3384 connectés
La 15.0 est là (en vrai !)
Les invités peuvent voter
 Page :   1  2  3  4  5  ..  53  54  55  ..  109  110  111  112  113  114
[SLACKWARE] du présent - 15.0
n°1319540
el_barbone
too old for this shit ...
Posté le 10-09-2012 à 10:35:45  profilanswer
[:koukouille:3]
En théorie, la théorie et la pratique sont identiques, en pratique, non.
n°1319545
wedgeant
Da penguin inside
Posté le 10-09-2012 à 17:33:24  profilanswer
T'as l'bout qui s'tortille ha, mama mia caramba  [:speedy gonzales]
Wedge#2487 @HS -#- PW: +∞ -#- Khaz-Modan/Boltiz @WoW
n°1319571
cycojesus
Mèo Lười
Posté le 11-09-2012 à 07:08:05  profilanswer
C'est le matin, C'est le bien [:inspecteur derrick]
Mon Sep 10 22:19:55 UTC 2012
a/sysvinit-scripts-2.0-noarch-9.txz:  Rebuilt.
  In rc.M, make sure we are actually returning from runlevel 1 before trying
  to restart udev.  Thanks to Cal Peake.
a/udev-182-x86_64-5.txz:  Rebuilt.
  Don't enable autosuspend for some HID devices.  With a 3.5+ kernel, this
  might cause these input devices to become non-responsive.
  Thanks to Patrick Verner.
ap/alsa-utils-1.0.26-x86_64-1.txz:  Upgraded.
  Removed alsaconf, which does not work with kmod.
l/alsa-lib-1.0.26-x86_64-1.txz:  Upgraded.
l/gdk-pixbuf2-2.26.1-x86_64-2.txz:  Rebuilt.
  Patched update-gdk-pixbuf-loaders to fix output on multilib systems.
l/seamonkey-solibs-2.12.1-x86_64-1.txz:  Upgraded.
  This is a bugfix release.
x/scim-1.4.14-x86_64-2.txz:  Rebuilt.
  Compile using --with-gtk-version=2 to fix problems with scim-setup.
  Thanks to Thomas Choi and alienBOB.
xap/seamonkey-2.12.1-x86_64-1.txz:  Upgraded.
[:paparasta]  [:me gusta:5]
Chết rồi ! ✍ ⌥⌘ http://codeberg.org/gwh
n°1319597
wedgeant
Da penguin inside
Posté le 11-09-2012 à 19:42:21  profilanswer
[:kaio] [:kaio] [:kaio] [:kaio] [:kaio]
n°1319615
el_barbone
Posté le 11-09-2012 à 23:42:12  profilanswer
[:wark0][:wark0][:wark0][:wark0][:wark0][:wark0]
n°1319621
cycojesus
Mèo Lười
Posté le 12-09-2012 à 08:09:35  profilanswer
Un peu tard certes mais petit  [:mauvlam] déjeuner
Wed Sep 12 02:45:31 UTC 2012
a/sysvinit-scripts-2.0-noarch-10.txz:  Rebuilt.
  Use start parameter when running /etc/rc.d/rc.atalk.
n/ca-certificates-20120623-noarch-2.txz:  Rebuilt.
  Use an installer script to make sure that update-ca-certificates works on
  a fresh installation.  Thanks to DarkVision on LQ.
n/netatalk-2.2.3-x86_64-3.txz:  Rebuilt.
  Switched to a better rc.atalk that parses the contents of netatalk.conf.
  Thanks to gerasimos_h.
[:hephaestos]
n°1319633
cycojesus
Mèo Lười
Posté le 12-09-2012 à 11:10:11  profilanswer
derniers ajustements de slip avant le catwalk [:ca gratte]
Wed Sep 12 06:04:55 UTC 2012
n/netatalk-2.2.3-x86_64-4.txz:  Rebuilt.
  Fix the install script so that it leaves rc.atalk.new when the package is
  upgraded instead of deleting it and leaving nothing but the old rc.atalk.
  Thanks to Sorin Mitrica.
Ça sent la fête qu'approche [:campedel:1]
n°1319638
wedgeant
Da penguin inside
Posté le 12-09-2012 à 11:44:23  profilanswer
[:scarlettj:4]
n°1319643
Col Hanzap​last
Jurassic geek. Vive le cobol !
