10271 connectés
La 15.0 est là (en vrai !)
Les invités peuvent voter
 Page :   1  2  3  4  5  ..  22  23  24  ..  109  110  111  112  113  114
[SLACKWARE] du présent - 15.0
n°1159410
regdub
Posté le 30-08-2009 à 13:31:05  profilanswer
Oui, très bon lien. :jap:
Legalize it @HFR
n°1159588
wedgeant
Da penguin inside
Posté le 31-08-2009 à 08:53:57  profilanswer
cycojesus a écrit :
[prendre des vacances alors que la 13.0 va sortir :pfff: La jeunesse de nôtre époque j'vous jure, aucun respect... AUCUN. RESPECT. !. /FOU/ /FOU/ /FOU/ ]
héwé mais c'est comme ça :o
merci d'avoir fait le boulot pendant c'temps là :D
Wedge#2487 @HS -#- PW: +∞ -#- Khaz-Modan/Boltiz @WoW
n°1159591
wedgeant
Da penguin inside
Posté le 31-08-2009 à 09:12:55  profilanswer
Voila le message d'annonce de la 13.0 :)
Yes it's that time again!  After many months of development and careful
testing, we are proud to announce the release of Slackware version 13.0!
We are sure you'll agree that the improvements made in this release more
than warrant the major version bump up from the 12.x series.  We've done our
best to bring the latest technology to Slackware while still maintaining the
stability and security that you have come to expect.  Slackware is well known
for it's simplicity and the fact that we try to bring software to you in the
condition that the authors intended.
Probably the biggest change is the addition of an official 64-bit port.
While the 32-bit (x86) version continues to be developed, this release brings
to you a complete port to 64-bit (x86_64).  We know that many of you have
been waiting eagerly for this, and once you try it you'll see it was well
worth the wait.
Slackware 13.0 brings many updates and enhancements, among which you'll find
two of the most advanced desktop environments available today: Xfce 4.6.1,
a fast and lightweight but visually appealing and easy to use desktop
environment, and KDE 4.2.4, a recent stable release of the new 4.2.x series
of the award-winning K Desktop Environment.  We continue to make use of HAL
(Hardware Abstraction Layer) which allows the system administrator to grant
use of various hardware devices according to users' group membership so that
they will be able to use items such as USB flash sticks, USB cameras that
appear like USB storage, portable hard drives, CD and DVD media, MP3 players,
and more, all without requiring sudo, the mount or umount command.  Just plug
and play.  Properly set up, Slackware's desktop should be suitable for any
level of Linux experience.
Slackware uses the 2.6.29.6 kernel bringing you advanced performance
features such as journaling filesystems, SCSI and ATA RAID volume support,
SATA support, Software RAID, LVM (the Logical Volume Manager), and
encrypted filesystems.  Kernel support for X DRI (the Direct Rendering
Interface) brings high-speed hardware accelerated 3D graphics to Linux.
There are two kinds of kernels in Slackware -- the huge kernels, which
contain support for just about every driver in the Linux kernel. These are
primarily intended to be used for installation, but there's no real reason
that you couldn't continue to run them after you have installed.  The
other type of kernel is the generic kernel, in which nearly every driver
is built as a module.  To use a generic kernel you'll need to build an
initrd to load your filesystem module and possibly your drive controller
or other drivers needed at boot time, configure LILO to load the initrd at
boot, and reinstall LILO.  See the docs in /boot after installing for more
information.  Slackware's Linux kernels come in both SMP and non-SMP types
now.  The SMP kernel supports multiple processors, multi-core CPUs,
HyperThreading, and about every other optimization available.  In our own
testing this kernel has proven to be fast, stable, and reliable.  We
recommend using the SMP kernel even on single processor machines if it
will run on them.
From the beginning, Slackware has offered a stable and secure Linux
distribution for UNIX veterans as well as an easy-to-use system for
beginners.  Slackware includes everything you'll need to run a powerful
server or workstation.  Each Slackware package follows the setup and
installation instructions from its author(s) as closely as possible,
offering you the most stable and easily expandable setup.
Here are some of the advanced features of Slackware 13.0:
- Runs the 2.6.29.6 version of the Linux kernel from ftp.kernel.org.
  Also included is a kernel patched with Speakup to support speech
  synthesizers providing access to Linux for the visually impaired
  community.  The 2.6.x kernel series has matured into a stable
  kernel, and provides reliable performance for your desktop or
  your production server.
- System binaries are linked with the GNU C Library, version 2.9.
  This version of glibc also has excellent compatibility with
  existing binaries.
- X11 based on the X.Org Foundation's modular X Window System.
