11040 connectés
La 15.0 est là (en vrai !)
Les invités peuvent voter
 Page :   1  2  3  4  5  ..  75  76  77  ..  109  110  111  112  113  114
[SLACKWARE] du présent - 15.0
n°1415043
cycojesus
Mèo Lười
Posté le 23-02-2018 à 09:22:03  profilanswer
Thu Feb 22 19:36:43 UTC 2018
a/pkgtools-15.0-noarch-5.txz:  Rebuilt.
  setup.services: add rc.smartd to setup menu.
a/smartmontools-6.6-x86_64-2.txz:  Rebuilt.
  Add rc.smartd init script.
a/sysvinit-scripts-2.1-noarch-6.txz:  Rebuilt.
  rc.M: start rc.smartd if it is executable.
d/meson-0.44.1-x86_64-1.txz:  Upgraded.
l/system-config-printer-1.5.11-x86_64-2.txz:  Rebuilt.
  Applied upstream patch to fix the auth dialog.
n/postfix-3.3.0-x86_64-1.txz:  Upgraded.
Chết rồi ! ✍ ⌥⌘ http://codeberg.org/gwh
n°1415131
cycojesus
Mèo Lười
Posté le 24-02-2018 à 18:34:27  profilanswer
Sat Feb 24 07:41:40 UTC 2018
a/kernel-firmware-20180222_7344ec9-noarch-1.txz:  Upgraded.
a/kernel-generic-4.14.21-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.14.21-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.14.21-x86_64-1.txz:  Upgraded.
d/kernel-headers-4.14.21-x86-1.txz:  Upgraded.
k/kernel-source-4.14.21-noarch-1.txz:  Upgraded.
l/SDL2_mixer-2.0.2-x86_64-2.txz:  Rebuilt.
  Recompiled to use FluidSynth.
l/fluidsynth-1.1.9-x86_64-1.txz:  Added.
l/notify-python-0.1.1-x86_64-5.txz:  Removed.
l/python-notify2-0.3.1-x86_64-1.txz:  Added.
l/sdl-1.2.15-x86_64-6.txz:  Rebuilt.
  Recompiled so that libSDL_mixer will use FluidSynth.
n/proftpd-1.3.6-x86_64-2.txz:  Rebuilt.
  Support ProFTPD modules mod_sftp and mod_facl.
n/wget-1.19.4-x86_64-2.txz:  Rebuilt.
  Applied upstream patch to fix logging in background mode.
  Thanks to Willy Sudiarto Raharjo.
x/ttf-tlwg-0.6.4-noarch-1.txz:  Added.
xap/audacious-plugins-3.9-x86_64-3.txz:  Rebuilt.
  Recompiled to add a FluidSynth-based MIDI plugin.
isolinux/initrd.img:  Rebuilt.
kernels/*:  Upgraded.
usb-and-pxe-installers/usbboot.img:  Rebuilt.
n°1415148
cycojesus
Mèo Lười
Posté le 25-02-2018 à 08:46:38  profilanswer
Sat Feb 24 20:51:49 UTC 2018
a/xfsprogs-4.15.0-x86_64-1.txz:  Upgraded.
l/LibRaw-0.18.8-x86_64-1.txz:  Upgraded.
t/fig2dev-3.2.6a-x86_64-1.txz:  Added.
t/transfig-3.2.5e-x86_64-3.txz:  Removed.
  This package has been renamed fig2dev.
t/xfig-3.2.6a-x86_64-1.txz:  Upgraded.
n°1415216
cycojesus
Mèo Lười
Posté le 27-02-2018 à 09:43:11  profilanswer
Tue Feb 27 06:51:04 UTC 2018
d/ccache-3.4.1-x86_64-1.txz:  Upgraded.
x/mesa-17.3.6-x86_64-1.txz:  Upgraded.
Mon Feb 26 21:32:03 UTC 2018
a/gawk-4.2.1-x86_64-1.txz:  Upgraded.
a/kernel-generic-4.14.22-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.14.22-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.14.22-x86_64-1.txz:  Upgraded.
a/lilo-24.2-x86_64-6.txz:  Rebuilt.
  Support NVMe devices. Thanks to timsoft.
ap/cups-filters-1.20.1-x86_64-1.txz:  Upgraded.
d/automake-1.16-noarch-1.txz:  Upgraded.
d/kernel-headers-4.14.22-x86-1.txz:  Upgraded.
k/kernel-source-4.14.22-noarch-1.txz:  Upgraded.
l/pycurl-7.43.0.1-x86_64-1.txz:  Upgraded.
n/gnupg2-2.2.5-x86_64-1.txz:  Upgraded.
x/libwacom-0.28-x86_64-1.txz:  Upgraded.
xfce/xfce4-terminal-0.8.7.1-x86_64-1.txz:  Upgraded.
n°1415371
cycojesus
Mèo Lười
Posté le 02-03-2018 à 07:20:47  profilanswer
gros
Thu Mar  1 23:24:54 UTC 2018
a/kernel-generic-4.14.23-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.14.23-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.14.23-x86_64-1.txz:  Upgraded.
a/lilo-24.2-x86_64-7.txz:  Rebuilt.
  liloconfig: prevent extraneous Windows partitions from being added
  to lilo.conf. Thanks to allend.
  liloconfig: display a notice when the script is scanning for partitions
  (which may take some time) so that it doesn't appear to be stalled.
a/xfsprogs-4.15.1-x86_64-1.txz:  Upgraded.
ap/man-db-2.8.2-x86_64-1.txz:  Upgraded.
ap/mpg123-1.25.10-x86_64-1.txz:  Upgraded.
d/help2man-1.47.6-x86_64-1.txz:  Upgraded.
d/kernel-headers-4.14.23-x86-1.txz:  Upgraded.
k/kernel-source-4.14.23-noarch-1.txz:  Upgraded.
l/SDL2-2.0.8-x86_64-1.txz:  Upgraded.
l/libunistring-0.9.9-x86_64-1.txz:  Upgraded.
l/mozilla-nss-3.35-x86_64-1.txz:  Upgraded.
  Upgraded to nss-3.35 and nspr-4.18.
l/sip-4.19.8-x86_64-1.txz:  Upgraded.
l/tevent-0.9.36-x86_64-1.txz:  Upgraded.
n/dhcp-4.4.1-x86_64-1.txz:  Upgraded.
  This update fixes two security issues:
    Corrected an issue where large sized 'X/x' format options were causing
  option handling logic to overwrite memory when expanding them to human
  readable form. Reported by Felix Wilhelm, Google Security Team.
