beta-x86_64-2.txz:  Rebuilt.
l/opusfile-0.9-x86_64-3.txz:  Rebuilt.
l/orc-0.4.28-x86_64-2.txz:  Rebuilt.
l/pango-1.42.1-x86_64-2.txz:  Rebuilt.
l/pangomm-2.40.1-x86_64-2.txz:  Rebuilt.
l/parted-3.2-x86_64-4.txz:  Rebuilt.
l/pcre-8.42-x86_64-2.txz:  Rebuilt.
l/pcre2-10.31-x86_64-2.txz:  Rebuilt.
l/phonon-4.8.3-x86_64-3.txz:  Rebuilt.
l/phonon-gstreamer-4.8.2-x86_64-2.txz:  Rebuilt.
l/pilot-link-0.12.5-x86_64-13.txz:  Rebuilt.
l/polkit-0.113-x86_64-4.txz:  Rebuilt.
l/polkit-gnome-0.105-x86_64-2.txz:  Rebuilt.
l/polkit-qt-1-0.112.0-x86_64-2.txz:  Rebuilt.
l/poppler-0.64.0-x86_64-1.txz:  Upgraded.
l/poppler-data-0.4.8-noarch-2.txz:  Rebuilt.
l/popt-1.16-x86_64-3.txz:  Rebuilt.
l/pulseaudio-11.1-x86_64-2.txz:  Rebuilt.
l/pycairo-1.16.3-x86_64-2.txz:  Rebuilt.
l/pycups-1.9.73-x86_64-4.txz:  Rebuilt.
l/pycurl-7.43.0.1-x86_64-2.txz:  Rebuilt.
l/pygobject-2.28.7-x86_64-2.txz:  Rebuilt.
l/pygobject3-3.28.2-x86_64-2.txz:  Rebuilt.
l/pygtk-2.24.0-x86_64-5.txz:  Rebuilt.
l/pyparsing-2.2.0-x86_64-2.txz:  Rebuilt.
l/python-appdirs-1.4.3-x86_64-2.txz:  Rebuilt.
l/python-certifi-2018.1.18-x86_64-2.txz:  Rebuilt.
l/python-chardet-3.0.4-x86_64-2.txz:  Rebuilt.
l/python-docutils-0.14-x86_64-2.txz:  Rebuilt.
l/python-idna-2.6-x86_64-2.txz:  Rebuilt.
l/python-notify2-0.3.1-x86_64-2.txz:  Rebuilt.
l/python-packaging-16.8-x86_64-2.txz:  Rebuilt.
l/python-pillow-5.1.0-x86_64-2.txz:  Rebuilt.
l/python-requests-2.18.4-x86_64-2.txz:  Rebuilt.
l/python-sane-2.8.3-x86_64-2.txz:  Rebuilt.
l/python-six-1.11.0-x86_64-2.txz:  Rebuilt.
l/python-urllib3-1.22-x86_64-2.txz:  Rebuilt.
l/qca-2.1.3-x86_64-2.txz:  Rebuilt.
l/qimageblitz-0.0.6-x86_64-2.txz:  Rebuilt.
l/qjson-0.8.1-x86_64-2.txz:  Rebuilt.
l/qt-4.8.7-x86_64-9.txz:  Rebuilt.
l/qt-gstreamer-1.2.0-x86_64-2.txz:  Rebuilt.
l/qtscriptgenerator-0.2.0-x86_64-3.txz:  Rebuilt.
l/raptor2-2.0.15-x86_64-5.txz:  Rebuilt.
l/rasqal-0.9.33-x86_64-3.txz:  Rebuilt.
l/readline-7.0.003-x86_64-2.txz:  Rebuilt.
l/redland-1.0.17-x86_64-4.txz:  Rebuilt.
l/sbc-1.3-x86_64-2.txz:  Rebuilt.
l/sdl-1.2.15-x86_64-7.txz:  Rebuilt.
l/seamonkey-solibs-2.49.2-x86_64-2.txz:  Rebuilt.
l/serf-1.3.9-x86_64-2.txz:  Rebuilt.
l/sg3_utils-1.42-x86_64-2.txz:  Rebuilt.
l/shared-desktop-ontologies-0.11.0-x86_64-2.txz:  Rebuilt.
l/shared-mime-info-1.9-x86_64-2.txz:  Rebuilt.
l/sip-4.19.8-x86_64-2.txz:  Rebuilt.
l/slang-2.3.2-x86_64-3.txz:  Rebuilt.
l/slang1-1.4.9-x86_64-2.txz:  Rebuilt.
l/soprano-2.9.4-x86_64-2.txz:  Rebuilt.
l/sound-theme-freedesktop-0.8-noarch-2.txz:  Rebuilt.
l/speex-1.2.0-x86_64-2.txz:  Rebuilt.
l/speexdsp-1.2rc3-x86_64-2.txz:  Rebuilt.
l/startup-notification-0.12-x86_64-3.txz:  Rebuilt.
l/strigi-0.7.8-x86_64-4.txz:  Rebuilt.
l/svgalib-1.9.25-x86_64-4.txz:  Rebuilt.
l/system-config-printer-1.5.11-x86_64-3.txz:  Rebuilt.
l/t1lib-5.1.2-x86_64-4.txz:  Rebuilt.
l/taglib-1.11.1-x86_64-3.txz:  Rebuilt.
l/taglib-extras-1.0.1-x86_64-2.txz:  Rebuilt.
l/talloc-2.1.13-x86_64-1.txz:  Upgraded.
l/tango-icon-theme-0.8.90-noarch-2.txz:  Rebuilt.
l/tango-icon-theme-extras-0.1.0-noarch-2.txz:  Rebuilt.
l/tdb-1.3.15-x86_64-2.txz:  Rebuilt.
l/tevent-0.9.36-x86_64-2.txz:  Rebuilt.
l/urwid-1.0.3-x86_64-3.txz:  Rebuilt.
l/utf8proc-2.1.0-x86_64-1.txz:  Added.
  This library is required by subversion-1.10.0.
l/v4l-utils-1.14.2-x86_64-2.txz:  Rebuilt.
l/virtuoso-ose-6.1.8-x86_64-8.txz:  Rebuilt.
l/vte-0.52.1-x86_64-2.txz:  Rebuilt.
l/wavpack-5.1.0-x86_64-2.txz:  Rebuilt.
l/xapian-core-1.4.5-x86_64-2.txz:  Rebuilt.
l/zlib-1.2.11-x86_64-2.txz:  Rebuilt.
n/ModemManager-1.6.12-x86_64-2.txz:  Rebuilt.
n/NetworkManager-1.10.6-x86_64-3.txz:  Rebuilt.
n/alpine-2.21-x86_64-2.txz:  Rebuilt.
n/autofs-5.1.4-x86_64-2.txz:  Rebuilt.
n/biff+comsat-0.17-x86_64-2.txz:  Rebuilt.
n/bind-9.11.3-x86_64-2.txz:  Rebuilt.
n/bluez-5.49-x86_64-3.txz:  Rebuilt.
n/bluez-firmware-1.2-x86_64-2.txz:  Rebuilt.
n/bootp-2.4.3-x86_64-3.txz:  Rebuilt.
n/bridge-utils-1.5-x86_64-2.txz:  Rebuilt.
n/bsd-finger-0.17-x86_64-3.txz:  Rebuilt.
n/ca-certificates-20170717-noarch-2.txz:  Rebuilt.
n/cifs-utils-6.7-x86_64-2.txz:  Rebuilt.
n/conntrack-tools-1.4.4-x86_64-2.txz:  Rebuilt.
n/crda-3.18-x86_64-6.txz:  Rebuilt.
n/curl-7.59.0-x86_64-3.txz:  Rebuilt.
n/cyrus-sasl-2.1.26-x86_64-4.txz:  Rebuilt.
n/dhcp-4.4.1-x86_64-2.txz:  Rebuilt.
n/dhcpcd-7.0.3-x86_64-2.txz:  Rebuilt.
n/dnsmasq-2.79-x86_64-2.txz:  Rebuilt.
n/dovecot-2.3.1-x86_64-3.txz:  Rebuilt.
  Recompiled using --with-lucene. Thanks to kj25vm.
n/ebtables-2.0.10-x86_64-2.txz:  Rebuilt.
n/elm-2.5.8-x86_64-5.txz:  Rebuilt.
n/epic5-2.0.1-x86_64-4.txz:  Rebuilt.
n/ethtool-4.16-x86_64-1.txz:  Upgraded.
n/fetchmail-6.3.26-x86_64-3.txz:  Rebuilt.
n/getmail-5.6-x86_64-2.txz:  Rebuilt.
n/gnupg-1.4.22-x86_64-2.txz:  Rebuilt.
n/gnupg2-2.2.6-x86_64-2.txz:  Rebuilt.
n/gnutls-3.6.2-x86_64-2.txz:  Rebuilt.
n/gpa-0.9.10-x86_64-2.txz:  Rebuilt.
n/gpgme-1.10.0-x86_64-2.txz:  Rebuilt.
n/htdig-3.2.0b6-x86_64-5.txz:  Rebuilt.
n/httpd-2.4.33-x86_64-3.txz:  Rebuilt.
n/icmpinfo-1.11-x86_64-3.txz:  Rebuilt.
n/iftop-1.0pre4-x86_64-2.txz:  Rebuilt.
n/inetd-1.79s-x86_64-11.txz:  Rebuilt.
n/iproute2-4.16.0-x86_64-2.txz:  Rebuilt.
n/ipset-6.38-x86_64-1.txz:  Upgraded.
n/iptables-1.6.2-x86_64-2.txz:  Rebuilt.
n/iptraf-ng-1.1.4-x86_64-3.txz:  Rebuilt.
n/iputils-s20140519-x86_64-2.txz:  Rebuilt.
n/irssi-1.1.1-x86_64-2.txz:  Rebuilt.
n/iw-4.14-x86_64-2.txz:  Rebuilt.
n/lftp-4.8.3-x86_64-2.txz:  Rebuilt.
n/libassuan-2.5.1-x86_64-2.txz:  Rebuilt.
n/libgcrypt-1.8.2-x86_64-2.txz:  Rebuilt.
n/libgpg-error-1.29-x86_64-2.txz:  Rebuilt.
n/libksba-1.3.5-x86_64-2.txz:  Rebuilt.
n/libmbim-1.16.0-x86_64-2.txz:  Rebuilt.
n/libmilter-8.15.2-x86_64-2.txz:  Rebuilt.
n/libmnl-1.0.4-x86_64-3.txz:  Rebuilt.
n/libndp-1.6-x86_64-2.txz:  Rebuilt.
n/libnetfilter_acct-1.0.3-x86_64-2.txz:  Rebuilt.
n/libnetfilter_conntrack-1.0.6-x86_64-2.txz:  Rebuilt.
n/libnetfilter_cthelper-1.0.0-x86_64-2.txz:  Rebuilt.
n/libnetfilter_cttimeout-1.0.0-x86_64-2.txz:  Rebuilt.
n/libnetfilter_log-1.0.1-x86_64-2.txz:  Rebuilt.
n/libnetfilter_queue-1.0.3-x86_64-2.txz:  Rebuilt.
n/libnfnetlink-1.0.1-x86_64-2.txz:  Rebuilt.
n/libnftnl-1.0.9-x86_64-2.txz:  Rebuilt.
n/libqmi-1.20.0-x86_64-2.txz:  Rebuilt.
n/libtirpc-1.0.3-x86_64-2.txz:  Rebuilt.
n/links-2.14-x86_64-3.txz:  Rebuilt.
n/lynx-2.8.9dev.16-x86_64-1.txz:  Upgraded.
n/mailx-12.5-x86_64-3.txz:  Rebuilt.
n/mcabber-1.0.5-x86_64-2.txz:  Rebuilt.
n/metamail-2.7-x86_64-7.txz:  Rebuilt.
n/mobile-broadband-provider-info-20170310-x86_64-2.txz:  Rebuilt.
n/mtr-0.92-x86_64-2.txz:  Rebuilt.
n/mutt-1.9.5-x86_64-1.txz:  Upgraded.
n/nc-1.10-x86_64-2.txz:  Rebuilt.
n/ncftp-3.2.6-x86_64-2.txz:  Rebuilt.
n/net-snmp-5.7.3-x86_64-7.txz:  Rebuilt.
n/net-tools-20170208_479bb4a-x86_64-2.txz:  Rebuilt.
n/netatalk-2.2.3-x86_64-7.txz:  Rebuilt.
n/netdate-bsd4-x86_64-2.txz:  Rebuilt.
n/netkit-bootparamd-0.17-x86_64-3.txz:  Rebuilt.
n/netkit-ftp-0.17-x86_64-4.txz:  Rebuilt.
n/netkit-ntalk-0.17-x86_64-5.txz:  Rebuilt.
n/netkit-routed-0.17-x86_64-2.txz:  Rebuilt.
n/netkit-rsh-0.17-x86_64-2.txz:  Rebuilt.
n/netkit-rusers-0.17-x86_64-2.txz:  Rebuilt.
n/netkit-rwall-0.17-x86_64-2.txz:  Rebuilt.
n/netkit-rwho-0.17-x86_64-3.txz:  Rebuilt.
n/netkit-timed-0.17-x86_64-2.txz:  Rebuilt.
n/netpipes-4.2-x86_64-2.txz:  Rebuilt.
n/nettle-3.4-x86_64-2.txz:  Rebuilt.
n/netwatch-1.3.1_2-x86_64-3.txz:  Rebuilt.
n/network-scripts-15.0-noarch-7.txz:  Rebuilt.
n/netwrite-0.17-x86_64-2.txz:  Rebuilt.
n/newspost-2.1.1-x86_64-2.txz:  Rebuilt.
n/nfacct-1.0.2-x86_64-2.txz:  Rebuilt.
n/nfs-utils-2.3.1-x86_64-2.txz:  Rebuilt.
n/nftables-0.8.2-x86_64-2.txz:  Rebuilt.
n/nghttp2-1.31.1-x86_64-1.txz:  Upgraded.
