5721 connectés
La 15.0 est là (en vrai !)
Les invités peuvent voter
 Page :   1  2  3  4  5  ..  107  108  109  110  111  112  113  114
[SLACKWARE] du présent - 15.0
n°1471546
cycojesus
Mèo Lười
Posté le 25-12-2021 à 10:30:21  profilanswer
 [:moggbomber]
Fri Dec 24 20:43:23 UTC 2021
Merry Christmas, everyone! :-) See you again on Sunday or Monday.
xap/pan-0.149-x86_64-1.txz:  Upgraded.
Chết rồi ! ✍ ⌥⌘ http://codeberg.org/gwh
n°1471606
cycojesus
Mèo Lười
Posté le 28-12-2021 à 10:34:07  profilanswer
Fini les vacances de la rigolade :o
Mon Dec 27 23:06:00 UTC 2021
The --enable-systemd-logind change to xorg-server that caused resume from
suspend regressions (and others) has been reverted, and in retrospect it was
a bad idea to take it at that point, but it had appeared as if it wouldn't
cause problems in the case where Xorg was running as root. Oh well, lesson
learned. But the build script has been enhanced to make it easy to build
rootless versions of the xorg-server packages. Just do this:
  ROOTLESSX=YES ./x11.SlackBuild xserver xorg-server
Depending on your GPU, this could work for your use case with no problems.
Also, I've gone ahead and taken a couple of shared library version bumps since
the projects (opencv and poppler) have decent track records as far as not
introducing regressions, and if there are any, we've got time to test and fix.
I'm still avoiding some things that aren't as trusted in that regard, and will
likely continue to do so. :-)
ap/cups-filters-1.28.10-x86_64-2.txz:  Rebuilt.
  Recompiled against poppler-21.12.0.
kde/ark-21.12.0-x86_64-2.txz:  Rebuilt.
  Applied upstream patches:
  [PATCH] Fix extraction "Dolphin Actions" not abiding "Open destination
  folder after extracting" setting.
  [PATCH] Do not highlight file after compression.
  Thanks to ctrlaltca.
kde/calligra-3.2.1-x86_64-15.txz:  Rebuilt.
kde/cantor-21.12.0-x86_64-2.txz:  Rebuilt.
kde/digikam-7.4.0-x86_64-2.txz:  Rebuilt.
  Recompiled against opencv-4.5.5.
kde/kfilemetadata-5.89.0-x86_64-2.txz:  Rebuilt.
kde/kile-2.9.93-x86_64-15.txz:  Rebuilt.
kde/kitinerary-21.12.0-x86_64-2.txz:  Rebuilt.
kde/krita-5.0.0-x86_64-2.txz:  Rebuilt.
kde/okular-21.12.0-x86_64-2.txz:  Rebuilt.
l/gegl-0.4.34-x86_64-2.txz:  Rebuilt.
l/gst-plugins-bad-free-1.18.5-x86_64-3.txz:  Rebuilt.
l/imagemagick-7.1.0_19-x86_64-1.txz:  Upgraded.
l/mlt-7.4.0-x86_64-1.txz:  Upgraded.
l/opencv-4.5.5-x86_64-1.txz:  Upgraded.
  Shared library .so-version bump.
l/poppler-21.12.0-x86_64-1.txz:  Upgraded.
n/fetchmail-6.4.26-x86_64-1.txz:  Upgraded.
n/tin-2.6.1-x86_64-1.txz:  Upgraded.
x/ibus-anthy-1.5.14-x86_64-1.txz:  Upgraded.
x/xorg-server-1.20.14-x86_64-2.txz:  Rebuilt.
  Recompiled using these options:
  --enable-suid-wrapper --enable-install-setuid --disable-systemd-logind.
x/xorg-server-xephyr-1.20.14-x86_64-2.txz:  Rebuilt.
x/xorg-server-xnest-1.20.14-x86_64-2.txz:  Rebuilt.
x/xorg-server-xvfb-1.20.14-x86_64-2.txz:  Rebuilt.
xap/geeqie-1.6-x86_64-4.txz:  Rebuilt.
xap/gimp-2.10.30-x86_64-2.txz:  Rebuilt.
xfce/tumbler-4.16.0-x86_64-4.txz:  Rebuilt.
extra/rust-for-mozilla/rust-1.54.0-x86_64-3.txz:  Added.
  This is an alternate version of Rust that may be useful for compiling
  software from Mozilla since using the very latest Rust often won't
  compile, or produces an unstable build.
n°1471639
cycojesus
Mèo Lười
Posté le 29-12-2021 à 16:01:04  profilanswer
Wed Dec 29 02:42:32 UTC 2021
l/libgsf-1.14.48-x86_64-1.txz:  Upgraded.
l/netpbm-10.97.00-x86_64-1.txz:  Upgraded.
n/wpa_supplicant-2.9-x86_64-8.txz:  Rebuilt.
  This update fixes the following security issues:
  AP mode PMF disconnection protection bypass.
  UPnP SUBSCRIBE misbehavior in hostapd WPS AP.
  P2P group information processing vulnerability.
  P2P provision discovery processing vulnerability.
  ASN.1: Validate DigestAlgorithmIdentifier parameters.
  Flush pending control interface message for an interface to be removed.
  These issues could result in a denial-of-service, privilege escalation,
  arbitrary code execution, or other unexpected behavior.
  Thanks to nobodino for pointing out the patches.
  For more information, see:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-0326
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-0535
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-12695
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-16275
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-27803
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-30004
  (* Security fix *)
xap/seamonkey-2.53.10.2-x86_64-1.txz:  Upgraded.
  This update contains security fixes and improvements.
    https://www.seamonkey-project.org/releases/seamonkey2.53.10.2
  (* Security fix *)
n°1471651
cycojesus
Mèo Lười
Posté le 30-12-2021 à 15:12:51  profilanswer
Wed Dec 29 20:48:42 UTC 2021
a/kernel-firmware-20211229_57d6b95-noarch-1.txz:  Upgraded.
a/kernel-generic-5.15.12-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.15.12-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.15.12-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.15.12-x86-1.txz:  Upgraded.
k/kernel-source-5.15.12-noarch-1.txz:  Upgraded.
isolinux/initrd.img:  Rebuilt.
kernels/*:  Upgraded.
usb-and-pxe-installers/usbboot.img:  Rebuilt.
n°1471718
cycojesus
Mèo Lười
Posté le 01-01-2022 à 11:09:51  profilanswer
Fri Dec 31 19:44:41 UTC 2021
a/e2fsprogs-1.46.5-x86_64-1.txz:  Upgraded.
ap/sqlite-3.37.1-x86_64-1.txz:  Upgraded.
n/mutt-2.1.5-x86_64-1.txz:  Upgraded.
n/yptools-4.2.3-x86_64-4.txz:  Rebuilt.
  Added /usr/sbin/yp_dump_binding and /usr/sbin/yptest.
  Add a hint about adding "nis" in /etc/pam.d/system-auth to /etc/default/yp.
n°1471724
kisscoolz
Posté le 01-01-2022 à 12:21:25  profilanswer
Happy New Year !  [:intercalaire]
Puisse cette année être celle où le grand Pat nous sorte une nouvelle release  [:tiibo:1]
n°1471768
cycojesus
Mèo Lười
Posté le 02-01-2022 à 16:03:54  profilanswer
Premier bébé pas dans la neigepluie de 2022
Sun Jan  2 01:25:29 UTC 2022
a/mdadm-4.2-x86_64-1.txz:  Upgraded.
ap/usbmuxd-20210925_e3a3180-x86_64-1.txz:  Upgraded.
  Updated to fix mounting devices with iOS 15.1. Thanks to qunying.
l/libimobiledevice-20211124_2c6121d-x86_64-1.txz:  Upgraded.
l/libimobiledevice-glue-20211125_3cb687b-x86_64-1.txz:  Added.
l/xapian-core-1.4.19-x86_64-1.txz:  Upgraded.
x/mesa-21.3.3-x86_64-1.txz:  Upgraded.
On y krowä [:alphat]
n°1471772
regdub
Posté le 02-01-2022 à 17:37:26  profilanswer
Happy New Year !  [:austin_powaaah]
Legalize it @HFR
n°1471782
cycojesus
Mèo Lười
Posté le 03-01-2022 à 07:45:56  profilanswer
Sun Jan  2 20:40:21 UTC 2022
d/doxygen-1.9.3-x86_64-1.txz:  Upgraded.
n/network-scripts-15.0-noarch-18.txz:  Rebuilt.
  netconfig: when DHCP configuration is selected, also add hostname labeled
  loopback entries to /etc/hosts. We don't want to have to rely on something
  else providing correct name service in order to be able to reach our
  machine through its own hostname. This was a regression since the netconfig
  shipped with Slackware 14.2.