    Option reference count was not correctly decremented in error path
  when parsing buffer for options. Reported by Felix Wilhelm, Google
  Security Team.
  For more information, see:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-5732
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-5733
  (* Security fix *)
n/dovecot-2.3.0.1-x86_64-1.txz:  Upgraded.
  This release addresses three security issues in dovecot:
    TLS SNI config lookups may lead to excessive memory usage, causing
  imap-login/pop3-login VSZ limit to be reached and the process restarted.
    Parsing invalid email addresses may cause a crash or leak memory contents
  to attacker. First discovered by Aleksandar Nikolic of Cisco Talos.
  Independently also discovered by "flxflndy" via HackerOne.
    Aborted SASL authentication leaks memory in login process.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-15130
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-14461
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-15132
  (* Security fix *)
n/ntp-4.2.8p11-x86_64-1.txz:  Upgraded.
  This release addresses five security issues in ntpd:
  * LOW/MEDIUM: Sec 3012 / CVE-2016-1549 / VU#961909: Sybil vulnerability:
    ephemeral association attack. While fixed in ntp-4.2.8p7, there are
    significant additional protections for this issue in 4.2.8p11.
    Reported by Matt Van Gundy of Cisco.
  * INFO/MEDIUM: Sec 3412 / CVE-2018-7182 / VU#961909: ctl_getitem(): buffer
    read overrun leads to undefined behavior and information leak.
    Reported by Yihan Lian of Qihoo 360.
  * LOW: Sec 3415 / CVE-2018-7170 / VU#961909: Multiple authenticated
    ephemeral associations. Reported on the questions@ list.
  * LOW: Sec 3453 / CVE-2018-7184 / VU#961909: Interleaved symmetric mode
    cannot recover from bad state. Reported by Miroslav Lichvar of Red Hat.
  * LOW/MEDIUM: Sec 3454 / CVE-2018-7185 / VU#961909: Unauthenticated packet
    can reset authenticated interleaved association.
    http://support.ntp.org/bin/view/Main/SecurityNotice#February_2018_ntp_4_2_8p11_NTP_S
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-1549
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-7182
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-7170
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-7184
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-7185
  (* Security fix *)
n/openvpn-2.4.5-x86_64-1.txz:  Upgraded.
  rc.openvpn: handle multiple config files.
  Thanks to Daniel Junior, Thomas Choi, and BrokenCog for helpful hints.
n/p11-kit-0.23.10-x86_64-1.txz:  Upgraded.
x/libinput-1.10.1-x86_64-1.txz:  Upgraded.
x/libxshmfence-1.3-x86_64-1.txz:  Upgraded.
xfce/xfce4-notifyd-0.4.2-x86_64-1.txz:  Upgraded.
xfce/xfce4-settings-4.12.2-x86_64-1.txz:  Upgraded.
n°1415663
cycojesus
Mèo Lười
Posté le 08-03-2018 à 11:01:55  profilanswer
Thu Mar  8 07:07:45 UTC 2018
a/dbus-1.12.6-x86_64-1.txz:  Upgraded.
a/kernel-generic-4.14.24-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.14.24-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.14.24-x86_64-1.txz:  Upgraded.
ap/cups-filters-1.20.1-x86_64-2.txz:  Rebuilt.
  Recompiled against qpdf-8.0.2.
ap/qpdf-8.0.2-x86_64-1.txz:  Upgraded.
  Shared library .so-version bump.
d/kernel-headers-4.14.24-x86-1.txz:  Upgraded.
d/mercurial-4.5.2-x86_64-1.txz:  Upgraded.
d/meson-0.45.0-x86_64-1.txz:  Upgraded.
d/rust-1.24.1-x86_64-1.txz:  Upgraded.
k/kernel-source-4.14.24-noarch-1.txz:  Upgraded.
kde/amarok-2.9.0-x86_64-1.txz:  Upgraded.
l/SDL2_image-2.0.3-x86_64-1.txz:  Upgraded.
l/cairo-1.15.10-x86_64-1.txz:  Upgraded.
l/gvfs-1.34.2.1-x86_64-1.txz:  Upgraded.
l/harfbuzz-1.7.6-x86_64-1.txz:  Upgraded.
l/libclc-20180223_3554053-x86_64-1.txz:  Upgraded.
l/librsvg-2.42.3-x86_64-1.txz:  Upgraded.
l/mozilla-nss-3.36-x86_64-1.txz:  Upgraded.
  Upgraded to nss-3.36 and nspr-4.19.
l/slang-2.3.2-x86_64-1.txz:  Upgraded.
n/mutt-1.9.4-x86_64-1.txz:  Upgraded.
n/php-7.2.3-x86_64-1.txz:  Upgraded.
  This update fixes a stack buffer overflow vulnerability.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-7584
  (* Security fix *)
x/appres-1.0.5-x86_64-1.txz:  Upgraded.
x/editres-1.0.7-x86_64-1.txz:  Upgraded.
x/fontconfig-2.13.0-x86_64-1.txz:  Upgraded.
x/iceauth-1.0.8-x86_64-1.txz:  Upgraded.
x/libdrm-2.4.91-x86_64-1.txz:  Upgraded.
x/libinput-1.10.2-x86_64-1.txz:  Upgraded.
x/libxcb-1.13-x86_64-1.txz:  Upgraded.
x/listres-1.0.4-x86_64-1.txz:  Upgraded.
x/mkfontscale-1.1.3-x86_64-1.txz:  Upgraded.
x/oclock-1.0.4-x86_64-1.txz:  Upgraded.
x/twm-1.0.10-x86_64-1.txz:  Upgraded.
x/util-macros-1.19.2-noarch-1.txz:  Upgraded.
x/viewres-1.0.5-x86_64-1.txz:  Upgraded.
x/wqy-zenhei-font-ttf-0.8.38_1-noarch-4.txz:  Rebuilt.
  Fix .conf files to not produce warnings with fontconfig-2.13.0.
x/xcb-proto-1.13-x86_64-1.txz:  Upgraded.
x/xdriinfo-1.0.6-x86_64-1.txz:  Upgraded.
x/xf86-video-amdgpu-18.0.0-x86_64-1.txz:  Upgraded.
x/xf86-video-ati-18.0.0-x86_64-1.txz:  Upgraded.
x/xkbcomp-1.4.1-x86_64-1.txz:  Upgraded.
n°1415697
cycojesus
Mèo Lười
Posté le 09-03-2018 à 07:07:27  profilanswer
Thu Mar  8 21:52:05 UTC 2018
a/kernel-modules-4.14.24-x86_64-2.txz:  Rebuilt.