  This update fixes a security issue:
  Denial of service due to NULL pointer dereference.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1000168
  (* Security fix *)
n/nmap-7.70-x86_64-2.txz:  Rebuilt.
n/nn-6.7.3-x86_64-5.txz:  Rebuilt.
n/npth-1.5-x86_64-2.txz:  Rebuilt.
n/ntp-4.2.8p11-x86_64-2.txz:  Rebuilt.
n/obexftp-0.24.2-x86_64-3.txz:  Rebuilt.
n/openldap-client-2.4.46-x86_64-2.txz:  Rebuilt.
n/openobex-1.7.2-x86_64-2.txz:  Rebuilt.
n/openssh-7.7p1-x86_64-3.txz:  Rebuilt.
n/openssl-1.0.2o-x86_64-2.txz:  Rebuilt.
n/openvpn-2.4.5-x86_64-2.txz:  Rebuilt.
n/p11-kit-0.23.10-x86_64-2.txz:  Rebuilt.
n/php-7.2.4-x86_64-2.txz:  Rebuilt.
n/pidentd-3.0.19-x86_64-3.txz:  Rebuilt.
n/pinentry-1.1.0-x86_64-2.txz:  Rebuilt.
n/popa3d-1.0.3-x86_64-2.txz:  Rebuilt.
n/postfix-3.3.0-x86_64-3.txz:  Rebuilt.
n/ppp-2.4.7-x86_64-2.txz:  Rebuilt.
n/procmail-3.22-x86_64-3.txz:  Rebuilt.
n/proftpd-1.3.6-x86_64-3.txz:  Rebuilt.
n/pssh-2.3.1-x86_64-3.txz:  Rebuilt.
n/rdist-6.1.5-x86_64-3.txz:  Rebuilt.
n/rp-pppoe-3.12-x86_64-2.txz:  Rebuilt.
n/rpcbind-0.2.4-x86_64-4.txz:  Rebuilt.
n/rsync-3.1.3-x86_64-2.txz:  Rebuilt.
n/samba-4.7.7-x86_64-1.txz:  Upgraded.
n/slrn-1.0.2-x86_64-2.txz:  Rebuilt.
n/snownews-1.5.12-x86_64-4.txz:  Rebuilt.
n/sshfs-2.10-x86_64-2.txz:  Rebuilt.
n/stunnel-5.44-x86_64-2.txz:  Rebuilt.
n/tcp_wrappers-7.6-x86_64-2.txz:  Rebuilt.
n/tcpdump-4.9.2-x86_64-2.txz:  Rebuilt.
n/telnet-0.17-x86_64-4.txz:  Rebuilt.
n/tftp-hpa-5.2-x86_64-4.txz:  Rebuilt.
n/tin-2.4.2-x86_64-3.txz:  Rebuilt.
n/traceroute-2.1.0-x86_64-2.txz:  Rebuilt.
n/ulogd-2.0.5-x86_64-3.txz:  Rebuilt.
n/uucp-1.07-x86_64-2.txz:  Rebuilt.
n/vlan-1.9-x86_64-3.txz:  Rebuilt.
n/vsftpd-3.0.3-x86_64-4.txz:  Rebuilt.
n/wget-1.19.4-x86_64-3.txz:  Rebuilt.
n/whois-5.3.0-x86_64-2.txz:  Rebuilt.
n/wireless_tools-29-x86_64-12.txz:  Rebuilt.
n/wpa_supplicant-2.6-x86_64-4.txz:  Rebuilt.
n/yptools-2.14-x86_64-10.txz:  Rebuilt.
n/ytalk-3.3.0-x86_64-4.txz:  Rebuilt.
n/zd1211-firmware-1.5-fw-2.txz:  Rebuilt.
t/fig2dev-3.2.7-x86_64-1.txz:  Upgraded.
t/texlive-2017.171108-x86_64-5.txz:  Rebuilt.
t/xfig-3.2.7-x86_64-1.txz:  Upgraded.
tcl/expect-5.45.4-x86_64-2.txz:  Rebuilt.
tcl/hfsutils-3.2.6-x86_64-6.txz:  Rebuilt.
tcl/tcl-8.6.8-x86_64-3.txz:  Rebuilt.
tcl/tclx-8.4.1-x86_64-4.txz:  Rebuilt.
tcl/tix-8.4.3-x86_64-4.txz:  Rebuilt.
tcl/tk-8.6.8-x86_64-2.txz:  Rebuilt.
x/anthy-9100h-x86_64-2.txz:  Rebuilt.
x/appres-1.0.5-x86_64-2.txz:  Rebuilt.
x/bdftopcf-1.1-x86_64-2.txz:  Rebuilt.
x/beforelight-1.0.5-x86_64-3.txz:  Rebuilt.
x/bitmap-1.0.8-x86_64-3.txz:  Rebuilt.
x/compiz-0.8.8-x86_64-5.txz:  Rebuilt.
x/dejavu-fonts-ttf-2.37-noarch-3.txz:  Rebuilt.
x/editres-1.0.7-x86_64-2.txz:  Rebuilt.
x/encodings-1.0.4-noarch-2.txz:  Rebuilt.
x/font-adobe-100dpi-1.0.3-noarch-2.txz:  Rebuilt.
x/font-adobe-75dpi-1.0.3-noarch-2.txz:  Rebuilt.
x/font-adobe-utopia-100dpi-1.0.4-noarch-2.txz:  Rebuilt.
x/font-adobe-utopia-75dpi-1.0.4-noarch-2.txz:  Rebuilt.
x/font-adobe-utopia-type1-1.0.4-noarch-2.txz:  Rebuilt.
x/font-alias-1.0.3-noarch-2.txz:  Rebuilt.
x/font-arabic-misc-1.0.3-noarch-2.txz:  Rebuilt.
x/font-bh-100dpi-1.0.3-noarch-2.txz:  Rebuilt.
x/font-bh-75dpi-1.0.3-noarch-2.txz:  Rebuilt.
x/font-bh-lucidatypewriter-100dpi-1.0.3-noarch-2.txz:  Rebuilt.
x/font-bh-lucidatypewriter-75dpi-1.0.3-noarch-2.txz:  Rebuilt.
x/font-bh-ttf-1.0.3-noarch-2.txz:  Rebuilt.
x/font-bh-type1-1.0.3-noarch-2.txz:  Rebuilt.
x/font-bitstream-100dpi-1.0.3-noarch-2.txz:  Rebuilt.
x/font-bitstream-75dpi-1.0.3-noarch-2.txz:  Rebuilt.
x/font-bitstream-speedo-1.0.2-noarch-2.txz:  Rebuilt.
x/font-bitstream-type1-1.0.3-noarch-2.txz:  Rebuilt.
x/font-cronyx-cyrillic-1.0.3-noarch-2.txz:  Rebuilt.
x/font-cursor-misc-1.0.3-noarch-2.txz:  Rebuilt.
x/font-daewoo-misc-1.0.3-noarch-2.txz:  Rebuilt.
x/font-dec-misc-1.0.3-noarch-2.txz:  Rebuilt.
x/font-ibm-type1-1.0.3-noarch-2.txz:  Rebuilt.
x/font-isas-misc-1.0.3-noarch-2.txz:  Rebuilt.
x/font-jis-misc-1.0.3-noarch-2.txz:  Rebuilt.
x/font-micro-misc-1.0.3-noarch-2.txz:  Rebuilt.
x/font-misc-cyrillic-1.0.3-noarch-2.txz:  Rebuilt.
x/font-misc-ethiopic-1.0.3-noarch-2.txz:  Rebuilt.
x/font-misc-meltho-1.0.3-noarch-2.txz:  Rebuilt.
x/font-misc-misc-1.1.2-noarch-2.txz:  Rebuilt.
x/font-mutt-misc-1.0.3-noarch-2.txz:  Rebuilt.
x/font-schumacher-misc-1.1.2-noarch-2.txz:  Rebuilt.
x/font-screen-cyrillic-1.0.4-noarch-2.txz:  Rebuilt.
x/font-sony-misc-1.0.3-noarch-2.txz:  Rebuilt.
x/font-sun-misc-1.0.3-noarch-2.txz:  Rebuilt.
x/font-util-1.3.1-x86_64-3.txz:  Rebuilt.
x/font-winitzki-cyrillic-1.0.3-noarch-2.txz:  Rebuilt.
x/font-xfree86-type1-1.0.4-noarch-2.txz:  Rebuilt.
x/fontconfig-2.12.6-x86_64-2.txz:  Rebuilt.
x/fonttosfnt-1.0.4-x86_64-3.txz:  Rebuilt.
x/freeglut-3.0.0-x86_64-2.txz:  Rebuilt.
x/fslsfonts-1.0.5-x86_64-3.txz:  Rebuilt.
x/fstobdf-1.0.6-x86_64-3.txz:  Rebuilt.
x/gccmakedep-1.0.3-noarch-2.txz:  Rebuilt.
x/glew-2.1.0-x86_64-2.txz:  Rebuilt.
x/glu-9.0.0-x86_64-2.txz:  Rebuilt.
x/iceauth-1.0.8-x86_64-2.txz:  Rebuilt.
x/ico-1.0.5-x86_64-2.txz:  Rebuilt.
x/imake-1.0.7-x86_64-3.txz:  Rebuilt.
x/intel-gpu-tools-1.22-x86_64-2.txz:  Rebuilt.
x/intel-vaapi-driver-2.1.0-x86_64-2.txz:  Rebuilt.
x/libFS-1.0.7-x86_64-2.txz:  Rebuilt.
x/libICE-1.0.9-x86_64-3.txz:  Rebuilt.
x/libSM-1.2.2-x86_64-3.txz:  Rebuilt.
x/libX11-1.6.5-x86_64-2.txz:  Rebuilt.
x/libXScrnSaver-1.2.2-x86_64-3.txz:  Rebuilt.
x/libXau-1.0.8-x86_64-3.txz:  Rebuilt.
x/libXaw-1.0.13-x86_64-2.txz:  Rebuilt.
x/libXaw3d-1.6.2-x86_64-4.txz:  Rebuilt.
x/libXaw3dXft-1.6.2d-x86_64-3.txz:  Rebuilt.
x/libXcm-0.5.2-x86_64-3.txz:  Rebuilt.
x/libXcomposite-0.4.4-x86_64-3.txz:  Rebuilt.
x/libXcursor-1.1.15-x86_64-2.txz:  Rebuilt.
x/libXdamage-1.1.4-x86_64-3.txz:  Rebuilt.
x/libXdmcp-1.1.2-x86_64-3.txz:  Rebuilt.
x/libXevie-1.0.3-x86_64-3.txz:  Rebuilt.
x/libXext-1.3.3-x86_64-3.txz:  Rebuilt.
x/libXfixes-5.0.3-x86_64-2.txz:  Rebuilt.
x/libXfont2-2.0.3-x86_64-2.txz:  Rebuilt.
x/libXfontcache-1.0.5-x86_64-3.txz:  Rebuilt.
x/libXft-2.3.2-x86_64-4.txz:  Rebuilt.
x/libXi-1.7.9-x86_64-2.txz:  Rebuilt.
x/libXinerama-1.1.3-x86_64-3.txz:  Rebuilt.
x/libXmu-1.1.2-x86_64-3.txz:  Rebuilt.
x/libXp-1.0.3-x86_64-3.txz:  Rebuilt.
x/libXpm-3.5.12-x86_64-2.txz:  Rebuilt.
x/libXpresent-1.0.0-x86_64-2.txz:  Rebuilt.
x/libXrandr-1.5.1-x86_64-2.txz:  Rebuilt.
x/libXrender-0.9.10-x86_64-2.txz:  Rebuilt.
x/libXres-1.2.0-x86_64-2.txz:  Rebuilt.
x/libXt-1.1.5-x86_64-2.txz:  Rebuilt.
x/libXtst-1.2.3-x86_64-2.txz:  Rebuilt.
x/libXv-1.0.11-x86_64-2.txz:  Rebuilt.
x/libXvMC-1.0.10-x86_64-2.txz:  Rebuilt.
x/libXxf86dga-1.1.4-x86_64-3.txz:  Rebuilt.
x/libXxf86misc-1.0.3-x86_64-3.txz:  Rebuilt.
x/libXxf86vm-1.1.4-x86_64-3.txz:  Rebuilt.
x/libdmx-1.1.3-x86_64-3.txz:  Rebuilt.
x/libdrm-2.4.91-x86_64-2.txz:  Rebuilt.
x/libepoxy-1.4.3-x86_64-2.txz:  Rebuilt.
x/liberation-fonts-ttf-2.00.1-noarch-2.txz:  Rebuilt.
x/libevdev-1.5.9-x86_64-2.txz:  Rebuilt.
x/libfontenc-1.1.3-x86_64-2.txz:  Rebuilt.
x/libhangul-0.1.0-x86_64-2.txz:  Rebuilt.
x/libinput-1.10.4-x86_64-2.txz:  Rebuilt.
x/libpciaccess-0.14-x86_64-2.txz:  Rebuilt.
x/libpthread-stubs-0.4-noarch-2.txz:  Rebuilt.
x/libva-2.1.0-x86_64-2.txz:  Rebuilt.
x/libva-utils-2.1.0-x86_64-2.txz:  Rebuilt.
