6871 connectés
La 15.0 est là (en vrai !)
Les invités peuvent voter
 Page :   1  2  3  4  5  ..  69  70  71  ..  109  110  111  112  113  114
[SLACKWARE] du présent - 15.0
n°1391108
cycojesus
Mèo Lười
Posté le 04-06-2016 à 06:15:55  profilanswer
Caramba ! Encore raté !
Fri Jun  3 23:36:07 UTC 2016
ap/lxc-2.0.1-x86_64-3.txz:  Rebuilt.
  In /etc/inittab, use "shutdown -h now" for powerfail.  Without this, lxc-stop
  will send SIGPWR to attempt to stop the container, and will then force stop
  it after a one minute timeout.  Thanks to Andreas Vögele.
  In the init scripts, wrap $container in double quotes to prevent syntax
  errors if the variable is unset.  Thanks to Jakub 'shasta' Jankowski.
l/libxml2-2.9.4-x86_64-2.txz:  Rebuilt.
  Fix attribute decoding during XML schema validation.
n/net-snmp-5.7.3-x86_64-3.txz:  Rebuilt.
  Include support for the ucd-snmp/diskio module.
n/ntp-4.2.8p8-x86_64-1.txz:  Upgraded.
  This release patches one high and four low severity security issues:
  CVE-2016-4957: Crypto-NAK crash
  CVE-2016-4953: Bad authentication demobilizes ephemeral associations
  CVE-2016-4954: Processing spoofed server packets
  CVE-2016-4955: Autokey association reset
  CVE-2016-4956: Broadcast interleave
  For more information, see:
    http://support.ntp.org/bin/view/Main/SecurityNotice#Recent_Vulnerabilities
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-4957
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-4953
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-4954
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-4955
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-4956
  (* Security fix *)
xap/imagemagick-6.9.4_7-x86_64-1.txz:  Upgraded.
xfce/xfce4-panel-4.12.0-x86_64-3.txz:  Rebuilt.
  Blink taskbar buttons for notification 4 times, not G_MAXUINT times.
  Thanks to Andrzej Telszewski.
[:el awrence:1]
Chết rồi ! ✍ ⌥⌘ http://codeberg.org/gwh
n°1391122
cycojesus
Mèo Lười
Posté le 05-06-2016 à 08:20:05  profilanswer
Sat Jun  4 20:56:31 UTC 2016
d/pkg-config-0.29.1-x86_64-2.txz:  Rebuilt.
  Added /usr/local/share/pkgconfig to $PKG_CONFIG_PATH.
  Thanks to bassmadrigal.
n/nftables-0.6-x86_64-1.txz:  Upgraded.
n/samba-4.4.3-x86_64-2.txz:  Rebuilt.
  Moved /etc/samba/private/ to /var/lib/samba/private/.
  Thanks to Pierre ANDREENKO.
x/xf86-input-evdev-2.10.3-x86_64-1.txz:  Upgraded.
n°1391164
cycojesus
Mèo Lười
Posté le 07-06-2016 à 11:26:58  profilanswer
La p'tite maj pan dans ta gueule, même pas mal
Tue Jun  7 06:03:13 UTC 2016
a/pkgtools-14.2-noarch-7.txz:  Rebuilt.
  In setup.80.make-bootdisk, use -i option with syslinux.
  Thanks to Richard Narron.
  In setup.80.make-bootdisk, try to use syslinux-nomtools.  This is more
  reliable due to a race condition between udev and mtools when syslinux
  makes rapid calls to mtools.  If syslinux-nomtools is not available, then
  run syslinux within strace which changes the timing enough that it works.
l/aspell-en-7.1_0-x86_64-1.txz:  Upgraded.
  On all of these aspell dictionary packages, use a proper $ARCH.
  Thanks to Didier Spaier.
n/yptools-2.14-x86_64-7.txz:  Rebuilt.
  Compile with --libexecdir=/usr/lib${LIBDIRSUFFIX}/yp or else ypserv will
  not be able to start ypxfr on 64-bit.  Thanks to Jonathan Woithe.
extra/aspell-word-lists/aspell-af-0.50_0-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-am-0.03_1-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-az-0.02_0-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-be-0.01-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-bg-4.1_0-x86_64-1.txz:  Upgraded.
extra/aspell-word-lists/aspell-bn-0.01.1_1-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-br-0.50_2-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-ca-20040130_1-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-cs-20040614_1-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-csb-0.02_0-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-cy-0.50_3-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-da-1.4.42_1-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-de-20030222_1-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-el-0.50_3-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-eo-2.1.20000225a_2-x86_64-1.txz:  Upgraded.
extra/aspell-word-lists/aspell-es-1.11_2-x86_64-1.txz:  Upgraded.
extra/aspell-word-lists/aspell-et-0.1.21_1-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-fa-0.11_0-x86_64-1.txz:  Upgraded.
extra/aspell-word-lists/aspell-fi-0.7_0-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-fo-0.2.16_1-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-fr-0.50_3-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-ga-4.5_0-x86_64-1.txz:  Upgraded.
extra/aspell-word-lists/aspell-gd-0.1.1_1-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-gl-0.5a_2-x86_64-1.txz:  Upgraded.
extra/aspell-word-lists/aspell-gu-0.03_0-x86_64-1.txz:  Upgraded.
extra/aspell-word-lists/aspell-gv-0.50_0-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-he-1.0_0-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-hi-0.02_0-x86_64-1.txz:  Upgraded.
extra/aspell-word-lists/aspell-hil-0.11_0-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-hr-0.51_0-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-hsb-0.02_0-x86_64-1.txz:  Upgraded.
extra/aspell-word-lists/aspell-hu-0.99.4.2_0-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-ia-0.50_1-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-id-1.2_0-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-is-0.51.1_0-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-it-2.2_20050523_0-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-ku-0.20_1-x86_64-1.txz:  Upgraded.
extra/aspell-word-lists/aspell-la-20020503_0-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-lt-1.2.1_0-x86_64-1.txz:  Upgraded.
extra/aspell-word-lists/aspell-lv-0.5.5_1-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-mg-0.03_0-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-mi-0.50_0-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-mk-0.50_0-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-mn-0.06_2-x86_64-1.txz:  Upgraded.
