5832 connectés
 Page :   1  2  3  4  5  ..  20  21  22  23  24  25
Le Topic Radeon 9X00 ! [topic RV250/R300] résumé -> 1er post
n°2021380
_deskira_
Posté le 04-12-2002 à 18:51:42  profilanswer
ca pourrait m aider
une desinstall soit-disant propre ne suffit pas a resoudre mon pb  [:toad666]
n°2021406
c_planet
Posté le 04-12-2002 à 18:58:39  profilanswer
1). Start Windows XP in VGA Mode by pressing F8 just as Windows begins to load.
2). Once in Windows, uninstall the the current driver set using the Add/Remove programs in your control Panel.
3). Delete the following registry entries
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SOFTWARE\ATI Technologies
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ati2mtaa
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ati2mtag
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Video
If any of those keys are missing just proceed.
4). Full Cleaning Steps
a). Do a file search on your Windows directory for ati*.* and delete everything it finds. If you are
using Rage3D Tweak there will be a couple files you'll want to keep (ATIOCen.inf, ATIOCen.PNF, and ATIOCpp.dll).
However, ATIOCen.inf and ATIOCen.PNF should be able to be safely removed and still retain functionality of Rage3D
Tweak.
b). Inf cleaning. Delete the following files from your Windows\inf directory
atirdn1.inf and atirdn1.PNF (?exact name?... something to that effect)
oemx.inf and oemx.PNF.... careful with these ones. You'll need to open each oemx.inf file to see
if it contains info for ATI cards. If it does, simply delete it (try not to delete any others, though it doesn't
really hurt).
5). Now reboot and your card should be detected as new and prompt you for a driver install.
le reste : http://www.rage3d.com/board/showth [...] d=33633482
n°2021547
titi14518
Posté le 04-12-2002 à 19:24:31  profilanswer
en gros vous preconisez une install des drivers sans le panneau de controles :??:  et ca regle tous vos problemes :??:
et donc les reglages tout par radeonator 2.0, y a tout de dispo ce qu il y a dans le panneau de controle ati :??:
n°2021557
Adriez
Posté le 04-12-2002 à 19:27:50  profilanswer
Yoda_57 a écrit a écrit :
Hmmm, çà n'enlève pas tout. En tous cas, la seule fois ou j'ai testé chez moi (j'ai encoe les 6131) çà n'avait pas tout supprimé.
Essaies la procédure décrite dans le readme des drivers.
Non en effet ça ne nettoie pas tout, et c'est pareil pour les drivers nvidia (j'en ai fais la mauvaise expérience, du coup des mois et des mois avec des problèmes de stabilité... aujourd'hui plus aucun probs).
En fait, il faut que tu reboots en mode sans échecs, tu désinstalles tes drivers, tu redémarres ensuite en sans échec encore, tu les installes et après c'est bon, tu as des pilotes clean.
Moi avant je ne faisais pas ça, du coup je me trouvais avec des fichiers de versions 40.72 + des drivers datant d'avant les 30.xx .... je vous laisse imaginer les degats ;o) (en effet les fichiers sont protégés dans Windows donc ils ne peuvent être remplacés qu'en mode sans échecs)
n°2021604
_deskira_
Posté le 04-12-2002 à 19:39:53  profilanswer
c_planet -> thanks  :jap:
j essayerai ce soir ou demain  :D
n°2021725
chrisleurn
Hardcore Will Never Die !
Posté le 04-12-2002 à 20:07:42  profilanswer
Y a chez GrosBill la Radeon 9500pro (generique) en vente pour 219? :ouch:
n°2021738
Marc
Chasseur de joce & sly
Posté le 04-12-2002 à 20:09:23  profilanswer
Ca doit être une 9500 ... à ce prix c chelou et en plus les 9500 Pro devrait pas y'en avoir avant Janvier
Message édité par Marc le 04-12-2002 à 20:09:54
Moi, j'aime pas les signatures
n°2021783
Adriez
Posté le 04-12-2002 à 20:19:57  profilanswer
http://www.grosbill.fr/cat.cgi?id=5529&p2=promo&p3=
Mais je pense que y'a un prob, car déjà la 9500 pro devait avoir 128 mo ddr et pas 64, non ?
