3901 connectés
 Page :   1  2  3  4
Optimiser un peu les performances de Gnome
n°752572
Arjuna
Aircraft Ident.: F-MBSD
Posté le 15-11-2005 à 17:59:50  profilanswer
ok ok :)
n°752611
Taz
bisounours-codeur
Posté le 15-11-2005 à 19:43:31  profilanswer
vmstat 1 60
pour faire une petite analyse sur 60s.
n'utilise que ssh. à bas telnet.
n°752619
Arjuna
Posté le 15-11-2005 à 20:00:50  profilanswer
Alors :
hostname -f et ping :
debian:/home/sylvain# hostname -f
debian.workgroup
debian:/home/sylvain# ping `hostname -f`
PING debian.workgroup (127.0.1.1) 56(84) bytes of data.
64 bytes from debian.workgroup (127.0.1.1): icmp_seq=1 ttl=64 time=0.087 ms
64 bytes from debian.workgroup (127.0.1.1): icmp_seq=2 ttl=64 time=0.079 ms
64 bytes from debian.workgroup (127.0.1.1): icmp_seq=3 ttl=64 time=0.079 ms
64 bytes from debian.workgroup (127.0.1.1): icmp_seq=4 ttl=64 time=0.075 ms
--- debian.workgroup ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 2999ms
rtt min/avg/max/mdev = 0.075/0.080/0.087/0.004 ms
ping sur mon ip :
debian:/home/sylvain# ifconfig -a
eth0      Lien encap:Ethernet  HWaddr 00:50:BA:0A:51:4D
          inet adr:192.168.0.3  Bcast:192.168.0.255  Masque:255.255.255.0
          adr inet6: fe80::250:baff:fe0a:514d/64 Scope:Lien
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:2685 errors:0 dropped:0 overruns:0 frame:0
          TX packets:456 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 lg file transmission:1000
          RX bytes:905373 (884.1 KiB)  TX bytes:68380 (66.7 KiB)
          Interruption:11 Adresse de base:0xe400
lo        Lien encap:Boucle locale
          inet adr:127.0.0.1  Masque:255.0.0.0
          adr inet6: ::1/128 Scope:Hôte
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:96 errors:0 dropped:0 overruns:0 frame:0
          TX packets:96 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 lg file transmission:0
          RX bytes:5505 (5.3 KiB)  TX bytes:5505 (5.3 KiB)
sit0      Lien encap:IPv6-dans-IPv4
          NOARP  MTU:1480  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 b)  TX bytes:0 (0.0 b)
debian:/home/sylvain# ping 192.168.0.3
PING 192.168.0.3 (192.168.0.3) 56(84) bytes of data.
64 bytes from 192.168.0.3: icmp_seq=1 ttl=64 time=0.084 ms
64 bytes from 192.168.0.3: icmp_seq=2 ttl=64 time=0.077 ms
--- 192.168.0.3 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 999ms
rtt min/avg/max/mdev = 0.077/0.080/0.084/0.009 ms
Un petit traceroute sur google, y'a pas de problème, il trouve bien et passe bien par mes deux routeurs :
debian:/home/sylvain# traceroute www.google.com
traceroute: Warning: www.google.com has multiple addresses; using 66.102.9.99
traceroute to www.l.google.com (66.102.9.99), 30 hops max, 40 byte packets
 1  192.168.0.138 (192.168.0.138)  21.444 ms  0.505 ms  0.253 ms
 2  10.0.0.138 (10.0.0.138)  3.311 ms  2.827 ms  1.633 ms
 3  AMontsouris-105-1-1-129.w80-15.abo.wanadoo.fr (80.15.103.129)  57.332 ms  55.359 ms  59.098 ms
 4  GE2-258.ncidf203.Aubervilliers.francetelecom.net (80.10.160.5)  58.408 ms  58.902 ms  56.764 ms
 5  pos1-0.nraub203.Aubervilliers.francetelecom.net (193.252.98.154)  61.900 ms  116.482 ms  172.329 ms
 6  193.252.159.126 (193.252.159.126)  58.875 ms  58.152 ms  57.580 ms
 7  po14-0.pascr3.Paris.opentransit.net (193.251.243.186)  60.853 ms  58.104 ms  56.960 ms
 8  po10-0.loncr3.London.opentransit.net (193.251.242.18)  67.586 ms  70.298 ms  65.326 ms
 9  google-1.GW.opentransit.net (193.251.249.82)  67.852 ms  67.750 ms  66.757 ms
