5532 connectés
  Linux et OS Alternatifs
  Installation
  impossible de monter un systeme de fichier
n°1491502
celiria
Posté le 29-04-2024 à 21:42:15  profilanswer
Bonjour à tous,
Je me trouve un soucis que je n'arrive pas résoudre.
J'ai acheté 3hdd 12To pour faire un raid 5 (S.M.A.R.T test ok)
Après avoir fait le RAID5, je n'arrive pas a créer et monter un système de fichier. Quand je selectionne le raid 5 fraichement monter, j'ai ce message d'erreur:
Code :
  1. Failed to execute command 'export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; export LANGUAGE=; omv-salt deploy run --no-color fstab 2>&1' with exit code '1': debian:
  2. ----------
  3.           ID: create_filesystem_mountpoint_a9ad836b-80f9-43fa-8bfa-f5e014100742
  4.     Function: file.accumulated
  5.       Result: True
  6.      Comment: Accumulator create_filesystem_mountpoint_a9ad836b-80f9-43fa-8bfa-f5e014100742 for file /etc/fstab was charged by text
  7.      Started: 20:35:46.417846
  8.     Duration: 0.654 ms
  9.      Changes:
  10. ----------
  11.           ID: mount_filesystem_mountpoint_a9ad836b-80f9-43fa-8bfa-f5e014100742
  12.     Function: mount.mounted
  13.         Name: /srv/dev-disk-by-uuid-7e5def3d-85d2-446b-8eb0-d52cf132273d
  14.       Result: True
  15.      Comment: Target was already mounted
  16.      Started: 20:35:46.419047
  17.     Duration: 166.766 ms
  18.      Changes:
  19. ----------
  20.           ID: create_filesystem_mountpoint_1a1943f0-b007-4663-a5f5-af485c1f41ae
  21.     Function: file.accumulated
  22.       Result: True
  23.      Comment: Accumulator create_filesystem_mountpoint_1a1943f0-b007-4663-a5f5-af485c1f41ae for file /etc/fstab was charged by text
  24.      Started: 20:35:46.586195
  25.     Duration: 2.838 ms
  26.      Changes:
  27. ----------
  28.           ID: mount_filesystem_mountpoint_1a1943f0-b007-4663-a5f5-af485c1f41ae
  29.     Function: mount.mounted
  30.         Name: /srv/dev-disk-by-uuid-684201C542019948
  31.       Result: False
  32.      Comment: ntfs-3g: Failed to access volume '/dev/disk/by-uuid/684201C542019948': No such file or directory
  33.               ntfs-3g 2022.10.3 integrated FUSE 28 - Third Generation NTFS Driver
  34.                 Configuration type 7, XATTRS are on, POSIX ACLS are on
  35.               Copyright (C) 2005-2007 Yura Pakhuchiy
  36.               Copyright (C) 2006-2009 Szabolcs Szakacsits
  37.               Copyright (C) 2007-2022 Jean-Pierre Andre
  38.               Copyright (C) 2009-2020 Erik Larsson
  39.               Usage:    ntfs-3g [-o option[,...]] <device|image_file> <mount_point>
  40.               Options:  ro (read-only mount), windows_names, uid=, gid=,
  41.                         umask=, fmask=, dmask=, streams_interface=.
