4477 connectés
La 15.0 est là (en vrai !)
Les invités peuvent voter
 Page :   1  2  3  4  5  ..  62  63  64  ..  109  110  111  112  113  114
[SLACKWARE] du présent - 15.0
n°1352609
cycojesus
Mèo Lười
Posté le 14-02-2014 à 12:37:48  profilanswer
Yay, boucles à Antpwerp [:azyl:3]
Thu Feb 13 23:45:53 UTC 2014
n/curl-7.35.0-x86_64-1.txz:  Upgraded.
  This update fixes a flaw where libcurl could, in some circumstances, reuse
  the wrong connection when asked to do an NTLM-authenticated HTTP or HTTPS
  request.
  For more information, see:
    http://curl.haxx.se/docs/adv_20140129.html
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-0015
  (* Security fix *)
n/ntp-4.2.6p5-x86_64-5.txz:  Rebuilt.
  All stable versions of NTP remain vulnerable to a remote attack where the
  "ntpdc -c monlist" command can be used to amplify network traffic as part
  of a denial of service attack.  By default, Slackware is not vulnerable
  since it includes "noquery" as a default restriction.  However, it is
  vulnerable if this restriction is removed.  To help mitigate this flaw,
  "disable monitor" has been added to the default ntp.conf (which will disable
  the monlist command even if other queries are allowed), and the default
  restrictions have been extended to IPv6 as well.
  All users of the NTP daemon should make sure that their ntp.conf contains
  "disable monitor" to prevent misuse of the NTP service.  The new ntp.conf
  file will be installed as /etc/ntp.conf.new with a package upgrade, but the
  changes will need to be merged into any existing ntp.conf file by the admin.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-5211
    http://www.kb.cert.org/vuls/id/348126
  (* Security fix *)
[:marronnix]
Chết rồi ! ✍ ⌥⌘ http://codeberg.org/gwh
n°1352924
cycojesus
Mèo Lười
Posté le 20-02-2014 à 09:45:32  profilanswer
Au lait, au lit, au lit, au lit [:lechiendejohnny:4]
Du lait au lit [:bibliophage:3]
Du lait au lit ! [:ben_be:3]
Thu Feb 20 00:30:49 UTC 2014
a/kernel-firmware-20140215git-noarch-1.txz:  Upgraded.
a/kernel-generic-3.10.30-x86_64-1.txz:  Upgraded.
  These are new kernels that fix CVE-2014-0038, a bug that can allow local
  users to gain a root shell.
  Be sure to reinstall LILO (run "lilo" as root) after upgrading the kernel
  packages, or on UEFI systems, copy the appropriate kernel to
  /boot/efi/EFI/Slackware/vmlinuz).
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-0038
  (* Security fix *)
a/kernel-huge-3.10.30-x86_64-1.txz:  Upgraded.
  (* Security fix *)
a/kernel-modules-3.10.30-x86_64-1.txz:  Upgraded.
a/shadow-4.1.5.1-x86_64-3.txz:  Rebuilt.
  Shadow 4.1.5 addressed a tty-hijacking vulnerability in "su -c"
  (CVE-2005-4890) by detaching the controlling terminal in the non-PAM
  case via a TIOCNOTTY request.  Bi-directional protection is excessive
  and breaks a commonly-used methods for privilege escalation on non-PAM
  systems (e.g. xterm -e /bin/su -s /bin/bash -c /bin/bash myscript).
  This update relaxes the restriction and only detaches the controlling
  tty when the callee is not root (which is, after all, the threat vector).
  Thanks to mancha for the patch (and the above information).
ap/mariadb-5.5.35-x86_64-1.txz:  Upgraded.
  This update fixes a buffer overflow in the mysql command line client which
  may allow malicious or compromised database servers to cause a denial of
  service (crash) and possibly execute arbitrary code via a long server
  version string.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-0001
  (* Security fix *)
d/kernel-headers-3.10.30-x86-1.txz:  Upgraded.
k/kernel-source-3.10.30-noarch-1.txz:  Upgraded.
  (* Security fix *)
n/gnutls-3.1.21-x86_64-1.txz:  Upgraded.
