2394 connectés
La 15.0 est là (en vrai !)
Les invités peuvent voter
 Page :   1  2  3  4  5  ..  51  52  53  ..  109  110  111  112  113  114
[SLACKWARE] du présent - 15.0
n°1315853
el_barbone
too old for this shit ...
Posté le 10-07-2012 à 15:35:46  profilanswer
[:serious thread]
En théorie, la théorie et la pratique sont identiques, en pratique, non.
n°1316083
cycojesus
Mèo Lười
Posté le 14-07-2012 à 08:18:24  profilanswer
[...] et le Treizième jour P.at, magnanime et Bon, refit le M.onde et introduisit le Dang.er [:dtc haha:5]
Tèje le Java
Pète le XeuFeuCeuhEu
Gtk+3
Fri Jul 13 23:14:15 UTC 2012
It's Friday the 13th, and Mercury is going into retrograde...  seems like the
perfect time to break things!  A few notes are in order here...   first, we've
switched to using openssl-1.0.1c, which changes the major number for the
crypto and ssl libraries from .0 to .1, meaning everything linked with the
previous version of openssl will need to be recompiled.  The
lib{crypto,ssl}.so.0 libraries were backed up into aaa_elflibs, but this only
means that binaries linked with those libraries will start, not that SSL will
continue to work for them.  The hashing format in /etc/ssl/certs/ has changed,
so any programs linking to the old libraries will not be able to use them.
Next, Java has gone away due to licensing restrictions...  Finally, these
changes have broken Xfce as it exists in -current at the moment, but I'll try
to do something about that soon.  Thanks to Robby Workman and Eric Hameleers
for lots of help on these updates!
a/aaa_elflibs-14.0-x86_64-1.txz:  Upgraded.
a/cryptsetup-1.4.3-x86_64-1.txz:  Upgraded.
a/cups-1.5.3-x86_64-2.txz:  Rebuilt.
a/cxxlibs-6.0.17-x86_64-1.txz:  Upgraded.
a/dbus-1.4.20-x86_64-1.txz:  Upgraded.
a/grep-2.13-x86_64-1.txz:  Upgraded.
a/gzip-1.5-x86_64-1.txz:  Upgraded.
a/kernel-generic-3.2.23-x86_64-1.txz:  Upgraded.
a/kernel-huge-3.2.23-x86_64-1.txz:  Upgraded.
a/kernel-modules-3.2.23-x86_64-1.txz:  Upgraded.
a/lvm2-2.02.96-x86_64-1.txz:  Upgraded.
a/mdadm-3.2.5-x86_64-1.txz:  Upgraded.
a/mkinitrd-1.4.7-x86_64-1.txz:  Upgraded.
  Thanks to Robby Workman.
  Added mdmon to initrd if RAID=1.  Thanks to Marek Wodzinski.
  Add firmware needed by modules.  Thanks to ecd102 on LQ.
a/openssl-solibs-1.0.1c-x86_64-1.txz:  Upgraded.
a/pciutils-3.1.9-x86_64-1.txz:  Upgraded.
  Moved the location of pci.ids to /usr/share/hwdata.
a/sysvinit-2.88dsf-x86_64-1.txz:  Upgraded.
a/sysvinit-scripts-2.0-noarch-1.txz:  Upgraded.
a/udev-175-x86_64-1.txz:  Upgraded.
a/upower-0.9.17-x86_64-1.txz:  Upgraded.
a/usbutils-006-x86_64-1.txz:  Upgraded.
  Moved the location of usb.ids to /usr/share/hwdata.
a/util-linux-2.21.2-x86_64-1.txz:  Upgraded.
ap/cdrdao-1.2.3-x86_64-2.txz:  Rebuilt.
ap/cdrtools-3.01a07-x86_64-1.txz:  Upgraded.
ap/ghostscript-9.05-x86_64-3.txz:  Rebuilt.
ap/gphoto2-2.4.14-x86_64-1.txz:  Upgraded.
ap/gutenprint-5.2.8-x86_64-2.txz:  Rebuilt.
ap/hplip-3.12.6-x86_64-2.txz:  Rebuilt.
ap/man-pages-3.41-noarch-1.txz:  Upgraded.
ap/mc-4.8.1.3-x86_64-1.txz:  Upgraded.
ap/moc-2.5.0_alpha4-x86_64-2.txz:  Rebuilt.
ap/mysql-5.5.25a-x86_64-1.txz:  Upgraded.
d/doxygen-1.8.1.1-x86_64-1.txz:  Upgraded.
d/git-1.7.11.1-x86_64-1.txz:  Upgraded.
d/kernel-headers-3.2.23-x86-1.txz:  Upgraded.
d/llvm-3.0-x86_64-2.txz:  Rebuilt.
d/perl-5.16.0-x86_64-2.txz:  Rebuilt.
d/python-2.7.3-x86_64-2.txz:  Rebuilt.
d/ruby-1.9.3_p194-x86_64-2.txz:  Rebuilt.
d/subversion-1.7.5-x86_64-3.txz:  Rebuilt.
e/emacs-24.1-x86_64-2.txz:  Rebuilt.
k/kernel-source-3.2.23-noarch-1.txz:  Upgraded.
  Changes to configuration:
  CONFIG_SCSI_ISCSI_ATTRS=m
  # CONFIG_BCMA is not set
  CONFIG_BRCMSMAC=m
  CONFIG_SCSI_ISCSI_ATTRS was made modular since the iSCSI userspace will not
  work with it built in.  This change disallows building the QLogic 40xx
  (ISP4XXX) and 8022 (ISP82XX) into the huge kernel, but for the same reason
  those would not have worked for installation anyway.
  CONFIG_BCMA was turned off because including it prevents building the
  Broadcom BRCMSMAC driver, which is the only working choice for several
  adapters other than the proprietary wl driver.  Unfortunately, removing
  BCMA removes support for bcm4331 from the b43 driver.  However, adding the
  BRCMSMAC causes several new adaptors to gain support, including some that
  are becoming quite common in recent laptops, so overall this change should
  be a net gain.
kde/amarok-2.5.0-x86_64-5.txz:  Rebuilt.
kde/calligra-2.4.3-x86_64-1.txz:  Upgraded.
kde/kdelibs-4.8.4-x86_64-2.txz:  Rebuilt.
kde/kdemultimedia-4.8.4-x86_64-2.txz:  Rebuilt.
kde/kdepim-4.8.4-x86_64-2.txz:  Rebuilt.
kdei/calligra-l10n-ca-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-ca\@valencia-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-cs-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-da-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-de-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-el-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-en_GB-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-es-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-et-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-fi-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-fr-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-hu-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-it-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-kk-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-nb-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-nds-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-nl-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-pl-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-pt-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-pt_BR-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-ru-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-sk-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-sv-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-uk-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-zh_CN-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-zh_TW-2.4.3-noarch-1.txz:  Upgraded.
