5737 connectés
La 15.0 est là (en vrai !)
Les invités peuvent voter
 Page :   1  2  3  4  5  ..  60  61  62  ..  109  110  111  112  113  114
[SLACKWARE] du présent - 15.0
n°1345863
cycojesus
Mèo Lười
Posté le 03-10-2013 à 10:28:51  profilanswer
Le sale upgrâdé, le sed soupoudré, Getty de la Mancha cravachée [:loulou le marlou]
Bonne heure [:prophecie:5]
Thu Oct  3 02:07:13 UTC 2013
a/etc-14.1-x86_64-2.txz:  Rebuilt.
  Added /lib{,64} and /usr/lib{,64} paths to the top of ld.so.conf.
a/getty-ps-2.1.0b-x86_64-2.txz:  Rebuilt.
  Patched crash bug.  Thanks to mancha.
a/pkgtools-14.1-noarch-1.tgz:  Upgraded.
  In setup.80.make-bootdisk, also install an elilo bootloader on x86_64.
a/sed-4.2.2-x86_64-1.txz:  Upgraded.
ap/vim-7.4.050-x86_64-1.txz:  Upgraded.
d/rcs-5.9.0-x86_64-1.txz:  Upgraded.
l/mozilla-nss-3.15.2-x86_64-1.txz:  Upgraded.
  Upgraded to nss-3.15.2 and nspr-4.10.1.
xap/vim-gvim-7.4.050-x86_64-1.txz:  Upgraded.
[:youpiyop:1]
Chết rồi ! ✍ ⌥⌘ http://codeberg.org/gwh
n°1345867
wedgeant
Da penguin inside
Posté le 03-10-2013 à 11:35:41  profilanswer
[:buk':2]
Wedge#2487 @HS -#- PW: +∞ -#- Khaz-Modan/Boltiz @WoW
n°1346429
cycojesus
Mèo Lười
Posté le 15-10-2013 à 09:47:47  profilanswer
Boum, quand la voiture fait boum, tout avec elle fait boum et c'est la merde-eux [:king_ping]
Heureusement, ceci  [:4lkaline:5]
Mon Oct 14 22:09:17 UTC 2013
And with this batch of updates and fixes (clearing the rest of the
important stuff from the TODO list), we have arrived at Slackware 14.1
release candidate 1!  Please test and report any remaining issues.
UEFI (with the exception of Secure Boot, which will have to wait until
we have real hardware) should be fully implemented in the installer now,
which will detect and warn about common problems, set up the EFI System
Partition under /boot/efi, and install ELILO and a UEFI boot entry
automatically.  There's a new README_UEFI.TXT file with detailed
instructions for installing 64-bit Slackware on UEFI (32-bit won't
support native UEFI due to the mismatch between 64-bit UEFI firmware and
a 32-bit kernel, so Legacy BIOS will be the only way to install 32-bit
Slackware on UEFI).  Several useful netfilter and networking utilities
have been added (thanks to Robby Workman and /dev/rob0 for these).
With this batch of updates, everything should be considered frozen
(including the kernel) unless there's a good reason to change something.
Enjoy!  See you all for the release, hopefully soon.  :-)
a/aaa_base-14.1-x86_64-1.txz:  Upgraded.
a/aaa_elflibs-14.1-x86_64-3.txz:  Rebuilt.
a/cups-1.5.4-x86_64-3.txz:  Rebuilt.
  Use a newer backport of the USB quirks patch.  Thanks to mancha.
  Blacklist the usblp module just in case.
a/elilo-3.14-x86_64-4.txz:  Rebuilt.
  Added eliloconfig, a script to automatically set up elilo on the EFI
  System Partition and add a boot entry for it with efibootmgr.
a/gptfdisk-0.8.7-x86_64-1.txz:  Upgraded.
a/kernel-firmware-20131008git-noarch-1.txz:  Upgraded.
a/kernel-generic-3.10.16-x86_64-1.txz:  Upgraded.
a/kernel-huge-3.10.16-x86_64-1.txz:  Upgraded.
a/kernel-modules-3.10.16-x86_64-1.txz:  Upgraded.
a/lilo-24.0-x86_64-3.txz:  Rebuilt.
  In liloconfig script, suggest not installing LILO on UEFI.
a/logrotate-3.8.6-x86_64-1.txz:  Upgraded.
a/pkgtools-14.1-noarch-2.tgz:  Rebuilt.
  Removed obsolete makebootdisk script.
  Added an /sbin/makebootstick symlink for making a USB boot stick.
a/shadow-4.1.5.1-x86_64-2.txz:  Rebuilt.
  Updated crypt() patch.  Thanks to mancha.
a/sysvinit-scripts-2.0-noarch-16.txz:  Rebuilt.
