11070 connectés
  Linux et OS Alternatifs
  Installation
  [kernel 2.6.7] VFS unable to mount root fs => .config inside
n°523833
pinguin007
a npe error
Posté le 19-07-2004 à 20:16:30  profilanswer
bon voila j'en ai marre, 3éme compil et 3éme fois que ca foire   [:brainwasher] [:tilleul]
j'en ai marre je ne sais pas ce que j'ai oublié
la config :
Toshiba tecra 500cdt (laptop)
p120
16Mo edo
hdd 1.3Go
debian woddy passé en sarge avec kernek 2.2.20 à la base
Tout marche trés bien sauf l'apm qui est désactivé et pour l'activer recompil du kernel d'ou le pourquoi de la recompil mais au reboot c'est le drame :/
voici le .config en question...
# Automatically generated make config: don't edit
CONFIG_X86=y
CONFIG_MMU=y
CONFIG_UID16=y
CONFIG_GENERIC_ISA_DMA=y
# Code maturity level options
CONFIG_EXPERIMENTAL=y
CONFIG_CLEAN_COMPILE=y
CONFIG_STANDALONE=y
CONFIG_BROKEN_ON_SMP=y
# General setup
CONFIG_SWAP=y
CONFIG_SYSVIPC=y
# CONFIG_POSIX_MQUEUE is not set
CONFIG_BSD_PROCESS_ACCT=y
CONFIG_SYSCTL=y
# CONFIG_AUDIT is not set
CONFIG_LOG_BUF_SHIFT=14
CONFIG_HOTPLUG=y
# CONFIG_IKCONFIG is not set
CONFIG_EMBEDDED=y
CONFIG_KALLSYMS=y
CONFIG_FUTEX=y
CONFIG_EPOLL=y
CONFIG_IOSCHED_NOOP=y
CONFIG_IOSCHED_AS=y
CONFIG_IOSCHED_DEADLINE=y
CONFIG_IOSCHED_CFQ=y
# CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
# Loadable module support
CONFIG_MODULES=y
CONFIG_MODULE_UNLOAD=y
# CONFIG_MODULE_FORCE_UNLOAD is not set
CONFIG_OBSOLETE_MODPARM=y
CONFIG_MODVERSIONS=y
CONFIG_KMOD=y
# Processor type and features
CONFIG_X86_PC=y
# CONFIG_X86_ELAN is not set
# CONFIG_X86_VOYAGER is not set
# CONFIG_X86_NUMAQ is not set
# CONFIG_X86_SUMMIT is not set
# CONFIG_X86_BIGSMP is not set
# CONFIG_X86_VISWS is not set
# CONFIG_X86_GENERICARCH is not set
# CONFIG_X86_ES7000 is not set
# CONFIG_M386 is not set
# CONFIG_M486 is not set
# CONFIG_M586 is not set
CONFIG_M586TSC=y
# CONFIG_M586MMX is not set
# CONFIG_M686 is not set
# CONFIG_MPENTIUMII is not set
# CONFIG_MPENTIUMIII is not set
# CONFIG_MPENTIUMM is not set
# CONFIG_MPENTIUM4 is not set
# CONFIG_MK6 is not set
# CONFIG_MK7 is not set
# CONFIG_MK8 is not set
# CONFIG_MCRUSOE is not set
# CONFIG_MWINCHIPC6 is not set
# CONFIG_MWINCHIP2 is not set
# CONFIG_MWINCHIP3D is not set
# CONFIG_MCYRIXIII is not set
# CONFIG_MVIAC3_2 is not set
CONFIG_X86_GENERIC=y
CONFIG_X86_CMPXCHG=y
CONFIG_X86_XADD=y
CONFIG_X86_L1_CACHE_SHIFT=7
CONFIG_RWSEM_XCHGADD_ALGORITHM=y
CONFIG_X86_PPRO_FENCE=y
CONFIG_X86_F00F_BUG=y
CONFIG_X86_WP_WORKS_OK=y
CONFIG_X86_INVLPG=y
CONFIG_X86_BSWAP=y
CONFIG_X86_POPAD_OK=y
CONFIG_X86_ALIGNMENT_16=y
CONFIG_X86_INTEL_USERCOPY=y
# CONFIG_HPET_TIMER is not set
# CONFIG_HPET_EMULATE_RTC is not set
# CONFIG_SMP is not set
# CONFIG_PREEMPT is not set
# CONFIG_X86_UP_APIC is not set
CONFIG_X86_TSC=y
# CONFIG_X86_MCE is not set
CONFIG_TOSHIBA=y
# CONFIG_I8K is not set
CONFIG_MICROCODE=m
CONFIG_X86_MSR=m
CONFIG_X86_CPUID=m
# Firmware Drivers
# CONFIG_EDD is not set
CONFIG_NOHIGHMEM=y
# CONFIG_HIGHMEM4G is not set
# CONFIG_HIGHMEM64G is not set
CONFIG_MATH_EMULATION=y
CONFIG_MTRR=y
# CONFIG_REGPARM is not set
# Power management options (ACPI, APM)
CONFIG_PM=y
# CONFIG_SOFTWARE_SUSPEND is not set
# CONFIG_PM_DISK is not set
# ACPI (Advanced Configuration and Power Interface) Support
# CONFIG_ACPI is not set
CONFIG_ACPI_BOOT=y
# APM (Advanced Power Management) BIOS Support
CONFIG_APM=y
CONFIG_APM_IGNORE_USER_SUSPEND=y
CONFIG_APM_DO_ENABLE=y
CONFIG_APM_CPU_IDLE=y
# CONFIG_APM_DISPLAY_BLANK is not set
# CONFIG_APM_RTC_IS_GMT is not set
# CONFIG_APM_ALLOW_INTS is not set
# CONFIG_APM_REAL_MODE_POWER_OFF is not set
# CPU Frequency scaling
# CONFIG_CPU_FREQ is not set
# Bus options (PCI, PCMCIA, EISA, MCA, ISA)
CONFIG_PCI=y
# CONFIG_PCI_GOBIOS is not set
# CONFIG_PCI_GOMMCONFIG is not set
# CONFIG_PCI_GODIRECT is not set
CONFIG_PCI_GOANY=y
CONFIG_PCI_BIOS=y
CONFIG_PCI_DIRECT=y
CONFIG_PCI_MMCONFIG=y
# CONFIG_PCI_LEGACY_PROC is not set
CONFIG_PCI_NAMES=y
# CONFIG_ISA is not set
# CONFIG_MCA is not set
# CONFIG_SCx200 is not set
# PCMCIA/CardBus support
CONFIG_PCMCIA=y
# CONFIG_PCMCIA_DEBUG is not set
# CONFIG_YENTA is not set
CONFIG_I82092=m
# CONFIG_TCIC is not set
# PCI Hotplug Support
# CONFIG_HOTPLUG_PCI is not set
# Executable file formats
CONFIG_BINFMT_ELF=y
CONFIG_BINFMT_AOUT=m
CONFIG_BINFMT_MISC=m
# Device Drivers
# Generic Driver Options
# CONFIG_FW_LOADER is not set
# Memory Technology Devices (MTD)
# CONFIG_MTD is not set
# Parallel port support
CONFIG_PARPORT=m
CONFIG_PARPORT_PC=m
# CONFIG_PARPORT_PC_FIFO is not set
# CONFIG_PARPORT_PC_SUPERIO is not set
# CONFIG_PARPORT_PC_PCMCIA is not set
# CONFIG_PARPORT_OTHER is not set
# CONFIG_PARPORT_1284 is not set
# Plug and Play support
# Block devices
CONFIG_BLK_DEV_FD=y
