3119 connectés
 Page :   1  2  3  4  5  ..  71  72  73  ..  193  194  195  196  197  198
[Topic Unique] ** MSI ** X570/470 & B550/450
n°10690167
kamikaze24
Posté le 23-01-2020 à 10:21:56  profilanswer
Salut
J'en profite vu que ça parle SSD m2, des radiateurs SSD nvme a recommander pour la comptabilité sur msi x470 gaming pro v1 ?
Je suis entrain d'en monter un sur le port m2_1 ,celui le plus haut et j'ai peur que ça le chauffe ma 2070S ...
Message édité par kamikaze24 le 23-01-2020 à 10:22:26
n°10690240
whiterabbi​t
Posté le 23-01-2020 à 12:43:50  profilanswer
J'ai un 960 Pro sur le port M2 placé juste sous ma 2080, ça ne chauffe pas au point de nécessiter un radiateur pour le SSD.
n°10690241
It_Connexi​on
Posté le 23-01-2020 à 12:45:58  profilanswer
Et puis tu as déjà un dissipateur sur la Gaming Pro Carbon :)
n°10690245
myzt
Posté le 23-01-2020 à 12:54:25  profilanswer
kamikaze24 a écrit :
Salut
C'est normal que ça chauffe, et faut pas vouloir tout refroidir  ;)
https://www.youtube.com/watch?v=KzSIfxHppPY
The thing about NVME SSDs is: The controller chip shouldn't heat up too much, or it'll throttle back and you'll lose performance.  But the flash cells should not be cooled, because that wears them out faster.  Thus, according to PCPer's storage editor
If you're not operating the SSD so much, you know, for such long periods at such high loads that you're worried about the controller actually throttling, I would not even install the heatsink.  If there's a motherboard that has the heatsink plate that goes on there, if you can get away with it, don't even put the plate on. I don't have any active cooling or heatsink attached to any nvme SSDs that I have in even in any sort of my production or, I think, even at the office I don't think we have any installed just because it's — not only is it overkill but it's just better (as long as you know you're not to the point where you know you're gonna cause that SSD to throttle), to just let it be on its own.
n°10690254
whiterabbi​t
Posté le 23-01-2020 à 13:06:53  profilanswer
Sur la Carbon oui (et seulement pour le premier port M2), pas sur la Gaming Pro tout court.
Mes deux ports M2 sont occupés par deux 960 Pro, la différence de température ne dépasse pas les 5 °C entre celui qui a un dissipateur et celui qui n'en a pas.
n°10690256
It_Connexi​on
Posté le 23-01-2020 à 13:08:08  profilanswer
Ha autant pour moi :)
n°10690390
Samdu33
Posté le 23-01-2020 à 17:12:01  profilanswer
Bonjour.
Peut-être pourrez vous m'expliquer ou m'aider.
Je possède 1 msi x470 gaming pro.
1 amd ryzen 2700x
J'ai 1 kit HyperX Predator DDR4 32Go, compatible avec cette carte mère.
Mais, après installation de la Ram, (comme préconise msi), je n'ai que la moitié d'afficher. 16 go et pas 32!
Pourtant, avec cpuz et autres logiciel,  elles sont identifiées,  mais ds le bios, comme ds Windows, 16 go.
Et impossible de les monter a plus de 2400 mhz ! Je me demande s'il y a 1 truc à faire ou si c'est la carte mère hs?
Merci d'avance pour vos réponses !
Message édité par Samdu33 le 23-01-2020 à 17:14:41
n°10690406
burn2
Pour ceux qui viendront après
Posté le 23-01-2020 à 17:48:02  profilanswer
Bonjour.
Le bios est-il à jour déjà?
n°10690408
Samdu33
Posté le 23-01-2020 à 17:49:54  profilanswer
Oui, il est à jour et j'ai testé avec 3 bios différents histoire d'être sur.
n°10690448
xenesys
Posté le 23-01-2020 à 18:46:10  profilanswer
As-tu testé à l'unité sur chaque port ddr ?