l/ConsoleKit-0.4.5-x86_64-1.txz:  Upgraded.
l/M2Crypto-0.21.1-x86_64-2.txz:  Rebuilt.
l/apr-util-1.4.1-x86_64-3.txz:  Rebuilt.
l/atk-2.4.0-x86_64-1.txz:  Upgraded.
l/babl-0.1.10-x86_64-1.txz:  Upgraded.
l/dbus-glib-0.98-x86_64-1.txz:  Upgraded.
l/dbus-python-1.1.0-x86_64-1.txz:  Upgraded.
l/desktop-file-utils-0.20-x86_64-1.txz:  Upgraded.
l/gdk-pixbuf2-2.26.1-x86_64-1.txz:  Upgraded.
l/gegl-0.2.0-x86_64-1.txz:  Upgraded.
l/glib2-2.32.3-x86_64-1.txz:  Upgraded.
l/gnome-icon-theme-3.4.0-x86_64-1.txz:  Upgraded.
l/gobject-introspection-1.32.1-x86_64-1.txz:  Added.
l/gst-plugins-base-0.10.36-x86_64-1.txz:  Upgraded.
l/gst-plugins-good-0.10.31-x86_64-1.txz:  Upgraded.
l/gstreamer-0.10.36-x86_64-1.txz:  Upgraded.
l/gtk+2-2.24.10-x86_64-1.txz:  Upgraded.
l/gtk+3-3.4.3-x86_64-1.txz:  Added.
l/jre-6u27-x86_64-1.txz:  Removed.
l/libarchive-2.8.5-x86_64-1.txz:  Upgraded.
l/libcddb-1.3.2-x86_64-2.txz:  Rebuilt.
l/libcdio-0.83-x86_64-1.txz:  Upgraded.
l/libcroco-0.6.5-x86_64-1.txz:  Added.
l/libgphoto2-2.4.14-x86_64-1.txz:  Upgraded.
  Fixed to generate correct udev rules.
  Thanks to Brad Hermanson.
l/libmsn-4.2.1-x86_64-2.txz:  Rebuilt.
l/libmtp-1.1.3-x86_64-1.txz:  Upgraded.
l/libnl3-3.2.11-x86_64-1.txz:  Added.
l/libnotify-0.7.5-x86_64-1.txz:  Upgraded.
l/libogg-1.3.0-x86_64-1.txz:  Upgraded.
l/libpcap-1.3.0-x86_64-1.txz:  Upgraded.
l/librsvg-2.36.1-x86_64-1.txz:  Upgraded.
l/libvncserver-0.9.9-x86_64-2.txz:  Rebuilt.
l/libvorbis-1.3.3-x86_64-1.txz:  Upgraded.
l/libwnck-2.30.7-x86_64-2.txz:  Rebuilt.
l/libxklavier-5.2.1-x86_64-1.txz:  Upgraded.
l/libyaml-0.1.4-x86_64-1.txz:  Added.
  Thanks to Vincent Batts.
l/loudmouth-1.4.3-x86_64-2.txz:  Rebuilt.
l/mozilla-nss-3.13.5-x86_64-1.txz:  Added.
l/neon-0.29.6-x86_64-2.txz:  Rebuilt.
l/notify-python-0.1.1-x86_64-3.txz:  Rebuilt.
l/pango-1.30.1-x86_64-1.txz:  Upgraded.
l/polkit-0.105-x86_64-1.txz:  Upgraded.
l/polkit-gnome-0.102-x86_64-1.txz:  Upgraded.
l/poppler-0.18.4-x86_64-1.txz:  Upgraded.
l/poppler-data-0.4.5-noarch-1.txz:  Upgraded.
l/pycurl-7.19.0-x86_64-2.txz:  Rebuilt.
l/pygobject-2.28.6-x86_64-1.txz:  Upgraded.
l/pygtk-2.24.0-x86_64-1.txz:  Upgraded.
l/qca-ossl-2.0.0_beta3-x86_64-2.txz:  Rebuilt.
l/qt-4.8.2-x86_64-1.txz:  Upgraded.
l/raptor-1.4.21-x86_64-1.txz:  Removed.
  This package is no longer used -- everything links to raptor2 instead.
  Plus, it overlaps with raptor2's /usr/bin/rapper binary, so make sure
  after removing it that you've got the right copy of that, reinstalling
  raptor2 if needed.  Thanks to G�rard Monpontet.
l/redland-1.0.15-x86_64-4.txz:  Rebuilt.
l/seamonkey-solibs-2.10.1-x86_64-2.txz:  Rebuilt.
l/shared-mime-info-1.0-x86_64-1.txz:  Upgraded.
l/v4l-utils-0.8.8-x86_64-2.txz:  Upgraded.
l/virtuoso-ose-6.1.3-x86_64-3.txz:  Rebuilt.
n/NetworkManager-0.9.4.0-x86_64-1.txz:  Upgraded.
  Link with Mozilla NSS rather than GnuTLS.
n/alpine-2.02-x86_64-1.txz:  Upgraded.
  Now using the re-alpine sources.
n/bind-9.9.1_P1-x86_64-2.txz:  Rebuilt.
n/bluez-4.99-x86_64-1.txz:  Upgraded.
n/bluez-hcidump-2.4-x86_64-1.txz:  Upgraded.
n/ca-certificates-20120623-noarch-1.txz:  Upgraded.
n/curl-7.26.0-x86_64-2.txz:  Rebuilt.
n/cyrus-sasl-2.1.23-x86_64-4.txz:  Rebuilt.
n/dhcp-4.2.4-x86_64-1.txz:  Upgraded.
n/dhcpcd-5.5.6-x86_64-1.txz:  Upgraded.
n/epic5-1.1.3-x86_64-1.txz:  Upgraded.
n/fetchmail-6.3.21-x86_64-2.txz:  Rebuilt.
n/gnupg-1.4.12-x86_64-1.txz:  Upgraded.
n/gnupg2-2.0.19-x86_64-1.txz:  Upgraded.
n/gnutls-3.0.21-x86_64-1.txz:  Upgraded.
n/gpgme-1.3.2-x86_64-1.txz:  Upgraded.
n/htdig-3.2.0b6-x86_64-4.txz:  Rebuilt.
n/httpd-2.4.2-x86_64-3.txz:  Rebuilt.
n/imapd-2.02-x86_64-1.txz:  Upgraded.
n/iproute2-3.4.0-x86_64-1.txz:  Upgraded.
n/iptables-1.4.14-x86_64-1.txz:  Upgraded.
n/irssi-0.8.15-x86_64-6.txz:  Rebuilt.
n/iw-3.5-x86_64-1.txz:  Upgraded.
n/lftp-4.3.8-x86_64-1.txz:  Upgraded.
n/libassuan-2.0.3-x86_64-1.txz:  Upgraded.
n/libgcrypt-1.5.0-x86_64-1.txz:  Upgraded.
