2991 connectés
La 15.0 est là (en vrai !)
Les invités peuvent voter
 Page :   1  2  3  4  5  ..  90  91  92  ..  109  110  111  112  113  114
[SLACKWARE] du présent - 15.0
n°1445109
cycojesus
Mèo Lười
Posté le 28-02-2020 à 07:01:05  profilanswer
Fri Feb 28 03:53:37 UTC 2020
ap/hplip-3.20.2-x86_64-1.txz:  Upgraded.
d/meson-0.53.2-x86_64-1.txz:  Upgraded.
d/python3-3.8.2-x86_64-1.txz:  Upgraded.
d/rust-1.41.1-x86_64-1.txz:  Upgraded.
l/libnotify-0.7.9-x86_64-1.txz:  Upgraded.
l/libsoup-2.68.4-x86_64-1.txz:  Upgraded.
n/libqmi-1.24.6-x86_64-1.txz:  Upgraded.
Chết rồi ! ✍ ⌥⌘ http://codeberg.org/gwh
n°1445228
cycojesus
Mèo Lười
Posté le 02-03-2020 à 22:04:29  profilanswer
Mon Mar  2 19:05:10 UTC 2020
a/dialog-1.3_20200228-x86_64-1.txz:  Upgraded.
l/Mako-1.1.2-x86_64-1.txz:  Upgraded.
l/imagemagick-7.0.9_27-x86_64-1.txz:  Upgraded.
l/libcap-2.33-x86_64-1.txz:  Upgraded.
n/bind-9.16.0-x86_64-2.txz:  Rebuilt.
  rc.bind: ensure /var/run/named exists before starting named. Thanks to MarcT.
  rc.bind: when stopping named, only kill processes in the current namespace.
x/libevdev-1.9.0-x86_64-1.txz:  Upgraded.
x/wayland-protocols-1.20-noarch-1.txz:  Upgraded.
xap/seamonkey-2.53.1-x86_64-1.txz:  Upgraded.
  This update contains security fixes and improvements.
  For more information, see:
    https://www.seamonkey-project.org/releases/seamonkey2.53.1
  (* Security fix *)
testing/packages/PAM/libcap-2.33-x86_64-1_pam.txz:  Upgraded.
Sat Feb 29 19:20:21 UTC 2020
a/kernel-generic-5.4.23-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.4.23-x86_64-1.txz:  Upgraded.
  DM_BUFIO y -> m
  DM_SNAPSHOT y -> m
a/kernel-modules-5.4.23-x86_64-1.txz:  Upgraded.
a/logrotate-3.16.0-x86_64-1.txz:  Upgraded.
ap/cups-filters-1.27.2-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.4.23-x86-1.txz:  Upgraded.
k/kernel-source-5.4.23-noarch-1.txz:  Upgraded.
isolinux/initrd.img:  Rebuilt.
kernels/*:  Upgraded.
testing/packages/PAM/hplip-3.20.2-x86_64-1_pam.txz:  Upgraded.
usb-and-pxe-installers/usbboot.img:  Rebuilt.
n°1445247
cycojesus
Mèo Lười
Posté le 04-03-2020 à 07:23:01  profilanswer
Wed Mar  4 01:39:54 UTC 2020
xap/seamonkey-2.53.1-x86_64-2.txz:  Rebuilt.
  Fixed $LIBDIRSUFFIX for 32-bit. Thanks to ljb643.
Tue Mar  3 22:39:20 UTC 2020
a/hwdata-0.333-noarch-1.txz:  Upgraded.
a/kernel-firmware-20200302_0148cfe-noarch-1.txz:  Upgraded.
ap/ddrescue-1.25-x86_64-1.txz:  Upgraded.
d/perl-5.30.1-x86_64-2.txz:  Rebuilt.
  Added Parse-Yapp-1.21, needed to build the parser for the Samba compile.
d/vala-0.48.0-x86_64-1.txz:  Upgraded.
l/at-spi2-atk-2.34.2-x86_64-1.txz:  Upgraded.
l/fribidi-1.0.9-x86_64-1.txz:  Upgraded.
l/sg3_utils-1.45-x86_64-1.txz:  Upgraded.
n/samba-4.12.0-x86_64-1.txz:  Upgraded.
testing/packages/PAM/samba-4.12.0-x86_64-1_pam.txz:  Upgraded.
n°1445280
cycojesus
Mèo Lười
Posté le 05-03-2020 à 06:45:44  profilanswer
Wed Mar  4 22:03:30 UTC 2020
a/sdparm-1.10-x86_64-3.txz:  Rebuilt.
  Recompiled against sg3_utils-1.45.
a/udisks-1.0.5-x86_64-5.txz:  Rebuilt.
d/cmake-3.16.5-x86_64-1.txz:  Upgraded.
l/libgpod-0.8.3-x86_64-6.txz:  Rebuilt.
n/curl-7.69.0-x86_64-1.txz:  Upgraded.
n/cyrus-sasl-2.1.27-x86_64-3.txz:  Rebuilt.
  Added SQL support via MariaDB. Thanks to niksoggia.
n/ntp-4.2.8p14-x86_64-1.txz:  Upgraded.
n/ppp-2.4.8-x86_64-1.txz:  Upgraded.
  This update fixes a security issue:
  By sending an unsolicited EAP packet to a vulnerable ppp client or server,
  an unauthenticated remote attacker could cause memory corruption in the
  pppd process, which may allow for arbitrary code execution.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-8597
  (* Security fix *)
testing/packages/PAM/cyrus-sasl-2.1.27-x86_64-3_pam.txz:  Rebuilt.
testing/packages/PAM/ppp-2.4.8-x86_64-1_pam.txz:  Upgraded.