  42.                         Please see the details in the manual (type: man ntfs-3g).
  43.               Example: ntfs-3g /dev/sda1 /mnt/windows
  44.               Plugin path: /usr/lib/x86_64-linux-gnu/ntfs-3g
  45.               News, support and information:  https://github.com/tuxera/ntfs-3g/
  46.      Started: 20:35:46.589369
  47.     Duration: 43.672 ms
  48.      Changes:
  49. ----------
  50.           ID: create_filesystem_mountpoint_86be2ba8-f14e-4024-bcca-fa68e4767881
  51.     Function: file.accumulated
  52.       Result: True
  53.      Comment: Accumulator create_filesystem_mountpoint_86be2ba8-f14e-4024-bcca-fa68e4767881 for file /etc/fstab was charged by text
  54.      Started: 20:35:46.633394
  55.     Duration: 2.299 ms
  56.      Changes:
  57. ----------
  58.           ID: mount_filesystem_mountpoint_86be2ba8-f14e-4024-bcca-fa68e4767881
  59.     Function: mount.mounted
  60.         Name: /srv/dev-disk-by-uuid-20b435f7-8335-4b9f-8a84-e74770784626
  61.       Result: True
  62.      Comment: Target was successfully mounted
  63.      Started: 20:35:46.636010
  64.     Duration: 698.989 ms
  65.      Changes:
  66.               ----------
  67.               mount:
  68.                   True
  69. ----------
  70.           ID: append_fstab_entries
  71.     Function: file.blockreplace
  72.         Name: /etc/fstab
  73.       Result: True
  74.      Comment: Changes were made
  75.      Started: 20:35:47.335611
  76.     Duration: 4.83 ms
  77.      Changes:
  78.               ----------
  79.               diff:
  80.                   ---
  81.                   +++
  82.                   @@ -15,5 +15,5 @@
  83.                    # >>> [openmediavault]
  84.                    /dev/disk/by-uuid/7e5def3d-85d2-446b-8eb0-d52cf132273d  /srv/dev-disk-by-uuid-7e5def3d-85d2-446b-8eb0-d52cf132273d xfs defaults,nofail,usrquota,grpquota,inode64 0 2
  85.                    /dev/disk/by-uuid/684201C542019948  /srv/dev-disk-by-uuid-684201C542019948 ntfs defaults,nofail,big_writes 0 2
  86.                   -/dev/disk/by-uuid/bd6fd4d3-3cf4-451f-a45f-8f5c4322ca13  /srv/dev-disk-by-uuid-bd6fd4d3-3cf4-451f-a45f-8f5c4322ca13 xfs defaults,nofail,usrquota,grpquota,inode64 0 2
  87.                   +/dev/disk/by-uuid/20b435f7-8335-4b9f-8a84-e74770784626  /srv/dev-disk-by-uuid-20b435f7-8335-4b9f-8a84-e74770784626 xfs defaults,nofail,usrquota,grpquota,inode64 0 2
  88.                    # <<< [openmediavault]
  89. ----------
  90.           ID: fstab_systemctl_daemon_reload
  91.     Function: module.run
  92.       Result: True
  93.      Comment: service.systemctl_reload: True
  94.      Started: 20:35:47.341200
  95.     Duration: 367.931 ms
  96.      Changes:
  97.               ----------
  98.               service.systemctl_reload:
  99.                   True
  100. Summary for debian
  101. ------------
  102. Succeeded: 7 (changed=3)
  103. Failed:    1
  104. ------------
  105. Total states run:     8
  106. Total run time:   1.288 s
  107. [ERROR   ] Command 'mount' failed with return code: 11
  108. [ERROR   ] stderr: ntfs-3g: Failed to access volume '/dev/disk/by-uuid/684201C542019948': No such file or directory
  109. ntfs-3g 2022.10.3 integrated FUSE 28 - Third Generation NTFS Driver
  110.  Configuration type 7, XATTRS are on, POSIX ACLS are on
  111. Copyright (C) 2005-2007 Yura Pakhuchiy
  112. Copyright (C) 2006-2009 Szabolcs Szakacsits
  113. Copyright (C) 2007-2022 Jean-Pierre Andre
  114. Copyright (C) 2009-2020 Erik Larsson
  115. Usage:    ntfs-3g [-o option[,...]] <device|image_file> <mount_point>
  116. Options:  ro (read-only mount), windows_names, uid=, gid=,
  117.           umask=, fmask=, dmask=, streams_interface=.
  118.           Please see the details in the manual (type: man ntfs-3g).
  119. Example: ntfs-3g /dev/sda1 /mnt/windows
  120. Plugin path: /usr/lib/x86_64-linux-gnu/ntfs-3g
  121. News, support and information:  https://github.com/tuxera/ntfs-3g/
  122. [ERROR   ] retcode: 11
  123. [ERROR   ] ntfs-3g: Failed to access volume '/dev/disk/by-uuid/684201C542019948': No such file or directory
  124. ntfs-3g 2022.10.3 integrated FUSE 28 - Third Generation NTFS Driver
  125.  Configuration type 7, XATTRS are on, POSIX ACLS are on
  126. Copyright (C) 2005-2007 Yura Pakhuchiy
  127. Copyright (C) 2006-2009 Szabolcs Szakacsits
  128. Copyright (C) 2007-2022 Jean-Pierre Andre
  129. Copyright (C) 2009-2020 Erik Larsson
  130. Usage:    ntfs-3g [-o option[,...]] <device|image_file> <mount_point>
  131. Options:  ro (read-only mount), windows_names, uid=, gid=,
  132.           umask=, fmask=, dmask=, streams_interface=.
