2293 connectés
  Disque dur
  Ralentissement applications, analyse disque dur
n°11330725
QuentinLeD​ieu
Posté le 19-03-2024 à 21:52:23  profilanswer
Bonjour, depuis peu j'ai remarquer un ralentissement lors de lancement d'applications, cela prenez plus de temps que d'habitude. J'ai donc fait une analyse disque dur par GSmartControl que je vais vous publiez...
J'ai un disque dur ssd pour windows, un disque dur hdd et un disque dur ssd en branchement direct carte mère.
D'abord le ssd où se situe windows
smartctl 7.2 2020-12-30 r5155 [x86_64-w64-mingw32-w10-b19045] (sf-7.2-1)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Crucial/Micron Client SSDs
Device Model:     CT250MX500SSD4
Serial Number:    1909E1ED07E8
LU WWN Device Id: 5 00a075 1e1ed07e8
Firmware Version: M3CR023
User Capacity:    250 059 350 016 bytes [250 GB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    Solid State Device
Form Factor:      M.2
TRIM Command:     Available
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sun Mar 17 11:09:13 2024 PM
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
AAM feature is:   Unavailable
APM level is:     254 (maximum performance)
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, frozen [SEC2]
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x80)    Offline data collection activity
                    was never started.
                    Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0)    The previous self-test routine completed
                    without error or no self-test has ever
                    been run.
Total time to complete Offline
data collection:         (    0) seconds.
capabilities:              (0x7b) SMART execute Offline immediate.
                    Auto Offline data collection on/off support.
                    Suspend Offline collection upon new
                    command.
                    Offline surface scan supported.
                    Self-test supported.
                    Conveyance Self-test supported.
                    Selective Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
                    Supports SMART auto save timer.
Error logging capability:        (0x01)    Error logging supported.
                    General Purpose Logging supported.
Short self-test routine
recommended polling time:      (   2) minutes.
Extended self-test routine
recommended polling time:      (  30) minutes.
Conveyance self-test routine
SCT capabilities:            (0x0031)    SCT Status supported.
                    SCT Feature Control supported.
                    SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     POSR-K   100   100   000    -    0
  5 Reallocate_NAND_Blk_Cnt -O--CK   100   100   010    -    0
  9 Power_On_Hours          -O--CK   100   100   000    -    14789
 12 Power_Cycle_Count       -O--CK   100   100   000    -    2425
171 Program_Fail_Count      -O--CK   100   100   000    -    0
172 Erase_Fail_Count        -O--CK   100   100   000    -    0
173 Ave_Block-Erase_Count   -O--CK   095   095   000    -    88
174 Unexpect_Power_Loss_Ct  -O--CK   100   100   000    -    13
180 Unused_Reserve_NAND_Blk PO--CK   000   000   000    -    27
183 SATA_Interfac_Downshift -O--CK   100   100   000    -    0
184 Error_Correction_Count  -O--CK   100   100   000    -    0
187 Reported_Uncorrect      -O--CK   100   100   000    -    0
194 Temperature_Celsius     -O---K   069   037   000    -    31 (Min/Max 0/63)
196 Reallocated_Event_Count -O--CK   100   100   000    -    0
197 Current_Pending_ECC_Cnt -O--CK   100   100   000    -    0
198 Offline_Uncorrectable   ----CK   100   100   000    -    0
199 UDMA_CRC_Error_Count    -O--CK   100   100   000    -    0
202 Percent_Lifetime_Remain ----CK   095   095   001    -    5
206 Write_Error_Rate        -OSR--   100   100   000    -    0
210 Success_RAIN_Recov_Cnt  -O--CK   100   100   000    -    0
246 Total_LBAs_Written      -O--CK   100   100   000    -    10781304321
247 Host_Program_Page_Count -O--CK   100   100   000    -    180437729
248 FTL_Program_Page_Count  -O--CK   100   100   000    -    247879436
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      1  Comprehensive SMART error log
0x03       GPL     R/O      1  Ext. Comprehensive SMART error log
0x04       GPL,SL  R/O      8  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x09           SL  R/W      1  Selective self-test log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x24       GPL     R/O     88  Current Device Internal Status Data log
0x25       GPL     R/O     64  Saved Device Internal Status Data log
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (1 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Completed [00% left] (0-65535)
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
SCT Status Version:                  3
SCT Version (vendor specific):       1 (0x0001)
Device State:                        Active (0)
Current Temperature:                    31 Celsius
Power Cycle Min/Max Temperature:     18/35 Celsius
Lifetime    Min/Max Temperature:      0/63 Celsius
Under/Over Temperature Limit Count:   0/0
SCT Temperature History Version:     2
Temperature Sampling Period:         1 minute
Temperature Logging Interval:        1 minute
Min/Max recommended Temperature:      0/100 Celsius
Min/Max Temperature Limit:            0/100 Celsius
Temperature History Size (Index):    128 (11)
Index    Estimated Time   Temperature Celsius
  12    2024-03-17 09:02    23  ****
  13    2024-03-17 09:03    25  ******
  14    2024-03-17 09:04    25  ******
  15    2024-03-17 09:05    25  ******
  16    2024-03-17 09:06    26  *******
  17    2024-03-17 09:07    28  *********
  18    2024-03-17 09:08    30  ***********
  19    2024-03-17 09:09    30  ***********
  20    2024-03-17 09:10    31  ************
 ...    ..(  5 skipped).    ..  ************
  26    2024-03-17 09:16    31  ************
  27    2024-03-17 09:17    35  ****************
  28    2024-03-17 09:18    35  ****************
  29    2024-03-17 09:19    35  ****************
  30    2024-03-17 09:20    36  *****************
 ...    ..(  2 skipped).    ..  *****************
  33    2024-03-17 09:23    36  *****************
  34    2024-03-17 09:24    35  ****************
  35    2024-03-17 09:25    31  ************
  36    2024-03-17 09:26    31  ************
  37    2024-03-17 09:27    33  **************
  38    2024-03-17 09:28    33  **************
  39    2024-03-17 09:29    33  **************
  40    2024-03-17 09:30    31  ************
  41    2024-03-17 09:31    31  ************
  42    2024-03-17 09:32    33  **************
  43    2024-03-17 09:33    33  **************
  44    2024-03-17 09:34    33  **************
  45    2024-03-17 09:35    31  ************
  46    2024-03-17 09:36    33  **************
  47    2024-03-17 09:37    31  ************
  48    2024-03-17 09:38    31  ************
  49    2024-03-17 09:39    31  ************
  50    2024-03-17 09:40    33  **************
  51    2024-03-17 09:41    31  ************
  54    2024-03-17 09:44    31  ************
  55    2024-03-17 09:45    33  **************
  56    2024-03-17 09:46    33  **************
  57    2024-03-17 09:47    33  **************
  58    2024-03-17 09:48    31  ************
  59    2024-03-17 09:49    33  **************
  60    2024-03-17 09:50    31  ************
  61    2024-03-17 09:51    33  **************
  62    2024-03-17 09:52    33  **************
  63    2024-03-17 09:53     ?  -
 ...    ..(  2 skipped).    ..  -
  66    2024-03-17 09:56     ?  -
  67    2024-03-17 09:57    23  ****
  68    2024-03-17 09:58    25  ******
  69    2024-03-17 09:59    25  ******
  70    2024-03-17 10:00    28  *********
  71    2024-03-17 10:01    30  ***********
  72    2024-03-17 10:02    31  ************
 ...    ..( 10 skipped).    ..  ************
  83    2024-03-17 10:13    31  ************
  84    2024-03-17 10:14    33  **************
  85    2024-03-17 10:15    33  **************
  86    2024-03-17 10:16    33  **************
  87    2024-03-17 10:17    31  ************
 ...    ..(  4 skipped).    ..  ************
  92    2024-03-17 10:22    31  ************
  93    2024-03-17 10:23    33  **************
  94    2024-03-17 10:24    31  ************
  95    2024-03-17 10:25    33  **************
  96    2024-03-17 10:26    31  ************