  (* Security fix *)
n°1445300
regdub
Posté le 05-03-2020 à 22:39:43  profilanswer
rp-pppoe a besoin d'être rebuildé avec le nouveau ppp (reported).
Legalize it @HFR
n°1445302
cycojesus
Mèo Lười
Posté le 06-03-2020 à 08:23:47  profilanswer
Fri Mar  6 02:45:42 UTC 2020
a/coreutils-8.32-x86_64-1.txz:  Upgraded.
a/kernel-generic-5.4.24-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.4.24-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.4.24-x86_64-1.txz:  Upgraded.
a/kmod-27-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.4.24-x86-1.txz:  Upgraded.
d/mercurial-5.3.1-x86_64-1.txz:  Upgraded.
k/kernel-source-5.4.24-noarch-1.txz:  Upgraded.
  -HEADER_TEST n
l/python-packaging-20.3-x86_64-1.txz:  Upgraded.
l/vte-0.60.0-x86_64-1.txz:  Upgraded.
x/mesa-20.0.1-x86_64-1.txz:  Upgraded.
n°1445316
regdub
Posté le 06-03-2020 à 19:02:33  profilanswer
regdub a écrit :
Je suis tombé sur un petit bug avec "find ... -ls" : les caractères accentués ne sont pas "compris" (genre "\303\251" ) mais sans le "-ls", ça s'affiche bien.
Ca vous dit quelque chose ?
Arf, j'avais jamais fait gaffe à ça, mais comme quelqu'un me l'a signalé sur LQ, c'est le comportement attendu décrit dans le man.
Legalize it @HFR
n°1445323
Posté le 07-03-2020 à 00:00:37  answer
Toujours pas de systemd chez Patrick ?
Il va mieux financièrement ?
n°1445324
regdub
Posté le 07-03-2020 à 00:49:43  profilanswer
Financièrement, oui, il me semble que j'ai vu passer un message dans ce sens et son patreon est probablement plus rentable que son ancienne boutique de cd/dvd Slackware avant que son fournisseur ne l'arnaque.
https://www.patreon.com/slackwarelinux
Pour systemd, non, pas tant que ce n'est pas incontournable et que l'init actuel fait partie des trucs appréciés par les utilisateurs, ce qui est toujours le cas, je pense.
Message édité par regdub le 07-03-2020 à 00:53:38
Legalize it @HFR
n°1445328
cycojesus
Mèo Lười
Posté le 07-03-2020 à 08:41:49  profilanswer
Je paraphrase, Pat a dit que si c'est comme PAM on auras systemd dans 23 ans...
Fri Mar  6 22:10:25 UTC 2020
a/cryptsetup-2.3.0-x86_64-2.txz:  Rebuilt.
  Include some additional documentation. Thanks to regdub.
a/sdparm-1.11-x86_64-1.txz:  Upgraded.
ap/moc-2.5.2-x86_64-6.txz:  Rebuilt.
  Fixed docs permissions. Thanks to regdub.
l/glib-networking-2.64.0-x86_64-1.txz:  Upgraded.
l/glib2-2.64.0-x86_64-1.txz:  Upgraded.
l/gvfs-1.44.0-x86_64-1.txz:  Upgraded.
l/libnl-1.1.4-x86_64-3.txz:  Rebuilt.
l/tdb-1.4.3-x86_64-3.txz:  Rebuilt.
l/tevent-0.10.2-x86_64-3.txz:  Rebuilt.
n/bind-9.16.0-x86_64-3.txz:  Rebuilt.
  Applied upstream patch to fix a discrepancy in the quota code that can
  result in a situation where the count is not properly decremented in
  some cases.
n/dovecot-2.3.10-x86_64-1.txz:  Upgraded.
n/rp-pppoe-3.13-x86_64-2.txz:  Rebuilt.
  This needed a rebuild for ppp-2.4.8. Thanks to regdub.
x/libinput-1.15.3-x86_64-1.txz:  Upgraded.
testing/packages/PAM/dovecot-2.3.10-x86_64-1_pam.txz:  Upgraded.
n°1445336
regdub
Posté le 07-03-2020 à 20:37:57  profilanswer
cycojesus a écrit :
... Thanks to regdub.
 [:docteur g:3]
Legalize it @HFR
n°1445340
cycojesus
Mèo Lười
Posté le 08-03-2020 à 08:51:57  profilanswer
 :sol:
Sat Mar  7 20:25:36 UTC 2020
l/gobject-introspection-1.64.0-x86_64-1.txz:  Upgraded.
l/imagemagick-7.0.10_0-x86_64-1.txz:  Upgraded.
l/libical-3.0.8-x86_64-1.txz:  Upgraded.
l/librsvg-2.48.0-x86_64-1.txz:  Upgraded.
l/libsoup-2.70.0-x86_64-1.txz:  Upgraded.
l/mozilla-nss-3.51-x86_64-1.txz:  Upgraded.
xap/libnma-1.8.28-x86_64-1.txz:  Added.
  This is the NetworkManager GUI client library, which was previously
  provided by network-manager-applet. It's now a standalone project, and
  is required by network-manager-applet and other NetworkManager frontends.
xap/network-manager-applet-1.16.0-x86_64-1.txz:  Upgraded.
