5293 connectés
  Linux et OS Alternatifs
  Installation
  Récuperation raid5 sous OMV
n°1460386
Lutinnoir
Seul parmi les autres
Posté le 04-02-2021 à 19:46:00  profilanswer
Suite a une carte mère HS, j'essai de récupérer un raid5 fait sous OMV sur un autre "pc" (NAS avec OMV).
Mais ne connaissant pas grand chose sur le sujet, je galère.
root@yggdrasil:~# cat /proc/mdstat
Personalities : [linear] [multipath] [raid0] [raid1] [raid6] [raid5] [raid4] [raid10]
md127 : inactive sdb[3](S) sde[1](S) sda[4](S) sdf[0](S) sdc[5](S) sdd[2](S)
      58597828608 blocks super 1.2
unused devices: <none>
root@yggdrasil:~# fdisk -l
Disk /dev/sda: 9,1 TiB, 10000831348736 bytes, 19532873728 sectors
Disk model: WDC WD100EZAZ-11
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk /dev/sdf: 9,1 TiB, 10000831348736 bytes, 19532873728 sectors
Disk model: WDC WD101EMAZ-11
Disk /dev/sdc: 9,1 TiB, 10000831348736 bytes, 19532873728 sectors
Disk /dev/sde: 9,1 TiB, 10000831348736 bytes, 19532873728 sectors
Disk /dev/sdb: 9,1 TiB, 10000831348736 bytes, 19532873728 sectors
Disk model: WDC WD100EFAX-68
Disk /dev/sdd: 9,1 TiB, 10000831348736 bytes, 19532873728 sectors
Disk /dev/sdg: 55,9 GiB, 60022480896 bytes, 117231408 sectors
Disk model: OCZ-AGILITY3
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x5e370459
Device     Boot    Start       End  Sectors  Size Id Type
/dev/sdg1  *        2048  83898367 83896320   40G 83 Linux
/dev/sdg2       83900414 117229567 33329154 15,9G  5 Extended
/dev/sdg5       83900416 117229567 33329152 15,9G 82 Linux swap / Solaris
root@yggdrasil:~# lsblk -o size,name,fstype,label,mountpoint
 SIZE NAME   FSTYPE            LABEL                   MOUNTPOINT
 9,1T sda    linux_raid_member Midgard.hwas.local:Data
 9,1T sdb    linux_raid_member Midgard.hwas.local:Data
 9,1T sdc    linux_raid_member Midgard.hwas.local:Data
 9,1T sdd    linux_raid_member Midgard.hwas.local:Data
 9,1T sde    linux_raid_member Midgard.hwas.local:Data
55,9G sdf
  40G ├─sdf1 ext4                                      /
   1K ├─sdf2
15,9G └─sdf5 swap                                      [SWAP]
 9,1T sdg    linux_raid_member Midgard.hwas.local:Data
Message édité par Lutinnoir le 05-02-2021 à 08:52:20
"If in doubt, flat out." @Colin McRae
n°1460454
jean pierr​e
Posté le 06-02-2021 à 17:29:48  profilanswer
bonjour,
je ne peut pas aider pour le raid, quelqu'il soit. Par contre ci dessous un liens sur un topic unic sur les raid.
https://forum.hardware.fr/hfr/Hardw [...] 2109_1.htm
En esperant que tu puisse recuperer les données
Jean Pierre
n°1460459
Lutinnoir
Posté le 06-02-2021 à 19:45:12  profilanswer
Merci beaucoup pour l'info.  [:bobox360:1]
n°1460539
slywalker
Posté le 09-02-2021 à 09:59:08  profilanswer
que te renvoie la commande suivante ?
mdadm --detail /dev/md127
n°1460548
Lutinnoir
Posté le 09-02-2021 à 11:06:55  profilanswer
slywalker a écrit :
J'ai rajouter un disque entre temps, la config a un peu bouger dans les lettres des DD.
root@yggdrasil:~# mdadm --detail /dev/md127
/dev/md127:
           Version : 1.2
        Raid Level : raid0
     Total Devices : 6
       Persistence : Superblock is persistent
             State : inactive
   Working Devices : 6
              UUID : 98b60dc4:2a022def:1368890c:1d136264
            Events : 15862
    Number   Major   Minor   RaidDevice
       -       8       64        -        /dev/sde
       -       8       32        -        /dev/sdc
       -       8       80        -        /dev/sdf
       -       8       48        -        /dev/sdd
       -       8       16        -        /dev/sdb
       -       8       96        -        /dev/sdg
Message édité par Lutinnoir le 09-02-2021 à 11:17:46
n°1460551
slywalker
Posté le 09-02-2021 à 11:15:38  profilanswer
T'aimes le risque toi  :D
Le résultat suivant stp ?