x/libvdpau-1.1.1-x86_64-2.txz:  Rebuilt.
x/libwacom-0.29-x86_64-2.txz:  Rebuilt.
x/libxcb-1.13-x86_64-2.txz:  Rebuilt.
x/libxkbfile-1.0.9-x86_64-2.txz:  Rebuilt.
x/libxshmfence-1.3-x86_64-2.txz:  Rebuilt.
x/listres-1.0.4-x86_64-2.txz:  Rebuilt.
x/lndir-1.0.3-x86_64-3.txz:  Rebuilt.
x/luit-1.1.1-x86_64-3.txz:  Rebuilt.
x/m17n-lib-1.8.0-x86_64-2.txz:  Rebuilt.
x/makedepend-1.0.5-x86_64-3.txz:  Rebuilt.
x/mesa-18.0.1-x86_64-1.txz:  Upgraded.
x/mkcomposecache-1.2.1-x86_64-3.txz:  Rebuilt.
x/mkfontdir-1.0.7-noarch-2.txz:  Rebuilt.
x/mkfontscale-1.1.3-x86_64-2.txz:  Rebuilt.
x/motif-2.3.8-x86_64-2.txz:  Rebuilt.
x/mtdev-1.1.5-x86_64-2.txz:  Rebuilt.
x/oclock-1.0.4-x86_64-2.txz:  Rebuilt.
x/pixman-0.34.0-x86_64-2.txz:  Rebuilt.
x/rendercheck-1.5-x86_64-2.txz:  Rebuilt.
x/rgb-1.0.6-x86_64-3.txz:  Rebuilt.
x/sazanami-fonts-ttf-20040629-noarch-2.txz:  Rebuilt.
x/scim-1.4.17-x86_64-2.txz:  Rebuilt.
x/scim-anthy-1.2.7-x86_64-2.txz:  Rebuilt.
x/scim-hangul-0.4.0-x86_64-2.txz:  Rebuilt.
x/scim-input-pad-0.1.3.1-x86_64-2.txz:  Rebuilt.
x/scim-m17n-0.2.3-x86_64-2.txz:  Rebuilt.
x/scim-pinyin-0.5.92-x86_64-2.txz:  Rebuilt.
x/scim-tables-0.5.14.1-x86_64-2.txz:  Rebuilt.
x/sessreg-1.1.1-x86_64-2.txz:  Rebuilt.
x/setxkbmap-1.3.1-x86_64-2.txz:  Rebuilt.
x/showfont-1.0.5-x86_64-3.txz:  Rebuilt.
x/sinhala_lklug-font-ttf-20060929-noarch-2.txz:  Rebuilt.
x/smproxy-1.0.6-x86_64-2.txz:  Rebuilt.
x/tibmachuni-font-ttf-1.901b-noarch-2.txz:  Rebuilt.
x/transset-1.0.2-x86_64-2.txz:  Rebuilt.
x/ttf-indic-fonts-0.5.14-noarch-2.txz:  Rebuilt.
x/ttf-tlwg-0.6.4-noarch-2.txz:  Rebuilt.
x/twm-1.0.10-x86_64-2.txz:  Rebuilt.
x/urw-core35-fonts-otf-20160712_79bcdfb_git-noarch-2.txz:  Rebuilt.
x/util-macros-1.19.2-noarch-2.txz:  Rebuilt.
x/viewres-1.0.5-x86_64-2.txz:  Rebuilt.
x/vulkan-sdk-1.1.70.0-x86_64-2.txz:  Rebuilt.
x/wqy-zenhei-font-ttf-0.8.38_1-noarch-5.txz:  Rebuilt.
x/x11-skel-7.7-x86_64-2.txz:  Rebuilt.
x/x11perf-1.6.0-x86_64-2.txz:  Rebuilt.
x/xauth-1.0.10-x86_64-2.txz:  Rebuilt.
x/xbacklight-1.2.2-x86_64-2.txz:  Rebuilt.
x/xbiff-1.0.3-x86_64-3.txz:  Rebuilt.
x/xbitmaps-1.1.2-x86_64-2.txz:  Rebuilt.
x/xcalc-1.0.6-x86_64-3.txz:  Rebuilt.
x/xcb-proto-1.13-x86_64-2.txz:  Rebuilt.
x/xcb-util-0.4.0-x86_64-3.txz:  Rebuilt.
x/xcb-util-cursor-0.1.3-x86_64-2.txz:  Rebuilt.
x/xcb-util-errors-1.0-x86_64-2.txz:  Rebuilt.
x/xcb-util-image-0.4.0-x86_64-3.txz:  Rebuilt.
x/xcb-util-keysyms-0.4.0-x86_64-3.txz:  Rebuilt.
x/xcb-util-renderutil-0.3.9-x86_64-3.txz:  Rebuilt.
x/xcb-util-wm-0.4.1-x86_64-3.txz:  Rebuilt.
x/xclipboard-1.1.3-x86_64-3.txz:  Rebuilt.
x/xclock-1.0.7-x86_64-3.txz:  Rebuilt.
x/xcm-0.5.2-x86_64-3.txz:  Rebuilt.
x/xcmsdb-1.0.5-x86_64-2.txz:  Rebuilt.
x/xcompmgr-1.1.7-x86_64-2.txz:  Rebuilt.
x/xconsole-1.0.7-x86_64-2.txz:  Rebuilt.
x/xcursor-themes-1.0.5-noarch-2.txz:  Rebuilt.
x/xcursorgen-1.0.6-x86_64-4.txz:  Rebuilt.
x/xdbedizzy-1.1.0-x86_64-3.txz:  Rebuilt.
x/xdg-user-dirs-0.15-x86_64-2.txz:  Rebuilt.
x/xdg-utils-1.1.2-noarch-2.txz:  Rebuilt.
x/xditview-1.0.4-x86_64-2.txz:  Rebuilt.
x/xdm-1.1.11-x86_64-8.txz:  Rebuilt.
x/xdpyinfo-1.3.2-x86_64-2.txz:  Rebuilt.
x/xdriinfo-1.0.6-x86_64-2.txz:  Rebuilt.
x/xedit-1.2.2-x86_64-3.txz:  Rebuilt.
x/xev-1.2.2-x86_64-2.txz:  Rebuilt.
x/xeyes-1.1.2-x86_64-2.txz:  Rebuilt.
x/xf86-input-acecad-1.5.0-x86_64-11.txz:  Rebuilt.
x/xf86-input-evdev-2.10.5-x86_64-2.txz:  Rebuilt.
x/xf86-input-joystick-1.6.3-x86_64-2.txz:  Rebuilt.
x/xf86-input-keyboard-1.9.0-x86_64-2.txz:  Rebuilt.
x/xf86-input-libinput-0.27.1-x86_64-2.txz:  Rebuilt.
x/xf86-input-mouse-1.9.2-x86_64-2.txz:  Rebuilt.
x/xf86-input-penmount-1.5.0-x86_64-11.txz:  Rebuilt.
x/xf86-input-synaptics-1.9.0-x86_64-2.txz:  Rebuilt.
x/xf86-input-vmmouse-13.1.0-x86_64-6.txz:  Rebuilt.
x/xf86-input-void-1.4.0-x86_64-11.txz:  Rebuilt.
x/xf86-input-wacom-0.36.1-x86_64-2.txz:  Rebuilt.
x/xf86-video-amdgpu-18.0.1-x86_64-2.txz:  Rebuilt.
x/xf86-video-apm-1.2.5-x86_64-10.txz:  Rebuilt.
x/xf86-video-ark-0.7.5-x86_64-10.txz:  Rebuilt.
x/xf86-video-ast-1.1.5-x86_64-4.txz:  Rebuilt.
x/xf86-video-ati-18.0.1-x86_64-2.txz:  Rebuilt.
x/xf86-video-chips-1.2.7-x86_64-2.txz:  Rebuilt.
x/xf86-video-cirrus-1.5.3-x86_64-4.txz:  Rebuilt.
x/xf86-video-dummy-0.3.8-x86_64-2.txz:  Rebuilt.
x/xf86-video-glint-1.2.9-x86_64-2.txz:  Rebuilt.
x/xf86-video-i128-1.3.6-x86_64-10.txz:  Rebuilt.
x/xf86-video-i740-1.3.6-x86_64-2.txz:  Rebuilt.
x/xf86-video-intel-git_20180206_aa36399c-x86_64-2.txz:  Rebuilt.
x/xf86-video-mach64-6.9.5-x86_64-4.txz:  Rebuilt.
x/xf86-video-mga-1.6.5-x86_64-2.txz:  Rebuilt.
x/xf86-video-neomagic-1.2.9-x86_64-4.txz:  Rebuilt.
x/xf86-video-nouveau-1.0.15-x86_64-2.txz:  Rebuilt.
x/xf86-video-nv-2.1.21-x86_64-2.txz:  Rebuilt.
x/xf86-video-openchrome-0.6.0-x86_64-2.txz:  Rebuilt.
x/xf86-video-r128-6.10.2-x86_64-2.txz:  Rebuilt.
x/xf86-video-rendition-4.2.6-x86_64-3.txz:  Rebuilt.
x/xf86-video-s3-0.6.5-x86_64-10.txz:  Rebuilt.
x/xf86-video-s3virge-1.10.7-x86_64-4.txz:  Rebuilt.
x/xf86-video-savage-2.3.9-x86_64-2.txz:  Rebuilt.
x/xf86-video-siliconmotion-1.7.9-x86_64-2.txz:  Rebuilt.
x/xf86-video-sis-0.10.9-x86_64-2.txz:  Rebuilt.
x/xf86-video-sisusb-0.9.7-x86_64-2.txz:  Rebuilt.
x/xf86-video-tdfx-1.4.7-x86_64-2.txz:  Rebuilt.
x/xf86-video-tga-1.2.2-x86_64-10.txz:  Rebuilt.
x/xf86-video-trident-1.3.8-x86_64-2.txz:  Rebuilt.
x/xf86-video-tseng-1.2.5-x86_64-10.txz:  Rebuilt.
x/xf86-video-v4l-0.2.0-x86_64-15.txz:  Rebuilt.
x/xf86-video-vboxvideo-1.0.0-x86_64-2.txz:  Rebuilt.
x/xf86-video-vesa-2.4.0-x86_64-2.txz:  Rebuilt.
x/xf86-video-vmware-13.2.1-x86_64-6.txz:  Rebuilt.
x/xf86-video-voodoo-1.2.5-x86_64-11.txz:  Rebuilt.
x/xf86dga-1.0.3-x86_64-3.txz:  Rebuilt.
x/xfd-1.1.2-x86_64-3.txz:  Rebuilt.
x/xfontsel-1.0.6-x86_64-2.txz:  Rebuilt.
x/xfs-1.2.0-x86_64-2.txz:  Rebuilt.
x/xfsinfo-1.0.5-x86_64-3.txz:  Rebuilt.
x/xgamma-1.0.6-x86_64-2.txz:  Rebuilt.
x/xgc-1.0.5-x86_64-2.txz:  Rebuilt.
x/xhost-1.0.7-x86_64-2.txz:  Rebuilt.
x/xinit-1.4.0-x86_64-2.txz:  Rebuilt.
x/xinput-1.6.2-x86_64-2.txz:  Rebuilt.
x/xkbcomp-1.4.1-x86_64-2.txz:  Rebuilt.
x/xkbevd-1.1.4-x86_64-2.txz:  Rebuilt.
x/xkbprint-1.0.4-x86_64-2.txz:  Rebuilt.
x/xkbutils-1.0.4-x86_64-3.txz:  Rebuilt.
x/xkeyboard-config-2.22-noarch-2.txz:  Rebuilt.
x/xkill-1.0.5-x86_64-2.txz:  Rebuilt.
x/xload-1.1.3-x86_64-2.txz:  Rebuilt.
x/xlogo-1.0.4-x86_64-3.txz:  Rebuilt.
x/xlsatoms-1.1.2-x86_64-2.txz:  Rebuilt.
x/xlsclients-1.1.4-x86_64-2.txz:  Rebuilt.
x/xlsfonts-1.0.6-x86_64-2.txz:  Rebuilt.
x/xmag-1.0.6-x86_64-2.txz:  Rebuilt.
x/xman-1.1.4-x86_64-3.txz:  Rebuilt.
x/xmessage-1.0.5-x86_64-2.txz:  Rebuilt.
x/xmh-1.0.3-x86_64-2.txz:  Rebuilt.
x/xmodmap-1.0.9-x86_64-2.txz:  Rebuilt.
x/xmore-1.0.2-x86_64-3.txz:  Rebuilt.
x/xorg-cf-files-1.0.6-x86_64-3.txz:  Rebuilt.
x/xorg-docs-1.7.1-noarch-2.txz:  Rebuilt.
x/xorg-server-1.19.6-x86_64-3.txz:  Rebuilt.
x/xorg-server-xephyr-1.19.6-x86_64-3.txz:  Rebuilt.
x/xorg-server-xnest-1.19.6-x86_64-3.txz:  Rebuilt.
x/xorg-server-xvfb-1.19.6-x86_64-3.txz:  Rebuilt.
x/xorg-sgml-doctools-1.11-x86_64-3.txz:  Rebuilt.
x/xorgproto-2018.4-x86_64-3.txz:  Rebuilt.
x/xpr-1.0.5-x86_64-2.txz:  Rebuilt.
x/xprop-1.2.3-x86_64-2.txz:  Rebuilt.
x/xpyb-1.3.1-x86_64-5.txz:  Rebuilt.
x/xrandr-1.5.0-x86_64-2.txz:  Rebuilt.