extra/aspell-word-lists/aspell-mr-0.10_0-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-ms-0.50_0-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-mt-0.50_0-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-nb-0.50.1_0-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-nds-0.01_0-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-nl-0.50_2-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-nn-0.50.1_1-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-no-0.50_2-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-ny-0.01_0-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-or-0.03_1-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-pa-0.01_1-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-pl-6.0_20061121_0-x86_64-1.txz:  Upgraded.
extra/aspell-word-lists/aspell-pt-0.50_2-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-pt_BR-20090702_0-x86_64-1.txz:  Upgraded.
extra/aspell-word-lists/aspell-qu-0.02_0-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-ro-3.3_2-x86_64-1.txz:  Upgraded.
extra/aspell-word-lists/aspell-ru-0.99f7_1-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-rw-0.50_0-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-sc-1.0-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-sk-2.01_2-x86_64-1.txz:  Upgraded.
extra/aspell-word-lists/aspell-sl-0.50_0-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-sr-0.02-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-sv-0.51_0-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-sw-0.50_0-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-ta-20040424_1-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-te-0.01_2-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-tet-0.1.1-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-tl-0.02_1-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-tn-1.0.1_0-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-tr-0.50_0-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-uk-1.4.0_0-x86_64-1.txz:  Upgraded.
extra/aspell-word-lists/aspell-uz-0.6_0-x86_64-1.txz:  Upgraded.
extra/aspell-word-lists/aspell-vi-0.01.1_1-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-wa-0.50_0-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-yi-0.01.1_1-x86_64-5.txz:  Rebuilt.
extra/aspell-word-lists/aspell-zu-0.50_0-x86_64-5.txz:  Rebuilt.
[:hollandais2:4]  [:ilhom]
n°1391198
cycojesus
Mèo Lười
Posté le 08-06-2016 à 06:53:57  profilanswer
[:gamercool_02:1]
Tue Jun  7 21:39:07 UTC 2016
a/smartmontools-6.5-x86_64-1.txz:  Upgraded.
n/gnutls-3.4.13-x86_64-1.txz:  Upgraded.
  Use secure_getenv() where available to obtain environment variables to
  fix an issue where setuid programs could potentially allow an attacker
  to overwrite and corrupt arbitrary files.
  This issue was only present in gnutls-3.4.12.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-4456
  (* Security fix *)
n/samba-4.4.4-x86_64-1.txz:  Upgraded.
  Migrate any .tdb files in /etc/samba/private to /var/lib/samba/private.
  Thanks to ivandi.
xap/gkrellm-2.3.7-x86_64-1.txz:  Upgraded.
xap/mozilla-firefox-45.2.0esr-x86_64-1.txz:  Upgraded.
  This release contains security fixes and improvements.
    http://www.mozilla.org/security/known-vulnerabilities/firefoxESR.html
  (* Security fix *)
[:grande greluche:5]
n°1391217
cycojesus
Mèo Lười
Posté le 09-06-2016 à 06:54:27  profilanswer
sommeil, cauchemar, disparition
Wed Jun  8 21:20:46 UTC 2016
a/kernel-generic-4.4.13-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.4.13-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.4.13-x86_64-1.txz:  Upgraded.
a/mkinitrd-1.4.8-x86_64-6.txz:  Rebuilt.
  Support LABEL= and UUID= for resume device.  Thanks to SeB.
a/pkgtools-14.2-noarch-8.txz:  Rebuilt.
  pkgtool:  Correctly determine root device when running from the installer.
d/kernel-headers-4.4.13-x86-1.txz:  Upgraded.
d/python-setuptools-22.0.5-x86_64-1.txz:  Upgraded.
  Include documentation in package.  Thanks to bassmadrigal.
k/kernel-source-4.4.13-noarch-1.txz:  Upgraded.
l/sdl-1.2.15-x86_64-4.txz:  Rebuilt.
  Patched an SDL_ttf bug that prevents shaded text from displaying.
  Thanks to Cheng Bao.
n/samba-4.4.4-x86_64-2.txz:  Rebuilt.
  Patched doinst.sh to fix a couple possible (harmless) error messages upon
  installation.  Thanks to Maciej Goluchowski.
isolinux/initrd.img:  Rebuilt.
kernels/*:  Upgraded.
testing/source/linux-4.5.4-configs/*:  Removed.
usb-and-pxe-installers/usbboot.img:  Rebuilt.
n°1391250
cycojesus
Mèo Lười
Posté le 10-06-2016 à 06:56:17  profilanswer
on avait un seul !...
Thu Jun  9 18:13:44 UTC 2016
a/e2fsprogs-1.43.1-x86_64-1.txz:  Upgraded.
ap/groff-1.22.3-x86_64-2.txz:  Rebuilt.
  Use correct app-defaults directory.  Thanks to DarkVision.
kde/kdelibs-4.14.20-x86_64-1.txz:  Upgraded.
x/xf86-video-intel-git_20160601_b617f80-x86_64-1.txz:  Upgraded.
  Rolling the git dice one more time since there are reports that this version
  fixes video corruption and freezes after resume.  Please let me know quickly
  if it causes any regressions.
  Rebuilt to update e2fsprogs.
n°1391283
regdub
Posté le 11-06-2016 à 14:11:18  profilanswer
[/fixed]Thu Jun  9 18:13:44 UTC 2016
+--------------------------+[/fixed]
 [:chtut:1]
Message édité par regdub le 11-06-2016 à 14:11:56
Legalize it @HFR
n°1391299
cycojesus
Mèo Lười
Posté le 13-06-2016 à 13:49:51  profilanswer
[:edwy:4] You think this is a game, motherfucker?!
Mon Jun 13 07:07:39 UTC 2016
a/grub-2.00-x86_64-5.txz:  Rebuilt.
  Use correct GRUB_DISABLE_RECOVERY option in /etc/default/grub.new.
  Thanks to Eugen Wissner.
a/mkinitrd-1.4.8-x86_64-7.txz:  Rebuilt.
