3875 connectés
 Page :   1  2  3  4  5  ..  24  25  26  27  28  29  30  31
Topic officiel ...................... ECCP-109 .....................
n°402846
NecOne
Posté le 11-02-2002 à 12:44:25  profilanswer
SirThomasLipton a écrit a écrit :
Fais attention, je ne vais pas tarder à m'amener :D
6  NecOne  31963  1062  0
Tiens alors j'en rebalance 1000 histoire de reprendre de l'avance
 :p  :p  :p  :p
n°402883
_lapin_
fallen for you
Posté le 11-02-2002 à 13:03:11  profilanswer
bon bhen moi il a rien balancé du tout  :(
si quelqu'un peut m'aider voilà mon ini:
# ECCP109 WINDOWS SERVICE INI FILE
# Replace 'user_ID' below a with a character string identifying you
# so we know who returned what distinguished points.  If you do not
# want credit for the points you generate (including prize money if
# one of your points solved the challenge) we still need something
# here. In this case just enter 'anonymous' for both this and the 2
# following fields.
HANDLE=[HFR]_lapin_
# If you do want credit replace 'email_address' with a valid email
# that we can use to contact you if one of your points is a winner.
EMAIL=lapin_terrier@hotmail.com
# Replace 'real_name' below with your real name - neither this name
# nor your email address will be published.
NAME=joel
# Uncomment one of the following two lines (i.e. remove the leading '#';)
# to set where logging information will be placed. The EVENT_LOG option
# is only available on Windows NT/2000 but the file option can be used
# on any system. In the latter case you can choose the name of the file
# used by setting your own choice of name after FILE: below (no spaces)
# Note that errors that occur before this INI file line is processed
# will not appear in the designated log file.
LOGGING=EVENT_LOG
LOGGING=FILE:event.log
# Replace 'number' below with a number between 0 and 15 that is the sum
# of 1, 2, 4 or 8 in any combination to indicate the level of detail to
# be used in the event log or log file.  Basic events such as service
# installation, removal, starts and stops are always logged. In addition,
# if the number below includes 1 (i.e. it is odd), then distinguised points
# found will be logged, while including a 2 value will log points sent to
# the server. If the number includes a 4 value, regular status reports will
# be logged (at intervals set below), while including a value of 8 will log
# thread starts and stops on each processor.
LOG_LEVEL=8
# Replace hours, minutes and seconds below with numbers so that the string
# gives the time interval between status entries in the event log or log
# file.
#LOG_INTERVAL=0:01:0
# You can set the priority with which the service runs as either high (H)
# normal (N) or low (L).  Within each of these levels you can also adjust
# the priority up or down by one or two points by appending either 1 or 2
# '+'(up) or '-'(down) signs. The default set below is Low (L), which uses
# only idle cycles on your machine. Moreover this priority is lowered by
# two points to avoid interfering with other processes that might also use
# idle cycles. You can change the priority by replacing the L-- below with
# another setting but you are very STRONGLY advised NOT to set either high
# priority (H) or normal priorities above N. The priorities used should
# hence be restricted to L--, L-, L, L+, L++, N--, N- and N.
PRIORITY=L--
# Uncomment the follwoing line (i.e. remove the leading '#';) if you have a
# permanent connection to the Internet and you are happy for it to be used
# to send distinguished points to the server.
CONNECTION=PERMANENT
#gives the interval between attempts to send points to the server.  When an
#attempt is made to send points to the server several tries will be made
#but if these all fail, no further attempts will be made until the interval
#set here has elapsed.