mdadm --examine --scan
n°1460554
Lutinnoir
Posté le 09-02-2021 à 11:18:56  profilanswer
Pour le risque pas tellement.
root@yggdrasil:~# mdadm --examine --scan
ARRAY /dev/md/Data  metadata=1.2 UUID=98b60dc4:2a022def:1368890c:1d136264 name=Midgard.hwas.local:Data
n°1460556
slywalker
Posté le 09-02-2021 à 11:29:49  profilanswer
Ce qui m'ennuie un peu, c'est ça :
/dev/md127:
           Version : 1.2
        Raid Level : raid0
     Total Devices : 6
             State : inactive
   Working Devices : 6
            Events : 15862
       -       8       64        -        /dev/sde
       -       8       32        -        /dev/sdc
       -       8       80        -        /dev/sdf
       -       8       48        -        /dev/sdd
       -       8       16        -        /dev/sdb
       -       8       96        -        /dev/sdg
Je vais poser la question qui tue : au cas où, tu as une sauvegarde de tes données ?
n°1460558
slywalker
Posté le 09-02-2021 à 11:33:26  profilanswer
Comme on est jamais trop prudent, une petite vérif. complémentaire
mdadm --examine /dev/sdb
mdadm --examine /dev/sdc
mdadm --examine /dev/sdd
mdadm --examine /dev/sde
mdadm --examine /dev/sdf
mdadm --examine /dev/sdg
n°1460559
Lutinnoir
Posté le 09-02-2021 à 11:33:44  profilanswer
Oui, j'ai une sauvegarde des fichiers les plus importants.
Je ne comprend pas non plus le raid0. Le raid provient d'un Openmediavault virtualisé sous Proxmox (Passthrough PCI RAID)  :whistle:
root@yggdrasil:~# mdadm --examine /dev/sdb
/dev/sdb:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x1
     Array UUID : 98b60dc4:2a022def:1368890c:1d136264
  Creation Time : Mon Sep 14 11:07:04 2020
     Raid Level : raid5
   Raid Devices : 6
 Avail Dev Size : 19532609536 (9313.87 GiB 10000.70 GB)
     Array Size : 48831523840 (46569.37 GiB 50003.48 GB)
    Data Offset : 264192 sectors
   Super Offset : 8 sectors
   Unused Space : before=264112 sectors, after=0 sectors
          State : clean
    Device UUID : f412e5ae:a126366b:db8ca0d4:44e240e8
Internal Bitmap : 8 sectors from superblock
    Update Time : Thu Feb  4 17:12:58 2021
  Bad Block Log : 512 entries available at offset 48 sectors
       Checksum : 2d8d564d - correct
         Events : 15866
         Layout : left-symmetric
     Chunk Size : 512K
   Device Role : Active device 4
   Array State : .AAAAA ('A' == active, '.' == missing, 'R' == replacing)
root@yggdrasil:~# mdadm --examine /dev/sdc
/dev/sdc:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x1
     Raid Level : raid5
   Raid Devices : 6
          State : clean
    Device UUID : 92519c3b:346aa675:32fb9444:ee603035
       Checksum : 8198c57c - correct
         Events : 15866
     Chunk Size : 512K
   Device Role : Active device 3
root@yggdrasil:~# mdadm --examine /dev/sdd
/dev/sdd:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x1
     Raid Level : raid5
   Raid Devices : 6
          State : clean
    Device UUID : c40f9713:6d6f9a4b:b5cfd38c:d1353221
       Checksum : 63c8324f - correct
         Events : 15866
     Chunk Size : 512K
   Device Role : Active device 5
root@yggdrasil:~# mdadm --examine /dev/sde
/dev/sde:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x1
     Raid Level : raid5
   Raid Devices : 6
          State : clean
    Device UUID : bfc96811:7cf45faf:7020b2d7:74953af5
    Update Time : Thu Feb  4 17:12:27 2021
       Checksum : e4462192 - correct
         Events : 15862
     Chunk Size : 512K
   Device Role : Active device 2
root@yggdrasil:~# mdadm --examine /dev/sdf
/dev/sdf:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x1
     Raid Level : raid5
   Raid Devices : 6
          State : clean
