4337 connectés
 Page :   1  2  3  4  5  ..  163  164  165  ..  257  258  259  260  261  262
[Topic nVidia 6800 series]
n°3395317
Jack_Power
Posté le 07-08-2004 à 01:02:50  profilanswer
Warning !
Info ou Intox ? :heink:
OK let's clear this mess up, it seems that 80% of the any vendor 6800 Ultra cards have as well 2,0ns Samsung (like 6800GT), BUT in fact these are only erroneously named 1,6ns chips. This is great news to us who bought GT .
Now stop whining, in the first place Samsung is responsible of this mistake.
Ca expliquerait pas mal de chose remarqué  [:atari]
Je vous laisse médité la dessus  ;) , personnellement bonne nuit .
[:m-power-bmw]
n°3395355
lovingbenj​i
J'en prendrai pour 1 dollar
Posté le 07-08-2004 à 01:21:49  profilanswer
Jack_Power a écrit :
C'est quoi ta version la ? Je vais looké ...
je la vois où ma version ?
Chic not Geek
n°3395356
lovingbenj​i
Posté le 07-08-2004 à 01:21:58  profilanswer
Petite question , c'est le design Msi ou encor du design nv  :??:
nv  :(
Chic not Geek
n°3395364
Krixoff
chaos
Posté le 07-08-2004 à 01:27:43  profilanswer
Gonishi a écrit :
C'est naze  :heink:
Tu peux me dire après c'est quoi l'intérêt du jeu dans ces conditions  :pfff:
ah ben voilà copaing  !
n°3395456
bjone
Insert booze to continue
Posté le 07-08-2004 à 06:53:50  profilanswer
NecOne a écrit :
Petite astuce pour Doom III ;)
Code :
  1. Doom3:
  2. I saw this somewhere on a forum..
  3. "I tried this and Im now running at 1280x1024 compared to 800x600 at the same settings.
  4. "As all of you who allready have this game recognized the game is very slow even on new Computers.
  5. I found out the reason for this and the solution to fix this problem.
  6. As you already know after installation the game consits only of the doom3.exe and some .PK4 files. Those PK4 files includes the entire game (sounds, videos, textures etc.) in high compressed form.
  7. Normally those files were decompresse during the game.
  8. But this exactly is the problem. Even new CPUs are not able to decompress those files while running the game with good peformance and therfore the game runs very **** also on new computers. I don't know if the develpers of ID-Soft was just too stupid to think about this or if they have an agreement with some hardware manufacturing firms.
  9. How to get around this problem:
  10. It is very simple. Go to your Doom 3 installation directoy and get inside the folder "Base". There are some .PK4 files you have to open each of them with WinRAR 3.3 and extract their entire contents to the Base dir in you Doom 3 installation folder (replace all files if they are any duplicates). Now you have to delete all .PK4 files in the Base folder to prevent the game to use those compressed files agian.
  11. Now the game starts and runs mutch faster!!!
Le gain est pas norme mais ça marche mieux
Astuce de merde.
pour info les PK4 de Doom3 ainsi que les PK3 de Quake 3 et dérivés c'est du Zip.
d'une part le jeu va grossir en taille sur disque dur.
d'autre part le temps de chargement des ressources risque d'être accentué, car il est souvent plus rapide de lire les données compressée puis de les décompresser que de lire directement les données décompressées.
bref, l'entièreté du tip est un troll.
n°3395458
bjone
Posté le 07-08-2004 à 06:54:56  profilanswer
lovingbenji a écrit :
:non: Essaye d'obtenir ne serait-ce que 10% de ce genre d'effets avec des sm2.0 ... >>>  ;)
http://mapage.noos.fr/bandamor/images/sm3.JPG
si tu parles de l'effet de lumière issu des trous, pris comme ça sur ce snapshot là, ça semble faisable avec une 3dfx 1.
Message édité par bjone le 07-08-2004 à 06:55:54
n°3395642
Gonishi
Posté le 07-08-2004 à 11:26:14  profilanswer
la remarque qui tue :lol:
n°3395649
profession​nal
Posté le 07-08-2004 à 11:29:31  profilanswer
Le bios de ma leadtek GT c est 5.40.02.15
n°3395691
lovingbenj​i
Posté le 07-08-2004 à 11:51:53  profilanswer
tu programmes pour Carmack sans doute ?  :lol:
Chic not Geek
n°3395693
lovingbenj​i
Posté le 07-08-2004 à 11:52:20  profilanswer
tu le vois où ?