  Fixed "build" and "source" symlinks.
n°1415794
cycojesus
Mèo Lười
Posté le 11-03-2018 à 09:09:10  profilanswer
Sun Mar 11 06:02:10 UTC 2018
a/e2fsprogs-1.44.0-x86_64-1.txz:  Upgraded.
a/kernel-generic-4.14.25-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.14.25-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.14.25-x86_64-1.txz:  Upgraded.
a/logrotate-3.14.0-x86_64-1.txz:  Upgraded.
ap/nano-2.9.4-x86_64-1.txz:  Upgraded.
d/distcc-3.3-x86_64-1.txz:  Upgraded.
d/kernel-headers-4.14.25-x86-1.txz:  Upgraded.
d/llvm-6.0.0-x86_64-1.txz:  Upgraded.
d/rust-1.24.1-x86_64-2.txz:  Rebuilt.
  Use the bundled LLVM compiler since Rust will usually not be ready to be
  built with the latest LLVM. Thanks to Andrew Clemons.
k/kernel-source-4.14.25-noarch-1.txz:  Upgraded.
l/fluidsynth-1.1.10-x86_64-1.txz:  Upgraded.
l/libxml2-2.9.8-x86_64-1.txz:  Upgraded.
n/dovecot-2.3.0.1-x86_64-2.txz:  Rebuilt.
  Recompiled with --with-ldap=plugin option. Thanks to AlexSlack.
x/libevdev-1.5.9-x86_64-1.txz:  Upgraded.
x/mesa-17.3.6-x86_64-2.txz:  Rebuilt.
  Recompiled against llvm-6.0.0.
x/xf86-video-vmware-13.2.1-x86_64-5.txz:  Rebuilt.
xap/pidgin-2.13.0-x86_64-1.txz:  Upgraded.
n°1415867
cycojesus
Mèo Lười
Posté le 12-03-2018 à 12:29:13  profilanswer
Mon Mar 12 07:16:15 UTC 2018
a/kernel-generic-4.14.26-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.14.26-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.14.26-x86_64-1.txz:  Upgraded.
d/kernel-headers-4.14.26-x86-1.txz:  Upgraded.
k/kernel-source-4.14.26-noarch-1.txz:  Upgraded.
x/ico-1.0.5-x86_64-1.txz:  Upgraded.
x/intel-gpu-tools-1.22-x86_64-1.txz:  Upgraded.
x/transset-1.0.2-x86_64-1.txz:  Upgraded.
x/xbacklight-1.2.2-x86_64-1.txz:  Upgraded.
x/xbitmaps-1.1.2-x86_64-1.txz:  Upgraded.
x/xcursor-themes-1.0.5-noarch-1.txz:  Upgraded.
x/xeyes-1.1.2-x86_64-1.txz:  Upgraded.
x/xf86-video-intel-git_20180206_aa36399c-x86_64-1.txz:  Upgraded.
x/xfontsel-1.0.6-x86_64-1.txz:  Upgraded.
x/xinit-1.4.0-x86_64-1.txz:  Upgraded.
x/xkill-1.0.5-x86_64-1.txz:  Upgraded.
x/xload-1.1.3-x86_64-1.txz:  Upgraded.
x/xlsclients-1.1.4-x86_64-1.txz:  Upgraded.
x/xlsfonts-1.0.6-x86_64-1.txz:  Upgraded.
x/xmessage-1.0.5-x86_64-1.txz:  Upgraded.
x/xpr-1.0.5-x86_64-1.txz:  Upgraded.
x/xprop-1.2.3-x86_64-1.txz:  Upgraded.
x/xpyb-1.3.1-x86_64-4.txz:  Rebuilt.
  Patched and recompiled against xcb-proto-1.13.
x/xrdb-1.1.1-x86_64-1.txz:  Upgraded.
x/xrefresh-1.0.6-x86_64-1.txz:  Upgraded.
x/xset-1.2.4-x86_64-1.txz:  Upgraded.
x/xsetroot-1.1.2-x86_64-1.txz:  Upgraded.
x/xsm-1.0.4-x86_64-1.txz:  Upgraded.
x/xwd-1.0.7-x86_64-1.txz:  Upgraded.
x/xwininfo-1.1.4-x86_64-1.txz:  Upgraded.
x/xwud-1.0.5-x86_64-1.txz:  Upgraded.
n°1415919
Col Hanzap​last
Jurassic geek. Vive le cobol !
Posté le 13-03-2018 à 13:48:14  profilanswer
Hello
Je n'arrive pas à lire une carte SDXC de 64GB formatée ExFAT. Une SDHC de 32GB formatée FAT32 est OK.
Hardwarement je pense que c'est bon car mon PC tourne sous Seven64 et gère les deux cartes sans problème grâce à un lecteur de carte interne.
La slackware est installée dans une machine virtuelle VirtualBox et je promène virtuellement le lecteur USB entre le host Seven et le gos Slack.
J'ai l'impression qu'il manque un module dans ma Slack.
https://reho.st/self/156ab76449c2de752efba9dfdf5074d2f41278a7.png
J'ai trouvé  :lol:
C'est là: https://github.com/relan/exfat
autoreconf --install
./configure
make
make install
Nouvelle commande pour mounter:
mount.exfat-fuse /dev/sdb1 /media/zip0
Ca marche bien mais le gestionnaire de fichiers, lui, se plante toujours avec le mount normal.