 101    2024-03-17 10:31    31  ************
 102    2024-03-17 10:32    33  **************
 103    2024-03-17 10:33    31  ************
 104    2024-03-17 10:34    31  ************
 105    2024-03-17 10:35    31  ************
 106    2024-03-17 10:36    33  **************
 107    2024-03-17 10:37    33  **************
 108    2024-03-17 10:38    31  ************
 109    2024-03-17 10:39    33  **************
 110    2024-03-17 10:40    31  ************
 113    2024-03-17 10:43    31  ************
 114    2024-03-17 10:44     ?  -
 115    2024-03-17 10:45     ?  -
 116    2024-03-17 10:46    23  ****
 117    2024-03-17 10:47    25  ******
 118    2024-03-17 10:48    26  *******
 121    2024-03-17 10:51    26  *******
 122    2024-03-17 10:52    28  *********
 123    2024-03-17 10:53    30  ***********
 124    2024-03-17 10:54    30  ***********
 125    2024-03-17 10:55    31  ************
 126    2024-03-17 10:56    31  ************
 127    2024-03-17 10:57    33  **************
   0    2024-03-17 10:58    35  ****************
   1    2024-03-17 10:59    35  ****************
   2    2024-03-17 11:00    33  **************
 ...    ..(  3 skipped).    ..  **************
   6    2024-03-17 11:04    33  **************
   7    2024-03-17 11:05    35  ****************
   8    2024-03-17 11:06    31  ************
  11    2024-03-17 11:09    31  ************
SCT Error Recovery Control command not supported
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 1) ==
0x01  0x008  4            2425  ---  Lifetime Power-On Resets
0x01  0x010  4           14789  ---  Power-on Hours
0x01  0x018  6      2191369729  ---  Logical Sectors Written
0x01  0x020  6        13644953  ---  Number of Write Commands
0x01  0x028  6      4053183344  ---  Logical Sectors Read
0x01  0x030  6        76655287  ---  Number of Read Commands
0x01  0x038  6      4294967296  ---  Date and Time TimeStamp
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4               0  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4              13  ---  Resets Between Cmd Acceptance and Completion
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              31  ---  Current Temperature
0x05  0x010  1              32  ---  Average Short Term Temperature
0x05  0x018  1              32  ---  Average Long Term Temperature
0x05  0x020  1              63  ---  Highest Temperature
0x05  0x028  1               0  ---  Lowest Temperature
0x05  0x030  1              49  ---  Highest Average Short Term Temperature
0x05  0x038  1               0  ---  Lowest Average Short Term Temperature
0x05  0x040  1              45  ---  Highest Average Long Term Temperature
0x05  0x048  1               0  ---  Lowest Average Long Term Temperature
0x05  0x050  4              46  ---  Time in Over-Temperature
0x05  0x058  1              70  ---  Specified Maximum Operating Temperature
0x05  0x060  4               0  ---  Time in Under-Temperature
0x05  0x068  1               0  ---  Specified Minimum Operating Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4          144798  ---  Number of Hardware Resets
0x06  0x010  4             219  ---  Number of ASR Events
0x06  0x018  4               0  ---  Number of Interface CRC Errors
0x07  =====  =               =  ===  == Solid State Device Statistics (rev 1) ==
0x07  0x008  1               5  ---  Percentage Used Endurance Indicator
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  2            0  Command failed due to ICRC error
0x0002  2            0  R_ERR response for data FIS
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0005  2            0  R_ERR response for non-data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
0x0008  2            0  Device-to-host non-data FIS retries
0x0009  2            0  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2            3  Device-to-host register FISes sent due to a COMRESET
0x000b  2            0  CRC errors within host-to-device FIS
0x000d  2            0  Non-CRC errors within host-to-device FIS
0x000f  2            0  R_ERR response for host-to-device data FIS, CRC
0x0010  2            0  R_ERR response for host-to-device data FIS, non-CRC
0x0012  2            0  R_ERR response for host-to-device non-data FIS, CRC
0x0013  2            0  R_ERR response for host-to-device non-data FIS, non-CRC
Ensuite le disque dur hdd là où j'installe à peu près tout
Model Family:     Western Digital Blue
Device Model:     WDC WD10EZEX-60M2NA0
Serial Number:    WD-WCC3FDFLDKCK
LU WWN Device Id: 5 0014ee 2b59f5f25
Firmware Version: 01.01A01
User Capacity:    1 000 204 886 016 bytes [1,00 TB]
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
ATA Version is:   ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sun Mar 17 11:10:07 2024 PM
APM feature is:   Unavailable
Offline data collection status:  (0x82)    Offline data collection activity
                    was completed without error.
                    been run.
data collection:         (11280) seconds.
capabilities:              (0x5b) SMART execute Offline immediate.
                    command.
                    No Conveyance Self-test supported.
                    power-saving mode.
recommended polling time:      ( 117) minutes.
SCT capabilities:            (0x303d)    SCT Status supported.
                    SCT Error Recovery Control supported.
  1 Raw_Read_Error_Rate     POSR-K   200   200   051    -    37
  3 Spin_Up_Time            POS--K   170   165   021    -    2483
  4 Start_Stop_Count        -O--CK   094   094   000    -    6649
  5 Reallocated_Sector_Ct   PO--CK   200   200   140    -    0
  7 Seek_Error_Rate         POSR-K   200   200   051    -    0
  9 Power_On_Hours          -O--CK   068   068   000    -    23950
 10 Spin_Retry_Count        PO--CK   100   100   051    -    0
 11 Calibration_Retry_Count -O--CK   100   100   000    -    0
 12 Power_Cycle_Count       -O--CK   095   095   000    -    5927
183 Runtime_Bad_Block       -O--CK   100   100   000    -    0
184 End-to-End_Error        PO--CK   100   100   097    -    0
187 Reported_Uncorrect      -O--CK   100   063   000    -    38
188 Command_Timeout         -O--CK   100   100   000    -    0
190 Airflow_Temperature_Cel -O---K   078   049   040    -    22 (Min/Max 16/22)
192 Power-Off_Retract_Count -O--CK   200   200   000    -    125
193 Load_Cycle_Count        -O--CK   198   198   000    -    6523
196 Reallocated_Event_Count -O--CK   200   200   000    -    0
197 Current_Pending_Sector  -O--CK   200   200   000    -    0
198 Offline_Uncorrectable   ----CK   200   200   000    -    0
199 UDMA_CRC_Error_Count    -O--CK   200   200   000    -    0
200 Multi_Zone_Error_Rate   ---R--   200   200   000    -    0
                            ||||||_ K auto-keep
0x02           SL  R/O      5  Comprehensive SMART error log
0x03       GPL     R/O      6  Ext. Comprehensive SMART error log
0x08       GPL     R/O      2  Power Conditions log
0x0d       GPL,SL  R/O      8  LPS Mis-alignment log
0x12       GPL     R/O      1  SATA NCQ Non-Data log
0xa0-0xa7  GPL,SL  VS      16  Device vendor specific log
0xa8-0xb5  GPL,SL  VS       1  Device vendor specific log
0xb6       GPL     VS    2995  Device vendor specific log
0xb6       SL      VS       1  Device vendor specific log
0xb7       GPL,SL  VS       1  Device vendor specific log
0xbd       GPL,SL  VS       1  Device vendor specific log
0xc0       GPL,SL  VS       1  Device vendor specific log
0xc1       GPL     VS      93  Device vendor specific log
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
Device Error Count: 38 (device log contains only the most recent 24 errors)
    CR     = Command Register
    FEATR  = Features Register
    COUNT  = Count (was: Sector Count) Register
    LBA_48 = Upper bytes of LBA High/Mid/Low Registers ]  ATA-8
    LH     = LBA High (was: Cylinder High) Register    ]   LBA
    LM     = LBA Mid (was: Cylinder Low) Register      ] Register
    LL     = LBA Low (was: Sector Number) Register     ]
    DV     = Device (was: Device/Head) Register
    DC     = Device Control Register
    ER     = Error register
    ST     = Status register
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 38 [13] occurred at disk power-on lifetime: 17587 hours (732 days + 19 hours)
  When the command that caused the error occurred, the device was active or idle.
