10220 connectés
La 15.0 est là (en vrai !)
Les invités peuvent voter
 Page :   1  2  3  4  5  ..  101  102  103  ..  109  110  111  112  113  114
[SLACKWARE] du présent - 15.0
n°1464156
cycojesus
Mèo Lười
Posté le 27-04-2021 à 11:09:58  profilanswer
Mon Apr 26 22:04:20 UTC 2021
a/hdparm-9.61-x86_64-1.txz:  Upgraded.
a/kernel-firmware-20210426_fa0efef-noarch-1.txz:  Upgraded.
ap/cups-2.3.3-x86_64-6.txz:  Rebuilt.
  Removed /lib/modprobe.d/cups-blacklist-usblp.conf. Thanks to vovim.
ap/vim-8.2.2814-x86_64-1.txz:  Upgraded.
d/strace-5.12-x86_64-1.txz:  Upgraded.
kde/kstars-3.5.3-x86_64-1.txz:  Upgraded.
kde/sddm-0.19.0-x86_64-7.txz:  Rebuilt.
  List X11 sessions before Wayland sessions. Thanks to Heinz Wiesinger.
l/imagemagick-7.0.11_9-x86_64-1.txz:  Upgraded.
xap/vim-gvim-8.2.2814-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-generic-5.12.0-x86_64-2.txz:  Rebuilt.
testing/packages/linux-5.12.x/kernel-headers-5.12.0-x86-2.txz:  Rebuilt.
testing/packages/linux-5.12.x/kernel-huge-5.12.0-x86_64-2.txz:  Rebuilt.
testing/packages/linux-5.12.x/kernel-modules-5.12.0-x86_64-2.txz:  Rebuilt.
testing/packages/linux-5.12.x/kernel-source-5.12.0-noarch-2.txz:  Rebuilt.
  Restore dm-crypt as built-in. Thanks to ctrlaltca.
  DM_CRYPT m -> y
  TCG_TPM m -> y
  TRUSTED_KEYS m -> y
Chết rồi ! ✍ ⌥⌘ http://codeberg.org/gwh
n°1464205
cycojesus
Mèo Lười
Posté le 28-04-2021 à 11:02:30  profilanswer
Tue Apr 27 19:19:28 UTC 2021
a/mkinitrd-1.4.11-x86_64-24.txz:  Rebuilt.
  Change mkinitrd shebang to #!/bin/bash. Thanks to mumahendras3.
  Still, don't point /bin/sh at a shell other than bash.
  Only include dm-snapshot if LVM is included. Thanks to j12i.
a/tcsh-6.22.04-x86_64-1.txz:  Upgraded.
ap/mariadb-10.6.0-x86_64-1.txz:  Upgraded.
  Removed TokuDB stuff from rc.mysqld. Thanks to gsl.
  This update fixes the illegal instruction regession on 32-bit with processors
  that do not support SSE4.1 instructions.
  Thanks to Noel and Charlie Wilder for reporting the issue upstream
  and Matteo Bernardini for helping with the debugging.
  And of course, thanks to the MariaDB upstream developers. :-)
n°1464207
gunsman
La bonne affaire...
Posté le 28-04-2021 à 11:10:21  profilanswer
On peut faire quelque chose de sympa esthetiquement sur une Slackware ?
J'ai besoin :
- Teamvieuwer
- Remmina
- Owncloud
- Overgrive
- Dropbox
- Chromium
- Firefox
- Pidgin
Actuellement j'utilise Xubuntu et franchement elle tourne au top cette distribution. Mais j'aimerais bien tester la Slackware depuis un bon moment mais je n'ose pas franchir le pas.
n°1464234
regdub
Posté le 28-04-2021 à 19:13:09  profilanswer
J'ai besoin :
- Teamvieuwer
- Remmina
- Owncloud
- Overgrive
- Dropbox
- Chromium
- Firefox
- Pidgin
Je ne comprends pas très bien la première question. :o
Les 3 derniers de ta liste sont dispos en packages d'origine et chez un contributeur, pour les autres, faut tester les scripts de build et les solutions type appimage/flatpak...
Fais-toi plusieurs partitions système, quitte à utiliser un disque externe. Ça permet de faire des expérimentations à son rythme et sans casser ce qui marche.
Legalize it @HFR
n°1464238
gunsman
La bonne affaire...
Posté le 28-04-2021 à 20:25:17  profilanswer
Merci !
J'ai installé Slackware en virtualbox, je vais maintenant essayer d'installer chaque logiciel. Je verrai bien ce que ça donne, en toit cas c'est très rapide, très réactif.
n°1464253
cycojesus
Mèo Lười
Posté le 29-04-2021 à 09:05:30  profilanswer
Thu Apr 29 01:37:15 UTC 2021
n/bind-9.16.15-x86_64-1.txz:  Upgraded.
  This update fixes bugs and the following security issues:
  A specially crafted GSS-TSIG query could cause a buffer overflow in the
  ISC implementation of SPNEGO.
  named crashed when a DNAME record placed in the ANSWER section during DNAME
  chasing turned out to be the final answer to a client query.
  Insufficient IXFR checks could result in named serving a zone without an SOA
  record at the apex, leading to a RUNTIME_CHECK assertion failure when the
  zone was subsequently refreshed. This has been fixed by adding an owner name
  check for all SOA records which are included in a zone transfer.
  For more information, see:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-25216
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-25215
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-25214
  (* Security fix *)
Wed Apr 28 18:40:26 UTC 2021
a/kernel-generic-5.10.33-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.10.33-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.10.33-x86_64-1.txz:  Upgraded.
a/less-581-x86_64-2.txz:  Rebuilt.
  lesspipe.sh: support *.tzst, *.tar.zst, *.tar.zstd.
d/guile-3.0.6-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.10.33-x86-1.txz:  Upgraded.
k/kernel-source-5.10.33-noarch-1.txz:  Upgraded.
n/iproute2-5.12.0-x86_64-1.txz:  Upgraded.
x/libwacom-1.10-x86_64-1.txz:  Upgraded.
isolinux/initrd.img:  Rebuilt.
kernels/*:  Upgraded.
usb-and-pxe-installers/usbboot.img:  Rebuilt.
n°1464308
cycojesus
Mèo Lười
Posté le 30-04-2021 à 11:00:27  profilanswer
Thu Apr 29 18:49:00 UTC 2021
a/less-581.2-x86_64-1.txz:  Upgraded.
ap/nano-5.7-x86_64-1.txz:  Upgraded.
d/cmake-3.20.2-x86_64-1.txz:  Upgraded.
n/httpd-2.4.47-x86_64-1.txz:  Upgraded.
n/samba-4.14.4-x86_64-1.txz:  Upgraded.
  This is a security release in order to address the following defect:
  Negative idmap cache entries can cause incorrect group entries in the
  Samba file server process token.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-20254
    https://www.samba.org/samba/security/CVE-2021-20254.html
  (* Security fix *)
extra/php8/php8-8.0.5-x86_64-1.txz:  Upgraded.
n°1464344
gunsman
La bonne affaire...
Posté le 01-05-2021 à 11:32:42  profilanswer
Slackware est en cours d'installation !
C'est une première pour moi, je dois avouer que ça me change des installations standard.
Je reviendrai dans quelques heures si je ne trouve pas de solution a mes problèmes.
J'espère pouvoir installer ce dont j'ai besoin !
J'adore déjà la philosophie de cette distribution.
n°1464348
cycojesus
Mèo Lười
Posté le 01-05-2021 à 15:41:46  profilanswer
 [:el awrence]
Fri Apr 30 18:09:21 UTC 2021
l/gvfs-1.48.1-x86_64-1.txz:  Upgraded.
l/imagemagick-7.0.11_10-x86_64-1.txz:  Upgraded.
n/php-7.4.18-x86_64-1.txz:  Upgraded.
  This update fixes bugs and security issues.
    https://www.php.net/ChangeLog-7.php#7.4.18
  (* Security fix *)
n/postfix-3.6.0-x86_64-1.txz:  Upgraded.
x/libepoxy-1.5.7-x86_64-1.txz:  Upgraded.
x/libinput-1.17.2-x86_64-1.txz:  Upgraded.
x/xorgproto-2021.4-x86_64-1.txz:  Upgraded.
xap/pavucontrol-4.0-x86_64-4.txz:  Rebuilt.
  Fix segfault after crtl-Q. Thanks to Jonathan Woithe and 2slguevH.
xap/pidgin-2.14.4-x86_64-1.txz:  Upgraded.
n°1464349
gunsman
La bonne affaire...
Posté le 01-05-2021 à 16:12:40  profilanswer
Bon désolé, je vais polluer un peu le topic avec mon installation...
Installation --> OK
Mise à jour --> OK
Passage en wifi --> OK
J'ai encore le problème de clavier au démarrage lors du Login qui reste en anglais alors que j'ai remplacé la langue dans /etc/profile.d/lang.sh
J'ai également un soucis quand je démarre sur ma station d'accueil, mon écran principal est detecté mais il n'y a rien qui s'affiche dessus.