ça validera quelles sont toutes reconnues de partout.
Pour la fréquence, mode xmp ou en manu testés ?
Topic MSI X570-X470&Co | OC 2700X+DDR4
n°10690450
Samdu33
Posté le 23-01-2020 à 18:52:09  profilanswer
Oui  testé sur tous les ports Ram.
Et testé en profil 1 et 2 et même en try memory. Rien... la carte mère hs ?
n°10690458
xenesys
Posté le 23-01-2020 à 19:03:33  profilanswer
Si à l'unité elles sont toutes OK je vois pas pourquoi la CM serait HS.
tu pourrais faire des captures d'ecran de windows vs cpuz pour voir cette bizarrerie ? ^^'''
n°10690465
BloodyCarn​age
Posté le 23-01-2020 à 19:23:47  profilanswer
Quelle est la référence exacte de ton kit?
Nothing's so bad it can't get worse
n°10690505
Samdu33
Posté le 23-01-2020 à 20:45:14  profilanswer
La ref : HX432C16PB3K2/32
Pour les photos je ferais cela demain. Faut mettre ça sur un site pour un lien photo ?
Merci au fait de répondre ! Ça fait plaisir d'être aidé,  surtout qd on est dans le brouillard.
n°10690514
myzt
Posté le 23-01-2020 à 21:00:17  profilanswer
Akilae_ a écrit :
T'as des problèmes de chauffe sur la Mortar?
Ici rien à signaler... même en laissant OCCT tourner toute la journée.
Ton boitier est ATX?
Je sais pas si c'est mieux d'avoir une carte ATX dans un boitier ATX en terme de refroidissement
Là ça va être tout compacté dans la tour  [:transparency]
n°10690516
Samdu33
Posté le 23-01-2020 à 21:04:33  profilanswer
n°10690521
Samdu33
Posté le 23-01-2020 à 21:15:13  profilanswer
alors si ça fonctionne,  photos :
http://img115.xooimage.com/views/3 [...] faa8d.jpg/
http://img115.xooimage.com/views/1 [...] faa9f.jpg/
http://img115.xooimage.com/views/c [...] faaaf.jpg/
http://img111.xooimage.com/views/a [...] faab3.jpg/
Message édité par Samdu33 le 23-01-2020 à 21:17:44
n°10690522
It_Connexi​on
Posté le 23-01-2020 à 21:17:31  profilanswer
Bizarre sur ta 2eme photo les 2 barrettes sont reconnues dans le BIOS
n°10690525
Samdu33
Posté le 23-01-2020 à 21:22:30  profilanswer
Oui, mais toujours affiché seulement 16 go et pas 32 ! Dingue non ?
En plus, plante à chaque changement de profil  1 ou 2 ou memory try.
Et revient tjrs au même ratio 2400 mhz.
Message édité par Samdu33 le 23-01-2020 à 21:27:58
n°10690527
burn2
Posté le 23-01-2020 à 21:27:11  profilanswer
Tu n'es visiblement pas le seul à avoir ce genre de problème cf:
https://forums.tomshardware.com/thr [...] m.3451240/
Bon là c'est avec 4 barrettes mais ça semble être le même pb.
EDIT: ça ressemble aussi à ça:
https://www.techpowerup.com/forums/ [...] 582/page-3
A chaque fois les conseils c'est :
1) démonter toutes les barettes
2) démonter le cpu et nettoyer les pins et remettre.
Mais bon à priori ça peut rester une incompatibilité matérielle mémoire/mb même si c'est sensé être compatible.
Message édité par burn2 le 23-01-2020 à 21:35:17
n°10690533
Samdu33
Posté le 23-01-2020 à 21:38:52  profilanswer
Merci. Je tenterais dès que possible un nettoyage des slots. Car le reste,  je l'ai déjà tenté ! Et j'ai aussi testé avec 2 autres séries de ddr4 d zutres marques...sans succès. J'attends aussi 1 réponse pour retour carte mère sous garantie. Merci encore pour vos réponses et temps consacré ! Je reviendrais poster la suite !
n°10690534
burn2
Posté le 23-01-2020 à 21:42:17  profilanswer
Ah tu as déjà testé avec d'autres barrettes?
