4343 connectés
 Page :   1  2  3  4  5  6  7  8  9  10  11  12  13  14  15  16  17  18
Quelle imprimante ?
n°774
mouss_diou​f
Ready to ride.
Posté le 16-03-2003 à 22:41:44  profilanswer
moi j'ai maintenant le choix entre la i850 à 320 CHF et la HP5550 à 200 CHF.
Je me tâte...
n°775
tonton05
Posté le 16-03-2003 à 23:04:17  profilanswer
si vous avez d'autre avis je suis prenant..........
n°776
mouss_diou​f
Ready to ride.
Posté le 17-03-2003 à 12:16:56  profilanswer
Quelques infos sur la i450 péchées chez Canon-Europe...
http://www.canon-europe.com/media/product_shots/printers/i450.jpg
Bubble Jet i450
High end performance & photo quality for you.
HIGH RESOLUTION
The i450 high-resolution, 4800 x 1200 dpi* printing capability combines with advanced MicroFine Droplet Technology? to ensure you of clear, crisp photo prints. Canon?s Micro-Nozzle technology giving a 2 picolitre droplet capability now give you six-ink quality in a four-ink system so you get high contrast and broad colour range every time.
HIGH SPEED
The i450 delivers business performance in a home printer. It prints up to 18 pages per minute monochrome and 12 pages per minute in colour. Using one-pass bi-directional printing, it can turn out a full-page colour A4 in approx. 48 seconds.
BORDERLESS PRINTING
This machine prints full-bleed photos on A4, 4" x 6" or 5" x 7" paper sizes giving your prints the look and feel of traditional photos. It produces a borderless, full-colour 4" x 6" photo in approx. 90 seconds.
DIRECT PRINT
With the i450, you can print your photos directly from your compatible Canon digital camera or digital video camera without ever touching a computer.
SOFTWARE SUPPORT
The i450 makes use of Exif Print support with Canon Easy-Photo Print software. This improves the quality of Exif 2.2 compliant digital images by using additional information captured at the time the photograph was taken. And, Easy-WebPrint software simplifies the printing of internet pages.
CONNECTIVITY
With a USB interface, the i450 is fully compatible with Windows® 98/Me/2000/XP and Mac OS 8.6-9.x/Mac OS X 10.2.1, so you will be up and running in minutes.
n°777
tonton05
Posté le 17-03-2003 à 23:51:36  profilanswer
je viens d'acheter la i850  :love:
elle est nickel  :pt1cable:
merci a tous pour vos conseils  :hello:
n°778
etern
Posté le 18-03-2003 à 12:33:59  profilanswer
J'ai la i850 depuis 5 jours.
J'en suis très content, bon la vitesse j'en parle pas, elle est speed cette imprimante, les photos sont vraiment parfaites sur papier photo (en tout cas sur le PR-101 10x15 fourni avec).
Les textes/graphiques sont extrêmement précis en mode normal et meilleur. Le texte noir est TRES précis sur papier normal 80g(comme une laser si on regarde à >5cm) et c'est du vrai noir. En mode meilleur, on ne peut pas voir les points.
Toutefois: le noir des textes fait un petit peu "charbon": si on glisse le doigt dessus, ca laisse une légère trace (ca le fait pas sur les couleurs), m'enfin en manipulant les feuilles normalement, y a pas trace, faut pas s'inquiéter, c'est juste quand on le fait exprès; des doigts légèrement moites ou humides favorisent cela.
Quant aux photos sur papier normal, ou un peu + épais, c'est vrai que l'encre a une certaine tendance à pénétrer la feuille. Sur papier normal, en mode meilleur, on ne voit et on ne peut pas voir les points (merci les gouttes de 2 pL), mais la photo (ou un graphique) a une apparence "mouchetée" et un peu terne. J'aimerais bien comparé avec une HP 5550 (d'une part avec la cartouche 3 couleurs et d'autre part avec la cartouche photo), mais bon, un scan ne permet pas de voir si l'image est terne ou pas...
Faudrait que Canon modifie un peu la composition de ses encres pour que cela soit vraiment parfait (qu'elles pénètrent moins, pas de "moucheté" pour les zones uniformes, ...).
J'ai vu qu'il y a avait deux types de cartouches (enfin plutôt d'encre, je ne sais plus trop, avec un k en plus ou quelque chose comme dans la référence, c'est juste pour le noir ? les couleurs ?