  133.           Please see the details in the manual (type: man ntfs-3g).
  134. Example: ntfs-3g /dev/sda1 /mnt/windows
  135. Plugin path: /usr/lib/x86_64-linux-gnu/ntfs-3g
  136. News, support and information:  https://github.com/tuxera/ntfs-3g/
  137. OMV\ExecException: Failed to execute command 'export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; export LANGUAGE=; omv-salt deploy run --no-color fstab 2>&1' with exit code '1': debian:
  138. ----------
  139.           ID: create_filesystem_mountpoint_a9ad836b-80f9-43fa-8bfa-f5e014100742
  140.     Function: file.accumulated
  141.       Result: True
  142.      Comment: Accumulator create_filesystem_mountpoint_a9ad836b-80f9-43fa-8bfa-f5e014100742 for file /etc/fstab was charged by text
  143.      Started: 20:35:46.417846
  144.     Duration: 0.654 ms
  145.      Changes:
  146. ----------
  147.           ID: mount_filesystem_mountpoint_a9ad836b-80f9-43fa-8bfa-f5e014100742
  148.     Function: mount.mounted
  149.         Name: /srv/dev-disk-by-uuid-7e5def3d-85d2-446b-8eb0-d52cf132273d
  150.       Result: True
  151.      Comment: Target was already mounted
  152.      Started: 20:35:46.419047
  153.     Duration: 166.766 ms
  154.      Changes:
  155. ----------
  156.           ID: create_filesystem_mountpoint_1a1943f0-b007-4663-a5f5-af485c1f41ae
  157.     Function: file.accumulated
  158.       Result: True
  159.      Comment: Accumulator create_filesystem_mountpoint_1a1943f0-b007-4663-a5f5-af485c1f41ae for file /etc/fstab was charged by text
  160.      Started: 20:35:46.586195
  161.     Duration: 2.838 ms
  162.      Changes:
  163. ----------
  164.           ID: mount_filesystem_mountpoint_1a1943f0-b007-4663-a5f5-af485c1f41ae
  165.     Function: mount.mounted
  166.         Name: /srv/dev-disk-by-uuid-684201C542019948
  167.       Result: False
  168.      Comment: ntfs-3g: Failed to access volume '/dev/disk/by-uuid/684201C542019948': No such file or directory
  169.               ntfs-3g 2022.10.3 integrated FUSE 28 - Third Generation NTFS Driver
  170.                 Configuration type 7, XATTRS are on, POSIX ACLS are on
  171.               Copyright (C) 2005-2007 Yura Pakhuchiy
  172.               Copyright (C) 2006-2009 Szabolcs Szakacsits
  173.               Copyright (C) 2007-2022 Jean-Pierre Andre
  174.               Copyright (C) 2009-2020 Erik Larsson
  175.               Usage:    ntfs-3g [-o option[,...]] <device|image_file> <mount_point>
  176.               Options:  ro (read-only mount), windows_names, uid=, gid=,
  177.                         umask=, fmask=, dmask=, streams_interface=.