Message édité par Col Hanzaplast le 13-03-2018 à 13:50:02
" Il n'y a aucune chance pour que l'iPhone s'attribue une part de marché significative. Aucune chance. " (Steve Ballmer 2007)
n°1415935
cycojesus
Mèo Lười
Posté le 13-03-2018 à 16:16:13  profilanswer
Tue Mar 13 04:24:58 UTC 2018
ap/hplip-3.18.3-x86_64-1.txz:  Upgraded.
ap/vim-8.0.1601-x86_64-1.txz:  Upgraded.
n/NetworkManager-1.10.6-x86_64-1.txz:  Upgraded.
x/bigreqsproto-1.1.2-noarch-1.txz:  Removed.
x/compositeproto-0.4.2-noarch-1.txz:  Removed.
x/damageproto-1.2.1-noarch-1.txz:  Removed.
x/dmxproto-2.3.1-noarch-1.txz:  Removed.
x/dri2proto-2.8-x86_64-2.txz:  Removed.
x/dri3proto-1.0-x86_64-2.txz:  Removed.
x/evieext-1.1.1-noarch-1.txz:  Removed.
x/fixesproto-5.0-x86_64-2.txz:  Removed.
x/fontcacheproto-0.1.3-noarch-1.txz:  Removed.
x/fontsproto-2.1.3-noarch-1.txz:  Removed.
x/glproto-1.4.17-noarch-1.txz:  Removed.
x/inputproto-2.3.2-noarch-1.txz:  Removed.
x/kbproto-1.0.7-noarch-1.txz:  Removed.
x/presentproto-1.1-x86_64-1.txz:  Removed.
x/printproto-1.0.5-noarch-1.txz:  Removed.
x/randrproto-1.5.0-noarch-1.txz:  Removed.
x/recordproto-1.14.2-noarch-1.txz:  Removed.
x/renderproto-0.11.1-noarch-1.txz:  Removed.
x/resourceproto-1.2.0-noarch-1.txz:  Removed.
x/scrnsaverproto-1.2.2-noarch-1.txz:  Removed.
x/videoproto-2.3.3-noarch-1.txz:  Removed.
x/xcmiscproto-1.2.2-noarch-1.txz:  Removed.
x/xextproto-7.3.0-x86_64-2.txz:  Removed.
x/xf86bigfontproto-1.2.0-noarch-1.txz:  Removed.
x/xf86dgaproto-2.1-noarch-1.txz:  Removed.
x/xf86driproto-2.1.1-noarch-1.txz:  Removed.
x/xf86miscproto-0.9.3-noarch-1.txz:  Removed.
x/xf86vidmodeproto-2.3.1-noarch-1.txz:  Removed.
x/xineramaproto-1.2.1-noarch-1.txz:  Removed.
x/xorgproto-2018.4-x86_64-1.txz:  Added.
x/xproto-7.0.31-noarch-1.txz:  Removed.
xap/vim-gvim-8.0.1601-x86_64-1.txz:  Upgraded.
n°1415948
Col Hanzap​last
Posté le 13-03-2018 à 17:27:56  profilanswer
Je suis à jour mais en kernel 3.10.107. C'est normal çà ?  :heink:
En fait je ne suis jamais passé en 14.2. C'est peut-être la cause ?
n°1415980
cycojesus
Mèo Lười
Posté le 14-03-2018 à 06:55:38  profilanswer
Tue Mar 13 21:12:51 UTC 2018
a/time-1.9-x86_64-1.txz:  Upgraded.
d/automake-1.16.1-noarch-1.txz:  Upgraded.
l/imagemagick-6.9.9_38-x86_64-1.txz:  Upgraded.
n/samba-4.7.6-x86_64-1.txz:  Upgraded.
  This is a security update in order to patch the following defects:
    On a Samba 4 AD DC the LDAP server in all versions of Samba from
  4.0.0 onwards incorrectly validates permissions to modify passwords
  over LDAP allowing authenticated users to change any other users`
  passwords, including administrative users.
    All versions of Samba from 4.0.0 onwards are vulnerable to a denial of
  service attack when the RPC spoolss service is configured to be run as
  an external daemon. Missing input sanitization checks on some of the
  input parameters to spoolss RPC calls could cause the print spooler
  service to crash. There is no known vulnerability associated with this
  error, merely a denial of service. If the RPC spoolss service is left by
  default as an internal service, all a client can do is crash its own
  authenticated connection.
    https://www.samba.org/samba/security/CVE-2018-1057.html
    https://wiki.samba.org/index.php/CVE-2018-1057
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1057
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1050
  (* Security fix *)
xap/mozilla-firefox-59.0-x86_64-1.txz:  Upgraded.
  This release contains security fixes and improvements.
    https://www.mozilla.org/en-US/security/advisories/mfsa2018-06/
    https://www.mozilla.org/security/known-vulnerabilities/firefox.html
  (* Security fix *)
n°1415981
cycojesus
Mèo Lười
Posté le 14-03-2018 à 06:56:55  profilanswer
très certainement [:kitchen':5]
n°1416026
regdub
Posté le 14-03-2018 à 18:54:52  profilanswer
Je vois que je ne suis pas le seul à traîner en arrière. :D
Legalize it @HFR
n°1416027
Col Hanzap​last
Posté le 14-03-2018 à 19:28:12  profilanswer
D'habitude quand je change de version j'écrase systématiquement tout avec la nouvelle version  ;)
Mais là j'ai une application installée que je ne voudrais pas perdre.
Comment passer de la 14.1 à la 14.2 dans ces conditions ?
n°1416081
cycojesus
Mèo Lười
Posté le 16-03-2018 à 07:03:07  profilanswer
Fri Mar 16 02:29:29 UTC 2018
a/kernel-firmware-20180314_4c0bf11-noarch-1.txz:  Upgraded.
a/kernel-generic-4.14.27-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.14.27-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.14.27-x86_64-1.txz:  Upgraded.
d/kernel-headers-4.14.27-x86-1.txz:  Upgraded.
k/kernel-source-4.14.27-noarch-1.txz:  Upgraded.
  TRANSPARENT_HUGEPAGE_ALWAYS y -> n
  TRANSPARENT_HUGEPAGE_MADVISE n -> y
  Thanks to Darth Vader.
n/bind-9.11.3-x86_64-1.txz:  Upgraded.
n/curl-7.59.0-x86_64-1.txz:  Upgraded.
  This update fixes security issues:
  FTP path trickery leads to NIL byte out of bounds write
  LDAP NULL pointer dereference
  RTSP RTP buffer over-read
    https://curl.haxx.se/docs/adv_2018-9cd6.html
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1000120
    https://curl.haxx.se/docs/adv_2018-97a2.html
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1000121
    https://curl.haxx.se/docs/adv_2018-b047.html
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1000122
  (* Security fix *)
x/libinput-1.10.3-x86_64-1.txz:  Upgraded.
xap/hexchat-2.14.1-x86_64-1.txz:  Upgraded.
xfce/xfce4-terminal-0.8.7.2-x86_64-1.txz:  Upgraded.
extra/wicd/wicd-1.7.4-x86_64-3.txz:  Rebuilt.