x/xrdb-1.1.1-x86_64-2.txz:  Rebuilt.
x/xrefresh-1.0.6-x86_64-2.txz:  Rebuilt.
x/xscope-1.4.1-x86_64-3.txz:  Rebuilt.
x/xset-1.2.4-x86_64-2.txz:  Rebuilt.
x/xsetroot-1.1.2-x86_64-2.txz:  Rebuilt.
x/xsm-1.0.4-x86_64-2.txz:  Rebuilt.
x/xstdcmap-1.0.3-x86_64-3.txz:  Rebuilt.
x/xterm-332-x86_64-1.txz:  Upgraded.
x/xtrans-1.3.5-noarch-2.txz:  Rebuilt.
x/xvidtune-1.0.3-x86_64-3.txz:  Rebuilt.
x/xvinfo-1.1.3-x86_64-2.txz:  Rebuilt.
x/xwd-1.0.7-x86_64-2.txz:  Rebuilt.
x/xwininfo-1.1.4-x86_64-2.txz:  Rebuilt.
x/xwud-1.0.5-x86_64-2.txz:  Rebuilt.
xap/MPlayer-20180208-x86_64-3.txz:  Rebuilt.
xap/audacious-3.9-x86_64-2.txz:  Rebuilt.
xap/audacious-plugins-3.9-x86_64-4.txz:  Rebuilt.
xap/blackbox-0.70.1-x86_64-8.txz:  Rebuilt.
xap/blueman-2.0.5-x86_64-2.txz:  Rebuilt.
xap/ddd-3.3.12-x86_64-6.txz:  Rebuilt.
xap/easytag-2.4.2-x86_64-2.txz:  Rebuilt.
xap/electricsheep-20090306-x86_64-5.txz:  Rebuilt.
xap/fluxbox-1.3.7-x86_64-3.txz:  Rebuilt.
xap/fvwm-2.6.7-x86_64-4.txz:  Rebuilt.
xap/geeqie-1.4-x86_64-2.txz:  Rebuilt.
xap/gftp-2.0.19-x86_64-6.txz:  Rebuilt.
xap/gimp-2.8.22-x86_64-2.txz:  Rebuilt.
xap/gkrellm-2.3.10-x86_64-3.txz:  Rebuilt.
xap/gnuchess-6.2.5-x86_64-2.txz:  Rebuilt.
xap/gnuplot-5.2.2-x86_64-2.txz:  Rebuilt.
xap/gparted-0.31.0-x86_64-2.txz:  Rebuilt.
xap/gucharmap-10.0.3-x86_64-2.txz:  Rebuilt.
xap/gv-3.7.4-x86_64-2.txz:  Rebuilt.
xap/hexchat-2.14.1-x86_64-2.txz:  Rebuilt.
xap/mozilla-firefox-59.0.2-x86_64-2.txz:  Rebuilt.
xap/mozilla-thunderbird-52.7.0-x86_64-2.txz:  Rebuilt.
xap/network-manager-applet-1.8.10-x86_64-5.txz:  Rebuilt.
xap/pan-0.143-x86_64-4.txz:  Rebuilt.
xap/pavucontrol-3.0-x86_64-2.txz:  Rebuilt.
xap/pidgin-2.13.0-x86_64-2.txz:  Rebuilt.
xap/rdesktop-1.8.3-x86_64-2.txz:  Rebuilt.
xap/rxvt-unicode-9.22-x86_64-4.txz:  Rebuilt.
xap/sane-1.0.27-x86_64-2.txz:  Rebuilt.
xap/seamonkey-2.49.2-x86_64-2.txz:  Rebuilt.
xap/seyon-2.20c-x86_64-4.txz:  Rebuilt.
xap/vim-gvim-8.0.1733-x86_64-1.txz:  Upgraded.
xap/windowmaker-0.95.8-x86_64-2.txz:  Rebuilt.
xap/x11-ssh-askpass-1.2.4.1-x86_64-3.txz:  Rebuilt.
xap/x3270-3.3.12ga7-x86_64-3.txz:  Rebuilt.
xap/xaos-3.6-x86_64-2.txz:  Rebuilt.
xap/xfractint-20.04p13-x86_64-2.txz:  Rebuilt.
xap/xgames-0.3-x86_64-5.txz:  Rebuilt.
xap/xine-lib-1.2.9-x86_64-2.txz:  Rebuilt.
xap/xine-ui-0.99.10-x86_64-2.txz:  Rebuilt.
xap/xlockmore-5.54-x86_64-3.txz:  Rebuilt.
xap/xmms-1.2.11-x86_64-6.txz:  Rebuilt.
xap/xpaint-2.10.2-x86_64-2.txz:  Rebuilt.
xap/xpdf-4.00-x86_64-3.txz:  Rebuilt.
xap/xsane-0.999-x86_64-2.txz:  Rebuilt.
xap/xscreensaver-5.39-x86_64-1.txz:  Upgraded.
xap/xv-3.10a-x86_64-9.txz:  Rebuilt.
xfce/Thunar-1.6.15-x86_64-2.txz:  Rebuilt.
xfce/exo-0.12.0-x86_64-2.txz:  Rebuilt.
xfce/garcon-0.6.1-x86_64-2.txz:  Rebuilt.
xfce/gtk-xfce-engine-2.10.1-x86_64-3.txz:  Rebuilt.
xfce/libxfce4ui-4.12.1-x86_64-3.txz:  Rebuilt.
xfce/libxfce4util-4.12.1-x86_64-4.txz:  Rebuilt.
xfce/orage-4.12.1-x86_64-5.txz:  Rebuilt.
xfce/thunar-volman-0.8.1-x86_64-3.txz:  Rebuilt.
xfce/tumbler-0.2.1-x86_64-2.txz:  Rebuilt.
xfce/xfce4-appfinder-4.12.0-x86_64-3.txz:  Rebuilt.
xfce/xfce4-clipman-plugin-1.4.2-x86_64-2.txz:  Rebuilt.
xfce/xfce4-dev-tools-4.12.0-x86_64-3.txz:  Rebuilt.
xfce/xfce4-notifyd-0.4.2-x86_64-2.txz:  Rebuilt.
xfce/xfce4-panel-4.12.2-x86_64-2.txz:  Rebuilt.
xfce/xfce4-power-manager-1.4.4-x86_64-5.txz:  Rebuilt.
xfce/xfce4-pulseaudio-plugin-0.4.0-x86_64-2.txz:  Rebuilt.
xfce/xfce4-screenshooter-1.8.2-x86_64-5.txz:  Rebuilt.
xfce/xfce4-session-4.12.1-x86_64-3.txz:  Rebuilt.
xfce/xfce4-settings-4.12.2-x86_64-2.txz:  Rebuilt.
xfce/xfce4-systemload-plugin-1.2.1-x86_64-2.txz:  Rebuilt.
  Patched to fix tooltips. Thanks to Rod3775.
xfce/xfce4-taskmanager-1.2.0-x86_64-2.txz:  Rebuilt.
xfce/xfce4-terminal-0.8.7.3-x86_64-2.txz:  Rebuilt.
xfce/xfce4-weather-plugin-0.8.10-x86_64-4.txz:  Rebuilt.
xfce/xfconf-4.12.1-x86_64-2.txz:  Rebuilt.
xfce/xfdesktop-4.12.4-x86_64-2.txz:  Rebuilt.
xfce/xfwm4-4.12.4-x86_64-2.txz:  Rebuilt.
y/bsd-games-2.13-x86_64-13.txz:  Rebuilt.
extra/aspell-word-lists/aspell-el-0.08_0-x86_64-1.txz:  Upgraded.
extra/aspell-word-lists/aspell-hus-0.03_1-x86_64-1.txz:  Added.
extra/aspell-word-lists/aspell-kn-0.01_1-x86_64-1.txz:  Added.
extra/fltk/fltk-1.3.4_2-x86_64-1.txz:  Upgraded.
extra/mplayerplug-in/mplayerplug-in-3.55-x86_64-1.txz:  Removed.
extra/tigervnc/tigervnc-1.8.0-x86_64-4.txz:  Rebuilt.
n°1417556
Col Hanzap​last
Jurassic geek. Vive le cobol !
Posté le 19-04-2018 à 12:25:23  profilanswer
... any SlackBuilds intended to be used with Slackware 15.0... ???
" Il n'y a aucune chance pour que l'iPhone s'attribue une part de marché significative. Aucune chance. " (Steve Ballmer 2007)
n°1417587
cycojesus
Mèo Lười
Posté le 20-04-2018 à 07:20:50  profilanswer
du rqb
Fri Apr 20 03:32:21 UTC 2018
a/kernel-generic-4.14.35-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.14.35-x86_64-1.txz:  Upgraded.
  SQUASHFS m -> y
  Thanks to alienBOB.
a/kernel-modules-4.14.35-x86_64-1.txz:  Upgraded.
d/kernel-headers-4.14.35-x86-1.txz:  Upgraded.
k/kernel-source-4.14.35-noarch-1.txz:  Upgraded.
   RCU_EXPERT n -> y
  +RCU_FANOUT 32
  +RCU_FANOUT_LEAF 16
  +RCU_FAST_NO_HZ y
  +RCU_NOCB_CPU y
  Thanks to alienBOB.
kde/kde-runtime-4.14.3-x86_64-7.txz:  Rebuilt.
  Recompiled against gpgme-1.11.0.
kde/kdepim-4.14.10-x86_64-4.txz:  Rebuilt.
kde/kdepimlibs-4.14.10-x86_64-6.txz:  Rebuilt.
kde/kget-4.14.3-x86_64-5.txz:  Rebuilt.
kde/kopete-4.14.3-x86_64-6.txz:  Rebuilt.
l/gmime-2.6.23-x86_64-4.txz:  Rebuilt.
n/gpa-0.9.10-x86_64-3.txz:  Rebuilt.
n/gpgme-1.11.0-x86_64-1.txz:  Upgraded.
n/mcabber-1.0.5-x86_64-3.txz:  Rebuilt.
n/mutt-1.9.5-x86_64-2.txz:  Rebuilt.
n/samba-4.7.7-x86_64-2.txz:  Rebuilt.
x/libinput-1.10.5-x86_64-1.txz:  Upgraded.
extra/fltk/fltk-1.3.4_2-x86_64-2.txz:  Rebuilt.
  Fixed fltk-config. Thanks to Matteo Bernardini.
Chết rồi ! ✍ ⌥⌘ http://codeberg.org/gwh
n°1417589
cycojesus
Mèo Lười
Posté le 20-04-2018 à 07:21:48  profilanswer
Tu n'installeras point de *.la dans /{,usr/}lib{,64}/ :o
n°1417670
cycojesus
Mèo Lười
Posté le 21-04-2018 à 21:50:23  profilanswer
Sat Apr 21 17:39:25 UTC 2018
a/lvm2-2.02.177-x86_64-1.txz:  Upgraded.
a/pkgtools-15.0-noarch-9.txz:  Rebuilt.
  installpkg: fixed occasional lack of package size reported by the installer.
d/binutils-2.30-x86_64-3.txz:  Rebuilt.
  Fixed /usr/$TARGET/lib directory. Thanks to GazL.
n/gpgme-1.11.1-x86_64-1.txz:  Upgraded.
n/ppp-2.4.7-x86_64-3.txz:  Rebuilt.
  Fixed rp-pppoe build. Thanks to voegelas for the bug report.
xfce/xfce4-settings-4.12.3-x86_64-1.txz:  Upgraded.
isolinux/initrd.img:  Rebuilt.
usb-and-pxe-installers/usbboot.img:  Rebuilt.
n°1417751
cycojesus
Mèo Lười
Posté le 24-04-2018 à 07:11:09  profilanswer
Mon Apr 23 22:17:42 UTC 2018
ap/gutenprint-5.2.14-x86_64-1.txz:  Upgraded.
d/meson-0.46.0-x86_64-1.txz:  Upgraded.
d/python-pip-10.0.1-x86_64-1.txz:  Upgraded.
n°1417783
cycojesus
Mèo Lười
Posté le 25-04-2018 à 08:55:00  profilanswer
Wed Apr 25 04:38:51 UTC 2018
a/kernel-generic-4.14.36-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.14.36-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.14.36-x86_64-1.txz:  Upgraded.
d/gcc-7.3.0-x86_64-3.txz:  Rebuilt.
d/gcc-brig-7.3.0-x86_64-3.txz:  Rebuilt.
d/gcc-g++-7.3.0-x86_64-3.txz:  Rebuilt.
d/gcc-gfortran-7.3.0-x86_64-3.txz:  Rebuilt.
d/gcc-gnat-7.3.0-x86_64-3.txz:  Rebuilt.
  Rebuilt to fix missing shared libraries. Thanks to qunying.
d/gcc-go-7.3.0-x86_64-3.txz:  Rebuilt.
d/gcc-objc-7.3.0-x86_64-3.txz:  Rebuilt.
d/kernel-headers-4.14.36-x86-1.txz:  Upgraded.
d/parallel-20180422-noarch-1.txz:  Added.
d/perl-5.26.2-x86_64-2.txz:  Rebuilt.
  Applied upstream patch to use net_buffer_length in DBD-mysql.
  Thanks to Iouri Kharon.
  Upgraded to URI-1.74.
k/kernel-source-4.14.36-noarch-1.txz:  Upgraded.
l/imagemagick-6.9.9_40-x86_64-3.txz:  Rebuilt.