SEND_INTERVAL=1:00:0
# If you're running in http mode and your machine is behind a firewall
# delete the initial '#' from the line below and replace MYPROXY:3128
# with the host name and port number of your HTTP proxy.
#PROXY=MYPROXY:3128
# If the address of the point collection host needs to be changed for any
# reason the following two lines will be added to this file to achieve this.
# At present the examples below show the current default values that are
# built into the software so these lines do not need to be enabled and will
# only be added if the host changes.  The code now contains a facility to
# update these lines automtically with an http message if the host has to be
# is moved in future so there should be no need to use this feature manually.
#DP_SERVER_HOST=erdos3.math.nd.edu
#DP_SERVER_URL=http://erdos3.math.nd.edu/cgi-bin/getres.cgi
#End of INI file description
et me dire ce qui cloche
n°402885
_lapin_
fallen for you
Posté le 11-02-2002 à 13:04:41  profilanswer
event log:
Attempt to send 1 distinguished point to server failed at Mon Feb 11 11:49:27 2002.
Attempt to send 1 distinguished point to server failed at Mon Feb 11 12:02:15 2002.
Attempt to send 1 distinguished point to server failed at Mon Feb 11 12:15:01 2002.
Attempt to send 1 distinguished point to server failed at Mon Feb 11 12:27:48 2002.
Attempt to send 1 distinguished point to server failed at Mon Feb 11 12:40:34 2002.
Attempt to send 1 distinguished point to server failed at Mon Feb 11 12:53:20 2002.
Attempt to send 1 distinguished point to server failed at Mon Feb 11 13:06:06 2002.
n°402887
_lapin_
fallen for you
Posté le 11-02-2002 à 13:05:39  profilanswer
dplist:
 Couldn't connect to host erdos3.math.nd.edu!
  No such file or directory
Successfully sent points flushed from dplist
Warning: only 0 of 1 points transmitted.
 :cry:
n°402892
sirthomasl​ipton
Posté le 11-02-2002 à 13:07:32  profilanswer
LOGGING=EVENT_LOG
-> A mon avis, tu dois en choisir un des deux mais pas les deux
-> et il faut que tu actives ça
Mais je ne vois pas le rapport avec le fait que ça n'envoie rien :(
Tu n'es pas derrière un proxy?
Edit le fichier dplist (pas dplist.log) et tu verras bien si tu as des dps en attente.
Stockholm -- guides privés -- vélotaf à Stockholm
n°402894
sirthomasl​ipton
Posté le 11-02-2002 à 13:08:18  profilanswer
tu dois être derrière un proxy, c'est pas possible autrement!
n°402896
sirthomasl​ipton
Posté le 11-02-2002 à 13:10:05  profilanswer
Pour LOG_INTERVAL=0:01:0, perso j'ai mis 12:00:00 pour l'intervalle, je pense que c'est amplement suffisant :D (une fois que tu auras résolu tes pbs de connection).
n°402910
_lapin_
fallen for you
Posté le 11-02-2002 à 13:22:10  profilanswer
ouaip j'ai mis 1mn pour voir ce qui ce passe
mon dplog c'est ca: si t'y comprends quelque chose  :crazy:
I0X17510c091692ee5149abffffbfffP15a22e883dddcb5c5e
7e34afd28cQ10f677a80c85858c487a9f7ff217VwSV130ID[H
FR]_lapin_,lapin_terrier@hotmail.com,joel
n°402964
Posté le 11-02-2002 à 14:08:46  answer
LOGGING=EVENT_LOG
il faut enlever le # pour l'activer !
n°403017
_lapin_
fallen for you
Posté le 11-02-2002 à 15:18:54  profilanswer
c'est donc rappé pour moi, à moins d'envoyer les points manuelement en important le fichier (dplist ?)
n°403085
NecOne
Posté le 11-02-2002 à 17:10:35  profilanswer
C'est une solution !!!!
n°403143
sirthomasl​ipton
Posté le 11-02-2002 à 17:45:57  profilanswer
Ben non, il suffit de mettre le proxy dans ton fichier ini! Si tu ne connais pas les paramètres de ton proxy, regarde dans les Outils/Options Internet/Connexion/LAN de ton internet explorer.