  After command completion occurred, registers were:
  ER -- ST COUNT  LBA_48  LH LM LL DV DC
  40 -- 51 00 00 00 00 00 5a 84 80 40 00  Error: WP at LBA = 0x005a8480 = 5932160
  Commands leading to the command that caused the error were:
  CR FEATR COUNT  LBA_48  LH LM LL DV DC  Powered_Up_Time  Command/Feature_Name
  61 00 08 00 28 00 00 01 2e 26 c0 40 00     02:57:55.137  WRITE FPDMA QUEUED
  61 00 20 00 28 00 00 58 8d 27 00 40 00     02:57:55.137  WRITE FPDMA QUEUED
  60 00 20 00 20 00 00 00 83 9a 40 40 00     02:57:55.137  READ FPDMA QUEUED
  61 00 20 00 10 00 00 58 95 9b c0 40 00     02:57:55.137  WRITE FPDMA QUEUED
  61 00 08 00 08 00 00 00 00 e9 e0 40 00     02:57:55.122  WRITE FPDMA QUEUED
Error 37 [12] occurred at disk power-on lifetime: 2237 hours (93 days + 5 hours)
  40 -- 51 00 00 00 00 35 c5 03 88 40 00  Error: WP at LBA = 0x35c50388 = 902103944
  61 01 00 00 28 00 00 32 9d 43 50 40 00     02:35:29.027  WRITE FPDMA QUEUED
  61 01 00 00 20 00 00 32 9d 42 50 40 00     02:35:29.026  WRITE FPDMA QUEUED
  60 00 40 00 18 00 00 35 c5 03 88 40 00     02:35:29.026  READ FPDMA QUEUED
  61 01 00 00 10 00 00 32 9d 41 50 40 00     02:35:29.026  WRITE FPDMA QUEUED
  61 01 00 00 08 00 00 32 9d 40 50 40 00     02:35:29.026  WRITE FPDMA QUEUED
Error 36 [11] occurred at disk power-on lifetime: 2237 hours (93 days + 5 hours)
  61 01 00 00 40 00 00 32 9d 40 50 40 00     02:35:24.807  WRITE FPDMA QUEUED
  61 01 00 00 28 00 00 32 9d 3f 50 40 00     02:35:24.793  WRITE FPDMA QUEUED
  61 01 00 00 20 00 00 32 9d 3e 50 40 00     02:35:24.788  WRITE FPDMA QUEUED
  61 01 00 00 18 00 00 32 9d 3d 50 40 00     02:35:24.788  WRITE FPDMA QUEUED
  61 00 08 00 10 00 00 00 5b 1f 18 40 00     02:35:24.788  WRITE FPDMA QUEUED
Error 35 [10] occurred at disk power-on lifetime: 2237 hours (93 days + 5 hours)
  61 01 00 00 20 00 00 32 9d 38 50 40 00     02:35:20.581  WRITE FPDMA QUEUED
  61 01 00 00 18 00 00 32 9d 37 50 40 00     02:35:20.573  WRITE FPDMA QUEUED
  61 01 00 00 10 00 00 32 9d 36 50 40 00     02:35:20.556  WRITE FPDMA QUEUED
  61 01 00 00 08 00 00 32 9d 35 50 40 00     02:35:20.555  WRITE FPDMA QUEUED
  60 00 40 00 78 00 00 35 c5 03 88 40 00     02:35:20.555  READ FPDMA QUEUED
Error 34 [9] occurred at disk power-on lifetime: 2237 hours (93 days + 5 hours)
  61 01 00 00 28 00 00 32 9d 2e 50 40 00     02:35:16.367  WRITE FPDMA QUEUED
  61 01 00 00 20 00 00 32 9d 2d 50 40 00     02:35:16.367  WRITE FPDMA QUEUED
  61 00 08 00 18 00 00 00 64 11 e8 40 00     02:35:16.367  WRITE FPDMA QUEUED
  60 00 08 00 10 00 00 00 4b a7 a8 40 00     02:35:16.360  READ FPDMA QUEUED
  61 00 08 00 38 00 00 00 5b 1f 20 40 00     02:35:16.353  WRITE FPDMA QUEUED
Error 33 [8] occurred at disk power-on lifetime: 2237 hours (93 days + 5 hours)
  61 01 00 00 48 00 00 32 9d 2c 50 40 00     02:35:12.158  WRITE FPDMA QUEUED
  60 00 08 00 40 00 00 00 4b a7 d0 40 00     02:35:12.158  READ FPDMA QUEUED
  61 01 00 00 38 00 00 32 9d 2b 50 40 00     02:35:12.158  WRITE FPDMA QUEUED
  60 00 40 00 30 00 00 35 c5 03 88 40 00     02:35:12.157  READ FPDMA QUEUED
  61 01 00 00 28 00 00 32 9d 2a 50 40 00     02:35:12.157  WRITE FPDMA QUEUED
Error 32 [7] occurred at disk power-on lifetime: 2237 hours (93 days + 5 hours)
  61 01 00 00 10 00 00 32 9d 26 50 40 00     02:35:07.955  WRITE FPDMA QUEUED
  61 01 00 00 08 00 00 32 9d 25 50 40 00     02:35:07.954  WRITE FPDMA QUEUED
  61 01 00 00 78 00 00 32 9d 1e 50 40 00     02:35:07.954  WRITE FPDMA QUEUED
  60 00 08 00 58 00 00 03 1d b9 60 40 00     02:35:07.954  READ FPDMA QUEUED
  61 00 08 00 50 00 00 00 5f 8a 88 40 00     02:35:07.954  WRITE FPDMA QUEUED
Error 31 [6] occurred at disk power-on lifetime: 2237 hours (93 days + 5 hours)
  61 01 00 00 28 00 00 32 9d 1f 50 40 00     02:35:03.748  WRITE FPDMA QUEUED
  61 01 00 00 20 00 00 32 9d 1e 50 40 00     02:35:03.743  WRITE FPDMA QUEUED
  61 01 00 00 18 00 00 32 9d 1d 50 40 00     02:35:03.743  WRITE FPDMA QUEUED
  61 00 08 00 10 00 00 00 5f 5c f8 40 00     02:35:03.743  WRITE FPDMA QUEUED
  61 00 08 00 08 00 00 00 5b 1f 18 40 00     02:35:03.743  WRITE FPDMA QUEUED
Error 30 [5] occurred at disk power-on lifetime: 2237 hours (93 days + 5 hours)
  40 -- 51 00 00 00 00 35 c5 03 88 40 00  Error: UNC at LBA = 0x35c50388 = 902103944
  60 00 08 00 08 00 00 00 4b a7 c0 40 00     02:34:59.544  READ FPDMA QUEUED
  60 00 40 00 60 00 00 35 c5 03 88 40 00     02:34:59.535  READ FPDMA QUEUED
  61 00 08 00 30 00 00 00 64 1b c0 40 00     02:34:59.535  WRITE FPDMA QUEUED
  61 01 00 00 28 00 00 32 9d 14 50 40 00     02:34:59.534  WRITE FPDMA QUEUED
  60 00 08 00 20 00 00 00 4b a7 d8 40 00     02:34:59.534  READ FPDMA QUEUED
Error 29 [4] occurred at disk power-on lifetime: 2237 hours (93 days + 5 hours)
  61 01 00 00 68 00 00 32 9d 12 50 40 00     02:34:55.306  WRITE FPDMA QUEUED
  61 01 00 00 60 00 00 32 9d 11 50 40 00     02:34:55.288  WRITE FPDMA QUEUED
  61 01 00 00 58 00 00 32 9d 10 50 40 00     02:34:55.280  WRITE FPDMA QUEUED
  61 01 00 00 50 00 00 32 9d 0f 50 40 00     02:34:55.275  WRITE FPDMA QUEUED
  61 01 00 00 18 00 00 32 9d 0e 50 40 00     02:34:55.270  WRITE FPDMA QUEUED
Error 28 [3] occurred at disk power-on lifetime: 2237 hours (93 days + 5 hours)
  61 01 00 00 20 00 00 32 9d 0b 50 40 00     02:34:51.053  WRITE FPDMA QUEUED
  61 01 00 00 18 00 00 32 9d 0a 50 40 00     02:34:51.053  WRITE FPDMA QUEUED
  61 01 00 00 10 00 00 32 9d 09 50 40 00     02:34:51.053  WRITE FPDMA QUEUED
  60 00 40 00 08 00 00 35 c5 03 88 40 00     02:34:51.053  READ FPDMA QUEUED
  ef 00 02 00 00 00 00 00 00 00 00 00 00     02:34:51.052  SET FEATURES [Enable write cache]
Error 27 [2] occurred at disk power-on lifetime: 2237 hours (93 days + 5 hours)
  61 01 00 00 20 00 00 32 9d 0a 50 40 00     02:34:46.852  WRITE FPDMA QUEUED
  61 01 00 00 18 00 00 32 9d 09 50 40 00     02:34:46.852  WRITE FPDMA QUEUED
  61 01 00 00 10 00 00 32 9d 08 50 40 00     02:34:46.851  WRITE FPDMA QUEUED
  60 00 40 00 08 00 00 35 c5 03 88 40 00     02:34:46.851  READ FPDMA QUEUED
  ef 00 02 00 00 00 00 00 00 00 00 00 00     02:34:46.851  SET FEATURES [Enable write cache]