  178.                         Please see the details in the manual (type: man ntfs-3g).
  179.               Example: ntfs-3g /dev/sda1 /mnt/windows
  180.               Plugin path: /usr/lib/x86_64-linux-gnu/ntfs-3g
  181.               News, support and information:  https://github.com/tuxera/ntfs-3g/
  182.      Started: 20:35:46.589369
  183.     Duration: 43.672 ms
  184.      Changes:
  185. ----------
  186.           ID: create_filesystem_mountpoint_86be2ba8-f14e-4024-bcca-fa68e4767881
  187.     Function: file.accumulated
  188.       Result: True
  189.      Comment: Accumulator create_filesystem_mountpoint_86be2ba8-f14e-4024-bcca-fa68e4767881 for file /etc/fstab was charged by text
  190.      Started: 20:35:46.633394
  191.     Duration: 2.299 ms
  192.      Changes:
  193. ----------
  194.           ID: mount_filesystem_mountpoint_86be2ba8-f14e-4024-bcca-fa68e4767881
  195.     Function: mount.mounted
  196.         Name: /srv/dev-disk-by-uuid-20b435f7-8335-4b9f-8a84-e74770784626
  197.       Result: True
  198.      Comment: Target was successfully mounted
  199.      Started: 20:35:46.636010
  200.     Duration: 698.989 ms
  201.      Changes:
  202.               ----------
  203.               mount:
  204.                   True
  205. ----------
  206.           ID: append_fstab_entries
  207.     Function: file.blockreplace
  208.         Name: /etc/fstab
  209.       Result: True
  210.      Comment: Changes were made
  211.      Started: 20:35:47.335611
  212.     Duration: 4.83 ms
  213.      Changes:
  214.               ----------
  215.               diff:
  216.                   ---
  217.                   +++
  218.                   @@ -15,5 +15,5 @@
  219.                    # >>> [openmediavault]
  220.                    /dev/disk/by-uuid/7e5def3d-85d2-446b-8eb0-d52cf132273d  /srv/dev-disk-by-uuid-7e5def3d-85d2-446b-8eb0-d52cf132273d xfs defaults,nofail,usrquota,grpquota,inode64 0 2
  221.                    /dev/disk/by-uuid/684201C542019948  /srv/dev-disk-by-uuid-684201C542019948 ntfs defaults,nofail,big_writes 0 2
  222.                   -/dev/disk/by-uuid/bd6fd4d3-3cf4-451f-a45f-8f5c4322ca13  /srv/dev-disk-by-uuid-bd6fd4d3-3cf4-451f-a45f-8f5c4322ca13 xfs defaults,nofail,usrquota,grpquota,inode64 0 2
  223.                   +/dev/disk/by-uuid/20b435f7-8335-4b9f-8a84-e74770784626  /srv/dev-disk-by-uuid-20b435f7-8335-4b9f-8a84-e74770784626 xfs defaults,nofail,usrquota,grpquota,inode64 0 2
  224.                    # <<< [openmediavault]
  225. ----------
  226.           ID: fstab_systemctl_daemon_reload
  227.     Function: module.run
  228.       Result: True
  229.      Comment: service.systemctl_reload: True
  230.      Started: 20:35:47.341200
  231.     Duration: 367.931 ms
  232.      Changes:
  233.               ----------
  234.               service.systemctl_reload:
  235.                   True
  236. Summary for debian
  237. ------------
  238. Succeeded: 7 (changed=3)
  239. Failed:    1
  240. ------------
  241. Total states run:     8
  242. Total run time:   1.288 s
  243. [ERROR   ] Command 'mount' failed with return code: 11
  244. [ERROR   ] stderr: ntfs-3g: Failed to access volume '/dev/disk/by-uuid/684201C542019948': No such file or directory
  245. ntfs-3g 2022.10.3 integrated FUSE 28 - Third Generation NTFS Driver
  246.  Configuration type 7, XATTRS are on, POSIX ACLS are on
  247. Copyright (C) 2005-2007 Yura Pakhuchiy
  248. Copyright (C) 2006-2009 Szabolcs Szakacsits
  249. Copyright (C) 2007-2022 Jean-Pierre Andre
  250. Copyright (C) 2009-2020 Erik Larsson
  251. Usage:    ntfs-3g [-o option[,...]] <device|image_file> <mount_point>
  252. Options:  ro (read-only mount), windows_names, uid=, gid=,
  253.           umask=, fmask=, dmask=, streams_interface=.
  254.           Please see the details in the manual (type: man ntfs-3g).
  255. Example: ntfs-3g /dev/sda1 /mnt/windows
  256. Plugin path: /usr/lib/x86_64-linux-gnu/ntfs-3g
  257. News, support and information:  https://github.com/tuxera/ntfs-3g/
  258. [ERROR   ] retcode: 11
  259. [ERROR   ] ntfs-3g: Failed to access volume '/dev/disk/by-uuid/684201C542019948': No such file or directory
  260. ntfs-3g 2022.10.3 integrated FUSE 28 - Third Generation NTFS Driver
  261.  Configuration type 7, XATTRS are on, POSIX ACLS are on
  262. Copyright (C) 2005-2007 Yura Pakhuchiy
  263. Copyright (C) 2006-2009 Szabolcs Szakacsits
  264. Copyright (C) 2007-2022 Jean-Pierre Andre
  265. Copyright (C) 2009-2020 Erik Larsson
  266. Usage:    ntfs-3g [-o option[,...]] <device|image_file> <mount_point>
  267. Options:  ro (read-only mount), windows_names, uid=, gid=,
  268.           umask=, fmask=, dmask=, streams_interface=.