n°403191
Posté le 11-02-2002 à 18:09:16  answer
Alors les 72pc de l'IUT se sentent mieux ? :D
n°403470
sirthomasl​ipton
Posté le 11-02-2002 à 20:56:31  profilanswer
Alors tu t'en sors mon canard? Euh nan lapin :D
n°403629
_lapin_
fallen for you
Posté le 11-02-2002 à 22:43:17  profilanswer
bhen là chuis chez moi pas au boulot :d
c'est pas le proxy qui va m'embeter, c'est le firewall
(je me suis telecharger un scanner, faut que je scanne le proxy pour les ports ouverts ? j'en prend un au hasard ?)
lafraise.com éditeur de bien jolis T-shirt
n°403630
sirthomasl​ipton
Posté le 11-02-2002 à 22:45:37  profilanswer
Celui que tu préféres :D
De préférence, un avec 69 dedans  :love:  :lol:
n°403872
sirthomasl​ipton
Posté le 12-02-2002 à 10:13:37  profilanswer
Alors tu trouves une solution?
n°403987
sirthomasl​ipton
Posté le 12-02-2002 à 13:12:37  profilanswer
Up pour la forme :D
N'oubliez pas: www.frenchx.fr.st
n°404270
_lapin_
fallen for you
Posté le 12-02-2002 à 17:53:16  profilanswer
bhen non, c'est pour le up !!
n°404296
NecOne
Posté le 12-02-2002 à 18:31:09  profilanswer
6  NecOne  32094  44  0
Piti Up déguisé  :hello:
n°404498
saudium
Posté le 12-02-2002 à 20:43:49  profilanswer
mardi gras ? ;)
root 66
n°404516
sirthomasl​ipton
Posté le 12-02-2002 à 20:49:44  profilanswer
Oulala, tu pétes le feu ce soir mon Na  :ouch: :D
n°404518
saudium
Posté le 12-02-2002 à 20:50:09  profilanswer
Cl ? :D
root 66
n°404523
sirthomasl​ipton
Posté le 12-02-2002 à 20:52:16  profilanswer
Par contre, tu ne fréquentes pas beaucoup le board? Je me trompe?
n°404539
saudium
Posté le 12-02-2002 à 20:57:09  profilanswer
si tu regardes la liste des membres et que tu les tries par nombre de posts, peut etre va tu cesser de me harceler avec  ça ? :D
[jfdsdjhfuetppo]--Message édité par saudium--[/jfdsdjhfuetppo]
root 66
n°404547
saudium
Posté le 12-02-2002 à 20:58:40  profilanswer
toi moi solstiz bmo et totow sommes les plus gros posteurs (je suis me 3eme :sol: )  mais c'est plutot du coté des autres qu'il faudrait sonner les cloches :??:
root 66
n°404559
sirthomasl​ipton
Posté le 12-02-2002 à 21:01:21  profilanswer
Ouai je sais bien :D
Je vais essayer de faire une mailing régulièrement avec les progressions... comme ça personne n'oubliera le board ;)
n°405119
sirthomasl​ipton
Posté le 13-02-2002 à 12:33:04  profilanswer
Que fait ce topic en 3ième page? Vous pouvez me le dire?
n°405200
sirthomasl​ipton
Posté le 13-02-2002 à 14:31:32  profilanswer
ECCp-109 est un programme de calcul partagé qui a pour objectif la résolution du challenge CERTICOM ECCp-109. Le but de ce challenge est de résoudre une équation particulière d'une fonction elliptique.
Soit la courbe C de la forme: y^2 = x^3 +ax +b
Nous disposons: de constantes a et b et de nombres premiers p.
Un point de la courbe est alors un couple d'entier (u,v) vérifiant l''équation %p (modulo p). Ce qui signifie plus simplement que p divise v^2-u^3-au-b. Nous savons également qu'il existe une méthode qui consiste à "additionner" deux points de la courbe afin d'en obtenir un troisième. Nous appelons ça une addition mais ce n'est pas une addtion comme nous l'entendons habituellement. Nous supposerons cette méthode vraie et admettrons qu'elle permet d'obtenir un troisième point sur la courbe à partir de deux autres points.
