8543 connectés
 Page :   1  2  3  4  5  6  7  8  9  10  11  12  13  14  15  16  17  18  19  20
[Topic Unique] WANSVIEW NC-536M/W HD WIFI IP Camera PT + IR-Cut + SD
n°685913
paillassou
Posté le 07-03-2012 à 16:55:48  profilanswer
un de mes message encore de moi (oui je suis énervé :lol:)
THANKS for reply !
You are wrong when you say "the key is too long".
because WPA2 allows you to enter a key of 8 to 63 characters.
It is not because YOUR firmware contains errors that, in the world,
we have to degrade the security of a wireless network on which a camera NC536MW is connected !
LOOK AT THE ATTACHEMENT PICTURES PLEASE ;)
take 2 minutes to read the technical specifications please:
http://en.wikipedia.org/wiki/Wi-Fi_Protected_Access
Security
Pre-shared key mode (PSK, also known as Personal mode) is designed for home and small office networks that don't require the complexity of an 802.1X authentication server.[9] Each wireless network device encrypts the network traffic using a 256 bit key. This key may be entered either as a string of 64 hexadecimal digits, or as a passphrase of 8 to 63 printable ASCII characters.[10] If ASCII characters are used, the 256 bit key is calculated by applying the PBKDF2 key derivation function to the passphrase, using the SSID as the salt and 4096 iterations of HMAC-SHA1.[11]
Even the ipcamera from FOSCAM works with 63 characters in WPA2 KEY !
There is a bug & error in memory management that saves settings WIFI.
Your engineers have to correct this as soon as possible.
Take the test yourself:
try with a WPA2 key with 31 characters => it works !
try with a WPA2 key with 32 or more characters (63 max) => fault
and you will find that I do not tell nonsense.
Sometimes it is better to recognize that there is an error and don't tell the client:
"but no, there is no problem ! It's your fault, change the key it's too long !"
This is not correct, because I also tried searching for understanding this problem.
I will also like you to find a solution quickly by a new firmware that fixes this problem.
thank you very much
Best regards
paillassou's author:
http://forum.hardware.fr/hfr/Hardw [...] 6652_1.htm
Message édité par paillassou le 07-03-2012 à 16:57:56
n°685914
paillassou
Posté le 07-03-2012 à 16:58:36  profilanswer
je m'y prends mal où quoi ?
comment dois je procéder pour qu'ils m'écoutent et me comprennent :(
Message édité par paillassou le 07-03-2012 à 17:04:29
n°685945
dj_ilf
Posté le 07-03-2012 à 22:16:23  profilanswer
paillassou, j'ai encore des questions...
- si tu as fait les tests de détection de mouvements, ça donne quoi ?
- la webcam que tu as acheté c'est une no-name ? (par rapport au lien que tu as utilisé)
je compte en acheter une, via ce lien : http://cgi.ebay.fr/720P-CMOS-WiFi- [...] 297wt_1396
tu penses que c good ?
n°685948
paillassou
Posté le 07-03-2012 à 22:20:42  profilanswer
ben écoute oui j'ai testé la détection avec enregistrement de snap sur SD => ça fonctionne
y a 4 zones de détection et ça fonctionne...
pour l'achat
moi j'ai envoyé plusieurs mails pour demander si c'était un WANSWIEW NC536MW, firmware etc...
et le vendeur EBAY (chez qui j'ai acheté la mienne) m'a convaincu, il est réglo...
BRAVO pour la recherche EBAY qui t'as permis de trouver celle là ;)
http://cgi.ebay.fr/720P-CMOS-WiFi- [...] 231abc54a8
voilà...
Message édité par paillassou le 07-03-2012 à 23:06:26
n°685950
Posté le 07-03-2012 à 22:22:07  answer
Non je pense pas.
Le problème c'est eux :D. C'est pas trop la faute à ton interlocutrice à mon avis, le problème c'est le développeur du firmware derrière qui ne veut pas reconnaître son erreur, ou le responsable technique, et là ca peut avoir y avoir plein de raisons (égo, refus de dépenser de l'argent en maintenance du firmware, la sécurité n'est pas un critère important pour eux,....).
Message édité par Profil supprimé le 07-03-2012 à 22:22:59
n°685962
supergut
Posté le 08-03-2012 à 08:39:36  profilanswer
I dont speak French, but if anybody is looking for NCH-536MW Firmware V1.4.0.1.4:
https://www.yousendit.com/download/ [...] MEdVQU1UQw
(the link will expire in a week, so hurry!)
n°685967
paillassou
Posté le 08-03-2012 à 09:58:56  profilanswer
OUAOUUUHH !!!  :bounce:
THANK YOU VERY MUCH !!!   :jap:
It's very important for the community !  :jap:
i'm going to made a MIRROR donwload
on a web site like "multiupload" ;)
BEST REGARDS  :jap:
AND thanks a lot one more time !