# CONFIG_PARIDE is not set
# CONFIG_BLK_CPQ_DA is not set
# CONFIG_BLK_CPQ_CISS_DA is not set
# CONFIG_BLK_DEV_DAC960 is not set
# CONFIG_BLK_DEV_UMEM is not set
CONFIG_BLK_DEV_LOOP=y
# CONFIG_BLK_DEV_CRYPTOLOOP is not set
CONFIG_BLK_DEV_NBD=m
# CONFIG_BLK_DEV_CARMEL is not set
CONFIG_BLK_DEV_RAM=y
CONFIG_BLK_DEV_RAM_SIZE=4096
CONFIG_BLK_DEV_INITRD=y
# CONFIG_LBD is not set
# ATA/ATAPI/MFM/RLL support
CONFIG_IDE=m
# CONFIG_BLK_DEV_IDE is not set
# CONFIG_BLK_DEV_HD_ONLY is not set
# CONFIG_BLK_DEV_HD is not set
# SCSI device support
# CONFIG_SCSI is not set
# Multi-device support (RAID and LVM)
# CONFIG_MD is not set
# Fusion MPT device support
# IEEE 1394 (FireWire) support
# CONFIG_IEEE1394 is not set
# I2O device support
# CONFIG_I2O is not set
# Networking support
CONFIG_NET=y
# Networking options
CONFIG_PACKET=m
# CONFIG_PACKET_MMAP is not set
CONFIG_NETLINK_DEV=m
CONFIG_UNIX=m
# CONFIG_NET_KEY is not set
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
# CONFIG_IP_ADVANCED_ROUTER is not set
# CONFIG_IP_PNP is not set
# CONFIG_NET_IPIP is not set
# CONFIG_NET_IPGRE is not set
# CONFIG_IP_MROUTE is not set
# CONFIG_ARPD is not set
# CONFIG_SYN_COOKIES is not set
# CONFIG_INET_AH is not set
# CONFIG_INET_ESP is not set
# CONFIG_INET_IPCOMP is not set
CONFIG_IPV6=m
# CONFIG_IPV6_PRIVACY is not set
# CONFIG_INET6_AH is not set
# CONFIG_INET6_ESP is not set
# CONFIG_INET6_IPCOMP is not set
# CONFIG_IPV6_TUNNEL is not set
# CONFIG_NETFILTER is not set
# SCTP Configuration (EXPERIMENTAL)
# CONFIG_IP_SCTP is not set
# CONFIG_ATM is not set
# CONFIG_BRIDGE is not set
# CONFIG_VLAN_8021Q is not set
# CONFIG_DECNET is not set
CONFIG_LLC=m
# CONFIG_LLC2 is not set
CONFIG_IPX=m
# CONFIG_IPX_INTERN is not set
CONFIG_ATALK=m
# CONFIG_DEV_APPLETALK is not set
# CONFIG_X25 is not set
# CONFIG_LAPB is not set
# CONFIG_NET_DIVERT is not set
# CONFIG_ECONET is not set
# CONFIG_WAN_ROUTER is not set
# CONFIG_NET_FASTROUTE is not set
# CONFIG_NET_HW_FLOWCONTROL is not set
# QoS and/or fair queueing
# CONFIG_NET_SCHED is not set
# Network testing
# CONFIG_NET_PKTGEN is not set
# CONFIG_NETPOLL is not set
# CONFIG_NET_POLL_CONTROLLER is not set
# CONFIG_HAMRADIO is not set
CONFIG_IRDA=m
# IrDA protocols
CONFIG_IRLAN=m
CONFIG_IRCOMM=m
CONFIG_IRDA_ULTRA=y
# IrDA options
# CONFIG_IRDA_CACHE_LAST_LSAP is not set
# CONFIG_IRDA_FAST_RR is not set
# CONFIG_IRDA_DEBUG is not set
# Infrared-port device drivers
# SIR device drivers
CONFIG_IRTTY_SIR=m
# Dongle support
# CONFIG_DONGLE is not set
# Old SIR device drivers
CONFIG_IRPORT_SIR=m
# Old Serial dongle support
# CONFIG_DONGLE_OLD is not set
# FIR device drivers
CONFIG_TOSHIBA_FIR=m
# CONFIG_VLSI_FIR is not set
# CONFIG_BT is not set
CONFIG_NETDEVICES=y
CONFIG_DUMMY=m
# CONFIG_BONDING is not set
# CONFIG_EQUALIZER is not set
# CONFIG_TUN is not set
# CONFIG_ETHERTAP is not set
# ARCnet devices
# CONFIG_ARCNET is not set
# Ethernet (10 or 100Mbit)
CONFIG_NET_ETHERNET=y
CONFIG_MII=m
# CONFIG_HAPPYMEAL is not set
# CONFIG_SUNGEM is not set
CONFIG_NET_VENDOR_3COM=y
CONFIG_VORTEX=m
# CONFIG_TYPHOON is not set
# Tulip family network device support
# CONFIG_NET_TULIP is not set
# CONFIG_HP100 is not set
# CONFIG_NET_PCI is not set
# Ethernet (1000 Mbit)
# CONFIG_ACENIC is not set
# CONFIG_DL2K is not set
# CONFIG_E1000 is not set
# CONFIG_NS83820 is not set
# CONFIG_HAMACHI is not set
# CONFIG_YELLOWFIN is not set
# CONFIG_R8169 is not set
# CONFIG_SK98LIN is not set
# CONFIG_TIGON3 is not set
# Ethernet (10000 Mbit)
# CONFIG_IXGB is not set
# CONFIG_S2IO is not set
# Token Ring devices
# CONFIG_TR is not set
# Wireless LAN (non-hamradio)
# CONFIG_NET_RADIO is not set
# PCMCIA network device support
CONFIG_NET_PCMCIA=y
# CONFIG_PCMCIA_3C589 is not set
# CONFIG_PCMCIA_3C574 is not set
# CONFIG_PCMCIA_FMVJ18X is not set
# CONFIG_PCMCIA_PCNET is not set
# CONFIG_PCMCIA_NMCLAN is not set
# CONFIG_PCMCIA_SMC91C92 is not set
# CONFIG_PCMCIA_XIRC2PS is not set
# CONFIG_PCMCIA_AXNET is not set
# Wan interfaces
# CONFIG_WAN is not set
# CONFIG_FDDI is not set
# CONFIG_HIPPI is not set
# CONFIG_PLIP is not set
# CONFIG_PPP is not set
# CONFIG_SLIP is not set
# CONFIG_SHAPER is not set
# CONFIG_NETCONSOLE is not set
# ISDN subsystem
# CONFIG_ISDN is not set
# Telephony Support
# CONFIG_PHONE is not set
# Input device support
CONFIG_INPUT=y
# Userland interfaces
CONFIG_INPUT_MOUSEDEV=y
CONFIG_INPUT_MOUSEDEV_PSAUX=y
CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024
CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768
# CONFIG_INPUT_JOYDEV is not set
# CONFIG_INPUT_TSDEV is not set
# CONFIG_INPUT_EVDEV is not set
# CONFIG_INPUT_EVBUG is not set
# Input I/O drivers
# CONFIG_GAMEPORT is not set
CONFIG_SOUND_GAMEPORT=y