De plus, ils ont pas mis de descriptif.... et le prix tout mini.... (enfin bon le prix peut se comprendre s'il s'agit d'une générique et non d'une marque)
n°2021817
c_planet
Posté le 04-12-2002 à 20:28:21  profilanswer
9500 pro de marque ici en belgique c'est +/- 260?
n°2022109
sullivanXP
Posté le 04-12-2002 à 21:55:13  profilanswer
Bon j'ai ressayer d'installer les catalyst sans les pannels ca ne change rien pour moi. Toujours un probleme de "smooth" sous nfs6. J'ai aussi tester le 3danalyser sans succes. Et le radeonator2 pas mal mais je prefere le rage 3d tweaker. C'est trop complexe à configurer pour chaque jeux. vivement les 2.5
n°2022118
tonton son​ic
RTFM
Posté le 04-12-2002 à 21:58:09  profilanswer
g l'impression d'avoir pareil. c super fluide mais sans etre fluide c une impression chelou  :heink:
Et?
n°2022128
mikestewar​t
Air Roll Spinnin'
Posté le 04-12-2002 à 22:01:34  profilanswer
C'est le jeu qu'est comme ça. :)
n°2022138
_deskira_
Posté le 04-12-2002 à 22:03:48  profilanswer
avec 3danalyzer et l option 'remove stuttering' en mode quality, ca a résolu le pb de saccades sous nfs6 pour moi
n°2022147
THE REAL K​RYSTOPHE
ストリートファイターBrasileiro NTSC-J
Posté le 04-12-2002 à 22:06:27  profilanswer
les 9700 zavez kombien au benchmark de ut2k3
entre le 640 et le 1600 ?  (botmacth surtoo)  une baisse ?
Message édité par THE REAL KRYSTOPHE le 04-12-2002 à 22:06:41
n°2022171
sullivanXP
Posté le 04-12-2002 à 22:12:25  profilanswer
Ben, tant mieux pour toi!  :)  Tu as une 9700? J'ai lu le fichier d'aide. Ils parlent de 9700 (pour le stuttering) mais pas de la 8500 :(. Est ce que tu as remarqué des différence pour d'autres jeux?
n°2022201
Adriez
Posté le 04-12-2002 à 22:20:50  profilanswer
ou ça ???
n°2022213
c_planet
Posté le 04-12-2002 à 22:22:51  profilanswer
halloweencomputers en attente d'arrivage je pense
n°2022226
_deskira_
Posté le 04-12-2002 à 22:25:03  profilanswer
vu que j ai que ut, ut2, quake 3 et nfs6 sur mon pc et que les autres fonctionnaient deja correctement ...  :D
n°2022296
seyed_s
Posté le 04-12-2002 à 22:46:01  profilanswer
mdr  :lol:
http://www.nvchips-fr.com/News/news.php?id=200212046
[:seyed_s]
n°2022356
pink floyd
Trance Is Life...
Posté le 04-12-2002 à 23:05:07  profilanswer
seyed_s a écrit a écrit :
mdr  :lol:
ca fe un moment que je l'ai posté  ;)
Oui aux titres de topic clair et precis...
n°2022368
THE REAL K​RYSTOPHE
Posté le 04-12-2002 à 23:08:16  profilanswer
mdr  :lol:
 :lol:  :lol:
tin cai bo :(
n°2022370
tonton son​ic
RTFM
Posté le 04-12-2002 à 23:08:33  profilanswer
version des drivers beta c normal :)
sauf que eux y sont tellement cons qu'ils font kan meme leur démo :D
j'imagine le briefing du gars :
"ecoute mec t'as 1/2 que ca plante, alors voila les trucs pour détourner l'attention pdt que windows redemarre :
regarde ta montre, parle du temps qu'il fait, bouscule la caméra sans le faire expres, ou fait tomber le portable, mais fait quelque chose :D"
Et?