10  72.14.238.242 (72.14.238.242)  67.778 ms 72.14.238.246 (72.14.238.246)  69.875 ms 72.14.238.242 (72.14.238.242)  67.158 ms
11  216.239.49.254 (216.239.49.254)  88.616 ms  87.606 ms  88.492 ms
12  66.249.95.167 (66.249.95.167)  79.521 ms  76.414 ms  78.220 ms
13  64.233.174.14 (64.233.174.14)  79.647 ms  78.731 ms  78.242 ms
14  66.102.9.99 (66.102.9.99)  76.860 ms  78.072 ms  78.382 ms
Par contre, mais ça doit venir de nslookup qui ne marche pas comme sous  Windows, ça ne marche pas :
debian:/home/sylvain# nslookup www.google.com
;; connection timed out; no servers could be reached
Sinon, vmstat ne semble pas installé. C'est quoi le bon package ?
debian:/home/sylvain# wmstat 1 60
bash: wmstat: command not found
debian:/home/sylvain# apt-get install vmstat
Lecture des listes de paquets... Fait
Construction de l'arbre des dépendances... Fait
E: Impossible de trouver le paquet vmstat
debian:/home/sylvain# apt-cache search vmstat
dstat - versatile resource statistics tool
ifstat - InterFace STATistics Monitoring
tcpstat - network interface statistics reporting tool
n°752622
Mjules
Parle dans le vide
Posté le 15-11-2005 à 20:04:18  profilanswer
pour nslookup, utilises plutôt dig ou hosts qui marchent mieux ;)
Celui qui pose une question est idiot 5 minutes. Celui qui n'en pose pas le reste toute sa vie. |  Membre du grand complot pharmaceutico-médico-scientifico-judéo-maçonnique.
n°752624
Arjuna
Posté le 15-11-2005 à 20:08:19  profilanswer
C'est guère plus folichon :D
sylvain@debian:~$ hosts www.google.com
bash: hosts: command not found
sylvain@debian:~$ dig www.google.com
; <<>> DiG 9.3.1 <<>> www.google.com
;; global options:  printcmd
n°752626
Mjules
Parle dans le vide
Posté le 15-11-2005 à 20:08:35  profilanswer
host sans s, pardon
n°752630
Arjuna
Posté le 15-11-2005 à 20:12:07  profilanswer
L'exemple du man fonctionne pas mieu... Y déconne votre bidule :D
 sylvain@debian:~$ dig +qr www.isc.org any -x 127.0.0.1 isc.org ns +noqr
; <<>> DiG 9.3.1 <<>> +qr www.isc.org any -x 127.0.0.1 isc.org ns +noqr
Ceci dit, mon routeur est configuré pour en pas répondre à ICMP ainsi que quelques autres paramètres (après flashage de sa ROM, je n'ai pas remodifié les paramètres du firewall, mise à par la mise en place d'une DMZ sur mon serveur 2K3)
n°752631
Arjuna
Posté le 15-11-2005 à 20:12:31  profilanswer
Marche pas mieu host apparement :
sylvain@debian:~$ host www.google.com
:spamafote:
C'est bizarre quand même, parceque nslookup marche sans problème sur mes pc sous windows, je viens de tester... donc les requêtes dns devraient marcher :??: (pis de toute façon, mozilla marche, donc c'est bien que ça marche ! :))
Message édité par Arjuna le 15-11-2005 à 20:13:38
n°752632
Arjuna
Posté le 15-11-2005 à 20:14:39  profilanswer
Je confirme, sous Windows ça marche :
Microsoft Windows XP [version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\MagicBuzz>nslookup www.google.com
*** Impossible de trouver le nom de serveur pour l'adresse 192.168.0.138 : Non-e
xistent domain
*** Les serveurs par défaut ne sont pas disponibles
Serveur :  UnKnown
Address:  192.168.0.138
Réponse ne faisant pas autorité :
Nom :    www.l.google.com
Addresses:  216.239.59.147, 216.239.59.99, 216.239.59.103, 216.239.59.104
Aliases:  www.google.com
En tout cas, je m'amuse bien, mon serveur à l'air de bien aimer se prendre des pings dans la tête :)
debian:/home/sylvain# ping -f 192.168.0.1 -c 65535
PING 192.168.0.1 (192.168.0.1) 56(84) bytes of data.