  Really disable OpenCL. Thanks to orbea.
kernels/*:  Upgraded.
n°1417810
cycojesus
Mèo Lười
Posté le 26-04-2018 à 07:04:51  profilanswer
Rhô purée :o
Thu Apr 26 01:34:12 UTC 2018
Don't like PulseAudio? Well... I hear you. Personally, it works for me, and it
makes it easier to switch between multiple audio inputs and outputs compared
to using plain ALSA. PulseAudio got off to a rocky start in the Linux world,
where it found itself adopted before it was ready (it was even billed on its
own website at the time as "the software that currently breaks your audio" ).
It's my opinion that the reputation that PulseAudio acquired due to problems
back then isn't deserved any longer. If your hardware supports the sampling
rate of the audio data you're trying to play, PulseAudio will not resample it
(and if your hardware doesn't support that rate, resampling can hardly be
avoided). The increased latency has not been an issue here. Nevertheless, I
recognize that there are use cases where PulseAudio is still a detriment.
While I don't generally recommend removing PulseAudio, I'm not going to cram
it down your throat. So, if you'd like to be rid of PulseAudio, head over to
the new extra/pure-alsa-system directory and follow the instructions in the
README file there, and you'll have a PulseAudio-free pure ALSA system.
Thanks to orbea who sent me a small patch for the mpg123.SlackBuild so that
it would detect the lack of PulseAudio and not try to build in support, which
got me to thinking about all of this. Cheers! :-)
a/btrfs-progs-v4.16.1-x86_64-1.txz:  Upgraded.
kde/kopete-4.14.3-x86_64-7.txz:  Rebuilt.
  Dropped obsolete wlm (libmsn) protocol. Thanks to alienBOB.
l/libmsn-4.2.1-x86_64-3.txz:  Removed.
l/poppler-data-0.4.9-noarch-1.txz:  Upgraded.
extra/pure-alsa-system/MPlayer-20180208-x86_64-3_alsa.txz:  Rebuilt.
extra/pure-alsa-system/alsa-lib-1.1.6-x86_64-3_alsa.txz:  Rebuilt.
extra/pure-alsa-system/alsa-plugins-1.1.6-x86_64-2_alsa.txz:  Rebuilt.
extra/pure-alsa-system/audacious-plugins-3.9-x86_64-4_alsa.txz:  Rebuilt.
extra/pure-alsa-system/ffmpeg-3.4.2-x86_64-2_alsa.txz:  Rebuilt.
extra/pure-alsa-system/fluidsynth-1.1.10-x86_64-2_alsa.txz:  Rebuilt.
extra/pure-alsa-system/gst-plugins-good-1.14.0-x86_64-2_alsa.txz:  Rebuilt.
extra/pure-alsa-system/gst-plugins-good0-0.10.31-x86_64-3_alsa.txz:  Rebuilt.
extra/pure-alsa-system/kde-runtime-4.14.3-x86_64-7_alsa.txz:  Rebuilt.
extra/pure-alsa-system/kmix-4.14.3-x86_64-4_alsa.txz:  Rebuilt.
extra/pure-alsa-system/libao-1.2.2-x86_64-2_alsa.txz:  Rebuilt.
extra/pure-alsa-system/libcanberra-0.30-x86_64-6_alsa.txz:  Rebuilt.
extra/pure-alsa-system/mpg123-1.25.10-x86_64-2_alsa.txz:  Rebuilt.
extra/pure-alsa-system/phonon-4.8.3-x86_64-3_alsa.txz:  Rebuilt.
extra/pure-alsa-system/sox-14.4.2-x86_64-5_alsa.txz:  Rebuilt.
extra/pure-alsa-system/xfce4-mixer-4.11.0-x86_64-1_alsa.txz:  Upgraded.
extra/pure-alsa-system/xfce4-volumed-0.1.13-x86_64-4_alsa.txz:  Rebuilt.
extra/pure-alsa-system/xine-lib-1.2.9-x86_64-2_alsa.txz:  Rebuilt.
n°1417862
cycojesus
Mèo Lười
Posté le 27-04-2018 à 10:23:39  profilanswer
Fri Apr 27 03:58:48 UTC 2018
a/kernel-generic-4.14.37-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.14.37-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.14.37-x86_64-1.txz:  Upgraded.
d/kernel-headers-4.14.37-x86-1.txz:  Upgraded.
k/kernel-source-4.14.37-noarch-1.txz:  Upgraded.
n/openvpn-2.4.6-x86_64-1.txz:  Upgraded.
  This is a security update fixing a potential double-free() in Interactive
  Service. This usually only leads to a process crash (DoS by an unprivileged
  local account) but since it could possibly lead to memory corruption if
  happening while multiple other threads are active at the same time,
  CVE-2018-9336 has been assigned to acknowledge this risk.
    https://github.com/OpenVPN/openvpn/commit/1394192b210cb3c6624a7419bcf3ff966742e79b
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-9336
  (* Security fix *)
n/php-7.2.5-x86_64-1.txz:  Upgraded.
  This release fixes bugs and security issues.
    https://php.net/ChangeLog-7.php#7.2.5
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-5712
  (* Security fix *)
n°1417864
Col Hanzap​last
Posté le 27-04-2018 à 10:51:02  profilanswer
Une idée pour la date de sortie de la version 15 ?
n°1417905
cycojesus
Mèo Lười
Posté le 27-04-2018 à 20:31:54  profilanswer
Pas vraiment mais d'après AlienBob il faut encore au moins passer à KDE 5.
Peut-être cet été ?
n°1417917
macomboh
Posté le 28-04-2018 à 01:12:43  profilanswer
 En fait la notion de "version" ou de "release" est tout à fait anecdotique pour SLackware ,
c'est juste une  occasion pour Patrick de passer des communiqués dans les  media pour  attirer leur attention dessus .
Ce  qu'il faut c'est passer régulierement les MAJ de la current ce qui ne prends que quelques instants.
n°1417936
cycojesus
Mèo Lười
Posté le 29-04-2018 à 09:05:37  profilanswer
Sun Apr 29 00:07:10 UTC 2018
a/glibc-zoneinfo-2018d-noarch-3.txz:  Rebuilt.
  timeconfig: fixed some cosmetic issues with output spacing.
a/gpm-1.20.7-x86_64-7.txz:  Rebuilt.
  setup.mouse: fixed some cosmetic issues with output spacing.
a/pkgtools-15.0-noarch-10.txz:  Rebuilt.
  Fixed some cosmetic issues with output spacing.
ap/slackpkg-2.82.2-noarch-3.txz:  Rebuilt.
  Edited the slack-desc to be properly formed (and more accurate).
d/doxygen-1.8.14-x86_64-3.txz:  Rebuilt.
  Reverted patch that causes doxygen to segfault. Thanks to orbea.
l/libvisio-0.1.6-x86_64-4.txz:  Rebuilt.
  Removed build script kludge to work around doxygen segfault.
x/mesa-18.0.2-x86_64-1.txz:  Upgraded.
x/x11-skel-7.7-x86_64-3.txz:  Rebuilt.
  xwmconfig: fixed some cosmetic issues with output spacing.
Fri Apr 27 23:15:41 UTC 2018
ap/nano-2.9.6-x86_64-1.txz:  Upgraded.
e/emacs-25.3-x86_64-3.txz:  Rebuilt.
  Provide unversioned emacs-no-x11 and emacs-with-x11 symlinks.
  Thanks to madridsecreto.
n/openssh-7.7p1-x86_64-4.txz:  Rebuilt.
  Fixed tunnel forwarding with -w option. Thanks to Mario Preksavec.
x/urw-core35-fonts-otf-20170801_91edd6e_git-noarch-1.txz:  Upgraded.
n°1417937
cycojesus
Mèo Lười
Posté le 29-04-2018 à 09:09:40  profilanswer
C'est ce que je fait aussi, mais les versions stables sont maintenues et on peut tout à fait rester sur une version stable. Le UPGRADE.TXT sert à passer d'une stable à une autre.
n°1417977
cycojesus
Mèo Lười
Posté le 30-04-2018 à 07:01:10  profilanswer
Mon Apr 30 01:34:10 UTC 2018
a/kernel-generic-4.14.38-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.14.38-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.14.38-x86_64-1.txz:  Upgraded.
d/kernel-headers-4.14.38-x86-1.txz:  Upgraded.
k/kernel-source-4.14.38-noarch-1.txz:  Upgraded.
l/libwebp-1.0.0-x86_64-1.txz:  Upgraded.
n/samba-4.8.1-x86_64-1.txz:  Upgraded.
x/x11-skel-7.7-x86_64-4.txz:  Rebuilt.
  xwmconfig: typo fix in comment. (fortune -m "only code" )
n°1418018
cycojesus
Mèo Lười
Posté le 01-05-2018 à 08:56:38  profilanswer
Mon Apr 30 22:35:43 UTC 2018
a/xz-5.2.4-x86_64-1.txz:  Upgraded.
ap/sudo-1.8.23-x86_64-1.txz:  Upgraded.
l/libwmf-0.2.8.4-x86_64-8.txz:  Rebuilt.
  Patched denial of service and possible execution of arbitrary code
  security issues.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2004-0941
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2006-3376
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2007-0455
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2007-2756
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2007-3472
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2007-3473
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2007-3477
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2009-3546
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-0848
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-4588
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-4695
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-4696
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-10167
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-10168
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-9011
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-9317
  (* Security fix *)
  Symlink to system Type1 fonts.
l/libwmf-docs-0.2.8.4-noarch-7.txz:  Removed.
  There's no good reason to split this package.
xap/mozilla-firefox-59.0.3-x86_64-1.txz:  Upgraded.
  This release contains security fixes and improvements.
    https://www.mozilla.org/security/known-vulnerabilities/firefox.html
  (* Security fix *)
n°1418071
cycojesus
Mèo Lười
Posté le 02-05-2018 à 07:07:43  profilanswer
Tue May  1 20:43:20 UTC 2018
a/dbus-1.12.8-x86_64-1.txz:  Upgraded.
a/eudev-3.2.5-x86_64-3.txz:  Rebuilt.
  Don't treat bind actions as add/update actions. Fixes MTP with recent
  kernels. Thanks to DarkVision for the link to the patch.
a/xfsprogs-4.16.1-x86_64-1.txz:  Upgraded.
ap/hplip-3.18.4-x86_64-1.txz:  Upgraded.
ap/man-pages-4.16-noarch-1.txz:  Upgraded.
l/gegl-0.4.0-x86_64-1.txz:  Upgraded.
l/gexiv2-0.10.8-x86_64-1.txz:  Added.
  Required by gimp-2.10.0.
l/json-c-0.13.1_20180305-x86_64-1.txz:  Added.
  Looks like we're getting this package back since libmypaint needs it.
l/json-glib-1.4.2-x86_64-1.txz:  Added.
  Required by gegl-0.4.0 and gimp-2.10.0.
x/libinput-1.10.6-x86_64-1.txz:  Upgraded.
x/libmypaint-1.3.0-x86_64-1.txz:  Added.
x/mypaint-brushes-1.3.0-noarch-1.txz:  Added.
xap/gimp-2.10.0-x86_64-1.txz:  Upgraded.
GIMP
n°1418162
cycojesus
Mèo Lười
Posté le 03-05-2018 à 19:06:41  profilanswer
Thu May  3 13:44:01 UTC 2018
a/kernel-firmware-20180430_397a604-noarch-1.txz:  Upgraded.
a/kernel-generic-4.14.39-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.14.39-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.14.39-x86_64-1.txz:  Upgraded.
d/kernel-headers-4.14.39-x86-1.txz:  Upgraded.
k/kernel-source-4.14.39-noarch-1.txz:  Upgraded.
l/LibRaw-0.18.10-x86_64-1.txz:  Upgraded.
  Fixes some minor security issues.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-13735
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-14265
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-14348
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-10528
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-10529
  (* Security fix *)
l/libaio-0.3.111-x86_64-1.txz:  Upgraded.
n/dhcpcd-7.0.4-x86_64-1.txz:  Upgraded.
n/gnupg2-2.2.7-x86_64-1.txz:  Upgraded.
Message édité par cycojesus le 03-05-2018 à 21:08:59
n°1418180
cycojesus
Mèo Lười
Posté le 04-05-2018 à 07:13:15  profilanswer
Thu May  3 22:42:35 UTC 2018
l/imagemagick-6.9.9_42-x86_64-1.txz:  Upgraded.
l/seamonkey-solibs-2.49.3-x86_64-1.txz:  Upgraded.
xap/seamonkey-2.49.3-x86_64-1.txz:  Upgraded.
  This update contains security fixes and improvements.
  For more information (when it appears), see:
    http://www.seamonkey-project.org/releases/seamonkey2.49.3
  (* Security fix *)
n°1418210
cycojesus
Mèo Lười
Posté le 05-05-2018 à 07:51:00  profilanswer
Fri May  4 19:40:52 UTC 2018
d/python-2.7.15-x86_64-1.txz:  Upgraded.
  Updated to the latest 2.7.x release.
  This fixes some security issues in difflib and poplib (regexes vulnerable
  to denial of service attacks), as well as security issues with the bundled
  expat library.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-0876
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-0718
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-4472
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-5300
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-9063
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-9233
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1060
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1061
  (* Security fix *)
e/emacs-25.3-x86_64-4.txz:  Rebuilt.
  Recompiled against imagemagick-6.9.9_42.
l/virtuoso-ose-6.1.8-x86_64-9.txz:  Rebuilt.
x/xterm-333-x86_64-1.txz:  Upgraded.
xap/xine-lib-1.2.9-x86_64-3.txz:  Rebuilt.
xap/xlockmore-5.55-x86_64-1.txz:  Upgraded.