Bon je continue à chercher.
n°1464374
cycojesus
Mèo Lười
Posté le 02-05-2021 à 13:28:57  profilanswer
Sat May  1 18:12:57 UTC 2021
a/mcelog-176-x86_64-1.txz:  Upgraded.
d/python-pip-21.1.1-x86_64-1.txz:  Upgraded.
l/librsvg-2.50.5-x86_64-1.txz:  Upgraded.
l/vte-0.64.1-x86_64-1.txz:  Upgraded.
x/libglvnd-1.3.3-x86_64-1.txz:  Upgraded.
x/wayland-protocols-1.21-noarch-1.txz:  Upgraded.
n°1464409
cycojesus
Mèo Lười
Posté le 03-05-2021 à 14:03:59  profilanswer
Sun May  2 19:41:57 UTC 2021
a/kernel-generic-5.10.34-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.10.34-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.10.34-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.10.34-x86-1.txz:  Upgraded.
d/meson-0.58.0-x86_64-1.txz:  Upgraded.
d/vala-0.52.3-x86_64-1.txz:  Upgraded.
k/kernel-source-5.10.34-noarch-1.txz:  Upgraded.
kde/plasma-wayland-protocols-1.3.0-x86_64-1.txz:  Upgraded.
l/at-spi2-core-2.40.1-x86_64-1.txz:  Upgraded.
l/libxkbcommon-1.3.0-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-generic-5.12.1-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-headers-5.12.1-x86-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-huge-5.12.1-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-modules-5.12.1-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-source-5.12.1-noarch-1.txz:  Upgraded.
n°1464447
cycojesus
Mèo Lười
Posté le 04-05-2021 à 08:34:00  profilanswer
Mon May  3 19:58:20 UTC 2021
a/kernel-firmware-20210503_3f23f51-noarch-1.txz:  Upgraded.
ap/mariadb-10.5.9-x86_64-1.txz:  Upgraded.
  Reverted to the latest stable release.
d/mercurial-5.8-x86_64-1.txz:  Upgraded.
kde/calligra-3.2.1-x86_64-8.txz:  Rebuilt.
  Recompiled against poppler-21.05.0.
kde/cantor-21.04.0-x86_64-2.txz:  Rebuilt.
kde/kfilemetadata-5.81.0-x86_64-2.txz:  Rebuilt.
kde/kile-2.9.93-x86_64-8.txz:  Rebuilt.
kde/kitinerary-21.04.0-x86_64-2.txz:  Rebuilt.
kde/krita-4.4.3-x86_64-4.txz:  Rebuilt.
kde/okular-21.04.0-x86_64-2.txz:  Rebuilt.
l/isl-0.24-x86_64-1.txz:  Upgraded.
l/poppler-21.05.0-x86_64-1.txz:  Upgraded.
  Shared library .so-version bump.
l/python-pygments-2.9.0-x86_64-1.txz:  Upgraded.
n/ethtool-5.12-x86_64-1.txz:  Upgraded.
n/httpd-2.4.47-x86_64-2.txz:  Rebuilt.
  Recompiled against the mariadb-10.5.9 shared libraries.
n/postfix-3.6.0-x86_64-2.txz:  Rebuilt.
xap/gparted-1.3.0-x86_64-1.txz:  Upgraded.
testing/packages/mariadb-10.6.0-x86_64-1.txz:  Upgraded.
  Since this is still considered alpha and not production ready, we'll put it
  in /testing for now. Unless you're using an Atom (or other 32-bit processor
  affected by the illegal instruction issue) it's probably best to stick with
  mariadb-10.5.9.
n°1464477
cycojesus
Mèo Lười
Posté le 04-05-2021 à 23:24:38  profilanswer
Tue May  4 18:56:00 UTC 2021
a/hwdata-0.347-noarch-1.txz:  Upgraded.
a/kernel-firmware-20210503_ecdfcf8-noarch-1.txz:  Upgraded.
d/python3-3.9.5-x86_64-1.txz:  Upgraded.
kde/bluedevil-5.21.5-x86_64-1.txz:  Upgraded.
kde/breeze-5.21.5-x86_64-1.txz:  Upgraded.
kde/breeze-grub-5.21.5-x86_64-1.txz:  Upgraded.
kde/breeze-gtk-5.21.5-x86_64-1.txz:  Upgraded.
kde/drkonqi-5.21.5-x86_64-1.txz:  Upgraded.
kde/kactivitymanagerd-5.21.5-x86_64-1.txz:  Upgraded.
kde/kde-cli-tools-5.21.5-x86_64-1.txz:  Upgraded.
kde/kde-gtk-config-5.21.5-x86_64-1.txz:  Upgraded.
kde/kdecoration-5.21.5-x86_64-1.txz:  Upgraded.
kde/kdeplasma-addons-5.21.5-x86_64-1.txz:  Upgraded.
kde/kgamma5-5.21.5-x86_64-1.txz:  Upgraded.
kde/khotkeys-5.21.5-x86_64-1.txz:  Upgraded.
kde/kinfocenter-5.21.5-x86_64-1.txz:  Upgraded.
kde/kmenuedit-5.21.5-x86_64-1.txz:  Upgraded.
kde/kscreen-5.21.5-x86_64-1.txz:  Upgraded.
kde/kscreenlocker-5.21.5-x86_64-1.txz:  Upgraded.
kde/ksshaskpass-5.21.5-x86_64-1.txz:  Upgraded.
kde/ksysguard-5.21.5-x86_64-1.txz:  Upgraded.
kde/kwallet-pam-5.21.5-x86_64-1.txz:  Upgraded.
kde/kwayland-integration-5.21.5-x86_64-1.txz:  Upgraded.
kde/kwayland-server-5.21.5-x86_64-1.txz:  Upgraded.
kde/kwin-5.21.5-x86_64-1.txz:  Upgraded.
kde/kwrited-5.21.5-x86_64-1.txz:  Upgraded.
kde/libkscreen-5.21.5-x86_64-1.txz:  Upgraded.
kde/libksysguard-5.21.5-x86_64-1.txz:  Upgraded.
kde/milou-5.21.5-x86_64-1.txz:  Upgraded.
kde/oxygen-5.21.5-x86_64-1.txz:  Upgraded.
kde/plasma-browser-integration-5.21.5-x86_64-1.txz:  Upgraded.
kde/plasma-desktop-5.21.5-x86_64-1.txz:  Upgraded.
kde/plasma-disks-5.21.5-x86_64-1.txz:  Upgraded.
kde/plasma-firewall-5.21.5-x86_64-1.txz:  Upgraded.
kde/plasma-integration-5.21.5-x86_64-1.txz:  Upgraded.
kde/plasma-nm-5.21.5-x86_64-1.txz:  Upgraded.
kde/plasma-pa-5.21.5-x86_64-1.txz:  Upgraded.
kde/plasma-sdk-5.21.5-x86_64-1.txz:  Upgraded.
kde/plasma-systemmonitor-5.21.5-x86_64-1.txz:  Upgraded.
kde/plasma-vault-5.21.5-x86_64-1.txz:  Upgraded.
kde/plasma-workspace-5.21.5-x86_64-1.txz:  Upgraded.
kde/plasma-workspace-wallpapers-5.21.5-x86_64-1.txz:  Upgraded.
kde/polkit-kde-agent-1-5.21.5-x86_64-1.txz:  Upgraded.
kde/powerdevil-5.21.5-x86_64-1.txz:  Upgraded.
kde/qqc2-breeze-style-5.21.5-x86_64-1.txz:  Upgraded.
kde/sddm-kcm-5.21.5-x86_64-1.txz:  Upgraded.
kde/systemsettings-5.21.5-x86_64-1.txz:  Upgraded.
kde/xdg-desktop-portal-kde-5.21.5-x86_64-1.txz:  Upgraded.
l/harfbuzz-2.8.1-x86_64-1.txz:  Upgraded.
x/ibus-table-1.12.6-x86_64-1.txz:  Upgraded.
x/liberation-fonts-ttf-2.1.4-noarch-1.txz:  Upgraded.
n°1464485
kisscoolz
Posté le 05-05-2021 à 10:44:56  profilanswer
Vous reprendrez bien un peu de kdessert ? :o
n°1464504
cycojesus
Mèo Lười
Posté le 05-05-2021 à 22:16:45  profilanswer
et aussi des truKs Kassés sont Karrément Komplétement Konsolidés :bounce:
Wed May  5 19:56:53 UTC 2021
a/bash-5.1.008-x86_64-1.txz:  Upgraded.
d/python-setuptools-56.1.0-x86_64-1.txz:  Upgraded.
l/libgnt-2.14.1-x86_64-1.txz:  Added.