    Device UUID : 10ad5791:3e873feb:a5b99e7d:0864c245
       Checksum : 9688ff6d - correct
         Events : 15862
     Chunk Size : 512K
   Device Role : Active device 1
root@yggdrasil:~# mdadm --examine /dev/sdg
/dev/sdg:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x1
     Raid Level : raid5
   Raid Devices : 6
          State : clean
    Device UUID : a2ce501c:0a8f0e64:511084e7:b4b18723
    Update Time : Thu Feb  4 14:52:51 2021
       Checksum : e1faac67 - correct
         Events : 15859
     Chunk Size : 512K
   Device Role : Active device 0
   Array State : AAAAAA ('A' == active, '.' == missing, 'R' == replacing)
Message édité par Lutinnoir le 09-02-2021 à 11:34:23
n°1460560
slywalker
Posté le 09-02-2021 à 11:36:14  profilanswer
Ce que je vois me plait plus déjà  :)
Du coup on y va soft, et on va tenter :
mdadm --assemble --scan
Suivi d'un :
cat /proc/mdstat
Message édité par slywalker le 09-02-2021 à 11:36:48
n°1460561
Lutinnoir
Posté le 09-02-2021 à 11:38:03  profilanswer
Si je comprend bien, tous les disques sont en "spare"
root@yggdrasil:~# mdadm --assemble --scan
md127 : inactive sdd[5](S) sdc[3](S) sdb[4](S) sdg[0](S) sde[2](S) sdf[1](S)
n°1460562
slywalker
Posté le 09-02-2021 à 11:42:26  profilanswer
Yep, c'est bien ça.
Du coup on y va un peu plus bourrin :
mdadm -assemble /dev/md127 /dev/sd[bcdefg]
suivi de :
cat /proc/mdstat
n°1460563
Lutinnoir
Posté le 09-02-2021 à 11:43:46  profilanswer
root@yggdrasil:~# mdadm -assemble /dev/md127 /dev/sd[bcdefg]
mdadm: option -s not valid in manage mode
Edit je viens de comprend la commande  [:haha fail]
root@yggdrasil:~# mdadm -assemble /dev/md127 /dev/sdb /dev/sdc /dev/sdd /dev/sde /dev/sdf /dev/sdg
Message édité par Lutinnoir le 09-02-2021 à 11:45:52
n°1460564
slywalker
Posté le 09-02-2021 à 11:46:16  profilanswer
My bad, j'ai oublié un tiret  :sweat:
mdadm --assemble /dev/md127 /dev/sd[bcdefg]
n°1460565
Lutinnoir
Posté le 09-02-2021 à 11:47:23  profilanswer
root@yggdrasil:~# mdadm --assemble /dev/md127 /dev/sd[bcdefg]
mdadm: /dev/sdb is busy - skipping
mdadm: /dev/sdc is busy - skipping
mdadm: /dev/sdd is busy - skipping
mdadm: /dev/sde is busy - skipping
mdadm: /dev/sdf is busy - skipping
mdadm: /dev/sdg is busy - skipping
n°1460566
slywalker
Posté le 09-02-2021 à 11:49:26  profilanswer
Rahhh ! Vilain RAID !
mdadm --stop /dev/md127
n°1460567
Lutinnoir
Posté le 09-02-2021 à 11:50:46  profilanswer
root@yggdrasil:~# mdadm --stop /dev/md127
mdadm: stopped /dev/md127
mdadm: /dev/md127 assembled from 3 drives - not enough to start the array.
Pour lui il trouve que 3 disques sur 6?
Message édité par Lutinnoir le 09-02-2021 à 13:42:50
n°1460568
slywalker
Posté le 09-02-2021 à 11:51:09  profilanswer
Sinon t'es très porté sur la mythologie nordique non ?  :D
n°1460569
slywalker
Posté le 09-02-2021 à 11:52:07  profilanswer
Bon, y a une coui*** dans le potage là :-/
cat /proc/mdstat
n°1460570
Lutinnoir
Posté le 09-02-2021 à 11:52:46  profilanswer
Plus facile pour me souvenir, de tous les équipements.  [:yems93]
md127 : inactive sdg[0](S) sdc[3](S) sde[2](S) sdd[5](S) sdf[1](S)
      48831523840 blocks super 1.2
Message édité par Lutinnoir le 09-02-2021 à 13:36:10
n°1460571
slywalker
Posté le 09-02-2021 à 11:54:51  profilanswer
on repart pour un tour ! (je retire le disque sdb pour le moment)
mdadm --assemble /dev/md127 /dev/sd[cdefg]
n°1460572
Lutinnoir
Posté le 09-02-2021 à 11:55:53  profilanswer
root@yggdrasil:~# mdadm --assemble /dev/md127 /dev/sd[cdefg]
mdadm: /dev/md127 assembled from 2 drives - not enough to start the array.
n°1460573
slywalker
Posté le 09-02-2021 à 11:58:37  profilanswer
c'est moche cette histoire.