  Clean up stale cron directories in /var/spool/cron.
  Create lock/run directories for LVM.
  Thanks to GazL.
  Mount cgroup controllers in subfolders.
  Thanks to Matteo Bernardini.
ap/diffutils-3.3-x86_64-1.txz:  Upgraded.
ap/mc-4.8.10-x86_64-2.txz:  Rebuilt.
  Upstream fix for crash when moving directories.
  Upstream fix for command line directory handling.
ap/powertop-2.4-x86_64-1.txz:  Upgraded.
ap/slackpkg-2.82.0-noarch-11.tgz:  Rebuilt.
  Verified and corrected the mirrors lists for x86 and x86_64.
  Changed version numbers from 14.0 to 14.1 in preparation for the upcoming
  Slackware 14.1 release.
  Corrected a manpage bug in the file-search section.
ap/tmux-1.8-x86_64-1.txz:  Added.
d/cmake-2.8.12-x86_64-1.txz:  Upgraded.
d/guile-2.0.9-x86_64-1.txz:  Upgraded.
d/kernel-headers-3.10.16-x86-1.txz:  Upgraded.
f/linux-howtos-20131011-noarch-1.txz:  Upgraded.
k/kernel-source-3.10.16-noarch-1.txz:  Upgraded.
kde/ark-4.10.5-x86_64-2.txz:  Rebuilt.
kde/calligra-2.7.3-x86_64-1.txz:  Upgraded.
kde/networkmanagement-0.9.0.9-x86_64-1.txz:  Upgraded.
kdei/calligra-l10n-bs-2.7.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-ca-2.7.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-cs-2.7.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-da-2.7.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-de-2.7.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-el-2.7.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-es-2.7.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-et-2.7.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-fi-2.7.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-fr-2.7.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-gl-2.7.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-hu-2.7.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-ia-2.7.3-noarch-1.txz:  Added.
kdei/calligra-l10n-it-2.7.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-kk-2.7.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-nb-2.7.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-nds-2.7.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-nl-2.7.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-pl-2.7.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-pt-2.7.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-pt_BR-2.7.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-ru-2.7.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-sk-2.7.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-sl-2.7.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-sv-2.7.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-tr-2.7.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-uk-2.7.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-zh_CN-2.7.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-zh_TW-2.7.3-noarch-1.txz:  Upgraded.
l/dconf-0.18.0-x86_64-1.txz:  Upgraded.
l/gc-7.2d-x86_64-1.txz:  Added.
  New dependency for guile.
l/gvfs-1.16.3-x86_64-2.txz:  Rebuilt.
l/libarchive-3.1.2-x86_64-1.txz:  Upgraded.
l/libevent-2.0.21-x86_64-1.txz:  Added.
l/libunistring-0.9.3-x86_64-1.txz:  Added.
n/ModemManager-1.0.0-x86_64-1.txz:  Upgraded.
n/NetworkManager-0.9.8.6-x86_64-1.txz:  Upgraded.
n/alpine-2.11-x86_64-1.txz:  Upgraded.
n/conntrack-tools-1.4.2-x86_64-1.txz:  Added.
n/ebtables-2.0.10-x86_64-1.txz:  Added.
n/epic5-1.1.6-x86_64-1.txz:  Upgraded.
n/gnupg-1.4.15-x86_64-1.txz:  Upgraded.
  Fixed possible infinite recursion in the compressed packet
  parser. [CVE-2013-4402]
  Protect against rogue keyservers sending secret keys.
  For more information, see:
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4402
  (* Security fix *)
n/gnupg2-2.0.22-x86_64-1.txz:  Upgraded.
  (* Security fix *)
n/gnutls-3.1.14-x86_64-1.txz:  Upgraded.
n/imapd-2.11-x86_64-1.txz:  Upgraded.
n/ipset-6.20-x86_64-1.txz:  Added.
n/iptables-1.4.20-x86_64-1.txz:  Upgraded.
n/lftp-4.4.10-x86_64-1.txz:  Upgraded.
n/libmbim-1.4.0-x86_64-1.txz:  Added.
n/libmnl-1.0.3-x86_64-1.txz:  Added.
n/libnetfilter_acct-1.0.2-x86_64-1.txz:  Added.
n/libnetfilter_conntrack-1.0.4-x86_64-1.txz:  Added.
n/libnetfilter_cthelper-1.0.0-x86_64-1.txz:  Added.
n/libnetfilter_cttimeout-1.0.0-x86_64-1.txz:  Added.
n/libnetfilter_log-1.0.1-x86_64-1.txz:  Added.
n/libnetfilter_queue-1.0.2-x86_64-1.txz:  Added.
n/libnfnetlink-1.0.1-x86_64-1.txz:  Added.
n/libqmi-1.4.0-x86_64-1.txz:  Added.
n/nfacct-1.0.1-x86_64-1.txz:  Added.
n/ntp-4.2.6p5-x86_64-4.txz:  Rebuilt.