  Compiled against imagemagick-6.9.9_42.
n°1418379
cycojesus
Mèo Lười
Posté le 10-05-2018 à 08:55:06  profilanswer
Thu May 10 03:25:47 UTC 2018
a/aaa_elflibs-14.2-x86_64-36.txz:  Rebuilt.
a/glibc-zoneinfo-2018e-noarch-1.txz:  Upgraded.
a/kernel-firmware-20180507_8fc2d4e-noarch-1.txz:  Upgraded.
a/kernel-generic-4.14.40-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.14.40-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.14.40-x86_64-1.txz:  Upgraded.
a/openssl-solibs-1.1.0h-x86_64-1.txz:  Upgraded.
a/openssl10-solibs-1.0.2o-x86_64-1.txz:  Added.
  Added compatibility libraries for binaries that need to remain compiled
  against openssl-1.0.2.
ap/hplip-3.18.4-x86_64-2.txz:  Rebuilt.
  Recompiled against openssl-1.1.0h.
ap/mariadb-10.2.14-x86_64-3.txz:  Rebuilt.
d/git-2.17.0-x86_64-3.txz:  Rebuilt.
d/kernel-headers-4.14.40-x86-1.txz:  Upgraded.
d/perl-5.26.2-x86_64-3.txz:  Rebuilt.
d/python-2.7.15-x86_64-2.txz:  Rebuilt.
d/python3-3.6.5-x86_64-3.txz:  Rebuilt.
d/ruby-2.5.1-x86_64-3.txz:  Rebuilt.
d/rust-1.25.0-x86_64-3.txz:  Rebuilt.
k/kernel-source-4.14.40-noarch-1.txz:  Upgraded.
l/M2Crypto-0.27.0-x86_64-4.txz:  Rebuilt.
l/apr-util-1.6.1-x86_64-7.txz:  Rebuilt.
l/gnome-keyring-3.28.2-x86_64-1.txz:  Upgraded.
l/gvfs-1.36.2-x86_64-1.txz:  Upgraded.
l/libarchive-3.3.2-x86_64-3.txz:  Rebuilt.
l/libevent-2.1.8-x86_64-3.txz:  Rebuilt.
l/libimobiledevice-1.2.0-x86_64-4.txz:  Rebuilt.
l/librsvg-2.42.4-x86_64-1.txz:  Upgraded.
l/libsoup-2.62.2-x86_64-1.txz:  Upgraded.
l/libssh2-1.8.0-x86_64-3.txz:  Rebuilt.
l/libvncserver-0.9.11-x86_64-4.txz:  Rebuilt.
l/libzip-1.5.1-x86_64-3.txz:  Rebuilt.
l/neon-0.30.2-x86_64-1.txz:  Upgraded.
  Compiled against openssl-1.1.0h.
l/opusfile-0.9-x86_64-4.txz:  Rebuilt.
l/pulseaudio-11.1-x86_64-3.txz:  Rebuilt.
l/pycurl-7.43.0.1-x86_64-3.txz:  Rebuilt.
l/qca-2.1.3-x86_64-3.txz:  Rebuilt.
l/qt-4.8.7-x86_64-10.txz:  Rebuilt.
l/redland-1.0.17-x86_64-5.txz:  Rebuilt.
l/serf-1.3.9-x86_64-3.txz:  Rebuilt.
n/alpine-2.21-x86_64-3.txz:  Rebuilt.
n/bind-9.11.3-x86_64-3.txz:  Rebuilt.
n/curl-7.59.0-x86_64-4.txz:  Rebuilt.
n/cyrus-sasl-2.1.27_rc7-x86_64-1.txz:  Upgraded.
n/dovecot-2.3.1-x86_64-4.txz:  Rebuilt.
n/epic5-2.0.1-x86_64-5.txz:  Rebuilt.
n/fetchmail-6.3.26-x86_64-4.txz:  Rebuilt.
n/htdig-3.2.0b6-x86_64-6.txz:  Rebuilt.
n/httpd-2.4.33-x86_64-4.txz:  Rebuilt.
n/irssi-1.1.1-x86_64-3.txz:  Rebuilt.
n/lftp-4.8.3-x86_64-3.txz:  Rebuilt.
n/libgpg-error-1.31-x86_64-1.txz:  Upgraded.
n/links-2.14-x86_64-4.txz:  Rebuilt.
n/lynx-2.8.9dev.16-x86_64-2.txz:  Rebuilt.
n/mailx-12.5-x86_64-4.txz:  Rebuilt.
n/mutt-1.9.5-x86_64-3.txz:  Rebuilt.
n/net-snmp-5.7.3-x86_64-8.txz:  Rebuilt.
n/nmap-7.70-x86_64-3.txz:  Rebuilt.
n/ntp-4.2.8p11-x86_64-3.txz:  Rebuilt.
n/openldap-client-2.4.46-x86_64-3.txz:  Rebuilt.
n/openssh-7.7p1-x86_64-5.txz:  Rebuilt.
  Thanks to alienBOB for the patch.
n/openssl-1.1.0h-x86_64-1.txz:  Upgraded.
n/openssl10-1.0.2o-x86_64-1.txz:  Added.
  Added a compatibility development package for sources that need to be
  compiled against openssl-1.0.2o. To compile against openssl-1.0.2o, you'll
  need to add lines like this to the build script:
    export CFLAGS="$CFLAGS -I/usr/include/openssl-1.0"
    export LIBS="-L/usr/lib${LIBDIRSUFFIX}/openssl-1.0"
  Some sources may still make a mess of things, and in those cases it might be
  easiest to temporarily remove the openssl (1.1.0h) package while compiling,
  in addition to the changes shown above.
  The shared libraries in this package (and also duplicated in the
  openssl10-solibs package) have also been changed to use versioned symbols.
  Old binaries and libraries will continue to run linked with these new
  libraries, but it is suggested to recompile them if possible. This will
  prevent problems in case something ends up linking both the 1.0.2 and the
  1.1.0 OpenSSL libraries.
n/openvpn-2.4.6-x86_64-2.txz:  Rebuilt.
n/php-7.2.5-x86_64-2.txz:  Rebuilt.
n/pidentd-3.0.19-x86_64-4.txz:  Rebuilt.
n/popa3d-1.0.3-x86_64-3.txz:  Rebuilt.
n/postfix-3.3.0-x86_64-4.txz:  Rebuilt.
n/proftpd-1.3.6-x86_64-4.txz:  Rebuilt.
n/slrn-1.0.2-x86_64-3.txz:  Rebuilt.
n/snownews-1.5.13_20180507-x86_64-1.txz:  Upgraded.
n/stunnel-5.44-x86_64-3.txz:  Rebuilt.
n/tcpdump-4.9.2-x86_64-3.txz:  Rebuilt.
n/ulogd-2.0.5-x86_64-4.txz:  Rebuilt.
n/vsftpd-3.0.3-x86_64-5.txz:  Rebuilt.
n/wget-1.19.5-x86_64-1.txz:  Upgraded.
  Fixed a security issue where a malicious web server could inject arbitrary
  cookies into the cookie jar file.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-0494
  (* Security fix *)
n/wpa_supplicant-2.6-x86_64-5.txz:  Rebuilt.
t/fig2dev-3.2.7a-x86_64-1.txz:  Upgraded.
t/xfig-3.2.7a-x86_64-1.txz:  Upgraded.
x/mesa-18.0.3-x86_64-1.txz:  Upgraded.
xap/gftp-2.0.19-x86_64-7.txz:  Rebuilt.
xap/gkrellm-2.3.10-x86_64-4.txz:  Rebuilt.
xap/gnuplot-5.2.3-x86_64-1.txz:  Upgraded.
xap/hexchat-2.14.1-x86_64-3.txz:  Rebuilt.
xap/mozilla-firefox-60.0-x86_64-1.txz:  Upgraded.
    https://www.mozilla.org/en-US/security/advisories/mfsa2018-11/
  (* Security fix *)
xap/rdesktop-1.8.3-x86_64-3.txz:  Rebuilt.
xap/sane-1.0.27-x86_64-3.txz:  Rebuilt.
xap/x3270-3.3.12ga7-x86_64-4.txz:  Rebuilt.
extra/sendmail/sendmail-8.15.2-x86_64-3.txz:  Rebuilt.
extra/sendmail/sendmail-cf-8.15.2-noarch-3.txz:  Rebuilt.
à tremper dans la cafetière
n°1418395
cycojesus
Mèo Lười
Posté le 10-05-2018 à 19:12:24  profilanswer
Thu May 10 13:17:20 UTC 2018
n/wpa_supplicant-2.6-x86_64-6.txz:  Rebuilt.
  Drop the use-system-openssl-ciphers patch. Thanks to GazL.
n°1418408
cycojesus
Mèo Lười
Posté le 11-05-2018 à 06:56:45  profilanswer
Thu May 10 21:01:11 UTC 2018
a/aaa_elflibs-14.2-x86_64-37.txz:  Rebuilt.
  Restored libpng14.so.14.
n/nghttp2-1.32.0-x86_64-1.txz:  Upgraded.
x/libdrm-2.4.92-x86_64-1.txz:  Upgraded.
x/xf86-video-intel-git_20180315_e7bfc906-x86_64-1.txz:  Upgraded.
x/xorg-server-1.20.0-x86_64-1.txz:  Upgraded.
x/xorg-server-xephyr-1.20.0-x86_64-1.txz:  Upgraded.
x/xorg-server-xnest-1.20.0-x86_64-1.txz:  Upgraded.
x/xorg-server-xvfb-1.20.0-x86_64-1.txz:  Upgraded.
n°1418462
macomboh
Posté le 12-05-2018 à 15:38:55  profilanswer
ATTENTION ATTENTION
IL est fortement déconseillé d'upgrader xorg en 1.20
surtout si l'on a une carte NVIDIA (driver proprio ou NOUVEAU)
les modules ABI ne sont pas à jour  et xorg ne se lancera pas  :fou:  :fou:  :fou:
le paramètre -ignoreABI ds le lancement de X semble inopérant !
Message édité par macomboh le 12-05-2018 à 15:39:27
n°1418471
cycojesus
Mèo Lười
Posté le 12-05-2018 à 18:32:29  profilanswer
Sat May 12 00:28:18 UTC 2018
Where possible, the driver packages for X11 have been recompiled. However,
there were some (xf86-video-geode, xf86-video-tseng, xf86-video-sis,
xf86-video-savage, xf86-video-s3virge, xf86-video-rendition, xf86-video-r128,
and xf86-video-mach64) that would not compile against xorg-server-1.20.0 and
for which no patches seem to be available. Is anyone still using those, or are
they finally obsolete? I'll hold off on removing them until I can find out one
way or the other.
a/aaa_elflibs-14.2-x86_64-38.txz:  Rebuilt.
a/bzip2-1.0.6-x86_64-3.txz:  Rebuilt.
  Added bzip2.pc.
ap/ghostscript-9.23-x86_64-3.txz:  Rebuilt.
  Recompiled against libidn-1.35.
d/rust-1.26.0-x86_64-1.txz:  Upgraded.
l/libidn-1.35-x86_64-1.txz:  Upgraded.
l/loudmouth-1.5.3-x86_64-3.txz:  Rebuilt.
n/NetworkManager-1.10.8-x86_64-1.txz:  Upgraded.
n/bind-9.11.3-x86_64-4.txz:  Rebuilt.
n/lynx-2.8.9dev.18-x86_64-1.txz:  Upgraded.
  Compiled against libidn-1.35.
n/mcabber-1.0.5-x86_64-4.txz:  Rebuilt.
n/mutt-1.9.5-x86_64-4.txz:  Rebuilt.
x/xf86-input-acecad-1.5.0-x86_64-12.txz:  Rebuilt.
x/xf86-input-evdev-2.10.5-x86_64-3.txz:  Rebuilt.
x/xf86-input-joystick-1.6.3-x86_64-3.txz:  Rebuilt.
x/xf86-input-keyboard-1.9.0-x86_64-3.txz:  Rebuilt.
x/xf86-input-libinput-0.27.1-x86_64-3.txz:  Rebuilt.
x/xf86-input-mouse-1.9.2-x86_64-3.txz:  Rebuilt.
x/xf86-input-penmount-1.5.0-x86_64-12.txz:  Rebuilt.
x/xf86-input-synaptics-1.9.0-x86_64-3.txz:  Rebuilt.
x/xf86-input-vmmouse-13.1.0-x86_64-7.txz:  Rebuilt.
x/xf86-input-void-1.4.0-x86_64-12.txz:  Rebuilt.
x/xf86-input-wacom-0.36.1-x86_64-3.txz:  Rebuilt.
x/xf86-video-amdgpu-18.0.1-x86_64-3.txz:  Rebuilt.
x/xf86-video-apm-1.2.5-x86_64-11.txz:  Rebuilt.
x/xf86-video-ark-0.7.5-x86_64-11.txz:  Rebuilt.
x/xf86-video-ast-1.1.5-x86_64-5.txz:  Rebuilt.
x/xf86-video-ati-18.0.1-x86_64-3.txz:  Rebuilt.
x/xf86-video-chips-1.2.7-x86_64-3.txz:  Rebuilt.
x/xf86-video-cirrus-1.5.3-x86_64-5.txz:  Rebuilt.
x/xf86-video-dummy-0.3.8-x86_64-3.txz:  Rebuilt.
x/xf86-video-glint-1.2.9-x86_64-3.txz:  Rebuilt.
x/xf86-video-i128-1.3.6-x86_64-11.txz:  Rebuilt.
x/xf86-video-i740-1.3.6-x86_64-3.txz:  Rebuilt.
x/xf86-video-mga-1.6.5-x86_64-3.txz:  Rebuilt.
x/xf86-video-neomagic-1.2.9-x86_64-5.txz:  Rebuilt.
x/xf86-video-nouveau-1.0.15-x86_64-3.txz:  Rebuilt.
x/xf86-video-nv-2.1.21-x86_64-3.txz:  Rebuilt.
x/xf86-video-openchrome-0.6.0-x86_64-3.txz:  Rebuilt.
x/xf86-video-s3-0.6.5-x86_64-11.txz:  Rebuilt.
x/xf86-video-siliconmotion-1.7.9-x86_64-3.txz:  Rebuilt.
x/xf86-video-sisusb-0.9.7-x86_64-3.txz:  Rebuilt.
x/xf86-video-tdfx-1.4.7-x86_64-3.txz:  Rebuilt.
x/xf86-video-tga-1.2.2-x86_64-11.txz:  Rebuilt.
x/xf86-video-trident-1.3.8-x86_64-3.txz:  Rebuilt.
x/xf86-video-v4l-0.2.0-x86_64-16.txz:  Rebuilt.
x/xf86-video-vboxvideo-1.0.0-x86_64-3.txz:  Rebuilt.
x/xf86-video-vesa-2.4.0-x86_64-3.txz:  Rebuilt.
x/xf86-video-vmware-13.2.1-x86_64-7.txz:  Rebuilt.
x/xf86-video-voodoo-1.2.5-x86_64-12.txz:  Rebuilt.
xap/pidgin-2.13.0-x86_64-3.txz:  Rebuilt.
n°1418586
cycojesus
Mèo Lười
Posté le 15-05-2018 à 07:16:38  profilanswer
Mon May 14 19:48:52 UTC 2018
a/openssl-solibs-1.1.0h-x86_64-2.txz:  Rebuilt.
ap/gutenprint-5.2.14-x86_64-2.txz:  Rebuilt.