n/libgpg-error-1.10-x86_64-1.txz:  Upgraded.
n/links-2.7-x86_64-1.txz:  Upgraded.
n/lynx-2.8.7-x86_64-3.txz:  Rebuilt.
n/mailx-12.5-x86_64-1.txz:  Upgraded.
n/mutt-1.5.21-x86_64-2.txz:  Rebuilt.
n/net-snmp-5.6.1-x86_64-4.txz:  Rebuilt.
n/netatalk-2.0.5-x86_64-2.txz:  Rebuilt.
n/nettle-2.5-x86_64-1.txz:  Added.
n/nmap-6.01-x86_64-2.txz:  Rebuilt.
n/ntp-4.2.6p5-x86_64-2.txz:  Rebuilt.
n/openldap-client-2.4.31-x86_64-2.txz:  Rebuilt.
n/openssh-6.0p1-x86_64-2.txz:  Rebuilt.
n/openssl-1.0.1c-x86_64-1.txz:  Upgraded.
n/openvpn-2.2.2-x86_64-1.txz:  Upgraded.
n/p11-kit-0.12-x86_64-1.txz:  Added.
n/php-5.4.4-x86_64-1.txz:  Upgraded.
  This release fixes a weakness in the DES implementation of crypt
  and a heap overflow issue in the phar extension.
  (* Security fix *)
n/pidentd-3.0.19-x86_64-2.txz:  Rebuilt.
n/popa3d-1.0.2-x86_64-3.txz:  Rebuilt.
n/proftpd-1.3.4a-x86_64-2.txz:  Rebuilt.
n/samba-3.6.6-x86_64-1.txz:  Upgraded.
n/sendmail-8.14.5-x86_64-3.txz:  Rebuilt.
n/sendmail-cf-8.14.5-noarch-3.txz:  Rebuilt.
n/slrn-0.9.9p1-x86_64-4.txz:  Rebuilt.
n/snownews-1.5.12-x86_64-2.txz:  Rebuilt.
n/stunnel-4.53-x86_64-1.txz:  Rebuilt.
n/tcpdump-4.3.0-x86_64-1.txz:  Upgraded.
n/vsftpd-3.0.0-x86_64-2.txz:  Rebuilt.
n/wget-1.13.4-x86_64-1.txz:  Upgraded.
n/wpa_supplicant-1.0-x86_64-1.txz:  Upgraded.
x/fontconfig-2.9.0-x86_64-1.txz:  Upgraded.
x/mesa-8.0.4-x86_64-1.txz:  Upgraded.
x/pixman-0.26.2-x86_64-1.txz:  Upgraded.
x/xdg-user-dirs-0.14-x86_64-1.txz:  Upgraded.
x/xorg-server-1.12.3-x86_64-1.txz:  Upgraded.
x/xorg-server-xephyr-1.12.3-x86_64-1.txz:  Upgraded.
x/xorg-server-xnest-1.12.3-x86_64-1.txz:  Upgraded.
x/xorg-server-xvfb-1.12.3-x86_64-1.txz:  Upgraded.
xap/MPlayer-1.1_20120701-x86_64-1.txz:  Upgraded.
  Latest 1.1 branch checkout.  Thanks to alienBOB.
xap/audacious-3.2.4-x86_64-1.txz:  Upgraded.
xap/audacious-plugins-3.2.4-x86_64-1.txz:  Upgraded.
xap/fluxbox-1.3.2-x86_64-1.txz:  Upgraded.
xap/fvwm-2.6.5-x86_64-1.txz:  Upgraded.
xap/gftp-2.0.19-x86_64-3.txz:  Rebuilt.
xap/gimp-2.8.0-x86_64-1.txz:  Upgraded.
xap/gkrellm-2.3.5-x86_64-2.txz:  Rebuilt.
xap/gucharmap-3.4.1-x86_64-1.txz:  Upgraded.
xap/mozilla-firefox-13.0.1-x86_64-2.txz:  Rebuilt.
  Don't build in the main source directory.  Thanks to ponce.
xap/mozilla-thunderbird-13.0.1-x86_64-2.txz:  Rebuilt.
xap/pan-0.139-x86_64-1.txz:  Upgraded.
xap/pidgin-2.10.6-x86_64-1.txz:  Upgraded.
  Fixes a security issue for users of MXit:  Incorrect handing of inline
  images in incoming instant messages can cause a buffer overflow and in
  some cases can be exploited to execute arbitrary code.
  For more information, see:
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-3374
  (* Security fix *)
xap/rdesktop-1.7.1-x86_64-3.txz:  Rebuilt.
xap/sane-1.0.22-x86_64-4.txz:  Rebuilt.
xap/seamonkey-2.10.1-x86_64-2.tx:  Rebuilt.
  Removed nss.pc and nspr.pc symlinks.
xap/windowmaker-0.95.3-x86_64-1.txz:  Upgraded.
xap/x3270-3.3.12ga7-x86_64-2.txz:  Rebuilt.
xap/xchat-2.8.8-x86_64-6.txz:  Rebuilt.
xap/xsane-0.998-x86_64-2.txz:  Rebuilt.
extra/jdk-6/jdk-6u27-x86_64-1.txz:  Removed.
isolinux/initrd.img:  Rebuilt.
  Change location of usb.ids and pci.ids to /usr/share/hwdata.
  Patched busybox to fix wget -P option.  Thanks to Kirill Smirnoff.
  Allow nic=auto for headless installs.  Thanks to alienBOB.
  Fixed /sbin/probe for systems that mix HP RAID with regular hard drives.
  Thanks to mario.
usb-and-pxe-installers/usbboot.img:  Rebuilt.
Faites quand même un backup, Émile [:shit hahat:4]
Message édité par cycojesus le 14-07-2012 à 08:25:15
Chết rồi ! ✍ ⌥⌘ http://codeberg.org/gwh
n°1316128
cycojesus
Mèo Lười
Posté le 15-07-2012 à 08:50:09  profilanswer
P.at pense aux galopins fiévreux [:bakk31]
Pa.t aide slackpkg
Sun Jul 15 01:40:08 UTC 2012
Juggle a few things around so that slackpkg won't fall over while upgrading
from 13.37 or an earlier -current:
a/aaa_elflibs-14.0-x86_64-2.txz:  Rebuilt.
  Don't include libcrypto.so.0 and libssl.so.0 in here.
  The openssl-solibs package is a better place for them.
a/openssl-solibs-1.0.1c-x86_64-2.txz:  Rebuilt.
  Moved the old 0.9.8x libraries here.
n/openssl-1.0.1c-x86_64-2.txz:  Rebuilt.
n/wget-1.13.4-x86_64-2.txz:  Rebuilt.
  Prefer linking with OpenSSL, since the license allows it.
  This is less of a moving target than GnuTLS.