Posté le 12-09-2012 à 14:59:00  profilanswer
Je remonte sur scène dès que la Slack 14 est out ! [:tim_coucou]
" Il n'y a aucune chance pour que l'iPhone s'attribue une part de marché significative. Aucune chance. " (Steve Ballmer 2007)
n°1319722
cycojesus
Mèo Lười
Posté le 14-09-2012 à 07:15:19  profilanswer
Pas voilà, c'est pas fini [:mom boucher]
Fri Sep 14 01:16:31 UTC 2012
a/less-451-x86_64-1.txz:  Upgraded.
  This is a bugfix release.  (Seems more or less safe  ;-)
a/patch-2.7-x86_64-1.txz:  Upgraded.
  This version of patch ignores destination filenames that are absolute or
  that contain a component of "..", unless such a filename is provided as
  an argument.
  For more information, see:
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2010-4651
  (* Security fix *)
a/shadow-4.1.4.3-x86_64-7.txz:  Rebuilt.
  Fixed adduser and login.defs to add or suggest group "scanner", which
  might still be required by third party scanner drivers.
  Thanks to Alex Baer.
a/sysvinit-scripts-2.0-noarch-11.txz:  Rebuilt.
  Edited rc.S to talk about the 3.x kernel in the udev comments.
  Edited rc.M to run rc.udev in all cases again, not just when returning
  from runlevel 1.  Even if udev is running already, the additional
  trigger may be required in order to get some devices working.  The
  comment that indicated it should only be run when returning from
  runlevel 1 came from a time when the only purpose for rc.udev was to
  start it if it wasn't running.  The behavior has changed since then, so
  the comment has been fixed.  Guess I should have remembered the words of:
    fortune -m Storer
l/libsoup-2.38.1-x86_64-2.txz:  Rebuilt.
  Added the .la files back, as it's not yet safe to eliminate them in this
  package.  Thanks to Erik Hanson.
n/bind-9.9.1_P3-x86_64-1.txz:  Upgraded.
  This update fixes a security issue where named could crash on a specially
  crafted record.  [RT #30416]
  (* Security fix *)
[:digiamb:1]
n°1319763
regdub
Posté le 14-09-2012 à 18:14:52  profilanswer
 [:mortalenvers]
Message édité par regdub le 14-09-2012 à 18:15:27
Legalize it @HFR
n°1319764
regdub
Posté le 14-09-2012 à 18:18:18  profilanswer
A l'approche de la 14.0 et de tout le bonheur qui va l'accompagner, j'ai quand même une pensée émue pour les utilisateurs d'Arch qui ne peuvent plus installer leur distrib sans avoir accès à un ordi connecté au wiki arch à coté. :o
Message édité par regdub le 14-09-2012 à 18:18:47
Legalize it @HFR
n°1319770
cycojesus
Mèo Lười
Posté le 15-09-2012 à 08:33:55  profilanswer
tchia vu le P'date résalien ! [:akt]
Fri Sep 14 20:29:40 UTC 2012
n/dhcp-4.2.4_P2-x86_64-1.txz:  Upgraded.
  An issue with the use of lease times was found and fixed.  Making certain
  changes to the end time of an IPv6 lease could cause the server to abort.
  Thanks to Glen Eustace of Massey University, New Zealand for finding this
  issue.  [ISC-Bugs #30281]
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-3955
  (* Security fix *)
n/php-5.4.7-x86_64-1.txz:  Upgraded.
[:xaero]  [:juju414]
n°1319801
Magicpanda
Pushing the envelope
Posté le 16-09-2012 à 14:17:02  profilanswer
c est tellement ca :D
" Quel est le but du capital ? Le but du capital c'est produire pour le capital. L'objectif, lui, est illimité. L'objectif du capital c'est produire pour produire." - Deleuze || André Gorz - Vers la société libérée
n°1319803
agentsteel
Posté le 16-09-2012 à 14:43:39  profilanswer
si, avec la Manjaro c'est possib' :D
http://agentoss.wordpress.com/
n°1319933
cycojesus
Mèo Lười
Posté le 20-09-2012 à 07:12:32  profilanswer
Here we go with MC'5
Du 'pDate [:korner:2]
Du GL'ib [:fredmoul:3]
Ouane Maur Taïme [:youmoussa]
[:cyd125]
Wed Sep 19 23:52:16 UTC 2012
Here we go one more time with Slackware 14.0 release candidate 5.
Really, this time it is not a drill!  Everything is in place and
ready to release at this point, and unless there's some kind of
showstopper found (which doesn't seem too likely after all the
testing that's happened), the release can be expected soon.
