5177 connectés
La 15.0 est là (en vrai !)
Les invités peuvent voter
 Page :   1  2  3  4  5  ..  68  69  70  ..  109  110  111  112  113  114
[SLACKWARE] du présent - 15.0
n°1388375
cycojesus
Mèo Lười
Posté le 19-03-2016 à 07:16:21  profilanswer
La folie du samedi matin [:papinse]
Fri Mar 18 20:02:40 UTC 2016
d/git-2.7.4-x86_64-1.txz:  Upgraded.
  NOTE:  Issuing this patch again since the bug reporter listed the
  wrong git version (2.7.1) as fixed.  The vulnerability was actually
  patched in git-2.7.4.
  Fixed buffer overflows allowing server and client side remote code
  execution in all git versions before 2.7.4.
  For more information, see:
    http://seclists.org/oss-sec/2016/q1/645
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-2315
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-2324
  (* Security fix *)
xap/hexchat-2.12.0-x86_64-1.txz:  Upgraded.
xap/mozilla-thunderbird-38.7.0-x86_64-1.txz:  Upgraded.
  This update contains security fixes and improvements.
    http://www.mozilla.org/security/known-vulnerabilities/thunderbird.html
  (* Security fix *)
extra/bash-completion/bash-completion-2.2-noarch-2.txz:  Rebuilt.
  Applied upstream patches to fix tar filename completion and related issues.
  Thanks to Robby Workman.
[:-arnadul-]
Chết rồi ! ✍ ⌥⌘ http://codeberg.org/gwh
n°1388426
cycojesus
Mèo Lười
Posté le 21-03-2016 à 14:00:10  profilanswer
Revenge ! [:freak bauer:1]
Mon Mar 21 03:19:48 UTC 2016
a/aaa_elflibs-14.2-x86_64-11.txz:  Rebuilt.
a/lvm2-2.02.147-x86_64-1.txz:  Upgraded.
a/pciutils-3.4.1-x86_64-2.txz:  Rebuilt.
  Use a shared libpci, not a static one.  This fixes linking some programs as
  the static library won't pull in other recent dependencies such as libudev.
  Thanks to 55020.
a/pkgtools-14.2-noarch-6.txz:  Rebuilt.
  In installpkg's terse mode, make some dots connecting the description to the
  uncompressed package size.
a/utempter-1.1.6-x86_64-2.txz:  Rebuilt.
  Fixed manpage symlinks.  Thanks to elyk.
ap/cups-filters-1.8.2-x86_64-2.txz:  Rebuilt.
  Recompiled against poppler-0.42.0.
ap/ddrescue-1.21-x86_64-1.txz:  Upgraded.
ap/man-pages-4.05-noarch-1.txz:  Upgraded.
ap/mc-4.8.16-x86_64-1.txz:  Upgraded.
kde/calligra-2.9.11-x86_64-2.txz:  Rebuilt.
kde/kde-workspace-4.11.22-x86_64-3.txz:  Rebuilt.
  Recompiled against shared library from pciutils-3.4.1.
kde/lskat-4.14.3-x86_64-3.txz:  Rebuilt.
  Fixed a typo in slack-desc.
l/harfbuzz-1.2.4-x86_64-1.txz:  Upgraded.
l/libodfgen-0.1.6-x86_64-1.txz:  Upgraded.
  Thanks to Heinz Wiesinger.
l/librevenge-0.0.4-x86_64-1.txz:  Upgraded.
l/libvisio-0.1.5-x86_64-1.txz:  Upgraded.
l/libwpd-0.10.1-x86_64-1.txz:  Upgraded.
l/libzip-1.0.1-x86_64-2.txz:  Rebuilt.
l/poppler-0.42.0-x86_64-1.txz:  Upgraded.
  Shared library .so-version bump.
l/taglib-1.10-x86_64-1.txz:  Upgraded.
l/wavpack-4.75.2-x86_64-1.txz:  Upgraded.
n/NetworkManager-1.0.10-x86_64-4.txz:  Rebuilt.
  When stopping NetworkManager, ensure that wpa_supplicant is also stopped.
  Thanks to allend.
n/bluez-5.38-x86_64-1.txz:  Upgraded.
tcl/tcl-8.6.5-x86_64-2.txz:  Rebuilt.
tcl/tk-8.6.5-x86_64-2.txz:  Rebuilt.
xap/hexchat-2.12.0-x86_64-2.txz:  Rebuilt.
xfce/tumbler-0.1.31-x86_64-5.txz:  Rebuilt.
xfce/xfce4-power-manager-1.4.4-x86_64-4.txz:  Rebuilt.
  Removed dead symlinks in documentation.  Thanks to elyk.
extra/source/flashplayer-plugin/flashplayer-plugin.SlackBuild:  Patched.
  Scrape the webpage to determine the latest version.
  Thanks to Eric Hameleers.
isolinux/initrd.img:  Rebuilt.
usb-and-pxe-installers/usbboot.img:  Rebuilt.
usb-and-pxe-installers/usbimg2disk.sh:  Patched.
  Fixed the call to sfdisk to make the first partition active.
  Thanks to Jonathan Woithe.
  Leave syslinux files in the USB stick root rather than trying to move them.
http://stkr.es/p/zq8
n°1388628
cycojesus
Mèo Lười
Posté le 26-03-2016 à 07:49:26  profilanswer
- Poland, Sir.
- Poland‽
- Poland.
- Fichtre ! [:pontet_crasse:5]
Fri Mar 25 20:43:59 UTC 2016
a/glibc-zoneinfo-2016c-noarch-1.txz:  Upgraded.
a/kernel-firmware-20160325git-noarch-1.txz:  Upgraded.
a/ntfs-3g-2016.2.22-x86_64-1.txz:  Upgraded.
ap/cups-filters-1.8.3-x86_64-1.txz:  Upgraded.
ap/sudo-1.8.16-x86_64-1.txz:  Upgraded.
ap/zsh-5.2-x86_64-1.txz:  Upgraded.
kde/ktouch-4.14.3-x86_64-3.txz:  Rebuilt.
  Patched to fix performance issues.  Thanks to Andrzej Telszewski.
l/libevent-2.0.22-x86_64-1.txz:  Upgraded.
  Multiple integer overflows in the evbuffer API allow context-dependent
  attackers to cause a denial of service or possibly have other unspecified
  impact via "insanely large inputs" to the (1) evbuffer_add,
  (2) evbuffer_expand, or (3) bufferevent_write function, which triggers a
  heap-based buffer overflow or an infinite loop.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-6272
  (* Security fix *)
l/polkit-0.113-x86_64-1.txz:  Upgraded.
  Polkit config format change:  Uses ".rules" files rather than ".pkla", and
  the rules files are JavaScript.  Thanks to Robby Workman.
l/polkit-gnome-0.105-x86_64-1.txz:  Upgraded.
n/NetworkManager-1.0.10-x86_64-5.txz:  Rebuilt.