Tu peux me trouver les logs mdadm des dernières minutes stp ?
PS : je vais devoir m'absenter d'ici 10 minutes, je pourrai reprendre l'aide dans l'après-midi
n°1460574
Lutinnoir
Posté le 09-02-2021 à 12:00:25  profilanswer
Ok ça marche, merci.
Feb  9 11:06:36 yggdrasil kernel: [  113.639804] rc rc0: two consecutive events of type pulse
Feb  9 11:09:01 yggdrasil CRON[6994]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Feb  9 11:09:07 yggdrasil systemd[1]: Starting Clean php session files...
Feb  9 11:09:07 yggdrasil systemd[1]: phpsessionclean.service: Succeeded.
Feb  9 11:09:07 yggdrasil systemd[1]: Started Clean php session files.
Feb  9 11:09:47 yggdrasil anacron[727]: Job `cron.daily' started
Feb  9 11:09:47 yggdrasil anacron[7061]: Updated timestamp for job `cron.daily' to 2021-02-09
Feb  9 11:15:01 yggdrasil CRON[7225]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Feb  9 11:17:01 yggdrasil CRON[7460]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Feb  9 11:17:01 yggdrasil postfix/postsuper[7463]: fatal: scan_dir_push: open directory hold: No such file or directory
Feb  9 11:17:02 yggdrasil cron[901]: postdrop: warning: unable to look up public/pickup: No such file or directory
Feb  9 11:17:02 yggdrasil postfix/postdrop[7465]: warning: unable to look up public/pickup: No such file or directory
Feb  9 11:19:47 yggdrasil systemd[1]: Starting Cleanup of Temporary Directories...
Feb  9 11:19:47 yggdrasil systemd-tmpfiles[7494]: [/usr/lib/tmpfiles.d/fail2ban-tmpfiles.conf:1] Line references path below legacy directory /var/run/, updating /var/run/fail2ban → /run/fail2ban; please update the tmpfiles.d/ drop-in file accordingly.
Feb  9 11:19:47 yggdrasil systemd[1]: systemd-tmpfiles-clean.service: Succeeded.
Feb  9 11:19:47 yggdrasil systemd[1]: Started Cleanup of Temporary Directories.
Feb  9 11:25:01 yggdrasil CRON[7592]: (pcp) CMD ( /usr/lib/pcp/bin/pmlogger_check -C)
Feb  9 11:27:14 yggdrasil dbus-daemon[708]: [system] Activating via systemd: service name='org.freedesktop.PackageKit' unit='packagekit.service' requested by ':1.14' (uid=0 pid=8953 comm="/usr/bin/gdbus call --system --dest org.freedeskto" )
Feb  9 11:27:14 yggdrasil systemd[1]: Starting PackageKit Daemon...
Feb  9 11:27:14 yggdrasil PackageKit: daemon start
Feb  9 11:27:14 yggdrasil dbus-daemon[708]: [system] Successfully activated service 'org.freedesktop.PackageKit'
Feb  9 11:27:14 yggdrasil systemd[1]: Started PackageKit Daemon.
Feb  9 11:27:17 yggdrasil cron-apt: CRON-APT RUN [/etc/cron-apt/config]: Tue Feb  9 11:09:47 CET 2021
Feb  9 11:27:17 yggdrasil cron-apt: CRON-APT SLEEP: 1045, Tue Feb  9 11:27:12 CET 2021
Feb  9 11:27:17 yggdrasil cron-apt: CRON-APT ACTION: 0-update
Feb  9 11:27:17 yggdrasil cron-apt: CRON-APT LINE: /usr/bin/apt-get  update -o quiet=2
Feb  9 11:27:18 yggdrasil cron-apt: CRON-APT ACTION: 3-download
Feb  9 11:27:18 yggdrasil cron-apt: CRON-APT LINE: /usr/bin/apt-get  autoclean -y
Feb  9 11:27:18 yggdrasil cron-apt: Reading package lists...
Feb  9 11:27:18 yggdrasil cron-apt: Building dependency tree...