  Rebuilt without the gimp2 print plugin (not compatible with gimp-2.10.0).
ap/vim-8.0.1839-x86_64-1.txz:  Upgraded.
n/openssl-1.1.0h-x86_64-2.txz:  Rebuilt.
  Fixed missing quotes in c_rehash. Thanks to Matteo Bernardini.
  After updating this package, it may be required to reinstall the
  ca-certificates package (or run: update-ca-certificates --fresh).
x/libdmx-1.1.4-x86_64-1.txz:  Upgraded.
xap/vim-gvim-8.0.1839-x86_64-1.txz:  Upgraded.
Code :
  1. update-ca-certificates --fresh
n°1418704
cycojesus
Mèo Lười
Posté le 17-05-2018 à 09:03:21  profilanswer
Thu May 17 04:13:16 UTC 2018
a/e2fsprogs-1.44.2-x86_64-1.txz:  Upgraded.
a/kernel-generic-4.14.41-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.14.41-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.14.41-x86_64-1.txz:  Upgraded.
a/usbutils-010-x86_64-1.txz:  Upgraded.
ap/lsscsi-0.29-x86_64-1.txz:  Upgraded.
ap/nano-2.9.7-x86_64-1.txz:  Upgraded.
d/kernel-headers-4.14.41-x86-1.txz:  Upgraded.
k/kernel-source-4.14.41-noarch-1.txz:  Upgraded.
l/libgphoto2-2.5.18-x86_64-1.txz:  Upgraded.
l/libimobiledevice-1.2.0-x86_64-5.txz:  Rebuilt.
  Patch to fix double free with OpenSSL-1.1.x. Thanks to ill323.
n/curl-7.60.0-x86_64-1.txz:  Upgraded.
  This release contains security fixes:
  FTP: shutdown response buffer overflow
  RTSP: bad headers buffer over-read
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1000300
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1000301
  (* Security fix *)
n/links-2.16-x86_64-1.txz:  Upgraded.
x/xdg-utils-1.1.3-noarch-1.txz:  Upgraded.
xfce/xfce4-terminal-0.8.7.4-x86_64-1.txz:  Upgraded.
extra/tigervnc/tigervnc-1.8.0-x86_64-5.txz:  Rebuilt.
  Patched and recompiled for xorg-server-1.20.0. Thanks to Matteo Bernardini.
pasture/php-5.6.36-x86_64-1.txz:  Added.
  Since some things still require php-5.6, here's an alternate package
  compiled against openssl-1.1. Thanks to Darth Vader.
nom nom nom
n°1418747
cycojesus
Mèo Lười
Posté le 18-05-2018 à 08:56:45  profilanswer
Thu May 17 20:49:42 UTC 2018
l/babl-0.1.48-x86_64-1.txz:  Upgraded.
l/gegl-0.4.2-x86_64-1.txz:  Upgraded.
l/gst-plugins-base-1.14.1-x86_64-1.txz:  Upgraded.
l/gst-plugins-good-1.14.1-x86_64-1.txz:  Upgraded.
l/gst-plugins-libav-1.14.1-x86_64-1.txz:  Upgraded.
l/gstreamer-1.14.1-x86_64-1.txz:  Upgraded.
n/ca-certificates-20180409-noarch-1.txz:  Upgraded.
n/samba-4.8.2-x86_64-1.txz:  Upgraded.
x/libinput-1.10.7-x86_64-1.txz:  Upgraded.
x/xf86-video-vmware-13.3.0-x86_64-1.txz:  Upgraded.
xap/mozilla-firefox-60.0.1-x86_64-1.txz:  Upgraded.
extra/pure-alsa-system/gst-plugins-good-1.14.1-x86_64-1_alsa.txz:  Upgraded.
n°1418836
cycojesus
Mèo Lười
Posté le 19-05-2018 à 08:43:10  profilanswer
Sat May 19 04:24:47 UTC 2018
a/aaa_elflibs-14.2-x86_64-39.txz:  Rebuilt.
  Restored libstdc++.so.5. Upgraded libidn and libidn2.
ap/vim-8.1.0001-x86_64-1.txz:  Upgraded.
l/libidn2-2.0.5-x86_64-1.txz:  Upgraded.
x/mesa-18.0.4-x86_64-1.txz:  Upgraded.
x/xf86-video-mach64-6.9.6-x86_64-1.txz:  Upgraded.
x/xf86-video-rendition-4.2.7-x86_64-1.txz:  Upgraded.
xap/vim-gvim-8.1.0001-x86_64-1.txz:  Upgraded.
n°1418978
cycojesus
Mèo Lười
Posté le 23-05-2018 à 11:13:47  profilanswer
Wed May 23 04:42:29 UTC 2018
a/kernel-firmware-20180518_2a9b2cf-noarch-1.txz:  Upgraded.
a/kernel-generic-4.14.43-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.14.43-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.14.43-x86_64-1.txz:  Upgraded.
a/pkgtools-15.0-noarch-11.txz:  Rebuilt.
  installpkg: Implement locking to prevent screen output or install script
  collisions if multiple copies of installpkg are running simultaneously.
  installpkg: Use $(mcookie) instead of $$. Fall back on $$ if mcookie is
  not available.
  makepkg: Add --compress option, usually used to change the preset
  compression level or block size. Thanks to shasta.
a/procps-ng-3.3.15-x86_64-1.txz:  Upgraded.
  Shared library .so-version bump.
  This update fixes bugs and security issues:
  library: Fix integer overflow and LPE in file2strvec
  library: Use size_t for alloc functions
  pgrep: Fix stack-based buffer overflow
  ps: Fix buffer overflow in output buffer, causing DOS
  top: Don't use cwd for location of config
  For more information, see:
    https://www.qualys.com/2018/05/17/procps-ng-audit-report-advisory.txt
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1124
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1126
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1125
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1123
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1122
  (* Security fix *)
ap/cups-filters-1.20.3-x86_64-2.txz:  Rebuilt.
  Recompiled against poppler-0.65.0.
ap/mariadb-10.2.15-x86_64-1.txz:  Upgraded.
  This update fixes bugs and security issues.
    https://mariadb.com/kb/en/mariadb-10215-release-notes/
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2786
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2759
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2777
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2810
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2782
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2784
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2787
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2766
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2755
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2819
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2817
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2761
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2781
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2771
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2813
  (* Security fix *)
ap/vim-8.1.0016-x86_64-1.txz:  Upgraded.
d/Cython-0.28.2-x86_64-1.txz:  Upgraded.
d/cmake-3.11.2-x86_64-1.txz:  Upgraded.
d/kernel-headers-4.14.43-x86-1.txz:  Upgraded.
d/meson-0.46.1-x86_64-1.txz:  Upgraded.
k/kernel-source-4.14.43-noarch-1.txz:  Upgraded.
  Changes to .config (thanks to tumble):
   TCP_CONG_ADVANCED n -> y
  +DEFAULT_CUBIC y
  +DEFAULT_RENO n
  +TCP_CONG_BBR m
  +TCP_CONG_BIC m
  +TCP_CONG_CDG m
  +TCP_CONG_DCTCP m
  +TCP_CONG_HSTCP m
  +TCP_CONG_HTCP m
  +TCP_CONG_HYBLA m
  +TCP_CONG_ILLINOIS m
  +TCP_CONG_LP m
  +TCP_CONG_NV m
  +TCP_CONG_SCALABLE m
  +TCP_CONG_VEGAS m
  +TCP_CONG_VENO m
  +TCP_CONG_WESTWOOD m
  +TCP_CONG_YEAH m
kde/calligra-2.9.11-x86_64-21.txz:  Rebuilt.
l/QScintilla-2.10.4-x86_64-1.txz:  Upgraded.
l/babl-0.1.50-x86_64-1.txz:  Upgraded.
l/glib-networking-2.56.1-x86_64-1.txz:  Upgraded.
l/poppler-0.65.0-x86_64-1.txz:  Upgraded.
l/vte-0.52.2-x86_64-1.txz:  Upgraded.
n/crda-3.18-x86_64-7.txz:  Rebuilt.
  Upgraded to wireless-regdb-2018.05.09.
n/mutt-1.10.0-x86_64-1.txz:  Upgraded.
n/postfix-3.3.1-x86_64-1.txz:  Upgraded.
n/stunnel-5.45-x86_64-1.txz:  Upgraded.
t/texlive-2017.171108-x86_64-6.txz:  Rebuilt.
x/intel-gpu-tools-1.22-x86_64-3.txz:  Rebuilt.
  Recompiled against procps-ng-3.3.15.
xap/gimp-2.10.2-x86_64-1.txz:  Upgraded.
xap/mozilla-thunderbird-52.8.0-x86_64-1.txz:  Upgraded.
    https://www.mozilla.org/en-US/thunderbird/52.8.0/releasenotes/
    https://www.mozilla.org/en-US/security/advisories/mfsa2018-13/
  (* Security fix *)
xap/vim-gvim-8.1.0016-x86_64-1.txz:  Upgraded.
xfce/tumbler-0.2.1-x86_64-3.txz:  Rebuilt.
n°1419159
cycojesus
Mèo Lười
Posté le 26-05-2018 à 07:18:50  profilanswer
Fri May 25 23:29:36 UTC 2018
a/glibc-zoneinfo-2018e-noarch-2.txz:  Rebuilt.
  Handle removal of US/Pacific-New timezone. If we see that the machine is
  using this, it will be automatically switched to US/Pacific.
a/kernel-firmware-20180525_7518922-noarch-1.txz:  Upgraded.
a/kernel-generic-4.14.44-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.14.44-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.14.44-x86_64-1.txz:  Upgraded.
a/pkgtools-15.0-noarch-12.txz:  Rebuilt.
  installpkg: Suppport --terselength to set the maximum length of a line
  output in --terse mode.
  removepkg: Use file locking to allow only one instance at a time of ldconfig.
  upgradepkg: Added --terse mode to output one line per upgraded package.
  upgradepkg: Suppport --terselength to set the maximum length of a line
ap/hplip-3.18.5-x86_64-1.txz:  Upgraded.
ap/sc-7.16-x86_64-6.txz:  Removed.
ap/sc-im-0.7.0-x86_64-1.txz:  Added.
  This is an improved version of the SC spreadsheet program.
d/kernel-headers-4.14.44-x86-1.txz:  Upgraded.
d/parallel-20180522-noarch-1.txz:  Upgraded.
k/kernel-source-4.14.44-noarch-1.txz:  Upgraded.
l/libunistring-0.9.10-x86_64-1.txz:  Upgraded.
l/mozilla-nss-3.37.1-x86_64-1.txz:  Upgraded.
n/nn-6.7.3-x86_64-6.txz:  Rebuilt.
  Don't include /etc/nntpserver.new - the network-scripts package already
  ships a copy of this for all the packages that use it.
n/php-7.2.6-x86_64-1.txz:  Upgraded.
n°1419250
cycojesus
Mèo Lười
Posté le 28-05-2018 à 23:06:03  profilanswer
Mon May 28 19:12:29 UTC 2018
a/pkgtools-15.0-noarch-13.txz:  Rebuilt.
  installpkg: default line length for --terselength is the number of columns.
  removepkg: added --terse mode.
  upgradepkg: default line length for --terselength is the number of columns.
  upgradepkg: accept -option in addition to --option.
ap/vim-8.1.0026-x86_64-1.txz:  Upgraded.
d/bison-3.0.5-x86_64-1.txz:  Upgraded.
e/emacs-26.1-x86_64-1.txz:  Upgraded.
kde/kopete-4.14.3-x86_64-8.txz:  Rebuilt.
n/conntrack-tools-1.4.5-x86_64-1.txz:  Upgraded.
n/libnetfilter_conntrack-1.0.7-x86_64-1.txz:  Upgraded.
n/libnftnl-1.1.0-x86_64-1.txz:  Upgraded.
n/links-2.16-x86_64-2.txz:  Rebuilt.