After careful consideration and a considerable amount of internal
testing I did relent to give the kernel one more bump to 3.2.29,
so of course 3.2.30 was released a couple of hours ago.  ;-)
But that's not a showstopper, and it seems to be time to get off
the never-ending kernel upgrade treadmill until the next cycle
begins.  Speaking of kernels, I added sample .configs for all the
3.x kernel branches in /testing.  So test away, and if there are
any new problems (or old ones that we missed), let us know soon!
a/glibc-solibs-2.15-x86_64-7.txz:  Rebuilt.
a/glibc-zoneinfo-2012f_2012f-noarch-7.txz:  Rebuilt.
  Upgraded to tzcode2012f and tzdata2012f.
a/kernel-generic-3.2.29-x86_64-1.txz:  Upgraded.
a/kernel-huge-3.2.29-x86_64-1.txz:  Upgraded.
a/kernel-modules-3.2.29-x86_64-1.txz:  Upgraded.
a/patch-2.7-x86_64-2.txz:  Rebuilt.
  Applied two upstream git commits to fix bugs which could cause target
  files to be removed or truncated.  Thanks to Qun-Ying.
d/git-1.7.12.1-x86_64-1.txz:  Upgraded.
d/kernel-headers-3.2.29-x86-1.txz:  Upgraded.
d/slacktrack-2.12-x86_64-1.txz:  Upgraded.
  This is a bugfix release.  Thanks to Stuart Winter.
d/subversion-1.7.6-x86_64-1.txz:  Upgraded.
k/kernel-source-3.2.29-noarch-1.txz:  Upgraded.
l/glibc-2.15-x86_64-7.txz:  Rebuilt.
l/glibc-i18n-2.15-x86_64-7.txz:  Rebuilt.
l/glibc-profile-2.15-x86_64-7.txz:  Rebuilt.
n/samba-3.6.8-x86_64-1.txz:  Upgraded.
n/vsftpd-3.0.2-x86_64-1.txz:  Upgraded.
  This update contains a seccomp sandbox policy fix which stops session
  crashes when listing large directories logged in as a real local user.
  Thanks to Martin.
isolinux/initrd.img:  Rebuilt.
  Upgraded to Linux kernel 3.2.29.
kernels/*:  Upgraded.
testing/source/config-testing-3.4.11/*:  Added.
  Sample .config files for the 3.4.11 Linux kernel.
testing/source/config-testing-3.5.4/*:  Added.
  Sample .config files for the 3.5.4 Linux kernel.
testing/packages/config-testing-3.6-rc4*:  Added.
  Sample .config files for the 3.6-rc4 Linux kernel.
usb-and-pxe-installers/usbboot.img:  Rebuilt.
[:badoit on the rocks]
n°1319934
wedgeant
Da penguin inside
Posté le 20-09-2012 à 07:58:44  profilanswer
[:wark0]
n°1320002
cycojesus
Mèo Lười
Posté le 22-09-2012 à 07:43:54  profilanswer
C'est le test
Test
La testacíon des testicouilles [:depardieu]
Sat Sep 22 00:34:26 UTC 2012
I'll go along with the last minute request to provide the released stable
version of xf86-video-nouveau.  The reason that we hadn't done this is that
the stable version of Mesa won't compile with this version of libdrm.  But,
since xf86-video-nouveau compiles fine with this libdrm and the Mesa we're
already shipping, it seems reasonable to provide them here in /testing.
Thanks to Didier Spaier.
testing/packages/libdrm-2.4.39-x86_64-1.txz:  Added.
testing/packages/xf86-video-nouveau-1.0.2-x86_64-1.txz:  Added.
[:depardieu:3]
n°1320003
cycojesus
Mèo Lười
Posté le 22-09-2012 à 07:51:51  profilanswer
Notons les ecrits du M.osieur:http://alien.slackbook.org/blog/end-of-the-week-end-of-the-cycle/
n°1320111
Col Hanzap​last
Posté le 24-09-2012 à 13:12:41  profilanswer
Un bruit court comme quoi la nouvelle slackware ne sortirait que dans deux ans ! Très exactement le 14/14/2014 :heink:
n°1320115
wedgeant
Da penguin inside
Posté le 24-09-2012 à 13:37:07  profilanswer
[:cmshadow]  [:delarue3]  [:tom barker]
n°1320141
cycojesus
Mèo Lười
Posté le 25-09-2012 à 07:12:29  profilanswer
Ha ha ha
Que t'y croyait
Que t'y a cru
Turlututu
Chapeau P.ointu [:anteus]
Mon Sep 24 20:25:12 UTC 2012
Here are a few minor bugfixes as well as a couple more test drivers for X:
a/e2fsprogs-1.42.6-x86_64-1.txz:  Upgraded.
a/sysvinit-scripts-2.0-noarch-12.txz:  Rebuilt.