  This requires the new libnma package.
n°1445359
cycojesus
Mèo Lười
Posté le 08-03-2020 à 22:02:47  profilanswer
Sun Mar  8 19:42:26 UTC 2020
d/bison-3.5.3-x86_64-1.txz:  Upgraded.
d/python-setuptools-45.3.0-x86_64-1.txz:  Upgraded.
l/adwaita-icon-theme-3.36.0-noarch-1.txz:  Upgraded.
l/at-spi2-core-2.36.0-x86_64-1.txz:  Upgraded.
l/pygobject3-3.36.0-x86_64-1.txz:  Upgraded.
l/python-pygments-2.6.1-x86_64-1.txz:  Upgraded.
n°1445429
cycojesus
Mèo Lười
Posté le 11-03-2020 à 07:08:35  profilanswer
Tue Mar 10 19:53:39 UTC 2020
d/guile-3.0.1-x86_64-1.txz:  Upgraded.
l/SDL2-2.0.10-x86_64-2.txz:  Rebuilt.
  Rebuilt to pick up wayland support. Thanks to franzen.
l/dconf-0.36.0-x86_64-1.txz:  Upgraded.
l/dconf-editor-3.36.0-x86_64-1.txz:  Upgraded.
l/gsettings-desktop-schemas-3.36.0-x86_64-1.txz:  Upgraded.
l/python-pygments-2.5.2-x86_64-1.txz:  Upgraded.
  It seems like the pragmatic thing to do here is to revert this one to fix
  the python2 programs and modules that depend on it. We'll have to do a bit
  more research to determine what the best course of action is regarding
  python2 in general, though. Certainly we shouldn't be requiring python2
  for anything important moving forward, but even that will take some work.
  Plasma 5 as currently built has multiple dependencies on python2, for
  example.
n/bind-9.16.0-x86_64-4.txz:  Rebuilt.
  Drop python2 support and switch to python3.
x/liberation-fonts-ttf-2.1.0-noarch-1.txz:  Upgraded.
xap/mozilla-firefox-68.6.0esr-x86_64-1.txz:  Upgraded.
  This release contains security fixes and improvements.
    https://www.mozilla.org/en-US/firefox/68.6.0/releasenotes/
    https://www.mozilla.org/security/advisories/mfsa2020-09/
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-6805
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-6806
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-6807
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-6811
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-20503
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-6812
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-6814
  (* Security fix *)
n°1445472
cycojesus
Mèo Lười
Posté le 12-03-2020 à 08:06:43  profilanswer
Wed Mar 11 19:54:51 UTC 2020
ap/hplip-3.20.3-x86_64-1.txz:  Upgraded.
d/vala-0.48.1-x86_64-1.txz:  Upgraded.
l/SDL2-2.0.12-x86_64-1.txz:  Upgraded.
l/gcr-3.36.0-x86_64-1.txz:  Upgraded.
l/glib2-2.64.1-x86_64-1.txz:  Upgraded.
l/gnome-keyring-3.36.0-x86_64-1.txz:  Upgraded.
l/libsecret-0.20.2-x86_64-1.txz:  Upgraded.
n/curl-7.69.1-x86_64-1.txz:  Upgraded.
testing/packages/PAM/gnome-keyring-3.36.0-x86_64-1_pam.txz:  Upgraded.
testing/packages/PAM/hplip-3.20.3-x86_64-1_pam.txz:  Upgraded.
n°1445556
cycojesus
Mèo Lười
Posté le 13-03-2020 à 23:08:41  profilanswer
Fri Mar 13 20:15:29 UTC 2020
a/cryptsetup-2.3.1-x86_64-1.txz:  Upgraded.
a/kernel-firmware-20200309_3b3dd5a-noarch-1.txz:  Upgraded.
a/kernel-generic-5.4.25-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.4.25-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.4.25-x86_64-1.txz:  Upgraded.
ap/ghostscript-9.51-x86_64-1.txz:  Upgraded.
d/gcc-9.3.0-x86_64-1.txz:  Upgraded.
d/gcc-brig-9.3.0-x86_64-1.txz:  Upgraded.
d/gcc-g++-9.3.0-x86_64-1.txz:  Upgraded.
d/gcc-gdc-9.3.0-x86_64-1.txz:  Upgraded.
d/gcc-gfortran-9.3.0-x86_64-1.txz:  Upgraded.
d/gcc-gnat-9.3.0-x86_64-1.txz:  Upgraded.
d/gcc-go-9.3.0-x86_64-1.txz:  Upgraded.
d/gcc-objc-9.3.0-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.4.25-x86-1.txz:  Upgraded.
d/libtool-2.4.6-x86_64-13.txz:  Rebuilt.
  Recompiled to update embedded GCC version number.
d/rust-1.42.0-x86_64-1.txz:  Upgraded.
d/scons-3.1.2-x86_64-2.txz:  Rebuilt.
k/kernel-source-5.4.25-noarch-1.txz:  Upgraded.
  GCC_VERSION 90200 -> 90300
l/libuv-1.35.0-x86_64-1.txz:  Upgraded.
n/NetworkManager-1.22.10-x86_64-1.txz:  Upgraded.
n/postfix-3.4.10-x86_64-1.txz:  Upgraded.
xap/blueman-2.1.2-x86_64-2.txz:  Rebuilt.
  This needed a rebuild for glib2-2.64.1. Thanks to Lockywolf.
xap/mozilla-thunderbird-68.6.0-x86_64-1.txz:  Upgraded.
    https://www.mozilla.org/en-US/thunderbird/68.6.0/releasenotes/
    https://www.mozilla.org/en-US/security/advisories/mfsa2020-10/
  (* Security fix *)
n°1445618
cycojesus
Mèo Lười
Posté le 16-03-2020 à 07:42:27  profilanswer
Sun Mar 15 19:50:24 UTC 2020
a/aaa_elflibs-15.0-x86_64-22.txz:  Rebuilt.
