4076 connectés
 Page :   1  2  3  4  5  ..  29  30  31  ..  64  65  66  67  68  69
[Topic FreeBSD] nouvelle version 10.0 dispo !!
n°987193
o'gure
Multi grognon de B_L
Posté le 04-12-2007 à 07:46:41  profilanswer
vlack a écrit :
Mon user sur mon poste a un UID 1001
Sur mon NAS c'est 1003.
Du coup, j'ai pas les droits. C'est quoi la technique ?
Je ne peux pas faire un gros chown de bourrin sur le nas, et changer l'UID du user, car l'UID 1001 est déjà pris sur le nas [:petrus75]
L'autre solution serait de changer l'UID de mon user local, mais je sens que ça va tout péter [:klemton]
Tu ne peux pas une authentification basée sur LDAP, NIS+ ?
Relax. Take a deep breath !
n°987554
vlack
Posté le 04-12-2007 à 19:08:35  profilanswer
Merci pour votre aide  :jap:
Ou AppleShare [:petrus75]
Pourquoi faire simple ?
J'ai ça comme choix en "security mode" :
  • Share. Fit for home or small office. Select this option if you would like to restrict share access with the use of an optional share password. Each user accesses the shares on the device as a common guest user and will have the same read/write privilege as other users. This option supports setting disk quotas on a per-share basis.
  • User. Fit for medium-size office or workgroup. Select this option if you would like to control access to shares based on user or group accounts and your network does not utilize a domain controller for authentication. If you select this option, you will need to create a user account for anyone accessing this device. This option supports setting disk quotas on a per-user or per-group basis.
  • Domain. Fit for department or corporate environment. Select this option if you would like to control access to shares based on user and group accounts and your Windows network utilizes a centralized domain controller or active directory service (ADS) for login authentication. This option will not support disk quotas. Do not select this option if you are unsure.
Actuellement je suis en "share"
Quand il neige des pâtes, fartez vos skis avec du fromage râpé.
n°987583
black_lord
Truth speaks from peacefulness
Posté le 04-12-2007 à 20:45:23  profilanswer
j'ai mis à jour tous mes freebsd [:jar jar]
ok, tout le monde s'en fout [:petrus75]
uptime is for lousy system administrators what Viagra is for impotent people - mes unixeries - github me
n°987590
vlack
Posté le 04-12-2007 à 20:54:48  profilanswer
Mais non :o
Je voulais te féliciter, mais ce sont des FreeBSD après tout, la mise à jour est une formalité :o
n°987591
black_lord
Posté le 04-12-2007 à 20:57:24  profilanswer
j'ai pas mis à jour le dernier 4.11 qui me reste [:dawa]
Message édité par black_lord le 04-12-2007 à 20:57:39
n°987605
-Opera-
mago spé électricité
Posté le 04-12-2007 à 21:35:22  profilanswer
Depuis la Beta4 le world ne compile plus chez moi. :/
You get so used to things the way they are. And I've always been alone. I guess that makes me lonely.
n°987729
the_fireba​ll
We Are What We Shit
Posté le 05-12-2007 à 10:58:00  profilanswer
hum j'ai l'impresison qu'avec portupgrade -arRf, des ports sont recompilés plusieurs fois, ce qui n'est pas optimal pour le moins ! Deja que ça rame dans mon qemu la compile, si en plus, je me tape plus d'une compile pour certains ports, c'est la loose !
Two thousand years of misery, of torture in my name, hypocrisy made paramount, paranoia the law, my name is called religion, sadistic, sacred whore.
n°987743
black_lord
Posté le 05-12-2007 à 11:33:54  profilanswer
http://bsdpants.blogspot.com/2006/ [...] ystem.html
mais perso je n'utilise plus portupgrade :)
n°987752
the_fireba​ll
We Are What We Shit
Posté le 05-12-2007 à 11:47:32  profilanswer
tu utilises quoi alors ? make ? portmaster ?
n°987753
black_lord
Posté le 05-12-2007 à 11:48:14  profilanswer
portmaster, ça m'évite de faire tout exploser quand je casse ruby (vécu)
n°987754
the_fireba​ll
We Are What We Shit
Posté le 05-12-2007 à 11:50:15  profilanswer
concretement, quels sont les avantages/inconvénient de l'un par rapport à l'autre ?
n°987756
black_lord
Posté le 05-12-2007 à 11:54:06  profilanswer
portmaster est un script shell, il n'a pas de dépendances, alors que portupgrade c'est du ruby toussa. Après pour la mise à jour des ports et le problème de savoir si on mets plusieurs fois un ports à jour j'ai pas comparé. j'avais même jamais fait gaffe au fait que portupgrade recompilait plusieurs fois un port.
n°987759
the_fireba​ll
We Are What We Shit
Posté le 05-12-2007 à 12:01:13  profilanswer
c'est la première fois que je vois ça aussi, mais je n'avais jamais fait de -arRf avant. Je pense que les multiples compilations viennent du fait que pour chaque ports, portupgrade va regarder ses dépendances et va les recompiler quoi qu'il en soit. mais peut etre que je me trompe sur les causes
n°987847
SpN
BF4: Joorem
Posté le 05-12-2007 à 15:10:50  profilanswer
Je connaissais pas portmaster, je vais regarder ça :) black_lord, comment tu as fait pour casser ruby ? :??:
the_fireball, j'ai la même supposition que toi, surtout avec le -f !