  Patched rc.networkmanager to only attempt to kill wpa_supplicant on shutdown
  using the first .pid found in /var/run or /run.  Otherwise if those
  directories are symlinked or bind mounted together there will be a race
  condition that may result in an error message.
  I'm still not certain that rc.networkmanager should be messing with
  wpa_supplicant.  What about cases where NetworkManager might be configured to
  *not* manage the wireless interfaces at all?
  Luckily, there is rarely any reason for stopping NetworkManager (outside of
  shutdown or reboot), or for restarting it.
n/irssi-0.8.19-x86_64-1.txz:  Upgraded.
n/nmap-7.11-x86_64-1.txz:  Upgraded.
xap/mozilla-thunderbird-38.7.1-x86_64-1.txz:  Upgraded.
  (* Security fix *)
[:zesheriff]
n°1388651
cycojesus
Mèo Lười
Posté le 27-03-2016 à 08:31:32  profilanswer
[:lilicite] - FVWM!
- bless you
Sat Mar 26 23:20:34 UTC 2016
a/etc-14.2-x86_64-6.txz:  Rebuilt.
  Added polkitd user (UID 87) and group (GID 87).
ap/mc-4.8.16-x86_64-2.txz:  Rebuilt.
  Applied some upstream patches.  Thanks to th_r.
d/cmake-3.5.1-x86_64-1.txz:  Upgraded.
l/iso-codes-3.66-noarch-1.txz:  Upgraded.
l/libsecret-0.18.5-x86_64-1.txz:  Upgraded.
l/polkit-0.113-x86_64-2.txz:  Rebuilt.
  Ensure that polkitd user (UID 87) and group (GID 87) exist.
  Ensure correct permissions on /etc/polkit-1/rules.d.
  Remove obsolete .pkla rules and /etc/polkit-1/localauthority directory.
  Don't build and install examples.
l/urwid-1.0.3-x86_64-1.txz:  Upgraded.
  Switch to version 1.0.3, since wicd has problems with newer versions.
n/bluez-5.38-x86_64-2.txz:  Rebuilt.
  Use reset=1 when loading the btusb module.
  Applied upstream patch to fix a crash when connecting to audio controllers.
  Thanks to gmgf.
n/curl-7.48.0-x86_64-1.txz:  Upgraded.
n/mtr-0.86-x86_64-1.txz:  Upgraded.
x/xkeyboard-config-2.17-noarch-1.txz:  Upgraded.
xap/fvwm-2.6.6-x86_64-1.txz:  Upgraded.
extra/brltty/brltty-5.3.1-x86_64-1.txz:  Upgraded.
extra/wicd/wicd-1.7.4-x86_64-2.txz:  Rebuilt.
  Fix wicd-curses crash bugs.  Thanks to foobaru, Tonus, and comet.berkeley.
[:klemo:3]
n°1388660
regdub
Posté le 27-03-2016 à 17:08:44  profilanswer
Après des mois de conservatisme, je me suis mis en route vers la modernité. [:grotouille]
Migration en 14.1 completed et slackpkgplus embrassed. [:desperadoflamenco:3]
Ca s'est bien passé.
Ce qui est chiant, c'est l'impression de passer du temps à gérer des trucs qu'on devrait pas, genre kaffeine qui mets 2 "Z" aux dates dans la base des enregistrements, et gvfs WTF qui créé un point de montage que root ne peut même pas "stater" sans erreur.  [:somberlain4:4]
Message édité par regdub le 27-03-2016 à 17:09:53
Legalize it @HFR
n°1388664
cycojesus
Mèo Lười
Posté le 28-03-2016 à 05:15:22  profilanswer
Tu t'ennuis dans ton lundi de Pâââââââââques, c'est sûr
Sun Mar 27 19:39:10 UTC 2016
a/dbus-1.10.8-x86_64-1.txz:  Upgraded.
a/grub-2.00-x86_64-4.txz:  Rebuilt.
  Include support for 32-bit EFI.  Thanks to Eric Hameleers.
a/lvm2-2.02.148-x86_64-1.txz:  Upgraded.
ap/hplip-3.16.3-x86_64-1.txz:  Upgraded.
l/dbus-python-1.2.4-x86_64-1.txz:  Upgraded.
extra/brltty/brltty-5.3.1-x86_64-2.txz:  Rebuilt.
  Added upstream patch to prefer a blank if the same glyph is used for other
  characters.  Added udev rules.  Thanks to Didier Spaier.
testing/source/linux-4.6-rc1-configs/*:  Added.
[:nakata2:4]
n°1388732
cycojesus
Mèo Lười
Posté le 29-03-2016 à 13:12:33  profilanswer
Écoutez, laisser P.at faire son travail...
Tue Mar 29 07:43:02 UTC 2016
d/git-2.8.0-x86_64-1.txz:  Upgraded.
n/iptables-1.6.0-x86_64-2.txz:  Rebuilt.
  Moved /usr/etc/ethertypes to /etc/ethertypes.  Thanks to e5150.
  Exclude any dangling symlinks when copying files.  Thanks to gsl.
  Add new option -e (or --errors) to abort on any errors.
[:diaphane05]
n°1388871
cycojesus
Mèo Lười
Posté le 02-04-2016 à 09:12:29  profilanswer
[:neoeljin]  [:neoeljin:4]  [:neoeljin:5]  [:neoeljin:3]
Fri Apr  1 21:17:37 UTC 2016
a/elilo-3.16-x86_64-2.txz:  Rebuilt.
  eliloconfig:  strip alphabetic characters from $EFI_PARTITION.
  Rebuilt /boot/elilo-x86_64.efi against gnu-efi-3.0.4.
a/kernel-firmware-20160401git-noarch-1.txz:  Upgraded.
ap/alsa-utils-1.1.1-x86_64-1.txz:  Upgraded.
  Don't run rc.alsa by default.
ap/at-3.1.19-x86_64-1.txz:  Upgraded.
d/mercurial-3.7.3-x86_64-1.txz:  Upgraded.
  This update fixes security issues and bugs, including remote code execution
  in binary delta decoding, arbitrary code execution with Git subrepos, and
  arbitrary code execution when converting Git repos.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-3630
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-3068
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-3069
  (* Security fix *)
f/linux-howtos-20160401-noarch-1.txz:  Upgraded.
l/alsa-lib-1.1.1-x86_64-1.txz:  Upgraded.
l/alsa-plugins-1.1.1-x86_64-1.txz:  Upgraded.
l/gnu-efi-3.0.4-x86_64-1.txz:  Upgraded.
l/newt-0.52.19-x86_64-1.txz:  Upgraded.
n/ModemManager-1.4.14-x86_64-1.txz:  Upgraded.
n/dhcp-4.3.4-x86_64-1.txz:  Upgraded.
  This update fixes bugs and (previously patched) security issues.
n/php-5.6.20-x86_64-1.txz:  Upgraded.
