3810 connectés
La 15.0 est là (en vrai !)
Les invités peuvent voter
 Page :   1  2  3  4  5  ..  55  56  57  ..  109  110  111  112  113  114
[SLACKWARE] du présent - 15.0
n°1329009
cycojesus
Mèo Lười
Posté le 20-01-2013 à 14:23:09  profilanswer
Das ist ein beugfix reülĩze, bug was fixed [:swimm3r:1]
Sun Jan 20 07:50:53 UTC 2013
xap/mozilla-firefox-18.0.1-x86_64-1.txz:  Upgraded.
  This is a bugfix release.
Das ist all [:m4u]
Chết rồi ! ✍ ⌥⌘ http://codeberg.org/gwh
n°1329045
wedgeant
Da penguin inside
Posté le 21-01-2013 à 09:22:07  profilanswer
Bugs shall not pass !
   [:ogratte:4]
Wedge#2487 @HS -#- PW: +∞ -#- Khaz-Modan/Boltiz @WoW
n°1329206
cycojesus
Mèo Lười
Posté le 22-01-2013 à 09:33:31  profilanswer
Y'en a qu'on essayé, y z'ont eu des problèmes [:haha dead:4]
Mon Jan 21 22:46:22 UTC 2013
l/seamonkey-solibs-2.15.1-x86_64-1.txz:  Upgraded.
xap/seamonkey-2.15.1-x86_64-1.txz:  Upgraded.
[:l2wic:4]
n°1329256
cycojesus
Mèo Lười
Posté le 23-01-2013 à 06:50:08  profilanswer
Gentlemen, start your axes [:dovakor_:1]
Tue Jan 22 23:40:16 UTC 2013
ap/hplip-3.12.11-x86_64-1.txz:  Upgraded.
ap/mysql-5.5.29-x86_64-1.txz:  Upgraded.
  Upgraded to the latest upstream version to fix security issues and provide
  other bug fixes and improvements.  Note that some of the changes may
  possibly introduce incompatibilities with the previous package.
  (* Security fix *)
n/php-5.4.11-x86_64-1.txz:  Upgraded.
[:4lkaline:3]
n°1329260
wedgeant
Da penguin inside
Posté le 23-01-2013 à 09:44:42  profilanswer
Et je patch, et tu patch, et nous patchons [:riot_]
n°1330121
cycojesus
Mèo Lười
Posté le 07-02-2013 à 00:49:57  profilanswer
La hype frappe [:bobbyfrasier:2]
Dérape [:kapitan wurst]
Ton bout de fromage te rape [:djokochut:4]
Wed Feb  6 07:14:25 UTC 2013
a/sharutils-4.13.3-x86_64-1.txz:  Upgraded.
ap/hplip-3.12.11-x86_64-1.txz:  Rebuilt.
  Recompiled with --enable-cups-ppd-install.  Thanks to guanx.
ap/moc-2.5.0_beta1-x86_64-1.txz:  Upgraded.
d/llvm-3.2-x86_64-2.txz:  Rebuilt.
  Removed dependency on GCC include files, and cleaned up some other paths.
  Thanks to Heinz Wiesinger.
d/make-3.82-x86_64-4.txz:  Rebuilt.
  Applied patch containing upstream bugfixes.
l/gnu-efi-3.0s-x86_64-1.txz:  Added.
l/seamonkey-solibs-2.15.2-x86_64-1.txz:  Upgraded.
l/taglib-1.8-x86_64-1.txz:  Upgraded.
n/dhcp-4.2.5-x86_64-1.txz:  Upgraded.
n/dhcpcd-5.6.6-x86_64-1.txz:  Upgraded.
n/iproute2-3.6.0-x86_64-1.txz:  Upgraded.
n/iptables-1.4.17-x86_64-1.txz:  Upgraded.
n/nmap-6.25-x86_64-1.txz:  Upgraded.
xap/seamonkey-2.15.2-x86_64-1.txz:  Upgraded.
xap/mozilla-firefox-18.0.2-x86_64-1.txz:  Upgraded.
T'y comprends 'ap [:hust_]
n°1330133
wedgeant
Da penguin inside
Posté le 07-02-2013 à 09:27:34  profilanswer
[:sud_conscient]  [:sud_conscient:1]  [:sud_conscient:2]
n°1330165
el_barbone
too old for this shit ...
Posté le 07-02-2013 à 14:30:53  profilanswer
[:koukouille:3]
En théorie, la théorie et la pratique sont identiques, en pratique, non.
n°1330223
cycojesus
Mèo Lười
Posté le 08-02-2013 à 10:15:07  profilanswer
L'ami y'a l'bout qui bouge
Genre rouge [:skullix:3]
Dans ta soupe de courge  [:hahalloween]
Fri Feb  8 03:57:05 UTC 2013
a/elilo-3.14-x86_64-1.txz:  Added.
d/llvm-3.2-x86_64-3.txz:  Rebuilt.
  Fixed a few places where lib64 was hardcoded regardless of $ARCH.
l/sdl-1.2.15-x86_64-1.txz:  Upgraded.
  Upgraded to SDL-1.2.15, SDL_image-1.2.12, SDL_mixer-1.2.12,
  SDL_net-1.2.8, and SDL_ttf-2.0.11.
  Patched resizing and mouse clicking bugs.
n/curl-7.29.0-x86_64-1.txz:  Upgraded.
  When negotiating SASL DIGEST-MD5 authentication, the function
  Curl_sasl_create_digest_md5_message() uses the data provided from the
  server without doing the proper length checks and that data is then
  appended to a local fixed-size buffer on the stack.  This vulnerability
  can be exploited by someone who is in control of a server that a libcurl
  based program is accessing with POP3, SMTP or IMAP.  For applications
  that accept user provided URLs, it is also thinkable that a malicious
  user would feed an application with a URL to a server hosting code
  targeting this flaw.
  Affected versions: curl 7.26.0 to and including 7.28.1
  For more information, see:
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-0249
  (* Security fix *)
[:darkbit:3]
n°1330366
cycojesus
Mèo Lười
Posté le 10-02-2013 à 09:36:50  profilanswer
Get it, elle est bonne [:youpiyop:1]
Sat Feb  9 21:45:56 UTC 2013
a/openssl-solibs-1.0.1d-x86_64-1.txz:  Upgraded.
  (* Security fix *)
l/phonon-gstreamer-4.6.3-x86_64-1.txz:  Upgraded.
n/openssl-1.0.1d-x86_64-1.txz:  Upgraded.
    Make the decoding of SSLv3, TLS and DTLS CBC records constant time.
  This addresses the flaw in CBC record processing discovered by
  Nadhem Alfardan and Kenny Paterson. Details of this attack can be found
  at: http://www.isg.rhul.ac.uk/tls/
  Thanks go to Nadhem Alfardan and Kenny Paterson of the Information
  Security Group at Royal Holloway, University of London
  (www.isg.rhul.ac.uk) for discovering this flaw and Adam Langley and
  Emilia K�sper for the initial patch.
  (CVE-2013-0169)
  [Emilia K�sper, Adam Langley, Ben Laurie, Andy Polyakov, Steve Henson]
    Fix flaw in AESNI handling of TLS 1.2 and 1.1 records for CBC mode
  ciphersuites which can be exploited in a denial of service attack.
  Thanks go to and to Adam Langley <agl@chromium.org> for discovering
  and detecting this bug and to Wolfgang Ettlinger
  <wolfgang.ettlinger@gmail.com> for independently discovering this issue.
  (CVE-2012-2686)
  [Adam Langley]
    Return an error when checking OCSP signatures when key is NULL.
  This fixes a DoS attack. (CVE-2013-0166)
  [Steve Henson]
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-2686
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-0166
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-0169
  (* Security fix *)
[:klm]
n°1330435
wedgeant
Da penguin inside
Posté le 11-02-2013 à 09:44:57  profilanswer
[:crapulax]  [:sud_conscient:4]  [:iryngael:4]
n°1330610
cycojesus
Mèo Lười
Posté le 12-02-2013 à 11:30:17  profilanswer
Assieds-toi ici petit [:sid sidious:1]
Ceci est pour ta face [:speedfightor]
Tue Feb 12 02:34:07 UTC 2013
a/elilo-3.14-x86_64-2.txz:  Rebuilt.