  If the hardware clock is kept in localtime, save the time to the hardware
  clock after starting ntpd.  This prevents the kernel from saving the system
  time to the hardware clock every 11 minutes, which would cause the hardware
  clock to be off by the difference between localtime and UTC.
  Thanks to tux_dude.
n/openvpn-2.3.2-x86_64-1.txz:  Upgraded.
  Added configure option --enable-password-save.  Thanks to Mario.
n/php-5.4.20-x86_64-1.txz:  Upgraded.
n/rfkill-0.5-x86_64-1.txz:  Upgraded.
n/ulogd-2.0.2-x86_64-1.txz:  Added.
x/xauth-1.0.8-x86_64-1.txz:  Upgraded.
x/xbacklight-1.2.1-x86_64-1.txz:  Upgraded.
x/xcompmgr-1.1.6-x86_64-2.txz:  Upgraded.
x/xf86-input-evdev-2.8.2-x86_64-1.txz:  Upgraded.
x/xf86-video-r128-6.9.2-x86_64-1.txz:  Upgraded.
x/xf86-video-savage-2.3.7-x86_64-1.txz:  Upgraded.
x/xorg-server-1.14.3-x86_64-2.txz:  Rebuilt.
  Patched a use-after-free bug that can cause an X server crash or
  memory corruption.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4396
  (* Security fix *)
x/xorg-server-xephyr-1.14.3-x86_64-2.txz:  Rebuilt.
x/xorg-server-xnest-1.14.3-x86_64-2.txz:  Rebuilt.
x/xorg-server-xvfb-1.14.3-x86_64-2.txz:  Rebuilt.
xap/network-manager-applet-0.9.8.4-x86_64-1.txz:  Upgraded.
xap/rdesktop-1.8.0-x86_64-1.txz:  Upgraded.
xap/sane-1.0.24-x86_64-1.txz:  Upgraded.
  Upgraded to sane-backends-1.0.24.
xfce/exo-0.10.2-x86_64-2.txz:  Rebuilt.
  Fix URL handling to not reject magnet links.
  Thanks to Larry Hajali.
extra/tigervnc/tigervnc-1.1.0-x86_64-1.txz:  Added.
  Thanks to alienBOB.
extra/tightvnc/tightvnc-1.3.10-x86_64-1.txz:  Removed.
extra/xf86-video-fbdev/xf86-video-fbdev-0.4.4-x86_64-1.txz:  Upgraded.
isolinux/initrd.img:  Rebuilt.
kernels/*:  Upgraded.
testing/source/config-testing-3.4.66/*:  Upgraded.
usb-and-pxe-installers/usbboot.img:  Rebuilt.
[:dtc haha:5]
n°1346442
wedgeant
Da penguin inside
Posté le 15-10-2013 à 12:29:06  profilanswer
At last we will have revenge  [:matthiman:1]
n°1346473
regdub
Posté le 15-10-2013 à 19:52:44  profilanswer
[:arrgghh]
n°1346492
cycojesus
Mèo Lười
Posté le 16-10-2013 à 11:20:08  profilanswer
Quenelles en ficelle [:the real nerdz:2]
Comme du boudin saucissonné [:zho]
olé
Wed Oct 16 05:36:47 UTC 2013
Here are a few more updates and bugfixes.  The small networking utilities
should be safe upgrades (thanks to Luiz Gustavo).  I'd thought about Samba
4.1 before the rc (and some more afterwards), and after testing it here
without any issues decided we should try it out.  The Samba project is
known for very high quality releases, so I don't believe we'll be stung by
a .0 version here.  The kernels were rebuilt to fix a regression that
occurred when the 3.10.0 kernel changed CONFIG_PARAVIRT_GUEST to
CONFIG_HYPERVISOR_GUEST, which caused some previously included VMWare and
Hyper-V drivers to not be built.  These are the changed kernel options:
   HYPERVISOR_GUEST n -> y
  +FB_HYPERV n
  +HID_HYPERV_MOUSE m
  +HYPERV m
  +HYPERV_BALLOON m
  +HYPERV_NET m
  +HYPERV_STORAGE m
  +HYPERV_UTILS m
  +PARAVIRT n
  +VMWARE_BALLOON m
  +XEN_PRIVILEGED_GUEST n
Thanks to Victor Miasnikov for the bug report.
a/kernel-generic-3.10.16-x86_64-2.txz:  Rebuilt.
a/kernel-huge-3.10.16-x86_64-2.txz:  Rebuilt.
a/kernel-modules-3.10.16-x86_64-2.txz:  Rebuilt.
a/minicom-2.6.2-x86_64-1.txz:  Upgraded.
d/kernel-headers-3.10.16-x86-2.txz:  Rebuilt.
d/mercurial-2.7.2-x86_64-1.txz:  Upgraded.
k/kernel-source-3.10.16-noarch-2.txz:  Rebuilt.
l/mozilla-nss-3.15.2-x86_64-2.txz:  Rebuilt.