  This release fixes bugs and security issues.
    http://php.net/ChangeLog-5.php#5.6.20
  (* Security fix *)
xap/audacious-3.7.2-x86_64-1.txz:  Upgraded.
xap/audacious-plugins-3.7.2-x86_64-1.txz:  Upgraded.
[:neoeljin:2]  [:neoeljin:1]
n°1389008
cycojesus
Mèo Lười
Posté le 05-04-2016 à 05:02:10  profilanswer
This post sponsored by les cauchemars des enfants de 6 ans [:etchebest]
Mon Apr  4 19:54:22 UTC 2016
a/lvm2-2.02.149-x86_64-1.txz:  Upgraded.
ap/sqlite-3.12.0-x86_64-1.txz:  Upgraded.
d/make-4.1-x86_64-2.txz:  Rebuilt.
  Applied patch:  Handle NULL returns from ttyname().  Thanks to e5150.
l/iso-codes-3.67-noarch-1.txz:  Upgraded.
n/NetworkManager-1.0.12-x86_64-1.txz:  Upgraded.
n/bluez-5.38-x86_64-3.txz:  Rebuilt.
  Added another patch from upstream git.  Thanks to gmgf.
n/mutt-1.6.0-x86_64-1.txz:  Upgraded.
x/inputproto-2.3.2-noarch-1.txz:  Upgraded.
xap/mozilla-thunderbird-38.7.2-x86_64-1.txz:  Upgraded.
  (* Security fix *)
[:etchebest:1]  [:etchebest:2]
n°1389055
cycojesus
Mèo Lười
Posté le 06-04-2016 à 10:03:41  profilanswer
vacances fatigue
Wed Apr  6 05:07:44 UTC 2016
d/git-2.8.1-x86_64-1.txz:  Upgraded.
d/nasm-2.12.01-x86_64-1.txz:  Upgraded.
d/strace-4.11-x86_64-1.txz:  Upgraded.
d/subversion-1.9.3-x86_64-1.txz:  Upgraded.
  Subversion servers and clients are vulnerable to remotely triggerable
  heap-based buffer overflows and out-of-bounds reads that may allow remote
  attackers to cause a denial of service or possibly execute arbitrary code
  under the context of the targeted process.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-5259
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-5343
  (* Security fix *)
l/harfbuzz-1.2.5-x86_64-1.txz:  Upgraded.
l/librsvg-2.40.15-x86_64-1.txz:  Upgraded.
n/bluez-5.39-x86_64-1.txz:  Upgraded.
x/mesa-11.2.0-x86_64-1.txz:  Upgraded.
x/xf86-video-intel-git_20160405_afddc9f-x86_64-1.txz:  Upgraded.
x/xorg-server-1.18.3-x86_64-1.txz:  Upgraded.
x/xorg-server-xephyr-1.18.3-x86_64-1.txz:  Upgraded.
x/xorg-server-xnest-1.18.3-x86_64-1.txz:  Upgraded.
x/xorg-server-xvfb-1.18.3-x86_64-1.txz:  Upgraded.
x/xterm-324-x86_64-1.txz:  Upgraded.
extra/tigervnc/tigervnc-1.6.0-x86_64-3.txz:  Rebuilt.
  Rebuilt for xorg-server-1.18.3.
n°1389061
regdub
Posté le 06-04-2016 à 11:58:05  profilanswer
[:xam1311]
 [:arrgghh]
 [:liano:5]
Legalize it @HFR
n°1389249
cycojesus
Mèo Lười
Posté le 12-04-2016 à 11:05:44  profilanswer
des trucs de résal en folïe aujourd'hui [:snip]
Tue Apr 12 05:37:20 UTC 2016
a/aaa_elflibs-14.2-x86_64-12.txz:  Rebuilt.
  Added libtdb.so.1.3.8.
a/lvm2-2.02.150-x86_64-1.txz:  Upgraded.
ap/sqlite-3.12.1-x86_64-1.txz:  Upgraded.
ap/tmux-2.2-x86_64-1.txz:  Upgraded.
l/QScintilla-2.9.1-x86_64-1.txz:  Upgraded.
l/harfbuzz-1.2.6-x86_64-1.txz:  Upgraded.
l/libpng-1.6.21-x86_64-1.txz:  Upgraded.
l/libtasn1-4.8-x86_64-1.txz:  Upgraded.
l/sip-4.17-x86_64-1.txz:  Upgraded.
n/epic5-2.0-x86_64-1.txz:  Upgraded.
n/httpd-2.4.20-x86_64-1.txz:  Upgraded.
n/nmap-7.12-x86_64-1.txz:  Upgraded.
n/proftpd-1.3.5b-x86_64-1.txz:  Upgraded.
  Compiled with --enable-dso.  Thanks to David M. Syzdek.
  Compiled with --enable-nls.  Thanks to Olek.
n/samba-4.4.0-x86_64-1.txz:  Upgraded.
  This will probably be a very short-lived package, but it would be good to
  hear about any bugs before 4.4.1 is packaged (probably tomorrow).
n/vsftpd-3.0.3-x86_64-2.txz:  Rebuilt.
  In /etc/vsftpd.conf.new, set seccomp_sandbox=NO to work around bugs.
x/xf86-video-amdgpu-1.1.0-x86_64-1.txz:  Upgraded.
x/xf86-video-ati-7.7.0-x86_64-1.txz:  Upgraded.
x/xf86-video-intel-git_20160411_a7526ea-x86_64-1.txz:  Upgraded.
xap/mozilla-firefox-45.0.2-x86_64-1.txz:  Upgraded.
[:jer0:1]
n°1389419
cycojesus
Mèo Lười
Posté le 16-04-2016 à 13:09:21  profilanswer
avisse `a la Pop
Fri Apr 15 20:37:37 UTC 2016
Finally got some fixes we were waiting for in this new kernel.
It's been almost a month since 14.2rc1 so we'll call this Slackware
14.2 release candidate 2.  Almost there.  Get in any last-minute
bug reports quickly.  :-)
a/kernel-generic-4.4.7-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.4.7-x86_64-1.txz:  Upgraded.
 BLK_DEV_NVME m -> y
a/kernel-modules-4.4.7-x86_64-1.txz:  Upgraded.
d/kernel-headers-4.4.7-x86-1.txz:  Upgraded.
k/kernel-source-4.4.7-noarch-1.txz:  Upgraded.
l/alsa-lib-1.1.1-x86_64-2.txz:  Rebuilt.
  Applied upstream patch to fix error EBADFD.  Thanks to e5150.
l/glibmm-2.46.4-x86_64-1.txz:  Upgraded.
l/gst-plugins-base-1.6.4-x86_64-1.txz:  Upgraded.
l/gst-plugins-good-1.6.4-x86_64-1.txz:  Upgraded.
l/gstreamer-1.6.4-x86_64-1.txz:  Upgraded.
l/gtkmm3-3.18.1-x86_64-1.txz:  Upgraded.
l/qca-2.1.1-x86_64-2.txz:  Rebuilt.