Message édité par paillassou le 08-03-2012 à 10:00:33
n°685969
normel
Posté le 08-03-2012 à 10:15:51  profilanswer
Hello good day all.
Last time i had contact with paillassou, and i managed to view the 536by mobile , thanks !
FTP is not working for me, i think it is because of the camera. I can not specify an upload folder. There is no space to set subfolder. Check the image below:
http://imageshack.us/photo/my-imag [...] oblem.jpg/
It does not accept the characters either.
n°686024
paillassou
Posté le 08-03-2012 à 22:07:04  profilanswer
Yes i know, it's the same thing for me.
Try do this:
http://IPaddress/cgi-bin/hi3510/getftp.cgi
you understand that IPaddress is your cam = 192.168.1.50 for example ;)
if FTP SERVER = 192.168.1.100
you should see that there is
var server="192.168.1.100"; var port="21"; var username="toto"; var password="xxxxxxxx"; var mode="1"; var filename="";
var filename="";     =>> is a empty variable / not use
Message édité par paillassou le 09-03-2012 à 07:13:01
n°686025
paillassou
Posté le 08-03-2012 à 22:50:20  profilanswer
I've just send a mail to WANSVIEW for that FTP problem of directory
n°686033
normel
Posté le 09-03-2012 à 02:27:46  profilanswer
Paillassou... Merci
IT looks like complicated, but i will check it out later.. i have another issue now.. I have installed the firmware version V1.4.0.1.4 given by supergut.
Now when i login, i see green strokes in the screen:S
Edit:
Got newer firmware, solved
Here is a link:
http://www.2shared.com/file/tGgKbS [...] mP2En.html
Message édité par normel le 09-03-2012 à 04:45:47
n°686034
paillassou
Posté le 09-03-2012 à 06:49:51  profilanswer
tags: wansview NCH536MW firmware B12SE_V1.4.0.1.4_536mP2En.pkg B12SE_V1.4.0.1.5_536mP2En.pkg
THANK YOU VERY MUCH  :jap:  :hello:
AOUOUUUUUH ;)  :bounce:
How do you do to retreive this new firmware
B12SE_V1.4.0.1.5_536mP2En.pkg ????
It's WONDERFUL !!!  :ouch:
Who sent it to you ???  :sarcastic:
Where do you download it ?  :sarcastic:
On an Official Wansview website ?  :sarcastic:
it's very strange ;) it's wonderful, it's amazing  :pt1cable:   :bounce:  :ouch:  :sarcastic:
After a few day (one week) from my LONG explanations about wifi problems (about long wpa2 key) messages,
there is a new firmare B12SE_V1.4.0.1.5_536mP2En.pkg that runs on the web, somewhere...
Message édité par paillassou le 09-03-2012 à 07:32:40
n°686050
paillassou
Posté le 09-03-2012 à 11:02:28  profilanswer
Pour information:
Mon mail de ce matin:
Date: 2012-03-09 14:21
To: wansview@hotmail.com; service@wansview.com
Subject: Re: Re: NCH536MW
After a few day from my explanations about wifi problems (about long wpa2 key) messages,
there is a new firmare that runs on the web, somewhere...
with this sort of filename
Where can I download this (very important) file
on an official WANSVIEW WEBSITE ???
Could you send it to me ?
THANKS
Best Regards
Message édité par paillassou le 09-03-2012 à 11:03:05
n°686051
paillassou
Posté le 09-03-2012 à 11:06:17  profilanswer
Pour information:
La réponse du "secrétariat" WANSVIEW
Date: 2012/3/9
To: Paillassou
Dear Sir,
Yes, I have reported it to our Technology deparment to do it according to your suggestion.
But this has not been published on the website.
So I only send it to you for first test.
Hope you may understand.
Thanks and best regards,
Yours sincerely,
wansview - Sabrina
www.wansview.com
MSN: wansview@hotmail.com
Skype: sabrina_win
n°686052
normel
Posté le 09-03-2012 à 11:13:40  profilanswer
I have directly contact with the manufacturer , since a couple of months.
You look satisfied..
I have tried what you wrote about FTP, but it did not work. As return i want you to fix this FTP for me , and give me remote help by teamviewer.