--- 192.168.0.1 ping statistics ---
65535 packets transmitted, 65535 received, 0% packet loss, time 12018ms
rtt min/avg/max/mdev = 0.105/0.123/11.903/0.080 ms, ipg/ewma 0.183/0.120 ms
Message édité par Arjuna le 15-11-2005 à 20:21:09
n°752636
Taz
bisounours-codeur
Posté le 15-11-2005 à 20:21:52  profilanswer
> apt-file search vmstat
procps: usr/bin/vmstat
n°752637
Arjuna
Posté le 15-11-2005 à 20:23:22  profilanswer
debian:/home/sylvain# apt-file search vmstat
bash: apt-file: command not found
apt-file marche pas. Mais le souci, c'est que j'ai 3 packets qui répondent à vmstat, et du coup je sais pas lequel est le bon...
n°752638
Arjuna
Posté le 15-11-2005 à 20:24:03  profilanswer
Euh... Capige rien...
Maintenant il marche :??: (vmstat)
Message édité par Arjuna le 15-11-2005 à 20:24:16
n°752640
Arjuna
Posté le 15-11-2005 à 20:32:40  profilanswer
Résultat de "vmstat 1 60" lancé :
- en mode console
- compte root
- toutes applications fermées dans gnome
http://ftp.manga-torii.com/vmstat.txt
Message édité par Arjuna le 15-11-2005 à 20:32:50
n°752642
Taz
bisounours-codeur
Posté le 15-11-2005 à 20:34:41  profilanswer
là encore tout est normal.
n°752643
Arjuna
Posté le 15-11-2005 à 20:37:19  profilanswer
bon, on va dire que c'est normal alors, et que ça doit venir de la façon de gérer la gui de gnome... la création d'une fenêtre doit bouffer pas mal d'io ou de cpu.
n°752644
alien cons​piracy
hardtrance addict
Posté le 15-11-2005 à 20:42:53  profilanswer
Après avoir installé prelink, tu as fait prelink -amR ?
n°752676
Arjuna
Posté le 15-11-2005 à 21:51:47  profilanswer
nope, vais voir ça
ps: désolé, pour le délai de réponse, j'ai un pote qui m'a appelé au téléphone pendant plus d'une heure :D
n°752681
Arjuna
Posté le 15-11-2005 à 22:19:23  profilanswer
groumpf, il a changé sa batterie :D
bon, donc, prelink -amR
n°752682
Arjuna
Posté le 15-11-2005 à 22:20:03  profilanswer
ça patine dans la choucroutte là...
n°752683
Arjuna
Posté le 15-11-2005 à 22:20:44  profilanswer
c'est normal si y'a plein de messages d'erreur ?