Feb  9 11:27:18 yggdrasil cron-apt: Reading state information...
Feb  9 11:27:18 yggdrasil cron-apt: Del cockpit-packagekit 235-1~bpo10+1 [520 kB]
Feb  9 11:27:18 yggdrasil cron-apt: Del cockpit 235-1~bpo10+1 [30.6 kB]
Feb  9 11:27:18 yggdrasil cron-apt: Del cockpit-machines 235-1~bpo10+1 [703 kB]
Feb  9 11:27:18 yggdrasil cron-apt: Del cockpit-pcp 235-1~bpo10+1 [81.4 kB]
Feb  9 11:27:18 yggdrasil cron-apt: Del cockpit-ws 235-1~bpo10+1 [1301 kB]
Feb  9 11:27:18 yggdrasil cron-apt: Del cockpit-storaged 235-1~bpo10+1 [608 kB]
Feb  9 11:27:18 yggdrasil cron-apt: Del cockpit-system 235-1~bpo10+1 [2312 kB]
Feb  9 11:27:18 yggdrasil cron-apt: Del cockpit-bridge 235-1~bpo10+1 [476 kB]
Feb  9 11:27:22 yggdrasil cron-apt: CRON-APT LINE: /usr/bin/apt-get  dist-upgrade -d -y -o APT::Get::Show-Upgraded=true
Feb  9 11:27:22 yggdrasil cron-apt: Reading package lists...
Feb  9 11:27:22 yggdrasil cron-apt: Building dependency tree...
Feb  9 11:27:22 yggdrasil cron-apt: Reading state information...
Feb  9 11:27:22 yggdrasil cron-apt: Calculating upgrade...
Feb  9 11:27:22 yggdrasil cron-apt: The following packages will be upgraded:
Feb  9 11:27:22 yggdrasil cron-apt:   base-files cockpit cockpit-bridge cockpit-machines cockpit-packagekit
Feb  9 11:27:22 yggdrasil cron-apt:   cockpit-pcp cockpit-storaged cockpit-system cockpit-ws grub-common grub-pc
Feb  9 11:27:22 yggdrasil cron-apt:   grub-pc-bin grub2-common iproute2 libcairo-gobject2 libcairo2 libgnutls30
Feb  9 11:27:22 yggdrasil cron-apt:   libmagic-mgc libmagic1 libnss-myhostname libpam-systemd libsystemd0 libudev1
Feb  9 11:27:22 yggdrasil cron-apt:   systemd systemd-sysv udev
Feb  9 11:27:22 yggdrasil cron-apt: 26 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Feb  9 11:27:22 yggdrasil cron-apt: Need to get 6165 kB/19.1 MB of archives.
Feb  9 11:27:22 yggdrasil cron-apt: After this operation, 35.8 kB disk space will be freed.
Feb  9 11:27:22 yggdrasil cron-apt: Get:1 https://deb.debian.org/debian buster-backports/main amd64 cockpit-bridge amd64 237-1~bpo10+1 [472 kB]
Feb  9 11:27:22 yggdrasil cron-apt: Get:2 https://deb.debian.org/debian buster-backports/main amd64 cockpit-ws amd64 237-1~bpo10+1 [1300 kB]
Feb  9 11:27:22 yggdrasil cron-apt: Get:3 https://deb.debian.org/debian buster-backports/main amd64 cockpit-system all 237-1~bpo10+1 [2399 kB]
Feb  9 11:27:22 yggdrasil cron-apt: Get:4 https://deb.debian.org/debian buster-backports/main amd64 cockpit all 237-1~bpo10+1 [30.8 kB]
Feb  9 11:27:22 yggdrasil cron-apt: Get:5 https://deb.debian.org/debian buster-backports/main amd64 cockpit-machines all 237-1~bpo10+1 [718 kB]
Feb  9 11:27:22 yggdrasil cron-apt: Get:6 https://deb.debian.org/debian buster-backports/main amd64 cockpit-packagekit all 237-1~bpo10+1 [546 kB]
Feb  9 11:27:22 yggdrasil cron-apt: Get:7 https://deb.debian.org/debian buster-backports/main amd64 cockpit-pcp amd64 237-1~bpo10+1 [81.1 kB]
Feb  9 11:27:22 yggdrasil cron-apt: Get:8 https://deb.debian.org/debian buster-backports/main amd64 cockpit-storaged all 237-1~bpo10+1 [618 kB]
Feb  9 11:27:22 yggdrasil cron-apt: Fetched 6165 kB in 3s (1769 kB/s)
Feb  9 11:27:22 yggdrasil cron-apt: Download complete and in download only mode
Feb  9 11:27:22 yggdrasil postfix/postdrop[9074]: warning: unable to look up public/pickup: No such file or directory
Feb  9 11:27:22 yggdrasil postfix/postsuper[9083]: fatal: scan_dir_push: open directory hold: No such file or directory
Feb  9 11:27:23 yggdrasil anacron[727]: Job `cron.daily' terminated (exit status: 1) (mailing output)
Feb  9 11:27:23 yggdrasil anacron[727]: postdrop: warning: unable to look up public/pickup: No such file or directory
Feb  9 11:27:23 yggdrasil postfix/postdrop[9102]: warning: unable to look up public/pickup: No such file or directory
Feb  9 11:27:23 yggdrasil anacron[727]: Normal exit (1 job run)
Feb  9 11:27:23 yggdrasil systemd[1]: anacron.service: Succeeded.