  This update fixes a flaw where a version 1 intermediate certificate would be
  considered as a CA certificate by GnuTLS by default.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-1959
  (* Security fix *)
xap/mozilla-firefox-27.0.1-x86_64-1.txz:  Upgraded.
isolinux/initrd.img:  Rebuilt.
kernels/*:  Upgraded.
usb-and-pxe-installers/usbboot.img:  Rebuilt.
[:fullraymond:5]  [:duckjerry]
n°1352934
wedgeant
Da penguin inside
Posté le 20-02-2014 à 14:04:06  profilanswer
Oh yeah, Oyez [:koukouille:3]
Wedge#2487 @HS -#- PW: +∞ -#- Khaz-Modan/Boltiz @WoW
n°1353314
cycojesus
Mèo Lười
Posté le 24-02-2014 à 22:31:19  profilanswer
J'ai Slackifié mon cubietruck et j'en suis Joie [:grayson]
n°1353352
wedgeant
Da penguin inside
Posté le 25-02-2014 à 10:51:21  profilanswer
 [:wildmary:4]
n°1353597
cycojesus
Mèo Lười
Posté le 28-02-2014 à 13:18:31  profilanswer
Va vous corrompre [:kaii:4]
Thu Feb 27 20:43:28 UTC 2014
d/subversion-1.7.16-x86_64-1.txz:  Upgraded.
  Fix denial of service bugs.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4505
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4558
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-0032
  (* Security fix *)
[:bibliophage:1]
n°1353773
cycojesus
Mèo Lười
Posté le 04-03-2014 à 09:59:12  profilanswer
[:neldor]
Mon Mar  3 23:32:18 UTC 2014
n/gnutls-3.1.22-x86_64-1.txz:  Upgraded.
  Fixed a security issue where a specially crafted certificate could
  bypass certificate validation checks.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-0092
  (* Security fix *)
[:neldor] Ceci était un communiqué du Collectif de Ceux qui ne se Font Pas Violenter [:jcqs:3]
n°1353779
wedgeant
Da penguin inside
Posté le 04-03-2014 à 13:45:23  profilanswer
[:koukouille:3]
n°1353902
cycojesus
Mèo Lười
Posté le 06-03-2014 à 10:15:38  profilanswer
<!-- insérer la blague sudo qu'on pense qu'elle nous donne l'air super in alors qu'en fait bin voilà quoi [:enyg:5] -->
Thu Mar  6 04:14:23 UTC 2014
ap/sudo-1.8.9p5-x86_64-1.txz:  Upgraded.
[:lebef]
n°1353903
el_barbone
too old for this shit ...
Posté le 06-03-2014 à 10:19:07  profilanswer
[:koukouille:3]
En théorie, la théorie et la pratique sont identiques, en pratique, non.
n°1353904
wedgeant
Da penguin inside
Posté le 06-03-2014 à 10:24:51  profilanswer
 [:tammuz:1]
n°1354212
cycojesus
Mèo Lười
Posté le 11-03-2014 à 11:28:34  profilanswer
ABCDEFGHIJKLMNOPQRSTU ok [:aaaaze:1]
1 & 2 'accor [:talladega:4]
 [:hadock31]
Tue Mar 11 07:06:18 UTC 2014
a/udisks-1.0.5-x86_64-1.txz:  Upgraded.
  This update fixes a stack-based buffer overflow when handling long path
  names.  A malicious, local user could use this flaw to create a
  specially-crafted directory structure that could lead to arbitrary code
  execution with the privileges of the udisks daemon (root).
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-0004
  (* Security fix *)
a/udisks2-2.1.3-x86_64-1.txz:  Upgraded.
  (* Security fix *)
[:cacatomique:1]
Message édité par cycojesus le 11-03-2014 à 11:30:23
n°1354217
Col Hanzap​last
Jurassic geek. Vive le cobol !