Voici en quoi consiste le challenge ECCp-109: CERTICOM a choisi un point P sur la courbe et un entier très grand k. Ils ont alors calculé le point Q := kP (c'est à dire qu'ils ont additionné le point P k fois à lui-même). Ce point Q se calcule assez rapidement lorsque qu'on utilise l'opération log(k); CERTICOM a donc pu choisir l'entier k extremment grand.
Maintenant que nous connaissons P et Q, nous devons retrouver cet entier k. Mais k est vraiment trop grand pour qu'on puisse le chercher par une simple méthode itérative (k=1, k=2, k=3, ...); nous devons trouver une méthode plus efficace donc plus rapide.
Voici les paramètres exacts du challenge ECCp-109:
p =564538252084441556247016902735257
y^2 = x^3 +321094768129147601892514872825668x +430782315140218274262276694323197
P = (97339010987059066523156133908935, 149670372846169285760682371978898)
Q = (44646769697405861057630861884284, 522968098895785888047540374779097)
Mais quel est le rapport avec la cryptographie? Un des principaux problèmes de la cryptographie est la sécurisation des communications sur un réseau vulnérable.
Prenons un exemple:
Vous êtes sur le point de faire un achat sur internet, sur le site marchand d'une société X. Pour cela, vous devez leur communiquer votre numéro de carte bleue. Mais internet est un réseau très peu sécurisé et des "pirates" peuvent assez aisemment intercepter la communication entre vous et X. Appelons un de ces pirates "Neo".
Comment pouvez-vous alors transmettre le numéro de votre carte bleue à X sans que Néo l'intercepte? Vous pouvez bien évidemment vous mettre d'accord avec X sur un cryptage de votre numéro mais dans ce cas, Néo a aussi connaissance de la manière dont votre numéro sera crypté, il peut donc le décrypter de son côté.
C'est là qu'intervient ce challenge: vous et X devaient vous mettre d'accord sur des informations "secrètes" auquelles même Néo n'aura pas accès. Les courbes elliptiques sont une manière de résoudre ce problème.
Voici donc le principe de fonctionnement du projet:
Vous et X convenez d'une courbe elliptique quelconque et d'un point P sur cette courbe. De son côté, X choisit un entier s et calcule le point A := sP (c'est à dire P ajouté s fois à lui-même). X vous communique alors ce point A mais pas l'entier s.
Vous faîtes de même de votre côté; vous choisissez un entier t afin d'obtenir le point B := tP. Vous donnez alors ce point B à X mais pas votre entier t.
Maintenant que vous connaissez le point A (celui que X vous a envoyé), vous calculez le point Z := tA (vous êtes la seule personne à connaître t). X procéde de la même manière avec le point B que vous lui avez envoyé et calcule Z := sB (s n'est connu que de X). L'utilisation de "Z" pour les deux points n'est pas un hasard puisque le point que vous avez obtenu et celui que X a obtenu sont les mêmes.
Z = tA = t(sP) = (ts)P = (st)P = s(t)P = sB
Ainsi, vous avez certaines informations qui restent "secrètes" et que Néo ne peut pas obtenir en "analysant" la communication. Cette explication n'est qu'une déscription grossière de cette méthode de cryptage mais vous pouvez facilement imaginer la "puissance" de ce schéma de cryptage.
Expliquons alors pourquoi Néo n'a pas connaissance de tous les paramètres.
Que peut voir Néo lors de la commnunication?
Juste les points que vous echangez avec X (A et B). Mais il n'a jamais connaissance de s et de t. Comment peut-il alors trouver l'information secrète que vous partagez avec X (c'est à dire le point Z)?
Il peut toujours essayer "d'additionner" A et B: A+B = sP + tP = (s+t)P mais il ne trouvera pas le même point que Z = (st)P. Il ne peut alors pas trouver un des entiers s ou t :D Voici donc en quoi consiste exactement notre problème de courbes elliptiques.