  Install crypto.prf in the correct directory.  Thanks to David Spencer.
n/gnutls-3.4.11-x86_64-1.txz:  Upgraded.
n/nfs-utils-1.3.3-x86_64-2.txz:  Rebuilt.
  Fix nfsd startup on kernels without IPv6 support.  Thanks to Mario Preksavec.
n/samba-4.4.2-x86_64-1.txz:  Upgraded.
  This update fixes the security issues known as "badlock" (or "sadlock" ),
  which may allow man-in-the-middle or denial-of-service attacks:
    CVE-2015-5370 (Multiple errors in DCE-RPC code)
    CVE-2016-2110 (Man in the middle attacks possible with NTLMSSP)
    CVE-2016-2111 (NETLOGON Spoofing Vulnerability)
    CVE-2016-2112 (LDAP client and server don't enforce integrity)
    CVE-2016-2113 (Missing TLS certificate validation)
    CVE-2016-2114 ("server signing = mandatory" not enforced)
    CVE-2016-2115 (SMB IPC traffic is not integrity protected)
    CVE-2016-2118 (SAMR and LSA man in the middle attacks possible)
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-5370
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-2110
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-2111
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-2112
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-2113
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-2114
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-2115
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-2118
  (* Security fix *)
x/xf86-video-intel-git_20160224_d167280-x86_64-1.txz:  Upgraded.
  So far, this version seems to be the most stable of the ones tested.
x/xf86-video-openchrome-0.4.0-x86_64-1.txz:  Upgraded.
x/xorg-server-1.18.3-x86_64-2.txz:  Rebuilt.
  Applied a patch from https://bugs.freedesktop.org/show_bug.cgi?id=49950
  to fix applying keyboard layout settings when using a keyboard/mouse combo
  device such as a Logitech wireless keyboard with the unifying receiver.
  Thanks to Jean-Philippe Guillemin.
x/xorg-server-xephyr-1.18.3-x86_64-2.txz:  Rebuilt.
x/xorg-server-xnest-1.18.3-x86_64-2.txz:  Rebuilt.
x/xorg-server-xvfb-1.18.3-x86_64-2.txz:  Rebuilt.
xap/geeqie-1.2.3-x86_64-1.txz:  Upgraded.
xap/mozilla-thunderbird-45.0-x86_64-1.txz:  Upgraded.
  This release contains security fixes and improvements.
  (* Security fix *)
kernels/*:  Upgraded.
n°1389533
cycojesus
Mèo Lười
Posté le 19-04-2016 à 06:47:40  profilanswer
strobin
Mon Apr 18 22:21:58 UTC 2016
a/coreutils-8.25-x86_64-2.txz:  Rebuilt.
  Reverted new default ls quoting.
a/glibc-zoneinfo-2016d-noarch-1.txz:  Upgraded.
ap/vim-7.4.1752-x86_64-1.txz:  Upgraded.
d/cmake-3.5.2-x86_64-1.txz:  Upgraded.
d/perl-5.22.1-x86_64-2.txz:  Rebuilt.
  Patched security issue "loss of taint in canonpath()".  Thanks to ttk.
  Patched to recognize gcc 5.x to allow using -D_FORTIFY_SOURCE=2.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-8607
  (* Security fix *)
n/bluez-5.39-x86_64-2.txz:  Rebuilt.
  In rc.bluetooth, don't attempt to start/stop rfcomm.  Thanks to e5150.
n/libgcrypt-1.7.0-x86_64-1.txz:  Upgraded.
x/mesa-11.2.1-x86_64-1.txz:  Upgraded.
x/xf86-video-intel-git_20160417_81029be-x86_64-1.txz:  Upgraded.
  Removed --with-default-dri=2 --with-default-accel=uxa options
  Added patch for modesetting + glamor fallback on gen9+.
  Hopefully the latest git, these option changes, and fallback patch will solve
  the issues reported on LQ.  Please test!
xap/imagemagick-6.9.3_8-x86_64-1.txz:  Upgraded.
xap/vim-gvim-7.4.1752-x86_64-1.txz:  Upgraded.
n°1389586
cycojesus
Mèo Lười
Posté le 20-04-2016 à 07:05:26  profilanswer
strcour
Tue Apr 19 18:59:10 UTC 2016
x/xf86-video-intel-git_20160418_562ae1f-x86_64-1.txz:  Upgraded.
  Bumped to latest git, dropped glamor fallback patch.
n°1389789
cycojesus
Mèo Lười
Posté le 24-04-2016 à 09:28:34  profilanswer
Le Saint Sacrement du jour est ici, sœurs et frères
Sun Apr 24 03:44:25 UTC 2016
a/grep-2.25-x86_64-1.txz:  Upgraded.
a/kernel-generic-4.4.8-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.4.8-x86_64-1.txz:  Upgraded.
 Needed to be built into the huge kernel since virtio is.  Thanks to Cal Peake.
 NET_9P m -> y
 NET_9P_VIRTIO m -> y
a/kernel-modules-4.4.8-x86_64-1.txz:  Upgraded.
a/lilo-24.2-x86_64-2.txz:  Rebuilt.
  Patched usable memory bug.  Thanks to Sl4ck3ver.
ap/lxc-2.0.0-x86_64-1.txz:  Upgraded.
ap/sqlite-3.12.2-x86_64-1.txz:  Upgraded.
d/kernel-headers-4.4.8-x86-1.txz:  Upgraded.
k/kernel-source-4.4.8-noarch-1.txz:  Upgraded.
n/NetworkManager-1.2.0-x86_64-1.txz:  Upgraded.
n/ca-certificates-20160104-noarch-1.txz:  Upgraded.
  Thanks to Cal Peake for fixing a build script typo that created duplicate
  certificates with each successive build.
n/gnupg2-2.0.30-x86_64-1.txz:  Upgraded.
x/motif-2.3.5-x86_64-1.txz:  Upgraded.
xap/network-manager-applet-1.2.0-x86_64-1.txz:  Upgraded.
  Patched busybox umask bug.  Thanks to Goran "CHUPCKO" Lazic.
n°1389865
cycojesus
Mèo Lười
Posté le 26-04-2016 à 11:30:12  profilanswer
inspiration.nil!