  Thanks to Zexuo.
n°1471906
cycojesus
Mèo Lười
Posté le 05-01-2022 à 13:18:41  profilanswer
Menu Kasdale avec des morceaux de pipewire (késako ?) dedans
Tue Jan  4 22:51:41 UTC 2022
a/bash-5.1.016-x86_64-1.txz:  Upgraded.
a/haveged-1.9.16-x86_64-1.txz:  Upgraded.
a/hwdata-0.355-noarch-1.txz:  Upgraded.
ap/gphoto2-2.5.28-x86_64-1.txz:  Upgraded.
kde/bluedevil-5.23.5-x86_64-1.txz:  Upgraded.
kde/breeze-5.23.5-x86_64-1.txz:  Upgraded.
kde/breeze-grub-5.23.5-x86_64-1.txz:  Upgraded.
kde/breeze-gtk-5.23.5-x86_64-1.txz:  Upgraded.
kde/drkonqi-5.23.5-x86_64-1.txz:  Upgraded.
kde/kactivitymanagerd-5.23.5-x86_64-1.txz:  Upgraded.
kde/kde-cli-tools-5.23.5-x86_64-1.txz:  Upgraded.
kde/kde-gtk-config-5.23.5-x86_64-1.txz:  Upgraded.
kde/kdecoration-5.23.5-x86_64-1.txz:  Upgraded.
kde/kdeplasma-addons-5.23.5-x86_64-1.txz:  Upgraded.
kde/kgamma5-5.23.5-x86_64-1.txz:  Upgraded.
kde/khotkeys-5.23.5-x86_64-1.txz:  Upgraded.
kde/kinfocenter-5.23.5-x86_64-1.txz:  Upgraded.
kde/kmenuedit-5.23.5-x86_64-1.txz:  Upgraded.
kde/konsole-21.12.0-x86_64-2.txz:  Rebuilt.
  Applied upstream patch:
  [PATCH] Use tighter matching when finding the default profile file name.
  Thanks to alienBOB.
kde/kscreen-5.23.5-x86_64-1.txz:  Upgraded.
kde/kscreenlocker-5.23.5-x86_64-1.txz:  Upgraded.
kde/ksshaskpass-5.23.5-x86_64-1.txz:  Upgraded.
kde/ksystemstats-5.23.5-x86_64-1.txz:  Upgraded.
kde/kwallet-pam-5.23.5-x86_64-1.txz:  Upgraded.
kde/kwayland-integration-5.23.5-x86_64-1.txz:  Upgraded.
kde/kwayland-server-5.23.5-x86_64-1.txz:  Upgraded.
kde/kwin-5.23.5-x86_64-1.txz:  Upgraded.
kde/kwrited-5.23.5-x86_64-1.txz:  Upgraded.
kde/layer-shell-qt-5.23.5-x86_64-1.txz:  Upgraded.
kde/libkscreen-5.23.5-x86_64-1.txz:  Upgraded.
kde/libksysguard-5.23.5-x86_64-1.txz:  Upgraded.
kde/milou-5.23.5-x86_64-1.txz:  Upgraded.
kde/oxygen-5.23.5-x86_64-1.txz:  Upgraded.
kde/plasma-browser-integration-5.23.5-x86_64-1.txz:  Upgraded.
kde/plasma-desktop-5.23.5-x86_64-1.txz:  Upgraded.
kde/plasma-disks-5.23.5-x86_64-1.txz:  Upgraded.
kde/plasma-firewall-5.23.5-x86_64-1.txz:  Upgraded.
kde/plasma-integration-5.23.5-x86_64-1.txz:  Upgraded.
kde/plasma-nm-5.23.5-x86_64-1.txz:  Upgraded.
kde/plasma-pa-5.23.5-x86_64-1.txz:  Upgraded.
kde/plasma-sdk-5.23.5-x86_64-1.txz:  Upgraded.
kde/plasma-systemmonitor-5.23.5-x86_64-1.txz:  Upgraded.
kde/plasma-vault-5.23.5-x86_64-1.txz:  Upgraded.
kde/plasma-workspace-5.23.5-x86_64-1.txz:  Upgraded.
kde/plasma-workspace-wallpapers-5.23.5-x86_64-1.txz:  Upgraded.
kde/polkit-kde-agent-1-5.23.5-x86_64-1.txz:  Upgraded.
kde/powerdevil-5.23.5-x86_64-1.txz:  Upgraded.
kde/qqc2-breeze-style-5.23.5-x86_64-1.txz:  Upgraded.
kde/sddm-kcm-5.23.5-x86_64-1.txz:  Upgraded.
kde/systemsettings-5.23.5-x86_64-1.txz:  Upgraded.
kde/xdg-desktop-portal-kde-5.23.5-x86_64-1.txz:  Upgraded.
l/imagemagick-7.1.0_19-x86_64-2.txz:  Rebuilt.
  It seems that even with --enable-opencl, ImageMagick has disabled OpenCL
  support by default unless the environment variable MAGICK_OCL_DEVICE=true
  is set, so there should be no harm enabling this feature again.
  Thanks to denydias.
l/iso-codes-4.9.0-noarch-1.txz:  Upgraded.
l/libgphoto2-2.5.28-x86_64-1.txz:  Upgraded.
l/pipewire-0.3.42-x86_64-2.txz:  Rebuilt.
  Added sample startup files in /etc/xdg/autostart. Thanks to stormtracknole.
  Added scripts (pipewire-enable.sh, pipewire-disable.sh) to setup pipewire as
  the default multimedia server, or to disable it and return to pulseaudio as
  the default. Thanks to stormtracknole and LuckyCyborg for many useful tips.
l/pulseaudio-15.0-x86_64-4.txz:  Rebuilt.
  Install pulseaudio.desktop as a .new file so that future package updates
  won't overwrite custom content.
n/whois-5.5.11-x86_64-1.txz:  Upgraded.
n/yptools-4.2.3-x86_64-5.txz:  Rebuilt.
  Fixed ypcat installation. Thanks to Stuart Winter.
x/libdrm-2.4.109-x86_64-1.txz:  Upgraded.
x/xdg-desktop-portal-1.12.1-x86_64-1.txz:  Upgraded.
x/xf86-video-vmware-13.3.0-x86_64-6.txz:  Rebuilt.
  Patched to build against libdrm-2.4.109. Thanks to gmgf.
n°1471936
regdub
Posté le 05-01-2022 à 21:16:26  profilanswer
https://img.super-h.fr/images/3cabb8a1bb24ca4c49ce078e115b5d36.jpg
Legalize it @HFR
n°1471937
regdub
Posté le 05-01-2022 à 21:16:43  profilanswer
Ça a l'air +/- requis pour ceux qui utilisent Plasma/wayland.
Tu n'as pas utilisé pipewire avec sway ?
Legalize it @HFR
n°1471938
cycojesus
Mèo Lười
Posté le 05-01-2022 à 22:33:22  profilanswer
Je... j'ai y pas touché en tout cas. J'ai cru comprendre que ça avait un rapport avec le bruit et que ça pouvait remplacer pulseaudio, c'est tout.
J'ai aucun problème de son dans sway avec pulseaudio.
Wed Jan  5 20:09:37 UTC 2022
a/aaa_libraries-15.0-x86_64-12.txz:  Rebuilt.
  Upgraded: libcap.so.2.62, libelf-0.186.so, libzstd.so.1.5.1,
  libcares.so.2.5.1, libexpat.so.1.8.2, libglib-2.0.so.0.7000.2,
  libgmodule-2.0.so.0.7000.2, libgobject-2.0.so.0.7000.2,
  libgthread-2.0.so.0.7000.2, libpcre2-8.so.0.10.4.
  Added: libunwind.so.8.0.1 (thanks to Jeebizz).
a/kernel-generic-5.15.13-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.15.13-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.15.13-x86_64-1.txz:  Upgraded.
d/doxygen-1.9.3-x86_64-2.txz:  Rebuilt.
  Fix manpage versions, build and install docs. Thanks to duncan_roe.
d/kernel-headers-5.15.13-x86-1.txz:  Upgraded.
k/kernel-source-5.15.13-noarch-1.txz:  Upgraded.
l/libuv-1.43.0-x86_64-1.txz:  Upgraded.
l/pipewire-0.3.43-x86_64-1.txz:  Upgraded.
  Remove redundant .sample files on package upgrade.
  When disabling pipewire, toss the .desktop files and keep the .sample files
  if both exist.
  Added missing X-KDE-autostart-phase=1 to pipewire-pulse.desktop.sample.
  Thanks to ZhaoLin1457.
n/curl-7.81.0-x86_64-1.txz:  Upgraded.
x/fcitx-qt5-1.2.7-x86_64-1.txz:  Upgraded.
                 :::::::                      root@tibou.le-moine.lan
         :::::::::::::::::::::::::             OS: Slackware 15.0 x86_64 x86_64
       ::::::::cllcccccllllllll::::::          Host: Micro-Star International Co., Ltd. B550-A PRO (MS-7C56)
    :::::::::lc               dc:::::::        Kernel: 5.15.12
   ::::::::cl   clllccllll    oc:::::::::      Uptime: 5 days, 5 hours, 54 mins
  :::::::::o   lc::::::::co   oc::::::::::     Packages: 2168 (pkgtool)
 ::::::::::o    cccclc:::::clcc::::::::::::    Shell: zsh 5.8
 :::::::::::lc        cclccclc:::::::::::::    Resolution: 3840x2160
::::::::::::::lcclcc          lc::::::::::::   WM: wlroots wm
::::::::::cclcc:::::lccclc     oc:::::::::::   Theme: GTK+ [GTK2], Adwaita [GTK3]
::::::::::o    l::::::::::l    lc:::::::::::   Icons: Adwaita [GTK2/3]
 :::::cll:o     clcllcccll     o:::::::::::    Terminal: alacritty
 :::::occ:o                  clc:::::::::::    CPU: AMD Ryzen 5 3600 (12) @ 3.600GHz
  ::::ocl:ccslclccclclccclclc:::::::::::::     GPU: AMD ATI Radeon RX 5500/5500M / Pro 5500M
   :::oclcccccccccccccllllllllllllll:::::      Memory: 19232MiB / 64306MiB
    ::lcc1lcccccccccccccccccccccccco::::
Message édité par cycojesus le 05-01-2022 à 22:37:02
n°1471978
cycojesus
Mèo Lười
Posté le 07-01-2022 à 08:22:35  profilanswer
Vous reprendrez un petit Kawa au Kalva ? [:aloy]
Fri Jan  7 06:03:52 UTC 2022
a/kernel-firmware-20220106_4aa2c65-noarch-1.txz:  Upgraded.
