5203 connectés
 Page :   1  2  3  4  5  ..  83  84  85  ..  91  92  93  94  95  96
[Topic unique] Canon EOS 70D: Dual Pixel AF
n°5532402
Perfect007
What else ?
Posté le 16-06-2015 à 12:48:27  profilanswer
J'ai la même configuration (70D et Z10) et je n'ai jamais réussi la connexion.
Pour utiliser Eos Remote, j'ai une tablette sous Android.
Parrainage Meta (casque Quest)= > https://www.meta.com/referrals/link/oculus_007_
n°5532519
major_niki​ta
Posté le 16-06-2015 à 14:50:00  profilanswer
as tu essayé ceci ?
chez moi ca ne marche pas alors que ca devrais
Just stumbled across this post because i tried to connect my Z30 to my Eos 70D using Canon Eos Remote.
After sideloading Snap, i installed Eos Remote.
During the first try connecting the Z30, I ended up like the others in this thread: The Z30 Wifi finds the EOS 70D and connects to it and tries to get an IP. Stuck.
Fortunately the Z30 saves the wifi connection to the 70D (if you have entered the right credentials).
Just open the saved wifi profile and modify it like i did:
To resolv the connection problem, i set the ip manually to an IP in the same Network the 70D is. You can see the ip during wifi setup on the 70D. In my case the cam has 192.168.1.2 so i set the Z30 to 192.168.1.3.
Here are my ip settings on the Z30 side (translated from german, so the terms may vary):
receive ip automatically: off
auto ip: off
IP Adress: 192.168.1.3
Netmask: 255.255.255.0
Primary DNS: 127.0.0.1 (btw: other values like 192.168.1.2 do not work)
Standard gateway: 192.168.1.2
ip v6 deaktivated
proxy deactivated
Devices can exchange data (do not know the correct english text. It is the last setting): enabled
After having set up this, i can connect to the cam and view pictures and remote control it. :-)
Have fun,
c est pas la connexion qui ne fonctionne pas, le Z10 se connecte bien en WIFI avec le 70D mais c est apres, l appareil n est pas visible :(
Message édité par major_nikita le 16-06-2015 à 14:54:27
n°5535253
major_niki​ta
Posté le 20-06-2015 à 19:20:57  profilanswer
une petite photo avec le 70D et le 50 1.8
http://hpics.li/5bfc012
je trouve que ca pique pas mal
n°5535284
Posté le 20-06-2015 à 20:44:27  answer
Pas vraiment en pleine réso ta photo, donc difficile de juger ...
n°5535342
db__
spécialiste de l'à peu près
Posté le 21-06-2015 à 00:27:06  profilanswer
avec un peu de piment de Cayenne, ça piquera comme il faut [:huit]
je suis né fatigué et fait pour me reposer
n°5535344
neyney
Do Want
Posté le 21-06-2015 à 00:30:53  profilanswer
[:albounet]
n°5535402
major_niki​ta
Posté le 21-06-2015 à 11:11:30  profilanswer
pleine réso
http://hpics.li/f8eb00f
soyez pas trop dur..
n°5535409
Posté le 21-06-2015 à 11:29:27  answer
L’œil n'est pas net :o  :whistle:  ;)
Je rigole hein, ce genre de bestiole ça tient la pause pendant une milliseconde tout au plus ;)
Plus ça va, plus j'aime bien le rendu de ce 50 STM :)
Message édité par Profil supprimé le 21-06-2015 à 11:29:54
n°5535512
major_niki​ta
Posté le 21-06-2015 à 19:24:14  profilanswer
model 1 le 50
http://www.kenrockwell.com/canon/lenses/images/50mm-f18-ef/D3S_0280-1200.jpg
Message édité par major_nikita le 21-06-2015 à 19:25:09
n°5535513
major_niki​ta
Posté le 21-06-2015 à 19:26:27  profilanswer
Et sinon, comment on peux piloter le flash extern, genre mon 430 speedelite ?
quand je le met en mode flash externe , il trouve pas le flash, c'est normal ?
Je met bien le 430 en mode slave , mais rien ne se passe :(
n°5535523
Panini
Posté le 21-06-2015 à 19:58:15  profilanswer
C'est assez tordu, lis bien les deux docs (flash et appareil).
L'appareil et le flash sont sur le même canal ?
flickr
n°5535525
major_niki​ta
Posté le 21-06-2015 à 20:04:41  profilanswer
salut
c'est bon j ai récupéré la DOC complète sur le site canon
et effectivement le réglage est très simple.
Pourriez vous m'éclairer (façon de parler) , je vais bientôt assister a un gala de gymnastique et il sera en partir dans le noir... avec projecteur sur les gymnaste. j aurais voulu avoir votre avis :
Sachant que j ai un seul flash speed elite 430 , que je serais a environ 10m des gymnaste, que j ai le 70D, dois je m en servir en flash déporter ? comme ca j aurais plus de puissance ?
ou alors je le met directe sur l appareil ?
sachant que j aimerais utiliser le 70-200 f4L (au lieu du 50 1.8)
Merci de vos avis
Edit : et qu elle réglage ? 70-200 f4 L a iso 800 ca pourrais le faire pour avoir un beau résultat (je viens du 350d pour rappel et au dela de iso 800 c'étais de la boulli en plus du flou de bougé)
Message édité par major_nikita le 21-06-2015 à 20:07:19
n°5535653
Guigui
Posté le 22-06-2015 à 09:50:30  profilanswer
major_nikita a écrit :
salut
Merci de vos avis
Tu veux faire quoi avec ton flash ?