  There's been much activity in the X development world, and the
  improvements in terms of performance and hardware support are
  too numerous to mention them all here.
- Installs gcc-4.3.3 as the default C, C++, Objective-C,
  Fortran-77/95, and Ada 95 compiler.
- Support for fully encrypted network connections with OpenSSL,
  OpenSSH, OpenVPN, and GnuPG.
- Apache (httpd) 2.2.13 web server with Dynamic Shared Object
  support, SSL, and PHP 5.2.10.
- PCMCIA, CardBus, USB, IEE1394 (FireWire) and ACPI support.  This
  makes Slackware a great operating system for your laptop.
- The udev dynamic device management system for Linux 2.6.x.
  This locates and configures most hardware automatically as it
  is added (or removed) from the system, and creates the access
  nodes in /dev.  It also loads the kernel modules required by
  sound cards and other hardware at boot time.
- New development tools, including Perl 5.10.0, Python 2.6.2,
  Ruby 1.8.7-p174, Subversion 1.6.4, git-1.6.4, mercurial-1.2.1,
  graphical tools like Qt designer and KDevelop, and much more.
- Updated versions of the Slackware package management tools make it
  easy to add, remove, upgrade, and make your own Slackware packages.
  Package tracking makes it easy to upgrade from Slackware 12.2 to
  Slackware 13.0 (see CHANGES_AND_HINTS.TXT).  The slackpkg tool can
  also help update from an older version of Slackware to a newer one,
  and keep your Slackware system up to date.  In addition, the
  slacktrack utility (in extra/) will help you build and maintain
  your own packages.
- Web browsers galore!  Includes KDE's Konqueror 4.2.4,
  SeaMonkey 1.1.17 (this is the replacement for the Mozilla
  Suite), and the immensely popular Firefox 3.5.2, as well as
  the Thunderbird 2.0.0.23 email and news client with advanced
  junk mail filtering.
- The complete K Desktop Environment (KDE) version 4.2.4, including
  the KOffice productivity suite, networking tools, GUI development
  with KDevelop, multimedia tools (including the amazing Amarok
  music player and K3B disc burning software), the Konqueror web
  browser and file manager, dozens of games and utilities,
  international language support, and more.
- A collection of GTK+ based applications including pidgin-2.5.9,
   gimp-2.6.6, gkrellm-2.3.2, gxine-0.5.903, xchat-2.8.6, xsane-0.996,
   and pan-0.133.
- A repository of extra software packages compiled and ready to run.
  This includes the Java(TM) 2 Software Development Kit Standard
  Edition, an MPlayer browser plugin, alternate Intel video drivers
  for X, and more (see the /extra directory).
- Many more improved and upgraded packages than we can list here.  For
  a complete list of core packages in Slackware 13.0, see this file:
    ftp://ftp.slackware.com/pub/slack [...] CKAGES.TXT
n°1159985
peyo22
Free heel :)
Posté le 01-09-2009 à 14:18:54  profilanswer
hello
des gens sont passes sur la 13.0 ?
perso j'ai quelques crash de kde4 (en meme temps c'etait juste pour tester et j'ai un peu stresse le kde, donc ca va pas me traumatiser), pareil chez vous ?
"Se tromper est humain ; Vraiment foutre la merde necessite le mot de passe de root."
n°1160000
wedgeant
Da penguin inside
Posté le 01-09-2009 à 14:28:31  profilanswer
\o/
Pas de crash  \o/
En même temps, je suis sous fluxbox  \o/
Message édité par wedgeant le 01-09-2009 à 14:28:47
n°1160003
el_barbone
too old for this shit ...
Posté le 01-09-2009 à 14:29:28  profilanswer
ça prouve bien que c'est KDE le pb \o/
En théorie, la théorie et la pratique sont identiques, en pratique, non.
n°1160005
wedgeant
Da penguin inside
Posté le 01-09-2009 à 14:30:50  profilanswer
méwé \o/
n°1160008
el_barbone
Posté le 01-09-2009 à 14:32:03  profilanswer
[:wark0]
n°1160224
peyo22
Free heel :)
Posté le 02-09-2009 à 09:08:04  profilanswer
wedgeant a écrit :
\o/
Pas de crash  \o/
Bah fluxbox power (depuis 3ans deja -_-')
En fait j'avais lance kde4 pour pouvoir troller dessus entre potes (la derniere fois que j'avais lance un kde c'etait quand il y a eu la toute premiere version sur arch, full buggee tout comme les maj de arch d'ailleurs, mais la n'est pas le debat :) )
eheh :)
n°1160679
cycojesus
Mèo Lười
Posté le 03-09-2009 à 12:34:59  profilanswer
Tiens, j'me dit à l'instant que je vais faire part au beau monde de ma solution Clean, Portable, Pas-Grosse-Bidouille-XMLite-à-la-Mords-moi-l'nœuds pour pas tripoter HAL et s'en foutre plein les doigts de la saleté pas conviviale...
