2567 connectés
  HiFi & Home Cinema
  [Topic Unique] des enceintes Q Acoustics
n°1386931
e_l_m_o
Globine, Tiste, Tarie
Posté le 02-04-2008 à 18:12:46  profilanswer
Dans ma quête d'enceintes compactes, je suis tombé sur la marque anglaise Q Acoustics.
La qualité de fabrication et les finitions ont l'air sympa et les prix sont raisonnables.
Voici le lien : http://www.qacoustics.co.uk/
Q1010
http://www.qacoustics.co.uk/images/qacoustics/1010.jpg
http://www.qacoustics.co.uk/images/qacoustics/1010cut.jpg
http://www.qacoustics.co.uk/images/qacoustics/1010beech.jpghttp://www.qacoustics.co.uk/images/qacoustics/1010black.jpghttp://www.qacoustics.co.uk/images/qacoustics/1010cherry.jpg
1010i Specifications
Enclosure Type  2-way
Bass Unit (mm)  100
Treble Unit (mm)  25
Frequency Response (±3dB)  68Hz - 20kHz
Nominal Impedance (Ohm)  6
Minimum Impedance (Ohm)  4
Sensitivity (2.83v@1m)  86dB
Recommended Amplifier Power  15 - 75W
Crossover Frequency (kHz)  2.5
Effective Volume (litres)  3.4
Cabinet Dimensions (HxDxWmm)  215 x 195 x 150
Weight (Kg per cabinet)  2.8
env. 199 eur
Q1020
http://www.qacoustics.co.uk/images/qacoustics/1020.jpg
http://www.qacoustics.co.uk/images/qacoustics/1020beech.jpghttp://www.qacoustics.co.uk/images/qacoustics/1020black.jpghttp://www.qacoustics.co.uk/images/qacoustics/1020cherry.jpg
1020i Specifications
Enclosure Type  2-way reflex
Bass Unit (mm)  125
Treble Unit (mm)  25
Sensitivity (2.83v@1m)  88dB
Recommended Amplifier Power  25 - 75W
Crossover Frequency (kHz)  2.8
Effective Volume (litres)  7.0
Cabinet Dimensions (HxDxWmm)  250 x 265 x 175
Weight (Kg per cabinet)  4.0
env. 249 eur
Q1050
http://www.qacoustics.co.uk/images/qacoustics/1050.jpg
1050i Specifications
Bass Unit (mm)  2x165
Treble Unit (mm)  25
Frequency Response (±3dB)  44Hz - 20kHz
Minimum Impedance (Ohm)  3.8
Sensitivity (2.83v@1m)  92dB
Recommended Amplifier Power  25 - 100W
Crossover Frequency (kHz)  2.4
Effective Volume (litres)  35.7
Cabinet Dimensions (HxDxWmm)  975 x 295 x 195
Weight (Kg per cabinet)  17.8
Message édité par e_l_m_o le 02-04-2008 à 18:30:37
J'ai acheté la télécommande universelle, reste plus qu'à choisir les appareils.
n°1386935
e_l_m_o
Posté le 02-04-2008 à 18:16:38  profilanswer
(topic unique ...j'espère que je ne fais pas un doublon ou un triplon  sinon je vais me faire télétubiser ...)
Est-ce qu'il y a une grande différence entre une Q1010 et une Q1020 ?
Message édité par e_l_m_o le 02-04-2008 à 18:20:41
n°1386998
_JbM
_Dense comme la brique
Posté le 02-04-2008 à 20:09:46  profilanswer
2cm sur la taille du hp grave, 2dB de rendement, et un niveau maximum atteignable sans doute supérieur de quelques décibels 1020.
Si tu n'as pas d'impératif de taille extrêmement serré, choisis donc plutot ce modèle ;)
n°1387107
e_l_m_o
Posté le 02-04-2008 à 23:46:00  profilanswer
C'est important 2db de rendement en plus ?
n°1387890
_JbM
Posté le 04-04-2008 à 17:36:17  profilanswer
Pas beaucoup, mais la tenue en puissance supplémentaire que pourra amener deux centimètres de diamètre en plus sera à mon avis la bienvenue ;)
C'est quand même 50% de surface de membrane en plus...
n°1387894
e_l_m_o
Posté le 04-04-2008 à 17:44:57  profilanswer
Merci ;)
Ca yé j'ai débloqué la situation, j'ai le droit à une q1020
J'ai re-mesuré et fabriqué une boite en carton noir pour que madame voit : 25x26,5x17,5 c'est quand même assez petit / discret !
Reste plus qu'à les trouver en noir chez un bon vendeur ...
[Materiel.net ne propose que la couleur cherry par exemple]
Message édité par e_l_m_o le 04-04-2008 à 17:46:44
n°1458249
arougeot
Posté le 16-10-2008 à 09:43:32  profilanswer
chez boulanger, j'ai cru les voir à 125 euros ! contre 249 en général. Où a stu acheté finalement ?
n°1459027
Pierre2312
Objectiviste subjectivé
Posté le 17-10-2008 à 17:22:01  profilanswer
L'auteur de ce topic (e_l_m_o) a probablement quitté ce forum.
Ceci étant dit, si tu trouves des Q Acoustics 1010 ou 1020 à ce prix là, je pense qu'il faut les acheter tout de suite. Vu que le prix de lancement était déjà, à mon avis, très bas...
n°1459042
grumfer
Posté le 17-10-2008 à 17:52:35  profilanswer
n°1479690
scorpy
Posté le 01-12-2008 à 13:31:14  profilanswer
bonjour,
Il n'y a pas plus d'animation pour ces enceintes qui ont l'air de qualité ?
ou les trouver à bon prix ? le pack complet (1050i, 1020i, 1000Ci et 1000 Si).
quelle est la diff entre les 1050 (1ere version) et 1050i (2eme version) ?
  HiFi & Home Cinema
Installation enceintes dans 3 pièces dont 2 avec 1 seule enceintenad ou atoll ? enceintes qui se marient ?
impossible de couper le son des enceintes sur Auzentec Préludedemande conseil enceintes PC pour une écoute loin du PC
probleme branchement enceintes 2.1, aidez moi svp !!branchement enceintes 5.1/pc
[Topic Unique] Driver pour Carte son SIS7012Home cinema vs enceintes+ampli pour de la tek
Comment enlever le bourdonnement du caisson de basse altec VS4121URGNT !!! - Enceintes JBL LX66 - URGENT!!!!!
Plus de sujets relatifs à : [Topic Unique] des enceintes Q Acoustics