Error 26 [1] occurred at disk power-on lifetime: 2237 hours (93 days + 5 hours)
  61 01 00 00 38 00 00 32 9d 08 50 40 00     02:34:42.629  WRITE FPDMA QUEUED
  61 01 00 00 20 00 00 32 9d 07 50 40 00     02:34:42.624  WRITE FPDMA QUEUED
  61 01 00 00 10 00 00 32 9d 06 50 40 00     02:34:42.618  WRITE FPDMA QUEUED
  61 01 00 00 08 00 00 32 9d 05 50 40 00     02:34:42.618  WRITE FPDMA QUEUED
  61 01 00 00 70 00 00 32 9d 03 50 40 00     02:34:42.618  WRITE FPDMA QUEUED
Error 25 [0] occurred at disk power-on lifetime: 2237 hours (93 days + 5 hours)
  61 01 00 00 48 00 00 32 9d 04 50 40 00     02:34:38.370  WRITE FPDMA QUEUED
  61 01 00 00 40 00 00 32 9d 03 50 40 00     02:34:38.364  WRITE FPDMA QUEUED
  61 01 00 00 38 00 00 32 9d 02 50 40 00     02:34:38.352  WRITE FPDMA QUEUED
  61 01 00 00 30 00 00 32 9d 01 50 40 00     02:34:38.352  WRITE FPDMA QUEUED
  61 01 00 00 28 00 00 32 9d 00 50 40 00     02:34:38.351  WRITE FPDMA QUEUED
Error 24 [23] occurred at disk power-on lifetime: 2237 hours (93 days + 5 hours)
  61 01 00 00 70 00 00 32 9c f5 50 40 00     02:34:34.083  WRITE FPDMA QUEUED
  61 01 00 00 70 00 00 32 9c f4 50 40 00     02:34:34.082  WRITE FPDMA QUEUED
  61 01 00 00 68 00 00 32 9c f3 50 40 00     02:34:34.082  WRITE FPDMA QUEUED
  61 01 00 00 60 00 00 32 9c f2 50 40 00     02:34:34.082  WRITE FPDMA QUEUED
  61 01 00 00 58 00 00 32 9c f1 50 40 00     02:34:34.081  WRITE FPDMA QUEUED
Error 23 [22] occurred at disk power-on lifetime: 2237 hours (93 days + 5 hours)
  60 01 00 00 38 00 00 03 4b 9f 18 40 00     02:34:29.840  READ FPDMA QUEUED
  60 01 00 00 30 00 00 03 4b 9e 18 40 00     02:34:29.840  READ FPDMA QUEUED
  60 00 f8 00 28 00 00 03 4b 9d 20 40 00     02:34:29.840  READ FPDMA QUEUED
  60 00 40 00 20 00 00 01 34 fe 62 40 00     02:34:29.840  READ FPDMA QUEUED
  61 01 00 00 18 00 00 32 9c d4 50 40 00     02:34:29.839  WRITE FPDMA QUEUED
Error 22 [21] occurred at disk power-on lifetime: 2237 hours (93 days + 5 hours)
  61 01 00 00 50 00 00 32 9c d3 50 40 00     02:34:24.590  WRITE FPDMA QUEUED
  61 01 00 00 48 00 00 32 9c d2 50 40 00     02:34:24.576  WRITE FPDMA QUEUED
  61 01 00 00 40 00 00 32 9c d1 50 40 00     02:34:24.568  WRITE FPDMA QUEUED
  61 01 00 00 38 00 00 32 9c d0 50 40 00     02:34:24.562  WRITE FPDMA QUEUED
  61 01 00 00 30 00 00 32 9c cf 50 40 00     02:34:24.562  WRITE FPDMA QUEUED
Error 21 [20] occurred at disk power-on lifetime: 2237 hours (93 days + 5 hours)
  61 01 00 00 48 00 00 32 9c c5 50 40 00     02:34:20.336  WRITE FPDMA QUEUED
  61 01 00 00 40 00 00 32 9c c4 50 40 00     02:34:20.335  WRITE FPDMA QUEUED
  61 01 00 00 38 00 00 32 9c c3 50 40 00     02:34:20.335  WRITE FPDMA QUEUED
  61 01 00 00 30 00 00 32 9c c2 50 40 00     02:34:20.333  WRITE FPDMA QUEUED
  61 01 00 00 28 00 00 32 9c c1 50 40 00     02:34:20.333  WRITE FPDMA QUEUED
Error 20 [19] occurred at disk power-on lifetime: 2237 hours (93 days + 5 hours)
  61 01 00 00 98 00 00 32 9c a2 50 40 00     02:34:16.038  WRITE FPDMA QUEUED
  61 01 00 00 90 00 00 32 9c a1 50 40 00     02:34:16.025  WRITE FPDMA QUEUED
  61 01 00 00 88 00 00 32 9c a0 50 40 00     02:34:16.019  WRITE FPDMA QUEUED
  61 01 00 00 80 00 00 32 9c 9f 50 40 00     02:34:16.013  WRITE FPDMA QUEUED
  61 01 00 00 78 00 00 32 9c 9e 50 40 00     02:34:16.013  WRITE FPDMA QUEUED
Error 19 [18] occurred at disk power-on lifetime: 2237 hours (93 days + 5 hours)
  61 01 00 00 10 00 00 32 9c 8e 50 40 00     02:34:11.785  WRITE FPDMA QUEUED
  61 01 00 00 08 00 00 32 9c 8d 50 40 00     02:34:11.785  WRITE FPDMA QUEUED
  60 00 40 00 78 00 00 35 c5 03 88 40 00     02:34:11.784  READ FPDMA QUEUED
  60 00 40 00 38 00 00 01 34 fc 8a 40 00     02:34:11.784  READ FPDMA QUEUED
  61 00 08 00 30 00 00 00 64 11 e8 40 00     02:34:11.784  WRITE FPDMA QUEUED
Error 18 [17] occurred at disk power-on lifetime: 2237 hours (93 days + 5 hours)
  61 01 00 00 30 00 00 32 9c 88 50 40 00     02:34:07.576  WRITE FPDMA QUEUED
  61 01 00 00 28 00 00 32 9c 87 50 40 00     02:34:07.564  WRITE FPDMA QUEUED
  61 01 00 00 20 00 00 32 9c 86 50 40 00     02:34:07.557  WRITE FPDMA QUEUED
  61 01 00 00 18 00 00 32 9c 85 50 40 00     02:34:07.556  WRITE FPDMA QUEUED
  61 00 08 00 10 00 00 00 5b 1f 18 40 00     02:34:07.556  WRITE FPDMA QUEUED
Error 17 [16] occurred at disk power-on lifetime: 2237 hours (93 days + 5 hours)
  61 01 00 00 40 00 00 32 9c 84 50 40 00     02:34:03.338  WRITE FPDMA QUEUED
  61 01 00 00 38 00 00 32 9c 83 50 40 00     02:34:03.335  WRITE FPDMA QUEUED
  61 01 00 00 30 00 00 32 9c 82 50 40 00     02:34:03.326  WRITE FPDMA QUEUED
  61 01 00 00 28 00 00 32 9c 81 50 40 00     02:34:03.326  WRITE FPDMA QUEUED
  61 01 00 00 20 00 00 32 9c 80 50 40 00     02:34:03.326  WRITE FPDMA QUEUED
Error 16 [15] occurred at disk power-on lifetime: 2237 hours (93 days + 5 hours)
  61 01 00 00 30 00 00 32 9c 81 50 40 00     02:33:59.135  WRITE FPDMA QUEUED
  61 01 00 00 28 00 00 32 9c 80 50 40 00     02:33:59.134  WRITE FPDMA QUEUED
  61 01 00 00 20 00 00 32 9c 7f 50 40 00     02:33:59.134  WRITE FPDMA QUEUED
  60 00 20 00 18 00 00 03 34 23 d8 40 00     02:33:59.134  READ FPDMA QUEUED
  60 00 40 00 10 00 00 35 c5 03 88 40 00     02:33:59.134  READ FPDMA QUEUED
Error 15 [14] occurred at disk power-on lifetime: 2237 hours (93 days + 5 hours)
  61 01 00 00 30 00 00 32 9c 80 50 40 00     02:33:54.951  WRITE FPDMA QUEUED
  61 01 00 00 28 00 00 32 9c 7f 50 40 00     02:33:54.938  WRITE FPDMA QUEUED
  60 00 40 00 20 00 00 35 c5 03 88 40 00     02:33:54.938  READ FPDMA QUEUED
  61 01 00 00 18 00 00 32 9c 7e 50 40 00     02:33:54.937  WRITE FPDMA QUEUED
  61 01 00 00 10 00 00 32 9c 7d 50 40 00     02:33:54.937  WRITE FPDMA QUEUED
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
SCT Version (vendor specific):       258 (0x0102)
Current Temperature:                    22 Celsius
Power Cycle Min/Max Temperature:     16/22 Celsius
Lifetime    Min/Max Temperature:      9/51 Celsius
Vendor specific:
00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Min/Max recommended Temperature:      0/60 Celsius
Min/Max Temperature Limit:           -41/85 Celsius
Temperature History Size (Index):    128 (126)