  Fixed detecting USB partition in init, added proper USB storage modules
  to mkinitrd, and added missing USB keyboard modules to
  mkinitrd_command_generator.sh to fix entering LUKS password with some
  newer USB keyboards.  Thanks to Eric Hameleers.
a/sysvinit-scripts-2.0-noarch-33.txz:  Rebuilt.
  rc.S:  In cryptsetup script, support supplying a password of "none"
  (interactive entry) for non-swap partitions to allow specifying additional
  options.  Support a new option "discard" to pass the --allow-discards option
  to cryptsetup when unlocking a volume, which can potentially improve
  performance and longevity on some SSDs.  Thanks to Nathan Wallace.
ap/cups-filters-1.9.0-x86_64-1.txz:  Upgraded.
ap/lxc-2.0.1-x86_64-4.txz:  Rebuilt.
  Merged rc.S changes.
l/hicolor-icon-theme-0.15-noarch-1.txz:  Upgraded.
n/NetworkManager-1.2.2-x86_64-2.txz:  Rebuilt.
  Install udev rules in the correct directory.  Thanks to gmgf.
n/samba-4.4.4-x86_64-3.txz:  Rebuilt.
  When installing, move any files existing in /etc/samba/private to
  /var/lib/samba/private, not just *.tdb files.
n/vsftpd-3.0.3-x86_64-3.txz:  Rebuilt.
  Patched to handle NULL returns from recent glibc crypt().  Thanks to nixi.
n/wget-1.18-x86_64-1.txz:  Upgraded.
  This version fixes a security vulnerability present in all old versions
  of wget.  On a server redirect from HTTP to a FTP resource, wget would
  trust the HTTP server and use the name in the redirected URL as the
  destination filename.  This behaviour was changed and now it works
  similarly as a redirect from HTTP to another HTTP resource so the original
  name is used as the destination file.  To keep the previous behaviour the
  user must provide --trust-server-names.
  The vulnerability was discovered by Dawid Golunski and was reported by
  Beyond Security's SecuriTeam.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-4971
  (* Security fix *)
x/xterm-325-x86_64-1.txz:  Upgraded.
isolinux/efiboot.img:  Rebuilt.
[:foulques:3]  [:sgt-d:2]  [:mika94400:4]
n°1391300
cycojesus
Mèo Lười
Posté le 14-06-2016 à 06:56:52  profilanswer
unknown is the past,
bright the future,
Slackware
Mon Jun 13 21:34:08 UTC 2016
a/gettext-0.19.8.1-x86_64-1.txz:  Upgraded.
a/pkgtools-14.2-noarch-9.txz:  Rebuilt.
  In setup.80.make-bootdisk, create a first bootable active primary partition
  rather than using a filesystem on the unpartitioned device.  Some BIOSes
  won't boot it otherwise.  Thanks to Richard Narron.
d/gettext-tools-0.19.8.1-x86_64-1.txz:  Upgraded.
n°1391328
cycojesus
Mèo Lười
Posté le 14-06-2016 à 19:25:07  profilanswer
The dreaded pidgin attack
Tue Jun 14 03:48:17 UTC 2016
xap/pidgin-2.10.12-x86_64-2.txz:  Rebuilt.
  Use the much larger collection of SSL certs in /etc/ssl/certs rather
  than the ones that ship with Pidgin, otherwise certificates issued by
  Let's Encrypt (and others) cannot be verified.  Thanks to Cesare.
n°1391337
cycojesus
Mèo Lười
Posté le 15-06-2016 à 09:21:00  profilanswer
Slackware speaks tiếng Pháp, ouïé [:klisstoriss:1]
Wed Jun 15 06:13:17 UTC 2016
a/aaa_elflibs-14.2-x86_64-19.txz:  Rebuilt.
ap/cups-2.1.4-x86_64-1.txz:  Upgraded.
Wed Jun 15 01:57:05 UTC 2016
a/glibc-zoneinfo-2016e-noarch-1.txz:  Upgraded.
a/pkgtools-14.2-noarch-10.txz:  Rebuilt.
  In removepkg, fix package name matching so that (for example) "removepkg s"
  will not remove a package whose name begins and ends with "s".
  Thanks to Andreas Guldstrand.
  Added internationalized man pages.
  Thanks to Didier Spaier and the Slint translation team.
ap/slackpkg-2.82.1-noarch-3.txz:  Rebuilt.
ap/vim-7.4.1938-x86_64-1.txz:  Upgraded.
d/git-2.9.0-x86_64-1.txz:  Upgraded.
xap/gparted-0.26.1-x86_64-1.txz:  Upgraded.
xap/vim-gvim-7.4.1938-x86_64-1.txz:  Upgraded.
[:sitaktif2]
n°1391352
cycojesus
Mèo Lười
Posté le 16-06-2016 à 07:05:07  profilanswer
trop tôt
Wed Jun 15 18:56:13 UTC 2016
a/aaa_elflibs-14.2-x86_64-20.txz:  Rebuilt.
kde/kdelibs-4.14.21-x86_64-1.txz:  Upgraded.
l/libjpeg-turbo-1.5.0-x86_64-1.txz:  Upgraded.
n/libgcrypt-1.7.1-x86_64-1.txz:  Upgraded.
n/libgpg-error-1.23-x86_64-1.txz:  Upgraded.
[:elmoricq]
n°1391363
cycojesus
Mèo Lười
Posté le 17-06-2016 à 06:40:55  profilanswer
fuite en avant
Thu Jun 16 21:52:57 UTC 2016
l/gd-2.2.1-x86_64-1.txz:  Upgraded.
  This update fixes the following security issues:
  Stack consumption vulnerability allows remote attackers to cause a denial of
  service via a crafted imagefilltoborder call.
  Integer signedness error allows remote attackers to cause a denial of service
  or potentially execute arbitrary code via crafted compressed gd2 data, which
  triggers a heap-based buffer overflow.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-8874
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-3074
  (* Security fix *)
n/php-5.6.22-x86_64-2.txz:  Rebuilt.
  Added option --with-vpx-dir=/usr.  Thanks to Pierre ANDREENKO.
Thu Jun 16 18:13:55 UTC 2016
testing/packages/tmux-2.2-x86_64-2.txz:  Rebuilt.
  Added /usr/share/terminfo/tmux{,-256color}.  Thanks to dugan.