  Fixed file ownerships on elilo-ia{32,64}.efi.
a/openssl-solibs-1.0.1e-x86_64-1.txz:  Upgraded.
ap/lm_sensors-3.3.3-x86_64-1.txz:  Upgraded.
kde/amarok-2.7.0-x86_64-1.txz:  Upgraded.
kde/analitza-4.10.0-x86_64-1.txz:  Upgraded.
kde/ark-4.10.0-x86_64-1.txz:  Upgraded.
kde/audiocd-kio-4.10.0-x86_64-1.txz:  Added.
kde/blinken-4.10.0-x86_64-1.txz:  Upgraded.
kde/bluedevil-1.3-x86_64-1.txz:  Upgraded.
kde/bomber-4.10.0-x86_64-1.txz:  Added.
kde/bovo-4.10.0-x86_64-1.txz:  Added.
kde/calligra-2.6.0-x86_64-1.txz:  Upgraded.
kde/cantor-4.10.0-x86_64-1.txz:  Upgraded.
kde/dragon-4.10.0-x86_64-1.txz:  Added.
kde/filelight-4.10.0-x86_64-1.txz:  Upgraded.
kde/granatier-4.10.0-x86_64-1.txz:  Added.
kde/gwenview-4.10.0-x86_64-1.txz:  Upgraded.
kde/juk-4.10.0-x86_64-1.txz:  Added.
kde/kaccessible-4.10.0-x86_64-1.txz:  Upgraded.
kde/kactivities-4.10.0-x86_64-1.txz:  Upgraded.
kde/kajongg-4.10.0-x86_64-1.txz:  Added.
kde/kalgebra-4.10.0-x86_64-1.txz:  Upgraded.
kde/kalzium-4.10.0-x86_64-1.txz:  Upgraded.
kde/kamera-4.10.0-x86_64-1.txz:  Upgraded.
kde/kanagram-4.10.0-x86_64-1.txz:  Upgraded.
kde/kapman-4.10.0-x86_64-1.txz:  Added.
kde/kate-4.10.0-x86_64-1.txz:  Upgraded.
kde/katomic-4.10.0-x86_64-1.txz:  Added.
kde/kblackbox-4.10.0-x86_64-1.txz:  Added.
kde/kblocks-4.10.0-x86_64-1.txz:  Added.
kde/kbounce-4.10.0-x86_64-1.txz:  Added.
kde/kbreakout-4.10.0-x86_64-1.txz:  Added.
kde/kbruch-4.10.0-x86_64-1.txz:  Upgraded.
kde/kcalc-4.10.0-x86_64-1.txz:  Upgraded.
kde/kcharselect-4.10.0-x86_64-1.txz:  Upgraded.
kde/kcolorchooser-4.10.0-x86_64-1.txz:  Upgraded.
kde/kde-base-artwork-4.10.0-x86_64-1.txz:  Added.
kde/kde-baseapps-4.10.0-x86_64-1.txz:  Upgraded.
kde/kde-runtime-4.10.0-x86_64-1.txz:  Upgraded.
kde/kde-wallpapers-4.10.0-noarch-1.txz:  Upgraded.
kde/kde-workspace-4.10.0-x86_64-1.txz:  Upgraded.
kde/kdeadmin-4.10.0-x86_64-1.txz:  Upgraded.
kde/kdeartwork-4.10.0-x86_64-1.txz:  Upgraded.
kde/kdegames-4.8.5-x86_64-1.txz:  Removed.
kde/kdegraphics-mobipocket-4.10.0-x86_64-1.txz:  Upgraded.
kde/kdegraphics-strigi-analyzer-4.10.0-x86_64-1.txz:  Upgraded.
kde/kdegraphics-thumbnailers-4.10.0-x86_64-1.txz:  Upgraded.
kde/kdelibs-4.10.0-x86_64-1.txz:  Upgraded.
kde/kdemultimedia-4.8.5-x86_64-1.txz:  Removed.
kde/kdenetwork-4.10.0-x86_64-1.txz:  Upgraded.
kde/kdepim-4.10.0-x86_64-1.txz:  Upgraded.
kde/kdepim-runtime-4.10.0-x86_64-1.txz:  Upgraded.
kde/kdepimlibs-4.10.0-x86_64-1.txz:  Upgraded.
kde/kdeplasma-addons-4.10.0-x86_64-1.txz:  Upgraded.
kde/kdesdk-4.10.0-x86_64-1.txz:  Upgraded.
kde/kdetoys-4.10.0-x86_64-1.txz:  Upgraded.
kde/kdevelop-4.4.1-x86_64-1.txz:  Upgraded.
kde/kdevplatform-1.4.1-x86_64-1.txz:  Upgraded.
kde/kdewebdev-4.10.0-x86_64-1.txz:  Upgraded.
kde/kdf-4.10.0-x86_64-1.txz:  Upgraded.
kde/kdiamond-4.10.0-x86_64-1.txz:  Added.
kde/kfloppy-4.10.0-x86_64-1.txz:  Upgraded.
kde/kfourinline-4.10.0-x86_64-1.txz:  Added.
kde/kgamma-4.10.0-x86_64-1.txz:  Upgraded.
kde/kgeography-4.10.0-x86_64-1.txz:  Upgraded.
kde/kgoldrunner-4.10.0-x86_64-1.txz:  Added.
kde/kgpg-4.10.0-x86_64-1.txz:  Upgraded.
kde/khangman-4.10.0-x86_64-1.txz:  Upgraded.
kde/kig-4.10.0-x86_64-1.txz:  Upgraded.
kde/kigo-4.10.0-x86_64-1.txz:  Added.
kde/killbots-4.10.0-x86_64-1.txz:  Added.
kde/kio-mtp-fae62fc_20121225git-x86_64-1.txz:  Added.
kde/kiriki-4.10.0-x86_64-1.txz:  Added.
kde/kiten-4.10.0-x86_64-1.txz:  Upgraded.
kde/kjumpingcube-4.10.0-x86_64-1.txz:  Added.
kde/klettres-4.10.0-x86_64-1.txz:  Upgraded.
kde/klickety-4.10.0-x86_64-1.txz:  Added.
kde/klines-4.10.0-x86_64-1.txz:  Added.
kde/kmag-4.10.0-x86_64-1.txz:  Upgraded.
kde/kmahjongg-4.10.0-x86_64-1.txz:  Added.
kde/kmines-4.10.0-x86_64-1.txz:  Added.
kde/kmix-4.10.0-x86_64-1.txz:  Added.
kde/kmousetool-4.10.0-x86_64-1.txz:  Upgraded.
kde/kmouth-4.10.0-x86_64-1.txz:  Upgraded.
kde/kmplot-4.10.0-x86_64-1.txz:  Upgraded.
kde/knavalbattle-4.10.0-x86_64-1.txz:  Added.
kde/knetwalk-4.10.0-x86_64-1.txz:  Added.
kde/kolf-4.10.0-x86_64-1.txz:  Added.
kde/kollision-4.10.0-x86_64-1.txz:  Added.
kde/kolourpaint-4.10.0-x86_64-1.txz:  Upgraded.
kde/konquest-4.10.0-x86_64-1.txz:  Added.
kde/konsole-4.10.0-x86_64-1.txz:  Upgraded.
kde/korundum-4.10.0-x86_64-1.txz:  Upgraded.
kde/kpat-4.10.0-x86_64-1.txz:  Added.
kde/kremotecontrol-4.10.0-x86_64-1.txz:  Upgraded.
kde/kreversi-4.10.0-x86_64-1.txz:  Added.
kde/kross-interpreters-4.10.0-x86_64-1.txz:  Added.
kde/kruler-4.10.0-x86_64-1.txz:  Upgraded.
kde/ksaneplugin-4.10.0-x86_64-1.txz:  Upgraded.
kde/kscreen-0.0.71-x86_64-1.txz:  Added.
kde/ksecrets-4.8.5-x86_64-1.txz:  Removed.
kde/kshisen-4.10.0-x86_64-1.txz:  Added.
kde/ksirk-4.10.0-x86_64-1.txz:  Added.
kde/ksnakeduel-4.10.0-x86_64-1.txz:  Added.
kde/ksnapshot-4.10.0-x86_64-1.txz:  Upgraded.
kde/kspaceduel-4.10.0-x86_64-1.txz:  Added.
kde/ksquares-4.10.0-x86_64-1.txz:  Added.
kde/kstars-4.10.0-x86_64-1.txz:  Upgraded.
kde/ksudoku-4.10.0-x86_64-1.txz:  Added.
kde/ktimer-4.10.0-x86_64-1.txz:  Upgraded.
kde/ktorrent-4.3.1-x86_64-1.txz:  Upgraded.
kde/ktouch-4.10.0-x86_64-1.txz:  Upgraded.
kde/ktuberling-4.10.0-x86_64-1.txz:  Added.
kde/kturtle-4.10.0-x86_64-1.txz:  Upgraded.
kde/kubrick-4.10.0-x86_64-1.txz:  Added.
kde/kwallet-4.10.0-x86_64-1.txz:  Upgraded.
kde/kwordquiz-4.10.0-x86_64-1.txz:  Upgraded.
kde/libkcddb-4.10.0-x86_64-1.txz:  Added.
kde/libkcompactdisc-4.10.0-x86_64-1.txz:  Added.