Si c'est pareil ça reste bizarre quand même.
Reste pb de carte mère ou de cpu pour le coup.
TLe cpu tu as bien essayé de le démonter et de le nettoyer? et de nettoyer côté socket CPU carte mère?
n°10690540
Samdu33
Posté le 23-01-2020 à 22:01:17  profilanswer
Tu veux dire démonter le processeur ?
Sinon, testé 1 barette. Elle fonctionne bien sur le 3ème spot et le 4ème. Pareil pour les 2 barrettes. Et si je les mets ensemble sur le slot 3 et 4, ça met erreur enfin, conseil pas optimal de marqué mais ça fonctionne avec 32 go affiche ss bios.
Message édité par Samdu33 le 23-01-2020 à 22:04:20
n°10690541
burn2
Posté le 23-01-2020 à 22:04:05  profilanswer
Oui démonter le processeur. Vérifier les pin et le socket côté carte mère.
Nettoyer à la soufflette et idem sur les ports de la mémoire au cas ou.
n°10690542
It_Connexi​on
Posté le 23-01-2020 à 22:04:16  profilanswer
Oui normal en général c'est Dim 2 et 4 et 1 et 3
n°10690545
Samdu33
Posté le 23-01-2020 à 22:07:38  profilanswer
En tout cas, c'est visiblement pas la ddr4.
Pour le reste, j'avoue ne pas comprendre le pourquoi du processeur .
J'ai payé quelqu'un pour le montage. J'espère y arrivé à démonter tout ça. Heu.. un sèche-cheveux  ça ira pour souffler ?
Mais vu que cela fonctionne sur 2 slots,  ça ne signifie pas que c'est la carte mère hs ou slots obstrués ?
Message édité par Samdu33 le 23-01-2020 à 22:09:22
n°10690546
burn2
Posté le 23-01-2020 à 22:07:41  profilanswer
A une époque (enfin avec des cpu plus anciens) ça marchait avec ce genre de conf mais sans dual DDR ce n'est plus le cas? :??:
Parce que la gestion de la mémoire est gérée par le cpu maintenant.
Donc si pb de pin  ou connerie qui gêne, ça peut provoquer des "bizarreries" dans la gestion de la mémoire.
Message édité par burn2 le 23-01-2020 à 22:08:52
n°10690547
Samdu33
Posté le 23-01-2020 à 22:10:30  profilanswer
n°10690548
It_Connexi​on
Posté le 23-01-2020 à 22:11:29  profilanswer
La sur l'AM4 avec une paire de barrettes c'est sur les Dim 2 et 4 sur la majorité des CM :)
Message édité par It_Connexion le 23-01-2020 à 22:12:00
n°10690552
Samdu33
Posté le 23-01-2020 à 22:16:48  profilanswer
Ben justement, c'est là que ça plante. Alors que sur 3 et 4 c'est ok sauf message du bios que c'est pas conseillé.
n°10690555
It_Connexi​on
Posté le 23-01-2020 à 22:23:22  profilanswer
Et une barrette sur le Dim 2 ou le 4 ça fonctionne ?
n°10690562
Samdu33
Posté le 23-01-2020 à 22:29:31  profilanswer
Ça fonctionne ( enfin, barrette reconnue à 100 % et pas à moitié) sur le 3 et le 4. Le 3, sans problème,  le 4 avec message d'avertissement que c'est pas conseillé.
Le 1 tout seul,  oui, mais de moitié la valeur de la Ram. Le 2, rien du tout.
Question bête : il y a pas moyen sans démonter de tester si tout est ok pour le processeur ? Je sais, je débute alors je suis galère lol !