  Recompiled with NSS_ENABLE_ECC=1.
  Thanks to Janusz Dziemidowicz.
n/iproute2-3.10.0-x86_64-2.txz:  Rebuilt.
n/iptraf-ng-1.1.4-x86_64-1.txz:  Upgraded.
n/iputils-s20121221-x86_64-1.txz:  Upgraded.
n/mtr-0.85-x86_64-1.txz:  Upgraded.
n/samba-4.1.0-x86_64-1.txz:  Upgraded.
n/tftp-hpa-5.2-x86_64-1.txz:  Upgraded.
tcl/tcl-8.6.1-x86_64-1.txz:  Upgraded.
  Thanks to fskmh.
tcl/tk-8.6.1-x86_64-1.txz:  Upgraded.
  Thanks to fskmh.
kernels/*:  Rebuilt.
[:mom boucher]  [:jonas]
n°1346510
cycojesus
Mèo Lười
Posté le 17-10-2013 à 09:27:00  profilanswer
Y reste des miettes de pâté après t'auras ta tartine [:double c]
Thu Oct 17 05:21:47 UTC 2013
kernels/memtest/memtest:  Upgraded.
  Upgraded to memtest86+-5.01.
Thu Oct 17 02:13:05 UTC 2013
a/elilo-3.14-x86_64-5.txz:  Rebuilt.
  In eliloconfig:
  If old Slackware boot entries are found, offer to remove them.
  Display the new boot entry after installing it.
  Use backslashes in the loader path to efibootmgr.  Thanks to John Yost.
[:fred999]
n°1346566
kisscoolz
Posté le 17-10-2013 à 20:06:30  profilanswer
Bonsoir,
Je me retrouve avec un petit couac sur mon portable.
J'ai groupé ma liaison filaire et ma connexion wifi avec du bonding. Ca marche sauf quand je sors du mode "suspendre".
Wicd ne gère pas automatiquement le bonding, en manuel pas de problème. Avec les scritps je vois pas ce que je dois toucher pour que ca se reconnecte tout seul.
Quelqu'un aurait une idée de comment faire ? C'est sur une slackware 13.37
Gracias
Message édité par kisscoolz le 18-10-2013 à 14:14:15
n°1346595
cycojesus
Mèo Lười
Posté le 18-10-2013 à 10:27:13  profilanswer
. [:douchebag forever]
Fri Oct 18 02:51:29 UTC 2013
l/libtiff-3.9.7-x86_64-1.txz:  Upgraded.
  Patched overflows, crashes, and out of bounds writes.
  Thanks to mancha for the backported patches.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-2088
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-2113
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-4447
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-4564
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-1960
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-1961
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4231
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4232
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4244
  (* Security fix *)
n/ModemManager-1.0.0-x86_64-2.txz:  Rebuilt.
  Recompiled using --with-polkit=no.
n/NetworkManager-0.9.8.8-x86_64-1.txz:  Upgraded.
n/openssh-6.3p1-x86_64-1.txz:  Upgraded.
n/yptools-2.14-x86_64-2.txz:  Rebuilt.
  Updated yp-tools crypt() patch.  Thanks to mancha.
. [:dovakor:5]
n°1346617
wedgeant
Da penguin inside
Posté le 18-10-2013 à 11:56:49  profilanswer
[:riot_]
n°1346670
cycojesus
Mèo Lười
Posté le 19-10-2013 à 09:28:02  profilanswer
sécurise ton Quenelle [:salade man]
Au chaud [:guigui]
Sat Oct 19 03:42:15 UTC 2013
a/kernel-generic-3.10.17-x86_64-1.txz:  Upgraded.
a/kernel-huge-3.10.17-x86_64-1.txz:  Upgraded.
a/kernel-modules-3.10.17-x86_64-1.txz:  Upgraded.
ap/hplip-3.13.10-x86_64-1.txz:  Upgraded.
  This fixes a polkit race condition that could allow local users to bypass
  intended access restrictions.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4325
  (* Security fix *)
d/kernel-headers-3.10.17-x86-1.txz:  Upgraded.
k/kernel-source-3.10.17-noarch-1.txz:  Upgraded.