  Upgraded: libcap.so.2.33, libncurses.so.6.2, libncursesw.so.6.2,
  libpcre.so.1.2.12, libpcreposix.so.0.0.7, libtinfo.so.6.2, libform.so.6.2,
  libformw.so.6.2, libglib-2.0.so.0.6400.1, libgmodule-2.0.so.0.6400.1,
  libgobject-2.0.so.0.6400.1, libgthread-2.0.so.0.6400.1,
  liblber-2.4.so.2.10.12, libldap-2.4.so.2.10.12, libmenu.so.6.2,
  libmenuw.so.6.2, libpanel.so.6.2, libpanelw.so.6.2, libstdc++.so.6.0.28.
a/xfsprogs-5.5.0-x86_64-1.txz:  Upgraded.
ap/sudo-1.8.31p1-x86_64-1.txz:  Upgraded.
  This is a bugfix release:
  Sudo once again ignores a failure to restore the RLIMIT_CORE resource limit,
  as it did prior to version 1.8.29. Linux containers don't allow RLIMIT_CORE
  to be set back to RLIM_INFINITY if we set the limit to zero, even for root,
  which resulted in a warning from sudo.
d/help2man-1.47.13-x86_64-1.txz:  Upgraded.
d/perl-5.30.2-x86_64-1.txz:  Upgraded.
  Also upgraded to Devel-CheckLib-1.14, DBI-1.643, and IO-Socket-SSL-2.067.
n/ModemManager-1.12.8-x86_64-1.txz:  Upgraded.
n/bluez-5.54-x86_64-1.txz:  Upgraded.
x/vulkan-sdk-1.2.131.2-x86_64-1.txz:  Upgraded.
n°1445650
cycojesus
Mèo Lười
Posté le 17-03-2020 à 07:02:37  profilanswer
Mon Mar 16 21:20:17 UTC 2020
a/kernel-firmware-20200316_8eb0b28-noarch-1.txz:  Upgraded.
l/imagemagick-7.0.10_1-x86_64-1.txz:  Upgraded.
l/qt5-webkit-5.212.0_alpha4-x86_64-1.txz:  Upgraded.
n/libqmi-1.24.8-x86_64-1.txz:  Upgraded.
n/postfix-3.5.0-x86_64-1.txz:  Upgraded.
n°1445671
cycojesus
Mèo Lười
Posté le 18-03-2020 à 07:40:48  profilanswer
Tue Mar 17 22:11:07 UTC 2020
Happy Feast of Saint Patrick. Stay safe everyone.
a/openssl-solibs-1.1.1e-x86_64-1.txz:  Upgraded.
d/ccache-3.7.8-x86_64-1.txz:  Upgraded.
l/glibmm-2.64.0-x86_64-1.txz:  Upgraded.
n/openssl-1.1.1e-x86_64-1.txz:  Upgraded.
  Fixed an overflow bug in the x64_64 Montgomery squaring procedure
  used in exponentiation with 512-bit moduli.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-1551
  (* Security fix *)
n/php-7.4.4-x86_64-1.txz:  Upgraded.
  This update fixes bugs and security issues:
  Core: get_headers() silently truncates after a null byte
  EXIF: Use-of-uninitialized-value in exif
  MBstring: mb_strtolower: stack-buffer-overflow at php_unicode_tolower_full
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-7066
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-7064
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-7065
  (* Security fix *)
La Saint-Pa.t est arrivée [:ipoubelle:2]
n°1445710
cycojesus
Mèo Lười
Posté le 19-03-2020 à 07:33:15  profilanswer
Thu Mar 19 01:45:30 UTC 2020
Don't bother with 5.4.26 folks, just wait for the next one. Trust me.
a/tcsh-6.22.02-x86_64-2.txz:  Rebuilt.
  Fixed merging history from multiple shells. Thanks to jmccue.
a/xz-5.2.5-x86_64-1.txz:  Upgraded.
d/git-2.25.2-x86_64-1.txz:  Upgraded.
l/glibmm-2.64.1-x86_64-1.txz:  Upgraded.
n/bind-9.16.1-x86_64-1.txz:  Upgraded.
n/dovecot-2.3.10-x86_64-2.txz:  Rebuilt.
x/libinput-1.15.4-x86_64-1.txz:  Upgraded.
x/mesa-20.0.2-x86_64-1.txz:  Upgraded.
testing/packages/PAM/dovecot-2.3.10-x86_64-2_pam.txz:  Rebuilt.
  Recompiled using --with-pam. Thanks to HQuest.
n°1445746
cycojesus
Mèo Lười
Posté le 20-03-2020 à 08:23:06  profilanswer
Thu Mar 19 22:01:05 UTC 2020
ap/ghostscript-9.52-x86_64-1.txz:  Upgraded.
l/PyQt5-5.13.2-x86_64-1.txz:  Added.
l/QScintilla-2.11.4-x86_64-3.txz:  Rebuilt.
  Added PyQt5 support. Thanks to alienBOB.
l/sip-4.19.21-x86_64-2.txz:  Rebuilt.
  Recompiled to pick up Qt5 support.
n/gpgme-1.13.1-x86_64-3.txz:  Rebuilt.
  Added Qt5 bindings. Thanks to alienBOB.
n°1445772
cycojesus
Mèo Lười
Posté le 20-03-2020 à 22:16:51  profilanswer
Fri Mar 20 18:58:08 UTC 2020
a/kernel-firmware-20200320_edf390c-noarch-1.txz:  Upgraded.
ap/vim-8.2.0418-x86_64-1.txz:  Upgraded.
d/cmake-3.17.0-x86_64-1.txz:  Upgraded.
l/fuse3-3.9.1-x86_64-1.txz:  Upgraded.
x/igt-gpu-tools-1.25-x86_64-1.txz:  Upgraded.
xap/vim-gvim-8.2.0418-x86_64-1.txz:  Upgraded.
n°1445807
cycojesus
Mèo Lười
Posté le 22-03-2020 à 09:06:49  profilanswer
Sun Mar 22 01:55:55 UTC 2020
a/kernel-generic-5.4.27-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.4.27-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.4.27-x86_64-1.txz:  Upgraded.
a/tcsh-6.22.02-x86_64-3.txz:  Rebuilt.