kde/libkdcraw-4.10.0-x86_64-1.txz:  Upgraded.
kde/libkdeedu-4.10.0-x86_64-1.txz:  Upgraded.
kde/libkdegames-4.10.0-x86_64-1.txz:  Added.
kde/libkexiv2-4.10.0-x86_64-1.txz:  Upgraded.
kde/libkipi-4.10.0-x86_64-1.txz:  Upgraded.
kde/libkmahjongg-4.10.0-x86_64-1.txz:  Added.
kde/libksane-4.10.0-x86_64-1.txz:  Upgraded.
kde/libkscreen-0.0.71-x86_64-1.txz:  Added.
kde/libktorrent-1.3.1-x86_64-1.txz:  Upgraded.
kde/lskat-4.10.0-x86_64-1.txz:  Added.
kde/marble-4.10.0-x86_64-1.txz:  Upgraded.
kde/mplayerthumbs-4.10.0-x86_64-1.txz:  Upgraded.
kde/nepomuk-core-4.10.0-x86_64-1.txz:  Added.
kde/nepomuk-widgets-4.10.0-x86_64-1.txz:  Added.
kde/okular-4.10.0-x86_64-1.txz:  Upgraded.
kde/oxygen-gtk2-1.3.1-x86_64-1.txz:  Upgraded.
kde/oxygen-gtk3-1.1.1-x86_64-1.txz:  Added.
kde/oxygen-icons-4.10.0-x86_64-1.txz:  Upgraded.
kde/pairs-4.10.0-x86_64-1.txz:  Added.
kde/palapeli-4.10.0-x86_64-1.txz:  Added.
kde/parley-4.10.0-x86_64-1.txz:  Upgraded.
kde/perlkde-4.10.0-x86_64-1.txz:  Upgraded.
kde/perlqt-4.10.0-x86_64-1.txz:  Upgraded.
kde/picmi-4.10.0-x86_64-1.txz:  Added.
kde/print-manager-4.10.0-x86_64-1.txz:  Added.
kde/printer-applet-4.8.5-x86_64-1.txz:  Removed.
kde/pykde4-4.10.0-x86_64-1.txz:  Upgraded.
kde/qtruby-4.10.0-x86_64-1.txz:  Upgraded.
kde/rocs-4.10.0-x86_64-1.txz:  Upgraded.
kde/skanlite-0.9-x86_64-1.txz:  Upgraded.
kde/smokegen-4.10.0-x86_64-1.txz:  Upgraded.
kde/smokekde-4.10.0-x86_64-1.txz:  Upgraded.
kde/smokeqt-4.10.0-x86_64-1.txz:  Upgraded.
kde/step-4.10.0-x86_64-1.txz:  Upgraded.
kde/superkaramba-4.10.0-x86_64-1.txz:  Upgraded.
kde/svgpart-4.10.0-x86_64-1.txz:  Upgraded.
kde/sweeper-4.10.0-x86_64-1.txz:  Upgraded.
kdei/calligra-l10n-bs-2.6.0-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-ca-2.6.0-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-ca@valencia-2.6.0-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-da-2.6.0-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-de-2.6.0-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-el-2.6.0-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-en_GB-2.6.0-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-es-2.6.0-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-et-2.6.0-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-fi-2.6.0-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-fr-2.6.0-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-gl-2.6.0-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-hu-2.6.0-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-it-2.6.0-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-kk-2.6.0-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-nb-2.6.0-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-nds-2.6.0-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-nl-2.6.0-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-pl-2.6.0-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-pt-2.6.0-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-pt_BR-2.6.0-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-ru-2.6.0-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-sk-2.6.0-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-sl-2.6.0-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-sv-2.6.0-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-uk-2.6.0-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-zh_CN-2.6.0-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-zh_TW-2.6.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-ar-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-bg-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-bs-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-ca-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-ca@valencia-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-cs-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-da-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-de-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-el-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-en_GB-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-es-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-et-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-eu-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-fa-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-fi-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-fr-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-ga-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-gl-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-he-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-hi-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-hr-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-hu-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-ia-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-is-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-it-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-ja-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-kk-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-km-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-ko-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-lt-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-lv-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-mr-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-nb-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-nds-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-nl-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-nn-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-pa-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-pl-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-pt-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-pt_BR-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-ro-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-ru-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-si-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-sk-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-sl-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-sr-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-sv-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-tg-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-th-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-tr-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-ug-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-uk-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-vi-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-wa-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-zh_CN-4.10.0-noarch-1.txz:  Upgraded.
kdei/kde-l10n-zh_TW-4.10.0-noarch-1.txz:  Upgraded.
l/PyQt-4.9.6-x86_64-1.txz:  Upgraded.
l/akonadi-1.9.0-x86_64-1.txz:  Upgraded.
l/attica-0.4.1-x86_64-1.txz:  Upgraded.
l/boost-1.52.0-x86_64-1.txz:  Upgraded.
l/ebook-tools-0.2.2-x86_64-1.txz:  Upgraded.
l/enchant-1.6.0-x86_64-1.txz:  Upgraded.
l/grantlee-0.3.0-x86_64-1.txz:  Upgraded.
l/liblastfm-1.0.3-x86_64-1.txz:  Upgraded.
l/libmtp-1.1.5-x86_64-1.txz:  Upgraded.
l/libplist-1.8-x86_64-1.txz:  Upgraded.
l/libsamplerate-0.1.8-x86_64-1.txz:  Upgraded.
l/libsndfile-1.0.25-x86_64-1.txz:  Upgraded.
l/libwpd-0.9.6-x86_64-1.txz:  Upgraded.
l/qjson-0.8.1-x86_64-1.txz:  Added.
l/qt-4.8.4-x86_64-1.txz:  Upgraded.
l/shared-desktop-ontologies-0.10.0-x86_64-1.txz:  Upgraded.
l/sip-4.14.2-x86_64-1.txz:  Upgraded.
l/soprano-2.9.0-x86_64-1.txz:  Upgraded.
l/virtuoso-ose-6.1.6-x86_64-1.txz:  Upgraded.
n/openssl-1.0.1e-x86_64-1.txz:  Upgraded.
  This release fixes a regression in openssl-1.0.1d, where the fix for
  CVE-2013-0169 caused data corruption on CPUs with AES-NI support.
n/sendmail-8.14.6-x86_64-1.txz:  Upgraded.
n/sendmail-cf-8.14.6-noarch-1.txz:  Upgraded.
Y'a du Kneuf [:badoit on the rocks]
n°1330648
cycojesus
Mèo Lười
Posté le 12-02-2013 à 23:37:59  profilanswer
pis  [:sweet-memories]
Tue Feb 12 21:33:16 UTC 2013
l/akonadi-1.9.0-x86_64-2.txz:  Rebuilt.
  Looks like this had been compiled before boost was updated.  Recompiled
  to link against the new version of boost.  Thanks to rvdboom.
n/curl-7.29.0-x86_64-2.txz:  Rebuilt.
  Patched to fix a segfault when closing an unused multi.
  Thanks to Willy Sudiarto Raharjo.
xap/fluxbox-1.3.4-x86_64-1.txz:  Upgraded.
[:moutrave]
n°1330680
wedgeant
Da penguin inside
Posté le 13-02-2013 à 13:27:44  profilanswer
[:wark0]
n°1330768
regdub
Posté le 13-02-2013 à 20:50:03  profilanswer
[:regdub]
Legalize it @HFR
n°1330787
cycojesus
Mèo Lười
Posté le 14-02-2013 à 08:59:28  profilanswer
Par la tête du Oi
JE te donne ceci
Petit Sa.c [:orthopedux:3]
Thu Feb 14 05:35:22 UTC 2013
a/gpm-1.20.7-x86_64-1.txz:  Upgraded.
  This bumps the shared library version number, and will require
  several other packages to be recompiled.  This will be done after
  there's been some time to test this in -current.  Meanwhile, things
  should continue to work normally with the old shared library in
  the aaa_elflibs package.
d/git-1.8.1.3-x86_64-1.txz:  Upgraded.
l/QScintilla-2.6.1-x86_64-4.txz:  Rebuilt.
  Recompiled against the new sip to fix API incompatibilities.
  Thanks to ecoslacker and alienBOB.
xap/gimp-2.8.4-x86_64-1.txz:  Upgraded.
xap/pidgin-2.10.7-x86_64-1.txz:  Upgraded.
  This update fixes several security issues:
  Remote MXit user could specify local file path.
  MXit buffer overflow reading data from network.
  Sametime crash with long user IDs.