  Patched to fix saving settings with wicd-curses. Thanks to justwantin.
n°1416082
cycojesus
Mèo Lười
Posté le 16-03-2018 à 07:04:28  profilanswer
backup des données de l'application ; upgrade ; recompilation de l'appli si besoin ?
n°1416136
cycojesus
Mèo Lười
Posté le 17-03-2018 à 08:50:02  profilanswer
Sat Mar 17 03:25:26 UTC 2018
Beannachtai na le Padraig oraibh!
a/hdparm-9.55-x86_64-1.txz:  Upgraded.
ap/dmidecode-3.1-x86_64-1.txz:  Upgraded.
d/cmake-3.10.3-x86_64-1.txz:  Upgraded.
n/libtirpc-1.0.3-x86_64-1.txz:  Upgraded.
x/xf86-video-amdgpu-18.0.1-x86_64-1.txz:  Upgraded.
x/xf86-video-ati-18.0.1-x86_64-1.txz:  Upgraded.
xap/mozilla-firefox-59.0.1-x86_64-1.txz:  Upgraded.
    https://www.mozilla.org/en-US/security/advisories/mfsa2018-08/
  (* Security fix *)
n°1416161
cycojesus
Mèo Lười
Posté le 18-03-2018 à 09:44:08  profilanswer
Sun Mar 18 00:55:39 UTC 2018
a/sysvinit-scripts-2.1-noarch-7.txz:  Rebuilt.
  rc.M: start consolekit before Bluetooth and NetworkManager. Thanks to allend.
d/python-setuptools-39.0.0-x86_64-1.txz:  Upgraded.
l/libvorbis-1.3.6-x86_64-1.txz:  Upgraded.
  This release fixes security issues.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-14632
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-14633
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-5146
  (* Security fix *)
l/pycairo-1.16.3-x86_64-1.txz:  Upgraded.
n/bluez-5.49-x86_64-1.txz:  Upgraded.
x/xorgproto-2018.4-x86_64-2.txz:  Rebuilt.
  Include support for legacy protocols. Thanks to nobodino.
extra/bash-completion/bash-completion-2.8-noarch-1.txz:  Upgraded.
n°1416200
cycojesus
Mèo Lười
Posté le 19-03-2018 à 07:01:32  profilanswer
Sun Mar 18 21:42:00 UTC 2018
d/Cython-0.28.1-x86_64-1.txz:  Upgraded.
d/python-setuptools-39.0.1-x86_64-1.txz:  Upgraded.
n/dnsmasq-2.79-x86_64-1.txz:  Upgraded.
n°1416261
cycojesus
Mèo Lười
Posté le 20-03-2018 à 07:11:12  profilanswer
Mon Mar 19 19:03:32 UTC 2018
a/kernel-generic-4.14.28-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.14.28-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.14.28-x86_64-1.txz:  Upgraded.
d/kernel-headers-4.14.28-x86-1.txz:  Upgraded.
k/kernel-source-4.14.28-noarch-1.txz:  Upgraded.
xap/gparted-0.31.0-x86_64-1.txz:  Upgraded.
n°1416323
cycojesus
Mèo Lười
Posté le 21-03-2018 à 07:09:54  profilanswer
Tue Mar 20 22:52:16 UTC 2018
l/gst-plugins-base-1.14.0-x86_64-1.txz:  Upgraded.
l/gst-plugins-good-1.14.0-x86_64-1.txz:  Upgraded.
l/gst-plugins-libav-1.14.0-x86_64-1.txz:  Upgraded.
l/gstreamer-1.14.0-x86_64-1.txz:  Upgraded.
n/nmap-7.70-x86_64-1.txz:  Upgraded.
x/fontconfig-2.12.6-x86_64-1.txz:  Upgraded.
  Reverted to previous version. There are problem reports with the latest
  version, and I see no upside to staying on the bleeding edge right now.
n°1416403
cycojesus
Mèo Lười
Posté le 22-03-2018 à 10:13:08  profilanswer
Thu Mar 22 07:12:40 UTC 2018
a/kernel-firmware-20180319_44476f2-noarch-1.txz:  Upgraded.
a/kernel-generic-4.14.29-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.14.29-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.14.29-x86_64-1.txz:  Upgraded.
a/util-linux-2.32-x86_64-1.txz:  Upgraded.
ap/ghostscript-9.23-x86_64-1.txz:  Upgraded.
d/kernel-headers-4.14.29-x86-1.txz:  Upgraded.
d/meson-0.45.1-x86_64-1.txz:  Upgraded.
k/kernel-source-4.14.29-noarch-1.txz:  Upgraded.
l/pcre-8.42-x86_64-1.txz:  Upgraded.
x/mesa-17.3.7-x86_64-1.txz:  Upgraded.
x/vulkan-sdk-1.1.70.0-x86_64-1.txz:  Upgraded.
  Thanks to dugan for help updating the build script.
x/xf86-input-libinput-0.27.0-x86_64-1.txz:  Upgraded.
n°1416462
cycojesus
Mèo Lười
Posté le 24-03-2018 à 09:06:05  profilanswer
Fri Mar 23 22:28:20 UTC 2018
a/glibc-zoneinfo-2018d-noarch-1.txz:  Upgraded.
d/git-2.16.3-x86_64-1.txz:  Upgraded.
n/openldap-client-2.4.46-x86_64-1.txz:  Upgraded.
x/libwacom-0.29-x86_64-1.txz:  Upgraded.
x/xf86-input-wacom-0.36.1-x86_64-1.txz:  Upgraded.
xap/mozilla-thunderbird-52.7.0-x86_64-1.txz:  Upgraded.
    https://www.mozilla.org/en-US/thunderbird/52.7.0/releasenotes/
  (* Security fix *)
n°1416480
cycojesus
Mèo Lười
Posté le 25-03-2018 à 09:49:07  profilanswer
Sat Mar 24 19:47:01 UTC 2018
a/sysvinit-scripts-2.1-noarch-8.txz:  Rebuilt.
  rc.M: Set default hostname using FQDN. Thanks to Andrzej Telszewski.
l/jansson-2.11-x86_64-1.txz:  Added.
n/curl-7.59.0-x86_64-2.txz:  Rebuilt.
  Recompiled to pick up HTTP/2 support from libnghttp2.
n/httpd-2.4.33-x86_64-1.txz:  Upgraded.