debian:/home/sylvain# prelink -amR
/usr/sbin/prelink.bin: /usr/lib/mozilla/TestGtkEmbed: Could not find one of the dependencies
/usr/sbin/prelink.bin: /usr/lib/openoffice/program/pkgchk.bin: Could not find one of the dependencies
/usr/sbin/prelink.bin: /usr/lib/openoffice/program/pluginapp.bin: Could not find one of the dependencies
/usr/sbin/prelink.bin: /usr/lib/openoffice/program/setofficelang.bin: Could not find one of the dependencies
/usr/sbin/prelink.bin: /usr/lib/openoffice/program/setup.bin: Could not find one of the dependencies
/usr/sbin/prelink.bin: /usr/lib/openoffice/program/soffice.bin: Could not find one of the dependencies
/usr/sbin/prelink.bin: /usr/lib/openoffice/program/spadmin.bin: Could not find one of the dependencies
/usr/sbin/prelink.bin: /usr/lib/openoffice/program/configimport.bin: Could not find one of the dependencies
/usr/sbin/prelink.bin: /usr/lib/openoffice/program/regcomp: Could not find one of the dependencies
Executing /sbin/init U
Message édité par Arjuna le 15-11-2005 à 22:24:14
n°752704
esox_ch
Posté le 15-11-2005 à 23:33:48  profilanswer
#apt-get check ?
Si la vérité est découverte par quelqu'un d'autre,elle perd toujours un peu d'attrait
n°752708
Arjuna
Posté le 15-11-2005 à 23:46:46  profilanswer
Rien d'anormal à signaler
login as: root
root@192.168.0.3's password:
Last login: Tue Nov 15 23:40:54 2005 from 192.168.0.105
Linux debian 2.6.12-1-k7 #1 Tue Sep 27 13:22:07 JST 2005 i686 GNU/Linux
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
debian:~# apt-get check
n°752711
Taz
bisounours-codeur
Posté le 15-11-2005 à 23:53:59  profilanswer
apt-get install prelink
et tu touches à rien, tu laisse cron lancer les trucs.
n°752712
Taz
bisounours-codeur
Posté le 15-11-2005 à 23:55:57  profilanswer
et non ouvrir une fenêtre ne bouffe ni des masses de CPU, ni des masses d'E/S
n°752715
Taz
bisounours-codeur
Posté le 16-11-2005 à 00:04:08  profilanswer
honnêtement, je vois pas. t'as plein de ram, un disque rapide, pas de swap utilisée. sur un P3 600, 128Mo, 10G de disque lent, gnome-2-10 ça tournait vachement bien.
n°752729
chaced
Posté le 16-11-2005 à 02:06:26  profilanswer
peut etre un probleme avec HAL ? http://forum.hardware.fr/hardwaref [...] 3499-1.htm
n°752730
belgique
Posté le 16-11-2005 à 02:26:16  profilanswer
Cela dit gnome-terminal est long à charger à la première utilisation chez moi.
n°752765
Arjuna
Posté le 16-11-2005 à 10:05:40  profilanswer
c'est ce que j'ai fait au début. faut que je le refasse :??:
n°752767
Arjuna
Posté le 16-11-2005 à 10:08:49  profilanswer
vais regarder ce pc de l'espace (jeu de moi à deux balles faisant référence au super calculateur du même nom embarqué dans le vaisseau dans le film 2001 l'odyssée de l'espace, qui faisait lui-même un clin d'oeil à la firme IBM :pt1cable:)
mais moi c'est pas la souris qui ramme, juste la fenêtre qui tarde à s'afficher. m'enfin c'est pas la mort non plus, suffit de cliquer un coup et taper "enter" et comme ça je suis sûr de pas avoir ratté mon double clic :D
n°752779
Taz
bisounours-codeur
Posté le 16-11-2005 à 10:42:32  profilanswer
non, mais t'amuse pas à lancer la commande prelink en aveugle
n°752794
memaster
M.arc a volé mon 62
Posté le 16-11-2005 à 11:38:49  profilanswer
moi c'est qd j'accede la 1ere fois (juste après demarrage) au menu de gnome.
ensuite c'est nickel, pk ne chargent ils pas ce menu en ram dès le demarrage??
n°752809
Arjuna
Posté le 16-11-2005 à 12:20:44  profilanswer
taz > ben je sais pas. hier avant hier qq1 m'a dit d'installer le package, ce que j'ai fais. Ensuite, une personne m'a dit de faire "prelink -amR", ce que j'ai fait.
