3423 connectés
 Page :   1  2  3  4  5  ..  48  49  50  ..  193  194  195  196  197  198
[Topic Unique] ** MSI ** X570/470 & B550/450
n°10626447
Luzog
Posté le 03-09-2019 à 09:00:17  profilanswer
twain2 a écrit :
Bonjour
J ai pas trouvé l option Offset cpu voltage dans mon bios msi
J ai une config Rad stock 2700 et msi b450 Tomahawk max
Pouvez vous l aidé?
Il faut que tu changes le paramétrage du vcore. Normalement, tu dois pouvoir mettre : auto/overdrive mod/offset mod.
Une fois que tu as sélectionné offset mod, tu selectionne + ou - et tu met l'offset que tu souhaites.
Mon Feed--Achats/Ventes
n°10626463
k-nar
Laqué.
Posté le 03-09-2019 à 09:46:41  profilanswer
taz26 a écrit :
https://en.wikipedia.org/wiki/PCI_E [...] (standard)
A PCI Express card fits into a slot of its physical size or larger (with ×16 as the largest used), but may not fit into a smaller PCI Express slot; for example, a ×16 card may not fit into a ×4 or ×8 slot. Some slots use open-ended sockets to permit physically longer cards and negotiate the best available electrical and logical connection.
The number of lanes actually connected to a slot may also be fewer than the number supported by the physical slot size. An example is a ×16 slot that runs at ×4, which will accept any ×1, ×2, ×4, ×8 or ×16 card, but provides only four lanes. Its specification may read as "×16 (×4 mode)", while "×size @ ×speed" notation ("×16 @ ×4" ) is also common. The advantage is that such slots can accommodate a larger range of PCI Express cards without requiring motherboard hardware to support the full transfer rate. Standard mechanical sizes are ×1, ×4, ×8, and ×16. Cards with a differing number of lanes need to use the next larger mechanical size (ie. a ×2 card uses the ×4 size, or a ×12 card uses the ×16 size).
Je me disais aussi... Mais j'ai vu sur le net des mecs dire que ça risquait de cramer la cm... Du bullshit je pense.
n°10626540
twain2
Posté le 03-09-2019 à 12:21:00  profilanswer
Je regarderai ce soir
n°10626750
bulfire
Posté le 03-09-2019 à 19:34:33  profilanswer
Est ce que un de vous a déjà reçu le kit de watercooling si on achetait une CM x570 dans cette opération ?
https://www.msi.com/Promotion/I-Love-You-3000-AMD/
J’ai aucune nouvelle et le site m’indique juste qu’ils attendent de recevoir les produits mais ça fait un mois et demi
n°10626752
cacahuete
Posté le 03-09-2019 à 19:39:51  profilanswer
Message édité par cacahuete le 03-09-2019 à 19:40:15
n°10626853
Bourin27
Posté le 03-09-2019 à 22:53:05  profilanswer
Pour ma part j'ai fait la demande du kit le 21/07, validation par MSI le 24/07.
Expédition le 24/08 et réception le 26/08. Soit un peu plus d'un mois entre ma demande et la réception.
Il est du coup monté sur le pc à mon fils (3770k), le mien étant déjà équipé d'un kraken X72
n°10626855
cacahuete
Posté le 03-09-2019 à 22:57:08  profilanswer
n°10626860
Bourin27
Posté le 03-09-2019 à 23:21:11  profilanswer
Oui. Avec le numéro de suivi UPS.
n°10626865
cacahuete
Posté le 03-09-2019 à 23:28:06  profilanswer
n°10627183
bulfire
Posté le 04-09-2019 à 19:38:21  profilanswer
Merci pour les retours il faut attendre alors :/
n°10627532
kobaia
Posté le 05-09-2019 à 15:34:04  profilanswer
Zarbi74 a écrit :
Sur Amazon.de (Allemagne), la X470 Gaming Plus est aussi annoncée, mais par un vendeur tiers et entre le 5 et le 9 septembre pour la disponibilité.