  Thanks to Robby Workman.
l/mozjs78-78.10.1esr-x86_64-1.txz:  Upgraded.
l/python-six-1.16.0-x86_64-1.txz:  Upgraded.
l/readline-8.1.001-x86_64-1.txz:  Upgraded.
n/mutt-2.0.7-x86_64-1.txz:  Upgraded.
n/php-7.4.19-x86_64-1.txz:  Upgraded.
xap/mozilla-firefox-88.0.1-x86_64-1.txz:  Upgraded.
  This release contains security fixes and improvements.
    https://www.mozilla.org/en-US/firefox/88.0.1/releasenotes/
    https://www.mozilla.org/security/advisories/mfsa2021-20/
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-29953
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-29952
  (* Security fix *)
xap/mozilla-thunderbird-78.10.1-x86_64-1.txz:  Upgraded.
    https://www.mozilla.org/en-US/thunderbird/78.10.1/releasenotes/
    https://www.mozilla.org/en-US/security/advisories/mfsa2021-19/
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-29951
  (* Security fix *)
xap/pidgin-2.14.4-x86_64-2.txz:  Rebuilt.
  Recompiled against libgnt-2.14.1 to restore the finch cli app.
xfce/xfce4-clipman-plugin-1.6.2-x86_64-1.txz:  Upgraded.
extra/php8/php8-8.0.6-x86_64-1.txz:  Upgraded.
n°1464554
cycojesus
Mèo Lười
Posté le 07-05-2021 à 09:25:58  profilanswer
Thu May  6 19:40:22 UTC 2021
ap/lsscsi-0.32-x86_64-1.txz:  Upgraded.
l/adwaita-icon-theme-40.1.1-noarch-1.txz:  Upgraded.
l/gjs-1.68.1-x86_64-1.txz:  Upgraded.
l/gnome-keyring-40.0-x86_64-1.txz:  Upgraded.
l/imagemagick-7.0.11_11-x86_64-1.txz:  Upgraded.
l/pipewire-0.3.27-x86_64-1.txz:  Upgraded.
xfce/xfce4-panel-4.16.3-x86_64-1.txz:  Upgraded.
n°1464607
cycojesus
Mèo Lười
Posté le 08-05-2021 à 09:59:59  profilanswer
Sat May  8 00:24:32 UTC 2021
a/kernel-generic-5.10.35-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.10.35-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.10.35-x86_64-1.txz:  Upgraded.
a/lvm2-2.03.12-x86_64-1.txz:  Upgraded.
ap/mariadb-10.5.10-x86_64-1.txz:  Upgraded.
ap/mpg123-1.27.0-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.10.35-x86-1.txz:  Upgraded.
k/kernel-source-5.10.35-noarch-1.txz:  Upgraded.
n/httpd-2.4.46-x86_64-3.txz:  Rebuilt.
  Reverted to httpd-2.4.46. Apparently 2.4.47 isn't actually released yet.
  Sorry for any problems this caused.
xfce/thunar-4.16.8-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-generic-5.12.2-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-headers-5.12.2-x86-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-huge-5.12.2-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-modules-5.12.2-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-source-5.12.2-noarch-1.txz:  Upgraded.
n°1464624
cycojesus
Mèo Lười
Posté le 09-05-2021 à 11:01:35  profilanswer
Yo K!  [:micheline_tchoutchou1:3]
Sun May  9 02:37:17 UTC 2021
kde/attica-5.82.0-x86_64-1.txz:  Upgraded.
kde/baloo-5.82.0-x86_64-1.txz:  Upgraded.
kde/bluez-qt-5.82.0-x86_64-1.txz:  Upgraded.
kde/breeze-icons-5.82.0-noarch-1.txz:  Upgraded.
kde/extra-cmake-modules-5.82.0-x86_64-1.txz:  Upgraded.
kde/frameworkintegration-5.82.0-x86_64-1.txz:  Upgraded.
kde/kactivities-5.82.0-x86_64-1.txz:  Upgraded.
kde/kactivities-stats-5.82.0-x86_64-1.txz:  Upgraded.
kde/kapidox-5.82.0-x86_64-1.txz:  Upgraded.
kde/karchive-5.82.0-x86_64-1.txz:  Upgraded.
kde/kauth-5.82.0-x86_64-1.txz:  Upgraded.
kde/kbookmarks-5.82.0-x86_64-1.txz:  Upgraded.
kde/kcalendarcore-5.82.0-x86_64-1.txz:  Upgraded.
kde/kcmutils-5.82.0-x86_64-1.txz:  Upgraded.
kde/kcodecs-5.82.0-x86_64-1.txz:  Upgraded.
kde/kcompletion-5.82.0-x86_64-1.txz:  Upgraded.
kde/kconfig-5.82.0-x86_64-1.txz:  Upgraded.
kde/kconfigwidgets-5.82.0-x86_64-1.txz:  Upgraded.
kde/kcontacts-5.82.0-x86_64-1.txz:  Upgraded.
kde/kcoreaddons-5.82.0-x86_64-1.txz:  Upgraded.
kde/kcrash-5.82.0-x86_64-1.txz:  Upgraded.
kde/kdav-5.82.0-x86_64-1.txz:  Upgraded.
kde/kdbusaddons-5.82.0-x86_64-1.txz:  Upgraded.
kde/kdeclarative-5.82.0-x86_64-1.txz:  Upgraded.
kde/kded-5.82.0-x86_64-1.txz:  Upgraded.
kde/kdelibs4support-5.82.0-x86_64-1.txz:  Upgraded.
kde/kdesignerplugin-5.82.0-x86_64-1.txz:  Upgraded.
kde/kdesu-5.82.0-x86_64-1.txz:  Upgraded.
kde/kdewebkit-5.82.0-x86_64-1.txz:  Upgraded.
kde/kdnssd-5.82.0-x86_64-1.txz:  Upgraded.
kde/kdoctools-5.82.0-x86_64-1.txz:  Upgraded.
kde/kemoticons-5.82.0-x86_64-1.txz:  Upgraded.
kde/kfilemetadata-5.82.0-x86_64-1.txz:  Upgraded.
kde/kglobalaccel-5.82.0-x86_64-1.txz:  Upgraded.
kde/kguiaddons-5.82.0-x86_64-1.txz:  Upgraded.
kde/kholidays-5.82.0-x86_64-1.txz:  Upgraded.
kde/khtml-5.82.0-x86_64-1.txz:  Upgraded.
kde/ki18n-5.82.0-x86_64-1.txz:  Upgraded.
kde/kiconthemes-5.82.0-x86_64-1.txz:  Upgraded.
kde/kidletime-5.82.0-x86_64-1.txz:  Upgraded.
kde/kimageformats-5.82.0-x86_64-1.txz:  Upgraded.
kde/kinit-5.82.0-x86_64-1.txz:  Upgraded.
kde/kio-5.82.0-x86_64-1.txz:  Upgraded.
kde/kirigami2-5.82.0-x86_64-1.txz:  Upgraded.
kde/kitemmodels-5.82.0-x86_64-1.txz:  Upgraded.
kde/kitemviews-5.82.0-x86_64-1.txz:  Upgraded.
kde/kjobwidgets-5.82.0-x86_64-1.txz:  Upgraded.
kde/kjs-5.82.0-x86_64-1.txz:  Upgraded.
kde/kjsembed-5.82.0-x86_64-1.txz:  Upgraded.
kde/kmediaplayer-5.82.0-x86_64-1.txz:  Upgraded.
kde/knewstuff-5.82.0-x86_64-1.txz:  Upgraded.
kde/knotifications-5.82.0-x86_64-1.txz:  Upgraded.
kde/knotifyconfig-5.82.0-x86_64-1.txz:  Upgraded.
kde/kpackage-5.82.0-x86_64-1.txz:  Upgraded.
kde/kparts-5.82.0-x86_64-1.txz:  Upgraded.
kde/kpeople-5.82.0-x86_64-1.txz:  Upgraded.
kde/kplotting-5.82.0-x86_64-1.txz:  Upgraded.
kde/kpty-5.82.0-x86_64-1.txz:  Upgraded.
kde/kquickcharts-5.82.0-x86_64-1.txz:  Upgraded.
kde/kross-5.82.0-x86_64-1.txz:  Upgraded.
kde/krunner-5.82.0-x86_64-1.txz:  Upgraded.
kde/kservice-5.82.0-x86_64-1.txz:  Upgraded.
kde/ktexteditor-5.82.0-x86_64-1.txz:  Upgraded.
kde/ktextwidgets-5.82.0-x86_64-1.txz:  Upgraded.
kde/kunitconversion-5.82.0-x86_64-1.txz:  Upgraded.
kde/kwallet-5.82.0-x86_64-1.txz:  Upgraded.
kde/kwayland-5.82.0-x86_64-1.txz:  Upgraded.
kde/kwidgetsaddons-5.82.0-x86_64-1.txz:  Upgraded.
kde/kwindowsystem-5.82.0-x86_64-1.txz:  Upgraded.
