4998 connectés
  Linux et OS Alternatifs
  Installation
  Probleme LimeWire!
Probleme LimeWire!
n°209923
Nico77
Posté le 11-01-2003 à 12:00:23  profilanswer
voila quand je veux installer Limewire,un .bin en fesant :
sh fichier.bin il me met :
[root@localhost tmp]# sh LimeWireLinux.bin
Preparing to install...
Extracting the installation resources from the installer archive...
Configuring the installer for this system's environment...
Launching installer...
Error: Unrecognized JVM specific option `-Xmx100331648'.
Error: Unrecognized JVM specific option `-Xms16777216'.
Invocation of this Java Application has caused an InvocationTargetException. Thi                                                              s application will now exit. (LAX)
Stack Trace:
java.lang.NoClassDefFoundError: ZeroGd9
        at ZeroGed.a(source file unknown:line unknown, pc 0x86ef82a)
        at ZeroGee.<init>(source file unknown:line unknown, pc 0x834b5a3)
        at ZeroGed.<init>(source file unknown:line unknown, pc 0x822d452)
        at ZeroGdv.a(source file unknown:line unknown, pc 0x85ff717)
        at com.zerog.ia.installer.Main.a(source file unknown:line unknown, pc 0x                                                              86958f1)
        at com.zerog.ia.installer.Main.c(source file unknown:line unknown, pc 0x                                                              86731ac)
        at com.zerog.ia.installer.Main.main(source file unknown:line unknown, pc                                                               0x8341ac2)
        at java.lang.reflect.Method.invoke0(Method.java:native)
        at java.lang.reflect.Method.invoke(Method.java:256)
        at com.zerog.lax.LAX.launch(source file unknown:line unknown, pc 0x82ba9                                                              d6)
        at com.zerog.lax.LAX.main(source file unknown:line unknown, pc 0x82033ed                                                              )
Voila qq a une idée?
n°209955
Nico77
Posté le 11-01-2003 à 13:21:50  profilanswer
UP!
n°209965
Kuei-Saho
Posté le 11-01-2003 à 13:57:45  profilanswer
Down
Dieu a cree l homme. Et ensuite, pour le remercier, l homme a cree Dieu.
n°209966
samuelp
Posté le 11-01-2003 à 14:04:44  profilanswer
Premierement LimeWire est un outil de pirate
Deuxiemement : c quoi ta JVM d'installé ?
 Troisiemement : Quelle version de LimeWire ?
n°209967
udok
La racaille des barbus ©clémen
Posté le 11-01-2003 à 14:05:30  profilanswer
on dirait qu'il veut la JVM
tu l'as bien installé ?
n°209969
Nico77
Posté le 11-01-2003 à 14:19:26  profilanswer
c limewire 2.8.5 et JVM j2re 1.4.1
merci  :D
n°209970
samuelp
Posté le 11-01-2003 à 14:24:42  profilanswer
merci  :D
Avec la 1.4.01 ça marche chez moi ;) mais chut faut pas le dire que j'ai LimeWire :D
n°209974
Nico77
Posté le 11-01-2003 à 14:29:31  profilanswer
c la meme que toi?
1.4.1.01 ?
sinon il veut dire koi ce message?
n°209979
udok
Posté le 11-01-2003 à 14:54:03  profilanswer
c'est pas libre badboy :o
n°209981
Nico77
Posté le 11-01-2003 à 14:57:40  profilanswer
bon sinon ya quoi a part limewire comme client p2p?
comme il veut pas s'installer chez moi...
n°210007
udok
Posté le 11-01-2003 à 15:39:42  profilanswer
mldonkey pour le réseau edonkey/overnet
mais si tu cherches des mp3, tu risques d'être un peu déçu en comparaison d'autres réseau de p2p
n°995392
bouba211
Posté le 27-12-2007 à 17:08:04  profilanswer
y a Ares.com qui est très bien " depuis que g ca, le reste ne m'interesse plus
n°995394
black_lord
Truth speaks from peacefulness
Posté le 27-12-2007 à 17:17:29  profilanswer
up d'un topic mort depuis 4 ans, sur du p2p...
uptime is for lousy system administrators what Viagra is for impotent people - mes unixeries - github me
  Installation
  Probleme LimeWire!
[chtit problème avec les dates]Probleme avec drip version cvs
gros gros probleme après compile kernel[Debian 3.0] Probleme avec APT
Problème SMP avec Mandrake -> passage à Debian[Debian 3.0] Probleme de boot
[debian] probleme chargement modules alsaProbleme d'affichage KDE 3
Probleme pour windowmaker apres compilation & installation [newbie]Probleme d'installation de LimeWire?????
Plus de sujets relatifs à : Probleme LimeWire!