Si c'est pour faire monter le fond en éclairage indirect, dans un grand gymnase c'est mort, surtout si tes sujets principaux sont éclairés au spot :/
Si c'est pour figer tes sujets principaux, ils sont déjà éclairés au spot donc ton flash servira surtout à gommer un peu les ombres dures dues au spot : il faut alors te placer avec le spot venant de droite ou de gauche (pas dans ton dos quoi) et mettre ton flash sur le boitier en éclairage direct. Si tu laisse faire l'expo auto il risque de ne pas délivrer un gros éclair considérant que le spot éclaire suffisamment ton sujet, il faudra donc le forcer un peu.
n°5535727
Posté le 22-06-2015 à 10:53:45  answer
Ah oui ?!
Bah il est bien aussi au final :)
n°5535941
neyney
Do Want
Posté le 22-06-2015 à 14:22:53  profilanswer
hmmm ... ça serait bien de redimensionner l'image :o
n°5536023
major_niki​ta
Posté le 22-06-2015 à 17:37:48  profilanswer
ben , ratio 1:1  :D
n°5536029
Posté le 22-06-2015 à 17:54:24  answer
NAN :o
Estampillé Le Grand Ken devant d'Éternel alors spa possib' !
 :whistle:
n°5536175
kiyoshi77
Posté le 23-06-2015 à 07:35:10  profilanswer
Yop !
Petite question : je compte peut-être acheter le 70D en Allemagne.
Ça se passe comme pour la garantie dans ce cas avec Canon France ? (Pas de marche gris)
Si vous avez la réponse, merci !
n°5538592
major_niki​ta
Posté le 26-06-2015 à 09:02:24  profilanswer
bonjour , je reviens vers vous concernant mes photo de gym, j ai fais un test hier avec un peu de lumiere.
au 70-200F4 L j ai sortie de bon truc @ 1/500 en surexposant a +3L .
a la retouche RAW ca me semble bien.
je seul truc , il est clair c est le manque de vitesse , quand les gym enchaine les flip et saltot. meme en Iservo ca floute pas mal , et en plus j avais mis selecteur central uniquement donc si je rate la fille c est flou ...
donc mon dilemme ce soir, c est 20-200F4L ou 50 1.8. je ne crois pas que le 50 sois vraiment fais pour du sport, et de plus , je serais au centre de la salle (40m) donc je pense que le 50 sera un poil court pour certaine scene.
donc voila qu en penser vous 50 ou 70-200 sachant que je vais shooter en RAW, et je pris pour que la batterie tienne 1000 cliché sans faire jouejoue avec l ecran en RAW S.
merci de vos avis.
n°5538907
DoV
Posté le 26-06-2015 à 14:45:01  profilanswer
J'arrive a passé les 800 photos avec la batterie et elle a 18 mois. 1000 ca risque d’être tendu surtout si tu fais de la rafale.
Tu as shooté a quelle sensibilité ?
n°5538988
6uigu1
Posté le 26-06-2015 à 15:16:21  profilanswer
Vu la place que prend un 50 1.8, je le mettrai dans la poche au cas ou :d
Sinon, si tes opinions politiques ou religieuses t'interdisent d'emmener 2 objos, prends le 70-200 et monte les iso au max, du bruit est plus rattrapable que du flou, et 50mm me parait trop court en effet :o
Message édité par 6uigu1 le 26-06-2015 à 15:19:49
Arnaques, Cuicui et Botanique / flickr
n°5538990
6uigu1
Posté le 26-06-2015 à 15:17:31  profilanswer
Sinon je vois pas bien le rapport avec la batterie, mais tu peux deja couper l'affichage des photos sur le lcd apres la prise de vue, pour economiser un peu de batterie ;)
n°5539035
major_niki​ta
Posté le 26-06-2015 à 16:06:07  profilanswer
Je vais rafal en RAWs et je vais shooter a MAX 1600 je pense
j espere etre >1/500
il y aura 2*1500W projecteur (halo) qui suivrons l athlète
Pour la batterie... quand y aura plus de batterie je passerais sur le 350d pour finir au 50mm
n°5539036
major_niki​ta
Posté le 26-06-2015 à 16:07:24  profilanswer
au Max , c est quoi selon toi le MAX acceptable
n°5539042
6uigu1
Posté le 26-06-2015 à 16:22:21  profilanswer
Sur 7d, j'essaie de rester sous les 1600 iso, donc je dirais 3200 sur 70d
Bon le resultat est moyen, mais la photo est regardable, plus qu'une photo floue en tout cas :d
n°5539047
major_niki​ta
Posté le 26-06-2015 à 16:27:02  profilanswer
tu es entrain de me dire que le 70D a une meilleur gestion du bruit que le 7D mark ?
n°5539074
DoV
Posté le 26-06-2015 à 16:47:26  profilanswer
A 3200 sans crop trop fort ça passe largement ! Faut voir ce que tu en fais après, sur un tirage 10x15 tu vois rien (sauf de très prés)
Après, le bruit est quand même visible mais pas choquant sur des tirages de tailles plus importantes.