[:ti3go]
n°1316156
wedgeant
Da penguin inside
Posté le 15-07-2012 à 14:37:56  profilanswer
cycojesus a écrit :
Tèje le Java
Ouais ... euh ... ça va l'faire moyen là quand même :/
edith: du coup, j'upgrade pas [:elessar53]
xfce c'est un peu beaucoup ce que j'utilise là :o
Message édité par wedgeant le 15-07-2012 à 14:38:40
Wedge#2487 @HS -#- PW: +∞ -#- Khaz-Modan/Boltiz @WoW
n°1316184
gui42
Posté le 15-07-2012 à 21:14:49  profilanswer
bonsoir
je vais surement dire 1 (2?) bêtises mais comment on fait sans Java ? Y'a quand même un certain nombre de sites qui l'utilisent ?
n°1316185
regdub
Posté le 15-07-2012 à 21:23:51  profilanswer
gui42 a écrit :
bonsoir
openjdk va arriver à la place, j'imagine
edit: je crois qu'il faudrait dire IcedTea plutôt que openjdk pour parler de la suite libre complète avec le plugin web, sachant que openjdk est utilisé comme nom de package par IcedTea
Message édité par regdub le 15-07-2012 à 21:36:54
Legalize it @HFR
n°1316194
cycojesus
Mèo Lười
Posté le 16-07-2012 à 07:01:41  profilanswer
La chaussette fantôme, le chainon manquant de l'évolution [:professeur moriarty]
Mon Jul 16 02:46:21 UTC 2012
a/lvm2-2.02.96-x86_64-3.txz:  Rebuilt.
  Removed static libraries.
  Fixed broken /usr/lib64/libdevmapper-event-lvm2raid.so symlink.
  Thanks to Patrick Verner.
Sun Jul 15 17:10:38 UTC 2012
a/lvm2-2.02.96-x86_64-2.txz:  Rebuilt.
  Recompiled to generate fixed /lib/udev/rules.d/13-dm-disk.rules.
a/mkinitrd-1.4.7-x86_64-2.txz:  Rebuilt.
  According to rworkman, udev is indeed required now in early boot for any
  system using an initrd, so we'll set UDEV=1 in mkinitrd (leaving -u as a
  no-op).  This should clear up the issues with the /init script that
  expected udevadm to be present.
  Use ldconfig -l to ensure all shared libraries have the correct symlinks.
  Thanks to Olek on LQ.
ap/sox-14.4.0-x86_64-1.txz:  Upgraded.
l/libspectre-0.2.6-x86_64-1.txz:  Upgraded.
[:mika123]
n°1316206
wedgeant
Da penguin inside
Posté le 16-07-2012 à 10:51:01  profilanswer
gui42 a écrit :
bonsoir
Pat a dit qu'il allait bosser sur la question, mais c'est clair que pour le moment, si on a besoin de la jvm, ne pas faire la mise à jour en -current est la bonne option :o
Cela dit, il restera la solution (aussi) de paquetiser tout ça soi même :o
n°1316212
cycojesus
Mèo Lười
Posté le 16-07-2012 à 11:37:53  profilanswer
Le Gens B.on a du Java paquage là :
http://connie.slackware.com/~alien [...] s/openjdk/
http://connie.slackware.com/~alien [...] edtea-web/
Message édité par cycojesus le 16-07-2012 à 11:38:12
n°1316248
gui42
Posté le 16-07-2012 à 21:29:07  profilanswer
ok, merci à vous. On va attendre que ça s'éclaircisse donc.
Et merci Pat et Alien surtout [:prosterne]
n°1316260
cycojesus
Mèo Lười
Posté le 17-07-2012 à 07:06:21  profilanswer
Des gentils paquets de B.onté [:wumalpy]
pour le petit déjeuner [:topchef:5]
Tue Jul 17 00:21:46 UTC 2012
a/mkinitrd-1.4.7-x86_64-3.txz:  Rebuilt.
  Issue /sbin/ldconfig differently to avoid linking to old library versions
  that might be present on the system.
  Use fixed 13-dm-disk.rules.
  Added top-level /run directory.
Mon Jul 16 19:00:08 UTC 2012
a/sysvinit-scripts-2.0-noarch-2.txz:  Rebuilt.
  Changed /etc/inittab to clear consoles after logout (actually before
  starting /bin/login from agetty *except* for the first console with the boot
  messages.  This seems a good compromise, and also prevents getting locked
  out of the machine if someone drops back to an earlier version of util-linux
  for some reason.  I found that one out the hard way.  ;-)
a/ntfs-3g-2012.1.15-x86_64-2.txz:  Rebuilt.
  Made /bin/ntfs-3g setuid root, because otherwise it refuses to allow
  non-root users to mount volumes now, even if /etc/fstab allows it.
a/util-linux-2.21.2-x86_64-2.txz:  Rebuilt.
  Use --enable-libmount-mount, not --enable-new-mount.  The latter option
  breaks umount for users, even when /etc/fstab should allow it.
  Thanks to Chris Vine for the bug report.
Yipi yipi yé [:azyl:1]
n°1316264
wedgeant
Da penguin inside
Posté le 17-07-2012 à 08:33:57  profilanswer
Et la java dans tout ça ?
 [:gingerspirit:5]
n°1316267
el_barbone
Posté le 17-07-2012 à 08:44:13  profilanswer
[:wark0]
n°1316268
cycojesus
Mèo Lười
Posté le 17-07-2012 à 08:49:37  profilanswer
 [:gingerspirit:5]
Moi quand je lis le T.out P.uissant écrire
je me dis que ja 'a chier pour Java qui a proprement valser du B.ien pour se retrouvé seul et pleurnichant dans le vide. Pis les entrailles de P.oulet font remarquer que le Java du D.isciple a bougé de http://connie.slackware.com/~alien/openjdk/ (<- D.isciple prépare des trucs trop forts et dans sa magnanimitude le partage avec P.euple) à http://connie.slackware.com/~alien [...] s/openjdk/ (<- D.isciple joue avec ses jouets que les rêves les plus fous placent hors du bas à sable.)
Juste mes 2¢ sur ces S.aintes écritures [:sharliecheen:4]
n°1316269
wedgeant
Da penguin inside
Posté le 17-07-2012 à 09:15:45  profilanswer
Openjdk  [:shimay:1]
n°1316270
el_barbone
Posté le 17-07-2012 à 09:16:45  profilanswer
[:koukouille:3]
n°1316342
FranceDenB​as
1 dépense = 1 socialiss' :o
Posté le 18-07-2012 à 09:47:45  profilanswer
La 14 est en cours de préparation, elle n'est pas disponible pour de vrai (titre trompeur :o ), y'a une date (précise ou non) pour la vraie dispo ?