  Crash when receiving a UPnP response with abnormally long values.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-0271
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-0272
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-0273
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-0274
  (* Security fix *)
[:oubien]
n°1330789
wedgeant
Da penguin inside
Posté le 14-02-2013 à 09:13:42  profilanswer
T'as le cul qui scintille [:cerveau dawak]
n°1330892
cycojesus
Mèo Lười
Posté le 15-02-2013 à 10:26:03  profilanswer
Et les fèz qui volent [:neoeljin]
Fri Feb 15 07:26:45 UTC 2013
xap/fluxbox-1.3.5-x86_64-1.txz:  Upgraded.
xap/pidgin-2.10.7-x86_64-2.txz:  Rebuilt.
  Fixed IRC support.  When building with SASL support (new in 2.10.7), the
  IRC plugin needs to link against libsasl2, otherwise it will fail to load.
[:neoeljin:4]
n°1330970
cycojesus
Mèo Lười
Posté le 16-02-2013 à 10:28:40  profilanswer
Mon P.apa [:pere a 13 ans]
Ne veut pas [:tendulkar]
Que je danse
Que je danse
Mon Pa.pa [:cisco1:4]
Ne veut pas
que je danse la Polka [:oxidoz]
Fri Feb 15 22:46:52 UTC 2013
a/elilo-3.14-x86_64-3.txz:  Rebuilt.
  Include the x64 bootloader, not the Itanium one.  Thanks to cendryon.
  We're also keeping the ia32 version, even though 32-bit UEFI is
  practically unknown.  There might be some 32-bit EFI implementations
  out there, so it doesn't hurt to have it.
ap/hplip-3.13.2-x86_64-1.txz:  Upgraded.
l/polkit-0.105-x86_64-4.txz:  Rebuilt.
  Reverted a patch that set the members of the wheel group as the
  authorized administrators.  On Slackware, root is the administrator
  and the wheel group is mostly unused.  Thanks to G�rard Monpontet.
xap/pidgin-2.10.7-x86_64-3.txz:  Rebuilt.
  Fixed linking libirc.so with libsasl2.
  Added Makefile.in and Makefile to the patch, and applied it after
  running ./configure.  Using autoreconf is not an option since most
  versions of Slackware aren't using the same libtools versions as the
  Pidgin developers are.  Third times the charm?
[:the geddons:4]
n°1331085
regdub
Posté le 17-02-2013 à 23:59:35  profilanswer
[:geekeeta]
 [:glaurungf]
Legalize it @HFR
n°1331100
wedgeant
Da penguin inside
Posté le 18-02-2013 à 09:18:26  profilanswer
[:bauer_attitude:3]
n°1331337
cycojesus
Mèo Lười
Posté le 20-02-2013 à 12:24:59  profilanswer
Oï, téma la Maje [:timofort:2]
T'àmène oh Terminus de la page
Alors soit sage [:elwe calafalas:3]
Wed Feb 20 05:24:23 UTC 2013
a/gpm-1.20.7-x86_64-2.txz:  Rebuilt.
  Fixed libgpm.so symlink.
ap/terminus-font-4.38-noarch-1.txz:  Added.
l/slang-2.2.4-x86_64-1.txz:  Upgraded.
n/slrn-1.0.1-x86_64-1.txz:  Upgraded.
xap/mozilla-firefox-19.0-x86_64-1.txz:  Upgraded.
  This release contains security fixes and improvements.
    http://www.mozilla.org/security/known-vulnerabilities/firefox.html
  (* Security fix *)
xap/mozilla-thunderbird-17.0.3-x86_64-1.txz:  Upgraded.
    http://www.mozilla.org/security/known-vulnerabilities/thunderbird.html
  (* Security fix *)
S'tro ratal [:velasquez:3]
n°1331486
cycojesus
Mèo Lười
Posté le 22-02-2013 à 08:55:49  profilanswer
Du X [:la fille au corbeau]
Du Bien [:nyxon:1]
Fri Feb 22 02:14:43 UTC 2013
x/mesa-9.0.3-x86_64-1.txz:  Upgraded.
Fri Feb 22 01:09:25 UTC 2013
Lots of X updates in this batch!  We were finally able to upgrade to the
latest cairo (including the long-requested XCB backend), as the text
corruption bug that was preventing that was fixed in the upstream X server.
We've also upgraded to the latest libdrm and Mesa.  Don't miss the new glu
package -- that was previously part of Mesa, and there are a lot of things
that link to it.  Thanks to Robby Workman for all the help with this.
a/eject-2.1.5-x86_64-4.txz:  Rebuilt.
  Patched to fix -T.  Thanks to GazL.
l/cairo-1.12.14-x86_64-1.txz:  Upgraded.
x/bdftopcf-1.0.4-x86_64-1.txz:  Upgraded.
x/beforelight-1.0.5-x86_64-1.txz:  Upgraded.
x/dri2proto-2.8-x86_64-1.txz:  Upgraded.
x/editres-1.0.6-x86_64-1.txz:  Upgraded.
x/glproto-1.4.16-noarch-1.txz:  Upgraded.
x/glu-9.0.0-x86_64-1.txz:  Added.
  This used to be part of Mesa, but was split out.
x/ico-1.0.4-x86_64-1.txz:  Upgraded.
x/intel-gpu-tools-1.3-x86_64-1.txz:  Upgraded.
x/libXcm-0.5.2-x86_64-1.txz:  Upgraded.
x/libXcomposite-0.4.4-x86_64-1.txz:  Upgraded.
x/libXdamage-1.1.4-x86_64-1.txz:  Upgraded.
x/libXi-1.6.2-x86_64-1.txz:  Upgraded.
x/libXrandr-1.4.0-x86_64-1.txz:  Upgraded.
x/libdrm-2.4.42-x86_64-1.txz:  Upgraded.
x/libxcb-1.9-x86_64-1.txz:  Upgraded.
x/mesa-9.0.2-x86_64-1.txz:  Upgraded.
x/mtdev-1.1.3-x86_64-1.txz:  Upgraded.
x/pixman-0.28.2-x86_64-1.txz:  Upgraded.
x/randrproto-1.4.0-noarch-1.txz:  Upgraded.
x/rgb-1.0.5-x86_64-1.txz:  Upgraded.
x/sessreg-1.0.8-x86_64-1.txz:  Upgraded.
x/showfont-1.0.4-x86_64-1.txz:  Upgraded.
x/ttf-indic-fonts-0.5.14-noarch-1.txz:  Upgraded.
x/viewres-1.0.4-x86_64-1.txz:  Upgraded.
x/xbacklight-1.2.0-x86_64-1.txz:  Upgraded.
x/xcalc-1.0.5-x86_64-1.txz:  Upgraded.
x/xcb-proto-1.8-x86_64-1.txz:  Upgraded.
x/xcm-0.5.2-x86_64-1.txz:  Added.
x/xconsole-1.0.5-x86_64-1.txz:  Upgraded.
x/xditview-1.0.3-x86_64-1.txz:  Upgraded.
x/xedit-1.2.1-x86_64-1.txz:  Upgraded.
x/xf86-input-acecad-1.5.0-x86_64-2.txz:  Rebuilt.
x/xf86-input-aiptek-1.4.1-x86_64-2.txz:  Rebuilt.
x/xf86-input-evdev-2.7.3-x86_64-1.txz:  Upgraded.
x/xf86-input-joystick-1.6.1-x86_64-2.txz:  Rebuilt.
x/xf86-input-keyboard-1.6.2-x86_64-1.txz:  Upgraded.
x/xf86-input-mouse-1.8.1-x86_64-1.txz:  Upgraded.
x/xf86-input-penmount-1.5.0-x86_64-2.txz:  Rebuilt.
x/xf86-input-synaptics-1.6.3-x86_64-1.txz:  Upgraded.
x/xf86-input-vmmouse-13.0.0-x86_64-1.txz:  Upgraded.
x/xf86-input-void-1.4.0-x86_64-2.txz:  Rebuilt.
x/xf86-input-wacom-0.19.0-x86_64-1.txz:  Upgraded.
x/xf86-video-apm-1.2.5-x86_64-1.txz:  Upgraded.
x/xf86-video-ark-0.7.5-x86_64-1.txz:  Upgraded.
x/xf86-video-ast-0.97.0-x86_64-1.txz:  Upgraded.
x/xf86-video-ati-7.1.0-x86_64-1.txz:  Upgraded.
x/xf86-video-chips-1.2.5-x86_64-1.txz:  Upgraded.
x/xf86-video-cirrus-1.5.2-x86_64-1.txz:  Upgraded.
x/xf86-video-dummy-0.3.6-x86_64-1.txz:  Upgraded.
x/xf86-video-glint-1.2.8-x86_64-1.txz:  Upgraded.
x/xf86-video-i128-1.3.6-x86_64-1.txz:  Upgraded.
x/xf86-video-i740-1.3.4-x86_64-1.txz:  Upgraded.
x/xf86-video-intel-2.21.3-x86_64-1.txz:  Upgraded.
x/xf86-video-mach64-6.9.4-x86_64-1.txz:  Upgraded.