Tue Apr 26 05:16:02 UTC 2016
ap/lxc-2.0.0-x86_64-2.txz:  Rebuilt.
  rc.lxc:  Stop containers with lxc-stop rather than having lxc-attach call
  /sbin/halt.  Thanks to linuxxer and Matteo Bernardini.
xfce/xfce4-weather-plugin-0.8.7-x86_64-1.txz:  Upgraded.
n°1389907
cycojesus
Mèo Lười
Posté le 27-04-2016 à 09:41:29  profilanswer
totutit
totitut
Le panda rouge a un bandage, je répète : le panda rouge a un bandage.
titotut
titutot
Wed Apr 27 04:20:57 UTC 2016
xap/mozilla-firefox-45.1.0esr-x86_64-1.txz:  Upgraded.
    http://www.mozilla.org/security/known-vulnerabilities/firefoxESR.html
  (* Security fix *)
n°1389946
cycojesus
Mèo Lười
Posté le 28-04-2016 à 06:43:38  profilanswer
46 - 0,09
Wed Apr 27 21:16:37 UTC 2016
n/yptools-2.14-x86_64-5.txz:  Rebuilt.
  Use /usr/lib$LIBDIRSUFFIX/yp in /var/yp/Makefile.new.  Thanks to alex14641.
xap/mozilla-firefox-45.1.0esr-x86_64-2.txz:  Rebuilt.
  Fixed $RELEASEVER to avoid installing extra files and placing a few files in
  the wrong location.  Thanks to Mikhail Zotov.
xfce/xfce4-settings-4.12.0-x86_64-3.txz:  Rebuilt.
  Patched a bug that may prevent a display from waking up from standby mode
  when running a 4.4.x (or newer) kernel.  Thanks to Matthias Schuster.
n°1390016
cycojesus
Mèo Lười
Posté le 30-04-2016 à 08:06:41  profilanswer
là y'a du scotch bande adhésive
Fri Apr 29 20:54:01 UTC 2016
ap/cups-filters-1.8.3-x86_64-2.txz:  Rebuilt.
  Recompiled against poppler-0.43.0.
kde/calligra-2.9.11-x86_64-3.txz:  Rebuilt.
l/poppler-0.43.0-x86_64-1.txz:  Upgraded.
n/ntp-4.2.8p7-x86_64-1.txz:  Upgraded.
  This release patches several low and medium severity security issues:
  CVE-2016-1551: Refclock impersonation vulnerability, AKA: refclock-peering
  CVE-2016-1549: Sybil vulnerability: ephemeral association attack,
    AKA: ntp-sybil - MITIGATION ONLY
  CVE-2016-2516: Duplicate IPs on unconfig directives will cause an assertion
    botch
  CVE-2016-2517: Remote configuration trustedkey/requestkey values are not
    properly validated
  CVE-2016-2518: Crafted addpeer with hmode > 7 causes array wraparound with
    MATCH_ASSOC
  CVE-2016-2519: ctl_getitem() return value not always checked
  CVE-2016-1547: Validate crypto-NAKs, AKA: nak-dos
  CVE-2016-1548: Interleave-pivot - MITIGATION ONLY
  CVE-2015-7704: KoD fix: peer associations were broken by the fix for
    NtpBug2901, AKA: Symmetric active/passive mode is broken
  CVE-2015-8138: Zero Origin Timestamp Bypass, AKA: Additional KoD Checks
  CVE-2016-1550: Improve NTP security against buffer comparison timing attacks,
    authdecrypt-timing, AKA: authdecrypt-timing
    http://support.ntp.org/bin/view/Main/SecurityNotice#Recent_Vulnerabilities
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-7704
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-8138
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-1547
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-1548
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-1549
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-1550
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-1551
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-2516
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-2517
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-2518
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-2519
  (* Security fix *)
n/php-5.6.21-x86_64-1.txz:  Upgraded.
    http://php.net/ChangeLog-5.php#5.6.21
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-3074
  (* Security fix *)
x/libdrm-2.4.68-x86_64-1.txz:  Upgraded.
xfce/tumbler-0.1.31-x86_64-6.txz:  Rebuilt.
[:serumm:2]
n°1390029
cycojesus
Mèo Lười
Posté le 30-04-2016 à 14:57:17  profilanswer
épi [:euro]
Sat Apr 30 05:51:33 UTC 2016
d/perl-5.22.2-x86_64-1.txz:  Upgraded.
n°1390041
cycojesus
Mèo Lười
Posté le 01-05-2016 à 08:14:40  profilanswer
l'afolie
Sat Apr 30 20:28:33 UTC 2016
a/aaa_elflibs-14.2-x86_64-13.txz:  Rebuilt.
a/lvm2-2.02.152-x86_64-1.txz:  Upgraded.
ap/gphoto2-2.5.10-x86_64-1.txz:  Upgraded.
ap/mariadb-10.0.25-x86_64-1.txz:  Upgraded.
ap/vim-7.4.1811-x86_64-1.txz:  Upgraded.
d/git-2.8.2-x86_64-1.txz:  Upgraded.
d/ruby-2.2.5-x86_64-1.txz:  Upgraded.
d/subversion-1.9.4-x86_64-1.txz:  Upgraded.
  This release fixes two security issues:
  CVE-2016-2167: svnserve/sasl may authenticate users using the wrong realm.
  CVE-2016-2168: Remotely triggerable DoS vulnerability in mod_authz_svn
    during COPY/MOVE authorization check.
    http://subversion.apache.org/security/CVE-2016-2167-advisory.txt
    http://subversion.apache.org/security/CVE-2016-2168-advisory.txt
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-2167
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-2168
  (* Security fix *)
l/libgphoto2-2.5.10-x86_64-1.txz:  Upgraded.
n/whois-5.2.12-x86_64-1.txz:  Upgraded.
n/yptools-2.14-x86_64-6.txz:  Rebuilt.
  Don't remove unmerged .new config files.  Thanks to christian laubscher.
x/xf86-input-evdev-2.10.2-x86_64-1.txz:  Upgraded.
xap/vim-gvim-7.4.1811-x86_64-1.txz:  Upgraded.
n°1390110
cycojesus
Mèo Lười
Posté le 03-05-2016 à 05:58:00  profilanswer
[:joker41]
Mon May  2 19:42:54 UTC 2016
ap/tmux-2.1-x86_64-2.txz:  Rebuilt.
  Reverted to tmux-2.1, because tmux-2.2 has dropped support for non-UTF8
  character sets "since supporting multiple character sets is a pain".
  Thanks to Dan Church for the bug report.
d/mercurial-3.8.1-x86_64-1.txz:  Upgraded.
  This update fixes possible arbitrary code execution when converting Git
  repos.  Mercurial prior to 3.8 allowed arbitrary code execution when using
  the convert extension on Git repos with hostile names.  This could affect
  automated code conversion services that allow arbitrary repository names.
  This is a further side-effect of Git CVE-2015-7545.
  Reported and fixed by Blake Burkhart.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-3105
  (* Security fix *)
l/icu4c-56.1-x86_64-2.txz:  Rebuilt.
  Patched pkgdata crash when using "-m".  Thanks to Fabio Bas.
l/librsvg-2.40.15-x86_64-2.txz:  Rebuilt.
  Reverted upstream patch that broke the rsvg-convert scaling functionality.
  Thanks to haary.
n/samba-4.4.3-x86_64-1.txz:  Upgraded.
xap/imagemagick-6.9.3_9-x86_64-1.txz:  Upgraded.