kde/kxmlgui-5.82.0-x86_64-1.txz:  Upgraded.
kde/kxmlrpcclient-5.82.0-x86_64-1.txz:  Upgraded.
kde/modemmanager-qt-5.82.0-x86_64-1.txz:  Upgraded.
kde/networkmanager-qt-5.82.0-x86_64-1.txz:  Upgraded.
kde/oxygen-icons5-5.82.0-noarch-1.txz:  Upgraded.
kde/plasma-framework-5.82.0-x86_64-1.txz:  Upgraded.
kde/prison-5.82.0-x86_64-1.txz:  Upgraded.
kde/purpose-5.82.0-x86_64-1.txz:  Upgraded.
kde/qqc2-desktop-style-5.82.0-x86_64-1.txz:  Upgraded.
kde/solid-5.82.0-x86_64-1.txz:  Upgraded.
kde/sonnet-5.82.0-x86_64-1.txz:  Upgraded.
kde/syndication-5.82.0-x86_64-1.txz:  Upgraded.
kde/syntax-highlighting-5.82.0-x86_64-1.txz:  Upgraded.
kde/threadweaver-5.82.0-x86_64-1.txz:  Upgraded.
n°1464697
cycojesus
Mèo Lười
Posté le 11-05-2021 à 09:35:42  profilanswer
Mon May 10 18:24:16 UTC 2021
ap/mpg123-1.27.2-x86_64-1.txz:  Upgraded.
ap/qpdf-10.3.2-x86_64-1.txz:  Upgraded.
d/ccache-4.3-x86_64-1.txz:  Upgraded.
d/guile-3.0.7-x86_64-1.txz:  Upgraded.
d/python-setuptools-56.2.0-x86_64-1.txz:  Upgraded.
l/imagemagick-7.0.11_12-x86_64-1.txz:  Upgraded.
l/netpbm-10.94.03-x86_64-1.txz:  Upgraded.
n/rp-pppoe-3.15-x86_64-1.txz:  Upgraded.
xap/gnuchess-6.2.8-x86_64-1.txz:  Upgraded.
n°1464727
cycojesus
Mèo Lười
Posté le 12-05-2021 à 08:51:51  profilanswer
Tue May 11 19:35:17 UTC 2021
a/btrfs-progs-5.12-x86_64-1.txz:  Upgraded.
a/hdparm-9.62-x86_64-1.txz:  Upgraded.
a/kernel-generic-5.10.36-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.10.36-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.10.36-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.10.36-x86-1.txz:  Upgraded.
d/meson-0.58.0-x86_64-2.txz:  Rebuilt.
  Applied upstream fix for GNOME projects failing to build.
  Some projects still require an adjustment to implicit_include_directories.
k/kernel-source-5.10.36-noarch-1.txz:  Upgraded.
l/elfutils-0.184-x86_64-1.txz:  Upgraded.
l/glib2-2.68.2-x86_64-1.txz:  Upgraded.
n/libtirpc-1.3.2-x86_64-1.txz:  Upgraded.
n/snownews-1.8-x86_64-1.txz:  Upgraded.
n°1464753
cycojesus
Mèo Lười
Posté le 13-05-2021 à 10:20:32  profilanswer
Wed May 12 19:02:20 UTC 2021
a/kernel-firmware-20210512_55d9649-noarch-1.txz:  Upgraded.
a/sysklogd-2.2.3-x86_64-1.txz:  Upgraded.
ap/sudo-1.9.7-x86_64-1.txz:  Upgraded.
d/distcc-3.4-x86_64-1.txz:  Upgraded.
n/rpcbind-1.2.6-x86_64-1.txz:  Upgraded.
x/libXfixes-6.0.0-x86_64-1.txz:  Upgraded.
x/mesa-21.1.0-x86_64-1.txz:  Upgraded.
xfce/mousepad-0.5.5-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-generic-5.12.3-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-headers-5.12.3-x86-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-huge-5.12.3-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-modules-5.12.3-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-source-5.12.3-noarch-1.txz:  Upgraded.
n°1464773
cycojesus
Mèo Lười
Posté le 14-05-2021 à 10:12:24  profilanswer
la K-fée est passée [:zest-o:8]
Fri May 14 02:38:35 UTC 2021
ap/vim-8.2.2850-x86_64-1.txz:  Upgraded.
d/llvm-12.0.0-x86_64-1.txz:  Upgraded.
d/rust-1.52.1-x86_64-1.txz:  Upgraded.
kde/akonadi-21.04.1-x86_64-1.txz:  Upgraded.
kde/akonadi-calendar-21.04.1-x86_64-1.txz:  Upgraded.
kde/akonadi-calendar-tools-21.04.1-x86_64-1.txz:  Upgraded.
kde/akonadi-contacts-21.04.1-x86_64-1.txz:  Upgraded.
kde/akonadi-import-wizard-21.04.1-x86_64-1.txz:  Upgraded.
kde/akonadi-mime-21.04.1-x86_64-1.txz:  Upgraded.
kde/akonadi-notes-21.04.1-x86_64-1.txz:  Upgraded.
kde/akonadi-search-21.04.1-x86_64-1.txz:  Upgraded.
kde/akonadiconsole-21.04.1-x86_64-1.txz:  Upgraded.
kde/akregator-21.04.1-x86_64-1.txz:  Upgraded.
kde/analitza-21.04.1-x86_64-1.txz:  Upgraded.
kde/ark-21.04.1-x86_64-1.txz:  Upgraded.
kde/artikulate-21.04.1-x86_64-1.txz:  Upgraded.
kde/audiocd-kio-21.04.1-x86_64-1.txz:  Upgraded.
kde/baloo-widgets-21.04.1-x86_64-1.txz:  Upgraded.
kde/blinken-21.04.1-x86_64-1.txz:  Upgraded.
kde/bomber-21.04.1-x86_64-1.txz:  Upgraded.
kde/bovo-21.04.1-x86_64-1.txz:  Upgraded.
kde/calendarsupport-21.04.1-x86_64-1.txz:  Upgraded.
kde/cantor-21.04.1-x86_64-1.txz:  Upgraded.
kde/cervisia-21.04.1-x86_64-1.txz:  Upgraded.
kde/dolphin-21.04.1-x86_64-1.txz:  Upgraded.
kde/dolphin-plugins-21.04.1-x86_64-1.txz:  Upgraded.
kde/dragon-21.04.1-x86_64-1.txz:  Upgraded.
kde/elisa-21.04.1-x86_64-1.txz:  Upgraded.
kde/eventviews-21.04.1-x86_64-1.txz:  Upgraded.
kde/ffmpegthumbs-21.04.1-x86_64-1.txz:  Upgraded.
kde/filelight-21.04.1-x86_64-1.txz:  Upgraded.
kde/granatier-21.04.1-x86_64-1.txz:  Upgraded.
kde/grantlee-editor-21.04.1-x86_64-1.txz:  Upgraded.
kde/grantleetheme-21.04.1-x86_64-1.txz:  Upgraded.
kde/gwenview-21.04.1-x86_64-1.txz:  Upgraded.
kde/incidenceeditor-21.04.1-x86_64-1.txz:  Upgraded.
kde/itinerary-21.04.1-x86_64-1.txz:  Upgraded.
kde/juk-21.04.1-x86_64-1.txz:  Upgraded.
kde/k3b-21.04.1-x86_64-1.txz:  Upgraded.
kde/kaddressbook-21.04.1-x86_64-1.txz:  Upgraded.
kde/kalarm-21.04.1-x86_64-1.txz:  Upgraded.
kde/kalarmcal-21.04.1-x86_64-1.txz:  Upgraded.
kde/kalgebra-21.04.1-x86_64-1.txz:  Upgraded.
kde/kalzium-21.04.1-x86_64-1.txz:  Upgraded.
kde/kamera-21.04.1-x86_64-1.txz:  Upgraded.
kde/kamoso-21.04.1-x86_64-1.txz:  Upgraded.
kde/kanagram-21.04.1-x86_64-1.txz:  Upgraded.
kde/kapman-21.04.1-x86_64-1.txz:  Upgraded.
kde/kapptemplate-21.04.1-x86_64-1.txz:  Upgraded.
kde/kate-21.04.1-x86_64-1.txz:  Upgraded.
kde/katomic-21.04.1-x86_64-1.txz:  Upgraded.
kde/kbackup-21.04.1-x86_64-1.txz:  Upgraded.
kde/kblackbox-21.04.1-x86_64-1.txz:  Upgraded.
kde/kblocks-21.04.1-x86_64-1.txz:  Upgraded.
kde/kbounce-21.04.1-x86_64-1.txz:  Upgraded.
kde/kbreakout-21.04.1-x86_64-1.txz:  Upgraded.
kde/kbruch-21.04.1-x86_64-1.txz:  Upgraded.
kde/kcachegrind-21.04.1-x86_64-1.txz:  Upgraded.
kde/kcalc-21.04.1-x86_64-1.txz:  Upgraded.