I am owning a Synology. and want to use that as ftp..
I will sent you a my contact details as private message!
Message édité par normel le 09-03-2012 à 11:17:46
n°686053
paillassou
Posté le 09-03-2012 à 11:24:26  profilanswer
OH no, no, no
i have no solution for the ftp... sorry...
it is just to try... sorry
n°686054
paillassou
Posté le 09-03-2012 à 11:27:34  profilanswer
after the wifi problem (long wpa2 key),
there is now a ftp problem about "directory" choose.
i'm waiting for WANSVIEW answer...
n°686061
foxyloxy
Posté le 09-03-2012 à 12:10:53  profilanswer
Hi folks - just for info I am having no luck getting this camera working with surveillance station on the synology.
Apologies this is in english - my french is not good.
n°686062
normel
Posté le 09-03-2012 à 12:19:54  profilanswer
hheehe. I was in france a while ago. Most people there, dont like english i think. Almost every person i asked something in english, looked BAD at me, and gave a french reaction. Good that those people here dont do that
But the synology is not supported as i know. IT is also reported in second post on this thread
Message édité par normel le 09-03-2012 à 12:20:25
n°686063
foxyloxy
Posté le 09-03-2012 à 12:24:19  profilanswer
The 2nd post translates as:
 I have not found (for the moment) compatibility with SURVEILLANCE STATION SYNOLOGY
must be digging in all available cams...
n°686134
supergut
Posté le 10-03-2012 à 01:25:15  profilanswer
here is a short tutorial how to use nch536mw with ispy (ispyconnect): rtsp streaming and ptz controls:
http://forums.ispyconnect.com/foru [...] osts&t=869
n°686141
paillassou
Posté le 10-03-2012 à 09:31:24  profilanswer
@normel
-WHO send to you the firmware file (give the mail address please) ?
-On wich website you've written to contact WANSVIEW to request that firmware file ?
www.wansview.com ???
www.wansview.net ???
www.ipcam-store.com ???
www.wansview.us ???
THANKS ;)
Message édité par paillassou le 10-03-2012 à 16:30:16
n°686196
normel
Posté le 10-03-2012 à 19:00:22  profilanswer
@paillassou
you already have the email, it is ( wansview@hotm.. )
I have close contact with the seller, bought many products from them.
The firmware she sent me, after i asked about the green strokes on the screen.
I have some clients, where i have to install these camera's. But i prefer recording in a synology, but it is not possible.. Record to SD card, clients does not want, because when camera is taken away, records are gone too.. Ftp is not working. So i think the only solution is to record to a server, which most be on 24hours.
Any tips??
n°686197
paillassou
Posté le 10-03-2012 à 19:16:50  profilanswer
OK thanks.
sorry no tips for the SYNO... :(
n°686348
pozzoremy
Posté le 12-03-2012 à 22:43:55  profilanswer
Bonsoir à toute l'équipe du topic,
Je tenais à vous remercier pour tous ces renseignements.
Si cela vous intéresse je vous mets à disposition une camera test.
http://31.34.102.175:1623
login : user
passwaord : 123456
Dans la même série NC-532MW vous pouvez tester cette camera  :
http://31.34.102.175:1027
login : user
password : 1234
Pour ceux qui veulent le login administrateur, je vous le communiquerai en privé
Pour info les cameras fonctionnent trés bien sur blue iris par contre je n'ai toujours pas trouver de NVR compatible, d'après le fabriquant c'est en court conception.
Bonne soirée
n°686349
paillassou
Posté le 12-03-2012 à 22:46:57  profilanswer
merci, bon il y a déjà demos en ligne ici
ONLINE DEMO:
NCH-536MW / NC-536MW / NC536MW
http://www.wansview.com/Article/Wa [...] O_1_1.html
http://002geap.nwsvr.com/
http://002fbyy.nwsvr.com
login = admin
password = 123456
mais merci encore pour ton intervention ;)
Message édité par paillassou le 12-03-2012 à 22:48:12
n°686351
gt13
Posté le 12-03-2012 à 22:54:38  profilanswer
pozzoremy a écrit :
... les cameras fonctionnent trés bien sur blue iris par contre je n'ai toujours pas trouver de NVR compatible, d'après le fabriquant c'est en court conception...
Question de profane: c'est quoi un NVR ?
n°686361
pozzoremy
Posté le 13-03-2012 à 07:34:27  profilanswer
Un NVR est Network Video Recorder. c'est un enregistreur numerique qui embarque un logiciel de gestion pour camera ip (comme le petit qui est dans les cam mais en plus evolué). En plus il te permet de paramètrer, visualiser et socker les videos de tes cams à distance. Certain plus evoluer peuvent s'additionner pour augmenter le nombre de cam et centraliser plusieurs stite sur un même pc de sécurité.