CONFIG_SERIO=y
CONFIG_SERIO_I8042=y
CONFIG_SERIO_SERPORT=y
# CONFIG_SERIO_CT82C710 is not set
# CONFIG_SERIO_PARKBD is not set
# CONFIG_SERIO_PCIPS2 is not set
# Input Device Drivers
CONFIG_INPUT_KEYBOARD=y
CONFIG_KEYBOARD_ATKBD=y
# CONFIG_KEYBOARD_SUNKBD is not set
# CONFIG_KEYBOARD_LKKBD is not set
# CONFIG_KEYBOARD_XTKBD is not set
# CONFIG_KEYBOARD_NEWTON is not set
CONFIG_INPUT_MOUSE=y
CONFIG_MOUSE_PS2=y
# CONFIG_MOUSE_SERIAL is not set
# CONFIG_MOUSE_VSXXXAA is not set
# CONFIG_INPUT_JOYSTICK is not set
# CONFIG_INPUT_TOUCHSCREEN is not set
# CONFIG_INPUT_MISC is not set
# Character devices
CONFIG_VT=y
CONFIG_VT_CONSOLE=y
CONFIG_HW_CONSOLE=y
# CONFIG_SERIAL_NONSTANDARD is not set
# Serial drivers
# CONFIG_SERIAL_8250 is not set
# Non-8250 serial port support
# CONFIG_UNIX98_PTYS is not set
CONFIG_LEGACY_PTYS=y
CONFIG_LEGACY_PTY_COUNT=4
# CONFIG_PRINTER is not set
# CONFIG_PPDEV is not set
# CONFIG_TIPAR is not set
# CONFIG_QIC02_TAPE is not set
# IPMI
# CONFIG_IPMI_HANDLER is not set
# Watchdog Cards
# CONFIG_WATCHDOG is not set
# CONFIG_HW_RANDOM is not set
CONFIG_NVRAM=m
CONFIG_RTC=y
CONFIG_DTLK=m
# CONFIG_R3964 is not set
# CONFIG_APPLICOM is not set
# CONFIG_SONYPI is not set
# Ftape, the floppy tape device driver
# CONFIG_FTAPE is not set
# CONFIG_AGP is not set
# CONFIG_DRM is not set
# PCMCIA character devices
# CONFIG_SYNCLINK_CS is not set
# CONFIG_MWAVE is not set
# CONFIG_RAW_DRIVER is not set
# CONFIG_HANGCHECK_TIMER is not set
# I2C support
# CONFIG_I2C is not set
# Misc devices
# CONFIG_IBM_ASM is not set
# Multimedia devices
# CONFIG_VIDEO_DEV is not set
# Digital Video Broadcasting Devices
# CONFIG_DVB is not set
# Graphics support
CONFIG_FB=y
# CONFIG_FB_PM2 is not set
# CONFIG_FB_CYBER2000 is not set
CONFIG_FB_ASILIANT=y
# CONFIG_FB_IMSTT is not set
# CONFIG_FB_VGA16 is not set
# CONFIG_FB_VESA is not set
# CONFIG_VIDEO_SELECT is not set
# CONFIG_FB_HGA is not set
# CONFIG_FB_RIVA is not set
# CONFIG_FB_MATROX is not set
# CONFIG_FB_RADEON_OLD is not set
# CONFIG_FB_RADEON is not set
# CONFIG_FB_ATY128 is not set
# CONFIG_FB_ATY is not set
# CONFIG_FB_SIS is not set
# CONFIG_FB_NEOMAGIC is not set
# CONFIG_FB_KYRO is not set
# CONFIG_FB_3DFX is not set
# CONFIG_FB_VOODOO1 is not set
# CONFIG_FB_TRIDENT is not set
# CONFIG_FB_VIRTUAL is not set
# Console display driver support
CONFIG_VGA_CONSOLE=y
# CONFIG_MDA_CONSOLE is not set
CONFIG_DUMMY_CONSOLE=y
# CONFIG_FRAMEBUFFER_CONSOLE is not set
# Logo configuration
CONFIG_LOGO=y
CONFIG_LOGO_LINUX_MONO=y
# CONFIG_LOGO_LINUX_VGA16 is not set
# CONFIG_LOGO_LINUX_CLUT224 is not set
# Sound
CONFIG_SOUND=y
# Advanced Linux Sound Architecture
# CONFIG_SND is not set
# Open Sound System
CONFIG_SOUND_PRIME=y
# CONFIG_SOUND_BT878 is not set
# CONFIG_SOUND_CMPCI is not set
# CONFIG_SOUND_EMU10K1 is not set
# CONFIG_SOUND_FUSION is not set
CONFIG_SOUND_CS4281=m
# CONFIG_SOUND_ES1370 is not set
# CONFIG_SOUND_ES1371 is not set
# CONFIG_SOUND_ESSSOLO1 is not set
# CONFIG_SOUND_MAESTRO is not set
# CONFIG_SOUND_MAESTRO3 is not set
# CONFIG_SOUND_ICH is not set
# CONFIG_SOUND_SONICVIBES is not set
# CONFIG_SOUND_TRIDENT is not set
# CONFIG_SOUND_MSNDCLAS is not set
# CONFIG_SOUND_MSNDPIN is not set
# CONFIG_SOUND_VIA82CXXX is not set
# CONFIG_SOUND_OSS is not set
# CONFIG_SOUND_ALI5455 is not set
# CONFIG_SOUND_FORTE is not set
# CONFIG_SOUND_RME96XX is not set
# CONFIG_SOUND_AD1980 is not set
# USB support
# CONFIG_USB is not set
# USB Gadget Support
# CONFIG_USB_GADGET is not set
# File systems
CONFIG_EXT2_FS=y
# CONFIG_EXT2_FS_XATTR is not set
# CONFIG_EXT3_FS is not set
# CONFIG_JBD is not set
# CONFIG_REISERFS_FS is not set
# CONFIG_JFS_FS is not set
# CONFIG_XFS_FS is not set
# CONFIG_MINIX_FS is not set
# CONFIG_ROMFS_FS is not set
# CONFIG_QUOTA is not set
# CONFIG_AUTOFS_FS is not set
# CONFIG_AUTOFS4_FS is not set
# CD-ROM/DVD Filesystems
CONFIG_ISO9660_FS=y
CONFIG_JOLIET=y
# CONFIG_ZISOFS is not set
# CONFIG_UDF_FS is not set
# DOS/FAT/NT Filesystems
CONFIG_FAT_FS=y
CONFIG_MSDOS_FS=y
CONFIG_VFAT_FS=y
# CONFIG_NTFS_FS is not set
# Pseudo filesystems
CONFIG_PROC_FS=y
CONFIG_PROC_KCORE=y
CONFIG_SYSFS=y
# CONFIG_DEVFS_FS is not set
# CONFIG_TMPFS is not set
# CONFIG_HUGETLBFS is not set
# CONFIG_HUGETLB_PAGE is not set
CONFIG_RAMFS=y
# Miscellaneous filesystems
# CONFIG_ADFS_FS is not set
# CONFIG_AFFS_FS is not set
# CONFIG_HFS_FS is not set
# CONFIG_HFSPLUS_FS is not set
# CONFIG_BEFS_FS is not set
# CONFIG_BFS_FS is not set
# CONFIG_EFS_FS is not set
# CONFIG_CRAMFS is not set
# CONFIG_VXFS_FS is not set
# CONFIG_HPFS_FS is not set
# CONFIG_QNX4FS_FS is not set
# CONFIG_SYSV_FS is not set
# CONFIG_UFS_FS is not set
# Network File Systems
# CONFIG_NFS_FS is not set
# CONFIG_NFSD is not set
# CONFIG_EXPORTFS is not set
# CONFIG_SMB_FS is not set
# CONFIG_CIFS is not set
# CONFIG_NCP_FS is not set
# CONFIG_CODA_FS is not set
# CONFIG_AFS_FS is not set
# Partition Types
# CONFIG_PARTITION_ADVANCED is not set
CONFIG_MSDOS_PARTITION=y