kde/kcalutils-21.04.1-x86_64-1.txz:  Upgraded.
kde/kcharselect-21.04.1-x86_64-1.txz:  Upgraded.
kde/kcolorchooser-21.04.1-x86_64-1.txz:  Upgraded.
kde/kcron-21.04.1-x86_64-1.txz:  Upgraded.
kde/kde-dev-scripts-21.04.1-x86_64-1.txz:  Upgraded.
kde/kde-dev-utils-21.04.1-x86_64-1.txz:  Upgraded.
kde/kdebugsettings-21.04.1-x86_64-1.txz:  Upgraded.
kde/kdeconnect-kde-21.04.1-x86_64-1.txz:  Upgraded.
kde/kdeedu-data-21.04.1-x86_64-1.txz:  Upgraded.
kde/kdegraphics-mobipocket-21.04.1-x86_64-1.txz:  Upgraded.
kde/kdegraphics-thumbnailers-21.04.1-x86_64-1.txz:  Upgraded.
kde/kdenetwork-filesharing-21.04.1-x86_64-1.txz:  Upgraded.
kde/kdenlive-21.04.1-x86_64-1.txz:  Upgraded.
kde/kdepim-addons-21.04.1-x86_64-1.txz:  Upgraded.
kde/kdepim-runtime-21.04.1-x86_64-1.txz:  Upgraded.
kde/kdesdk-kioslaves-21.04.1-x86_64-1.txz:  Upgraded.
kde/kdesdk-thumbnailers-21.04.1-x86_64-1.txz:  Upgraded.
kde/kdevelop-5.6.2-x86_64-4.txz:  Rebuilt.
  Recompiled against llvm-12.0.0.
kde/kdf-21.04.1-x86_64-1.txz:  Upgraded.
kde/kdialog-21.04.1-x86_64-1.txz:  Upgraded.
kde/kdiamond-21.04.1-x86_64-1.txz:  Upgraded.
kde/keditbookmarks-21.04.1-x86_64-1.txz:  Upgraded.
kde/kfind-21.04.1-x86_64-1.txz:  Upgraded.
kde/kfloppy-21.04.1-x86_64-1.txz:  Upgraded.
kde/kfourinline-21.04.1-x86_64-1.txz:  Upgraded.
kde/kgeography-21.04.1-x86_64-1.txz:  Upgraded.
kde/kget-21.04.1-x86_64-1.txz:  Upgraded.
kde/kgoldrunner-21.04.1-x86_64-1.txz:  Upgraded.
kde/kgpg-21.04.1-x86_64-1.txz:  Upgraded.
kde/khangman-21.04.1-x86_64-1.txz:  Upgraded.
kde/khelpcenter-21.04.1-x86_64-1.txz:  Upgraded.
kde/kidentitymanagement-21.04.1-x86_64-1.txz:  Upgraded.
kde/kig-21.04.1-x86_64-1.txz:  Upgraded.
kde/kigo-21.04.1-x86_64-1.txz:  Upgraded.
kde/killbots-21.04.1-x86_64-1.txz:  Upgraded.
kde/kimagemapeditor-21.04.1-x86_64-1.txz:  Upgraded.
kde/kimap-21.04.1-x86_64-1.txz:  Upgraded.
kde/kio-extras-21.04.1-x86_64-1.txz:  Upgraded.
kde/kio-gdrive-21.04.1-x86_64-1.txz:  Upgraded.
kde/kipi-plugins-21.04.1-x86_64-1.txz:  Upgraded.
kde/kirigami-gallery-21.04.1-x86_64-1.txz:  Upgraded.
kde/kiriki-21.04.1-x86_64-1.txz:  Upgraded.
kde/kiten-21.04.1-x86_64-1.txz:  Upgraded.
kde/kitinerary-21.04.1-x86_64-1.txz:  Upgraded.
kde/kjumpingcube-21.04.1-x86_64-1.txz:  Upgraded.
kde/kldap-21.04.1-x86_64-1.txz:  Upgraded.
kde/kleopatra-21.04.1-x86_64-1.txz:  Upgraded.
kde/klickety-21.04.1-x86_64-1.txz:  Upgraded.
kde/klines-21.04.1-x86_64-1.txz:  Upgraded.
kde/kmag-21.04.1-x86_64-1.txz:  Upgraded.
kde/kmahjongg-21.04.1-x86_64-1.txz:  Upgraded.
kde/kmail-21.04.1-x86_64-1.txz:  Upgraded.
kde/kmail-account-wizard-21.04.1-x86_64-1.txz:  Upgraded.
kde/kmailtransport-21.04.1-x86_64-1.txz:  Upgraded.
kde/kmbox-21.04.1-x86_64-1.txz:  Upgraded.
kde/kmime-21.04.1-x86_64-1.txz:  Upgraded.
kde/kmines-21.04.1-x86_64-1.txz:  Upgraded.
kde/kmix-21.04.1-x86_64-1.txz:  Upgraded.
kde/kmousetool-21.04.1-x86_64-1.txz:  Upgraded.
kde/kmouth-21.04.1-x86_64-1.txz:  Upgraded.
kde/kmplot-21.04.1-x86_64-1.txz:  Upgraded.
kde/knavalbattle-21.04.1-x86_64-1.txz:  Upgraded.
kde/knetwalk-21.04.1-x86_64-1.txz:  Upgraded.
kde/knights-21.04.1-x86_64-1.txz:  Upgraded.
kde/knotes-21.04.1-x86_64-1.txz:  Upgraded.
kde/kolf-21.04.1-x86_64-1.txz:  Upgraded.
kde/kollision-21.04.1-x86_64-1.txz:  Upgraded.
kde/kolourpaint-21.04.1-x86_64-1.txz:  Upgraded.
kde/kompare-21.04.1-x86_64-1.txz:  Upgraded.
kde/konqueror-21.04.1-x86_64-1.txz:  Upgraded.
kde/konquest-21.04.1-x86_64-1.txz:  Upgraded.
kde/konsole-21.04.1-x86_64-1.txz:  Upgraded.
kde/kontact-21.04.1-x86_64-1.txz:  Upgraded.
kde/kontactinterface-21.04.1-x86_64-1.txz:  Upgraded.
kde/kontrast-21.04.1-x86_64-1.txz:  Upgraded.
kde/konversation-21.04.1-x86_64-1.txz:  Upgraded.
kde/kopeninghours-21.04.1-x86_64-1.txz:  Upgraded.
kde/kopete-21.04.1-x86_64-1.txz:  Upgraded.
kde/korganizer-21.04.1-x86_64-1.txz:  Upgraded.
kde/kosmindoormap-21.04.1-x86_64-1.txz:  Upgraded.
kde/kpat-21.04.1-x86_64-1.txz:  Upgraded.
kde/kpimtextedit-21.04.1-x86_64-1.txz:  Upgraded.
kde/kpkpass-21.04.1-x86_64-1.txz:  Upgraded.
kde/kpmcore-21.04.1-x86_64-1.txz:  Upgraded.
kde/kpublictransport-21.04.1-x86_64-1.txz:  Upgraded.
kde/kqtquickcharts-21.04.1-x86_64-1.txz:  Upgraded.
kde/krdc-21.04.1-x86_64-1.txz:  Upgraded.
kde/kreversi-21.04.1-x86_64-1.txz:  Upgraded.
kde/krfb-21.04.1-x86_64-1.txz:  Upgraded.
kde/kross-interpreters-21.04.1-x86_64-1.txz:  Upgraded.
kde/kruler-21.04.1-x86_64-1.txz:  Upgraded.
kde/kshisen-21.04.1-x86_64-1.txz:  Upgraded.
kde/ksirk-21.04.1-x86_64-1.txz:  Upgraded.
kde/ksmtp-21.04.1-x86_64-1.txz:  Upgraded.
kde/ksnakeduel-21.04.1-x86_64-1.txz:  Upgraded.
kde/kspaceduel-21.04.1-x86_64-1.txz:  Upgraded.
kde/ksquares-21.04.1-x86_64-1.txz:  Upgraded.
kde/ksudoku-21.04.1-x86_64-1.txz:  Upgraded.
kde/ksystemlog-21.04.1-x86_64-1.txz:  Upgraded.
kde/kteatime-21.04.1-x86_64-1.txz:  Upgraded.
kde/ktimer-21.04.1-x86_64-1.txz:  Upgraded.
kde/ktnef-21.04.1-x86_64-1.txz:  Upgraded.
kde/ktorrent-21.04.1-x86_64-1.txz:  Upgraded.
kde/ktouch-21.04.1-x86_64-1.txz:  Upgraded.
kde/kturtle-21.04.1-x86_64-1.txz:  Upgraded.
kde/kubrick-21.04.1-x86_64-1.txz:  Upgraded.
kde/kwalletmanager-21.04.1-x86_64-1.txz:  Upgraded.
kde/kwave-21.04.1-x86_64-1.txz:  Upgraded.