 127    2024-03-17 09:03    21  **
 ...    ..( 57 skipped).    ..  **
  57    2024-03-17 10:01    21  **
  58    2024-03-17 10:02     ?  -
  59    2024-03-17 10:03    16  -
  60    2024-03-17 10:04     ?  -
  61    2024-03-17 10:05    16  -
  62    2024-03-17 10:06    16  -
  63    2024-03-17 10:07    16  -
  64    2024-03-17 10:08    17  -
  65    2024-03-17 10:09    17  -
  66    2024-03-17 10:10    18  -
  69    2024-03-17 10:13    18  -
  70    2024-03-17 10:14    19  -
 ...    ..(  3 skipped).    ..  -
  74    2024-03-17 10:18    19  -
  75    2024-03-17 10:19    20  *
 ...    ..(  7 skipped).    ..  *
  83    2024-03-17 10:27    20  *
  84    2024-03-17 10:28    21  **
 ...    ..( 11 skipped).    ..  **
  96    2024-03-17 10:40    21  **
  97    2024-03-17 10:41    22  ***
 ...    ..( 28 skipped).    ..  ***
 126    2024-03-17 11:10    22  ***
SCT Error Recovery Control:
           Read:     85 (8,5 seconds)
          Write:     85 (8,5 seconds)
Device Statistics (GP/SMART Log 0x04) not supported
0x0009  2            5  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2            7  Device-to-host register FISes sent due to a COMRESET
0x8000  4         3965  Vendor specific
Et le petit dernier, disque dur ssd brancher directement sur la carte mère. En espérant que cela puisse vous aidez, je suis à l'écoute de vos conseils. Les disques durs datent d'il y a 12 ans déja, le dernier est plus récent. ^^
Je vous remercie de votre attention.
Model Family:     Samsung based SSDs
Device Model:     Samsung SSD 840 EVO 120GB
Serial Number:    S1D5NSBFB38462W
LU WWN Device Id: 5 002538 8a0882855
Firmware Version: EXT0CB6Q
User Capacity:    120 034 123 776 bytes [120 GB]
Sector Size:      512 bytes logical/physical
ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 4c
Local Time is:    Sun Mar 17 11:11:55 2024 PM
See vendor-specific Attribute list for marginal Attributes.
Offline data collection status:  (0x00)    Offline data collection activity
                    was never started.
                    Auto Offline Data Collection: Disabled.
                    been run.
data collection:         ( 4200) seconds.
capabilities:              (0x53) SMART execute Offline immediate.
                    command.
                    No Offline surface scan supported.
                    power-saving mode.
recommended polling time:      (  70) minutes.
SCT capabilities:            (0x003d)    SCT Status supported.
  5 Reallocated_Sector_Ct   PO--CK   100   100   010    -    0
  9 Power_On_Hours          -O--CK   095   095   000    -    23499
 12 Power_Cycle_Count       -O--CK   094   094   000    -    5986
177 Wear_Leveling_Count     PO--C-   001   001   000    -    2710
179 Used_Rsvd_Blk_Cnt_Tot   PO--C-   100   001   010    Past 0
181 Program_Fail_Cnt_Total  -O--CK   100   100   010    -    0
182 Erase_Fail_Count_Total  -O--CK   100   100   010    -    0
183 Runtime_Bad_Block       PO--C-   100   100   010    -    0
187 Uncorrectable_Error_Cnt -O--CK   100   100   000    -    0
190 Airflow_Temperature_Cel -O--CK   076   049   000    -    24
195 ECC_Error_Rate          -O-RC-   200   200   000    -    0
199 CRC_Error_Count         -OSRCK   100   100   000    -    0
235 POR_Recovery_Count      -O--C-   099   099   000    -    187
241 Total_LBAs_Written      -O--CK   099   099   000    -    294079156473
                            ||||||_ K auto-keep
0xa1       GPL,SL  VS      16  Device vendor specific log
0xce       GPL,SL  VS      16  Device vendor specific log
0xde           SL  VS       1  Device vendor specific log
No Errors Logged
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Current Temperature:                    24 Celsius
Power Cycle Min/Max Temperature:      ?/ ? Celsius
Lifetime    Min/Max Temperature:      ?/ ? Celsius
Under/Over Temperature Limit Count:   0/141048
Temperature Sampling Period:         10 minutes
Temperature Logging Interval:        10 minutes
Min/Max recommended Temperature:      ?/ ? Celsius
Min/Max Temperature Limit:            ?/ ? Celsius
Temperature History Size (Index):    128 (6)
   7    2024-03-16 14:00     ?  -
 ...    ..(120 skipped).    ..  -
   0    2024-03-17 10:10     ?  -
   1    2024-03-17 10:20    27  ********
   2    2024-03-17 10:30    28  *********
   3    2024-03-17 10:40    31  ************
   4    2024-03-17 10:50    28  *********
   5    2024-03-17 11:00    25  ******
   6    2024-03-17 11:10    23  ****
           Read: Disabled
          Write: Disabled
0x0009  2            4  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2            4  Device-to-host register FISes sent due to a COMRESET
n°11330746
theBattous​ai
Posté le 19-03-2024 à 23:15:07  profilanswer
A priori, soit juste une affaire de défragmentation, soit un virus.
n°11330787
patrick220​00
Posté le 20-03-2024 à 09:57:00  profilanswer
Une autre possibilité : un disque presque plein. J'ai eu la mauvaise surprise à cause d'EPIC games et Fortnite  qui  avait saturé un SSD de 250Go. Avec l'arbre d'occupation du ssd de "Windirstat" c'était flagrant.
n°11332127
QuentinLeD​ieu
Posté le 27-03-2024 à 17:10:27  profilanswer
J'ai fait une défragmentation, j'ai pas ressenti de véritable amélioration...
n°11332133
mrdoug
Posté le 27-03-2024 à 18:50:34  profilanswer
Un disque dur n'est pas fait pour y installer des applications :o
De nos jours c'est bon que pour du stockage.
Message édité par mrdoug le 27-03-2024 à 18:50:50
n°11332155
fabcoq
Posté le 27-03-2024 à 20:55:11  profilanswer
bonsoir,
As-tu essayé de passer avec crystaldiskinfo ?
Le résultat est plus clair au lieu de ton long texte.
Pourrais-tu poster une copie d'écran du résultat ?
n°11332352
TotalRecal​l
Posté le 29-03-2024 à 09:01:39  profilanswer
A priori à la lecture des trois rapports SMART aucune erreur flagrante, je pense que les trois sont bons malgré leur âge.
Tu peux faire un CrystalDiskInfo qui sera plus visuel mais il devrait dire la même chose que moi.
Tu peux aussi faire un test de débit sur chaque, histoire d'être tranquille.
Tu ne précises pas sur quel disque sont installées les applis "lentes", c'est le 2e, le WD ?