n°2022373
THE REAL K​RYSTOPHE
Posté le 04-12-2002 à 23:09:19  profilanswer
j espers ke c pas la chauffe de la karte
sinon ont va en voar des tomik sur les forum !
n°2022428
seyed_s
Posté le 04-12-2002 à 23:28:09  profilanswer
le pick up est trop bien fé sa race  :love:  :love:  :love: surtout en faisant défiler la barre jusqu'au bout :eek:
[:seyed_s]
n°2022439
MagiSim
Magique, et oui !
Posté le 04-12-2002 à 23:32:34  profilanswer
Nota, le R300 n'avait pas buggué lors de la présentation de Doom3 avant l'annonce de la puce.... :/
Pour savoir pourquoi je suis magique, faut me connaître !
n°2022442
seyed_s
Posté le 04-12-2002 à 23:34:41  profilanswer
ça c'est un coup bas  :non:
[:seyed_s]
n°2022467
YodaNC
Posté le 04-12-2002 à 23:42:50  profilanswer
mai c vrai kan meme :whistle:
[VDS] Pentax: Grip K10/K20, accessoires ...
n°2022474
_deskira_
Posté le 04-12-2002 à 23:45:44  profilanswer
apres un bon format ca va mieux :D
n°2022515
MagiSim
Magique, et oui !
Posté le 04-12-2002 à 23:58:21  profilanswer
Ben vi, mais bon, chacun son tour !  :wahoo:
n°2022538
mikestewar​t
Air Roll Spinnin'
Posté le 05-12-2002 à 00:04:51  profilanswer
mdr  :lol:
Moi faut pas que je fasse de commentaire sinôn je vais encore dire une connerie. :D
[Mode Fanatic On]
Ben 2 mois avant la dispo en boutique de la carte c'est pas joli joli, nous avec ATI et la R9700 la carte elle rulez pendant des heures sans plantage 6 mois avant la sortie. Bon, donc soit Nvidia sort sa GeForceFX 6 mois plus tard, juste après la sortie du R400, pour régler tout ça soit tous les acheteurs de GeForceFX vont planter toutes les 2 mn 30...500Mhz même avec une turbine pour ventiler c'est clair que c'était trop beau pour pas planter et c'est pour ça que les reviews sont pas prêtes de venir. Et Nvidia c'est de la merde je vous l'avais dit, voilà. :p
[Mode Fanatic Off]
Fini la déconne, Nvidia avait déjà dit qu'il y a encore des problèmes d'instabilité avec la GeForceFX mais que ça serait réglé pour les reviews et la dispo donc finalement c'est pas une news nouvelle et c'est tout à fait normal tout ça. :)
Message édité par mikestewart le 05-12-2002 à 00:06:18
n°2022583
tonton son​ic
RTFM
Posté le 05-12-2002 à 00:37:05  profilanswer
une question justement sur la fréquence d'horloge des GPU
pkoi y tournent pas encore aussi vite que nos CPU?
pas assez de place pour refroidire?
probleme PCB de la carte?
trop complexe?
ca m'intrigue  :)
Et?
n°2022599
mareek
Et de 3 \o/
Posté le 05-12-2002 à 00:46:35  profilanswer
trop complexe?
ca m'intrigue  :)
nombre de transistor plus important + refroidissement plus petit + plus grande experience des fabriquant de CPU dans le domaine + différence de structures que je ne connais pas
"I wonder if the internal negative pressure in self pumping toothpaste tubes is adjusted for different market altitudes." John Carmack
n°2022614
tonton son​ic
RTFM
Posté le 05-12-2002 à 00:51:41  profilanswer
oki
donc en gros c a cause du nb de transistor --> chauffe plus --> comme on a moins de place pour refroidir --> baisé
ok merci chui fixé  :)
Et?