[:paydaybear:2]
n°1346730
wedgeant
Da penguin inside
Posté le 21-10-2013 à 09:35:38  profilanswer
Mais tu les trouves où ces smileys ? [:rofl] [:rofl] [:rofl]
n°1346762
cycojesus
Mèo Lười
Posté le 21-10-2013 à 22:51:35  profilanswer
C'est tout cloué en place [:ftb91]  [:rosette de lyon]  [:kaman:1]
des quenelles [:cisco11:3]
des sapes [:bisounours58:1]
 [:cetrio:4]
Mon Oct 21 07:30:10 UTC 2013
Looks like we get a Slackware 14.1 release candidate 2...  but things are
pretty much nailed down at this point.  Please test and report any last
minute issues!
a/kernel-generic-3.10.17-x86_64-2.txz:  Rebuilt.
a/kernel-huge-3.10.17-x86_64-2.txz:  Rebuilt.
a/kernel-modules-3.10.17-x86_64-2.txz:  Rebuilt.
a/sharutils-4.14-x86_64-1.txz:  Upgraded.
ap/slackpkg-2.82.0-noarch-12.tgz:  Rebuilt.
  Corrected typos in the slackpkg man page.
  Thanks to sycamorex.
d/gcc-4.8.2-x86_64-1.txz:  Upgraded.
d/gcc-g++-4.8.2-x86_64-1.txz:  Upgraded.
d/gcc-gfortran-4.8.2-x86_64-1.txz:  Upgraded.
d/gcc-gnat-4.8.2-x86_64-1.txz:  Upgraded.
d/gcc-go-4.8.2-x86_64-1.txz:  Upgraded.
d/gcc-java-4.8.2-x86_64-1.txz:  Upgraded.
d/gcc-objc-4.8.2-x86_64-1.txz:  Upgraded.
d/kernel-headers-3.10.17-x86-2.txz:  Rebuilt.
d/libtool-2.4.2-x86_64-2.txz:  Rebuilt.
  Rebuilt to update GCC version, which is detected at compile time.
k/kernel-source-3.10.17-noarch-2.txz:  Rebuilt.
kde/kdelibs-4.10.5-x86_64-2.txz:  Rebuilt.
  Reverted three upstream commits which (although technically correct) have
  the effect of causing KDE to display the wrong icons in some cases.
  Thanks to alienBOB.
l/qt-4.8.5-x86_64-2.txz:  Rebuilt.
  Adjusted the SlackBuild to make sure that libwebcore (which is used
  internally for the Qt build) doesn't end up in QtWebKit.pc.
n/mutt-1.5.22-x86_64-1.txz:  Upgraded.
  Thanks to Markus Reichelt for the updates to the ./configure options.
n/samba-4.1.0-x86_64-2.txz:  Rebuilt.
  Added symlinks for libtalloc.so and libpytalloc-util.so.
  Thanks to Adis Nezirovic.
xap/MPlayer-1.1_20130819-x86_64-2.txz:  Rebuilt.
  Added a patch to fix subtitles in the case where MPlayer is recompiled
  on a system that has libass.  Thanks to Marin Glibic.
xap/rdesktop-1.8.0-x86_64-2.txz:  Rebuilt.
  Patched to fix crash with -P and/or -N.
  Thanks to mancha.
kernels/*:  Rebuilt.
[:ethnik:3]  [:maestro fantastico:2]
n°1346772
wedgeant
Da penguin inside
Posté le 22-10-2013 à 09:42:37  profilanswer
[:am73]
n°1346773
cycojesus
Mèo Lười
Posté le 22-10-2013 à 09:53:40  profilanswer
et plutôt 2 fois qu'1 [:woods11:1]
l'était pas chiante cette pub [:enora malagreluche]
Tue Oct 22 03:06:58 UTC 2013
x/mesa-9.1.7-x86_64-1.txz:  Upgraded.
Mon Oct 21 23:34:20 UTC 2013
a/usb_modeswitch-2.0.1-x86_64-1.txz:  Upgraded.
[:klm]  [:woods11]
n°1346833
cycojesus
Mèo Lười
Posté le 23-10-2013 à 10:25:46  profilanswer
des bons fruits [:the bloodhound gang:2]
Tue Oct 22 21:29:12 UTC 2013
t/transfig-3.2.5e-x86_64-2.txz:  Rebuilt.
  Fixed package permissions.  Thanks to a4z.
t/xfig-3.2.5c-x86_64-2.txz:  Rebuilt.