Feb  9 11:28:01 yggdrasil CRON[9116]: (pcp) CMD ( /usr/lib/pcp/bin/pmie_check -C)
Feb  9 11:30:01 yggdrasil CRON[9308]: (pcp) CMD ( /usr/lib/pcp/bin/pmlogger_daily -p)
Feb  9 11:30:01 yggdrasil CRON[9309]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Feb  9 11:30:01 yggdrasil CRON[9310]: (root) CMD ([ -x /etc/init.d/anacron ] && if [ ! -d /run/systemd/system ]; then /usr/sbin/invoke-rc.d anacron start >/dev/null; fi)
Feb  9 11:30:01 yggdrasil CRON[9311]: (pcp) CMD ( /usr/lib/pcp/bin/pmlogger_daily_report -o /var/log/pcp/sa -p)
Feb  9 11:32:20 yggdrasil PackageKit: daemon quit
Feb  9 11:32:20 yggdrasil systemd[1]: packagekit.service: Main process exited, code=killed, status=15/TERM
Feb  9 11:32:20 yggdrasil systemd[1]: packagekit.service: Succeeded.
Feb  9 11:32:27 yggdrasil systemd[1]: Started Run anacron jobs.
Feb  9 11:32:27 yggdrasil anacron[10076]: Anacron 2.3 started on 2021-02-09
Feb  9 11:32:27 yggdrasil anacron[10076]: Normal exit (0 jobs run)
Feb  9 11:32:27 yggdrasil systemd[1]: anacron.service: Succeeded.
Feb  9 11:39:01 yggdrasil CRON[10177]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Feb  9 11:39:07 yggdrasil systemd[1]: Starting Clean php session files...
Feb  9 11:39:07 yggdrasil systemd[1]: phpsessionclean.service: Succeeded.
Feb  9 11:39:07 yggdrasil systemd[1]: Started Clean php session files.
Feb  9 11:45:01 yggdrasil CRON[10336]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Feb  9 11:50:09 yggdrasil kernel: [ 2726.748241] md: md127 stopped.
Feb  9 11:50:14 yggdrasil kernel: [ 2731.319976] md: md127 stopped.
Feb  9 11:50:14 yggdrasil kernel: [ 2731.323707] md: md127 stopped.
Feb  9 11:50:14 yggdrasil udisksd[723]: Error reading sysfs attr `/sys/devices/virtual/block/md127/md/degraded': Failed to open file “/sys/devices/virtual/block/md127/md/degraded”: No such file or directory (g-file-error-quark, 4)
Feb  9 11:50:14 yggdrasil udisksd[723]: Error reading sysfs attr `/sys/devices/virtual/block/md127/md/sync_action': Failed to open file “/sys/devices/virtual/block/md127/md/sync_action”: No such file or directory (g-file-error-quark, 4)
Feb  9 11:50:14 yggdrasil udisksd[723]: Error reading sysfs attr `/sys/devices/virtual/block/md127/md/sync_completed': Failed to open file “/sys/devices/virtual/block/md127/md/sync_completed”: No such file or directory (g-file-error-quark, 4)
Feb  9 11:55:01 yggdrasil CRON[10790]: (pcp) CMD ( /usr/lib/pcp/bin/pmlogger_check -C)
Feb  9 11:55:30 yggdrasil kernel: [ 3047.851073] md: md127 stopped.
Feb  9 11:55:36 yggdrasil kernel: [ 3053.784470] md: md127 stopped.