Exemple Qnap et synology
Bonne journée
n°686363
paillassou
Posté le 13-03-2012 à 07:59:55  profilanswer
Merci à gt13 d'avoir posé la question :)
Merci à pozzoremy pour cette réponse claire, nette et précise ;)
... OK, bon moi, j'appelle ça un NAS avec package de surveillance vidéo
(genre NAS SYNOLOGY + Surveillance Station)
j'en parle sur la 1ere page
Malheureusement, concernant SYNO, pas de compatibilité pour le moment,
et ce, même en rentrant l'url
/tmpfs/snap.jpg ou /tmpfs/auto.jpg
j'ai même tenté d'autres marques de caméras
sans succès... :'(
Message édité par paillassou le 13-03-2012 à 08:23:22
n°686368
gt13
Posté le 13-03-2012 à 11:24:57  profilanswer
Merci pour les éclaircissements.
En ce qui me concerne, j'ai un NAS très basique (D-Link DNS-320), et si je comprends bien:
un NAS de base + un logiciel du genre Blue Iris ou iSpy => donne l'équivalent d'un NVR ?
Mon problème est que je voudrais multiplier mes sources (actuellement une webcam sous Cammster + une Foscam FI8918W, et probablement une Wanswiew NC-536 une fois qu'elle aura été bien débuggée par tous les bienveillants contributeurs à ce topic ;)  ), et ne pas passer des heures pour visionner ensuite ce qu'il s'est passé devant les caméras (images et vidéos).
Mon idée actuelle serait de trouver un logiciel qui sache piloter tout ça, prendre les images, des vidéos (avec buffer pour démarrer la vidéo un peu avant le déclenchement par détection de mouvement), et m'envoyer tout sur le NAS, si possible avec des noms de fichiers commençant par un champ du type YYYYMMDDHHMMSS pour que tout soit automatiquement rangé dans l'ordre chronologique afin de pouvoir rapidement balayer les séquences.
Je retiens notamment du message de pozzoremy que Blue Iris semble être un candidat sérieux.
Je vais donc essayer de le tester (dès que je trouve un peu de temps...)
n°686370
paillassou
Posté le 13-03-2012 à 11:33:28  profilanswer
gt13 a écrit :
...et probablement une Wanswiew NC-536 une fois qu'elle aura été bien débuggée
malheureusement, sincèrement, vu la tournure que prend mon échange de mail avec
service@wansview.com & wansview@hotmail.com
je vais être très honnête, j'ai pas l'impression que ça s'arrange de si tôt... :(
Cela semble être totalement différent du service/support technique FOSCAM
en terme de réactivité concernant les fix de firmware...
De plus, je leur ai demandé à 4 reprises de m'envoyer les firmwares NCH536MW EXISTANTS => rien, nada, aucune réponse !
SVP => service ecrivez leur, comme moi, "in english"
inspirez vous de mes messages, faites des "copier-coller" de mes messages
faut les faire bouger... MERCI à tous
Could you, PLEASE send me the latest NCH536MW firmwares you've got:
-B12SE_V1.4.0.1.4_536mP2En.pkg
-B12SE_V1.4.0.1.5_536mP2En.pkg
-and others if exists
any firmware can be downloaded on WANSVIEW website.
PLEASE send it to mail@gmail.com
could you fix the wifi problem for long WPA2 key ?
could you fix the possibility to choose an FTP directory in the FTP server parameters ?
THANK YOU VERY MUCH
BEST REGARDS
Message édité par paillassou le 13-03-2012 à 11:38:11
n°686445
paillassou
Posté le 13-03-2012 à 22:50:26  profilanswer
une cagade de plus !!!
Le soft IPC Monitor IPCMonitor.exe IPCMonitor_en1_v1.0.1.3 ne fonctionne pas...
http://www.wansview.com/news/news- [...] 35-1.shtml
IPCMonitor_en1_v1.0.1.3 doesn't work =>
error message => "Start video Failed"
Message édité par paillassou le 13-03-2012 à 22:50:38
n°686475
paillassou
Posté le 14-03-2012 à 15:54:41  profilanswer
htttp://adresseIP/cgi-bin/hi3510/param.cgi?cmd=getsysinfo&-act=set&-devid=NCH536MW
that url command line works to change the camera designation ;)
be careful => the DDNS service by SmartEye should be disabled...