Donc, cher lecteur, oublie à jamais ces raclures de .fdi que tu sais jamais où ils se trouvent (j'ai installé 2 Slacks toutes neuves recemment) et, une fois pour toute colle ces quelques lignes dans ton .xinitrc (que tu trimballes depuis la nuit des temps) :
## Le Propre : pourquoi, comment.
# Pour un touchpad Synaptics soyeux et obéissant
synclient VertEdgeScroll=1 HorizEdgeScroll=1 TapButton1=1 TapButton2=2 TapButton3=3
# Pour un clavier du Bien
setxkbmap us_intl
Comme ça HEALL y fais ses besoins en silence au démarrage et toi *PAF* tu lui botte le postérieur en douce ensuite :kaola:
Message édité par cycojesus le 03-09-2009 à 12:35:48
Chết rồi ! ✍ ⌥⌘ http://codeberg.org/gwh
n°1161441
wedgeant
Da penguin inside
Posté le 07-09-2009 à 11:49:25  profilanswer
Un nouveau sondage est disponible [:dawa]
n°1161442
el_barbone
Posté le 07-09-2009 à 11:52:22  profilanswer
a voté :o
n°1161443
wedgeant
Da penguin inside
Posté le 07-09-2009 à 11:55:38  profilanswer
[:wark0]
t'es vraiment en ext4 ? [:opus dei]
bon, sur ma 13.0 vanilla dans un VM, j'ai mis ext4 aussi, mais j'ai pas poussé plus loin pour voir si c'était vraiment intéressant en fait :D
n°1161450
cycojesus
Mèo Lười
Posté le 07-09-2009 à 12:14:11  profilanswer
ext4 ici aussi sur les 2 'tites nouvelles.
c'est... ça marche c'est tout
EDIT : sur celui qui vient de décédé j'était en xfs parce qu'il me donnait plus de place... ext3 mangeait genre 5 ou 10% pour lui-même
Message édité par cycojesus le 07-09-2009 à 12:15:43
n°1161457
el_barbone
Posté le 07-09-2009 à 13:20:32  profilanswer
wedgeant a écrit :
[:wark0]
ext4 sur fedora11 par defaut, j'ai pas fais gaffe et depuis c'est resté :o
n°1161463
Col Hanzap​last
Jurassic geek. Vive le cobol !
Posté le 07-09-2009 à 14:16:45  profilanswer
Ext2 ici car j'ai besoin d'y accéder à partir de Windows et je ne sais jamais si les utilitaires ad-hoc, genre IFS driver, savent lire autre chose... :lol:
" Il n'y a aucune chance pour que l'iPhone s'attribue une part de marché significative. Aucune chance. " (Steve Ballmer 2007)
n°1161464
wedgeant
Da penguin inside
Posté le 07-09-2009 à 14:18:28  profilanswer
quasiment certain que ça marche avec ext3, il me semble l'avoir utilisé pendant quelques minutes (pour essayer) :jap:
n°1161465
mikala
Souviens toi du 5 Novembre...
Posté le 07-09-2009 à 14:20:35  profilanswer
tiens par rapport à a ext4, il n'y avait pas un certain nombre de modifications qui ont été apportés dans le 2.6.30 et pas le 2.6.29 afin d'améliorer/sécuriser le fonctionnement de ce système de fichier ?
Intermittent du GNU
n°1161466
wedgeant
Da penguin inside
Posté le 07-09-2009 à 14:24:02  profilanswer
je sais pas [:elessar53]
p'tet que si le topic kernel était à jour ... [:cupra]
n°1161467
el_barbone
Posté le 07-09-2009 à 14:25:28  profilanswer
http://forum-images.hardware.fr/themes_static/images_forum/1/exclam.gif
ceci est un message subliminal pour o'gure [:hahaguy]
n°1164669
zezette
"Allez hop, au revoir"
Posté le 17-09-2009 à 15:32:35  profilanswer
Bonsoir à tous,
Je viens d'installer la Slackware 13 et j'ai utilisé mon noyau recompilé maison 2.6.31. Je lance xorgsetup pour préconfigurer kde (4.2.4) puis startx et ça charge... (tout ça en root). Et quand je veux tenter d'utiliser la souris ou le clavier, rien ne se passe... J'ai essayé de lancer kdm : même problème. Pourtant, en mode texte, la souris et le clavier fonctionnent parfaitement... Il s'agit d'un clavier et d'une souris ps/2 tout ce qu'il y a de plus basiques.