Donc je pense qu'il faudra attendre au moins le 15 septembre pour voir ces cartes disponibles (au compte goutte) dans les magasins.
ben elle date de 2018 la X470 Gaming Plus , c'est pas une nouveauté
un lien parmi d'autres pour ceusses qui s'y interessent
https://www.youtube.com/watch?v=7wW1lAbgBZw
par contre qu'est ce qui change avec l'arrivée de la X470 Gaming Plus *MAX* ?
n°10627545
Zarbi74
Posté le 05-09-2019 à 15:54:29  profilanswer
Je parle de la version MAX... faut suivre... :o
Elle apporte un bios plus gros et une compatibilité assurée (au moins pour le boot) avec les Zen 2.
Si tu achètes une X470 Gaming Plus/ Pro (non MAX) qui date un peu (stock), tu vas avoir un bios non compatible avec les Zen 2 et tu seras obligé de trouver un plus vieux proco pour faire la mise à jour.
Mon Topic Vente
n°10627590
kobaia
Posté le 05-09-2019 à 17:40:45  profilanswer
Bios 'plus gros'  ? mais z'encore  :o    bref concretement ....quoi ?
c'est ça qui serait interessant si tu as des infos
n°10627651
Christoliq​uide
Posté le 05-09-2019 à 18:51:36  profilanswer
32 mo pour le bios au lieu de 16 mo je crois. Et pour que le bios fonctionne correctement a 100% avec les Zen 2, il faut 32 mo.
n°10627657
F117
Posté le 05-09-2019 à 19:05:04  profilanswer
en clair il y a plus a racheter des cartes meres avec des bios a 32 mo
sauf qu'en général les fabricants n'indiquent pas la taille des bios
n°10627666
kobaia
Posté le 05-09-2019 à 19:43:32  profilanswer
oki merci,
Donc pour une avoir une mobo future proof pour series 3000  plutot viser au moins bios en X470  , et ce genre de mobo en version de remise à jour récente
et la MSI B450 Tomahawk MAX ? moins évident s'agissant du point 32Mo (?)
n°10627667
Zarbi74
Posté le 05-09-2019 à 19:46:54  profilanswer
En fait, le 32Mo permet de couvrir toute la gamme des Ryzen.
Alors qu'avec une mise à jour sur des bios de 16Mo, le Ryzen série 1XXX ne peuvent pas fonctionner: ce n'est pas grave si on a un Zen 2XXX ou un 3XXX mais c'est un peu gênant quand on a vendu une CM censée faire tourner tous les Ryzen.
Du fait des 16Mo, ils sont obligés de faire un choix pour la compatibilité.
La B450 Tomahawk Max est très bien.
Les X470 rajoutent quelques ports (moi j'en aurais l'usage mais ce n'est pas le cas de tout le monde).
Mon Topic Vente
n°10627676
bulfire
Posté le 05-09-2019 à 20:07:01  profilanswer
Sauf que c'est plus cas depuis les dernières maj (pas sur que ça concerne toutes les cartes cependant), mais le RAID soft est de retour, il n'y que le BIOS qui est en version lite (moins chargé graphiquement de dragons Haute Définition)
n°10628412
kobaia
Posté le 07-09-2019 à 17:53:49  profilanswer
D'apres Buildzoid , il estime qu'une mobo en chipset B450 + VRM 4+2 ( c'est le cas des MSI Tomahawk par ex ) ne va pas etre capable de tenir 4GHz avec un 2700X et un oc' PBO ( ou ce qui tient lieu de nom chez MSI ) sur une grosse charge de travail
en gros d'apres lui, la mobo va dire au pross 'heu là j'ai vraiment trop de courant à fournir , et j'ai trop chaud ' et le Ryzen va redescendre son coeff !
bon c'est pas trop représentatif non plus de l'usage quotidien mais c'est un point comme un autre avec le 2700
c'est ici à 25:00
https://www.youtube.com/watch?v=t1DnvthxpnY
so what ?  said Miles ...