a/tcsh-6.23.02-x86_64-1.txz:  Upgraded.
ap/sqlite-3.37.2-x86_64-1.txz:  Upgraded.
ap/vim-8.2.4018-x86_64-1.txz:  Upgraded.
d/mercurial-6.0.1-x86_64-1.txz:  Upgraded.
kde/akonadi-21.12.1-x86_64-1.txz:  Upgraded.
kde/akonadi-calendar-21.12.1-x86_64-1.txz:  Upgraded.
kde/akonadi-calendar-tools-21.12.1-x86_64-1.txz:  Upgraded.
kde/akonadi-contacts-21.12.1-x86_64-1.txz:  Upgraded.
kde/akonadi-import-wizard-21.12.1-x86_64-1.txz:  Upgraded.
kde/akonadi-mime-21.12.1-x86_64-1.txz:  Upgraded.
kde/akonadi-notes-21.12.1-x86_64-1.txz:  Upgraded.
kde/akonadi-search-21.12.1-x86_64-1.txz:  Upgraded.
kde/akonadiconsole-21.12.1-x86_64-1.txz:  Upgraded.
kde/akregator-21.12.1-x86_64-1.txz:  Upgraded.
kde/analitza-21.12.1-x86_64-1.txz:  Upgraded.
kde/ark-21.12.1-x86_64-1.txz:  Upgraded.
kde/artikulate-21.12.1-x86_64-1.txz:  Upgraded.
kde/audiocd-kio-21.12.1-x86_64-1.txz:  Upgraded.
kde/baloo-widgets-21.12.1-x86_64-1.txz:  Upgraded.
kde/blinken-21.12.1-x86_64-1.txz:  Upgraded.
kde/bomber-21.12.1-x86_64-1.txz:  Upgraded.
kde/bovo-21.12.1-x86_64-1.txz:  Upgraded.
kde/calendarsupport-21.12.1-x86_64-1.txz:  Upgraded.
kde/cantor-21.12.1-x86_64-1.txz:  Upgraded.
kde/cervisia-21.12.1-x86_64-1.txz:  Upgraded.
kde/dolphin-21.12.1-x86_64-1.txz:  Upgraded.
kde/dolphin-plugins-21.12.1-x86_64-1.txz:  Upgraded.
kde/dragon-21.12.1-x86_64-1.txz:  Upgraded.
kde/elisa-21.12.1-x86_64-1.txz:  Upgraded.
kde/eventviews-21.12.1-x86_64-1.txz:  Upgraded.
kde/ffmpegthumbs-21.12.1-x86_64-1.txz:  Upgraded.
kde/filelight-21.12.1-x86_64-1.txz:  Upgraded.
kde/granatier-21.12.1-x86_64-1.txz:  Upgraded.
kde/grantlee-editor-21.12.1-x86_64-1.txz:  Upgraded.
kde/grantleetheme-21.12.1-x86_64-1.txz:  Upgraded.
kde/gwenview-21.12.1-x86_64-1.txz:  Upgraded.
kde/incidenceeditor-21.12.1-x86_64-1.txz:  Upgraded.
kde/itinerary-21.12.1-x86_64-1.txz:  Upgraded.
kde/juk-21.12.1-x86_64-1.txz:  Upgraded.
kde/k3b-21.12.1-x86_64-1.txz:  Upgraded.
kde/kaddressbook-21.12.1-x86_64-1.txz:  Upgraded.
kde/kalarm-21.12.1-x86_64-1.txz:  Upgraded.
kde/kalarmcal-21.12.1-x86_64-1.txz:  Upgraded.
kde/kalgebra-21.12.1-x86_64-1.txz:  Upgraded.
kde/kalzium-21.12.1-x86_64-1.txz:  Upgraded.
kde/kamera-21.12.1-x86_64-1.txz:  Upgraded.
kde/kamoso-21.12.1-x86_64-1.txz:  Upgraded.
kde/kanagram-21.12.1-x86_64-1.txz:  Upgraded.
kde/kapman-21.12.1-x86_64-1.txz:  Upgraded.
kde/kapptemplate-21.12.1-x86_64-1.txz:  Upgraded.
kde/kate-21.12.1-x86_64-1.txz:  Upgraded.
kde/katomic-21.12.1-x86_64-1.txz:  Upgraded.
kde/kbackup-21.12.1-x86_64-1.txz:  Upgraded.
kde/kblackbox-21.12.1-x86_64-1.txz:  Upgraded.
kde/kblocks-21.12.1-x86_64-1.txz:  Upgraded.
kde/kbounce-21.12.1-x86_64-1.txz:  Upgraded.
kde/kbreakout-21.12.1-x86_64-1.txz:  Upgraded.
kde/kbruch-21.12.1-x86_64-1.txz:  Upgraded.
kde/kcachegrind-21.12.1-x86_64-1.txz:  Upgraded.
kde/kcalc-21.12.1-x86_64-1.txz:  Upgraded.
kde/kcalutils-21.12.1-x86_64-1.txz:  Upgraded.
kde/kcharselect-21.12.1-x86_64-1.txz:  Upgraded.
kde/kcolorchooser-21.12.1-x86_64-1.txz:  Upgraded.
kde/kcron-21.12.1-x86_64-1.txz:  Upgraded.
kde/kde-dev-scripts-21.12.1-x86_64-1.txz:  Upgraded.
kde/kde-dev-utils-21.12.1-x86_64-1.txz:  Upgraded.
kde/kdebugsettings-21.12.1-x86_64-1.txz:  Upgraded.
kde/kdeconnect-kde-21.12.1-x86_64-1.txz:  Upgraded.
kde/kdeedu-data-21.12.1-x86_64-1.txz:  Upgraded.
kde/kdegraphics-mobipocket-21.12.1-x86_64-1.txz:  Upgraded.
kde/kdegraphics-thumbnailers-21.12.1-x86_64-1.txz:  Upgraded.
kde/kdenetwork-filesharing-21.12.1-x86_64-1.txz:  Upgraded.
kde/kdenlive-21.12.1-x86_64-1.txz:  Upgraded.
kde/kdepim-addons-21.12.1-x86_64-1.txz:  Upgraded.
kde/kdepim-runtime-21.12.1-x86_64-1.txz:  Upgraded.
kde/kdesdk-kioslaves-21.12.1-x86_64-1.txz:  Upgraded.
kde/kdesdk-thumbnailers-21.12.1-x86_64-1.txz:  Upgraded.
kde/kdev-php-21.12.1-x86_64-1.txz:  Upgraded.
kde/kdev-python-21.12.1-x86_64-1.txz:  Upgraded.
kde/kdevelop-21.12.1-x86_64-1.txz:  Upgraded.
kde/kdf-21.12.1-x86_64-1.txz:  Upgraded.
kde/kdialog-21.12.1-x86_64-1.txz:  Upgraded.
kde/kdiamond-21.12.1-x86_64-1.txz:  Upgraded.
kde/keditbookmarks-21.12.1-x86_64-1.txz:  Upgraded.
kde/kfind-21.12.1-x86_64-1.txz:  Upgraded.
kde/kfloppy-21.12.1-x86_64-1.txz:  Upgraded.
kde/kfourinline-21.12.1-x86_64-1.txz:  Upgraded.
kde/kgeography-21.12.1-x86_64-1.txz:  Upgraded.
kde/kget-21.12.1-x86_64-1.txz:  Upgraded.
kde/kgoldrunner-21.12.1-x86_64-1.txz:  Upgraded.
kde/kgpg-21.12.1-x86_64-1.txz:  Upgraded.
kde/khangman-21.12.1-x86_64-1.txz:  Upgraded.
kde/khelpcenter-21.12.1-x86_64-1.txz:  Upgraded.
kde/kidentitymanagement-21.12.1-x86_64-1.txz:  Upgraded.
kde/kig-21.12.1-x86_64-1.txz:  Upgraded.
kde/kigo-21.12.1-x86_64-1.txz:  Upgraded.
kde/killbots-21.12.1-x86_64-1.txz:  Upgraded.
kde/kimagemapeditor-21.12.1-x86_64-1.txz:  Upgraded.
kde/kimap-21.12.1-x86_64-1.txz:  Upgraded.
kde/kio-extras-21.12.1-x86_64-1.txz:  Upgraded.
kde/kio-gdrive-21.12.1-x86_64-1.txz:  Upgraded.
kde/kipi-plugins-21.12.1-x86_64-1.txz:  Upgraded.
kde/kirigami-gallery-21.12.1-x86_64-1.txz:  Upgraded.
kde/kiriki-21.12.1-x86_64-1.txz:  Upgraded.
kde/kiten-21.12.1-x86_64-1.txz:  Upgraded.
kde/kitinerary-21.12.1-x86_64-1.txz:  Upgraded.
kde/kjumpingcube-21.12.1-x86_64-1.txz:  Upgraded.
kde/kldap-21.12.1-x86_64-1.txz:  Upgraded.