Posté le 11-03-2014 à 12:51:09  profilanswer
Pourrait-on avoir connaissance de la blague sudo dont il est question plus haut ? [:iansoio]
" Il n'y a aucune chance pour que l'iPhone s'attribue une part de marché significative. Aucune chance. " (Steve Ballmer 2007)
n°1354228
cycojesus
Mèo Lười
Posté le 11-03-2014 à 16:34:17  profilanswer
http://xkcd.com/149/
Si tu ne la connaissais pas tu me dois un http://www.ina.fr/notice/voir/PUB3784050046
n°1354234
regdub
Posté le 11-03-2014 à 22:20:26  profilanswer
 [:hado papi:1]
n°1354368
cycojesus
Mèo Lười
Posté le 14-03-2014 à 13:24:26  profilanswer
Mon nuage de moi eu un instant d'amnésie qu'un subtil coup de tatane équirisa.
Dotn acet [:4lkaline2:4]
Fri Mar 14 00:44:48 UTC 2014
n/samba-4.1.6-x86_64-1.txz:  Upgraded.
  This update fixes two security issues:
  CVE-2013-4496:
  Samba versions 3.4.0 and above allow the administrator to implement
  locking out Samba accounts after a number of bad password attempts.
  However, all released versions of Samba did not implement this check for
  password changes, such as are available over multiple SAMR and RAP
  interfaces, allowing password guessing attacks.
  CVE-2013-6442:
  Samba versions 4.0.0 and above have a flaw in the smbcacls command. If
  smbcacls is used with the "-C|--chown name" or "-G|--chgrp name"
  command options it will remove the existing ACL on the object being
  modified, leaving the file or directory unprotected.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4496
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-6442
  (* Security fix *)
Thu Mar 13 03:32:38 UTC 2014
n/mutt-1.5.23-x86_64-1.txz:  Upgraded.
  This update fixes a buffer overflow where malformed RFC2047 header
  lines could result in denial of service or potentially the execution
  of arbitrary code as the user running mutt.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-0467
  (* Security fix *)
[:rudolf hoax:4]  [:kapitan wurst]  [:nham:5]
n°1354473
cycojesus
Mèo Lười
Posté le 16-03-2014 à 09:54:52  profilanswer
douleur [:swimm3r:5]
Sun Mar 16 02:52:28 UTC 2014
n/php-5.4.26-x86_64-1.txz:  Upgraded.
  This update fixes a flaw where a specially crafted data file may cause a
  segfault or 100% CPU consumption when a web page uses fileinfo() on it.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-1943
  (* Security fix *)
[:freak bauer:4]
Message édité par cycojesus le 16-03-2014 à 09:55:36
n°1354562
wedgeant
Da penguin inside
Posté le 18-03-2014 à 10:21:21  profilanswer
[:wark0]
n°1354569
el_barbone
Posté le 18-03-2014 à 11:22:48  profilanswer
[:koukouille:3]
n°1354571
gui42
Posté le 18-03-2014 à 11:40:12  profilanswer
cross-topic ssd
faut que je mette à jour le noyau de ma 14.1, si je prends le 3.10.30 de la current, est-ce qu'il y a autre chose que je dois mettre à jour ?
merci pour votre aide
edit :
ça devrait le faire non ?
Message édité par gui42 le 18-03-2014 à 11:45:20
n°1354576
wedgeant
Da penguin inside
Posté le 18-03-2014 à 12:04:49  profilanswer
normalement oui, peut-être la libc ... mais encore, pas sur que ça soit nécessaire ...
n°1354592
gui42
Posté le 18-03-2014 à 16:28:33  profilanswer
elle est pas été mise à jour depuis la sortie de 14.1, on est bien d'accord ?
n°1354594
wedgeant
Da penguin inside
Posté le 18-03-2014 à 17:39:24  profilanswer
Yep, je viens de vérifier :jap:
n°1354608
gui42
Posté le 19-03-2014 à 08:52:52  profilanswer
je vais upgrader ça (et les autres patches tiens  :whistle: ) même si en fait ça n'avance à rien pour le ssd (mais c'est une autre histoire).
bonne journée
n°1354774
gui42
Posté le 21-03-2014 à 18:12:04  profilanswer
une autre question.
Suivant les recommandations du topic ssd, /tmp est monté en tmpfs avec l'option noexec.
Mais je ne peux plus compiler quoi que ce soit du coup, surtout quand j'utilise un slackbuild qui utilise automatiquement /tmp.
Quelle serait la bonne méthode ?
D'avance merci
n°1354785
regdub
Posté le 21-03-2014 à 20:31:55  profilanswer
gui42 a écrit :
une autre question.