[:tilk le sholva]
n°1391412
cycojesus
Mèo Lười
Posté le 19-06-2016 à 13:58:21  profilanswer
(posté sans même l'aide des internets)
[fixed]Fri Jun 17 22:43:09 UTC 2016
xap/imagemagick-6.9.4_9-x86_64-1.txz:  Upgraded.
n°1391455
cycojesus
Mèo Lười
Posté le 21-06-2016 à 09:24:13  profilanswer
running gag
Mon Jun 20 21:39:07 UTC 2016
a/aaa_elflibs-14.2-x86_64-21.txz:  Rebuilt.
a/mkinitrd-1.4.8-x86_64-8.txz:  Rebuilt.
  In mkinitrd_command_generator.sh, include a few more modules that might be
  needed to unlock a LUKS partition using a USB keyboard.
l/cairo-1.14.6-x86_64-2.txz:  Rebuilt.
  Patched an issue that was causing GTK3 applets to crash.
  See:  https://github.com/mate-desktop/mate-panel/issues/369
  Thanks to Willy Sudiarto Raharjo.
l/libarchive-3.2.1-x86_64-1.txz:  Upgraded.
  This release fixes several critical bugs, including some with security
  implications.
  (* Security fix *)
l/pcre-8.39-x86_64-1.txz:  Upgraded.
  This release fixes bugs (including a couple of DoS security issues), and
  retrofits to PCRE1 some appropriate JIT improvements from PCRE2.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-1283
  (* Security fix *)
n°1391512
cycojesus
Mèo Lười
Posté le 22-06-2016 à 09:17:56  profilanswer
En raison d'une grève spontanée du P.R.O.U>.T. nous ne sommes pas mesure de vous délivrer les otages
Tue Jun 21 19:11:38 UTC 2016
a/aaa_elflibs-14.2-x86_64-22.txz:  Rebuilt.
l/gmp-6.1.1-x86_64-1.txz:  Upgraded.
testing/packages/screen-4.4.0-x86_64-1.txz:  Added.
Tue Jun 21 17:50:21 UTC 2016
a/bash-4.3.046-x86_64-1.txz:  Upgraded.
Merci de votre altercation
n°1391536
cycojesus
Mèo Lười
Posté le 23-06-2016 à 12:16:12  profilanswer
avant la nourriture
Thu Jun 23 08:04:53 UTC 2016
ap/cups-filters-1.9.0-x86_64-2.txz:  Rebuilt.
  Recompiled against poppler-0.45.0.
kde/calligra-2.9.11-x86_64-5.txz:  Rebuilt.
l/poppler-0.45.0-x86_64-1.txz:  Upgraded.
xfce/tumbler-0.1.31-x86_64-8.txz:  Rebuilt.
Wed Jun 22 21:56:53 UTC 2016
a/etc-14.2-x86_64-7.txz:  Rebuilt.
  Added root to the audio group.
a/kernel-firmware-20160622git-noarch-1.txz:  Upgraded.
ap/nano-2.6.0-x86_64-1.txz:  Upgraded.
d/llvm-3.8.0-x86_64-2.txz:  Rebuilt.
  Don't remove LLVMHello.so as it is referenced in LLVMExports.cmake breaking
  builds that use "find_package(LLVM 3.8 CONFIG)".  Thanks to Hunter S.
l/pulseaudio-9.0-x86_64-1.txz:  Upgraded.
  This release fixes many bugs, including this one that was commonly reported
  during the Slackware 14.2 development cycle:
  "Automatic routing improvements:
  In 8.0, PulseAudio started to automatically switch to another profile when
  the device associated with the current profile is unplugged.  That seemingly
  smart thing had some serious unintended consequences.  One typical issue was
  that when unplugging headphones, PulseAudio might switch to S/PDIF output
  and not switch back to headphones when they are plugged in again.  Another
  issue was that HDMI in many cases appears to get temporarily unplugged when
  the monitor goes to sleep mode, or even when switching the refresh rate of
  the monitor -- PulseAudio 8.0 would move audio away from the HDMI monitor in
  these cases and not move the audio back to HDMI when the monitor becomes
  available again.  These issues are now fixed."
l/sip-4.18-x86_64-1.txz:  Upgraded.
xfce/xfce4-pulseaudio-plugin-0.2.4-x86_64-2.txz:  Rebuilt.
  Applied a patch to make the icon background match the theme (although this
  will only work if the theme has a GTK+3 subtheme).  Thanks to DarkVision.
n°1391566
cycojesus
Mèo Lười
Posté le 24-06-2016 à 09:20:15  profilanswer
tiny updates, so Hot right now!
Thu Jun 23 22:59:25 UTC 2016
kde/kde-workspace-4.11.22-x86_64-4.txz:  Rebuilt.
  Fixed a bug with generating the initial panel where two Konqueror launchers
  would be created.  Instead, there will be one launcher each for Dolphin,
  Konqueror, Firefox, and Konsole.  Thanks to Eric Hameleers.
n°1391642
cycojesus
Mèo Lười
Posté le 27-06-2016 à 09:27:08  profilanswer
Le petit Kernel attends sa maman au rayon layette, le petit Kernel. Merci !
Sun Jun 26 01:28:27 UTC 2016
ap/screen-4.4.0-x86_64-1.txz:  Upgraded.
xfce/xfce4-pulseaudio-plugin-0.2.4-x86_64-3.txz:  Rebuilt.
  Reverted the icon background color patch, which was causing artifacts around
  the icon or other issues such as the icon being too wide.  These seemed
  worse than the background color issue, which at least doesn't affect the
  default Xfce theme.  The patch remains in the source directory, commented
  out in case anyone wants to try it.  Also, an alternate patch from
  Jean-Philippe Guillemin has been added to the source directory (commented
  out).
Fri Jun 24 23:37:19 UTC 2016
Sorry about the delay, but we had to wait for this kernel.  At least we were
able to get some other good fixes in this week while we were waiting.  :-)
a/aaa_elflibs-14.2-x86_64-23.txz:  Rebuilt.
a/kernel-generic-4.4.14-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.4.14-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.4.14-x86_64-1.txz:  Upgraded.
ap/mariadb-10.0.26-x86_64-1.txz:  Upgraded.
d/kernel-headers-4.4.14-x86-1.txz:  Upgraded.
k/kernel-source-4.4.14-noarch-1.txz:  Upgraded.