kde/kleopatra-21.12.1-x86_64-1.txz:  Upgraded.
kde/klickety-21.12.1-x86_64-1.txz:  Upgraded.
kde/klines-21.12.1-x86_64-1.txz:  Upgraded.
kde/kmag-21.12.1-x86_64-1.txz:  Upgraded.
kde/kmahjongg-21.12.1-x86_64-1.txz:  Upgraded.
kde/kmail-21.12.1-x86_64-1.txz:  Upgraded.
kde/kmail-account-wizard-21.12.1-x86_64-1.txz:  Upgraded.
kde/kmailtransport-21.12.1-x86_64-1.txz:  Upgraded.
kde/kmbox-21.12.1-x86_64-1.txz:  Upgraded.
kde/kmime-21.12.1-x86_64-1.txz:  Upgraded.
kde/kmines-21.12.1-x86_64-1.txz:  Upgraded.
kde/kmix-21.12.1-x86_64-1.txz:  Upgraded.
kde/kmousetool-21.12.1-x86_64-1.txz:  Upgraded.
kde/kmouth-21.12.1-x86_64-1.txz:  Upgraded.
kde/kmplot-21.12.1-x86_64-1.txz:  Upgraded.
kde/knavalbattle-21.12.1-x86_64-1.txz:  Upgraded.
kde/knetwalk-21.12.1-x86_64-1.txz:  Upgraded.
kde/knights-21.12.1-x86_64-1.txz:  Upgraded.
kde/knotes-21.12.1-x86_64-1.txz:  Upgraded.
kde/kolf-21.12.1-x86_64-1.txz:  Upgraded.
kde/kollision-21.12.1-x86_64-1.txz:  Upgraded.
kde/kolourpaint-21.12.1-x86_64-1.txz:  Upgraded.
kde/kompare-21.12.1-x86_64-1.txz:  Upgraded.
kde/konqueror-21.12.1-x86_64-1.txz:  Upgraded.
kde/konquest-21.12.1-x86_64-1.txz:  Upgraded.
kde/konsole-21.12.1-x86_64-1.txz:  Upgraded.
kde/kontact-21.12.1-x86_64-1.txz:  Upgraded.
kde/kontactinterface-21.12.1-x86_64-1.txz:  Upgraded.
kde/kontrast-21.12.1-x86_64-1.txz:  Upgraded.
kde/konversation-21.12.1-x86_64-1.txz:  Upgraded.
kde/kopeninghours-21.12.1-x86_64-1.txz:  Upgraded.
kde/kopete-21.12.1-x86_64-1.txz:  Upgraded.
kde/korganizer-21.12.1-x86_64-1.txz:  Upgraded.
kde/kosmindoormap-21.12.1-x86_64-1.txz:  Upgraded.
kde/kpat-21.12.1-x86_64-1.txz:  Upgraded.
kde/kpimtextedit-21.12.1-x86_64-1.txz:  Upgraded.
kde/kpkpass-21.12.1-x86_64-1.txz:  Upgraded.
kde/kpmcore-21.12.1-x86_64-1.txz:  Upgraded.
kde/kpublictransport-21.12.1-x86_64-1.txz:  Upgraded.
kde/kqtquickcharts-21.12.1-x86_64-1.txz:  Upgraded.
kde/krdc-21.12.1-x86_64-1.txz:  Upgraded.
kde/kreversi-21.12.1-x86_64-1.txz:  Upgraded.
kde/krfb-21.12.1-x86_64-1.txz:  Upgraded.
kde/krita-5.0.2-x86_64-1.txz:  Upgraded.
kde/kross-interpreters-21.12.1-x86_64-1.txz:  Upgraded.
kde/kruler-21.12.1-x86_64-1.txz:  Upgraded.
kde/kshisen-21.12.1-x86_64-1.txz:  Upgraded.
kde/ksirk-21.12.1-x86_64-1.txz:  Upgraded.
kde/ksmtp-21.12.1-x86_64-1.txz:  Upgraded.
kde/ksnakeduel-21.12.1-x86_64-1.txz:  Upgraded.
kde/kspaceduel-21.12.1-x86_64-1.txz:  Upgraded.
kde/ksquares-21.12.1-x86_64-1.txz:  Upgraded.
kde/ksudoku-21.12.1-x86_64-1.txz:  Upgraded.
kde/ksystemlog-21.12.1-x86_64-1.txz:  Upgraded.
kde/kteatime-21.12.1-x86_64-1.txz:  Upgraded.
kde/ktimer-21.12.1-x86_64-1.txz:  Upgraded.
kde/ktnef-21.12.1-x86_64-1.txz:  Upgraded.
kde/ktorrent-21.12.1-x86_64-1.txz:  Upgraded.
kde/ktouch-21.12.1-x86_64-1.txz:  Upgraded.
kde/kturtle-21.12.1-x86_64-1.txz:  Upgraded.
kde/kubrick-21.12.1-x86_64-1.txz:  Upgraded.
kde/kwalletmanager-21.12.1-x86_64-1.txz:  Upgraded.
kde/kwave-21.12.1-x86_64-1.txz:  Upgraded.
kde/kwordquiz-21.12.1-x86_64-1.txz:  Upgraded.
kde/libgravatar-21.12.1-x86_64-1.txz:  Upgraded.
kde/libkcddb-21.12.1-x86_64-1.txz:  Upgraded.
kde/libkcompactdisc-21.12.1-x86_64-1.txz:  Upgraded.
kde/libkdcraw-21.12.1-x86_64-1.txz:  Upgraded.
kde/libkdegames-21.12.1-x86_64-1.txz:  Upgraded.
kde/libkdepim-21.12.1-x86_64-1.txz:  Upgraded.
kde/libkeduvocdocument-21.12.1-x86_64-1.txz:  Upgraded.
kde/libkexiv2-21.12.1-x86_64-1.txz:  Upgraded.
kde/libkgapi-21.12.1-x86_64-1.txz:  Upgraded.
kde/libkipi-21.12.1-x86_64-1.txz:  Upgraded.
kde/libkleo-21.12.1-x86_64-1.txz:  Upgraded.
kde/libkmahjongg-21.12.1-x86_64-1.txz:  Upgraded.
kde/libkomparediff2-21.12.1-x86_64-1.txz:  Upgraded.
kde/libksane-21.12.1-x86_64-1.txz:  Upgraded.
kde/libksieve-21.12.1-x86_64-1.txz:  Upgraded.
kde/libktorrent-21.12.1-x86_64-1.txz:  Upgraded.
kde/lokalize-21.12.1-x86_64-1.txz:  Upgraded.
kde/lskat-21.12.1-x86_64-1.txz:  Upgraded.
kde/mailcommon-21.12.1-x86_64-1.txz:  Upgraded.
kde/mailimporter-21.12.1-x86_64-1.txz:  Upgraded.
kde/marble-21.12.1-x86_64-1.txz:  Upgraded.
kde/markdownpart-21.12.1-x86_64-1.txz:  Upgraded.
kde/mbox-importer-21.12.1-x86_64-1.txz:  Upgraded.
kde/messagelib-21.12.1-x86_64-1.txz:  Upgraded.
kde/minuet-21.12.1-x86_64-1.txz:  Upgraded.
kde/okular-21.12.1-x86_64-1.txz:  Upgraded.
kde/palapeli-21.12.1-x86_64-1.txz:  Upgraded.
kde/parley-21.12.1-x86_64-1.txz:  Upgraded.
kde/partitionmanager-21.12.1-x86_64-1.txz:  Upgraded.
kde/picmi-21.12.1-x86_64-1.txz:  Upgraded.
kde/pim-data-exporter-21.12.1-x86_64-1.txz:  Upgraded.
kde/pim-sieve-editor-21.12.1-x86_64-1.txz:  Upgraded.
kde/pimcommon-21.12.1-x86_64-1.txz:  Upgraded.
kde/poxml-21.12.1-x86_64-1.txz:  Upgraded.
kde/print-manager-21.12.1-x86_64-1.txz:  Upgraded.
kde/rocs-21.12.1-x86_64-1.txz:  Upgraded.
kde/skanlite-21.12.1-x86_64-1.txz:  Upgraded.
kde/spectacle-21.12.1-x86_64-1.txz:  Upgraded.
kde/step-21.12.1-x86_64-1.txz:  Upgraded.
kde/svgpart-21.12.1-x86_64-1.txz:  Upgraded.
kde/sweeper-21.12.1-x86_64-1.txz:  Upgraded.
kde/umbrello-21.12.1-x86_64-1.txz:  Upgraded.
kde/yakuake-21.12.1-x86_64-1.txz:  Upgraded.
kde/zanshin-21.12.1-x86_64-1.txz:  Upgraded.
kde/zeroconf-ioslave-21.12.1-x86_64-1.txz:  Upgraded.
l/mozilla-nss-3.74-x86_64-1.txz:  Upgraded.
l/readline-8.1.002-x86_64-1.txz:  Upgraded.
n/bluez-5.63-x86_64-1.txz:  Upgraded.
xap/vim-gvim-8.2.4018-x86_64-1.txz:  Upgraded.
n°1472015
kisscoolz
Posté le 07-01-2022 à 14:10:45  profilanswer
[:vave:4]
n°1472070
regdub
Posté le 08-01-2022 à 17:55:04  profilanswer
Ceux qui utilisent Plasma/wayland changent pour les fonctions liées à la video/capture d'écran, comme les thumbnails de fénêtres et tout ce qui est recording/partage de bureau.
