3923 connectés
  Linux et OS Alternatifs
  LG 4160b - Problème de gravure
n°606947
smity
Posté le 19-12-2004 à 03:50:43  profilanswer
Bonjour...
Quelqu'un aurait il un graveur LG 4160b qui fonctionne sous linux ?!!
je viens de changer de graveur de DVD depuis peut... et avec le LG il veux pas graver... error... !
[root@nobody log]# dvdrecord -v -dao speed=1 dev=1,0,0 -data /usr/image.iso
dvdrtools v0.1.6
Portions (c) 2002-2003 Ark Linux <bero@arklinux.org>
This program is free software; you can redistribute it and/or modify it under
the terms of the GNU General Public License as published by the Free Software
Foundation; either version 2, or (at your option) any later version.
This program is distributed in the hope that it will be useful, but WITHOUT ANY
WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR
A PARTICULAR PURPOSE.  See the GNU General Public License for more details.
You should have received a copy of the GNU General Public License along with
this program; see the file COPYING.  If not, write to the Free Software
Foundation, 59 Temple Place, Suite 330, Boston, MA 02111-1307, USA.
Based on:
Cdrecord 1.11a15 (i686-pc-linux-gnu) Copyright (C) 1995-2001 Jörg Schilling
TOC Type: 1 = CD-ROM
scsidev: '1,0,0'
scsibus: 1 target: 0 lun: 0
Linux sg driver version: 3.5.31
Using libscg version 'bero-0.5a'
dvdrecord: Warning: using inofficial version of libscg (bero-0.5a '@(#)scsitransp.c     1.81 01/04/20 Copyright 1988,1995,2000 J. Schilling').
atapi: 1
Device type    : Removable CD-ROM
Version        : 2
Response Format: 2
Capabilities   :
Vendor_info    : 'HL-DT-ST'
Identifikation : 'DVDRAM GSA-4160B'
Revision       : 'A301'
Device seems to be: Generic mmc2 DVD.
Using generic SCSI-3/mmc DVD-R(W) driver (mmc_mdvd).
Driver flags   : SWABAUDIO BURNFREE
Supported modes: PACKET SAO
Drive buf size : 1114112 = 1088 KB
FIFO size      : 4194304 = 4096 KB
Track 01: data  4199 MB
Total size:     4822 MB (477:45.17) = 2149888 sectors
Lout start:     4822 MB (477:47/13) = 2149888 sectors
Current Secsize: 2048
  ATIP start of lead in:  -150 (00:00/00)
Disk type:    unknown dye (reserved id code)
Manuf. index: -1
Manufacturer: unknown (not in table)
Blocks total: 2298496 Blocks current: 2298496 Blocks remaining: 148608
Starting to write CD/DVD at speed 1 in write mode for single session.
Last chance to quit, starting real write in 0 seconds. Operation starts.
Waiting for reader process to fill input buffer ... input buffer ready.
trackno=0
BURN-Free is ON.
Performing OPC...
Sending CUE sheet...
Starting new track at sector: 2150054
Track 01:   0 of 4199 MB written.dvdrecord: Input/output error. write_g1: scsi sendcmd: no error
CDB:  2A 00 00 20 CE A6 00 00 1F 00
status: 0x2 (CHECK CONDITION)
Sense Bytes: 70 00 05 00 00 00 00 10 2A 00 00 0C 21 02 00 00
Sense Key: 0x5 Illegal Request, Segment 0
Sense Code: 0x21 Qual 0x02 (logical block address out of range) [No matching qualifier] Fru 0x0
Sense flags: Blk 0 (not valid)
cmd finished after 0.002s timeout 200s
write track data: error after 0 bytes
Sense Bytes: 70 00 00 00 00 00 00 10 00 00 00 0C 00 00 00 00 00 00
Writing  time:    9.282s
Fixating...
Fixating time:    0.005s
dvdrecord: fifo had 64 puts and 1 gets.
dvdrecord: fifo was 0 times empty and 0 times full, min fill was 100%.
comme vous l'aurez remarquer j'utilise dvdrecord, en emulation scsi !
avec mon anciens graveur tout était nickel !
j'ai changer pour un LG, brancher au meme endroit.. j'ai reinstaller dvdrtools... rien a faire...
ya t'il une manipulation particulière quand on change de lecteur ?! j'ai cru voir sur des forums english que les LG bugguait un peu avec LinuX ?
n°607776
smity
Posté le 20-12-2004 à 18:24:51  profilanswer
en fait, il y a un bug connu entre LG et LinuX
les graveurs LG ne fonctionne pas sous LINUX !
n°607780
Mjules
Parle dans le vide
Posté le 20-12-2004 à 18:32:00  profilanswer
depuis quand ?
si tu as un noyau 2.6, essaye de graver sans émulation scsi
Celui qui pose une question est idiot 5 minutes. Celui qui n'en pose pas le reste toute sa vie. |  Membre du grand complot pharmaceutico-médico-scientifico-judéo-maçonnique.
n°607957
smity
Posté le 21-12-2004 à 00:47:21  profilanswer
alors... le package dvdrtools ne passe pas avec les lecteurs IDE, sauf en emulation scsi !
Donc j'ai installer le package cdrtools avec le programme cdrtools-prodvd, que je trouve dailleurs bien meilleur que dvdrtools... bref sa passe.
donc... comment faire pour avoir la clef de prodvd, sachant que j'en est demandé une sur le site, il y a 3 mois de cela et que j'attend toujours la réponse ?!!
et merci !
j'avoue que je n'avais pas pensé a ne pas utiliser l'émulation scsi...
n°608272
smity
Posté le 21-12-2004 à 16:31:07  profilanswer
et hop, un petit up au saut du lit :-p
Probleme de boot apres sid [Résolu]probleme de chargement mdk 10.1 help pls
Problème ACPI Mdk 10.1Problème suite à une reinstallation de windows
Problème de connexion à samba sous WinXP[Debian] Problème à l'installation ( binaire qui n'en fini plus )
[SUSE] probleme de chargement de module reseauNvidia + probleme de module
VNC - problème de pass-wordProblème droits d'accès!
Plus de sujets relatifs à : LG 4160b - Problème de gravure