"Il a inventé le bougisme : je bouge donc je suis" :sol: - Dupont-Aignan à propos de Son Altesse Sérénissime Sarkal 1er. Merci Handsome Devil et Meriadeck.
n°1316343
wedgeant
Da penguin inside
Posté le 18-07-2012 à 10:06:29  profilanswer
[:wark0]
n°1316344
wedgeant
Da penguin inside
Posté le 18-07-2012 à 10:07:52  profilanswer
Hé ho, quand tu fais l'upgrade en -current, c'est 14.0 qui s'affiche [:elessar53]
Et elle sera prête quand elle sera prête :o
n°1316351
FranceDenB​as
Posté le 18-07-2012 à 10:33:30  profilanswer
ok (pour le "vrai", je parlais de stable = 14.0). :o
Message édité par FranceDenBas le 18-07-2012 à 10:34:35
n°1316394
cycojesus
Mèo Lười
Posté le 18-07-2012 à 22:26:05  profilanswer
C'est la B.ière
Qui comme ton frère
Apporte
Ta face dans la porte [:inek]
Wed Jul 18 05:35:26 UTC 2012
a/mkinitrd-1.4.7-x86_64-4.txz:  Rebuilt.
  Added support for compressed kernel modules.
  Thanks to Stuart Winter.
kde/kdepimlibs-4.8.4-x86_64-2.txz:  Rebuilt.
kde/perlqt-4.8.4-x86_64-2.txz:  Rebuilt.
kde/qtruby-4.8.4-x86_64-2.txz:  Rebuilt.
kde/rocs-4.8.4-x86_64-2.txz:  Rebuilt.
kde/smokeqt-4.8.4-x86_64-2.txz:  Rebuilt.
l/fribidi-0.19.2-x86_64-2.txz:  Rebuilt.
  Patched headers for compatibility with the new glib2 package.
  Thanks to Darrell Anderson.
l/gst-plugins-good-0.10.31-x86_64-2.txz:  Rebuilt.
l/hal-0.5.14-x86_64-3.txz:  Removed.
l/hal-info-20091130-noarch-1.txz:  Removed.
l/libexif-0.6.21-x86_64-1.txz:  Upgraded.
  This update fixes a number of remotely exploitable issues in libexif
   with effects ranging from information leakage to potential remote
   code execution.
    http://sourceforge.net/mailarchive/message.php?msg_id=29534027
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-2812
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-2813
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-2814
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-2836
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-2837
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-2840
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-2841
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-2845
  (* Security fix *)
l/libgphoto2-2.4.14-x86_64-2.txz:  Rebuilt.
l/libvisual-0.4.0-x86_64-3.txz:  Rebuilt.
  Patched header for compatibility with the new glib2 package.
l/seamonkey-solibs-2.11-x86_64-1.txz:  Upgraded.
  This release contains security fixes and improvements.
    http://www.mozilla.org/security/known-vulnerabilities/seamonkey.html
  (* Security fix *)
l/wv2-0.4.2-x86_64-1.txz:  Removed.
  Calligra doesn't require this (it bundles a forked version), nor does
  anything else in Slackware.  It is unmaintained upstream and requires
  patching to compile with the recent glib2.  Perhaps SlackBuilds.org
  should take it over?  If so, change all occurances of:
  #include <glib/*> to #include <glib.h>
n/net-snmp-5.6.1-x86_64-5.txz:  Rebuilt.
xap/mozilla-firefox-14.0.1-x86_64-1.txz:  Upgraded.
    http://www.mozilla.org/security/known-vulnerabilities/firefox.html
  (* Security fix *)
xap/mozilla-thunderbird-14.0-x86_64-1.txz:  Upgraded.
    http://www.mozilla.org/security/known-vulnerabilities/thunderbird.html
  (* Security fix *)
xap/seamonkey-2.11-x86_64-1.txz:  Upgraded.
  (* Security fix *)
mozilla-la-la [:cvpr] hal [:sid sidious]
n°1316398
cycojesus
Mèo Lười
Posté le 18-07-2012 à 23:58:17  profilanswer
RAB (Rab À Boire)
Wed Jul 18 20:21:15 UTC 2012
l/hicolor-icon-theme-0.12-noarch-2.txz:  Rebuilt.
  Don't update (create) icon theme caches unless they exist already.
  Once created, these icon registries cause problems unless they are
  rebuilt every time new icons are added.  If you have any
  icon-theme.cache files under /usr/share/icons, it would be a good
  idea to get rid of them (unless you're planning to handle keeping
  them up to date).
n/gpa-0.9.2-x86_64-1.txz:  Upgraded.
n/iputils-s20101006-x86_64-2.txz:  Rebuilt.
xap/MPlayer-1.1_20120701-x86_64-2.txz:  Rebuilt.
  them up to date).
[:ethnik:2]  [:depardieu:3]
n°1316399
cycojesus
Mèo Lười
Posté le 19-07-2012 à 00:03:59  profilanswer
wv2
n°1316406
wedgeant
Da penguin inside
Posté le 19-07-2012 à 08:31:40  profilanswer
[:nozdormu]
n°1316659
cycojesus
Mèo Lười
Posté le 23-07-2012 à 07:07:38  profilanswer
Lecture de le Lundi dans le matin
À l'heure où verdit le thé
P.at te livre la pâtée [:double c]
Sun Jul 22 22:38:36 UTC 2012
Howdy!  Lots of shiny stuff here, including the long awaited Xfce 4.10!
Thanks to Robby Workman for the initial set of build scripts, and lots
of testing (plus some very helpful notes about things such as the proper
build order).  I'm calling this a beta (finally!), and it's really very
close to what we expect to release.  Test away.
BTW, Mercury leaves retrograde on August 8th, position 01:26 Leo.  ;-)
a/aaa_elflibs-14.0-x86_64-3.txz:  Rebuilt.
  Fixed missing libz.so.1.
a/lvm2-2.02.96-x86_64-4.txz:  Rebuilt.
  Recompiled for udev-182.
a/sysvinit-scripts-2.0-noarch-3.txz:  Rebuilt.
  Show the date after setting the system clock.
  Shut down udev in rc.6.  Thanks to Robby Workman.
  In rc.S, determine the actual root partition and insert it into /etc/mtab
  so that "/dev/root" isn't shown when booting a kernel without an initrd.
  I should have fixed this years ago.
a/udev-182-x86_64-1.txz:  Upgraded.
  Well, udev in this devel cycle has certainly been interesting!  A fair
  number of odd bug reports have been coming in, and we hadn't really been
  able to get a handle on the source of the issues.  Quite some time ago
  we started testing udev-182, and noticed that it caused some issues with
  the persistent net and cd rules.  There'd sometimes be two entries per
  device, so a machine with a single Ethernet card might come up showing the
  card as eth1, with two rules in 70-persistent-net.rules (eth0 and eth1).
  We tested a lot of udev versions trying to determine where the problem
  started, and it seemed to begin with version 176, the first one that
  used libkmod rather than calling out to module-init-tools to load modules.