Comme wayland ne permet pas nativement à n'importe quel process de mater le contenu des fenêtres, on ajoute un process qui prend du CPU pour ajouter la fonctionnalité, ce qui pose la question de si on y gagne en temps CPU et qui gère la permission d'accéder aux flux pipewire...
Message édité par regdub le 08-01-2022 à 17:56:33
Legalize it @HFR
n°1472222
cycojesus
Mèo Lười
Posté le 13-01-2022 à 08:48:47  profilanswer
ah ok, c'est plus clair. C'est vrai que je me suis pas posé la question du partage/capture d'écran mon besoin dans ce domaine étant rarissime.
Et maintenant, RC3-final, dernière ligne droite
Wed Jan 12 22:04:33 UTC 2022
Good hello, and welcome to the third and final release candidate for Slackware
15.0. We're 99% frozen at this point and are mostly looking for regression or
other bug reports that might be able to be addressed before this goes stable.
Of course, the management here reserves the right to make exceptions... that
5.15.15 kernel version has a nice ring to it. If your requests didn't make it
into this iteration, perhaps we will revisit them for the next -current cycle.
Some were just a little too late but will more than likely be needed next time
(I'm looking at Didier's grubconfig), while others are just out of scope for
the main tree where I like to abide by YAGNI as much as possible.
Anyway, let's get some testing done and we'll be there soon. Enjoy! :-)
a/aaa_base-15.0-x86_64-2.txz:  Rebuilt.
  The Linux Counter has shut down, so remove the registration email.
  Update the welcome email for Slackware 15.0.
a/aaa_libraries-15.0-x86_64-13.txz:  Rebuilt.
  Upgraded: libsigsegv.so.2.0.7.
a/eudev-3.2.11-x86_64-1.txz:  Upgraded.
a/haveged-1.9.17-x86_64-1.txz:  Upgraded.
a/hdparm-9.63-x86_64-1.txz:  Upgraded.
a/kernel-firmware-20220111_13dca28-noarch-1.txz:  Upgraded.
a/kernel-generic-5.15.14-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.15.14-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.15.14-x86_64-1.txz:  Upgraded.
ap/vim-8.2.4065-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.15.14-x86-1.txz:  Upgraded.
d/strace-5.16-x86_64-1.txz:  Upgraded.
d/vala-0.54.6-x86_64-1.txz:  Upgraded.
k/kernel-source-5.15.14-noarch-1.txz:  Upgraded.
  VMD m -> y
  Thanks to dr.s.
kde/attica-5.90.0-x86_64-1.txz:  Upgraded.
kde/baloo-5.90.0-x86_64-1.txz:  Upgraded.
kde/bluez-qt-5.90.0-x86_64-1.txz:  Upgraded.
kde/breeze-icons-5.90.0-noarch-1.txz:  Upgraded.
kde/extra-cmake-modules-5.90.0-x86_64-1.txz:  Upgraded.
kde/frameworkintegration-5.90.0-x86_64-1.txz:  Upgraded.
kde/kactivities-5.90.0-x86_64-1.txz:  Upgraded.
kde/kactivities-stats-5.90.0-x86_64-1.txz:  Upgraded.
kde/kapidox-5.90.0-x86_64-1.txz:  Upgraded.
kde/karchive-5.90.0-x86_64-1.txz:  Upgraded.
kde/kauth-5.90.0-x86_64-1.txz:  Upgraded.
kde/kbookmarks-5.90.0-x86_64-1.txz:  Upgraded.
kde/kcalendarcore-5.90.0-x86_64-1.txz:  Upgraded.
kde/kcmutils-5.90.0-x86_64-1.txz:  Upgraded.
kde/kcodecs-5.90.0-x86_64-1.txz:  Upgraded.
kde/kcompletion-5.90.0-x86_64-1.txz:  Upgraded.
kde/kconfig-5.90.0-x86_64-1.txz:  Upgraded.
kde/kconfigwidgets-5.90.0-x86_64-1.txz:  Upgraded.
kde/kcontacts-5.90.0-x86_64-1.txz:  Upgraded.
kde/kcoreaddons-5.90.0-x86_64-1.txz:  Upgraded.
kde/kcrash-5.90.0-x86_64-1.txz:  Upgraded.
kde/kdav-5.90.0-x86_64-1.txz:  Upgraded.
kde/kdbusaddons-5.90.0-x86_64-1.txz:  Upgraded.
kde/kdeclarative-5.90.0-x86_64-1.txz:  Upgraded.
kde/kded-5.90.0-x86_64-1.txz:  Upgraded.
kde/kdelibs4support-5.90.0-x86_64-1.txz:  Upgraded.
kde/kdesignerplugin-5.90.0-x86_64-1.txz:  Upgraded.
kde/kdesu-5.90.0-x86_64-1.txz:  Upgraded.
kde/kdewebkit-5.90.0-x86_64-1.txz:  Upgraded.
kde/kdnssd-5.90.0-x86_64-1.txz:  Upgraded.
kde/kdoctools-5.90.0-x86_64-1.txz:  Upgraded.
kde/kemoticons-5.90.0-x86_64-1.txz:  Upgraded.
kde/kfilemetadata-5.90.0-x86_64-1.txz:  Upgraded.
kde/kglobalaccel-5.90.0-x86_64-1.txz:  Upgraded.
kde/kguiaddons-5.90.0-x86_64-1.txz:  Upgraded.
kde/kholidays-5.90.0-x86_64-1.txz:  Upgraded.
kde/khtml-5.90.0-x86_64-1.txz:  Upgraded.
kde/ki18n-5.90.0-x86_64-1.txz:  Upgraded.
kde/kiconthemes-5.90.0-x86_64-1.txz:  Upgraded.
kde/kidletime-5.90.0-x86_64-1.txz:  Upgraded.
kde/kimageformats-5.90.0-x86_64-1.txz:  Upgraded.
kde/kinit-5.90.0-x86_64-1.txz:  Upgraded.
kde/kio-5.90.0-x86_64-1.txz:  Upgraded.
kde/kirigami2-5.90.0-x86_64-1.txz:  Upgraded.
kde/kitemmodels-5.90.0-x86_64-1.txz:  Upgraded.
kde/kitemviews-5.90.0-x86_64-1.txz:  Upgraded.
kde/kjobwidgets-5.90.0-x86_64-1.txz:  Upgraded.
kde/kjs-5.90.0-x86_64-1.txz:  Upgraded.
kde/kjsembed-5.90.0-x86_64-1.txz:  Upgraded.
kde/kmediaplayer-5.90.0-x86_64-1.txz:  Upgraded.
kde/knewstuff-5.90.0-x86_64-1.txz:  Upgraded.
kde/knotifications-5.90.0-x86_64-1.txz:  Upgraded.
kde/knotifyconfig-5.90.0-x86_64-1.txz:  Upgraded.
kde/kpackage-5.90.0-x86_64-1.txz:  Upgraded.
kde/kparts-5.90.0-x86_64-1.txz:  Upgraded.
kde/kpeople-5.90.0-x86_64-1.txz:  Upgraded.
kde/kplotting-5.90.0-x86_64-1.txz:  Upgraded.
kde/kpty-5.90.0-x86_64-1.txz:  Upgraded.
kde/kquickcharts-5.90.0-x86_64-1.txz:  Upgraded.
kde/kross-5.90.0-x86_64-1.txz:  Upgraded.
kde/krunner-5.90.0-x86_64-1.txz:  Upgraded.
kde/kservice-5.90.0-x86_64-1.txz:  Upgraded.
kde/ktexteditor-5.90.0-x86_64-1.txz:  Upgraded.
kde/ktextwidgets-5.90.0-x86_64-1.txz:  Upgraded.
kde/kunitconversion-5.90.0-x86_64-1.txz:  Upgraded.
kde/kwallet-5.90.0-x86_64-1.txz:  Upgraded.
kde/kwayland-5.90.0-x86_64-1.txz:  Upgraded.
kde/kwidgetsaddons-5.90.0-x86_64-1.txz:  Upgraded.
kde/kwindowsystem-5.90.0-x86_64-1.txz:  Upgraded.
kde/kxmlgui-5.90.0-x86_64-1.txz:  Upgraded.
kde/kxmlrpcclient-5.90.0-x86_64-1.txz:  Upgraded.
kde/latte-dock-0.10.7-x86_64-1.txz:  Upgraded.
kde/modemmanager-qt-5.90.0-x86_64-1.txz:  Upgraded.
kde/networkmanager-qt-5.90.0-x86_64-1.txz:  Upgraded.
kde/oxygen-icons5-5.90.0-noarch-1.txz:  Upgraded.
kde/plasma-framework-5.90.0-x86_64-1.txz:  Upgraded.
kde/plasma-workspace-5.23.5-x86_64-2.txz:  Rebuilt.
  [PATCH] [libtaskmanager] Increase buffer for pipewire format negotiation.
  [PATCH] runners/shell: Port from KToolInvocation::invokeTerminal
  to KTerminalLauncherJob.