D'avance merci
Chez moi, j'ai juste "nosuid,nodev".
A la limite, si tu veux la jouer parano, tu compiles sur une VM dédiée à ça, sans noexec sur /tmp, donc.
Legalize it @HFR
n°1354838
gui42
Posté le 23-03-2014 à 22:14:23  profilanswer
donc pour toi, c'est déjà un peu exagéré le noexec sur /tmp ?
n°1354840
regdub
Posté le 23-03-2014 à 22:47:38  profilanswer
A mon avis, c'est lié à une utilisation de type serveur web / multi-utilisateur, mais après, je n'ai aucune compétence officielle dans ce domaine (edit: de la sécurité).
Message édité par regdub le 23-03-2014 à 22:56:36
Legalize it @HFR
n°1354853
gui42
Posté le 24-03-2014 à 07:48:06  profilanswer
ok merci
bonne journée
n°1355249
cycojesus
Mèo Lười
Posté le 29-03-2014 à 08:13:47  profilanswer
Tiens ton mange [:kevinchotin]
La secure des internets c'est aussi un portant de la vie. Tu l'enlèves et bin [:_oodid] ...
Fri Mar 28 03:43:11 UTC 2014
l/mozilla-nss-3.16-x86_64-1.txz:  Upgraded.
  This update fixes a security issue:
  The cert_TestHostName function in lib/certdb/certdb.c in the
  certificate-checking implementation in Mozilla Network Security Services
  (NSS) before 3.16 accepts a wildcard character that is embedded in an
  internationalized domain name's U-label, which might allow man-in-the-middle
  attackers to spoof SSL servers via a crafted certificate.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-1492
  (* Security fix *)
l/seamonkey-solibs-2.25-x86_64-1.txz:  Upgraded.
n/curl-7.36.0-x86_64-1.txz:  Upgraded.
  This update fixes four security issues.
    http://curl.haxx.se/docs/adv_20140326A.html
    http://curl.haxx.se/docs/adv_20140326B.html
    http://curl.haxx.se/docs/adv_20140326C.html
    http://curl.haxx.se/docs/adv_20140326D.html
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-0138
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-0139
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-1263
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-2522
  (* Security fix *)
n/httpd-2.4.9-x86_64-1.txz:  Upgraded.
  This update addresses two security issues.
  Segfaults with truncated cookie logging. mod_log_config:  Prevent segfaults
    when logging truncated cookies.  Clean up the cookie logging parser to
    recognize only the cookie=value pairs, not valueless cookies.
  mod_dav:  Keep track of length of cdata properly when removing leading
    spaces. Eliminates a potential denial of service from specifically crafted
    DAV WRITE requests.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-0098
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-6438
  (* Security fix *)
n/openssh-6.6p1-x86_64-1.txz:  Upgraded.
  This update fixes a security issue when using environment passing with
  a sshd_config(5) AcceptEnv pattern with a wildcard.  OpenSSH could be
  tricked into accepting any environment variable that contains the
  characters before the wildcard character.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-2532
  (* Security fix *)
n/tin-2.2.0-x86_64-1.txz:  Upgraded.
xap/mozilla-firefox-28.0-x86_64-1.txz:  Upgraded.
  This release contains security fixes and improvements.
    http://www.mozilla.org/security/known-vulnerabilities/firefox.html
  (* Security fix *)
xap/mozilla-thunderbird-24.4.0-x86_64-1.txz:  Upgraded.
  This update contains security fixes and improvements.
    http://www.mozilla.org/security/known-vulnerabilities/thunderbird.html
  (* Security fix *)
xap/seamonkey-2.25-x86_64-1.txz:  Upgraded.
    http://www.mozilla.org/security/known-vulnerabilities/seamonkey.html
  (* Security fix *)
[:nicarao:1]
n°1355357
wedgeant
Da penguin inside
Posté le 31-03-2014 à 09:28:26  profilanswer
[:koukouille:3]
n°1355451
cycojesus
Mèo Lười
Posté le 01-04-2014 à 06:42:41  profilanswer
Il est des jours ainsi où la parole viens à manquer,
Les mots s'évaporent dans les brumes d'un esprit encaqueté
Et c'est en vin que l'on bois pour les retrouver et lors les battre  [:ororuk:3]
Mon Mar 31 20:30:28 UTC 2014
l/apr-1.5.0-x86_64-1.txz:  Upgraded.
l/apr-util-1.5.3-x86_64-1.txz:  Upgraded.
n/httpd-2.4.9-x86_64-2.txz:  Rebuilt.