kde/kwordquiz-21.04.1-x86_64-1.txz:  Upgraded.
kde/libgravatar-21.04.1-x86_64-1.txz:  Upgraded.
kde/libkcddb-21.04.1-x86_64-1.txz:  Upgraded.
kde/libkcompactdisc-21.04.1-x86_64-1.txz:  Upgraded.
kde/libkdcraw-21.04.1-x86_64-1.txz:  Upgraded.
kde/libkdegames-21.04.1-x86_64-1.txz:  Upgraded.
kde/libkdepim-21.04.1-x86_64-1.txz:  Upgraded.
kde/libkeduvocdocument-21.04.1-x86_64-1.txz:  Upgraded.
kde/libkexiv2-21.04.1-x86_64-1.txz:  Upgraded.
kde/libkgapi-21.04.1-x86_64-1.txz:  Upgraded.
kde/libkipi-21.04.1-x86_64-1.txz:  Upgraded.
kde/libkleo-21.04.1-x86_64-1.txz:  Upgraded.
kde/libkmahjongg-21.04.1-x86_64-1.txz:  Upgraded.
kde/libkomparediff2-21.04.1-x86_64-1.txz:  Upgraded.
kde/libksane-21.04.1-x86_64-1.txz:  Upgraded.
kde/libksieve-21.04.1-x86_64-1.txz:  Upgraded.
kde/libktorrent-21.04.1-x86_64-1.txz:  Upgraded.
kde/lokalize-21.04.1-x86_64-1.txz:  Upgraded.
kde/lskat-21.04.1-x86_64-1.txz:  Upgraded.
kde/mailcommon-21.04.1-x86_64-1.txz:  Upgraded.
kde/mailimporter-21.04.1-x86_64-1.txz:  Upgraded.
kde/marble-21.04.1-x86_64-1.txz:  Upgraded.
kde/markdownpart-21.04.1-x86_64-1.txz:  Upgraded.
kde/mbox-importer-21.04.1-x86_64-1.txz:  Upgraded.
kde/messagelib-21.04.1-x86_64-1.txz:  Upgraded.
kde/minuet-21.04.1-x86_64-1.txz:  Upgraded.
kde/okular-21.04.1-x86_64-1.txz:  Upgraded.
kde/palapeli-21.04.1-x86_64-1.txz:  Upgraded.
kde/parley-21.04.1-x86_64-1.txz:  Upgraded.
kde/partitionmanager-21.04.1-x86_64-1.txz:  Upgraded.
kde/picmi-21.04.1-x86_64-1.txz:  Upgraded.
kde/pim-data-exporter-21.04.1-x86_64-1.txz:  Upgraded.
kde/pim-sieve-editor-21.04.1-x86_64-1.txz:  Upgraded.
kde/pimcommon-21.04.1-x86_64-1.txz:  Upgraded.
kde/poxml-21.04.1-x86_64-1.txz:  Upgraded.
kde/print-manager-21.04.1-x86_64-1.txz:  Upgraded.
kde/rocs-21.04.1-x86_64-1.txz:  Upgraded.
kde/spectacle-21.04.1-x86_64-1.txz:  Upgraded.
kde/step-21.04.1-x86_64-1.txz:  Upgraded.
kde/svgpart-21.04.1-x86_64-1.txz:  Upgraded.
kde/sweeper-21.04.1-x86_64-1.txz:  Upgraded.
kde/umbrello-21.04.1-x86_64-1.txz:  Upgraded.
kde/yakuake-21.04.1-x86_64-1.txz:  Upgraded.
kde/zeroconf-ioslave-21.04.1-x86_64-1.txz:  Upgraded.
l/libidn2-2.3.1-x86_64-1.txz:  Upgraded.
l/libtasn1-4.17.0-x86_64-1.txz:  Upgraded.
l/qt5-5.15.2-x86_64-9.txz:  Rebuilt.
x/egl-wayland-1.1.7-x86_64-1.txz:  Upgraded.
x/mesa-21.1.0-x86_64-2.txz:  Rebuilt.
xap/vim-gvim-8.2.2850-x86_64-1.txz:  Upgraded.
n°1464775
kisscoolz
Posté le 14-05-2021 à 10:55:59  profilanswer
Il fait quoi le stylo déjà ? Vas y appui une fois de plus pour voir !  [:kzimir]
n°1464790
cycojesus
Mèo Lười
Posté le 15-05-2021 à 09:58:23  profilanswer
Fri May 14 19:59:26 UTC 2021
a/btrfs-progs-5.12.1-x86_64-1.txz:  Upgraded.
a/kernel-generic-5.10.37-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.10.37-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.10.37-x86_64-1.txz:  Upgraded.
ap/lxc-2.0.11_fad08f383-x86_64-8.txz:  Rebuilt.
  Add some additional required packages, run ldconfig inside the rootfs,
  update the slackpkg.conf, and account for changed hostname handling.
  Thanks to PiterPunk.
d/kernel-headers-5.10.37-x86-1.txz:  Upgraded.
k/kernel-source-5.10.37-noarch-1.txz:  Upgraded.
n/getmail-6.16-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-generic-5.12.4-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-headers-5.12.4-x86-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-huge-5.12.4-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-modules-5.12.4-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-source-5.12.4-noarch-1.txz:  Upgraded.
n°1464804
cycojesus
Mèo Lười
Posté le 16-05-2021 à 02:11:34  profilanswer
Sat May 15 18:09:18 UTC 2021
l/libxml2-2.9.12-x86_64-1.txz:  Upgraded.
  This update fixes a denial-of-service security issue.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-3541
  (* Security fix *)
l/mozilla-nss-3.65-x86_64-1.txz:  Upgraded.
l/zstd-1.5.0-x86_64-1.txz:  Upgraded.
n/libqmi-1.28.4-x86_64-1.txz:  Upgraded.
xap/rxvt-unicode-9.26-x86_64-1.txz:  Upgraded.
n°1464825
cycojesus
Mèo Lười
Posté le 16-05-2021 à 21:32:29  profilanswer
Sun May 16 18:36:10 UTC 2021
a/dialog-1.3_20210509-x86_64-1.txz:  Upgraded.
l/libidn-1.37-x86_64-1.txz:  Upgraded.
l/netpbm-10.94.04-x86_64-1.txz:  Upgraded.
n°1464849
cycojesus
Mèo Lười
Posté le 18-05-2021 à 08:34:44  profilanswer
Mon May 17 19:12:54 UTC 2021
l/libusb-compat-0.1.7-x86_64-1.txz:  Upgraded.
xap/mozilla-thunderbird-78.10.2-x86_64-1.txz:  Upgraded.
    https://www.mozilla.org/en-US/thunderbird/78.10.2/releasenotes/
  (* Security fix *)
extra/fltk/fltk-1.3.6-x86_64-1.txz:  Upgraded.
n°1464925
cycojesus
Mèo Lười
Posté le 20-05-2021 à 11:45:20  profilanswer
des Knoyaux [:cerises de sadlig:2]
Wed May 19 21:05:00 UTC 2021
a/kernel-firmware-20210518_f846292-noarch-1.txz:  Upgraded.
a/kernel-generic-5.10.38-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.10.38-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.10.38-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.10.38-x86-1.txz:  Upgraded.
k/kernel-source-5.10.38-noarch-1.txz:  Upgraded.
l/imagemagick-7.0.11_13-x86_64-1.txz:  Upgraded.
l/pango-1.48.5-x86_64-1.txz:  Upgraded.
l/pipewire-0.3.28-x86_64-1.txz:  Upgraded.
  Config files are now installed in the data dir, system overrides
  in /etc/pipewire and $HOME are checked first.
x/libX11-1.7.1-x86_64-1.txz:  Upgraded.
  This update fixes missing request length checks in libX11 that can lead to
  the emission of extra X protocol requests to the X server.
    https://lists.x.org/archives/xorg-announce/2021-May/003088.html
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-31535
  (* Security fix *)
x/libdrm-2.4.106-x86_64-1.txz:  Upgraded.
xfce/xfce4-screenshooter-1.9.9-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-generic-5.12.5-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-headers-5.12.5-x86-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-huge-5.12.5-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-modules-5.12.5-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-source-5.12.5-noarch-1.txz:  Upgraded.
n°1464933
Col Hanzap​last
Jurassic geek. Vive le cobol !
Posté le 20-05-2021 à 14:47:53  profilanswer
Comment fait-on pour tester les kernels en 5.12.x ?