[:ethnik]
n°1346838
wedgeant
Da penguin inside
Posté le 23-10-2013 à 11:58:08  profilanswer
C'est bon les fig  [:sir_knumskull]
n°1346872
cycojesus
Mèo Lười
Posté le 24-10-2013 à 08:08:35  profilanswer
Mangez des légumes [:toutoune25]
Buvez des cucurbitacés [:pdbzombifiay:2]
Pulvérisez une fenêtre [:lil lyza]
Thu Oct 24 01:22:57 UTC 2013
a/kernel-generic-3.10.17-x86_64-3.txz:  Rebuilt.
a/kernel-huge-3.10.17-x86_64-3.txz:  Rebuilt.
a/kernel-modules-3.10.17-x86_64-3.txz:  Rebuilt.
a/pciutils-3.2.0-x86_64-1.txz:  Upgraded.
  Thanks to J�r�me Pinot.
a/usbutils-007-x86_64-1.txz:  Upgraded.
ap/acct-6.5.4-x86_64-2.txz:  Rebuilt.
  Patched to fix broken sa output.  Thanks to ktreadway.
d/kernel-headers-3.10.17-x86-3.txz:  Rebuilt.
k/kernel-source-3.10.17-noarch-3.txz:  Rebuilt.
n/lftp-4.4.9-x86_64-1.txz:  Upgraded.
  Reverted to lftp-4.4.9 due to a regression in the mirror function.
kernels/*:  Rebuilt.
  Make CONFIG_USB_UHCI_HCD modular in the huge kernels.
[:g-a-s:2]
n°1346883
wedgeant
Da penguin inside
Posté le 24-10-2013 à 11:20:01  profilanswer
T'as le Pinot qui frétille [:hahaguy]
n°1346958
cycojesus
Mèo Lười
Posté le 26-10-2013 à 09:08:13  profilanswer
K'est SCIM turlupine [:t_faz:1]
Fri Oct 25 22:05:38 UTC 2013
x/scim-1.4.14-x86_64-4.txz:  Rebuilt.
  Put the Qt module in the proper inputmethods directory, and enable the
  plugin in /etc/profile.d/scim.{csh,sh}.  Thanks to guanx.
x/xterm-297-x86_64-1.txz:  Upgraded.
[:brischri:5]
n°1347030
wedgeant
Da penguin inside
Posté le 28-10-2013 à 09:11:25  profilanswer
[:riot_]
n°1347043
cycojesus
Mèo Lười
Posté le 28-10-2013 à 11:12:10  profilanswer
Nvidia c le mal sal ki te pouri ton retour de vacansse paske t'avais rebooté la machine depuis perpète et ke lé poilots son plu ajour du kou [:trollol]
Mon Oct 28 06:03:16 UTC 2013
Slackware 14.1 release candidate 3.  Last call.  :)
a/grub-2.00-x86_64-2.txz:  Rebuilt.
  Applied upstream patch to terminate EFI several times.  This is a workaround
  for buggy UEFI implementations.  Thanks to xflow7.
a/lilo-24.0-x86_64-4.txz:  Rebuilt.
  Test for Windows partitions better in liloconfig.
  Thanks to slacktroll for the bug report.
  Add commented out "compact" to lilo.conf.
a/sysvinit-scripts-2.0-noarch-17.txz:  Rebuilt.
  Check for devtmpfs (not tmpfs) before starting udev.
  Remove obsolete reference to rc.optical-symlinks in rc.M.
  Thanks to GazL.
ap/pm-utils-1.4.1-x86_64-5.txz:  Rebuilt.
  Set all the hooks in the power.d directory to non-executable.  This package
  shouldn't be playing games with the user's settings.  Thanks to jtsn.
l/poppler-0.24.3-x86_64-1.txz:  Upgraded.
n/gnutls-3.1.15-x86_64-1.txz:  Upgraded.
  Fixed an issue where a server that returns more 4 DANE entries could corrupt
  the memory of a requesting client.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4466
  (* Security fix *)
xap/xine-ui-0.99.7-x86_64-1.txz:  Upgraded.
  Fixed file open dialog with a patch from BLFS.
  Thanks to mats_b_tegner.
  Don't list the USB installer partitions in the FAT/NTFS partition menu.
touche entrée => culé [:atchaa:5]
Message édité par cycojesus le 28-10-2013 à 11:37:14
n°1347083
cycojesus
Mèo Lười
Posté le 29-10-2013 à 07:07:28  profilanswer
Le Caligula du gras viens poser ses pieds gras dans le gras du gras [:mika94400:1]
ha [:psymon:1]
Mon Oct 28 22:08:47 UTC 2013
kde/calligra-2.7.4-x86_64-1.txz:  Upgraded.
kdei/calligra-l10n-bs-2.7.4-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-ca-2.7.4-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-ca@valencia-2.7.4-noarch-1.txz:  Added.
kdei/calligra-l10n-cs-2.7.4-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-da-2.7.4-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-de-2.7.4-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-el-2.7.4-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-es-2.7.4-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-et-2.7.4-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-fi-2.7.4-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-fr-2.7.4-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-gl-2.7.4-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-hu-2.7.4-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-ia-2.7.4-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-it-2.7.4-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-kk-2.7.4-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-nb-2.7.4-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-nds-2.7.4-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-nl-2.7.4-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-pl-2.7.4-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-pt-2.7.4-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-pt_BR-2.7.4-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-ru-2.7.4-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-sk-2.7.4-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-sl-2.7.4-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-sv-2.7.4-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-tr-2.7.4-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-uk-2.7.4-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-zh_CN-2.7.4-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-zh_TW-2.7.4-noarch-1.txz:  Upgraded.