  269.           Please see the details in the manual (type: man ntfs-3g).
  270. Example: ntfs-3g /dev/sda1 /mnt/windows
  271. Plugin path: /usr/lib/x86_64-linux-gnu/ntfs-3g
  272. News, support and information:  https://github.com/tuxera/ntfs-3g/ in /usr/share/php/openmediavault/system/process.inc:247
  273. Stack trace:
  274. #0 /usr/share/php/openmediavault/engine/module/serviceabstract.inc(62): OMV\System\Process->execute()
  275. #1 /usr/share/openmediavault/engined/rpc/config.inc(186): OMV\Engine\Module\ServiceAbstract->deploy()
  276. #2 [internal function]: Engined\Rpc\Config->applyChanges()
  277. #3 /usr/share/php/openmediavault/rpc/serviceabstract.inc(122): call_user_func_array()
  278. #4 /usr/share/php/openmediavault/rpc/serviceabstract.inc(149): OMV\Rpc\ServiceAbstract->callMethod()
  279. #5 /usr/share/php/openmediavault/rpc/serviceabstract.inc(622): OMV\Rpc\ServiceAbstract->OMV\Rpc\{closure}()
  280. #6 /usr/share/php/openmediavault/rpc/serviceabstract.inc(146): OMV\Rpc\ServiceAbstract->execBgProc()
  281. #7 /usr/share/openmediavault/engined/rpc/config.inc(207): OMV\Rpc\ServiceAbstract->callMethodBg()
  282. #8 [internal function]: Engined\Rpc\Config->applyChangesBg()
  283. #9 /usr/share/php/openmediavault/rpc/serviceabstract.inc(122): call_user_func_array()
  284. #10 /usr/share/php/openmediavault/rpc/rpc.inc(86): OMV\Rpc\ServiceAbstract->callMethod()
  285. #11 /usr/sbin/omv-engined(535): OMV\Rpc\Rpc::call()
  286. #12 {main}
Je me suis dit qu'il y avait une merdouille sur l'un des disque, donc j'ai formaté les 3 disques et j'ai remonter un raid5 et j'ai toujours le mme message d'erreur...
je suis passé sous OMV 7.0.5.1 pareil toujours le meme resultat... :fou:
J'ai donc rereformé les disques et j'ai essayé de créer et monter un système de fichier sur un seul disque. XFS ou EXT4 rien de marche (le message d'erreur ci-dessous c'était pour la partie XFS avec un seul disques). eh la miracle ! ! ! rien de nouveau toujours le meme probleme :cry:
Donc la je me retrouve avec 3 belles briques appelé hdd, mais je n'ai plus d'idée.
Je ne pense pas que le problème vienne de l'hardware (i3-6100 / 4Gb ram) et je n'ai pas eu de coupure de courant pendant les montages des raids ou lors de passage de omv6 à omv7.
J'espere que quelqu'un pourra m'aiguiller pour resoudre ce probleme.  :hello:
n°1491530
rat de com​bat
attention rongeur méchant!
Posté le 30-04-2024 à 12:41:18  profilanswer
Un lsblk (LSBLK) stp.
  Installation
(RESOLU) Thunderbird : impossible d'envoyer courrielImpossible de demarrer la machine virtuelle
Gros soucis système de paquets Ubuntu et autorisations Ubuntu Softwareremplissage de log qui plantent le système
erreur 500 lors du montage systeme fichiersTeamviewer: impossible de taper des charactères accentués
[Rslu]Pfsense et résolution vers un serveur DNS autoritaire impossibleInstallation LMDE5 : impossible d'avoir le wifi
[Ubuntu] Impossible de faire apparaître une clé usb sur GpartedDebian 11 - apt-get update impossible
Plus de sujets relatifs à : impossible de monter un systeme de fichier