[:orca78]
n°1390144
cycojesus
Mèo Lười
Posté le 04-05-2016 à 06:19:44  profilanswer
Ça gargouille
Tue May  3 20:30:53 UTC 2016
a/openssl-solibs-1.0.2h-x86_64-1.txz:  Upgraded.
n/bind-9.10.4-x86_64-1.txz:  Upgraded.
n/openssl-1.0.2h-x86_64-1.txz:  Upgraded.
  This update fixes the following security issues:
  Memory corruption in the ASN.1 encoder (CVE-2016-2108)
  Padding oracle in AES-NI CBC MAC check (CVE-2016-2107)
  EVP_EncodeUpdate overflow (CVE-2016-2105)
  EVP_EncryptUpdate overflow (CVE-2016-2106)
  ASN.1 BIO excessive memory allocation (CVE-2016-2109)
  EBCDIC overread (CVE-2016-2176)
    https://www.openssl.org/news/secadv/20160503.txt
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-2108
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-2107
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-2105
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-2106
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-2109
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-2176
  (* Security fix *)
xap/hexchat-2.12.1-x86_64-1.txz:  Upgraded.
testing/packages/tmux-2.2-x86_64-1.txz:  Added.
  For those using a UTF8 locale, I'm adding back the latest tmux in /testing.
  Most likely we'll throw the switch on "UTF8 by default" shortly into the
  next development cycle, but now isn't the time for it.
n°1390172
cycojesus
Mèo Lười
Posté le 05-05-2016 à 07:14:07  profilanswer
enménage, déménage, aménage, toujours le ménage
Wed May  4 19:24:29 UTC 2016
ap/hplip-3.16.5-x86_64-1.txz:  Upgraded.
xap/mozilla-firefox-45.1.1esr-x86_64-1.txz:  Upgraded.
n°1390177
cycojesus
Mèo Lười
Posté le 05-05-2016 à 11:11:18  profilanswer
Thu May  5 05:17:19 UTC 2016
a/kernel-generic-4.4.9-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.4.9-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.4.9-x86_64-1.txz:  Upgraded.
a/sysvinit-scripts-2.0-noarch-31.txz:  Rebuilt.
  In rc.M, bluetooth must start before NetworkManager (like it did in Slackware
  14.1) in order to enable bluetooth networking.  Thanks to James Marca.
ap/lxc-2.0.0-x86_64-3.txz:  Rebuilt.
  Merged rc.M changes.
d/kernel-headers-4.4.9-x86-1.txz:  Upgraded.
k/kernel-source-4.4.9-noarch-1.txz:  Upgraded.
n/mutt-1.6.1-x86_64-1.txz:  Upgraded.
n°1390357
cycojesus
Mèo Lười
Posté le 11-05-2016 à 11:51:31  profilanswer
Ça veux pas faire du rouge
Wed May 11 05:20:01 UTC 2016
a/dcron-4.5-x86_64-5.txz:  Rebuilt.
  Patched bug where cron.update is not picked up while jobs are still running.
  Thanks to Jeroen Hendriks.
ap/lxc-2.0.0-x86_64-4.txz:  Rebuilt.
  Applied "[PATCH] cgfsng: don't require that systemd subsystem be mounted".
  Thanks to Johannes Schöpfer.
ap/moc-2.5.1-x86_64-1.txz:  Upgraded.
ap/slackpkg-2.82.1-noarch-1.txz:  Upgraded.
  Updated x86* mirrors lists for Slackware 14.2.
n/openvpn-2.3.11-x86_64-1.txz:  Upgraded.
x/mesa-11.2.2-x86_64-1.txz:  Upgraded.
xap/imagemagick-6.9.4_1-x86_64-1.txz:  Upgraded.
  This release addresses several security issues in ImageMagick, including:
  Insufficient shell characters filtering allows code execution (CVE-2016-3714)
  Server Side Request Forgery (CVE-2016-3718)
  File deletion (CVE-2016-3715)
  File moving (CVE-2016-3716)
  Local file read (CVE-2016-3717)
  In addition, the default policy.xml config file has been modified to disable
  all of the previously vulnerable coders, and to disable indirect reads.
    https://imagetragick.com
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-3714
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-3718
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-3715
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-3716
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-3717
  (* Security fix *)
n°1390373
cycojesus
Mèo Lười
Posté le 12-05-2016 à 09:11:20  profilanswer
Là, ça a fait du rouge [:le rouge]
Thu May 12 01:50:21 UTC 2016
a/kernel-firmware-20160511git-noarch-1.txz:  Upgraded.
a/kernel-generic-4.4.10-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.4.10-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.4.10-x86_64-1.txz:  Upgraded.
ap/man-pages-4.06-noarch-1.txz:  Upgraded.
d/kernel-headers-4.4.10-x86-1.txz:  Upgraded.
k/kernel-source-4.4.10-noarch-1.txz:  Upgraded.
n/NetworkManager-1.2.2-x86_64-1.txz:  Upgraded.
xap/mozilla-thunderbird-45.1.0-x86_64-1.txz:  Upgraded.
    http://www.mozilla.org/security/kn [...] rbird.html
  (* Security fix *)
xap/network-manager-applet-1.2.2-x86_64-1.txz:  Upgraded.
[:x-files]
n°1390460
cycojesus
Mèo Lười
Posté le 15-05-2016 à 17:55:55  profilanswer
"Live, from Bagdad"
nan en fait rien
Message édité par cycojesus le 15-05-2016 à 17:57:09
n°1390518
cycojesus
Mèo Lười
Posté le 17-05-2016 à 11:10:48  profilanswer
Tue May 17 05:06:44 UTC 2016
a/kernel-firmware-20160516git-noarch-1.txz:  Upgraded.
a/lvm2-2.02.154-x86_64-1.txz:  Upgraded.
d/python-setuptools-21.0.0-x86_64-1.txz:  Upgraded.
n/lftp-4.7.1-x86_64-1.txz:  Upgraded.
xap/imagemagick-6.9.4_1-x86_64-2.txz:  Rebuilt.
  Fixed .new config file installation.  Thanks to ivandi.
testing/source/linux-4.5.4-configs/*:  Added.
testing/source/linux-4.6-configs/*:  Added.
oïé !
n°1390539
cycojesus
Mèo Lười
Posté le 18-05-2016 à 06:56:33  profilanswer
pi
Tue May 17 21:52:11 UTC 2016
a/aaa_elflibs-14.2-x86_64-14.txz:  Rebuilt.
d/mercurial-3.8.2-x86_64-1.txz:  Upgraded.
l/gdbm-1.12-x86_64-1.txz:  Upgraded.
l/libmtp-1.1.11-x86_64-1.txz:  Upgraded.
n/libndp-1.6-x86_64-1.txz:  Upgraded.