x/xf86-video-mga-1.6.2-x86_64-1.txz:  Upgraded.
x/xf86-video-modesetting-0.6.0-x86_64-1.txz:  Upgraded.
x/xf86-video-neomagic-1.2.7-x86_64-1.txz:  Upgraded.
x/xf86-video-nouveau-1.0.4-x86_64-1.txz:  Upgraded.
x/xf86-video-nv-2.1.20-x86_64-2.txz:  Rebuilt.
x/xf86-video-openchrome-0.3.1-x86_64-1.txz:  Upgraded.
x/xf86-video-r128-6.9.1-x86_64-1.txz:  Upgraded.
x/xf86-video-rendition-4.2.5-x86_64-1.txz:  Upgraded.
x/xf86-video-s3-0.6.5-x86_64-1.txz:  Upgraded.
x/xf86-video-s3virge-1.10.6-x86_64-1.txz:  Upgraded.
x/xf86-video-savage-2.3.6-x86_64-1.txz:  Upgraded.
x/xf86-video-siliconmotion-1.7.7-x86_64-1.txz:  Upgraded.
x/xf86-video-sis-0.10.7-x86_64-1.txz:  Upgraded.
x/xf86-video-sisusb-0.9.6-x86_64-1.txz:  Added.
x/xf86-video-tdfx-1.4.5-x86_64-1.txz:  Upgraded.
x/xf86-video-tga-1.2.2-x86_64-1.txz:  Upgraded.
x/xf86-video-trident-1.3.6-x86_64-1.txz:  Upgraded.
x/xf86-video-tseng-1.2.5-x86_64-1.txz:  Added.
x/xf86-video-v4l-0.2.0-x86_64-6.txz:  Rebuilt.
x/xf86-video-vesa-2.3.2-x86_64-1.txz:  Upgraded.
x/xf86-video-vmware-13.0.0-x86_64-1.txz:  Upgraded.
x/xf86-video-voodoo-1.2.5-x86_64-1.txz:  Upgraded.
x/xf86-video-xgi-git_be3abf8570a-x86_64-1.txz:  Added.
x/xf86-video-xgixp-1.8.1-x86_64-1.txz:  Added.
x/xfsinfo-1.0.4-x86_64-1.txz:  Upgraded.
x/xkbutils-1.0.4-x86_64-1.txz:  Upgraded.
x/xmag-1.0.5-x86_64-1.txz:  Upgraded.
x/xmessage-1.0.4-x86_64-1.txz:  Upgraded.
x/xorg-server-1.13.2-x86_64-1.txz:  Upgraded.
x/xorg-server-xephyr-1.13.2-x86_64-1.txz:  Upgraded.
x/xorg-server-xnest-1.13.2-x86_64-1.txz:  Upgraded.
x/xorg-server-xvfb-1.13.2-x86_64-1.txz:  Upgraded.
x/xrandr-1.4.0-x86_64-1.txz:  Upgraded.
x/xscope-1.4-x86_64-1.txz:  Upgraded.
x/xsetroot-1.1.1-x86_64-1.txz:  Upgraded.
x/xsm-1.0.3-x86_64-1.txz:  Upgraded.
x/xstdcmap-1.0.3-x86_64-1.txz:  Upgraded.
x/xterm-290-x86_64-1.txz:  Upgraded.
x/xvidtune-1.0.3-x86_64-1.txz:  Upgraded.
x/xvinfo-1.1.2-x86_64-1.txz:  Upgraded.
[:brischri:5]
n°1331490
wedgeant
Da penguin inside
Posté le 22-02-2013 à 09:21:00  profilanswer
Il a ajouté de la glu dans son paquetage [:cerveau dawak]
n°1331595
cycojesus
Mèo Lười
Posté le 24-02-2013 à 09:28:15  profilanswer
et ça  [:bob gray]
Sat Feb 23 22:34:33 UTC 2013
a/dosfstools-3.0.15-x86_64-1.txz:  Upgraded.
a/libcgroup-0.38-x86_64-2.txz:  Rebuilt.
  Use full path to /usr/sbin/cgclear, since /usr/sbin isn't in the $PATH
  when the script is called at shutdown/reboot.  Thanks to LukenShiro.
l/slang-2.2.4-x86_64-2.txz:  Rebuilt.
  Recompiled with -fno-tree-dse to avoid optimization bugs.
  Thanks to Petri Kaukasoina.
[:la fille au corbeau:1]
n°1331712
cycojesus
Mèo Lười
Posté le 26-02-2013 à 07:54:05  profilanswer
Ba voui, ça manquait [:niku:1]
Mon Feb 25 19:45:33 UTC 2013
l/seamonkey-solibs-2.16-x86_64-1.txz:  Upgraded.
xap/seamonkey-2.16-x86_64-1.txz:  Upgraded.
    http://www.mozilla.org/security/known-vulnerabilities/seamonkey.html
  (* Security fix *)
[:mixmax]
n°1331776
cycojesus
Mèo Lười
Posté le 27-02-2013 à 09:39:40  profilanswer
............ ........... .......... .. . ........... ............ [:zzanna:2]
Wed Feb 27 04:58:17 UTC 2013
a/coreutils-8.21-x86_64-1.txz:  Upgraded.
d/git-1.8.1.4-x86_64-1.txz:  Upgraded.
x/fontconfig-2.10.2-x86_64-1.txz:  Upgraded.
x/mesa-9.1-x86_64-1.txz:  Upgraded.
  Hate to stomp on the fresh proprietary video driver installs out there
  again, but it's probably better to get this in sooner than later.
x/wqy-zenhei-font-ttf-0.9.45-noarch-1.txz:  Upgraded.
x/xf86-video-openchrome-0.3.1-x86_64-2.txz:  Rebuilt.
  Merged upstream patch to fix lockups with some chipsets.
  Thanks to J. Scott Heppler.
x/xorg-server-1.13.2-x86_64-2.txz:  Rebuilt.
  Clean up randr provider removal, fixing a number of random server crashes
  on shutdown.  Thanks to Richard David Sherman and Robby Workman.
  Applied a patch to fix panning and scaling.
  Thanks to David Allen and Luigi Genoni.
x/xorg-server-xephyr-1.13.2-x86_64-2.txz:  Rebuilt.
x/xorg-server-xnest-1.13.2-x86_64-2.txz:  Rebuilt.
x/xorg-server-xvfb-1.13.2-x86_64-2.txz:  Rebuilt.
[:haha dead:1]  ... !
n°1331963
cycojesus
Mèo Lười
Posté le 01-03-2013 à 08:30:17  profilanswer
L'avion pété des choses [:ograoumpapas:3]
Les réparions d'suite [:nekromanttik:5]
Fri Mar  1 05:41:39 UTC 2013
ap/groff-1.22.2-x86_64-1.txz:  Upgraded.
x/fontconfig-2.10.2-x86_64-2.txz:  Rebuilt.
  Fixed dangling symlink to 20-fix-globaladvance.conf (which was removed).
  Create the symlinks in doinst.sh before running fc-cache.
  Don't include /usr/share/fonts in the fonts.conf font directory list as that
  causes bitmapped fonts to be used.  Thanks to Iouri Kharon.
là ! [:noel le graet:2]
n°1332104
cycojesus
Mèo Lười
Posté le 04-03-2013 à 08:04:52  profilanswer
Du Web 2.0 de la hype [:parti manger]
Du plus secure [:turbocat:1]
Sun Mar  3 22:10:56 UTC 2013
ap/cdrtools-3.01a13-x86_64-1.txz:  Upgraded.
l/apr-util-1.5.1-x86_64-1.txz:  Upgraded.
n/httpd-2.4.4-x86_64-1.txz:  Upgraded.
  This update provides bugfixes and enhancements.
  Two security issues are fixed:
  *  Various XSS flaws due to unescaped hostnames and URIs HTML output in
     mod_info, mod_status, mod_imagemap, mod_ldap, and mod_proxy_ftp.
     [Jim Jagielski, Stefan Fritsch, Niels Heinen <heinenn google com>]
  *  XSS in mod_proxy_balancer manager interface. [Jim Jagielski,
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-3499
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-4558
  (* Security fix *)
n/php-5.4.12-x86_64-1.txz:  Upgraded.
x/fontconfig-2.10.2-x86_64-3.txz:  Rebuilt.
  Applied patch from upstream git to fix 10-autohint.conf.
Le Bien [:muzah:2]
n°1332109
wedgeant
Da penguin inside
Posté le 04-03-2013 à 09:25:15  profilanswer
Du patch, des femmes et d'la bière nom de dieu !!  [:triticum:2]
n°1332338
cycojesus
Mèo Lười
Posté le 07-03-2013 à 07:56:25  profilanswer
Le KDEau du jeudi, jour comme un jour sans... sans... BIÈRE [:bouldoguemystere:1]
Tidjiou [:ograoumpapas]
Thu Mar  7 00:16:35 UTC 2013
a/syslinux-5.01-x86_64-1.txz:  Upgraded.
ap/sudo-1.8.6p7-x86_64-1.txz:  Upgraded.