Faut voir ta sensibilité perso au bruit !
Message édité par DoV le 26-06-2015 à 16:58:07
n°5539090
6uigu1
Posté le 26-06-2015 à 16:59:26  profilanswer
Que le 7d1 oui evidemment, pas 1 stop mais pas loin il me semble :)
n°5539097
major_niki​ta
Posté le 26-06-2015 à 17:10:27  profilanswer
ca sera du 10*15 max, voir si ca se trouve que du format numérique
donc si vraiment j ai du mal je peux essayer le 3200 donc  :jap:
n°5539109
major_niki​ta
Posté le 26-06-2015 à 17:37:26  profilanswer
et derniere chose tres importante au niveau du calcul de l exposition de la scene (lumiere projecteur sur la gymnaste) il faut mieux se mettre en mode spot ? ou normal ?
car si je met normal, il va assombrir l ensemble vu qu autour de la personne il fera noir ?
n°5539110
Poogz
Posté le 26-06-2015 à 17:39:01  profilanswer
Si tu te mets en spot sur la partie éclairée, l’environnement sera encore plus sombre.
n°5539124
6uigu1
Posté le 26-06-2015 à 18:17:44  profilanswer
Pour un gymnase, amha tu te mets en mode M, tu tatonnes sur les 3 premieres photos puis t'y touches plus :o
n°5539130
major_niki​ta
Posté le 26-06-2015 à 18:33:07  profilanswer
Et alors, ça peux faire bien non ?
n°5539132
major_niki​ta
Posté le 26-06-2015 à 18:35:51  profilanswer
Oula, je ne suis pas aussi confirmer pour être en mode M.
Je vais me mettre en Av à F4 Iso 1600
Et je vais le laisser gère la vitesse
Ou alors je met 1/500 et il se debrouille.
Merci de vos conseil
n°5539133
Poogz
Posté le 26-06-2015 à 18:44:13  profilanswer
Oui ça peut le faire mais vu que tu parlais d'assombrissement de l'ensemble :d
La méthode de 6uigu1 est aussi bonne, l'éclairage devrait rester constant.
n°5539203
major_niki​ta
Posté le 26-06-2015 à 23:50:33  profilanswer
Bonsoir
alors, et ben.... le 70d il est vraiment bon au niveau AF deja , difficile de faire mieux je pense, il est rarement pris au dépourvu, il capture chaque mouvement a une vitesse incroyable. Donc l eclairage etais tres tres difficile , genre un projo de 1200W qui eclaire un rond autour du gymnaste...
enfin a 1ere vu ca a l air pas trop mal
j ai plus qu a trier les 2000 cliché (d ailleur la batterie etais a peine a 75%) et voir ce que je peux récup en post traitement
n°5539205
neyney
Do Want
Posté le 27-06-2015 à 00:09:32  profilanswer
difficile de faire mieux niveau AF ? si si ... c'est possible :D
n°5539230
major_niki​ta
Posté le 27-06-2015 à 09:01:00  profilanswer
Et donc , la bonne nouvelle, c est l autonomie de la batterie !!! 3000 photo avec desfois un acces a l écran lcd pour visualiser et 75% de perdu....
j aurais besoin de savoir quel logiciel vous utilié pour traiter 3000 Raw d un seul coup et de bonne maniere. J utilise en ce moment le logiciel canon en automatique, mais j ai droit a 1 an d adobe cloud truc machin, car c'étais dans le pack de l appareil 70d.
merci et bon week end
n°5539237
dimidimi
Posté le 27-06-2015 à 09:11:15  profilanswer
traiter 3000 photo d'un seul coup ??? chaque photos est differnte ...
n°5539239
major_niki​ta
Posté le 27-06-2015 à 09:13:06  profilanswer
pas tres différente en faite, vu que c'est en rafal, il y a des serie de 10-15 photo avec la même exposition lumineuse, enfin bref ca fais des lot de  photo a me palucher
Message édité par major_nikita le 27-06-2015 à 09:14:10
n°5539243
dimidimi
Posté le 27-06-2015 à 09:21:00  profilanswer
en faite je ne vois aps l'interet de les traiter toute, autant selectionner celle qui vaillent le coup et traiter celle ci
Canon 1D mark II : fichier RAW 800/1600 isoObjectifs canon 5D mark III
Quelle différence entre flash canon 580 ex et 580 ex II ?Avis entre objectifs canon 55-250 IS II et 70-300 USM
Carte mémoire de mon CANON EOS 1000D protégée en écriture[Topic Unique] Canon 180mm f/3.5 L USM Macro
Plus de sujets relatifs à : [Topic unique] Canon EOS 70D: Dual Pixel AF