  This kernel release fixes two security issues:
  Corrupted offset allows for arbitrary decrements in compat
  IPT_SO_SET_REPLACE setsockopt.  Risk:  High.  Impact:  Kernel memory
  corruption, leading to elevation of privileges or kernel code execution.
  This occurs in a compat_setsockopt() call that is normally restricted to
  root, however, Linux 3/4 kernels that support user and network namespaces
  can allow an unprivileged user to trigger this functionality.  This is
  exploitable from inside a container.
  Out of bounds reads when processing IPT_SO_SET_REPLACE setsockopt.
  Risk:  Medium.  Impact:  Out of bounds heap memory access, leading to a
  Denial of Service (or possibly heap disclosure or further impact).
  This occurs in a setsockopt() call that is normally restricted to root,
  however, Linux 3/4 kernels that support user and network namespaces can
    http://www.openwall.com/lists/oss-security/2016/06/24/5
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-4997
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-4998
  (* Security fix *)
l/libpng-1.6.23-x86_64-1.txz:  Upgraded.
l/librsvg-2.40.16-x86_64-1.txz:  Upgraded.
n/php-5.6.23-x86_64-1.txz:  Upgraded.
  This release fixes bugs and security issues.
    http://php.net/ChangeLog-5.php#5.6.23
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-5766
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-5767
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-5768
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-5769
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-5770
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-5771
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-5772
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-5773
  (* Security fix *)
n°1391715
cycojesus
Mèo Lười
Posté le 29-06-2016 à 09:10:31  profilanswer
Wed Jun 29 00:23:01 UTC 2016
a/kernel-firmware-20160628git-noarch-1.txz:  Upgraded.
n°1391759
cycojesus
Mèo Lười
Posté le 30-06-2016 à 09:09:46  profilanswer
on va raté le bus là !
Wed Jun 29 19:38:51 UTC 2016
a/sysklogd-1.5.1-x86_64-2.txz:  Rebuilt.
  Add a new -c option to disable suppression of repeated messages, which helps
  log parsing tools such as fail2ban work better.
ap/at-3.1.19-x86_64-2.txz:  Rebuilt.
  Removed broken at_deny.5 man page symlink.
n°1391794
cycojesus
Mèo Lười
Posté le 01-07-2016 à 06:42:18  profilanswer
Thu Jun 30 17:25:39 UTC 2016
testing/packages/kernel-module-ecryptfs-4.4.14-x86_64-1.txz:  Added.
  This package contains a fixed version of the eCryptfs kernel module.
n°1391830
cycojesus
Mèo Lười
Posté le 02-07-2016 à 08:33:36  profilanswer
un p'tit chose pour le ouïquinde [:raph01:1]
Thu Jun 30 20:26:57 UTC 2016
Slackware 14.2 x86_64 stable is released!
The long development cycle (the Linux community has lately been living in
"interesting times", as they say) is finally behind us, and we're proud to
announce the release of Slackware 14.2.  The new release brings many updates
and modern tools, has switched from udev to eudev (no systemd), and adds
well over a hundred new packages to the system.  Thanks to the team, the
upstream developers, the dedicated Slackware community, and everyone else
who pitched in to help make this release a reality.
The ISOs are off to be replicated, a 6 CD-ROM 32-bit set and a dual-sided
32-bit/64-bit x86/x86_64 DVD.  Please consider supporting the Slackware
project by picking up a copy from store.slackware.com.  We're taking
pre-orders now, and offer a discount if you sign up for a subscription.
Have fun!  :-)
n°1391831
regdub
Posté le 02-07-2016 à 09:18:30  profilanswer
[:topchef:5]  [:madcat:1]  [:johnnymanziel:2]
 [:timoonn:5]  [:cerveau bidulman]
Aller, j'essaie de migrer dans le mois.
Message édité par regdub le 02-07-2016 à 09:23:47
Legalize it @HFR
n°1391869
cycojesus
Mèo Lười
Posté le 04-07-2016 à 09:08:42  profilanswer
Ça s'en va et ça revient,
c'est fait de tous petits riens
Sun Jul  3 19:29:33 UTC 2016
a/file-5.28-x86_64-1.txz:  Upgraded.
a/util-linux-2.28-x86_64-1.txz:  Upgraded.
xap/mozilla-firefox-47.0.1-x86_64-1.txz:  Upgraded.
Message édité par cycojesus le 04-07-2016 à 09:09:05
n°1391903
cycojesus
Mèo Lười
Posté le 05-07-2016 à 10:01:11  profilanswer
never over
Tue Jul  5 04:52:45 UTC 2016
xap/mozilla-thunderbird-45.2.0-x86_64-1.txz:  Upgraded.
    http://www.mozilla.org/security/known-vulnerabilities/thunderbird.html
  (* Security fix *)
n°1392044
cycojesus
Mèo Lười
Posté le 08-07-2016 à 06:36:19  profilanswer
[:seawan:4]
Thu Jul  7 19:52:36 UTC 2016
n/samba-4.4.5-x86_64-1.txz:  Upgraded.
  This release fixes a security issue:
  Client side SMB2/3 required signing can be downgraded.
  It's possible for an attacker to downgrade the required signing for an
  SMB2/3 client connection, by injecting the SMB2_SESSION_FLAG_IS_GUEST or
  SMB2_SESSION_FLAG_IS_NULL flags.  This means that the attacker can
  impersonate a server being connected to by Samba, and return malicious
  results.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-2119
  (* Security fix *)
[:seawan:1]
n°1392089
cycojesus
Mèo Lười
Posté le 09-07-2016 à 09:37:41  profilanswer
Fri Jul  8 23:17:22 UTC 2016
x/mesa-12.0.0-x86_64-1.txz:  Upgraded.
/me doit learn à écrire un bot un jour
n°1392125
cycojesus
Mèo Lười
Posté le 10-07-2016 à 09:56:32  profilanswer
blague
Sat Jul  9 18:35:56 UTC 2016
x/mesa-12.0.1-x86_64-1.txz:  Upgraded.
n°1392178
cycojesus
Mèo Lười
Posté le 12-07-2016 à 09:26:14  profilanswer
hutfaïte !
Tue Jul 12 03:48:34 UTC 2016
a/etc-14.2-x86_64-8.txz:  Rebuilt.