[:dok38:3]
n°1347133
cycojesus
Mèo Lười
Posté le 29-10-2013 à 14:40:41  profilanswer
Lw saview-tu ? Le dis est in organe qui ne sert à rien. [:dovakor:4]
Tue Oct 29 05:03:04 UTC 2013
a/elilo-3.14-x86_64-6.txz:  Rebuilt.
  Add some error messages to eliloconfig.
  Thanks to Nille_kungen.
a/mkinitrd-1.4.8-x86_64-2.txz:  Rebuilt.
  In mkinitrd_command_generator.sh, if a USB keyboard is detected add the
  hid_generic module (in addition to usbhid).  Recent kernels need this.
  Thanks to mario.
xap/xscreensaver-5.22-x86_64-2.txz:  Rebuilt.
  Recompiled to pick up the GPL text (which is used by several screensavers)
  from libX11's docs.  After the last libX11 upgrade the old location was no
  longer valid.
[:x-bar]
n°1347135
wedgeant
Da penguin inside
Posté le 29-10-2013 à 14:41:36  profilanswer
Ca sent bon  [:kapitan wurst:4]
n°1347176
cycojesus
Mèo Lười
Posté le 30-10-2013 à 07:28:03  profilanswer
25-1 [:jobi joba_]
Tue Oct 29 15:06:41 UTC 2013
xap/mozilla-firefox-24.1.0esr-x86_64-1.txz:  Upgraded.
[:tuoni:2]
n°1347305
cycojesus
Mèo Lười
Posté le 01-11-2013 à 08:32:46  profilanswer
Un peu de gloubiboulga pour la route [:smilees:4]
Fri Nov  1 02:06:40 UTC 2013
ap/dc3dd-7.1.614-x86_64-1.txz:  Upgraded.
kde/kdevelop-4.5.2-x86_64-1.txz:  Upgraded.
kde/kdevelop-php-1.5.2-x86_64-1.txz:  Upgraded.
kde/kdevelop-php-docs-1.5.2-x86_64-1.txz:  Upgraded.
kde/kdevplatform-1.5.2-x86_64-1.txz:  Upgraded.
kde/lskat-4.10.5-x86_64-2.txz:  Rebuilt.
  Fixed a typo in slack-desc.
n/gnutls-3.1.16-x86_64-1.txz:  Upgraded.
n/network-scripts-14.1-noarch-2.txz:  Rebuilt.
  Fixed a typo in netconfig.
  Don't produce a flash of screen output when scanning for LVM volumes
  after completing the package installation.
[:matmoutong:1]
n°1347372
cycojesus
Mèo Lười
Posté le 03-11-2013 à 13:49:24  profilanswer
__ _____ ____________ _ __ ___ _ __ ! [:oscar le connard:2]
Sun Nov  3 06:07:52 UTC 2013
xap/mozilla-thunderbird-24.1.0-x86_64-1.txz:  Upgraded.
  This release contains security fixes and improvements.
    http://www.mozilla.org/security/known-vulnerabilities/thunderbird.html
  (* Security fix *)
___ _ ___ ? [:kinik]
n°1347396
wedgeant
Da penguin inside
Posté le 04-11-2013 à 08:59:21  profilanswer
[:wark0]
n°1347470
cycojesus
Mèo Lười
Posté le 05-11-2013 à 15:10:30  profilanswer
meuh [:moutrave]
Mon Nov  4 02:38:43 UTC 2013
testing/source/config-testing-3.12/*:  Added.
[:sophiste]  [:sophiste:3]
n°1347471
wedgeant
Da penguin inside
Posté le 05-11-2013 à 15:23:13  profilanswer
[:transparency]
n°1347489
Col Hanzap​last
Jurassic geek. Vive le cobol !
Posté le 06-11-2013 à 08:28:43  profilanswer
http://forum-images.hardware.fr/images/perso/1/richardjouir.gif
Message édité par Col Hanzaplast le 06-11-2013 à 08:29:47
" Il n'y a aucune chance pour que l'iPhone s'attribue une part de marché significative. Aucune chance. " (Steve Ballmer 2007)
n°1347608
cycojesus
Mèo Lười
Posté le 08-11-2013 à 07:16:38  profilanswer
sâches que ton week-end est mort [:xqwzts:1]
Et bon appétit bien sûr ! [:robuchon]
Mon Nov  4 17:08:47 UTC 2013
Slackware 14.1 x86_64 stable is released!