Y a une autre chose que je voudrais savoir: le papier Canon GP-301 est-il un bon papier ? Vaut-il le coup pour des photos à exposer ? (parce que le PR-101 et le PP-101, merci le prix...)
n°779
Figti
Posté le 18-03-2003 à 16:12:55  profilanswer
Ca faisait 4 ans que j'avais pas changé d'imprimante :crazy:; je viens de sauter le pas avec une i850... c'est bluffant!
Je redécouvre le bonheur d'imprimer, en particulier les photos...
Si le papier photo Canon peut être cher (5 petites feuilles sont fournies, ça permet d'apprécier leur (réelle) qualité ;)), j'ai aussi essayé avec du papier photo mat 120g d'Office Dépôt (6?/50pages): ça donne un résultat nickel pour être mis sous cadre...
n°780
mouss_diou​f
Ready to ride.
Posté le 18-03-2003 à 16:39:40  profilanswer
ben moi ca fait 7 ans que je traine ma HP690C...ca va me faire un choc la i850 que je vais me payer :pt1cable:
n°781
tonton05
Posté le 18-03-2003 à 19:33:49  profilanswer
t'as fait ton choix ?
t'as raison elle est excellente cette imprimante..........
n°782
arawak
Posté le 19-03-2003 à 17:11:15  profilanswer
Je ne trouve nul part la i850 sur Montgallet à paris aux alentours de 200-210 euros , vous les avez acheté où vous ??? :sweat:
n°783
mouss_diou​f
Ready to ride.
Posté le 20-03-2003 à 15:27:39  profilanswer
Voilà !
Je viens de faire réserver la seule i850 en stock dans le seul magasin info à vendre ce genre d'article autour de chez moi. Elle est pas encore très répandue dans les magasins de ma région et elles commencent à arriver au compte-goutte.
320 CHF.
Je vais la chercher demain en fin d'après-midi. :love:
n°784
arawak
Posté le 20-03-2003 à 16:00:24  profilanswer
content pour toi...
je vais peut etre en avoir une demain !  :pt1cable:
 [:nicolas hc]
n°785
tonton05
Posté le 20-03-2003 à 22:02:42  profilanswer
Pour moi je l'ai acheté chez DARTY à toulouse.
Je l'ai payé 210 euros  :pt1cable:  :sol:
n°786
mouss_diou​f
Ready to ride.
Posté le 20-03-2003 à 22:39:26  profilanswer
tu en es content ? pas de mauvaise surprise ? de décéptions ?
n°787
mouss_diou​f
Ready to ride.
Posté le 20-03-2003 à 23:44:35  profilanswer
Hum...je viens de voir que la i850 a que 248ko de mémoire. ca me parait peu.
http://www.monsieurprix.com/fiche/ [...] 25354.html
La HP5550 dispose de 8Mo.
http://www.tomshardware.fr/article [...] &NumPage=6
Je suis un peu largué là.
Concretement ca change quoi ?
n°788
tonton05
Posté le 21-03-2003 à 15:01:49  profilanswer
Comparé à mon ancienne imprimante (epson 760  :kaola: ) y'a pas photo
Une imprimante comme la i850 ca change la vie  :love:
n°789
arawak
Posté le 21-03-2003 à 17:04:34  profilanswer
je vais avoir la mienne ce soir ! pour 202 euros ! :D
aux chiottes mon epson stylus color 600 sans drivers sous XP et avec des cartouches introuvables !!! :kaola:
Message édité par arawak le 21-03-2003 à 17:05:02
n°790
Coxwell
Posté le 21-03-2003 à 17:10:45  profilanswer
noelemac a écrit :
j'avais une 690c aussi avant lol. difficile d'être décu par la 5550.
Elle est impeccable cette imprimante :) !
Je la possède depuis fin décembre et je suis très satisafait, sauf qu'elle consomme  :whistle:  beaucoup ?
Normal me direz-vous avec les derniers tirages que je viens de faire  :)
n°791
mouss_diou​f
Ready to ride.
Posté le 21-03-2003 à 20:19:48  profilanswer
Ca y est ! Ma Canon i850 est installée et j'ai fait un ou 2 tirages pour l'instant. J'ai quand meme du m'y reprendre à 3 fois, car au moment de la detection du port d'imprimante par le soft canon, c'est celui de XP qui se lancait et ca me bloquait la detection.
Bref, maintenant ca marche, la qualité (par rapport a ma vieille HP690c) est bien sur excellente. J'ai pas de papier photo pour tester, je verrai ca demain.
Malheureusement, j'ai pas de scanner non plus, je pourrai pas vous faire profiter de mes tirages, mais en tout cas elle est superbe cette imprimante.
Voilà, première réaction a chaud, si vous avez des questions vous genez pas !