Si oui à ta place je virerais le WD (et éventuellement le SSD antique de 120Go), pour mettre à la place un SSD de 1 ou 2To selon tes besoins, ça va certainement améliorer pas mal les choses pour pas trop cher, même si il faut d'abord exclure une cause logicielle.
Le taux de remplissage est effectivement aussi un critère important si le souci est côté SSD.
Message édité par TotalRecall le 29-03-2024 à 09:02:32
Topic .Net - C# @ Prog
n°11332743
QuentinLeD​ieu
Posté le 31-03-2024 à 18:03:44  profilanswer
C'est le hdd (WD) là ou je met mes applis sur lequels ils ralentissent.
n°11332744
QuentinLeD​ieu
Posté le 31-03-2024 à 18:08:44  profilanswer
Voici par CrystalDiskInfo:
CrystalDiskInfo 9.2.3 (C) 2008-2024 hiyohiyo
                                Crystal Dew World: https://crystalmark.info/
    OS : Windows 10  22H2 [10.0 Build 19045] (x64)
  Date : 2024/03/31 18:07:37
-- Controller Map ----------------------------------------------------------
 + AMD SATA Controller [ATA]
   - CT250MX500SSD4
   - IEEE 1667 Probe Silo générique
   - Silo de stockage TCG Microsoft
   - Generic IEEE 1667 ACT
 - Contrôleur des espaces de stockage Microsoft [SCSI]
 + AMD Virtualized AHCI Controller for StoreMI [SCSI]
   - HL-DT-ST DVDRAM GH24NSB0
   - WDC WD10EZEX-60M2NA0
   - Samsung SSD 840 EVO 120GB
-- Disk List ---------------------------------------------------------------
 (01) Samsung SSD 840 EVO 120GB : 120,0 GB [2/1/0, pd1] - sg
 (02) WDC WD10EZEX-60M2NA0 : 1000,2 GB [1/1/0, pd1]
 (03) CT250MX500SSD4 : 250,0 GB [0/0/0, pd1] - m3
           Model : Samsung SSD 840 EVO 120GB
        Firmware : EXT0CB6Q
   Serial Number : S1D5NSBFB38462W
       Disk Size : 120,0 GB (8,4/120,0/120,0/120,0)
     Buffer Size : Inconnu
     Queue Depth : 32
    # of Sectors : 234441648
   Rotation Rate : ---- (SSD)
       Interface : Serial ATA
   Major Version : ACS-2
   Minor Version : ATA8-ACS version 4c
   Transfer Mode : SATA/600 | SATA/600
  Power On Hours : 23597 heures
  Power On Count : 6005 fois
     Host Writes : 140920 GB
Wear Level Count : 2729
     Temperature : 26 C (78 F)
   Health Status : Prudence (1 %)
        Features : S.M.A.R.T., NCQ, TRIM, GPL
       APM Level : ----
       AAM Level : ----
    Drive Letter : C:
-- S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
05 100 100 _10 000000000000 Nombre de secteurs réalloués
09 _95 _95 __0 000000005C2D Heures de Fonctionnement
0C _94 _94 __0 000000001775 Nombre total de cycles marche/arrêt
B1 __1 __1 __0 000000000AA9 Nombre de niveau d'usure
B3 100 __1 _10 000000000000 Nombre de blocs réservés utilisés (Total)
B5 100 100 _10 000000000000 Nombre d'echec du programme (Total)
B6 100 100 _10 000000000000 Nombre d'echec d'effacement (Total)
B7 100 100 _10 000000000000 Blocs avec une mauvaise durée (Total)
BB 100 100 __0 000000000000 Nombre d'erreurs incorrigeables
BE _74 _49 __0 00000000001A Température Débit d'Air
C3 200 200 __0 000000000000 Taux Erreur ECC
C7 100 100 __0 000000000000 Nombre d'erreur CRC
EB _99 _99 __0 0000000000BB Nombre de Récupération POR
F1 _99 _99 __0 0044CF0CD766 Total LBA en Ecriture
-- IDENTIFY_DEVICE ---------------------------------------------------------
        0    1    2    3    4    5    6    7    8    9
000: 0040 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: 5331 4435 4E53 4246 4233 3834 3632 5720 2020 2020
020: 0000 0000 0000 4558 5430 4342 3651 5361 6D73 756E
030: 6720 5353 4420 3834 3020 4556 4F20 3132 3047 4220
040: 2020 2020 2020 2020 2020 2020 2020 8001 4001 2F00
050: 4000 0200 0200 0007 3FFF 0010 003F FC10 00FB 0101
060: 4BB0 0DF9 0000 0007 0003 0078 0078 0078 0078 0F10
070: 0000 0000 0000 0000 0000 001F 850E 0046 006C 0060
080: 03FC 0039 746B 7D01 4163 7469 BC01 4163 407F 0001
090: 0004 0000 FFFE 0000 0000 0000 0000 0000 0000 0000
100: 4BB0 0DF9 0000 0000 0000 0008 4000 0000 5002 5388
110: A088 2855 0000 0000 0000 0000 0000 0000 0000 401E
120: 401C 0000 0000 0000 0000 0000 0000 0000 0029 0000
130: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
140: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
150: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
160: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0001
170: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
180: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
190: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 0000 003D 0000 0000 4000
210: 0000 0000 0000 0000 0000 0000 0000 0001 0000 0000
220: 0000 0000 107F 0000 0000 0000 0000 0000 0000 0000
230: 0000 0000 0000 0000 0000 0800 0000 0000 0000 0000
240: 0000 0000 0000 4000 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 06A5
-- SMART_READ_DATA ---------------------------------------------------------
     +0 +1 +2 +3 +4 +5 +6 +7 +8 +9 +A +B +C +D +E +F
000: 01 00 05 33 00 64 64 00 00 00 00 00 00 00 09 32
010: 00 5F 5F 2D 5C 00 00 00 00 00 0C 32 00 5E 5E 75
020: 17 00 00 00 00 00 B1 13 00 01 01 A9 0A 00 00 00
030: 00 00 B3 13 00 64 01 00 00 00 00 00 00 00 B5 32
040: 00 64 64 00 00 00 00 00 00 00 B6 32 00 64 64 00
050: 00 00 00 00 00 00 B7 13 00 64 64 00 00 00 00 00
060: 00 00 BB 32 00 64 64 00 00 00 00 00 00 00 BE 32
070: 00 4A 31 1A 00 00 00 00 00 00 C3 1A 00 C8 C8 00
080: 00 00 00 00 00 00 C7 3E 00 64 64 00 00 00 00 00
090: 00 00 EB 12 00 63 63 BB 00 00 00 00 00 00 F1 32
0A0: 00 63 63 66 D7 0C CF 44 00 00 00 00 00 00 00 00
0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 68 10 00 53
170: 03 00 01 00 02 46 00 00 00 00 00 00 00 00 00 00
180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 14
-- SMART_READ_THRESHOLD ----------------------------------------------------
000: 01 00 05 0A 00 00 00 00 00 00 00 00 00 00 09 00
010: 00 00 00 00 00 00 00 00 00 00 0C 00 00 00 00 00
020: 00 00 00 00 00 00 B1 00 00 00 00 00 00 00 00 00
030: 00 00 B3 0A 00 00 00 00 00 00 00 00 00 00 B5 0A
040: 00 00 00 00 00 00 00 00 00 00 B6 0A 00 00 00 00
050: 00 00 00 00 00 00 B7 0A 00 00 00 00 00 00 00 00
060: 00 00 BB 00 00 00 00 00 00 00 00 00 00 00 BE 00
070: 00 00 00 00 00 00 00 00 00 00 C3 00 00 00 00 00
080: 00 00 00 00 00 00 C7 00 00 00 00 00 00 00 00 00
090: 00 00 EB 00 00 00 00 00 00 00 00 00 00 00 F1 00
0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4E
           Model : WDC WD10EZEX-60M2NA0
        Firmware : 01.01A01
   Serial Number : WD-WCC3FDFLDKCK
       Disk Size : 1000,2 GB (8,4/137,4/1000,2/1000,2)
     Queue Depth : 32
    # of Sectors : 1953525168
   Rotation Rate : 7200 RPM
   Minor Version : ACS-3 Revision 3b
  Power On Hours : 24049 heures
  Power On Count : 5946 fois
     Temperature : 22 C (71 F)
   Health Status : Bon
        Features : S.M.A.R.T., NCQ, GPL
       APM Level : ----
       AAM Level : ----
    Drive Letter : D:
01 200 200 _51 000000000025 Taux d'erreurs de lecture
03 167 165 _21 000000000A5A Durée de rotation
04 _94 _94 __0 000000001A0C Nombre de démarrages/arrêts
05 200 200 140 000000000000 Nombre de secteurs réalloués
07 200 200 _51 000000000000 Taux d'erreurs de recherche
09 _68 _68 __0 000000005DF1 Heures de Fonctionnement
0A 100 100 _51 000000000000 Nombre d'essais de relancement de la rotation
0B 100 100 __0 000000000000 Nombre de recalibration
0C _95 _95 __0 00000000173A Nombre total de cycles marche/arrêt du disque dur
B7 100 100 __0 000000000000 Spécifique au constructeur
B8 100 100 _97 000000000000 Transfert des données à travers le cache tampon RAM entre l'hôte et le disque dur ne correspond pas.