Message édité par paillassou le 14-03-2012 à 15:58:57
n°686485
paillassou
Posté le 14-03-2012 à 18:41:43  profilanswer
je viens de me rendre compte que, visiblement, et d'après mes recherches
http://wansview.net/about-us.html
http://agasio.com/about-us/
Agasio Technologies LLC was founded by the same entrepreneurs who founded Foscam Digital Technologies LLC in the United States.
FOSCAM = WANSVIEW = AGASIO
en gros, c'est plus ou moins la même maison...  :ouch:  :ouch:  :ouch:
et que:
WANSVIEW NCH-536MW = DERICAM H501W = AGASIO A522W
Message édité par paillassou le 14-03-2012 à 18:45:24
n°686498
paillassou
Posté le 14-03-2012 à 22:29:57  profilanswer
En fait, le fichier de sauvegarde config_backup.bin est un fichier compressé.
il faut renommer config_backup.bin en config_backup.zip
Ensuite, si on l'ouvre avec 7zip, on peut rentrer dans les différents dossiers linux.
Actually, the backup file config_backup.bin is a compressed ZIP file
so, if you rename config_backup.bin to config_backup.zip
you can open it with "7zip" software and browse the linux directory ;)
Message édité par paillassou le 14-03-2012 à 22:33:28
n°686504
normel
Posté le 15-03-2012 à 00:05:59  profilanswer
still nothing about  possibility to choose an FTP directory in the FTP server parameters??
i also hope, synology will support wansview AS SOON AS POSSIBLE
n°686509
paillassou
Posté le 15-03-2012 à 07:23:40  profilanswer
wansview@hotmail.com & service@wansview.com
=> no reactivity...
=> no response...
=> no firmware...
=> they don't understand me... they don't answer me...
sorry normel...  :??:  :sarcastic:
let's write a message like me to wansview
THANK YOU VERY MUCH
BEST REGARDS
Message édité par paillassou le 15-03-2012 à 07:26:50
n°686513
samuel14
Posté le 15-03-2012 à 08:09:35  profilanswer
toujours pas de solution pour les NAS Synology ?je viens de voir la question de notre ami anglophone ;)
Je trouve que la FI8910W est un peu limite en résolution...je préférerais un modèle HD (ready :p ).
"WANSVIEW NCH-536MW = DERICAM H501W = AGASIO A522W" tu peux ajouter ça dans le titre du topic ?
Message édité par samuel14 le 15-03-2012 à 08:12:45
n°686514
paillassou
Posté le 15-03-2012 à 08:18:19  profilanswer
Désolé, rien...
Mais bon faudrait peut être que la communauté se réveille
(toi, moi, nous...) écrivons à SYNOLOGY pour ça...
Déjà que wansview ne me répond pas pour les bugs...
Ils vont pas, eux, contacter SYNO, pour rendre compatible leur cam...
Écrivez leur, faites les bouger...
Bye
n°686515
paillassou
Posté le 15-03-2012 à 08:19:45  profilanswer
Quelle solution y a pour SYNO ????
Message édité par paillassou le 15-03-2012 à 08:20:12
n°686518
samuel14
Posté le 15-03-2012 à 08:46:12  profilanswer
Désolé, rien...
Bye
Je pense que je vais essayer de faire bouger les choses...car il n'y a que cette CAM qui soit abordable en HD motorisée (+IR-CUT).
mais je ne sais pas si c'est au fabricant de CAM de les rendre compatibles où à Syno...
Il n'y a pas une sorte d'API standard qui rendrait toutes les CAM compatibles ? car on ne parle pas de branchement en USB (donc drivers) mais d'un équipement réseau. Il existe bien le TWAIN réseau pour les scanners...
EDT : en attendant j'ai ouvert un ticket chez Syno.
Message édité par samuel14 le 15-03-2012 à 08:49:35
Est ce que ça existe un adaptateur WIFI/USB pour disque dur USB ?camera ip Heden V5.5 PAS DE SON
Webcam IP/ DCS 5230/ récupération d'images (analogie autres webcams)Problème de connexion entre PC et Imprimante Wifi
Quel soft utiliser (java) pour afficher caméra IP ?AVIS SUR HEDEN - Caméra IP extérieure - CAMH04IPWE
Quel nas Choisir pour enregistrement cameraHD 5450 512MO et 27' ?
Plus de sujets relatifs à : [Topic Unique] WANSVIEW NC-536M/W HD WIFI IP Camera PT + IR-Cut + SD