It's been another interesting release cycle here at Slackware bringing
new features like support for UEFI machines, updated compilers and
development tools, the switch from MySQL to MariaDB, and many more
improvements throughout the system.  Thanks to the team, the upstream
developers, the dedicated Slackware community, and everyone else who
pitched in to help make this release a reality.
The ISOs are off to be replicated, a 6 CD-ROM 32-bit set and a dual-sided
32-bit/64-bit x86/x86_64 DVD.  Please consider supporting the Slackware
project by picking up a copy from store.slackware.com.  We're taking
pre-orders now, and offer a discount if you sign up for a subscription.
Have fun!  :-)
[:_gwinruz]  [:hunters:1]
n°1347624
regdub
Posté le 08-11-2013 à 10:38:19  profilanswer
[:caudacien:5]
 [:_gwinruz]
n°1347625
gui42
Posté le 08-11-2013 à 11:03:45  profilanswer
:love:  :bounce:  :love:
Merci à P.atrick
 :sweat:
 :sleep:  :non:
n°1347627
wedgeant
Da penguin inside
Posté le 08-11-2013 à 11:26:44  profilanswer
[:dovakor:2]
n°1347665
agentsteel
Posté le 08-11-2013 à 20:16:17  profilanswer
toujours pas de systemd?  [:grozny gaud]
Message édité par agentsteel le 08-11-2013 à 20:17:01
http://agentoss.wordpress.com/
n°1347687
Col Hanzap​last
Posté le 09-11-2013 à 19:28:55  profilanswer
VirtualBox 4.3.2 et Slack 14.1 64bits: Kernel Panic en bootant l'image ISO.  :heink:
L'avantage de planter dès le départ c'est qu'on a pas encore modifié l'ancienne installation, on peut donc repartir sur celle-ci discrètement comme si on n'avait touché à rien...  [:lefab:5]
n°1348112
cycojesus
Mèo Lười
Posté le 19-11-2013 à 10:06:30  profilanswer
P.at prends soin de ne pas laisser el topAc des cendres dans le tréfonds [:tombig:3]
de la Magie il pousse [:zzozo:2]
Mon Nov 18 20:52:16 UTC 2013
l/seamonkey-solibs-2.22-x86_64-1.txz:  Upgraded.
n/openssh-6.4p1-x86_64-1.txz:  Upgraded.
  sshd(8): fix a memory corruption problem triggered during rekeying
  when an AES-GCM cipher is selected.
    http://www.openssh.com/txt/gcmrekey.adv
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4548
  (* Security fix *)
n/php-5.4.22-x86_64-1.txz:  Upgraded.
  This is a bugfix release.
n/samba-4.1.1-x86_64-1.txz:  Upgraded.
  This update fixes two security issues:
  * Samba versions 3.2.0 and above do not check the underlying file or
    directory ACL when opening an alternate data stream.
  * In setups which provide ldap(s) and/or https services, the private key
    for SSL/TLS encryption might be world readable.  This typically happens
    in active directory domain controller setups.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4475
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4476
  (* Security fix *)
  Added tdb.h, tdb.pc, and a libtdb.so symlink.  Thanks to Matteo Bernardini.
xap/mozilla-firefox-25.0.1-x86_64-1.txz:  Upgraded.
    http://www.mozilla.org/security/known-vulnerabilities/firefox.html
  (* Security fix *)
xap/seamonkey-2.22-x86_64-1.txz:  Upgraded.
  This update contains security fixes and improvements.
    http://www.mozilla.org/security/known-vulnerabilities/seamonkey.html
  (* Security fix *)
[:bilderberg:1]
n°1348130
Posté le 19-11-2013 à 13:45:45  answer
Faudrait avoir l’avis de Patrick.
n°1348133
wedgeant
Da penguin inside
Posté le 19-11-2013 à 14:26:58  profilanswer
La dernière fois qu'il en a parlé c'était pour dire que c'était d'la merde  [:coffe]
Slackware 9.0[slackware] Suppression de terminaux virtuels ?
!! Configuration reseaux, slackware 9 !!Installer slackware 9.0 par ftp (boot disquette)
[Pb] Installation new HDD sous slackware 8.0[RESOLU] Pb d'execution mysql sur slackware ...
Slackware 9 du pur bonheurMonter une partition NTFS sous linux (slackware 9.0)
Slackware 9.0 Finale OUTJe sens que je vais quitter Slackware (pas en serv)
Plus de sujets relatifs à : [SLACKWARE] du présent - 15.0