  Recompiled against new apr/apr-util to restore missing mod_mpm_event.so.
[:mimounne]  [:boy johnny:2]
n°1355905
cycojesus
Mèo Lười
Posté le 08-04-2014 à 20:04:42  profilanswer
Laule tu prends le tout de la chose et tu refait [:orthopedux:3]
sinon [:noel le graet:3]
Tue Apr  8 14:19:51 UTC 2014
a/openssl-solibs-1.0.1g-x86_64-1.txz:  Upgraded.
n/openssl-1.0.1g-x86_64-1.txz:  Upgraded.
  A missing bounds check in the handling of the TLS heartbeat extension
  can be used to reveal up to 64k of memory to a connected client or server.
  Thanks for Neel Mehta of Google Security for discovering this bug and to
  Adam Langley <agl@chromium.org> and Bodo Moeller <bmoeller@acm.org> for
  preparing the fix.
  Fix for the attack described in the paper "Recovering OpenSSL
  ECDSA Nonces Using the FLUSH+RELOAD Cache Side-channel Attack"
  by Yuval Yarom and Naomi Benger. Details can be obtained from:
  http://eprint.iacr.org/2014/140
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-0160
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-0076
  (* Security fix *)
[:drunkdude]
n°1355948
wedgeant
Da penguin inside
Posté le 09-04-2014 à 10:06:31  profilanswer
[:koukouille:3]
n°1356891
cycojesus
Mèo Lười
Posté le 22-04-2014 à 07:27:41  profilanswer
Ceci n'est pas un œuf [:ouicertes]
Mon Apr 21 20:09:48 UTC 2014
l/libyaml-0.1.6-x86_64-1.txz:  Upgraded.
  This update fixes a heap overflow in URI escape parsing of YAML in Ruby,
  where a specially crafted string could cause a heap overflow leading to
  arbitrary code execution.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-2525
    https://www.ruby-lang.org/en/news/2014/03/29/heap-overflow-in-yaml-uri-escape-parsing-cve-2014-2525/
  (* Security fix *)
n/php-5.4.27-x86_64-1.txz:  Upgraded.
  This update fixes a security issue in the in the awk script detector
  which allows context-dependent attackers to cause a denial of service
  (CPU consumption) via a crafted ASCII file that triggers a large amount
  of backtracking.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-7345
  (* Security fix *)
[:fibbzh]
n°1356973
cycojesus
Mèo Lười
Posté le 23-04-2014 à 07:20:52  profilanswer
Mé oué on tem [:darkangel:2]
on tador [:otacon-yuiitsu:1]
on va gaver tou ton cor [:kastor94]
Tue Apr 22 17:31:48 UTC 2014
a/bash-4.3.011-x86_64-1.txz:  Upgraded.
a/gawk-4.1.1-x86_64-1.txz:  Upgraded.
a/grep-2.18-x86_64-1.txz:  Upgraded.
ap/vim-7.4.258-x86_64-1.txz:  Upgraded.
n/openssh-6.6p1-x86_64-2.txz:  Rebuilt.
  Fixed a bug with curve25519-sha256 that caused a key exchange failure in
  about 1 in 512 connection attempts.
xap/vim-gvim-7.4.258-x86_64-1.txz:  Upgraded.
[:princesse pipi]
n°1357010
wedgeant
Da penguin inside
Posté le 23-04-2014 à 12:32:25  profilanswer
[:koukouille:3]
n°1357557
cycojesus
Mèo Lười
Posté le 30-04-2014 à 10:59:02  profilanswer
Lors que tu bailles j' enfournes [:chiminiv9]
Tue Apr 29 23:35:59 UTC 2014
ap/screen-4.2.1-x86_64-1.txz:  Upgraded.
l/qt-4.8.6-x86_64-1.txz:  Upgraded.
xap/mozilla-firefox-29.0-x86_64-1.txz:  Upgraded.