" Il n'y a aucune chance pour que l'iPhone s'attribue une part de marché significative. Aucune chance. " (Steve Ballmer 2007)
n°1464952
regdub
Posté le 21-05-2021 à 00:07:17  profilanswer
Dans /etc/slackpkg/slackpkg.conf, mettre/remplacer
Code :
  1. PRIORITY=( patches testing %PKGMAIN extra pasture )
Legalize it @HFR
n°1465014
cycojesus
Mèo Lười
Posté le 22-05-2021 à 09:48:15  profilanswer
Fri May 21 19:33:21 UTC 2021
a/exfatprogs-1.1.2-x86_64-1.txz:  Upgraded.
a/kmod-29-x86_64-1.txz:  Upgraded.
a/logrotate-3.18.1-x86_64-1.txz:  Upgraded.
a/pkgtools-15.0-noarch-41.txz:  Rebuilt.
  installpkg, upgradepkg: skip the install script when doing upgradepkg's
  pre-install. In cases where the script operations are expensive this can
  nearly double the speed of upgrading a package. Thanks to Stuart Winter.
ap/texinfo-6.7-x86_64-5.txz:  Rebuilt.
  Recompiled against perl-5.34.0.
ap/vim-8.2.2876-x86_64-1.txz:  Upgraded.
  Compiled against perl-5.34.0.
d/perl-5.34.0-x86_64-1.txz:  Upgraded.
d/sassc-3.6.2-x86_64-1.txz:  Upgraded.
d/subversion-1.14.1-x86_64-3.txz:  Rebuilt.
l/libsass-3.6.5-x86_64-1.txz:  Upgraded.
l/libsigc++3-3.0.7-x86_64-1.txz:  Upgraded.
n/bind-9.16.16-x86_64-1.txz:  Upgraded.
n/epic5-2.1.4-x86_64-2.txz:  Rebuilt.
n/irssi-1.2.3-x86_64-2.txz:  Rebuilt.
n/libndp-1.8-x86_64-1.txz:  Upgraded.
n/net-snmp-5.9-x86_64-6.txz:  Rebuilt.
n/ntp-4.2.8p15-x86_64-8.txz:  Rebuilt.
n/openldap-2.4.58-x86_64-2.txz:  Rebuilt.
x/mesa-21.1.1-x86_64-1.txz:  Upgraded.
xap/hexchat-2.14.3-x86_64-8.txz:  Rebuilt.
xap/rxvt-unicode-9.26-x86_64-2.txz:  Rebuilt.
xap/vim-gvim-8.2.2876-x86_64-1.txz:  Upgraded.
n°1465023
cycojesus
Mèo Lười
Posté le 22-05-2021 à 22:26:10  profilanswer
Sat May 22 19:25:09 UTC 2021
a/kernel-generic-5.10.39-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.10.39-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.10.39-x86_64-1.txz:  Upgraded.
ap/slackpkg-15.0.3-noarch-1.txz:  Upgraded.
   Fixed 'continue' error message. Thanks to dive.
d/kernel-headers-5.10.39-x86-1.txz:  Upgraded.
k/kernel-source-5.10.39-noarch-1.txz:  Upgraded.
l/libsigc++-2.10.7-x86_64-1.txz:  Upgraded.
x/libepoxy-1.5.8-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-generic-5.12.6-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-headers-5.12.6-x86-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-huge-5.12.6-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-modules-5.12.6-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-source-5.12.6-noarch-1.txz:  Upgraded.
n°1465048
cycojesus
Mèo Lười
Posté le 24-05-2021 à 10:20:58  profilanswer
Sun May 23 19:31:03 UTC 2021
a/mcelog-176-x86_64-2.txz:  Rebuilt.
  Fixed size syntax in logrotate config file. Thanks to ecd102.
d/parallel-20210522-noarch-1.txz:  Upgraded.
d/python-pip-21.1.2-x86_64-1.txz:  Upgraded.
d/python-setuptools-57.0.0-x86_64-1.txz:  Upgraded.
l/elfutils-0.185-x86_64-1.txz:  Upgraded.
l/expat-2.4.1-x86_64-1.txz:  Upgraded.
  This update provides new mitigations against the "billion laughs" denial
  of service attack.
    https://github.com/libexpat/libexpat/blob/R_2_4_1/expat/Changes
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-0340
  (* Security fix *)
l/imagemagick-7.0.11_13-x86_64-2.txz:  Rebuilt.
n/httpd-2.4.46-x86_64-4.txz:  Rebuilt.
n°1465107
cycojesus
Mèo Lười
Posté le 26-05-2021 à 09:09:37  profilanswer
Tue May 25 18:01:05 UTC 2021
a/xfsprogs-5.12.0-x86_64-1.txz:  Upgraded.
l/libcap-2.50-x86_64-1.txz:  Upgraded.
l/libqalculate-3.19.0-x86_64-1.txz:  Upgraded.
n/gnutls-3.6.16-x86_64-1.txz:  Upgraded.
  Fixed potential miscalculation of ECDSA/EdDSA code backported from Nettle.
  In GnuTLS, as long as it is built and linked against the fixed version of
  Nettle, this only affects GOST curves.  [CVE-2021-20305]
  Fixed potential use-after-free in sending "key_share" and "pre_shared_key"
  extensions. When sending those extensions, the client may dereference a
  pointer no longer valid after realloc. This happens only when the client
  sends a large Client Hello message, e.g., when HRR is sent in a resumed
  session previously negotiated large FFDHE parameters, because the initial
  allocation of the buffer is large enough without having to call realloc
  (#1151).  [GNUTLS-SA-2021-03-10, CVSS: low]
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-20305
  (* Security fix *)
n/libnftnl-1.2.0-x86_64-1.txz:  Upgraded.
n/links-2.23-x86_64-1.txz:  Upgraded.
n°1465147
cycojesus
Mèo Lười
Posté le 27-05-2021 à 09:33:17  profilanswer
Wed May 26 20:00:32 UTC 2021
a/kernel-generic-5.10.40-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.10.40-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.10.40-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.10.40-x86-1.txz:  Upgraded.
k/kernel-source-5.10.40-noarch-1.txz:  Upgraded.
l/librsvg-2.50.6-x86_64-1.txz:  Upgraded.
l/python-urllib3-1.26.5-x86_64-1.txz:  Upgraded.
n/ca-certificates-20210526-noarch-1.txz:  Upgraded.
  This update provides the latest CA certificates to check for the
  authenticity of SSL connections.
n/curl-7.77.0-x86_64-1.txz:  Upgraded.
  This update fixes security issues:
  schannel cipher selection surprise
  TELNET stack contents disclosure
  TLS session caching disaster
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-22297
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-22298
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-22901
  (* Security fix *)
n/net-snmp-5.9.1-x86_64-1.txz:  Upgraded.
n/nftables-0.9.9-x86_64-1.txz:  Upgraded.
x/libinput-1.17.3-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-generic-5.12.7-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-headers-5.12.7-x86-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-huge-5.12.7-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-modules-5.12.7-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-source-5.12.7-noarch-1.txz:  Upgraded.
n°1465173
cycojesus
Mèo Lười
Posté le 27-05-2021 à 22:55:14  profilanswer
Thu May 27 18:50:50 UTC 2021
a/aaa_libraries-15.0-x86_64-7.txz:  Rebuilt.
  Upgraded: libcap.so.2.50, libelf-0.185.so, libzstd.so.1.5.0,
  libexpat.so.1.8.1, libglib-2.0.so.0.6800.2, libgmodule-2.0.so.0.6800.2,
  libgobject-2.0.so.0.6800.2, libgthread-2.0.so.0.6800.2, libidn.so.12.6.2,
  libisl.so.23.1.0, libpcre2-8.so.0.10.2, libtiff.so.5.7.0, libtiffxx.so.5.7.0.
ap/mariadb-10.5.10-x86_64-2.txz:  Rebuilt.
  Recompiled against pcre2-10.37.
ap/vim-8.2.2891-x86_64-1.txz:  Upgraded.
l/netpbm-10.94.05-x86_64-1.txz:  Upgraded.
l/pcre2-10.37-x86_64-1.txz:  Upgraded.
xap/vim-gvim-8.2.2891-x86_64-1.txz:  Upgraded.
n°1465190
cycojesus
Mèo Lười
Posté le 29-05-2021 à 09:52:38  profilanswer
Fri May 28 19:26:15 UTC 2021
a/cryptsetup-2.3.6-x86_64-1.txz:  Upgraded.
a/kernel-generic-5.10.41-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.10.41-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.10.41-x86_64-1.txz:  Upgraded.
d/cmake-3.20.3-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.10.41-x86-1.txz:  Upgraded.
k/kernel-source-5.10.41-noarch-1.txz:  Upgraded.
l/mozilla-nss-3.66-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-generic-5.12.8-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-headers-5.12.8-x86-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-huge-5.12.8-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-modules-5.12.8-x86_64-1.txz:  Upgraded.
testing/packages/linux-5.12.x/kernel-source-5.12.8-noarch-1.txz:  Upgraded.
n°1465206
cycojesus
Mèo Lười
Posté le 30-05-2021 à 11:44:03  profilanswer
Sat May 29 17:36:51 UTC 2021
n/dhcp-4.4.2_P1-x86_64-1.txz:  Upgraded.