# Native Language Support
CONFIG_NLS=y
CONFIG_NLS_DEFAULT="iso8859-15"
# CONFIG_NLS_CODEPAGE_437 is not set
# CONFIG_NLS_CODEPAGE_737 is not set
# CONFIG_NLS_CODEPAGE_775 is not set
CONFIG_NLS_CODEPAGE_850=y
# CONFIG_NLS_CODEPAGE_852 is not set
# CONFIG_NLS_CODEPAGE_855 is not set
# CONFIG_NLS_CODEPAGE_857 is not set
# CONFIG_NLS_CODEPAGE_860 is not set
# CONFIG_NLS_CODEPAGE_861 is not set
# CONFIG_NLS_CODEPAGE_862 is not set
# CONFIG_NLS_CODEPAGE_863 is not set
# CONFIG_NLS_CODEPAGE_864 is not set
# CONFIG_NLS_CODEPAGE_865 is not set
# CONFIG_NLS_CODEPAGE_866 is not set
# CONFIG_NLS_CODEPAGE_869 is not set
# CONFIG_NLS_CODEPAGE_936 is not set
# CONFIG_NLS_CODEPAGE_950 is not set
# CONFIG_NLS_CODEPAGE_932 is not set
# CONFIG_NLS_CODEPAGE_949 is not set
# CONFIG_NLS_CODEPAGE_874 is not set
# CONFIG_NLS_ISO8859_8 is not set
# CONFIG_NLS_CODEPAGE_1250 is not set
# CONFIG_NLS_CODEPAGE_1251 is not set
# CONFIG_NLS_ISO8859_1 is not set
# CONFIG_NLS_ISO8859_2 is not set
# CONFIG_NLS_ISO8859_3 is not set
# CONFIG_NLS_ISO8859_4 is not set
# CONFIG_NLS_ISO8859_5 is not set
# CONFIG_NLS_ISO8859_6 is not set
# CONFIG_NLS_ISO8859_7 is not set
# CONFIG_NLS_ISO8859_9 is not set
# CONFIG_NLS_ISO8859_13 is not set
# CONFIG_NLS_ISO8859_14 is not set
CONFIG_NLS_ISO8859_15=y
# CONFIG_NLS_KOI8_R is not set
# CONFIG_NLS_KOI8_U is not set
CONFIG_NLS_UTF8=y
# Profiling support
# CONFIG_PROFILING is not set
# Kernel hacking
# CONFIG_DEBUG_KERNEL is not set
CONFIG_EARLY_PRINTK=y
# CONFIG_DEBUG_SPINLOCK_SLEEP is not set
# CONFIG_FRAME_POINTER is not set
# CONFIG_4KSTACKS is not set
# Security options
# CONFIG_SECURITY is not set
# Cryptographic options
# CONFIG_CRYPTO is not set
# Library routines
# CONFIG_CRC32 is not set
# CONFIG_LIBCRC32C is not set
CONFIG_X86_BIOS_REBOOT=y
CONFIG_X86_STD_RESOURCES=y
à vot' bon coeur m'ssieurs dames  :jap:
LoD 4 ever && PWC spirit|Le topak de l'iMP-450|inDATOUNEwe trust
n°523857
zekern
Posté le 19-07-2004 à 21:10:12  profilanswer
t'as essayé avec le tutorial d'alexis De Lattre ?
http://people.via.ecp.fr/~alexis/f [...] noyau.html
Y'a un .config de base, et il marche bien.
(la preuve je tourne avec :D )
n°523865
Klaimant
Posté le 19-07-2004 à 21:26:36  profilanswer
# File systems
CONFIG_EXT2_FS=y
CONFIG_EXT2_FS_XATTR=y (peut etre)
Fais le ou ne le fais pas, mais il n'y a pas d'essai !!!
n°523867
Klaimant
Posté le 19-07-2004 à 21:29:16  profilanswer
Si ca t'interresse je peux te filer le .config de ma passerelle pentium 166 ;)
n°523896
pinguin007
a npe error
Posté le 19-07-2004 à 22:55:09  profilanswer
heu wouais pk pas :)
à priori j'aurais juste a rajouter l'apm et la gestion du pcmcia :??:
n°523901
Klaimant
Posté le 19-07-2004 à 23:02:33  profilanswer
# Automatically generated by make menuconfig: don't edit
CONFIG_X86=y
# CONFIG_SBUS is not set
CONFIG_UID16=y
CONFIG_MODULES=y
CONFIG_KMOD=y
# CONFIG_M586TSC is not set
CONFIG_M586MMX=y
# CONFIG_MELAN is not set
CONFIG_X86_INVLPG=y
CONFIG_X86_XADD=y
CONFIG_X86_BSWAP=y
# CONFIG_RWSEM_GENERIC_SPINLOCK is not set
CONFIG_X86_L1_CACHE_SHIFT=5
CONFIG_X86_USE_STRING_486=y
CONFIG_X86_HAS_TSC=y
CONFIG_X86_GOOD_APIC=y
# CONFIG_X86_F00F_WORKS_OK is not set
CONFIG_X86_MCE=y
# CONFIG_TOSHIBA is not set
CONFIG_MICROCODE=m
# CONFIG_X86_MSR is not set
# CONFIG_X86_CPUID is not set
CONFIG_NOHIGHMEM=y
# CONFIG_HIGHMEM is not set
# CONFIG_MATH_EMULATION is not set
# CONFIG_MTRR is not set
# CONFIG_X86_UP_IOAPIC is not set
# CONFIG_X86_TSC_DISABLE is not set
CONFIG_X86_TSC=y
# General setup
CONFIG_NET=y
CONFIG_PCI=y
CONFIG_PCI_GOANY=y
CONFIG_PCI_BIOS=y
CONFIG_PCI_DIRECT=y
CONFIG_ISA=y
CONFIG_PCI_NAMES=y
# CONFIG_EISA is not set
CONFIG_HOTPLUG=y
# CONFIG_PCMCIA is not set
# CONFIG_HOTPLUG_PCI_COMPAQ is not set
# CONFIG_HOTPLUG_PCI_COMPAQ_NVRAM is not set
CONFIG_SYSVIPC=y
# CONFIG_BSD_PROCESS_ACCT is not set
CONFIG_SYSCTL=y
CONFIG_KCORE_ELF=y
# CONFIG_KCORE_AOUT is not set
CONFIG_BINFMT_AOUT=y
CONFIG_BINFMT_ELF=y
CONFIG_BINFMT_MISC=y
# CONFIG_OOM_KILLER is not set
# CONFIG_PM is not set
# CONFIG_APM is not set
# ACPI Support
# CONFIG_PARPORT is not set
# Plug and Play configuration
CONFIG_PNP=y
CONFIG_ISAPNP=y
# Block devices
CONFIG_BLK_DEV_FD=y
# CONFIG_BLK_DEV_XD is not set
# CONFIG_CISS_SCSI_TAPE is not set
# CONFIG_CISS_MONITOR_THREAD is not set
CONFIG_BLK_DEV_LOOP=m
# CONFIG_BLK_DEV_RAM is not set
# CONFIG_BLK_DEV_INITRD is not set
# CONFIG_BLK_STATS is not set
# CONFIG_BLK_DEV_MD is not set
# CONFIG_MD_LINEAR is not set
# CONFIG_MD_RAID0 is not set
# CONFIG_MD_RAID1 is not set
# CONFIG_MD_RAID5 is not set
# CONFIG_MD_MULTIPATH is not set
# CONFIG_BLK_DEV_LVM is not set
CONFIG_PACKET=y