  Rebuilt to enable X driver for -g mode.
n/lynx-2.8.9dev.19-x86_64-1.txz:  Upgraded.
n/nftables-0.8.5-x86_64-1.txz:  Upgraded.
n/p11-kit-0.23.11-x86_64-1.txz:  Upgraded.
n/ulogd-2.0.7-x86_64-1.txz:  Upgraded.
n/whois-5.3.1-x86_64-1.txz:  Upgraded.
xap/network-manager-applet-1.8.12-x86_64-1.txz:  Upgraded.
xap/vim-gvim-8.1.0026-x86_64-1.txz:  Upgraded.
Emacs :love:  :bounce:
n°1419331
cycojesus
Mèo Lười
Posté le 31-05-2018 à 08:53:17  profilanswer
Thu May 31 04:55:33 UTC 2018
a/kernel-generic-4.14.47-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.14.47-x86_64-1.txz:  Upgraded.
  SCSI_DPT_I2O m -> y
  SCSI_ISCI m -> y (thanks to wael_h)
a/kernel-modules-4.14.47-x86_64-1.txz:  Upgraded.
a/pkgtools-15.0-noarch-14.txz:  Rebuilt.
  installpkg: rarely, an uncompressed size that's not quite to the next level
  (e.g., 1020K) will exceed the expected length and cause a --terse line to
  be one character longer than --terselength. Chop lines to --terselength
  before outputting them. The trailing ']' might be dropped, but no big deal.
ap/slackpkg-2.83.0-noarch-1.txz:  Upgraded.
  Release 2.83.0; thanks to orbea, Didier Spaier, burdi01, David Allen,
  Eduard Rozenberg, and Stuart Winter for various fixes and enhancements.
  Allow using vimdiff to compare .new and original files
  Numerous fixups for alternate $ROOT
  .new config files are sorted so that display order should be consistent
  among multiple machines
  Abort operation if system date is near epoch (mostly relevant for ARM
  machines and others with no RTC)
  Update Slackware ARM gpg key
  Update Slackware ARM mirror list
  No longer offer to run lilo - simply advise user that the kernel image has
  changed and give advice, but also require a keypress to (hopefully) confirm
  that the message was actually read
  mandoc lint fixes to slackpkg.8
  Warn user if a -current mirror is selected (but only warn once)
d/git-2.17.1-x86_64-1.txz:  Upgraded.
d/kernel-headers-4.14.47-x86-1.txz:  Upgraded.
d/rust-1.26.1-x86_64-1.txz:  Upgraded.
k/kernel-source-4.14.47-noarch-1.txz:  Upgraded.
l/fftw-3.3.8-x86_64-1.txz:  Upgraded.
l/imagemagick-6.9.9_48-x86_64-1.txz:  Upgraded.
n/network-scripts-15.0-noarch-8.txz:  Rebuilt.
  Allow setting an interface in promiscuous mode; this is needed for networking
  to function properly in containers
  Fixup setting of IPALIASES (allow non /32 masks; not only is the /32 mask not
  required and even undesirable in some cases, this makes ipv6 support easier
  to integrate (and Darren is working on that as well)
  Thanks to Darren Austin.
n/stunnel-5.46-x86_64-1.txz:  Upgraded.
n/ulogd-2.0.7-x86_64-2.txz:  Rebuilt.
  Fixed empty logrotate file.
x/xorg-server-1.20.0-x86_64-2.txz:  Rebuilt.
  Patched to fix nouveau segfault. Thanks to Rod3775 for the patch.
x/xorg-server-xephyr-1.20.0-x86_64-2.txz:  Rebuilt.
x/xorg-server-xnest-1.20.0-x86_64-2.txz:  Rebuilt.
x/xorg-server-xvfb-1.20.0-x86_64-2.txz:  Rebuilt.
xap/network-manager-applet-1.8.12-x86_64-2.txz:  Rebuilt.
  Patched crash bug. Thanks to gmgf.
slackpkgplus est malade maintenant Installe 6mt https://sourceforge.net/projects/slackpkgplus/files/ si tu t'en fiche de $ROOT pour slackpkg mais que t'aimes slackpkg+
Message édité par cycojesus le 31-05-2018 à 12:25:11
n°1419406
cycojesus
Mèo Lười
Posté le 02-06-2018 à 09:09:03  profilanswer
Fri Jun  1 21:28:10 UTC 2018
a/mcelog-158-x86_64-1.txz:  Upgraded.
a/pkgtools-15.0-noarch-15.txz:  Rebuilt.
  installpkg, upgradepkg: test tty -s before using tput. Thanks to aaazen.
d/cmake-3.11.3-x86_64-1.txz:  Upgraded.
l/imagemagick-6.9.9_49-x86_64-1.txz:  Upgraded.
  Support OpenMP. This had been disabled years ago due to issues with perl
  modules, but probably that's been fixed by now. Thanks to olear.
l/pygobject3-3.28.3-x86_64-1.txz:  Upgraded.
x/xf86-input-evdev-2.10.6-x86_64-1.txz:  Upgraded.
x/xf86-input-synaptics-1.9.1-x86_64-1.txz:  Upgraded.
xap/fvwm-2.6.8-x86_64-1.txz:  Upgraded.
extra/xf86-video-fbdev/xf86-video-fbdev-0.5.0-x86_64-1.txz:  Upgraded.
n°1419446
cycojesus
Mèo Lười
Posté le 03-06-2018 à 09:37:50  profilanswer
Sun Jun  3 05:14:12 UTC 2018
a/mkinitrd-1.4.11-x86_64-7.txz:  Rebuilt.
  Provide absolute path to depmod. Thanks to andygoth.
ap/mariadb-10.3.7-x86_64-1.txz:  Upgraded.
  libmysqld.so.19 was renamed to libmariadbd.so.19.
  Anything linking to libmysqld.so.19 will need to be recompiled.
ap/nano-2.9.8-x86_64-1.txz:  Upgraded.
ap/sysstat-11.6.4-x86_64-1.txz:  Upgraded.
kde/amarok-2.9.0-x86_64-3.txz:  Rebuilt.
  Recompiled to link to libmariadbd.so.19.
l/librsvg-2.42.5-x86_64-1.txz:  Upgraded.
n/p11-kit-0.23.12-x86_64-1.txz:  Upgraded.
x/mesa-18.1.1-x86_64-1.txz:  Upgraded.
n°1419500
cycojesus
Mèo Lười
Posté le 05-06-2018 à 11:50:46  profilanswer
Tue Jun  5 05:24:22 UTC 2018
ap/mc-4.8.21-x86_64-1.txz:  Upgraded.
ap/soma-3.0.4-noarch-1.txz:  Upgraded.
d/perl-5.26.2-x86_64-4.txz:  Rebuilt.
  Added IO-Socket-SSL-2.056 and Net-SSLeay-1.85. Thanks to Xsane.
n/ModemManager-1.8.0-x86_64-1.txz:  Upgraded.
n/bluez-5.50-x86_64-1.txz:  Upgraded.
n/dhcpcd-7.0.5b-x86_64-1.txz:  Upgraded.
xap/gnuplot-5.2.4-x86_64-1.txz:  Upgraded.
mc
n°1419547
cycojesus
Mèo Lười
Posté le 07-06-2018 à 07:03:07  profilanswer
Wed Jun  6 22:19:01 UTC 2018
a/bash-4.4.023-x86_64-1.txz:  Upgraded.
a/kernel-firmware-20180604_1fa9ce3-noarch-1.txz:  Upgraded.
a/kernel-generic-4.14.48-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.14.48-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.14.48-x86_64-1.txz:  Upgraded.
ap/cups-2.2.8-x86_64-1.txz:  Upgraded.
ap/ghostscript-fonts-std-8.11-noarch-3.txz:  Rebuilt.
  Rebuilt this and many other font packages or packages with build scripts
  that call mkfontdir or mkfontscale to suppress any error messages caused
  by collisions if another package installation is writing files to the
  same font directories when those utilities are run. In that case, the
  other package will also be running mkfontdir/mkfontscale after the files
  are installed, so any issues will be cleaned up then. Last one out turn
  off the lights, so to speak.
ap/sqlite-3.24.0-x86_64-1.txz:  Upgraded.
ap/terminus-font-4.40-noarch-3.txz:  Rebuilt.
d/kernel-headers-4.14.48-x86-1.txz:  Upgraded.
d/rust-1.26.2-x86_64-1.txz:  Upgraded.
k/kernel-source-4.14.48-noarch-1.txz:  Upgraded.
l/elfutils-0.171-x86_64-1.txz:  Upgraded.
l/harfbuzz-1.7.7-x86_64-1.txz:  Upgraded.
l/mozilla-nss-3.37.3-x86_64-1.txz:  Upgraded.
l/readline-7.0.005-x86_64-1.txz:  Upgraded.
x/dejavu-fonts-ttf-2.37-noarch-4.txz:  Rebuilt.
x/font-adobe-100dpi-1.0.3-noarch-3.txz:  Rebuilt.
x/font-adobe-75dpi-1.0.3-noarch-3.txz:  Rebuilt.
x/font-adobe-utopia-100dpi-1.0.4-noarch-3.txz:  Rebuilt.
x/font-adobe-utopia-75dpi-1.0.4-noarch-3.txz:  Rebuilt.
x/font-adobe-utopia-type1-1.0.4-noarch-3.txz:  Rebuilt.
x/font-arabic-misc-1.0.3-noarch-3.txz:  Rebuilt.
x/font-bh-100dpi-1.0.3-noarch-3.txz:  Rebuilt.
x/font-bh-75dpi-1.0.3-noarch-3.txz:  Rebuilt.
x/font-bh-lucidatypewriter-100dpi-1.0.3-noarch-3.txz:  Rebuilt.
x/font-bh-lucidatypewriter-75dpi-1.0.3-noarch-3.txz:  Rebuilt.
x/font-bh-ttf-1.0.3-noarch-3.txz:  Rebuilt.
x/font-bh-type1-1.0.3-noarch-3.txz:  Rebuilt.
x/font-bitstream-100dpi-1.0.3-noarch-3.txz:  Rebuilt.
x/font-bitstream-75dpi-1.0.3-noarch-3.txz:  Rebuilt.
x/font-bitstream-speedo-1.0.2-noarch-3.txz:  Rebuilt.
x/font-bitstream-type1-1.0.3-noarch-3.txz:  Rebuilt.
x/font-cronyx-cyrillic-1.0.3-noarch-3.txz:  Rebuilt.
x/font-cursor-misc-1.0.3-noarch-3.txz:  Rebuilt.
x/font-daewoo-misc-1.0.3-noarch-3.txz:  Rebuilt.
x/font-dec-misc-1.0.3-noarch-3.txz:  Rebuilt.
x/font-ibm-type1-1.0.3-noarch-3.txz:  Rebuilt.
x/font-isas-misc-1.0.3-noarch-3.txz:  Rebuilt.
x/font-jis-misc-1.0.3-noarch-3.txz:  Rebuilt.
x/font-micro-misc-1.0.3-noarch-3.txz:  Rebuilt.
x/font-misc-cyrillic-1.0.3-noarch-3.txz:  Rebuilt.
x/font-misc-ethiopic-1.0.3-noarch-3.txz:  Rebuilt.
x/font-misc-meltho-1.0.3-noarch-3.txz:  Rebuilt.
x/font-misc-misc-1.1.2-noarch-3.txz:  Rebuilt.
x/font-mutt-misc-1.0.3-noarch-3.txz:  Rebuilt.
x/font-schumacher-misc-1.1.2-noarch-3.txz:  Rebuilt.
x/font-screen-cyrillic-1.0.4-noarch-3.txz:  Rebuilt.
x/font-sony-misc-1.0.3-noarch-3.txz:  Rebuilt.
x/font-sun-misc-1.0.3-noarch-3.txz:  Rebuilt.
x/font-winitzki-cyrillic-1.0.3-noarch-3.txz:  Rebuilt.
x/font-xfree86-type1-1.0.4-noarch-3.txz:  Rebuilt.
x/liberation-fonts-ttf-2.00.1-noarch-3.txz:  Rebuilt.
x/libinput-1.11.0-x86_64-1.txz:  Upgraded.
x/sazanami-fonts-ttf-20040629-noarch-3.txz:  Rebuilt.
x/sinhala_lklug-font-ttf-20060929-noarch-3.txz:  Rebuilt.
x/tibmachuni-font-ttf-1.901b-noarch-3.txz:  Rebuilt.
x/ttf-indic-fonts-0.5.14-noarch-3.txz:  Rebuilt.
x/ttf-tlwg-0.6.4-noarch-3.txz:  Rebuilt.
x/urw-core35-fonts-otf-20170801_91edd6e_git-noarch-2.txz:  Rebuilt.
x/wqy-zenhei-font-ttf-0.8.38_1-noarch-6.txz:  Rebuilt.
xap/mozilla-firefox-60.0.2-x86_64-1.txz:  Upgraded.
  (* Security fix *)
xap/x3270-3.3.12ga7-x86_64-5.txz:  Rebuilt.
[:gorex]
 Page :   1  2  3  4  5  ..  76  77  78  ..  109  110  111  112  113  114
Slackware 9.0[slackware] Suppression de terminaux virtuels ?
!! Configuration reseaux, slackware 9 !!Installer slackware 9.0 par ftp (boot disquette)
[Pb] Installation new HDD sous slackware 8.0[RESOLU] Pb d'execution mysql sur slackware ...
Slackware 9 du pur bonheurMonter une partition NTFS sous linux (slackware 9.0)
Slackware 9.0 Finale OUTJe sens que je vais quitter Slackware (pas en serv)
Plus de sujets relatifs à : [SLACKWARE] du présent - 15.0