Feb  9 11:55:36 yggdrasil kernel: [ 3053.788473] md: md127 stopped.
Feb  9 11:55:37 yggdrasil udisksd[723]: Error reading sysfs attr `/sys/devices/virtual/block/md127/md/degraded': Failed to open file “/sys/devices/virtual/block/md127/md/degraded”: No such file or directory (g-file-error-quark, 4)
Feb  9 11:55:37 yggdrasil udisksd[723]: Error reading sysfs attr `/sys/devices/virtual/block/md127/md/sync_action': Failed to open file “/sys/devices/virtual/block/md127/md/sync_action”: No such file or directory (g-file-error-quark, 4)
Feb  9 11:55:37 yggdrasil udisksd[723]: Error reading sysfs attr `/sys/devices/virtual/block/md127/md/sync_completed': Failed to open file “/sys/devices/virtual/block/md127/md/sync_completed”: No such file or directory (g-file-error-quark, 4)
Feb  9 11:58:01 yggdrasil CRON[11267]: (pcp) CMD ( /usr/lib/pcp/bin/pmie_check -C)
Feb  9 12:00:01 yggdrasil CRON[11455]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Feb  9 12:00:39 yggdrasil nmbd[1026]: [2021/02/09 12:00:39.885983,  0] ../source3/nmbd/nmbd_namequery.c:109(query_name_response
Message édité par Lutinnoir le 09-02-2021 à 13:07:20
n°1460580
slywalker
Posté le 09-02-2021 à 13:59:49  profilanswer
on reprend :)
mv /etc/mdadm/mdadm.conf /etc/mdadm/mdadm.conf.20210209
mdadm --assemble --verbose --scan
cat /proc/mdstat
Message édité par slywalker le 09-02-2021 à 14:03:22
n°1460581
Lutinnoir
Posté le 09-02-2021 à 14:02:24  profilanswer
On a une difference du nombre "events" entre disque.
root@yggdrasil:~# mdadm --assemble --verbose --scan
mdadm: looking for devices for /dev/md/Data
mdadm: No super block found on /dev/sdh5 (Expected magic a92b4efc, got 00000000)
mdadm: no RAID superblock on /dev/sdh5
mdadm: /dev/sdh2 is too small for md: size is 2 sectors.
mdadm: no RAID superblock on /dev/sdh2
mdadm: No super block found on /dev/sdh1 (Expected magic a92b4efc, got 00000474)
mdadm: no RAID superblock on /dev/sdh1
mdadm: No super block found on /dev/sdh (Expected magic a92b4efc, got cd8e1c7b)
mdadm: No super block found on /dev/sda1 (Expected magic a92b4efc, got 000007a5)
mdadm: no RAID superblock on /dev/sda1
mdadm: No super block found on /dev/sda (Expected magic a92b4efc, got 00000000)
mdadm: /dev/sdg is identified as a member of /dev/md/Data, slot 0.
mdadm: /dev/sde is identified as a member of /dev/md/Data, slot 2.
mdadm: /dev/sdc is identified as a member of /dev/md/Data, slot 3.
mdadm: /dev/sdf is identified as a member of /dev/md/Data, slot 1.
mdadm: /dev/sdb is identified as a member of /dev/md/Data, slot 4.
mdadm: /dev/sdd is identified as a member of /dev/md/Data, slot 5.
mdadm: added /dev/sdg to /dev/md/Data as 0 (possibly out of date)
mdadm: added /dev/sdf to /dev/md/Data as 1 (possibly out of date)
mdadm: added /dev/sde to /dev/md/Data as 2 (possibly out of date)
mdadm: added /dev/sdb to /dev/md/Data as 4
mdadm: added /dev/sdd to /dev/md/Data as 5
mdadm: added /dev/sdc to /dev/md/Data as 3
mdadm: /dev/md/Data assembled from 3 drives - not enough to start the array.
n°1460582
slywalker
Posté le 09-02-2021 à 14:04:09  profilanswer
mmhhhh ....
je mange et je reviens  :)
n°1460585
slywalker
Posté le 09-02-2021 à 14:56:15  profilanswer
Bon, on a des disques desynchro, c'est moche ....
Mais la bonne nouvelle, c'est que le delta de desynchro est très faible.
On va donc pouvoir forcer le montage du RAID.
Je tiens bien à préciser que l'opération suivante peut corrompre des données, mais en l'état, il n'y a pour moi pas d'autres choix possible.