# CONFIG_NETLINK_DEV is not set
CONFIG_NETFILTER=y
CONFIG_NETFILTER_DEBUG=y
CONFIG_FILTER=y
CONFIG_UNIX=y
CONFIG_INET=y
# CONFIG_INET_ECN is not set
#   IP: Netfilter Configuration
CONFIG_IP_NF_CONNTRACK=m
CONFIG_IP_NF_FTP=m
CONFIG_IP_NF_AMANDA=m
CONFIG_IP_NF_TFTP=m
CONFIG_IP_NF_IRC=m
CONFIG_IP_NF_QUEUE=m
CONFIG_IP_NF_IPTABLES=m
CONFIG_IP_NF_MATCH_LIMIT=m
CONFIG_IP_NF_MATCH_MAC=m
CONFIG_IP_NF_MATCH_PKTTYPE=m
CONFIG_IP_NF_MATCH_MARK=m
CONFIG_IP_NF_MATCH_MULTIPORT=m
CONFIG_IP_NF_MATCH_TOS=m
CONFIG_IP_NF_MATCH_RECENT=m
CONFIG_IP_NF_MATCH_ECN=m
CONFIG_IP_NF_MATCH_DSCP=m
CONFIG_IP_NF_MATCH_AH_ESP=m
CONFIG_IP_NF_MATCH_LENGTH=m
CONFIG_IP_NF_MATCH_TTL=m
CONFIG_IP_NF_MATCH_TCPMSS=m
CONFIG_IP_NF_MATCH_HELPER=m
CONFIG_IP_NF_MATCH_STATE=m
CONFIG_IP_NF_MATCH_CONNTRACK=m
CONFIG_IP_NF_MATCH_UNCLEAN=m
CONFIG_IP_NF_MATCH_OWNER=m
CONFIG_IP_NF_FILTER=m
CONFIG_IP_NF_TARGET_REJECT=m
CONFIG_IP_NF_TARGET_MIRROR=m
CONFIG_IP_NF_NAT=m
CONFIG_IP_NF_NAT_NEEDED=y
CONFIG_IP_NF_TARGET_MASQUERADE=m
CONFIG_IP_NF_TARGET_REDIRECT=m
CONFIG_IP_NF_NAT_AMANDA=m
CONFIG_IP_NF_NAT_LOCAL=y
CONFIG_IP_NF_NAT_SNMP_BASIC=m
CONFIG_IP_NF_NAT_IRC=m
CONFIG_IP_NF_NAT_FTP=m
CONFIG_IP_NF_NAT_TFTP=m
CONFIG_IP_NF_MANGLE=m
CONFIG_IP_NF_TARGET_TOS=m
CONFIG_IP_NF_TARGET_ECN=m
CONFIG_IP_NF_TARGET_DSCP=m
CONFIG_IP_NF_TARGET_MARK=m
CONFIG_IP_NF_TARGET_LOG=m
CONFIG_IP_NF_TARGET_ULOG=m
CONFIG_IP_NF_TARGET_TCPMSS=m
CONFIG_IP_NF_ARPTABLES=m
CONFIG_IP_NF_ARPFILTER=m
CONFIG_IP_NF_ARP_MANGLE=m
# CONFIG_IP_NF_COMPAT_IPCHAINS is not set
# CONFIG_IP_NF_COMPAT_IPFWADM is not set
#   IP: Virtual Server Configuration
# CONFIG_IP_VS is not set
# CONFIG_IPV6 is not set
CONFIG_KHTTPD=m
# CONFIG_IPX is not set
# CONFIG_ATALK is not set
# Appletalk devices
# CONFIG_LLC is not set
# Network testing
# Telephony Support
# CONFIG_PHONE_IXJ is not set
# CONFIG_PHONE_IXJ_PCMCIA is not set
# ATA/IDE/MFM/RLL support
CONFIG_IDE=y
# IDE, ATA and ATAPI Block devices
CONFIG_BLK_DEV_IDE=y
# CONFIG_BLK_DEV_HD_IDE is not set
CONFIG_BLK_DEV_IDEDISK=y
CONFIG_IDEDISK_MULTI_MODE=y
# CONFIG_IDEDISK_STROKE is not set
# CONFIG_BLK_DEV_IDECS is not set
CONFIG_BLK_DEV_IDECD=y
# CONFIG_BLK_DEV_IDETAPE is not set
# CONFIG_BLK_DEV_IDEFLOPPY is not set
# CONFIG_BLK_DEV_IDESCSI is not set
# CONFIG_IDE_TASK_IOCTL is not set
# CONFIG_BLK_DEV_CMD640 is not set
# CONFIG_BLK_DEV_CMD640_ENHANCED is not set
# CONFIG_BLK_DEV_ISAPNP is not set
CONFIG_BLK_DEV_IDEPCI=y
# CONFIG_BLK_DEV_GENERIC is not set
CONFIG_IDEPCI_SHARE_IRQ=y
CONFIG_BLK_DEV_IDEDMA_PCI=y
# CONFIG_BLK_DEV_OFFBOARD is not set
# CONFIG_BLK_DEV_IDEDMA_FORCED is not set
CONFIG_IDEDMA_PCI_AUTO=y
# CONFIG_IDEDMA_ONLYDISK is not set
CONFIG_BLK_DEV_IDEDMA=y
# CONFIG_IDEDMA_PCI_WIP is not set
# CONFIG_BLK_DEV_ADMA100 is not set
# CONFIG_BLK_DEV_AEC62XX is not set
# CONFIG_BLK_DEV_ALI15X3 is not set
# CONFIG_WDC_ALI15X3 is not set
# CONFIG_BLK_DEV_AMD74XX is not set
# CONFIG_AMD74XX_OVERRIDE is not set
# CONFIG_BLK_DEV_ATIIXP is not set
# CONFIG_BLK_DEV_CMD64X is not set
# CONFIG_BLK_DEV_TRIFLEX is not set
# CONFIG_BLK_DEV_CY82C693 is not set
# CONFIG_BLK_DEV_CS5530 is not set
# CONFIG_BLK_DEV_HPT34X is not set
# CONFIG_HPT34X_AUTODMA is not set
# CONFIG_BLK_DEV_HPT366 is not set
CONFIG_BLK_DEV_PIIX=y
# CONFIG_BLK_DEV_NS87415 is not set
# CONFIG_BLK_DEV_OPTI621 is not set
# CONFIG_BLK_DEV_PDC202XX_OLD is not set
# CONFIG_PDC202XX_BURST is not set
# CONFIG_BLK_DEV_PDC202XX_NEW is not set
# CONFIG_BLK_DEV_RZ1000 is not set
# CONFIG_BLK_DEV_SC1200 is not set
# CONFIG_BLK_DEV_SVWKS is not set
# CONFIG_BLK_DEV_SIIMAGE is not set
# CONFIG_BLK_DEV_SIS5513 is not set
# CONFIG_BLK_DEV_SLC90E66 is not set
# CONFIG_BLK_DEV_TRM290 is not set
# CONFIG_BLK_DEV_VIA82CXXX is not set
# CONFIG_IDE_CHIPSETS is not set
CONFIG_IDEDMA_AUTO=y
# CONFIG_IDEDMA_IVB is not set
# CONFIG_DMA_NONPCI is not set
# CONFIG_BLK_DEV_ATARAID is not set
# CONFIG_BLK_DEV_ATARAID_PDC is not set
# CONFIG_BLK_DEV_ATARAID_HPT is not set
# CONFIG_BLK_DEV_ATARAID_MEDLEY is not set
# CONFIG_BLK_DEV_ATARAID_SII is not set
# SCSI support
CONFIG_SCSI=m
CONFIG_BLK_DEV_SD=m
CONFIG_SD_EXTRA_DEVS=40
# CONFIG_CHR_DEV_ST is not set
# CONFIG_CHR_DEV_OSST is not set
# CONFIG_BLK_DEV_SR is not set
# CONFIG_CHR_DEV_SG is not set
CONFIG_SCSI_DEBUG_QUEUES=y
CONFIG_SCSI_MULTI_LUN=y
CONFIG_SCSI_CONSTANTS=y