  Asking upstream about it, they suggested that we just turn the generation
  of persistent rules off.  They'd already turned it off by default.  "Make
  'em make rules!" seemed to be the answer, and since I remember well why
  the autogeneration of net and CD rules came about, I wasn't really happy
  with that answer.  After deploying the "safe" upgrade to 175, we got a
  couple of reports of this same issue happening (though none of us could
  reproduce the issue with 175).  Robby ended up making some patches to
  the rule writing scripts for udev-182 that were able to stop the doubling
  up of rules, but the devices themselves would still be misnumbered on the
  first boot without rules, and would then be correct after a reboot.
    Last week I sat down determined to figure out where the race condition
  was.  After endless reboots with various tests, I got the idea to put my
  network modules on the initrd and have it shell out so that I could take
  a look at them.  What I found was that the rules were generated correctly
  on the initrd.  Well, that was a surprise, but I must have had some kind
  of hunch to even try a test like that.  On another hunch, I ran
  "pstree -c -p | grep udevd" on the running system.  Heh.  There it was.
  We had been running two copies of udevd, and they were fighting it out.
  At some point along the line, udevd was changed.  It used to be that if
  you tried to start a second copy it wouldn't start, and would exit with
  status 1, and our rc.udev script relied on this behavior.  Fixing the
  problem was considerably easier than finding it...  rworkman and I made
  some changes in rc.udev to check if udevd was already running instead
  of expecting it to check for itself.  Another change was required to
  cause it to write out rules if they didn't exist already, and then to
  read them back in (otherwise optical symlinks were still missing on first
  boot without rules).  There's still one issue that was also present with
  udev-175, which is that a hotplugged optical drive won't get symlinks
  unless it has been in at boot and had rules generated for it then.
  Otherwise, things are looking considerably better.  Firmware is loading
  correctly, rules are autogenerated properly again, and several devices
  that were missing in /dev have returned.
    So, there's the story.  Maybe more than you really wanted to know.  ;-)
  Thanks to rworkman for his help on this.  Please report any new problems.
  And if anyone knows how to get symlinks working for a hotplugged optical
  drive like they did in udev-165, a fix would be most appreciated.
a/udisks2-1.98.0-x86_64-1.txz:  Added.
ap/foomatic-filters-4.0.12-x86_64-1.txz:  Upgraded.
ap/gutenprint-5.2.9-x86_64-1.txz:  Upgraded.
ap/slackpkg-2.82.0-noarch-6.tgz:  Rebuilt.
  Support XFCE series.  Note that slackpkg will upgrade itself, but it still
  won't know about the XFCE series during that run, so you'll need to run it
  a second time to install Xfce.
l/GConf-3.2.5-x86_64-1.txz:  Added.
l/gcr-3.4.1-x86_64-1.txz:  Added.
l/glade3-3.8.1-x86_64-1.txz:  Added.
l/glib-networking-2.32.3-x86_64-1.txz:  Added.
l/gnome-keyring-3.4.1-x86_64-1.txz:  Added.
l/gsettings-desktop-schemas-3.4.2-noarch-1.txz:  Added.
l/gvfs-1.12.3-x86_64-1.txz:  Added.
l/js185-1.0.0-x86_64-1.txz:  Added.
l/keybinder-0.3.0-x86_64-1.txz:  Added.
l/libcanberra-0.29-x86_64-1.txz:  Added.
l/libgnome-keyring-3.4.1-x86_64-1.txz:  Added.
l/libproxy-0.4.7-x86_64-1.txz:  Added.
l/libsoup-2.38.1-x86_64-1.txz:  Added.
l/libtasn1-2.12-x86_64-1.txz:  Added.
l/loudmouth-1.4.3-x86_64-3.txz:  Rebuilt.
  Rebuilt with --enable-debug=yes, which I hear disables debugging messages on
  the console.  Go figure.  :-)  Thanks to Youjie Zhou.
l/media-player-info-17-noarch-1.txz:  Added.
l/mozilla-nss-3.13.5-x86_64-2.txz:  Rebuilt.
  Added nspr-config and nss-config.
  Removed unneeded binaries in /usr/bin.
  Removed config files in /usr/include/nspr/md.
l/sound-theme-freedesktop-0.7-noarch-1.txz:  Added.
n/php-5.4.5-x86_64-1.txz:  Upgraded.
  Fixed potential overflow in _php_stream_scandir (CVE-2012-2688).
  (Thanks to Jason Powell, Stas)
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-2688
  (* Security fix *)
xap/network-manager-applet-0.9.4.1-x86_64-1.txz:  Added.
xap/xfce-4.6.2-x86_64-5.txz:  Removed.
xfce/Terminal-0.4.8-x86_64-1.txz:  Added.
xfce/Thunar-1.4.0-x86_64-1.txz:  Added.
xfce/exo-0.8.0-x86_64-1.txz:  Added.
xfce/garcon-0.2.0-x86_64-1.txz:  Added.
xfce/gtk-xfce-engine-3.0.0-x86_64-1.txz:  Added.
xfce/libxfce4ui-4.10.0-x86_64-1.txz:  Added.
xfce/libxfce4util-4.10.0-x86_64-1.txz:  Added.
xfce/libxfcegui4-4.10.0-x86_64-1.txz:  Added.
xfce/orage-4.8.3-x86_64-1.txz:  Added.
xfce/thunar-volman-0.8.0-x86_64-1.txz:  Upgraded.
xfce/tumbler-0.1.25-x86_64-1.txz:  Added.
xfce/xfce4-appfinder-4.10.0-x86_64-1.txz:  Added.
xfce/xfce4-clipman-plugin-1.2.3-x86_64-1.txz:  Added.
xfce/xfce4-dev-tools-4.10.0-x86_64-1.txz:  Added.
xfce/xfce4-mixer-4.8.0-x86_64-1.txz:  Added.
xfce/xfce4-notifyd-0.2.2-x86_64-1.txz:  Upgraded.
xfce/xfce4-panel-4.10.0-x86_64-1.txz:  Added.
xfce/xfce4-power-manager-1.2.0-x86_64-1.txz:  Upgraded.
xfce/xfce4-screenshooter-1.8.1-x86_64-1.txz:  Added.
xfce/xfce4-session-4.10.0-x86_64-1.txz:  Added.
xfce/xfce4-settings-4.10.0-x86_64-1.txz:  Added.
xfce/xfce4-systemload-plugin-1.1.0-x86_64-1.txz:  Added.
xfce/xfce4-taskmanager-1.0.0-x86_64-1.txz:  Added.
xfce/xfce4-volumed-0.1.13-x86_64-1.txz:  Added.
xfce/xfce4-weather-plugin-0.7.4-x86_64-1.txz:  Added.
xfce/xfconf-4.10.0-x86_64-1.txz:  Added.
xfce/xfdesktop-4.10.0-x86_64-1.txz:  Added.
xfce/xfwm4-4.10.0-x86_64-1.txz:  Added.
xfce/xfwm4-themes-4.10.0-x86_64-1.txz:  Added.
xeufeuceuïsée [:jeje84:1]
n°1316672
wedgeant
Da penguin inside
Posté le 23-07-2012 à 09:30:59  profilanswer
Allez, Loup, Yä !