  Added HTTP/2 support (requires jansson and nghttp2).
n/nghttp2-1.31.0-x86_64-1.txz:  Added.
n°1416486
ballista
Posté le 25-03-2018 à 16:47:18  profilanswer
blacklister le paquet dans /etc/slackpkg/blacklist si tu utilises slackpkg
Message édité par ballista le 25-03-2018 à 16:49:25
n°1416499
cycojesus
Mèo Lười
Posté le 26-03-2018 à 07:12:59  profilanswer
Mon Mar 26 03:28:26 UTC 2018
a/e2fsprogs-1.44.1-x86_64-1.txz:  Upgraded.
a/kbd-1.15.3-x86_64-3.txz:  Rebuilt.
  setconsolefont: generate font list on the fly. Thanks to David Woodhouse.
a/kernel-generic-4.14.30-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.14.30-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.14.30-x86_64-1.txz:  Upgraded.
d/kernel-headers-4.14.30-x86-1.txz:  Upgraded.
k/kernel-source-4.14.30-noarch-1.txz:  Upgraded.
l/imagemagick-6.9.9_40-x86_64-1.txz:  Upgraded.
l/libdvdread-6.0.0-x86_64-2.txz:  Rebuilt.
  Fixed misplaced files under /usr/share/doc.
l/libmtp-1.1.15-x86_64-1.txz:  Upgraded.
l/liboggz-1.1.1-x86_64-2.txz:  Rebuilt.
  Removed spurious /usr/share/doc directory.
l/librsvg-2.42.3-x86_64-2.txz:  Rebuilt.
xfce/xfce4-pulseaudio-plugin-0.4.0-x86_64-1.txz:  Upgraded.
n°1416539
cycojesus
Mèo Lười
Posté le 27-03-2018 à 07:13:40  profilanswer
Mon Mar 26 22:06:38 UTC 2018
a/aaa_terminfo-6.1-x86_64-1.txz:  Upgraded.
a/etc-15.0-x86_64-2.txz:  Rebuilt.
  Don't include /etc/termcap-* files here. They aren't needed by anything
  shipped with Slackware, and shouldn't be needed by much of anything at all.
  But we'll ship a full /etc/termcap with the ncurses package just in case.
a/hdparm-9.56-x86_64-1.txz:  Upgraded.
l/apr-util-1.6.1-x86_64-3.txz:  Rebuilt.
  Recompiled using --with-mysql=/usr option.
l/libusb-1.0.22-x86_64-1.txz:  Upgraded.
l/ncurses-6.1_20180324-x86_64-1.txz:  Upgraded.
xap/mozilla-firefox-59.0.2-x86_64-1.txz:  Upgraded.
    https://www.mozilla.org/en-US/security/advisories/mfsa2018-10/
  (* Security fix *)
n°1416674
cycojesus
Mèo Lười
Posté le 29-03-2018 à 07:09:20  profilanswer
Thu Mar 29 01:02:50 UTC 2018
a/etc-15.0-x86_64-3.txz:  Rebuilt.
  When adding an sddm user, use $HOME = /var/lib/sddm.
  Make sure the sddm user is a member of the video group.
a/kernel-generic-4.14.31-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.14.31-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.14.31-x86_64-1.txz:  Upgraded.
a/openssl-solibs-1.0.2o-x86_64-1.txz:  Upgraded.
d/kernel-headers-4.14.31-x86-1.txz:  Upgraded.
k/kernel-source-4.14.31-noarch-1.txz:  Upgraded.
n/openssl-1.0.2o-x86_64-1.txz:  Upgraded.
  This update fixes a security issue:
  Constructed ASN.1 types with a recursive definition could exceed the stack.
    https://www.openssl.org/news/secadv/20180327.txt
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-0739
  (* Security fix *)
extra/recordmydesktop/recordmydesktop-0.3.8.1-x86_64-4.txz:  Rebuilt.
  Applied bitrate patches from Arch. Thanks to USUARIONUEVO.
n°1416711
cycojesus
Mèo Lười
Posté le 30-03-2018 à 07:13:53  profilanswer
Thu Mar 29 20:48:28 UTC 2018
a/bash-4.4.019-x86_64-2.txz:  Rebuilt.
  Fixed builtins.1 and rbash.1 manpages to work properly with strict
  implementations (such as mandoc). Thanks to orbea.
ap/cups-2.2.7-x86_64-1.txz:  Upgraded.
ap/mariadb-10.2.14-x86_64-1.txz:  Upgraded.
ap/nano-2.9.5-x86_64-1.txz:  Upgraded.
d/cmake-3.11.0-x86_64-1.txz:  Upgraded.
d/flex-2.6.4-x86_64-2.txz:  Rebuilt.
  Fix flex compiled with recent glibc. Thanks to nobodino.
d/python-pip-9.0.3-x86_64-1.txz:  Upgraded.
d/python3-3.6.5-x86_64-1.txz:  Upgraded.
  Refactored difflib and poplib to fix potential DoS vectors.
  Thanks to Jamie Davis for the patch.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1060
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1061
  (* Security fix *)
d/ruby-2.5.1-x86_64-1.txz:  Upgraded.
  This release includes some bug fixes and some security fixes:
  HTTP response splitting in WEBrick.
  Unintentional file and directory creation with directory traversal in
  tempfile and tmpdir.
  DoS by large request in WEBrick.
  Buffer under-read in String#unpack.
  Unintentional socket creation by poisoned NUL byte in UNIXServer
  and UNIXSocket.
  Unintentional directory traversal by poisoned NUL byte in Dir.
  Multiple vulnerabilities in RubyGems.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-17742
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-6914
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-8777
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-8778
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-8779
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-8780
  (* Security fix *)
d/subversion-1.9.7-x86_64-3.txz:  Rebuilt.
  Recompiled for ruby-2.5.1.
kde/korundum-4.14.3-x86_64-5.txz:  Rebuilt.
kde/qtruby-4.14.3-x86_64-7.txz:  Rebuilt.
l/apr-util-1.6.1-x86_64-4.txz:  Rebuilt.
  Merged upstream patch to fix httpd build.
n/dhcpcd-7.0.2-x86_64-1.txz:  Upgraded.
n/dovecot-2.3.1-x86_64-1.txz:  Upgraded.
n/epic5-2.0.1-x86_64-3.txz:  Rebuilt.
x/mesa-18.0.0-x86_64-1.txz:  Upgraded.
xfce/xfce4-terminal-0.8.7.3-x86_64-1.txz:  Upgraded.
n°1416804
cycojesus
Mèo Lười
Posté le 01-04-2018 à 09:10:19  profilanswer
Sun Apr  1 02:53:26 UTC 2018
a/aaa_terminfo-6.1-x86_64-2.txz:  Rebuilt.
a/kernel-firmware-20180330_a3be6d4-noarch-1.txz:  Upgraded.
a/kernel-generic-4.14.32-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.14.32-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.14.32-x86_64-1.txz:  Upgraded.
ap/cups-filters-1.20.1-x86_64-3.txz:  Rebuilt.