# CONFIG_SCSI_LOGGING is not set
# SCSI low-level drivers
# CONFIG_BLK_DEV_3W_XXXX_RAID is not set
# CONFIG_SCSI_7000FASST is not set
# CONFIG_SCSI_ACARD is not set
# CONFIG_SCSI_AHA152X is not set
# CONFIG_SCSI_AHA1542 is not set
# CONFIG_SCSI_AHA1740 is not set
# CONFIG_SCSI_AACRAID is not set
# CONFIG_SCSI_AIC7XXX is not set
# CONFIG_SCSI_AIC79XX is not set
# CONFIG_SCSI_AIC7XXX_OLD is not set
# CONFIG_SCSI_DPT_I2O is not set
# CONFIG_SCSI_ADVANSYS is not set
# CONFIG_SCSI_IN2000 is not set
# CONFIG_SCSI_AM53C974 is not set
# CONFIG_SCSI_MEGARAID is not set
# CONFIG_SCSI_MEGARAID2 is not set
# CONFIG_SCSI_BUSLOGIC is not set
# CONFIG_SCSI_CPQFCTS is not set
# CONFIG_SCSI_DMX3191D is not set
# CONFIG_SCSI_DTC3280 is not set
# CONFIG_SCSI_EATA is not set
# CONFIG_SCSI_EATA_DMA is not set
# CONFIG_SCSI_EATA_PIO is not set
# CONFIG_SCSI_FUTURE_DOMAIN is not set
# CONFIG_SCSI_GDTH is not set
# CONFIG_SCSI_GENERIC_NCR5380 is not set
# CONFIG_SCSI_IPS is not set
# CONFIG_SCSI_INITIO is not set
# CONFIG_SCSI_INIA100 is not set
# CONFIG_SCSI_NCR53C406A is not set
# CONFIG_SCSI_NCR53C7xx is not set
# CONFIG_SCSI_SYM53C8XX_2 is not set
# CONFIG_SCSI_NCR53C8XX is not set
CONFIG_SCSI_SYM53C8XX=m
CONFIG_SCSI_NCR53C8XX_DEFAULT_TAGS=4
CONFIG_SCSI_NCR53C8XX_MAX_TAGS=32
CONFIG_SCSI_NCR53C8XX_SYNC=20
# CONFIG_SCSI_NCR53C8XX_PROFILE is not set
# CONFIG_SCSI_NCR53C8XX_IOMAPPED is not set
# CONFIG_SCSI_NCR53C8XX_PQS_PDS is not set
# CONFIG_SCSI_NCR53C8XX_SYMBIOS_COMPAT is not set
# CONFIG_SCSI_PAS16 is not set
# CONFIG_SCSI_PCI2000 is not set
# CONFIG_SCSI_PCI2220I is not set
# CONFIG_SCSI_PSI240I is not set
# CONFIG_SCSI_QLOGIC_FAS is not set
# CONFIG_SCSI_QLOGIC_ISP is not set
# CONFIG_SCSI_QLOGIC_FC is not set
# CONFIG_SCSI_QLOGIC_1280 is not set
# CONFIG_SCSI_SEAGATE is not set
# CONFIG_SCSI_SIM710 is not set
# CONFIG_SCSI_SYM53C416 is not set
# CONFIG_SCSI_DC390T is not set
# CONFIG_SCSI_T128 is not set
# CONFIG_SCSI_U14_34F is not set
# CONFIG_SCSI_ULTRASTOR is not set
# CONFIG_SCSI_NSP32 is not set
# CONFIG_SCSI_DEBUG is not set
# CONFIG_FUSION is not set
# CONFIG_FUSION_BOOT is not set
# CONFIG_FUSION_ISENSE is not set
# CONFIG_FUSION_CTL is not set
# CONFIG_FUSION_LAN is not set
# IEEE 1394 (FireWire) support (EXPERIMENTAL)
# CONFIG_I2O_PCI is not set
# CONFIG_I2O_BLOCK is not set
# CONFIG_I2O_LAN is not set
# CONFIG_I2O_SCSI is not set
# CONFIG_I2O_PROC is not set
# Network device support
CONFIG_NETDEVICES=y
# ARCnet devices
CONFIG_DUMMY=m
# CONFIG_NET_SB1000 is not set
# CONFIG_SUNLANCE is not set
# CONFIG_SUNBMAC is not set
# CONFIG_SUNQE is not set
# CONFIG_EL1 is not set
# CONFIG_EL2 is not set
# CONFIG_ELPLUS is not set
# CONFIG_EL16 is not set
CONFIG_EL3=m
# CONFIG_3C515 is not set
# CONFIG_ELMC is not set
# CONFIG_ELMC_II is not set
# CONFIG_VORTEX is not set
# CONFIG_LANCE is not set
# CONFIG_NET_VENDOR_SMC is not set
# CONFIG_NET_VENDOR_RACAL is not set
# CONFIG_AT1700 is not set
# CONFIG_DEPCA is not set
# CONFIG_NET_ISA is not set
CONFIG_NET_PCI=y
# CONFIG_PCNET32 is not set
# CONFIG_AMD8111_ETH is not set
# CONFIG_ADAPTEC_STARFIRE is not set
# CONFIG_AC3200 is not set
# CONFIG_APRICOT is not set
# CONFIG_B44 is not set
# CONFIG_CS89x0 is not set
# CONFIG_TULIP is not set
# CONFIG_DE4X5 is not set
# CONFIG_DGRS is not set
# CONFIG_DM9102 is not set
# CONFIG_EEPRO100 is not set
# CONFIG_EEPRO100_PIO is not set
# CONFIG_E100 is not set
# CONFIG_LNE390 is not set
# CONFIG_FEALNX is not set
# CONFIG_NATSEMI is not set
# CONFIG_NE2K_PCI is not set
# CONFIG_FORCEDETH is not set
# CONFIG_NE3210 is not set
# CONFIG_ES3210 is not set
# CONFIG_8139CP is not set
CONFIG_8139TOO=m
# CONFIG_8139TOO_PIO is not set
CONFIG_8139TOO_TUNE_TWISTER=y
CONFIG_8139TOO_8129=y
# CONFIG_8139_OLD_RX_RESET is not set
# CONFIG_SIS900 is not set
# CONFIG_EPIC100 is not set
# CONFIG_SUNDANCE is not set
# CONFIG_SUNDANCE_MMIO is not set
# CONFIG_TLAN is not set
# CONFIG_VIA_RHINE is not set
# CONFIG_VIA_RHINE_MMIO is not set
# CONFIG_WINBOND_840 is not set
# CONFIG_NET_POCKET is not set
# CONFIG_MYRI_SBUS is not set
CONFIG_PPP=m
CONFIG_PPP_MULTILINK=y
CONFIG_PPP_FILTER=y
CONFIG_PPP_ASYNC=m
CONFIG_PPP_SYNC_TTY=m
CONFIG_PPP_DEFLATE=m
CONFIG_PPP_BSDCOMP=m
CONFIG_PPPOE=m
# CONFIG_NET_FC is not set
# CONFIG_RCPCI is not set
# Wan interfaces
# Amateur Radio support
# IrDA (infrared) support
# CONFIG_IRDA is not set
# ISDN subsystem
# Old CD-ROM drivers (not SCSI, not IDE)
# CONFIG_CD_NO_IDESCSI is not set
# Input core support
# CONFIG_INPUT is not set
# CONFIG_INPUT_KEYBDEV is not set
# CONFIG_INPUT_MOUSEDEV is not set
# CONFIG_INPUT_UINPUT is not set
# Character devices
CONFIG_VT=y
CONFIG_VT_CONSOLE=y
CONFIG_SERIAL=y
# CONFIG_SERIAL_CONSOLE is not set
# CONFIG_SERIAL_EXTENDED is not set
CONFIG_UNIX98_PTYS=y
CONFIG_UNIX98_PTY_COUNT=256
# I2C support
# Mice
# CONFIG_BUSMOUSE is not set
CONFIG_MOUSE=y
CONFIG_PSMOUSE=y