  In rc.M, don't run rc.wicd if /usr/sbin/wicd does not exist.  This change
  prevents a leftover rc.wicd from blocking NetworkManager startup.
l/gamin-0.1.10-x86_64-5.txz:  Rebuilt.
  Patched to fix a deadlock bug, and to fix building against recent libraries.
  Thanks to sberthelot, sombragris, and ponce on LQ.
l/mozilla-nss-3.13.5-x86_64-3.txz:  Rebuilt.
  Added libcrmf.a to the package, needed to compile xulrunner.
  Thanks to Robby Workman.
  Upgraded to e2fsprogs-1.42.6.
testing/packages/xf86-video-intel-2.20.8-x86_64-1.txz:  Added.
  This driver requires the libdrm in /testing.
testing/packages/xf86-video-ati-6.14.6-x86_64-1.txz:  Added.
testing/source/config-testing-3.*:  Rebuilt.
  Changed CONFIG_GFS2_FS in huge kernels from y -> m to fix the compile.
[:timothius:3]
n°1320142
wedgeant
Da penguin inside
Posté le 25-09-2012 à 08:18:15  profilanswer
La forte envie qui te tient  [:hahatention madame]
Ne te lache plus  [:extraelle]
n°1320179
cycojesus
Mèo Lười
Posté le 26-09-2012 à 07:09:57  profilanswer
P.at fait durer le plaisir [:lezioul:3]
Tue Sep 25 17:52:58 UTC 2012
a/sysvinit-scripts-2.0-noarch-13.txz:  Rebuilt.
  Changed the path in rc.M for wicd from relative to absolute.  It works
  either way, but it should be an absolute path just to be consistent with
  the rest of the script.
[:rockbottom:3]
n°1320369
gui42
Posté le 29-09-2012 à 07:05:20  profilanswer
:bounce:
debout là dedans
Yes, it is that time again!  After well over a year of planning,
development, and testing, the Slackware Linux Project is proud to
announce the latest stable release of the longest running distribution
of the Linux operating system, Slackware version 14.0!
Bon week-end !
n°1320371
cycojesus
Mèo Lười
Posté le 29-09-2012 à 09:05:07  profilanswer
Embarrassons-nous sous le gui [:plo-ck]
Wed Sep 26 01:10:42 UTC 2012
Slackware 14.0 x86_64 stable is released!
We're perfectionists here at Slackware, so this release has been a long
time a-brewing.  But we think you'll agree that it was worth the wait.
Slackware 14.0 combines modern components, ease of use, and flexible
configuration... our "KISS" philosophy demands it.
The ISOs are off to be replicated, a 6 CD-ROM 32-bit set and a dual-sided
32-bit/64-bit x86/x86_64 DVD.  Please consider supporting the Slackware
project by picking up a copy from store.slackware.com.  We're taking
pre-orders now, and offer a discount if you sign up for a subscription.
Thanks to everyone who helped make this happen.  The Slackware team, the
upstream developers, and (of course) the awesome Slackware user community.
Have fun!  :-)
[:polo99991:2]  [:bibliophage:1]
Message édité par cycojesus le 29-09-2012 à 09:05:58
n°1320374
Col Hanzap​last
Posté le 29-09-2012 à 09:54:54  profilanswer
Miracle ! [:shimay:1]
On a du bol. Dans deux mois c'est la fin du monde...
n°1320375
regdub
Posté le 29-09-2012 à 10:02:49  profilanswer
[:anne-gaelle1]
Legalize it @HFR
n°1320384
etranger
Posté le 29-09-2012 à 17:31:33  profilanswer
Aujourd'hui, quel est l'avantage d'utiliser une Slackware au lieu d'une autre distribution ?
n°1320387
agentsteel
Posté le 29-09-2012 à 20:45:48  profilanswer
La Slackware est stable et simple à administrer (si on sait lire les man et la doc).
Bonne nouvelle, le wiki officiel tout nouveau :
http://docs.slackware.com/
Plutôt conservatrice -  dans le choix des softs par défaut (sendmail par exemple), scripts d'init BSD
A mon avis, une des distros les plus simples pour se faire la main pour créer des packages (cf les slackbuilds).
n°1320393
Neji Hyuga
:grut:
Posté le 30-09-2012 à 12:53:42  profilanswer
Pas de fioritures, facile à maintenir, pas de packages dans tous les sens pour des fonctions dont on ne servira jamais etc...
Le système fait ce qu'on lui demande, point.
Pour apprendre réellement comment fonctionne un système Linux, c'est excellent
n°1320395
etranger
Posté le 30-09-2012 à 13:33:54  profilanswer
Je prècise que je suis débutant dans le monde linux !