  In /etc/profile.d/lang.{csh,sh}.new, make en_US.UTF-8 the default locale.
a/kernel-generic-4.4.15-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.4.15-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.4.15-x86_64-1.txz:  Upgraded.
a/lilo-24.2-x86_64-3.txz:  Rebuilt.
  In liloconfig:  Skip the menu asking if the user wants a UTF-8 virtual
  console, and use the kernel default (currently this is UTF-8 active).
d/kernel-headers-4.4.15-x86-1.txz:  Upgraded.
k/kernel-source-4.4.15-noarch-1.txz:  Upgraded.
n°1392227
cycojesus
Mèo Lười
Posté le 12-07-2016 à 18:51:02  profilanswer
Heureux et généreux, je te bénis ton Pine64 avec Slackware [:cisco11]
n°1392329
nh3xus
Posté le 15-07-2016 à 18:59:52  profilanswer
Bien la Front Page pas à jour ? :o
n°1392522
cycojesus
Mèo Lười
Posté le 22-07-2016 à 07:04:47  profilanswer
Thu Jul 21 23:25:54 UTC 2016
ap/tmux-2.2-x86_64-2.txz:  Upgraded.
  Moved from /testing.
d/guile-2.0.12-x86_64-1.txz:  Upgraded.
l/freetype-2.6.4-x86_64-1.txz:  Upgraded.
n/libgcrypt-1.7.2-x86_64-1.txz:  Upgraded.
n/network-scripts-14.2-noarch-2.txz:  Rebuilt.
  In rc.inet1.new, use -L option to dhcpcd to disable Zeroconf.  This is
  (almost) never going to be wanted, and ends up used accidentally on slower
  systems (such as some ARM platforms), preventing a proper DHCP lease.
  Thanks to Stuart Winter.
n/php-5.6.24-x86_64-1.txz:  Upgraded.
    http://php.net/ChangeLog-5.php#5.6.24
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-5385
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-6207
  (* Security fix *)
xap/gimp-2.8.18-x86_64-1.txz:  Upgraded.
  Use-after-free vulnerability in the xcf_load_image function in
  app/xcf/xcf-load.c in GIMP allows remote attackers to cause a denial of
  service (program crash) or possibly execute arbitrary code via a crafted
  XCF file.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-4994
  (* Security fix *)
n°1392549
cycojesus
Mèo Lười
Posté le 23-07-2016 à 09:08:48  profilanswer
Fri Jul 22 20:51:23 UTC 2016
a/dialog-1.3_20160424-x86_64-1.txz:  Upgraded.
a/kmod-23-x86_64-1.txz:  Upgraded.
a/lvm2-2.02.161-x86_64-1.txz:  Upgraded.
d/git-2.9.2-x86_64-1.txz:  Upgraded.
l/desktop-file-utils-0.23-x86_64-1.txz:  Upgraded.
l/freetype-2.6.5-x86_64-1.txz:  Upgraded.
l/harfbuzz-1.3.0-x86_64-1.txz:  Upgraded.
n/bind-9.10.4_P2-x86_64-1.txz:  Upgraded.
  Fixed a security issue:
  getrrsetbyname with a non absolute name could trigger an infinite
    recursion bug in lwresd and named with lwres configured if when
    combined with a search list entry the resulting name is too long.
    (CVE-2016-2775) [RT #42694]
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-2775
  (* Security fix *)
n/httpd-2.4.23-x86_64-1.txz:  Upgraded.
n/lftp-4.7.3-x86_64-1.txz:  Upgraded.
n/links-2.13-x86_64-1.txz:  Upgraded.
x/xf86-video-openchrome-0.5.0-x86_64-1.txz:  Upgraded.
x/xkeyboard-config-2.18-noarch-1.txz:  Upgraded.
x/xorg-server-1.18.4-x86_64-1.txz:  Upgraded.
x/xorg-server-xephyr-1.18.4-x86_64-1.txz:  Upgraded.
x/xorg-server-xnest-1.18.4-x86_64-1.txz:  Upgraded.
x/xorg-server-xvfb-1.18.4-x86_64-1.txz:  Upgraded.
n°1392607
cycojesus
Mèo Lười
Posté le 26-07-2016 à 07:05:33  profilanswer
Oh noes!
Mon Jul 25 19:59:06 UTC 2016
a/pkgtools-14.2-noarch-11.txz:  Rebuilt.
  Changes to pkgtool:
  Remove option to install from floppy disks.
  Don't use the --file option, which appears to be broken in the latest version
  of dialog.  The only reason --file was ever used in the first place was to
  work around the Linux ARG_MAX limit of 131072 bytes, and since Linux 2.6.23 a
  much larger limit is in place making it unlikely to become an issue again.
  So we'll go back to passing the package list on the command line.
  Thanks to David Miller for the bug report.
[:duck action:5]
n°1392662
cycojesus
Mèo Lười
Posté le 27-07-2016 à 15:30:33  profilanswer
Le port ARM hard-float is coming !
Sun Jul 24 18:18:18 BST 2016
Hello!
The 32-bit hard float port is almost complete. I'll probably push it out to the
FTP site in September unless the auto builder completes within the next couple
of weeks, and I'm satisfied with the tests.
The plan is to maintain in the same fashion as the soft float port: a small set
of "officially supported" devices (currently it's what the soft float port had,
minus kirkwood (so Trimslice, Banana Pi and QEMU)), and the community will
continue to support "Device du jour".
OS maintenance will be the same as the soft float port: the last stable release
plus between 4-6 months support for the previous stable release (so for example
14.1 would be maintained for 4-6 months after 14.2 is released), ad infinitum.
I'll probably add support for new devices that look like nice toys as time and
money permits: I have Orange PI One (Allwinner A20 - same SoC as the Banana Pi)
and Orange Pi H3 versions that the OrangePi company sent as samples. I started
playing with the A20 version today, and once the H3 support hits the mainstream
kernel, I'll look in to that.
I have some plans to further automate the build and maintenance process so that
I can continue to maintain it, but more efficiently than with the soft float port.