Sinon, vous avez déjà mis en place un FreeBSD sous vmware ? J'ai ce foutu problème de 'calcru: negative runtime' :fou: Sur google, à part kern.timecounter.hardware il n'y a rien d'autre :cry:
n°987864
black_lord
Posté le 05-12-2007 à 15:36:00  profilanswer
si je le savais je l'aurais pas cassé [:petrus75]
edit c'était lors d'une maj, une dépendance qui a pété, et du coup ruby était HS
Message édité par black_lord le 05-12-2007 à 15:37:05
n°987865
SpN
BF4: Joorem
Posté le 05-12-2007 à 15:37:18  profilanswer
[:ddr555]
C'est après une MAJ ?
Edit: Oki, perso pour éviter ce genre de couilles, je compile à la mano, un ptit make... Si c'est ok je désinstalle, et je fais un make install clean.
Message édité par SpN le 05-12-2007 à 15:38:11
n°988451
vlack
Posté le 06-12-2007 à 20:46:30  profilanswer
Pour reprendre ma question posée sur blabla :
Comment rendre une clef usb bootable ?
(oui j'ai scrooglé)
n°988492
black_lord
Posté le 06-12-2007 à 23:51:52  profilanswer
tu as regardé http://imil.net/nlk/ ? (oui c'est du netbsd mais bon)
Message édité par black_lord le 06-12-2007 à 23:52:08
n°988536
Posté le 07-12-2007 à 08:51:28  answer
[:ninja dago]
Autant j'adore FreeBSD, autant je trouve que la gestion XWindows est vraiment pourrave  :sweat:  C'est pas la volonte qui manque, mais faire fonctionner X est deja un defi, mais en plus avec la bonne reso et la CG reconnue, c'est de l'exploit... :/
n°988540
acheron2
Posté le 07-12-2007 à 09:00:17  profilanswer
SpN a écrit :
[:ddr555]
c'est le meilleur moyen de tout faire péter (exp inside). Que se passe t'il quand tu recompiles une lib et quelle bump de révision ? => tous les softs dépendant de cette lib ne fonctionneront plus (j'ai borké tout mon domaine samba en faisant une mise à jour de cups...)
n°988617
SpN
BF4: Joorem
Posté le 07-12-2007 à 11:22:10  profilanswer
Oui. J'ai eu le problème avec OpenSSL et les libcrypto. Je les sauvegarde avant chaque MAJ [:spamafote]
Et la méthode citée plus haut n'est utilisé que pour portupgrade :)
n°988696
-Opera-
Posté le 07-12-2007 à 13:32:43  profilanswer
Ben faut bien admettre que X11 commence sérieusement à sentir le moisi maintenant, ce n'est pas toujours dans les vieux pots qu'on fait les meilleures soupes. [:spamafote]
n°988878
vlack
Posté le 08-12-2007 à 08:57:10  profilanswer
Merci :jap:
Donc grub ferait l'affaire.
Mais je viens de voir que j'ai pas usb comme "boot device" dans mon bios [:cerveau klem]
Bourdel [:mechant]
n°988885
black_lord
Posté le 08-12-2007 à 09:38:48  profilanswer
vlack a écrit :
Merci :jap:
Bourdel [:mechant]
[:rofl]
n°988891
vlack
Posté le 08-12-2007 à 09:56:23  profilanswer
C'est pas drôle  :sweat:
Mon ordi reboot dès que j'essaye de graver un cd avec cdrecord :sweat:
Avec burncd ça mouline dans le vide indéfiniment :sweat:
n°988913
black_lord
Posté le 08-12-2007 à 11:05:56  profilanswer
[:xx_xx]
graveur ? nappe IDE ? CM ?
n°988918
vlack
Posté le 08-12-2007 à 11:13:32  profilanswer
[:xx_xx]
J'ai déjà changé le graveur, même problème.
La nappe : je ne pense pas, j'ai un DD dessus qui fonctionne correctement.
CM : Bah pareil, le DD sur la même nappe fonctionne...