  Actually apply the shell history patch this time. Thanks to jmccue.
ap/cups-filters-1.27.3-x86_64-1.txz:  Upgraded.
d/automake-1.16.2-noarch-1.txz:  Upgraded.
d/kernel-headers-5.4.27-x86-1.txz:  Upgraded.
d/parallel-20200322-noarch-1.txz:  Upgraded.
k/kernel-source-5.4.27-noarch-1.txz:  Upgraded.
l/gmime-3.2.7-x86_64-1.txz:  Upgraded.
l/pangomm-2.42.1-x86_64-1.txz:  Upgraded.
n/gnupg2-2.2.20-x86_64-1.txz:  Upgraded.
xap/xaos-3.7-x86_64-1.txz:  Upgraded.
xap/xscreensaver-5.44-x86_64-1.txz:  Upgraded.
testing/packages/PAM/xscreensaver-5.44-x86_64-1_pam.txz:  Upgraded.
n°1445840
cycojesus
Mèo Lười
Posté le 23-03-2020 à 08:36:19  profilanswer
Sun Mar 22 19:58:16 UTC 2020
l/glibmm-2.64.2-x86_64-1.txz:  Upgraded.
l/imagemagick-7.0.10_2-x86_64-1.txz:  Upgraded.
l/libcue-2.2.1-x86_64-1.txz:  Added.
  The initial use for this is adding CUE support to audacious-plugins.
l/libdvdnav-6.1.0-x86_64-1.txz:  Upgraded.
l/libdvdread-6.1.0-x86_64-1.txz:  Upgraded.
xap/audacious-4.0-x86_64-1.txz:  Upgraded.
xap/audacious-plugins-4.0-x86_64-1.txz:  Upgraded.
extra/pure-alsa-system/audacious-plugins-4.0-x86_64-1_alsa.txz:  Upgraded.
n°1445868
cycojesus
Mèo Lười
Posté le 24-03-2020 à 08:13:53  profilanswer
Tue Mar 24 05:08:25 UTC 2020
n/curl-7.69.1-x86_64-3.txz:  Rebuilt.
  Removed --with-ca-bundle=/usr/share/curl/ca-bundle.crt and
  added --without-ca-bundle. Thanks to drgibbon and Willy Sudiarto Raharjo.
Mon Mar 23 20:03:39 UTC 2020
a/e2fsprogs-1.45.6-x86_64-1.txz:  Upgraded.
d/git-2.26.0-x86_64-1.txz:  Upgraded.
l/gd-2.3.0-x86_64-1.txz:  Upgraded.
  Potential double-free in gdImage*Ptr().
  gdImageColorMatch() out of bounds write on heap.
  Uninitialized read in gdImageCreateFromXbm().
  Double-free in gdImageBmp.
  Potential NULL pointer dereference in gdImageClone().
  Potential infinite loop in gdImageCreateFromGifCtx().
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-6978
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-6977
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-11038
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1000222
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-14553
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-5711
  (* Security fix *)
l/libbluray-1.2.0-x86_64-1.txz:  Upgraded.
n/curl-7.69.1-x86_64-2.txz:  Rebuilt.
  Use --with-ca-path=/etc/ssl/certs instead of
  --with-ca-bundle=/usr/share/curl/ca-bundle.crt. Thanks to shastah.
xap/audacious-4.0-x86_64-2.txz:  Rebuilt.
  Rebuilt with autotools to fix French language support. Thanks to gmgf.
xap/audacious-plugins-4.0-x86_64-2.txz:  Rebuilt.
  Rebuilt with autotools.
extra/pure-alsa-system/audacious-plugins-4.0-x86_64-2_alsa.txz:  Rebuilt.
n°1445918
cycojesus
Mèo Lười
Posté le 26-03-2020 à 08:36:04  profilanswer
Wed Mar 25 22:53:06 UTC 2020
a/e2fsprogs-1.45.6-x86_64-2.txz:  Rebuilt.
  Fixed RELEASE-NOTES dangling symlink.
a/kernel-generic-5.4.28-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.4.28-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.4.28-x86_64-1.txz:  Upgraded.
ap/nano-4.9-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.4.28-x86-1.txz:  Upgraded.
d/llvm-10.0.0-x86_64-1.txz:  Upgraded.
  Shared library .so-version bump.
d/rust-1.42.0-x86_64-2.txz:  Rebuilt.
  Recompiled against llvm-10.0.0.
d/scons-3.1.2-x86_64-3.txz:  Rebuilt.
  Fixed shebangs for python3, removed useless .bat files.
