3341 connectés
La 15.0 est là (en vrai !)
Les invités peuvent voter
 Page :   1  2  3  4  5  ..  46  47  48  ..  109  110  111  112  113  114
[SLACKWARE] du présent - 15.0
n°1287506
wedgeant
Da penguin inside
Posté le 12-08-2011 à 09:58:05  profilanswer
htop [:dawak]
Wedge#2487 @HS -#- PW: +∞ -#- Khaz-Modan/Boltiz @WoW
n°1287610
cycojesus
Mèo Lười
Posté le 13-08-2011 à 21:34:52  profilanswer
Du cadeau pour tous [:pad78]
32bitiste et de navarre
mange
Fri Aug 12 23:20:00 UTC 2011
d/binutils-2.21.53.0.2-i486-1.txz:  Upgraded.
n/bind-9.7.4-i486-1.txz:  Upgraded.
  This BIND update addresses a couple of security issues:
  * named, set up to be a caching resolver, is vulnerable to a user
    querying a domain with very large resource record sets (RRSets)
    when trying to negatively cache the response. Due to an off-by-one
    error, caching the response could cause named to crash. [RT #24650]
    [CVE-2011-1910]
  * Change #2912 (see CHANGES) exposed a latent bug in the DNS message
    processing code that could allow certain UPDATE requests to crash
    named. [RT #24777] [CVE-2011-2464]
  For more information, see:
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2011-1910
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2011-2464
  (* Security fix *)
Fri Aug 12 16:25:35 UTC 2011
ap/htop-0.9-i486-1.txz:  Added.
  Oops, this was missing on 32-bit.  Thanks to Willy Sudiarto Raharjo.
hmm, que du bon miam  [:ethnik]
Chết rồi ! ✍ ⌥⌘ http://codeberg.org/gwh
n°1287671
cycojesus
Mèo Lười
Posté le 15-08-2011 à 09:51:49  profilanswer
Internettes-toi, Slackeux,
Firefoxise avant tout le monde [:ami-el]
Sun Aug 14 17:49:30 UTC 2011
n/wget-1.13-x86_64-1.txz:  Upgraded.
xap/mozilla-firefox-6.0-x86_64-1.txz:  Upgraded.
[:takuya007:1]
n°1287727
wedgeant
Da penguin inside
Posté le 16-08-2011 à 08:36:56  profilanswer
firefox 6, c'est la betalphaprerilize ou bien ? [:transparency]
n°1287730
el_barbone
too old for this shit ...
Posté le 16-08-2011 à 08:45:26  profilanswer
[:hahaguy]
En théorie, la théorie et la pratique sont identiques, en pratique, non.
n°1288513
cycojesus
Mèo Lười
Posté le 25-08-2011 à 20:20:45  profilanswer
Java
Mozilla
Soma
Firmwa'
 [:chkl:5]
Thu Aug 25 09:10:45 UTC 2011
a/kernel-firmware-20110814git-noarch-1.txz:  Upgraded.
  Fetch the latest kernel firmware from git -- the stuff in the kernel sources
  is somewhat stale.
ap/soma-2.7.1-noarch-1.txz:  Added.
  Soma is a command line/dialog Internet radio player.
  Thanks to David Woodfall.
l/jre-6u27-x86_64-1.txz:  Upgraded.
n/php-5.3.8-x86_64-1.txz:  Upgraded.
  Security fixes vs. 5.3.6 (5.3.7 was not usable):
  Updated crypt_blowfish to 1.2. (CVE-2011-2483)
  Fixed crash in error_log(). Reported by Mateusz Kocielski
  Fixed buffer overflow on overlog salt in crypt().
  Fixed bug #54939 (File path injection vulnerability in RFC1867
  File upload filename). Reported by Krzysztof Kotowicz. (CVE-2011-2202)
  Fixed stack buffer overflow in socket_connect(). (CVE-2011-1938)
  Fixed bug #54238 (use-after-free in substr_replace()). (CVE-2011-1148)
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2011-1148
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2011-1938
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2011-2202
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2011-2483
  (* Security fix *)
extra/jdk-6/jdk-6u27-x86_64-1.txz:  Upgraded.
testing/packages/mozilla-firefox-7.0b1-x86_64-1.txz:  Added.