Donc si tu es bien pleinement conscient de ça, je te propose les commandes suivantes :
mv /etc/mdadm/mdadm.conf /etc/mdadm/mdadm.conf.20210209-2
mdadm --assemble --force /dev/md127 /dev/sd[bcdefg]
cat /proc/mdstat
n°1460587
Lutinnoir
Posté le 09-02-2021 à 15:13:35  profilanswer
Le raid5 est re-up. Il est en dégradé 5/6, mais c'est suffisant pour récupérer les dernières données.
Merci beaucoup pour ta patience et tes connaissances.
root@yggdrasil:~# mv /etc/mdadm/mdadm.conf /etc/mdadm/mdadm.conf.20210209-2
mv: impossible d'évaluer '/etc/mdadm/mdadm.conf': Aucun fichier ou dossier de ce type
root@yggdrasil:~# mdadm --assemble --force /dev/md127 /dev/sd[bcdefg]
mdadm: forcing event count in /dev/sdf(1) from 15862 upto 15866
mdadm: forcing event count in /dev/sde(2) from 15862 upto 15866
mdadm: forcing event count in /dev/sdg(0) from 15859 upto 15866
mdadm: /dev/md127 assembled from 6 drives - not enough to start the array.
/dev/md127:
           Version : 1.2
        Raid Level : raid5
     Used Dev Size : 9766304768 (9313.87 GiB 10000.70 GB)
      Raid Devices : 6
     Total Devices : 6
     Intent Bitmap : Internal
             State : clean, degraded
    Active Devices : 5
   Working Devices : 6
    Failed Devices : 0
     Spare Devices : 1
        Chunk Size : 512K
Consistency Policy : bitmap
            Events : 15866
    Number   Major   Minor   RaidDevice State
       0       8       96        0      spare rebuilding   /dev/sdg
       1       8       80        1      active sync   /dev/sdf
       2       8       64        2      active sync   /dev/sde
       3       8       32        3      active sync   /dev/sdc
       4       8       16        4      active sync   /dev/sdb
       5       8       48        5      active sync   /dev/sdd
md127 : active (auto-read-only) raid5 sdg[0] sdf[1] sde[2] sdd[5] sdc[3] sdb[4]
      48831523840 blocks super 1.2 level 5, 512k chunk, algorithm 2 [6/5] [_UUUUU]
      bitmap: 0/73 pages [0KB], 65536KB chunk
n°1460588
slywalker
Posté le 09-02-2021 à 15:23:33  profilanswer
Tant mieux si c'est reparti  :)
pour mon info, tu peux stp refaire un :
cat /proc/mdstat
n°1460591
Lutinnoir
Posté le 09-02-2021 à 15:27:10  profilanswer
md127 : active raid5 sdg[0] sdf[1] sde[2] sdd[5] sdc[3] sdb[4]
      48831523840 blocks super 1.2 level 5, 512k chunk, algorithm 2 [6/6] [UUUUUU]
le raid c'est reconstruit, il est maintenant clean.  [:cytrouille]
n°1460592
slywalker
Posté le 09-02-2021 à 15:36:37  profilanswer
Cool :-)
il te faudra remettre en place ton fichier mdadm.conf par contre :-)
n°1460593
Lutinnoir
Posté le 09-02-2021 à 15:39:15  profilanswer
slywalker a écrit :
Cool :-)
C'est fait, encore merci.
n°1460770
frenchieis​verige
Nej, men HEJSAN!
Posté le 15-02-2021 à 09:31:32  profilanswer
Je vais mettre un lien de cette conversation dans le topic officiel OMV d'HFR car je la trouve intéressante. Merci de ne pas la supprimer :jap:
[TU]: Linux Mint | NAS Homemade | Noyau Linux | OpenMediaVault | Windows 11
n°1460777
Trit'
Posté le 15-02-2021 à 10:45:33  profilanswer
Sauvegarde-la dans archive.org et garde le lien !
n°1460790
frenchieis​verige
Nej, men HEJSAN!
Posté le 15-02-2021 à 13:55:56  profilanswer
Je ne connaissais pas merci!
  Installation
Openmediavault-systeme de fichieropenmediavault-pas accès au SSH
openmediavault raid5 disparuParamétrage Rsync Openmediavault freebox
erreur 0x80070035 openmediavaultdisque système openmediavault hors service
Impossible de ne connecter a l'interface d'openmediavaultProblème Login sur OpenMediaVault
Debian : RAID5 et SWAP
Plus de sujets relatifs à : Récuperation raid5 sous OMV