  Thanks to teeemcee and ponce.
d/vala-0.48.2-x86_64-1.txz:  Upgraded.
k/kernel-source-5.4.28-noarch-1.txz:  Upgraded.
l/libgsf-1.14.47-x86_64-1.txz:  Upgraded.
l/neon-0.31.0-x86_64-1.txz:  Upgraded.
l/netpbm-10.89.03-x86_64-1.txz:  Upgraded.
l/qt5-5.13.2-x86_64-3.txz:  Rebuilt.
x/mesa-20.0.2-x86_64-2.txz:  Rebuilt.
xfce/thunar-1.8.14-x86_64-1.txz:  Upgraded.
n°1445968
cycojesus
Mèo Lười
Posté le 27-03-2020 à 08:00:38  profilanswer
Thu Mar 26 22:37:06 UTC 2020
x/libwacom-1.3-x86_64-1.txz:  Upgraded.
n°1446015
cycojesus
Mèo Lười
Posté le 28-03-2020 à 09:18:38  profilanswer
Sat Mar 28 05:48:42 UTC 2020
a/lvm2-2.03.09-x86_64-1.txz:  Upgraded.
d/guile-3.0.2-x86_64-1.txz:  Upgraded.
l/glib-networking-2.64.1-x86_64-1.txz:  Upgraded.
l/gtk+3-3.24.16-x86_64-1.txz:  Upgraded.
l/gvfs-1.44.1-x86_64-1.txz:  Upgraded.
l/librsvg-2.48.1-x86_64-1.txz:  Upgraded.
l/vte-0.60.1-x86_64-1.txz:  Upgraded.
xap/audacious-4.0-x86_64-3.txz:  Rebuilt.
  Also support GTK+ interface, including a .desktop file for it.
xap/audacious-plugins-4.0-x86_64-3.txz:  Rebuilt.
  Rebuilt with --enable-gtk.
extra/pure-alsa-system/audacious-plugins-4.0-x86_64-3_alsa.txz:  Rebuilt.
extra/pure-alsa-system/qt5-5.13.2-x86_64-3_alsa.txz:  Added.
n°1446074
cycojesus
Mèo Lười
Posté le 30-03-2020 à 07:35:38  profilanswer
Sun Mar 29 23:05:46 UTC 2020
d/ccache-3.7.9-x86_64-1.txz:  Upgraded.
d/llvm-10.0.0-x86_64-2.txz:  Rebuilt.
  Ensure that lit-cpuid is built and installed. Thanks to jkh2cpu.
l/imagemagick-7.0.10_3-x86_64-1.txz:  Upgraded.
l/netpbm-10.90.00-x86_64-1.txz:  Upgraded.
n/mutt-1.13.5-x86_64-1.txz:  Upgraded.
n/nfs-utils-2.4.3-x86_64-2.txz:  Rebuilt.
  Rebuilt with --with-pluginpath=/usr/lib${LIBDIRSUFFIX}/libnfsidmap.
  Thanks to lecho.
x/xorg-server-1.20.8-x86_64-1.txz:  Upgraded.
x/xorg-server-xephyr-1.20.8-x86_64-1.txz:  Upgraded.
x/xorg-server-xnest-1.20.8-x86_64-1.txz:  Upgraded.
x/xorg-server-xvfb-1.20.8-x86_64-1.txz:  Upgraded.
x/xorg-server-xwayland-1.20.8-x86_64-1.txz:  Upgraded.
n°1446113
cycojesus
Mèo Lười
Posté le 31-03-2020 à 08:32:43  profilanswer
Tue Mar 31 04:00:43 UTC 2020
a/pkgtools-15.0-noarch-31.txz:  Rebuilt.
  removepkg: support an uninstall script. See removepkg(8).
d/meson-0.54.0-x86_64-1.txz:  Upgraded.
n°1446169
cycojesus
Mèo Lười
Posté le 31-03-2020 à 23:09:09  profilanswer
Tue Mar 31 19:01:17 UTC 2020
a/dialog-1.3_20200327-x86_64-1.txz:  Upgraded.
a/openssl-solibs-1.1.1f-x86_64-1.txz:  Upgraded.
ap/nano-4.9.1-x86_64-1.txz:  Upgraded.
l/elfutils-0.179-x86_64-1.txz:  Upgraded.
n/gnutls-3.6.13-x86_64-1.txz:  Upgraded.
  libgnutls: Fix a DTLS-protocol regression (caused by TLS1.3 support),
  since 3.6.3. The DTLS client would not contribute any randomness to the
  DTLS negotiation, breaking the security guarantees of the DTLS protocol.
  [GNUTLS-SA-2020-03-31, CVSS: high]
  (* Security fix *)
n/httpd-2.4.43-x86_64-1.txz:  Upgraded.
n/openssl-1.1.1f-x86_64-1.txz:  Upgraded.
n°1446243
cycojesus
Mèo Lười
Posté le 02-04-2020 à 10:05:57  profilanswer
Thu Apr  2 06:07:52 UTC 2020
a/hwdata-0.334-noarch-1.txz:  Upgraded.
a/kernel-generic-5.4.29-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.4.29-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.4.29-x86_64-1.txz:  Upgraded.
a/pkgtools-15.0-noarch-32.txz:  Rebuilt.
  installpkg: handle the uninstall script packaged as /install/douninst.sh.
  removepkg: add --skip-douninst option to skip running the uninstall script.
    Save removed douninst.sh in /var/log/pkgtools/removed_uninstall_scripts.
ap/groff-1.22.4-x86_64-2.txz:  Rebuilt.
  Fixed docdir. Thanks to Xsane.
d/gcc-9.3.0-x86_64-2.txz:  Rebuilt.
d/gcc-brig-9.3.0-x86_64-2.txz:  Rebuilt.
d/gcc-g++-9.3.0-x86_64-2.txz:  Rebuilt.
d/gcc-gdc-9.3.0-x86_64-2.txz:  Rebuilt.
d/gcc-gfortran-9.3.0-x86_64-2.txz:  Rebuilt.