  This update fixes security issues that could allow a user to run commands
  without authenticating after the password timeout has already expired.
  Note that the vulnerability did not permit a user to run commands other
  than those allowed by the sudoers policy.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-1775
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-1776
  (* Security fix *)
kde/analitza-4.10.1-x86_64-1.txz:  Upgraded.
kde/ark-4.10.1-x86_64-1.txz:  Upgraded.
kde/audiocd-kio-4.10.1-x86_64-1.txz:  Upgraded.
kde/blinken-4.10.1-x86_64-1.txz:  Upgraded.
kde/bomber-4.10.1-x86_64-1.txz:  Upgraded.
kde/bovo-4.10.1-x86_64-1.txz:  Upgraded.
kde/calligra-2.6.1-x86_64-1.txz:  Upgraded.
kde/cantor-4.10.1-x86_64-1.txz:  Upgraded.
kde/dragon-4.10.1-x86_64-1.txz:  Upgraded.
kde/filelight-4.10.1-x86_64-1.txz:  Upgraded.
kde/granatier-4.10.1-x86_64-1.txz:  Upgraded.
kde/gwenview-4.10.1-x86_64-1.txz:  Upgraded.
kde/juk-4.10.1-x86_64-1.txz:  Upgraded.
kde/kaccessible-4.10.1-x86_64-1.txz:  Upgraded.
kde/kactivities-4.10.1-x86_64-1.txz:  Upgraded.
kde/kajongg-4.10.1-x86_64-1.txz:  Upgraded.
kde/kalgebra-4.10.1-x86_64-1.txz:  Upgraded.
kde/kalzium-4.10.1-x86_64-1.txz:  Upgraded.
kde/kamera-4.10.1-x86_64-1.txz:  Upgraded.
kde/kanagram-4.10.1-x86_64-1.txz:  Upgraded.
kde/kapman-4.10.1-x86_64-1.txz:  Upgraded.
kde/kate-4.10.1-x86_64-1.txz:  Upgraded.
kde/katomic-4.10.1-x86_64-1.txz:  Upgraded.
kde/kblackbox-4.10.1-x86_64-1.txz:  Upgraded.
kde/kblocks-4.10.1-x86_64-1.txz:  Upgraded.
kde/kbounce-4.10.1-x86_64-1.txz:  Upgraded.
kde/kbreakout-4.10.1-x86_64-1.txz:  Upgraded.
kde/kbruch-4.10.1-x86_64-1.txz:  Upgraded.
kde/kcalc-4.10.1-x86_64-1.txz:  Upgraded.
kde/kcharselect-4.10.1-x86_64-1.txz:  Upgraded.
kde/kcolorchooser-4.10.1-x86_64-1.txz:  Upgraded.
kde/kde-base-artwork-4.10.1-x86_64-1.txz:  Upgraded.
kde/kde-baseapps-4.10.1-x86_64-1.txz:  Upgraded.
kde/kde-runtime-4.10.1-x86_64-1.txz:  Upgraded.
kde/kde-wallpapers-4.10.1-noarch-1.txz:  Upgraded.
kde/kde-workspace-4.10.1-x86_64-1.txz:  Upgraded.
kde/kdeadmin-4.10.1-x86_64-1.txz:  Upgraded.
kde/kdeartwork-4.10.1-x86_64-1.txz:  Upgraded.
kde/kdegraphics-mobipocket-4.10.1-x86_64-1.txz:  Upgraded.
kde/kdegraphics-strigi-analyzer-4.10.1-x86_64-1.txz:  Upgraded.
kde/kdegraphics-thumbnailers-4.10.1-x86_64-1.txz:  Upgraded.
kde/kdelibs-4.10.1-x86_64-1.txz:  Upgraded.
kde/kdenetwork-4.10.1-x86_64-1.txz:  Upgraded.
kde/kdepim-4.10.1-x86_64-1.txz:  Upgraded.
kde/kdepim-runtime-4.10.1-x86_64-1.txz:  Upgraded.
kde/kdepimlibs-4.10.1-x86_64-1.txz:  Upgraded.
kde/kdeplasma-addons-4.10.1-x86_64-1.txz:  Upgraded.
kde/kdesdk-4.10.1-x86_64-1.txz:  Upgraded.
kde/kdetoys-4.10.1-x86_64-1.txz:  Upgraded.
kde/kdewebdev-4.10.1-x86_64-1.txz:  Upgraded.
kde/kdf-4.10.1-x86_64-1.txz:  Upgraded.
kde/kdiamond-4.10.1-x86_64-1.txz:  Upgraded.
kde/kfloppy-4.10.1-x86_64-1.txz:  Upgraded.
kde/kfourinline-4.10.1-x86_64-1.txz:  Upgraded.
kde/kgamma-4.10.1-x86_64-1.txz:  Upgraded.
kde/kgeography-4.10.1-x86_64-1.txz:  Upgraded.
kde/kgoldrunner-4.10.1-x86_64-1.txz:  Upgraded.
kde/kgpg-4.10.1-x86_64-1.txz:  Upgraded.
kde/khangman-4.10.1-x86_64-1.txz:  Upgraded.
kde/kig-4.10.1-x86_64-1.txz:  Upgraded.
kde/kigo-4.10.1-x86_64-1.txz:  Upgraded.
kde/killbots-4.10.1-x86_64-1.txz:  Upgraded.
kde/kiriki-4.10.1-x86_64-1.txz:  Upgraded.
kde/kiten-4.10.1-x86_64-1.txz:  Upgraded.
kde/kjumpingcube-4.10.1-x86_64-1.txz:  Upgraded.
kde/klettres-4.10.1-x86_64-1.txz:  Upgraded.
kde/klickety-4.10.1-x86_64-1.txz:  Upgraded.
kde/klines-4.10.1-x86_64-1.txz:  Upgraded.
kde/kmag-4.10.1-x86_64-1.txz:  Upgraded.
kde/kmahjongg-4.10.1-x86_64-1.txz:  Upgraded.
kde/kmines-4.10.1-x86_64-1.txz:  Upgraded.
kde/kmix-4.10.1-x86_64-1.txz:  Upgraded.
kde/kmousetool-4.10.1-x86_64-1.txz:  Upgraded.
kde/kmouth-4.10.1-x86_64-1.txz:  Upgraded.
kde/kmplot-4.10.1-x86_64-1.txz:  Upgraded.
kde/knavalbattle-4.10.1-x86_64-1.txz:  Upgraded.
kde/knetwalk-4.10.1-x86_64-1.txz:  Upgraded.
kde/kolf-4.10.1-x86_64-1.txz:  Upgraded.
kde/kollision-4.10.1-x86_64-1.txz:  Upgraded.
kde/kolourpaint-4.10.1-x86_64-1.txz:  Upgraded.
kde/konquest-4.10.1-x86_64-1.txz:  Upgraded.
kde/konsole-4.10.1-x86_64-1.txz:  Upgraded.
kde/korundum-4.10.1-x86_64-1.txz:  Upgraded.
kde/kpat-4.10.1-x86_64-1.txz:  Upgraded.
kde/kremotecontrol-4.10.1-x86_64-1.txz:  Upgraded.
kde/kreversi-4.10.1-x86_64-1.txz:  Upgraded.
kde/kross-interpreters-4.10.1-x86_64-1.txz:  Upgraded.
kde/kruler-4.10.1-x86_64-1.txz:  Upgraded.
kde/ksaneplugin-4.10.1-x86_64-1.txz:  Upgraded.
kde/kshisen-4.10.1-x86_64-1.txz:  Upgraded.
kde/ksirk-4.10.1-x86_64-1.txz:  Upgraded.
kde/ksnakeduel-4.10.1-x86_64-1.txz:  Upgraded.
kde/ksnapshot-4.10.1-x86_64-1.txz:  Upgraded.
kde/kspaceduel-4.10.1-x86_64-1.txz:  Upgraded.
kde/ksquares-4.10.1-x86_64-1.txz:  Upgraded.
kde/kstars-4.10.1-x86_64-1.txz:  Upgraded.
kde/ksudoku-4.10.1-x86_64-1.txz:  Upgraded.
kde/ktimer-4.10.1-x86_64-1.txz:  Upgraded.
kde/ktouch-4.10.1-x86_64-1.txz:  Upgraded.
kde/ktuberling-4.10.1-x86_64-1.txz:  Upgraded.
kde/kturtle-4.10.1-x86_64-1.txz:  Upgraded.
kde/kubrick-4.10.1-x86_64-1.txz:  Upgraded.
kde/kwallet-4.10.1-x86_64-1.txz:  Upgraded.