  (* Security fix *)
xap/mozilla-thunderbird-24.5.0-x86_64-1.txz:  Upgraded.
  (* Security fix *)
[:texturelapins]
n°1358020
cycojesus
Mèo Lười
Posté le 09-05-2014 à 07:24:42  profilanswer
hilléèè [:masklinn]
Donnez-moi un A [:akilae]
Donnez-moi un D [:akilae]
Donnez-moi un L [:akilae]
Donnez-moi un N [:akilae]
Donnez-moi un EXTRA [:akilae]
Donnez-moi un ISOLINUX [:akilae]
Donnez-moi un KERNELS [:akilae]
Donnez-moi un USB-AND-PXE-INSTALLERS [:akilae]
T'mélanges et paf t'as la MAJie [:cetrio:3]
Fri May  9 01:47:42 UTC 2014
a/glibc-solibs-2.19-x86_64-1.txz:  Upgraded.
a/glibc-zoneinfo-2014b-noarch-1.txz:  Upgraded.
a/kernel-firmware-20140506git-noarch-1.txz:  Upgraded.
a/kernel-generic-3.14.3-x86_64-1.txz:  Upgraded.
a/kernel-huge-3.14.3-x86_64-1.txz:  Upgraded.
a/kernel-modules-3.14.3-x86_64-1.txz:  Upgraded.
d/binutils-2.24.51.0.3-x86_64-1.txz:  Upgraded.
d/gcc-4.8.2-x86_64-2.txz:  Rebuilt.
  Include libiberty.a since that's no longer in the binutils package.
d/gcc-g++-4.8.2-x86_64-2.txz:  Rebuilt.
d/gcc-gfortran-4.8.2-x86_64-2.txz:  Rebuilt.
d/gcc-gnat-4.8.2-x86_64-2.txz:  Rebuilt.
d/gcc-go-4.8.2-x86_64-2.txz:  Rebuilt.
d/gcc-java-4.8.2-x86_64-2.txz:  Rebuilt.
d/gcc-objc-4.8.2-x86_64-2.txz:  Rebuilt.
d/kernel-headers-3.14.3-x86-1.txz:  Upgraded.
d/oprofile-0.9.7-x86_64-5.txz:  Rebuilt.
k/kernel-source-3.14.3-noarch-1.txz:  Upgraded.
l/glibc-2.19-x86_64-1.txz:  Upgraded.
l/glibc-i18n-2.19-x86_64-1.txz:  Upgraded.
l/glibc-profile-2.19-x86_64-1.txz:  Upgraded.
n/libnftnl-1.0.1-x86_64-1.txz:  Added.
n/nftables-0.2-x86_64-1.txz:  Added.
extra/bash-completion/bash-completion-2.1-noarch-2.txz:  Rebuilt.
  Patched to fix an issue with bash-4.3.  Thanks to ponce.
[:ethnik]
n°1358029
wedgeant
Da penguin inside
Posté le 09-05-2014 à 10:07:18  profilanswer
[:koukouille:3]
n°1358198
cycojesus
Mèo Lười
Posté le 12-05-2014 à 11:35:29  profilanswer
A
Mais fais A
AAAAAAAAAAAAaaaa [:ex-floodeur:1]
Mon May 12 02:24:36 UTC 2014
l/seamonkey-solibs-2.26-x86_64-1.txz:  Upgraded.
xap/mozilla-firefox-29.0.1-x86_64-1.txz:  Upgraded.
xap/seamonkey-2.26-x86_64-1.tx:  Upgraded.
  (* Security fix *)
[:a03hegaz:5]
Slackware 9.0[slackware] Suppression de terminaux virtuels ?
!! Configuration reseaux, slackware 9 !!Installer slackware 9.0 par ftp (boot disquette)
[Pb] Installation new HDD sous slackware 8.0[RESOLU] Pb d'execution mysql sur slackware ...
Slackware 9 du pur bonheurMonter une partition NTFS sous linux (slackware 9.0)
Slackware 9.0 Finale OUTJe sens que je vais quitter Slackware (pas en serv)
Plus de sujets relatifs à : [SLACKWARE] du présent - 15.0