  Recompiled against poppler-0.63.0.
ap/sqlite-3.22.0-x86_64-2.txz:  Rebuilt.
  Recompiled against icu4c-61.1.
d/kernel-headers-4.14.32-x86-1.txz:  Upgraded.
d/rust-1.25.0-x86_64-1.txz:  Upgraded.
d/subversion-1.9.7-x86_64-4.txz:  Rebuilt.
k/kernel-source-4.14.32-noarch-1.txz:  Upgraded.
kde/calligra-2.9.11-x86_64-19.txz:  Rebuilt.
  Recompiled against icu4c-61.1 and poppler-0.63.0.
l/apr-util-1.6.1-x86_64-5.txz:  Rebuilt.
l/boost-1.66.0-x86_64-2.txz:  Rebuilt.
l/gvfs-1.34.2.1-x86_64-2.txz:  Rebuilt.
l/harfbuzz-1.7.6-x86_64-2.txz:  Rebuilt.
l/icu4c-61.1-x86_64-1.txz:  Upgraded.
l/libgpod-0.8.3-x86_64-4.txz:  Rebuilt.
l/libical-3.0.1-x86_64-2.txz:  Rebuilt.
l/libvisio-0.1.6-x86_64-2.txz:  Rebuilt.
l/ncurses-6.1_20180324-x86_64-2.txz:  Rebuilt.
  Removed "rep=%p1%c\E[%p2%{1}%-%db," from the xterm-new definition. It was not
  present in the xterm-new definition shipped in Slackware 14.2 and is causing
  problems with dialog.
l/poppler-0.63.0-x86_64-1.txz:  Upgraded.
l/raptor2-2.0.15-x86_64-4.txz:  Rebuilt.
n/NetworkManager-1.10.6-x86_64-2.txz:  Rebuilt.
n/dovecot-2.3.1-x86_64-2.txz:  Rebuilt.
n/httpd-2.4.33-x86_64-2.txz:  Rebuilt.
n/php-7.2.4-x86_64-1.txz:  Upgraded.
  This update fixes a security issue where sensitive data belonging to other
  accounts might be accessed by a local user.
    http://bugs.php.net/75605
  (* Security fix *)
  Compiled against icu4c-61.1.
n/postfix-3.3.0-x86_64-2.txz:  Rebuilt.
n/tin-2.4.2-x86_64-2.txz:  Rebuilt.
t/texlive-2017.171108-x86_64-4.txz:  Rebuilt.
xap/network-manager-applet-1.8.10-x86_64-4.txz:  Rebuilt.
xap/rxvt-2.7.10-x86_64-5.txz:  Removed.
xap/rxvt-unicode-9.22-x86_64-1.txz:  Added.
  Thanks to MadMaverick9 for the utempter support patch.
xfce/tumbler-0.2.1-x86_64-1.txz:  Upgraded.
  Compiled against poppler-0.63.0.
xfce/xfce4-screenshooter-1.8.2-x86_64-4.txz:  Rebuilt.
xfce/xfce4-weather-plugin-0.8.10-x86_64-3.txz:  Rebuilt.
n°1416826
cycojesus
Mèo Lười
Posté le 02-04-2018 à 09:05:51  profilanswer
Sun Apr  1 21:05:03 UTC 2018
a/aaa_terminfo-6.1-x86_64-3.txz:  Rebuilt.
a/sed-4.5-x86_64-1.txz:  Upgraded.
ap/lsof-4.91-x86_64-1.txz:  Upgraded.
ap/vim-8.0.1655-x86_64-1.txz:  Upgraded.
kde/konsole-4.14.3-x86_64-4.txz:  Rebuilt.
  Use TERM=konsole.
l/libidn-1.34-x86_64-1.txz:  Upgraded.
  Fix integer overflow in combine_hangul()
  Fix integer overflow in punycode decoder
  Fix NULL pointer dereference in g_utf8_normalize()
  Fix NULL pointer dereference in stringprep_ucs4_nfkc_normalize()
  (* Security fix *)
l/ncurses-6.1_20180324-x86_64-3.txz:  Upgraded.
  Use unmodified upstream terminfo definitions rather than break a feature
  of the xterm-new definition for the benefit of a program that can't pick
  the right TERM= setting. Thanks to GazL.
xap/rxvt-unicode-9.22-x86_64-2.txz:  Rebuilt.
  In the urxvt terminfo definitions, set kbs=^H.
xap/vim-gvim-8.0.1655-x86_64-1.txz:  Upgraded.
extra/brltty/brltty-5.6-x86_64-1.txz:  Upgraded.
n°1416884
cycojesus
Mèo Lười
Posté le 04-04-2018 à 06:57:05  profilanswer
Wed Apr  4 00:16:40 UTC 2018
a/pkgtools-15.0-noarch-6.txz:  Rebuilt.
  pkgtool: don't use LANG=C.
  installpkg: don't use LANG=C, but set LC_ALL=C prior to running dd (where we
  need to parse the output) and sort (where we need predictable collation).
ap/cups-filters-1.20.2-x86_64-1.txz:  Upgraded.
ap/sqlite-3.23.0-x86_64-1.txz:  Upgraded.
l/adwaita-icon-theme-3.28.0-noarch-1.txz:  Upgraded.
l/at-spi2-atk-2.26.2-x86_64-1.txz:  Upgraded.
l/at-spi2-core-2.28.0-x86_64-1.txz:  Upgraded.
l/atk-2.28.1-x86_64-1.txz:  Upgraded.
l/gcr-3.28.0-x86_64-1.txz:  Upgraded.
l/glib-networking-2.56.0-x86_64-1.txz:  Upgraded.
l/glib2-2.56.0-x86_64-1.txz:  Upgraded.
l/gnome-keyring-3.28.0.2-x86_64-1.txz:  Upgraded.
l/gobject-introspection-1.56.0-x86_64-1.txz:  Upgraded.
l/gsettings-desktop-schemas-3.28.0-x86_64-1.txz:  Upgraded.
l/gtk+3-3.22.29-x86_64-1.txz:  Upgraded.
l/libsecret-0.18.6-x86_64-1.txz:  Upgraded.
l/libsoup-2.62.0-x86_64-1.txz:  Upgraded.
l/pango-1.42.0-x86_64-1.txz:  Upgraded.
l/pygobject3-3.28.2-x86_64-1.txz:  Upgraded.
l/vte-0.52.0-x86_64-1.txz:  Upgraded.
n/getmail-5.6-x86_64-1.txz:  Upgraded.
n/iproute2-4.16.0-x86_64-1.txz:  Upgraded.
n/openssh-7.7p1-x86_64-1.txz:  Upgraded.