kde/kwordquiz-4.10.1-x86_64-1.txz:  Upgraded.
kde/libkcddb-4.10.1-x86_64-1.txz:  Upgraded.
kde/libkcompactdisc-4.10.1-x86_64-1.txz:  Upgraded.
kde/libkdcraw-4.10.1-x86_64-1.txz:  Upgraded.
kde/libkdeedu-4.10.1-x86_64-1.txz:  Upgraded.
kde/libkdegames-4.10.1-x86_64-1.txz:  Upgraded.
kde/libkexiv2-4.10.1-x86_64-1.txz:  Upgraded.
kde/libkipi-4.10.1-x86_64-1.txz:  Upgraded.
kde/libkmahjongg-4.10.1-x86_64-1.txz:  Upgraded.
kde/libksane-4.10.1-x86_64-1.txz:  Upgraded.
kde/lskat-4.10.1-x86_64-1.txz:  Upgraded.
kde/marble-4.10.1-x86_64-1.txz:  Upgraded.
kde/mplayerthumbs-4.10.1-x86_64-1.txz:  Upgraded.
kde/nepomuk-core-4.10.1-x86_64-1.txz:  Upgraded.
kde/nepomuk-widgets-4.10.1-x86_64-1.txz:  Upgraded.
kde/okular-4.10.1-x86_64-1.txz:  Upgraded.
kde/oxygen-icons-4.10.1-x86_64-1.txz:  Upgraded.
kde/pairs-4.10.1-x86_64-1.txz:  Upgraded.
kde/palapeli-4.10.1-x86_64-1.txz:  Upgraded.
kde/parley-4.10.1-x86_64-1.txz:  Upgraded.
kde/perlkde-4.10.1-x86_64-1.txz:  Upgraded.
kde/perlqt-4.10.1-x86_64-1.txz:  Upgraded.
kde/picmi-4.10.1-x86_64-1.txz:  Upgraded.
kde/print-manager-4.10.1-x86_64-1.txz:  Upgraded.
kde/pykde4-4.10.1-x86_64-1.txz:  Upgraded.
kde/qtruby-4.10.1-x86_64-1.txz:  Upgraded.
kde/rocs-4.10.1-x86_64-1.txz:  Upgraded.
kde/smokegen-4.10.1-x86_64-1.txz:  Upgraded.
kde/smokekde-4.10.1-x86_64-1.txz:  Upgraded.
kde/smokeqt-4.10.1-x86_64-1.txz:  Upgraded.
kde/step-4.10.1-x86_64-1.txz:  Upgraded.
kde/superkaramba-4.10.1-x86_64-1.txz:  Upgraded.
kde/svgpart-4.10.1-x86_64-1.txz:  Upgraded.
kde/sweeper-4.10.1-x86_64-1.txz:  Upgraded.
kdei/calligra-l10n-bs-2.6.1-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-ca-2.6.1-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-ca@valencia-2.6.1-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-da-2.6.1-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-de-2.6.1-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-el-2.6.1-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-en_GB-2.6.1-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-es-2.6.1-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-et-2.6.1-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-fi-2.6.1-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-fr-2.6.1-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-gl-2.6.1-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-hu-2.6.1-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-it-2.6.1-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-kk-2.6.1-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-nb-2.6.1-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-nds-2.6.1-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-nl-2.6.1-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-pl-2.6.1-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-pt-2.6.1-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-pt_BR-2.6.1-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-ru-2.6.1-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-sk-2.6.1-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-sl-2.6.1-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-sv-2.6.1-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-uk-2.6.1-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-zh_CN-2.6.1-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-zh_TW-2.6.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-ar-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-bg-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-bs-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-ca-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-ca@valencia-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-cs-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-da-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-de-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-el-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-en_GB-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-es-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-et-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-eu-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-fa-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-fi-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-fr-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-ga-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-gl-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-he-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-hi-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-hr-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-hu-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-ia-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-is-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-it-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-ja-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-kk-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-km-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-ko-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-lt-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-lv-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-mr-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-nb-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-nds-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-nl-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-nn-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-pa-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-pl-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-pt-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-pt_BR-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-ro-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-ru-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-si-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-sk-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-sl-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-sr-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-sv-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-tg-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-th-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-tr-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-ug-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-uk-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-vi-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-wa-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-zh_CN-4.10.1-noarch-1.txz:  Upgraded.
kdei/kde-l10n-zh_TW-4.10.1-noarch-1.txz:  Upgraded.
 [:lavie_lavraie]
n°1332342
wedgeant
Da penguin inside
Posté le 07-03-2013 à 09:19:58  profilanswer
[:koukouille:3]
n°1332488
cycojesus
Mèo Lười
Posté le 09-03-2013 à 10:14:30  profilanswer
Prendez une capsule, B.oris
Prendez, suivront du renardpanda en gelée [:phosphoreloaded:3]
Sat Mar  9 06:19:05 UTC 2013
xap/mozilla-firefox-19.0.2-x86_64-1.txz:  Upgraded.
  (* Security fix *)
xap/mozilla-thunderbird-17.0.4esr-x86_64-1.txz:  Upgraded.
  (* Security fix *)
[:oriane:5]
n°1332589
cycojesus
Mèo Lười
Posté le 12-03-2013 à 09:30:34  profilanswer
Tiens, de l'update verbeuse comme que tu l'aimes [:4lkaline2:5]
De la tartine de mots pour accompagner le beurre de ton existence au petit déjeuner [:3615 dovakor:2]
du l'Emacs propre pour te fortifer [:gottfer_damnt]
Tue Mar 12 06:59:27 UTC 2013
Here we go with some more updates...  a few notes on them are in order.
For this kernel update I decided to go with 3.7.10.  Yeah, the 3.7 series
is EOL, but I've heard about some broken drivers in 3.8.x that make me
hesitate to push forward.  Another option might be to move to 3.4.x, which
is working on my machine finally (a clocksource bug was crashing it with
earlier versions).  The USB host and usb-storage drivers are now modular
in both the huge and generic kernels to avoid an issue where a USB stick
could be assigned /dev/sda when running the huge kernel.  The brcmsmac
driver for Broadcom wifi is built.  However, this takes over for any
Broadcom card that it can support -- those cards will no longer be supported
by the b43 driver.  So, if you're currently using b43 and find that it no
longer works, you'll need to move to the brcmsmac driver instead.  It's
technically possible to build these with the overlapping support, but it's
a mess that way which is probably why nobody else is doing that.  And finally,
rudimentary UEFI support makes its first appearance in -current in the form
of a bootable USB image called efiboot.img.  Still no support in the
installer for setting up elilo, but this will at least get Linux installed
without the need for Legacy BIOS support.  Looking into how to set up the
boot support in the installer will be the next order of business, and I
have a few different ideas about the way to go about that...  probably
some good material for a discussion on LQ.  BTW, a GPT FAT image like this
one is _supposed_ to work as an El-Torito alternate boot image when creating
an ISO image (extra mkisofs options: -eltorito-alt-boot -no-emul-boot
-eltorito-platform 0xEF -eltorito-boot usb-and-pxe-installers/efiboot.img),
but it's mostly not working here.  I did get one of these to work when booted
from an ISO, but all the attempts after that failed.  Looks like it might be
a problem with the -boot-load-size being detected properly for one magic
EFI image and not for all the others.  If anyone is brave or bored enough to
look into that, hints are gratefully accepted.  Anyway, that's it for now.
Have fun!
a/glibc-solibs-2.17-x86_64-1.txz:  Upgraded.
a/glibc-zoneinfo-2013b-noarch-1.txz:  Upgraded.
a/kernel-firmware-20130311git-noarch-1.txz:  Upgraded.
a/kernel-generic-3.7.10-x86_64-1.txz:  Upgraded.
a/kernel-huge-3.7.10-x86_64-1.txz:  Upgraded.
a/kernel-modules-3.7.10-x86_64-1.txz:  Upgraded.
a/syslinux-4.06-x86_64-1.txz:  Upgraded.
  Actually, dropping back from 5.01, which has a bug that prevents extra
  options given at the boot prompt from being passed to the kernel.
  We'll look at this again when 5.02 comes out.
d/kernel-headers-3.7.10-x86-1.txz:  Upgraded.
e/emacs-24.3-x86_64-1.txz:  Upgraded.
k/kernel-source-3.7.10-noarch-1.txz:  Upgraded.
l/glibc-2.17-x86_64-1.txz:  Upgraded.
l/glibc-i18n-2.17-x86_64-1.txz:  Upgraded.
l/glibc-profile-2.17-x86_64-1.txz:  Upgraded.
isolinux/initrd.img:  Rebuilt.
  This adds support for kernel mode setting video, needed to have any text
  output with some UEFI implementations.  If you need to bypass this, use
  the "nomodeset" option at the boot prompt.