# CONFIG_82C710_MOUSE is not set
# CONFIG_PC110_PAD is not set
# CONFIG_MK712_MOUSE is not set
# Joysticks
# CONFIG_INPUT_GAMEPORT is not set
# CONFIG_IPMI_PANIC_EVENT is not set
# CONFIG_IPMI_DEVICE_INTERFACE is not set
# CONFIG_IPMI_KCS is not set
# CONFIG_IPMI_WATCHDOG is not set
# Watchdog Cards
# CONFIG_SCx200_GPIO is not set
# CONFIG_AMD_RNG is not set
# CONFIG_INTEL_RNG is not set
# CONFIG_AMD_PM768 is not set
# CONFIG_NVRAM is not set
# CONFIG_RTC is not set
# CONFIG_DTLK is not set
CONFIG_AGP=y
CONFIG_AGP_INTEL=y
CONFIG_AGP_I810=y
CONFIG_AGP_VIA=y
CONFIG_AGP_AMD=y
# CONFIG_AGP_AMD_K8 is not set
CONFIG_AGP_SIS=y
CONFIG_AGP_ALI=y
# CONFIG_AGP_SWORKS is not set
# CONFIG_AGP_NVIDIA is not set
# CONFIG_AGP_ATI is not set
# Direct Rendering Manager (XFree86 DRI support)
CONFIG_DRM=y
# CONFIG_DRM_OLD is not set
CONFIG_DRM_NEW=y
CONFIG_DRM_TDFX=y
# CONFIG_DRM_GAMMA is not set
# CONFIG_DRM_R128 is not set
CONFIG_DRM_RADEON=y
CONFIG_DRM_I810=y
CONFIG_DRM_I810_XFREE_41=y
# CONFIG_DRM_I830 is not set
# CONFIG_DRM_MGA is not set
# CONFIG_DRM_SIS is not set
# CONFIG_OBMOUSE is not set
# File systems
# CONFIG_QFMT_V2 is not set
CONFIG_AUTOFS4_FS=y
# CONFIG_REISERFS_CHECK is not set
# CONFIG_REISERFS_PROC_INFO is not set
# CONFIG_ADFS_FS_RW is not set
# CONFIG_BEFS_DEBUG is not set
CONFIG_EXT3_FS=m
CONFIG_JBD=m
# CONFIG_JBD_DEBUG is not set
CONFIG_FAT_FS=m
CONFIG_MSDOS_FS=m
# CONFIG_UMSDOS_FS is not set
CONFIG_VFAT_FS=m
# CONFIG_JFFS_FS is not set
# CONFIG_JFFS2_FS is not set
CONFIG_TMPFS=y
CONFIG_RAMFS=y
CONFIG_ISO9660_FS=y
CONFIG_JOLIET=y
# CONFIG_JFS_DEBUG is not set
# CONFIG_JFS_STATISTICS is not set
# CONFIG_NTFS_RW is not set
CONFIG_PROC_FS=y
# CONFIG_DEVFS_MOUNT is not set
# CONFIG_DEVFS_DEBUG is not set
CONFIG_DEVPTS_FS=y
# CONFIG_QNX4FS_RW is not set
CONFIG_EXT2_FS=y
# CONFIG_UDF_RW is not set
# CONFIG_UFS_FS_WRITE is not set
# CONFIG_XFS_QUOTA is not set
# CONFIG_XFS_RT is not set
# CONFIG_XFS_TRACE is not set
# CONFIG_XFS_DEBUG is not set
# CONFIG_INTERMEZZO_FS is not set
# CONFIG_NFS_V3 is not set
# CONFIG_NFS_DIRECTIO is not set
# CONFIG_ROOT_NFS is not set
# CONFIG_NFSD_V3 is not set
# CONFIG_NFSD_TCP is not set
# CONFIG_SUNRPC is not set
# CONFIG_LOCKD is not set
CONFIG_SMB_FS=m
# CONFIG_SMB_NLS_DEFAULT is not set
# CONFIG_SMB_UNIX is not set
# CONFIG_NCPFS_PACKET_SIGNING is not set
# CONFIG_NCPFS_IOCTL_LOCKING is not set
# CONFIG_NCPFS_STRONG is not set
# CONFIG_NCPFS_NFS_NS is not set
# CONFIG_NCPFS_OS2_NS is not set
# CONFIG_NCPFS_SMALLDOS is not set
# CONFIG_NCPFS_NLS is not set
# CONFIG_NCPFS_EXTRAS is not set
# CONFIG_ZISOFS_FS is not set
# Partition Types
CONFIG_SMB_NLS=y
CONFIG_NLS=y
CONFIG_NLS_DEFAULT="iso8859-1"
# CONFIG_NLS_CODEPAGE_850 is not set
# CONFIG_NLS_ISO8859_15 is not set
# CONFIG_NLS_UTF8 is not set
# Console drivers
CONFIG_VIDEO_SELECT=y
# Frame-buffer support
CONFIG_FB=y
# CONFIG_FB_CLGEN is not set
# CONFIG_FB_PM3 is not set
CONFIG_FB_VESA=y
CONFIG_FB_VGA16=m
# CONFIG_FB_INTEL is not set
# CONFIG_FB_IT8181 is not set
CONFIG_FBCON_ADVANCED=y
# CONFIG_FBCON_MFB is not set
CONFIG_FBCON_CFB2=m
CONFIG_FBCON_CFB4=m
CONFIG_FBCON_CFB8=y
CONFIG_FBCON_CFB16=y
# CONFIG_FBCON_CFB24 is not set
# CONFIG_FBCON_CFB32 is not set
# CONFIG_FBCON_AFB is not set
# CONFIG_FBCON_ILBM is not set
# CONFIG_FBCON_IPLAN2P2 is not set
# CONFIG_FBCON_IPLAN2P4 is not set
# CONFIG_FBCON_IPLAN2P8 is not set
# CONFIG_FBCON_MAC is not set
CONFIG_FBCON_VGA_PLANES=m
# CONFIG_FBCON_VGA is not set
# CONFIG_FBCON_HGA is not set
CONFIG_FBCON_FONTWIDTH8_ONLY=y
CONFIG_FBCON_FONTS=y
CONFIG_FONT_8x8=y
CONFIG_FONT_8x16=y
# CONFIG_FONT_SUN8x16 is not set
# CONFIG_FONT_PEARL_8x8 is not set
# CONFIG_FONT_ACORN_8x8 is not set
# Sound
# CONFIG_SOUND is not set
# USB support
CONFIG_USB=y
CONFIG_USB_DEBUG=y
CONFIG_USB_DEVICEFS=y
# CONFIG_USB_BANDWIDTH is not set
# CONFIG_USB_EHCI_HCD is not set
CONFIG_USB_UHCI_ALT=y
CONFIG_USB_OHCI=m
# CONFIG_USB_SL811HS_ALT is not set
# CONFIG_USB_SL811HS is not set
# CONFIG_USB_AUDIO is not set
# CONFIG_USB_EMI26 is not set
# CONFIG_USB_BLUETOOTH is not set
# CONFIG_USB_MIDI is not set
CONFIG_USB_STORAGE=m
# CONFIG_USB_STORAGE_DEBUG is not set
# CONFIG_USB_STORAGE_DATAFAB is not set
# CONFIG_USB_STORAGE_FREECOM is not set
# CONFIG_USB_STORAGE_ISD200 is not set
# CONFIG_USB_STORAGE_DPCM is not set
# CONFIG_USB_STORAGE_HP8200e is not set
# CONFIG_USB_STORAGE_SDDR09 is not set
# CONFIG_USB_STORAGE_SDDR55 is not set
# CONFIG_USB_STORAGE_JUMPSHOT is not set
# CONFIG_USB_ACM is not set
CONFIG_USB_PRINTER=m