  Patched a compiler bug concerning assumed-shape vs. deferred-shape arrays.
d/gcc-gnat-9.3.0-x86_64-2.txz:  Rebuilt.
d/gcc-go-9.3.0-x86_64-2.txz:  Rebuilt.
d/gcc-objc-9.3.0-x86_64-2.txz:  Rebuilt.
d/kernel-headers-5.4.29-x86-1.txz:  Upgraded.
d/ruby-2.7.1-x86_64-1.txz:  Upgraded.
  This update fixes security issues:
  Unsafe Object Creation Vulnerability in JSON (Additional fix).
  Heap exposure vulnerability in the socket library.
    https://www.ruby-lang.org/en/news/2020/03/19/json-dos-cve-2020-10663/
    https://www.ruby-lang.org/en/news/2020/03/31/heap-exposure-in-socket-cve-2020-10933/
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-10663
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-10933
  (* Security fix *)
k/kernel-source-5.4.29-noarch-1.txz:  Upgraded.
l/graphite2-1.3.14-x86_64-1.txz:  Upgraded.
l/librsvg-2.48.2-x86_64-1.txz:  Upgraded.
l/utf8proc-2.5.0-x86_64-1.txz:  Upgraded.
x/libva-2.7.0-x86_64-1.txz:  Upgraded.
x/libva-utils-2.7.1-x86_64-1.txz:  Upgraded.
n°1446314
cycojesus
Mèo Lười
Posté le 03-04-2020 à 08:10:43  profilanswer
Code :
  1. Thu Apr  2 22:13:11 UTC 2020
  2. a/kernel-generic-5.4.30-x86_64-1.txz:  Upgraded.
  3. a/kernel-huge-5.4.30-x86_64-1.txz:  Upgraded.
  4. a/kernel-modules-5.4.30-x86_64-1.txz:  Upgraded.
  5. d/kernel-headers-5.4.30-x86-1.txz:  Upgraded.
  6. k/kernel-source-5.4.30-noarch-1.txz:  Upgraded.
  7. l/atk-2.36.0-x86_64-1.txz:  Upgraded.
  8. l/libunwind-1.4.0-x86_64-1.txz:  Upgraded.
  9. n/conntrack-tools-1.4.6-x86_64-1.txz:  Upgraded.
  10. n/libnetfilter_conntrack-1.0.8-x86_64-1.txz:  Upgraded.
  11. n/libnftnl-1.1.6-x86_64-1.txz:  Upgraded.
  12. n/nftables-0.9.4-x86_64-1.txz:  Upgraded.
  13. x/mesa-20.0.3-x86_64-1.txz:  Upgraded.
  14. xap/network-manager-applet-1.16.0-x86_64-2.txz:  Rebuilt.
  15.   Rebuilt using meson. Thanks to bassmadrigal.
  16. isolinux/initrd.img:  Rebuilt.
  17. kernels/*:  Upgraded.
  18. usb-and-pxe-installers/usbboot.img:  Rebuilt.
  19. +--------------------------+
n°1446394
cycojesus
Mèo Lười
Posté le 04-04-2020 à 07:17:09  profilanswer
Fri Apr  3 23:07:16 UTC 2020
ap/lsof-4.93.2-x86_64-2.txz:  Rebuilt.
  Fixed the manpage. Thanks to kaott.
ap/sc-7.16-x86_64-7.txz:  Rebuilt.
  Brought back the classic SC. Thanks to dive.
d/Cython-0.29.16-x86_64-1.txz:  Upgraded.
d/mercurial-5.3.2-x86_64-1.txz:  Upgraded.
l/gtk+3-3.24.17-x86_64-1.txz:  Upgraded.
n/dhcpcd-8.1.7-x86_64-1.txz:  Upgraded.
n/iproute2-5.6.0-x86_64-1.txz:  Upgraded.
x/libdrm-2.4.101-x86_64-1.txz:  Upgraded.
x/mesa-20.0.4-x86_64-1.txz:  Upgraded.
xap/mozilla-firefox-68.6.1esr-x86_64-1.txz:  Upgraded.
  This release contains critical security fixes and improvements.
  "Under certain conditions, when running the nsDocShell destructor, a race
  condition can cause a use-after-free. We are aware of targeted attacks in
  the wild abusing this flaw."
  "Under certain conditions, when handling a ReadableStream, a race condition
  can cause a use-after-free. We are aware of targeted attacks in the wild
  abusing this flaw."
    https://www.mozilla.org/en-US/firefox/68.6.1/releasenotes/
    https://www.mozilla.org/en-US/security/advisories/mfsa2020-11/
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-6819
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-6820
  (* Security fix *)
n°1446435
cycojesus
Mèo Lười
Posté le 04-04-2020 à 21:44:40  profilanswer
Sat Apr  4 19:22:23 UTC 2020
ap/sc-7.16-x86_64-8.txz:  Rebuilt.
  Fixed permissions on installed binaries. Thanks to mats_b_tegner.
ap/sc-im-20200210_862c273-x86_64-1.txz:  Upgraded.
  Switched to pulling from git to fix various crashes.
x/glew-2.2.0-x86_64-1.txz:  Upgraded.
n°1446439
cycojesus
Mèo Lười
Posté le 05-04-2020 à 08:46:08  profilanswer
Sun Apr  5 01:33:45 UTC 2020
kde/calligra-2.9.11-x86_64-34.txz:  Rebuilt.
  Recompiled against glew-2.2.0.
  The libGLEW.so.2.2 .soname (rather than libGLEW.so.2) gets me every time.
  Thanks to marrowsuck for the bug report.
l/libdvdread-6.1.1-x86_64-1.txz:  Upgraded.
x/mesa-20.0.4-x86_64-2.txz:  Rebuilt.
n°1446967
cycojesus
Mèo Lười
Posté le 06-04-2020 à 08:20:50  profilanswer
Sun Apr  5 21:02:32 UTC 2020
d/bison-3.5.4-x86_64-1.txz:  Upgraded.
kde/k3b-2.0.3-x86_64-7.txz:  Rebuilt.