Chic not Geek
n°3395701
profession​nal
Posté le 07-08-2004 à 11:55:39  profilanswer
Sur 6800 GT dans le panneau de controle Nvidia
Message édité par professionnal le 07-08-2004 à 11:56:31
n°3395716
Gonishi
Posté le 07-08-2004 à 12:05:28  profilanswer
http://www.xbitlabs.com/images/video/doom3/new_hell_1280_pure.gif
Je crois que t'as fait le bon choix, de quoi avoir un 60 fps constant avec une carte pas trop cher  :love:
n°3395718
Gonishi
Posté le 07-08-2004 à 12:06:20  profilanswer
c'était un screen de far cry  :sarcastic:
n°3395729
lovingbenj​i
Posté le 07-08-2004 à 12:11:53  profilanswer
sans dec ?!!!  :ouch:
Chic not Geek
n°3395731
Krixoff
chaos
Posté le 07-08-2004 à 12:12:30  profilanswer
Gonishi a écrit :
http://www.xbitlabs.com/images/vid [...] 0_pure.gif
c'est affolant, le 6800 plus rapide qu'une x800xt dans doom3
n°3395732
lovingbenj​i
Posté le 07-08-2004 à 12:12:46  profilanswer
ok idem pour moi  ;)
Chic not Geek
n°3395746
Gonishi
Posté le 07-08-2004 à 12:22:40  profilanswer
normal y pas d'antialiasing
donc
le GeForce 6800 est capable de calculer les passes ne s´occupant que des données Z avec un débit double.
http://www2.hardware.fr/articles/491/page5.html
Message édité par Gonishi le 07-08-2004 à 12:23:40
n°3395748
Gonishi
Posté le 07-08-2004 à 12:23:06  profilanswer
oups désolé je viens de comprendre  [:cupra]
n°3395750
Krixoff
chaos
Posté le 07-08-2004 à 12:23:42  profilanswer
donc
ah ok sans AA !
n°3396240
kao98
Posté le 07-08-2004 à 16:47:18  profilanswer
Bon, ben j'ai fini par identifier mes problèmes avec ma carte, mais pas à les résoudres !
En fait, ça chauffe. Mais comme vous êtes tous ou presque en wc, ça vous fais pas la même chose ! En fait, comme la carte est tellement longue à en rejoindre les disques dur, ça divise le boitier en deux. Et donc, sous la carte, de l'air est chauffé par le gros rad, surtout côté mémoire. Et donc, c'est toute la carte qui chauffe de plus en plus ! Et ce malgrès un ventilo en facade ! Mais l'air qu'il injecte dans la machine est réchauffée par les disques dur ! J'ai placé un de ces ventilos que l'on place sur un emplacement PCI qui est censé expulsé l'air chaud de la carte mais tout ce qu'il expulse c'est de l'air frais. Il n'est pas assez long en fait pour aspiré l'air chaud.
Alors, quelqu'un a-t'il compris d'une part ce que je racontais ? Et, auriez-vous des solutions SVP (heu, pas de watercooling !) ?
au fait, je suis boitier ouvert !
Message édité par kao98 le 07-08-2004 à 16:47:48
n°3396243
Posté le 07-08-2004 à 16:49:02  answer
bah moi j'ai aps de wc et ca chauffe pas trop
par contre ma tour est tres bien ventilé :) et fait bcp de bruit
Message édité par Profil supprimé le 07-08-2004 à 16:49:15
n°3396246
Jack_Power
Posté le 07-08-2004 à 16:50:17  profilanswer
Bon c'est monté  :sol:
Alors autant prévenir les futurs utilisateurs de Gainward Golden Sample 6800 ultra , il va vous falloir obligatoirement lire attentivement la page 217 et comment flashé avec le bios xfx ,car se que je n'avais pas remarqué lors de mon premier montage rapide de mardi , c'est que les 2 ventillos tournent a donf que vous soyez en 2D ou 3D avec le dernier bios ou l'ancien d'ailleurs ! Et c'est extremement pénible !