  Terminus fonts were added to avoid small KMS text (bypass with "nofont" ).
  USB host and usb-storage modules were added since those are no longer built
  into the huge kernels.
  The hv_storvsc.ko module was added to support installing in Hyper-V.
kernels/*:  Upgraded.
usb-and-pxe-installers/efiboot.img:  Added.
  This is a USB installer image that can be booted from UEFI.
usb-and-pxe-installers/usbboot.img:  Rebuilt.
[:gabuzaumeu]
n°1332646
cycojesus
Mèo Lười
Posté le 12-03-2013 à 23:31:32  profilanswer
u sauras que l'update s'est propagée au multilib comme il se doit
Tu l'aura su là : http://alien.slackbook.org/blog/a- [...] e-current/
 [:dunngeon:3]
n°1332658
wedgeant
Da penguin inside
Posté le 13-03-2013 à 09:15:25  profilanswer
Et tu l'auras installée ... goutée ... léchée  [:jocetoofoo]
n°1332761
cycojesus
Mèo Lười
Posté le 14-03-2013 à 10:59:51  profilanswer
Même si tu es jeune, à jeun et le cerveau chaste t'oublie quand même pas de
# removepkg scim-bridge
*barf*
Post interdit aux moins de 18 ans
#$%@&^ de Google de mes @!$@#$ [:fullraymond:2]
Failli louper la MAJie tout occupé à installer TT-RSS
Monde de Merde [:chatoo:3]
Thu Mar 14 03:55:33 UTC 2013
a/dosfstools-3.0.16-x86_64-1.txz:  Upgraded.
d/perl-5.16.3-x86_64-1.txz:  Upgraded.
  This update fixes a flaw in the rehashing code that can be exploited
  to carry out a denial of service attack against code that uses arbitrary
  user input as hash keys.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-1667
  (* Security fix *)
l/seamonkey-solibs-2.16.1-x86_64-1.txz:  Upgraded.
x/inputproto-2.3-noarch-1.txz:  Upgraded.
x/libXi-1.7-x86_64-1.txz:  Upgraded.
x/scim-bridge-0.4.16-x86_64-5.txz:  Removed.
  This functionality was included in scim-1.4.14.
x/xf86-input-acecad-1.5.0-x86_64-3.txz:  Rebuilt.
x/xf86-input-aiptek-1.4.1-x86_64-3.txz:  Rebuilt.
x/xf86-input-evdev-2.7.3-x86_64-2.txz:  Rebuilt.
x/xf86-input-joystick-1.6.1-x86_64-3.txz:  Rebuilt.
x/xf86-input-keyboard-1.6.2-x86_64-2.txz:  Rebuilt.
x/xf86-input-mouse-1.8.1-x86_64-2.txz:  Rebuilt.
x/xf86-input-penmount-1.5.0-x86_64-3.txz:  Rebuilt.
x/xf86-input-synaptics-1.6.3-x86_64-2.txz:  Rebuilt.
x/xf86-input-vmmouse-13.0.0-x86_64-2.txz:  Rebuilt.
  The previous update to this package mistakenly switched back to HAL
  from udev.  This has been fixed.  Thanks to Tomas M.
x/xf86-input-void-1.4.0-x86_64-3.txz:  Rebuilt.
x/xf86-input-wacom-0.19.0-x86_64-2.txz:  Rebuilt.
x/xf86-video-apm-1.2.5-x86_64-2.txz:  Rebuilt.
x/xf86-video-ark-0.7.5-x86_64-2.txz:  Rebuilt.
x/xf86-video-ast-0.97.0-x86_64-2.txz:  Rebuilt.
x/xf86-video-ati-7.1.0-x86_64-2.txz:  Rebuilt.
x/xf86-video-chips-1.2.5-x86_64-2.txz:  Rebuilt.
x/xf86-video-cirrus-1.5.2-x86_64-2.txz:  Rebuilt.
x/xf86-video-dummy-0.3.6-x86_64-2.txz:  Rebuilt.
x/xf86-video-glint-1.2.8-x86_64-2.txz:  Rebuilt.
x/xf86-video-i128-1.3.6-x86_64-2.txz:  Rebuilt.
x/xf86-video-i740-1.3.4-x86_64-2.txz:  Rebuilt.
x/xf86-video-intel-2.21.4-x86_64-1.txz:  Upgraded.
x/xf86-video-mach64-6.9.4-x86_64-2.txz:  Rebuilt.
x/xf86-video-mga-1.6.2-x86_64-2.txz:  Rebuilt.
x/xf86-video-modesetting-0.6.0-x86_64-2.txz:  Rebuilt.
x/xf86-video-neomagic-1.2.7-x86_64-2.txz:  Rebuilt.
x/xf86-video-nouveau-1.0.4-x86_64-2.txz:  Rebuilt.
x/xf86-video-nv-2.1.20-x86_64-3.txz:  Rebuilt.
x/xf86-video-openchrome-0.3.1-x86_64-3.txz:  Rebuilt.
x/xf86-video-r128-6.9.1-x86_64-2.txz:  Rebuilt.
x/xf86-video-rendition-4.2.5-x86_64-2.txz:  Rebuilt.
x/xf86-video-s3-0.6.5-x86_64-2.txz:  Rebuilt.
x/xf86-video-s3virge-1.10.6-x86_64-2.txz:  Rebuilt.
x/xf86-video-savage-2.3.6-x86_64-2.txz:  Rebuilt.
x/xf86-video-siliconmotion-1.7.7-x86_64-2.txz:  Rebuilt.
x/xf86-video-sis-0.10.7-x86_64-2.txz:  Rebuilt.
x/xf86-video-sisusb-0.9.6-x86_64-2.txz:  Rebuilt.
x/xf86-video-tdfx-1.4.5-x86_64-2.txz:  Rebuilt.
x/xf86-video-tga-1.2.2-x86_64-2.txz:  Rebuilt.
x/xf86-video-trident-1.3.6-x86_64-2.txz:  Rebuilt.
x/xf86-video-tseng-1.2.5-x86_64-2.txz:  Rebuilt.
x/xf86-video-v4l-0.2.0-x86_64-7.txz:  Rebuilt.
x/xf86-video-vesa-2.3.2-x86_64-2.txz:  Rebuilt.
x/xf86-video-vmware-13.0.0-x86_64-2.txz:  Rebuilt.
x/xf86-video-voodoo-1.2.5-x86_64-2.txz:  Rebuilt.
x/xf86-video-xgi-git_be3abf8570a-x86_64-2.txz:  Rebuilt.
x/xf86-video-xgixp-1.8.1-x86_64-2.txz:  Rebuilt.
x/xorg-server-1.14.0-x86_64-1.txz:  Upgraded.
  Dropped the broken randr patch for panning/scaling.  According to the
  release notes, a different fix was merged upstream.
  Dropped randr cleanup patch that was merged upstream.
x/xorg-server-xephyr-1.14.0-x86_64-1.txz:  Upgraded.
x/xorg-server-xnest-1.14.0-x86_64-1.txz:  Upgraded.
x/xorg-server-xvfb-1.14.0-x86_64-1.txz:  Upgraded.
x/xterm-291-x86_64-1.txz:  Upgraded.
xap/seamonkey-2.16.1-x86_64-1.txz:  Upgraded.
  This update contains security fixes and improvements.
  (* Security fix *)
[:domo-kun]
Ch'i tout vénér rháaaaaaaaaaaaa puragnafiée chier merde bordel enflure de crétin atrophié des bords -.-
Reader et Adaway, [:triste]
Message édité par cycojesus le 14-03-2013 à 11:07:26
n°1332763
wedgeant
Da penguin inside
Posté le 14-03-2013 à 11:06:19  profilanswer
Y'avait un grain dans la perle et dans le singe des mers  [:mickounet]
n°1332928
Posté le 15-03-2013 à 18:56:03  answer
Je me pose la question : c'est bien Slackware ?
n°1332932
Flying-Che​wbacca
What has been seen...
Posté le 15-03-2013 à 20:12:47  profilanswer
Ca dépend, t'as eu le droit à une retraite anticipée ou un emploi du temps de ministre?
n°1332938
regdub
Posté le 15-03-2013 à 21:39:10  profilanswer
Un souci avec Arch ?
Legalize it @HFR
Slackware 9.0[slackware] Suppression de terminaux virtuels ?
!! Configuration reseaux, slackware 9 !!Installer slackware 9.0 par ftp (boot disquette)
[Pb] Installation new HDD sous slackware 8.0[RESOLU] Pb d'execution mysql sur slackware ...
Slackware 9 du pur bonheurMonter une partition NTFS sous linux (slackware 9.0)
Slackware 9.0 Finale OUTJe sens que je vais quitter Slackware (pas en serv)
Plus de sujets relatifs à : [SLACKWARE] du présent - 15.0