BB 100 _63 __0 000000000026 Nombre d'erreurs qui n'ont pas pu être récupérés en utilisant le matériel ECC (voir C3)
BC 100 100 __0 000000000000 Nombre d'opérations avortées en raison de HDD timeout (temps dépassé)
BE _78 _49 _40 0000160F0016 Température interne sur les disques Western Digital avec une valeur de l’attribut inférieure à 50
C0 200 200 __0 00000000007D Nombre de fois que l'armature magnétique a été rétractée automatiquement suite à une coupure secteur
C1 198 198 __0 00000000198E Nombre de fois que la tête a changé de position
C4 200 200 __0 000000000000 Nombre d'opérations de réallocation (remap)
C5 200 200 __0 000000000000 Nombre de secteurs "instables"
C6 200 200 __0 000000000000 Nombre total d'erreurs incorrigibles d'un secteur
C7 200 200 __0 000000000000 Nombre d'erreurs dans le transfert de données via le câble d'interface
C8 200 200 __0 000000000000 Nombre total d'erreurs à l'écriture d'un secteur
        0    1    2    3    4    5    6    7    8    9
000: 427A 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: 2020 2020 2057 442D 5743 4333 4644 464C 444B 434B
020: 0000 0000 0000 3031 2E30 3141 3031 5744 4320 5744
030: 3130 455A 4558 2D36 304D 324E 4130 2020 2020 2020
040: 2020 2020 2020 2020 2020 2020 2020 8010 4000 2F00
050: 4001 0000 0000 0007 3FFF 0010 003F FC10 00FB 0110
060: FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 2008
070: 0000 0000 0000 0000 0000 001F 850E 0026 00CC 0040
080: 03FE 001F 706B 7C61 4123 7069 BC41 4123 203F 003C
090: 003C 0000 FFFE 0000 0000 0000 0000 0000 0000 0000
100: 6DB0 7470 0000 0000 0000 0000 6003 0000 5001 4EE2
110: B59F 5F25 0000 0000 0000 0000 0000 0000 0000 40DC
140: 0000 0000 0004 0000 0000 0000 0000 0000 0000 0000
160: 0000 0000 0000 0000 0000 0000 0000 0000 0002 0000
200: 0000 0000 0000 0000 0000 0000 303D 0000 0000 0000
210: 0000 0000 0000 0000 0000 0000 0000 1C20 0000 0000
220: 0000 0000 107E 0000 0000 0000 0000 0000 0000 0000
230: 6DB0 7470 0000 0000 0001 1000 0000 0000 0000 0000
240: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 64A5
000: 10 00 01 2F 00 C8 C8 25 00 00 00 00 00 00 03 27
010: 00 A7 A5 5A 0A 00 00 00 00 00 04 32 00 5E 5E 0C
020: 1A 00 00 00 00 00 05 33 00 C8 C8 00 00 00 00 00
030: 00 00 07 2F 00 C8 C8 00 00 00 00 00 00 00 09 32
040: 00 44 44 F1 5D 00 00 00 00 00 0A 33 00 64 64 00
050: 00 00 00 00 00 00 0B 32 00 64 64 00 00 00 00 00
060: 00 00 0C 32 00 5F 5F 3A 17 00 00 00 00 00 B7 32
070: 00 64 64 00 00 00 00 00 00 00 B8 33 00 64 64 00
080: 00 00 00 00 00 00 BB 32 00 64 3F 26 00 00 00 00
090: 00 00 BC 32 00 64 64 00 00 00 00 00 00 00 BE 22
0A0: 00 4E 31 16 00 0F 16 00 00 00 C0 32 00 C8 C8 7D
0B0: 00 00 00 00 00 00 C1 32 00 C6 C6 8E 19 00 00 00
0C0: 00 00 C4 32 00 C8 C8 00 00 00 00 00 00 00 C5 32
0D0: 00 C8 C8 00 00 00 00 00 00 00 C6 30 00 C8 C8 00
0E0: 00 00 00 00 00 00 C7 32 00 C8 C8 00 00 00 00 00
0F0: 00 00 C8 08 00 C8 C8 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 82 00 10 2C 01 5B
170: 03 00 01 00 02 75 00 00 00 00 00 00 00 00 00 00
180: 00 00 01 02 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80
000: 10 00 01 33 C8 C8 00 00 00 00 00 00 00 00 03 15
010: 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00
020: 00 00 00 00 00 00 05 8C 00 00 00 00 00 00 00 00
030: 00 00 07 33 C8 C8 00 00 00 00 00 00 00 00 09 00
040: 00 00 00 00 00 00 00 00 00 00 0A 33 00 00 00 00
050: 00 00 00 00 00 00 0B 00 00 00 00 00 00 00 00 00
060: 00 00 0C 00 00 00 00 00 00 00 00 00 00 00 B7 00
070: 00 00 00 00 00 00 00 00 00 00 B8 61 00 00 00 00
080: 00 00 00 00 00 00 BB 00 00 00 00 00 00 00 00 00
090: 00 00 BC 00 00 00 00 00 00 00 00 00 00 00 BE 28
0A0: 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00
0B0: 00 00 00 00 00 00 C1 00 00 00 00 00 00 00 00 00
0C0: 00 00 C4 00 00 00 00 00 00 00 00 00 00 00 C5 00
0D0: 00 00 00 00 00 00 00 00 00 00 C6 00 00 00 00 00
0E0: 00 00 00 00 00 00 C7 00 00 00 00 00 00 00 00 00
0F0: 00 00 C8 00 C8 C8 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 3C
 (03) CT250MX500SSD4
           Model : CT250MX500SSD4
        Firmware : M3CR023
   Serial Number : 1909E1ED07E8
       Disk Size : 250,0 GB (8,4/137,4/250,0/250,0)
     Queue Depth : 32
    # of Sectors : 488397168
   Major Version : ACS-3
   Minor Version : ACS-3 Revision 5
  Power On Hours : 14894 heures
  Power On Count : 2444 fois
     Host Writes : 5153 GB
     Temperature : 31 C (87 F)
   Health Status : Bon (95 %)
        Features : S.M.A.R.T., APM, NCQ, TRIM, DevSleep, GPL
       APM Level : 00FEh [ON]
       AAM Level : ----
    Drive Letter : G:
01 100 100 __0 000000000000 Raw Read Error Rate
05 100 100 _10 000000000000 Reallocated NAND Block Count
09 100 100 __0 000000003A2E Power On Hours Count
0C 100 100 __0 00000000098C Power Cycle Count
AB 100 100 __0 000000000000 Program Fail Count
AC 100 100 __0 000000000000 Erase Fail Count
AD _95 _95 __0 000000000058 Average Block Erase Count
AE 100 100 __0 00000000000D Unexpected Power Loss Count
B4 __0 __0 __0 00000000001B Unused Spare NAND Blocks
B7 100 100 __0 000000000000 SATA interface Downshift
B8 100 100 __0 000000000000 Error Correction Count
BB 100 100 __0 000000000000 Reported Uncorrectable Errors
C2 _69 _37 __0 003F0000001F Temperature
C4 100 100 __0 000000000000 Reallocation Event Count
C5 100 100 __0 000000000000 Current Pending ECC Count
C6 100 100 __0 000000000000 SMART Offline Scan Uncorrectable Error Count
C7 100 100 __0 000000000000 UDMA CRC Error Count
CA _95 _95 __1 000000000005 Lifetime Remaining
CE 100 100 __0 000000000000 Write Error Rate
D2 100 100 __0 000000000000 Successful RAIN Recovery Count
F6 100 100 __0 0002842B6673 Cumulative Host Sectors Written
F7 100 100 __0 00000AC7FE75 Host Program NAND Pages Count
F8 100 100 __0 00000EDE334A FTL Program NAND Pages Count