# CONFIG_USB_HID is not set
# CONFIG_USB_HIDINPUT is not set
# CONFIG_USB_HIDDEV is not set
# CONFIG_USB_KBD is not set
# CONFIG_USB_MOUSE is not set
# CONFIG_USB_AIPTEK is not set
# CONFIG_USB_WACOM is not set
# CONFIG_USB_KBTAB is not set
# CONFIG_USB_POWERMATE is not set
# CONFIG_USB_DC2XX is not set
# CONFIG_USB_MDC800 is not set
# CONFIG_USB_SCANNER is not set
# CONFIG_USB_MICROTEK is not set
# CONFIG_USB_HPUSBSCSI is not set
# CONFIG_USB_PEGASUS is not set
# CONFIG_USB_RTL8150 is not set
# CONFIG_USB_KAWETH is not set
# CONFIG_USB_CATC is not set
# CONFIG_USB_CDCETHER is not set
# CONFIG_USB_USBNET is not set
# CONFIG_USB_USS720 is not set
# USB Serial Converter support
# CONFIG_USB_SERIAL is not set
# CONFIG_USB_RIO500 is not set
# CONFIG_USB_AUERSWALD is not set
# CONFIG_USB_TIGL is not set
# CONFIG_USB_BRLVGER is not set
# CONFIG_USB_LCD is not set
# Support for USB gadgets
# Bluetooth support
# CONFIG_BLUEZ is not set
# Kernel hacking
CONFIG_LOG_BUF_SHIFT=0
# Library routines
CONFIG_CRC32=y
CONFIG_ZLIB_INFLATE=m
CONFIG_ZLIB_DEFLATE=m
n°523902
pinguin007
a npe error
Posté le 19-07-2004 à 23:06:20  profilanswer
danke je vais voir ca, chez toi ca met combien de temps pour compiler sur le 166 :??:
n°523906
Klaimant
Posté le 19-07-2004 à 23:12:41  profilanswer
1 heure (mais j'ai 128 de ram)
n°523909
pinguin007
a npe error
Posté le 19-07-2004 à 23:14:33  profilanswer
humph... wouais donc ca va metre du temps comme d'hab quoi ...
n°523914
Klaimant
Posté le 19-07-2004 à 23:17:20  profilanswer
Recompile la nuit, au pire tu peux mettre un 2.4.18 par apt ;)
apt-get install kernel-image-2.4.18-1-386 kernel-pcmcia-modules-2.4.18-1-386 kernel-source-2.4.18
n°523921
pinguin007
a npe error
Posté le 19-07-2004 à 23:20:51  profilanswer
bah tant qu'a faire autant prendre un 2.6 nan :??:
n°523922
Klaimant
Posté le 19-07-2004 à 23:21:14  profilanswer
en sid alors [:ddr555]
n°523925
pinguin007
a npe error
Posté le 19-07-2004 à 23:21:55  profilanswer
ah ?
en sarge ca merde un 2.6 ??
n°523926
Klaimant
Posté le 19-07-2004 à 23:22:23  profilanswer
non pour installer les binaires je parle ;)
n°523927
Klaimant
Posté le 19-07-2004 à 23:23:33  profilanswer
au passage, c'est un fichier de config de 2.4 que je t'ai filé ;)
n°523928
pinguin007
a npe error
Posté le 19-07-2004 à 23:25:31  profilanswer
han :/
bon ben goto 2.4 alors :)
donc tu me conseil un 2.4.18 :??:
n°523932
Klaimant
Posté le 19-07-2004 à 23:27:01  profilanswer
han :/
non pas du tout ;)
mais il y a un 2.4.18 de debian déjà tout compilé ;)
n°523933
pinguin007
a npe error
Posté le 19-07-2004 à 23:28:11  profilanswer
mais justement si il est déja tout compilé comment ca ce passe pour le .config ??
je fais mon make menuconfig, et aprés il se contentera juste de garder les fichiers qui coorespondent aux options selectionée :??:
n°523935
Klaimant
Posté le 19-07-2004 à 23:29:18  profilanswer
non tu configures rien, c'est déjà compilé, pas spécifiquement pour ta machine, mais très largement pour fonctionner avec beaucoup de matériel sans avoir à connaitre la recompilation de noyau
n°523936
pinguin007
a npe error
Posté le 19-07-2004 à 23:31:18  profilanswer
oki donc a ce moment là, j'ai plus besoin de ton .config :??:
par contre et ce que tu sais si par defaut ce 2.4.18 supporte l'apm :??:
n°523937
Klaimant
Posté le 19-07-2004 à 23:32:45  profilanswer
non ;)
mais tu es pas loin, mais il doit te manquer des supports comme le dvfs proc ou de l'extend
n°523938
Klaimant
Posté le 19-07-2004 à 23:34:38  profilanswer
CONFIG_PROC_FS=y
CONFIG_PROC_KCORE=y
CONFIG_SYSFS=y
Par exemple celui la :O
Message édité par Klaimant le 19-07-2004 à 23:34:50
n°523941
pinguin007
a npe error
Posté le 19-07-2004 à 23:36:10  profilanswer
:o le saloupio qui c'est pas set :o maichant  [:brainwasher]
merci ^^
Message édité par pinguin007 le 19-07-2004 à 23:36:19
n°523942
Klaimant
Posté le 19-07-2004 à 23:36:34  profilanswer
merci ^^
Je suis sur que ca marchera ta compilation après ;)
n°523945
pinguin007
a npe error
Posté le 19-07-2004 à 23:39:31  profilanswer
rah je me tate un max, bon je viens de voir que j'ai une image d'un 2.6.6-1 donc je pense que je vais installer ca, et puis si l'apm est pas dedans je relance la compil en rajoutant le truc qui manque :)
n°523946
Klaimant
Posté le 19-07-2004 à 23:42:53  profilanswer
comme tu veux
n°523953
pinguin007
a npe error
Posté le 19-07-2004 à 23:51:07  profilanswer
disons que j'en ai un peu marre d'avoir un portable branché sur le secteur qui passe sont temps à compiler :D
n°523965
pinguin007
a npe error
Posté le 20-07-2004 à 00:14:21  profilanswer
en tous cas merci ^^
  Installation
[resolu][kernel]TTY possible mais pas de terminal possible sous X?Kernel 2.6 : no module ataraid found, aborting...
question patch kernel... (was: Pb urpmi kernel 2.6)Souci de config sous PhpMyAdmin
Installer une Debian Woody avec un kernel 2.6.xConfig de Postfix
pb de compilation du kernel 2.6.7 sous debian.Config minimale pour Mac OS X 10.1 ?
kernel smp ?? mdk 10.0 probleme graphique atimount --bind help !!!
Plus de sujets relatifs à : [kernel 2.6.7] VFS unable to mount root fs => .config inside