The OS is built for armv7 minimum target. The main C flags are:
-march=armv7-a -mfpu=vfpv3-d16 -mfloat-abi=hard
Development consists of a couple of machines that act as "-current" (lead
builder and the "oh s*it!" builder), plus a couple of machines to maintain
stable releases; so I need to buy a few more machines to do that.
If you would like to donate to this project, please sponsor it:
  http://arm.slackware.com/sponsor/
Discussion thread:
http://www.linuxquestions.org/questions/slackware-arm-108/donations-being-accepted-for-32bit-hard-float-port-4175585417/
 Cheers,
 Stuart
Tue Jul 19 22:25:49 UTC 2016
[:binary finary]
n°1392725
cycojesus
Mèo Lười
Posté le 29-07-2016 à 07:08:05  profilanswer
back 2 Boyz
Thu Jul 28 19:44:25 UTC 2016
a/kernel-generic-4.4.16-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.4.16-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.4.16-x86_64-1.txz:  Upgraded.
d/kernel-headers-4.4.16-x86-1.txz:  Upgraded.
k/kernel-source-4.4.16-noarch-1.txz:  Upgraded.
l/libidn-1.33-x86_64-1.txz:  Upgraded.
  Fixed out-of-bounds read bugs.  Fixed crashes on invalid UTF-8.
  Thanks to Hanno Böck.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-8948
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-6261
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-6262
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-6263
  (* Security fix *)
l/libtasn1-4.9-x86_64-1.txz:  Upgraded.
n/bluez-5.41-x86_64-1.txz:  Upgraded.
extra/tigervnc/tigervnc-1.6.0-x86_64-4.txz:  Rebuilt.
  Recompiled for xorg-server-1.18.4.
[:sebastien0123:4]
n°1393089
cycojesus
Mèo Lười
Posté le 07-08-2016 à 12:28:22  profilanswer
Sat Aug  6 19:29:16 UTC 2016
n/curl-7.50.1-x86_64-1.txz:  Upgraded.
  This release fixes security issues:
  TLS: switch off SSL session id when client cert is used
  TLS: only reuse connections with the same client cert
  curl_multi_cleanup: clear connection pointer for easy handles
    https://curl.haxx.se/docs/adv_20160803A.html
    https://curl.haxx.se/docs/adv_20160803B.html
    https://curl.haxx.se/docs/adv_20160803C.html
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-5419
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-5420
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-5421
  (* Security fix *)
n/mutt-1.6.2-x86_64-1.txz:  Upgraded.
n/openssh-7.3p1-x86_64-1.txz:  Upgraded.
  This is primarily a bugfix release, and also addresses security issues.
  sshd(8): Mitigate a potential denial-of-service attack against the system's
  crypt(3) function via sshd(8).
  sshd(8): Mitigate timing differences in password authentication that could
  be used to discern valid from invalid account names when long passwords were
  sent and particular password hashing algorithms are in use on the server.
  ssh(1), sshd(8): Fix observable timing weakness in the CBC padding oracle
  countermeasures.
  ssh(1), sshd(8): Improve operation ordering of MAC verification for
  Encrypt-then-MAC (EtM) mode transport MAC algorithms to verify the MAC
  before decrypting any ciphertext.
  sshd(8): (portable only) Ignore PAM environment vars when UseLogin=yes.
    http://www.openssh.com/txt/release-7.3
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-6210
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-8325
  (* Security fix *)
n/stunnel-5.35-x86_64-1.txz:  Upgraded.
  Fixes security issues:
  Fixed malfunctioning "verify = 4".
  Fixed incorrectly enforced client certificate requests.
  (* Security fix *)
[:peillon:2]
n°1393261
cycojesus
Mèo Lười
Posté le 12-08-2016 à 09:48:04  profilanswer
Thu Aug 11 18:24:29 UTC 2016
a/glibc-solibs-2.24-x86_64-1.txz:  Upgraded.
a/glibc-zoneinfo-2016f-noarch-1.txz:  Upgraded.
a/kernel-generic-4.4.17-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.4.17-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.4.17-x86_64-1.txz:  Upgraded.
ap/diffutils-3.4-x86_64-1.txz:  Upgraded.
ap/vim-7.4.2196-x86_64-1.txz:  Upgraded.
d/binutils-2.27-x86_64-1.txz:  Upgraded.
d/gcc-5.4.0-x86_64-1.txz:  Upgraded.
d/gcc-g++-5.4.0-x86_64-1.txz:  Upgraded.
d/gcc-gfortran-5.4.0-x86_64-1.txz:  Upgraded.
d/gcc-gnat-5.4.0-x86_64-1.txz:  Upgraded.
d/gcc-go-5.4.0-x86_64-1.txz:  Upgraded.
d/gcc-java-5.4.0-x86_64-1.txz:  Upgraded.
d/gcc-objc-5.4.0-x86_64-1.txz:  Upgraded.
d/kernel-headers-4.4.17-x86-1.txz:  Upgraded.
d/llvm-3.8.1-x86_64-1.txz:  Upgraded.
d/oprofile-1.1.0-x86_64-2.txz:  Rebuilt.
k/kernel-source-4.4.17-noarch-1.txz:  Upgraded.
l/glibc-2.24-x86_64-1.txz:  Upgraded.
l/glibc-i18n-2.24-x86_64-1.txz:  Upgraded.
l/glibc-profile-2.24-x86_64-1.txz:  Upgraded.
xap/mozilla-firefox-48.0-x86_64-1.txz:  Upgraded.
    http://www.mozilla.org/security/known-vulnerabilities/firefox.html
  (* Security fix *)
xap/vim-gvim-7.4.2196-x86_64-1.txz:  Upgraded.
[:raztapeaupoulos]  [:_niala_]
n°1393851
cycojesus
Mèo Lười
Posté le 24-08-2016 à 07:30:24  profilanswer
Tant de choses `a vous dire :
Tue Aug 23 19:45:33 UTC 2016
a/glibc-solibs-2.24-x86_64-2.txz:  Rebuilt.
a/kernel-firmware-20160823git-noarch-1.txz:  Upgraded.
a/kernel-generic-4.4.19-x86_64-1.txz:  Upgraded.