  Thanks to gmgf.
kde/prison-5.90.0-x86_64-1.txz:  Upgraded.
kde/purpose-5.90.0-x86_64-1.txz:  Upgraded.
kde/qqc2-desktop-style-5.90.0-x86_64-1.txz:  Upgraded.
kde/solid-5.90.0-x86_64-1.txz:  Upgraded.
kde/sonnet-5.90.0-x86_64-1.txz:  Upgraded.
kde/syndication-5.90.0-x86_64-1.txz:  Upgraded.
kde/syntax-highlighting-5.90.0-x86_64-1.txz:  Upgraded.
kde/threadweaver-5.90.0-x86_64-1.txz:  Upgraded.
l/SDL2-2.0.20-x86_64-1.txz:  Upgraded.
l/SDL2_ttf-2.0.18-x86_64-1.txz:  Upgraded.
l/libsigsegv-2.14-x86_64-1.txz:  Upgraded.
l/pango-1.48.11-x86_64-1.txz:  Upgraded.
l/python-urllib3-1.26.8-x86_64-1.txz:  Upgraded.
n/getmail-6.18.6-x86_64-1.txz:  Upgraded.
n/iproute2-5.16.0-x86_64-1.txz:  Upgraded.
n/metamail-2.7-x86_64-10.txz:  Rebuilt.
  Fixed misnamed mimencode man page. Thanks to mbeninca.
n/mtr-0.95-x86_64-1.txz:  Upgraded.
n/socat-1.7.4.3-x86_64-1.txz:  Upgraded.
xap/freerdp-2.5.0-x86_64-1.txz:  Upgraded.
xap/gnuplot-5.4.3-x86_64-1.txz:  Upgraded.
xap/mozilla-firefox-91.5.0esr-x86_64-1.txz:  Upgraded.
  This release contains security fixes and improvements.
    https://www.mozilla.org/en-US/firefox/91.5.0/releasenotes/
    https://www.mozilla.org/security/advisories/mfsa2022-02/
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22746
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22743
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22742
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22741
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22740
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22738
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22737
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-4140
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22748
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22745
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22744
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22747
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22739
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22751
  (* Security fix *)
xap/mozilla-thunderbird-91.5.0-x86_64-1.txz:  Upgraded.
    https://www.mozilla.org/en-US/thunderbird/91.5.0/releasenotes/
    https://www.mozilla.org/en-US/security/advisories/mfsa2022-03/
  (* Security fix *)
xap/vim-gvim-8.2.4065-x86_64-1.txz:  Upgraded.
n°1472262
cycojesus
Mèo Lười
Posté le 14-01-2022 à 06:59:19  profilanswer
Fri Jan 14 05:24:07 UTC 2022
a/cryptsetup-2.4.3-x86_64-1.txz:  Upgraded.
  This update addresses a multi-step attack on LUKS2 format by orchestrating
  LUKS2 reencryption metadata in existing LUKS2 header. An attacker is able to
  trigger permanent data decryption (ciphertext->plaintext transformation) on
  part of data device on next LUKS2 device activation. Attacker does _not_
  have to know passphrase or decrypted volume encryption key.
  cryptsetup versions older than 2.2.0 are not affected by this, because they
  do not support online LUKS2 reencryption.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-4122
  (* Security fix *)
n°1472313
cycojesus
Mèo Lười
Posté le 16-01-2022 à 10:32:09  profilanswer
Ça se prépare
Sun Jan 16 07:23:29 UTC 2022
a/aaa_base-15.0-x86_64-3.txz:  Rebuilt.
  In initial email to root, use the new /var/lib/pkgtools/ paths to the files
  for packages and scripts. Thanks to franzen.
a/btrfs-progs-5.16-x86_64-1.txz:  Upgraded.
d/python3-3.9.10-x86_64-1.txz:  Upgraded.
d/rust-1.58.0-x86_64-1.txz:  Upgraded.
kde/digikam-7.5.0-x86_64-1.txz:  Upgraded.
kde/kglobalaccel-5.90.0-x86_64-2.txz:  Rebuilt.
  Applied patch:
  [PATCH] Prevent kglobalaccel5 getting activated on non-Plasma systems.
  Although this patch was later reverted, I'm on board with the need for it.
  If it causes any problems, please let me know soon.
  Thanks to Lockywolf.
kde/kid3-3.9.1-x86_64-1.txz:  Upgraded.
kde/plasma-wayland-protocols-1.6.0-x86_64-1.txz:  Upgraded.
kde/sddm-0.19.0-x86_64-10.txz:  Rebuilt.
  Allow the init program to properly supervise sddm when entering runlevel 4.
  Thanks to mumahendras3.
l/neon-0.32.2-x86_64-1.txz:  Upgraded.
l/netpbm-10.97.02-x86_64-1.txz:  Upgraded.
n/postfix-3.6.4-x86_64-1.txz:  Upgraded.
x/mesa-21.3.4-x86_64-1.txz:  Upgraded.
x/xterm-370-x86_64-2.txz:  Rebuilt.
  Use upstream app-defaults again. Thanks to OldHolborn.
n°1472341
cycojesus
Mèo Lười
Posté le 17-01-2022 à 07:19:29  profilanswer
5.15.15
Sun Jan 16 21:33:27 UTC 2022
a/aaa_libraries-15.0-x86_64-14.txz:  Rebuilt.
  Upgraded: libexpat.so.1.8.3.
a/kernel-generic-5.15.15-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.15.15-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.15.15-x86_64-1.txz:  Upgraded.
ap/cups-filters-1.28.11-x86_64-1.txz:  Upgraded.
ap/ksh93-1.0_20220114_e569f23e-x86_64-1.txz:  Upgraded.
ap/vim-8.2.4115-x86_64-1.txz:  Upgraded.
d/gdb-11.2-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.15.15-x86-1.txz:  Upgraded.
k/kernel-source-5.15.15-noarch-1.txz:  Upgraded.
kde/kwayland-server-5.23.5-x86_64-2.txz:  Rebuilt.
  [PATCH] Store surface object in tablet cursor using QPointer.
l/expat-2.4.3-x86_64-1.txz:  Upgraded.
  Fix issues with left shifts by >=29 places resulting in:
    a) realloc acting as free
    b) realloc allocating too few bytes
    c) undefined behavior
  Fix integer overflow on variable m_groupSize in function doProlog leading
  to realloc acting as free. Impact is denial of service or other undefined
  behavior.
  Prevent integer overflows near memory allocation at multiple places.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-45960
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-46143
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22822
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22823
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22824
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22825
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22826
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22827
  (* Security fix *)
l/libunwind-1.6.2-x86_64-1.txz:  Upgraded.
x/xterm-370-x86_64-3.txz:  Rebuilt.
  Ship a sample XTerm.linux.console app-defaults file. Thanks to GazL.
xap/vim-gvim-8.2.4115-x86_64-1.txz:  Upgraded.
xap/xsnow-3.4.3-x86_64-1.txz:  Upgraded.
n°1472363
cycojesus
Mèo Lười
Posté le 18-01-2022 à 08:11:02  profilanswer
Caramba, encore raté ! [:brutalos]
Mon Jan 17 22:44:42 UTC 2022
Things haven't quite settled down yet with more bugfixes and a couple of safe
upgrades, so not today folks. But enjoy Slackware's half-birthday anyway! ;-)
ap/slackpkg-15.0.10-noarch-1.txz:  Upgraded.
  Fix mirrors.ucr.ac.cr link address (Emmet Ford)
  Remove wroc.pl mirrors (Emmet Ford)
  Remove kddilabs.jp from mirrors (Emmet Ford)
  Unattended usage improvements (PiterPUNK)
  Create file to flag if the system needs restart (PiterPUNK)
  Thanks to Robby Workman.
kde/kstars-3.5.7-x86_64-1.txz:  Upgraded.
kde/kwin-5.23.5-x86_64-2.txz:  Rebuilt.
  [PATCH] Bypass wayland interface blacklisting.
  Thanks to LuckyCyborg.
kde/plasma-workspace-5.23.5-x86_64-3.txz:  Rebuilt.
  [PATCH 1/2] Revert "Drop setupX11 from startplasma-waylandsession."
  [PATCH 2/2] Revert "Drop X11 root properties for KDE full session."
l/libical-3.0.13-x86_64-1.txz:  Upgraded.
n/p11-kit-0.24.1-x86_64-1.txz:  Upgraded.
n/stunnel-5.62-x86_64-1.txz:  Upgraded.
x/xterm-370-x86_64-4.txz:  Rebuilt.
  Fixed XTerm-console (previously XTerm.linux.console).
  Renamed XTerm.upstream.default to XTerm-upstream.
  Thanks to GazL.
xap/fluxbox-1.3.7-x86_64-6.txz:  Rebuilt.
  [PATCH] replace FbRootWindow::depth with maxDepth.
xap/geeqie-1.7.1-x86_64-1.txz:  Upgraded.
n°1472402
cycojesus
Mèo Lười
Posté le 19-01-2022 à 09:31:46  profilanswer
Tue Jan 18 20:39:39 UTC 2022
l/rpcsvc-proto-1.4.3-x86_64-1.txz:  Upgraded.
x/xterm-370-x86_64-5.txz:  Rebuilt.
  XTerm-console: don't include locale options by default. Fix typo in comment.
  Thanks to GazL.
n°1472431
cycojesus
Mèo Lười
Posté le 20-01-2022 à 09:16:55  profilanswer
Mé kan alor ⸘ :bounce:
Wed Jan 19 18:18:02 UTC 2022
ap/inxi-3.3.12_1-noarch-1.txz:  Upgraded.
ap/man-db-2.9.4-x86_64-3.txz:  Rebuilt.
  Don't use --no-purge in the daily cron job to update the databases.
l/gst-plugins-bad-free-1.18.5-x86_64-4.txz:  Rebuilt.