Je suis sur que ça vient de mon noyau car avec le noyau par défaut ça fonctionne. Mais mon noyau fonctionne pourtant très bien avec Slackware 12.2 (KDE 3.5.10)...
Il doit y avoir un nouveau truc indispensable à ajouter au noyau pour faire fonctionner KDE, mais lequel...
Merci de votre aide :)
Message édité par zezette le 17-09-2009 à 15:47:57
"Par moment j'me d'mande si chui pas con" G. de Suresnes
n°1164671
wedgeant
Da penguin inside
Posté le 17-09-2009 à 15:34:52  profilanswer
tu peux poster ici le résultat de:
grep EE /var/log/Xorg.0.log
[:opus dei]
n°1164674
el_barbone
Posté le 17-09-2009 à 15:38:59  profilanswer
zezette a écrit :
Bonsoir à tous,
 [:zytrahusathome]
n°1164676
wedgeant
Da penguin inside
Posté le 17-09-2009 à 15:41:39  profilanswer
chut toi [:god]
Zezette, tant que j'y pense, il y a de gros changements entre la 12.2 et la 13.0, surtout au niveau de X, donc c'est pas parce qu'un truc marchait avec la 12.2 qu'il ne faut pas faire quelques modifs pour la 13.0 ;)
n°1164695
zezette
Posté le 17-09-2009 à 16:03:58  profilanswer
[:opus dei]
Ca ne renvoie rien (à part la légende de EE)
n°1164696
zezette
Posté le 17-09-2009 à 16:04:35  profilanswer
wedgeant a écrit :
chut toi [:god]
J'imagine bien qu'il y a des trucs à changer... le tout est de trouver lesquels...
n°1164700
the_k586
♥ Punk à Chats ♥
Posté le 17-09-2009 à 16:09:10  profilanswer
genre input-evdev a installer ?  dbus & hal a lancer ?
♦ bl0g ♦ // ♠ Twitter ♠ // << Just for the lulz ! The Only reason anyone does anything >> // Free Open DNS
n°1164710
wedgeant
Da penguin inside
Posté le 17-09-2009 à 16:17:30  profilanswer
même chose avec WW ? :??:
n°1164893
zezette
&#034;Allez hop, au revoir&#034;
Posté le 18-09-2009 à 09:56:26  profilanswer
Ha... on chauffe :
 (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(WW) The directory "/usr/share/fonts/local" does not exist.
(WW) The directory "/usr/share/fonts/CID" does not exist.
(WW) AllowEmptyInput is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
(WW) Disabling Mouse0
(WW) Disabling Keyboard0
(WW) intel(0): libpciaccess reported 0 rom size, guessing 64kB
(WW) intel(0): Register 0x61114 (PORT_HOTPLUG_STAT) changed from 0x00000000 to 0x00000b00
Il faudrait donc pas allower les empty inputs :)
n°1164894
wedgeant
Da penguin inside
Posté le 18-09-2009 à 09:57:38  profilanswer
t'as gagné :D
cherche l'option qui correspond dans xorg.conf et mets la à "off" :jap:
n°1164905
zezette
Posté le 18-09-2009 à 10:09:55  profilanswer
wedgeant a écrit :
t'as gagné :D
ben oui et non : sans rien changer dans xorg.conf la souris et le clavier fonctionnent avec le noyau par défaut et pas avec mon noyau d'où ma recherche...
En attendant, j'ai ajouté à mon xorg.conf :
Section "ServerFlags"
  Option "AllowEmptyInput" "off"
EndSection
et ça marche... mais bon... :)
Message édité par zezette le 18-09-2009 à 10:19:04
n°1164930
regdub
Posté le 18-09-2009 à 11:09:31  profilanswer
Ca ne serait pas à cause du fait que evdev serait désactivé dans ton noyau ?
Legalize it @HFR
n°1164931
zezette
Posté le 18-09-2009 à 11:13:51  profilanswer
C'est fort possible en effet :) ; je checke ça...
--edit--
J'ai activé evdev... et ça marche :)
Merci !!!
Message édité par zezette le 18-09-2009 à 11:21:56
n°1165569
zezette
Posté le 21-09-2009 à 09:42:47  profilanswer
Rebonsoir à tous,
Je continue avec mes questions... :)
J'ai donc lancé xorgsetup (qui me génère un xorg.conf plus ou moins complet) et j'ai choisi mon clavier. Pourtant au démarrage, c'est en qwerty... Je sais évidemment le changer mais je voudrais que ce soit directement bien reglé... Comment faire ?