Message édité par kobaia le 07-09-2019 à 17:55:31
n°10628435
worm'skill​er
Le roi de la petit côte
Posté le 07-09-2019 à 18:45:02  profilanswer
bullshit, une x470 gaming plus en 16 mo fera tourner sans probleme un zen 2 avec les bios actuels.
La version 32 mo te permettra juste d'avoir un bios plus coloré et être compatible avec les très vieux processeurs amd. ce dont en s'en fiche.
"le prix passe, la qualité reste"
n°10628436
worm'skill​er
Posté le 07-09-2019 à 18:47:29  profilanswer
c'est ici à 25:00
içi vers 13 minutes, il dit que la x470 gaming plus tient sans problème les octocores même en pays très chaud sauf si tu fais un oc de la mort : https://www.youtube.com/watch?v=7wW1lAbgBZw
n°10628437
F117
Posté le 07-09-2019 à 18:47:32  profilanswer
Si on a pas encore acheté la carte mère autan acheter une carte qui a un bios de 32 mo
n°10628447
cacahuete
Posté le 07-09-2019 à 19:12:03  profilanswer
Message édité par cacahuete le 07-09-2019 à 22:05:58
n°10628461
Zarbi74
Posté le 07-09-2019 à 19:43:51  profilanswer
Sauf que quand tu achètes une X470 Gaming Plus et qu'elle n'a pas le bon bios, tu risques d'être dans la merde pour flasher.  :whistle:
Alors que les X470 en version MAX seront nécessairement compatibles.
C'est l'idée de mon post.  :jap:
Mon Topic Vente
n°10628579
worm'skill​er
Posté le 08-09-2019 à 10:27:18  profilanswer
entendu mais au pire on demande au vendeur de flasher le bios si il te vend un processeur série 3000.
n°10628617
Zarbi74
Posté le 08-09-2019 à 12:45:48  profilanswer
C'est clair, mais encore faut-il que ce soit proposé... :/
Mon Topic Vente
n°10628693
Lestanquet
Posté le 08-09-2019 à 16:39:29  profilanswer
Salut à tous, j'ai une tomahawk max b450 et je peaufine si on peut dire. Dans le bios pour le contrôle du fan CPU on me propose pwm, DC ou auto, j'ai laissé en auto mais du coup je ne sais pas tellement à quoi ça correspond, ça me semble monitoré. Quelqu'un connait ? merci
Edit : vous avez coché le smart fan aussi ?
Message édité par Lestanquet le 08-09-2019 à 17:05:39
n°10628711
Divio
Posté le 08-09-2019 à 17:16:34  profilanswer
Sur ma B450 Tomahawk Max, j'ai 3 ventilos connectés : 1 CPU PWM, 1 boitier arrière PWM et 1 boitier avant 3 pins.
Pour le CPU, j'ai coché PWM
Pour le boitier arrière, j'ai coché PWM
Pour le boitier avant, j'ai coché DC
Smart Fan est activé.
Pour chaque ventilo j'ai reconstruit la courbe à ma sauce.
Tout va bien. Pas de nuisances sonores à bas régime.
n°10628718
Lestanquet
Posté le 08-09-2019 à 17:28:43  profilanswer
OK ! de mon côté ils sont tous compatibles PWM donc j'ai coché PWM et smart fan mais sans changer les courbes. Les températures sont bonnes c'est l'essentiel. DC ça correspond à quoi du coup ?
Message édité par Lestanquet le 08-09-2019 à 17:28:56
n°10628737
Divio
Posté le 08-09-2019 à 18:27:00  profilanswer
DC est l'acronyme de " Direct Current "
N'ayant que 3 pins sur le ventilateur de façade, la carte mère régule le ventilo par le biais de la tension du courant.
Message édité par Divio le 08-09-2019 à 18:33:15
n°10628742
Lestanquet
Posté le 08-09-2019 à 18:37:57  profilanswer
Ok merci ;)
n°10628847
Natopsi
☄️Just end it already!☄️
Posté le 08-09-2019 à 22:40:05  profilanswer
Bon bah le package logiciel MSI c'est définitivement de la merde.