  A flaw was found in the implementation of the Linux kernels handling of
  networking challenge ack where an attacker is able to determine the shared
  counter.  This may allow an attacker located on different subnet to inject
  or take over a TCP connection between a server and client without having to
  be a traditional Man In the Middle (MITM) style attack.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-5389
  (* Security fix *)
a/kernel-huge-4.4.19-x86_64-1.txz:  Upgraded.
  (* Security fix *)
a/kernel-modules-4.4.19-x86_64-1.txz:  Upgraded.
ap/diffutils-3.5-x86_64-1.txz:  Upgraded.
ap/linuxdoc-tools-0.9.72-x86_64-1.txz:  Upgraded.
ap/screen-4.4.0-x86_64-2.txz:  Rebuilt.
  Reverted a change to /etc/screenrc.new that prevented the console from being
  cleared when a screen session was detached.  Thanks to Stuart Winter.
d/binutils-2.27-x86_64-2.txz:  Rebuilt.
  Recompiled with --disable-compressed-debug-sections, since other tools are
  not yet capable of parsing that.
  Thanks to Vincent Batts, Heinz Wiesinger, and Stuart Winter.
d/kernel-headers-4.4.19-x86-1.txz:  Upgraded.
k/kernel-source-4.4.19-noarch-1.txz:  Upgraded.
  (* Security fix *)
l/glib2-2.46.2-x86_64-3.txz:  Rebuilt.
  Applied upstream patch to fix a use-before-allocate bug in libgio.  Without
  this fix, Thunar will crash if $HOME is on an NFS volume.
l/glibc-2.24-x86_64-2.txz:  Rebuilt.
  If libm.so is a linker script, don't clobber it with a symlink.
  Thanks to guanx.
l/glibc-i18n-2.24-x86_64-2.txz:  Rebuilt.
l/glibc-profile-2.24-x86_64-2.txz:  Rebuilt.
n/gnupg-1.4.21-x86_64-1.txz:  Upgraded.
  Fix critical security bug in the RNG [CVE-2016-6313].  An attacker who
  obtains 580 bytes from the standard RNG can trivially predict the next
  20 bytes of output.  (This is according to the NEWS file included in the
  source.  According to the annoucement linked below, an attacker who obtains
  4640 bits from the RNG can trivially predict the next 160 bits of output.)
  Problem detected by Felix Doerre and Vladimir Klebanov, KIT.
    https://lists.gnupg.org/pipermail/gnupg-announce/2016q3/000395.html
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-6313
  (* Security fix *)
n/libgcrypt-1.7.3-x86_64-1.txz:  Upgraded.
  (* Security fix *)
n/network-scripts-14.2-noarch-3.txz:  Rebuilt.
  In rc.inet1, skip interfaces that are not configured in rc.inet1.conf
  to speed up the boot time slightly.
  Thanks to Amritpal Bath.
n/stunnel-5.35-x86_64-2.txz:  Rebuilt.
  Fixed incorrect config file name in generate-stunnel-key.sh.
  Thanks to Ebben Aries.
xap/mozilla-firefox-48.0.1-x86_64-1.txz:  Upgraded.
n°1393918
cycojesus
Mèo Lười
Posté le 25-08-2016 à 07:00:58  profilanswer
et ça aussi
Wed Aug 24 19:37:40 UTC 2016
xap/mozilla-firefox-48.0.2-x86_64-1.txz:  Upgraded.
ainsi que
Wed Aug 24 01:02:03 UTC 2016
Hello!
Slackware ARM -current and onwards is now a hard float OS!
To those of you whom are reading this after having let an automated tool
upgrade a soft float "-current" installation, and have found their system
has been destroyed:-
I did think of several ways to mitigate this by patching slackpkg, but it's not
fool proof so I've tried to mitigate such issues by deliberately wiping the soft
float port contents >2 months ahead of time in order to break your tools and cause
you to read the Change Log and take action.
Slackware is not designed to have automated packaging upgrade tools, so there's
no 100% fool proof way.
Like a phoenix rising from the ashes, and after several weeks of development
flavoured with other appropriate but overused marketing metaphors, the
Slackware ARM hard float port has landed! (see what I did there? ;-) )
What's important is that this port is built from the same soft float port source
tree, so is already based upon its success and stability over the last 10 years.
A few bugs have been fixed along the way, and the source tree updated to abstract
out as much architecture-specific stuff as possible (removing armv5 CFLAGS from
almost 1000 build scripts was not a lot of fun!).
The OS has been rebuilt over ~25 passes, so the core OS has been well excercised.
I've been testing as much as I can for the last few weeks and everything
looks in good order.  I cannot test everything though, so expect breakages.
Please report anything in the usual place:
The currently supported systems that have been tested are:
  Trimslice Pro
  Banana Pi
  Versatile (QEMU emulation)
This is Day Zero of the release - the community projects will need their time
to update images, documentation and so on.
The mini root filesystem for -current is also available:
ftp://ftp.arm.slackware.com/slackwarearm/slackwarearm-devtools/minirootfs/
If you were previously using the Mozilla suite: these were moved out of tree
for the soft float port (since they only supported hard float), but are now
present once again in the 'xap' series.
Thanks to everyone who has made donations.  As well as being an encouragement,
it's enabled the purchase of two new Banana Pi's to support maintenance of
stable release.  Please also know that whilst within the Slackware team, I
do contribute back to the x86 project with enhancements and fixes that benefit
both ARM and x86, from a volume point of view Slackware ARM is chiefly a
downstream consumer and would not exist without the work of the small and
dedicated Slackware team, and of course Patrick.  We love working on Slackware,
and donations encourage us particulatly when it becomes an uphill slog for
periods of time.
Please help support the project to keep it alive in the public domain!
Cheers and enjoy.  Apparently people have been waiting for a hard float port
for some time! ;-)
 Stuart.
surtout
Slackware 9.0[slackware] Suppression de terminaux virtuels ?
!! Configuration reseaux, slackware 9 !!Installer slackware 9.0 par ftp (boot disquette)
[Pb] Installation new HDD sous slackware 8.0[RESOLU] Pb d'execution mysql sur slackware ...
Slackware 9 du pur bonheurMonter une partition NTFS sous linux (slackware 9.0)
Slackware 9.0 Finale OUTJe sens que je vais quitter Slackware (pas en serv)
Plus de sujets relatifs à : [SLACKWARE] du présent - 15.0