        0    1    2    3    4    5    6    7    8    9
010: 3139 3039 4531 4544 3037 4538 2020 2020 2020 2020
020: 0000 0000 0000 4D33 4352 3032 3320 4354 3235 304D
030: 5835 3030 5353 4434 2020 2020 2020 2020 2020 2020
050: 4001 0000 0000 0006 3FFF 0010 003F FC10 00FB BD01
060: FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 0D98
070: 0000 0000 0000 0000 0000 001F 850E 0086 014C 0044
080: 07F0 006D 706B 7409 4163 7069 B409 4163 407F 0001
090: 0001 00FE FFFE 0000 0000 0000 0000 0000 0000 0000
100: 5970 1D1C 0000 0000 0000 0008 6003 0000 500A 0751
110: E1ED 07E8 0000 0000 0000 0000 0000 0000 0000 411C
120: 401C 0000 0000 0000 0000 0000 0000 0000 0029 4372
130: 7563 6961 6C00 0000 0000 0000 0000 0000 0000 0000
160: 0000 0000 0000 0000 0000 0000 0000 0000 0007 0001
200: 0000 0000 0000 0000 0000 0000 0031 0000 0000 4000
220: 0000 0000 11FF 0000 0000 0000 0000 0000 0000 0000
230: 5970 1D1C 0000 0000 0001 0200 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 F5A5
000: 10 00 01 2F 00 64 64 00 00 00 00 00 00 00 05 32
010: 00 64 64 00 00 00 00 00 00 00 09 32 00 64 64 2E
020: 3A 00 00 00 00 00 0C 32 00 64 64 8C 09 00 00 00
030: 00 00 AB 32 00 64 64 00 00 00 00 00 00 00 AC 32
040: 00 64 64 00 00 00 00 00 00 00 AD 32 00 5F 5F 58
050: 00 00 00 00 00 00 AE 32 00 64 64 0D 00 00 00 00
060: 00 00 B4 33 00 00 00 1B 00 00 00 00 00 00 B7 32
070: 00 64 64 00 00 00 00 00 00 00 B8 32 00 64 64 00
080: 00 00 00 00 00 00 BB 32 00 64 64 00 00 00 00 00
090: 00 00 C2 22 00 45 25 1F 00 00 00 3F 00 00 C4 32
0A0: 00 64 64 00 00 00 00 00 00 00 C5 32 00 64 64 00
0B0: 00 00 00 00 00 00 C6 30 00 64 64 00 00 00 00 00
0C0: 00 00 C7 32 00 64 64 00 00 00 00 00 00 00 CA 30
0D0: 00 5F 5F 05 00 00 00 00 00 00 CE 0E 00 64 64 00
0E0: 00 00 00 00 00 00 D2 32 00 64 64 00 00 00 00 00
0F0: 00 00 F6 32 00 64 64 73 66 2B 84 02 00 00 F7 32
100: 00 64 64 75 FE C7 0A 00 00 00 F8 32 00 64 64 4A
110: 33 DE 0E 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 7B
170: 03 00 01 00 02 1E 02 00 00 00 00 00 00 00 00 00
180: 00 00 4D 33 43 52 30 32 33 20 00 00 00 00 00 00
190: 53 4D 32 32 35 38 42 31 36 41 52 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 6D
000: 01 00 01 00 00 00 00 00 00 00 00 00 00 00 05 0A
010: 00 00 00 00 00 00 00 00 00 00 09 00 00 00 00 00
020: 00 00 00 00 00 00 0C 00 00 00 00 00 00 00 00 00
030: 00 00 AB 00 00 00 00 00 00 00 00 00 00 00 AC 00
040: 00 00 00 00 00 00 00 00 00 00 AD 00 00 00 00 00
050: 00 00 00 00 00 00 AE 00 00 00 00 00 00 00 00 00
060: 00 00 B4 00 00 00 00 00 00 00 00 00 00 00 B7 00
070: 00 00 00 00 00 00 00 00 00 00 B8 00 00 00 00 00
090: 00 00 C2 00 00 00 00 00 00 00 00 00 00 00 C4 00
0A0: 00 00 00 00 00 00 00 00 00 00 C5 00 00 00 00 00
0B0: 00 00 00 00 00 00 C6 00 00 00 00 00 00 00 00 00
0C0: 00 00 C7 00 00 00 00 00 00 00 00 00 00 00 CA 01
0D0: 00 00 00 00 00 00 00 00 00 00 CE 00 00 00 00 00
0E0: 00 00 00 00 00 00 D2 00 00 00 00 00 00 00 00 00
0F0: 00 00 F6 00 00 00 00 00 00 00 00 00 00 00 F7 00
100: 00 00 00 00 00 00 00 00 00 00 F8 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 22
n°11332747
TotalRecal​l
Posté le 31-03-2024 à 18:15:22  profilanswer
Tu l'as pas épargné le Samsung 840 avec les 140To d'écriture :eek:. Il est en "Prudence" à cause de ça, faudrait faire un test en écriture mais à mon avis il doit bien fatiguer.
Et avec un screenshot pour changer si possible...
Après, je t'ai déjà donné mon avis, ce constat ne fait que le conforter.
n°11332766
QuentinLeD​ieu
Posté le 31-03-2024 à 21:07:06  profilanswer
Ah bon XD, 140 To d'écriture ? WTF, je vois pas comment c'est possible XD, je l'ai depuis 10 ans. Bon, le WD aussi pourtant...
Message édité par QuentinLeDieu le 31-03-2024 à 21:09:29
n°11332772
matt442
Posté le 31-03-2024 à 21:51:28  profilanswer
les hdd sont beaucoup plus endurants surtout comparé aux ssd 120go de il y a 10 ans.
pourquoi autant d'écriture ?? ben ca peut etre le controleur qui déconne complètement et donne des infos bizarres... ou bien ce ssd s'est trouvé a un moment dans un pc qui manquait de ram ?
en tout cas il est bien rincé, je pense qu'il a fait son temps.  :)
n°11332773
QuentinLeD​ieu
Posté le 31-03-2024 à 21:54:08  profilanswer
n°11332780
TotalRecal​l
Posté le 31-03-2024 à 22:49:01  profilanswer
Ben oui, le screenshot dit exactement la même chose que je t'expliquais plus haut, normal. C'est un test de débit pour lequel je te conseillais de nous faire un screenshot, pour le SMART on a déjà tout.
Je sais pas tes intentions mais je pense qu'on a fait le tour.
Le 120Go est mourant et il doit se traîner (j'imagine qu'il y a le swap dessus entre autres et qu'il est archi plein : d'où l'usure extrême), et le WD est lent par nature en plus d'avoir lui aussi sans doute déjà bien vécu. Ils ont autant de chance l'un que l'autre de ralentir le PC.
Je le redis si c'était pas clair la première fois : vire tout ça et mets un SSD neuf pour l'ensemble, tu seras plus tranquille [:spamafote]
Message édité par TotalRecall le 31-03-2024 à 22:50:58
n°11332793
QuentinLeD​ieu
Posté le 31-03-2024 à 23:51:38  profilanswer
ok d'accord, je te remercie de tes réponses, :)
n°11332802
gallean
Posté le 01-04-2024 à 01:35:31  profilanswer
ouai donc changement du ssd par un plus gros+un autre pour les install de jeux, garde tes dd pour les backups...
LSD for Éthiopie BIOS en 1.2.0.7 pour les mobo MSI
  Disque dur
Nouveau disque 4To.Ralentissement retard en jeux help please
Vieux disque dur, qu'en faire?mon disque dur fait 130000TB
Disque interne mal reconnuDisque neuf à problèmes...ou pas ?
Disque actif alors qu'il n'a que des donnéesUtiliser un disque de surveillance en stockage PC
Disque dur inaccessibleDisque dur externe incconu fichiers récupérés 0 ko HELP
Plus de sujets relatifs à : Ralentissement applications, analyse disque dur