  Recompiled against libdvdread-6.1.1.
l/gobject-introspection-1.64.1-x86_64-1.txz:  Upgraded.
l/imagemagick-7.0.10_4-x86_64-1.txz:  Upgraded.
l/libdvdnav-6.1.0-x86_64-2.txz:  Rebuilt.
  Who bumps an .soname and only boosts the version number by 0.0.1?
  Anyway, sorry to drop the ball a second time. I'll try to avoid this.
  Thanks to gmgf for the bug report.
n/fetchmail-6.4.3-x86_64-1.txz:  Upgraded.
tcl/tclx-8.4.4-x86_64-1.txz:  Upgraded.
xap/MPlayer-20200103-x86_64-2.txz:  Rebuilt.
xap/windowmaker-0.95.9-x86_64-1.txz:  Upgraded.
xap/xine-lib-1.2.10-x86_64-2.txz:  Rebuilt.
extra/pure-alsa-system/MPlayer-20200103-x86_64-2_alsa.txz:  Rebuilt.
extra/pure-alsa-system/xine-lib-1.2.10-x86_64-2_alsa.txz:  Rebuilt.
n°1447056
cycojesus
Mèo Lười
Posté le 07-04-2020 à 08:03:29  profilanswer
Mon Apr  6 21:23:19 UTC 2020
ap/vim-8.2.0521-x86_64-1.txz:  Upgraded.
d/vala-0.48.3-x86_64-1.txz:  Upgraded.
l/imagemagick-7.0.10_5-x86_64-1.txz:  Upgraded.
x/compiz-0.8.18-x86_64-1.txz:  Upgraded.
xap/audacious-4.0.1-x86_64-1.txz:  Upgraded.
xap/audacious-plugins-4.0.1-x86_64-1.txz:  Upgraded.
xap/vim-gvim-8.2.0521-x86_64-1.txz:  Upgraded.
extra/brltty/brltty-6.1-x86_64-1.txz:  Upgraded.
extra/pure-alsa-system/audacious-plugins-4.0.1-x86_64-1_alsa.txz:  Upgraded.
testing/packages/PAM/sudo-1.8.31p1-x86_64-1_pam.txz:  Upgraded.
n°1447111
cycojesus
Mèo Lười
Posté le 08-04-2020 à 07:52:31  profilanswer
Tue Apr  7 22:23:02 UTC 2020
testing/packages/PAM/samba-4.12.1-x86_64-1_pam.txz:  Upgraded.
Tue Apr  7 21:19:42 UTC 2020
a/btrfs-progs-5.6-x86_64-1.txz:  Upgraded.
ap/cups-filters-1.27.3-x86_64-2.txz:  Rebuilt.
  Recompiled against qpdf-10.0.0.
ap/nano-4.9.2-x86_64-1.txz:  Upgraded.
ap/qpdf-10.0.0-x86_64-1.txz:  Upgraded.
d/strace-5.6-x86_64-1.txz:  Upgraded.
l/imagemagick-7.0.10_6-x86_64-1.txz:  Upgraded.
l/python-pygments-2.5.2-x86_64-2.txz:  Rebuilt.
  Rebuilt to fix stale signature on some mirrors.
  Thanks to Xsane and Petri Kaukasoina.
xap/mozilla-firefox-68.7.0esr-x86_64-1.txz:  Upgraded.
    https://www.mozilla.org/en-US/firefox/68.7.0/releasenotes/
    https://www.mozilla.org/en-US/security/advisories/mfsa2020-13/
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-6828
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-6827
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-6821
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-6822
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-6825
  (* Security fix *)
n°1447165
cycojesus
Mèo Lười
Posté le 09-04-2020 à 07:18:13  profilanswer
Thu Apr  9 00:53:59 UTC 2020
a/kernel-generic-5.4.31-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.4.31-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.4.31-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.4.31-x86-1.txz:  Upgraded.
k/kernel-source-5.4.31-noarch-1.txz:  Upgraded.
l/mozilla-nss-3.51.1-x86_64-1.txz:  Upgraded.
n/samba-4.12.1-x86_64-1.txz:  Upgraded.
xap/mozilla-thunderbird-68.7.0-x86_64-1.txz:  Upgraded.
    https://www.mozilla.org/en-US/thunderbird/68.7.0/releasenotes/
  (* Security fix *)
n°1447231
cycojesus
Mèo Lười
Posté le 10-04-2020 à 08:01:05  profilanswer
Thu Apr  9 22:20:10 UTC 2020
d/cmake-3.17.1-x86_64-1.txz:  Upgraded.
l/glib2-2.64.2-x86_64-1.txz:  Upgraded.
l/libssh-0.9.4-x86_64-1.txz:  Upgraded.
  Fixed possible DoS in client and server when handling AES-CTR keys
  with OpenSSL.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-1730
  (* Security fix *)
Slackware 9.0[slackware] Suppression de terminaux virtuels ?
!! Configuration reseaux, slackware 9 !!Installer slackware 9.0 par ftp (boot disquette)
[Pb] Installation new HDD sous slackware 8.0[RESOLU] Pb d'execution mysql sur slackware ...
Slackware 9 du pur bonheurMonter une partition NTFS sous linux (slackware 9.0)
Slackware 9.0 Finale OUTJe sens que je vais quitter Slackware (pas en serv)
Plus de sujets relatifs à : [SLACKWARE] du présent - 15.0