De plus de tres grosses instabilitées avec le bios gainward d'origine des que vous monté un peu en mhz ram ou gpu d'ailleurs .
Alors j'en ais eut plein fion fo dire se qui est  :o , j'ais suivie les conseil de nos amis allemand , flash avec le bios XFX moddé de nvnews, et la je m'attendais pas a une tel claque  :ouch:  :love:
Le bug des ventillos et corrigés , vous bootez plus vite , la cg est désormé cadencé d'orgine a 425/1200 mhz  [:aras qui rit]
Bref difficile de descendre en dessous de 150 fps a unreal 2k4  [:atari]
Ca y est j'ais fait dans mon pantalon  :lol:
Bon je me calme  :o , faut s'occupé du petit lovingbenji a present  :)
n°3396253
Jack_Power
Posté le 07-08-2004 à 16:55:05  profilanswer
ok idem pour moi  ;)
Bon alors enfin de compte c'est quel version que j'aille looké  :)
n°3396254
profession​nal
Posté le 07-08-2004 à 16:56:56  profilanswer
5.40.02.15
n°3396267
Posté le 07-08-2004 à 17:07:32  answer
ta essayer dnas une map en exterieur avec 32 bot en mode difficile ?
car les 150 fps j'y croit pas :D
n°3396268
kao98
Posté le 07-08-2004 à 17:08:09  profilanswer
ca veut dire quoi "très bien ventilé" ? Moi, j'ai un ventilo en extraction en haut, un autre sous la carte graphique et un qui soufle à l'avant ! Bon, c'est des ventilos de base ! Peut-être qu'avec des turbines à 4000 tpm, ce serait mieux ventilé !?
n°3396271
Jack_Power
Posté le 07-08-2004 à 17:08:58  profilanswer
ok alors deja sur le ftp leadtek , pas tres securisé d'ailleurs  :D ,
ya ca ftp://ftp.winfast.com.tw/entertai [...] s/2992.zip mais je pense que ca doit etre l'original sans doute ...1 min.... sinon ya du pny et pov en gt :
PNY - 6800GT
350/1000 v5.40.02.15.02
Download
64. Point of View - 6800GT
350/1000 v5.40.02.15.02 (256MB DDR3, Samsung 2ns)
Aucune idée de ce qui donnent ....
Nope apparament ya que le fichier 2992 en GT officiel leadtek , par contre aucune idée sur le numero version ,je cherche ...
Message édité par Jack_Power le 07-08-2004 à 17:12:42
n°3396272
Posté le 07-08-2004 à 17:09:15  answer
un 120 en facade
un 120 derriere
un 92 sur le cpu
voila :)
n°3396275
Jack_Power
Posté le 07-08-2004 à 17:11:31  profilanswer
6 bots  :o , sur icetomb en deathmatch 1024x768 aniso 2 aa 0 trilinéair, high quality  :p , j'ais juste testé 5 mins a la va vite , je viens a peine de tout remonté , j'ais mis proc a 3.42ghz et la ram a 187 desynchro  :D  (P4B 3.06ghz d'origine)
Enfin pour moment tres satisfait de mon achat , reste plus qu'a voir le comportement de Doom 3 ...
Message édité par Jack_Power le 07-08-2004 à 17:18:53
n°3396325
lovingbenj​i
Posté le 07-08-2004 à 17:39:44  profilanswer
PNY - 6800GT
Download
Merci Jack ;)
c'est surement en effet celui d'origine, vu sa date !
Je vais attendre un peu le prochain, en espérant qu'il sorte !
Chic not Geek
n°3396327
hamon6
PSN: HaMoNeR
Posté le 07-08-2004 à 17:42:28  profilanswer
Dis moi tu peut me donner le lien de ce Bios moddé...et la flasher a utiliser ?!
Merci d'avance !
n°3396369
Jack_Power
Posté le 07-08-2004 à 18:02:42  profilanswer
Merci d'avance !
