3468 connectés
  Hardware - Périphériques
  Webcam / Caméra IP
  Wanscam HW0041-2 Alarm 2 Megapixel 1080P IP Camera
n°943674
vasycara
Posté le 03-01-2018 à 11:15:36  profilanswer
New Wanscam HW0041-2 Two Way Audio Alarm 2 megapixel 1080P IP Camera
Specification :
Application environment
indoor / outdoor Indoor
waterproof /
day / night control auto / manual
System
OS Embedded Linux OS
processor Hi3516C
Onvif Protocol available yes
PC software / APP for Android & iPhone yes
Camera image
sensor 1/2.7" CMOS
built-in LEDs 9pcs LEDs
IR distance 10m
Lens
focal length 3.6mm
IR-CUT Build-in IR CUT, no color cast,auto switch
Pan/Tilt
preset 8 preset positions
rotation angle Pan: 355°, Tilt: 90°
rotation speed Pan: 5-30°/ S; Tilt: 5-50°/ S
Video
compression H.264/MJPEG
MegaPixel 2 MP
max. resolution (H.264 / MJPEG) 1080P (1920x1080)
max. frame rate 50Hz: 25fps/60HZ: 30fps (1280x720)
multiple streams 1080P(1920x1080), 960P(1280x960), 720P(1280x720)
VGA-(640x352), (320x176)
IMD (Intelligent Motion Detection) zone Support 4 Independent detection areas
(Sensitivity can be adjustd 1-100)
privacy video mask 4
Audio
audio encoder G.726/G.711(G.711 Default)
audio streaming 2-way audio
microphone external input
Network
protocol TCP/IP, HTTP, TCP, ICMP, UDP, ARP, IGMP, SMTP, FTP, DHCP, DNS, DDNS, NTP, UPNP, RTSP, etc.
Ethernet Ethernet (10/100 Base-T), RJ45 connector
Wireless Standard WIFI, 802.11b/g/n
Supported OS Support Microsoft Win XP/Win7/Win8/ Mac OS.
Browser Support Internet Explorer, FireFox, Google Browser, etc
Alarm
trigger event Support Email Photo Alert, Snapshot and Record uploaded to FTP or TF Card.
Interface
digital input / output 1/1
TF card slot yes, supports Max 128G TF card
General
color White
power supply DC5V 2A
dimensions (W x H x D) 99x108mm
Wanscam HW0041-2 Two Way Audio Alarm 2 Megapixel 1080P IP Camera
I have this ip camera with firmware V6.6.8.1.1-20160310.
Please if anyone has a newer firmware. I tried at Wanscam, but no result.
n°943675
vasycara
Posté le 03-01-2018 à 11:17:26  profilanswer
This comes with telnet disabled. I was able to activate telnet, but I do not know the user and the telnet password. I tried several variants, but none is good.
Please if anyone knows the user and password  for telnet to HW0041-2 Two Way Audio Alarm 2 Megapixel 1080P.
  Webcam / Caméra IP
acces interface camera ip perduCaméra DS-CD2035-I non reconnue
Camera CtronicsPb pour configurer camera ip DAHUA
camera IP à distanceA la recherche d'une camera ip
Camera de surveillance AXIS M1031-WConseil achat camera pour site web
Cherche écran 1080p pour ma femme
Plus de sujets relatifs à : Wanscam HW0041-2 Alarm 2 Megapixel 1080P IP Camera