  The patch to restore tcp_wrappers no longer works (applies, but breaks
  incoming connections), so tcp_wrappers is no longer supported. This support
  was dropped by upstream years ago, and there are many better ways to filter
  incoming ports since the days when tcp_wrappers was the only choice.
  There is very little chance that we will try to add support for tcp_wrappers
  again here. Migrate to a better port filtering solution (e.g., iptables or
  nftables), or (I suppose) you could try asking for the support to be
  reinstated upstream. ;-)
xap/rxvt-unicode-9.22-x86_64-3.txz:  Rebuilt.
  Don't modify the default terminfo definitions. Thanks to GazL.
n°1416930
cycojesus
Mèo Lười
Posté le 05-04-2018 à 07:01:33  profilanswer
Wed Apr  4 22:07:03 UTC 2018
l/alsa-lib-1.1.6-x86_64-2.txz:  Rebuilt.
  Restored missing mixer modules.
Wed Apr  4 21:12:00 UTC 2018
ap/alsa-utils-1.1.6-x86_64-1.txz:  Upgraded.
d/mercurial-4.5.3-x86_64-1.txz:  Upgraded.
l/alsa-lib-1.1.6-x86_64-1.txz:  Upgraded.
l/alsa-oss-1.1.6-x86_64-1.txz:  Upgraded.
l/alsa-plugins-1.1.6-x86_64-1.txz:  Upgraded.
l/gvfs-1.36.0-x86_64-1.txz:  Upgraded.
n°1416958
cycojesus
Mèo Lười
Posté le 06-04-2018 à 06:54:36  profilanswer
Thu Apr  5 21:21:24 UTC 2018
a/procps-ng-3.3.13-x86_64-1.txz:  Upgraded.
ap/man-db-2.8.3-x86_64-1.txz:  Upgraded.
d/git-2.17.0-x86_64-1.txz:  Upgraded.
l/python-pillow-5.1.0-x86_64-1.txz:  Upgraded.
n/openssh-7.7p1-x86_64-2.txz:  Rebuilt.
  Restored tcp_wrappers support. Thanks to ecd102 for the patch.
n°1416964
Col Hanzap​last
Posté le 06-04-2018 à 14:54:38  profilanswer
Non non ne me remerciez pas, tout le plaisir est pour moi...  :p
https://reho.st/self/7758d04ad80c48ad1e7505fe5b47eecaa6ac1160.png
n°1416979
cycojesus
Mèo Lười
Posté le 07-04-2018 à 08:53:04  profilanswer
Fri Apr  6 20:47:43 UTC 2018
a/patch-2.7.6-x86_64-2.txz:  Rebuilt.
  Fix arbitrary shell execution possible with obsolete ed format patches.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1000156
  (* Security fix *)
d/strace-4.22-x86_64-1.txz:  Upgraded.
xfce/Thunar-1.6.15-x86_64-1.txz:  Upgraded.
n°1417006
cycojesus
Mèo Lười
Posté le 08-04-2018 à 09:16:00  profilanswer
Sun Apr  8 03:39:55 UTC 2018
ap/joe-4.6-x86_64-1.txz:  Upgraded.
l/gdk-pixbuf2-2.36.12-x86_64-1.txz:  Upgraded.
n/bluez-5.49-x86_64-2.txz:  Rebuilt.
  Patched to fix bluetoothd crashes. Thanks to SeB.
Sat Apr  7 21:00:57 UTC 2018
a/btrfs-progs-v4.16-x86_64-1.txz:  Upgraded.
ap/sysstat-11.6.3-x86_64-1.txz:  Upgraded.
kde/kdev-python-1.7.3-x86_64-2.txz:  Rebuilt.
  Make shared libraries executable.
l/exiv2-0.26-x86_64-2.txz:  Rebuilt.
l/glib-1.2.10-x86_64-5.txz:  Rebuilt.
l/glib2-2.56.1-x86_64-1.txz:  Upgraded.
l/pango-1.42.1-x86_64-1.txz:  Upgraded.
l/slang-2.3.2-x86_64-2.txz:  Rebuilt.
n/dhcpcd-7.0.3-x86_64-1.txz:  Upgraded.
xfce/libxfce4util-4.12.1-x86_64-3.txz:  Rebuilt.
n°1417039
cycojesus
Mèo Lười
Posté le 09-04-2018 à 07:04:55  profilanswer
Sun Apr  8 22:22:25 UTC 2018
a/kernel-firmware-20180329_8c1e439-noarch-1.txz:  Upgraded.
a/kernel-generic-4.14.33-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.14.33-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.14.33-x86_64-1.txz:  Upgraded.
d/ccache-3.4.2-x86_64-1.txz:  Upgraded.
d/kernel-headers-4.14.33-x86-1.txz:  Upgraded.
k/kernel-source-4.14.33-noarch-1.txz:  Upgraded.
  FAT_DEFAULT_UTF8 n -> y
n°1417091
cycojesus
Mèo Lười
Posté le 10-04-2018 à 07:09:33  profilanswer
Mon Apr  9 23:03:06 UTC 2018
l/gobject-introspection-1.56.1-x86_64-1.txz:  Upgraded.
l/gvfs-1.36.1-x86_64-1.txz:  Upgraded.
l/libsoup-2.62.1-x86_64-1.txz:  Upgraded.
n/wireless-tools-29-x86_64-10.txz:  Removed.
n/wireless_tools-29-x86_64-11.txz:  Rebuilt.
  Renamed package to match upstream tarball name.
x/libinput-1.10.4-x86_64-1.txz:  Upgraded.
Slackware 9.0[slackware] Suppression de terminaux virtuels ?
!! Configuration reseaux, slackware 9 !!Installer slackware 9.0 par ftp (boot disquette)
[Pb] Installation new HDD sous slackware 8.0[RESOLU] Pb d'execution mysql sur slackware ...
Slackware 9 du pur bonheurMonter une partition NTFS sous linux (slackware 9.0)
Slackware 9.0 Finale OUTJe sens que je vais quitter Slackware (pas en serv)
Plus de sujets relatifs à : [SLACKWARE] du présent - 15.0