  Link against neon-0.32.2.  Thanks to marav.
n/bind-9.16.25-x86_64-1.txz:  Upgraded.
n/ethtool-5.16-x86_64-1.txz:  Upgraded.
n/samba-4.15.4-x86_64-1.txz:  Upgraded.
n/wpa_supplicant-2.10-x86_64-1.txz:  Upgraded.
  The implementations of EAP-pwd in hostapd before 2.10 and wpa_supplicant
  before 2.10 are vulnerable to side-channel attacks as a result of cache
  access patterns.
  NOTE: this issue exists because of an incomplete fix for CVE-2019-9495.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-23303
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-23304
  (* Security fix *)
x/xterm-370-x86_64-6.txz:  Rebuilt.
  XTerm-console: improve the font settings. Thanks to GazL.
n°1472471
cycojesus
Mèo Lười
Posté le 21-01-2022 à 09:45:36  profilanswer
On ne fumera pas des 555 pour la 15.0  [:tymor]
Fri Jan 21 05:47:49 UTC 2022
a/aaa_libraries-15.0-x86_64-15.txz:  Rebuilt.
  Upgraded: libzstd.so.1.5.2.
a/kernel-firmware-20220119_0c6a7b3-noarch-1.txz:  Upgraded.
a/kernel-generic-5.15.16-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.15.16-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.15.16-x86_64-1.txz:  Upgraded.
ap/vim-8.2.4166-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.15.16-x86-1.txz:  Upgraded.
d/rust-1.58.1-x86_64-1.txz:  Upgraded.
k/kernel-source-5.15.16-noarch-1.txz:  Upgraded.
l/qt5-5.15.3_20211130_014c375b-x86_64-2.txz:  Rebuilt.
  [PATCH] Move the wayland socket polling to a separate event thread.
l/svgalib-1.9.25-x86_64-7.txz:  Rebuilt.
  Don't try to use the (broken) assembly. Thanks to nobodino.
l/zstd-1.5.2-x86_64-1.txz:  Upgraded.
x/ibus-m17n-1.4.9-x86_64-1.txz:  Upgraded.
xap/vim-gvim-8.2.4166-x86_64-1.txz:  Upgraded.
extra/php80/php80-8.0.15-x86_64-1.txz:  Upgraded.
extra/php81/php81-8.1.2-x86_64-1.txz:  Upgraded.
P.S.: une LaRue si t'as la ref
Message édité par cycojesus le 21-01-2022 à 09:47:33
n°1472511
cycojesus
Mèo Lười
Posté le 22-01-2022 à 10:13:13  profilanswer
Fri Jan 21 19:58:34 UTC 2022
kde/kconfigwidgets-5.90.1-x86_64-1.txz:  Upgraded.
l/libwebp-1.2.2-x86_64-1.txz:  Upgraded.
n°1472530
cycojesus
Mèo Lười
Posté le 23-01-2022 à 10:34:45  profilanswer
Sun Jan 23 01:17:39 UTC 2022
ap/ddrescue-1.26-x86_64-1.txz:  Upgraded.
d/parallel-20220122-noarch-1.txz:  Upgraded.
l/libimobiledevice-20211124_2c6121d-x86_64-2.txz:  Rebuilt.
  Don't include compatibility pkgconfig symlink. It's unlikely that
  anything requires it.
l/libimobiledevice-glue-20211125_3cb687b-x86_64-2.txz:  Rebuilt.
  Removed broken pkgconfig symlink. Thanks to marav.
n°1472541
cycojesus
Mèo Lười
Posté le 23-01-2022 à 22:50:38  profilanswer
Sun Jan 23 19:36:54 UTC 2022
l/imagemagick-7.1.0_20-x86_64-1.txz:  Upgraded.
  Built using --with-fftw. Thanks to stormbr.
n°1472542
regdub
Posté le 24-01-2022 à 00:21:27  profilanswer
[:ilovezadig:2]
Legalize it @HFR
n°1472587
cycojesus
Mèo Lười
Posté le 25-01-2022 à 09:54:53  profilanswer
Quality-time [:csvop:1]
Tue Jan 25 06:16:36 UTC 2022
It may look like we're currently experiencing more stuckness, but this will
lead us to Quality. We'll have this release in the can before you know it.
a/aaa_glibc-solibs-2.33-x86_64-5.txz:  Rebuilt.
a/aaa_libraries-15.0-x86_64-16.txz:  Rebuilt.
  Rebuilt to pick up the patched libexpat.so.1.8.3.
a/kernel-firmware-20220124_eb8ea1b-noarch-1.txz:  Upgraded.
a/kernel-generic-5.15.16-x86_64-2.txz:  Upgraded.
a/kernel-huge-5.15.16-x86_64-2.txz:  Upgraded.
  -9P_FSCACHE n
   9P_FS m -> y
  Thanks to peake.
a/kernel-modules-5.15.16-x86_64-2.txz:  Upgraded.
a/mkinitrd-1.4.11-x86_64-27.txz:  Rebuilt.
  mkinitrd_command_generator.sh: properly detect partitions of a RAID device.
  Thanks to perrin4869.
a/util-linux-2.37.3-x86_64-1.txz:  Upgraded.
  This release fixes two security mount(8) and umount(8) issues:
  An issue related to parsing the /proc/self/mountinfo file allows an
  unprivileged user to unmount other user's filesystems that are either
  world-writable themselves or mounted in a world-writable directory.
  Improper UID check in libmount allows an unprivileged user to unmount
  FUSE filesystems of users with similar UID.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-3995
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-3996
  (* Security fix *)
ap/vim-8.2.4212-x86_64-1.txz:  Upgraded.
d/git-2.35.0-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.15.16-x86-2.txz:  Upgraded.
k/kernel-source-5.15.16-noarch-2.txz:  Upgraded.
l/expat-2.4.3-x86_64-2.txz:  Rebuilt.
  Fix signed integer overflow in function XML_GetBuffer for when
  XML_CONTEXT_BYTES is defined to >0 (which is both common and
  default). Impact is denial of service or other undefined behavior.
  While we're here, also patch a memory leak on output file opening error.
  Thanks to marav.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-23852
  (* Security fix *)
l/fluidsynth-2.2.5-x86_64-1.txz:  Upgraded.
l/glibc-2.33-x86_64-5.txz:  Rebuilt.
  This update patches two security issues:
  Unexpected return value from glibc's realpath().
  Off-by-one buffer overflow/underflow in glibc's getcwd().
  Thanks to Qualys Research Labs for reporting these issues.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-3998
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-3999
  (* Security fix *)
l/glibc-i18n-2.33-x86_64-5.txz:  Rebuilt.
l/glibc-profile-2.33-x86_64-5.txz:  Rebuilt.
l/tdb-1.4.6-x86_64-1.txz:  Upgraded.
x/xf86-input-libinput-1.2.1-x86_64-1.txz:  Upgraded.
xap/mozilla-thunderbird-91.5.1-x86_64-1.txz:  Upgraded.
  This is a bugfix release.
    https://www.mozilla.org/en-US/thunderbird/91.5.1/releasenotes/
xap/vim-gvim-8.2.4212-x86_64-1.txz:  Upgraded.
n°1472588
regdub
Posté le 25-01-2022 à 10:46:43  profilanswer
Stuckness shouldn't be avoided.  It's the psychic predecessor of all real understanding.  An egoless acceptance of stuckness is a key to an understanding of all Quality, in mechanical work as in other endeavors.
                -- R. Pirsig, "Zen and the Art of Motorcycle Maintenance"
 [:travis_bickle]
Legalize it @HFR
n°1472593
cycojesus
Mèo Lười
Posté le 25-01-2022 à 16:28:35  profilanswer
 [:travis_bickle]
n°1472600
cycojesus
Mèo Lười
Posté le 25-01-2022 à 22:05:19  profilanswer
Tue Jan 25 20:10:35 UTC 2022
d/icecream-1.3.1-x86_64-4.txz:  Rebuilt.
  rc.icecream.conf: generate an error message and avoid a hang when
  "hostname -d" doesn't work, usually because the hostname in /etc/HOSTNAME
  can't be resolved. Thanks to franzen.
kde/latte-dock-0.10.8-x86_64-1.txz:  Upgraded.
xap/geeqie-1.7.2-x86_64-1.txz:  Upgraded.
n°1472605
cycojesus
Mèo Lười
Posté le 26-01-2022 à 08:28:53  profilanswer
Le polo polka de polkit est troué :o
Wed Jan 26 04:37:35 UTC 2022
l/polkit-0.120-x86_64-2.txz:  Rebuilt.
  [PATCH] pkexec: local privilege escalation.
  Thanks to Qualys Research Labs for reporting this issue.
    https://blog.qualys.com/vulnerabilities-threat-research/2022/01/25/pwnkit-local-privilege-escalation-vulnerability-discovered-in-polkits-pkexec-cve-2021-4034
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-4034
  (* Security fix *)
n°1472626
regdub
Posté le 26-01-2022 à 22:38:54  profilanswer
On attends que samba bouche(ka) ses trous maintenant.
Nous n'irons pas danser cette semaine. :o
With the word out I wonder if they'll actually wait until Monday. After missing the last soft deadline for release, I was targeting next Monday but it seems that's not a good day. We really don't want to release with a network service package in the main tree containing a 9.9 critical security issue.