Tout est en page 217 du topic , oui ici !  :hello:
Avec liens , explications de bibi  :D
Le mod xfx te permet de faire tourné les ventillos tout le temps a vitesse 2D + obtenir un zolie 425/1200 direct d'origine sans coolbits , donc si tu surf t'es env. a 50/55 degré (idem bios gainward), et en jeux entre 75/80 degré tout en gardant un espace sonore de qualité .(avec bios gainward 65 degré env. mais nivo bruit  :kaola: )
J'ais testé la differance avec les bios gainward , tu gagne 10 degré avec les ventillos a fond certe MAIS bonjour l'avion on se croie avec une FX 5800Ultra ! [:tristanf]
C'est l'unique solution pour moment d'avoir la paix nivo bruit en gardant un minimum d'efficacité de cooling . De toute facon apres lecture de quelques sites ca deviend risqué vers 100 degré donc ya d'la marge  :D
M'enfin tu verra en branchant , tu me remerciera apres  [:atari]
Sinon la prochaine generation de cg ca sans le wc obligatoire  :o
Message édité par Jack_Power le 07-08-2004 à 18:05:16
n°3396391
rootsayen
Jungle Cat
Posté le 07-08-2004 à 18:20:41  profilanswer
"Sinon la prochaine generation de cg ca sans le wc obligatoire  "
Je pense pas, t'as vu chez ATI, c'est raisonable le refroidissement :) Le prob chez nVidia, c'est que y'a pas eu d'amélioration de gravure entre le nv30-35 et nv40, alors forcement ca consome et chauffe +. Mais je vois mal la prochaine génération en 0.13, je penche vers du 0.11 ou 0.09.
Message édité par rootsayen le 07-08-2004 à 18:21:09
"Being solitary is being alone well; being alone luxuriously immersed in doings of your own choice, aware of the fullness of your own presence rather than the absence of others."
n°3397014
JoeG
A + F
Posté le 08-08-2004 à 01:00:05  profilanswer
est ce que c'est limitant d'avoir une cm qui supporte seulement l'agp 4x avec une 6800gt ?
n°3397032
thekiller3
Posté le 08-08-2004 à 01:14:07  profilanswer
non.
n°3397060
kao98
Posté le 08-08-2004 à 01:40:13  profilanswer
La différence entre les refroidissements ATI et NVIDIA je trouve ça assez allucinant ! Les ATI semblent tout de même bien plus silencieuses ! Non ? Z'en pensez quoi ?
n°3397073
thekiller3
Posté le 08-08-2004 à 01:52:06  profilanswer
j'en pense rien vu que je vais watercooler tout le bordel... :D
n°3397304
rootsayen
Jungle Cat
Posté le 08-08-2004 à 10:58:42  profilanswer
Baaah c'est vrai :)  Mais les X800 ont moins de transistors que les nv40, et surtout, nVidia s'est pas trop pris la tete pour monter un venti/rad silencieux. Suffit de voir les améliorations apportées par le systeme de Leadtek ou du futur MSI.
n°3397359
mrdoug
Posté le 08-08-2004 à 11:32:17  profilanswer
J'aimerai bien me prendre une geforce 6800 Ultra mais je me demande s'il faut que j'attende le PCI-E, histoire de mettre une seconde carte en sli dans quelques années. Qu'en pensez-vous ?
n°3397370
nick64
Miam!
Posté le 08-08-2004 à 11:35:36  profilanswer
dans quelques années on sera au pci express 32X, la 6800 ultra sera périmée....
Mon FeedBack
n°3397382
mrdoug
Posté le 08-08-2004 à 11:38:49  profilanswer
ow31 a écrit :
Je pense que la drog, s'pa bieng ! :whistle:
D'ici là le prix aura nettement baissé  :)
coup de geule contre ati/nvidia & carte mere :qualitée de l'Entree Video ATI vs Nvidia
Bi-Ecran: (9800pro) ATI /nVidia (5900) ? - surchauffe ?"Nvidia WDM Video capture (universal)"?!?
Pilotes NvidiaPilotes Nvidia 45.xx pour 2k/xp : ou est ce qu'on active la sortie tv?
[CG] Quelle est la meilleure Nvidia 4 Gamers sur le marché ?new drivers nvidia 56.72
NVidia TI 4200 - Ventilo misèreInstallation d'une ATi après une NVIDIA
Plus de sujets relatifs à : [Topic nVidia 6800 series]