A+
Message édité par mouss_diouf le 21-03-2003 à 20:20:19
n°792
hatred
Posté le 21-03-2003 à 21:17:08  profilanswer
A+
tu n'avais pas les echantillons de 10x15 dans le carton ?
 [:d4buff]
n°793
Cantafan
Posté le 21-03-2003 à 21:51:50  profilanswer
A mon avis, vaut mieux pas essayer avec un cable parallèle, elle doit tout faire ramer à fond. Quelqu'un a essayé?
n°794
mouss_diou​f
Ready to ride.
Posté le 21-03-2003 à 22:04:17  profilanswer
 [:d4buff]
Si, je m'en suis rendu compte après-coup. j'en ai 5.
Pas encore essayé.
n°795
mouss_diou​f
Ready to ride.
Posté le 22-03-2003 à 13:04:37  profilanswer
http://fr.ch.msnusers.com/_Secure/0QADdAuES81kKAy!WsU!vmqONJI0B0j16kdz2ThPX5g0394s79zTV9bF9Ni5S0D0ZObL!ljnYcPHM68XTkG09LeFmKvFsu0*Mqo7dAhxwUxg/i850icon.jpg :love:
p'tit UP déguisé !
n°796
MaxoOo
Panem et circenses...
Posté le 22-03-2003 à 18:01:15  profilanswer
j'ai essayé les 2, ça rame pas en parallèle, mais ça doit être un poil plus lent à vue de nez
n°797
mouss_diou​f
Ready to ride.
Posté le 22-03-2003 à 18:05:58  profilanswer
moi avec l'USB ca marche très bien en tout cas...j'ai tiré des photos à pleurer, meme si les couleurs sont pas tres fideles (elles sont legerement plus froides que les photos tirées en labo), je devrais pouvoir ameliorer ca avec Photoshop 7.0
n°798
Cantafan
Posté le 22-03-2003 à 20:03:17  profilanswer
moi avec l'USB ca marche très bien en tout cas...j'ai tiré des photos à pleurer, meme si les couleurs sont pas tres fideles (elles sont legerement plus froides que les photos tirées en labo), je devrais pouvoir améliorer ca avec Photoshop 7.0
La qualité d'impression (trame, séchage, fidélité des couleurs...) dépend pas mal de l'encre mais le papier joue un rôle peut-être plus important. A ne pas négliger donc.
Pour ma part, j'ai testé 2 papiers HP sur la i850. Avec le papier glossy premium, c'est catastrophique :(  et le papier couché premium (100g) très correct, mais peut-être moins fidèle que l'équivalent Canon.
J'ai également testé des papiers Canon: PR101, PP101, MP101. Tous excellents! :ouch:  La qualité entre les 2 premiers est identique, seule la surface du PR101 est plus régulière, donc préférer le moins cher.
Ceux qui ont testé d'autres papiers, qu'ils le disent, ça m'intérresse. :jap:
n°799
Butaze
Posté le 24-03-2003 à 13:46:17  profilanswer
Je viens d'essayer 3 papiers Kodak sur une i950 : 40 euros foutus à la poubelle. Aucun n'était compatible : grosses tâches, l'encre ne pénètre pas correctement le papier.
n°800
carbone14
Posté le 24-03-2003 à 14:51:40  profilanswer
C'est très bien tout ça. Je rentre juste de vacances avec un paquet de photos.
Me reste plus qu'à trouver 200 euros pour une i850.
n°801
Gabet13
bah rien...
Posté le 24-03-2003 à 15:35:48  profilanswer
comme sur ma s820 et ma s750.
Le papier Kodak, je le fuit comme la peste !
n°802
LaMoR
Metal up your ass
Posté le 25-03-2003 à 10:02:46  profilanswer
Canon i850 : meilleur imprimante jet d'encre du moment pour PPC et, elue meilleur produit du moment !!
http://presence-pc.com/news/newsv3.php?news=367
n°803
tonton05
Posté le 25-03-2003 à 11:19:21  profilanswer
Ou achetez-vous vos cartouches ?
Et a quel prix ?
n°804
LaMoR
Metal up your ass
Posté le 25-03-2003 à 11:25:46  profilanswer
Et a quel prix ?
Cdiscount et le prix est inférieur à 9?/cartouche
n°805
Cantafan
Posté le 26-03-2003 à 22:18:03  profilanswer
Lol, au fait, Enolin, le créateur de ce topic vient de poster un nouveau sujet dans la catégorie mobo.
n°806
Gabet13
bah rien...