  This update fixes a security issue:
  Corrected a buffer overwrite possible when parsing hexadecimal
  literals with more than 1024 octets. Reported by Jon Franklin from Dell,
  and also by Pawel Wieczorkiewicz from Amazon Web Services. [Gitlab #182]
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-25217
  (* Security fix *)
n°1465315
cycojesus
Mèo Lười
Posté le 02-06-2021 à 12:24:34  profilanswer
Tue Jun  1 18:41:29 UTC 2021
l/gsl-2.7-x86_64-1.txz:  Upgraded.
l/mozjs78-78.11.0esr-x86_64-1.txz:  Upgraded.
n/samba-4.14.5-x86_64-1.txz:  Upgraded.
Mon May 31 23:21:18 UTC 2021
ap/alsa-utils-1.2.5-x86_64-1.txz:  Upgraded.
ap/ispell-3.4.03-x86_64-1.txz:  Upgraded.
d/m4-1.4.19-x86_64-1.txz:  Upgraded.
l/alsa-lib-1.2.5-x86_64-1.txz:  Upgraded.
l/alsa-plugins-1.2.5-x86_64-1.txz:  Upgraded.
l/imagemagick-7.0.11_14-x86_64-1.txz:  Upgraded.
l/libedit-20210522_3.1-x86_64-1.txz:  Upgraded.
l/python-certifi-2021.5.30-x86_64-1.txz:  Upgraded.
xap/mozilla-firefox-89.0-x86_64-1.txz:  Upgraded.
  This is a bugfix release.
    https://www.mozilla.org/en-US/firefox/89.0/releasenotes/
n°1465505
cycojesus
Mèo Lười
Posté le 07-06-2021 à 23:17:32  profilanswer
Surpris par... la nuit !
Mon Jun  7 18:53:49 UTC 2021
Hey folks! Sorry about the delay in getting this batch out but I had other
distractions going on here last week that prevented getting this one wrapped
up. Anyway, probably the highlight of this update set is that we've decided
to abandon the 5.10 LTS kernel in favor of following the latest one. We've
never really had a policy that required LTS in a stable release although that
is how it has been done for years, but based on comments from the Slackware
community it seems like 5.10 LTS isn't getting a lot of love and lacks
hardware support that people need now. Conversely, the reports on 5.12 have
been almost entirely positive, so we're going to provide what we think is the
best available kernel. It's unlikely that we'll see another LTS prior to
release, so the plan for maintenance is to keep following the latest kernels
as needed for security purposes. If that means we have to jump to a new branch
while supporting the stable release, we'll start the kernel out in testing
first until we've had some feedback that it's safe to move it to the patches
directory. Sooner or later we will end up on an LTS kernel again, and at that
point we'll just roll with that one. Feel free to comment (or complain) about
this plan on LQ... I'll be curious to see what people think. Anyway, enjoy!
a/hwdata-0.348-noarch-1.txz:  Upgraded.
a/kernel-generic-5.12.9-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.12.9-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.12.9-x86_64-1.txz:  Upgraded.
ap/ispell-3.4.04-x86_64-1.txz:  Upgraded.
ap/mpg123-1.28.0-x86_64-1.txz:  Upgraded.
ap/slackpkg-15.0.5-noarch-1.txz:  Upgraded.
  Add "--" option to "command cd" in bash completion file. (akinomyoga)
  shell-completions/slackpkg.bash: add "show-changelog".
  Import bash-completion file from upstream project.
  Added the new-config actions for specific files. (Piter PUNK)
  Harden slackpkg with respect to obtaining GPG key. (CRTS)
d/clisp-2.50_20191103_c26de7873-x86_64-5.txz:  Rebuilt.
  Upgraded to libffcall-2.3.
d/git-2.32.0-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.12.9-x86-1.txz:  Upgraded.
d/poke-1.3-x86_64-1.txz:  Upgraded.
d/vala-0.52.4-x86_64-1.txz:  Upgraded.
k/kernel-source-5.12.9-noarch-1.txz:  Upgraded.
kde/calligra-3.2.1-x86_64-9.txz:  Rebuilt.
  Recompiled against poppler-21.06.1.
kde/cantor-21.04.1-x86_64-2.txz:  Rebuilt.
kde/digikam-7.2.0-x86_64-3.txz:  Rebuilt.
  Recompiled against imagemagick-7.0.11_14.
kde/kfilemetadata-5.82.0-x86_64-2.txz:  Rebuilt.
kde/kile-2.9.93-x86_64-9.txz:  Rebuilt.
kde/kitinerary-21.04.1-x86_64-2.txz:  Rebuilt.
kde/krita-4.4.3-x86_64-5.txz:  Rebuilt.
kde/okular-21.04.1-x86_64-2.txz:  Rebuilt.
l/alsa-lib-1.2.5-x86_64-2.txz:  Rebuilt.
  Account for unexpected packing of the conf file tarballs. We'll see if this
  is enough to make things work well again.
l/at-spi2-core-2.40.2-x86_64-1.txz:  Upgraded.
l/dvdauthor-0.7.2-x86_64-5.txz:  Rebuilt.
l/libogg-1.3.5-x86_64-1.txz:  Upgraded.
l/librsvg-2.50.7-x86_64-1.txz:  Upgraded.
l/pipewire-0.3.29-x86_64-1.txz:  Upgraded.
l/polkit-0.119-x86_64-1.txz:  Upgraded.
  This update includes a mitigation for local privilege escalation using
  polkit_system_bus_name_get_creds_sync().
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-3560
  (* Security fix *)
l/poppler-21.06.1-x86_64-1.txz:  Upgraded.
l/pycairo-1.20.1-x86_64-1.txz:  Upgraded.
l/qca-2.3.3-x86_64-1.txz:  Upgraded.
l/vte-0.64.2-x86_64-1.txz:  Upgraded.
n/epic5-2.1.5-x86_64-1.txz:  Upgraded.
n/httpd-2.4.48-x86_64-1.txz:  Upgraded.
  mod_http2: Fix a potential NULL pointer dereference.
  Unexpected <Location> section matching with 'MergeSlashes OFF'.
  mod_auth_digest: possible stack overflow by one nul byte while validating
  the Digest nonce.
  mod_session: Fix possible crash due to NULL pointer dereference, which
  could be used to cause a Denial of Service with a malicious backend
  server and SessionHeader.
  could be used to cause a Denial of Service.
  mod_proxy_http: Fix possible crash due to NULL pointer dereference, which
  mod_proxy_wstunnel, mod_proxy_http: Handle Upgradable protocols end-to-end
  negotiation.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-31618
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-30641
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-35452
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-26691
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-26690
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-13950
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-17567
  (* Security fix *)
n/libmbim-1.24.8-x86_64-1.txz:  Upgraded.
n/libqmi-1.28.6-x86_64-1.txz:  Upgraded.
n/nettle-3.7.3-x86_64-1.txz:  Upgraded.
n/openldap-2.4.59-x86_64-1.txz:  Upgraded.
n/p11-kit-0.24.0-x86_64-1.txz:  Upgraded.
n/php-7.4.20-x86_64-1.txz:  Upgraded.
n/vsftpd-3.0.4-x86_64-1.txz:  Upgraded.
n/whois-5.5.10-x86_64-1.txz:  Upgraded.
x/libX11-1.7.2-x86_64-1.txz:  Upgraded.
  This is a bug fix release, correcting a regression introduced by and
  improving the checks from the fix for CVE-2021-31535.
x/libinput-1.18.0-x86_64-1.txz:  Upgraded.
x/mesa-21.1.2-x86_64-1.txz:  Upgraded.
xap/blueman-2.2.1-x86_64-1.txz:  Upgraded.
xap/gnuplot-5.4.2-x86_64-1.txz:  Upgraded.
xap/mozilla-thunderbird-78.11.0-x86_64-1.txz:  Upgraded.
    https://www.mozilla.org/en-US/thunderbird/78.11.0/releasenotes/
    https://www.mozilla.org/en-US/security/advisories/mfsa2021-26/
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-29964
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-29967
  (* Security fix *)
xap/pidgin-2.14.5-x86_64-1.txz:  Upgraded.
xap/xine-lib-1.2.11-x86_64-6.txz:  Rebuilt.
extra/bash-completion/bash-completion-2.11-noarch-2.txz:  Rebuilt.
  Removed the slackpkg completion file.
extra/php8/php8-8.0.7-x86_64-1.txz:  Upgraded.
Slackware 9.0[slackware] Suppression de terminaux virtuels ?
!! Configuration reseaux, slackware 9 !!Installer slackware 9.0 par ftp (boot disquette)
[Pb] Installation new HDD sous slackware 8.0[RESOLU] Pb d'execution mysql sur slackware ...
Slackware 9 du pur bonheurMonter une partition NTFS sous linux (slackware 9.0)
Slackware 9.0 Finale OUTJe sens que je vais quitter Slackware (pas en serv)
Plus de sujets relatifs à : [SLACKWARE] du présent - 15.0