 [:shimay:1]
Leave me aloooone !
  [:loup gris]
n°1316847
cycojesus
Mèo Lười
Posté le 25-07-2012 à 08:13:23  profilanswer
D'update
Wed Jul 25 02:02:40 UTC 2012
a/ed-1.6-x86_64-1.txz:  Upgraded.
a/etc-13.013-x86_64-2.txz:  Rebuilt.
  Get rid of broken /etc/skel/.xsession.  Thanks to GazL.
a/logrotate-3.8.1-x86_64-2.txz:  Rebuilt.
  Fixed cron script to not log an error when there wasn't one.
  Thanks to NoStressHQ and GazL on LQ.
a/sysvinit-scripts-2.0-noarch-4.txz:  Rebuilt.
  Fixed rc.S to handle /dev/root properly in cases where /etc/fstab contains
  CIFS volumes (and lines start with //).  Thanks to John.
a/udev-182-x86_64-2.txz:  Rebuilt.
  Add another sanity check to rc.udev to warn if CONFIG_DEVTMPFS and
  CONFIG_DEVTMPFS_MOUNT are not enabled in the kernel.
ap/zsh-5.0.0-x86_64-1.txz:  Upgraded.
e/emacs-24.1-x86_64-3.txz:  Rebuilt.
  Don't use GConf.
l/gvfs-1.12.3-x86_64-2.txz:  Rebuilt.
  Don't restart D-Bus in the installation script.  It causes errors from
  the installer, and is no longer needed anyway since D-Bus notices
  changed configuration without a reload.
  Don't automount network volumes (causes a long startup delay in Thunar).
l/libpng-1.4.12-x86_64-1.txz:  Upgraded.
  Fixed incorrect type (int copy should be png_size_t copy) in png_inflate()
  (fixes CVE-2011-3045).
  Revised png_set_text_2() to avoid potential memory corruption (fixes
    CVE-2011-3048).
  Changed "a+w" to "u+w" in Makefile.in to fix CVE-2012-3386.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2011-3045
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2011-3048
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-3386
  (* Security fix *)
xap/network-manager-applet-0.9.4.1-x86_64-2.txz:  Rebuilt.
  Use GTK+2 for the UI, not GTK+3 (better theme matching).
xfce/xfce4-weather-plugin-0.8.0-x86_64-1.txz:  Upgraded.
xfce/xfwm4-4.10.0-x86_64-2.txz:  Rebuilt.
  Modified xinitrc.xfce to handle system-wide .Xresources and .Xmodmap.
  Launch startxfce4 using ck-launch-session and/or dbus-launch to fix problems
  with using XDM.  This same approach should also help Thunar on other window
  managers.  Let me know if there are any issues, as I'll likely be applying
  these changes to the other xinitrc files.  Thanks to GazL on LQ.
extra/bash-completion/bash-completion-2.0-noarch-2.txz:  Rebuilt.
  Updated the slackpkg and slapt-get completions for the XFCE series.
  Thanks to Igor Murzov.
ed _o/
zsh \o_
emacs \0/
Message édité par cycojesus le 25-07-2012 à 08:16:55
n°1316849
wedgeant
Da penguin inside
Posté le 25-07-2012 à 08:20:17  profilanswer
emacs c'est pour les ploupes :o
 [:camino]
n°1316928
Tsomi
From station to station
Posté le 25-07-2012 à 21:18:57  profilanswer
L'ajout de Gconf... [:rfv]
n°1317046
cycojesus
Mèo Lười
Posté le 28-07-2012 à 08:44:34  profilanswer
Le Poulpe frappe [:lefab]
et expulse GConf de son corps
Fri Jul 27 17:15:24 UTC 2012
a/util-linux-2.21.2-x86_64-3.txz:  Rebuilt.
  Use /bin/hostname from the git version of net-tools.
e/emacs-24.1-x86_64-4.txz:  Rebuilt.
  Fixed ./configure, which needed --without-gconf, not --disable-gconf.
kde/calligra-2.4.3-x86_64-2.txz:  Rebuilt.
kde/gwenview-4.8.4-x86_64-2.txz:  Rebuilt.
kde/kde-baseapps-4.8.4-x86_64-2.txz:  Rebuilt.
  Fixed missing /etc/profile.d/kde.{sh,csh} scripts.
kde/kde-runtime-4.8.4-x86_64-2.txz:  Rebuilt.
kde/kdeartwork-4.8.4-x86_64-2.txz:  Rebuilt.
kde/kdegraphics-thumbnailers-4.8.4-x86_64-2.txz:  Rebuilt.
kde/kdeplasma-addons-4.8.4-x86_64-2.txz:  Rebuilt.
kde/libkexiv2-4.8.4-x86_64-2.txz:  Rebuilt.
l/exiv2-0.23-x86_64-1.txz:  Upgraded.
  This bumps the shared library version, requiring more rebuilds.
l/strigi-0.7.7-x86_64-2.txz:  Rebuilt.
n/bind-9.9.1_P2-x86_64-1.txz:  Upgraded.
  Prevents a named assert (crash) when validating caused by using
  "Bad cache" data before it has been initialized.  [RT #30025]
  ISC_QUEUE handling for recursive clients was updated to address a
  race condition that could cause a memory leak.  This rarely occurred
  with UDP clients, but could be a significant problem for a server
  handling a steady rate of TCP queries.  [RT #29539 & #30233]
  Under heavy incoming TCP query loads named could experience a
  memory leak which could lead to significant reductions in query
  response or cause the server to be terminated on systems with
  "out of memory" killers. [RT #29539]
  A condition has been corrected where improper handling of zero-length
  RDATA could cause undesirable behavior, including termination of
  the named process.  [RT #29644]
  (* Security fix *)
n/net-tools-1.60.20120726git-x86_64-1.txz:  Upgraded.
  ifconfig was broken when using CIDR notation, fixed by switching to the
  git version of net-tools.  Thanks to Igor Alov.
xap/geeqie-1.0-x86_64-4.txz:  Rebuilt.
  Fixed missing space in SeTnet.  Thanks to John Pullan.
  Use -s option for eject.
[:brokk21]
n°1317073
wedgeant
Da penguin inside
Posté le 28-07-2012 à 15:12:07  profilanswer
Et tu fais la mise à jour dans ton corps haletant et frèle [:dawak]
Et tu sens ton système qui devient bon et fort [:dawak]
n°1317188
cycojesus
Mèo Lười
Posté le 31-07-2012 à 07:10:04  profilanswer
hop là, un bus qu'atteri dans tes céréales c'est la petit bonheur du matin [:ackernul]
Mon Jul 30 20:42:03 UTC 2012
a/udev-182-x86_64-3.txz:  Rebuilt.