Posté le 26-03-2003 à 22:25:52  profilanswer
Et ce topic qui fait maintenant 39 pages juste pour une petite question sur le choix d'une imprimante  [:skyx%40v]  :lol:
edit : 39 pages pas 14...  :whistle:
Message édité par Gabet13 le 26-03-2003 à 22:27:58
n°807
Cantafan
Posté le 30-03-2003 à 14:30:19  profilanswer
Lol, j'ai testé le papier photo HP (165g) sur ma i850 (réglage papier photo glacé correspondant au GP301 donc).
C'est pas mal, mais on est pas au niveau de ce que peut donner un papier Canon. Je peux pas vous donner la différence de qualité avec le GP301, mais elle est importante par rapport au PR101. :whistle:
Et ça rend plus mat qu'autre chose. Ou aspect ciré, légèrement satiné. Sauf que c'est pas du verni! :lol:
Peu de problème de colorimétrie, enfin ton légèrement verdâtre.
Par contre, encore une fois, comportement irréprochable dans les tons les plus clairs. :jap:  :love:
Canon rulessssssssssssss!
n°808
ragefan
Posté le 30-03-2003 à 21:29:19  profilanswer
quelqun a comparé s820 et i850 en qualité photo ?
n°809
olivierau
Posté le 01-04-2003 à 11:31:42  profilanswer
j'ai une stylus photo 870 qui donne de tres bon resultats en papier photo mais j'ai laissé tomber l'impression massive de photos car ce n'est pas du tout avantageux par rapport aux laboratoires sur le net
quand je compares le prix d'une impression a4 avec 4 photos 10*13 (10*15 ca passe pas dans la feuille)ca coute 1.2 ? les 4 pour le labo et toi ca va te revenir a entre 0.75 et 1.5 ? rien que pour le papier si tu tapes dans les marques des imprimantes.
donc tu en a deja presque pour aussi cher rien qu'avec le papier , et je ne parle meme pas de l'usure de la cartouche
ma question est donc quel est l'interet de prendre une tres bonne imprimante photo? si c'est pour faire de l'impression 10x15?
n°810
pastor
٩(•̪̀●́)۶ ٩(●̮̮̃•̃)۶ ٩͡๏̯͡๏)۶
Posté le 01-04-2003 à 23:09:09  profilanswer
* regler la colorimetrie à sa guise
* faire des formats personalisés
* financer canon,epson,HP,lexmark
* avoir immediatement des sorties (pratique pour ses clients )
n°811
olivierau
Posté le 01-04-2003 à 23:23:00  profilanswer
chez moi je preferes les couleurs du labo que celles de mon imprimante (un peu moins eclatantes)
ton second point est le seul que je concois a mon niveau d'autant que une page a4 c'est deja 2.59? (chez fotoways alors que 4 photos 10*15 c'est 1.20? :heink: )
pour le 3 eme point je t'en laisse le soin :lol:
le 4eme ne s'applique pas pour moi
n°812
Gabet13
bah rien...
Posté le 01-04-2003 à 23:28:11  profilanswer
Moi qui fait de l'astrophotographie, je trouve un gros avantage : je tire mes photos avec les bons réglages, ce que les labos font à l'arrache !
Genre, la photo d'une constellation réglée trop surexposée par le labos pour cause de "vos photos sont trop sombre..." lol !
y a même un labo qui ne m'a rien développé croyant que les photos étaient toutes noires, et donc ratées !  :lol:  (j'ai du tout refaire  :fou: ) sans compter les retirages d'autres pellicules sur lesquelles, il y avait aussi un mélange de paysages diurnes et astrophoto...
Bref, je fais mes tirages et ça me renviends moins cher que de retirer les photos du labo.
n°813
olivierau
Posté le 01-04-2003 à 23:31:54  profilanswer
j'ai du mal m'expliquer ; quand je parles d'imprimantes et de labos je parles des developpments de photos d'apareils photos numeriques ;)
n°814
pastor
Posté le 01-04-2003 à 23:32:29  profilanswer
ah oui il y a un truc qui m'enerve aussi : j'ai deja fait faire beaucoup de tirages à la FNAC :
Problème : la reso de mon APN (2048 X 1538) ne correspond pas apparemment  à un format standard, du coup mes tirages ont soit des bandes blanches horizontales soit verticales :/
plutôt baclé comme service ...
edit : faille spacio-temporelle
Message édité par pastor le 01-04-2003 à 23:37:40
Imprimante HP 5550 ?imprimante bureautique
ça marche comment une imprimante laser couleur?qqun sait combien une imprimante thermique revient par page?
vieille imprimanteImprimante Kyocera 7000+ qui ne change plus de bac a papier
Plus de sujets relatifs à : Quelle imprimante ?