Je penche donc vers un problème logiciel. J'aimerais tester avec un autre OS, mais pour ça faudrait que je puisse en installer un, ou graver un liveCD [:petrus75]
Je vais tenter une mise à jour, avec un nouveau noyal ça marchera peut-être mieux...
n°989063
vlack
Posté le 08-12-2007 à 20:39:53  profilanswer
Il y a un danger objectif à me synchro avec RELENG_7 ?
n°989071
black_lord
Posté le 08-12-2007 à 21:19:51  profilanswer
non. pas de soucis en -CURRENT du temps de la 7, j'ai pas encore updaté vers la 8.
n°989082
vlack
Posté le 08-12-2007 à 21:58:16  profilanswer
make buildworld en cour [:totoz]
n°989094
-Opera-
Posté le 08-12-2007 à 23:57:08  profilanswer
Au contraire, grosse màj hier, notemment au niveau de bind. Le monde a de nouveau compilé pour moi. \o/
Par contre, j'ai du enlever mes paramètres de make pour que ça passe. [:benou]
Message édité par -Opera- le 09-12-2007 à 00:00:11
n°989128
vlack
Posté le 09-12-2007 à 11:52:06  profilanswer
Après une interminable session de mergemaster, I'm back.
FreeBSD boitalette 7.0-BETA2 FreeBSD 7.0-BETA2 #3: Sun Dec  9 01:54:13 CET 2007     root@boitalette:/usr/obj/usr/src/sys/NOYAU  i386
n°990551
Walk_Man
To live is to die.
Posté le 12-12-2007 à 14:41:53  profilanswer
Salut les gens,
dites moi j'aimerai tenter de faire de la redondance de lignes internet, vous feriez ca avec quoi ? pf tout simplement ? Ou vous connaissez un autre outils qui fasse le café dans le genre.
Merci à vous :)
¡ Viva la Revolución !
n°990563
SpN
BF4: Joorem
Posté le 12-12-2007 à 15:01:25  profilanswer
La classe [:fanou]
n°990597
acheron2
Posté le 12-12-2007 à 15:53:56  profilanswer
Walk_Man a écrit :
Salut les gens,
Merci à vous :)
je ne sais pas si ça répond à ta question :
http://www.openbsd-edu.net/index.p [...] ignes_ADSL
n°990789
black_lord
Posté le 12-12-2007 à 18:38:26  profilanswer
Walk_Man a écrit :
Salut les gens,
Merci à vous :)
http://www.freebsd.org/doc/en_US.I [...] ation.html [:kukron]
n°990797
Walk_Man
To live is to die.
Posté le 12-12-2007 à 19:13:45  profilanswer
Forcement, oublié de regarder ZE BOOK, the handbook :o
Merci pour vos liens :love:
n°990830
vlack
Posté le 12-12-2007 à 20:00:57  profilanswer
SpN a écrit :
La classe [:fanou]
 [:zzzagathezzz]
n°990911
-Opera-
Posté le 13-12-2007 à 07:08:09  profilanswer
Gné, pas BETA4 ?  :??:
Clair, moi aussi le nombre de fois que j'ai cherché sur google alors que la réponse était là.  :D
"Le handbook toujours tu consulteras en premier".
n°990915
-Opera-
Posté le 13-12-2007 à 07:22:40  profilanswer
Pour ceux en RELENG_7, GROSSE màj des ports depuis hier/aujourd'hui [:mlc]
Looking up portsnap.FreeBSD.org mirrors... 4 mirrors found.
Fetching snapshot tag from portsnap1.FreeBSD.org... done.
Fetching snapshot metadata... done.
Updating from Tue Dec 11 19:49:23 CET 2007 to Thu Dec 13 04:42:35 CET 2007.
Fetching 4 metadata patches... done.
Applying metadata patches... done.
Fetching 0 metadata files... done.
Fetching 400 patches(...)
Applying patches... done.
Fetching 52 new ports or files... done.
Message édité par -Opera- le 13-12-2007 à 07:23:25
n°990922
acheron2
Posté le 13-12-2007 à 08:38:26  profilanswer
et oui, l'arbre des ports est en 'dégèlement' (http://lists.freebsd.org/pipermail/freebsd-ports/2007-December/045458.html)
Les ports sont indépendants de la version du système de base, releng_7 n'est pas le seul à avoir les ports à jour...
Message édité par acheron2 le 13-12-2007 à 08:40:48
[OpenBSD] Le topic du poisson qui pique (8.0 out, en route vers 8.1)Problème d'update Fedora (version de kernel, nvidia inside)
ubuntu version 6. qqqch ecran noir instal sur portableCat en version colorée ?
ldap / samba - guide - CA MARCHE !! WIKI dispoPidgin 2.6.0 (Voice and video support)
quelle version linux?[FreeBSD 5.4 Stable] Pure-FTPd et FXP
Plus de sujets relatifs à : [Topic FreeBSD] nouvelle version 10.0 dispo !!