--edit--
solution :
- xorg.conf ne sert plus à rien si on utilise hal
- Copier /usr/share/hal/fdi/policy/10osvendor/10-keymap.fdi dans /etc/hal/fdi/policy/10osvendor et l'éditer
infos : http://wiki.slackware-fr.org/xwind [...] onf_ou_hal
--fin edit--
Autre chose, avec la version précédente de Slackware, lors du premier lancement de kde, j'avais un assistant qui apparaissait dans lequel, je choisissais mon pays, ma langue, la gaspillomètre, ... (C'était kpersonalizer --before-session). Maintenant il n'apparait plus. Y a t'il moyen de le faire réapparaitre ?
--edit--
solution : kpersonalizer n'existe plus
Message édité par zezette le 22-09-2009 à 07:58:24
n°1165571
wedgeant
Da penguin inside
Posté le 21-09-2009 à 09:49:05  profilanswer
[:zytra]
Dans xorg.conf, il faut penser à ajouter l'option AllowEmptyInput à off et une autre aussi, je sais plus trop, sinon hal passe par dessus et t'as ton clavier en qwerty pour kdm. Si tu veux les explications complètes, y'a un très bon tuto sur le wiki slackware-fr.org :jap:
Pour kde, c'est kde4 maintenant, ton assistant de paramétrage n'existe plus :non:
Par contre, pour configurer tout comme il faut, il suffit d'aller dans le gestionnaire de configuration qui apparait dans menu K et de fouiner dans toutes les options présentes :jap:
n°1165573
zezette
Posté le 21-09-2009 à 09:55:46  profilanswer
wedgeant a écrit :
[:zytra]
Je le craignais... En fait c'est pour des ordinateurs mis à disposition du public ; L'avantage de l'assistant, c'est que les gens choisissaient directement leur langue... mais bon, je vais un peu chercher...
Message édité par zezette le 22-09-2009 à 07:57:52
n°1165599
regdub
Posté le 21-09-2009 à 10:37:04  profilanswer
Petite question sur slack 12.2
Mon fichier /etc/hal/fdi/policy/preferences.fdi contient ceci :
<device>
  <match key="volume.fstype" string="vfat">
    <merge key="volume.policy.mount_option.fmask=" type="int">0113</merge>
    <merge key="volume.policy.mount_option.dmask" type="int">0007</merge>
    <merge key="volume.policy.mount_option.umask" type="string">0000</merge>
  </match>
</device>
mais quand je plug une clé USB déclarée ni dans fstab ni dans une règle udev perso, ces options HAL ne sont pas utilisées : je vois les répertoires en 755 par ex.
Legalize it @HFR
n°1165600
regdub
Posté le 21-09-2009 à 10:38:56  profilanswer
Aie, j'ai pas googlé avant de poser la question. :/
Legalize it @HFR
n°1165603
wedgeant
Da penguin inside
Posté le 21-09-2009 à 10:47:44  profilanswer
j'ai le même pb et j'arrive toujours pas à faire en sorte que ça marche :/
si t'as la solution, je suis preneur :jap:
n°1165609
regdub
Posté le 21-09-2009 à 10:59:35  profilanswer
Rien trouvé. :/
Et sur la clé montée, lshal donne bien :
volume.policy.mount_option.fmask= = 75
soit 113 en octal.
Cela dit, on a aussi :
volume.mount.valid_options = {'ro', 'sync', 'dirsync', 'noatime', 'nodiratime', 'noexec', 'quiet', 'remount', 'exec', 'utf8', 'shortname=', 'codepage=', 'iocharset=', 'umask=', 'dmask=', 'fmask=', 'uid=', 'flush'} (string list)
Peut-être en ajoutant un "=" après dmask et umask ?
Message édité par regdub le 21-09-2009 à 10:59:58
Legalize it @HFR
n°1165812
cycojesus
Mèo Lười
Posté le 22-09-2009 à 04:38:45  profilanswer
\o/ http://slackware.com/changelog/current.php?cpu=arm \o/
Slackware 9.0[slackware] Suppression de terminaux virtuels ?
!! Configuration reseaux, slackware 9 !!Installer slackware 9.0 par ftp (boot disquette)
[Pb] Installation new HDD sous slackware 8.0[RESOLU] Pb d'execution mysql sur slackware ...
Slackware 9 du pur bonheurMonter une partition NTFS sous linux (slackware 9.0)
Slackware 9.0 Finale OUTJe sens que je vais quitter Slackware (pas en serv)
Plus de sujets relatifs à : [SLACKWARE] du présent - 15.0