  This update fixes a security issue.  It was found that libndp did
  not properly validate and check the origin of Neighbor Discovery
  Protocol (NDP) messages.  An attacker on a non-local network could
  use this flaw to advertise a node as a router, allowing them to
  perform man-in-the-middle attacks on a connecting client, or
  disrupt the network connectivity of that client.
  Thanks to Julien Bernard (Viagénie) for reporting this issue.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-3698
  (* Security fix *)
xap/gnuplot-5.0.3-x86_64-2.txz:  Rebuilt.
  Added libcaca support.  Thanks to Andrew Clemons.
n°1390628
cycojesus
Mèo Lười
Posté le 21-05-2016 à 07:30:08  profilanswer
Comme si de rien n'était
Fri May 20 21:20:29 UTC 2016
a/aaa_base-14.2-x86_64-2.txz:  Rebuilt.
  Updated your your initial email.  ;-)
  Thanks to Tonus for the typo report.
a/aaa_elflibs-14.2-x86_64-15.txz:  Rebuilt.
a/btrfs-progs-v4.5.3-x86_64-1.txz:  Upgraded.
a/e2fsprogs-1.43-x86_64-1.txz:  Upgraded.
a/gzip-1.8-x86_64-1.txz:  Upgraded.
a/kernel-generic-4.4.11-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.4.11-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.4.11-x86_64-1.txz:  Upgraded.
a/tar-1.29-x86_64-1.txz:  Upgraded.
ap/lxc-2.0.1-x86_64-1.txz:  Upgraded.
ap/sqlite-3.13.0-x86_64-1.txz:  Upgraded.
ap/vim-7.4.1832-x86_64-1.txz:  Upgraded.
d/kernel-headers-4.4.11-x86-1.txz:  Upgraded.
k/kernel-source-4.4.11-noarch-1.txz:  Upgraded.
n/curl-7.49.0-x86_64-1.txz:  Upgraded.
  Fixed a TLS certificate check bypass with mbedTLS/PolarSSL.
    https://curl.haxx.se/docs/adv_20160518.html
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-3739
  (* Security fix *)
n/dnsmasq-2.76-x86_64-1.txz:  Upgraded.
n/lftp-4.7.2-x86_64-1.txz:  Upgraded.
xap/vim-gvim-7.4.1832-x86_64-1.txz:  Upgraded.
n°1390771
cycojesus
Mèo Lười
Posté le 25-05-2016 à 12:54:51  profilanswer
Wed May 25 04:20:09 UTC 2016
a/aaa_elflibs-14.2-x86_64-16.txz:  Rebuilt.
a/e2fsprogs-1.43-x86_64-2.txz:  Rebuilt.
  Do not use 64-bit by default on ext4, since some bootloaders cannot handle
  it yet.  But use "auto_64-bit_support = 1", which will enable 64-bit if the
  number of blocks for the file system requires the feature to be enabled.
a/syslinux-4.07-x86_64-1.txz:  Upgraded.
ap/cups-filters-1.8.3-x86_64-3.txz:  Rebuilt.
  Recompiled against poppler-0.44.0.
ap/mpg123-1.23.4-x86_64-1.txz:  Upgraded.
ap/slackpkg-2.82.1-noarch-2.txz:  Rebuilt.
  Updated URLs for garr.it mirrors.  Thanks to Andrej Sossi.
d/git-2.8.3-x86_64-1.txz:  Upgraded.
kde/calligra-2.9.11-x86_64-4.txz:  Rebuilt.
l/libarchive-3.1.2-x86_64-3.txz:  Rebuilt.
  Patched an issue with Zip archive handling that could allow an attacker
  to overwrite parts of the heap in a controlled fashion and execute
  arbitrary code.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-1541
  (* Security fix *)
l/poppler-0.44.0-x86_64-1.txz:  Upgraded.
n/gnutls-3.4.12-x86_64-1.txz:  Upgraded.
xap/MPlayer-1.2_20160125-x86_64-3.txz:  Rebuilt.
  Recompiled with --disable-ossaudio.
xfce/tumbler-0.1.31-x86_64-7.txz:  Rebuilt.
[:aloy]
n°1390827
cycojesus
Mèo Lười
Posté le 26-05-2016 à 06:57:28  profilanswer
SLACKEUX, rise!!!
Wed May 25 23:37:36 UTC 2016
x/xf86-input-wacom-0.33.0-x86_64-1.txz:  Upgraded.
  In rc.dropbear, drop the option to use /etc/motd.net (this was preventing
  dropbear from starting properly).  Thanks to Eduard Rozenberg.
:bounce:
n°1390849
regdub
Posté le 26-05-2016 à 19:51:47  profilanswer
Je sens comme une accélération.  [:sire de botcor:2]
J'ai perdu du temps cause écran de PC en panne.  [:megalyth]
Pas sûr que j'aie le temps de goûter à current avant la sortie officielle.  [:madameorange:1]
Message édité par regdub le 26-05-2016 à 19:54:27
Legalize it @HFR
n°1390862
cycojesus
Mèo Lười
Posté le 27-05-2016 à 09:30:30  profilanswer
YEAH, CHI PA TOU SEUL !!!!!!!!!!!!!!!!!!
Y'a plus de plus à mettre dans tes plusplus™®©
Thu May 26 23:12:27 UTC 2016
a/aaa_elflibs-14.2-x86_64-17.txz:  Rebuilt.
l/libpng-1.6.22-x86_64-1.txz:  Upgraded.
l/libtiff-4.0.6-x86_64-1.txz:  Upgraded.
n/bind-9.10.4_P1-x86_64-1.txz:  Upgraded.
x/libXfixes-5.0.2-x86_64-1.txz:  Upgraded.
x/xproto-7.0.29-noarch-1.txz:  Upgraded.
xap/imagemagick-6.9.4_4-x86_64-1.txz:  Upgraded.
Thu May 26 20:30:18 UTC 2016
ap/ghostscript-9.19-x86_64-1.txz:  Upgraded.
  Dumped old unmaintained bundled libraries and linked with system libraries
  instead.  There had been a crash previously with the GIMP plugin and
  ghostscript > 9.07, but now it works as expected.  Thanks to qunying.
[:le fleau]  [:douchebag forever:2]  [:beel1]
n°1390896
cycojesus
Mèo Lười
Posté le 28-05-2016 à 08:50:19  profilanswer
bon bin
Fri May 27 23:08:17 UTC 2016
a/sysvinit-scripts-2.0-noarch-32.txz:  Rebuilt.
  rc.S:  Fixed cgroup, cgmanager, and cgproxy handling so that it works if /usr
  is a separate partition.  Thanks to Richard Cranium and Matteo Bernardini.
ap/ghostscript-9.19-x86_64-2.txz:  Rebuilt.
  Use the bundled version of openjpeg, which includes patches needed by
  ghostscript.  Thanks to qunying.
ap/lxc-2.0.1-x86_64-2.txz:  Rebuilt.