I'm now targeting Wednesday 2022-02-02. We'll hope Slackware doesn't see its shadow that day.
https://www.linuxquestions.org/ques [...] ost6322012
Message édité par regdub le 26-01-2022 à 22:56:17
Legalize it @HFR
n°1472667
cycojesus
Mèo Lười
Posté le 27-01-2022 à 22:44:30  profilanswer
2022-02-02 c'est à la fois loin et tout près  :bounce:
Meanwhile
Wed Jan 26 20:46:44 UTC 2022
a/aaa_libraries-15.0-x86_64-17.txz:  Rebuilt.
  Upgraded: libcap.so.2.63, libglib-2.0.so.0.7000.3,
  libgmodule-2.0.so.0.7000.3, libgobject-2.0.so.0.7000.3,
  libgthread-2.0.so.0.7000.3, libtdb.so.1.4.6.
a/mkinitrd-1.4.11-x86_64-28.txz:  Rebuilt.
  Support kernel modules compressed with xz. Thanks to baldzhang.
l/glib2-2.70.3-x86_64-1.txz:  Upgraded.
l/libcap-2.63-x86_64-1.txz:  Upgraded.
n/bluez-5.63-x86_64-2.txz:  Rebuilt.
  rc.bluetooth: use #!/bin/bash shebang.
  Filter commented and empty lines when parsing uart.conf.
  Thanks to atelszewski.
n°1472674
cycojesus
Mèo Lười
Posté le 28-01-2022 à 09:08:53  profilanswer
ToussaKa
Thu Jan 27 22:43:13 UTC 2022
a/aaa_libraries-15.0-x86_64-18.txz:  Rebuilt.
a/kernel-generic-5.15.17-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.15.17-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.15.17-x86_64-1.txz:  Upgraded.
a/lzlib-1.13-x86_64-1.txz:  Upgraded.
a/sysvinit-scripts-15.0-noarch-8.txz:  Rebuilt.
  rc.S: clear /var/lock/subsys before starting libcgroup services.
  Thanks to pyllyukko.
ap/pamixer-1.5-x86_64-2.txz:  Rebuilt.
  Recompiled against boost-1.78.0.
d/kernel-headers-5.15.17-x86-1.txz:  Upgraded.
k/kernel-source-5.15.17-noarch-1.txz:  Upgraded.
kde/kig-21.12.1-x86_64-2.txz:  Rebuilt.
kde/kopeninghours-21.12.1-x86_64-2.txz:  Rebuilt.
kde/krita-5.0.2-x86_64-2.txz:  Rebuilt.
l/boost-1.78.0-x86_64-1.txz:  Upgraded.
  I hadn't planned to update this at such a late stage, but POV-Ray needs it
  and everything we ship builds fine against it. Thanks to bender647.
l/cryfs-0.10.3-x86_64-4.txz:  Rebuilt.
l/expat-2.4.3-x86_64-3.txz:  Rebuilt.
  Prevent integer overflow in doProlog.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-23990
  (* Security fix *)
l/netpbm-10.97.03-x86_64-1.txz:  Upgraded.
l/openexr-2.5.7-x86_64-5.txz:  Rebuilt.
l/pipewire-0.3.44-x86_64-1.txz:  Upgraded.
n/fetchmail-6.4.27-x86_64-1.txz:  Upgraded.
n/libgpg-error-1.44-x86_64-1.txz:  Upgraded.
x/mesa-21.3.5-x86_64-1.txz:  Upgraded.
xap/mozilla-firefox-91.5.1esr-x86_64-1.txz:  Upgraded.
    https://www.mozilla.org/en-US/firefox/91.5.1/releasenotes/
  (* Security fix *)
extra/rust-for-mozilla/rust-1.54.0-x86_64-4.txz:  Rebuilt.
  Removed duplicated libLLVM shared library.
n°1472725
cycojesus
Mèo Lười
Posté le 29-01-2022 à 08:49:07  profilanswer
on va y arriver
Sat Jan 29 06:17:05 UTC 2022
a/rpm2tgz-1.2.2-x86_64-5.txz:  Rebuilt.
  rpm2targz: when extracting the cpio archive from inside the RPM, use
  --no-absolute-filenames to protect against a poorly made RPM scribbling all
  over system files/directories. Thanks to Sl4ck3ver.
  Support -i option to ignore non-zero exit value from rpm2cpio.
  This allows repackaging some malformed RPMs.
  Thanks to ricky_cardo for the sample malformed RPM.
Fri Jan 28 21:01:03 UTC 2022
a/plzip-1.10-x86_64-1.txz:  Upgraded.
ap/sudo-1.9.9-x86_64-1.txz:  Upgraded.
d/Cython-0.29.27-x86_64-1.txz:  Upgraded.
d/poke-2.0-x86_64-1.txz:  Upgraded.
l/python-charset-normalizer-2.0.10-x86_64-1.txz:  Upgraded.
x/mesa-21.3.5-x86_64-2.txz:  Rebuilt.
  Include eglinfo utility. Thanks to LuckyCyborg.
x/wayland-protocols-1.25-noarch-1.txz:  Upgraded.
n°1472763
cycojesus
Mèo Lười
Posté le 30-01-2022 à 10:55:18  profilanswer
Un p'tit Kawa pour patienter ? :o
Sat Jan 29 19:23:50 UTC 2022
a/kernel-generic-5.15.18-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.15.18-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.15.18-x86_64-1.txz:  Upgraded.
ap/vim-8.2.4256-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.15.18-x86-1.txz:  Upgraded.
k/kernel-source-5.15.18-noarch-1.txz:  Upgraded.
xap/vim-gvim-8.2.4256-x86_64-1.txz:  Upgraded.
n°1472785
cycojesus
Mèo Lười
Posté le 31-01-2022 à 08:54:55  profilanswer
Sun Jan 30 20:48:46 UTC 2022
a/aaa_libraries-15.0-x86_64-19.txz:  Rebuilt.
  Upgraded:  libexpat.so.1.8.4, libjson-c.so.5.1.0 (thanks to peake).
ap/at-3.2.4-x86_64-1.txz:  Upgraded.
d/git-2.35.1-x86_64-1.txz:  Upgraded.
l/expat-2.4.4-x86_64-1.txz:  Upgraded.
  This update merges the patches we previously applied to expat-2.4.3.
l/imagemagick-7.1.0_22-x86_64-1.txz:  Upgraded.
l/lcms2-2.13-x86_64-1.txz:  Upgraded.
n°1472837
cycojesus
Mèo Lười
Posté le 01-02-2022 à 08:09:23  profilanswer
  • The sepulchral voice intones, "The cave is now closed."
  • Hey, my shiny brass lamp is almost out of fuel!
Tue Feb  1 05:35:21 UTC 2022
a/rpm2tgz-1.2.2-x86_64-6.txz:  Rebuilt.
  Don't use --no-absolute-filenames, because inexplicably it also strips the
  leading '/' from symlink targets, generally creating a broken symlink.
  The problem we were attempting to fix is far less common than symlinks to
  absolute filenames, so we'll revert this for further consideration.
  Thanks to pghvlaans.
Tue Feb  1 04:37:04 UTC 2022
kde/falkon-3.2.0-x86_64-1.txz:  Upgraded.
kde/ktexteditor-5.90.0-x86_64-2.txz:  Rebuilt.
  [PATCH] only start programs in user's path.
  [PATCH] only execute diff in path.
  Thanks to gmgf.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-23853
  (* Security fix *)
l/libcanberra-0.30-x86_64-9.txz:  Rebuilt.
  Fix a bug crashing some applications in Wayland desktops.
  Thanks to 01micko.
n/samba-4.15.5-x86_64-1.txz:  Upgraded.
  This is a security release in order to address the following defects:
  UNIX extensions in SMB1 disclose whether the outside target of a symlink
  exists.
  Out-of-Bound Read/Write on Samba vfs_fruit module. This vulnerability
  allows remote attackers to execute arbitrary code as root on affected Samba
  installations that use the VFS module vfs_fruit.
  Re-adding an SPN skips subsequent SPN conflict checks. An attacker who has
  the ability to write to an account can exploit this to perform a
  denial-of-service attack by adding an SPN that matches an existing service.
  Additionally, an attacker who can intercept traffic can impersonate existing
  services, resulting in a loss of confidentiality and integrity.
    https://www.samba.org/samba/security/CVE-2021-44141.html
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-44141
    https://www.samba.org/samba/security/CVE-2021-44142.html
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-44142
    https://www.samba.org/samba/security/CVE-2022-0336.html
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-0336
  (* Security fix *)
x/xterm-370-x86_64-7.txz:  Rebuilt.
  Rebuilt with --disable-sixel-graphics to fix a buffer overflow.
  Thanks to gmgf.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-24130
  (* Security fix *)
testing/source/linux-5.16.4-configs/*:  Added.
  Sample config files to build 5.16.4 Linux kernels.
n°1472839
regdub
Posté le 01-02-2022 à 09:54:58  profilanswer
C'est les soldes sur les fix de sécurité.  [:padmasana:3]
Legalize it @HFR
Slackware 9.0[slackware] Suppression de terminaux virtuels ?
!! Configuration reseaux, slackware 9 !!Installer slackware 9.0 par ftp (boot disquette)
[Pb] Installation new HDD sous slackware 8.0[RESOLU] Pb d'execution mysql sur slackware ...
Slackware 9 du pur bonheurMonter une partition NTFS sous linux (slackware 9.0)
Slackware 9.0 Finale OUTJe sens que je vais quitter Slackware (pas en serv)
Plus de sujets relatifs à : [SLACKWARE] du présent - 15.0