ça fait quoi au juste ? quelles sont les vérifs à faire avant de lancer ce module ?
Message édité par Arjuna le 16-11-2005 à 12:21:14
n°752812
Taz
bisounours-codeur
Posté le 16-11-2005 à 12:24:54  profilanswer
c'est pas grave, c'est juste que le cron fait mieux les choses dans plus de dossiers. tu vas pas t'amuser à faire des prelink manuels et incomplets chaque fois que t'installes/maj un nouveau truc quand même
n°752814
chaced
Posté le 16-11-2005 à 12:36:02  profilanswer
Utilise XTerm :D
n°753011
Posté le 17-11-2005 à 00:59:43  answer
chaced a écrit :
-ton DMA est bien actif pour ton HD ?
 voir avec hdparm /dev/hda et hdparm -t /dev/hda pour tester
mode newbie : et pour vérifier si le dm est activé avec mon lecteur et mon graveur DVD, comment fait on ?
n°753015
mardi_soir
Posté le 17-11-2005 à 01:21:38  profilanswer
j'etait jusqu'a il y  a peu sur un p2 400 Mhz et xfce tourne nickel (mêm e17 sans tout les modules cela dit).   ..
j'avais remis un noyau minimum .. mais .. je granti sur un p2 il est possible d'avoir un truc relativement rapide ..
ps > gnome-terminal est lent même sur un p4
bonc'tait pas une bete de course nnn plus mais .. ca focntionait bien sous kde .
sous debian en tout cas ..
n°753146
chaced
Posté le 17-11-2005 à 15:38:18  profilanswer
On a :
hda : ide primary master
hdb : ide primary slave
hdc : ide secondary master
hdd : ide secondary slave
en fonction de ça, tu demande a hdparm les infos sur ton lecteur cd
par exemple pour mon graveur j'ai :
yup:/home/cedric# hdparm /dev/hdc
/dev/hdc:
 IO_support   =  1 (32-bit)
 unmaskirq    =  1 (on)
 using_dma    =  1 (on)
 keepsettings =  0 (off)
 readonly     =  0 (off)
 readahead    = 256 (on)
n°753200
Kornwall
Posté le 17-11-2005 à 18:11:54  profilanswer
ça va j'ai fais un test dd :
sudo hdparm -tT /dev/hda
environ 56mo de transfert ;)
n°754175
Posté le 20-11-2005 à 12:24:25  answer
merci chaced
mon graveur et mon lecteur DVD supportent le udma2 apparemment (j'ai fait sudo hdparm -I /dev/nom_de_mon-periphérique)
et la commande sudo hdparm -d /dev/nom_de_mon-periphérique m'indique que le dma est pas activé
est-il activable sur ces lecteurs ?
(mon disque dur est udma5 avec dma activé)
Message édité par Profil supprimé le 20-11-2005 à 12:29:13
n°754187
chaced
Posté le 20-11-2005 à 12:50:42  profilanswer
hdparm -d1 pour activer.
n°754236
Posté le 20-11-2005 à 15:07:10  answer
ben non apparemment c'est seuelment pour la session en cours, ça
faut éditer hdparm.conf
http://wiki.ubuntu-fr.org/materiel/optimisation_ide
ma question c'était pas comment faire mais si dans mon cas c'était faisable et souhaitable ?
 Page :   1  2  3  4
Où configure-t-on la fréquence du moniteur dans Gnome ?Accéder à son home partagé par Samba avec GNOME
Problème avec les menus Gnome[debian]Probleme de lancement gnome et extinction du pc
[RESOLU#] Gnome 2.12 : ajouter des résolutions d'écran[gnome] désactiver l'apparition automatique d'une icone sur le bureau
[DEBIAN] Probleme avec GnomeProbleme dernier gnome
[resolu]Comment changer le lecteur video par defaut de gnome?visualiseur de photos sous debian gnome
Plus de sujets relatifs à : Optimiser un peu les performances de Gnome