  Merged rc.S changes.
l/libxml2-2.9.4-x86_64-1.txz:  Upgraded.
  This release fixes bugs and security issues:
  Heap-based buffer underreads due to xmlParseName (CVE-2016-4447).
  Format string vulnerability (CVE-2016-4448).
  Inappropriate fetch of entities content (CVE-2016-4449).
    http://xmlsoft.org/news.html
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-4447
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-4448
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-4449
  (* Security fix *)
l/libxslt-1.1.29-x86_64-1.txz:  Upgraded.
  This release fixes bugs and a security issue:
  Fix for type confusion in preprocessing attributes (Daniel Veillard).
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-7995
  (* Security fix *)
n/php-5.6.22-x86_64-1.txz:  Upgraded.
    http://php.net/ChangeLog-5.php#5.6.22
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-7456
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-5093
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-5094
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-5096
  (* Security fix *)
xap/geeqie-1.3-x86_64-1.txz:  Upgraded.
  Make rc.dropbear executable.  Thanks to Eduard Rozenberg.
quoi
n°1390968
cycojesus
Mèo Lười
Posté le 31-05-2016 à 09:20:05  profilanswer
Je n'suis pas z'un héros !
Tue May 31 05:42:04 UTC 2016
a/aaa_elflibs-14.2-x86_64-18.txz:  Rebuilt.
ap/tmux-2.1-x86_64-3.txz:  Rebuilt.
  Added /usr/share/terminfo/tmux{,-256color}.  Thanks to dugan.
d/python-setuptools-21.2.2-x86_64-1.txz:  Upgraded.
n/curl-7.49.1-x86_64-1.txz:  Upgraded.
xap/blueman-2.0.4-x86_64-1.txz:  Upgraded.
xap/imagemagick-6.9.4_5-x86_64-1.txz:  Upgraded.
  Removed popen() support to prevent another shell vulnerability.  This
  issue was discovered by Bob Friesenhahn, of the GraphicsMagick project.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-5118
  (* Security fix *)
xap/mozilla-thunderbird-45.1.1-x86_64-1.txz:  Upgraded.
  (* Security fix *)
xap/xscreensaver-5.35-x86_64-1.txz:  Upgraded.
poil au dos
n°1390994
cycojesus
Mèo Lười
Posté le 01-06-2016 à 06:56:18  profilanswer
chépa
Tue May 31 20:05:12 UTC 2016
ap/cdrtools-3.01-x86_64-3.txz:  Rebuilt.
  Applied cdrtools-3.01-fix-20151126-mkisofs-isoinfo.patch.  Thanks to gmgf.
ap/hplip-3.16.5-x86_64-2.txz:  Rebuilt.
  Recompiled with these changed paths:
   --with-hpppddir=/usr/share/ppd/HP
   --with-drvdir=/usr/share/cups/drv/HP
  This matches what is expected for Slackware in the distros.dat file and is
  hardcoded in core_install.py.  Thanks to kjhambrick.
l/LibRaw-0.17.2-x86_64-1.txz:  Upgraded.
l/lcms2-2.7-x86_64-2.txz:  Rebuilt.
  Don't package PDF/RTF docs.
n/bluez-5.40-x86_64-1.txz:  Upgraded.
extra/bash-completion/bash-completion-2.2-noarch-3.txz:  Rebuilt.
  Removed mpv -> mplayer symlink.  Thanks to Robby Workman.
patché
n°1391062
cycojesus
Mèo Lười
Posté le 03-06-2016 à 07:01:53  profilanswer
Pépin nouveau
Thu Jun  2 19:08:13 UTC 2016
This could be the last batch of updates before 14.2 stable, so please test!
a/kernel-firmware-20160601git-noarch-1.txz:  Upgraded.
a/kernel-generic-4.4.12-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.4.12-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.4.12-x86_64-1.txz:  Upgraded.
ap/hplip-3.16.5-x86_64-3.txz:  Rebuilt.
  Patched setup.py to set LC_ALL=C, which should fix parsing CUPS output.
d/gdb-7.11.1-x86_64-1.txz:  Upgraded.
d/kernel-headers-4.4.12-x86-1.txz:  Upgraded.
k/kernel-source-4.4.12-noarch-1.txz:  Upgraded.
l/harfbuzz-1.2.7-x86_64-1.txz:  Upgraded.
n/libnftnl-1.0.6-x86_64-1.txz:  Upgraded.
xap/imagemagick-6.9.4_6-x86_64-1.txz:  Upgraded.
xap/xscreensaver-5.35-x86_64-2.txz:  Rebuilt.
  Fixed missing '\' in the build script which caused a few configure options
  to be skipped.  Thanks to Stuart Winter.
bref
n°1391108
cycojesus
Mèo Lười
Posté le 04-06-2016 à 06:15:55  profilanswer
Caramba ! Encore raté !
Fri Jun  3 23:36:07 UTC 2016
ap/lxc-2.0.1-x86_64-3.txz:  Rebuilt.
  In /etc/inittab, use "shutdown -h now" for powerfail.  Without this, lxc-stop
  will send SIGPWR to attempt to stop the container, and will then force stop
  it after a one minute timeout.  Thanks to Andreas Vögele.
  In the init scripts, wrap $container in double quotes to prevent syntax
  errors if the variable is unset.  Thanks to Jakub 'shasta' Jankowski.
l/libxml2-2.9.4-x86_64-2.txz:  Rebuilt.
  Fix attribute decoding during XML schema validation.
n/net-snmp-5.7.3-x86_64-3.txz:  Rebuilt.
  Include support for the ucd-snmp/diskio module.
n/ntp-4.2.8p8-x86_64-1.txz:  Upgraded.
  This release patches one high and four low severity security issues:
  CVE-2016-4957: Crypto-NAK crash
  CVE-2016-4953: Bad authentication demobilizes ephemeral associations
  CVE-2016-4954: Processing spoofed server packets
  CVE-2016-4955: Autokey association reset
  CVE-2016-4956: Broadcast interleave
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-4957
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-4953
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-4954
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-4955
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-4956
  (* Security fix *)
xap/imagemagick-6.9.4_7-x86_64-1.txz:  Upgraded.
xfce/xfce4-panel-4.12.0-x86_64-3.txz:  Rebuilt.
  Blink taskbar buttons for notification 4 times, not G_MAXUINT times.
[:el awrence:1]
Slackware 9.0[slackware] Suppression de terminaux virtuels ?
!! Configuration reseaux, slackware 9 !!Installer slackware 9.0 par ftp (boot disquette)
[Pb] Installation new HDD sous slackware 8.0[RESOLU] Pb d'execution mysql sur slackware ...
Slackware 9 du pur bonheurMonter une partition NTFS sous linux (slackware 9.0)
Slackware 9.0 Finale OUTJe sens que je vais quitter Slackware (pas en serv)
Plus de sujets relatifs à : [SLACKWARE] du présent - 15.0