Supposons que nous avons P et A; nous devons trouver l'entier s tel que A := sP. Nous avons là le même problème à résoudre que celui proposé par le challenge ECCp-109. CERTICOM cherche à savoir ce que peut actuellement résoudre notre Néo. Pour ECCp-109, nous travaillons avec un nombre p de 109 bits hors plus p augmente, plus le problème est long à résoudre! Pour un p de 131 bits, il nous faudrait 65536 fois plus de puissance de calcul alors que les calculs effectués par vous et par X ne seraient pas beaucoup plus longs!
Ma conclusion personelle: ECCp powaaaaaaaaaa :D
Traduction du site officielle par SirThomasLipton, le 13.02.2002 entre 12h et 14h :D
n°405454
manu512
Moi je dis Prout :D
Posté le 13-02-2002 à 19:15:51  profilanswer
Ma TI92 booster a trouve en 10H !!!!
Je deconne  :lol:  :lol:  :lol:  :pt1cable:
Team [HFR] The Roadrunner Machines & Seti@Donf
n°405501
manu512
Moi je dis Prout :D
Posté le 13-02-2002 à 19:47:40  profilanswer
Heu 230 DP en 24H c bien ou pas ??? (1 seul machine )
G l'impression d'avoir plombé le topic moi  :sarcastic:
[jfdsdjhfuetppo]--Message édité par Manu512--[/jfdsdjhfuetppo]
n°405517
_lapin_
fallen for you
Posté le 13-02-2002 à 20:09:39  profilanswer
bhen... heu... c'est tres bien ouai, t'as quoi comme
machine ?  :eek2:
avec 2 machines, je fais la moitié  :sarcastic:
[jfdsdjhfuetppo]--Message édité par _lapin_--[/jfdsdjhfuetppo]
n°405519
Posté le 13-02-2002 à 20:10:43  answer
ha ben... heu... c'est .. comment dire... TRES bien :D
Pour une seule machine :D
 :bounce:  :bounce:
n°405542
manu512
Moi je dis Prout :D
Posté le 13-02-2002 à 20:38:40  profilanswer
Ben c ds mon profil  :heink:
 :lol:  :lol:  :lol:
XP1500+@1900+ pour le moment car a 2000+ il est trop hot  :cry:
Euh vient de voir un truc c pas 230 DP c 180 DP les 50 restant c mon PII lol
n°405638
sirthomasl​ipton
Posté le 13-02-2002 à 21:41:15  profilanswer
ça reste très correct :D
Tu passes nous voir sur www.frenchx.fr.st ?
n°405666
COULIX
un pc pour les attirer ...
Posté le 14-02-2002 à 01:46:41  profilanswer
mew caledonia 51 ieme =)
bientot 50 ! c dur y a que moi qui bosse.
.... et dans les tenebres les lier
n°405871
sirthomasl​ipton
Posté le 14-02-2002 à 12:51:37  profilanswer
Tu pourrais aider la French X quand même :sarcastic:
n°405932
saudium
Posté le 14-02-2002 à 13:50:16  profilanswer
quand ils commenceront à se casser les dents sur les grosses teams ....
root 66
n°405967
manu512
Moi je dis Prout :D
Posté le 14-02-2002 à 14:16:06  profilanswer
 :heink: Jy suis deja mais vive le cache  :D
n°406429
sirthomasl​ipton
Posté le 14-02-2002 à 20:33:59  profilanswer
Pense quand même à le lâcher un de ces 4 :D
n°406509
Learn
Tigre & Dragon
Posté le 14-02-2002 à 22:14:33  profilanswer
hello,
Pour donner mes points à la Frenchx team ,c'est quoi l'adresse? :D
j'ai pas le courage de cherché :D
L'obscurité ne peut pas chasser l'obscurité ; seule la lumière le peut. La haine ne peut pas chasser la haine ; seul l'amour le peut. Martin Luther King
cherche bios pour k7tpro msi 6330 non-officielNVIDIA DETONATOR 12.41 officiel : comment avoir l'onglet overclocking?
PATCH VIA OFFICIEL ENFIN SORTI
Plus de sujets relatifs à : Topic officiel ...................... ECCP-109 .....................