Je ne sais pas ce que fout MSI dragon center derrière, mais j'ai réussi à me mettre dans une situation où le CPU semble rester bloqué à sa fréquence de base. Du moins jusqu'au moment ou j'appuie sur "rétablir par défaut" dans Ryzen Master  [:humanrage:5]
J'ai fini par désactiver les services MSI bidule et la hop miracle ça semble marcher à nouveau normalement  [:apges:3]
Puis je ne sais pas ce qui a fait ça (bios ou dragon qui veut incendier mon matos center),  mais j'ai lancé un OCCT, et la le cpu qui monde à 95°C puis qui commence à throttle, je comprends pas. Ah si le ventilateur CPU n'est pas monté dans les tours  [:frog sad:2]
Message édité par Natopsi le 08-09-2019 à 22:40:40
⚡ACH/VDS⚡HFRCoin◈1435mm⚡
n°10628862
cacahuete
Posté le 08-09-2019 à 23:24:51  profilanswer
n°10628953
Natopsi
Posté le 09-09-2019 à 09:13:14  profilanswer
Oui la je le garde au frais mais je sens que je vais le virer [:herbesahne]
n°10629080
sthomas38
Posté le 09-09-2019 à 12:24:45  profilanswer
MAJ de bios pour certaines CM dont ma Tomahawk max. Je l'ai faite, et rien de particulier à signaler pour l'instant, à part qu'ils ont viré un profil XMP, y'en a plus qu'un maintenant mais de toute façon c'était les 2 mêmes :o
Ah oui et curieusement quand j'ai voulu accéder au BIOS pour flash le nouveau, j'en étais incapable sans clear CMOS préalable. Le PC faisait que booter en boucle quand j'appuyais sur DEL ou sur Windows sinon :o
n°10629109
letit6908
Posté le 09-09-2019 à 13:04:08  profilanswer
Ça devient vraiment n'importe quoi, ces MAJ bios :fou:
Au bout de 2 mois de commercialisation des Zen 2, je ne comprends pas que l'on est pas en mesure d'avoir des bios à jour qui soient corrects. Plus je suis les différents sujets concernant les  Zen 2, plus on tombe sur des problèmes variés  :kaola:
C'est vraiment à croire que c'est les utilisateurs qui font les tests  :whistle:
n°10629126
Lestanquet
Posté le 09-09-2019 à 13:18:44  profilanswer
Désolé mais j'ai bien le choix de deux profils xmp différents.
n°10629145
sthomas38
Posté le 09-09-2019 à 13:46:02  profilanswer
Tu as le BIOS v32 ? Et une Tomahawk MAX ? Parce que c'est bizarre du coup ou alors peut-être que tes deux profils XMP sont différents ? C'était pas le cas des miens avant ce BIOS :jap:
n°10629148
Lestanquet
Posté le 09-09-2019 à 13:49:13  profilanswer
Ah au temps pour moi j'ai le v31. Je regarderai ce soir.
n°10629250
cacahuete
Posté le 09-09-2019 à 16:56:50  profilanswer
n°10629303
Lestanquet
Posté le 09-09-2019 à 18:14:24  profilanswer
La correction de quoi ? Du boost ? Ou des températures et de la conso  [:o_noel]
Conseil d'achat Ecran 144 Hz gamingMSI Radeon R9 390 8g vs Radeon RX 480 NITRO+ LITE 4Go
Update config gaming pour VR + Montage 4k[Topic unique] nvidia GP107 Pascal (14nm)
Aorus x470 compatibilité Ram 3466mhz pour 2700xPC gaming / streaming
Temps de Boot sur MSI z270 Pro CarbonRefroidissement MSI GTX 670
Virtualisation sur proc AMD et CM MSIMise à jour - MSI X370 Gaming Plus URGENT
Plus de sujets relatifs à : [Topic Unique] ** MSI ** X570/470 & B550/450