Caca-boud*ah nan tiens, PHP [:tenaka]
n°1289482
cycojesus
Mèo Lười
Posté le 06-09-2011 à 08:48:27  profilanswer
Tue Sep 06 00:15:03 UTC 2011 (* Security fix *)
l/seamonkey-solibs-2.3.3-x86_64-1.txz: Upgraded
    This update contains security fixes and improvements.
    http://www.mozilla.org/security/announce/
    http://www.mozilla.org/security/announce/2011/mfsa2011-34.html
  (* Security fix *)
n/httpd-2.2.20-x86_64-1.txz: Upgraded
    SECURITY: CVE-2011-3192 (cve.mitre.org)
  core: Fix handling of byte-range requests to use less memory, to avoid
  denial of service. If the sum of all ranges in a request is larger than
  the original file, ignore the ranges and send the complete file.
  PR 51714. [Stefan Fritsch, Jim Jagielski, Ruediger Pluem, Eric Covener]
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2011-3192
  (* Security fix *)
xap/mozilla-firefox-6.0.2-x86_64-1.txz: Upgraded
    This release contains security fixes and improvements.
    http://www.mozilla.org/security/known-vulnerabilities/firefox.html
  (* Security fix *)
xap/mozilla-thunderbird-6.0.1-x86_64-1.txz: Upgraded
    http://www.mozilla.org/security/known-vulnerabilities/thunderbird.html
  (* Security fix *)
xap/seamonkey-2.3.3-x86_64-1.txz: Upgraded
  (* Security fix *)
testing/mozilla-firefox-7.0b4-x86_64-1.txz: Upgraded
ouillé  [:la fugue:2]
n°1289489
wedgeant
Da penguin inside
Posté le 06-09-2011 à 09:15:40  profilanswer
sécuritifix  [:corpsmourant]
Message édité par wedgeant le 06-09-2011 à 09:16:06
n°1289680
cycojesus
Mèo Lười
Posté le 06-09-2011 à 19:52:40  profilanswer
...and one more thing [:cd5:1]
Tue Sep  6 16:53:43 UTC 2011
n/openssh-5.9p1-x86_64-1.txz:  Upgraded.
T'y a cru hein à ton upgrade de folie, bah non [:the dark m:3]
n°1289796
cycojesus
Mèo Lười
Posté le 07-09-2011 à 23:00:51  profilanswer
[:dupdup17:1] Petit armateur de laid, as-tu vu cette Software Collection qui te taquines le coin de l'œil en bordure du Bois ?
La voilà là @ http://alien.slackbook.org/blog/kd [...] slackware/ où elle te raconte sa petite vie pertinente. [:kalymereau]
n°1289974
cycojesus
Mèo Lười
Posté le 10-09-2011 à 09:54:03  profilanswer
[:mister yoda:2] Pam campe devant la porte
 [:wildmary:1] Pam risque fort de se taper l'incruste un jour
Joue avec ta vie là @ http://connie.slackware.com/~vbatts/pam/
 [:pamela-ewing]
n°1290043
wedgeant
Da penguin inside
Posté le 12-09-2011 à 09:13:41  profilanswer
PAM § [:dawak]
http://t2.gstatic.com/images?q=tbn:ANd9GcSOW_CZCrFKt9UCMwMcxWApgDVIiHXN2lhLgTAnm40kZCBt_kzMjQ
n°1290839
cycojesus
Mèo Lười
Posté le 19-09-2011 à 07:19:20  profilanswer
I has a Slackware VPS  [:destremau:3]
I has a Slackware server  [:4lkaline]
et maintenant qu'en faire ? [:babook:4]
n°1290847
wedgeant
Da penguin inside
Posté le 19-09-2011 à 09:14:27  profilanswer
Slackware cloudz [:dawak]
n°1293011
ant_wedge
he did it !
Posté le 11-10-2011 à 12:09:30  profilanswer
[:koukouille:3]
Dieu dit « M-x make-network admin ». Et il le fût.