Message édité par Samdu33 le 23-01-2020 à 22:52:41
n°10690596
BloodyCarn​age
Posté le 24-01-2020 à 00:43:45  profilanswer
Alors effectivement, la réf est dans la liste MAIS il y a une note à prendre en compte:
Note:
Memory compatibility support depends on the CPU memory controller.
Le problème est que MSI ne précise pas avec quel CPU ils ont validé les différents modules de RAM. Et vu les pas de géant au niveau de l'IMC à chaque évolution de zen, il n'est pas impossible que cette RAM ne fonctionne correctement que couplée avec un CPU zen2.
Si ça vient de là, il n'y a pas grand chose à faire changer de kit.
n°10690615
burn2
Posté le 24-01-2020 à 06:27:57  profilanswer
Tu peux choisir la génération du cpu dans le tableau msi.
Et la ref sort toujours sous ryzen 2xxx.
Mais en l'occurence il dit avoir testé avec d'autres barrettes et c'est idem.
Donc ç'a rsssemble plus à un pb de carte mère ou cpu.
n°10690639
Samdu33
Posté le 24-01-2020 à 09:13:54  profilanswer
Exact, testé avec corsair et 1 autre marque.
Mais je précise que d'autres ont la même carte mère et le même processeur et cela fonctionne. Alors, oui, ptet rechanger de kit(ça serait pas de chance tt de même !) . Pour l'instant je vais tenter le nettoyage et si pas ok, retour carte mère pour la garantie. Si tjrs pas ok, retour processeur. En tout cas, merci à tous pour votre aide. Je vous tiens au courant pour la suite. Comme ça,  ça pourra servir à d'autres.
n°10690798
vegetaleb
Un jour je serai riche!
Posté le 24-01-2020 à 15:11:37  profilanswer
Salut
J'ai un B450M de Msi, donc seulement 4 Sata, j'utilise 2 SSD et 2 DD dessus, si je rajoute une carte nvme ssd, elle va arrêter 2 de mes stockages Sata?
Mon blog pour photographie: https://fujiandstuff.wordpress.com/
n°10690810
kamikaze24
Posté le 24-01-2020 à 15:33:35  profilanswer
vegetaleb a écrit :
Salut
Salut
C'est indiqué dans ta notice.
Suivant si tu installes m2_1 ou m2_2.
n°10690811
burn2
Posté le 24-01-2020 à 15:34:20  profilanswer
Faut lire la doc mais c'est possible oui.
n°10690827
vegetaleb
Posté le 24-01-2020 à 15:54:01  profilanswer
Y a rien dans la doc justement et il n'y a qu'un seul M2
C'est tout ce que j'ai trouvé:
M2_1 : Slot M.2 (Touche M)
Installer le disque dur M.2 dans le slot M.2 comme indiqué ci-dessous
n°10690828
It_Connexi​on
Posté le 24-01-2020 à 15:54:09  profilanswer
Ha oui la je pense que tu as un soucis  :sweat:
Soit CM soit CPU comme le disent mes VDD
n°10690837
burn2
Posté le 24-01-2020 à 16:01:16  profilanswer
Si ce n'est pas précisé alors ça ne doit pas désactiver de port sata.
Tu as pris la doc en ligne sur le site? (genre la version Full ENG? )
Sur la pro carbon c'est bien précisé dans la doc.
Conseil d'achat Ecran 144 Hz gamingMSI Radeon R9 390 8g vs Radeon RX 480 NITRO+ LITE 4Go
Update config gaming pour VR + Montage 4k[Topic unique] nvidia GP107 Pascal (14nm)
Aorus x470 compatibilité Ram 3466mhz pour 2700xPC gaming / streaming
Temps de Boot sur MSI z270 Pro CarbonRefroidissement MSI GTX 670
Virtualisation sur proc AMD et CM MSIMise à jour - MSI X370 Gaming Plus URGENT
Plus de sujets relatifs à : [Topic Unique] ** MSI ** X570/470 & B550/450