Pas de foiritures, facile à maintenir, pas de packages dans tous les sens pour des fonctions dont on ne servira jamais etc...
Se n'est pas se que fait archlinux mais avec une plus grande communauté et un meilleur gestionnaire de package ?
J'utilise quasimment que archlinux depuis que j'ai choisi de me passer de windows et j'ai beaucoups apris durant l'installation (les installations plutot). ça ma pas mal servis quand j'ai essayé d'autre distribs comme ubuntu, mint, openSuse , slackware, fedora.
Mais avec cette nouvelle version je vais re-essayé slackware. Le problème c'est que je suis sur un portable récent avec la technologie optimus, sous archlinux il y a bumblebee et tout les drivers a jour. Je ne sais pas ce qui en est sur Slakware.
n°1320397
agentsteel
Posté le 30-09-2012 à 16:34:11  profilanswer
Comme dit plus haut, l'avantage de la Slack par rapport à Arch, c'est que tu peux installer le système sans avoir besoin du wiki à côté! :)
Arch a plus de paquets dans ses dépôts, oui. Aucune idée pour Bumblebee mais ça doit pouvoir se trouver.
n°1320412
wedgeant
Da penguin inside
Posté le 30-09-2012 à 20:03:20  profilanswer
Slack c'est pas pour les noobs épicétou [:nozdormu]
n°1320413
wedgeant
Da penguin inside
Posté le 30-09-2012 à 20:06:32  profilanswer
Pour bumblebee... euh... j'ai une cg nvidia optimus, j'ai jamais eu besoin du bouzin, X se démerde très bien pour switcher entre la cg intel intégrée avec le driver kivabien et la cg nvidia avec le driver nouveau... [:petrus75]
n°1320415
Neji Hyuga
:grut:
Posté le 30-09-2012 à 20:43:39  profilanswer
Personnellement je n'installe pas une Slackware pour me servir d'un gestionnaire de paquets (voir pas de paquets du tout) ni pour solliciter la communauté dès que je rencontre un problème.
Il faut voir une Slack comme une feuille blanche où tu y dessines ce que tu veux.
C'est très bon pour apprendre réellement les bases et les mécanismes d'un système UNIX/Linux.
n°1320420
agentsteel
Posté le 30-09-2012 à 22:34:20  profilanswer
Bon je me suis fait une petite install rapide de cette 14.0
pour les noobs qui n'en veulent, cf mon blog :D
n°1320487
etranger
Posté le 01-10-2012 à 21:47:46  profilanswer
Sans bumblebee il ne switch pas, tu utilise soit l'une soit l'autre. Et tu ne sais pas si celle que tu n'utlise pas tourne ou non.
Bumblebee te permet d'utiliser la nvidia quand tu en a besoin et de l'étaindre lorsque tu ne l'utilise pas (via bbswitch) pour économiser l'énérgie.
En attendant les drivers nvidia  :whistle:
n°1320492
Neji Hyuga
:grut:
Posté le 01-10-2012 à 22:25:45  profilanswer
Après le joli troll de Torvald, je pense qu'on peut toujours attendre :o
n°1320525
wedgeant
Da penguin inside
Posté le 02-10-2012 à 10:22:32  profilanswer
bah c'est rigolo quand même, par défaut c'est le driver intel qui est chargé chez moi, et pourtant quand j'ai besoin d'une appli 3d, c'est tout de suite super fluide  [:getalife] (avec une intel intégrée qui ne fait pas de 3d  [:chrisbk])
n°1320527
wedgeant
Da penguin inside
Posté le 02-10-2012 à 10:31:13  profilanswer
Je viens de jeter un oeil dessus ...
C'est une bonne initiative, mais c'est illisible (malheureusement  :sweat: ), pas aéré, pas indenté ...  [:everything4free]
Et c'est grosso modo la même doc d'install/conf post install qu'on trouve déjà partout, c'est un peu dommage :spamafote:
Ca serait une bonne idée que tu ajoutes ta touche perso, tes tips à toi ...
Slackware 9.0[slackware] Suppression de terminaux virtuels ?
!! Configuration reseaux, slackware 9 !!Installer slackware 9.0 par ftp (boot disquette)
[Pb] Installation new HDD sous slackware 8.0[RESOLU] Pb d'execution mysql sur slackware ...
Slackware 9 du pur bonheurMonter une partition NTFS sous linux (slackware 9.0)
Slackware 9.0 Finale OUTJe sens que je vais quitter Slackware (pas en serv)
Plus de sujets relatifs à : [SLACKWARE] du présent - 15.0