n°1293039
wedgeant
Da penguin inside
Posté le 11-10-2011 à 16:19:10  profilanswer
Let sleeping Slackers lie :o
n°1293073
cycojesus
Mèo Lười
Posté le 12-10-2011 à 07:07:53  profilanswer
Le rail chauffe [:cetrio]
Tue Oct 11 07:50:04 UTC 2011 (* Security fix *)
de slackware64-current ChangeLog.txt
7 new update(s), 4 security update(s)
    a/file-5.09-x86_64-1.txz: Upgraded l/seamonkey-solibs-2.4.1-x86_64-1.txz: Upgraded n/httpd-2.2.21-x86_64-1.txz: Upgraded Respond with HTTP_NOT_IMPLEMENTED when the method is not recognized. [Jean-Frederic Clere] SECURITY: CVE-2011-3348 Fix a regression introduced by the CVE-2011-3192 byterange fix in 2.2.20. PR 51748. [] For more information, see: http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2011-3348 (* Security fix *) xap/mozilla-firefox-7.0.1-x86_64-1.txz: Upgraded This release contains security fixes and improvements. For more information, see: http://www.mozilla.org/security/known-vulnerabilities/firefox.html (* Security fix *) xap/mozilla-thunderbird-7.0.1-x86_64-1.txz: Upgraded This release contains security fixes and improvements. For more information, see: http://www.mozilla.org/security/known-vulnerabilities/thunderbird.html (* Security fix *) xap/seamonkey-2.4.1-x86_64-1.txz: Upgraded This update contains security fixes and improvements. For more information, see: http://www.mozilla.org/security/announce/ (* Security fix *) testing/mozilla-firefox-8.0b2-x86_64-1.txz: Upgraded
n°1293305
regdub
Posté le 13-10-2011 à 22:20:51  profilanswer
On dirait un fichier texte ouvert sous windows. :/
Legalize it @HFR
n°1293321
wedgeant
Da penguin inside
Posté le 14-10-2011 à 08:38:05  profilanswer
c'est un fichier 64bits [:afrojojo]
n°1293578
cycojesus
Mèo Lười
Posté le 16-10-2011 à 23:27:23  profilanswer
enfin posé su'l'ftp [:monsieur kennedy:1]
a/file-5.09-x86_64-1.txz:  Upgraded.
l/seamonkey-solibs-2.4.1-x86_64-1.txz:  Upgraded.
n/httpd-2.2.21-x86_64-1.txz:  Upgraded.
  PR 51748. [<lowprio20 gmail.com>]
  (* Security fix *)
xap/mozilla-firefox-7.0.1-x86_64-1.txz:  Upgraded.
  (* Security fix *)
xap/mozilla-thunderbird-7.0.1-x86_64-1.txz:  Upgraded.
  (* Security fix *)
xap/seamonkey-2.4.1-x86_64-1.txz:  Upgraded.
  (* Security fix *)
testing/packages/mozilla-firefox-8.0b2-x86_64-1.txz:  Upgraded.
tout d'la maj à Ÿie [:david blaine]
n°1293598
wedgeant
Da penguin inside
Posté le 17-10-2011 à 09:09:16  profilanswer
[:wark0]
n°1293957
wedgeant
Da penguin inside
Posté le 20-10-2011 à 15:09:30  profilanswer
Bon anniv' à Pat [:dawak]
n°1293967
el_barbone
Posté le 20-10-2011 à 17:37:33  profilanswer
ah, il est pas mort ... [:dawak]
n°1293974
o'gure
Multi grognon de B_L
Posté le 20-10-2011 à 18:51:38  profilanswer
il n'est est pas encore fermé ce topic ? [:sysman:2]
Message édité par o'gure le 20-10-2011 à 18:51:43
n°1293981
Posté le 20-10-2011 à 20:19:44  answer
La distro est encore en vie, des updates régulières sont faites, la communauté est active et donc Modération ne ferme pas ce topic. [:airforceone]
n°1294016
wedgeant
Da penguin inside
Posté le 21-10-2011 à 08:37:02  profilanswer
[:prozac]
 [:le kneu]
n°1294020
el_barbone
Posté le 21-10-2011 à 09:18:18  profilanswer
[:hahaguy]
 [:el_barbone:5]
n°1295234
cycojesus
Mèo Lười
Posté le 02-11-2011 à 19:54:36  profilanswer
Karrément Déplié Étrangleur  Sai Cool 4.7.3 débarque en fraude dans ton slip Kangourou @ http://alien.slackbook.org/blog/kde-updated-to-4-7-3/ [:siluro:3]
n°1295996
wedgeant
Da penguin inside
Posté le 10-11-2011 à 11:19:47  profilanswer
Tue Nov  8 04:07:49 UTC 2011
n/openssh-5.9p1-i486-2.txz:  Rebuilt.
  Upstream different timestamp, size, ChangeLog.  GPG verifies on both
  this newer one and what we had before (?).
xap/mozilla-firefox-8.0-i486-1.txz:  Upgraded.
n°1295997
el_barbone
Posté le 10-11-2011 à 11:20:18  profilanswer
[:koukouille:3]
n°1295998
wedgeant
Da penguin inside
Posté le 10-11-2011 à 11:22:22  profilanswer
[:cerveau dawak]
n°1296107
cycojesus
Mèo Lười
Posté le 11-11-2011 à 13:40:18  profilanswer
kikkapété mones flux rss ?! :o
n°1296177
cycojesus
Mèo Lười
Posté le 12-11-2011 à 16:34:36  profilanswer
[:ptdrr] hein!