  Since many people blacklist aaa_base when upgrading with slackpkg, add a
  top-level /run directory to prevent problems.
l/gsettings-desktop-schemas-3.4.2-x86_64-2.txz:  Rebuilt.
  Since this requires /usr/lib64 on x86_64, the package should not be built
  as "noarch".  Thanks to Eugene Wissner.
l/libdbusmenu-qt-0.9.2-x86_64-2.txz:  Rebuilt.
  Relocate documentation.
n/curl-7.27.0-x86_64-1.txz:  Upgraded.
n/iproute2-3.4.0-x86_64-2.txz:  Rebuilt.
  Removed unused config files in wrong (/usr/etc) location.
  Thanks to Lars Lindqvist.
xap/blackbox-0.70.1-x86_64-5.txz:  Rebuilt.
  Start D-Bus in the xinitrc.
xap/fluxbox-1.3.2-x86_64-2.txz:  Rebuilt.
xap/fvwm-2.6.5-x86_64-2.txz:  Rebuilt.
xap/windowmaker-0.95.3-x86_64-2.txz:  Rebuilt.
  Removed OpenSUSE menu.
xfce/xfce4-systemload-plugin-1.1.1-x86_64-1.txz:  Upgraded.
extra/source/java/*:  Added.
  Added a script to repackage Oracle's Java JRE or JDK as a Slackware package.
B.ien [:robuchon]
Message édité par cycojesus le 31-07-2012 à 07:11:06
n°1317198
wedgeant
Da penguin inside
Posté le 31-07-2012 à 12:08:42  profilanswer
Moi j'vous l'dis, l'upgrade de xfce 4.vieux à xfce 4.neuf, eh ben ça s'fait pas tout seul :o
Je me suis retrouvé avec une barre toute pourrie, qu'il a fallu que je delete toute ma config pour la refaire ... [:thalis]
Mais bon, maintenant c'est beau [:dawak]
n°1317199
el_barbone
Posté le 31-07-2012 à 12:09:32  profilanswer
en même temps, là t'as que ça à foutre ... [:koukouille:3]
n°1317201
wedgeant
Da penguin inside
Posté le 31-07-2012 à 12:11:31  profilanswer
Accessoirement, j'ai un déménagement à préparer, aussi :o
Pis j'voulais mater le p'tit cul des brésiliennes sur le replay du beach-volley, mais les nanas jouent en combi  [:le kneu]  [:le kneu]  [:le kneu]
n°1317203
el_barbone
Posté le 31-07-2012 à 12:16:15  profilanswer
c'est pour quand [:opus dei]
n°1317206
wedgeant
Da penguin inside
Posté le 31-07-2012 à 13:33:56  profilanswer
Fin aout  [:fatidik972]
n°1317263
cycojesus
Mèo Lười
Posté le 02-08-2012 à 07:14:02  profilanswer
alors que début août il se passe ceci [:ericshawn:5]
Wed Aug  1 20:24:06 UTC 2012
a/dbus-1.4.20-x86_64-2.txz:  Rebuilt.
  Patched rc.messagebus to restart the system D-Bus daemon even if a user
  daemon is running (as it does now with X11 sessions).
  Thanks to Darren Austin.
a/sysvinit-2.88dsf-x86_64-2.txz:  Rebuilt.
  Fixed paths.h for /etc/forcefsck and /etc/fastboot.
  Thanks to Ken Milmore.
a/sysvinit-scripts-2.0-noarch-5.txz:  Rebuilt.
  Removed my convoluted /dev/root workaround in favor of a much more simple,
  elegant solution.  Thanks to Gary Langshaw.
e/emacs-24.1-x86_64-5.txz:  Rebuilt.
  Recompiled --without-gsettings, which should fix runtime complaints.
xap/xpdf-3.02pl6-x86_64-4.txz:  Rebuilt.
  Patched to fix slow scrolling caused by a quirk exposed in newer versions
  of gcc.  Patch by Michael Gilbert.  Thanks to LQ for pointing it out.
extra/google-chrome/google-chrome.SlackBuild:  Modified.
  Allow $ARCH to be preset before running the script.  This is useful for
  systems running a 32-bit userspace under a 64-bit kernel, perhaps in a
  chroot environment.  Thanks to Zhu Qun-Ying.
P.at bichone B.ien²
n°1317316
wedgeant
Da penguin inside
Posté le 02-08-2012 à 16:16:54  profilanswer
This is S.Pa.rtaaaaaaa  [:leonidas ier]
n°1317336
cycojesus
Mèo Lười
Posté le 03-08-2012 à 07:12:48  profilanswer
Oh mon bateau oh oh oh [:destremau]
C'est le plus beau des bateaux oh oh [:dovakor:5]
Thu Aug  2 23:16:33 UTC 2012
a/cups-1.5.4-x86_64-1.txz:  Upgraded.
a/util-linux-2.21.2-x86_64-4.txz:  Rebuilt.
  Added an upstream patch to fix loop encryption in mount.
  Thanks to Kris Karas.
  Added back "line" utility.  Thanks to Marco Arioli.
  Added an upstream patch to fix sector granularity in fdisk.
ap/mysql-5.5.25a-x86_64-2.txz:  Rebuilt.
  Change the private header installation to match what MariaDB is now doing.
  Thanks to Heinz Wiesinger.
kde/calligra-2.4.3-x86_64-3.txz:  Rebuilt.
kde/okular-4.8.4-x86_64-2.txz:  Rebuilt.
l/icu4c-49.1.2-x86_64-1.txz:  Added.
l/libwpd-0.9.4-x86_64-1.txz:  Upgraded.
l/poppler-0.20.2-x86_64-1.txz:  Upgraded.
  Thanks to Eric Hameleers.
xfce/tumbler-0.1.25-x86_64-2.txz:  Rebuilt.
extra/source/java/java.SlackBuild:  Patched.
  Fixed a missing [ that was causing jdk to be packaged with a dangling
  symlink.  Thanks to Josiah Boothby.
icu4c [:justhynbrydhou:2]
n°1317377
regdub
Posté le 05-08-2012 à 04:41:26  profilanswer
retour du Slackware Package Browser
http://packages.slackware.com
 [:tietie006]
Message édité par regdub le 05-08-2012 à 04:41:42
Legalize it @HFR
Slackware 9.0[slackware] Suppression de terminaux virtuels ?
!! Configuration reseaux, slackware 9 !!Installer slackware 9.0 par ftp (boot disquette)
[Pb] Installation new HDD sous slackware 8.0[RESOLU] Pb d'execution mysql sur slackware ...
Slackware 9 du pur bonheurMonter une partition NTFS sous linux (slackware 9.0)
Slackware 9.0 Finale OUTJe sens que je vais quitter Slackware (pas en serv)
Plus de sujets relatifs à : [SLACKWARE] du présent - 15.0