n°2022625
mareek
Et de 3 \o/
Posté le 05-12-2002 à 00:58:21  profilanswer
oki
la structure interne doit jouer pas mal aussi, il faudrait qu'un des "cerveaux" qui passent sur ce topic donnent leur avis sur la question.
n°2022627
Oxygen3
Tears from the moon
Posté le 05-12-2002 à 01:00:20  profilanswer
tu as eu mes données entre 1024 et 1600 :p
Metro-Pole ▬ Réseau A Suivre...: Annuseries|LeVillage|pErDUSA
n°2022642
Yoda_57
Marc, gagame, c'était mieux
Posté le 05-12-2002 à 01:09:57  profilanswer
ben faut dire qu'avec le retard qu'ils prennent, ils essaient quand même de montrer que la carte arrive et est prête.
Ah ben non finalement, elle arrive, mais elle n'est pas encore prête   :whistle:
Message édité par Yoda_57 le 05-12-2002 à 01:21:38
Art ?|Pro ?|Sport ?| ACH/VDS matos photo divers
n°2022655
tonton son​ic
RTFM
Posté le 05-12-2002 à 01:19:36  profilanswer
et qui c qui va faire les beta testeurs encore? ??  :D  :(  :fou:
Et?
n°2022683
mareek
Et de 3 \o/
Posté le 05-12-2002 à 01:44:14  profilanswer
Pour ceux qui ne l'ont pas encore lu, pleins de news sur la strategie d'Ati de la bouche de son DG :
http://www.presence-pc.com/news/index.php3?news=6659
Message édité par mareek le 05-12-2002 à 01:45:03
n°2023264
mareek
Et de 3 \o/
Posté le 05-12-2002 à 12:08:10  profilanswer
sealbirman a écrit a écrit :
Pour rire un peu, apparemment Nvidia aurait encore quelques soucis de 'jeunesse' avec ses drivers GeforceFX; 2 plantouilles en direct sur la présentation de démos GeForceFX sur une chaine allemande... :ouch: ; bon, c'est des versions béta de carte et de driver mais si la sortie doit se faire pour fin décembre, faudrait pas trop se précipiter pour l'acheter...
http://www.presence-pc.com/news/index.php3?p=0
et la vidéo est là:
http://www.presence-pc.com/links.p [...] rafik2.wmv
déjà posté, faut lire un peu le topic
n°2023274
sealbirman
Rhhha ha hahaha...
Posté le 05-12-2002 à 12:10:48  profilanswer
ahh zut, pardon pour le dérangement;  :jap:
n°2023548
manutere
Euh.... Bou !!
Posté le 05-12-2002 à 13:42:21  profilanswer
bon alors moi aussi je le dit pour ceux qui ont des problemes de begayement dans certains jeux comme rallysport ou nfs,avec 3danalyzer et l option 'remove stuttering' en mode quality, ca a résolu tous les problemes de ce genres.
  voila je le repete pour ceux qui ont la fleme de lire :)
j'aurais une autre question peut etre trés bete:
  le proc est un facteur limitant tout le monde le sais mais en quoi? la montée en resolution? ou autres? :heink:
Message édité par manutere le 05-12-2002 à 14:07:54
Problème de son avec le tuner de ma AIW Radeonradeon 8500 et driver 2.4
radeon 9700 prole ventilo de ma radeon 8500 LE fait du boucan,par quoi le remplacer ?
plein écran Windows média player VS Radeon 7500Radeon 9700 Pro ou la nouvelle Geforce FX??
Radeon 9700 ou Geforce FXKT7A et radeon 7500 compatible ?
compatible la radeon 7500 ??Acheter une RADEON 9700 au canada ca vaut le coup ?
Plus de sujets relatifs à : Le Topic Radeon 9X00 ! [topic RV250/R300] résumé -> 1er post