Fri Nov 11 18:58:21 UTC 2011
  Good 11-11-11, everyone!  Enjoy some fresh time.  :)
a/glibc-solibs-2.14.1-x86_64-1.txz:  Upgraded.
a/glibc-zoneinfo-2011i_2011n-noarch-1.txz:  Upgraded.
  New upstream homepage:  http://www.iana.org/time-zones
l/glibc-2.14.1-x86_64-1.txz:  Upgraded.
l/glibc-i18n-2.14.1-x86_64-1.txz:  Upgraded.
l/glibc-profile-2.14.1-x86_64-1.txz:  Upgraded.
[:pooogz]  [:jose mourinho]  [:jose mourinho:2]  [:jose mourinho:1] un
n°1296191
cycojesus
Mèo Lười
Posté le 13-11-2011 à 08:24:59  profilanswer
La schizophrénie est un mal nécessaire http://alien.slackbook.org/blog/mu [...] 1-11-glibc [:midnaite]
n°1296236
wedgeant
Da penguin inside
Posté le 14-11-2011 à 09:50:25  profilanswer
Suite à nouvelle machine kelébelle kelsenbonlesablecho kela64bits, je vais bientôt migrer de Slack à Slack64 [:dawak]
n°1296240
cycojesus
Mèo Lười
Posté le 14-11-2011 à 10:07:08  profilanswer
Ré, pas red [:-cas-:3]
Sun Nov 13 16:03:06 UTC 2011
a/glibc-solibs-2.14.1-x86_64-2.txz:  Rebuilt.
a/glibc-zoneinfo-2011i_2011n-noarch-2.txz:  Rebuilt.
l/glibc-2.14.1-x86_64-2.txz:  Rebuilt.
  Merged ELF patches -- Matt Burgess <matthew_at_linuxfromscratch_dot_org>
l/glibc-i18n-2.14.1-x86_64-2.txz:  Rebuilt.
l/glibc-profile-2.14.1-x86_64-2.txz:  Rebuilt.
testing/packages/mozilla-firefox-9.0b1-x86_64-1.txz:  Added.
n°1296241
cycojesus
Mèo Lười
Posté le 14-11-2011 à 10:15:11  profilanswer
2003 welcomes you!
n°1296922
cycojesus
Mèo Lười
Posté le 21-11-2011 à 16:24:00  profilanswer
De la mise en page trucideuse dans le ChangeLog [:el awrence:1]
Thu Nov 17 02:09:25 UTC 2011
n/bind-9.7.4_P1-x86_64-1.txz:  Upgraded.
        --- 9.7.4-P1 released ---
3218.   [security]      Cache lookup could return RRSIG data associated with
                        nonexistent records, leading to an assertion
                        failure. [RT #26590]
  (* Security fix *)
caramba [:edhelas:2]
n°1296923
wedgeant
Da penguin inside
Posté le 21-11-2011 à 16:30:08  profilanswer
weeeeeee
 [:bakk33]
n°1297173
cycojesus
Mèo Lười
Posté le 23-11-2011 à 19:15:32  profilanswer
FUC YÉ
Wed Nov 23 15:17:39 UTC 2011
d/make-3.82-x86_64-3.txz:  Rebuilt.
  Patched a free() crash when building Android.  Thanks to Troy Unrau.
  Fixed IA32 arch, package locations...  sorry :)
Tue Nov 22 15:23:55 UTC 2011
testing/packages/mozilla-firefox-9.0b2-x86_64-1.txz:  Upgraded.
[:judy_comon]
n°1297204
wedgeant
Da penguin inside
Posté le 24-11-2011 à 09:33:56  profilanswer
Patched [:dawak]
Slackware 9.0[slackware] Suppression de terminaux virtuels ?
!! Configuration reseaux, slackware 9 !!Installer slackware 9.0 par ftp (boot disquette)
[Pb] Installation new HDD sous slackware 8.0[RESOLU] Pb d'execution mysql sur slackware ...
Slackware 9 du pur bonheurMonter une partition NTFS sous linux (slackware 9.0)
Slackware 9.0 Finale OUTJe sens que je vais quitter Slackware (pas en serv)
Plus de sujets relatifs à : [SLACKWARE] du présent - 15.0
